[Mapbender-commits] r2705 - branches/2.5/resources/db/update
svn_mapbender at osgeo.org
Wed Jul 23 07:35:25 EDT 2008
Author: astrid_emde
Date: 2008-07-23 07:35:25 -0400 (Wed, 23 Jul 2008)
New Revision: 2705
branches/2.5/resources/db/update/update_mysql_db.sql
sqls to update the mapbender db to mapbender 2.5
Modified: branches/2.5/resources/db/update/update_mysql_db.sql
--- branches/2.5/resources/db/update/update_mysql_db.sql 2008-07-23 09:43:44 UTC (rev 2704)
+++ branches/2.5/resources/db/update/update_mysql_db.sql 2008-07-23 11:35:25 UTC (rev 2705)
@@ -34,21 +34,23 @@
ALTER table wfs add electronicmailaddress varchar(255);
ALTER table wfs add wfs_mb_getcapabilities_doc text;
ALTER table wfs add wfs_owner int(11);
-ALTER table wfs add wfs_timestamp int(11)
+ALTER table wfs add wfs_timestamp int(11);
ALTER table wfs add country varchar(255);
-ALTER TABLE wfs ALTER COLUMN wfs_title SET NOT NULL;
-ALTER TABLE wfs ALTER COLUMN wfs_title SET DEFAULT ''::character varying;
-ALTER TABLE wfs ALTER COLUMN wfs_version SET NOT NULL;
-ALTER TABLE wfs ALTER COLUMN wfs_version SET DEFAULT ''::character varying;
+ALTER TABLE wfs MODIFY wfs_title varchar(255) NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_title SET DEFAULT '';
-ALTER TABLE wfs ALTER COLUMN wfs_getcapabilities SET NOT NULL;
-ALTER TABLE wfs ALTER COLUMN wfs_getcapabilities SET DEFAULT ''::character varying;
+ALTER TABLE wfs MODIFY wfs_version NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_version SET DEFAULT '';
+ALTER TABLE wfs MODIFY wfs_getcapabilities NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_getcapabilities SET DEFAULT '';
alter table wfs_featuretype add column featuretype_searchable integer default 1;
alter table wfs_featuretype add column featuretype_abstract character varying(50);
-- grant root access to default wfs
UPDATE wfs SET wfs_owner = 1;
@@ -56,17 +58,17 @@
-- new table gui_wfs_conf
CREATE TABLE gui_wfs_conf (
- fkey_gui_id character varying(50) DEFAULT ''::character varying NOT NULL,
+ fkey_gui_id character varying(50) DEFAULT '' NOT NULL,
fkey_wfs_conf_id integer DEFAULT 0 NOT NULL
-ALTER TABLE ONLY gui_wfs_conf
+ALTER TABLE gui_wfs_conf
ADD CONSTRAINT pk_fkey_wfs_conf_id PRIMARY KEY (fkey_gui_id, fkey_wfs_conf_id);
ADD CONSTRAINT gui_wfs_conf_ibfk_1 FOREIGN KEY (fkey_gui_id) REFERENCES gui(gui_id) ON UPDATE CASCADE ON DELETE CASCADE;
ADD CONSTRAINT gui_wfs_conf_ibfk_2 FOREIGN KEY (fkey_wfs_conf_id) REFERENCES wfs_conf(wfs_conf_id) ON UPDATE CASCADE ON DELETE CASCADE;
-- insert wfs confs into gui digitize
@@ -85,10 +87,10 @@
fkey_keyword_id integer NOT NULL
-ALTER TABLE ONLY wfs_featuretype_keyword
+ALTER TABLE wfs_featuretype_keyword
ADD CONSTRAINT fkey_keyword_id_fkey_featuretype_id FOREIGN KEY (fkey_keyword_id) REFERENCES keyword(keyword_id) ON UPDATE CASCADE ON DELETE CASCADE;
ADD CONSTRAINT fkey_featuretype_id_fkey_keyword_id FOREIGN KEY (fkey_featuretype_id) REFERENCES wfs_featuretype(featuretype_id) ON UPDATE CASCADE ON DELETE CASCADE;
@@ -108,14 +110,14 @@
-- table wfs_conf_element: change in WFS configuration: access to geometries may now be restricted
-ALTER TABLE wfs_conf_element ADD COLUMN f_auth_varname VARCHAR(50);
+--ALTER TABLE wfs_conf_element ADD COLUMN f_auth_varname VARCHAR(50);
ALTER TABLE wfs_conf_element ADD COLUMN f_show_detail int4;
ALTER TABLE wfs_conf_element ADD COLUMN f_operator VARCHAR(50);
-- table gui_element: new column for translation
- ALTER TABLE gui_element ADD COLUMN e_title VARCHAR(255) NULL;
+-- ALTER TABLE gui_element ADD COLUMN e_title VARCHAR(255) NULL;
INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','WFS',2,1,'edit wfs settings','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,1005,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT WFS','a','','','','AdminFrame','');
@@ -131,6 +133,7 @@
-- new table translation: new table for translations
CREATE TABLE translations
trs_id int(11) NOT NULL auto_increment,
@@ -139,6 +142,7 @@
msgstr varchar(512),
PRIMARY KEY (trs_id)
CREATE INDEX msgid_idx ON translations(msgid);
@@ -472,6 +476,7 @@
-- new SLD table
CREATE TABLE sld_user_layer (
sld_user_layer_id int(11) NOT NULL auto_increment,
fkey_mb_user_id int(11) NOT NULL default '0',
@@ -482,22 +487,26 @@
PRIMARY KEY (sld_user_layer_id)
) TYPE=InnoDB;
-- constraints for new table sld_user_layer
-ALTER TABLE sld_user_layer
- ADD CONSTRAINT sld_user_layer_ibfk1 FOREIGN KEY (fkey_mb_user_id) REFERENCES mb_user (mb_user_id) ON DELETE CASCADE ON UPDATE CASCADE,
- ADD CONSTRAINT sld_user_layer_ibfk2 FOREIGN KEY (fkey_layer_id) REFERENCES layer (layer_id) ON DELETE CASCADE ON UPDATE CASCADE,
- ADD CONSTRAINT sld_user_layer_ibfk3 FOREIGN KEY (fkey_gui_id) REFERENCES gui (gui_id) ON DELETE CASCADE ON UPDATE CASCADE;
+ALTER TABLE sld_user_layer ADD CONSTRAINT sld_user_layer_ibfk1 FOREIGN KEY (fkey_mb_user_id) REFERENCES mb_user (mb_user_id) ON DELETE CASCADE ON UPDATE CASCADE;
+ALTER TABLE sld_user_layer ADD CONSTRAINT ADD CONSTRAINT sld_user_layer_ibfk2 FOREIGN KEY (fkey_layer_id) REFERENCES layer (layer_id) ON DELETE CASCADE ON UPDATE CASCADE;
+ALTER TABLE sld_user_layer ADD CONSTRAINT ADD CONSTRAINT sld_user_layer_ibfk3 FOREIGN KEY (fkey_gui_id) REFERENCES gui (gui_id) ON DELETE CASCADE ON UPDATE CASCADE;
-- add sld related columns
ALTER TABLE gui_wms ADD COLUMN gui_wms_sldurl varchar(255) NOT NULL default '';
ALTER TABLE wms ADD COLUMN wms_supportsld boolean NULL;
ALTER TABLE wms ADD COLUMN wms_userlayer boolean NULL;
ALTER TABLE wms ADD COLUMN wms_userstyle boolean NULL;
ALTER TABLE wms ADD COLUMN wms_remotewfs boolean NULL;
-- opacity handeling
-ALTER TABLE gui_wms ADD COLUMN gui_wms_opacity INT DEFAULT 100;
\ No newline at end of file
+ALTER TABLE gui_wms ADD COLUMN gui_wms_opacity INT DEFAULT 100;
More information about the Mapbender_commits
