[Mapbender-commits] r3581 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Feb 20 08:26:21 EST 2009
Author: christoph
Date: 2009-02-20 08:26:21 -0500 (Fri, 20 Feb 2009)
New Revision: 3581
   trunk/mapbender/http/php/mod_wfs_conf.php
   trunk/mapbender/http/php/mod_wfs_edit.php
http://trac.osgeo.org/mapbender/ticket/386
Modified: trunk/mapbender/http/php/mod_wfs_conf.php
--- trunk/mapbender/http/php/mod_wfs_conf.php	2009-02-20 13:24:42 UTC (rev 3580)
+++ trunk/mapbender/http/php/mod_wfs_conf.php	2009-02-20 13:26:21 UTC (rev 3581)
@@ -19,6 +19,12 @@
 require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
 require(dirname(__FILE__)."/../classes/class_wfs_conf.php");
+foreach ($_POST as $key => &$value) {
+	if (is_string($value) && 1 === get_magic_quotes_gpc()) {
+		$value = stripslashes($value);
 <html>
 <head>
@@ -117,7 +123,7 @@
 /* save wfs_conf properties */
-if(isset($_REQUEST["save"])){
+if(isset($_POST["save"])){
         db_select_db($DB,$con);
@@ -126,7 +132,7 @@
         $sql .= "fkey_featuretype_id, g_label, g_label_id, g_button, ";
         $sql .= "g_button_id, g_style, g_buffer, g_res_style, g_use_wzgraphics";
 		$sql .= ") VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10, ";
-        if (!empty($_REQUEST["g_use_wzgraphics"])) {
+        if (!empty($_POST["g_use_wzgraphics"])) {
 			$sql .= "'1'";
 		else {
@@ -134,51 +140,62 @@
         $sql .= "); ";
-		$v = array($_REQUEST["wfs_conf_abstract"], $_REQUEST["wfs"], $_REQUEST["featuretype"], $_REQUEST["g_label"], $_REQUEST["g_label_id"], $_REQUEST["g_button"], $_REQUEST["g_button_id"], $_REQUEST["g_style"], $_REQUEST["g_buffer"], $_REQUEST["g_res_style"]);
+		$v = array(
+			$_POST["wfs_conf_abstract"],
+			$_POST["wfs"],
+			$_POST["featuretype"],
+			$_POST["g_label"],
+			$_POST["g_label_id"],
+			$_POST["g_button"],
+			$_POST["g_button_id"],
+			$_POST["g_style"],
+			$_POST["g_buffer"],
+			$_POST["g_res_style"]
 		$t = array("s", "s", "s", "s", "s", "s", "s", "s", "s", "s");
         $res = db_prep_query($sql, $v, $t);
         $wfsID = db_insert_id($con,'wfs_conf','wfs_conf_id');
-        for ($i = 0; $i < $_REQUEST["num"]; $i++){
+        for ($i = 0; $i < $_POST["num"]; $i++){
                 $sql = "INSERT INTO wfs_conf_element (fkey_wfs_conf_id,f_id,f_search,f_pos,f_min_input,f_style_id,f_toupper,f_label,f_label_id,f_show,f_respos,f_edit,f_form_element_html,f_mandatory,f_auth_varname,f_show_detail,f_detailpos,f_operator) VALUES(";
                 $sql .= "$1, $2, ";
-                if (!empty($_REQUEST["f_search".$i])) {
+                if (!empty($_POST["f_search".$i])) {
                 	$sql .= "'1'";
                 else {
                 	$sql .= "'0'";
                 $sql .= ", $3, $4, $5, ";
-				if (!empty($_REQUEST["f_toupper".$i])) {
+				if (!empty($_POST["f_toupper".$i])) {
                 	$sql .= "'1'";
                 else {
                 	$sql .= "'0'";
                 $sql .= ",$6, $7, ";
-                if (!empty($_REQUEST["f_show".$i])) {
+                if (!empty($_POST["f_show".$i])) {
                 	$sql .= "'1'";
                 else {
                 	$sql .= "'0'";
                 $sql .= ", $8, ";
-                if (!empty($_REQUEST["f_edit".$i])) {
+                if (!empty($_POST["f_edit".$i])) {
                 	$sql .= "'1'";
                 else {
                 	$sql .= "'0'";
                 $sql .= ",$9, ";
-                if (!empty($_REQUEST["f_mandatory".$i])) {
+                if (!empty($_POST["f_mandatory".$i])) {
                 	$sql .= "'1'";
                 else {
                 	$sql .= "'0'";
                 $sql .= ",$10,";
-                if(!empty($_REQUEST["f_show_detail".$i])){
+                if(!empty($_POST["f_show_detail".$i])){
                 	$sql .= "'1'";
                 else {
@@ -187,14 +204,14 @@
                 $sql .= ",$11,$12";
  				$sql .= "); ";
-				$v = array($wfsID, $_REQUEST["f_id".$i], $_REQUEST["f_pos".$i], $_REQUEST["f_min_input".$i], $_REQUEST["f_style_id".$i], $_REQUEST["f_label".$i], $_REQUEST["f_label_id".$i], $_REQUEST["f_respos".$i], stripslashes($_REQUEST["f_form_element_html".$i]), $_REQUEST["f_auth_varname".$i], $_REQUEST["f_detailpos".$i], $_REQUEST["f_operator".$i]);
+				$v = array($wfsID, $_POST["f_id".$i], $_POST["f_pos".$i], $_POST["f_min_input".$i], $_POST["f_style_id".$i], $_POST["f_label".$i], $_POST["f_label_id".$i], $_POST["f_respos".$i], $_POST["f_form_element_html".$i], $_POST["f_auth_varname".$i], $_POST["f_detailpos".$i], $_POST["f_operator".$i]);
 				$t = array("i", "s", "s", "i", "s", "s", "s", "i", "s", "s", "i", "s");
-        if (isset($_REQUEST["f_geom"])) {
+        if (isset($_POST["f_geom"])) {
 	        $sql = "UPDATE wfs_conf_element SET f_geom = 1 ";
 	        $sql .= "WHERE fkey_wfs_conf_id = $1 AND f_id = $2;";
-	        $v = array($wfsID, $_REQUEST["f_geom"]);
+	        $v = array($wfsID, $_POST["f_geom"]);
 	        $t = array("i", "i");
@@ -208,16 +225,16 @@
 /* select wfs */
-if(isset($_REQUEST["wfs"]) && $_REQUEST["wfs"] == ""){
-        unset($_REQUEST["wfs"]);
-        unset($_REQUEST["featuretype"]);
+if(isset($_POST["wfs"]) && $_POST["wfs"] == ""){
+        unset($_POST["wfs"]);
+        unset($_POST["featuretype"]);
 echo "<select name='wfs' onchange='selectWFS()'>";
 echo "<option value=''>...</option>";
 for($i=0; $i<count($aWFS->wfs_id);$i++){
         echo "<option value='".$aWFS->wfs_id[$i]."' ";
-        if(isset($_REQUEST["wfs"]) && $aWFS->wfs_id[$i] == $_REQUEST["wfs"]){
+        if(isset($_POST["wfs"]) && $aWFS->wfs_id[$i] == $_POST["wfs"]){
                 echo "selected";
         echo ">".$aWFS->wfs_id[$i]." ".$aWFS->wfs_title[$i]."</option>";
@@ -230,10 +247,10 @@
 /* select featuretype */
-if(isset($_REQUEST["wfs"])){
+if(isset($_POST["wfs"])){
-                if($aWFS->wfs_id[$i] == $_REQUEST["wfs"]){
+                if($aWFS->wfs_id[$i] == $_POST["wfs"]){
                         echo "<table>";
                         echo "<tr><td>ID:</td><td>".$aWFS->wfs_id[$i]."</td></tr>";
                         echo "<tr><td>Name:</td><td>".$aWFS->wfs_name[$i]."</td></tr>";
@@ -246,12 +263,12 @@
-        $aWFS->getfeatures($_REQUEST["wfs"]);
+        $aWFS->getfeatures($_POST["wfs"]);
         echo "<table>";
         for($i=0; $i<count($aWFS->features->featuretype_id); $i++){
                 echo "<tr>";
                 echo "<td><input type='radio' name='featuretype' value='".$aWFS->features->featuretype_id[$i]."' onclick='submit()' ";
-                if(isset($_REQUEST["featuretype"]) && $_REQUEST["featuretype"] == $aWFS->features->featuretype_id[$i]){
+                if(isset($_POST["featuretype"]) && $_POST["featuretype"] == $aWFS->features->featuretype_id[$i]){
                         echo "checked ";
                 echo "/></td>";
@@ -264,11 +281,11 @@
 /* end select featuretype */
 /* configure elements */
-if(isset($_REQUEST["featuretype"])){
+if(isset($_POST["featuretype"])){
-                if($_REQUEST["featuretype"] == $aWFS->features->featuretype_id[$i]){
+                if($_POST["featuretype"] == $aWFS->features->featuretype_id[$i]){
                         echo "<hr>SRS: ".$aWFS->features->featuretype_srs[$i];
@@ -288,7 +305,7 @@
         /* set element options */
-        $aWFS->getelements($_REQUEST["featuretype"]);
+        $aWFS->getelements($_POST["featuretype"]);
         echo "<table border='1'>";
         echo "<tr valign = bottom>";
                 echo "<td>" . toImage('ID') . "</td>";
@@ -354,4 +371,4 @@
 /* end configure elements */
 </form>
-</body>
\ No newline at end of file
+</body>
Modified: trunk/mapbender/http/php/mod_wfs_edit.php
--- trunk/mapbender/http/php/mod_wfs_edit.php	2009-02-20 13:24:42 UTC (rev 3580)
+++ trunk/mapbender/http/php/mod_wfs_edit.php	2009-02-20 13:26:21 UTC (rev 3581)
@@ -18,6 +18,12 @@
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 <html>
 <head>
@@ -91,13 +97,13 @@
 <?php
         $sql = "UPDATE wfs_conf SET ";
         $sql .= "wfs_conf_abstract = $1, g_label = $2, ";
         $sql .= "g_label_id = $3, g_button = $4, g_button_id = $5, g_style = $6, ";
         $sql .= "g_buffer = $7, g_res_style = $8, g_use_wzgraphics = ";
         	$sql .= "1";
         else {
@@ -105,35 +111,35 @@
         $sql .= " WHERE wfs_conf_id = $9;";
-        $v = array($_REQUEST["wfs_conf_abstract"], $_REQUEST["g_label"], $_REQUEST["g_label_id"], $_REQUEST["g_button"], $_REQUEST["g_button_id"], $_REQUEST["g_style"], $_REQUEST["g_buffer"], $_REQUEST["g_res_style"], $_REQUEST["gaz"]);
+        $v = array($_POST["wfs_conf_abstract"], $_POST["g_label"], $_POST["g_label_id"], $_POST["g_button"], $_POST["g_button_id"], $_POST["g_style"], $_POST["g_buffer"], $_POST["g_res_style"], $_POST["gaz"]);
         $t = array("s", "s", "s", "s", "s", "s", "s", "s", "s");
-	        $v = array($_REQUEST["gaz"], $_REQUEST["f_geom"]);
+	        $v = array($_POST["gaz"], $_POST["f_geom"]);
 	        $t = array("i", "s");
 			$sql = "UPDATE wfs_conf_element SET f_geom = 0 ";
 	        $sql .= "WHERE fkey_wfs_conf_id = $1 AND f_id <> $2;";
 		else {
 	        $sql .= "WHERE fkey_wfs_conf_id = $1;";
-	        $v = array($_REQUEST["gaz"]);
+	        $v = array($_POST["gaz"]);
 	        $t = array("i");
-        for($i=0; $i<$_REQUEST["num"]; $i++){
+        for($i=0; $i<$_POST["num"]; $i++){
                 $sql = "UPDATE wfs_conf_element SET f_search = '";
                 	$sql .= "1";
                 else {
@@ -141,7 +147,7 @@
                 $sql .= "', f_pos = $1, f_min_input = $2, f_style_id = $3,";
                 $sql .= "f_toupper = '" ;
                 	$sql .= "1";
                 else {
@@ -149,7 +155,7 @@
                 $sql .= "',f_label = $4, f_label_id = $5,";
                 $sql .= "f_show = '";
                 	$sql .= "1";
                 else {
@@ -157,7 +163,7 @@
 				$sql .= "',f_respos = $6,";
                 $sql .= "f_edit = '";
                 	$sql .= "1";
                 else {
@@ -165,15 +171,15 @@
 				$sql .= "', f_form_element_html = $7,";
                 $sql .= "f_mandatory = '";
                 	$sql .= "1";
                 else {
                 	$sql .= "0";
 				$sql .= "', f_auth_varname = $8";
-			   	$sql .= ", f_show_detail = '";
+				$sql .= ", f_show_detail = '";
                 	$sql .= "1";
                 else {
@@ -183,7 +189,7 @@
                 $sql .= ", f_operator = $10";
 				$sql .= " WHERE fkey_wfs_conf_id = $11 AND f_id = $12;";
-				$v = array($_REQUEST["f_pos".$i], $_REQUEST["f_min_input".$i], $_REQUEST["f_style_id".$i], $_REQUEST["f_label".$i], $_REQUEST["f_label_id".$i], $_REQUEST["f_respos".$i], stripslashes($_REQUEST["f_form_element_html".$i]), $_REQUEST["f_auth_varname".$i], $_REQUEST["f_detailpos".$i], $_REQUEST["f_operator".$i], $_REQUEST["gaz"], $_REQUEST["f_id".$i]);
+				$v = array($_POST["f_pos".$i], $_POST["f_min_input".$i], $_POST["f_style_id".$i], $_POST["f_label".$i], $_POST["f_label_id".$i], $_POST["f_respos".$i], $_POST["f_form_element_html".$i], $_POST["f_auth_varname".$i], $_POST["f_detailpos".$i], $_POST["f_operator".$i], $_POST["gaz"], $_POST["f_id".$i]);
 				$t = array("s", "i", "s", "s", "s", "s", "s", "s", "i", "s", "i", "s");
@@ -199,7 +205,7 @@
 $cnt = 0;
 while($row = db_fetch_array($res)){
         echo "<option value='".$row["wfs_conf_id"]."' ";
-        if(isset($_REQUEST["gaz"]) && $row["wfs_conf_id"] == $_REQUEST["gaz"]){
+        if(isset($_POST["gaz"]) && $row["wfs_conf_id"] == $_POST["gaz"]){
                 echo "selected";
         echo ">".$row["wfs_conf_id"]." ".$row["wfs_conf_abstract"]."</option>";
@@ -220,9 +226,9 @@
-if (isset($_REQUEST["gaz"])) {
+if (isset($_POST["gaz"])) {
         $sql = "SELECT * FROM wfs_conf WHERE wfs_conf_id = $1";
         $t = array("i");
         if($row = db_fetch_array($res)){
@@ -246,7 +252,7 @@
         $sql = "SELECT * FROM wfs_conf_element ";
         $sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
         $sql .= "WHERE fkey_wfs_conf_id = $1 ORDER BY f_id";
 		$t = array("i");
@@ -307,8 +313,8 @@
                 echo "<td><input name='f_toupper".$cnt."' type='checkbox'";
                 if($row["f_toupper"] == 1){ echo " checked"; }
                 echo "></td>";
-                echo "<td><input name='f_label".$cnt."' type='text' size='4' value='".$row["f_label"]."'></td>";
-                echo "<td><input name='f_label_id".$cnt."' type='text' size='2' value='".$row["f_label_id"]."'></td>";
+                echo "<td><input name='f_label".$cnt."' type='text' size='4' value=\"".htmlentities($row["f_label"])."\"></td>";
+                echo "<td><input name='f_label_id".$cnt."' type='text' size='2' value=\"".htmlentities($row["f_label_id"])."\"></td>";
                 echo "<td><input name='f_show".$cnt."' type='checkbox'";
                 if($row["f_show"] == 1){ echo " checked"; }
                 echo "></td>";
@@ -323,8 +329,8 @@
                 echo "<td><input name='f_edit".$cnt."' type='checkbox'";
                 if($row["f_edit"] == 1){ echo " checked"; }
                 echo "></td>";
-                echo "<td><textarea name='f_form_element_html".$cnt."' cols='15' rows='1' >".$row["f_form_element_html"]."</textarea></td>";
-                echo "<td><input name='f_auth_varname".$cnt."' type='text' size='8' value='".$row["f_auth_varname"]."'></td>";
+                echo "<td><textarea name='f_form_element_html".$cnt."' cols='15' rows='1' >".htmlentities($row["f_form_element_html"])."</textarea></td>";
+                echo "<td><input name='f_auth_varname$cnt' type='text' size='8' value=\"" . htmlentities($row["f_auth_varname"]) . "\"></td>";
                 echo "<td><select name='f_operator".$cnt."' id='f_operator".$cnt."' ";
                 if($row["f_search"] != 1){
                 	echo "disabled";
@@ -368,4 +374,4 @@
 </form>
-</body>
+</body>
More information about the Mapbender_commits mailing list
