[Mapbender-commits] r2952 - branches/tree_dev/http/x_test
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Sep 17 06:31:27 EDT 2008
Author: christoph
Date: 2008-09-17 06:31:27 -0400 (Wed, 17 Sep 2008)
New Revision: 2952
   branches/tree_dev/http/x_test/customTree.js
   branches/tree_dev/http/x_test/customTreeModel.js
   branches/tree_dev/http/x_test/tree.html
refactoring
Modified: branches/tree_dev/http/x_test/customTree.js
--- branches/tree_dev/http/x_test/customTree.js	2008-09-17 10:10:20 UTC (rev 2951)
+++ branches/tree_dev/http/x_test/customTree.js	2008-09-17 10:31:27 UTC (rev 2952)
@@ -6,11 +6,96 @@
 	this.$root = $("<ul></ul>");
 	var that = this;
+	var currentlyDraggedNode;
-	var setProperties = function () {
+	var addContextMenuToLeaf = function ($domNode, treeNode) {
+		$domNode.contextMenu('leafMenu', {
+			onContextMenu: function(e) {
+				return true;
+			onShowMenu: function(e, menu) {
+				return menu;
+			bindings: {
+				'deleteService': function () {
+					treeNode.remove();
+	var addContextMenuToFolder = function ($domNode, treeNode) {
+		$domNode.contextMenu('folderMenu', {
+			onContextMenu: function(e){
+				return true;
+			onShowMenu: function(e, menu){
+				return menu;
+			bindings: {
+				'addFolder': function(item){
+					var newChild = treeNode.addChild();
+				'deleteFolder': function(){
+				'editFolder': function(){
+	var addContextMenuToRoot = function ($domNode, treeNode) {
+		$domNode.contextMenu('rootMenu', {
+				return true;
+				return menu;
+			bindings: {
+	var addOpenCloseBehaviour = function ($domNode) {
+		$domNode.toggle(function () {
+			$(this).siblings().hide("fast");
+		}, function () {
+			$(this).siblings().show("fast");
+	var makeNodeDroppable = function ($domNode, treeNode) {
+		$domNode.droppable({
+			"accept": function ($draggable) {
+				var $invalidDroppables = $(".currently-dragging .treeNodeDrop");
+				var $invalidDroppablesMinusThis = $invalidDroppables.not($domNode);
+				if ($invalidDroppables.size() > $invalidDroppablesMinusThis.size()) {
+					return false;
+				return true;
+			"tolerance": "pointer",
+			"drop": function (e, ui) {
+				$toDomNode = $(this);
+				$fromDomNode = $(ui.draggable);
+				currentlyDraggedNode.afterMove = function () {
+					$toDomNode.next().append($(ui.draggable));
+					$(".treeLeaf").removeAttr("style");
+					$("*").removeClass("currently-dragging");
+				currentlyDraggedNode.move(treeNode);
 	 *  A recursive function to draw the nodes of a tree and attach
 	 *  draggables and droppables
@@ -28,20 +113,7 @@
 			$currentLabel = $("<span>" + treeNode.name + "</span>");
 			$currentItem = $("<li class='treeLeaf'></li>");
 			$currentItem.append($currentLabel);
-			$currentLabel.contextMenu('leafMenu', {
-				onContextMenu: function(e) {
-					return true;
-				onShowMenu: function(e, menu) {
-					return menu;
-				bindings: {
-					'deleteService': function () {
-						treeNode.remove();
+			addContextMenuToLeaf($currentLabel, treeNode);
 		else {
 			// this treeNode is an inner node
@@ -57,67 +129,24 @@
 			// (not for root node)
 			if (treeNode != that.myTree.root) {
-				$currentLabel.toggle(function () {
-					$(this).siblings().hide("fast");
-				}, function () {
-					$(this).siblings().show("fast");
+				addOpenCloseBehaviour($currentLabel);
-			// enable folder closing and opening
-			// (not for root node)
+			// enable context menu
-				$currentLabel.contextMenu('folderMenu', {
-					onContextMenu: function(e){
-						return true;
-					onShowMenu: function(e, menu){
-						return menu;
-					bindings: {
-						'addFolder': function(item){
-							var newChild = treeNode.addChild();
-						'deleteFolder': function(){
-						'editFolder': function(){
+				addContextMenuToFolder($currentLabel, treeNode);
+			else {
+				addContextMenuToRoot($currentLabel, treeNode);
 			// make inner nodes droppable
-			$currentLabel.droppable({
-				"accept": function ($draggable) {
-					var $invalidDroppables = $(".currently-dragging .treeNodeDrop");
-					var $invalidDroppablesMinusThis = $invalidDroppables.not($currentLabel);
+			makeNodeDroppable($currentLabel, treeNode);
-					if ($invalidDroppables.size() > $invalidDroppablesMinusThis.size()) {
-						return false;
-					return true;
-				"tolerance": "pointer",
-				"drop": function (e, ui) {
-					$toDomNode = $(this);
-					$fromDomNode = $(ui.draggable);
-					that.myTree.currentlyDraggedNode.afterMove = function () {
-						$toDomNode.next().append($(ui.draggable));
-						$(".treeLeaf").removeAttr("style");
-						$("*").removeClass("currently-dragging");
-					that.myTree.currentlyDraggedNode.move(treeNode);
 			// visit the child nodes (depth first)
@@ -134,7 +163,7 @@
 				"helper": "clone",
 				"start": function(){
 					$(this).addClass("currently-dragging");
-					that.myTree.currentlyDraggedNode = treeNode;
+					currentlyDraggedNode = treeNode;
Modified: branches/tree_dev/http/x_test/customTreeModel.js
--- branches/tree_dev/http/x_test/customTreeModel.js	2008-09-17 10:10:20 UTC (rev 2951)
+++ branches/tree_dev/http/x_test/customTreeModel.js	2008-09-17 10:31:27 UTC (rev 2952)
@@ -119,8 +119,6 @@
 var CustomTree = function () {
 	this.root = new CustomTreeNode (null);
-	this.currentlyDraggedNode = null;
 	var that = this;
Modified: branches/tree_dev/http/x_test/tree.html
--- branches/tree_dev/http/x_test/tree.html	2008-09-17 10:10:20 UTC (rev 2951)
+++ branches/tree_dev/http/x_test/tree.html	2008-09-17 10:31:27 UTC (rev 2952)
@@ -51,6 +51,11 @@
 				<li id="editFolder"><img src="images/folder_edit.png" /> Edit</li>
 			</ul>
 		</div>
+		<div class="contextMenu" id="rootMenu">
+			<ul>
+				<li id="addFolder"><img src="images/folder_add.png" /> Add </li>
+			</ul>
+		</div>
 		<div class="contextMenu" id="leafMenu">
 			<ul>
 				<li id="deleteService"><img src="images/folder_delete.png" /> Delete</li>
More information about the Mapbender_commits mailing list
