[Mapbender-commits] r4913 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Nov 3 11:23:05 EST 2009
Author: christoph
Date: 2009-11-03 11:23:04 -0500 (Tue, 03 Nov 2009)
New Revision: 4913
   trunk/mapbender/http/classes/class_wmc.php
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php	2009-11-03 16:22:35 UTC (rev 4912)
+++ trunk/mapbender/http/classes/class_wmc.php	2009-11-03 16:23:04 UTC (rev 4913)
@@ -224,7 +224,96 @@
 	// DATABASE FUNCTIONS
+	public function selectByUser ($user) {
+		$wmcArray = array();
+		// get WMC ids
+		$wmcIdArray = $user->getWmcByOwner();
+		// get WMC data
+		$v = array();
+		$t = array();
+		$wmcIdList = "";
+		for ($i = 0; $i < count($wmcIdArray); $i++) {
+			if ($i > 0) {
+				$wmcIdList .= ",";
+			$wmcIdList .= "$".($i+1);
+			array_push($v, $wmcIdArray[$i]);
+			array_push($t, 's');
+		if ($wmcIdList !== "") {
+			$sql = "SELECT DISTINCT wmc_id, wmc_title, wmc_timestamp FROM mb_user_wmc ";
+			$sql .= "WHERE wmc_id IN (" . $wmcIdList . ") ";
+			$sql .=	"ORDER BY wmc_timestamp DESC";
+			$res = db_prep_query($sql, $v, $t);
+			while($row = db_fetch_array($res)){
+				$currentResult = array();
+				$currentResult["id"] = $row["wmc_id"];
+				$currentResult["title"] = administration::convertIncomingString($row["wmc_title"]);
+				$currentResult["timestamp"] = date("M d Y H:i:s", $row["wmc_timestamp"]);
+				array_push($wmcArray, $currentResult);
+		return $wmcArray;
+	public function updateUrlsFromDb () {
+		$query_mbWMSId = "/wmc:ViewContext/wmc:LayerList/wmc:Layer/wmc:Extension/mapbender:wms_id";
+		try {
+			$WMCDoc = DOMDocument::loadXML($this->toXml());
+		catch (Exception $E) {
+			new mb_exception("WMC XML is broken.");
+		$xpath = new DOMXPath($WMCDoc);
+		$xpath->registerNamespace("wmc","http://www.opengis.net/context");
+		$xpath->registerNamespace("mapbender","http://www.mapbender.org/context");
+		$xpath->registerNamespace("xlink","http://www.w3.org/1999/xlink");
+		$WMSIdList = $xpath->query($query_mbWMSId);
+		foreach($WMSIdList as $WMSId) {
+			$id =  $WMSId->nodeValue;
+			$sql = "SELECT wms_timestamp,wms_getmap,wms_getlegendurl FROM wms WHERE wms_id = $1";
+			$v = array($id);
+			$t = array("t");
+			$res = db_prep_query($sql,$v,$t);
+			if (db_error()) {
+				true;
+			} //FIMXE: PROPER ERROR MESSAGE
+			if($row = db_fetch_row($res)) {
+				$wms_timestamp = $row[0];
+				if ($this->timestamp < $wms_timestamp) {
+				// wmc is fresh, life is good
+				else{
+					$MapResources = $xpath->query("../../wmc:Server/wmc:OnlineResource",$WMSId);
+					foreach($MapResources as $MapResource) {
+						$MapResource->setAttribute("xlink:href",$row[1]);
+					$LegendResources = $xpath->query("../../wmc:StyleList/wmc:Style/wmc:LegendURL/wmc:OnlineResource",$WMSId);
+					foreach ($LegendResources as $LegendResource) {
+						$base = $row[2];
+						$origurl = explode('&', $LegendResource->getAttribute("xlink:href"),2);
+						$url = $base . $origurl[1];
+						$LegendResource->setAttribute("xlink:href",$url);
+		$updatedWMC = $WMCDoc->saveXML();
+		$this->update_existing($updatedWMC,$wmsId);
+		return $updatedWMC;
 	 * Stores this WMC in the database. The WMC has to be instantiated first, see above.
More information about the Mapbender_commits mailing list
