[Mapbender-commits] r5059 -
branches/2.6/resources/db/pgsql/UTF-8/update
trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Wed Dec 2 08:36:34 EST 2009
Author: verenadiewald
Date: 2009-12-02 08:36:33 -0500 (Wed, 02 Dec 2009)
New Revision: 5059
branches/2.6/resources/db/pgsql/UTF-8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql
sql for f_auth_varname in table wfs_conf_element was missing
Modified: branches/2.6/resources/db/pgsql/UTF-8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql
--- branches/2.6/resources/db/pgsql/UTF-8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql 2009-12-02 10:03:02 UTC (rev 5058)
+++ branches/2.6/resources/db/pgsql/UTF-8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql 2009-12-02 13:36:33 UTC (rev 5059)
@@ -115,6 +115,7 @@
-- table wfs_conf_element: change in WFS configuration: access to geometries may now be restricted
+ALTER TABLE wfs_conf_element ADD COLUMN f_auth_varname VARCHAR(50);
ALTER TABLE wfs_conf_element ADD COLUMN f_show_detail int4;
ALTER TABLE wfs_conf_element ADD COLUMN f_operator VARCHAR(50);
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql 2009-12-02 10:03:02 UTC (rev 5058)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql 2009-12-02 13:36:33 UTC (rev 5059)
@@ -115,6 +115,7 @@
More information about the Mapbender_commits
