[Mapbender-commits] r5141 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Dec 11 07:46:12 EST 2009
Author: christoph
Date: 2009-12-11 07:46:12 -0500 (Fri, 11 Dec 2009)
New Revision: 5141
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql	2009-12-11 12:43:10 UTC (rev 5140)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql	2009-12-11 12:46:12 UTC (rev 5141)
@@ -654,3 +654,6 @@
 -- element var enableSearchWithoutParams for gazetteerWFS
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'enableSearchWithoutParams', '0', 'define that search can be started without any search params' ,'var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'enableSearchWithoutParams' AND fkey_e_id = 'gazetteerWFS');
+UPDATE gui_element SET e_js_file = '../plugins/mb_selectMapsize.js', e_attributes = '' WHERE e_id = 'selectMapsize';
\ No newline at end of file
More information about the Mapbender_commits mailing list
