[Mapbender-commits] r3587 - in branches/print_dev: http/print resources/db/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Feb 24 11:30:43 EST 2009
Author: mschulz
Date: 2009-02-24 11:30:43 -0500 (Tue, 24 Feb 2009)
New Revision: 3587
   branches/print_dev/http/print/mod_printPDF_div.php
   branches/print_dev/http/print/printFactory.php
   branches/print_dev/http/print/testConfigTemplate.json
   branches/print_dev/resources/db/update/update_gui2_print.sql
added drop-down selection for template configurations
Modified: branches/print_dev/http/print/mod_printPDF_div.php
--- branches/print_dev/http/print/mod_printPDF_div.php	2009-02-24 16:28:58 UTC (rev 3586)
+++ branches/print_dev/http/print/mod_printPDF_div.php	2009-02-24 16:30:43 UTC (rev 3587)
@@ -25,13 +25,43 @@
 echo "var myId = '".$e_id."';";
+/* the array of json print config files */
+try{
+	if (mbPrintConfigFilenames){}
+catch(e){
+	mbPrintConfigFilenames = new Array("testConfigTemplate.json");
+/* the array of json print config titles */
+try{
+	if (mbPrintConfigTitles){}
+catch(e){
+	mbPrintConfigTitles = new Array("Default");
+/* the path where the json print config files reside*/
+try{
+	if (mbPrintConfigPath){}
+catch(e){
+	mbPrintConfigPath = "../print/";
 eventInit.register(function () {
 	mod_printPDF_init();
 function mod_printPDF_init() {
-	/* first we'd need to read the json configuration */
-	$.get("../print/testConfigTemplate.json", function(json, status){
+	/* first we'd need to build the configuration selection */
+	buildConfigSelector();
+	/* second we'd need to read the json configuration */
+	loadConfig(mbPrintConfigFilenames[0]);
+function loadConfig(configFilename) {
+	$.get(mbPrintConfigPath + configFilename, function(json, status){
 	    var obj = eval('(' + json + ')');
 	    buildForm(obj);
 	    hookForm();
@@ -153,11 +183,12 @@
  * @param {Object} json the config object in json
 function buildForm(json) {
+	$(".print_option_dyn").remove();
 	var str = "";
 	for (var item in json.controls) {
 		var element = json.controls[item];
 		var element_id = myId + "_" + element.id;
-		str += '<div class="print_option">\n';
+		str += '<div class="print_option_dyn">\n';
 		str += '<label class="print_label" for="'+element.id+'">'+element.label+'</label>\n';
 		switch (element.type) {
 			case "text":
@@ -180,6 +211,21 @@
 	if (str) $("#"+myId+"_formsubmit").before(str);
+ * Generates the configuration select element from the gui element vars
+ * mbPrintConfigFilenames and mbPrintConfigTitles
+function buildConfigSelector() {
+	var str = "";
+	str += '<label class="print_label" for="printPDF_template">Vorlage</label>\n';
+	str += '<select id="printPDF_template" name="printPDF_template" size="1" onchange="loadConfig(mbPrintConfigFilenames[this.selectedIndex]);">\n';
+	for (var i = 0; i < mbPrintConfigFilenames.length; i++) {
+		str += '<option value="'+mbPrintConfigFilenames[i]+'">'+mbPrintConfigTitles[i]+'</option>\n';
+	str += '</select><br />\n';
+	if (str) $("#printPDF_selector").append(str);
 function stripslashes( str ) {
     return (str+'').replace(/\0/g, '0').replace(/\\([\\'"])/g, '$1');
\ No newline at end of file
Modified: branches/print_dev/http/print/printFactory.php
--- branches/print_dev/http/print/printFactory.php	2009-02-24 16:28:58 UTC (rev 3586)
+++ branches/print_dev/http/print/printFactory.php	2009-02-24 16:30:43 UTC (rev 3587)
@@ -3,7 +3,7 @@
 require_once(dirname(__FILE__)."/classes/factoryClasses.php");
 $pf = new mbPdfFactory();
-$pdf = $pf->create('testConfigTemplate.json');
+$pdf = $pf->create($_REQUEST["printPDF_template"]);
 $pdf->render();
 $pdf->save();
Modified: branches/print_dev/http/print/testConfigTemplate.json
--- branches/print_dev/http/print/testConfigTemplate.json	2009-02-24 16:28:58 UTC (rev 3586)
+++ branches/print_dev/http/print/testConfigTemplate.json	2009-02-24 16:30:43 UTC (rev 3587)
@@ -58,7 +58,22 @@
     			"height" : 185
 	   		"messung" : {
-    			"type" : "measure"
+    			"type" : "measure",
+    			"do_fill" : 0,
+    			"fill_color" : {
+    				"r" : 255,
+    				"g" : 0,
+    				"b" : 0
+    			"do_stroke" : 0,
+    			"stroke_color" : {
+    				"r" : 0,
+    				"g" : 0,
+    				"b" : 0
+    			"line_style" : {
+    				"width" : 1.0
 	   		"minikarte" : {
     			"type" : "overview",
Modified: branches/print_dev/resources/db/update/update_gui2_print.sql
--- branches/print_dev/resources/db/update/update_gui2_print.sql	2009-02-24 16:28:58 UTC (rev 3586)
+++ branches/print_dev/resources/db/update/update_gui2_print.sql	2009-02-24 16:30:43 UTC (rev 3587)
@@ -8,6 +8,7 @@
 </div>
 <div id="printPDF_input">
 <form id="printPDF_form" action="../print/printFactory.php">
+<div id="printPDF_selector"></div>
 <input type="hidden" id="map_url" name="map_url" value=""/>
 <input type="hidden" id="overview_url" name="overview_url" value=""/>
More information about the Mapbender_commits mailing list
