[Mapbender-commits] r2711 - branches/2.5/http/print
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jul 24 01:54:02 EDT 2008
Author: beck
Date: 2008-07-24 01:54:02 -0400 (Thu, 24 Jul 2008)
New Revision: 2711
Removed:
   branches/2.5/http/print/mod_printPDF.php
Deleted: branches/2.5/http/print/mod_printPDF.php
--- branches/2.5/http/print/mod_printPDF.php	2008-07-24 05:51:12 UTC (rev 2710)
+++ branches/2.5/http/print/mod_printPDF.php	2008-07-24 05:54:02 UTC (rev 2711)
@@ -1,369 +0,0 @@
-<?php
-# $Id: mod_printPDF.php
-# http://www.mapbender.org/index.php/mod_printPDF.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-session_start();
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-// ini_set("error_reporting",E_ALL);
-// ini_set("display_errors","on");
-<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
-<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
-<head>
-	<meta http-equiv="cache-control" content="no-cache" />
-	<meta http-equiv="pragma" content="no-cache" />
-	<meta http-equiv="expires" content="0" />
-	<?php printf("<meta http-equiv=\"Content-Type\" content=\"text/html; charset=%s\" />",CHARSET);	?>
-	<title>Print PDF</title>
-	<?php
-	include '../include/dyn_css.php';
-	//FIXME:
-	//setlocale(LC_ALL, "de_DE.utf8");
-	require_once(dirname(__FILE__)."/../print/".$_REQUEST["conf"]);
-	printf("
-	<script type=\"text/javascript\">
-		var target = '%s';
-		var comment = '%s';
-		var comment_length = %s;
-		var label_button = '%s';
-		var type = '%s';
-	</script>",
-	$_REQUEST["target"],$label_comment,$comment_length,$label_button,$type
-	<script type="text/javascript">
-	var size;
-	var format;
-	var map_width;
-	var map_height;
-	if(type=='window'){
-		var pt = window.opener;
-	else if(type == 'iframe'){
-		var pt = parent;
-	function mod_legend_print(){
-		var mod_legend_target = target;
-		var ind = pt.getMapObjIndexByName(mod_legend_target);
-		var layers;
-		document.forms[0].layers.value = "";
-		document.forms[0].wms_id.value = "";
-		document.forms[0].wms_title.value = "";
-		document.forms[0].legendurl.value = "";
-		for(var i=0; i<pt.mb_mapObj[ind].wms.length; i++){
-			layers = pt.mb_mapObj[ind].wms[i].getLayers(pt.mb_mapObj[ind]);
-			if(layers != "" && layers){
-				if(i>0 && document.forms[0].wms_id.value!=''){
-				    document.forms[0].layers.value += "___";
-				    document.forms[0].wms_id.value += "___";
-				    document.forms[0].wms_title.value += "___";
-				    document.forms[0].legendurl.value += "___";
-				document.forms[0].wms_id.value += pt.mb_mapObj[ind].wms[i].wms_id;
-				document.forms[0].wms_title.value += pt.mb_mapObj[ind].wms[i].wms_title;
-				for(var j=0; j<layers.length; j++){
-					var layer = layers[j];
-					var title = pt.mb_mapObj[ind].wms[i].getTitleByLayerName(layers[j]);
-					var layerStyle = pt.mb_mapObj[ind].wms[i].getCurrentStyleByLayerName(layers[j]);
-					if(layerStyle==false){
-						var temp_legendurl = pt.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layers[j],"default");
-					else{
-						var temp_legendurl = pt.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layers[j],layerStyle);
-					//---------- legendurl ----------
-					tmp_name = "";
-					if(j>0){
-						document.forms[0].layers.value += ",";
-						document.forms[0].layers.value += title;
-					if(j>0){
-						document.forms[0].legendurl.value += ",";
-					if (temp_legendurl!= '' || !temp_legendurl == 'true'){
-						document.forms[0].legendurl.value += temp_legendurl;
-					}else{
-						document.forms[0].legendurl.value +='0';
-			else{
-				document.forms[0].layers.value += "0";
-			    document.forms[0].wms_id.value += "0";
-			    document.forms[0].wms_title.value += "0";
-			    document.forms[0].legendurl.value += "0";
-		}//for
-		//alert(document.forms[0].layers.value+"---"+document.forms[0].wms_id.value+"---"+document.forms[0].wms_title.value+"---"+document.forms[0].legendurl.value);
-	function validate(){
-		size = document.getElementById('size').options[document.getElementById('size').selectedIndex].value;
-		format = document.getElementById('format').options[document.getElementById('format').selectedIndex].value;
-		if(size != "" && format != ""){
-			var ind = pt.getMapObjIndexByName(target);
-			var coord = pt.mb_mapObj[ind].extent.split(",");
-			var centerX = parseFloat(coord[0]) + (parseFloat(coord[2]) - parseFloat(coord[0]))/2
-			var centerY = parseFloat(coord[1]) + (parseFloat(coord[3]) - parseFloat(coord[1]))/2
-			if(size == "A4" && format == "portrait"){
-				map_width = <?php echo $a4p_map_width; ?>;
-				map_height = <?php echo $a4p_map_height; ?>;
-			if(size == "A4" && format == "landscape"){
-				map_width = <?php echo $a4l_map_width; ?>;
-				map_height = <?php echo $a4l_map_height; ?>;
-			if(size == "A3" && format == "portrait"){
-				map_width = <?php echo $a3p_map_width; ?>;
-				map_height = <?php echo $a3p_map_height; ?>;
-			if(size == "A3" && format == "landscape"){
-				map_width = <?php echo $a3l_map_width; ?>;
-				map_height = <?php echo $a3l_map_height; ?>;
-			if(size == "A2" && format == "portrait"){
-				map_width = <?php echo $a2p_map_width; ?>;
-				map_height = <?php echo $a2p_map_height; ?>;
-			if(size == "A2" && format == "landscape"){
-				map_width = <?php echo $a2l_map_width; ?>;
-				map_height = <?php echo $a2l_map_height; ?>;
-			if(size == "A1" && format == "portrait"){
-				map_width = <?php echo $a1p_map_width; ?>;
-				map_height = <?php echo $a1p_map_height; ?>;
-			if(size == "A1" && format == "landscape"){
-				map_width = <?php echo $a1l_map_width; ?>;
-				map_height = <?php echo $a1l_map_height; ?>;
-			if(size == "A0" && format == "portrait"){
-				map_width = <?php echo $a0p_map_width; ?>;
-				map_height = <?php echo $a0p_map_height; ?>;
-			if(size == "A0" && format == "landscape"){
-				map_width = <?php echo $a0l_map_width; ?>;
-				map_height = <?php echo $a0l_map_height; ?>;
-			var pos = pt.makeClickPos2RealWorldPos(target, map_width , map_height);
-			pt.mb_mapObj[ind].extent = coord[0] + "," + pos[1] + "," + pos[0] + "," +  coord[3];
-			var prevscale= pt.mb_getScale(target);
-			pt.mb_mapObj[ind].width = Math.round(map_width);
-			pt.mb_mapObj[ind].height = Math.round(map_height);
-			pt.document.getElementById(target).style.width = Math.round(map_width);
-			pt.document.getElementById(target).style.height = Math.round(map_height);
-			pt.window.frames[target].document.getElementById("maps").style.width = Math.round(map_width);
-			pt.window.frames[target].document.getElementById("maps").style.height = Math.round(map_height);
-			//pt.setMapRequest(target);
-			pt.mb_repaintScale(target, null, null, prevscale);
-		document.form1.map_url.value = '';
-				if(pt.mb_mapObj[ind].wms[i].gui_wms_visible > 0){
-					if(pt.mb_mapObj[ind].wms[i].mapURL != false && pt.mb_mapObj[ind].wms[i].mapURL != 'false' && pt.mb_mapObj[ind].wms[i].mapURL != ''){
-						if(document.form1.map_url.value != ""){
-							document.form1.map_url.value += "___";
-						document.form1.map_url.value += pt.mb_mapObj[ind].wms[i].mapURL;
-			//overview_url
-			var ind_overview = pt.getMapObjIndexByName('overview');
-			//alert ("l�nge: " + length+ " - " + ind_overview + name + pt.mb_mapObj[ind_overview].wms.length);
-			if(pt.mb_mapObj[ind_overview].mapURL != false ){
-				document.forms[0].overview_url.value = pt.mb_mapObj[ind_overview].mapURL;
-	function refreshParams(){
-		var f = document.form1;
-		f.map_url.value = "";
-					if(f.map_url.value != ""){
-						f.map_url.value += "___";
-					f.map_url.value += pt.mb_mapObj[ind].wms[i].mapURL;
-		f.map_scale.value = pt.mb_getScale(target);
-		f.epsg.value = pt.mb_mapObj[ind].epsg;
-		mod_legend_print();
-	function printMap(){
-		if(size != "" && (format == "portrait" || format == "landscape")){
-			refreshParams();
-			if(document.form1.c1.value != comment){
-				document.form1.comment1.value = document.form1.c1.value;
-			if(document.form1.c2.value != comment){
-				document.form1.comment2.value = document.form1.c2.value;
-			if(document.form1.mylegendcheckbox.checked == 0){
-				document.form1.mylegend.value = 'false';
-			}else{
-				document.form1.mylegend.value = 'true';
-			// write the measured coordinates
-			if (pt.mod_measure_RX != undefined && pt.mod_measure_RY != undefined) {
-				var tmp_x = '';
-				var tmp_y = '';
-				for(i = 0; i<pt.mod_measure_RX.length; i++) {
-					if(tmp_x != '') {
-						tmp_x += ','
-					tmp_x += pt.mod_measure_RX[i];
-				for(i = 0; i<pt.mod_measure_RY.length; i++) {
-					if(tmp_y != '') {
-						tmp_y += ','
-					tmp_y += pt.mod_measure_RY[i];
-				document.forms['form1'].elements['measured_x_values'].value = tmp_x;
-				document.forms['form1'].elements['measured_y_values'].value = tmp_y;
-			document.form1.submit();
-		else{
-			alert("<?php echo _("No format selected!")?>");
-	function valCom(obj){
-		if(obj.value.length > comment_length){
-			obj.value = obj.value.substr(0,comment_length);
-	</script>
-</head>
-<body>
-<form name="form1" method="POST" action="../print/mod_printPDF_pdf.php?<?php echo SID; ?>" target="_blank">
-<p>
-	<label for="size"><?php echo $label_format ?>:</label>
-	<select id="size" name="size" onchange="validate();">
-		<option value="false">-</option>
-		<?php
-		for($i = 4; $i >= 0; $i--) {
-			if(${"a".$i}) {
-				printf("<option value=\"A%s\">%s</option>",$i,${"label_format_a".$i});
-	</select>
-</p>
-<p>
-	<label for="format"><?php echo $label_orientation; ?>:</label>
-	<select id="format" name="format" onchange="validate();">
-		<option value="portrait"><?php echo $label_portrait; ?></option>
-		<option value="landscape"><?php echo $label_landscape; ?></option>
-	</select>
-</p>
-<?php if($highquality === TRUE): ?>
-	<p>
-		<label for="quality"><?php echo $label_quality; ?>:</label>
-		<input type="radio" id="quality" name="quality" value="1" checked="checked" /> <?php echo $label_72dpi; ?>
-		<input type="radio" id="quality" name="quality" value="2" /> <?php echo $label_288dpi; ?>
-	</p>
-<?php endif; ?>
-<p>
-	<label for="c1"><?php echo $label_comment; ?>:</label>
-	<input type="text" id="c1" name="c1" maxlength="<?php echo $comment_length; ?>" onkeydown="valCom(this);" />
-	<em>(max. <?php echo $comment_length; ?>)</em>
-</p>
-<p>
-	<label for="c2"><?php echo $label_comment; ?>:</label>
-	<input type="text" id="c2" name="c2" maxlength="<?php echo $comment_length; ?>" onkeydown="valCom(this);" />
-</p>
-<?php if($legend === TRUE): ?>
-	<p>
-		<label for="mylegendcheckbox"><?php echo $label_legend; ?>:</label>
-		<input type="checkbox" id="mylegendcheckbox" name="mylegendcheckbox" value="false" />
-	</p>
-<?php else: ?>
-	<input type="hidden" name="mylegendcheckbox" value="false" />
-<?php endif; ?>
-<input type="hidden" name="map_url" />
-<input type="hidden" name="overview_url" />
-<input type="hidden" name="wms_title" />
-<input type="hidden" name="wms_id" />
-<input type="hidden" name="layers" />
-<input type="hidden" name="legendurl" />
-<input type="hidden" name="map_scale" />
-<input type="hidden" name="epsg" />
-<input type="hidden" name="conf" value="<?php echo $_REQUEST["conf"]; ?>" />
-<input type="hidden" name="comment1" />
-<input type="hidden" name="comment2" />
-<input type="hidden" name="mylegend" value="true" >
-<input type="hidden" name="measured_x_values" />
-<input type="hidden" name="measured_y_values" />
-<p>
-	<input type="button" id="print" name="print" value="<?php echo $label_button; ?>" onclick="printMap();" />
-</p>
-</form>
-</body>
-</html>
\ No newline at end of file
More information about the Mapbender_commits mailing list
