[Mapbender-commits] r2704 - branches/testbaudson_dev/documents
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jul 23 05:43:45 EDT 2008
Author: christoph
Date: 2008-07-23 05:43:44 -0400 (Wed, 23 Jul 2008)
New Revision: 2704
   branches/testbaudson_dev/documents/mpbn25_.dia
updated
* innodb
* correct foreign keys with cascading
Modified: branches/testbaudson_dev/documents/mpbn25_.dia
--- branches/testbaudson_dev/documents/mpbn25_.dia	2008-07-23 09:13:25 UTC (rev 2703)
+++ branches/testbaudson_dev/documents/mpbn25_.dia	2008-07-23 09:43:44 UTC (rev 2704)
@@ -65,13 +65,13 @@
   <dia:layer name="Background" visible="true">
     <dia:object type="UML - Class" version="0" id="O0">
       <dia:attribute name="obj_pos">
-        <dia:point val="10.7,9.7"/>
+        <dia:point val="12.25,4.2"/>
       </dia:attribute>
       <dia:attribute name="obj_bb">
-        <dia:rectangle val="10.65,9.65;23.5,14.55"/>
+        <dia:rectangle val="12.2,4.15;25.05,9.05"/>
       </dia:attribute>
       <dia:attribute name="elem_corner">
       </dia:attribute>
       <dia:attribute name="elem_width">
         <dia:real val="12.75"/>
@@ -122,7 +122,7 @@
         <dia:color val="#000000"/>
       </dia:attribute>
       <dia:attribute name="fill_color">
-        <dia:color val="#ffffff"/>
+        <dia:color val="#add8e6"/>
       </dia:attribute>
       <dia:attribute name="text_color">
@@ -265,13 +265,13 @@
     </dia:object>
     <dia:object type="UML - Class" version="0" id="O1">
-        <dia:point val="10.35,-20.15"/>
+        <dia:point val="12.5,-34.7"/>
       </dia:attribute>
-        <dia:rectangle val="10.3,-20.2;25.6,-3.3"/>
+        <dia:rectangle val="12.45,-34.75;27.75,-17.85"/>
       </dia:attribute>
       </dia:attribute>
         <dia:real val="15.199999999999999"/>
@@ -322,7 +322,7 @@
       </dia:attribute>
       </dia:attribute>
@@ -810,13 +810,13 @@
     </dia:object>
     <dia:object type="UML - Class" version="0" id="O2">
-        <dia:point val="10.7,1.7"/>
+        <dia:point val="12.6,-9.6"/>
       </dia:attribute>
-        <dia:rectangle val="10.65,1.65;20.35,4.95"/>
+        <dia:rectangle val="12.55,-9.65;22.25,-6.35"/>
       </dia:attribute>
       </dia:attribute>
         <dia:real val="9.5999999999999996"/>
@@ -867,7 +867,7 @@
       </dia:attribute>
       </dia:attribute>
@@ -964,16 +964,16 @@
     </dia:object>
     <dia:object type="UML - Association" version="1" id="O3">
-        <dia:point val="17.95,-3.30081"/>
+        <dia:point val="20.1,-17.8497"/>
       </dia:attribute>
-        <dia:rectangle val="14.75,-3.35081;21.65,2.5"/>
+        <dia:rectangle val="16.65,-17.8997;30.2,-8.85"/>
       </dia:attribute>
       <dia:attribute name="orth_points">
-        <dia:point val="17.95,-0.799871"/>
-        <dia:point val="15.5,-0.799871"/>
-        <dia:point val="15.5,1.7"/>
+        <dia:point val="20.1,-13.7249"/>
+        <dia:point val="17.4,-13.7249"/>
+        <dia:point val="17.4,-9.6"/>
       </dia:attribute>
       <dia:attribute name="orth_orient">
         <dia:enum val="1"/>
@@ -981,7 +981,7 @@
         <dia:enum val="1"/>
       </dia:attribute>
       <dia:attribute name="autorouting">
-        <dia:boolean val="false"/>
+        <dia:boolean val="true"/>
       </dia:attribute>
       <dia:attribute name="name">
         <dia:string>##</dia:string>
@@ -1012,7 +1012,7 @@
             <dia:string>#fkey_mb_user_id#</dia:string>
           </dia:attribute>
           <dia:attribute name="multiplicity">
-            <dia:string>##</dia:string>
+            <dia:string>#on delete cascade on update cascade#</dia:string>
           </dia:attribute>
           <dia:attribute name="arrow">
@@ -1032,16 +1032,16 @@
     </dia:object>
     <dia:object type="UML - Association" version="1" id="O4">
-        <dia:point val="17.075,9.6517"/>
+        <dia:point val="18.625,4.1497"/>
       </dia:attribute>
-        <dia:rectangle val="14.75,4.15;21.65,10.4517"/>
+        <dia:rectangle val="16.65,-7.15;30.2,4.9497"/>
       </dia:attribute>
-        <dia:point val="17.075,7.92505"/>
-        <dia:point val="15.5,7.92505"/>
-        <dia:point val="15.5,4.9"/>
+        <dia:point val="18.625,-1.12515"/>
+        <dia:point val="17.4,-1.12515"/>
+        <dia:point val="17.4,-6.4"/>
       </dia:attribute>
         <dia:enum val="1"/>
@@ -1049,7 +1049,7 @@
         <dia:enum val="1"/>
       </dia:attribute>
       </dia:attribute>
@@ -1080,7 +1080,7 @@
             <dia:string>#fkey_mb_group_id#</dia:string>
           </dia:attribute>
           </dia:attribute>
@@ -1100,25 +1100,25 @@
     </dia:object>
     <dia:object type="UML - SmallPackage" version="0" id="O5">
-        <dia:point val="32,-17.4625"/>
+        <dia:point val="10.8,21.8875"/>
       </dia:attribute>
-        <dia:rectangle val="31.95,-18.4125;77.8,-14.4125"/>
+        <dia:rectangle val="10.75,20.9375;56.6,24.1375"/>
       </dia:attribute>
       </dia:attribute>
         <dia:real val="45.75"/>
       </dia:attribute>
       <dia:attribute name="elem_height">
-        <dia:real val="3"/>
+        <dia:real val="2.2000000000000002"/>
       </dia:attribute>
       <dia:attribute name="line_colour">
       </dia:attribute>
       <dia:attribute name="fill_colour">
       </dia:attribute>
       <dia:attribute name="stereotype">
         <dia:string>#postgres:post#</dia:string>
@@ -1126,8 +1126,7 @@
       <dia:attribute name="text">
         <dia:composite type="text">
           <dia:attribute name="string">
-            <dia:string>#ALTER TABLE mb_user ALTER COLUMN mb_user_id SET DEFAULT nextval('mb_user_id'::regclass);
-SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('mb_user','mb_user_id'), (SELECT max(mb_user_id) FROM mb_user), true);#</dia:string>
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('mb_user','mb_user_id'), (SELECT max(mb_user_id) FROM mb_user), true);#</dia:string>
           </dia:attribute>
           <dia:attribute name="font">
             <dia:font family="monospace" style="0" name="Courier"/>
@@ -1136,7 +1135,7 @@
             <dia:real val="0.80000000000000004"/>
           </dia:attribute>
           <dia:attribute name="pos">
-            <dia:point val="32.3,-15.82"/>
+            <dia:point val="11.1,23.53"/>
           </dia:attribute>
           <dia:attribute name="color">
@@ -1149,16 +1148,16 @@
     </dia:object>
     <dia:object type="UML - SmallPackage" version="0" id="O6">
-        <dia:point val="31.985,-13.1975"/>
+        <dia:point val="10.785,25.5025"/>
       </dia:attribute>
-        <dia:rectangle val="31.935,-14.1475;42.085,-10.9475"/>
+        <dia:rectangle val="10.735,24.5525;42.235,27.7525"/>
       </dia:attribute>
       </dia:attribute>
-        <dia:real val="10.049999999999999"/>
+        <dia:real val="31.400000000000002"/>
       </dia:attribute>
@@ -1167,15 +1166,15 @@
       </dia:attribute>
       </dia:attribute>
-        <dia:string>#postgres:pre#</dia:string>
+        <dia:string>#innodb:pre#</dia:string>
       </dia:attribute>
-            <dia:string>#CREATE SEQUENCE mb_user_id;#</dia:string>
+            <dia:string>#ALTER TABLE mb_user CHANGE COLUMN mb_user_id mb_user_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
           </dia:attribute>
@@ -1184,7 +1183,7 @@
           </dia:attribute>
-            <dia:point val="32.285,-11.555"/>
+            <dia:point val="11.085,27.145"/>
           </dia:attribute>
@@ -1197,33 +1196,82 @@
     </dia:object>
     <dia:object type="UML - SmallPackage" version="0" id="O7">
-        <dia:point val="31.985,-9.5975"/>
+        <dia:point val="10.8157,17.505"/>
       </dia:attribute>
-        <dia:rectangle val="31.935,-10.5475;63.435,-7.3475"/>
+        <dia:rectangle val="10.7657,16.555;43.6657,20.555"/>
       </dia:attribute>
       </dia:attribute>
-        <dia:real val="31.400000000000002"/>
+        <dia:real val="32.800000000000004"/>
       </dia:attribute>
+        <dia:real val="3"/>
+      </dia:attribute>
+      <dia:attribute name="line_colour">
+        <dia:color val="#000000"/>
+      </dia:attribute>
+      <dia:attribute name="fill_colour">
+      </dia:attribute>
+      <dia:attribute name="stereotype">
+        <dia:string>#postgres:pre#</dia:string>
+      </dia:attribute>
+      <dia:attribute name="text">
+        <dia:composite type="text">
+          <dia:attribute name="string">
+            <dia:string>#CREATE SEQUENCE mb_user_id_seq;
+ALTER TABLE mb_user ALTER COLUMN mb_user_id SET DEFAULT nextval('mb_user_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          <dia:attribute name="font">
+            <dia:font family="monospace" style="0" name="Courier"/>
+          </dia:attribute>
+          <dia:attribute name="height">
+            <dia:real val="0.80000000000000004"/>
+          </dia:attribute>
+          <dia:attribute name="pos">
+            <dia:point val="11.1157,19.1475"/>
+          </dia:attribute>
+          <dia:attribute name="color">
+          </dia:attribute>
+          <dia:attribute name="alignment">
+            <dia:enum val="0"/>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O8">
+      <dia:attribute name="obj_pos">
+        <dia:point val="10.8083,38.855"/>
+      </dia:attribute>
+      <dia:attribute name="obj_bb">
+        <dia:rectangle val="10.7583,37.905;43.3083,41.105"/>
+      </dia:attribute>
+      <dia:attribute name="elem_corner">
+      </dia:attribute>
+      <dia:attribute name="elem_width">
+        <dia:real val="32.450000000000003"/>
+      </dia:attribute>
+      <dia:attribute name="elem_height">
       </dia:attribute>
       </dia:attribute>
       </dia:attribute>
-        <dia:string>#mysql:post#</dia:string>
       </dia:attribute>
-            <dia:string>#ALTER TABLE mb_user CHANGE COLUMN mb_user_id mb_user_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+            <dia:string>#ALTER TABLE mb_group CHANGE COLUMN mb_group_id mb_group_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
           </dia:attribute>
@@ -1232,7 +1280,7 @@
           </dia:attribute>
-            <dia:point val="32.285,-7.955"/>
+            <dia:point val="11.1083,40.4975"/>
           </dia:attribute>
@@ -1243,5 +1291,102 @@
         </dia:composite>
       </dia:attribute>
     </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O9">
+        <dia:point val="10.7583,35.33"/>
+      </dia:attribute>
+        <dia:rectangle val="10.7083,34.38;57.9583,37.58"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="47.149999999999999"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#postgres:post#</dia:string>
+      </dia:attribute>
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('mb_group','mb_group_id'), (SELECT max(mb_group_id) FROM mb_group), true);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="11.0583,36.9725"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O10">
+        <dia:point val="10.7083,31.03"/>
+      </dia:attribute>
+        <dia:rectangle val="10.6583,30.08;44.6083,34.08"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="33.850000000000001"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE mb_group_id_seq;
+ALTER TABLE mb_group ALTER COLUMN mb_group_id SET DEFAULT nextval('mb_group_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="11.0083,32.6725"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
   </dia:layer>
 </dia:diagram>
More information about the Mapbender_commits mailing list
