[Mapbender-commits] r2652 - in trunk/mapbender: . core
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jul 11 09:14:41 EDT 2008
Author: christoph
Date: 2008-07-11 09:14:41 -0400 (Fri, 11 Jul 2008)
New Revision: 2652
Added:
   trunk/mapbender/core/
   trunk/mapbender/core/globalSettings.php
   trunk/mapbender/core/i18n.php
   trunk/mapbender/core/system.php
Added: trunk/mapbender/core/globalSettings.php
--- trunk/mapbender/core/globalSettings.php	                        (rev 0)
+++ trunk/mapbender/core/globalSettings.php	2008-07-11 13:14:41 UTC (rev 2652)
@@ -0,0 +1,52 @@
+<?php
+// start the session
+session_start();
+// All data Mapbender handles internally are UTF-8
+mb_internal_encoding("UTF-8");
+// constants
+require_once(dirname(__FILE__)."/../core/system.php");
+// configuration file
+require_once(dirname(__FILE__)."/../conf/mapbender.conf");
+// database wrapper
+if(SYS_DBTYPE=="mysql") {
+	require_once(dirname(__FILE__) . "/../lib/database-mysql.php");
+else {
+	require_once(dirname(__FILE__) . "/../lib/database-pgsql.php");
+// class for error handling
+require_once(dirname(__FILE__)."/../http/classes/class_mb_exception.php");
+// I18n wrapper function, gettext
+require_once(dirname(__FILE__) . "/../core/i18n.php");
+require_once(dirname(__FILE__) . "/../http/classes/class_locale.php");
+$localeObj = new Mb_locale($_SESSION["mb_lang"]);
+// establish database connection
+$con = db_connect($DBSERVER, $OWNER, $PW);
+db_select_db(DB, $con);
Added: trunk/mapbender/core/i18n.php
--- trunk/mapbender/core/i18n.php	                        (rev 0)
+++ trunk/mapbender/core/i18n.php	2008-07-11 13:14:41 UTC (rev 2652)
@@ -0,0 +1,8 @@
+<?php
+	function _mb ($someString) {
+		if (USE_I18N) {
+			return _($someString);
+		return $someString;
\ No newline at end of file
Added: trunk/mapbender/core/system.php
--- trunk/mapbender/core/system.php	                        (rev 0)
+++ trunk/mapbender/core/system.php	2008-07-11 13:14:41 UTC (rev 2652)
@@ -0,0 +1,37 @@
+<?php
+# $Id:$
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+# mapbender version
+define("MB_VERSION_NUMBER", "2.5.0");
+define("MB_VERSION_APPENDIX", "RC2");
+define("MB_RELEASE_DATE", mktime(0,0,0,4,21,2008));//h, min,sec,month,day,year
+# constants from map.js
+define("MB_RESOLUTION", "28.35");
+define("MB_FEATURE_COUNT", "100");
+define("MB_SECURITY_PROXY", "http://wms1.ccgis.de/mapbender/tools/security_proxy.php?mb_ows_security_proxy=");
+# available log levels
+define("LOG_LEVEL_LIST", "off,error,warning,notice,all");
+define("ZOOM_MOUSEWHEEL", "1.1");
More information about the Mapbender_commits mailing list
