[Mapbender-commits] r3582 - in trunk/mapbender: http/classes
http/extensions resources/db/update tools
svn_mapbender at osgeo.org
Mon Feb 23 11:25:37 EST 2009
Author: mschulz
Date: 2009-02-23 11:25:37 -0500 (Mon, 23 Feb 2009)
New Revision: 3582
Added:
trunk/mapbender/http/extensions/DifferenceEngine.php
trunk/mapbender/tools/mod_monitorCapabilities_read_single_diff.php
trunk/mapbender/http/classes/class_monitor.php
trunk/mapbender/resources/db/update/update_2.6.sql
trunk/mapbender/tools/mod_monitorCapabilities_main.php
trunk/mapbender/tools/mod_monitorCapabilities_read.php
trunk/mapbender/tools/mod_monitorCapabilities_read_single.php
http://trac.osgeo.org/mapbender/ticket/348 updated monitoring modules to store and display diffs of local and remote capabilities
Modified: trunk/mapbender/http/classes/class_monitor.php
--- trunk/mapbender/http/classes/class_monitor.php 2009-02-20 13:26:21 UTC (rev 3581)
+++ trunk/mapbender/http/classes/class_monitor.php 2009-02-23 16:25:37 UTC (rev 3582)
@@ -22,6 +22,8 @@
require_once(dirname(__FILE__)."/../classes/class_wms.php");
require_once(dirname(__FILE__)."/../classes/class_bbox.php");
+require_once(dirname(__FILE__)."/../extensions/DifferenceEngine.php");
define("MONITOR_DEFAULT_SCALE", 500000);
define("MONITOR_IMG_WIDTH", 20);
define("MONITOR_IMG_HEIGHT", 20);
@@ -54,6 +56,7 @@
var $remoteXML;
var $localXML;
+ var $capabilitiesDiff;
function __construct($wmsId, $uploadId, $autoUpdate) {
$this->wmsId = $wmsId;
@@ -104,6 +107,9 @@
// capabilities files don't match
else {
$this->result = 0;
+ $localXMLArray = explode("\n", htmlentities($this->localXML));
+ $remoteXMLArray = explode("\n", htmlentities($this->remoteXML));
+ $this->capabilitiesDiff = $this->outputDiffHtml($localXMLArray,$remoteXMLArray);
@@ -176,6 +182,8 @@
$str .= "-------------------------------------------------------------------\n";
$str .= "local XML:\n\n" . $this->localXML . "\n\n";
+ $str .= "diff:\n\n" . $this->capabilitiesDiff . "\n\n";
+ $str .= "-------------------------------------------------------------------\n";
return (string) $str;
@@ -183,9 +191,9 @@
* Update database
function updateInDB() {
- $sql = "UPDATE mb_monitor SET updated = $1, status = $2, image = $3, status_comment = $4, upload_url = $5, timestamp_end = $6, map_url = $7 WHERE upload_id = $8 AND fkey_wms_id = $9";
- $v = array($this->updated, $this->result, $this->returnsImage, $this->comment, $this->capabilitiesURL, $this->timestamp, $this->mapURL, $this->uploadId, $this->wmsId);
- $t = array('s', 'i', 'i', 's', 's', 's', 's', 's', 'i');
+ $sql = "UPDATE mb_monitor SET updated = $1, status = $2, image = $3, status_comment = $4, upload_url = $5, timestamp_end = $6, map_url = $7, timestamp_begin = $8, caps_diff = $9 WHERE upload_id = $10 AND fkey_wms_id = $11";
+ $v = array($this->updated, $this->result, $this->returnsImage, $this->comment, $this->capabilitiesURL, time(), $this->mapURL, $this->timestamp, $this->capabilitiesDiff, $this->uploadId, $this->wmsId);
+ $t = array('s', 'i', 'i', 's', 's', 's', 's', 's', 's', 's', 'i');
$res = db_prep_query($sql,$v,$t);
@@ -474,6 +482,14 @@
$someArray = db_fetch_array($res);
return $someArray["wms_getcapabilities_doc"];
+ * creates a html diff of the xml documents
+ private function outputDiffHtml($localXMLArray,$remoteXMLArray) {
+ $diffObj = new Diff($localXMLArray,$remoteXMLArray);
+ $dft = new TableDiffFormatter();
+ return $dft->format($diffObj);
Added: trunk/mapbender/http/extensions/DifferenceEngine.php
--- trunk/mapbender/http/extensions/DifferenceEngine.php (rev 0)
+++ trunk/mapbender/http/extensions/DifferenceEngine.php 2009-02-23 16:25:37 UTC (rev 3582)
@@ -0,0 +1,1062 @@
+<?php
+ * A PHP diff engine for phpwiki. (Taken from phpwiki-1.3.3)
+ * Additions by Axel Boldt for MediaWiki
+ * @copyright (C) 2000, 2001 Geoffrey T. Dairiki <dairiki at dairiki.org>
+ * @license You may copy this code freely under the conditions of the GPL.
+define('USE_ASSERTS', function_exists('assert'));
+class _DiffOp {
+ var $type;
+ var $orig;
+ var $closing;
+ function reverse() {
+ trigger_error("pure virtual", E_USER_ERROR);
+ function norig() {
+ return $this->orig ? sizeof($this->orig) : 0;
+ function nclosing() {
+ return $this->closing ? sizeof($this->closing) : 0;
+class _DiffOp_Copy extends _DiffOp {
+ var $type = 'copy';
+ function _DiffOp_Copy ($orig, $closing = false) {
+ if (!is_array($closing))
+ $closing = $orig;
+ $this->orig = $orig;
+ $this->closing = $closing;
+ return new _DiffOp_Copy($this->closing, $this->orig);
+class _DiffOp_Delete extends _DiffOp {
+ var $type = 'delete';
+ function _DiffOp_Delete ($lines) {
+ $this->orig = $lines;
+ $this->closing = false;
+ return new _DiffOp_Add($this->orig);
+class _DiffOp_Add extends _DiffOp {
+ var $type = 'add';
+ function _DiffOp_Add ($lines) {
+ $this->closing = $lines;
+ $this->orig = false;
+ return new _DiffOp_Delete($this->closing);
+class _DiffOp_Change extends _DiffOp {
+ var $type = 'change';
+ function _DiffOp_Change ($orig, $closing) {
+ return new _DiffOp_Change($this->closing, $this->orig);
+ * Class used internally by Diff to actually compute the diffs.
+ * The algorithm used here is mostly lifted from the perl module
+ * Algorithm::Diff (version 1.06) by Ned Konz, which is available at:
+ * http://www.perl.com/CPAN/authors/id/N/NE/NEDKONZ/Algorithm-Diff-1.06.zip
+ * More ideas are taken from:
+ * http://www.ics.uci.edu/~eppstein/161/960229.html
+ * Some ideas are (and a bit of code) are from from analyze.c, from GNU
+ * diffutils-2.7, which can be found at:
+ * ftp://gnudist.gnu.org/pub/gnu/diffutils/diffutils-2.7.tar.gz
+ * closingly, some ideas (subdivision by NCHUNKS > 2, and some optimizations)
+ * are my own.
+ * @author Geoffrey T. Dairiki
+ * @access private
+class _DiffEngine
+ function diff ($from_lines, $to_lines) {
+ $n_from = sizeof($from_lines);
+ $n_to = sizeof($to_lines);
+ $this->xchanged = $this->ychanged = array();
+ $this->xv = $this->yv = array();
+ $this->xind = $this->yind = array();
+ unset($this->seq);
+ unset($this->in_seq);
+ unset($this->lcs);
+ // Skip leading common lines.
+ for ($skip = 0; $skip < $n_from && $skip < $n_to; $skip++) {
+ if ($from_lines[$skip] != $to_lines[$skip])
+ break;
+ $this->xchanged[$skip] = $this->ychanged[$skip] = false;
+ // Skip trailing common lines.
+ $xi = $n_from; $yi = $n_to;
+ for ($endskip = 0; --$xi > $skip && --$yi > $skip; $endskip++) {
+ if ($from_lines[$xi] != $to_lines[$yi])
+ break;
+ $this->xchanged[$xi] = $this->ychanged[$yi] = false;
+ // Ignore lines which do not exist in both files.
+ for ($xi = $skip; $xi < $n_from - $endskip; $xi++)
+ $xhash[$from_lines[$xi]] = 1;
+ for ($yi = $skip; $yi < $n_to - $endskip; $yi++) {
+ $line = $to_lines[$yi];
+ if ( ($this->ychanged[$yi] = empty($xhash[$line])) )
+ continue;
+ $yhash[$line] = 1;
+ $this->yv[] = $line;
+ $this->yind[] = $yi;
+ for ($xi = $skip; $xi < $n_from - $endskip; $xi++) {
+ $line = $from_lines[$xi];
+ if ( ($this->xchanged[$xi] = empty($yhash[$line])) )
+ continue;
+ $this->xv[] = $line;
+ $this->xind[] = $xi;
+ // Find the LCS.
+ $this->_compareseq(0, sizeof($this->xv), 0, sizeof($this->yv));
+ // Merge edits when possible
+ $this->_shift_boundaries($from_lines, $this->xchanged, $this->ychanged);
+ $this->_shift_boundaries($to_lines, $this->ychanged, $this->xchanged);
+ // Compute the edit operations.
+ $edits = array();
+ $xi = $yi = 0;
+ while ($xi < $n_from || $yi < $n_to) {
+ USE_ASSERTS && assert($yi < $n_to || $this->xchanged[$xi]);
+ USE_ASSERTS && assert($xi < $n_from || $this->ychanged[$yi]);
+ // Skip matching "snake".
+ $copy = array();
+ while ( $xi < $n_from && $yi < $n_to
+ && !$this->xchanged[$xi] && !$this->ychanged[$yi]) {
+ $copy[] = $from_lines[$xi++];
+ ++$yi;
+ if ($copy)
+ $edits[] = new _DiffOp_Copy($copy);
+ // Find deletes & adds.
+ $delete = array();
+ while ($xi < $n_from && $this->xchanged[$xi])
+ $delete[] = $from_lines[$xi++];
+ $add = array();
+ while ($yi < $n_to && $this->ychanged[$yi])
+ $add[] = $to_lines[$yi++];
+ if ($delete && $add)
+ $edits[] = new _DiffOp_Change($delete, $add);
+ elseif ($delete)
+ $edits[] = new _DiffOp_Delete($delete);
+ elseif ($add)
+ $edits[] = new _DiffOp_Add($add);
+ return $edits;
+ * Divide the Largest Common Subsequence (LCS) of the sequences
+ * [XOFF, XLIM) and [YOFF, YLIM) into NCHUNKS approximately equally
+ * sized segments.
+ * Returns (LCS, PTS). LCS is the length of the LCS. PTS is an
+ * array of NCHUNKS+1 (X, Y) indexes giving the diving points between
+ * sub sequences. The first sub-sequence is contained in [X0, X1),
+ * [Y0, Y1), the second in [X1, X2), [Y1, Y2) and so on. Note
+ * that (X0, Y0) == (XOFF, YOFF) and
+ * (X[NCHUNKS], Y[NCHUNKS]) == (XLIM, YLIM).
+ * This function assumes that the first lines of the specified portions
+ * of the two files do not match, and likewise that the last lines do not
+ * match. The caller must trim matching lines from the beginning and end
+ * of the portions it is going to specify.
+ function _diag ($xoff, $xlim, $yoff, $ylim, $nchunks) {
+ $flip = false;
+ if ($xlim - $xoff > $ylim - $yoff) {
+ // Things seems faster (I'm not sure I understand why)
+ // when the shortest sequence in X.
+ $flip = true;
+ list ($xoff, $xlim, $yoff, $ylim)
+ = array( $yoff, $ylim, $xoff, $xlim);
+ if ($flip)
+ for ($i = $ylim - 1; $i >= $yoff; $i--)
+ $ymatches[$this->xv[$i]][] = $i;
+ else
+ $ymatches[$this->yv[$i]][] = $i;
+ $this->lcs = 0;
+ $this->seq[0]= $yoff - 1;
+ $this->in_seq = array();
+ $ymids[0] = array();
+ $numer = $xlim - $xoff + $nchunks - 1;
+ $x = $xoff;
+ for ($chunk = 0; $chunk < $nchunks; $chunk++) {
+ if ($chunk > 0)
+ for ($i = 0; $i <= $this->lcs; $i++)
+ $ymids[$i][$chunk-1] = $this->seq[$i];
+ $x1 = $xoff + (int)(($numer + ($xlim-$xoff)*$chunk) / $nchunks);
+ for ( ; $x < $x1; $x++) {
+ $line = $flip ? $this->yv[$x] : $this->xv[$x];
+ if (empty($ymatches[$line]))
+ continue;
+ $matches = $ymatches[$line];
+ reset($matches);
+ while (list ($junk, $y) = each($matches))
+ if (empty($this->in_seq[$y])) {
+ $k = $this->_lcs_pos($y);
+ USE_ASSERTS && assert($k > 0);
+ $ymids[$k] = $ymids[$k-1];
+ break;
+ while (list ($junk, $y) = each($matches)) {
+ if ($y > $this->seq[$k-1]) {
+ USE_ASSERTS && assert($y < $this->seq[$k]);
+ // Optimization: this is a common case:
+ // next match is just replacing previous match.
+ $this->in_seq[$this->seq[$k]] = false;
+ $this->seq[$k] = $y;
+ $this->in_seq[$y] = 1;
+ else if (empty($this->in_seq[$y])) {
+ $seps[] = $flip ? array($yoff, $xoff) : array($xoff, $yoff);
+ $ymid = $ymids[$this->lcs];
+ for ($n = 0; $n < $nchunks - 1; $n++) {
+ $x1 = $xoff + (int)(($numer + ($xlim - $xoff) * $n) / $nchunks);
+ $y1 = $ymid[$n] + 1;
+ $seps[] = $flip ? array($y1, $x1) : array($x1, $y1);
+ $seps[] = $flip ? array($ylim, $xlim) : array($xlim, $ylim);
+ return array($this->lcs, $seps);
+ function _lcs_pos ($ypos) {
+ $end = $this->lcs;
+ if ($end == 0 || $ypos > $this->seq[$end]) {
+ $this->seq[++$this->lcs] = $ypos;
+ $this->in_seq[$ypos] = 1;
+ return $this->lcs;
+ $beg = 1;
+ while ($beg < $end) {
+ $mid = (int)(($beg + $end) / 2);
+ if ( $ypos > $this->seq[$mid] )
+ $beg = $mid + 1;
+ else
+ $end = $mid;
+ USE_ASSERTS && assert($ypos != $this->seq[$end]);
+ $this->in_seq[$this->seq[$end]] = false;
+ $this->seq[$end] = $ypos;
+ return $end;
+ * Find LCS of two sequences.
+ * The results are recorded in the vectors $this->{x,y}changed[], by
+ * storing a 1 in the element for each line that is an insertion
+ * or deletion (ie. is not in the LCS).
+ * The subsequence of file 0 is [XOFF, XLIM) and likewise for file 1.
+ * Note that XLIM, YLIM are exclusive bounds.
+ * All line numbers are origin-0 and discarded lines are not counted.
+ function _compareseq ($xoff, $xlim, $yoff, $ylim) {
+ // Slide down the bottom initial diagonal.
+ while ($xoff < $xlim && $yoff < $ylim
+ && $this->xv[$xoff] == $this->yv[$yoff]) {
+ ++$xoff;
+ ++$yoff;
+ // Slide up the top initial diagonal.
+ while ($xlim > $xoff && $ylim > $yoff
+ && $this->xv[$xlim - 1] == $this->yv[$ylim - 1]) {
+ --$xlim;
+ --$ylim;
+ if ($xoff == $xlim || $yoff == $ylim)
+ $lcs = 0;
+ else {
+ // This is ad hoc but seems to work well.
+ //$nchunks = sqrt(min($xlim - $xoff, $ylim - $yoff) / 2.5);
+ //$nchunks = max(2,min(8,(int)$nchunks));
+ $nchunks = min(7, $xlim - $xoff, $ylim - $yoff) + 1;
+ list ($lcs, $seps)
+ = $this->_diag($xoff,$xlim,$yoff, $ylim,$nchunks);
+ if ($lcs == 0) {
+ // X and Y sequences have no common subsequence:
+ // mark all changed.
+ while ($yoff < $ylim)
+ $this->ychanged[$this->yind[$yoff++]] = 1;
+ while ($xoff < $xlim)
+ $this->xchanged[$this->xind[$xoff++]] = 1;
+ else {
+ // Use the partitions to split this problem into subproblems.
+ reset($seps);
+ $pt1 = $seps[0];
+ while ($pt2 = next($seps)) {
+ $this->_compareseq ($pt1[0], $pt2[0], $pt1[1], $pt2[1]);
+ $pt1 = $pt2;
+ * Adjust inserts/deletes of identical lines to join changes
+ * as much as possible.
+ * We do something when a run of changed lines include a
+ * line at one end and has an excluded, identical line at the other.
+ * We are free to choose which identical line is included.
+ * `compareseq' usually chooses the one at the beginning,
+ * but usually it is cleaner to consider the following identical line
+ * to be the "change".
+ * This is extracted verbatim from analyze.c (GNU diffutils-2.7).
+ function _shift_boundaries ($lines, &$changed, $other_changed) {
+ $i = 0;
+ $j = 0;
+ USE_ASSERTS && assert('sizeof($lines) == sizeof($changed)');
+ $len = sizeof($lines);
+ $other_len = sizeof($other_changed);
+ while (1) {
+ * Scan forwards to find beginning of another run of changes.
+ * Also keep track of the corresponding point in the other file.
+ * Throughout this code, $i and $j are adjusted together so that
+ * the first $i elements of $changed and the first $j elements
+ * of $other_changed both contain the same number of zeros
+ * (unchanged lines).
+ * Furthermore, $j is always kept so that $j == $other_len or
+ * $other_changed[$j] == false.
+ while ($j < $other_len && $other_changed[$j])
+ $j++;
+ while ($i < $len && ! $changed[$i]) {
+ USE_ASSERTS && assert('$j < $other_len && ! $other_changed[$j]');
+ $i++; $j++;
+ $j++;
+ if ($i == $len)
+ break;
+ $start = $i;
+ // Find the end of this run of changes.
+ while (++$i < $len && $changed[$i])
+ continue;
+ do {
+ * Record the length of this run of changes, so that
+ * we can later determine whether the run has grown.
+ $runlength = $i - $start;
+ * Move the changed region back, so long as the
+ * previous unchanged line matches the last changed one.
+ * This merges with previous changed regions.
+ while ($start > 0 && $lines[$start - 1] == $lines[$i - 1]) {
+ $changed[--$start] = 1;
+ $changed[--$i] = false;
+ while ($start > 0 && $changed[$start - 1])
+ $start--;
+ USE_ASSERTS && assert('$j > 0');
+ while ($other_changed[--$j])
+ continue;
+ USE_ASSERTS && assert('$j >= 0 && !$other_changed[$j]');
+ * Set CORRESPONDING to the end of the changed run, at the last
+ * point where it corresponds to a changed run in the other file.
+ * CORRESPONDING == LEN means no such point has been found.
+ $corresponding = $j < $other_len ? $i : $len;
+ * Move the changed region forward, so long as the
+ * first changed line matches the following unchanged one.
+ * This merges with following changed regions.
+ * Do this second, so that if there are no merges,
+ * the changed region is moved forward as far as possible.
+ while ($i < $len && $lines[$start] == $lines[$i]) {
+ $changed[$start++] = false;
+ $changed[$i++] = 1;
+ while ($i < $len && $changed[$i])
+ $i++;
+ $j++;
+ if ($j < $other_len && $other_changed[$j]) {
+ $corresponding = $i;
+ $j++;
+ } while ($runlength != $i - $start);
+ * If possible, move the fully-merged run of changes
+ * back to a corresponding run in the other file.
+ while ($corresponding < $i) {
+ $changed[--$i] = 0;
+ continue;
+ * Class representing a 'diff' between two sequences of strings.
+class Diff
+ var $edits;
+ * Constructor.
+ * Computes diff between sequences of strings.
+ * @param $from_lines array An array of strings.
+ * (Typically these are lines from a file.)
+ * @param $to_lines array An array of strings.
+ function Diff($from_lines, $to_lines) {
+ $eng = new _DiffEngine;
+ $this->edits = $eng->diff($from_lines, $to_lines);
+ //$this->_check($from_lines, $to_lines);
+ * Compute reversed Diff.
+ * SYNOPSIS:
+ * $diff = new Diff($lines1, $lines2);
+ * $rev = $diff->reverse();
+ * @return object A Diff object representing the inverse of the
+ * original diff.
+ function reverse () {
+ $rev = $this;
+ $rev->edits = array();
+ foreach ($this->edits as $edit) {
+ $rev->edits[] = $edit->reverse();
+ return $rev;
+ * Check for empty diff.
+ * @return bool True iff two sequences were identical.
+ function isEmpty () {
+ if ($edit->type != 'copy')
+ return false;
+ return true;
+ * Compute the length of the Longest Common Subsequence (LCS).
+ * This is mostly for diagnostic purposed.
+ * @return int The length of the LCS.
+ function lcs () {
+ $lcs = 0;
+ if ($edit->type == 'copy')
+ $lcs += sizeof($edit->orig);
+ return $lcs;
+ * Get the original set of lines.
+ * This reconstructs the $from_lines parameter passed to the
+ * constructor.
+ * @return array The original sequence of strings.
+ function orig() {
+ $lines = array();
+ if ($edit->orig)
+ array_splice($lines, sizeof($lines), 0, $edit->orig);
+ return $lines;
+ * Get the closing set of lines.
+ * This reconstructs the $to_lines parameter passed to the
+ * constructor.
+ * @return array The sequence of strings.
+ function closing() {
+ $lines = array();
+ if ($edit->closing)
+ array_splice($lines, sizeof($lines), 0, $edit->closing);
+ return $lines;
+ * Check a Diff for validity.
+ * This is here only for debugging purposes.
+ function _check ($from_lines, $to_lines) {
+ if (serialize($from_lines) != serialize($this->orig()))
+ trigger_error("Reconstructed original doesn't match", E_USER_ERROR);
+ if (serialize($to_lines) != serialize($this->closing()))
+ trigger_error("Reconstructed closing doesn't match", E_USER_ERROR);
+ $rev = $this->reverse();
+ if (serialize($to_lines) != serialize($rev->orig()))
+ trigger_error("Reversed original doesn't match", E_USER_ERROR);
+ if (serialize($from_lines) != serialize($rev->closing()))
+ trigger_error("Reversed closing doesn't match", E_USER_ERROR);
+ $prevtype = 'none';
+ if ( $prevtype == $edit->type )
+ trigger_error("Edit sequence is non-optimal", E_USER_ERROR);
+ $prevtype = $edit->type;
+ $lcs = $this->lcs();
+ trigger_error("Diff okay: LCS = $lcs", E_USER_NOTICE);
+ * FIXME: bad name.
+class MappedDiff
+extends Diff
+ * Constructor.
+ * This can be used to compute things like
+ * case-insensitve diffs, or diffs which ignore
+ * changes in white-space.
+ * @param $mapped_from_lines array This array should
+ * have the same size number of elements as $from_lines.
+ * The elements in $mapped_from_lines and
+ * $mapped_to_lines are what is actually compared
+ * when computing the diff.
+ * @param $mapped_to_lines array This array should
+ * have the same number of elements as $to_lines.
+ function MappedDiff($from_lines, $to_lines,
+ $mapped_from_lines, $mapped_to_lines) {
+ assert(sizeof($from_lines) == sizeof($mapped_from_lines));
+ assert(sizeof($to_lines) == sizeof($mapped_to_lines));
+ $this->Diff($mapped_from_lines, $mapped_to_lines);
+ $xi = $yi = 0;
+ for ($i = 0; $i < sizeof($this->edits); $i++) {
+ $orig = &$this->edits[$i]->orig;
+ if (is_array($orig)) {
+ $orig = array_slice($from_lines, $xi, sizeof($orig));
+ $xi += sizeof($orig);
+ $closing = &$this->edits[$i]->closing;
+ if (is_array($closing)) {
+ $closing = array_slice($to_lines, $yi, sizeof($closing));
+ $yi += sizeof($closing);
+ * A class to format Diffs
+ * This class formats the diff in classic diff format.
+ * It is intended that this class be customized via inheritance,
+ * to obtain fancier outputs.
+class DiffFormatter
+ * Number of leading context "lines" to preserve.
+ * This should be left at zero for this class, but subclasses
+ * may want to set this to other values.
+ var $leading_context_lines = 0;
+ * Number of trailing context "lines" to preserve.
+ var $trailing_context_lines = 0;
+ * Format a diff.
+ * @param $diff object A Diff object.
+ * @return string The formatted output.
+ function format($diff) {
+ $xi = $yi = 1;
+ $block = false;
+ $context = array();
+ $nlead = $this->leading_context_lines;
+ $ntrail = $this->trailing_context_lines;
+ $this->_start_diff();
+ foreach ($diff->edits as $edit) {
+ if ($edit->type == 'copy') {
+ if (is_array($block)) {
+ if (sizeof($edit->orig) <= $nlead + $ntrail) {
+ $block[] = $edit;
+ else{
+ if ($ntrail) {
+ $context = array_slice($edit->orig, 0, $ntrail);
+ $block[] = new _DiffOp_Copy($context);
+ $this->_block($x0, $ntrail + $xi - $x0,
+ $y0, $ntrail + $yi - $y0,
+ $block);
+ $block = false;
+ $context = $edit->orig;
+ else {
+ if (! is_array($block)) {
+ $context = array_slice($context, sizeof($context) - $nlead);
+ $x0 = $xi - sizeof($context);
+ $y0 = $yi - sizeof($context);
+ $block = array();
+ if ($context)
+ $block[] = $edit;
+ if ($edit->orig)
+ $xi += sizeof($edit->orig);
+ $yi += sizeof($edit->closing);
+ $this->_block($x0, $xi - $x0,
+ $y0, $yi - $y0,
+ $block);
+ return $this->_end_diff();
+ function _block($xbeg, $xlen, $ybeg, $ylen, &$edits) {
+ $this->_start_block($this->_block_header($xbeg, $xlen, $ybeg, $ylen));
+ foreach ($edits as $edit) {
+ $this->_context($edit->orig);
+ elseif ($edit->type == 'add')
+ $this->_added($edit->closing);
+ elseif ($edit->type == 'delete')
+ $this->_deleted($edit->orig);
+ elseif ($edit->type == 'change')
+ $this->_changed($edit->orig, $edit->closing);
+ else
+ trigger_error("Unknown edit type", E_USER_ERROR);
+ $this->_end_block();
+ function _start_diff() {
+ ob_start();
+ function _end_diff() {
+ $val = ob_get_contents();
+ ob_end_clean();
+ return $val;
+ function _block_header($xbeg, $xlen, $ybeg, $ylen) {
+ if ($xlen > 1)
+ $xbeg .= "," . ($xbeg + $xlen - 1);
+ if ($ylen > 1)
+ $ybeg .= "," . ($ybeg + $ylen - 1);
+ return $xbeg . ($xlen ? ($ylen ? 'c' : 'd') : 'a') . $ybeg;
+ function _start_block($header) {
+ echo $header;
+ function _end_block() {
+ function _lines($lines, $prefix = ' ') {
+ foreach ($lines as $line)
+ echo "$prefix $line\n";
+ function _context($lines) {
+ $this->_lines($lines);
+ function _added($lines) {
+ $this->_lines($lines, ">");
+ function _deleted($lines) {
+ $this->_lines($lines, "<");
+ function _changed($orig, $closing) {
+ $this->_deleted($orig);
+ echo "---\n";
+ $this->_added($closing);
+ * Additions by Axel Boldt follow, partly taken from diff.php, phpwiki-1.3.3
+define('NBSP', "\xC2\xA0"); // utf-8 non-breaking space.
+class _HWLDF_WordAccumulator {
+ function _HWLDF_WordAccumulator () {
+ $this->_lines = array();
+ $this->_line = '';
+ $this->_group = '';
+ $this->_tag = '';
+ function _flushGroup ($new_tag) {
+ if ($this->_group !== '') {
+ if ($this->_tag == 'mark')
+ $this->_line .= '<strong>'.$this->_group.'</strong>';
+ else
+ $this->_line .= $this->_group;
+ $this->_tag = $new_tag;
+ function _flushLine ($new_tag) {
+ $this->_flushGroup($new_tag);
+ if ($this->_line != '')
+ $this->_lines[] = $this->_line;
+ function addWords ($words, $tag = '') {
+ if ($tag != $this->_tag)
+ $this->_flushGroup($tag);
+ foreach ($words as $word) {
+ // new-line should only come as first char of word.
+ if ($word == '')
+ continue;
+ if ($word[0] == "\n") {
+ $this->_group .= NBSP;
+ $this->_flushLine($tag);
+ $word = substr($word, 1);
+ assert(!strstr($word, "\n"));
+ $this->_group .= $word;
+ function getLines() {
+ $this->_flushLine('~done');
+ return $this->_lines;
+class WordLevelDiff extends MappedDiff
+ function WordLevelDiff ($orig_lines, $closing_lines) {
+ list ($orig_words, $orig_stripped) = $this->_split($orig_lines);
+ list ($closing_words, $closing_stripped) = $this->_split($closing_lines);
+ $this->MappedDiff($orig_words, $closing_words,
+ $orig_stripped, $closing_stripped);
+ function _split($lines) {
+ // FIXME: fix POSIX char class.
+# if (!preg_match_all('/ ( [^\S\n]+ | [[:alnum:]]+ | . ) (?: (?!< \n) [^\S\n])? /xs',
+ if (!preg_match_all('/ ( [^\S\n]+ | [0-9_A-Za-z\x80-\xff]+ | . ) (?: (?!< \n) [^\S\n])? /xs',
+ implode("\n", $lines),
+ $m)) {
+ return array(array(''), array(''));
+ return array($m[0], $m[1]);
+ function orig () {
+ $orig = new _HWLDF_WordAccumulator;
+ $orig->addWords($edit->orig);
+ elseif ($edit->orig)
+ $orig->addWords($edit->orig, 'mark');
+ return $orig->getLines();
+ function closing () {
+ $closing = new _HWLDF_WordAccumulator;
+ $closing->addWords($edit->closing);
+ elseif ($edit->closing)
+ $closing->addWords($edit->closing, 'mark');
+ return $closing->getLines();
+ * "Unified" diff formatter.
+ * This class formats the diff in classic "unified diff" format.
+class UnifiedDiffFormatter extends DiffFormatter
+ function UnifiedDiffFormatter($context_lines = 4) {
+ $this->leading_context_lines = $context_lines;
+ $this->trailing_context_lines = $context_lines;
+ if ($xlen != 1)
+ $xbeg .= "," . $xlen;
+ if ($ylen != 1)
+ $ybeg .= "," . $ylen;
+ return "@@ -$xbeg +$ybeg @@\n";
+ $this->_lines($lines, "+");
+ $this->_lines($lines, "-");
+ function _changed($orig, $final) {
+ $this->_added($final);
+ * Wikipedia Table style diff formatter.
+class TableDiffFormatter extends DiffFormatter
+ function TableDiffFormatter() {
+ $this->leading_context_lines = 2;
+ $this->trailing_context_lines = 2;
+ function _pre($text){
+ $text = htmlspecialchars($text);
+ $text = str_replace(' ',' ',$text);
+ return $text;
+ function _block_header( $xbeg, $xlen, $ybeg, $ylen ) {
+ global $lang;
+ $l1 = $lang['line'].' '.$xbeg;
+ $l2 = $lang['line'].' '.$ybeg;
+ $r = '<tr><td class="diff-blockheader" colspan="2">'.$l1.":</td>\n" .
+ '<td class="diff-blockheader" colspan="2">'.$l2.":</td></tr>\n";
+ return $r;
+ function _start_block( $header ) {
+ print( $header );
+ function _lines( $lines, $prefix=' ', $color="white" ) {
+ function addedLine( $line ) {
+ $line = str_replace(' ',' ',$line);
+ return '<td>+</td><td class="diff-addedline">' .
+ $line.'</td>';
+ function deletedLine( $line ) {
+ return '<td>-</td><td class="diff-deletedline">' .
+ $line.'</td>';
+ function emptyLine() {
+ //$line = str_replace(' ',' ',$line);
+ return '<td colspan="2"> </td>';
+ function contextLine( $line ) {
+ return '<td> </td><td class="diff-context">'.$line.'</td>';
+ foreach ($lines as $line) {
+ print( '<tr>' . $this->emptyLine() .
+ $this->addedLine( $line ) . "</tr>\n" );
+ print( '<tr>' . $this->deletedLine( $line ) .
+ $this->emptyLine() . "</tr>\n" );
+ function _context( $lines ) {
+ print( '<tr>' . $this->contextLine( $line ) .
+ $this->contextLine( $line ) . "</tr>\n" );
+ function _changed( $orig, $closing ) {
+ $diff = new WordLevelDiff( $orig, $closing );
+ $del = $diff->orig();
+ $add = $diff->closing();
+ while ( $line = array_shift( $del ) ) {
+ $aline = array_shift( $add );
+ $this->addedLine( $aline ) . "</tr>\n" );
+ $this->_added( $add ); # If any leftovers
+//Setup VIM: ex: et ts=2 enc=utf-8 :
Modified: trunk/mapbender/resources/db/update/update_2.6.sql
--- trunk/mapbender/resources/db/update/update_2.6.sql 2009-02-20 13:26:21 UTC (rev 3581)
+++ trunk/mapbender/resources/db/update/update_2.6.sql 2009-02-23 16:25:37 UTC (rev 3582)
@@ -59,6 +59,9 @@
UPDATE gui_element SET e_attributes = 'onload="init()"' WHERE e_id = 'body' AND fkey_gui_id IN ('admin1', 'admin2_de', 'admin2_en', 'admin_de_services', 'admin_en_services');
+-- new capabilities diff column for monitoring
+ALTER TABLE mb_monitor ADD COLUMN caps_diff text;
+ALTER TABLE mb_monitor ALTER COLUMN caps_diff SET DEFAULT ''::text;
-- scope
@@ -146,4 +149,4 @@
INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Measure distance', 'Messen');
-UPDATE gui_element SET e_attributes = 'onload="init()"' WHERE e_id = 'body' AND fkey_gui_id IN ('wms_africa', 'wms_australia', 'wms_europe', 'wms_gdi_de', 'wms_germany', 'wms_north_america', 'wms_worldwide');
\ No newline at end of file
+UPDATE gui_element SET e_attributes = 'onload="init()"' WHERE e_id = 'body' AND fkey_gui_id IN ('wms_africa', 'wms_australia', 'wms_europe', 'wms_gdi_de', 'wms_germany', 'wms_north_america', 'wms_worldwide');
Modified: trunk/mapbender/tools/mod_monitorCapabilities_main.php
--- trunk/mapbender/tools/mod_monitorCapabilities_main.php 2009-02-20 13:26:21 UTC (rev 3581)
+++ trunk/mapbender/tools/mod_monitorCapabilities_main.php 2009-02-23 16:25:37 UTC (rev 3582)
@@ -184,7 +184,7 @@
if ($status[$i] == -2 && intval(time())-intval($timestamp_begin[$i]) > intval(TIME_LIMIT)) {
$comment[$i] = "Monitoring process timed out.";
$status[$i] = -1;
- $new_sql = "UPDATE mb_monitor SET status = '-1', isImage = '-1', status_comment = 'Monitoring process timed out.', timestamp_end = $1 WHERE fkey_wms_id = $2 AND upload_id = $3";
+ $new_sql = "UPDATE mb_monitor SET status = '-1', image = '-1', status_comment = 'Monitoring process timed out.', timestamp_end = $1 WHERE fkey_wms_id = $2 AND upload_id = $3";
$new_v = array((intval($upload_id[$i])+intval(TIME_LIMIT)), $wms_id[$i], $time);
$new_t = array('s', 'i', 's');
$new_res = db_prep_query($new_sql,$new_v,$new_t);
Modified: trunk/mapbender/tools/mod_monitorCapabilities_read.php
--- trunk/mapbender/tools/mod_monitorCapabilities_read.php 2009-02-20 13:26:21 UTC (rev 3581)
+++ trunk/mapbender/tools/mod_monitorCapabilities_read.php 2009-02-23 16:25:37 UTC (rev 3582)
@@ -1,6 +1,5 @@
<?php
-# $Id: mod_monitorCapabilities_read.php 1283 2007-10-25 15:20:25Z baudson $
+# $Id: mod_monitorCapabilities_read.php 3354 2008-12-17 10:31:57Z mschulz $
# http://www.mapbender.org/index.php/Monitor_Capabilities
# Copyright (C) 2002 CCGIS
@@ -86,8 +85,8 @@
else {
$avg_response_time[$wms[$i]] = round(db_result($res,0,1)-db_result($res,0,0), 1);
- $sql = "SELECT status, status_comment, timestamp_begin, timestamp_end, upload_url, updated, image, map_url FROM mb_monitor ";
+ $sql = "SELECT status, status_comment, timestamp_begin, timestamp_end, upload_url, updated, image, map_url, caps_diff FROM mb_monitor ";
$sql .= "WHERE upload_id = $1 AND fkey_wms_id = $2 ORDER BY status, status_comment, timestamp_end, fkey_wms_id";
$v = array($upload_id[$wms[$i]], $wms_id[$wms[$i]]);
$t = array('s', 'i');
@@ -100,7 +99,8 @@
$upload_url[$wms[$i]] = db_result($res,0,"upload_url");
$updated[$wms[$i]] = db_result($res,0,"updated");
$mapurl[$wms[$i]] = db_result($res,0,"map_url");
- $image[$wms[$i]] = db_result($res,0,"image");
+ $image[$wms[$i]] = db_result($res,0,"image");
+ $caps_diff[$wms[$i]] = db_result($res,0,"caps_diff");
if ($status[$wms[$i]] == -2 && intval(time())-intval($timestamp_begin[$wms[$i]]) > intval(TIME_LIMIT)) {
$comment[$wms[$i]] = "Monitoring process timed out.";
@@ -166,7 +166,7 @@
$str .= "<th align='left' colspan = 2><a href='".$PHP_SELF."?sortby=status'>current status</a></th>";
$str .= "<th align='left'><a href='".$PHP_SELF."?sortby=image'>image</a></th>";
$str .= "<th align='left'><a href='".$PHP_SELF."?sortby=avgresp'>avg. response time</a></th>";
-$str .= "<th align='left'><a href='".$PHP_SELF."?sortby=avail'>overall availability</a></th><th></th></tr>";
+$str .= "<th align='left'><a href='".$PHP_SELF."?sortby=avail'>overall availability</a></th><th></th><th>Diff</th></tr>";
$cnt = 0;
foreach ($newArray as $k => $value) {
@@ -237,7 +237,11 @@
$str .= "</tr></table></td>";
# $str .= "\n\t\t\t<td><a href='output_".$wms_id[$k]."_".$max.".txt' target=_blank>log</a></td>";
- $str .= "\n\t\t<td><input type=button value='details' onclick=\"var newWindow = window.open('../tools/mod_monitorCapabilities_read_single.php?wmsid=".$wms_id[$k]."','wms','width=500,height=700,scrollbars');newWindow.href.location='test.php'\"></td></tr>";
+ $str .= "\n\t\t<td><input type=button value='details' onclick=\"var newWindow = window.open('../tools/mod_monitorCapabilities_read_single.php?wmsid=".$wms_id[$k]."','wms','width=500,height=700,scrollbars');newWindow.href.location='test.php'\"></td>";
+ $str .= "\n\t\t\t<td>";
+ if ($caps_diff[$k] != "")
+ $str .= "<a href='mod_monitorCapabilities_read_single_diff.php?wmsid=".$wms_id[$k]."&upload_id=".$upload_id[$k]."' target=_blank>view</a>";
+ $str .= "</td></tr>";
$cnt++;
$str .= "\n\t</table>\n\t<br/><input type=hidden name=cbs value='".$cnt."'>\n</form>";
Modified: trunk/mapbender/tools/mod_monitorCapabilities_read_single.php
--- trunk/mapbender/tools/mod_monitorCapabilities_read_single.php 2009-02-20 13:26:21 UTC (rev 3581)
+++ trunk/mapbender/tools/mod_monitorCapabilities_read_single.php 2009-02-23 16:25:37 UTC (rev 3582)
@@ -1,6 +1,5 @@
<?php
-# $Id: mod_monitorCapabilities_read_single.php 76 2006-08-15 12:25:34Z heuser $
+# $Id: mod_monitorCapabilities_read_single.php 3354 2008-12-17 10:31:57Z mschulz $
@@ -18,8 +17,8 @@
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
#require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
+require_once(dirname(__FILE__)."/../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../http/classes/class_administration.php");
session_start();
import_request_variables("PG");
$con = db_connect($DBSERVER,$OWNER,$PW);
@@ -48,7 +47,7 @@
die;
-$sql = "SELECT upload_id, status, status_comment, timestamp_begin, timestamp_end, upload_url, updated FROM mb_monitor ";
+$sql = "SELECT upload_id, status, status_comment, timestamp_begin, timestamp_end, upload_url, updated, caps_diff FROM mb_monitor ";
$sql .= "WHERE fkey_wms_id = $1 AND NOT status = '-2' ORDER BY upload_id DESC";
$v = array($wms_id);
$t = array('i');
@@ -61,7 +60,8 @@
$comment[$cnt] = db_result($res,$cnt,"status_comment");
$timestamp_begin = db_result($res,$cnt,"timestamp_begin");
$timestamp_end = db_result($res,$cnt,"timestamp_end");
- $upload_url[$cnt] = db_result($res,$cnt,"upload_url");
+ $upload_url[$cnt] = db_result($res,$cnt,"upload_url");
+ $caps_diff[$cnt] = db_result($res,$cnt,"caps_diff");
if ($status[$cnt] == '0' || $status[$cnt] == '1') {
$response_time[$cnt] = strval($timestamp_end-$timestamp_begin) . " s";
@@ -75,7 +75,7 @@
$str = "<span style='font-size:30'>monitoring results</span><hr><br>\n";
$str .= "<b>" . $wms_id . "</b><br>" . $admin->getWmsTitleByWmsId($wms_id) . "<br><br><br>\n";
$str .= "<table cellpadding=10 cellspacing=0 border=0>";
-$str .= "<tr bgcolor='#dddddd'><th align='left'>date</th><th align='left' colspan = 2>status</th><th align='center'>response time</th></tr>";
+$str .= "<tr bgcolor='#dddddd'><th align='left'>date</th><th align='left' colspan = 2>status</th><th align='center'>response time</th><th align='center'>Diff</th></tr>";
for ($k=0; $k<count($upload_id); $k++) {
$img = "stop.bmp";
@@ -92,7 +92,10 @@
$str .= "\n\t\t\t<td><a href='".$upload_url[$k]."' target=_blank><img title='Connect to service' border=0 src = '../img/trafficlights/". $img. "'></a></td>";
$str .= "\n\t\t\t<td>" . $comment[$k] . "</td>";
$str .= "\n\t\t\t<td align='center'>" . $response_time[$k] . "</td>";
+ $str .= "<a href='mod_monitorCapabilities_read_single_diff.php?wmsid=".$wms_id."&upload_id=".$upload_id[$k]."' target=_blank>view</a>";
$str .= "\n\t</table>\n\t";
Added: trunk/mapbender/tools/mod_monitorCapabilities_read_single_diff.php
--- trunk/mapbender/tools/mod_monitorCapabilities_read_single_diff.php (rev 0)
+++ trunk/mapbender/tools/mod_monitorCapabilities_read_single_diff.php 2009-02-23 16:25:37 UTC (rev 3582)
@@ -0,0 +1,85 @@
+<?php
+# $Id: mod_monitorCapabilities_read_single_diff.php 3342 2008-12-16 12:31:26Z mschulz $
+# http://www.mapbender.org/index.php/Monitor_Capabilities
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+#require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+import_request_variables("PG");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<title>Mapbender - monitor diff results</title>
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<style type="text/css">
+* {font-family: Arial, "Courier New", monospace; font-size: small;}
+.diff-context {background: #eee;}
+.diff-deletedline {background: #eaa;}
+.diff-addedline {background: #aea;}
+.diff-blockheader {background: #ccc;}
+</style>
+</head>
+<body>
+<?php
+$admin = new administration();
+if ($_GET['wmsid']) {
+ $wms_id = intval($_GET['wmsid']);
+else {
+ echo "Invalid WMS ID.";
+ die;
+if ($_GET['upload_id']) {
+ $upload_id = intval($_GET['upload_id']);
+else {
+ echo "Invalid upload ID.";
+ die;
+$sql = "SELECT caps_diff FROM mb_monitor ";
+$sql .= "WHERE fkey_wms_id = $1 AND upload_id = $2";
+$v = array($wms_id,$upload_id);
+$t = array('i','i');
+$res = db_prep_query($sql,$v,$t);
+while ($row = db_fetch_array($res)) {
+ $caps_diff = db_result($res,0,"caps_diff");
+$str = "<span style='font-size:30'>monitoring results</span><hr><br>\n";
+$str .= "<b>" . $wms_id . "</b><br>" . $admin->getWmsTitleByWmsId($wms_id) . "<br><br><br>\n";
+$str .= "<table cellpadding=3 cellspacing=0 border=0>";
+$str .= "<tr><td align='center' colspan='2'>Local</td><td align='center' colspan='2'>Remote</td></tr>";
+$str .= $caps_diff;
+$str .= "\n\t</table>\n\t";
+echo $str;
+</body></html>
More information about the Mapbender_commits
