[Mapbender-commits] r5142 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Dec 11 08:51:56 EST 2009
Author: christoph
Date: 2009-12-11 08:51:56 -0500 (Fri, 11 Dec 2009)
New Revision: 5142
Added:
   trunk/mapbender/http/plugins/mb_cookie.js
   trunk/mapbender/http/plugins/mod_selectMapsize.js
Added: trunk/mapbender/http/plugins/mb_cookie.js
--- trunk/mapbender/http/plugins/mb_cookie.js	                        (rev 0)
+++ trunk/mapbender/http/plugins/mb_cookie.js	2009-12-11 13:51:56 UTC (rev 5142)
@@ -0,0 +1,156 @@
+ * Package: cookie
+ * Description:
+ * Sets a cookie after each map request. The cookie contains the
+ * current settings of the map, similar to WMC.
+ * Files:
+ *  - http/plugins/mb_cookie.js
+ * SQL:
+ * > INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+ * > e_mb_mod, e_target, e_requires, e_url) VALUES ('<appId>','cookie',20,1,
+ * > '','','div','','',-1,-1,1,1,NULL ,'','','div','../plugins/mb_cookie.js',
+ * > '','mapframe1','','');
+ * Help:
+ * http://www.mapbender.org/Cookie
+ * Maintainer:
+ * http://www.mapbender.org/User:Christoph_Baudson
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+var mod_mapCookie_target             = options.target[0];
+var mod_mapCookie_cookieLifetimeDays = 365;
+var mod_mapCookie_cookieName         = 'stored_map_state';
+Mapbender.events.init.register(function () {
+	mod_mapCookie_restoreMapState();
+	Mapbender.modules[mod_mapCookie_target].afterMapRequest.register(function () {
+		mod_mapCookie_storeMapState();
+function mod_mapCookie_restoreMapState() {
+	if(!document.cookie) {
+		return;
+	var currentMapState = Mapbender.modules[mod_mapCookie_target];
+	var cookieData      = document.cookie.split(';');
+	var cookieExists = false;
+	for(var i = 0; i < cookieData.length; i++) {
+		var cookieName = new RegExp(mod_mapCookie_cookieName);
+		if(!cookieData[i].match(cookieName)) {
+			continue;
+		cookieExists = true;
+		var storedMapState = $.parseJSON('(' + cookieData[i].replace(cookieName + '=','') + ')');
+		console.log(storedMapState);
+		currentMapState.epsg   = storedMapState.epsg;
+		var currentWmsLayers = [];
+		for(var j = 0; j < currentMapState.wms.length; j++) {
+			for(var k = 0; k < currentMapState.wms[j].objLayer.length; k++) {
+				currentWmsLayers.push(currentMapState.wms[j].objLayer[k]);
+		for(var j = 0; j < currentWmsLayers.length; j++) {
+			for(k = 0; k < storedMapState.layers.length; k++) {
+				var storedWmsTitle           = storedMapState.layers[k][0];
+				var storedLayerId            = storedMapState.layers[k][1];
+				var storedLayerName          = storedMapState.layers[k][2];
+				var storedLayerVisibility    = storedMapState.layers[k][3];
+				var storedLayerQueryablility = storedMapState.layers[k][4];
+				if(currentWmsLayers[j].layer_id == storedLayerId) {
+					currentWmsLayers[j].gui_layer_visible    = storedLayerVisibility;
+					currentWmsLayers[j].gui_layer_querylayer = storedLayerQueryablility;
+		var index = getMapObjIndexByName(mod_mapCookie_target);
+		var dimensions = storedMapState.mapsize.split(",");
+		var width      = parseInt(dimensions[0]);
+		var height     = parseInt(dimensions[1]);
+		var coordArray = storedMapState.extent.split(",");
+		var newExtent = new Mapbender.Extent(
+			coordArray[0],
+			coordArray[1],
+			coordArray[2],
+			coordArray[3]
+		currentMapState.setWidth(width);
+		currentMapState.setHeight(height);
+		currentMapState.calculateExtent(newExtent);
+	if (!cookieExists) {
+		return;
+	for(var i = 0; i < currentMapState.wms.length; i++) {
+		mb_restateLayers(mod_mapCookie_target,currentMapState.wms[i].wms_id);
+//	eventAfterLoadWMS.trigger();
+	for(var i = 0; i < mb_mapObj.length; i++) {
+		mb_mapObj[i].setMapRequest();
+function mod_mapCookie_storeMapState() {
+	var cookieData          = {};
+	var cookieExpires       = new Date();
+	cookieData.epsg   = currentMapState.epsg;
+	cookieData.extent = currentMapState.getExtent();
+	cookieData.layers = [];
+		for(var j = 0; j < currentMapState.wms[i].objLayer.length; j++) {
+			var currentLayers = [];
+			currentLayers.push(
+				currentMapState.wms[i].wms_title,
+				currentMapState.wms[i].objLayer[j].layer_id,
+				currentMapState.wms[i].objLayer[j].layer_name,
+				currentMapState.wms[i].objLayer[j].gui_layer_visible,
+				currentMapState.wms[i].objLayer[j].gui_layer_querylayer
+			cookieData.layers.push(currentLayers);
+	cookieData.mapsize = currentMapState.getWidth() + "," + currentMapState.getHeight();
+	cookieExpires.setTime(
+		cookieExpires.getTime() +
+		(parseInt(mod_mapCookie_cookieLifetimeDays, 10) * 24 * 60 * 60 * 1000)
+	document.cookie = mod_mapCookie_cookieName +
+		'=' + $.toJSON(cookieData) + ';expires=' +
+		cookieExpires.toGMTString() + ';';
+	console.log('JSON: %s',$.toJSON(cookieData));
Added: trunk/mapbender/http/plugins/mod_selectMapsize.js
--- trunk/mapbender/http/plugins/mod_selectMapsize.js	                        (rev 0)
+++ trunk/mapbender/http/plugins/mod_selectMapsize.js	2009-12-11 13:51:56 UTC (rev 5142)
@@ -0,0 +1,36 @@
+var mod_selectMapsize_target = options.target[0];
+$this = $(this).change(function () {
+	mod_selectMapsize(this);
+function mod_selectMapsize(obj){
+	var map = Mapbender.modules[mod_selectMapsize_target];
+	var p = obj.value.split(",");
+	var w = parseInt(p[0], 10) ;
+	var h = parseInt(p[1], 10);
+	var pos = map.convertPixelToReal(new Mapbender.Point(w,h));
+	var coords = map.getExtent().split(",");
+	map.setExtent(new Mapbender.Extent(
+		coords[0],
+		pos[1],
+		pos[0],
+		coords[3]
+	map.setWidth(w);
+	map.setHeight(h);
+	map.setMapRequest();
+	map.events.dimensionsChanged.register(function (obj) {
+		$this.children("option").each(function () {
+			var value = this.value.split(",");
+			if (obj.width === value[0] && obj.height === value[1]) {
+				console.log("select: " + value);
More information about the Mapbender_commits mailing list
