[Mapbender-commits] r2712 - branches/2.5/http/print
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jul 24 01:54:25 EDT 2008
Author: beck
Date: 2008-07-24 01:54:24 -0400 (Thu, 24 Jul 2008)
New Revision: 2712
Added:
   branches/2.5/http/print/mod_printPDF.php
Added: branches/2.5/http/print/mod_printPDF.php
--- branches/2.5/http/print/mod_printPDF.php	                        (rev 0)
+++ branches/2.5/http/print/mod_printPDF.php	2008-07-24 05:54:24 UTC (rev 2712)
@@ -0,0 +1,370 @@
+<?php
+# $Id: mod_printPDF.php
+# http://www.mapbender.org/index.php/mod_printPDF.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+session_start();
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
+<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
+<head>
+	<meta http-equiv="cache-control" content="no-cache" />
+	<meta http-equiv="pragma" content="no-cache" />
+	<meta http-equiv="expires" content="0" />
+	<?php printf("<meta http-equiv=\"Content-Type\" content=\"text/html; charset=%s\" />",CHARSET);	?>
+	<title>Print PDF</title>
+	<?php
+	include '../include/dyn_css.php';
+	//FIXME:
+	//setlocale(LC_ALL, "de_DE.utf8");
+	require_once(dirname(__FILE__)."/../print/".$_REQUEST["conf"]);
+	printf("
+	<script type=\"text/javascript\">
+		var target = '%s';
+		var comment1 = '%s';
+		var comment1_length = %s;
+		var comment2 = '%s';
+		var comment2_length = %s;
+		var label_button = '%s';
+		var type = '%s';
+	</script>",
+	$_REQUEST["target"],$label_comment1,$comment1_length,$label_comment2,$comment2_length,$label_button,$type
+	<script type="text/javascript">
+	var size;
+	var format;
+	var map_width;
+	var map_height;
+	if(type=='window'){
+		var pt = window.opener;
+	else if(type == 'iframe'){
+		var pt = parent;
+	function mod_legend_print(){
+		var mod_legend_target = target;
+		var ind = pt.getMapObjIndexByName(mod_legend_target);
+		var layers;
+		document.forms[0].layers.value = "";
+		document.forms[0].wms_id.value = "";
+		document.forms[0].wms_title.value = "";
+		document.forms[0].legendurl.value = "";
+		for(var i=0; i<pt.mb_mapObj[ind].wms.length; i++){
+			layers = pt.mb_mapObj[ind].wms[i].getLayers(pt.mb_mapObj[ind]);
+			if(layers != "" && layers){
+				if(i>0 && document.forms[0].wms_id.value!=''){
+				    document.forms[0].layers.value += "___";
+				    document.forms[0].wms_id.value += "___";
+				    document.forms[0].wms_title.value += "___";
+				    document.forms[0].legendurl.value += "___";
+				document.forms[0].wms_id.value += pt.mb_mapObj[ind].wms[i].wms_id;
+				document.forms[0].wms_title.value += pt.mb_mapObj[ind].wms[i].wms_title;
+				for(var j=0; j<layers.length; j++){
+					var layer = layers[j];
+					var title = pt.mb_mapObj[ind].wms[i].getTitleByLayerName(layers[j]);
+					var layerStyle = pt.mb_mapObj[ind].wms[i].getCurrentStyleByLayerName(layers[j]);
+					if(layerStyle==false){
+						var temp_legendurl = pt.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layers[j],"default");
+					else{
+						var temp_legendurl = pt.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layers[j],layerStyle);
+					//---------- legendurl ----------
+					tmp_name = "";
+					if(j>0){
+						document.forms[0].layers.value += ",";
+						document.forms[0].layers.value += title;
+					if(j>0){
+						document.forms[0].legendurl.value += ",";
+					if (temp_legendurl!= '' || !temp_legendurl == 'true'){
+						document.forms[0].legendurl.value += temp_legendurl;
+					}else{
+						document.forms[0].legendurl.value +='0';
+			else{
+				document.forms[0].layers.value += "0";
+			    document.forms[0].wms_id.value += "0";
+			    document.forms[0].wms_title.value += "0";
+			    document.forms[0].legendurl.value += "0";
+		}//for
+		//alert(document.forms[0].layers.value+"---"+document.forms[0].wms_id.value+"---"+document.forms[0].wms_title.value+"---"+document.forms[0].legendurl.value);
+	function validate(){
+		size = document.getElementById('size').options[document.getElementById('size').selectedIndex].value;
+		format = document.getElementById('format').options[document.getElementById('format').selectedIndex].value;
+		if(size != "" && format != ""){
+			var ind = pt.getMapObjIndexByName(target);
+			var coord = pt.mb_mapObj[ind].extent.split(",");
+			var centerX = parseFloat(coord[0]) + (parseFloat(coord[2]) - parseFloat(coord[0]))/2
+			var centerY = parseFloat(coord[1]) + (parseFloat(coord[3]) - parseFloat(coord[1]))/2
+			if(size == "A4" && format == "portrait"){
+				map_width = <?php echo $a4p_map_width; ?>;
+				map_height = <?php echo $a4p_map_height; ?>;
+			if(size == "A4" && format == "landscape"){
+				map_width = <?php echo $a4l_map_width; ?>;
+				map_height = <?php echo $a4l_map_height; ?>;
+			if(size == "A3" && format == "portrait"){
+				map_width = <?php echo $a3p_map_width; ?>;
+				map_height = <?php echo $a3p_map_height; ?>;
+			if(size == "A3" && format == "landscape"){
+				map_width = <?php echo $a3l_map_width; ?>;
+				map_height = <?php echo $a3l_map_height; ?>;
+			if(size == "A2" && format == "portrait"){
+				map_width = <?php echo $a2p_map_width; ?>;
+				map_height = <?php echo $a2p_map_height; ?>;
+			if(size == "A2" && format == "landscape"){
+				map_width = <?php echo $a2l_map_width; ?>;
+				map_height = <?php echo $a2l_map_height; ?>;
+			if(size == "A1" && format == "portrait"){
+				map_width = <?php echo $a1p_map_width; ?>;
+				map_height = <?php echo $a1p_map_height; ?>;
+			if(size == "A1" && format == "landscape"){
+				map_width = <?php echo $a1l_map_width; ?>;
+				map_height = <?php echo $a1l_map_height; ?>;
+			if(size == "A0" && format == "portrait"){
+				map_width = <?php echo $a0p_map_width; ?>;
+				map_height = <?php echo $a0p_map_height; ?>;
+			if(size == "A0" && format == "landscape"){
+				map_width = <?php echo $a0l_map_width; ?>;
+				map_height = <?php echo $a0l_map_height; ?>;
+			var pos = pt.makeClickPos2RealWorldPos(target, map_width , map_height);
+			pt.mb_mapObj[ind].extent = coord[0] + "," + pos[1] + "," + pos[0] + "," +  coord[3];
+			pt.mb_mapObj[ind].width = Math.round(map_width);
+			pt.mb_mapObj[ind].height = Math.round(map_height);
+			pt.document.getElementById(target).style.width = Math.round(map_width);
+			pt.document.getElementById(target).style.height = Math.round(map_height);
+			pt.window.frames[target].document.getElementById("maps").style.width = Math.round(map_width);
+			pt.window.frames[target].document.getElementById("maps").style.height = Math.round(map_height);
+			//pt.setMapRequest(target);
+			pt.mb_repaintScale(target, null, null, pt.mb_getScale(target));
+		document.form1.map_url.value = '';
+				if(pt.mb_mapObj[ind].wms[i].gui_wms_visible > 0){
+					if(pt.mb_mapObj[ind].wms[i].mapURL != false && pt.mb_mapObj[ind].wms[i].mapURL != 'false' && pt.mb_mapObj[ind].wms[i].mapURL != ''){
+						if(document.form1.map_url.value != ""){
+							document.form1.map_url.value += "___";
+						document.form1.map_url.value += pt.mb_mapObj[ind].wms[i].mapURL;
+			//overview_url
+			var ind_overview = pt.getMapObjIndexByName('overview');
+			//alert ("l�nge: " + length+ " - " + ind_overview + name + pt.mb_mapObj[ind_overview].wms.length);
+			if(pt.mb_mapObj[ind_overview].mapURL != false ){
+				document.forms[0].overview_url.value = pt.mb_mapObj[ind_overview].mapURL;
+	function refreshParams(){
+		var f = document.form1;
+		f.map_url.value = "";
+					if(f.map_url.value != ""){
+						f.map_url.value += "___";
+					f.map_url.value += pt.mb_mapObj[ind].wms[i].mapURL;
+		f.map_scale.value = pt.mb_getScale(target);
+		f.epsg.value = pt.mb_mapObj[ind].epsg;
+		mod_legend_print();
+	function printMap(){
+		if(size != "" && (format == "portrait" || format == "landscape")){
+			refreshParams();
+			if(document.form1.c1.value != comment1){
+				document.form1.comment1.value = document.form1.c1.value;
+			if(document.form1.c2.value != comment2){
+				document.form1.comment2.value = document.form1.c2.value;
+			if(document.form1.mylegendcheckbox.checked == 0){
+				document.form1.mylegend.value = 'false';
+			}else{
+				document.form1.mylegend.value = 'true';
+			// write the measured coordinates
+			if (pt.mod_measure_RX != undefined && pt.mod_measure_RY != undefined) {
+				var tmp_x = '';
+				var tmp_y = '';
+				for(i = 0; i<pt.mod_measure_RX.length; i++) {
+					if(tmp_x != '') {
+						tmp_x += ','
+					tmp_x += pt.mod_measure_RX[i];
+				for(i = 0; i<pt.mod_measure_RY.length; i++) {
+					if(tmp_y != '') {
+						tmp_y += ','
+					tmp_y += pt.mod_measure_RY[i];
+				document.forms['form1'].elements['measured_x_values'].value = tmp_x;
+				document.forms['form1'].elements['measured_y_values'].value = tmp_y;
+			document.form1.submit();
+		else{
+			alert("<?php echo _("No format selected!")?>");
+	function checkCommentLength(obj,maxLength){
+		if(obj.value.length > maxLength){
+			obj.value = obj.value.substr(0,maxLength);
+	</script>
+</head>
+<body>
+<form name="form1" method="POST" action="../print/mod_printPDF_pdf.php?<?php echo SID; ?>" target="_blank">
+<p id="container_size">
+	<label for="size"><?php echo $label_format ?></label>
+	<select id="size" name="size" onchange="validate();">
+		<option value="false">-</option>
+		<?php
+		for($i = 4; $i >= 0; $i--) {
+			if(${"a".$i}) {
+				printf("<option value=\"A%s\">%s</option>",$i,${"label_format_a".$i});
+	</select>
+</p>
+<p id="container_orientation">
+	<label for="format"><?php echo $label_orientation; ?></label>
+	<select id="format" name="format" onchange="validate();">
+		<option value="portrait"><?php echo $label_portrait; ?></option>
+		<option value="landscape"><?php echo $label_landscape; ?></option>
+	</select>
+</p>
+<?php if($highquality === TRUE): ?>
+	<p id="container_quality">
+		<label for="quality"><?php echo $label_quality; ?></label>
+		<input type="radio" id="quality" name="quality" value="1" checked="checked" /> <?php echo $label_72dpi; ?>
+		<input type="radio" id="quality" name="quality" value="2" /> <?php echo $label_288dpi; ?>
+	</p>
+<?php endif; ?>
+<?php
+ini_set("error_reporting",E_ALL);
+ini_set("display_errors","on");
+	for($i = 1; $i <= 2; $i++) {
+		$max_comment_length = ${"comment".$i."_length"};
+		$label_hint         = ($max_comment_length > -1) ? sprintf(" <em>(max. %s)</em>",$max_comment_length) : NULL;
+		$javascript         = ($max_comment_length > -1) ? sprintf(" onblur=\"checkCommentLength(this,%s)\"",$max_comment_length) : NULL;
+		$html  = sprintf("<p id=\"container_comment%s\">",$i);
+		$html .= sprintf("<label for=\"c%s\">%s%s</label> ",$i,${"label_comment".$i},$label_hint);
+		$html .= sprintf("<textarea id=\"c%s\" name=\"c%s\" cols=\"20\" rows=\"2\"%s></textarea> ",$i,$i,$javascript);
+		$html .= "</p>";
+		echo $html;
+<?php if($legend === TRUE): ?>
+	<p id="container_legend">
+		<label for="mylegendcheckbox"><?php echo $label_legend; ?></label>
+		<input type="checkbox" id="mylegendcheckbox" name="mylegendcheckbox" value="false" />
+	</p>
+<?php else: ?>
+	<input type="hidden" name="mylegendcheckbox" value="false" />
+<?php endif; ?>
+<input type="hidden" name="map_url" />
+<input type="hidden" name="overview_url" />
+<input type="hidden" name="wms_title" />
+<input type="hidden" name="wms_id" />
+<input type="hidden" name="layers" />
+<input type="hidden" name="legendurl" />
+<input type="hidden" name="map_scale" />
+<input type="hidden" name="epsg" />
+<input type="hidden" name="conf" value="<?php echo $_REQUEST["conf"]; ?>" />
+<input type="hidden" name="comment1" />
+<input type="hidden" name="comment2" />
+<input type="hidden" name="mylegend" value="true" >
+<input type="hidden" name="measured_x_values" />
+<input type="hidden" name="measured_y_values" />
+<p>
+	<input type="button" id="print" name="print" value="<?php echo $label_button; ?>" onclick="printMap();" />
+</p>
+</form>
+</body>
+</html>
\ No newline at end of file
More information about the Mapbender_commits mailing list
