[Mapbender-commits] r5153 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Sat Dec 12 05:24:34 EST 2009
Author: armin11
Date: 2009-12-12 05:24:34 -0500 (Sat, 12 Dec 2009)
New Revision: 5153
Added:
trunk/mapbender/http/php/mod_loadCatalogToGUI.php
wrong name
Added: trunk/mapbender/http/php/mod_loadCatalogToGUI.php
--- trunk/mapbender/http/php/mod_loadCatalogToGUI.php (rev 0)
+++ trunk/mapbender/http/php/mod_loadCatalogToGUI.php 2009-12-12 10:24:34 UTC (rev 5153)
@@ -0,0 +1,272 @@
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/Administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+import_request_variables("PG");
+require(dirname(__FILE__)."/../php/mb_validatePermission.php");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>Load WMS from Catalog</title>
+<?php
+include '../include/dyn_css.php';
+<style type="text/css">
+ body{
+ background-color: #ffffff;
+ font-family: Arial, Helvetica, sans-serif;
+ font-size : 12px;
+ color: #808080
+ .list_guis{
+ font-size : 12px;
+ color: #808080;
+ .text1{
+ font-size : 15px;
+ position:absolute;
+ top:190px;
+ .select1{
+ top:210px;
+ width:270px;
+ .text2{
+ font-size : 15px;
+ top:190px;
+ left:300px;
+ .select2{
+ top:210px;
+ left:300px;
+ .getcapabilities{
+ font-size : 15px;
+ top:570px;
+</style>
+<script language="JavaScript">
+function validate(vals){
+ if(vals == 'guiList'){
+ var listIndex = document.form1.guiList.selectedIndex;
+ if(listIndex<0){
+ alert("Please select a GUI.");
+ return false;
+ else{
+ var gui_id=document.form1.guiList.options[listIndex].value;
+ //LOAD CATALOG
+ document.form1.action='../php/mod_loadCatalog.php<?php echo SID;?>';
+ document.form1.submit();
+function load(){
+ if(document.form1.guiList.selectedIndex<0){
+ alert("Please Select a GUI.");
+ return false;
+ var gui_ind = document.form1.guiList.selectedIndex;
+ var ind = document.form1.catID.selectedIndex;
+ var ind2 = document.form1.guiID_.selectedIndex;
+ var indexCatList = document.form1.catID.selectedIndex;
+ var permission = true;
+ var selectedCatId = document.form1.catID.options[document.form1.catID.selectedIndex].value;
+ for (i = 0; i < document.form1.catList.length; i++) {
+ if (document.form1.catList.options[i].value == selectedCatId){
+ permission = false;
+ alert ('The Catalog (' + selectedCatId + ') is already loaded in this application.');
+ break;
+ if (permission) { // only check if permission is not false
+ var loadConfirmed = confirm("Load " + document.form1.catID.options[ind].text + " FROM " + document.form1.guiID_.options[ind2].value + " INTO "+document.form1.guiList.options[gui_ind].value+" ?");
+ if(loadConfirmed){
+ else{
+ document.form1.guiID_.selectedIndex = -1;
+</script>
+</head>
+<body>
+<?php
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+$admin = new administration();
+$ownguis = $admin->getGuisByOwner($_SESSION["mb_user_id"],true);
+// insert values here
+if(isset($catID) && isset($guiID_)){
+ $sql_ins = "INSERT INTO gui_cat (fkey_gui_id,fkey_cat_id) ";
+ $sql_ins .= "VALUES ($1,$2)";
+ $v = array($guiList,$catID);
+ $t = array('s','i');
+ db_prep_query($sql_ins,$v,$t);
+echo "<form name='form1' action='" . $self."' method='post'>";
+echo "<table cellpadding='0' cellspacing='0' border='0'>";
+echo "<tr>";
+echo "<td>";
+if (count($ownguis)>0){
+ echo"GUI";
+ echo"<br/>";
+ $sql = "SELECT * FROM gui WHERE gui_id IN (";
+ $v = $ownguis;
+ $t = array();
+ for ($i = 1; $i <= count($ownguis); $i++){
+ if ($i > 1) {
+ $sql .= ",";
+ $sql .= "$".$i;
+ array_push($t, "s");
+ $sql .= ") ORDER BY gui_name";
+ $res = db_prep_query($sql, $v, $t);
+ $count=0;
+ echo"<select size='8' name='guiList' style='width:200px' onClick='submit()'>";
+ while($row = db_fetch_array($res)){
+ $gui_name[$count]=$row["gui_name"];
+ $gui_description[$count]=$row["gui_description"];
+ $count++;
+ echo "<option value='".$row["gui_id"]."' ";
+ if($guiList && $guiList == $row["gui_name"]){
+ echo "selected";
+ echo ">".$row["gui_name"]."</option>";
+ $arrayGUIs=$_SESSION["mb_user_guis"];
+ echo count($arrayGUIs);
+ echo "</select><br/><br/>";
+ echo "</td>";
+ echo "<td>";
+ echo "Catalog";
+ echo "<br/>";
+ if(isset($guiList) && $guiList!=""){
+ $sql = "SELECT DISTINCT cat_id, cat_title FROM gui_cat ";
+ $sql .= "JOIN gui ON gui_cat.fkey_gui_id = gui.gui_id JOIN cat ON gui_cat.fkey_cat_id=cat.cat_id ";
+ $sql .= "AND gui_cat.fkey_gui_id=gui.gui_id WHERE gui.gui_name = $1";
+ $v = array($guiList);
+ $t = array('s');
+ $res = db_prep_query($sql,$v,$t);
+ $count=0;
+ echo"<select size='8' name='catList' style='width:200px'>";
+ if ($row["cat_title"]!=""){
+ echo "<option value='".$row["cat_id"]."' ";
+ echo ">".$row["cat_title"]."</option>";
+ $count++;
+ echo "</select><br><br>";
+ }else{
+ echo"<select size='8' name='catList' style='width:200px' on Click='submit()'>";
+ echo "</td>";
+ echo "<tr></table><br>";
+ echo"<div class='text1'>Load Catalog</div>";
+ $sql = "SELECT DISTINCT cat.cat_id,cat.cat_title,cat.cat_abstract,cat.cat_owner FROM gui_cat JOIN cat ON ";
+ $sql .= "cat.cat_id = gui_cat.fkey_cat_id WHERE gui_cat.fkey_gui_id IN(";
+ $v = $arrayGUIs;
+ $t = array();
+ for ($i = 1; $i <= count($arrayGUIs); $i++){
+ if ($i > 1) {
+ $sql .= ",";
+ $sql .= "$" . $i;
+ $sql .= ") ORDER BY cat.cat_title";
+ echo "<select class='select1' name='catID' size='20' onchange='submit()'>";
+ $cnt = 0;
+ if($row["cat_owner"] == $_SESSION["mb_user_id"]){
+ echo "style='color:green' ";
+ else{
+ echo "style='color:red' ";
+ if(isset($catID) && $catID == $row["cat_id"]){
+ echo "selected";
+ $wms_getcapabilities = $row["wms_getcapabilities"];
+ $cnt++;
+ echo "</select>";
+ if(isset($catID)){
+ echo "<div class='text2'>FROM:</div>";
+ $sql = "SELECT * from gui_cat WHERE fkey_cat_id = $1 ORDER BY fkey_gui_id";
+ $v = array($catID);
+ $t = array("s");
+ echo "<select class='select2' name='guiID_' size='20' onchange='load()'>";
+ $cnt = 0;
+ echo "<option value='".$row["fkey_gui_id"]."' ";
+ echo ">".$row["fkey_gui_id"]."</option>";
+ $cnt++;
+ echo "</select>";
+echo "</form>";
+}else{
+ echo "There are no GUIs available for this user. Please create a GUI first.";
+echo "<div class='getcapabilities'>" . $wms_getcapabilities . "</div>";
+</body>
+</html>
\ No newline at end of file
More information about the Mapbender_commits
