[Mapbender-commits] r2508 - branches/beck_dev/mapbender/http/extensions
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jun 17 11:55:33 EDT 2008
Author: Greq
Date: 2008-06-17 11:55:33 -0400 (Tue, 17 Jun 2008)
New Revision: 2508
Added:
   branches/beck_dev/mapbender/http/extensions/jquery-1.2.6.min.js
   branches/beck_dev/mapbender/http/extensions/jquery-ui-personalized-1.5.min.js
jquery 1.2.6
jquery ui
Added: branches/beck_dev/mapbender/http/extensions/jquery-1.2.6.min.js
--- branches/beck_dev/mapbender/http/extensions/jquery-1.2.6.min.js	                        (rev 0)
+++ branches/beck_dev/mapbender/http/extensions/jquery-1.2.6.min.js	2008-06-17 15:55:33 UTC (rev 2508)
@@ -0,0 +1,32 @@
+ * jQuery 1.2.6 - New Wave Javascript
+ * Copyright (c) 2008 John Resig (jquery.com)
+ * Dual licensed under the MIT (MIT-LICENSE.txt)
+ * and GPL (GPL-LICENSE.txt) licenses.
+ * $Date: 2008-05-24 14:22:17 -0400 (Sat, 24 May 2008) $
+ * $Rev: 5685 $
+(function(){var _jQuery=window.jQuery,_$=window.$;var jQuery=window.jQuery=window.$=function(selector,context){return new jQuery.fn.init(selector,context);};var quickExpr=/^[^<]*(<(.|\s)+>)[^>]*$|^#(\w+)$/,isSimple=/^.[^:#\[\.]*$/,undefined;jQuery.fn=jQuery.prototype={init:function(selector,context){selector=selector||document;if(selector.nodeType){this[0]=selector;this.length=1;return this;}if(typeof selector=="string"){var match=quickExpr.exec(selector);if(match&&(match[1]||!context)){if(match[1])selector=jQuery.clean([match[1]],context);else{var elem=document.getElementById(match[3]);if(elem){if(elem.id!=match[3])return jQuery().find(selector);return jQuery(elem);}selector=[];}}else
+return jQuery(context).find(selector);}else if(jQuery.isFunction(selector))return jQuery(document)[jQuery.fn.ready?"ready":"load"](selector);return this.setArray(jQuery.makeArray(selector));},jquery:"1.2.6",size:function(){return this.length;},length:0,get:function(num){return num==undefined?jQuery.makeArray(this):this[num];},pushStack:function(elems){var ret=jQuery(elems);ret.prevObject=this;return ret;},setArray:function(elems){this.length=0;Array.prototype.push.apply(this,elems);return this;},each:function(callback,args){return jQuery.each(this,callback,args);},index:function(elem){var ret=-1;return jQuery.inArray(elem&&elem.jquery?elem[0]:elem,this);},attr:function(name,value,type){var options=name;if(name.constructor==String)if(value===undefined)return this[0]&&jQuery[type||"attr"](this[0],name);else{options={};options[name]=value;}return this.each(function(i){for(name in options)jQuery.attr(type?this.style:this,name,jQuery.prop(this,options[name],type,i,name));});},css:function(key,value){if((key=='width'||key=='height')&&parseFloat(value)<0)value=undefined;return this.attr(key,value,"curCSS");},text:function(text){if(typeof text!="object"&&text!=null)return this.empty().append((this[0]&&this[0].ownerDocument||document).createTextNode(text));var ret="";jQuery.each(text||this,function(){jQuery.each(this.childNodes,function(){if(this.nodeType!=8)ret+=this.nodeType!=1?this.nodeValue:jQuery.fn.text([this]);});});return ret;},wrapAll:function(html){if(this[0])jQuery(html,this[0].ownerDocument).clone().insertBefore(this[0]).map(function(){var elem=this;while(elem.firstChild)elem=elem.firstChild;return elem;}).append(this);return this;},wrapInner:function(html){return this.each(function(){jQuery(this).contents().wrapAll(html);});},wrap:function(html){return this.each(function(){jQuery(this).wrapAll(html);});},append:function(){return this.domManip(arguments,true,false,function(elem){if(this.nodeType==1)this.appendChild(elem);});},prepend:function(){return this.domManip(arguments,true,true,function(elem){if(this.nodeType==1)this.insertBefore(elem,this.firstChild);});},before:function(){return this.domManip(arguments,false,false,function(elem){this.parentNode.insertBefore(elem,this);});},after:function(){return this.domManip(arguments,false,true,function(elem){this.parentNode.insertBefore(elem,this.nextSibling);});},end:function(){return this.prevObject||jQuery([]);},find:function(selector){var elems=jQuery.map(this,function(elem){return jQuery.find(selector,elem);});return this.pushStack(/[^+>] [^+>]/.test(selector)||selector.indexOf("..")>-1?jQuery.unique(elems):elems);},clone:function(events){var ret=this.map(function(){if(jQuery.browser.msie&&!jQuery.isXMLDoc(this)){var clone=this.cloneNode(true),container=document.createElement("div");container.appendChild(clone);return jQuery.clean([container.innerHTML])[0];}else
+return this.cloneNode(true);});var clone=ret.find("*").andSelf().each(function(){if(this[expando]!=undefined)this[expando]=null;});if(events===true)this.find("*").andSelf().each(function(i){if(this.nodeType==3)return;var events=jQuery.data(this,"events");for(var type in events)for(var handler in events[type])jQuery.event.add(clone[i],type,events[type][handler],events[type][handler].data);});return ret;},filter:function(selector){return this.pushStack(jQuery.isFunction(selector)&&jQuery.grep(this,function(elem,i){return selector.call(elem,i);})||jQuery.multiFilter(selector,this));},not:function(selector){if(selector.constructor==String)if(isSimple.test(selector))return this.pushStack(jQuery.multiFilter(selector,this,true));else
+selector=jQuery.multiFilter(selector,this);var isArrayLike=selector.length&&selector[selector.length-1]!==undefined&&!selector.nodeType;return this.filter(function(){return isArrayLike?jQuery.inArray(this,selector)<0:this!=selector;});},add:function(selector){return this.pushStack(jQuery.unique(jQuery.merge(this.get(),typeof selector=='string'?jQuery(selector):jQuery.makeArray(selector))));},is:function(selector){return!!selector&&jQuery.multiFilter(selector,this).length>0;},hasClass:function(selector){return this.is("."+selector);},val:function(value){if(value==undefined){if(this.length){var elem=this[0];if(jQuery.nodeName(elem,"select")){var index=elem.selectedIndex,values=[],options=elem.options,one=elem.type=="select-one";if(index<0)return null;for(var i=one?index:0,max=one?index+1:options.length;i<max;i++){var option=options[i];if(option.selected){value=jQuery.browser.msie&&!option.attributes.value.specified?option.text:option.value;if(one)return value;values.push(value);}}return values;}else
+return(this[0].value||"").replace(/\r/g,"");}return undefined;}if(value.constructor==Number)value+='';return this.each(function(){if(this.nodeType!=1)return;if(value.constructor==Array&&/radio|checkbox/.test(this.type))this.checked=(jQuery.inArray(this.value,value)>=0||jQuery.inArray(this.name,value)>=0);else if(jQuery.nodeName(this,"select")){var values=jQuery.makeArray(value);jQuery("option",this).each(function(){this.selected=(jQuery.inArray(this.value,values)>=0||jQuery.inArray(this.text,values)>=0);});if(!values.length)this.selectedIndex=-1;}else
+this.value=value;});},html:function(value){return value==undefined?(this[0]?this[0].innerHTML:null):this.empty().append(value);},replaceWith:function(value){return this.after(value).remove();},eq:function(i){return this.slice(i,i+1);},slice:function(){return this.pushStack(Array.prototype.slice.apply(this,arguments));},map:function(callback){return this.pushStack(jQuery.map(this,function(elem,i){return callback.call(elem,i,elem);}));},andSelf:function(){return this.add(this.prevObject);},data:function(key,value){var parts=key.split(".");parts[1]=parts[1]?"."+parts[1]:"";if(value===undefined){var data=this.triggerHandler("getData"+parts[1]+"!",[parts[0]]);if(data===undefined&&this.length)data=jQuery.data(this[0],key);return data===undefined&&parts[1]?this.data(parts[0]):data;}else
+return this.trigger("setData"+parts[1]+"!",[parts[0],value]).each(function(){jQuery.data(this,key,value);});},removeData:function(key){return this.each(function(){jQuery.removeData(this,key);});},domManip:function(args,table,reverse,callback){var clone=this.length>1,elems;return this.each(function(){if(!elems){elems=jQuery.clean(args,this.ownerDocument);if(reverse)elems.reverse();}var obj=this;if(table&&jQuery.nodeName(this,"table")&&jQuery.nodeName(elems[0],"tr"))obj=this.getElementsByTagName("tbody")[0]||this.appendChild(this.ownerDocument.createElement("tbody"));var scripts=jQuery([]);jQuery.each(elems,function(){var elem=clone?jQuery(this).clone(true)[0]:this;if(jQuery.nodeName(elem,"script"))scripts=scripts.add(elem);else{if(elem.nodeType==1)scripts=scripts.add(jQuery("script",elem).remove());callback.call(obj,elem);}});scripts.each(evalScript);});}};jQuery.fn.init.prototype=jQuery.fn;function evalScript(i,elem){if(elem.src)jQuery.ajax({url:elem.src,async:false,dataType:"script"});else
+jQuery.globalEval(elem.text||elem.textContent||elem.innerHTML||"");if(elem.parentNode)elem.parentNode.removeChild(elem);}function now(){return+new Date;}jQuery.extend=jQuery.fn.extend=function(){var target=arguments[0]||{},i=1,length=arguments.length,deep=false,options;if(target.constructor==Boolean){deep=target;target=arguments[1]||{};i=2;}if(typeof target!="object"&&typeof target!="function")target={};if(length==i){target=this;--i;}for(;i<length;i++)if((options=arguments[i])!=null)for(var name in options){var src=target[name],copy=options[name];if(target===copy)continue;if(deep&&copy&&typeof copy=="object"&&!copy.nodeType)target[name]=jQuery.extend(deep,src||(copy.length!=null?[]:{}),copy);else if(copy!==undefined)target[name]=copy;}return target;};var expando="jQuery"+now(),uuid=0,windowData={},exclude=/z-?index|font-?weight|opacity|zoom|line-?height/i,defaultView=document.defaultView||{};jQuery.extend({noConflict:function(deep){window.$=_$;if(deep)window.jQuery=_jQuery;return jQuery;},isFunction:function(fn){return!!fn&&typeof fn!="string"&&!fn.nodeName&&fn.constructor!=Array&&/^[\s[]?function/.test(fn+"");},isXMLDoc:function(elem){return elem.documentElement&&!elem.body||elem.tagName&&elem.ownerDocument&&!elem.ownerDocument.body;},globalEval:function(data){data=jQuery.trim(data);if(data){var head=document.getElementsByTagName("head")[0]||document.documentElement,script=document.createElement("script");script.type="text/javascript";if(jQuery.browser.msie)script.text=data;else
+script.appendChild(document.createTextNode(data));head.insertBefore(script,head.firstChild);head.removeChild(script);}},nodeName:function(elem,name){return elem.nodeName&&elem.nodeName.toUpperCase()==name.toUpperCase();},cache:{},data:function(elem,name,data){elem=elem==window?windowData:elem;var id=elem[expando];if(!id)id=elem[expando]=++uuid;if(name&&!jQuery.cache[id])jQuery.cache[id]={};if(data!==undefined)jQuery.cache[id][name]=data;return name?jQuery.cache[id][name]:id;},removeData:function(elem,name){elem=elem==window?windowData:elem;var id=elem[expando];if(name){if(jQuery.cache[id]){delete jQuery.cache[id][name];name="";for(name in jQuery.cache[id])break;if(!name)jQuery.removeData(elem);}}else{try{delete elem[expando];}catch(e){if(elem.removeAttribute)elem.removeAttribute(expando);}delete jQuery.cache[id];}},each:function(object,callback,args){var name,i=0,length=object.length;if(args){if(length==undefined){for(name in object)if(callback.apply(object[name],args)===false)break;}else
+for(;i<length;)if(callback.apply(object[i++],args)===false)break;}else{if(length==undefined){for(name in object)if(callback.call(object[name],name,object[name])===false)break;}else
+for(var value=object[0];i<length&&callback.call(value,i,value)!==false;value=object[++i]){}}return object;},prop:function(elem,value,type,i,name){if(jQuery.isFunction(value))value=value.call(elem,i);return value&&value.constructor==Number&&type=="curCSS"&&!exclude.test(name)?value+"px":value;},className:{add:function(elem,classNames){jQuery.each((classNames||"").split(/\s+/),function(i,className){if(elem.nodeType==1&&!jQuery.className.has(elem.className,className))elem.className+=(elem.className?" ":"")+className;});},remove:function(elem,classNames){if(elem.nodeType==1)elem.className=classNames!=undefined?jQuery.grep(elem.className.split(/\s+/),function(className){return!jQuery.className.has(classNames,className);}).join(" "):"";},has:function(elem,className){return jQuery.inArray(className,(elem.className||elem).toString().split(/\s+/))>-1;}},swap:function(elem,options,callback){var old={};for(var name in options){old[name]=elem.style[name];elem.style[name]=options[name];}callback.call(elem);for(var name in options)elem.style[name]=old[name];},css:function(elem,name,force){if(name=="width"||name=="height"){var val,props={position:"absolute",visibility:"hidden",display:"block"},which=name=="width"?["Left","Right"]:["Top","Bottom"];function getWH(){val=name=="width"?elem.offsetWidth:elem.offsetHeight;var padding=0,border=0;jQuery.each(which,function(){padding+=parseFloat(jQuery.curCSS(elem,"padding"+this,true))||0;border+=parseFloat(jQuery.curCSS(elem,"border"+this+"Width",true))||0;});val-=Math.round(padding+border);}if(jQuery(elem).is(":visible"))getWH();else
+jQuery.swap(elem,props,getWH);return Math.max(0,val);}return jQuery.curCSS(elem,name,force);},curCSS:function(elem,name,force){var ret,style=elem.style;function color(elem){if(!jQuery.browser.safari)return false;var ret=defaultView.getComputedStyle(elem,null);return!ret||ret.getPropertyValue("color")=="";}if(name=="opacity"&&jQuery.browser.msie){ret=jQuery.attr(style,"opacity");return ret==""?"1":ret;}if(jQuery.browser.opera&&name=="display"){var save=style.outline;style.outline="0 solid black";style.outline=save;}if(name.match(/float/i))name=styleFloat;if(!force&&style&&style[name])ret=style[name];else if(defaultView.getComputedStyle){if(name.match(/float/i))name="float";name=name.replace(/([A-Z])/g,"-$1").toLowerCase();var computedStyle=defaultView.getComputedStyle(elem,null);if(computedStyle&&!color(elem))ret=computedStyle.getPropertyValue(name);else{var swap=[],stack=[],a=elem,i=0;for(;a&&color(a);a=a.parentNode)stack.unshift(a);for(;i<stack.length;i++)if(color(stack[i])){swap[i]=stack[i].style.display;stack[i].style.display="block";}ret=name=="display"&&swap[stack.length-1]!=null?"none":(computedStyle&&computedStyle.getPropertyValue(name))||"";for(i=0;i<swap.length;i++)if(swap[i]!=null)stack[i].style.display=swap[i];}if(name=="opacity"&&ret=="")ret="1";}else if(elem.currentStyle){var camelCase=name.replace(/\-(\w)/g,function(all,letter){return letter.toUpperCase();});ret=elem.currentStyle[name]||elem.currentStyle[camelCase];if(!/^\d+(px)?$/i.test(ret)&&/^\d/.test(ret)){var left=style.left,rsLeft=elem.runtimeStyle.left;elem.runtimeStyle.left=elem.currentStyle.left;style.left=ret||0;ret=style.pixelLeft+"px";style.left=left;elem.runtimeStyle.left=rsLeft;}}return ret;},clean:function(elems,context){var ret=[];context=context||document;if(typeof context.createElement=='undefined')context=context.ownerDocument||context[0]&&context[0].ownerDocument||document;jQuery.each(elems,function(i,elem){if(!elem)return;if(elem.constructor==Number)elem+='';if(typeof elem=="string"){elem=elem.replace(/(<(\w+)[^>]*?)\/>/g,function(all,front,tag){return tag.match(/^(abbr|br|col|img|input|link|meta|param|hr|area|embed)$/i)?all:front+"></"+tag+">";});var tags=jQuery.trim(elem).toLowerCase(),div=context.createElement("div");var wrap=!tags.indexOf("<opt")&&[1,"<select multiple='multiple'>","</select>"]||!tags.indexOf("<leg")&&[1,"<fieldset>","</fieldset>"]||tags.match(/^<(thead|tbody|tfoot|colg|cap)/)&&[1,"<table>","</table>"]||!tags.indexOf("<tr")&&[2,"<table><tbody>","</tbody></table>"]||(!tags.indexOf("<td")||!tags.indexOf("<th"))&&[3,"<table><tbody><tr>","</tr></tbody></table>"]||!tags.indexOf("<col")&&[2,"<table><tbody></tbody><colgroup>","</colgroup></table>"]||jQuery.browser.msie&&[1,"div<div>","</div>"]||[0,"",""];div.innerHTML=wrap[1]+elem+wrap[2];while(wrap[0]--)div=div.lastChild;if(jQuery.browser.msie){var tbody=!tags.indexOf("<table")&&tags.indexOf("<tbody")<0?div.firstChild&&div.firstChild.childNodes:wrap[1]=="<table>"&&tags.indexOf("<tbody")<0?div.childNodes:[];for(var j=tbody.length-1;j>=0;--j)if(jQuery.nodeName(tbody[j],"tbody")&&!tbody[j].childNodes.length)tbody[j].parentNode.removeChild(tbody[j]);if(/^\s/.test(elem))div.insertBefore(context.createTextNode(elem.match(/^\s*/)[0]),div.firstChild);}elem=jQuery.makeArray(div.childNodes);}if(elem.length===0&&(!jQuery.nodeName(elem,"form")&&!jQuery.nodeName(elem,"select")))return;if(elem[0]==undefined||jQuery.nodeName(elem,"form")||elem.options)ret.push(elem);else
+ret=jQuery.merge(ret,elem);});return ret;},attr:function(elem,name,value){if(!elem||elem.nodeType==3||elem.nodeType==8)return undefined;var notxml=!jQuery.isXMLDoc(elem),set=value!==undefined,msie=jQuery.browser.msie;name=notxml&&jQuery.props[name]||name;if(elem.tagName){var special=/href|src|style/.test(name);if(name=="selected"&&jQuery.browser.safari)elem.parentNode.selectedIndex;if(name in elem&&notxml&&!special){if(set){if(name=="type"&&jQuery.nodeName(elem,"input")&&elem.parentNode)throw"type property can't be changed";elem[name]=value;}if(jQuery.nodeName(elem,"form")&&elem.getAttributeNode(name))return elem.getAttributeNode(name).nodeValue;return elem[name];}if(msie&&notxml&&name=="style")return jQuery.attr(elem.style,"cssText",value);if(set)elem.setAttribute(name,""+value);var attr=msie&&notxml&&special?elem.getAttribute(name,2):elem.getAttribute(name);return attr===null?undefined:attr;}if(msie&&name=="opacity"){if(set){elem.zoom=1;elem.filter=(elem.filter||"").replace(/alpha\([^)]*\)/,"")+(parseInt(value)+''=="NaN"?"":"alpha(opacity="+value*100+")");}return elem.filter&&elem.filter.indexOf("opacity=")>=0?(parseFloat(elem.filter.match(/opacity=([^)]*)/)[1])/100)+'':"";}name=name.replace(/-([a-z])/ig,function(all,letter){return letter.toUpperCase();});if(set)elem[name]=value;return elem[name];},trim:function(text){return(text||"").replace(/^\s+|\s+$/g,"");},makeArray:function(array){var ret=[];if(array!=null){var i=array.length;if(i==null||array.split||array.setInterval||array.call)ret[0]=array;else
+while(i)ret[--i]=array[i];}return ret;},inArray:function(elem,array){for(var i=0,length=array.length;i<length;i++)if(array[i]===elem)return i;return-1;},merge:function(first,second){var i=0,elem,pos=first.length;if(jQuery.browser.msie){while(elem=second[i++])if(elem.nodeType!=8)first[pos++]=elem;}else
+while(elem=second[i++])first[pos++]=elem;return first;},unique:function(array){var ret=[],done={};try{for(var i=0,length=array.length;i<length;i++){var id=jQuery.data(array[i]);if(!done[id]){done[id]=true;ret.push(array[i]);}}}catch(e){ret=array;}return ret;},grep:function(elems,callback,inv){var ret=[];for(var i=0,length=elems.length;i<length;i++)if(!inv!=!callback(elems[i],i))ret.push(elems[i]);return ret;},map:function(elems,callback){var ret=[];for(var i=0,length=elems.length;i<length;i++){var value=callback(elems[i],i);if(value!=null)ret[ret.length]=value;}return ret.concat.apply([],ret);}});var userAgent=navigator.userAgent.toLowerCase();jQuery.browser={version:(userAgent.match(/.+(?:rv|it|ra|ie)[\/: ]([\d.]+)/)||[])[1],safari:/webkit/.test(userAgent),opera:/opera/.test(userAgent),msie:/msie/.test(userAgent)&&!/opera/.test(userAgent),mozilla:/mozilla/.test(userAgent)&&!/(compatible|webkit)/.test(userAgent)};var styleFloat=jQuery.browser.msie?"styleFloat":"cssFloat";jQuery.extend({boxModel:!jQuery.browser.msie||document.compatMode=="CSS1Compat",props:{"for":"htmlFor","class":"className","float":styleFloat,cssFloat:styleFloat,styleFloat:styleFloat,readonly:"readOnly",maxlength:"maxLength",cellspacing:"cellSpacing"}});jQuery.each({parent:function(elem){return elem.parentNode;},parents:function(elem){return jQuery.dir(elem,"parentNode");},next:function(elem){return jQuery.nth(elem,2,"nextSibling");},prev:function(elem){return jQuery.nth(elem,2,"previousSibling");},nextAll:function(elem){return jQuery.dir(elem,"nextSibling");},prevAll:function(elem){return jQuery.dir(elem,"previousSibling");},siblings:function(elem){return jQuery.sibling(elem.parentNode.firstChild,elem);},children:function(elem){return jQuery.sibling(elem.firstChild);},contents:function(elem){return jQuery.nodeName(elem,"iframe")?elem.contentDocument||elem.contentWindow.document:jQuery.makeArray(elem.childNodes);}},function(name,fn){jQuery.fn[name]=function(selector){var ret=jQuery.map(this,fn);if(selector&&typeof selector=="string")ret=jQuery.multiFilter(selector,ret);return this.pushStack(jQuery.unique(ret));};});jQuery.each({appendTo:"append",prependTo:"prepend",insertBefore:"before",insertAfter:"after",replaceAll:"replaceWith"},function(name,original){jQuery.fn[name]=function(){var args=arguments;return this.each(function(){for(var i=0,length=args.length;i<length;i++)jQuery(args[i])[original](this);});};});jQuery.each({removeAttr:function(name){jQuery.attr(this,name,"");if(this.nodeType==1)this.removeAttribute(name);},addClass:function(classNames){jQuery.className.add(this,classNames);},removeClass:function(classNames){jQuery.className.remove(this,classNames);},toggleClass:function(classNames){jQuery.className[jQuery.className.has(this,classNames)?"remove":"add"](this,classNames);},remove:function(selector){if(!selector||jQuery.filter(selector,[this]).r.length){jQuery("*",this).add(this).each(function(){jQuery.event.remove(this);jQuery.removeData(this);});if(this.parentNode)this.parentNode.removeChild(this);}},empty:function(){jQuery(">*",this).remove();while(this.firstChild)this.removeChild(this.firstChild);}},function(name,fn){jQuery.fn[name]=function(){return this.each(fn,arguments);};});jQuery.each(["Height","Width"],function(i,name){var type=name.toLowerCase();jQuery.fn[type]=function(size){return this[0]==window?jQuery.browser.opera&&document.body["client"+name]||jQuery.browser.safari&&window["inner"+name]||document.compatMode=="CSS1Compat"&&document.documentElement["client"+name]||document.body["client"+name]:this[0]==document?Math.max(Math.max(document.body["scroll"+name],document.documentElement["scroll"+name]),Math.max(document.body["offset"+name],document.documentElement["offset"+name])):size==undefined?(this.length?jQuery.css(this[0],type):null):this.css(type,size.constructor==String?size:size+"px");};});function num(elem,prop){return elem[0]&&parseInt(jQuery.curCSS(elem[0],prop,true),10)||0;}var chars=jQuery.browser.safari&&parseInt(jQuery.browser.version)<417?"(?:[\\w*_-]|\\\\.)":"(?:[\\w\u0128-\uFFFF*_-]|\\\\.)",quickChild=new RegExp("^>\\s*("+chars+"+)"),quickID=new RegExp("^("+chars+"+)(#)("+chars+"+)"),quickClass=new RegExp("^([#.]?)("+chars+"*)");jQuery.extend({expr:{"":function(a,i,m){return m[2]=="*"||jQuery.nodeName(a,m[2]);},"#":function(a,i,m){return a.getAttribute("id")==m[2];},":":{lt:function(a,i,m){return i<m[3]-0;},gt:function(a,i,m){return i>m[3]-0;},nth:function(a,i,m){return m[3]-0==i;},eq:function(a,i,m){return m[3]-0==i;},first:function(a,i){return i==0;},last:function(a,i,m,r){return i==r.length-1;},even:function(a,i){return i%2==0;},odd:function(a,i){return i%2;},"first-child":function(a){return a.parentNode.getElementsByTagName("*")[0]==a;},"last-child":function(a){return jQuery.nth(a.parentNode.lastChild,1,"previousSibling")==a;},"only-child":function(a){return!jQuery.nth(a.parentNode.lastChild,2,"previousSibling");},parent:function(a){return a.firstChild;},empty:function(a){return!a.firstChild;},contains:function(a,i,m){return(a.textContent||a.innerText||jQuery(a).text()||"").indexOf(m[3])>=0;},visible:function(a){return"hidden"!=a.type&&jQuery.css(a,"display")!="none"&&jQuery.css(a,"visibility")!="hidden";},hidden:function(a){return"hidden"==a.type||jQuery.css(a,"display")=="none"||jQuery.css(a,"visibility")=="hidden";},enabled:function(a){return!a.disabled;},disabled:function(a){return a.disabled;},checked:function(a){return a.checked;},selected:function(a){return a.selected||jQuery.attr(a,"selected");},text:function(a){return"text"==a.type;},radio:function(a){return"radio"==a.type;},checkbox:function(a){return"checkbox"==a.type;},file:function(a){return"file"==a.type;},password:function(a){return"password"==a.type;},submit:function(a){return"submit"==a.type;},image:function(a){return"image"==a.type;},reset:function(a){return"reset"==a.type;},button:function(a){return"button"==a.type||jQuery.nodeName(a,"button");},input:function(a){return/input|select|textarea|button/i.test(a.nodeName);},has:function(a,i,m){return jQuery.find(m[3],a).length;},header:function(a){return/h\d/i.test(a.nodeName);},animated:function(a){return jQuery.grep(jQuery.timers,function(fn){return a==fn.elem;}).length;}}},parse:[/^(\[) *@?([\w-]+) *([!*$^~=]*) *('?"?)(.*?)\4 *\]/,/^(:)([\w-]+)\("?'?(.*?(\(.*?\))?[^(]*?)"?'?\)/,new RegExp("^([:.#]*)("+chars+"+)")],multiFilter:function(expr,elems,not){var old,cur=[];while(expr&&expr!=old){old=expr;var f=jQuery.filter(expr,elems,not);expr=f.t.replace(/^\s*,\s*/,"");cur=not?elems=f.r:jQuery.merge(cur,f.r);}return cur;},find:function(t,context){if(typeof t!="string")return[t];if(context&&context.nodeType!=1&&context.nodeType!=9)return[];context=context||document;var ret=[context],done=[],last,nodeName;while(t&&last!=t){var r=[];last=t;t=jQuery.trim(t);var foundToken=false,re=quickChild,m=re.exec(t);if(m){nodeName=m[1].toUpperCase();for(var i=0;ret[i];i++)for(var c=ret[i].firstChild;c;c=c.nextSibling)if(c.nodeType==1&&(nodeName=="*"||c.nodeName.toUpperCase()==nodeName))r.push(c);ret=r;t=t.replace(re,"");if(t.indexOf(" ")==0)continue;foundToken=true;}else{re=/^([>+~])\s*(\w*)/i;if((m=re.exec(t))!=null){r=[];var merge={};nodeName=m[2].toUpperCase();m=m[1];for(var j=0,rl=ret.length;j<rl;j++){var n=m=="~"||m=="+"?ret[j].nextSibling:ret[j].firstChild;for(;n;n=n.nextSibling)if(n.nodeType==1){var id=jQuery.data(n);if(m=="~"&&merge[id])break;if(!nodeName||n.nodeName.toUpperCase()==nodeName){if(m=="~")merge[id]=true;r.push(n);}if(m=="+")break;}}ret=r;t=jQuery.trim(t.replace(re,""));foundToken=true;}}if(t&&!foundToken){if(!t.indexOf(",")){if(context==ret[0])ret.shift();done=jQuery.merge(done,ret);r=ret=[context];t=" "+t.substr(1,t.length);}else{var re2=quickID;var m=re2.exec(t);if(m){m=[0,m[2],m[3],m[1]];}else{re2=quickClass;m=re2.exec(t);}m[2]=m[2].replace(/\\/g,"");var elem=ret[ret.length-1];if(m[1]=="#"&&elem&&elem.getElementById&&!jQuery.isXMLDoc(elem)){var oid=elem.getElementById(m[2]);if((jQuery.browser.msie||jQuery.browser.opera)&&oid&&typeof oid.id=="string"&&oid.id!=m[2])oid=jQuery('[@id="'+m[2]+'"]',elem)[0];ret=r=oid&&(!m[3]||jQuery.nodeName(oid,m[3]))?[oid]:[];}else{for(var i=0;ret[i];i++){var tag=m[1]=="#"&&m[3]?m[3]:m[1]!=""||m[0]==""?"*":m[2];if(tag=="*"&&ret[i].nodeName.toLowerCase()=="object")tag="param";r=jQuery.merge(r,ret[i].getElementsByTagName(tag));}if(m[1]==".")r=jQuery.classFilter(r,m[2]);if(m[1]=="#"){var tmp=[];for(var i=0;r[i];i++)if(r[i].getAttribute("id")==m[2]){tmp=[r[i]];break;}r=tmp;}ret=r;}t=t.replace(re2,"");}}if(t){var val=jQuery.filter(t,r);ret=r=val.r;t=jQuery.trim(val.t);}}if(t)ret=[];if(ret&&context==ret[0])ret.shift();done=jQuery.merge(done,ret);return done;},classFilter:function(r,m,not){m=" "+m+" ";var tmp=[];for(var i=0;r[i];i++){var pass=(" "+r[i].className+" ").indexOf(m)>=0;if(!not&&pass||not&&!pass)tmp.push(r[i]);}return tmp;},filter:function(t,r,not){var last;while(t&&t!=last){last=t;var p=jQuery.parse,m;for(var i=0;p[i];i++){m=p[i].exec(t);if(m){t=t.substring(m[0].length);m[2]=m[2].replace(/\\/g,"");break;}}if(!m)break;if(m[1]==":"&&m[2]=="not")r=isSimple.test(m[3])?jQuery.filter(m[3],r,true).r:jQuery(r).not(m[3]);else if(m[1]==".")r=jQuery.classFilter(r,m[2],not);else if(m[1]=="["){var tmp=[],type=m[3];for(var i=0,rl=r.length;i<rl;i++){var a=r[i],z=a[jQuery.props[m[2]]||m[2]];if(z==null||/href|src|selected/.test(m[2]))z=jQuery.attr(a,m[2])||'';if((type==""&&!!z||type=="="&&z==m[5]||type=="!="&&z!=m[5]||type=="^="&&z&&!z.indexOf(m[5])||type=="$="&&z.substr(z.length-m[5].length)==m[5]||(type=="*="||type=="~=")&&z.indexOf(m[5])>=0)^not)tmp.push(a);}r=tmp;}else if(m[1]==":"&&m[2]=="nth-child"){var merge={},tmp=[],test=/(-?)(\d*)n((?:\+|-)?\d*)/.exec(m[3]=="even"&&"2n"||m[3]=="odd"&&"2n+1"||!/\D/.test(m[3])&&"0n+"+m[3]||m[3]),first=(test[1]+(test[2]||1))-0,last=test[3]-0;for(var i=0,rl=r.length;i<rl;i++){var node=r[i],parentNode=node.parentNode,id=jQuery.data(parentNode);if(!merge[id]){var c=1;for(var n=parentNode.firstChild;n;n=n.nextSibling)if(n.nodeType==1)n.nodeIndex=c++;merge[id]=true;}var add=false;if(first==0){if(node.nodeIndex==last)add=true;}else if((node.nodeIndex-last)%first==0&&(node.nodeIndex-last)/first>=0)add=true;if(add^not)tmp.push(node);}r=tmp;}else{var fn=jQuery.expr[m[1]];if(typeof fn=="object")fn=fn[m[2]];if(typeof fn=="string")fn=eval("false||function(a,i){return "+fn+";}");r=jQuery.grep(r,function(elem,i){return fn(elem,i,m,r);},not);}}return{r:r,t:t};},dir:function(elem,dir){var matched=[],cur=elem[dir];while(cur&&cur!=document){if(cur.nodeType==1)matched.push(cur);cur=cur[dir];}return matched;},nth:function(cur,result,dir,elem){result=result||1;var num=0;for(;cur;cur=cur[dir])if(cur.nodeType==1&&++num==result)break;return cur;},sibling:function(n,elem){var r=[];for(;n;n=n.nextSibling){if(n.nodeType==1&&n!=elem)r.push(n);}return r;}});jQuery.event={add:function(elem,types,handler,data){if(elem.nodeType==3||elem.nodeType==8)return;if(jQuery.browser.msie&&elem.setInterval)elem=window;if(!handler.guid)handler.guid=this.guid++;if(data!=undefined){var fn=handler;handler=this.proxy(fn,function(){return fn.apply(this,arguments);});handler.data=data;}var events=jQuery.data(elem,"events")||jQuery.data(elem,"events",{}),handle=jQuery.data(elem,"handle")||jQuery.data(elem,"handle",function(){if(typeof jQuery!="undefined"&&!jQuery.event.triggered)return jQuery.event.handle.apply(arguments.callee.elem,arguments);});handle.elem=elem;jQuery.each(types.split(/\s+/),function(index,type){var parts=type.split(".");type=parts[0];handler.type=parts[1];var handlers=events[type];if(!handlers){handlers=events[type]={};if(!jQuery.event.special[type]||jQuery.event.special[type].setup.call(elem)===false){if(elem.addEventListener)elem.addEventListener(type,handle,false);else if(elem.attachEvent)elem.attachEvent("on"+type,handle);}}handlers[handler.guid]=handler;jQuery.event.global[type]=true;});elem=null;},guid:1,global:{},remove:function(elem,types,handler){if(elem.nodeType==3||elem.nodeType==8)return;var events=jQuery.data(elem,"events"),ret,index;if(events){if(types==undefined||(typeof types=="string"&&types.charAt(0)=="."))for(var type in events)this.remove(elem,type+(types||""));else{if(types.type){handler=types.handler;types=types.type;}jQuery.each(types.split(/\s+/),function(index,type){var parts=type.split(".");type=parts[0];if(events[type]){if(handler)delete events[type][handler.guid];else
+for(handler in events[type])if(!parts[1]||events[type][handler].type==parts[1])delete events[type][handler];for(ret in events[type])break;if(!ret){if(!jQuery.event.special[type]||jQuery.event.special[type].teardown.call(elem)===false){if(elem.removeEventListener)elem.removeEventListener(type,jQuery.data(elem,"handle"),false);else if(elem.detachEvent)elem.detachEvent("on"+type,jQuery.data(elem,"handle"));}ret=null;delete events[type];}}});}for(ret in events)break;if(!ret){var handle=jQuery.data(elem,"handle");if(handle)handle.elem=null;jQuery.removeData(elem,"events");jQuery.removeData(elem,"handle");}}},trigger:function(type,data,elem,donative,extra){data=jQuery.makeArray(data);if(type.indexOf("!")>=0){type=type.slice(0,-1);var exclusive=true;}if(!elem){if(this.global[type])jQuery("*").add([window,document]).trigger(type,data);}else{if(elem.nodeType==3||elem.nodeType==8)return undefined;var val,ret,fn=jQuery.isFunction(elem[type]||null),event=!data[0]||!data[0].preventDefault;if(event){data.unshift({type:type,target:elem,preventDefault:function(){},stopPropagation:function(){},timeStamp:now()});data[0][expando]=true;}data[0].type=type;if(exclusive)data[0].exclusive=true;var handle=jQuery.data(elem,"handle");if(handle)val=handle.apply(elem,data);if((!fn||(jQuery.nodeName(elem,'a')&&type=="click"))&&elem["on"+type]&&elem["on"+type].apply(elem,data)===false)val=false;if(event)data.shift();if(extra&&jQuery.isFunction(extra)){ret=extra.apply(elem,val==null?data:data.concat(val));if(ret!==undefined)val=ret;}if(fn&&donative!==false&&val!==false&&!(jQuery.nodeName(elem,'a')&&type=="click")){this.triggered=true;try{elem[type]();}catch(e){}}this.triggered=false;}return val;},handle:function(event){var val,ret,namespace,all,handlers;event=arguments[0]=jQuery.event.fix(event||window.event);namespace=event.type.split(".");event.type=namespace[0];namespace=namespace[1];all=!namespace&&!event.exclusive;handlers=(jQuery.data(this,"events")||{})[event.type];for(var j in handlers){var handler=handlers[j];if(all||handler.type==namespace){event.handler=handler;event.data=handler.data;ret=handler.apply(this,arguments);if(val!==false)val=ret;if(ret===false){event.preventDefault();event.stopPropagation();}}}return val;},fix:function(event){if(event[expando]==true)return event;var originalEvent=event;event={originalEvent:originalEvent};var props="altKey attrChange attrName bubbles button cancelable charCode clientX clientY ctrlKey currentTarget data detail eventPhase fromElement handler keyCode metaKey newValue originalTarget pageX pageY prevValue relatedNode relatedTarget screenX screenY shiftKey srcElement target timeStamp toElement type view wheelDelta which".split(" ");for(var i=props.length;i;i--)event[props[i]]=originalEvent[props[i]];event[expando]=true;event.preventDefault=function(){if(originalEvent.preventDefault)originalEvent.preventDefault();originalEvent.returnValue=false;};event.stopPropagation=function(){if(originalEvent.stopPropagation)originalEvent.stopPropagation();originalEvent.cancelBubble=true;};event.timeStamp=event.timeStamp||now();if(!event.target)event.target=event.srcElement||document;if(event.target.nodeType==3)event.target=event.target.parentNode;if(!event.relatedTarget&&event.fromElement)event.relatedTarget=event.fromElement==event.target?event.toElement:event.fromElement;if(event.pageX==null&&event.clientX!=null){var doc=document.documentElement,body=document.body;event.pageX=event.clientX+(doc&&doc.scrollLeft||body&&body.scrollLeft||0)-(doc.clientLeft||0);event.pageY=event.clientY+(doc&&doc.scrollTop||body&&body.scrollTop||0)-(doc.clientTop||0);}if(!event.which&&((event.charCode||event.charCode===0)?event.charCode:event.keyCode))event.which=event.charCode||event.keyCode;if(!event.metaKey&&event.ctrlKey)event.metaKey=event.ctrlKey;if(!event.which&&event.button)event.which=(event.button&1?1:(event.button&2?3:(event.button&4?2:0)));return event;},proxy:function(fn,proxy){proxy.guid=fn.guid=fn.guid||proxy.guid||this.guid++;return proxy;},special:{ready:{setup:function(){bindReady();return;},teardown:function(){return;}},mouseenter:{setup:function(){if(jQuery.browser.msie)return false;jQuery(this).bind("mouseover",jQuery.event.special.mouseenter.handler);return true;},teardown:function(){if(jQuery.browser.msie)return false;jQuery(this).unbind("mouseover",jQuery.event.special.mouseenter.handler);return true;},handler:function(event){if(withinElement(event,this))return true;event.type="mouseenter";return jQuery.event.handle.apply(this,arguments);}},mouseleave:{setup:function(){if(jQuery.browser.msie)return false;jQuery(this).bind("mouseout",jQuery.event.special.mouseleave.handler);return true;},teardown:function(){if(jQuery.browser.msie)return false;jQuery(this).unbind("mouseout",jQuery.event.special.mouseleave.handler);return true;},handler:function(event){if(withinElement(event,this))return true;event.type="mouseleave";return jQuery.event.handle.apply(this,arguments);}}}};jQuery.fn.extend({bind:function(type,data,fn){return type=="unload"?this.one(type,data,fn):this.each(function(){jQuery.event.add(this,type,fn||data,fn&&data);});},one:function(type,data,fn){var one=jQuery.event.proxy(fn||data,function(event){jQuery(this).unbind(event,one);return(fn||data).apply(this,arguments);});return this.each(function(){jQuery.event.add(this,type,one,fn&&data);});},unbind:function(type,fn){return this.each(function(){jQuery.event.remove(this,type,fn);});},trigger:function(type,data,fn){return this.each(function(){jQuery.event.trigger(type,data,this,true,fn);});},triggerHandler:function(type,data,fn){return this[0]&&jQuery.event.trigger(type,data,this[0],false,fn);},toggle:function(fn){var args=arguments,i=1;while(i<args.length)jQuery.event.proxy(fn,args[i++]);return this.click(jQuery.event.proxy(fn,function(event){this.lastToggle=(this.lastToggle||0)%i;event.preventDefault();return args[this.lastToggle++].apply(this,arguments)||false;}));},hover:function(fnOver,fnOut){return this.bind('mouseenter',fnOver).bind('mouseleave',fnOut);},ready:function(fn){bindReady();if(jQuery.isReady)fn.call(document,jQuery);else
+jQuery.readyList.push(function(){return fn.call(this,jQuery);});return this;}});jQuery.extend({isReady:false,readyList:[],ready:function(){if(!jQuery.isReady){jQuery.isReady=true;if(jQuery.readyList){jQuery.each(jQuery.readyList,function(){this.call(document);});jQuery.readyList=null;}jQuery(document).triggerHandler("ready");}}});var readyBound=false;function bindReady(){if(readyBound)return;readyBound=true;if(document.addEventListener&&!jQuery.browser.opera)document.addEventListener("DOMContentLoaded",jQuery.ready,false);if(jQuery.browser.msie&&window==top)(function(){if(jQuery.isReady)return;try{document.documentElement.doScroll("left");}catch(error){setTimeout(arguments.callee,0);return;}jQuery.ready();})();if(jQuery.browser.opera)document.addEventListener("DOMContentLoaded",function(){if(jQuery.isReady)return;for(var i=0;i<document.styleSheets.length;i++)if(document.styleSheets[i].disabled){setTimeout(arguments.callee,0);return;}jQuery.ready();},false);if(jQuery.browser.safari){var numStyles;(function(){if(jQuery.isReady)return;if(document.readyState!="loaded"&&document.readyState!="complete"){setTimeout(arguments.callee,0);return;}if(numStyles===undefined)numStyles=jQuery("style, link[rel=stylesheet]").length;if(document.styleSheets.length!=numStyles){setTimeout(arguments.callee,0);return;}jQuery.ready();})();}jQuery.event.add(window,"load",jQuery.ready);}jQuery.each(("blur,focus,load,resize,scroll,unload,click,dblclick,"+"mousedown,mouseup,mousemove,mouseover,mouseout,change,select,"+"submit,keydown,keypress,keyup,error").split(","),function(i,name){jQuery.fn[name]=function(fn){return fn?this.bind(name,fn):this.trigger(name);};});var withinElement=function(event,elem){var parent=event.relatedTarget;while(parent&&parent!=elem)try{parent=parent.parentNode;}catch(error){parent=elem;}return parent==elem;};jQuery(window).bind("unload",function(){jQuery("*").add(document).unbind();});jQuery.fn.extend({_load:jQuery.fn.load,load:function(url,params,callback){if(typeof url!='string')return this._load(url);var off=url.indexOf(" ");if(off>=0){var selector=url.slice(off,url.length);url=url.slice(0,off);}callback=callback||function(){};var type="GET";if(params)if(jQuery.isFunction(params)){callback=params;params=null;}else{params=jQuery.param(params);type="POST";}var self=this;jQuery.ajax({url:url,type:type,dataType:"html",data:params,complete:function(res,status){if(status=="success"||status=="notmodified")self.html(selector?jQuery("<div/>").append(res.responseText.replace(/<script(.|\s)*?\/script>/g,"")).find(selector):res.responseText);self.each(callback,[res.responseText,status,res]);}});return this;},serialize:function(){return jQuery.param(this.serializeArray());},serializeArray:function(){return this.map(function(){return jQuery.nodeName(this,"form")?jQuery.makeArray(this.elements):this;}).filter(function(){return this.name&&!this.disabled&&(this.checked||/select|textarea/i.test(this.nodeName)||/text|hidden|password/i.test(this.type));}).map(function(i,elem){var val=jQuery(this).val();return val==null?null:val.constructor==Array?jQuery.map(val,function(val,i){return{name:elem.name,value:val};}):{name:elem.name,value:val};}).get();}});jQuery.each("ajaxStart,ajaxStop,ajaxComplete,ajaxError,ajaxSuccess,ajaxSend".split(","),function(i,o){jQuery.fn[o]=function(f){return this.bind(o,f);};});var jsc=now();jQuery.extend({get:function(url,data,callback,type){if(jQuery.isFunction(data)){callback=data;data=null;}return jQuery.ajax({type:"GET",url:url,data:data,success:callback,dataType:type});},getScript:function(url,callback){return jQuery.get(url,null,callback,"script");},getJSON:function(url,data,callback){return jQuery.get(url,data,callback,"json");},post:function(url,data,callback,type){if(jQuery.isFunction(data)){callback=data;data={};}return jQuery.ajax({type:"POST",url:url,data:data,success:callback,dataType:type});},ajaxSetup:function(settings){jQuery.extend(jQuery.ajaxSettings,settings);},ajaxSettings:{url:location.href,global:true,type:"GET",timeout:0,contentType:"application/x-www-form-urlencoded",processData:true,async:true,data:null,username:null,password:null,accepts:{xml:"application/xml, text/xml",html:"text/html",script:"text/javascript, application/javascript",json:"application/json, text/javascript",text:"text/plain",_default:"*/*"}},lastModified:{},ajax:function(s){s=jQuery.extend(true,s,jQuery.extend(true,{},jQuery.ajaxSettings,s));var jsonp,jsre=/=\?(&|$)/g,status,data,type=s.type.toUpperCase();if(s.data&&s.processData&&typeof s.data!="string")s.data=jQuery.param(s.data);if(s.dataType=="jsonp"){if(type=="GET"){if(!s.url.match(jsre))s.url+=(s.url.match(/\?/)?"&":"?")+(s.jsonp||"callback")+"=?";}else if(!s.data||!s.data.match(jsre))s.data=(s.data?s.data+"&":"")+(s.jsonp||"callback")+"=?";s.dataType="json";}if(s.dataType=="json"&&(s.data&&s.data.match(jsre)||s.url.match(jsre))){jsonp="jsonp"+jsc++;if(s.data)s.data=(s.data+"").replace(jsre,"="+jsonp+"$1");s.url=s.url.replace(jsre,"="+jsonp+"$1");s.dataType="script";window[jsonp]=function(tmp){data=tmp;success();complete();window[jsonp]=undefined;try{delete window[jsonp];}catch(e){}if(head)head.removeChild(script);};}if(s.dataType=="script"&&s.cache==null)s.cache=false;if(s.cache===false&&type=="GET"){var ts=now();var ret=s.url.replace(/(\?|&)_=.*?(&|$)/,"$1_="+ts+"$2");s.url=ret+((ret==s.url)?(s.url.match(/\?/)?"&":"?")+"_="+ts:"");}if(s.data&&type=="GET"){s.url+=(s.url.match(/\?/)?"&":"?")+s.data;s.data=null;}if(s.global&&!jQuery.active++)jQuery.event.trigger("ajaxStart");var remote=/^(?:\w+:)?\/\/([^\/?#]+)/;if(s.dataType=="script"&&type=="GET"&&remote.test(s.url)&&remote.exec(s.url)[1]!=location.host){var head=document.getElementsByTagName("head")[0];var script=document.createElement("script");script.src=s.url;if(s.scriptCharset)script.charset=s.scriptCharset;if(!jsonp){var done=false;script.onload=script.onreadystatechange=function(){if(!done&&(!this.readyState||this.readyState=="loaded"||this.readyState=="complete")){done=true;success();complete();head.removeChild(script);}};}head.appendChild(script);return undefined;}var requestDone=false;var xhr=window.ActiveXObject?new ActiveXObject("Microsoft.XMLHTTP"):new XMLHttpRequest();if(s.username)xhr.open(type,s.url,s.async,s.username,s.password);else
+xhr.open(type,s.url,s.async);try{if(s.data)xhr.setRequestHeader("Content-Type",s.contentType);if(s.ifModified)xhr.setRequestHeader("If-Modified-Since",jQuery.lastModified[s.url]||"Thu, 01 Jan 1970 00:00:00 GMT");xhr.setRequestHeader("X-Requested-With","XMLHttpRequest");xhr.setRequestHeader("Accept",s.dataType&&s.accepts[s.dataType]?s.accepts[s.dataType]+", */*":s.accepts._default);}catch(e){}if(s.beforeSend&&s.beforeSend(xhr,s)===false){s.global&&jQuery.active--;xhr.abort();return false;}if(s.global)jQuery.event.trigger("ajaxSend",[xhr,s]);var onreadystatechange=function(isTimeout){if(!requestDone&&xhr&&(xhr.readyState==4||isTimeout=="timeout")){requestDone=true;if(ival){clearInterval(ival);ival=null;}status=isTimeout=="timeout"&&"timeout"||!jQuery.httpSuccess(xhr)&&"error"||s.ifModified&&jQuery.httpNotModified(xhr,s.url)&&"notmodified"||"success";if(status=="success"){try{data=jQuery.httpData(xhr,s.dataType,s.dataFilter);}catch(e){status="parsererror";}}if(status=="success"){var modRes;try{modRes=xhr.getResponseHeader("Last-Modified");}catch(e){}if(s.ifModified&&modRes)jQuery.lastModified[s.url]=modRes;if(!jsonp)success();}else
+jQuery.handleError(s,xhr,status);complete();if(s.async)xhr=null;}};if(s.async){var ival=setInterval(onreadystatechange,13);if(s.timeout>0)setTimeout(function(){if(xhr){xhr.abort();if(!requestDone)onreadystatechange("timeout");}},s.timeout);}try{xhr.send(s.data);}catch(e){jQuery.handleError(s,xhr,null,e);}if(!s.async)onreadystatechange();function success(){if(s.success)s.success(data,status);if(s.global)jQuery.event.trigger("ajaxSuccess",[xhr,s]);}function complete(){if(s.complete)s.complete(xhr,status);if(s.global)jQuery.event.trigger("ajaxComplete",[xhr,s]);if(s.global&&!--jQuery.active)jQuery.event.trigger("ajaxStop");}return xhr;},handleError:function(s,xhr,status,e){if(s.error)s.error(xhr,status,e);if(s.global)jQuery.event.trigger("ajaxError",[xhr,s,e]);},active:0,httpSuccess:function(xhr){try{return!xhr.status&&location.protocol=="file:"||(xhr.status>=200&&xhr.status<300)||xhr.status==304||xhr.status==1223||jQuery.browser.safari&&xhr.status==undefined;}catch(e){}return false;},httpNotModified:function(xhr,url){try{var xhrRes=xhr.getResponseHeader("Last-Modified");return xhr.status==304||xhrRes==jQuery.lastModified[url]||jQuery.browser.safari&&xhr.status==undefined;}catch(e){}return false;},httpData:function(xhr,type,filter){var ct=xhr.getResponseHeader("content-type"),xml=type=="xml"||!type&&ct&&ct.indexOf("xml")>=0,data=xml?xhr.responseXML:xhr.responseText;if(xml&&data.documentElement.tagName=="parsererror")throw"parsererror";if(filter)data=filter(data,type);if(type=="script")jQuery.globalEval(data);if(type=="json")data=eval("("+data+")");return data;},param:function(a){var s=[];if(a.constructor==Array||a.jquery)jQuery.each(a,function(){s.push(encodeURIComponent(this.name)+"="+encodeURIComponent(this.value));});else
+for(var j in a)if(a[j]&&a[j].constructor==Array)jQuery.each(a[j],function(){s.push(encodeURIComponent(j)+"="+encodeURIComponent(this));});else
+s.push(encodeURIComponent(j)+"="+encodeURIComponent(jQuery.isFunction(a[j])?a[j]():a[j]));return s.join("&").replace(/%20/g,"+");}});jQuery.fn.extend({show:function(speed,callback){return speed?this.animate({height:"show",width:"show",opacity:"show"},speed,callback):this.filter(":hidden").each(function(){this.style.display=this.oldblock||"";if(jQuery.css(this,"display")=="none"){var elem=jQuery("<"+this.tagName+" />").appendTo("body");this.style.display=elem.css("display");if(this.style.display=="none")this.style.display="block";elem.remove();}}).end();},hide:function(speed,callback){return speed?this.animate({height:"hide",width:"hide",opacity:"hide"},speed,callback):this.filter(":visible").each(function(){this.oldblock=this.oldblock||jQuery.css(this,"display");this.style.display="none";}).end();},_toggle:jQuery.fn.toggle,toggle:function(fn,fn2){return jQuery.isFunction(fn)&&jQuery.isFunction(fn2)?this._toggle.apply(this,arguments):fn?this.animate({height:"toggle",width:"toggle",opacity:"toggle"},fn,fn2):this.each(function(){jQuery(this)[jQuery(this).is(":hidden")?"show":"hide"]();});},slideDown:function(speed,callback){return this.animate({height:"show"},speed,callback);},slideUp:function(speed,callback){return this.animate({height:"hide"},speed,callback);},slideToggle:function(speed,callback){return this.animate({height:"toggle"},speed,callback);},fadeIn:function(speed,callback){return this.animate({opacity:"show"},speed,callback);},fadeOut:function(speed,callback){return this.animate({opacity:"hide"},speed,callback);},fadeTo:function(speed,to,callback){return this.animate({opacity:to},speed,callback);},animate:function(prop,speed,easing,callback){var optall=jQuery.speed(speed,easing,callback);return this[optall.queue===false?"each":"queue"](function(){if(this.nodeType!=1)return false;var opt=jQuery.extend({},optall),p,hidden=jQuery(this).is(":hidden"),self=this;for(p in prop){if(prop[p]=="hide"&&hidden||prop[p]=="show"&&!hidden)return opt.complete.call(this);if(p=="height"||p=="width"){opt.display=jQuery.css(this,"display");opt.overflow=this.style.overflow;}}if(opt.overflow!=null)this.style.overflow="hidden";opt.curAnim=jQuery.extend({},prop);jQuery.each(prop,function(name,val){var e=new jQuery.fx(self,opt,name);if(/toggle|show|hide/.test(val))e[val=="toggle"?hidden?"show":"hide":val](prop);else{var parts=val.toString().match(/^([+-]=)?([\d+-.]+)(.*)$/),start=e.cur(true)||0;if(parts){var end=parseFloat(parts[2]),unit=parts[3]||"px";if(unit!="px"){self.style[name]=(end||1)+unit;start=((end||1)/e.cur(true))*start;self.style[name]=start+unit;}if(parts[1])end=((parts[1]=="-="?-1:1)*end)+start;e.custom(start,end,unit);}else
+e.custom(start,val,"");}});return true;});},queue:function(type,fn){if(jQuery.isFunction(type)||(type&&type.constructor==Array)){fn=type;type="fx";}if(!type||(typeof type=="string"&&!fn))return queue(this[0],type);return this.each(function(){if(fn.constructor==Array)queue(this,type,fn);else{queue(this,type).push(fn);if(queue(this,type).length==1)fn.call(this);}});},stop:function(clearQueue,gotoEnd){var timers=jQuery.timers;if(clearQueue)this.queue([]);this.each(function(){for(var i=timers.length-1;i>=0;i--)if(timers[i].elem==this){if(gotoEnd)timers[i](true);timers.splice(i,1);}});if(!gotoEnd)this.dequeue();return this;}});var queue=function(elem,type,array){if(elem){type=type||"fx";var q=jQuery.data(elem,type+"queue");if(!q||array)q=jQuery.data(elem,type+"queue",jQuery.makeArray(array));}return q;};jQuery.fn.dequeue=function(type){type=type||"fx";return this.each(function(){var q=queue(this,type);q.shift();if(q.length)q[0].call(this);});};jQuery.extend({speed:function(speed,easing,fn){var opt=speed&&speed.constructor==Object?speed:{complete:fn||!fn&&easing||jQuery.isFunction(speed)&&speed,duration:speed,easing:fn&&easing||easing&&easing.constructor!=Function&&easing};opt.duration=(opt.duration&&opt.duration.constructor==Number?opt.duration:jQuery.fx.speeds[opt.duration])||jQuery.fx.speeds.def;opt.old=opt.complete;opt.complete=function(){if(opt.queue!==false)jQuery(this).dequeue();if(jQuery.isFunction(opt.old))opt.old.call(this);};return opt;},easing:{linear:function(p,n,firstNum,diff){return firstNum+diff*p;},swing:function(p,n,firstNum,diff){return((-Math.cos(p*Math.PI)/2)+0.5)*diff+firstNum;}},timers:[],timerId:null,fx:function(elem,options,prop){this.options=options;this.elem=elem;this.prop=prop;if(!options.orig)options.orig={};}});jQuery.fx.prototype={update:function(){if(this.options.step)this.options.step.call(this.elem,this.now,this);(jQuery.fx.step[this.prop]||jQuery.fx.step._default)(this);if(this.prop=="height"||this.prop=="width")this.elem.style.display="block";},cur:function(force){if(this.elem[this.prop]!=null&&this.elem.style[this.prop]==null)return this.elem[this.prop];var r=parseFloat(jQuery.css(this.elem,this.prop,force));return r&&r>-10000?r:parseFloat(jQuery.curCSS(this.elem,this.prop))||0;},custom:function(from,to,unit){this.startTime=now();this.start=from;this.end=to;this.unit=unit||this.unit||"px";this.now=this.start;this.pos=this.state=0;this.update();var self=this;function t(gotoEnd){return self.step(gotoEnd);}t.elem=this.elem;jQuery.timers.push(t);if(jQuery.timerId==null){jQuery.timerId=setInterval(function(){var timers=jQuery.timers;for(var i=0;i<timers.length;i++)if(!timers[i]())timers.splice(i--,1);if(!timers.length){clearInterval(jQuery.timerId);jQuery.timerId=null;}},13);}},show:function(){this.options.orig[this.prop]=jQuery.attr(this.elem.style,this.prop);this.options.show=true;this.custom(0,this.cur());if(this.prop=="width"||this.prop=="height")this.elem.style[this.prop]="1px";jQuery(this.elem).show();},hide:function(){this.options.orig[this.prop]=jQuery.attr(this.elem.style,this.prop);this.options.hide=true;this.custom(this.cur(),0);},step:function(gotoEnd){var t=now();if(gotoEnd||t>this.options.duration+this.startTime){this.now=this.end;this.pos=this.state=1;this.update();this.options.curAnim[this.prop]=true;var done=true;for(var i in this.options.curAnim)if(this.options.curAnim[i]!==true)done=false;if(done){if(this.options.display!=null){this.elem.style.overflow=this.options.overflow;this.elem.style.display=this.options.display;if(jQuery.css(this.elem,"display")=="none")this.elem.style.display="block";}if(this.options.hide)this.elem.style.display="none";if(this.options.hide||this.options.show)for(var p in this.options.curAnim)jQuery.attr(this.elem.style,p,this.options.orig[p]);}if(done)this.options.complete.call(this.elem);return false;}else{var n=t-this.startTime;this.state=n/this.options.duration;this.pos=jQuery.easing[this.options.easing||(jQuery.easing.swing?"swing":"linear")](this.state,n,0,1,this.options.duration);this.now=this.start+((this.end-this.start)*this.pos);this.update();}return true;}};jQuery.extend(jQuery.fx,{speeds:{slow:600,fast:200,def:400},step:{scrollLeft:function(fx){fx.elem.scrollLeft=fx.now;},scrollTop:function(fx){fx.elem.scrollTop=fx.now;},opacity:function(fx){jQuery.attr(fx.elem.style,"opacity",fx.now);},_default:function(fx){fx.elem.style[fx.prop]=fx.now+fx.unit;}}});jQuery.fn.offset=function(){var left=0,top=0,elem=this[0],results;if(elem)with(jQuery.browser){var parent=elem.parentNode,offsetChild=elem,offsetParent=elem.offsetParent,doc=elem.ownerDocument,safari2=safari&&parseInt(version)<522&&!/adobeair/i.test(userAgent),css=jQuery.curCSS,fixed=css(elem,"position")=="fixed";if(elem.getBoundingClientRect){var box=elem.getBoundingClientRect();add(box.left+Math.max(doc.documentElement.scrollLeft,doc.body.scrollLeft),box.top+Math.max(doc.documentElement.scrollTop,doc.body.scrollTop));add(-doc.documentElement.clientLeft,-doc.documentElement.clientTop);}else{add(elem.offsetLeft,elem.offsetTop);while(offsetParent){add(offsetParent.offsetLeft,offsetParent.offsetTop);if(mozilla&&!/^t(able|d|h)$/i.test(offsetParent.tagName)||safari&&!safari2)border(offsetParent);if(!fixed&&css(offsetParent,"position")=="fixed")fixed=true;offsetChild=/^body$/i.test(offsetParent.tagName)?offsetChild:offsetParent;offsetParent=offsetParent.offsetParent;}while(parent&&parent.tagName&&!/^body|html$/i.test(parent.tagName)){if(!/^inline|table.*$/i.test(css(parent,"display")))add(-parent.scrollLeft,-parent.scrollTop);if(mozilla&&css(parent,"overflow")!="visible")border(parent);parent=parent.parentNode;}if((safari2&&(fixed||css(offsetChild,"position")=="absolute"))||(mozilla&&css(offsetChild,"position")!="absolute"))add(-doc.body.offsetLeft,-doc.body.offsetTop);if(fixed)add(Math.max(doc.documentElement.scrollLeft,doc.body.scrollLeft),Math.max(doc.documentElement.scrollTop,doc.body.scrollTop));}results={top:top,left:left};}function border(elem){add(jQuery.curCSS(elem,"borderLeftWidth",true),jQuery.curCSS(elem,"borderTopWidth",true));}function add(l,t){left+=parseInt(l,10)||0;top+=parseInt(t,10)||0;}return results;};jQuery.fn.extend({position:function(){var left=0,top=0,results;if(this[0]){var offsetParent=this.offsetParent(),offset=this.offset(),parentOffset=/^body|html$/i.test(offsetParent[0].tagName)?{top:0,left:0}:offsetParent.offset();offset.top-=num(this,'marginTop');offset.left-=num(this,'marginLeft');parentOffset.top+=num(offsetParent,'borderTopWidth');parentOffset.left+=num(offsetParent,'borderLeftWidth');results={top:offset.top-parentOffset.top,left:offset.left-parentOffset.left};}return results;},offsetParent:function(){var offsetParent=this[0].offsetParent;while(offsetParent&&(!/^body|html$/i.test(offsetParent.tagName)&&jQuery.css(offsetParent,'position')=='static'))offsetParent=offsetParent.offsetParent;return jQuery(offsetParent);}});jQuery.each(['Left','Top'],function(i,name){var method='scroll'+name;jQuery.fn[method]=function(val){if(!this[0])return;return val!=undefined?this.each(function(){this==window||this==document?window.scrollTo(!i?val:jQuery(window).scrollLeft(),i?val:jQuery(window).scrollTop()):this[method]=val;}):this[0]==window||this[0]==document?self[i?'pageYOffset':'pageXOffset']||jQuery.boxModel&&document.documentElement[method]||document.body[method]:this[0][method];};});jQuery.each(["Height","Width"],function(i,name){var tl=i?"Left":"Top",br=i?"Right":"Bottom";jQuery.fn["inner"+name]=function(){return this[name.toLowerCase()]()+num(this,"padding"+tl)+num(this,"padding"+br);};jQuery.fn["outer"+name]=function(margin){return this["inner"+name]()+num(this,"border"+tl+"Width")+num(this,"border"+br+"Width")+(margin?num(this,"margin"+tl)+num(this,"margin"+br):0);};});})();
\ No newline at end of file
Added: branches/beck_dev/mapbender/http/extensions/jquery-ui-personalized-1.5.min.js
--- branches/beck_dev/mapbender/http/extensions/jquery-ui-personalized-1.5.min.js	                        (rev 0)
+++ branches/beck_dev/mapbender/http/extensions/jquery-ui-personalized-1.5.min.js	2008-06-17 15:55:33 UTC (rev 2508)
@@ -0,0 +1,146 @@
+;(function($){$.ui={plugin:{add:function(module,option,set){var proto=$.ui[module].prototype;for(var i in set){proto.plugins[i]=proto.plugins[i]||[];proto.plugins[i].push([option,set[i]]);}},call:function(instance,name,args){var set=instance.plugins[name];if(!set){return;}
+for(var i=0;i<set.length;i++){if(instance.options[set[i][0]]){set[i][1].apply(instance.element,args);}}}},cssCache:{},css:function(name){if($.ui.cssCache[name]){return $.ui.cssCache[name];}
+var tmp=$('<div class="ui-resizable-gen">').addClass(name).css({position:'absolute',top:'-5000px',left:'-5000px',display:'block'}).appendTo('body');$.ui.cssCache[name]=!!((!(/auto|default/).test(tmp.css('cursor'))||(/^[1-9]/).test(tmp.css('height'))||(/^[1-9]/).test(tmp.css('width'))||!(/none/).test(tmp.css('backgroundImage'))||!(/transparent|rgba\(0, 0, 0, 0\)/).test(tmp.css('backgroundColor'))));try{$('body').get(0).removeChild(tmp.get(0));}catch(e){}
+return $.ui.cssCache[name];},disableSelection:function(e){e.unselectable="on";e.onselectstart=function(){return false;};if(e.style){e.style.MozUserSelect="none";}},enableSelection:function(e){e.unselectable="off";e.onselectstart=function(){return true;};if(e.style){e.style.MozUserSelect="";}},hasScroll:function(e,a){var scroll=/top/.test(a||"top")?'scrollTop':'scrollLeft',has=false;if(e[scroll]>0)return true;e[scroll]=1;has=e[scroll]>0?true:false;e[scroll]=0;return has;}};var _remove=$.fn.remove;$.fn.remove=function(){$("*",this).add(this).trigger("remove");return _remove.apply(this,arguments);};function getter(namespace,plugin,method){var methods=$[namespace][plugin].getter||[];methods=(typeof methods=="string"?methods.split(/,?\s+/):methods);return($.inArray(method,methods)!=-1);}
+$.widget=function(name,prototype){var namespace=name.split(".")[0];name=name.split(".")[1];$.fn[name]=function(options){var isMethodCall=(typeof options=='string'),args=Array.prototype.slice.call(arguments,1);if(isMethodCall&&getter(namespace,name,options)){var instance=$.data(this[0],name);return(instance?instance[options].apply(instance,args):undefined);}
+return this.each(function(){var instance=$.data(this,name);if(isMethodCall&&instance&&$.isFunction(instance[options])){instance[options].apply(instance,args);}else if(!isMethodCall){$.data(this,name,new $[namespace][name](this,options));}});};$[namespace][name]=function(element,options){var self=this;this.widgetName=name;this.widgetBaseClass=namespace+'-'+name;this.options=$.extend({disabled:false},$[namespace][name].defaults,options);this.element=$(element).bind('setData.'+name,function(e,key,value){return self.setData(key,value);}).bind('getData.'+name,function(e,key){return self.getData(key);}).bind('remove',function(){return self.destroy();});this.init();};$[namespace][name].prototype=$.extend({},$.widget.prototype,prototype);};$.widget.prototype={init:function(){},destroy:function(){this.element.removeData(this.widgetName);},getData:function(key){return this.options[key];},setData:function(key,value){this.options[key]=value;if(key=='disabled'){this.element[value?'addClass':'removeClass'](this.widgetBaseClass+'-disabled');}},enable:function(){this.setData('disabled',false);},disable:function(){this.setData('disabled',true);}};$.ui.mouse={mouseInit:function(){var self=this;this.element.bind('mousedown.'+this.widgetName,function(e){return self.mouseDown(e);});if($.browser.msie){this._mouseUnselectable=this.element.attr('unselectable');this.element.attr('unselectable','on');}
+this.started=false;},mouseDestroy:function(){this.element.unbind('.'+this.widgetName);($.browser.msie&&this.element.attr('unselectable',this._mouseUnselectable));},mouseDown:function(e){(this._mouseStarted&&this.mouseUp(e));this._mouseDownEvent=e;var self=this,btnIsLeft=(e.which==1),elIsCancel=(typeof this.options.cancel=="string"?$(e.target).is(this.options.cancel):false);if(!btnIsLeft||elIsCancel||!this.mouseCapture(e)){return true;}
+this._mouseDelayMet=!this.options.delay;if(!this._mouseDelayMet){this._mouseDelayTimer=setTimeout(function(){self._mouseDelayMet=true;},this.options.delay);}
+if(this.mouseDistanceMet(e)&&this.mouseDelayMet(e)){this._mouseStarted=(this.mouseStart(e)!==false);if(!this._mouseStarted){e.preventDefault();return true;}}
+this._mouseMoveDelegate=function(e){return self.mouseMove(e);};this._mouseUpDelegate=function(e){return self.mouseUp(e);};$(document).bind('mousemove.'+this.widgetName,this._mouseMoveDelegate).bind('mouseup.'+this.widgetName,this._mouseUpDelegate);return false;},mouseMove:function(e){if($.browser.msie&&!e.button){return this.mouseUp(e);}
+if(this._mouseStarted){this.mouseDrag(e);return false;}
+if(this.mouseDistanceMet(e)&&this.mouseDelayMet(e)){this._mouseStarted=(this.mouseStart(this._mouseDownEvent,e)!==false);(this._mouseStarted?this.mouseDrag(e):this.mouseUp(e));}
+return!this._mouseStarted;},mouseUp:function(e){$(document).unbind('mousemove.'+this.widgetName,this._mouseMoveDelegate).unbind('mouseup.'+this.widgetName,this._mouseUpDelegate);if(this._mouseStarted){this._mouseStarted=false;this.mouseStop(e);}
+return false;},mouseDistanceMet:function(e){return(Math.max(Math.abs(this._mouseDownEvent.pageX-e.pageX),Math.abs(this._mouseDownEvent.pageY-e.pageY))>=this.options.distance);},mouseDelayMet:function(e){return this._mouseDelayMet;},mouseStart:function(e){},mouseDrag:function(e){},mouseStop:function(e){},mouseCapture:function(e){return true;}};$.ui.mouse.defaults={cancel:null,distance:1,delay:0};})(jQuery);(function($){$.widget("ui.draggable",$.extend($.ui.mouse,{init:function(){var o=this.options;if(o.helper=='original'&&!(/(relative|absolute|fixed)/).test(this.element.css('position')))
+this.element.css('position','relative');this.element.addClass('ui-draggable');(o.disabled&&this.element.addClass('ui-draggable-disabled'));this.mouseInit();},mouseStart:function(e){var o=this.options;if(this.helper||o.disabled||$(e.target).is('.ui-resizable-handle'))return false;var handle=!this.options.handle||!$(this.options.handle,this.element).length?true:false;$(this.options.handle,this.element).find("*").andSelf().each(function(){if(this==e.target)handle=true;});if(!handle)return false;if($.ui.ddmanager)$.ui.ddmanager.current=this;this.helper=$.isFunction(o.helper)?$(o.helper.apply(this.element[0],[e])):(o.helper=='clone'?this.element.clone():this.element);if(!this.helper.parents('body').length)this.helper.appendTo((o.appendTo=='parent'?this.element[0].parentNode:o.appendTo));if(this.helper[0]!=this.element[0]&&!(/(fixed|absolute)/).test(this.helper.css("position")))this.helper.css("position","absolute");this.margins={left:(parseInt(this.element.css("marginLeft"),10)||0),top:(parseInt(this.element.css("marginTop"),10)||0)};this.cssPosition=this.helper.css("position");this.offset=this.element.offset();this.offset={top:this.offset.top-this.margins.top,left:this.offset.left-this.margins.left};this.offset.click={left:e.pageX-this.offset.left,top:e.pageY-this.offset.top};this.offsetParent=this.helper.offsetParent();var po=this.offsetParent.offset();if(this.offsetParent[0]==document.body&&$.browser.mozilla)po={top:0,left:0};this.offset.parent={top:po.top+(parseInt(this.offsetParent.css("borderTopWidth"),10)||0),left:po.left+(parseInt(this.offsetParent.css("borderLeftWidth"),10)||0)};var p=this.element.position();this.offset.relative=this.cssPosition=="relative"?{top:p.top-(parseInt(this.helper.css("top"),10)||0)+this.offsetParent[0].scrollTop,left:p.left-(parseInt(this.helper.css("left"),10)||0)+this.offsetParent[0].scrollLeft}:{top:0,left:0};this.originalPosition=this.generatePosition(e);this.helperProportions={width:this.helper.outerWidth(),height:this.helper.outerHeight()};if(o.cursorAt){if(o.cursorAt.left!=undefined)this.offset.click.left=o.cursorAt.left+this.margins.left;if(o.cursorAt.right!=undefined)this.offset.click.left=this.helperProportions.width-o.cursorAt.right+this.margins.left;if(o.cursorAt.top!=undefined)this.offset.click.top=o.cursorAt.top+this.margins.top;if(o.cursorAt.bottom!=undefined)this.offset.click.top=this.helperProportions.height-o.cursorAt.bottom+this.margins.top;}
+if(o.containment){if(o.containment=='parent')o.containment=this.helper[0].parentNode;if(o.containment=='document'||o.containment=='window')this.containment=[0-this.offset.relative.left-this.offset.parent.left,0-this.offset.relative.top-this.offset.parent.top,$(o.containment=='document'?document:window).width()-this.offset.relative.left-this.offset.parent.left-this.helperProportions.width-this.margins.left-(parseInt(this.element.css("marginRight"),10)||0),($(o.containment=='document'?document:window).height()||document.body.parentNode.scrollHeight)-this.offset.relative.top-this.offset.parent.top-this.helperProportions.height-this.margins.top-(parseInt(this.element.css("marginBottom"),10)||0)];if(!(/^(document|window|parent)$/).test(o.containment)){var ce=$(o.containment)[0];var co=$(o.containment).offset();this.containment=[co.left+(parseInt($(ce).css("borderLeftWidth"),10)||0)-this.offset.relative.left-this.offset.parent.left,co.top+(parseInt($(ce).css("borderTopWidth"),10)||0)-this.offset.relative.top-this.offset.parent.top,co.left+Math.max(ce.scrollWidth,ce.offsetWidth)-(parseInt($(ce).css("borderLeftWidth"),10)||0)-this.offset.relative.left-this.offset.parent.left-this.helperProportions.width-this.margins.left-(parseInt(this.element.css("marginRight"),10)||0),co.top+Math.max(ce.scrollHeight,ce.offsetHeight)-(parseInt($(ce).css("borderTopWidth"),10)||0)-this.offset.relative.top-this.offset.parent.top-this.helperProportions.height-this.margins.top-(parseInt(this.element.css("marginBottom"),10)||0)];}}
+this.propagate("start",e);this.helperProportions={width:this.helper.outerWidth(),height:this.helper.outerHeight()};if($.ui.ddmanager&&!o.dropBehaviour)$.ui.ddmanager.prepareOffsets(this,e);this.helper.addClass("ui-draggable-dragging");this.mouseDrag(e);return true;},convertPositionTo:function(d,pos){if(!pos)pos=this.position;var mod=d=="absolute"?1:-1;return{top:(pos.top
++this.offset.relative.top*mod
++this.offset.parent.top*mod
+-(this.cssPosition=="fixed"||(this.cssPosition=="absolute"&&this.offsetParent[0]==document.body)?0:this.offsetParent[0].scrollTop)*mod
++(this.cssPosition=="fixed"?this.offsetParent[0].scrollTop:0)*mod
++this.margins.top*mod),left:(pos.left
++this.offset.relative.left*mod
++this.offset.parent.left*mod
+-(this.cssPosition=="fixed"||(this.cssPosition=="absolute"&&this.offsetParent[0]==document.body)?0:this.offsetParent[0].scrollLeft)*mod
++(this.cssPosition=="fixed"?this.offsetParent[0].scrollLeft:0)*mod
++this.margins.left*mod)};},generatePosition:function(e){var o=this.options;var position={top:(e.pageY
+-this.offset.click.top
+-this.offset.relative.top
+-this.offset.parent.top
++(this.cssPosition=="fixed"||(this.cssPosition=="absolute"&&this.offsetParent[0]==document.body)?0:this.offsetParent[0].scrollTop)
+-(this.cssPosition=="fixed"?this.offsetParent[0].scrollTop:0)),left:(e.pageX
+-this.offset.click.left
+-this.offset.relative.left
+-this.offset.parent.left
++(this.cssPosition=="fixed"||(this.cssPosition=="absolute"&&this.offsetParent[0]==document.body)?0:this.offsetParent[0].scrollLeft)
+-(this.cssPosition=="fixed"?this.offsetParent[0].scrollLeft:0))};if(!this.originalPosition)return position;if(this.containment){if(position.left<this.containment[0])position.left=this.containment[0];if(position.top<this.containment[1])position.top=this.containment[1];if(position.left>this.containment[2])position.left=this.containment[2];if(position.top>this.containment[3])position.top=this.containment[3];}
+if(o.grid){var top=this.originalPosition.top+Math.round((position.top-this.originalPosition.top)/o.grid[1])*o.grid[1];position.top=this.containment?(!(top<this.containment[1]||top>this.containment[3])?top:(!(top<this.containment[1])?top-o.grid[1]:top+o.grid[1])):top;var left=this.originalPosition.left+Math.round((position.left-this.originalPosition.left)/o.grid[0])*o.grid[0];position.left=this.containment?(!(left<this.containment[0]||left>this.containment[2])?left:(!(left<this.containment[0])?left-o.grid[0]:left+o.grid[0])):left;}
+return position;},mouseDrag:function(e){this.position=this.generatePosition(e);this.positionAbs=this.convertPositionTo("absolute");this.position=this.propagate("drag",e)||this.position;if(!this.options.axis||this.options.axis!="y")this.helper[0].style.left=this.position.left+'px';if(!this.options.axis||this.options.axis!="x")this.helper[0].style.top=this.position.top+'px';if($.ui.ddmanager)$.ui.ddmanager.drag(this,e);return false;},mouseStop:function(e){if($.ui.ddmanager&&!this.options.dropBehaviour)
+$.ui.ddmanager.drop(this,e);if(this.options.revert){var self=this;$(this.helper).animate(this.originalPosition,parseInt(this.options.revert,10)||500,function(){self.propagate("stop",e);self.clear();});}else{this.propagate("stop",e);this.clear();}
+return false;},clear:function(){this.helper.removeClass("ui-draggable-dragging");if(this.options.helper!='original'&&!this.cancelHelperRemoval)this.helper.remove();this.helper=null;this.cancelHelperRemoval=false;},plugins:{},uiHash:function(e){return{helper:this.helper,position:this.position,absolutePosition:this.positionAbs,options:this.options};},propagate:function(n,e){$.ui.plugin.call(this,n,[e,this.uiHash()]);return this.element.triggerHandler(n=="drag"?n:"drag"+n,[e,this.uiHash()],this.options[n]);},destroy:function(){if(!this.element.data('draggable'))return;this.element.removeData("draggable").unbind(".draggable").removeClass('ui-draggable');this.mouseDestroy();}}));$.extend($.ui.draggable,{defaults:{appendTo:"parent",axis:false,cancel:":input,button",delay:0,distance:0,helper:"original"}});$.ui.plugin.add("draggable","cursor",{start:function(e,ui){var t=$('body');if(t.css("cursor"))ui.options._cursor=t.css("cursor");t.css("cursor",ui.options.cursor);},stop:function(e,ui){if(ui.options._cursor)$('body').css("cursor",ui.options._cursor);}});$.ui.plugin.add("draggable","zIndex",{start:function(e,ui){var t=$(ui.helper);if(t.css("zIndex"))ui.options._zIndex=t.css("zIndex");t.css('zIndex',ui.options.zIndex);},stop:function(e,ui){if(ui.options._zIndex)$(ui.helper).css('zIndex',ui.options._zIndex);}});$.ui.plugin.add("draggable","opacity",{start:function(e,ui){var t=$(ui.helper);if(t.css("opacity"))ui.options._opacity=t.css("opacity");t.css('opacity',ui.options.opacity);},stop:function(e,ui){if(ui.options._opacity)$(ui.helper).css('opacity',ui.options._opacity);}});$.ui.plugin.add("draggable","iframeFix",{start:function(e,ui){$(ui.options.iframeFix===true?"iframe":ui.options.iframeFix).each(function(){$('<div class="ui-draggable-iframeFix" style="background: #fff;"></div>').css({width:this.offsetWidth+"px",height:this.offsetHeight+"px",position:"absolute",opacity:"0.001",zIndex:1000}).css($(this).offset()).appendTo("body");});},stop:function(e,ui){$("div.DragDropIframeFix").each(function(){this.parentNode.removeChild(this);});}});$.ui.plugin.add("draggable","scroll",{start:function(e,ui){var o=ui.options;var i=$(this).data("draggable");o.scrollSensitivity=o.scrollSensitivity||20;o.scrollSpeed=o.scrollSpeed||20;i.overflowY=function(el){do{if(/auto|scroll/.test(el.css('overflow'))||(/auto|scroll/).test(el.css('overflow-y')))return el;el=el.parent();}while(el[0].parentNode);return $(document);}(this);i.overflowX=function(el){do{if(/auto|scroll/.test(el.css('overflow'))||(/auto|scroll/).test(el.css('overflow-x')))return el;el=el.parent();}while(el[0].parentNode);return $(document);}(this);if(i.overflowY[0]!=document&&i.overflowY[0].tagName!='HTML')i.overflowYOffset=i.overflowY.offset();if(i.overflowX[0]!=document&&i.overflowX[0].tagName!='HTML')i.overflowXOffset=i.overflowX.offset();},drag:function(e,ui){var o=ui.options;var i=$(this).data("draggable");if(i.overflowY[0]!=document&&i.overflowY[0].tagName!='HTML'){if((i.overflowYOffset.top+i.overflowY[0].offsetHeight)-e.pageY<o.scrollSensitivity)
+i.overflowY[0].scrollTop=i.overflowY[0].scrollTop+o.scrollSpeed;if(e.pageY-i.overflowYOffset.top<o.scrollSensitivity)
+i.overflowY[0].scrollTop=i.overflowY[0].scrollTop-o.scrollSpeed;}else{if(e.pageY-$(document).scrollTop()<o.scrollSensitivity)
+$(document).scrollTop($(document).scrollTop()-o.scrollSpeed);if($(window).height()-(e.pageY-$(document).scrollTop())<o.scrollSensitivity)
+$(document).scrollTop($(document).scrollTop()+o.scrollSpeed);}
+if(i.overflowX[0]!=document&&i.overflowX[0].tagName!='HTML'){if((i.overflowXOffset.left+i.overflowX[0].offsetWidth)-e.pageX<o.scrollSensitivity)
+i.overflowX[0].scrollLeft=i.overflowX[0].scrollLeft+o.scrollSpeed;if(e.pageX-i.overflowXOffset.left<o.scrollSensitivity)
+i.overflowX[0].scrollLeft=i.overflowX[0].scrollLeft-o.scrollSpeed;}else{if(e.pageX-$(document).scrollLeft()<o.scrollSensitivity)
+$(document).scrollLeft($(document).scrollLeft()-o.scrollSpeed);if($(window).width()-(e.pageX-$(document).scrollLeft())<o.scrollSensitivity)
+$(document).scrollLeft($(document).scrollLeft()+o.scrollSpeed);}}});$.ui.plugin.add("draggable","snap",{start:function(e,ui){var inst=$(this).data("draggable");inst.snapElements=[];$(ui.options.snap===true?'.ui-draggable':ui.options.snap).each(function(){var $t=$(this);var $o=$t.offset();if(this!=inst.element[0])inst.snapElements.push({item:this,width:$t.outerWidth(),height:$t.outerHeight(),top:$o.top,left:$o.left});});},drag:function(e,ui){var inst=$(this).data("draggable");var d=ui.options.snapTolerance||20;var x1=ui.absolutePosition.left,x2=x1+inst.helperProportions.width,y1=ui.absolutePosition.top,y2=y1+inst.helperProportions.height;for(var i=inst.snapElements.length-1;i>=0;i--){var l=inst.snapElements[i].left,r=l+inst.snapElements[i].width,t=inst.snapElements[i].top,b=t+inst.snapElements[i].height;if(!((l-d<x1&&x1<r+d&&t-d<y1&&y1<b+d)||(l-d<x1&&x1<r+d&&t-d<y2&&y2<b+d)||(l-d<x2&&x2<r+d&&t-d<y1&&y1<b+d)||(l-d<x2&&x2<r+d&&t-d<y2&&y2<b+d)))continue;if(ui.options.snapMode!='inner'){var ts=Math.abs(t-y2)<=20;var bs=Math.abs(b-y1)<=20;var ls=Math.abs(l-x2)<=20;var rs=Math.abs(r-x1)<=20;if(ts)ui.position.top=inst.convertPositionTo("relative",{top:t-inst.helperProportions.height,left:0}).top;if(bs)ui.position.top=inst.convertPositionTo("relative",{top:b,left:0}).top;if(ls)ui.position.left=inst.convertPositionTo("relative",{top:0,left:l-inst.helperProportions.width}).left;if(rs)ui.position.left=inst.convertPositionTo("relative",{top:0,left:r}).left;}
+if(ui.options.snapMode!='outer'){var ts=Math.abs(t-y1)<=20;var bs=Math.abs(b-y2)<=20;var ls=Math.abs(l-x1)<=20;var rs=Math.abs(r-x2)<=20;if(ts)ui.position.top=inst.convertPositionTo("relative",{top:t,left:0}).top;if(bs)ui.position.top=inst.convertPositionTo("relative",{top:b-inst.helperProportions.height,left:0}).top;if(ls)ui.position.left=inst.convertPositionTo("relative",{top:0,left:l}).left;if(rs)ui.position.left=inst.convertPositionTo("relative",{top:0,left:r-inst.helperProportions.width}).left;}};}});$.ui.plugin.add("draggable","connectToSortable",{start:function(e,ui){var inst=$(this).data("draggable");inst.sortables=[];$(ui.options.connectToSortable).each(function(){if($.data(this,'sortable')){var sortable=$.data(this,'sortable');inst.sortables.push({instance:sortable,shouldRevert:sortable.options.revert});sortable.refresh();sortable.propagate("activate",e,inst);}});},stop:function(e,ui){var inst=$(this).data("draggable");$.each(inst.sortables,function(){if(this.instance.isOver){this.instance.isOver=0;inst.cancelHelperRemoval=true;this.instance.cancelHelperRemoval=false;if(this.shouldRevert)this.instance.options.revert=true;this.instance.mouseStop(e);this.instance.element.triggerHandler("sortreceive",[e,$.extend(this.instance.ui(),{sender:inst.element})],this.instance.options["receive"]);this.instance.options.helper=this.instance.options._helper;}else{this.instance.propagate("deactivate",e,inst);}});},drag:function(e,ui){var inst=$(this).data("draggable"),self=this;var checkPos=function(o){var l=o.left,r=l+o.width,t=o.top,b=t+o.height;return(l<(this.positionAbs.left+this.offset.click.left)&&(this.positionAbs.left+this.offset.click.left)<r&&t<(this.positionAbs.top+this.offset.click.top)&&(this.positionAbs.top+this.offset.click.top)<b);};$.each(inst.sortables,function(i){if(checkPos.call(inst,this.instance.containerCache)){if(!this.instance.isOver){this.instance.isOver=1;this.instance.currentItem=$(self).clone().appendTo(this.instance.element).data("sortable-item",true);this.instance.options._helper=this.instance.options.helper;this.instance.options.helper=function(){return ui.helper[0];};e.target=this.instance.currentItem[0];this.instance.mouseCapture(e,true,true);this.instance.mouseStart(e,true,true);this.instance.offset.click.top=inst.offset.click.top;this.instance.offset.click.left=inst.offset.click.left;this.instance.offset.parent.left-=inst.offset.parent.left-this.instance.offset.parent.left;this.instance.offset.parent.top-=inst.offset.parent.top-this.instance.offset.parent.top;inst.propagate("toSortable",e);}
+if(this.instance.currentItem)this.instance.mouseDrag(e);}else{if(this.instance.isOver){this.instance.isOver=0;this.instance.cancelHelperRemoval=true;this.instance.options.revert=false;this.instance.mouseStop(e,true);this.instance.options.helper=this.instance.options._helper;this.instance.currentItem.remove();this.instance.placeholder.remove();inst.propagate("fromSortable",e);}};});}});$.ui.plugin.add("draggable","stack",{start:function(e,ui){var group=$.makeArray($(ui.options.stack.group)).sort(function(a,b){return(parseInt($(a).css("zIndex"),10)||ui.options.stack.min)-(parseInt($(b).css("zIndex"),10)||ui.options.stack.min);});$(group).each(function(i){this.style.zIndex=ui.options.stack.min+i;});this[0].style.zIndex=ui.options.stack.min+group.length;}});})(jQuery);(function($){$.widget("ui.droppable",{init:function(){this.element.addClass("ui-droppable");this.isover=0;this.isout=1;var o=this.options,accept=o.accept;o=$.extend(o,{accept:o.accept&&o.accept.constructor==Function?o.accept:function(d){return $(d).is(accept);}});this.proportions={width:this.element.outerWidth(),height:this.element.outerHeight()};$.ui.ddmanager.droppables.push(this);},plugins:{},ui:function(c){return{draggable:(c.currentItem||c.element),helper:c.helper,position:c.position,absolutePosition:c.positionAbs,options:this.options,element:this.element};},destroy:function(){var drop=$.ui.ddmanager.droppables;for(var i=0;i<drop.length;i++)
+if(drop[i]==this)
+drop.splice(i,1);this.element.removeClass("ui-droppable ui-droppable-disabled").removeData("droppable").unbind(".droppable");},over:function(e){var draggable=$.ui.ddmanager.current;if(!draggable||(draggable.currentItem||draggable.element)[0]==this.element[0])return;if(this.options.accept.call(this.element,(draggable.currentItem||draggable.element))){$.ui.plugin.call(this,'over',[e,this.ui(draggable)]);this.element.triggerHandler("dropover",[e,this.ui(draggable)],this.options.over);}},out:function(e){var draggable=$.ui.ddmanager.current;if(!draggable||(draggable.currentItem||draggable.element)[0]==this.element[0])return;if(this.options.accept.call(this.element,(draggable.currentItem||draggable.element))){$.ui.plugin.call(this,'out',[e,this.ui(draggable)]);this.element.triggerHandler("dropout",[e,this.ui(draggable)],this.options.out);}},drop:function(e,custom){var draggable=custom||$.ui.ddmanager.current;if(!draggable||(draggable.currentItem||draggable.element)[0]==this.element[0])return false;var childrenIntersection=false;this.element.find(".ui-droppable").not(".ui-draggable-dragging").each(function(){var inst=$.data(this,'droppable');if(inst.options.greedy&&$.ui.intersect(draggable,$.extend(inst,{offset:inst.element.offset()}),inst.options.tolerance)){childrenIntersection=true;return false;}});if(childrenIntersection)return false;if(this.options.accept.call(this.element,(draggable.currentItem||draggable.element))){$.ui.plugin.call(this,'drop',[e,this.ui(draggable)]);this.element.triggerHandler("drop",[e,this.ui(draggable)],this.options.drop);return true;}
+return false;},activate:function(e){var draggable=$.ui.ddmanager.current;$.ui.plugin.call(this,'activate',[e,this.ui(draggable)]);if(draggable)this.element.triggerHandler("dropactivate",[e,this.ui(draggable)],this.options.activate);},deactivate:function(e){var draggable=$.ui.ddmanager.current;$.ui.plugin.call(this,'deactivate',[e,this.ui(draggable)]);if(draggable)this.element.triggerHandler("dropdeactivate",[e,this.ui(draggable)],this.options.deactivate);}});$.extend($.ui.droppable,{defaults:{disabled:false,tolerance:'intersect'}});$.ui.intersect=function(draggable,droppable,toleranceMode){if(!droppable.offset)return false;var x1=(draggable.positionAbs||draggable.position.absolute).left,x2=x1+draggable.helperProportions.width,y1=(draggable.positionAbs||draggable.position.absolute).top,y2=y1+draggable.helperProportions.height;var l=droppable.offset.left,r=l+droppable.proportions.width,t=droppable.offset.top,b=t+droppable.proportions.height;switch(toleranceMode){case'fit':return(l<x1&&x2<r&&t<y1&&y2<b);break;case'intersect':return(l<x1+(draggable.helperProportions.width/2)&&x2-(draggable.helperProportions.width/2)<r&&t<y1+(draggable.helperProportions.height/2)&&y2-(draggable.helperProportions.height/2)<b);break;case'pointer':return(l<((draggable.positionAbs||draggable.position.absolute).left+(draggable.clickOffset||draggable.offset.click).left)&&((draggable.positionAbs||draggable.position.absolute).left+(draggable.clickOffset||draggable.offset.click).left)<r&&t<((draggable.positionAbs||draggable.position.absolute).top+(draggable.clickOffset||draggable.offset.click).top)&&((draggable.positionAbs||draggable.position.absolute).top+(draggable.clickOffset||draggable.offset.click).top)<b);break;case'touch':return((y1>=t&&y1<=b)||(y2>=t&&y2<=b)||(y1<t&&y2>b))&&((x1>=l&&x1<=r)||(x2>=l&&x2<=r)||(x1<l&&x2>r));break;default:return false;break;}};$.ui.ddmanager={current:null,droppables:[],prepareOffsets:function(t,e){var m=$.ui.ddmanager.droppables;var type=e?e.type:null;for(var i=0;i<m.length;i++){if(m[i].options.disabled||(t&&!m[i].options.accept.call(m[i].element,(t.currentItem||t.element))))continue;m[i].visible=m[i].element.is(":visible");if(!m[i].visible)continue;m[i].offset=m[i].element.offset();m[i].proportions={width:m[i].element.outerWidth(),height:m[i].element.outerHeight()};if(type=="dragstart"||type=="sortactivate")m[i].activate.call(m[i],e);}},drop:function(draggable,e){var dropped=false;$.each($.ui.ddmanager.droppables,function(){if(!this.options)return;if(!this.options.disabled&&this.visible&&$.ui.intersect(draggable,this,this.options.tolerance))
+dropped=this.drop.call(this,e);if(!this.options.disabled&&this.visible&&this.options.accept.call(this.element,(draggable.currentItem||draggable.element))){this.isout=1;this.isover=0;this.deactivate.call(this,e);}});return dropped;},drag:function(draggable,e){if(draggable.options.refreshPositions)$.ui.ddmanager.prepareOffsets(draggable,e);$.each($.ui.ddmanager.droppables,function(){if(this.disabled||this.greedyChild||!this.visible)return;var intersects=$.ui.intersect(draggable,this,this.options.tolerance);var c=!intersects&&this.isover==1?'isout':(intersects&&this.isover==0?'isover':null);if(!c)return;var parentInstance;if(this.options.greedy){var parent=this.element.parents('.ui-droppable:eq(0)');if(parent.length){parentInstance=$.data(parent[0],'droppable');parentInstance.greedyChild=(c=='isover'?1:0);}}
+if(parentInstance&&c=='isover'){parentInstance['isover']=0;parentInstance['isout']=1;parentInstance.out.call(parentInstance,e);}
+this[c]=1;this[c=='isout'?'isover':'isout']=0;this[c=="isover"?"over":"out"].call(this,e);if(parentInstance&&c=='isout'){parentInstance['isout']=0;parentInstance['isover']=1;parentInstance.over.call(parentInstance,e);}});}};$.ui.plugin.add("droppable","activeClass",{activate:function(e,ui){$(this).addClass(ui.options.activeClass);},deactivate:function(e,ui){$(this).removeClass(ui.options.activeClass);},drop:function(e,ui){$(this).removeClass(ui.options.activeClass);}});$.ui.plugin.add("droppable","hoverClass",{over:function(e,ui){$(this).addClass(ui.options.hoverClass);},out:function(e,ui){$(this).removeClass(ui.options.hoverClass);},drop:function(e,ui){$(this).removeClass(ui.options.hoverClass);}});})(jQuery);(function($){$.widget("ui.resizable",$.extend($.ui.mouse,{init:function(){var self=this,o=this.options;var elpos=this.element.css('position');this.element.addClass("ui-resizable").css({position:/static/.test(elpos)?'relative':elpos});$.extend(o,{_aspectRatio:!!(o.aspectRatio),proxy:o.proxy||o.ghost||o.animate?o.proxy||'proxy':null,knobHandles:o.knobHandles===true?'ui-resizable-knob-handle':o.knobHandles});var aBorder='1px solid #DEDEDE';o.defaultTheme={'ui-resizable':{display:'block'},'ui-resizable-handle':{position:'absolute',background:'#F2F2F2',fontSize:'0.1px'},'ui-resizable-n':{cursor:'n-resize',height:'4px',left:'0px',right:'0px',borderTop:aBorder},'ui-resizable-s':{cursor:'s-resize',height:'4px',left:'0px',right:'0px',borderBottom:aBorder},'ui-resizable-e':{cursor:'e-resize',width:'4px',top:'0px',bottom:'0px',borderRight:aBorder},'ui-resizable-w':{cursor:'w-resize',width:'4px',top:'0px',bottom:'0px',borderLeft:aBorder},'ui-resizable-se':{cursor:'se-resize',width:'4px',height:'4px',borderRight:aBorder,borderBottom:aBorder},'ui-resizable-sw':{cursor:'sw-resize',width:'4px',height:'4px',borderBottom:aBorder,borderLeft:aBorder},'ui-resizable-ne':{cursor:'ne-resize',width:'4px',height:'4px',borderRight:aBorder,borderTop:aBorder},'ui-resizable-nw':{cursor:'nw-resize',width:'4px',height:'4px',borderLeft:aBorder,borderTop:aBorder}};o.knobTheme={'ui-resizable-handle':{background:'#F2F2F2',border:'1px solid #808080',height:'8px',width:'8px'},'ui-resizable-n':{cursor:'n-resize',top:'0px',left:'45%'},'ui-resizable-s':{cursor:'s-resize',bottom:'0px',left:'45%'},'ui-resizable-e':{cursor:'e-resize',right:'0px',top:'45%'},'ui-resizable-w':{cursor:'w-resize',left:'0px',top:'45%'},'ui-resizable-se':{cursor:'se-resize',right:'0px',bottom:'0px'},'ui-resizable-sw':{cursor:'sw-resize',left:'0px',bottom:'0px'},'ui-resizable-nw':{cursor:'nw-resize',left:'0px',top:'0px'},'ui-resizable-ne':{cursor:'ne-resize',right:'0px',top:'0px'}};o._nodeName=this.element[0].nodeName;if(o._nodeName.match(/canvas|textarea|input|select|button|img/i)){var el=this.element;if(/relative/.test(el.css('position'))&&$.browser.opera)
+el.css({position:'relative',top:'auto',left:'auto'});el.wrap($('<div class="ui-wrapper" style="overflow: hidden;"></div>').css({position:el.css('position'),width:el.outerWidth(),height:el.outerHeight(),top:el.css('top'),left:el.css('left')}));var oel=this.element;this.element=this.element.parent();this.element.data('resizable',this);this.element.css({marginLeft:oel.css("marginLeft"),marginTop:oel.css("marginTop"),marginRight:oel.css("marginRight"),marginBottom:oel.css("marginBottom")});oel.css({marginLeft:0,marginTop:0,marginRight:0,marginBottom:0});if($.browser.safari&&o.preventDefault)oel.css('resize','none');o.proportionallyResize=oel.css({position:'static',zoom:1,display:'block'});this.element.css({margin:oel.css('margin')});this._proportionallyResize();}
+if(!o.handles)o.handles=!$('.ui-resizable-handle',this.element).length?"e,s,se":{n:'.ui-resizable-n',e:'.ui-resizable-e',s:'.ui-resizable-s',w:'.ui-resizable-w',se:'.ui-resizable-se',sw:'.ui-resizable-sw',ne:'.ui-resizable-ne',nw:'.ui-resizable-nw'};if(o.handles.constructor==String){o.zIndex=o.zIndex||1000;if(o.handles=='all')o.handles='n,e,s,w,se,sw,ne,nw';var n=o.handles.split(",");o.handles={};var insertionsDefault={handle:'position: absolute; display: none; overflow:hidden;',n:'top: 0pt; width:100%;',e:'right: 0pt; height:100%;',s:'bottom: 0pt; width:100%;',w:'left: 0pt; height:100%;',se:'bottom: 0pt; right: 0px;',sw:'bottom: 0pt; left: 0px;',ne:'top: 0pt; right: 0px;',nw:'top: 0pt; left: 0px;'};for(var i=0;i<n.length;i++){var handle=$.trim(n[i]),dt=o.defaultTheme,hname='ui-resizable-'+handle,loadDefault=!$.ui.css(hname)&&!o.knobHandles,userKnobClass=$.ui.css('ui-resizable-knob-handle'),allDefTheme=$.extend(dt[hname],dt['ui-resizable-handle']),allKnobTheme=$.extend(o.knobTheme[hname],!userKnobClass?o.knobTheme['ui-resizable-handle']:{});var applyZIndex=/sw|se|ne|nw/.test(handle)?{zIndex:++o.zIndex}:{};var defCss=(loadDefault?insertionsDefault[handle]:''),axis=$(['<div class="ui-resizable-handle ',hname,'" style="',defCss,insertionsDefault.handle,'"></div>'].join('')).css(applyZIndex);o.handles[handle]='.ui-resizable-'+handle;this.element.append(axis.css(loadDefault?allDefTheme:{}).css(o.knobHandles?allKnobTheme:{}).addClass(o.knobHandles?'ui-resizable-knob-handle':'').addClass(o.knobHandles));}
+if(o.knobHandles)this.element.addClass('ui-resizable-knob').css(!$.ui.css('ui-resizable-knob')?{}:{});}
+this._renderAxis=function(target){target=target||this.element;for(var i in o.handles){if(o.handles[i].constructor==String)
+o.handles[i]=$(o.handles[i],this.element).show();if(o.transparent)
+o.handles[i].css({opacity:0});if(this.element.is('.ui-wrapper')&&o._nodeName.match(/textarea|input|select|button/i)){var axis=$(o.handles[i],this.element),padWrapper=0;padWrapper=/sw|ne|nw|se|n|s/.test(i)?axis.outerHeight():axis.outerWidth();var padPos=['padding',/ne|nw|n/.test(i)?'Top':/se|sw|s/.test(i)?'Bottom':/^e$/.test(i)?'Right':'Left'].join("");if(!o.transparent)
+target.css(padPos,padWrapper);this._proportionallyResize();}
+if(!$(o.handles[i]).length)continue;}};this._renderAxis(this.element);o._handles=$('.ui-resizable-handle',self.element);if(o.disableSelection)
+o._handles.each(function(i,e){$.ui.disableSelection(e);});o._handles.mouseover(function(){if(!o.resizing){if(this.className)
+var axis=this.className.match(/ui-resizable-(se|sw|ne|nw|n|e|s|w)/i);self.axis=o.axis=axis&&axis[1]?axis[1]:'se';}});if(o.autohide){o._handles.hide();$(self.element).addClass("ui-resizable-autohide").hover(function(){$(this).removeClass("ui-resizable-autohide");o._handles.show();},function(){if(!o.resizing){$(this).addClass("ui-resizable-autohide");o._handles.hide();}});}
+this.mouseInit();},plugins:{},ui:function(){return{axis:this.options.axis,options:this.options};},propagate:function(n,e){$.ui.plugin.call(this,n,[e,this.ui()]);this.element.triggerHandler(n=="resize"?n:["resize",n].join(""),[e,this.ui()],this.options[n]);},destroy:function(){var el=this.element,wrapped=el.children(".ui-resizable").get(0);this.mouseDestroy();var _destroy=function(exp){$(exp).removeClass("ui-resizable ui-resizable-disabled").removeData("resizable").unbind(".resizable").find('.ui-resizable-handle').remove();};_destroy(el);if(el.is('.ui-wrapper')&&wrapped){el.parent().append($(wrapped).css({position:el.css('position'),width:el.outerWidth(),height:el.outerHeight(),top:el.css('top'),left:el.css('left')})).end().remove();_destroy(wrapped);}},mouseStart:function(e){if(this.options.disabled)return false;var handle=false;for(var i in this.options.handles){if($(this.options.handles[i])[0]==e.target)handle=true;}
+if(!handle)return false;var o=this.options,iniPos=this.element.position(),el=this.element,num=function(v){return parseInt(v,10)||0;},ie6=$.browser.msie&&$.browser.version<7;o.resizing=true;o.documentScroll={top:$(document).scrollTop(),left:$(document).scrollLeft()};if(el.is('.ui-draggable')||(/absolute/).test(el.css('position'))){var sOffset=$.browser.msie&&!o.containment&&(/absolute/).test(el.css('position'))&&!(/relative/).test(el.parent().css('position'));var dscrollt=sOffset?o.documentScroll.top:0,dscrolll=sOffset?o.documentScroll.left:0;el.css({position:'absolute',top:(iniPos.top+dscrollt),left:(iniPos.left+dscrolll)});}
+if($.browser.opera&&/relative/.test(el.css('position')))
+el.css({position:'relative',top:'auto',left:'auto'});this._renderProxy();var curleft=num(this.helper.css('left')),curtop=num(this.helper.css('top'));this.offset=this.helper.offset();this.position={left:curleft,top:curtop};this.size=o.proxy||ie6?{width:el.outerWidth(),height:el.outerHeight()}:{width:el.width(),height:el.height()};this.originalSize=o.proxy||ie6?{width:el.outerWidth(),height:el.outerHeight()}:{width:el.width(),height:el.height()};this.originalPosition={left:curleft,top:curtop};this.sizeDiff={width:el.outerWidth()-el.width(),height:el.outerHeight()-el.height()};this.originalMousePosition={left:e.pageX,top:e.pageY};o.aspectRatio=(typeof o.aspectRatio=='number')?o.aspectRatio:((this.originalSize.height/this.originalSize.width)||1);if(o.preserveCursor)
+$('body').css('cursor',this.axis+'-resize');this.propagate("start",e);return true;},mouseDrag:function(e){var el=this.helper,o=this.options,props={},self=this,smp=this.originalMousePosition,a=this.axis;var dx=(e.pageX-smp.left)||0,dy=(e.pageY-smp.top)||0;var trigger=this._change[a];if(!trigger)return false;var data=trigger.apply(this,[e,dx,dy]),ie6=$.browser.msie&&$.browser.version<7,csdif=this.sizeDiff;if(o._aspectRatio||e.shiftKey)
+data=this._updateRatio(data,e);data=this._respectSize(data,e);this.propagate("resize",e);el.css({top:this.position.top+"px",left:this.position.left+"px",width:this.size.width+"px",height:this.size.height+"px"});if(!o.proxy&&o.proportionallyResize)
+this._proportionallyResize();this._updateCache(data);return false;},mouseStop:function(e){this.options.resizing=false;var o=this.options,num=function(v){return parseInt(v,10)||0;},self=this;if(o.proxy){var pr=o.proportionallyResize,ista=pr&&(/textarea/i).test(pr.get(0).nodeName),soffseth=ista&&$.ui.hasScroll(pr.get(0),'left')?0:self.sizeDiff.height,soffsetw=ista?0:self.sizeDiff.width;var s={width:(self.size.width-soffsetw),height:(self.size.height-soffseth)},left=(parseInt(self.element.css('left'),10)+(self.position.left-self.originalPosition.left))||null,top=(parseInt(self.element.css('top'),10)+(self.position.top-self.originalPosition.top))||null;if(!o.animate)
+this.element.css($.extend(s,{top:top,left:left}));if(o.proxy&&!o.animate)this._proportionallyResize();}
+if(o.preserveCursor)
+$('body').css('cursor','auto');this.propagate("stop",e);if(o.proxy)this.helper.remove();return false;},_updateCache:function(data){var o=this.options;this.offset=this.helper.offset();if(data.left)this.position.left=data.left;if(data.top)this.position.top=data.top;if(data.height)this.size.height=data.height;if(data.width)this.size.width=data.width;},_updateRatio:function(data,e){var o=this.options,cpos=this.position,csize=this.size,a=this.axis;if(data.height)data.width=(csize.height/o.aspectRatio);else if(data.width)data.height=(csize.width*o.aspectRatio);if(a=='sw'){data.left=cpos.left+(csize.width-data.width);data.top=null;}
+if(a=='nw'){data.top=cpos.top+(csize.height-data.height);data.left=cpos.left+(csize.width-data.width);}
+return data;},_respectSize:function(data,e){var el=this.helper,o=this.options,pRatio=o._aspectRatio||e.shiftKey,a=this.axis,ismaxw=data.width&&o.maxWidth&&o.maxWidth<data.width,ismaxh=data.height&&o.maxHeight&&o.maxHeight<data.height,isminw=data.width&&o.minWidth&&o.minWidth>data.width,isminh=data.height&&o.minHeight&&o.minHeight>data.height;if(isminw)data.width=o.minWidth;if(isminh)data.height=o.minHeight;if(ismaxw)data.width=o.maxWidth;if(ismaxh)data.height=o.maxHeight;var dw=this.originalPosition.left+this.originalSize.width,dh=this.position.top+this.size.height;var cw=/sw|nw|w/.test(a),ch=/nw|ne|n/.test(a);if(isminw&&cw)data.left=dw-o.minWidth;if(ismaxw&&cw)data.left=dw-o.maxWidth;if(isminh&&ch)data.top=dh-o.minHeight;if(ismaxh&&ch)data.top=dh-o.maxHeight;var isNotwh=!data.width&&!data.height;if(isNotwh&&!data.left&&data.top)data.top=null;else if(isNotwh&&!data.top&&data.left)data.left=null;return data;},_proportionallyResize:function(){var o=this.options;if(!o.proportionallyResize)return;var prel=o.proportionallyResize,el=this.helper||this.element;if(!o.borderDif){var b=[prel.css('borderTopWidth'),prel.css('borderRightWidth'),prel.css('borderBottomWidth'),prel.css('borderLeftWidth')],p=[prel.css('paddingTop'),prel.css('paddingRight'),prel.css('paddingBottom'),prel.css('paddingLeft')];o.borderDif=$.map(b,function(v,i){var border=parseInt(v,10)||0,padding=parseInt(p[i],10)||0;return border+padding;});}
+prel.css({height:(el.height()-o.borderDif[0]-o.borderDif[2])+"px",width:(el.width()-o.borderDif[1]-o.borderDif[3])+"px"});},_renderProxy:function(){var el=this.element,o=this.options;this.elementOffset=el.offset();if(o.proxy){this.helper=this.helper||$('<div style="overflow:hidden;"></div>');var ie6=$.browser.msie&&$.browser.version<7,ie6offset=(ie6?1:0),pxyoffset=(ie6?2:-1);this.helper.addClass(o.proxy).css({width:el.outerWidth()+pxyoffset,height:el.outerHeight()+pxyoffset,position:'absolute',left:this.elementOffset.left-ie6offset+'px',top:this.elementOffset.top-ie6offset+'px',zIndex:++o.zIndex});this.helper.appendTo("body");if(o.disableSelection)
+$.ui.disableSelection(this.helper.get(0));}else{this.helper=el;}},_change:{e:function(e,dx,dy){return{width:this.originalSize.width+dx};},w:function(e,dx,dy){var o=this.options,cs=this.originalSize,sp=this.originalPosition;return{left:sp.left+dx,width:cs.width-dx};},n:function(e,dx,dy){var o=this.options,cs=this.originalSize,sp=this.originalPosition;return{top:sp.top+dy,height:cs.height-dy};},s:function(e,dx,dy){return{height:this.originalSize.height+dy};},se:function(e,dx,dy){return $.extend(this._change.s.apply(this,arguments),this._change.e.apply(this,[e,dx,dy]));},sw:function(e,dx,dy){return $.extend(this._change.s.apply(this,arguments),this._change.w.apply(this,[e,dx,dy]));},ne:function(e,dx,dy){return $.extend(this._change.n.apply(this,arguments),this._change.e.apply(this,[e,dx,dy]));},nw:function(e,dx,dy){return $.extend(this._change.n.apply(this,arguments),this._change.w.apply(this,[e,dx,dy]));}}}));$.extend($.ui.resizable,{defaults:{cancel:":input,button",distance:0,delay:0,preventDefault:true,transparent:false,minWidth:10,minHeight:10,aspectRatio:false,disableSelection:true,preserveCursor:true,autohide:false,knobHandles:false}});$.ui.plugin.add("resizable","containment",{start:function(e,ui){var o=ui.options,self=$(this).data("resizable"),el=self.element;var oc=o.containment,ce=(oc instanceof $)?oc.get(0):(/parent/.test(oc))?el.parent().get(0):oc;if(!ce)return;self.containerElement=$(ce);if(/document/.test(oc)||oc==document){self.containerOffset={left:0,top:0};self.containerPosition={left:0,top:0};self.parentData={element:$(document),left:0,top:0,width:$(document).width(),height:$(document).height()||document.body.parentNode.scrollHeight};}
+else{self.containerOffset=$(ce).offset();self.containerPosition=$(ce).position();self.containerSize={height:$(ce).innerHeight(),width:$(ce).innerWidth()};var co=self.containerOffset,ch=self.containerSize.height,cw=self.containerSize.width,width=($.ui.hasScroll(ce,"left")?ce.scrollWidth:cw),height=($.ui.hasScroll(ce)?ce.scrollHeight:ch);self.parentData={element:ce,left:co.left,top:co.top,width:width,height:height};}},resize:function(e,ui){var o=ui.options,self=$(this).data("resizable"),ps=self.containerSize,co=self.containerOffset,cs=self.size,cp=self.position,pRatio=o._aspectRatio||e.shiftKey,cop={top:0,left:0},ce=self.containerElement;if(/static/.test(ce.css('position')))
+cop=self.containerPosition;if(cp.left<(o.proxy?co.left:cop.left)){self.size.width=self.size.width+(o.proxy?(self.position.left-co.left):(self.position.left-cop.left));if(pRatio)self.size.height=self.size.width*o.aspectRatio;self.position.left=o.proxy?co.left:cop.left;}
+if(cp.top<(o.proxy?co.top:0)){self.size.height=self.size.height+(o.proxy?(self.position.top-co.top):self.position.top);if(pRatio)self.size.width=self.size.height/o.aspectRatio;self.position.top=o.proxy?co.top:0;}
+var woset=(o.proxy?self.offset.left-co.left:(self.position.left-cop.left))+self.sizeDiff.width,hoset=(o.proxy?self.offset.top-co.top:self.position.top)+self.sizeDiff.height;if(woset+self.size.width>=self.parentData.width){self.size.width=self.parentData.width-woset;if(pRatio)self.size.height=self.size.width*o.aspectRatio;}
+if(hoset+self.size.height>=self.parentData.height){self.size.height=self.parentData.height-hoset;if(pRatio)self.size.width=self.size.height/o.aspectRatio;}},stop:function(e,ui){var o=ui.options,self=$(this).data("resizable"),cp=self.position,co=self.containerOffset,cop=self.containerPosition,ce=self.containerElement;var helper=$(self.helper),ho=helper.offset(),w=helper.innerWidth(),h=helper.innerHeight();if(o.proxy&&!o.animate&&/relative/.test(ce.css('position')))
+$(this).css({left:(ho.left-co.left),top:(ho.top-co.top),width:w,height:h});if(o.proxy&&!o.animate&&/static/.test(ce.css('position')))
+$(this).css({left:cop.left+(ho.left-co.left),top:cop.top+(ho.top-co.top),width:w,height:h});}});$.ui.plugin.add("resizable","grid",{resize:function(e,ui){var o=ui.options,self=$(this).data("resizable"),cs=self.size,os=self.originalSize,op=self.originalPosition,a=self.axis,ratio=o._aspectRatio||e.shiftKey;o.grid=typeof o.grid=="number"?[o.grid,o.grid]:o.grid;var ox=Math.round((cs.width-os.width)/(o.grid[0]||1))*(o.grid[0]||1),oy=Math.round((cs.height-os.height)/(o.grid[1]||1))*(o.grid[1]||1);if(/^(se|s|e)$/.test(a)){self.size.width=os.width+ox;self.size.height=os.height+oy;}
+else if(/^(ne)$/.test(a)){self.size.width=os.width+ox;self.size.height=os.height+oy;self.position.top=op.top-oy;}
+else if(/^(sw)$/.test(a)){self.size.width=os.width+ox;self.size.height=os.height+oy;self.position.left=op.left-ox;}
+else{self.size.width=os.width+ox;self.size.height=os.height+oy;self.position.top=op.top-oy;self.position.left=op.left-ox;}}});$.ui.plugin.add("resizable","animate",{stop:function(e,ui){var o=ui.options,self=$(this).data("resizable");var pr=o.proportionallyResize,ista=pr&&(/textarea/i).test(pr.get(0).nodeName),soffseth=ista&&$.ui.hasScroll(pr.get(0),'left')?0:self.sizeDiff.height,soffsetw=ista?0:self.sizeDiff.width;var style={width:(self.size.width-soffsetw),height:(self.size.height-soffseth)},left=(parseInt(self.element.css('left'),10)+(self.position.left-self.originalPosition.left))||null,top=(parseInt(self.element.css('top'),10)+(self.position.top-self.originalPosition.top))||null;self.element.animate($.extend(style,top&&left?{top:top,left:left}:{}),{duration:o.animateDuration||"slow",easing:o.animateEasing||"swing",step:function(){var data={width:parseInt(self.element.css('width'),10),height:parseInt(self.element.css('height'),10),top:parseInt(self.element.css('top'),10),left:parseInt(self.element.css('left'),10)};if(pr)pr.css({width:data.width,height:data.height});self._updateCache(data);self.propagate("animate",e);}});}});$.ui.plugin.add("resizable","ghost",{start:function(e,ui){var o=ui.options,self=$(this).data("resizable"),pr=o.proportionallyResize,cs=self.size;if(!pr)self.ghost=self.element.clone();else self.ghost=pr.clone();self.ghost.css({opacity:.25,display:'block',position:'relative',height:cs.height,width:cs.width,margin:0,left:0,top:0}).addClass('ui-resizable-ghost').addClass(typeof o.ghost=='string'?o.ghost:'');self.ghost.appendTo(self.helper);},resize:function(e,ui){var o=ui.options,self=$(this).data("resizable"),pr=o.proportionallyResize;if(self.ghost)self.ghost.css({position:'relative',height:self.size.height,width:self.size.width});},stop:function(e,ui){var o=ui.options,self=$(this).data("resizable"),pr=o.proportionallyResize;if(self.ghost&&self.helper)self.helper.get(0).removeChild(self.ghost.get(0));}});$.ui.plugin.add("resizable","alsoResize",{start:function(e,ui){var o=ui.options,self=$(this).data("resizable"),_store=function(exp){$(exp).each(function(){$(this).data("resizable-alsoresize",{width:parseInt($(this).width(),10),height:parseInt($(this).height(),10),left:parseInt($(this).css('left'),10),top:parseInt($(this).css('top'),10)});});};if(typeof(o.alsoResize)=='object'){$.each(o.alsoResize,function(exp,c){_store(exp);});}else{_store(o.alsoResize);}},resize:function(e,ui){var o=ui.options,self=$(this).data("resizable"),os=self.originalSize,op=self.originalPosition;var delta={height:(self.size.height-os.height)||0,width:(self.size.width-os.width)||0,top:(self.position.top-op.top)||0,left:(self.position.left-op.left)||0},_alsoResize=function(exp,c){$(exp).each(function(){var start=$(this).data("resizable-alsoresize"),style={},css=c&&c.length?c:['width','height','top','left'];$.each(css||['width','height','top','left'],function(i,prop){var sum=(start[prop]||0)+(delta[prop]||0);if(sum&&sum>=0)
+style[prop]=sum||null;});$(this).css(style);});};if(typeof(o.alsoResize)=='object'){$.each(o.alsoResize,function(exp,c){_alsoResize(exp,c);});}else{_alsoResize(o.alsoResize);}},stop:function(e,ui){$(this).removeData("resizable-alsoresize-start");}});})(jQuery);(function($){$.widget("ui.selectable",$.extend($.ui.mouse,{init:function(){var self=this;this.element.addClass("ui-selectable");this.dragged=false;var selectees;this.refresh=function(){selectees=$(self.options.filter,self.element[0]);selectees.each(function(){var $this=$(this);var pos=$this.offset();$.data(this,"selectable-item",{element:this,$element:$this,left:pos.left,top:pos.top,right:pos.left+$this.width(),bottom:pos.top+$this.height(),startselected:false,selected:$this.hasClass('ui-selected'),selecting:$this.hasClass('ui-selecting'),unselecting:$this.hasClass('ui-unselecting')});});};this.refresh();this.selectees=selectees.addClass("ui-selectee");this.mouseInit();this.helper=$(document.createElement('div')).css({border:'1px dotted black'});},toggle:function(){if(this.options.disabled){this.enable();}else{this.disable();}},destroy:function(){this.element.removeClass("ui-selectable ui-selectable-disabled").removeData("selectable").unbind(".selectable");this.mouseDestroy();},mouseStart:function(e){var self=this;this.opos=[e.pageX,e.pageY];if(this.options.disabled)
+return;var options=this.options;this.selectees=$(options.filter,this.element[0]);this.element.triggerHandler("selectablestart",[e,{"selectable":this.element[0],"options":options}],options.start);$('body').append(this.helper);this.helper.css({"z-index":100,"position":"absolute","left":e.clientX,"top":e.clientY,"width":0,"height":0});if(options.autoRefresh){this.refresh();}
+this.selectees.filter('.ui-selected').each(function(){var selectee=$.data(this,"selectable-item");selectee.startselected=true;if(!e.ctrlKey){selectee.$element.removeClass('ui-selected');selectee.selected=false;selectee.$element.addClass('ui-unselecting');selectee.unselecting=true;self.element.triggerHandler("selectableunselecting",[e,{selectable:self.element[0],unselecting:selectee.element,options:options}],options.unselecting);}});var isSelectee=false;$(e.target).parents().andSelf().each(function(){if($.data(this,"selectable-item"))isSelectee=true;});return this.options.keyboard?!isSelectee:true;},mouseDrag:function(e){var self=this;this.dragged=true;if(this.options.disabled)
+return;var options=this.options;var x1=this.opos[0],y1=this.opos[1],x2=e.pageX,y2=e.pageY;if(x1>x2){var tmp=x2;x2=x1;x1=tmp;}
+if(y1>y2){var tmp=y2;y2=y1;y1=tmp;}
+this.helper.css({left:x1,top:y1,width:x2-x1,height:y2-y1});this.selectees.each(function(){var selectee=$.data(this,"selectable-item");if(!selectee||selectee.element==self.element[0])
+return;var hit=false;if(options.tolerance=='touch'){hit=(!(selectee.left>x2||selectee.right<x1||selectee.top>y2||selectee.bottom<y1));}else if(options.tolerance=='fit'){hit=(selectee.left>x1&&selectee.right<x2&&selectee.top>y1&&selectee.bottom<y2);}
+if(hit){if(selectee.selected){selectee.$element.removeClass('ui-selected');selectee.selected=false;}
+if(selectee.unselecting){selectee.$element.removeClass('ui-unselecting');selectee.unselecting=false;}
+if(!selectee.selecting){selectee.$element.addClass('ui-selecting');selectee.selecting=true;self.element.triggerHandler("selectableselecting",[e,{selectable:self.element[0],selecting:selectee.element,options:options}],options.selecting);}}else{if(selectee.selecting){if(e.ctrlKey&&selectee.startselected){selectee.$element.removeClass('ui-selecting');selectee.selecting=false;selectee.$element.addClass('ui-selected');selectee.selected=true;}else{selectee.$element.removeClass('ui-selecting');selectee.selecting=false;if(selectee.startselected){selectee.$element.addClass('ui-unselecting');selectee.unselecting=true;}
+self.element.triggerHandler("selectableunselecting",[e,{selectable:self.element[0],unselecting:selectee.element,options:options}],options.unselecting);}}
+if(selectee.selected){if(!e.ctrlKey&&!selectee.startselected){selectee.$element.removeClass('ui-selected');selectee.selected=false;selectee.$element.addClass('ui-unselecting');selectee.unselecting=true;self.element.triggerHandler("selectableunselecting",[e,{selectable:self.element[0],unselecting:selectee.element,options:options}],options.unselecting);}}}});return false;},mouseStop:function(e){var self=this;this.dragged=false;var options=this.options;$('.ui-unselecting',this.element[0]).each(function(){var selectee=$.data(this,"selectable-item");selectee.$element.removeClass('ui-unselecting');selectee.unselecting=false;selectee.startselected=false;self.element.triggerHandler("selectableunselected",[e,{selectable:self.element[0],unselected:selectee.element,options:options}],options.unselected);});$('.ui-selecting',this.element[0]).each(function(){var selectee=$.data(this,"selectable-item");selectee.$element.removeClass('ui-selecting').addClass('ui-selected');selectee.selecting=false;selectee.selected=true;selectee.startselected=true;self.element.triggerHandler("selectableselected",[e,{selectable:self.element[0],selected:selectee.element,options:options}],options.selected);});this.element.triggerHandler("selectablestop",[e,{selectable:self.element[0],options:this.options}],this.options.stop);this.helper.remove();return false;}}));$.extend($.ui.selectable,{defaults:{distance:0,delay:0,cancel:":input,button",appendTo:'body',autoRefresh:true,filter:'*',tolerance:'touch'}});})(jQuery);(function($){function contains(a,b){var safari2=$.browser.safari&&$.browser.version<522;if(a.contains&&!safari2){return a.contains(b);}
+if(a.compareDocumentPosition)
+return!!(a.compareDocumentPosition(b)&16);while(b=b.parentNode)
+if(b==a)return true;return false;};$.widget("ui.sortable",$.extend($.ui.mouse,{init:function(){var o=this.options;this.containerCache={};this.element.addClass("ui-sortable");this.refresh();this.floating=this.items.length?(/left|right/).test(this.items[0].item.css('float')):false;if(!(/(relative|absolute|fixed)/).test(this.element.css('position')))this.element.css('position','relative');this.offset=this.element.offset();this.mouseInit();},plugins:{},ui:function(inst){return{helper:(inst||this)["helper"],placeholder:(inst||this)["placeholder"]||$([]),position:(inst||this)["position"],absolutePosition:(inst||this)["positionAbs"],options:this.options,element:this.element,item:(inst||this)["currentItem"],sender:inst?inst.element:null};},propagate:function(n,e,inst,noPropagation){$.ui.plugin.call(this,n,[e,this.ui(inst)]);if(!noPropagation)this.element.triggerHandler(n=="sort"?n:"sort"+n,[e,this.ui(inst)],this.options[n]);},serialize:function(o){var items=($.isFunction(this.options.items)?this.options.items.call(this.element):$(this.options.items,this.element)).not('.ui-sortable-helper');var str=[];o=o||{};items.each(function(){var res=($(this).attr(o.attribute||'id')||'').match(o.expression||(/(.+)[-=_](.+)/));if(res)str.push((o.key||res[1])+'[]='+(o.key?res[1]:res[2]));});return str.join('&');},toArray:function(attr){var items=($.isFunction(this.options.items)?this.options.items.call(this.element):$(this.options.items,this.element)).not('.ui-sortable-helper');var ret=[];items.each(function(){ret.push($(this).attr(attr||'id'));});return ret;},intersectsWith:function(item){var x1=this.positionAbs.left,x2=x1+this.helperProportions.width,y1=this.positionAbs.top,y2=y1+this.helperProportions.height;var l=item.left,r=l+item.width,t=item.top,b=t+item.height;if(this.options.tolerance=="pointer"||(this.options.tolerance=="guess"&&this.helperProportions[this.floating?'width':'height']>item[this.floating?'width':'height'])){return(y1+this.offset.click.top>t&&y1+this.offset.click.top<b&&x1+this.offset.click.left>l&&x1+this.offset.click.left<r);}else{return(l<x1+(this.helperProportions.width/2)&&x2-(this.helperProportions.width/2)<r&&t<y1+(this.helperProportions.height/2)&&y2-(this.helperProportions.height/2)<b);}},intersectsWithEdge:function(item){var x1=this.positionAbs.left,x2=x1+this.helperProportions.width,y1=this.positionAbs.top,y2=y1+this.helperProportions.height;var l=item.left,r=l+item.width,t=item.top,b=t+item.height;if(this.options.tolerance=="pointer"||(this.options.tolerance=="guess"&&this.helperProportions[this.floating?'width':'height']>item[this.floating?'width':'height'])){if(!(y1+this.offset.click.top>t&&y1+this.offset.click.top<b&&x1+this.offset.click.left>l&&x1+this.offset.click.left<r))return false;if(this.floating){if(x1+this.offset.click.left>l&&x1+this.offset.click.left<l+item.width/2)return 2;if(x1+this.offset.click.left>l+item.width/2&&x1+this.offset.click.left<r)return 1;}else{if(y1+this.offset.click.top>t&&y1+this.offset.click.top<t+item.height/2)return 2;if(y1+this.offset.click.top>t+item.height/2&&y1+this.offset.click.top<b)return 1;}}else{if(!(l<x1+(this.helperProportions.width/2)&&x2-(this.helperProportions.width/2)<r&&t<y1+(this.helperProportions.height/2)&&y2-(this.helperProportions.height/2)<b))return false;if(this.floating){if(x2>l&&x1<l)return 2;if(x1<r&&x2>r)return 1;}else{if(y2>t&&y1<t)return 1;if(y1<b&&y2>b)return 2;}}
+return false;},refresh:function(){this.refreshItems();this.refreshPositions();},refreshItems:function(){this.items=[];this.containers=[this];var items=this.items;var queries=[$.isFunction(this.options.items)?this.options.items.call(this.element):$(this.options.items,this.element)];if(this.options.connectWith){for(var i=this.options.connectWith.length-1;i>=0;i--){var cur=$(this.options.connectWith[i]);for(var j=cur.length-1;j>=0;j--){var inst=$.data(cur[j],'sortable');if(inst&&!inst.options.disabled){queries.push($.isFunction(inst.options.items)?inst.options.items.call(inst.element):$(inst.options.items,inst.element));this.containers.push(inst);}};};}
+for(var i=queries.length-1;i>=0;i--){queries[i].each(function(){$.data(this,'sortable-item',true);items.push({item:$(this),width:0,height:0,left:0,top:0});});};},refreshPositions:function(fast){for(var i=this.items.length-1;i>=0;i--){var t=this.items[i].item;if(!fast)this.items[i].width=(this.options.toleranceElement?$(this.options.toleranceElement,t):t).outerWidth();if(!fast)this.items[i].height=(this.options.toleranceElement?$(this.options.toleranceElement,t):t).outerHeight();var p=(this.options.toleranceElement?$(this.options.toleranceElement,t):t).offset();this.items[i].left=p.left;this.items[i].top=p.top;};for(var i=this.containers.length-1;i>=0;i--){var p=this.containers[i].element.offset();this.containers[i].containerCache.left=p.left;this.containers[i].containerCache.top=p.top;this.containers[i].containerCache.width=this.containers[i].element.outerWidth();this.containers[i].containerCache.height=this.containers[i].element.outerHeight();};},destroy:function(){this.element.removeClass("ui-sortable ui-sortable-disabled").removeData("sortable").unbind(".sortable");this.mouseDestroy();for(var i=this.items.length-1;i>=0;i--)
+this.items[i].item.removeData("sortable-item");},createPlaceholder:function(that){var self=that||this,o=self.options;if(o.placeholder.constructor==String){var className=o.placeholder;o.placeholder={element:function(){return $('<div></div>').addClass(className)[0];},update:function(i,p){p.css(i.offset()).css({width:i.outerWidth(),height:i.outerHeight()});}};}
+self.placeholder=$(o.placeholder.element.call(self.element,self.currentItem)).appendTo('body').css({position:'absolute'});o.placeholder.update.call(self.element,self.currentItem,self.placeholder);},contactContainers:function(e){for(var i=this.containers.length-1;i>=0;i--){if(this.intersectsWith(this.containers[i].containerCache)){if(!this.containers[i].containerCache.over){if(this.currentContainer!=this.containers[i]){var dist=10000;var itemWithLeastDistance=null;var base=this.positionAbs[this.containers[i].floating?'left':'top'];for(var j=this.items.length-1;j>=0;j--){if(!contains(this.containers[i].element[0],this.items[j].item[0]))continue;var cur=this.items[j][this.containers[i].floating?'left':'top'];if(Math.abs(cur-base)<dist){dist=Math.abs(cur-base);itemWithLeastDistance=this.items[j];}}
+if(!itemWithLeastDistance&&!this.options.dropOnEmpty)
+continue;if(this.placeholder)this.placeholder.remove();if(this.containers[i].options.placeholder){this.containers[i].createPlaceholder(this);}else{this.placeholder=null;;}
+itemWithLeastDistance?this.rearrange(e,itemWithLeastDistance):this.rearrange(e,null,this.containers[i].element);this.propagate("change",e);this.containers[i].propagate("change",e,this);this.currentContainer=this.containers[i];}
+this.containers[i].propagate("over",e,this);this.containers[i].containerCache.over=1;}}else{if(this.containers[i].containerCache.over){this.containers[i].propagate("out",e,this);this.containers[i].containerCache.over=0;}}};},mouseCapture:function(e,overrideHandle){if(this.options.disabled||this.options.type=='static')return false;var currentItem=null,nodes=$(e.target).parents().each(function(){if($.data(this,'sortable-item')){currentItem=$(this);return false;}});if($.data(e.target,'sortable-item'))currentItem=$(e.target);if(!currentItem)return false;if(this.options.handle&&!overrideHandle){var validHandle=false;$(this.options.handle,currentItem).find("*").andSelf().each(function(){if(this==e.target)validHandle=true;});if(!validHandle)return false;}
+this.currentItem=currentItem;return true;},mouseStart:function(e,overrideHandle,noActivation){var o=this.options;this.currentContainer=this;this.refresh();this.helper=typeof o.helper=='function'?$(o.helper.apply(this.element[0],[e,this.currentItem])):this.currentItem.clone();if(!this.helper.parents('body').length)this.helper.appendTo((o.appendTo!='parent'?o.appendTo:this.currentItem[0].parentNode));this.helper.css({position:'absolute',clear:'both'}).addClass('ui-sortable-helper');this.margins={left:(parseInt(this.currentItem.css("marginLeft"),10)||0),top:(parseInt(this.currentItem.css("marginTop"),10)||0)};this.offset=this.currentItem.offset();this.offset={top:this.offset.top-this.margins.top,left:this.offset.left-this.margins.left};this.offset.click={left:e.pageX-this.offset.left,top:e.pageY-this.offset.top};this.offsetParent=this.helper.offsetParent();var po=this.offsetParent.offset();this.offset.parent={top:po.top+(parseInt(this.offsetParent.css("borderTopWidth"),10)||0),left:po.left+(parseInt(this.offsetParent.css("borderLeftWidth"),10)||0)};this.originalPosition=this.generatePosition(e);this.helperProportions={width:this.helper.outerWidth(),height:this.helper.outerHeight()};if(o.cursorAt){if(o.cursorAt.left!=undefined)this.offset.click.left=o.cursorAt.left;if(o.cursorAt.right!=undefined)this.offset.click.left=this.helperProportions.width-o.cursorAt.right;if(o.cursorAt.top!=undefined)this.offset.click.top=o.cursorAt.top;if(o.cursorAt.bottom!=undefined)this.offset.click.top=this.helperProportions.height-o.cursorAt.bottom;}
+this.domPosition=this.currentItem.prev()[0];if(o.containment){if(o.containment=='parent')o.containment=this.helper[0].parentNode;if(o.containment=='document'||o.containment=='window')this.containment=[0-this.offset.parent.left,0-this.offset.parent.top,$(o.containment=='document'?document:window).width()-this.offset.parent.left-this.helperProportions.width-this.margins.left-(parseInt(this.element.css("marginRight"),10)||0),($(o.containment=='document'?document:window).height()||document.body.parentNode.scrollHeight)-this.offset.parent.top-this.helperProportions.height-this.margins.top-(parseInt(this.element.css("marginBottom"),10)||0)];if(!(/^(document|window|parent)$/).test(o.containment)){var ce=$(o.containment)[0];var co=$(o.containment).offset();this.containment=[co.left+(parseInt($(ce).css("borderLeftWidth"),10)||0)-this.offset.parent.left,co.top+(parseInt($(ce).css("borderTopWidth"),10)||0)-this.offset.parent.top,co.left+Math.max(ce.scrollWidth,ce.offsetWidth)-(parseInt($(ce).css("borderLeftWidth"),10)||0)-this.offset.parent.left-this.helperProportions.width-this.margins.left-(parseInt(this.currentItem.css("marginRight"),10)||0),co.top+Math.max(ce.scrollHeight,ce.offsetHeight)-(parseInt($(ce).css("borderTopWidth"),10)||0)-this.offset.parent.top-this.helperProportions.height-this.margins.top-(parseInt(this.currentItem.css("marginBottom"),10)||0)];}}
+if(o.placeholder)this.createPlaceholder();this.propagate("start",e);this.helperProportions={width:this.helper.outerWidth(),height:this.helper.outerHeight()};if(this.options.placeholder!='clone')this.currentItem.css('visibility','hidden');if(!noActivation){for(var i=this.containers.length-1;i>=0;i--){this.containers[i].propagate("activate",e,this);}}
+if($.ui.ddmanager)$.ui.ddmanager.current=this;if($.ui.ddmanager&&!o.dropBehaviour)$.ui.ddmanager.prepareOffsets(this,e);this.dragging=true;this.mouseDrag(e);return true;},convertPositionTo:function(d,pos){if(!pos)pos=this.position;var mod=d=="absolute"?1:-1;return{top:(pos.top
+-(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollTop)*mod
+-(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollLeft)*mod
++(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollTop)),left:(e.pageX
++(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollLeft))};if(!this.originalPosition)return position;if(this.containment){if(position.left<this.containment[0])position.left=this.containment[0];if(position.top<this.containment[1])position.top=this.containment[1];if(position.left>this.containment[2])position.left=this.containment[2];if(position.top>this.containment[3])position.top=this.containment[3];}
+return position;},mouseDrag:function(e){this.position=this.generatePosition(e);this.positionAbs=this.convertPositionTo("absolute");for(var i=this.items.length-1;i>=0;i--){var intersection=this.intersectsWithEdge(this.items[i]);if(!intersection)continue;if(this.items[i].item[0]!=this.currentItem[0]&&this.currentItem[intersection==1?"next":"prev"]()[0]!=this.items[i].item[0]&&!contains(this.currentItem[0],this.items[i].item[0])&&(this.options.type=='semi-dynamic'?!contains(this.element[0],this.items[i].item[0]):true)){this.direction=intersection==1?"down":"up";this.rearrange(e,this.items[i]);this.propagate("change",e);break;}}
+this.contactContainers(e);this.propagate("sort",e);if(!this.options.axis||this.options.axis=="x")this.helper[0].style.left=this.position.left+'px';if(!this.options.axis||this.options.axis=="y")this.helper[0].style.top=this.position.top+'px';if($.ui.ddmanager)$.ui.ddmanager.drag(this,e);return false;},mouseStop:function(e,noPropagation){if($.ui.ddmanager&&!this.options.dropBehaviour)
+$.ui.ddmanager.drop(this,e);if(this.options.revert){var self=this;var cur=self.currentItem.offset();if(self.placeholder)self.placeholder.animate({opacity:'hide'},(parseInt(this.options.revert,10)||500)-50);$(this.helper).animate({left:cur.left-this.offset.parent.left-self.margins.left+(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollLeft),top:cur.top-this.offset.parent.top-self.margins.top+(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollTop)},parseInt(this.options.revert,10)||500,function(){self.propagate("stop",e,null,noPropagation);self.clear(e);});}else{this.propagate("stop",e,null,noPropagation);this.clear(e,noPropagation);}
+return false;},clear:function(e,noPropagation){if(this.domPosition!=this.currentItem.prev().not(".ui-sortable-helper")[0])this.propagate("update",e,null,noPropagation);if(!contains(this.element[0],this.currentItem[0])){if(this.domPosition==this.currentItem.prev().not(".ui-sortable-helper")[0])this.propagate("update",e,null,noPropagation);this.propagate("remove",e,null,noPropagation);for(var i=this.containers.length-1;i>=0;i--){if(contains(this.containers[i].element[0],this.currentItem[0])){this.containers[i].propagate("update",e,this,noPropagation);this.containers[i].propagate("receive",e,this,noPropagation);}};};for(var i=this.containers.length-1;i>=0;i--){this.containers[i].propagate("deactivate",e,this,noPropagation);if(this.containers[i].containerCache.over){this.containers[i].propagate("out",e,this);this.containers[i].containerCache.over=0;}}
+this.dragging=false;if(this.cancelHelperRemoval)return false;$(this.currentItem).css('visibility','');if(this.placeholder)this.placeholder.remove();this.helper.remove();return true;},rearrange:function(e,i,a){a?a.append(this.currentItem):i.item[this.direction=='down'?'before':'after'](this.currentItem);this.refreshPositions(true);if(this.options.placeholder)this.options.placeholder.update.call(this.element,this.currentItem,this.placeholder);}}));$.extend($.ui.sortable,{getter:"serialize toArray",defaults:{tolerance:"guess",distance:0,delay:0,cancel:":input,button",items:'> *',zIndex:1000,dropOnEmpty:true,appendTo:"parent"}});$.ui.plugin.add("sortable","cursor",{start:function(e,ui){var t=$('body');if(t.css("cursor"))ui.options._cursor=t.css("cursor");t.css("cursor",ui.options.cursor);},stop:function(e,ui){if(ui.options._cursor)$('body').css("cursor",ui.options._cursor);}});$.ui.plugin.add("sortable","zIndex",{start:function(e,ui){var t=ui.helper;if(t.css("zIndex"))ui.options._zIndex=t.css("zIndex");t.css('zIndex',ui.options.zIndex);},stop:function(e,ui){if(ui.options._zIndex)$(ui.helper).css('zIndex',ui.options._zIndex);}});$.ui.plugin.add("sortable","opacity",{start:function(e,ui){var t=ui.helper;if(t.css("opacity"))ui.options._opacity=t.css("opacity");t.css('opacity',ui.options.opacity);},stop:function(e,ui){if(ui.options._opacity)$(ui.helper).css('opacity',ui.options._opacity);}});$.ui.plugin.add("sortable","scroll",{start:function(e,ui){var o=ui.options;var i=$(this).data("sortable");o.scrollSensitivity=o.scrollSensitivity||20;o.scrollSpeed=o.scrollSpeed||20;i.overflowY=function(el){do{if(/auto|scroll/.test(el.css('overflow'))||(/auto|scroll/).test(el.css('overflow-y')))return el;el=el.parent();}while(el[0].parentNode);return $(document);}(i.currentItem);i.overflowX=function(el){do{if(/auto|scroll/.test(el.css('overflow'))||(/auto|scroll/).test(el.css('overflow-x')))return el;el=el.parent();}while(el[0].parentNode);return $(document);}(i.currentItem);if(i.overflowY[0]!=document&&i.overflowY[0].tagName!='HTML')i.overflowYOffset=i.overflowY.offset();if(i.overflowX[0]!=document&&i.overflowX[0].tagName!='HTML')i.overflowXOffset=i.overflowX.offset();},sort:function(e,ui){var o=ui.options;var i=$(this).data("sortable");if(i.overflowY[0]!=document&&i.overflowY[0].tagName!='HTML'){if((i.overflowYOffset.top+i.overflowY[0].offsetHeight)-e.pageY<o.scrollSensitivity)
+$(document).scrollLeft($(document).scrollLeft()+o.scrollSpeed);}}});})(jQuery);
\ No newline at end of file
More information about the Mapbender_commits mailing list
