[Mapbender-commits] r2507 - branches/beck_dev/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jun 17 10:48:43 EDT 2008
Author: Greq
Date: 2008-06-17 10:48:42 -0400 (Tue, 17 Jun 2008)
New Revision: 2507
Added:
   branches/beck_dev/mapbender/http/php/mod_editApplication_server.php
   branches/beck_dev/mapbender/http/php/mod_editApplication.php
save
button class
Modified: branches/beck_dev/mapbender/http/php/mod_editApplication.php
--- branches/beck_dev/mapbender/http/php/mod_editApplication.php	2008-06-17 10:26:31 UTC (rev 2506)
+++ branches/beck_dev/mapbender/http/php/mod_editApplication.php	2008-06-17 14:48:42 UTC (rev 2507)
@@ -42,10 +42,13 @@
 <link rel='stylesheet' type='text/css' href='../css/popup.css'>
 <script type='text/javascript' src='../extensions/jquery-1.2.6.min.js'></script>
 <script type='text/javascript' src='../extensions/jquery-ui-personalized-1.5.min.js'></script>
+<script type='text/javascript' src='../extensions/jqjson.js'></script>
 <script type='text/javascript' src='../javascripts/popup.js'></script>
 <script language="JavaScript" type="text/javascript">
 <?php
 	include("../../lib/event.js");
+	echo "var editApplicationId = '" . $editApplicationId . "';";
 	var controlPopup;
@@ -95,6 +98,7 @@
 		saveButton.registerStart(selectButton.triggerStop);
 		saveButton.registerStart(dragButton.triggerStop);
+		saveButton.registerStart(updateDatabase);
 		controlPopup.show();
@@ -211,6 +215,30 @@
+	function updateDatabase (options) {
+		var data = [];
+		$(".collection").children().each(function() {
+			data.push({
+				name:this.name,
+				top:parseInt(this.style.top),
+				left:parseInt(this.style.left)
+		var queryObj = {
+			command:"update",
+			parameters:{
+				applicationId:editApplicationId,
+				data:data
+		$.post("mod_editApplication_server.php", {
+			queryObj:$.toJSON(queryObj)
+		}, function (json, status) {
+			var replyObj = eval('(' + json + ')');
+			alert(replyObj.success);
 </script>
 </head>
@@ -262,8 +290,8 @@
 	//			echo "' >";
 	//			echo "<".db_result($res,$i,"e_element")." ";
 			if(db_result($res,$i,"e_id") != ""){
-				echo " id='".db_result($res,$i,"e_id")."'";
-				echo " name='".db_result($res,$i,"e_id")."'";
+				echo " id='".db_result($res,$i,"e_id")."' ";
+				echo " name='".db_result($res,$i,"e_id")."' ";
 			if(db_result($res,$i,"e_attributes") != ""){
 	//				echo " ".stripslashes(preg_replace($pattern,$replacement,db_result($res,$i,"e_attributes")));
Added: branches/beck_dev/mapbender/http/php/mod_editApplication_server.php
--- branches/beck_dev/mapbender/http/php/mod_editApplication_server.php	                        (rev 0)
+++ branches/beck_dev/mapbender/http/php/mod_editApplication_server.php	2008-06-17 14:48:42 UTC (rev 2507)
@@ -0,0 +1,55 @@
+<?php
+require_once(dirname(__FILE__) . "/../php/mb_validateSession.php");
+require_once(dirname(__FILE__) . "/../classes/class_user.php");
+require_once(dirname(__FILE__) . "/../classes/class_json.php");
+ * encodes and delivers the data
+ * @param object the un-encoded object
+function sendOutput($out){
+	global $json;
+	$output = $json->encode($out);
+	header("Content-Type: text/x-json");
+	echo $output;
+$json = new Mapbender_JSON();
+$queryObj = $json->decode(stripslashes($_REQUEST['queryObj']));
+$resultObj = array();
+$e = new mb_exception("command: " . $queryObj->command);
+$userId = $_SESSION[mb_user_id];
+switch($queryObj->command){
+	// gets available WMCs
+	case 'update':
+		$elementArray = $queryObj->parameters->data;
+		for ($i = 0; $i < count($elementArray); $i++) {
+			$currentElement = $elementArray[$i];
+			$id = $currentElement->name;
+			$top = $currentElement->top;
+			$left = $currentElement->left;
+			$app = $queryObj->parameters->applicationId;
+			$sql = "UPDATE gui_element SET e_left = $1, e_top = $2 " .
+					"WHERE e_id = $3 AND fkey_gui_id = $4";
+			$v = array($left, $top, $id, $app);
+			$t = array("i", "i", "s", "s");
+			$res = db_prep_query($sql, $v, $t);
+			$e = new mb_notice("updating element '" . $id . "'");
+		$resultObj["success"] = "Elements have been updated in the database.";
+	break;
+	// Invalid command
+	default:
+		$resultObj["error"] = "no action specified...";
+sendOutput($resultObj);
\ No newline at end of file
More information about the Mapbender_commits mailing list
