[Mapbender-commits] r5060 - branches/2.6/resources/db/mysql/ISO-8859-1/update branches/2.6/resources/db/mysql/UTF-8/update branches/2.6/resources/db/pgsql/ISO-8859-1/update trunk/mapbender/resources/db/mysql/ISO-8859-1/update trunk/mapbender/resources/db/mysql/UTF-8/update trunk/mapbender/resources/db/pgsql/ISO-8859-1/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Dec 2 08:41:36 EST 2009
Author: verenadiewald
Date: 2009-12-02 08:41:35 -0500 (Wed, 02 Dec 2009)
New Revision: 5060
   branches/2.6/resources/db/mysql/ISO-8859-1/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql
   branches/2.6/resources/db/mysql/UTF-8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql
   branches/2.6/resources/db/pgsql/ISO-8859-1/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql
   trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql
   trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql
   trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql
sql for f_auth_varname in table wfs_conf_element was missing
Modified: branches/2.6/resources/db/mysql/ISO-8859-1/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql
--- branches/2.6/resources/db/mysql/ISO-8859-1/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql	2009-12-02 13:36:33 UTC (rev 5059)
+++ branches/2.6/resources/db/mysql/ISO-8859-1/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql	2009-12-02 13:41:35 UTC (rev 5060)
@@ -113,6 +113,7 @@
 -- table wfs_conf_element: change in WFS configuration: access to geometries may now be restricted
+ALTER TABLE wfs_conf_element ADD COLUMN f_auth_varname VARCHAR(50);
 ALTER TABLE wfs_conf_element ADD COLUMN f_show_detail int4;
 ALTER TABLE wfs_conf_element ADD COLUMN f_operator VARCHAR(50);
Modified: branches/2.6/resources/db/mysql/UTF-8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql
--- branches/2.6/resources/db/mysql/UTF-8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql	2009-12-02 13:36:33 UTC (rev 5059)
+++ branches/2.6/resources/db/mysql/UTF-8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql	2009-12-02 13:41:35 UTC (rev 5060)
@@ -113,6 +113,7 @@
Modified: branches/2.6/resources/db/pgsql/ISO-8859-1/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql
--- branches/2.6/resources/db/pgsql/ISO-8859-1/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql	2009-12-02 13:36:33 UTC (rev 5059)
+++ branches/2.6/resources/db/pgsql/ISO-8859-1/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql	2009-12-02 13:41:35 UTC (rev 5060)
@@ -115,6 +115,7 @@
Modified: trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql
--- trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql	2009-12-02 13:36:33 UTC (rev 5059)
+++ trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql	2009-12-02 13:41:35 UTC (rev 5060)
@@ -113,6 +113,7 @@
Modified: trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql
--- trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql	2009-12-02 13:36:33 UTC (rev 5059)
+++ trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql	2009-12-02 13:41:35 UTC (rev 5060)
@@ -113,6 +113,7 @@
Modified: trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql
--- trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql	2009-12-02 13:36:33 UTC (rev 5059)
+++ trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql	2009-12-02 13:41:35 UTC (rev 5060)
@@ -115,6 +115,7 @@
More information about the Mapbender_commits mailing list
