[Mapbender-commits] r5197 - in trunk/mapbender: http/javascripts lib
svn_mapbender at osgeo.org
Wed Dec 16 05:42:30 EST 2009
Author: kmq
Date: 2009-12-16 05:42:29 -0500 (Wed, 16 Dec 2009)
New Revision: 5197
trunk/mapbender/http/javascripts/mod_ResultList.js
trunk/mapbender/lib/resultGeometryListController.js
selecting, shopwing popups for all datatable entries - final(hopefully)
Modified: trunk/mapbender/http/javascripts/mod_ResultList.js
--- trunk/mapbender/http/javascripts/mod_ResultList.js 2009-12-16 09:35:34 UTC (rev 5196)
+++ trunk/mapbender/http/javascripts/mod_ResultList.js 2009-12-16 10:42:29 UTC (rev 5197)
@@ -36,8 +36,21 @@
this.addGlobalButton = function(buttondef){
//buttondef format:
//{"title":<if no image is given then this is displayed>, callback: <function( ))
+ //type: <type> // either "select" or "button", defaults to "button"
+ // if type is "select", add options like this:
+ // selectoptions : [{label :<label>,value : <value>},... ]
// this is the domelement
+ var bd = buttondef|| {};
+ bd.title = bd.title || "no title";
+ bd.type = bd.type || "button";
+ bd.selectoptions = bd.selectoptions || []
+ bd.callback = bd.callback || function(){};
+ return;
var result = function(){
var args = {
WFSConf: me.WFSConf,
@@ -47,12 +60,26 @@
buttondef.callback.call(this,args);
- var button = $("<span><button type='button' class='ui-state-default ui-corner-all'>"+buttondef.title+"</button></span>").click(result);
if($('#'+options.id+"buttonrow").length < 1){
$('#'+options.id).append('<div id="'+options.id +'buttonrow"></div>');
$('#'+options.id+'buttonrow').css("clear","both");
- $('#'+options.id +'buttonrow').append(button);
+ if (bd.type == "button")
+ var button = $("<span><button type='button' class='ui-state-default ui-corner-all'>"+buttondef.title+"</button></span>").click(result);
+ $('#'+options.id +'buttonrow').append(button);
+ }else if (bd.type == "select"){
+ var options = "";
+ for (c in bd.selectoptions){
+ options += '<option value="'+ bd.selectoptions[c].value +'">'+bd.selectoptions[c].label +'</options>';
+ var selectbox = '<select>'+ options +'</select>';
+ $('#'+options.id +'buttonrow').append(selectbox);
+ }else{
+ alert("invalid buttondefintion");
@@ -109,73 +136,124 @@
$('#'+options.id).css("display","block");
- $("tr td span.wfsFproperty",me.table).click(function(){
- // go up to the row, which has the "modelindex" set
- var i = $(this.parentNode.parentNode).data("modelindex");
- var feature = me.model.getFeature(i);
- var infoPopupHtml = "<table>";
- for (index in me.detailColumns) {
- infoPopupHtml += "<tr>";
- infoPopupHtml += "<td>" + me.detailColumns[index].label + "</td>";
- infoPopupHtml += "<td>" + me.model.getFeatureProperty(i, me.detailColumns[index].name)+ "</td>";
- infoPopupHtml += "</tr>";
- infoPopupHtml += "</table>";
- var infoPopup = $("<div> </div>");
- infoPopup.append(infoPopupHtml);
- buttonList = $("<ul></ul>").css("list-style-type","none");
- for (c in popupButtons){
- var callback = function() {
- var args = {
- WFSConf: me.WFSConf,
- geoJSON: feature,
- selectedRows: me.getSelected()
+ var resultHighlight = new Highlight(
+ options.target,
+ "resultListHighlight",
+ {"position":"absolute", "top":"0px", "left":"0px", "z-index":options.resultHighlightZIndex},
+ options.resultHighlightLineWidth
+ var rowNodes = me.datatable.fnGetNodes();
+ for (rowNodeIndex in rowNodes){
+ (function() {
+ var row = rowNodes[rowNodeIndex];
+ $(".wfsFproperty", row).click(function(){
+ // go up to the row, which has the "modelindex" set
+ var modelIndex = $(row).data("modelindex");
+ var feature = me.model.getFeature(i);
+ var infoPopupHtml = "<table>";
+ for (var columnIndex in me.detailColumns) {
+ infoPopupHtml += "<tr>";
+ infoPopupHtml += "<td>" + me.detailColumns[columnIndex].label + "</td>";
+ infoPopupHtml += "<td>" + me.model.getFeatureProperty(modelIndex, me.detailColumns[columnIndex].name)+ "</td>";
+ infoPopupHtml += "</tr>";
+ infoPopupHtml += "</table>";
+ var infoPopup = $("<div> </div>");
+ infoPopup.append(infoPopupHtml);
+ buttonList = $("<ul></ul>").css("list-style-type","none");
+ for (var c in popupButtons){
+ var callback = function() {
+ var args = {
+ WFSConf: me.WFSConf,
+ geoJSON: feature,
+ selectedRows: me.getSelected()
+ popupButtons[c].callback.call(this,args);
- popupButtons[c].callback.call(this,args);
- var button = $("<li><button type='button' class='ui-state-default ui-corner-all'>"+popupButtons[c].title+"</button></li>").click(callback);
- button.css("display","inline");
- buttonList.append(button);
- infoPopup.append(buttonList);
- infoPopup.dialog({
- title : "Details",
- autoOpen : false,
- draggable : true,
- width : options.infoPopupWidth,
- height : options.infoPopupHeight
+ var button = $("<li><button type='button' class='ui-state-default ui-corner-all'>"+popupButtons[c].title+"</button></li>").click(callback);
+ button.css("display","inline");
+ buttonList.append(button);
+ infoPopup.append(buttonList);
+ infoPopup.dialog({
+ title : "Details",
+ autoOpen : false,
+ draggable : true,
+ width : options.infoPopupWidth,
+ height : options.infoPopupHeight
+ infoPopup.dialog("open");
+ if (options.maxHighlightedPoints > 0 && feature.getTotalPointCount() > options.maxHighlightedPoints) {
+ feature = feature.getBBox4();
+ resultHighlight.del(feature, options.resultHighlightColor);
+ var bbox = feature.getBBox();
+ var bufferFloat = parseFloat(me.WFSConf.g_buffer);
+ var buffer = new Point(bufferFloat,bufferFloat);
+ bbox[0] = bbox[0].minus(buffer);
+ bbox[1] = bbox[1].plus(buffer);
+ //mb_calculateExtent(targetArray[0], bbox[0].x, bbox[0].y, bbox[1].x, bbox[1].y);
+ //zoom(targetArray[0], 'true', 1.0);
+ var map = Mapbender.modules[options.target[0]];
+ map.calculateExtent(
+ new Mapbender.Extent(bbox[0], bbox[1])
+ map.setMapRequest();
+ resultHighlight.add(feature, options.resultHighlightColor);
+ resultHighlight.paint();
+ $(row).mouseover(function () {
+ var i = $(this).data("modelindex");
+ }).mouseout(function () {
- infoPopup.dialog("open");
- if (options.maxHighlightedPoints > 0 && feature.getTotalPointCount() > options.maxHighlightedPoints) {
- feature = feature.getBBox4();
- resultHighlight.del(feature, options.resultHighlightColor);
- var bbox = feature.getBBox();
- var bufferFloat = parseFloat(me.WFSConf.g_buffer);
- var buffer = new Point(bufferFloat,bufferFloat);
- bbox[0] = bbox[0].minus(buffer);
- bbox[1] = bbox[1].plus(buffer);
- //mb_calculateExtent(targetArray[0], bbox[0].x, bbox[0].y, bbox[1].x, bbox[1].y);
- //zoom(targetArray[0], 'true', 1.0);
- var map = Mapbender.modules[options.target[0]];
- map.calculateExtent(
- new Mapbender.Extent(bbox[0], bbox[1])
- map.setMapRequest();
- resultHighlight.add(feature, options.resultHighlightColor);
- resultHighlight.paint();
- // set style of cursor to pointer for the result table
- $("tr td span.wfsFproperty",me.table).css("cursor","pointer");
+ // make rows selectable
+ $(row).click((function(){
+ if($(this).hasClass('row_selected')){
+ $(this).removeClass('row_selected');
+ else{
+ $(this).addClass('row_selected');
+ return true;
+ // set style of cursor to pointer for the result table
+ $(".wfsFproperty", row).css("cursor","pointer");
this.hide = function(){
Modified: trunk/mapbender/lib/resultGeometryListController.js
--- trunk/mapbender/lib/resultGeometryListController.js 2009-12-16 09:35:34 UTC (rev 5196)
+++ trunk/mapbender/lib/resultGeometryListController.js 2009-12-16 10:42:29 UTC (rev 5197)
@@ -23,8 +23,6 @@
// array of buttondef objects
this.buttoncolumns = []
- var me = this;
this.options = options;
@@ -79,50 +77,11 @@
// fnAddData returns an array of indices
var index = me.datatable.fnAddData(rowData);
// this is ok because we only added a single row
var rowNode = me.datatable.fnGetNodes(index[0]);
$(rowNode).data("modelindex",modelIndex);
- var resultHighlight = new Highlight(
- me.options.target,
- "resultListHighlight",
- {"position":"absolute", "top":"0px", "left":"0px", "z-index":me.options.resultHighlightZIndex},
- me.options.resultHighlightLineWidth
- $(rowNode).mouseover(function () {
- var i = $(this).data("modelindex");
- if (me.options.maxHighlightedPoints > 0 && feature.getTotalPointCount() > me.options.maxHighlightedPoints) {
- resultHighlight.add(feature, me.options.resultHighlightColor);
- }).mouseout(function () {
- resultHighlight.del(feature, me.options.resultHighlightColor);
- // make rows selectable
- $(rowNode).click((function(){
- if($(this).hasClass('row_selected')){
- $(this).removeClass('row_selected');
- else{
- $(this).addClass('row_selected');
- return true;
More information about the Mapbender_commits
