[Mapbender-commits] r5198 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Dec 16 06:14:03 EST 2009
Author: kmq
Date: 2009-12-16 06:14:03 -0500 (Wed, 16 Dec 2009)
New Revision: 5198
   trunk/mapbender/http/javascripts/mod_ResultList.js
allow adding selectboxes to resultList
Modified: trunk/mapbender/http/javascripts/mod_ResultList.js
--- trunk/mapbender/http/javascripts/mod_ResultList.js	2009-12-16 10:42:29 UTC (rev 5197)
+++ trunk/mapbender/http/javascripts/mod_ResultList.js	2009-12-16 11:14:03 UTC (rev 5198)
@@ -33,57 +33,55 @@
 		//alert($(this).data("modelindex"));
-	this.addGlobalButton = function(buttondef){
-		//buttondef format:
-		//{"title":<if no image is given then this is displayed>, callback: <function( ))
-		//type: <type> // either "select" or "button", defaults to "button"
-		//  if type is "select", add options like this:
-		// selectoptions : [{label :<label>,value : <value>},...   ]
-		// this is the domelement
-		var bd = buttondef|| {};
-		bd.title = bd.title || "no title";
-		bd.type = bd.type || "button";
-		bd.selectoptions = bd.selectoptions || []
-		bd.callback = bd.callback || function(){};
-		return;
+	this.addGlobalButton =  function(buttondef){
+			//buttondef format:
+			//{"title":<if no image is given then this is displayed>, callback: <function( ))
+			//type: <type> // either "select" or "button", defaults to "button"
+			//  if type is "select", add options like this:
+			// selectoptions : [{label :<label>,value : <value>},...   ]
+			// this is the domelement
+			var bd = buttondef|| {};
+			bd.title = bd.title || "no title";
+			bd.type = bd.type || "button";
+			bd.classes = bd.classes || "";
+			bd.selectoptions = bd.selectoptions || []
+			bd.callback = bd.callback || function(){};
-		var result = function(){
-			var  args =  {
-				WFSConf: me.WFSConf,
-				geoJSON: me.model.toString(),
-				selectedRows: me.getSelected(),
-				table: me.datatable
+			var result = function(){
+				var  args =  {
+					WFSConf: me.WFSConf,
+					geoJSON: me.model.toString(),
+					selectedRows: me.getSelected(),
+					table: me.datatable
+				buttondef.callback.call(this,args);
-			buttondef.callback.call(this,args);
+			if($('#'+options.id+"buttonrow").length < 1){
+				$('#'+options.id).append('<div id="'+options.id +'buttonrow"></div>');
+				$('#'+options.id+'buttonrow').css("clear","both");
-		if($('#'+options.id+"buttonrow").length < 1){
-			$('#'+options.id).append('<div id="'+options.id +'buttonrow"></div>');
-			$('#'+options.id+'buttonrow').css("clear","both");
+			if (bd.type == "button")
+				var button = $('<span><button type="button" class="ui-state-default ui-corner-all '+ bd.classes  +'">'+buttondef.title+'</button></span>').click(result);
+				$('#'+options.id +'buttonrow').append(button);
+			}else if (bd.type == "select"){
+				var select_options = "";
+				for (c in bd.selectoptions){
+					select_options += '<option value="'+ bd.selectoptions[c].value +'">'+bd.selectoptions[c].label +'</options>';
+				var selectbox = '<select class="'+ bd.classes  + '">'+ select_options  +'</select>';
+				$('#'+options.id +'buttonrow').append(selectbox);
+			}else{
+				alert("invalid buttondefintion");
-		if (bd.type == "button")
-			var button = $("<span><button type='button' class='ui-state-default ui-corner-all'>"+buttondef.title+"</button></span>").click(result);
-			$('#'+options.id +'buttonrow').append(button);
-		}else if (bd.type == "select"){
-			var options = "";
-			for (c in bd.selectoptions){
-				options += '<option value="'+ bd.selectoptions[c].value +'">'+bd.selectoptions[c].label +'</options>';
-			var selectbox = '<select>'+ options  +'</select>';
-			$('#'+options.id +'buttonrow').append(selectbox);
-		}else{
-			alert("invalid buttondefintion");
 	this.addRowButton = function(buttondef){
 	// buttondef format:
 	//  title:
More information about the Mapbender_commits mailing list
