[Mapbender-commits] r2651 - trunk/mapbender/lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jul 11 05:29:37 EDT 2008
Author: christoph
Date: 2008-07-11 05:29:36 -0400 (Fri, 11 Jul 2008)
New Revision: 2651
Added:
   trunk/mapbender/lib/database-mysqli.php
   trunk/mapbender/lib/database-mysql.php
(incomplete) MySQLi wrapper by Mathias Trunte + improvements to MySQL wrapper
Modified: trunk/mapbender/lib/database-mysql.php
--- trunk/mapbender/lib/database-mysql.php	2008-07-11 08:15:18 UTC (rev 2650)
+++ trunk/mapbender/lib/database-mysql.php	2008-07-11 09:29:36 UTC (rev 2651)
@@ -1,5 +1,5 @@
 <?php
-# $Id:database-mysql.php 2619 2008-07-08 15:46:11Z christoph $
+# $Id$
 # http://www.mapbender.org/index.php/database-mysql.php
 # Copyright (C) 2002 CCGIS
@@ -53,8 +53,8 @@
  *  Notice the global vars $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname that must be set up
  *  in other functions in this library
-include_once(dirname(__FILE__)."/../http/classes/class_mb_exception.php");
-include_once(dirname(__FILE__)."/../http/classes/class_checkInput.php");
+include_once(dirname(__FILE__)."/../../http/classes/class_mb_exception.php");
+include_once(dirname(__FILE__)."/../../http/classes/class_checkInput.php");
 function db_escapestring($unescaped_string){
 	return @mysql_escape_string($unescaped_string);
@@ -230,11 +230,12 @@
  * Returns the number of rows in this result set
  *  @param		$qhandle (string)	Query result set handle
+ * (!!! Deprecated? Changed the MySQL-Command to match the current syntax)
 function db_numrows($qhandle) {
 	// return only if qhandle exists, otherwise 0
 	if ($qhandle) {
-		return @mysql_numrows($qhandle);
+		return @mysql_num_rows($qhandle);
 	} else {
 		return 0;
@@ -290,9 +291,10 @@
  *  Returns the number of fields in this result set
  *  @param		$lhandle (string)	Query result set handle
 function db_numfields($lhandle) {
-	return @mysql_numfields($lhandle);
+	return @mysql_num_fields($lhandle);
Added: trunk/mapbender/lib/database-mysqli.php
--- trunk/mapbender/lib/database-mysqli.php	                        (rev 0)
+++ trunk/mapbender/lib/database-mysqli.php	2008-07-11 09:29:36 UTC (rev 2651)
@@ -0,0 +1,481 @@
+<?php
+ * System-wide database type
+ * @var	constant		$sys_database_type
+$sys_database_type='mysqli';
+ *  Connect to the database
+ *  Notice the global vars that must be set up
+ *  Notice the global vars $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname that must be set up
+ *  in other functions in this library
+function db_escapestring($unescaped_string){
+	global $conn;
+	return mysqli_escape_string($conn, $unescaped_string);
+function db_escape_string($unescaped_string){
+	global $conn;
+function db_connect($DBSERVER="",$OWNER="",$PW="") {
+	global $sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname,
+		$conn,$conn_update,$sys_db_use_replication,$sys_dbreadhost;
+	if ($DBSERVER)
+		$sys_dbhost = $DBSERVER;
+	if ($OWNER)
+		$sys_dbuser = $OWNER;
+	if ($PW)
+		$sys_dbpasswd = $PW;
+	if (PORT!=''){
+		$sys_dbport = ':'.PORT;
+	else{
+		$sys_dbport = '';
+	if ($sys_db_use_replication) {
+		//  if configured for replication, $conn is the read-only host
+		//  we do not connect to update server until needed
+		$conn = mysqli_connect($sys_dbreadhost,$sys_dbuser,$sys_dbpasswd);
+		$conn_update=mysqli_connect($sys_dbhost,$sys_dbuser,$sys_dbpasswd);
+	} else {
+		$conn = mysqli_connect($sys_dbhost,$sys_dbuser,$sys_dbpasswd,$sys_dbname,intval($sys_dbport));
+		#echo "@mysql_pconnect($sys_dbhost.$sys_dbport,$sys_dbuser,$sys_dbpasswd)";
+	if ($sys_dbname)
+		mysqli_select_db($conn, $sys_dbname);
+	return $conn;
+function db_select_db($DB,$con="") {
+	global $conn,$sys_dbname;
+	$sys_dbname = $DB;
+	$_con = $con ? $con : $conn;
+	$ret = mysqli_select_db($_con, $sys_dbname);
+	if ($ret){
+		return true;
+	else {
+		return false;
+//	echo "$ret=@mysql_select_db($sys_dbname,$_con);";
+ *  Query the database
+ *  @param		$qstring (string)	SQL statement
+ *  @param		$limit (int)		How many rows do you want returned
+ *  @param		$offset (int)		Of matching rows, return only rows starting here
+function db_query($qstring,$limit='-1',$offset=0) {
+	/* Ausmisten! Der Code ist unübersichtlich, und bei manchen Zweigen ist nicht klar,
+	 * ob sie überhaupt ausgeführt werden...
+	global $QUERY_COUNT,$sys_db_use_replication,$sys_db_is_dirty,$DB,
+		$sys_dbname,$conn,$conn_update,$sys_dbhost,$sys_dbuser,$sys_dbpasswd;
+	$QUERY_COUNT++;
+	if(!$sys_dbname && $DB)
+	db_select_db($sys_dbname,$conn);
+	if ($limit > 0) {
+		if (!$offset || $offset < 0) {
+			$offset=0;
+		$qstring=$qstring." LIMIT $offset,$limit";
+//	if ($GLOBALS['IS_DEBUG'])
+		$GLOBALS['G_DEBUGQUERY'] .= $qstring . "<P><BR>\n";
+	//are we configured to try to use replication?
+		//if we haven't yet done an insert/update,
+		//read from the read-only db
+		if (!$sys_db_is_dirty && mb_eregi("^( )*(select)",$qstring)) {
+			if ($QUERY_COUNT%3==0) {
+				// 1/3rd of read queries go to master for now
+				return mysqli_query($sys_dbname,$qstring,$conn_update);
+			} else {
+				return mysqli_query($sys_dbname,$qstring,$conn);
+		} else {
+			//must be an update/insert/delete query - go to master server
+			$sys_db_is_dirty=true;
+	} else {
+		$ret = mysqli_query($conn, $qstring);
+//		echo "@mysql_db_query($sys_dbname,$qstring,$conn); ret=$ret<br>";
+		if(!$ret){
+			$e = new mb_exception("db_query($qstring)=$ret db_error=".db_error());
+		return $ret;
+	//echo "SQL__".$qstring;
+function db_prepare_typestr($types) {
+	$result = '';
+	foreach ($types as $current_type) {
+		$result .= $current_type;
+	return $result;
+ *  prepare and query the database
+ *  @param		$params (array string params)
+ *  @param		$types (array string types)
+function db_prep_query($qstring, $params, $types){
+	// Beim Umschreiben an der PostGreSQL-Bibliothek orientieren
+	global $conn, $stmt;
+	@mysqli_stmt_close($stmt);
+	$ci = new checkInput($qstring,$params,$types);
+	$params = $ci->v;
+	if(PREPAREDSTATEMENTS == false){
+		for ($i=0; $i<count($params); $i++){
+			$needle = "$".strval($i+1);
+			$tmp = '';
+			if($params[$i] !== NULL){
+				if($types[$i] == 's'){ $tmp .= "'"; }
+				$tmp .= $params[$i];
+			else{
+				$tmp .= "NULL";
+			$posa = mb_strpos($qstring, $needle);
+			$posb = mb_strlen($needle);
+			$qstring = mb_substr($qstring,0,$posa).$tmp.mb_substr($qstring,($posa + $posb));
+		$r = db_query($qstring);
+		if(!$r){
+			$e = new mb_exception("Error while executing sql statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error());
+	else{
+		if (!$conn) {
+			$e = new mb_exception("Error while connecting to the database in ".$_SERVER['SCRIPT_FILENAME'].", Error: ".db_error());
+		echo $qstring;
+		$qstring = preg_replace('/\$[0-9]+/', '?', $qstring);
+		echo $qstring;
+		$stmt = mysqli_prepare($conn, $qstring);
+		//echo $result;
+		if(!$stmt){
+			echo "Error while preparing statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error();
+			$e = new mb_exception("Error while preparing statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error());
+		$type_string = '"';
+		$param_string = '';
+		$val_def_string = '';
+		$val_string = '';
+		/*for ($i = 0; $i < count($params); $i++) {
+			if ($params[$i] !== NULL) {
+				$type_string .= $types[$i];
+				if ($i > 0) {
+					$param_string .= ', ';
+					$val_string .= ', ';
+				$param_string .= '"'.$params[$i].'"';
+				if ($types[$i] == 's')
+					$val_def_string .= '$val'.$i.'="'.$params[$i].'";';
+				else
+					$val_def_string .= '$val'.$i.'='.$params[$i].';';
+				$val_string .= '$val'.$i;
+				//mysqli_stmt_bind_param($result, $types[$i], $params[$i]);
+		for( $i = 0; $i < count($params); ++$i ) {
+			$thisVar = "v$i";
+			$variadicParams .= '$' . $thisVar;
+			if( $i != count($params) - 1 ) // don't append a comma on the last variable
+				$variadicParams .= ', ';
+			$variadicExtVars[ $thisVar ] = $params[ $i ];
+		echo $variadicParams;
+		$bindParamFunc = create_function( '$vars, &$stmt','extract( $vars ); $stmt->bind_param( \'' . implode($types) . '\', ' . $variadicParams . ' );' );
+		$bindParamFunc( $variadicExtVars, $stmt );
+		/* $typeStr = call_user_func_array( 'db_prepare_typestr', $types );
+      	array_unshift( $params, $typeStr );
+      	call_user_func_array( array( 'mysqli_bind_param', $qstring  ), $params ); */
+		/*$type_string .= '"';
+		$eval_string = $val_def_string.'mysqli_stmt_bind_param($result,'.$type_string.','.$val_string.');';
+		$xyz=1;
+		//$eval_string = 'eead results, this function cancelcho $result;';
+		//$eval_string = 'return mysqli_stmt_bind_param($result,'.$type_string.',$xyz);';
+		echo $eval_string;
+		//echo "mysqli_stmt_bind_param($result,$type_string,$param_string)";
+		eval($eval_string);*/
+		$r = mysqli_stmt_execute($stmt);
+		if(!$r){
+			$e = new mb_exception("Error while executing prepared statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error());
+		$result2 = $stmt;
+	return $stmt;
+ *	Begin a transaction
+ *	Begin a transaction for databases that support them
+ *	may cause unexpected behavior in databases that don't
+function db_begin() {
+	return db_query("BEGIN WORK");
+ * Commit a transaction
+ * Commit a transaction for databases that support them
+function db_commit() {
+	return db_query("COMMIT");
+ * Roll back a transaction
+ * Rollback a transaction for databases that support them
+function db_rollback() {
+	$str = db_error();
+	db_query("ROLLBACK");
+	die('sql error: ' . $str . " ROLLBACK performed....");
+ * Returns the number of rows in this result set
+ *  @param		$qhandle (string)	Query result set handle
+function db_num_rows($qhandle) {
+	// return only if qhandle exists, otherwise 0
+	if ($qhandle) {
+		return mysqli_num_rows($qhandle);
+	} else {
+		return 0;
+ *  Frees a database result properly
+function db_free_result($qhandle) {
+	return mysqli_free_result($qhandle);
+ *  Reset a result set.
+ *  Reset is useful for db_fetch_array sometimes you need to start over
+ *  @param		$row (int)		Row number
+function db_reset_result($qhandle,$row=0) {
+	return mysqli_data_seek($qhandle,$row);
+ *  Returns a field from a result set
+ *  @param		$field (string)	Field name
+function db_result($qhandle,$row,$field) {
+	//return mysqli_result($qhandle,$row,$field);
+	if( mysqli_num_rows( $qhandle ) ) {
+		$x = 0;
+		while( $array = mysqli_fetch_array( $qhandle, MYSQLI_NUM ) ) {
+			if( $row == $x++ ) {
+				return isset( $array[ $field ] ) ? $array[ $field ] : '';
+ *  Returns the number of fields in this result set
+ *  @param		$lhandle (string)	Query result set handle
+function db_numfields($lhandle) {
+	return mysqli_num_fields($lhandle);
+ * php 3,4,5
+function db_num_fields($lhandle) {
+ *  Returns the number of rows changed in the last query
+ *  @param		$fnumber (int)	Column number
+function db_fieldname($lhandle,$fnumber) {
+	   return mysql_field_name($lhandle,$fnumber);
+function db_affected_rows($qhandle) {
+	return mysqli_affected_rows($qhandle);
+ *  Fetch an array
+ *  Returns an associative array from
+ *  the current row of this database result
+ *  Use db_reset_result to seek a particular row
+function db_fetch_array($qhandle) {
+	global $conn;
+	$data = mysqli_stmt_result_metadata($qhandle);
+        $fields = array();
+        $out = array();
+        $fields[0] = &$qhandle;
+        $count = 1;
+        while($field = mysqli_fetch_field($data)) {
+            $fields[$count] = &$out[$field->name];
+            $count++;
+        call_user_func_array(mysqli_stmt_bind_result, $fields);
+        mysqli_stmt_fetch($qhandle);
+        return (count($out) == 0) ? false : $out;
+	/*if (!$qhandle)
+		return NULL;
+	else
+		return mysqli_fetch_array($conn); */
+ * fetch a row into an array
+function db_fetch_row($qhandle,$fnumber=0) {
+	  global $stmt;
+	  if ($qhandle)
+	  	return mysqli_fetch_row($stmt);
+	  else
+	  	return NULL;
+ *  Returns the last primary key from an insert
+ *  @param		$table_name (string)	Is the name of the table you inserted into
+ *  @param		$pkey_field_name (string)	Is the field name of the primary key
+function db_insertid($qhandle="",$table_name="",$pkey_field_name="") {
+	return mysqli_insert_id();
+function db_insert_id($qhandle="",$table_name="",$pkey_field_name="") {
+ * Returns the last error from the database
+function db_error() {
+	global $conn;
+	return mysqli_error($conn);
+ * Get the flags associated with the specified field in a result
+ * 					Examples: "not_null", "primary_key", "unique_key", "multiple_key",
+ *                    "blob", "unsigned", "zerofill","binary", "enum",
+ *                    "auto_increment", "timestamp"
+function db_field_flags($lhandle,$fnumber) {
+	   return mysqli_field_flags($lhandle,$fnumber);
+ * Get the type of the specified field
+function db_field_type($lhandle,$fnumber) {
+	   return mysqli_field_type($lhandle,$fnumber);
+ * Get the length of the specified field
+function db_field_len($lhandle,$fnumber) {
+	   return mysqli_field_len($lhandle,$fnumber);
\ No newline at end of file
More information about the Mapbender_commits mailing list
