[Mapbender-commits] r5154 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sat Dec 12 05:26:02 EST 2009
Author: uli
Date: 2009-12-12 05:26:02 -0500 (Sat, 12 Dec 2009)
New Revision: 5154
Removed:
   trunk/mapbender/http/php/mod_loadCatalogToGui.php
typo
Deleted: trunk/mapbender/http/php/mod_loadCatalogToGui.php
--- trunk/mapbender/http/php/mod_loadCatalogToGui.php	2009-12-12 10:24:34 UTC (rev 5153)
+++ trunk/mapbender/http/php/mod_loadCatalogToGui.php	2009-12-12 10:26:02 UTC (rev 5154)
@@ -1,272 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/Administration
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-import_request_variables("PG");
-require(dirname(__FILE__)."/../php/mb_validatePermission.php");
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>Load WMS from Catalog</title>
-<?php
-include '../include/dyn_css.php';
-<style type="text/css">
-  	body{
-      background-color: #ffffff;
-  		font-family: Arial, Helvetica, sans-serif;
-  		font-size : 12px;
-  		color: #808080
-  	.list_guis{
-  		font-size : 12px;
-  		color: #808080;
-	.text1{
-	   font-size : 15px;
-	   position:absolute;
-	   top:190px;
-	.select1{
-	   top:210px;
-	   width:270px;
-	.text2{
-	   font-size : 15px;
-	   top:190px;
-	   left:300px;
-	.select2{
-	   top:210px;
-	   left:300px;
-	.getcapabilities{
-	   font-size : 15px;
-	   top:570px;
-</style>
-<script language="JavaScript">
-function validate(vals){
-   if(vals == 'guiList'){
-      var listIndex = document.form1.guiList.selectedIndex;
-      if(listIndex<0){
-		   alert("Please select a GUI.");
-			return false;
-      else{
-         var gui_id=document.form1.guiList.options[listIndex].value;
-         	//LOAD CATALOG
-			document.form1.action='../php/mod_loadCatalog.php<?php echo SID;?>';
-			document.form1.submit();
-function load(){
-      if(document.form1.guiList.selectedIndex<0){
-		   alert("Please Select a GUI.");
-			return false;
-      var gui_ind = document.form1.guiList.selectedIndex;
-      var ind = document.form1.catID.selectedIndex;
-      var ind2 = document.form1.guiID_.selectedIndex;
-			var indexCatList = document.form1.catID.selectedIndex;
-			var permission = true;
-			var selectedCatId = document.form1.catID.options[document.form1.catID.selectedIndex].value;
-			for (i = 0; i < document.form1.catList.length; i++) {
-						if (document.form1.catList.options[i].value == selectedCatId){
-							 permission = false;
-							 alert ('The Catalog (' + selectedCatId + ') is already loaded in this application.');
-							 break;
-  			if (permission) { // only check if permission is not false
-        	var loadConfirmed = confirm("Load " + document.form1.catID.options[ind].text + " FROM " + document.form1.guiID_.options[ind2].value + " INTO "+document.form1.guiList.options[gui_ind].value+" ?");
-            if(loadConfirmed){
-          	else{
-             	document.form1.guiID_.selectedIndex = -1;
-</script>
-</head>
-<body>
-<?php
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-$admin = new administration();
-$ownguis = $admin->getGuisByOwner($_SESSION["mb_user_id"],true);
-// insert values here
-if(isset($catID) && isset($guiID_)){
-	$sql_ins = "INSERT INTO gui_cat (fkey_gui_id,fkey_cat_id) ";
-	$sql_ins .= "VALUES ($1,$2)";
-	$v = array($guiList,$catID);
-	$t = array('s','i');
-	db_prep_query($sql_ins,$v,$t);
-echo "<form name='form1' action='" . $self."' method='post'>";
-echo "<table cellpadding='0' cellspacing='0' border='0'>";
-echo "<tr>";
-echo "<td>";
-if (count($ownguis)>0){
-	echo"GUI";
-	echo"<br/>";
-	$sql = "SELECT * FROM gui WHERE gui_id IN (";
-	$v = $ownguis;
-	$t = array();
-	for ($i = 1; $i <= count($ownguis); $i++){
-		if ($i > 1) {
-			$sql .= ",";
-		$sql .= "$".$i;
-		array_push($t, "s");
-	$sql .= ") ORDER BY gui_name";
-	$res = db_prep_query($sql, $v, $t);
-	$count=0;
-	echo"<select size='8' name='guiList' style='width:200px' onClick='submit()'>";
-	while($row = db_fetch_array($res)){
-		$gui_name[$count]=$row["gui_name"];
-		$gui_description[$count]=$row["gui_description"];
-		$count++;
-		echo "<option value='".$row["gui_id"]."' ";
-		if($guiList && $guiList == $row["gui_name"]){
-			echo "selected";
-		echo ">".$row["gui_name"]."</option>";
-	$arrayGUIs=$_SESSION["mb_user_guis"];
-	echo count($arrayGUIs);
-	echo "</select><br/><br/>";
-	echo "</td>";
-	echo "<td>";
-	echo "Catalog";
-	echo "<br/>";
-	if(isset($guiList) && $guiList!=""){
-		$sql = "SELECT DISTINCT cat_id, cat_title FROM gui_cat ";
-		$sql .= "JOIN gui ON gui_cat.fkey_gui_id = gui.gui_id JOIN cat ON gui_cat.fkey_cat_id=cat.cat_id ";
-		$sql .= "AND gui_cat.fkey_gui_id=gui.gui_id WHERE gui.gui_name = $1";
-		$v = array($guiList);
-		$t = array('s');
-		$res = db_prep_query($sql,$v,$t);
-		$count=0;
-		echo"<select size='8' name='catList' style='width:200px'>";
-			if ($row["cat_title"]!=""){
-				echo "<option value='".$row["cat_id"]."' ";
-				echo ">".$row["cat_title"]."</option>";
-			$count++;
-		echo "</select><br><br>";
-	}else{
-		echo"<select size='8' name='catList' style='width:200px' on Click='submit()'>";
-	echo "</td>";
-	echo "<tr></table><br>";
-	echo"<div class='text1'>Load Catalog</div>";
-	$sql = "SELECT DISTINCT cat.cat_id,cat.cat_title,cat.cat_abstract,cat.cat_owner FROM gui_cat JOIN cat ON ";
-	$sql .= "cat.cat_id = gui_cat.fkey_cat_id WHERE gui_cat.fkey_gui_id IN(";
-	$v = $arrayGUIs;
-	$t = array();
-	for ($i = 1; $i <= count($arrayGUIs); $i++){
-		if ($i > 1) {
-			$sql .= ",";
-		$sql .= "$" . $i;
-	$sql .= ") ORDER BY cat.cat_title";
-	echo "<select class='select1' name='catID' size='20' onchange='submit()'>";
-	$cnt = 0;
-		if($row["cat_owner"] == $_SESSION["mb_user_id"]){
-			echo "style='color:green' ";
-		else{
-			echo "style='color:red' ";
-		if(isset($catID) && $catID == $row["cat_id"]){
-			echo "selected";
-			$wms_getcapabilities = $row["wms_getcapabilities"];
-		$cnt++;
-	echo "</select>";
-	if(isset($catID)){
-		echo "<div class='text2'>FROM:</div>";
-		$sql = "SELECT * from gui_cat WHERE fkey_cat_id = $1 ORDER BY fkey_gui_id";
-		$v = array($catID);
-		$t = array("s");
-		echo "<select class='select2' name='guiID_' size='20' onchange='load()'>";
-		$cnt = 0;
-			echo "<option value='".$row["fkey_gui_id"]."' ";
-			echo ">".$row["fkey_gui_id"]."</option>";
-			$cnt++;
-	echo "</select>";
-echo "</form>";
-}else{
-	echo "There are no GUIs available for this user. Please create a GUI first.";
-echo "<div class='getcapabilities'>" . $wms_getcapabilities . "</div>";
-</body>
-</html>
\ No newline at end of file
More information about the Mapbender_commits mailing list
