[Mapbender-commits] r4914 - in trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom: css css/dot-luv css/dot-luv/images development-bundle/ui
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Nov 4 05:29:32 EST 2009
Author: christoph
Date: 2009-11-04 05:29:29 -0500 (Wed, 04 Nov 2009)
New Revision: 4914
Added:
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_diagonals-thick_15_0b3e6f_40x40.png
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_dots-medium_30_0b58a2_4x4.png
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_dots-small_20_333333_2x2.png
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_dots-small_30_a32d00_2x2.png
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_dots-small_40_00498f_2x2.png
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_flat_0_aaaaaa_40x100.png
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_flat_40_292929_40x100.png
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_gloss-wave_20_111111_500x100.png
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-icons_00498f_256x240.png
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-icons_98d2fb_256x240.png
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-icons_9ccdfc_256x240.png
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-icons_ffffff_256x240.png
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/jquery-ui-1.7.2.custom.css
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.blind.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.bounce.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.clip.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.core.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.drop.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.explode.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.fold.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.highlight.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.pulsate.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.scale.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.shake.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.slide.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.transfer.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.jquery-ui-1.7.2.custom.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.accordion.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.core.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.datepicker.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.dialog.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.draggable.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.droppable.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.progressbar.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.resizable.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.selectable.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.slider.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.sortable.js
   trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.tabs.js
another ui theme
minified js
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_diagonals-thick_15_0b3e6f_40x40.png
(Binary files differ)
Property changes on: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_diagonals-thick_15_0b3e6f_40x40.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_dots-medium_30_0b58a2_4x4.png
Property changes on: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_dots-medium_30_0b58a2_4x4.png
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_dots-small_20_333333_2x2.png
Property changes on: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_dots-small_20_333333_2x2.png
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_dots-small_30_a32d00_2x2.png
Property changes on: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_dots-small_30_a32d00_2x2.png
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_dots-small_40_00498f_2x2.png
Property changes on: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_dots-small_40_00498f_2x2.png
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_flat_0_aaaaaa_40x100.png
Property changes on: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_flat_0_aaaaaa_40x100.png
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_flat_40_292929_40x100.png
Property changes on: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_flat_40_292929_40x100.png
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_gloss-wave_20_111111_500x100.png
Property changes on: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-bg_gloss-wave_20_111111_500x100.png
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-icons_00498f_256x240.png
Property changes on: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-icons_00498f_256x240.png
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-icons_98d2fb_256x240.png
Property changes on: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-icons_98d2fb_256x240.png
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-icons_9ccdfc_256x240.png
Property changes on: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-icons_9ccdfc_256x240.png
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-icons_ffffff_256x240.png
Property changes on: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/images/ui-icons_ffffff_256x240.png
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/jquery-ui-1.7.2.custom.css
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/jquery-ui-1.7.2.custom.css	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/css/dot-luv/jquery-ui-1.7.2.custom.css	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,406 @@
+* jQuery UI CSS Framework
+* Copyright (c) 2009 AUTHORS.txt (http://jqueryui.com/about)
+* Dual licensed under the MIT (MIT-LICENSE.txt) and GPL (GPL-LICENSE.txt) licenses.
+/* Layout helpers
+.ui-helper-hidden { display: none; }
+.ui-helper-hidden-accessible { position: absolute; left: -99999999px; }
+.ui-helper-reset { margin: 0; padding: 0; border: 0; outline: 0; line-height: 1.3; text-decoration: none; font-size: 100%; list-style: none; }
+.ui-helper-clearfix:after { content: "."; display: block; height: 0; clear: both; visibility: hidden; }
+.ui-helper-clearfix { display: inline-block; }
+/* required comment for clearfix to work in Opera \*/
+* html .ui-helper-clearfix { height:1%; }
+.ui-helper-clearfix { display:block; }
+/* end clearfix */
+.ui-helper-zfix { width: 100%; height: 100%; top: 0; left: 0; position: absolute; opacity: 0; filter:Alpha(Opacity=0); }
+/* Interaction Cues
+.ui-state-disabled { cursor: default !important; }
+/* Icons
+/* states and images */
+.ui-icon { display: block; text-indent: -99999px; overflow: hidden; background-repeat: no-repeat; }
+/* Misc visuals
+/* Overlays */
+.ui-widget-overlay { position: absolute; top: 0; left: 0; width: 100%; height: 100%; }
+* To view and modify this theme, visit http://jqueryui.com/themeroller/?ffDefault=Arial,%20sans-serif&fwDefault=bold&fsDefault=1.3em&cornerRadius=4px&bgColorHeader=0b3e6f&bgTextureHeader=08_diagonals_thick.png&bgImgOpacityHeader=15&borderColorHeader=0b3e6f&fcHeader=f6f6f6&iconColorHeader=98d2fb&bgColorContent=111111&bgTextureContent=12_gloss_wave.png&bgImgOpacityContent=20&borderColorContent=000000&fcContent=d9d9d9&iconColorContent=9ccdfc&bgColorDefault=333333&bgTextureDefault=09_dots_small.png&bgImgOpacityDefault=20&borderColorDefault=333333&fcDefault=ffffff&iconColorDefault=9ccdfc&bgColorHover=00498f&bgTextureHover=09_dots_small.png&bgImgOpacityHover=40&borderColorHover=222222&fcHover=ffffff&iconColorHover=ffffff&bgColorActive=292929&bgTextureActive=01_flat.png&bgImgOpacityActive=40&borderColorActive=096ac8&fcActive=75abff&iconColorActive=00498f&bgColorHighlight=0b58a2&bgTextureHighlight=10_dots_medium.png&bgImgOpacityHighlight=30&borderColorHighlight=052f57&fcHighlight=ffffff&iconColorHighlight=ffffff&bgColorError=a32d00&bgTextureError=09_dots_small.png&bgImgOpacityError=30&borderColorError=cd0a0a&fcError=ffffff&iconColorError=ffffff&bgColorOverlay=aaaaaa&bgTextureOverlay=01_flat.png&bgImgOpacityOverlay=0&opacityOverlay=30&bgColorShadow=aaaaaa&bgTextureShadow=01_flat.png&bgImgOpacityShadow=0&opacityShadow=30&thicknessShadow=8px&offsetTopShadow=-8px&offsetLeftShadow=-8px&cornerRadiusShadow=8px
+/* Component containers
+.ui-widget { font-family: Arial, sans-serif; font-size: 1.3em; }
+.ui-widget input, .ui-widget select, .ui-widget textarea, .ui-widget button { font-family: Arial, sans-serif; font-size: 1em; }
+.ui-widget-content { border: 1px solid #000000; background: #111111 url(images/ui-bg_gloss-wave_20_111111_500x100.png) 50% top repeat-x; color: #d9d9d9; }
+.ui-widget-content a { color: #d9d9d9; }
+.ui-widget-header { border: 1px solid #0b3e6f; background: #0b3e6f url(images/ui-bg_diagonals-thick_15_0b3e6f_40x40.png) 50% 50% repeat; color: #f6f6f6; font-weight: bold; }
+.ui-widget-header a { color: #f6f6f6; }
+/* Interaction states
+.ui-state-default, .ui-widget-content .ui-state-default { border: 1px solid #333333; background: #333333 url(images/ui-bg_dots-small_20_333333_2x2.png) 50% 50% repeat; font-weight: bold; color: #ffffff; outline: none; }
+.ui-state-default a, .ui-state-default a:link, .ui-state-default a:visited { color: #ffffff; text-decoration: none; outline: none; }
+.ui-state-hover, .ui-widget-content .ui-state-hover, .ui-state-focus, .ui-widget-content .ui-state-focus { border: 1px solid #222222; background: #00498f url(images/ui-bg_dots-small_40_00498f_2x2.png) 50% 50% repeat; font-weight: bold; color: #ffffff; outline: none; }
+.ui-state-hover a, .ui-state-hover a:hover { color: #ffffff; text-decoration: none; outline: none; }
+.ui-state-active, .ui-widget-content .ui-state-active { border: 1px solid #096ac8; background: #292929 url(images/ui-bg_flat_40_292929_40x100.png) 50% 50% repeat-x; font-weight: bold; color: #75abff; outline: none; }
+.ui-state-active a, .ui-state-active a:link, .ui-state-active a:visited { color: #75abff; outline: none; text-decoration: none; }
+.ui-state-highlight, .ui-widget-content .ui-state-highlight {border: 1px solid #052f57; background: #0b58a2 url(images/ui-bg_dots-medium_30_0b58a2_4x4.png) 50% 50% repeat; color: #ffffff; }
+.ui-state-highlight a, .ui-widget-content .ui-state-highlight a { color: #ffffff; }
+.ui-state-error, .ui-widget-content .ui-state-error {border: 1px solid #cd0a0a; background: #a32d00 url(images/ui-bg_dots-small_30_a32d00_2x2.png) 50% 50% repeat; color: #ffffff; }
+.ui-state-error a, .ui-widget-content .ui-state-error a { color: #ffffff; }
+.ui-state-error-text, .ui-widget-content .ui-state-error-text { color: #ffffff; }
+.ui-state-disabled, .ui-widget-content .ui-state-disabled { opacity: .35; filter:Alpha(Opacity=35); background-image: none; }
+.ui-priority-primary, .ui-widget-content .ui-priority-primary { font-weight: bold; }
+.ui-priority-secondary, .ui-widget-content .ui-priority-secondary { opacity: .7; filter:Alpha(Opacity=70); font-weight: normal; }
+/* Icons
+.ui-icon { width: 16px; height: 16px; background-image: url(images/ui-icons_9ccdfc_256x240.png); }
+.ui-widget-content .ui-icon {background-image: url(images/ui-icons_9ccdfc_256x240.png); }
+.ui-widget-header .ui-icon {background-image: url(images/ui-icons_98d2fb_256x240.png); }
+.ui-state-default .ui-icon { background-image: url(images/ui-icons_9ccdfc_256x240.png); }
+.ui-state-hover .ui-icon, .ui-state-focus .ui-icon {background-image: url(images/ui-icons_ffffff_256x240.png); }
+.ui-state-active .ui-icon {background-image: url(images/ui-icons_00498f_256x240.png); }
+.ui-state-highlight .ui-icon {background-image: url(images/ui-icons_ffffff_256x240.png); }
+.ui-state-error .ui-icon, .ui-state-error-text .ui-icon {background-image: url(images/ui-icons_ffffff_256x240.png); }
+/* positioning */
+.ui-icon-carat-1-n { background-position: 0 0; }
+.ui-icon-carat-1-ne { background-position: -16px 0; }
+.ui-icon-carat-1-e { background-position: -32px 0; }
+.ui-icon-carat-1-se { background-position: -48px 0; }
+.ui-icon-carat-1-s { background-position: -64px 0; }
+.ui-icon-carat-1-sw { background-position: -80px 0; }
+.ui-icon-carat-1-w { background-position: -96px 0; }
+.ui-icon-carat-1-nw { background-position: -112px 0; }
+.ui-icon-carat-2-n-s { background-position: -128px 0; }
+.ui-icon-carat-2-e-w { background-position: -144px 0; }
+.ui-icon-triangle-1-n { background-position: 0 -16px; }
+.ui-icon-triangle-1-ne { background-position: -16px -16px; }
+.ui-icon-triangle-1-e { background-position: -32px -16px; }
+.ui-icon-triangle-1-se { background-position: -48px -16px; }
+.ui-icon-triangle-1-s { background-position: -64px -16px; }
+.ui-icon-triangle-1-sw { background-position: -80px -16px; }
+.ui-icon-triangle-1-w { background-position: -96px -16px; }
+.ui-icon-triangle-1-nw { background-position: -112px -16px; }
+.ui-icon-triangle-2-n-s { background-position: -128px -16px; }
+.ui-icon-triangle-2-e-w { background-position: -144px -16px; }
+.ui-icon-arrow-1-n { background-position: 0 -32px; }
+.ui-icon-arrow-1-ne { background-position: -16px -32px; }
+.ui-icon-arrow-1-e { background-position: -32px -32px; }
+.ui-icon-arrow-1-se { background-position: -48px -32px; }
+.ui-icon-arrow-1-s { background-position: -64px -32px; }
+.ui-icon-arrow-1-sw { background-position: -80px -32px; }
+.ui-icon-arrow-1-w { background-position: -96px -32px; }
+.ui-icon-arrow-1-nw { background-position: -112px -32px; }
+.ui-icon-arrow-2-n-s { background-position: -128px -32px; }
+.ui-icon-arrow-2-ne-sw { background-position: -144px -32px; }
+.ui-icon-arrow-2-e-w { background-position: -160px -32px; }
+.ui-icon-arrow-2-se-nw { background-position: -176px -32px; }
+.ui-icon-arrowstop-1-n { background-position: -192px -32px; }
+.ui-icon-arrowstop-1-e { background-position: -208px -32px; }
+.ui-icon-arrowstop-1-s { background-position: -224px -32px; }
+.ui-icon-arrowstop-1-w { background-position: -240px -32px; }
+.ui-icon-arrowthick-1-n { background-position: 0 -48px; }
+.ui-icon-arrowthick-1-ne { background-position: -16px -48px; }
+.ui-icon-arrowthick-1-e { background-position: -32px -48px; }
+.ui-icon-arrowthick-1-se { background-position: -48px -48px; }
+.ui-icon-arrowthick-1-s { background-position: -64px -48px; }
+.ui-icon-arrowthick-1-sw { background-position: -80px -48px; }
+.ui-icon-arrowthick-1-w { background-position: -96px -48px; }
+.ui-icon-arrowthick-1-nw { background-position: -112px -48px; }
+.ui-icon-arrowthick-2-n-s { background-position: -128px -48px; }
+.ui-icon-arrowthick-2-ne-sw { background-position: -144px -48px; }
+.ui-icon-arrowthick-2-e-w { background-position: -160px -48px; }
+.ui-icon-arrowthick-2-se-nw { background-position: -176px -48px; }
+.ui-icon-arrowthickstop-1-n { background-position: -192px -48px; }
+.ui-icon-arrowthickstop-1-e { background-position: -208px -48px; }
+.ui-icon-arrowthickstop-1-s { background-position: -224px -48px; }
+.ui-icon-arrowthickstop-1-w { background-position: -240px -48px; }
+.ui-icon-arrowreturnthick-1-w { background-position: 0 -64px; }
+.ui-icon-arrowreturnthick-1-n { background-position: -16px -64px; }
+.ui-icon-arrowreturnthick-1-e { background-position: -32px -64px; }
+.ui-icon-arrowreturnthick-1-s { background-position: -48px -64px; }
+.ui-icon-arrowreturn-1-w { background-position: -64px -64px; }
+.ui-icon-arrowreturn-1-n { background-position: -80px -64px; }
+.ui-icon-arrowreturn-1-e { background-position: -96px -64px; }
+.ui-icon-arrowreturn-1-s { background-position: -112px -64px; }
+.ui-icon-arrowrefresh-1-w { background-position: -128px -64px; }
+.ui-icon-arrowrefresh-1-n { background-position: -144px -64px; }
+.ui-icon-arrowrefresh-1-e { background-position: -160px -64px; }
+.ui-icon-arrowrefresh-1-s { background-position: -176px -64px; }
+.ui-icon-arrow-4 { background-position: 0 -80px; }
+.ui-icon-arrow-4-diag { background-position: -16px -80px; }
+.ui-icon-extlink { background-position: -32px -80px; }
+.ui-icon-newwin { background-position: -48px -80px; }
+.ui-icon-refresh { background-position: -64px -80px; }
+.ui-icon-shuffle { background-position: -80px -80px; }
+.ui-icon-transfer-e-w { background-position: -96px -80px; }
+.ui-icon-transferthick-e-w { background-position: -112px -80px; }
+.ui-icon-folder-collapsed { background-position: 0 -96px; }
+.ui-icon-folder-open { background-position: -16px -96px; }
+.ui-icon-document { background-position: -32px -96px; }
+.ui-icon-document-b { background-position: -48px -96px; }
+.ui-icon-note { background-position: -64px -96px; }
+.ui-icon-mail-closed { background-position: -80px -96px; }
+.ui-icon-mail-open { background-position: -96px -96px; }
+.ui-icon-suitcase { background-position: -112px -96px; }
+.ui-icon-comment { background-position: -128px -96px; }
+.ui-icon-person { background-position: -144px -96px; }
+.ui-icon-print { background-position: -160px -96px; }
+.ui-icon-trash { background-position: -176px -96px; }
+.ui-icon-locked { background-position: -192px -96px; }
+.ui-icon-unlocked { background-position: -208px -96px; }
+.ui-icon-bookmark { background-position: -224px -96px; }
+.ui-icon-tag { background-position: -240px -96px; }
+.ui-icon-home { background-position: 0 -112px; }
+.ui-icon-flag { background-position: -16px -112px; }
+.ui-icon-calendar { background-position: -32px -112px; }
+.ui-icon-cart { background-position: -48px -112px; }
+.ui-icon-pencil { background-position: -64px -112px; }
+.ui-icon-clock { background-position: -80px -112px; }
+.ui-icon-disk { background-position: -96px -112px; }
+.ui-icon-calculator { background-position: -112px -112px; }
+.ui-icon-zoomin { background-position: -128px -112px; }
+.ui-icon-zoomout { background-position: -144px -112px; }
+.ui-icon-search { background-position: -160px -112px; }
+.ui-icon-wrench { background-position: -176px -112px; }
+.ui-icon-gear { background-position: -192px -112px; }
+.ui-icon-heart { background-position: -208px -112px; }
+.ui-icon-star { background-position: -224px -112px; }
+.ui-icon-link { background-position: -240px -112px; }
+.ui-icon-cancel { background-position: 0 -128px; }
+.ui-icon-plus { background-position: -16px -128px; }
+.ui-icon-plusthick { background-position: -32px -128px; }
+.ui-icon-minus { background-position: -48px -128px; }
+.ui-icon-minusthick { background-position: -64px -128px; }
+.ui-icon-close { background-position: -80px -128px; }
+.ui-icon-closethick { background-position: -96px -128px; }
+.ui-icon-key { background-position: -112px -128px; }
+.ui-icon-lightbulb { background-position: -128px -128px; }
+.ui-icon-scissors { background-position: -144px -128px; }
+.ui-icon-clipboard { background-position: -160px -128px; }
+.ui-icon-copy { background-position: -176px -128px; }
+.ui-icon-contact { background-position: -192px -128px; }
+.ui-icon-image { background-position: -208px -128px; }
+.ui-icon-video { background-position: -224px -128px; }
+.ui-icon-script { background-position: -240px -128px; }
+.ui-icon-alert { background-position: 0 -144px; }
+.ui-icon-info { background-position: -16px -144px; }
+.ui-icon-notice { background-position: -32px -144px; }
+.ui-icon-help { background-position: -48px -144px; }
+.ui-icon-check { background-position: -64px -144px; }
+.ui-icon-bullet { background-position: -80px -144px; }
+.ui-icon-radio-off { background-position: -96px -144px; }
+.ui-icon-radio-on { background-position: -112px -144px; }
+.ui-icon-pin-w { background-position: -128px -144px; }
+.ui-icon-pin-s { background-position: -144px -144px; }
+.ui-icon-play { background-position: 0 -160px; }
+.ui-icon-pause { background-position: -16px -160px; }
+.ui-icon-seek-next { background-position: -32px -160px; }
+.ui-icon-seek-prev { background-position: -48px -160px; }
+.ui-icon-seek-end { background-position: -64px -160px; }
+.ui-icon-seek-first { background-position: -80px -160px; }
+.ui-icon-stop { background-position: -96px -160px; }
+.ui-icon-eject { background-position: -112px -160px; }
+.ui-icon-volume-off { background-position: -128px -160px; }
+.ui-icon-volume-on { background-position: -144px -160px; }
+.ui-icon-power { background-position: 0 -176px; }
+.ui-icon-signal-diag { background-position: -16px -176px; }
+.ui-icon-signal { background-position: -32px -176px; }
+.ui-icon-battery-0 { background-position: -48px -176px; }
+.ui-icon-battery-1 { background-position: -64px -176px; }
+.ui-icon-battery-2 { background-position: -80px -176px; }
+.ui-icon-battery-3 { background-position: -96px -176px; }
+.ui-icon-circle-plus { background-position: 0 -192px; }
+.ui-icon-circle-minus { background-position: -16px -192px; }
+.ui-icon-circle-close { background-position: -32px -192px; }
+.ui-icon-circle-triangle-e { background-position: -48px -192px; }
+.ui-icon-circle-triangle-s { background-position: -64px -192px; }
+.ui-icon-circle-triangle-w { background-position: -80px -192px; }
+.ui-icon-circle-triangle-n { background-position: -96px -192px; }
+.ui-icon-circle-arrow-e { background-position: -112px -192px; }
+.ui-icon-circle-arrow-s { background-position: -128px -192px; }
+.ui-icon-circle-arrow-w { background-position: -144px -192px; }
+.ui-icon-circle-arrow-n { background-position: -160px -192px; }
+.ui-icon-circle-zoomin { background-position: -176px -192px; }
+.ui-icon-circle-zoomout { background-position: -192px -192px; }
+.ui-icon-circle-check { background-position: -208px -192px; }
+.ui-icon-circlesmall-plus { background-position: 0 -208px; }
+.ui-icon-circlesmall-minus { background-position: -16px -208px; }
+.ui-icon-circlesmall-close { background-position: -32px -208px; }
+.ui-icon-squaresmall-plus { background-position: -48px -208px; }
+.ui-icon-squaresmall-minus { background-position: -64px -208px; }
+.ui-icon-squaresmall-close { background-position: -80px -208px; }
+.ui-icon-grip-dotted-vertical { background-position: 0 -224px; }
+.ui-icon-grip-dotted-horizontal { background-position: -16px -224px; }
+.ui-icon-grip-solid-vertical { background-position: -32px -224px; }
+.ui-icon-grip-solid-horizontal { background-position: -48px -224px; }
+.ui-icon-gripsmall-diagonal-se { background-position: -64px -224px; }
+.ui-icon-grip-diagonal-se { background-position: -80px -224px; }
+/* Misc visuals
+/* Corner radius */
+.ui-corner-tl { -moz-border-radius-topleft: 4px; -webkit-border-top-left-radius: 4px; }
+.ui-corner-tr { -moz-border-radius-topright: 4px; -webkit-border-top-right-radius: 4px; }
+.ui-corner-bl { -moz-border-radius-bottomleft: 4px; -webkit-border-bottom-left-radius: 4px; }
+.ui-corner-br { -moz-border-radius-bottomright: 4px; -webkit-border-bottom-right-radius: 4px; }
+.ui-corner-top { -moz-border-radius-topleft: 4px; -webkit-border-top-left-radius: 4px; -moz-border-radius-topright: 4px; -webkit-border-top-right-radius: 4px; }
+.ui-corner-bottom { -moz-border-radius-bottomleft: 4px; -webkit-border-bottom-left-radius: 4px; -moz-border-radius-bottomright: 4px; -webkit-border-bottom-right-radius: 4px; }
+.ui-corner-right {  -moz-border-radius-topright: 4px; -webkit-border-top-right-radius: 4px; -moz-border-radius-bottomright: 4px; -webkit-border-bottom-right-radius: 4px; }
+.ui-corner-left { -moz-border-radius-topleft: 4px; -webkit-border-top-left-radius: 4px; -moz-border-radius-bottomleft: 4px; -webkit-border-bottom-left-radius: 4px; }
+.ui-corner-all { -moz-border-radius: 4px; -webkit-border-radius: 4px; }
+/* Overlays */
+.ui-widget-overlay { background: #aaaaaa url(images/ui-bg_flat_0_aaaaaa_40x100.png) 50% 50% repeat-x; opacity: .30;filter:Alpha(Opacity=30); }
+.ui-widget-shadow { margin: -8px 0 0 -8px; padding: 8px; background: #aaaaaa url(images/ui-bg_flat_0_aaaaaa_40x100.png) 50% 50% repeat-x; opacity: .30;filter:Alpha(Opacity=30); -moz-border-radius: 8px; -webkit-border-radius: 8px; }/* Accordion
+.ui-accordion .ui-accordion-header { cursor: pointer; position: relative; margin-top: 1px; zoom: 1; }
+.ui-accordion .ui-accordion-li-fix { display: inline; }
+.ui-accordion .ui-accordion-header-active { border-bottom: 0 !important; }
+.ui-accordion .ui-accordion-header a { display: block; font-size: 1em; padding: .5em .5em .5em 2.2em; }
+.ui-accordion .ui-accordion-header .ui-icon { position: absolute; left: .5em; top: 50%; margin-top: -8px; }
+.ui-accordion .ui-accordion-content { padding: 1em 2.2em; border-top: 0; margin-top: -2px; position: relative; top: 1px; margin-bottom: 2px; overflow: auto; display: none; }
+.ui-accordion .ui-accordion-content-active { display: block; }/* Datepicker
+.ui-datepicker { width: 17em; padding: .2em .2em 0; }
+.ui-datepicker .ui-datepicker-header { position:relative; padding:.2em 0; }
+.ui-datepicker .ui-datepicker-prev, .ui-datepicker .ui-datepicker-next { position:absolute; top: 2px; width: 1.8em; height: 1.8em; }
+.ui-datepicker .ui-datepicker-prev-hover, .ui-datepicker .ui-datepicker-next-hover { top: 1px; }
+.ui-datepicker .ui-datepicker-prev { left:2px; }
+.ui-datepicker .ui-datepicker-next { right:2px; }
+.ui-datepicker .ui-datepicker-prev-hover { left:1px; }
+.ui-datepicker .ui-datepicker-next-hover { right:1px; }
+.ui-datepicker .ui-datepicker-prev span, .ui-datepicker .ui-datepicker-next span { display: block; position: absolute; left: 50%; margin-left: -8px; top: 50%; margin-top: -8px;  }
+.ui-datepicker .ui-datepicker-title { margin: 0 2.3em; line-height: 1.8em; text-align: center; }
+.ui-datepicker .ui-datepicker-title select { float:left; font-size:1em; margin:1px 0; }
+.ui-datepicker select.ui-datepicker-month-year {width: 100%;}
+.ui-datepicker select.ui-datepicker-month,
+.ui-datepicker select.ui-datepicker-year { width: 49%;}
+.ui-datepicker .ui-datepicker-title select.ui-datepicker-year { float: right; }
+.ui-datepicker table {width: 100%; font-size: .9em; border-collapse: collapse; margin:0 0 .4em; }
+.ui-datepicker th { padding: .7em .3em; text-align: center; font-weight: bold; border: 0;  }
+.ui-datepicker td { border: 0; padding: 1px; }
+.ui-datepicker td span, .ui-datepicker td a { display: block; padding: .2em; text-align: right; text-decoration: none; }
+.ui-datepicker .ui-datepicker-buttonpane { background-image: none; margin: .7em 0 0 0; padding:0 .2em; border-left: 0; border-right: 0; border-bottom: 0; }
+.ui-datepicker .ui-datepicker-buttonpane button { float: right; margin: .5em .2em .4em; cursor: pointer; padding: .2em .6em .3em .6em; width:auto; overflow:visible; }
+.ui-datepicker .ui-datepicker-buttonpane button.ui-datepicker-current { float:left; }
+/* with multiple calendars */
+.ui-datepicker.ui-datepicker-multi { width:auto; }
+.ui-datepicker-multi .ui-datepicker-group { float:left; }
+.ui-datepicker-multi .ui-datepicker-group table { width:95%; margin:0 auto .4em; }
+.ui-datepicker-multi-2 .ui-datepicker-group { width:50%; }
+.ui-datepicker-multi-3 .ui-datepicker-group { width:33.3%; }
+.ui-datepicker-multi-4 .ui-datepicker-group { width:25%; }
+.ui-datepicker-multi .ui-datepicker-group-last .ui-datepicker-header { border-left-width:0; }
+.ui-datepicker-multi .ui-datepicker-group-middle .ui-datepicker-header { border-left-width:0; }
+.ui-datepicker-multi .ui-datepicker-buttonpane { clear:left; }
+.ui-datepicker-row-break { clear:both; width:100%; }
+/* RTL support */
+.ui-datepicker-rtl { direction: rtl; }
+.ui-datepicker-rtl .ui-datepicker-prev { right: 2px; left: auto; }
+.ui-datepicker-rtl .ui-datepicker-next { left: 2px; right: auto; }
+.ui-datepicker-rtl .ui-datepicker-prev:hover { right: 1px; left: auto; }
+.ui-datepicker-rtl .ui-datepicker-next:hover { left: 1px; right: auto; }
+.ui-datepicker-rtl .ui-datepicker-buttonpane { clear:right; }
+.ui-datepicker-rtl .ui-datepicker-buttonpane button { float: left; }
+.ui-datepicker-rtl .ui-datepicker-buttonpane button.ui-datepicker-current { float:right; }
+.ui-datepicker-rtl .ui-datepicker-group { float:right; }
+.ui-datepicker-rtl .ui-datepicker-group-last .ui-datepicker-header { border-right-width:0; border-left-width:1px; }
+.ui-datepicker-rtl .ui-datepicker-group-middle .ui-datepicker-header { border-right-width:0; border-left-width:1px; }
+/* IE6 IFRAME FIX (taken from datepicker 1.5.3 */
+.ui-datepicker-cover {
+    display: none; /*sorry for IE5*/
+    display/**/: block; /*sorry for IE5*/
+    position: absolute; /*must have*/
+    z-index: -1; /*must have*/
+    filter: mask(); /*must have*/
+    top: -4px; /*must have*/
+    left: -4px; /*must have*/
+    width: 200px; /*must have*/
+    height: 200px; /*must have*/
+}/* Dialog
+.ui-dialog { position: relative; padding: .2em; width: 300px; }
+.ui-dialog .ui-dialog-titlebar { padding: .5em .3em .3em 1em; position: relative;  }
+.ui-dialog .ui-dialog-title { float: left; margin: .1em 0 .2em; }
+.ui-dialog .ui-dialog-titlebar-close { position: absolute; right: .3em; top: 50%; width: 19px; margin: -10px 0 0 0; padding: 1px; height: 18px; }
+.ui-dialog .ui-dialog-titlebar-close span { display: block; margin: 1px; }
+.ui-dialog .ui-dialog-titlebar-close:hover, .ui-dialog .ui-dialog-titlebar-close:focus { padding: 0; }
+.ui-dialog .ui-dialog-content { border: 0; padding: .5em 1em; background: none; overflow: auto; zoom: 1; }
+.ui-dialog .ui-dialog-buttonpane { text-align: left; border-width: 1px 0 0 0; background-image: none; margin: .5em 0 0 0; padding: .3em 1em .5em .4em; }
+.ui-dialog .ui-dialog-buttonpane button { float: right; margin: .5em .4em .5em 0; cursor: pointer; padding: .2em .6em .3em .6em; line-height: 1.4em; width:auto; overflow:visible; }
+.ui-dialog .ui-resizable-se { width: 14px; height: 14px; right: 3px; bottom: 3px; }
+.ui-draggable .ui-dialog-titlebar { cursor: move; }
+/* Progressbar
+.ui-progressbar { height:2em; text-align: left; }
+.ui-progressbar .ui-progressbar-value {margin: -1px; height:100%; }/* Resizable
+.ui-resizable { position: relative;}
+.ui-resizable-handle { position: absolute;font-size: 0.1px;z-index: 99999; display: block;}
+.ui-resizable-disabled .ui-resizable-handle, .ui-resizable-autohide .ui-resizable-handle { display: none; }
+.ui-resizable-n { cursor: n-resize; height: 7px; width: 100%; top: -5px; left: 0px; }
+.ui-resizable-s { cursor: s-resize; height: 7px; width: 100%; bottom: -5px; left: 0px; }
+.ui-resizable-e { cursor: e-resize; width: 7px; right: -5px; top: 0px; height: 100%; }
+.ui-resizable-w { cursor: w-resize; width: 7px; left: -5px; top: 0px; height: 100%; }
+.ui-resizable-se { cursor: se-resize; width: 12px; height: 12px; right: 1px; bottom: 1px; }
+.ui-resizable-sw { cursor: sw-resize; width: 9px; height: 9px; left: -5px; bottom: -5px; }
+.ui-resizable-nw { cursor: nw-resize; width: 9px; height: 9px; left: -5px; top: -5px; }
+.ui-resizable-ne { cursor: ne-resize; width: 9px; height: 9px; right: -5px; top: -5px;}/* Slider
+.ui-slider { position: relative; text-align: left; }
+.ui-slider .ui-slider-handle { position: absolute; z-index: 2; width: 1.2em; height: 1.2em; cursor: default; }
+.ui-slider .ui-slider-range { position: absolute; z-index: 1; font-size: .7em; display: block; border: 0; }
+.ui-slider-horizontal { height: .8em; }
+.ui-slider-horizontal .ui-slider-handle { top: -.3em; margin-left: -.6em; }
+.ui-slider-horizontal .ui-slider-range { top: 0; height: 100%; }
+.ui-slider-horizontal .ui-slider-range-min { left: 0; }
+.ui-slider-horizontal .ui-slider-range-max { right: 0; }
+.ui-slider-vertical { width: .8em; height: 100px; }
+.ui-slider-vertical .ui-slider-handle { left: -.3em; margin-left: 0; margin-bottom: -.6em; }
+.ui-slider-vertical .ui-slider-range { left: 0; width: 100%; }
+.ui-slider-vertical .ui-slider-range-min { bottom: 0; }
+.ui-slider-vertical .ui-slider-range-max { top: 0; }/* Tabs
+.ui-tabs { padding: .2em; zoom: 1; }
+.ui-tabs .ui-tabs-nav { list-style: none; position: relative; padding: .2em .2em 0; }
+.ui-tabs .ui-tabs-nav li { position: relative; float: left; border-bottom-width: 0 !important; margin: 0 .2em -1px 0; padding: 0; }
+.ui-tabs .ui-tabs-nav li a { float: left; text-decoration: none; padding: .5em 1em; }
+.ui-tabs .ui-tabs-nav li.ui-tabs-selected { padding-bottom: 1px; border-bottom-width: 0; }
+.ui-tabs .ui-tabs-nav li.ui-tabs-selected a, .ui-tabs .ui-tabs-nav li.ui-state-disabled a, .ui-tabs .ui-tabs-nav li.ui-state-processing a { cursor: text; }
+.ui-tabs .ui-tabs-nav li a, .ui-tabs.ui-tabs-collapsible .ui-tabs-nav li.ui-tabs-selected a { cursor: pointer; } /* first selector in group seems obsolete, but required to overcome bug in Opera applying cursor: text overall if defined elsewhere... */
+.ui-tabs .ui-tabs-panel { padding: 1em 1.4em; display: block; border-width: 0; background: none; }
+.ui-tabs .ui-tabs-hide { display: none !important; }
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.blind.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.blind.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.blind.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,2 @@
+(function($){$.effects.blind=function(o){return this.queue(function(){var el=$(this),props=['position','top','left'];var mode=$.effects.setMode(el,o.options.mode||'hide');var direction=o.options.direction||'vertical';$.effects.save(el,props);el.show();var wrapper=$.effects.createWrapper(el).css({overflow:'hidden'});var ref=(direction=='vertical')?'height':'width';var distance=(direction=='vertical')?wrapper.height():wrapper.width();if(mode=='show')wrapper.css(ref,0);var animation={};animation[ref]=mode=='show'?distance:0;wrapper.animate(animation,o.duration,o.options.easing,function(){if(mode=='hide')el.hide();$.effects.restore(el,props);$.effects.removeWrapper(el);if(o.callback)o.callback.apply(el[0],arguments);el.dequeue();});});};})(jQuery);
\ No newline at end of file
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.bounce.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.bounce.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.bounce.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,2 @@
+(function($){$.effects.bounce=function(o){return this.queue(function(){var el=$(this),props=['position','top','left'];var mode=$.effects.setMode(el,o.options.mode||'effect');var direction=o.options.direction||'up';var distance=o.options.distance||20;var times=o.options.times||5;var speed=o.duration||250;if(/show|hide/.test(mode))props.push('opacity');$.effects.save(el,props);el.show();$.effects.createWrapper(el);var ref=(direction=='up'||direction=='down')?'top':'left';var motion=(direction=='up'||direction=='left')?'pos':'neg';var distance=o.options.distance||(ref=='top'?el.outerHeight({margin:true})/3:el.outerWidth({margin:true})/3);if(mode=='show')el.css('opacity',0).css(ref,motion=='pos'?-distance:distance);if(mode=='hide')distance=distance/(times*2);if(mode!='hide')times--;if(mode=='show'){var animation={opacity:1};animation[ref]=(motion=='pos'?'+=':'-=')+distance;el.animate(animation,speed/2,o.options.easing);distance=distance/2;times--;};for(var i=0;i<times;i++){var animation1={},animation2={};animation1[ref]=(motion=='pos'?'-=':'+=')+distance;animation2[ref]=(motion=='pos'?'+=':'-=')+distance;el.animate(animation1,speed/2,o.options.easing).animate(animation2,speed/2,o.options.easing);distance=(mode=='hide')?distance*2:distance/2;};if(mode=='hide'){var animation={opacity:0};animation[ref]=(motion=='pos'?'-=':'+=')+distance;el.animate(animation,speed/2,o.options.easing,function(){el.hide();$.effects.restore(el,props);$.effects.removeWrapper(el);if(o.callback)o.callback.apply(this,arguments);});}else{var animation1={},animation2={};animation1[ref]=(motion=='pos'?'-=':'+=')+distance;animation2[ref]=(motion=='pos'?'+=':'-=')+distance;el.animate(animation1,speed/2,o.options.easing).animate(animation2,speed/2,o.options.easing,function(){$.effects.restore(el,props);$.effects.removeWrapper(el);if(o.callback)o.callback.apply(this,arguments);});};el.queue('fx',function(){el.dequeue();});el.dequeue();});};})(jQuery);
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.clip.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.clip.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.clip.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,3 @@
+(function($){$.effects.clip=function(o){return this.queue(function(){var el=$(this),props=['position','top','left','height','width'];var mode=$.effects.setMode(el,o.options.mode||'hide');var direction=o.options.direction||'vertical';$.effects.save(el,props);el.show();var wrapper=$.effects.createWrapper(el).css({overflow:'hidden'});var animate=el[0].tagName=='IMG'?wrapper:el;var ref={size:(direction=='vertical')?'height':'width',position:(direction=='vertical')?'top':'left'};var distance=(direction=='vertical')?animate.height():animate.width();if(mode=='show'){animate.css(ref.size,0);animate.css(ref.position,distance/2);}
+var animation={};animation[ref.size]=mode=='show'?distance:0;animation[ref.position]=mode=='show'?0:distance/2;animate.animate(animation,{queue:false,duration:o.duration,easing:o.options.easing,complete:function(){if(mode=='hide')el.hide();$.effects.restore(el,props);$.effects.removeWrapper(el);if(o.callback)o.callback.apply(el[0],arguments);el.dequeue();}});});};})(jQuery);
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.core.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.core.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.core.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,22 @@
+;jQuery.effects||(function($){$.effects={version:"1.7.2",save:function(element,set){for(var i=0;i<set.length;i++){if(set[i]!==null)element.data("ec.storage."+set[i],element[0].style[set[i]]);}},restore:function(element,set){for(var i=0;i<set.length;i++){if(set[i]!==null)element.css(set[i],element.data("ec.storage."+set[i]));}},setMode:function(el,mode){if(mode=='toggle')mode=el.is(':hidden')?'show':'hide';return mode;},getBaseline:function(origin,original){var y,x;switch(origin[0]){case'top':y=0;break;case'middle':y=0.5;break;case'bottom':y=1;break;default:y=origin[0]/original.height;};switch(origin[1]){case'left':x=0;break;case'center':x=0.5;break;case'right':x=1;break;default:x=origin[1]/original.width;};return{x:x,y:y};},createWrapper:function(element){if(element.parent().is('.ui-effects-wrapper'))
+return element.parent();var props={width:element.outerWidth(true),height:element.outerHeight(true),'float':element.css('float')};element.wrap('<div class="ui-effects-wrapper" style="font-size:100%;background:transparent;border:none;margin:0;padding:0"></div>');var wrapper=element.parent();if(element.css('position')=='static'){wrapper.css({position:'relative'});element.css({position:'relative'});}else{var top=element.css('top');if(isNaN(parseInt(top,10)))top='auto';var left=element.css('left');if(isNaN(parseInt(left,10)))left='auto';wrapper.css({position:element.css('position'),top:top,left:left,zIndex:element.css('z-index')}).show();element.css({position:'relative',top:0,left:0});}
+wrapper.css(props);return wrapper;},removeWrapper:function(element){if(element.parent().is('.ui-effects-wrapper'))
+return element.parent().replaceWith(element);return element;},setTransition:function(element,list,factor,value){value=value||{};$.each(list,function(i,x){unit=element.cssUnit(x);if(unit[0]>0)value[x]=unit[0]*factor+unit[1];});return value;},animateClass:function(value,duration,easing,callback){var cb=(typeof easing=="function"?easing:(callback?callback:null));var ea=(typeof easing=="string"?easing:null);return this.each(function(){var offset={};var that=$(this);var oldStyleAttr=that.attr("style")||'';if(typeof oldStyleAttr=='object')oldStyleAttr=oldStyleAttr["cssText"];if(value.toggle){that.hasClass(value.toggle)?value.remove=value.toggle:value.add=value.toggle;}
+var oldStyle=$.extend({},(document.defaultView?document.defaultView.getComputedStyle(this,null):this.currentStyle));if(value.add)that.addClass(value.add);if(value.remove)that.removeClass(value.remove);var newStyle=$.extend({},(document.defaultView?document.defaultView.getComputedStyle(this,null):this.currentStyle));if(value.add)that.removeClass(value.add);if(value.remove)that.addClass(value.remove);for(var n in newStyle){if(typeof newStyle[n]!="function"&&newStyle[n]&&n.indexOf("Moz")==-1&&n.indexOf("length")==-1&&newStyle[n]!=oldStyle[n]&&(n.match(/color/i)||(!n.match(/color/i)&&!isNaN(parseInt(newStyle[n],10))))&&(oldStyle.position!="static"||(oldStyle.position=="static"&&!n.match(/left|top|bottom|right/))))offset[n]=newStyle[n];}
+that.animate(offset,duration,ea,function(){if(typeof $(this).attr("style")=='object'){$(this).attr("style")["cssText"]="";$(this).attr("style")["cssText"]=oldStyleAttr;}else $(this).attr("style",oldStyleAttr);if(value.add)$(this).addClass(value.add);if(value.remove)$(this).removeClass(value.remove);if(cb)cb.apply(this,arguments);});});}};function _normalizeArguments(a,m){var o=a[1]&&a[1].constructor==Object?a[1]:{};if(m)o.mode=m;var speed=a[1]&&a[1].constructor!=Object?a[1]:(o.duration?o.duration:a[2]);speed=$.fx.off?0:typeof speed==="number"?speed:$.fx.speeds[speed]||$.fx.speeds._default;var callback=o.callback||($.isFunction(a[1])&&a[1])||($.isFunction(a[2])&&a[2])||($.isFunction(a[3])&&a[3]);return[a[0],o,speed,callback];}
+$.fn.extend({_show:$.fn.show,_hide:$.fn.hide,__toggle:$.fn.toggle,_addClass:$.fn.addClass,_removeClass:$.fn.removeClass,_toggleClass:$.fn.toggleClass,effect:function(fx,options,speed,callback){return $.effects[fx]?$.effects[fx].call(this,{method:fx,options:options||{},duration:speed,callback:callback}):null;},show:function(){if(!arguments[0]||(arguments[0].constructor==Number||(/(slow|normal|fast)/).test(arguments[0])))
+return this._show.apply(this,arguments);else{return this.effect.apply(this,_normalizeArguments(arguments,'show'));}},hide:function(){if(!arguments[0]||(arguments[0].constructor==Number||(/(slow|normal|fast)/).test(arguments[0])))
+return this._hide.apply(this,arguments);else{return this.effect.apply(this,_normalizeArguments(arguments,'hide'));}},toggle:function(){if(!arguments[0]||(arguments[0].constructor==Number||(/(slow|normal|fast)/).test(arguments[0]))||($.isFunction(arguments[0])||typeof arguments[0]=='boolean')){return this.__toggle.apply(this,arguments);}else{return this.effect.apply(this,_normalizeArguments(arguments,'toggle'));}},addClass:function(classNames,speed,easing,callback){return speed?$.effects.animateClass.apply(this,[{add:classNames},speed,easing,callback]):this._addClass(classNames);},removeClass:function(classNames,speed,easing,callback){return speed?$.effects.animateClass.apply(this,[{remove:classNames},speed,easing,callback]):this._removeClass(classNames);},toggleClass:function(classNames,speed,easing,callback){return((typeof speed!=="boolean")&&speed)?$.effects.animateClass.apply(this,[{toggle:classNames},speed,easing,callback]):this._toggleClass(classNames,speed);},morph:function(remove,add,speed,easing,callback){return $.effects.animateClass.apply(this,[{add:add,remove:remove},speed,easing,callback]);},switchClass:function(){return this.morph.apply(this,arguments);},cssUnit:function(key){var style=this.css(key),val=[];$.each(['em','px','%','pt'],function(i,unit){if(style.indexOf(unit)>0)
+val=[parseFloat(style),unit];});return val;}});$.each(['backgroundColor','borderBottomColor','borderLeftColor','borderRightColor','borderTopColor','color','outlineColor'],function(i,attr){$.fx.step[attr]=function(fx){if(fx.state==0){fx.start=getColor(fx.elem,attr);fx.end=getRGB(fx.end);}
+fx.elem.style[attr]="rgb("+[Math.max(Math.min(parseInt((fx.pos*(fx.end[0]-fx.start[0]))+fx.start[0],10),255),0),Math.max(Math.min(parseInt((fx.pos*(fx.end[1]-fx.start[1]))+fx.start[1],10),255),0),Math.max(Math.min(parseInt((fx.pos*(fx.end[2]-fx.start[2]))+fx.start[2],10),255),0)].join(",")+")";};});function getRGB(color){var result;if(color&&color.constructor==Array&&color.length==3)
+return color;if(result=/rgb\(\s*([0-9]{1,3})\s*,\s*([0-9]{1,3})\s*,\s*([0-9]{1,3})\s*\)/.exec(color))
+return[parseInt(result[1],10),parseInt(result[2],10),parseInt(result[3],10)];if(result=/rgb\(\s*([0-9]+(?:\.[0-9]+)?)\%\s*,\s*([0-9]+(?:\.[0-9]+)?)\%\s*,\s*([0-9]+(?:\.[0-9]+)?)\%\s*\)/.exec(color))
+return[parseFloat(result[1])*2.55,parseFloat(result[2])*2.55,parseFloat(result[3])*2.55];if(result=/#([a-fA-F0-9]{2})([a-fA-F0-9]{2})([a-fA-F0-9]{2})/.exec(color))
+return[parseInt(result[1],16),parseInt(result[2],16),parseInt(result[3],16)];if(result=/#([a-fA-F0-9])([a-fA-F0-9])([a-fA-F0-9])/.exec(color))
+return[parseInt(result[1]+result[1],16),parseInt(result[2]+result[2],16),parseInt(result[3]+result[3],16)];if(result=/rgba\(0, 0, 0, 0\)/.exec(color))
+return colors['transparent'];return colors[$.trim(color).toLowerCase()];}
+function getColor(elem,attr){var color;do{color=$.curCSS(elem,attr);if(color!=''&&color!='transparent'||$.nodeName(elem,"body"))
+break;attr="backgroundColor";}while(elem=elem.parentNode);return getRGB(color);};var colors={aqua:[0,255,255],azure:[240,255,255],beige:[245,245,220],black:[0,0,0],blue:[0,0,255],brown:[165,42,42],cyan:[0,255,255],darkblue:[0,0,139],darkcyan:[0,139,139],darkgrey:[169,169,169],darkgreen:[0,100,0],darkkhaki:[189,183,107],darkmagenta:[139,0,139],darkolivegreen:[85,107,47],darkorange:[255,140,0],darkorchid:[153,50,204],darkred:[139,0,0],darksalmon:[233,150,122],darkviolet:[148,0,211],fuchsia:[255,0,255],gold:[255,215,0],green:[0,128,0],indigo:[75,0,130],khaki:[240,230,140],lightblue:[173,216,230],lightcyan:[224,255,255],lightgreen:[144,238,144],lightgrey:[211,211,211],lightpink:[255,182,193],lightyellow:[255,255,224],lime:[0,255,0],magenta:[255,0,255],maroon:[128,0,0],navy:[0,0,128],olive:[128,128,0],orange:[255,165,0],pink:[255,192,203],purple:[128,0,128],violet:[128,0,128],red:[255,0,0],silver:[192,192,192],white:[255,255,255],yellow:[255,255,0],transparent:[255,255,255]};$.easing.jswing=$.easing.swing;$.extend($.easing,{def:'easeOutQuad',swing:function(x,t,b,c,d){return $.easing[$.easing.def](x,t,b,c,d);},easeInQuad:function(x,t,b,c,d){return c*(t/=d)*t+b;},easeOutQuad:function(x,t,b,c,d){return-c*(t/=d)*(t-2)+b;},easeInOutQuad:function(x,t,b,c,d){if((t/=d/2)<1)return c/2*t*t+b;return-c/2*((--t)*(t-2)-1)+b;},easeInCubic:function(x,t,b,c,d){return c*(t/=d)*t*t+b;},easeOutCubic:function(x,t,b,c,d){return c*((t=t/d-1)*t*t+1)+b;},easeInOutCubic:function(x,t,b,c,d){if((t/=d/2)<1)return c/2*t*t*t+b;return c/2*((t-=2)*t*t+2)+b;},easeInQuart:function(x,t,b,c,d){return c*(t/=d)*t*t*t+b;},easeOutQuart:function(x,t,b,c,d){return-c*((t=t/d-1)*t*t*t-1)+b;},easeInOutQuart:function(x,t,b,c,d){if((t/=d/2)<1)return c/2*t*t*t*t+b;return-c/2*((t-=2)*t*t*t-2)+b;},easeInQuint:function(x,t,b,c,d){return c*(t/=d)*t*t*t*t+b;},easeOutQuint:function(x,t,b,c,d){return c*((t=t/d-1)*t*t*t*t+1)+b;},easeInOutQuint:function(x,t,b,c,d){if((t/=d/2)<1)return c/2*t*t*t*t*t+b;return c/2*((t-=2)*t*t*t*t+2)+b;},easeInSine:function(x,t,b,c,d){return-c*Math.cos(t/d*(Math.PI/2))+c+b;},easeOutSine:function(x,t,b,c,d){return c*Math.sin(t/d*(Math.PI/2))+b;},easeInOutSine:function(x,t,b,c,d){return-c/2*(Math.cos(Math.PI*t/d)-1)+b;},easeInExpo:function(x,t,b,c,d){return(t==0)?b:c*Math.pow(2,10*(t/d-1))+b;},easeOutExpo:function(x,t,b,c,d){return(t==d)?b+c:c*(-Math.pow(2,-10*t/d)+1)+b;},easeInOutExpo:function(x,t,b,c,d){if(t==0)return b;if(t==d)return b+c;if((t/=d/2)<1)return c/2*Math.pow(2,10*(t-1))+b;return c/2*(-Math.pow(2,-10*--t)+2)+b;},easeInCirc:function(x,t,b,c,d){return-c*(Math.sqrt(1-(t/=d)*t)-1)+b;},easeOutCirc:function(x,t,b,c,d){return c*Math.sqrt(1-(t=t/d-1)*t)+b;},easeInOutCirc:function(x,t,b,c,d){if((t/=d/2)<1)return-c/2*(Math.sqrt(1-t*t)-1)+b;return c/2*(Math.sqrt(1-(t-=2)*t)+1)+b;},easeInElastic:function(x,t,b,c,d){var s=1.70158;var p=0;var a=c;if(t==0)return b;if((t/=d)==1)return b+c;if(!p)p=d*.3;if(a<Math.abs(c)){a=c;var s=p/4;}
+else var s=p/(2*Math.PI)*Math.asin(c/a);return-(a*Math.pow(2,10*(t-=1))*Math.sin((t*d-s)*(2*Math.PI)/p))+b;},easeOutElastic:function(x,t,b,c,d){var s=1.70158;var p=0;var a=c;if(t==0)return b;if((t/=d)==1)return b+c;if(!p)p=d*.3;if(a<Math.abs(c)){a=c;var s=p/4;}
+else var s=p/(2*Math.PI)*Math.asin(c/a);return a*Math.pow(2,-10*t)*Math.sin((t*d-s)*(2*Math.PI)/p)+c+b;},easeInOutElastic:function(x,t,b,c,d){var s=1.70158;var p=0;var a=c;if(t==0)return b;if((t/=d/2)==2)return b+c;if(!p)p=d*(.3*1.5);if(a<Math.abs(c)){a=c;var s=p/4;}
+else var s=p/(2*Math.PI)*Math.asin(c/a);if(t<1)return-.5*(a*Math.pow(2,10*(t-=1))*Math.sin((t*d-s)*(2*Math.PI)/p))+b;return a*Math.pow(2,-10*(t-=1))*Math.sin((t*d-s)*(2*Math.PI)/p)*.5+c+b;},easeInBack:function(x,t,b,c,d,s){if(s==undefined)s=1.70158;return c*(t/=d)*t*((s+1)*t-s)+b;},easeOutBack:function(x,t,b,c,d,s){if(s==undefined)s=1.70158;return c*((t=t/d-1)*t*((s+1)*t+s)+1)+b;},easeInOutBack:function(x,t,b,c,d,s){if(s==undefined)s=1.70158;if((t/=d/2)<1)return c/2*(t*t*(((s*=(1.525))+1)*t-s))+b;return c/2*((t-=2)*t*(((s*=(1.525))+1)*t+s)+2)+b;},easeInBounce:function(x,t,b,c,d){return c-$.easing.easeOutBounce(x,d-t,0,c,d)+b;},easeOutBounce:function(x,t,b,c,d){if((t/=d)<(1/2.75)){return c*(7.5625*t*t)+b;}else if(t<(2/2.75)){return c*(7.5625*(t-=(1.5/2.75))*t+.75)+b;}else if(t<(2.5/2.75)){return c*(7.5625*(t-=(2.25/2.75))*t+.9375)+b;}else{return c*(7.5625*(t-=(2.625/2.75))*t+.984375)+b;}},easeInOutBounce:function(x,t,b,c,d){if(t<d/2)return $.easing.easeInBounce(x,t*2,0,c,d)*.5+b;return $.easing.easeOutBounce(x,t*2-d,0,c,d)*.5+c*.5+b;}});})(jQuery);
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.drop.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.drop.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.drop.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,2 @@
+(function($){$.effects.drop=function(o){return this.queue(function(){var el=$(this),props=['position','top','left','opacity'];var mode=$.effects.setMode(el,o.options.mode||'hide');var direction=o.options.direction||'left';$.effects.save(el,props);el.show();$.effects.createWrapper(el);var ref=(direction=='up'||direction=='down')?'top':'left';var motion=(direction=='up'||direction=='left')?'pos':'neg';var distance=o.options.distance||(ref=='top'?el.outerHeight({margin:true})/2:el.outerWidth({margin:true})/2);if(mode=='show')el.css('opacity',0).css(ref,motion=='pos'?-distance:distance);var animation={opacity:mode=='show'?1:0};animation[ref]=(mode=='show'?(motion=='pos'?'+=':'-='):(motion=='pos'?'-=':'+='))+distance;el.animate(animation,{queue:false,duration:o.duration,easing:o.options.easing,complete:function(){if(mode=='hide')el.hide();$.effects.restore(el,props);$.effects.removeWrapper(el);if(o.callback)o.callback.apply(this,arguments);el.dequeue();}});});};})(jQuery);
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.explode.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.explode.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.explode.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,3 @@
+(function($){$.effects.explode=function(o){return this.queue(function(){var rows=o.options.pieces?Math.round(Math.sqrt(o.options.pieces)):3;var cells=o.options.pieces?Math.round(Math.sqrt(o.options.pieces)):3;o.options.mode=o.options.mode=='toggle'?($(this).is(':visible')?'hide':'show'):o.options.mode;var el=$(this).show().css('visibility','hidden');var offset=el.offset();offset.top-=parseInt(el.css("marginTop"),10)||0;offset.left-=parseInt(el.css("marginLeft"),10)||0;var width=el.outerWidth(true);var height=el.outerHeight(true);for(var i=0;i<rows;i++){for(var j=0;j<cells;j++){el.clone().appendTo('body').wrap('<div></div>').css({position:'absolute',visibility:'visible',left:-j*(width/cells),top:-i*(height/rows)}).parent().addClass('ui-effects-explode').css({position:'absolute',overflow:'hidden',width:width/cells,height:height/rows,left:offset.left+j*(width/cells)+(o.options.mode=='show'?(j-Math.floor(cells/2))*(width/cells):0),top:offset.top+i*(height/rows)+(o.options.mode=='show'?(i-Math.floor(rows/2))*(height/rows):0),opacity:o.options.mode=='show'?0:1}).animate({left:offset.left+j*(width/cells)+(o.options.mode=='show'?0:(j-Math.floor(cells/2))*(width/cells)),top:offset.top+i*(height/rows)+(o.options.mode=='show'?0:(i-Math.floor(rows/2))*(height/rows)),opacity:o.options.mode=='show'?1:0},o.duration||500);}}
+setTimeout(function(){o.options.mode=='show'?el.css({visibility:'visible'}):el.css({visibility:'visible'}).hide();if(o.callback)o.callback.apply(el[0]);el.dequeue();$('div.ui-effects-explode').remove();},o.duration||500);});};})(jQuery);
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.fold.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.fold.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.fold.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,2 @@
+(function($){$.effects.fold=function(o){return this.queue(function(){var el=$(this),props=['position','top','left'];var mode=$.effects.setMode(el,o.options.mode||'hide');var size=o.options.size||15;var horizFirst=!(!o.options.horizFirst);var duration=o.duration?o.duration/2:$.fx.speeds._default/2;$.effects.save(el,props);el.show();var wrapper=$.effects.createWrapper(el).css({overflow:'hidden'});var widthFirst=((mode=='show')!=horizFirst);var ref=widthFirst?['width','height']:['height','width'];var distance=widthFirst?[wrapper.width(),wrapper.height()]:[wrapper.height(),wrapper.width()];var percent=/([0-9]+)%/.exec(size);if(percent)size=parseInt(percent[1],10)/100*distance[mode=='hide'?0:1];if(mode=='show')wrapper.css(horizFirst?{height:0,width:size}:{height:size,width:0});var animation1={},animation2={};animation1[ref[0]]=mode=='show'?distance[0]:size;animation2[ref[1]]=mode=='show'?distance[1]:0;wrapper.animate(animation1,duration,o.options.easing).animate(animation2,duration,o.options.easing,function(){if(mode=='hide')el.hide();$.effects.restore(el,props);$.effects.removeWrapper(el);if(o.callback)o.callback.apply(el[0],arguments);el.dequeue();});});};})(jQuery);
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.highlight.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.highlight.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.highlight.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,2 @@
+(function($){$.effects.highlight=function(o){return this.queue(function(){var el=$(this),props=['backgroundImage','backgroundColor','opacity'];var mode=$.effects.setMode(el,o.options.mode||'show');var color=o.options.color||"#ffff99";var oldColor=el.css("backgroundColor");$.effects.save(el,props);el.show();el.css({backgroundImage:'none',backgroundColor:color});var animation={backgroundColor:oldColor};if(mode=="hide")animation['opacity']=0;el.animate(animation,{queue:false,duration:o.duration,easing:o.options.easing,complete:function(){if(mode=="hide")el.hide();$.effects.restore(el,props);if(mode=="show"&&$.browser.msie)this.style.removeAttribute('filter');if(o.callback)o.callback.apply(this,arguments);el.dequeue();}});});};})(jQuery);
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.pulsate.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.pulsate.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.pulsate.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,3 @@
+(function($){$.effects.pulsate=function(o){return this.queue(function(){var el=$(this);var mode=$.effects.setMode(el,o.options.mode||'show');var times=o.options.times||5;var duration=o.duration?o.duration/2:$.fx.speeds._default/2;if(mode=='hide')times--;if(el.is(':hidden')){el.css('opacity',0);el.show();el.animate({opacity:1},duration,o.options.easing);times=times-2;}
+for(var i=0;i<times;i++){el.animate({opacity:0},duration,o.options.easing).animate({opacity:1},duration,o.options.easing);};if(mode=='hide'){el.animate({opacity:0},duration,o.options.easing,function(){el.hide();if(o.callback)o.callback.apply(this,arguments);});}else{el.animate({opacity:0},duration,o.options.easing).animate({opacity:1},duration,o.options.easing,function(){if(o.callback)o.callback.apply(this,arguments);});};el.queue('fx',function(){el.dequeue();});el.dequeue();});};})(jQuery);
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.scale.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.scale.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.scale.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,3 @@
+(function($){$.effects.puff=function(o){return this.queue(function(){var el=$(this);var options=$.extend(true,{},o.options);var mode=$.effects.setMode(el,o.options.mode||'hide');var percent=parseInt(o.options.percent,10)||150;options.fade=true;var original={height:el.height(),width:el.width()};var factor=percent/100;el.from=(mode=='hide')?original:{height:original.height*factor,width:original.width*factor};options.from=el.from;options.percent=(mode=='hide')?percent:100;options.mode=mode;el.effect('scale',options,o.duration,o.callback);el.dequeue();});};$.effects.scale=function(o){return this.queue(function(){var el=$(this);var options=$.extend(true,{},o.options);var mode=$.effects.setMode(el,o.options.mode||'effect');var percent=parseInt(o.options.percent,10)||(parseInt(o.options.percent,10)==0?0:(mode=='hide'?0:100));var direction=o.options.direction||'both';var origin=o.options.origin;if(mode!='effect'){options.origin=origin||['middle','center'];options.restore=true;}
+var original={height:el.height(),width:el.width()};el.from=o.options.from||(mode=='show'?{height:0,width:0}:original);var factor={y:direction!='horizontal'?(percent/100):1,x:direction!='vertical'?(percent/100):1};el.to={height:original.height*factor.y,width:original.width*factor.x};if(o.options.fade){if(mode=='show'){el.from.opacity=0;el.to.opacity=1;};if(mode=='hide'){el.from.opacity=1;el.to.opacity=0;};};options.from=el.from;options.to=el.to;options.mode=mode;el.effect('size',options,o.duration,o.callback);el.dequeue();});};$.effects.size=function(o){return this.queue(function(){var el=$(this),props=['position','top','left','width','height','overflow','opacity'];var props1=['position','top','left','overflow','opacity'];var props2=['width','height','overflow'];var cProps=['fontSize'];var vProps=['borderTopWidth','borderBottomWidth','paddingTop','paddingBottom'];var hProps=['borderLeftWidth','borderRightWidth','paddingLeft','paddingRight'];var mode=$.effects.setMode(el,o.options.mode||'effect');var restore=o.options.restore||false;var scale=o.options.scale||'both';var origin=o.options.origin;var original={height:el.height(),width:el.width()};el.from=o.options.from||original;el.to=o.options.to||original;if(origin){var baseline=$.effects.getBaseline(origin,original);el.from.top=(original.height-el.from.height)*baseline.y;el.from.left=(original.width-el.from.width)*baseline.x;el.to.top=(original.height-el.to.height)*baseline.y;el.to.left=(original.width-el.to.width)*baseline.x;};var factor={from:{y:el.from.height/original.height,x:el.from.width/original.width},to:{y:el.to.height/original.height,x:el.to.width/original.width}};if(scale=='box'||scale=='both'){if(factor.from.y!=factor.to.y){props=props.concat(vProps);el.from=$.effects.setTransition(el,vProps,factor.from.y,el.from);el.to=$.effects.setTransition(el,vProps,factor.to.y,el.to);};if(factor.from.x!=factor.to.x){props=props.concat(hProps);el.from=$.effects.setTransition(el,hProps,factor.from.x,el.from);el.to=$.effects.setTransition(el,hProps,factor.to.x,el.to);};};if(scale=='content'||scale=='both'){if(factor.from.y!=factor.to.y){props=props.concat(cProps);el.from=$.effects.setTransition(el,cProps,factor.from.y,el.from);el.to=$.effects.setTransition(el,cProps,factor.to.y,el.to);};};$.effects.save(el,restore?props:props1);el.show();$.effects.createWrapper(el);el.css('overflow','hidden').css(el.from);if(scale=='content'||scale=='both'){vProps=vProps.concat(['marginTop','marginBottom']).concat(cProps);hProps=hProps.concat(['marginLeft','marginRight']);props2=props.concat(vProps).concat(hProps);el.find("*[width]").each(function(){child=$(this);if(restore)$.effects.save(child,props2);var c_original={height:child.height(),width:child.width()};child.from={height:c_original.height*factor.from.y,width:c_original.width*factor.from.x};child.to={height:c_original.height*factor.to.y,width:c_original.width*factor.to.x};if(factor.from.y!=factor.to.y){child.from=$.effects.setTransition(child,vProps,factor.from.y,child.from);child.to=$.effects.setTransition(child,vProps,factor.to.y,child.to);};if(factor.from.x!=factor.to.x){child.from=$.effects.setTransition(child,hProps,factor.from.x,child.from);child.to=$.effects.setTransition(child,hProps,factor.to.x,child.to);};child.css(child.from);child.animate(child.to,o.duration,o.options.easing,function(){if(restore)$.effects.restore(child,props2);});});};el.animate(el.to,{queue:false,duration:o.duration,easing:o.options.easing,complete:function(){if(mode=='hide')el.hide();$.effects.restore(el,restore?props:props1);$.effects.removeWrapper(el);if(o.callback)o.callback.apply(this,arguments);el.dequeue();}});});};})(jQuery);
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.shake.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.shake.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.shake.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,2 @@
+(function($){$.effects.shake=function(o){return this.queue(function(){var el=$(this),props=['position','top','left'];var mode=$.effects.setMode(el,o.options.mode||'effect');var direction=o.options.direction||'left';var distance=o.options.distance||20;var times=o.options.times||3;var speed=o.duration||o.options.duration||140;$.effects.save(el,props);el.show();$.effects.createWrapper(el);var ref=(direction=='up'||direction=='down')?'top':'left';var motion=(direction=='up'||direction=='left')?'pos':'neg';var animation={},animation1={},animation2={};animation[ref]=(motion=='pos'?'-=':'+=')+distance;animation1[ref]=(motion=='pos'?'+=':'-=')+distance*2;animation2[ref]=(motion=='pos'?'-=':'+=')+distance*2;el.animate(animation,speed,o.options.easing);for(var i=1;i<times;i++){el.animate(animation1,speed,o.options.easing).animate(animation2,speed,o.options.easing);};el.animate(animation1,speed,o.options.easing).animate(animation,speed/2,o.options.easing,function(){$.effects.restore(el,props);$.effects.removeWrapper(el);if(o.callback)o.callback.apply(this,arguments);});el.queue('fx',function(){el.dequeue();});el.dequeue();});};})(jQuery);
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.slide.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.slide.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.slide.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,2 @@
+(function($){$.effects.slide=function(o){return this.queue(function(){var el=$(this),props=['position','top','left'];var mode=$.effects.setMode(el,o.options.mode||'show');var direction=o.options.direction||'left';$.effects.save(el,props);el.show();$.effects.createWrapper(el).css({overflow:'hidden'});var ref=(direction=='up'||direction=='down')?'top':'left';var motion=(direction=='up'||direction=='left')?'pos':'neg';var distance=o.options.distance||(ref=='top'?el.outerHeight({margin:true}):el.outerWidth({margin:true}));if(mode=='show')el.css(ref,motion=='pos'?-distance:distance);var animation={};animation[ref]=(mode=='show'?(motion=='pos'?'+=':'-='):(motion=='pos'?'-=':'+='))+distance;el.animate(animation,{queue:false,duration:o.duration,easing:o.options.easing,complete:function(){if(mode=='hide')el.hide();$.effects.restore(el,props);$.effects.removeWrapper(el);if(o.callback)o.callback.apply(this,arguments);el.dequeue();}});});};})(jQuery);
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.transfer.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.transfer.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.transfer.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,2 @@
+(function($){$.effects.transfer=function(o){return this.queue(function(){var elem=$(this),target=$(o.options.to),endPosition=target.offset(),animation={top:endPosition.top,left:endPosition.left,height:target.innerHeight(),width:target.innerWidth()},startPosition=elem.offset(),transfer=$('<div class="ui-effects-transfer"></div>').appendTo(document.body).addClass(o.options.className).css({top:startPosition.top,left:startPosition.left,height:elem.innerHeight(),width:elem.innerWidth(),position:'absolute'}).animate(animation,o.duration,o.options.easing,function(){transfer.remove();(o.callback&&o.callback.apply(elem[0],arguments));elem.dequeue();});});};})(jQuery);
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.jquery-ui-1.7.2.custom.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.jquery-ui-1.7.2.custom.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.jquery-ui-1.7.2.custom.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,535 @@
+;jQuery.ui||(function($){var _remove=$.fn.remove,isFF2=$.browser.mozilla&&(parseFloat($.browser.version)<1.9);$.ui={version:"1.7.2",plugin:{add:function(module,option,set){var proto=$.ui[module].prototype;for(var i in set){proto.plugins[i]=proto.plugins[i]||[];proto.plugins[i].push([option,set[i]]);}},call:function(instance,name,args){var set=instance.plugins[name];if(!set||!instance.element[0].parentNode){return;}
+for(var i=0;i<set.length;i++){if(instance.options[set[i][0]]){set[i][1].apply(instance.element,args);}}}},contains:function(a,b){return document.compareDocumentPosition?a.compareDocumentPosition(b)&16:a!==b&&a.contains(b);},hasScroll:function(el,a){if($(el).css('overflow')=='hidden'){return false;}
+var scroll=(a&&a=='left')?'scrollLeft':'scrollTop',has=false;if(el[scroll]>0){return true;}
+el[scroll]=1;has=(el[scroll]>0);el[scroll]=0;return has;},isOverAxis:function(x,reference,size){return(x>reference)&&(x<(reference+size));},isOver:function(y,x,top,left,height,width){return $.ui.isOverAxis(y,top,height)&&$.ui.isOverAxis(x,left,width);},keyCode:{BACKSPACE:8,CAPS_LOCK:20,COMMA:188,CONTROL:17,DELETE:46,DOWN:40,END:35,ENTER:13,ESCAPE:27,HOME:36,INSERT:45,LEFT:37,NUMPAD_ADD:107,NUMPAD_DECIMAL:110,NUMPAD_DIVIDE:111,NUMPAD_ENTER:108,NUMPAD_MULTIPLY:106,NUMPAD_SUBTRACT:109,PAGE_DOWN:34,PAGE_UP:33,PERIOD:190,RIGHT:39,SHIFT:16,SPACE:32,TAB:9,UP:38}};if(isFF2){var attr=$.attr,removeAttr=$.fn.removeAttr,ariaNS="http://www.w3.org/2005/07/aaa",ariaState=/^aria-/,ariaRole=/^wairole:/;$.attr=function(elem,name,value){var set=value!==undefined;return(name=='role'?(set?attr.call(this,elem,name,"wairole:"+value):(attr.apply(this,arguments)||"").replace(ariaRole,"")):(ariaState.test(name)?(set?elem.setAttributeNS(ariaNS,name.replace(ariaState,"aaa:"),value):attr.call(this,elem,name.replace(ariaState,"aaa:"))):attr.apply(this,arguments)));};$.fn.removeAttr=function(name){return(ariaState.test(name)?this.each(function(){this.removeAttributeNS(ariaNS,name.replace(ariaState,""));}):removeAttr.call(this,name));};}
+$.fn.extend({remove:function(){$("*",this).add(this).each(function(){$(this).triggerHandler("remove");});return _remove.apply(this,arguments);},enableSelection:function(){return this.attr('unselectable','off').css('MozUserSelect','').unbind('selectstart.ui');},disableSelection:function(){return this.attr('unselectable','on').css('MozUserSelect','none').bind('selectstart.ui',function(){return false;});},scrollParent:function(){var scrollParent;if(($.browser.msie&&(/(static|relative)/).test(this.css('position')))||(/absolute/).test(this.css('position'))){scrollParent=this.parents().filter(function(){return(/(relative|absolute|fixed)/).test($.curCSS(this,'position',1))&&(/(auto|scroll)/).test($.curCSS(this,'overflow',1)+$.curCSS(this,'overflow-y',1)+$.curCSS(this,'overflow-x',1));}).eq(0);}else{scrollParent=this.parents().filter(function(){return(/(auto|scroll)/).test($.curCSS(this,'overflow',1)+$.curCSS(this,'overflow-y',1)+$.curCSS(this,'overflow-x',1));}).eq(0);}
+return(/fixed/).test(this.css('position'))||!scrollParent.length?$(document):scrollParent;}});$.extend($.expr[':'],{data:function(elem,i,match){return!!$.data(elem,match[3]);},focusable:function(element){var nodeName=element.nodeName.toLowerCase(),tabIndex=$.attr(element,'tabindex');return(/input|select|textarea|button|object/.test(nodeName)?!element.disabled:'a'==nodeName||'area'==nodeName?element.href||!isNaN(tabIndex):!isNaN(tabIndex))&&!$(element)['area'==nodeName?'parents':'closest'](':hidden').length;},tabbable:function(element){var tabIndex=$.attr(element,'tabindex');return(isNaN(tabIndex)||tabIndex>=0)&&$(element).is(':focusable');}});function getter(namespace,plugin,method,args){function getMethods(type){var methods=$[namespace][plugin][type]||[];return(typeof methods=='string'?methods.split(/,?\s+/):methods);}
+var methods=getMethods('getter');if(args.length==1&&typeof args[0]=='string'){methods=methods.concat(getMethods('getterSetter'));}
+return($.inArray(method,methods)!=-1);}
+$.widget=function(name,prototype){var namespace=name.split(".")[0];name=name.split(".")[1];$.fn[name]=function(options){var isMethodCall=(typeof options=='string'),args=Array.prototype.slice.call(arguments,1);if(isMethodCall&&options.substring(0,1)=='_'){return this;}
+if(isMethodCall&&getter(namespace,name,options,args)){var instance=$.data(this[0],name);return(instance?instance[options].apply(instance,args):undefined);}
+return this.each(function(){var instance=$.data(this,name);(!instance&&!isMethodCall&&$.data(this,name,new $[namespace][name](this,options))._init());(instance&&isMethodCall&&$.isFunction(instance[options])&&instance[options].apply(instance,args));});};$[namespace]=$[namespace]||{};$[namespace][name]=function(element,options){var self=this;this.namespace=namespace;this.widgetName=name;this.widgetEventPrefix=$[namespace][name].eventPrefix||name;this.widgetBaseClass=namespace+'-'+name;this.options=$.extend({},$.widget.defaults,$[namespace][name].defaults,$.metadata&&$.metadata.get(element)[name],options);this.element=$(element).bind('setData.'+name,function(event,key,value){if(event.target==element){return self._setData(key,value);}}).bind('getData.'+name,function(event,key){if(event.target==element){return self._getData(key);}}).bind('remove',function(){return self.destroy();});};$[namespace][name].prototype=$.extend({},$.widget.prototype,prototype);$[namespace][name].getterSetter='option';};$.widget.prototype={_init:function(){},destroy:function(){this.element.removeData(this.widgetName).removeClass(this.widgetBaseClass+'-disabled'+' '+this.namespace+'-state-disabled').removeAttr('aria-disabled');},option:function(key,value){var options=key,self=this;if(typeof key=="string"){if(value===undefined){return this._getData(key);}
+options={};options[key]=value;}
+$.each(options,function(key,value){self._setData(key,value);});},_getData:function(key){return this.options[key];},_setData:function(key,value){this.options[key]=value;if(key=='disabled'){this.element
+[value?'addClass':'removeClass'](this.widgetBaseClass+'-disabled'+' '+
+this.namespace+'-state-disabled').attr("aria-disabled",value);}},enable:function(){this._setData('disabled',false);},disable:function(){this._setData('disabled',true);},_trigger:function(type,event,data){var callback=this.options[type],eventName=(type==this.widgetEventPrefix?type:this.widgetEventPrefix+type);event=$.Event(event);event.type=eventName;if(event.originalEvent){for(var i=$.event.props.length,prop;i;){prop=$.event.props[--i];event[prop]=event.originalEvent[prop];}}
+this.element.trigger(event,data);return!($.isFunction(callback)&&callback.call(this.element[0],event,data)===false||event.isDefaultPrevented());}};$.widget.defaults={disabled:false};$.ui.mouse={_mouseInit:function(){var self=this;this.element.bind('mousedown.'+this.widgetName,function(event){return self._mouseDown(event);}).bind('click.'+this.widgetName,function(event){if(self._preventClickEvent){self._preventClickEvent=false;event.stopImmediatePropagation();return false;}});if($.browser.msie){this._mouseUnselectable=this.element.attr('unselectable');this.element.attr('unselectable','on');}
+this.started=false;},_mouseDestroy:function(){this.element.unbind('.'+this.widgetName);($.browser.msie&&this.element.attr('unselectable',this._mouseUnselectable));},_mouseDown:function(event){event.originalEvent=event.originalEvent||{};if(event.originalEvent.mouseHandled){return;}
+(this._mouseStarted&&this._mouseUp(event));this._mouseDownEvent=event;var self=this,btnIsLeft=(event.which==1),elIsCancel=(typeof this.options.cancel=="string"?$(event.target).parents().add(event.target).filter(this.options.cancel).length:false);if(!btnIsLeft||elIsCancel||!this._mouseCapture(event)){return true;}
+this.mouseDelayMet=!this.options.delay;if(!this.mouseDelayMet){this._mouseDelayTimer=setTimeout(function(){self.mouseDelayMet=true;},this.options.delay);}
+if(this._mouseDistanceMet(event)&&this._mouseDelayMet(event)){this._mouseStarted=(this._mouseStart(event)!==false);if(!this._mouseStarted){event.preventDefault();return true;}}
+this._mouseMoveDelegate=function(event){return self._mouseMove(event);};this._mouseUpDelegate=function(event){return self._mouseUp(event);};$(document).bind('mousemove.'+this.widgetName,this._mouseMoveDelegate).bind('mouseup.'+this.widgetName,this._mouseUpDelegate);($.browser.safari||event.preventDefault());event.originalEvent.mouseHandled=true;return true;},_mouseMove:function(event){if($.browser.msie&&!event.button){return this._mouseUp(event);}
+if(this._mouseStarted){this._mouseDrag(event);return event.preventDefault();}
+if(this._mouseDistanceMet(event)&&this._mouseDelayMet(event)){this._mouseStarted=(this._mouseStart(this._mouseDownEvent,event)!==false);(this._mouseStarted?this._mouseDrag(event):this._mouseUp(event));}
+return!this._mouseStarted;},_mouseUp:function(event){$(document).unbind('mousemove.'+this.widgetName,this._mouseMoveDelegate).unbind('mouseup.'+this.widgetName,this._mouseUpDelegate);if(this._mouseStarted){this._mouseStarted=false;this._preventClickEvent=(event.target==this._mouseDownEvent.target);this._mouseStop(event);}
+return false;},_mouseDistanceMet:function(event){return(Math.max(Math.abs(this._mouseDownEvent.pageX-event.pageX),Math.abs(this._mouseDownEvent.pageY-event.pageY))>=this.options.distance);},_mouseDelayMet:function(event){return this.mouseDelayMet;},_mouseStart:function(event){},_mouseDrag:function(event){},_mouseStop:function(event){},_mouseCapture:function(event){return true;}};$.ui.mouse.defaults={cancel:null,distance:1,delay:0};})(jQuery);(function($){$.widget("ui.draggable",$.extend({},$.ui.mouse,{_init:function(){if(this.options.helper=='original'&&!(/^(?:r|a|f)/).test(this.element.css("position")))
+this.element[0].style.position='relative';(this.options.addClasses&&this.element.addClass("ui-draggable"));(this.options.disabled&&this.element.addClass("ui-draggable-disabled"));this._mouseInit();},destroy:function(){if(!this.element.data('draggable'))return;this.element.removeData("draggable").unbind(".draggable").removeClass("ui-draggable"
++" ui-draggable-dragging"
++" ui-draggable-disabled");this._mouseDestroy();},_mouseCapture:function(event){var o=this.options;if(this.helper||o.disabled||$(event.target).is('.ui-resizable-handle'))
+return false;this.handle=this._getHandle(event);if(!this.handle)
+return false;return true;},_mouseStart:function(event){var o=this.options;this.helper=this._createHelper(event);this._cacheHelperProportions();if($.ui.ddmanager)
+$.ui.ddmanager.current=this;this._cacheMargins();this.cssPosition=this.helper.css("position");this.scrollParent=this.helper.scrollParent();this.offset=this.element.offset();this.offset={top:this.offset.top-this.margins.top,left:this.offset.left-this.margins.left};$.extend(this.offset,{click:{left:event.pageX-this.offset.left,top:event.pageY-this.offset.top},parent:this._getParentOffset(),relative:this._getRelativeOffset()});this.originalPosition=this._generatePosition(event);this.originalPageX=event.pageX;this.originalPageY=event.pageY;if(o.cursorAt)
+this._adjustOffsetFromHelper(o.cursorAt);if(o.containment)
+this._setContainment();this._trigger("start",event);this._cacheHelperProportions();if($.ui.ddmanager&&!o.dropBehaviour)
+$.ui.ddmanager.prepareOffsets(this,event);this.helper.addClass("ui-draggable-dragging");this._mouseDrag(event,true);return true;},_mouseDrag:function(event,noPropagation){this.position=this._generatePosition(event);this.positionAbs=this._convertPositionTo("absolute");if(!noPropagation){var ui=this._uiHash();this._trigger('drag',event,ui);this.position=ui.position;}
+if(!this.options.axis||this.options.axis!="y")this.helper[0].style.left=this.position.left+'px';if(!this.options.axis||this.options.axis!="x")this.helper[0].style.top=this.position.top+'px';if($.ui.ddmanager)$.ui.ddmanager.drag(this,event);return false;},_mouseStop:function(event){var dropped=false;if($.ui.ddmanager&&!this.options.dropBehaviour)
+dropped=$.ui.ddmanager.drop(this,event);if(this.dropped){dropped=this.dropped;this.dropped=false;}
+if((this.options.revert=="invalid"&&!dropped)||(this.options.revert=="valid"&&dropped)||this.options.revert===true||($.isFunction(this.options.revert)&&this.options.revert.call(this.element,dropped))){var self=this;$(this.helper).animate(this.originalPosition,parseInt(this.options.revertDuration,10),function(){self._trigger("stop",event);self._clear();});}else{this._trigger("stop",event);this._clear();}
+return false;},_getHandle:function(event){var handle=!this.options.handle||!$(this.options.handle,this.element).length?true:false;$(this.options.handle,this.element).find("*").andSelf().each(function(){if(this==event.target)handle=true;});return handle;},_createHelper:function(event){var o=this.options;var helper=$.isFunction(o.helper)?$(o.helper.apply(this.element[0],[event])):(o.helper=='clone'?this.element.clone():this.element);if(!helper.parents('body').length)
+helper.appendTo((o.appendTo=='parent'?this.element[0].parentNode:o.appendTo));if(helper[0]!=this.element[0]&&!(/(fixed|absolute)/).test(helper.css("position")))
+helper.css("position","absolute");return helper;},_adjustOffsetFromHelper:function(obj){if(obj.left!=undefined)this.offset.click.left=obj.left+this.margins.left;if(obj.right!=undefined)this.offset.click.left=this.helperProportions.width-obj.right+this.margins.left;if(obj.top!=undefined)this.offset.click.top=obj.top+this.margins.top;if(obj.bottom!=undefined)this.offset.click.top=this.helperProportions.height-obj.bottom+this.margins.top;},_getParentOffset:function(){this.offsetParent=this.helper.offsetParent();var po=this.offsetParent.offset();if(this.cssPosition=='absolute'&&this.scrollParent[0]!=document&&$.ui.contains(this.scrollParent[0],this.offsetParent[0])){po.left+=this.scrollParent.scrollLeft();po.top+=this.scrollParent.scrollTop();}
+if((this.offsetParent[0]==document.body)||(this.offsetParent[0].tagName&&this.offsetParent[0].tagName.toLowerCase()=='html'&&$.browser.msie))
+po={top:0,left:0};return{top:po.top+(parseInt(this.offsetParent.css("borderTopWidth"),10)||0),left:po.left+(parseInt(this.offsetParent.css("borderLeftWidth"),10)||0)};},_getRelativeOffset:function(){if(this.cssPosition=="relative"){var p=this.element.position();return{top:p.top-(parseInt(this.helper.css("top"),10)||0)+this.scrollParent.scrollTop(),left:p.left-(parseInt(this.helper.css("left"),10)||0)+this.scrollParent.scrollLeft()};}else{return{top:0,left:0};}},_cacheMargins:function(){this.margins={left:(parseInt(this.element.css("marginLeft"),10)||0),top:(parseInt(this.element.css("marginTop"),10)||0)};},_cacheHelperProportions:function(){this.helperProportions={width:this.helper.outerWidth(),height:this.helper.outerHeight()};},_setContainment:function(){var o=this.options;if(o.containment=='parent')o.containment=this.helper[0].parentNode;if(o.containment=='document'||o.containment=='window')this.containment=[0-this.offset.relative.left-this.offset.parent.left,0-this.offset.relative.top-this.offset.parent.top,$(o.containment=='document'?document:window).width()-this.helperProportions.width-this.margins.left,($(o.containment=='document'?document:window).height()||document.body.parentNode.scrollHeight)-this.helperProportions.height-this.margins.top];if(!(/^(document|window|parent)$/).test(o.containment)&&o.containment.constructor!=Array){var ce=$(o.containment)[0];if(!ce)return;var co=$(o.containment).offset();var over=($(ce).css("overflow")!='hidden');this.containment=[co.left+(parseInt($(ce).css("borderLeftWidth"),10)||0)+(parseInt($(ce).css("paddingLeft"),10)||0)-this.margins.left,co.top+(parseInt($(ce).css("borderTopWidth"),10)||0)+(parseInt($(ce).css("paddingTop"),10)||0)-this.margins.top,co.left+(over?Math.max(ce.scrollWidth,ce.offsetWidth):ce.offsetWidth)-(parseInt($(ce).css("borderLeftWidth"),10)||0)-(parseInt($(ce).css("paddingRight"),10)||0)-this.helperProportions.width-this.margins.left,co.top+(over?Math.max(ce.scrollHeight,ce.offsetHeight):ce.offsetHeight)-(parseInt($(ce).css("borderTopWidth"),10)||0)-(parseInt($(ce).css("paddingBottom"),10)||0)-this.helperProportions.height-this.margins.top];}else if(o.containment.constructor==Array){this.containment=o.containment;}},_convertPositionTo:function(d,pos){if(!pos)pos=this.position;var mod=d=="absolute"?1:-1;var o=this.options,scroll=this.cssPosition=='absolute'&&!(this.scrollParent[0]!=document&&$.ui.contains(this.scrollParent[0],this.offsetParent[0]))?this.offsetParent:this.scrollParent,scrollIsRootNode=(/(html|body)/i).test(scroll[0].tagName);return{top:(pos.top
++this.offset.relative.top*mod
++this.offset.parent.top*mod
+-($.browser.safari&&this.cssPosition=='fixed'?0:(this.cssPosition=='fixed'?-this.scrollParent.scrollTop():(scrollIsRootNode?0:scroll.scrollTop()))*mod)),left:(pos.left
++this.offset.relative.left*mod
++this.offset.parent.left*mod
+-($.browser.safari&&this.cssPosition=='fixed'?0:(this.cssPosition=='fixed'?-this.scrollParent.scrollLeft():scrollIsRootNode?0:scroll.scrollLeft())*mod))};},_generatePosition:function(event){var o=this.options,scroll=this.cssPosition=='absolute'&&!(this.scrollParent[0]!=document&&$.ui.contains(this.scrollParent[0],this.offsetParent[0]))?this.offsetParent:this.scrollParent,scrollIsRootNode=(/(html|body)/i).test(scroll[0].tagName);if(this.cssPosition=='relative'&&!(this.scrollParent[0]!=document&&this.scrollParent[0]!=this.offsetParent[0])){this.offset.relative=this._getRelativeOffset();}
+var pageX=event.pageX;var pageY=event.pageY;if(this.originalPosition){if(this.containment){if(event.pageX-this.offset.click.left<this.containment[0])pageX=this.containment[0]+this.offset.click.left;if(event.pageY-this.offset.click.top<this.containment[1])pageY=this.containment[1]+this.offset.click.top;if(event.pageX-this.offset.click.left>this.containment[2])pageX=this.containment[2]+this.offset.click.left;if(event.pageY-this.offset.click.top>this.containment[3])pageY=this.containment[3]+this.offset.click.top;}
+if(o.grid){var top=this.originalPageY+Math.round((pageY-this.originalPageY)/o.grid[1])*o.grid[1];pageY=this.containment?(!(top-this.offset.click.top<this.containment[1]||top-this.offset.click.top>this.containment[3])?top:(!(top-this.offset.click.top<this.containment[1])?top-o.grid[1]:top+o.grid[1])):top;var left=this.originalPageX+Math.round((pageX-this.originalPageX)/o.grid[0])*o.grid[0];pageX=this.containment?(!(left-this.offset.click.left<this.containment[0]||left-this.offset.click.left>this.containment[2])?left:(!(left-this.offset.click.left<this.containment[0])?left-o.grid[0]:left+o.grid[0])):left;}}
+return{top:(pageY
+-this.offset.click.top
+-this.offset.relative.top
+-this.offset.parent.top
++($.browser.safari&&this.cssPosition=='fixed'?0:(this.cssPosition=='fixed'?-this.scrollParent.scrollTop():(scrollIsRootNode?0:scroll.scrollTop())))),left:(pageX
+-this.offset.click.left
+-this.offset.relative.left
+-this.offset.parent.left
++($.browser.safari&&this.cssPosition=='fixed'?0:(this.cssPosition=='fixed'?-this.scrollParent.scrollLeft():scrollIsRootNode?0:scroll.scrollLeft())))};},_clear:function(){this.helper.removeClass("ui-draggable-dragging");if(this.helper[0]!=this.element[0]&&!this.cancelHelperRemoval)this.helper.remove();this.helper=null;this.cancelHelperRemoval=false;},_trigger:function(type,event,ui){ui=ui||this._uiHash();$.ui.plugin.call(this,type,[event,ui]);if(type=="drag")this.positionAbs=this._convertPositionTo("absolute");return $.widget.prototype._trigger.call(this,type,event,ui);},plugins:{},_uiHash:function(event){return{helper:this.helper,position:this.position,absolutePosition:this.positionAbs,offset:this.positionAbs};}}));$.extend($.ui.draggable,{version:"1.7.2",eventPrefix:"drag",defaults:{addClasses:true,appendTo:"parent",axis:false,cancel:":input,option",connectToSortable:false,containment:false,cursor:"auto",cursorAt:false,delay:0,distance:1,grid:false,handle:false,helper:"original",iframeFix:false,opacity:false,refreshPositions:false,revert:false,revertDuration:500,scope:"default",scroll:true,scrollSensitivity:20,scrollSpeed:20,snap:false,snapMode:"both",snapTolerance:20,stack:false,zIndex:false}});$.ui.plugin.add("draggable","connectToSortable",{start:function(event,ui){var inst=$(this).data("draggable"),o=inst.options,uiSortable=$.extend({},ui,{item:inst.element});inst.sortables=[];$(o.connectToSortable).each(function(){var sortable=$.data(this,'sortable');if(sortable&&!sortable.options.disabled){inst.sortables.push({instance:sortable,shouldRevert:sortable.options.revert});sortable._refreshItems();sortable._trigger("activate",event,uiSortable);}});},stop:function(event,ui){var inst=$(this).data("draggable"),uiSortable=$.extend({},ui,{item:inst.element});$.each(inst.sortables,function(){if(this.instance.isOver){this.instance.isOver=0;inst.cancelHelperRemoval=true;this.instance.cancelHelperRemoval=false;if(this.shouldRevert)this.instance.options.revert=true;this.instance._mouseStop(event);this.instance.options.helper=this.instance.options._helper;if(inst.options.helper=='original')
+this.instance.currentItem.css({top:'auto',left:'auto'});}else{this.instance.cancelHelperRemoval=false;this.instance._trigger("deactivate",event,uiSortable);}});},drag:function(event,ui){var inst=$(this).data("draggable"),self=this;var checkPos=function(o){var dyClick=this.offset.click.top,dxClick=this.offset.click.left;var helperTop=this.positionAbs.top,helperLeft=this.positionAbs.left;var itemHeight=o.height,itemWidth=o.width;var itemTop=o.top,itemLeft=o.left;return $.ui.isOver(helperTop+dyClick,helperLeft+dxClick,itemTop,itemLeft,itemHeight,itemWidth);};$.each(inst.sortables,function(i){this.instance.positionAbs=inst.positionAbs;this.instance.helperProportions=inst.helperProportions;this.instance.offset.click=inst.offset.click;if(this.instance._intersectsWith(this.instance.containerCache)){if(!this.instance.isOver){this.instance.isOver=1;this.instance.currentItem=$(self).clone().appendTo(this.instance.element).data("sortable-item",true);this.instance.options._helper=this.instance.options.helper;this.instance.options.helper=function(){return ui.helper[0];};event.target=this.instance.currentItem[0];this.instance._mouseCapture(event,true);this.instance._mouseStart(event,true,true);this.instance.offset.click.top=inst.offset.click.top;this.instance.offset.click.left=inst.offset.click.left;this.instance.offset.parent.left-=inst.offset.parent.left-this.instance.offset.parent.left;this.instance.offset.parent.top-=inst.offset.parent.top-this.instance.offset.parent.top;inst._trigger("toSortable",event);inst.dropped=this.instance.element;inst.currentItem=inst.element;this.instance.fromOutside=inst;}
+if(this.instance.currentItem)this.instance._mouseDrag(event);}else{if(this.instance.isOver){this.instance.isOver=0;this.instance.cancelHelperRemoval=true;this.instance.options.revert=false;this.instance._trigger('out',event,this.instance._uiHash(this.instance));this.instance._mouseStop(event,true);this.instance.options.helper=this.instance.options._helper;this.instance.currentItem.remove();if(this.instance.placeholder)this.instance.placeholder.remove();inst._trigger("fromSortable",event);inst.dropped=false;}};});}});$.ui.plugin.add("draggable","cursor",{start:function(event,ui){var t=$('body'),o=$(this).data('draggable').options;if(t.css("cursor"))o._cursor=t.css("cursor");t.css("cursor",o.cursor);},stop:function(event,ui){var o=$(this).data('draggable').options;if(o._cursor)$('body').css("cursor",o._cursor);}});$.ui.plugin.add("draggable","iframeFix",{start:function(event,ui){var o=$(this).data('draggable').options;$(o.iframeFix===true?"iframe":o.iframeFix).each(function(){$('<div class="ui-draggable-iframeFix" style="background: #fff;"></div>').css({width:this.offsetWidth+"px",height:this.offsetHeight+"px",position:"absolute",opacity:"0.001",zIndex:1000}).css($(this).offset()).appendTo("body");});},stop:function(event,ui){$("div.ui-draggable-iframeFix").each(function(){this.parentNode.removeChild(this);});}});$.ui.plugin.add("draggable","opacity",{start:function(event,ui){var t=$(ui.helper),o=$(this).data('draggable').options;if(t.css("opacity"))o._opacity=t.css("opacity");t.css('opacity',o.opacity);},stop:function(event,ui){var o=$(this).data('draggable').options;if(o._opacity)$(ui.helper).css('opacity',o._opacity);}});$.ui.plugin.add("draggable","scroll",{start:function(event,ui){var i=$(this).data("draggable");if(i.scrollParent[0]!=document&&i.scrollParent[0].tagName!='HTML')i.overflowOffset=i.scrollParent.offset();},drag:function(event,ui){var i=$(this).data("draggable"),o=i.options,scrolled=false;if(i.scrollParent[0]!=document&&i.scrollParent[0].tagName!='HTML'){if(!o.axis||o.axis!='x'){if((i.overflowOffset.top+i.scrollParent[0].offsetHeight)-event.pageY<o.scrollSensitivity)
+i.scrollParent[0].scrollTop=scrolled=i.scrollParent[0].scrollTop+o.scrollSpeed;else if(event.pageY-i.overflowOffset.top<o.scrollSensitivity)
+i.scrollParent[0].scrollTop=scrolled=i.scrollParent[0].scrollTop-o.scrollSpeed;}
+if(!o.axis||o.axis!='y'){if((i.overflowOffset.left+i.scrollParent[0].offsetWidth)-event.pageX<o.scrollSensitivity)
+i.scrollParent[0].scrollLeft=scrolled=i.scrollParent[0].scrollLeft+o.scrollSpeed;else if(event.pageX-i.overflowOffset.left<o.scrollSensitivity)
+i.scrollParent[0].scrollLeft=scrolled=i.scrollParent[0].scrollLeft-o.scrollSpeed;}}else{if(!o.axis||o.axis!='x'){if(event.pageY-$(document).scrollTop()<o.scrollSensitivity)
+scrolled=$(document).scrollTop($(document).scrollTop()-o.scrollSpeed);else if($(window).height()-(event.pageY-$(document).scrollTop())<o.scrollSensitivity)
+scrolled=$(document).scrollTop($(document).scrollTop()+o.scrollSpeed);}
+if(!o.axis||o.axis!='y'){if(event.pageX-$(document).scrollLeft()<o.scrollSensitivity)
+scrolled=$(document).scrollLeft($(document).scrollLeft()-o.scrollSpeed);else if($(window).width()-(event.pageX-$(document).scrollLeft())<o.scrollSensitivity)
+scrolled=$(document).scrollLeft($(document).scrollLeft()+o.scrollSpeed);}}
+if(scrolled!==false&&$.ui.ddmanager&&!o.dropBehaviour)
+$.ui.ddmanager.prepareOffsets(i,event);}});$.ui.plugin.add("draggable","snap",{start:function(event,ui){var i=$(this).data("draggable"),o=i.options;i.snapElements=[];$(o.snap.constructor!=String?(o.snap.items||':data(draggable)'):o.snap).each(function(){var $t=$(this);var $o=$t.offset();if(this!=i.element[0])i.snapElements.push({item:this,width:$t.outerWidth(),height:$t.outerHeight(),top:$o.top,left:$o.left});});},drag:function(event,ui){var inst=$(this).data("draggable"),o=inst.options;var d=o.snapTolerance;var x1=ui.offset.left,x2=x1+inst.helperProportions.width,y1=ui.offset.top,y2=y1+inst.helperProportions.height;for(var i=inst.snapElements.length-1;i>=0;i--){var l=inst.snapElements[i].left,r=l+inst.snapElements[i].width,t=inst.snapElements[i].top,b=t+inst.snapElements[i].height;if(!((l-d<x1&&x1<r+d&&t-d<y1&&y1<b+d)||(l-d<x1&&x1<r+d&&t-d<y2&&y2<b+d)||(l-d<x2&&x2<r+d&&t-d<y1&&y1<b+d)||(l-d<x2&&x2<r+d&&t-d<y2&&y2<b+d))){if(inst.snapElements[i].snapping)(inst.options.snap.release&&inst.options.snap.release.call(inst.element,event,$.extend(inst._uiHash(),{snapItem:inst.snapElements[i].item})));inst.snapElements[i].snapping=false;continue;}
+if(o.snapMode!='inner'){var ts=Math.abs(t-y2)<=d;var bs=Math.abs(b-y1)<=d;var ls=Math.abs(l-x2)<=d;var rs=Math.abs(r-x1)<=d;if(ts)ui.position.top=inst._convertPositionTo("relative",{top:t-inst.helperProportions.height,left:0}).top-inst.margins.top;if(bs)ui.position.top=inst._convertPositionTo("relative",{top:b,left:0}).top-inst.margins.top;if(ls)ui.position.left=inst._convertPositionTo("relative",{top:0,left:l-inst.helperProportions.width}).left-inst.margins.left;if(rs)ui.position.left=inst._convertPositionTo("relative",{top:0,left:r}).left-inst.margins.left;}
+var first=(ts||bs||ls||rs);if(o.snapMode!='outer'){var ts=Math.abs(t-y1)<=d;var bs=Math.abs(b-y2)<=d;var ls=Math.abs(l-x1)<=d;var rs=Math.abs(r-x2)<=d;if(ts)ui.position.top=inst._convertPositionTo("relative",{top:t,left:0}).top-inst.margins.top;if(bs)ui.position.top=inst._convertPositionTo("relative",{top:b-inst.helperProportions.height,left:0}).top-inst.margins.top;if(ls)ui.position.left=inst._convertPositionTo("relative",{top:0,left:l}).left-inst.margins.left;if(rs)ui.position.left=inst._convertPositionTo("relative",{top:0,left:r-inst.helperProportions.width}).left-inst.margins.left;}
+if(!inst.snapElements[i].snapping&&(ts||bs||ls||rs||first))
+(inst.options.snap.snap&&inst.options.snap.snap.call(inst.element,event,$.extend(inst._uiHash(),{snapItem:inst.snapElements[i].item})));inst.snapElements[i].snapping=(ts||bs||ls||rs||first);};}});$.ui.plugin.add("draggable","stack",{start:function(event,ui){var o=$(this).data("draggable").options;var group=$.makeArray($(o.stack.group)).sort(function(a,b){return(parseInt($(a).css("zIndex"),10)||o.stack.min)-(parseInt($(b).css("zIndex"),10)||o.stack.min);});$(group).each(function(i){this.style.zIndex=o.stack.min+i;});this[0].style.zIndex=o.stack.min+group.length;}});$.ui.plugin.add("draggable","zIndex",{start:function(event,ui){var t=$(ui.helper),o=$(this).data("draggable").options;if(t.css("zIndex"))o._zIndex=t.css("zIndex");t.css('zIndex',o.zIndex);},stop:function(event,ui){var o=$(this).data("draggable").options;if(o._zIndex)$(ui.helper).css('zIndex',o._zIndex);}});})(jQuery);(function($){$.widget("ui.droppable",{_init:function(){var o=this.options,accept=o.accept;this.isover=0;this.isout=1;this.options.accept=this.options.accept&&$.isFunction(this.options.accept)?this.options.accept:function(d){return d.is(accept);};this.proportions={width:this.element[0].offsetWidth,height:this.element[0].offsetHeight};$.ui.ddmanager.droppables[this.options.scope]=$.ui.ddmanager.droppables[this.options.scope]||[];$.ui.ddmanager.droppables[this.options.scope].push(this);(this.options.addClasses&&this.element.addClass("ui-droppable"));},destroy:function(){var drop=$.ui.ddmanager.droppables[this.options.scope];for(var i=0;i<drop.length;i++)
+if(drop[i]==this)
+drop.splice(i,1);this.element.removeClass("ui-droppable ui-droppable-disabled").removeData("droppable").unbind(".droppable");},_setData:function(key,value){if(key=='accept'){this.options.accept=value&&$.isFunction(value)?value:function(d){return d.is(value);};}else{$.widget.prototype._setData.apply(this,arguments);}},_activate:function(event){var draggable=$.ui.ddmanager.current;if(this.options.activeClass)this.element.addClass(this.options.activeClass);(draggable&&this._trigger('activate',event,this.ui(draggable)));},_deactivate:function(event){var draggable=$.ui.ddmanager.current;if(this.options.activeClass)this.element.removeClass(this.options.activeClass);(draggable&&this._trigger('deactivate',event,this.ui(draggable)));},_over:function(event){var draggable=$.ui.ddmanager.current;if(!draggable||(draggable.currentItem||draggable.element)[0]==this.element[0])return;if(this.options.accept.call(this.element[0],(draggable.currentItem||draggable.element))){if(this.options.hoverClass)this.element.addClass(this.options.hoverClass);this._trigger('over',event,this.ui(draggable));}},_out:function(event){var draggable=$.ui.ddmanager.current;if(!draggable||(draggable.currentItem||draggable.element)[0]==this.element[0])return;if(this.options.accept.call(this.element[0],(draggable.currentItem||draggable.element))){if(this.options.hoverClass)this.element.removeClass(this.options.hoverClass);this._trigger('out',event,this.ui(draggable));}},_drop:function(event,custom){var draggable=custom||$.ui.ddmanager.current;if(!draggable||(draggable.currentItem||draggable.element)[0]==this.element[0])return false;var childrenIntersection=false;this.element.find(":data(droppable)").not(".ui-draggable-dragging").each(function(){var inst=$.data(this,'droppable');if(inst.options.greedy&&$.ui.intersect(draggable,$.extend(inst,{offset:inst.element.offset()}),inst.options.tolerance)){childrenIntersection=true;return false;}});if(childrenIntersection)return false;if(this.options.accept.call(this.element[0],(draggable.currentItem||draggable.element))){if(this.options.activeClass)this.element.removeClass(this.options.activeClass);if(this.options.hoverClass)this.element.removeClass(this.options.hoverClass);this._trigger('drop',event,this.ui(draggable));return this.element;}
+return false;},ui:function(c){return{draggable:(c.currentItem||c.element),helper:c.helper,position:c.position,absolutePosition:c.positionAbs,offset:c.positionAbs};}});$.extend($.ui.droppable,{version:"1.7.2",eventPrefix:'drop',defaults:{accept:'*',activeClass:false,addClasses:true,greedy:false,hoverClass:false,scope:'default',tolerance:'intersect'}});$.ui.intersect=function(draggable,droppable,toleranceMode){if(!droppable.offset)return false;var x1=(draggable.positionAbs||draggable.position.absolute).left,x2=x1+draggable.helperProportions.width,y1=(draggable.positionAbs||draggable.position.absolute).top,y2=y1+draggable.helperProportions.height;var l=droppable.offset.left,r=l+droppable.proportions.width,t=droppable.offset.top,b=t+droppable.proportions.height;switch(toleranceMode){case'fit':return(l<x1&&x2<r&&t<y1&&y2<b);break;case'intersect':return(l<x1+(draggable.helperProportions.width/2)&&x2-(draggable.helperProportions.width/2)<r&&t<y1+(draggable.helperProportions.height/2)&&y2-(draggable.helperProportions.height/2)<b);break;case'pointer':var draggableLeft=((draggable.positionAbs||draggable.position.absolute).left+(draggable.clickOffset||draggable.offset.click).left),draggableTop=((draggable.positionAbs||draggable.position.absolute).top+(draggable.clickOffset||draggable.offset.click).top),isOver=$.ui.isOver(draggableTop,draggableLeft,t,l,droppable.proportions.height,droppable.proportions.width);return isOver;break;case'touch':return((y1>=t&&y1<=b)||(y2>=t&&y2<=b)||(y1<t&&y2>b))&&((x1>=l&&x1<=r)||(x2>=l&&x2<=r)||(x1<l&&x2>r));break;default:return false;break;}};$.ui.ddmanager={current:null,droppables:{'default':[]},prepareOffsets:function(t,event){var m=$.ui.ddmanager.droppables[t.options.scope];var type=event?event.type:null;var list=(t.currentItem||t.element).find(":data(droppable)").andSelf();droppablesLoop:for(var i=0;i<m.length;i++){if(m[i].options.disabled||(t&&!m[i].options.accept.call(m[i].element[0],(t.currentItem||t.element))))continue;for(var j=0;j<list.length;j++){if(list[j]==m[i].element[0]){m[i].proportions.height=0;continue droppablesLoop;}};m[i].visible=m[i].element.css("display")!="none";if(!m[i].visible)continue;m[i].offset=m[i].element.offset();m[i].proportions={width:m[i].element[0].offsetWidth,height:m[i].element[0].offsetHeight};if(type=="mousedown")m[i]._activate.call(m[i],event);}},drop:function(draggable,event){var dropped=false;$.each($.ui.ddmanager.droppables[draggable.options.scope],function(){if(!this.options)return;if(!this.options.disabled&&this.visible&&$.ui.intersect(draggable,this,this.options.tolerance))
+dropped=this._drop.call(this,event);if(!this.options.disabled&&this.visible&&this.options.accept.call(this.element[0],(draggable.currentItem||draggable.element))){this.isout=1;this.isover=0;this._deactivate.call(this,event);}});return dropped;},drag:function(draggable,event){if(draggable.options.refreshPositions)$.ui.ddmanager.prepareOffsets(draggable,event);$.each($.ui.ddmanager.droppables[draggable.options.scope],function(){if(this.options.disabled||this.greedyChild||!this.visible)return;var intersects=$.ui.intersect(draggable,this,this.options.tolerance);var c=!intersects&&this.isover==1?'isout':(intersects&&this.isover==0?'isover':null);if(!c)return;var parentInstance;if(this.options.greedy){var parent=this.element.parents(':data(droppable):eq(0)');if(parent.length){parentInstance=$.data(parent[0],'droppable');parentInstance.greedyChild=(c=='isover'?1:0);}}
+if(parentInstance&&c=='isover'){parentInstance['isover']=0;parentInstance['isout']=1;parentInstance._out.call(parentInstance,event);}
+this[c]=1;this[c=='isout'?'isover':'isout']=0;this[c=="isover"?"_over":"_out"].call(this,event);if(parentInstance&&c=='isout'){parentInstance['isout']=0;parentInstance['isover']=1;parentInstance._over.call(parentInstance,event);}});}};})(jQuery);(function($){$.widget("ui.resizable",$.extend({},$.ui.mouse,{_init:function(){var self=this,o=this.options;this.element.addClass("ui-resizable");$.extend(this,{_aspectRatio:!!(o.aspectRatio),aspectRatio:o.aspectRatio,originalElement:this.element,_proportionallyResizeElements:[],_helper:o.helper||o.ghost||o.animate?o.helper||'ui-resizable-helper':null});if(this.element[0].nodeName.match(/canvas|textarea|input|select|button|img/i)){if(/relative/.test(this.element.css('position'))&&$.browser.opera)
+this.element.css({position:'relative',top:'auto',left:'auto'});this.element.wrap($('<div class="ui-wrapper" style="overflow: hidden;"></div>').css({position:this.element.css('position'),width:this.element.outerWidth(),height:this.element.outerHeight(),top:this.element.css('top'),left:this.element.css('left')}));this.element=this.element.parent().data("resizable",this.element.data('resizable'));this.elementIsWrapper=true;this.element.css({marginLeft:this.originalElement.css("marginLeft"),marginTop:this.originalElement.css("marginTop"),marginRight:this.originalElement.css("marginRight"),marginBottom:this.originalElement.css("marginBottom")});this.originalElement.css({marginLeft:0,marginTop:0,marginRight:0,marginBottom:0});this.originalResizeStyle=this.originalElement.css('resize');this.originalElement.css('resize','none');this._proportionallyResizeElements.push(this.originalElement.css({position:'static',zoom:1,display:'block'}));this.originalElement.css({margin:this.originalElement.css('margin')});this._proportionallyResize();}
+this.handles=o.handles||(!$('.ui-resizable-handle',this.element).length?"e,s,se":{n:'.ui-resizable-n',e:'.ui-resizable-e',s:'.ui-resizable-s',w:'.ui-resizable-w',se:'.ui-resizable-se',sw:'.ui-resizable-sw',ne:'.ui-resizable-ne',nw:'.ui-resizable-nw'});if(this.handles.constructor==String){if(this.handles=='all')this.handles='n,e,s,w,se,sw,ne,nw';var n=this.handles.split(",");this.handles={};for(var i=0;i<n.length;i++){var handle=$.trim(n[i]),hname='ui-resizable-'+handle;var axis=$('<div class="ui-resizable-handle '+hname+'"></div>');if(/sw|se|ne|nw/.test(handle))axis.css({zIndex:++o.zIndex});if('se'==handle){axis.addClass('ui-icon ui-icon-gripsmall-diagonal-se');};this.handles[handle]='.ui-resizable-'+handle;this.element.append(axis);}}
+this._renderAxis=function(target){target=target||this.element;for(var i in this.handles){if(this.handles[i].constructor==String)
+this.handles[i]=$(this.handles[i],this.element).show();if(this.elementIsWrapper&&this.originalElement[0].nodeName.match(/textarea|input|select|button/i)){var axis=$(this.handles[i],this.element),padWrapper=0;padWrapper=/sw|ne|nw|se|n|s/.test(i)?axis.outerHeight():axis.outerWidth();var padPos=['padding',/ne|nw|n/.test(i)?'Top':/se|sw|s/.test(i)?'Bottom':/^e$/.test(i)?'Right':'Left'].join("");target.css(padPos,padWrapper);this._proportionallyResize();}
+if(!$(this.handles[i]).length)
+continue;}};this._renderAxis(this.element);this._handles=$('.ui-resizable-handle',this.element).disableSelection();this._handles.mouseover(function(){if(!self.resizing){if(this.className)
+var axis=this.className.match(/ui-resizable-(se|sw|ne|nw|n|e|s|w)/i);self.axis=axis&&axis[1]?axis[1]:'se';}});if(o.autoHide){this._handles.hide();$(this.element).addClass("ui-resizable-autohide").hover(function(){$(this).removeClass("ui-resizable-autohide");self._handles.show();},function(){if(!self.resizing){$(this).addClass("ui-resizable-autohide");self._handles.hide();}});}
+this._mouseInit();},destroy:function(){this._mouseDestroy();var _destroy=function(exp){$(exp).removeClass("ui-resizable ui-resizable-disabled ui-resizable-resizing").removeData("resizable").unbind(".resizable").find('.ui-resizable-handle').remove();};if(this.elementIsWrapper){_destroy(this.element);var wrapper=this.element;wrapper.parent().append(this.originalElement.css({position:wrapper.css('position'),width:wrapper.outerWidth(),height:wrapper.outerHeight(),top:wrapper.css('top'),left:wrapper.css('left')})).end().remove();}
+this.originalElement.css('resize',this.originalResizeStyle);_destroy(this.originalElement);},_mouseCapture:function(event){var handle=false;for(var i in this.handles){if($(this.handles[i])[0]==event.target)handle=true;}
+return this.options.disabled||!!handle;},_mouseStart:function(event){var o=this.options,iniPos=this.element.position(),el=this.element;this.resizing=true;this.documentScroll={top:$(document).scrollTop(),left:$(document).scrollLeft()};if(el.is('.ui-draggable')||(/absolute/).test(el.css('position'))){el.css({position:'absolute',top:iniPos.top,left:iniPos.left});}
+if($.browser.opera&&(/relative/).test(el.css('position')))
+el.css({position:'relative',top:'auto',left:'auto'});this._renderProxy();var curleft=num(this.helper.css('left')),curtop=num(this.helper.css('top'));if(o.containment){curleft+=$(o.containment).scrollLeft()||0;curtop+=$(o.containment).scrollTop()||0;}
+this.offset=this.helper.offset();this.position={left:curleft,top:curtop};this.size=this._helper?{width:el.outerWidth(),height:el.outerHeight()}:{width:el.width(),height:el.height()};this.originalSize=this._helper?{width:el.outerWidth(),height:el.outerHeight()}:{width:el.width(),height:el.height()};this.originalPosition={left:curleft,top:curtop};this.sizeDiff={width:el.outerWidth()-el.width(),height:el.outerHeight()-el.height()};this.originalMousePosition={left:event.pageX,top:event.pageY};this.aspectRatio=(typeof o.aspectRatio=='number')?o.aspectRatio:((this.originalSize.width/this.originalSize.height)||1);var cursor=$('.ui-resizable-'+this.axis).css('cursor');$('body').css('cursor',cursor=='auto'?this.axis+'-resize':cursor);el.addClass("ui-resizable-resizing");this._propagate("start",event);return true;},_mouseDrag:function(event){var el=this.helper,o=this.options,props={},self=this,smp=this.originalMousePosition,a=this.axis;var dx=(event.pageX-smp.left)||0,dy=(event.pageY-smp.top)||0;var trigger=this._change[a];if(!trigger)return false;var data=trigger.apply(this,[event,dx,dy]),ie6=$.browser.msie&&$.browser.version<7,csdif=this.sizeDiff;if(this._aspectRatio||event.shiftKey)
+data=this._updateRatio(data,event);data=this._respectSize(data,event);this._propagate("resize",event);el.css({top:this.position.top+"px",left:this.position.left+"px",width:this.size.width+"px",height:this.size.height+"px"});if(!this._helper&&this._proportionallyResizeElements.length)
+this._proportionallyResize();this._updateCache(data);this._trigger('resize',event,this.ui());return false;},_mouseStop:function(event){this.resizing=false;var o=this.options,self=this;if(this._helper){var pr=this._proportionallyResizeElements,ista=pr.length&&(/textarea/i).test(pr[0].nodeName),soffseth=ista&&$.ui.hasScroll(pr[0],'left')?0:self.sizeDiff.height,soffsetw=ista?0:self.sizeDiff.width;var s={width:(self.size.width-soffsetw),height:(self.size.height-soffseth)},left=(parseInt(self.element.css('left'),10)+(self.position.left-self.originalPosition.left))||null,top=(parseInt(self.element.css('top'),10)+(self.position.top-self.originalPosition.top))||null;if(!o.animate)
+this.element.css($.extend(s,{top:top,left:left}));self.helper.height(self.size.height);self.helper.width(self.size.width);if(this._helper&&!o.animate)this._proportionallyResize();}
+$('body').css('cursor','auto');this.element.removeClass("ui-resizable-resizing");this._propagate("stop",event);if(this._helper)this.helper.remove();return false;},_updateCache:function(data){var o=this.options;this.offset=this.helper.offset();if(isNumber(data.left))this.position.left=data.left;if(isNumber(data.top))this.position.top=data.top;if(isNumber(data.height))this.size.height=data.height;if(isNumber(data.width))this.size.width=data.width;},_updateRatio:function(data,event){var o=this.options,cpos=this.position,csize=this.size,a=this.axis;if(data.height)data.width=(csize.height*this.aspectRatio);else if(data.width)data.height=(csize.width/this.aspectRatio);if(a=='sw'){data.left=cpos.left+(csize.width-data.width);data.top=null;}
+if(a=='nw'){data.top=cpos.top+(csize.height-data.height);data.left=cpos.left+(csize.width-data.width);}
+return data;},_respectSize:function(data,event){var el=this.helper,o=this.options,pRatio=this._aspectRatio||event.shiftKey,a=this.axis,ismaxw=isNumber(data.width)&&o.maxWidth&&(o.maxWidth<data.width),ismaxh=isNumber(data.height)&&o.maxHeight&&(o.maxHeight<data.height),isminw=isNumber(data.width)&&o.minWidth&&(o.minWidth>data.width),isminh=isNumber(data.height)&&o.minHeight&&(o.minHeight>data.height);if(isminw)data.width=o.minWidth;if(isminh)data.height=o.minHeight;if(ismaxw)data.width=o.maxWidth;if(ismaxh)data.height=o.maxHeight;var dw=this.originalPosition.left+this.originalSize.width,dh=this.position.top+this.size.height;var cw=/sw|nw|w/.test(a),ch=/nw|ne|n/.test(a);if(isminw&&cw)data.left=dw-o.minWidth;if(ismaxw&&cw)data.left=dw-o.maxWidth;if(isminh&&ch)data.top=dh-o.minHeight;if(ismaxh&&ch)data.top=dh-o.maxHeight;var isNotwh=!data.width&&!data.height;if(isNotwh&&!data.left&&data.top)data.top=null;else if(isNotwh&&!data.top&&data.left)data.left=null;return data;},_proportionallyResize:function(){var o=this.options;if(!this._proportionallyResizeElements.length)return;var element=this.helper||this.element;for(var i=0;i<this._proportionallyResizeElements.length;i++){var prel=this._proportionallyResizeElements[i];if(!this.borderDif){var b=[prel.css('borderTopWidth'),prel.css('borderRightWidth'),prel.css('borderBottomWidth'),prel.css('borderLeftWidth')],p=[prel.css('paddingTop'),prel.css('paddingRight'),prel.css('paddingBottom'),prel.css('paddingLeft')];this.borderDif=$.map(b,function(v,i){var border=parseInt(v,10)||0,padding=parseInt(p[i],10)||0;return border+padding;});}
+if($.browser.msie&&!(!($(element).is(':hidden')||$(element).parents(':hidden').length)))
+continue;prel.css({height:(element.height()-this.borderDif[0]-this.borderDif[2])||0,width:(element.width()-this.borderDif[1]-this.borderDif[3])||0});};},_renderProxy:function(){var el=this.element,o=this.options;this.elementOffset=el.offset();if(this._helper){this.helper=this.helper||$('<div style="overflow:hidden;"></div>');var ie6=$.browser.msie&&$.browser.version<7,ie6offset=(ie6?1:0),pxyoffset=(ie6?2:-1);this.helper.addClass(this._helper).css({width:this.element.outerWidth()+pxyoffset,height:this.element.outerHeight()+pxyoffset,position:'absolute',left:this.elementOffset.left-ie6offset+'px',top:this.elementOffset.top-ie6offset+'px',zIndex:++o.zIndex});this.helper.appendTo("body").disableSelection();}else{this.helper=this.element;}},_change:{e:function(event,dx,dy){return{width:this.originalSize.width+dx};},w:function(event,dx,dy){var o=this.options,cs=this.originalSize,sp=this.originalPosition;return{left:sp.left+dx,width:cs.width-dx};},n:function(event,dx,dy){var o=this.options,cs=this.originalSize,sp=this.originalPosition;return{top:sp.top+dy,height:cs.height-dy};},s:function(event,dx,dy){return{height:this.originalSize.height+dy};},se:function(event,dx,dy){return $.extend(this._change.s.apply(this,arguments),this._change.e.apply(this,[event,dx,dy]));},sw:function(event,dx,dy){return $.extend(this._change.s.apply(this,arguments),this._change.w.apply(this,[event,dx,dy]));},ne:function(event,dx,dy){return $.extend(this._change.n.apply(this,arguments),this._change.e.apply(this,[event,dx,dy]));},nw:function(event,dx,dy){return $.extend(this._change.n.apply(this,arguments),this._change.w.apply(this,[event,dx,dy]));}},_propagate:function(n,event){$.ui.plugin.call(this,n,[event,this.ui()]);(n!="resize"&&this._trigger(n,event,this.ui()));},plugins:{},ui:function(){return{originalElement:this.originalElement,element:this.element,helper:this.helper,position:this.position,size:this.size,originalSize:this.originalSize,originalPosition:this.originalPosition};}}));$.extend($.ui.resizable,{version:"1.7.2",eventPrefix:"resize",defaults:{alsoResize:false,animate:false,animateDuration:"slow",animateEasing:"swing",aspectRatio:false,autoHide:false,cancel:":input,option",containment:false,delay:0,distance:1,ghost:false,grid:false,handles:"e,s,se",helper:false,maxHeight:null,maxWidth:null,minHeight:10,minWidth:10,zIndex:1000}});$.ui.plugin.add("resizable","alsoResize",{start:function(event,ui){var self=$(this).data("resizable"),o=self.options;_store=function(exp){$(exp).each(function(){$(this).data("resizable-alsoresize",{width:parseInt($(this).width(),10),height:parseInt($(this).height(),10),left:parseInt($(this).css('left'),10),top:parseInt($(this).css('top'),10)});});};if(typeof(o.alsoResize)=='object'&&!o.alsoResize.parentNode){if(o.alsoResize.length){o.alsoResize=o.alsoResize[0];_store(o.alsoResize);}
+else{$.each(o.alsoResize,function(exp,c){_store(exp);});}}else{_store(o.alsoResize);}},resize:function(event,ui){var self=$(this).data("resizable"),o=self.options,os=self.originalSize,op=self.originalPosition;var delta={height:(self.size.height-os.height)||0,width:(self.size.width-os.width)||0,top:(self.position.top-op.top)||0,left:(self.position.left-op.left)||0},_alsoResize=function(exp,c){$(exp).each(function(){var el=$(this),start=$(this).data("resizable-alsoresize"),style={},css=c&&c.length?c:['width','height','top','left'];$.each(css||['width','height','top','left'],function(i,prop){var sum=(start[prop]||0)+(delta[prop]||0);if(sum&&sum>=0)
+style[prop]=sum||null;});if(/relative/.test(el.css('position'))&&$.browser.opera){self._revertToRelativePosition=true;el.css({position:'absolute',top:'auto',left:'auto'});}
+el.css(style);});};if(typeof(o.alsoResize)=='object'&&!o.alsoResize.nodeType){$.each(o.alsoResize,function(exp,c){_alsoResize(exp,c);});}else{_alsoResize(o.alsoResize);}},stop:function(event,ui){var self=$(this).data("resizable");if(self._revertToRelativePosition&&$.browser.opera){self._revertToRelativePosition=false;el.css({position:'relative'});}
+$(this).removeData("resizable-alsoresize-start");}});$.ui.plugin.add("resizable","animate",{stop:function(event,ui){var self=$(this).data("resizable"),o=self.options;var pr=self._proportionallyResizeElements,ista=pr.length&&(/textarea/i).test(pr[0].nodeName),soffseth=ista&&$.ui.hasScroll(pr[0],'left')?0:self.sizeDiff.height,soffsetw=ista?0:self.sizeDiff.width;var style={width:(self.size.width-soffsetw),height:(self.size.height-soffseth)},left=(parseInt(self.element.css('left'),10)+(self.position.left-self.originalPosition.left))||null,top=(parseInt(self.element.css('top'),10)+(self.position.top-self.originalPosition.top))||null;self.element.animate($.extend(style,top&&left?{top:top,left:left}:{}),{duration:o.animateDuration,easing:o.animateEasing,step:function(){var data={width:parseInt(self.element.css('width'),10),height:parseInt(self.element.css('height'),10),top:parseInt(self.element.css('top'),10),left:parseInt(self.element.css('left'),10)};if(pr&&pr.length)$(pr[0]).css({width:data.width,height:data.height});self._updateCache(data);self._propagate("resize",event);}});}});$.ui.plugin.add("resizable","containment",{start:function(event,ui){var self=$(this).data("resizable"),o=self.options,el=self.element;var oc=o.containment,ce=(oc instanceof $)?oc.get(0):(/parent/.test(oc))?el.parent().get(0):oc;if(!ce)return;self.containerElement=$(ce);if(/document/.test(oc)||oc==document){self.containerOffset={left:0,top:0};self.containerPosition={left:0,top:0};self.parentData={element:$(document),left:0,top:0,width:$(document).width(),height:$(document).height()||document.body.parentNode.scrollHeight};}
+else{var element=$(ce),p=[];$(["Top","Right","Left","Bottom"]).each(function(i,name){p[i]=num(element.css("padding"+name));});self.containerOffset=element.offset();self.containerPosition=element.position();self.containerSize={height:(element.innerHeight()-p[3]),width:(element.innerWidth()-p[1])};var co=self.containerOffset,ch=self.containerSize.height,cw=self.containerSize.width,width=($.ui.hasScroll(ce,"left")?ce.scrollWidth:cw),height=($.ui.hasScroll(ce)?ce.scrollHeight:ch);self.parentData={element:ce,left:co.left,top:co.top,width:width,height:height};}},resize:function(event,ui){var self=$(this).data("resizable"),o=self.options,ps=self.containerSize,co=self.containerOffset,cs=self.size,cp=self.position,pRatio=self._aspectRatio||event.shiftKey,cop={top:0,left:0},ce=self.containerElement;if(ce[0]!=document&&(/static/).test(ce.css('position')))cop=co;if(cp.left<(self._helper?co.left:0)){self.size.width=self.size.width+(self._helper?(self.position.left-co.left):(self.position.left-cop.left));if(pRatio)self.size.height=self.size.width/o.aspectRatio;self.position.left=o.helper?co.left:0;}
+if(cp.top<(self._helper?co.top:0)){self.size.height=self.size.height+(self._helper?(self.position.top-co.top):self.position.top);if(pRatio)self.size.width=self.size.height*o.aspectRatio;self.position.top=self._helper?co.top:0;}
+self.offset.left=self.parentData.left+self.position.left;self.offset.top=self.parentData.top+self.position.top;var woset=Math.abs((self._helper?self.offset.left-cop.left:(self.offset.left-cop.left))+self.sizeDiff.width),hoset=Math.abs((self._helper?self.offset.top-cop.top:(self.offset.top-co.top))+self.sizeDiff.height);var isParent=self.containerElement.get(0)==self.element.parent().get(0),isOffsetRelative=/relative|absolute/.test(self.containerElement.css('position'));if(isParent&&isOffsetRelative)woset-=self.parentData.left;if(woset+self.size.width>=self.parentData.width){self.size.width=self.parentData.width-woset;if(pRatio)self.size.height=self.size.width/self.aspectRatio;}
+if(hoset+self.size.height>=self.parentData.height){self.size.height=self.parentData.height-hoset;if(pRatio)self.size.width=self.size.height*self.aspectRatio;}},stop:function(event,ui){var self=$(this).data("resizable"),o=self.options,cp=self.position,co=self.containerOffset,cop=self.containerPosition,ce=self.containerElement;var helper=$(self.helper),ho=helper.offset(),w=helper.outerWidth()-self.sizeDiff.width,h=helper.outerHeight()-self.sizeDiff.height;if(self._helper&&!o.animate&&(/relative/).test(ce.css('position')))
+$(this).css({left:ho.left-cop.left-co.left,width:w,height:h});if(self._helper&&!o.animate&&(/static/).test(ce.css('position')))
+$(this).css({left:ho.left-cop.left-co.left,width:w,height:h});}});$.ui.plugin.add("resizable","ghost",{start:function(event,ui){var self=$(this).data("resizable"),o=self.options,cs=self.size;self.ghost=self.originalElement.clone();self.ghost.css({opacity:.25,display:'block',position:'relative',height:cs.height,width:cs.width,margin:0,left:0,top:0}).addClass('ui-resizable-ghost').addClass(typeof o.ghost=='string'?o.ghost:'');self.ghost.appendTo(self.helper);},resize:function(event,ui){var self=$(this).data("resizable"),o=self.options;if(self.ghost)self.ghost.css({position:'relative',height:self.size.height,width:self.size.width});},stop:function(event,ui){var self=$(this).data("resizable"),o=self.options;if(self.ghost&&self.helper)self.helper.get(0).removeChild(self.ghost.get(0));}});$.ui.plugin.add("resizable","grid",{resize:function(event,ui){var self=$(this).data("resizable"),o=self.options,cs=self.size,os=self.originalSize,op=self.originalPosition,a=self.axis,ratio=o._aspectRatio||event.shiftKey;o.grid=typeof o.grid=="number"?[o.grid,o.grid]:o.grid;var ox=Math.round((cs.width-os.width)/(o.grid[0]||1))*(o.grid[0]||1),oy=Math.round((cs.height-os.height)/(o.grid[1]||1))*(o.grid[1]||1);if(/^(se|s|e)$/.test(a)){self.size.width=os.width+ox;self.size.height=os.height+oy;}
+else if(/^(ne)$/.test(a)){self.size.width=os.width+ox;self.size.height=os.height+oy;self.position.top=op.top-oy;}
+else if(/^(sw)$/.test(a)){self.size.width=os.width+ox;self.size.height=os.height+oy;self.position.left=op.left-ox;}
+else{self.size.width=os.width+ox;self.size.height=os.height+oy;self.position.top=op.top-oy;self.position.left=op.left-ox;}}});var num=function(v){return parseInt(v,10)||0;};var isNumber=function(value){return!isNaN(parseInt(value,10));};})(jQuery);(function($){$.widget("ui.selectable",$.extend({},$.ui.mouse,{_init:function(){var self=this;this.element.addClass("ui-selectable");this.dragged=false;var selectees;this.refresh=function(){selectees=$(self.options.filter,self.element[0]);selectees.each(function(){var $this=$(this);var pos=$this.offset();$.data(this,"selectable-item",{element:this,$element:$this,left:pos.left,top:pos.top,right:pos.left+$this.outerWidth(),bottom:pos.top+$this.outerHeight(),startselected:false,selected:$this.hasClass('ui-selected'),selecting:$this.hasClass('ui-selecting'),unselecting:$this.hasClass('ui-unselecting')});});};this.refresh();this.selectees=selectees.addClass("ui-selectee");this._mouseInit();this.helper=$(document.createElement('div')).css({border:'1px dotted black'}).addClass("ui-selectable-helper");},destroy:function(){this.element.removeClass("ui-selectable ui-selectable-disabled").removeData("selectable").unbind(".selectable");this._mouseDestroy();},_mouseStart:function(event){var self=this;this.opos=[event.pageX,event.pageY];if(this.options.disabled)
+return;var options=this.options;this.selectees=$(options.filter,this.element[0]);this._trigger("start",event);$(options.appendTo).append(this.helper);this.helper.css({"z-index":100,"position":"absolute","left":event.clientX,"top":event.clientY,"width":0,"height":0});if(options.autoRefresh){this.refresh();}
+this.selectees.filter('.ui-selected').each(function(){var selectee=$.data(this,"selectable-item");selectee.startselected=true;if(!event.metaKey){selectee.$element.removeClass('ui-selected');selectee.selected=false;selectee.$element.addClass('ui-unselecting');selectee.unselecting=true;self._trigger("unselecting",event,{unselecting:selectee.element});}});$(event.target).parents().andSelf().each(function(){var selectee=$.data(this,"selectable-item");if(selectee){selectee.$element.removeClass("ui-unselecting").addClass('ui-selecting');selectee.unselecting=false;selectee.selecting=true;selectee.selected=true;self._trigger("selecting",event,{selecting:selectee.element});return false;}});},_mouseDrag:function(event){var self=this;this.dragged=true;if(this.options.disabled)
+return;var options=this.options;var x1=this.opos[0],y1=this.opos[1],x2=event.pageX,y2=event.pageY;if(x1>x2){var tmp=x2;x2=x1;x1=tmp;}
+if(y1>y2){var tmp=y2;y2=y1;y1=tmp;}
+this.helper.css({left:x1,top:y1,width:x2-x1,height:y2-y1});this.selectees.each(function(){var selectee=$.data(this,"selectable-item");if(!selectee||selectee.element==self.element[0])
+return;var hit=false;if(options.tolerance=='touch'){hit=(!(selectee.left>x2||selectee.right<x1||selectee.top>y2||selectee.bottom<y1));}else if(options.tolerance=='fit'){hit=(selectee.left>x1&&selectee.right<x2&&selectee.top>y1&&selectee.bottom<y2);}
+if(hit){if(selectee.selected){selectee.$element.removeClass('ui-selected');selectee.selected=false;}
+if(selectee.unselecting){selectee.$element.removeClass('ui-unselecting');selectee.unselecting=false;}
+if(!selectee.selecting){selectee.$element.addClass('ui-selecting');selectee.selecting=true;self._trigger("selecting",event,{selecting:selectee.element});}}else{if(selectee.selecting){if(event.metaKey&&selectee.startselected){selectee.$element.removeClass('ui-selecting');selectee.selecting=false;selectee.$element.addClass('ui-selected');selectee.selected=true;}else{selectee.$element.removeClass('ui-selecting');selectee.selecting=false;if(selectee.startselected){selectee.$element.addClass('ui-unselecting');selectee.unselecting=true;}
+self._trigger("unselecting",event,{unselecting:selectee.element});}}
+if(selectee.selected){if(!event.metaKey&&!selectee.startselected){selectee.$element.removeClass('ui-selected');selectee.selected=false;selectee.$element.addClass('ui-unselecting');selectee.unselecting=true;self._trigger("unselecting",event,{unselecting:selectee.element});}}}});return false;},_mouseStop:function(event){var self=this;this.dragged=false;var options=this.options;$('.ui-unselecting',this.element[0]).each(function(){var selectee=$.data(this,"selectable-item");selectee.$element.removeClass('ui-unselecting');selectee.unselecting=false;selectee.startselected=false;self._trigger("unselected",event,{unselected:selectee.element});});$('.ui-selecting',this.element[0]).each(function(){var selectee=$.data(this,"selectable-item");selectee.$element.removeClass('ui-selecting').addClass('ui-selected');selectee.selecting=false;selectee.selected=true;selectee.startselected=true;self._trigger("selected",event,{selected:selectee.element});});this._trigger("stop",event);this.helper.remove();return false;}}));$.extend($.ui.selectable,{version:"1.7.2",defaults:{appendTo:'body',autoRefresh:true,cancel:":input,option",delay:0,distance:0,filter:'*',tolerance:'touch'}});})(jQuery);(function($){$.widget("ui.sortable",$.extend({},$.ui.mouse,{_init:function(){var o=this.options;this.containerCache={};this.element.addClass("ui-sortable");this.refresh();this.floating=this.items.length?(/left|right/).test(this.items[0].item.css('float')):false;this.offset=this.element.offset();this._mouseInit();},destroy:function(){this.element.removeClass("ui-sortable ui-sortable-disabled").removeData("sortable").unbind(".sortable");this._mouseDestroy();for(var i=this.items.length-1;i>=0;i--)
+this.items[i].item.removeData("sortable-item");},_mouseCapture:function(event,overrideHandle){if(this.reverting){return false;}
+if(this.options.disabled||this.options.type=='static')return false;this._refreshItems(event);var currentItem=null,self=this,nodes=$(event.target).parents().each(function(){if($.data(this,'sortable-item')==self){currentItem=$(this);return false;}});if($.data(event.target,'sortable-item')==self)currentItem=$(event.target);if(!currentItem)return false;if(this.options.handle&&!overrideHandle){var validHandle=false;$(this.options.handle,currentItem).find("*").andSelf().each(function(){if(this==event.target)validHandle=true;});if(!validHandle)return false;}
+this.currentItem=currentItem;this._removeCurrentsFromItems();return true;},_mouseStart:function(event,overrideHandle,noActivation){var o=this.options,self=this;this.currentContainer=this;this.refreshPositions();this.helper=this._createHelper(event);this._cacheHelperProportions();this._cacheMargins();this.scrollParent=this.helper.scrollParent();this.offset=this.currentItem.offset();this.offset={top:this.offset.top-this.margins.top,left:this.offset.left-this.margins.left};this.helper.css("position","absolute");this.cssPosition=this.helper.css("position");$.extend(this.offset,{click:{left:event.pageX-this.offset.left,top:event.pageY-this.offset.top},parent:this._getParentOffset(),relative:this._getRelativeOffset()});this.originalPosition=this._generatePosition(event);this.originalPageX=event.pageX;this.originalPageY=event.pageY;if(o.cursorAt)
+this._adjustOffsetFromHelper(o.cursorAt);this.domPosition={prev:this.currentItem.prev()[0],parent:this.currentItem.parent()[0]};if(this.helper[0]!=this.currentItem[0]){this.currentItem.hide();}
+this._createPlaceholder();if(o.containment)
+this._setContainment();if(o.cursor){if($('body').css("cursor"))this._storedCursor=$('body').css("cursor");$('body').css("cursor",o.cursor);}
+if(o.opacity){if(this.helper.css("opacity"))this._storedOpacity=this.helper.css("opacity");this.helper.css("opacity",o.opacity);}
+if(o.zIndex){if(this.helper.css("zIndex"))this._storedZIndex=this.helper.css("zIndex");this.helper.css("zIndex",o.zIndex);}
+if(this.scrollParent[0]!=document&&this.scrollParent[0].tagName!='HTML')
+this.overflowOffset=this.scrollParent.offset();this._trigger("start",event,this._uiHash());if(!this._preserveHelperProportions)
+this._cacheHelperProportions();if(!noActivation){for(var i=this.containers.length-1;i>=0;i--){this.containers[i]._trigger("activate",event,self._uiHash(this));}}
+if($.ui.ddmanager)
+$.ui.ddmanager.current=this;if($.ui.ddmanager&&!o.dropBehaviour)
+$.ui.ddmanager.prepareOffsets(this,event);this.dragging=true;this.helper.addClass("ui-sortable-helper");this._mouseDrag(event);return true;},_mouseDrag:function(event){this.position=this._generatePosition(event);this.positionAbs=this._convertPositionTo("absolute");if(!this.lastPositionAbs){this.lastPositionAbs=this.positionAbs;}
+if(this.options.scroll){var o=this.options,scrolled=false;if(this.scrollParent[0]!=document&&this.scrollParent[0].tagName!='HTML'){if((this.overflowOffset.top+this.scrollParent[0].offsetHeight)-event.pageY<o.scrollSensitivity)
+this.scrollParent[0].scrollTop=scrolled=this.scrollParent[0].scrollTop+o.scrollSpeed;else if(event.pageY-this.overflowOffset.top<o.scrollSensitivity)
+this.scrollParent[0].scrollTop=scrolled=this.scrollParent[0].scrollTop-o.scrollSpeed;if((this.overflowOffset.left+this.scrollParent[0].offsetWidth)-event.pageX<o.scrollSensitivity)
+this.scrollParent[0].scrollLeft=scrolled=this.scrollParent[0].scrollLeft+o.scrollSpeed;else if(event.pageX-this.overflowOffset.left<o.scrollSensitivity)
+this.scrollParent[0].scrollLeft=scrolled=this.scrollParent[0].scrollLeft-o.scrollSpeed;}else{if(event.pageY-$(document).scrollTop()<o.scrollSensitivity)
+scrolled=$(document).scrollTop($(document).scrollTop()+o.scrollSpeed);if(event.pageX-$(document).scrollLeft()<o.scrollSensitivity)
+$.ui.ddmanager.prepareOffsets(this,event);}
+this.positionAbs=this._convertPositionTo("absolute");if(!this.options.axis||this.options.axis!="y")this.helper[0].style.left=this.position.left+'px';if(!this.options.axis||this.options.axis!="x")this.helper[0].style.top=this.position.top+'px';for(var i=this.items.length-1;i>=0;i--){var item=this.items[i],itemElement=item.item[0],intersection=this._intersectsWithPointer(item);if(!intersection)continue;if(itemElement!=this.currentItem[0]&&this.placeholder[intersection==1?"next":"prev"]()[0]!=itemElement&&!$.ui.contains(this.placeholder[0],itemElement)&&(this.options.type=='semi-dynamic'?!$.ui.contains(this.element[0],itemElement):true)){this.direction=intersection==1?"down":"up";if(this.options.tolerance=="pointer"||this._intersectsWithSides(item)){this._rearrange(event,item);}else{break;}
+this._trigger("change",event,this._uiHash());break;}}
+this._contactContainers(event);if($.ui.ddmanager)$.ui.ddmanager.drag(this,event);this._trigger('sort',event,this._uiHash());this.lastPositionAbs=this.positionAbs;return false;},_mouseStop:function(event,noPropagation){if(!event)return;if($.ui.ddmanager&&!this.options.dropBehaviour)
+$.ui.ddmanager.drop(this,event);if(this.options.revert){var self=this;var cur=self.placeholder.offset();self.reverting=true;$(this.helper).animate({left:cur.left-this.offset.parent.left-self.margins.left+(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollLeft),top:cur.top-this.offset.parent.top-self.margins.top+(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollTop)},parseInt(this.options.revert,10)||500,function(){self._clear(event);});}else{this._clear(event,noPropagation);}
+return false;},cancel:function(){var self=this;if(this.dragging){this._mouseUp();if(this.options.helper=="original")
+this.currentItem.css(this._storedCSS).removeClass("ui-sortable-helper");else
+this.currentItem.show();for(var i=this.containers.length-1;i>=0;i--){this.containers[i]._trigger("deactivate",null,self._uiHash(this));if(this.containers[i].containerCache.over){this.containers[i]._trigger("out",null,self._uiHash(this));this.containers[i].containerCache.over=0;}}}
+if(this.placeholder[0].parentNode)this.placeholder[0].parentNode.removeChild(this.placeholder[0]);if(this.options.helper!="original"&&this.helper&&this.helper[0].parentNode)this.helper.remove();$.extend(this,{helper:null,dragging:false,reverting:false,_noFinalSort:null});if(this.domPosition.prev){$(this.domPosition.prev).after(this.currentItem);}else{$(this.domPosition.parent).prepend(this.currentItem);}
+return true;},serialize:function(o){var items=this._getItemsAsjQuery(o&&o.connected);var str=[];o=o||{};$(items).each(function(){var res=($(o.item||this).attr(o.attribute||'id')||'').match(o.expression||(/(.+)[-=_](.+)/));if(res)str.push((o.key||res[1]+'[]')+'='+(o.key&&o.expression?res[1]:res[2]));});return str.join('&');},toArray:function(o){var items=this._getItemsAsjQuery(o&&o.connected);var ret=[];o=o||{};items.each(function(){ret.push($(o.item||this).attr(o.attribute||'id')||'');});return ret;},_intersectsWith:function(item){var x1=this.positionAbs.left,x2=x1+this.helperProportions.width,y1=this.positionAbs.top,y2=y1+this.helperProportions.height;var l=item.left,r=l+item.width,t=item.top,b=t+item.height;var dyClick=this.offset.click.top,dxClick=this.offset.click.left;var isOverElement=(y1+dyClick)>t&&(y1+dyClick)<b&&(x1+dxClick)>l&&(x1+dxClick)<r;if(this.options.tolerance=="pointer"||this.options.forcePointerForContainers||(this.options.tolerance!="pointer"&&this.helperProportions[this.floating?'width':'height']>item[this.floating?'width':'height'])){return isOverElement;}else{return(l<x1+(this.helperProportions.width/2)&&x2-(this.helperProportions.width/2)<r&&t<y1+(this.helperProportions.height/2)&&y2-(this.helperProportions.height/2)<b);}},_intersectsWithPointer:function(item){var isOverElementHeight=$.ui.isOverAxis(this.positionAbs.top+this.offset.click.top,item.top,item.height),isOverElementWidth=$.ui.isOverAxis(this.positionAbs.left+this.offset.click.left,item.left,item.width),isOverElement=isOverElementHeight&&isOverElementWidth,verticalDirection=this._getDragVerticalDirection(),horizontalDirection=this._getDragHorizontalDirection();if(!isOverElement)
+return false;return this.floating?(((horizontalDirection&&horizontalDirection=="right")||verticalDirection=="down")?2:1):(verticalDirection&&(verticalDirection=="down"?2:1));},_intersectsWithSides:function(item){var isOverBottomHalf=$.ui.isOverAxis(this.positionAbs.top+this.offset.click.top,item.top+(item.height/2),item.height),isOverRightHalf=$.ui.isOverAxis(this.positionAbs.left+this.offset.click.left,item.left+(item.width/2),item.width),verticalDirection=this._getDragVerticalDirection(),horizontalDirection=this._getDragHorizontalDirection();if(this.floating&&horizontalDirection){return((horizontalDirection=="right"&&isOverRightHalf)||(horizontalDirection=="left"&&!isOverRightHalf));}else{return verticalDirection&&((verticalDirection=="down"&&isOverBottomHalf)||(verticalDirection=="up"&&!isOverBottomHalf));}},_getDragVerticalDirection:function(){var delta=this.positionAbs.top-this.lastPositionAbs.top;return delta!=0&&(delta>0?"down":"up");},_getDragHorizontalDirection:function(){var delta=this.positionAbs.left-this.lastPositionAbs.left;return delta!=0&&(delta>0?"right":"left");},refresh:function(event){this._refreshItems(event);this.refreshPositions();},_connectWith:function(){var options=this.options;return options.connectWith.constructor==String?[options.connectWith]:options.connectWith;},_getItemsAsjQuery:function(connected){var self=this;var items=[];var queries=[];var connectWith=this._connectWith();if(connectWith&&connected){for(var i=connectWith.length-1;i>=0;i--){var cur=$(connectWith[i]);for(var j=cur.length-1;j>=0;j--){var inst=$.data(cur[j],'sortable');if(inst&&inst!=this&&!inst.options.disabled){queries.push([$.isFunction(inst.options.items)?inst.options.items.call(inst.element):$(inst.options.items,inst.element).not(".ui-sortable-helper"),inst]);}};};}
+queries.push([$.isFunction(this.options.items)?this.options.items.call(this.element,null,{options:this.options,item:this.currentItem}):$(this.options.items,this.element).not(".ui-sortable-helper"),this]);for(var i=queries.length-1;i>=0;i--){queries[i][0].each(function(){items.push(this);});};return $(items);},_removeCurrentsFromItems:function(){var list=this.currentItem.find(":data(sortable-item)");for(var i=0;i<this.items.length;i++){for(var j=0;j<list.length;j++){if(list[j]==this.items[i].item[0])
+this.items.splice(i,1);};};},_refreshItems:function(event){this.items=[];this.containers=[this];var items=this.items;var self=this;var queries=[[$.isFunction(this.options.items)?this.options.items.call(this.element[0],event,{item:this.currentItem}):$(this.options.items,this.element),this]];var connectWith=this._connectWith();if(connectWith){for(var i=connectWith.length-1;i>=0;i--){var cur=$(connectWith[i]);for(var j=cur.length-1;j>=0;j--){var inst=$.data(cur[j],'sortable');if(inst&&inst!=this&&!inst.options.disabled){queries.push([$.isFunction(inst.options.items)?inst.options.items.call(inst.element[0],event,{item:this.currentItem}):$(inst.options.items,inst.element),inst]);this.containers.push(inst);}};};}
+for(var i=queries.length-1;i>=0;i--){var targetData=queries[i][1];var _queries=queries[i][0];for(var j=0,queriesLength=_queries.length;j<queriesLength;j++){var item=$(_queries[j]);item.data('sortable-item',targetData);items.push({item:item,instance:targetData,width:0,height:0,left:0,top:0});};};},refreshPositions:function(fast){if(this.offsetParent&&this.helper){this.offset.parent=this._getParentOffset();}
+for(var i=this.items.length-1;i>=0;i--){var item=this.items[i];if(item.instance!=this.currentContainer&&this.currentContainer&&item.item[0]!=this.currentItem[0])
+continue;var t=this.options.toleranceElement?$(this.options.toleranceElement,item.item):item.item;if(!fast){item.width=t.outerWidth();item.height=t.outerHeight();}
+var p=t.offset();item.left=p.left;item.top=p.top;};if(this.options.custom&&this.options.custom.refreshContainers){this.options.custom.refreshContainers.call(this);}else{for(var i=this.containers.length-1;i>=0;i--){var p=this.containers[i].element.offset();this.containers[i].containerCache.left=p.left;this.containers[i].containerCache.top=p.top;this.containers[i].containerCache.width=this.containers[i].element.outerWidth();this.containers[i].containerCache.height=this.containers[i].element.outerHeight();};}},_createPlaceholder:function(that){var self=that||this,o=self.options;if(!o.placeholder||o.placeholder.constructor==String){var className=o.placeholder;o.placeholder={element:function(){var el=$(document.createElement(self.currentItem[0].nodeName)).addClass(className||self.currentItem[0].className+" ui-sortable-placeholder").removeClass("ui-sortable-helper")[0];if(!className)
+el.style.visibility="hidden";return el;},update:function(container,p){if(className&&!o.forcePlaceholderSize)return;if(!p.height()){p.height(self.currentItem.innerHeight()-parseInt(self.currentItem.css('paddingTop')||0,10)-parseInt(self.currentItem.css('paddingBottom')||0,10));};if(!p.width()){p.width(self.currentItem.innerWidth()-parseInt(self.currentItem.css('paddingLeft')||0,10)-parseInt(self.currentItem.css('paddingRight')||0,10));};}};}
+self.placeholder=$(o.placeholder.element.call(self.element,self.currentItem));self.currentItem.after(self.placeholder);o.placeholder.update(self,self.placeholder);},_contactContainers:function(event){for(var i=this.containers.length-1;i>=0;i--){if(this._intersectsWith(this.containers[i].containerCache)){if(!this.containers[i].containerCache.over){if(this.currentContainer!=this.containers[i]){var dist=10000;var itemWithLeastDistance=null;var base=this.positionAbs[this.containers[i].floating?'left':'top'];for(var j=this.items.length-1;j>=0;j--){if(!$.ui.contains(this.containers[i].element[0],this.items[j].item[0]))continue;var cur=this.items[j][this.containers[i].floating?'left':'top'];if(Math.abs(cur-base)<dist){dist=Math.abs(cur-base);itemWithLeastDistance=this.items[j];}}
+if(!itemWithLeastDistance&&!this.options.dropOnEmpty)
+continue;this.currentContainer=this.containers[i];itemWithLeastDistance?this._rearrange(event,itemWithLeastDistance,null,true):this._rearrange(event,null,this.containers[i].element,true);this._trigger("change",event,this._uiHash());this.containers[i]._trigger("change",event,this._uiHash(this));this.options.placeholder.update(this.currentContainer,this.placeholder);}
+this.containers[i]._trigger("over",event,this._uiHash(this));this.containers[i].containerCache.over=1;}}else{if(this.containers[i].containerCache.over){this.containers[i]._trigger("out",event,this._uiHash(this));this.containers[i].containerCache.over=0;}}};},_createHelper:function(event){var o=this.options;var helper=$.isFunction(o.helper)?$(o.helper.apply(this.element[0],[event,this.currentItem])):(o.helper=='clone'?this.currentItem.clone():this.currentItem);if(!helper.parents('body').length)
+$(o.appendTo!='parent'?o.appendTo:this.currentItem[0].parentNode)[0].appendChild(helper[0]);if(helper[0]==this.currentItem[0])
+this._storedCSS={width:this.currentItem[0].style.width,height:this.currentItem[0].style.height,position:this.currentItem.css("position"),top:this.currentItem.css("top"),left:this.currentItem.css("left")};if(helper[0].style.width==''||o.forceHelperSize)helper.width(this.currentItem.width());if(helper[0].style.height==''||o.forceHelperSize)helper.height(this.currentItem.height());return helper;},_adjustOffsetFromHelper:function(obj){if(obj.left!=undefined)this.offset.click.left=obj.left+this.margins.left;if(obj.right!=undefined)this.offset.click.left=this.helperProportions.width-obj.right+this.margins.left;if(obj.top!=undefined)this.offset.click.top=obj.top+this.margins.top;if(obj.bottom!=undefined)this.offset.click.top=this.helperProportions.height-obj.bottom+this.margins.top;},_getParentOffset:function(){this.offsetParent=this.helper.offsetParent();var po=this.offsetParent.offset();if(this.cssPosition=='absolute'&&this.scrollParent[0]!=document&&$.ui.contains(this.scrollParent[0],this.offsetParent[0])){po.left+=this.scrollParent.scrollLeft();po.top+=this.scrollParent.scrollTop();}
+if((this.offsetParent[0]==document.body)||(this.offsetParent[0].tagName&&this.offsetParent[0].tagName.toLowerCase()=='html'&&$.browser.msie))
+po={top:0,left:0};return{top:po.top+(parseInt(this.offsetParent.css("borderTopWidth"),10)||0),left:po.left+(parseInt(this.offsetParent.css("borderLeftWidth"),10)||0)};},_getRelativeOffset:function(){if(this.cssPosition=="relative"){var p=this.currentItem.position();return{top:p.top-(parseInt(this.helper.css("top"),10)||0)+this.scrollParent.scrollTop(),left:p.left-(parseInt(this.helper.css("left"),10)||0)+this.scrollParent.scrollLeft()};}else{return{top:0,left:0};}},_cacheMargins:function(){this.margins={left:(parseInt(this.currentItem.css("marginLeft"),10)||0),top:(parseInt(this.currentItem.css("marginTop"),10)||0)};},_cacheHelperProportions:function(){this.helperProportions={width:this.helper.outerWidth(),height:this.helper.outerHeight()};},_setContainment:function(){var o=this.options;if(o.containment=='parent')o.containment=this.helper[0].parentNode;if(o.containment=='document'||o.containment=='window')this.containment=[0-this.offset.relative.left-this.offset.parent.left,0-this.offset.relative.top-this.offset.parent.top,$(o.containment=='document'?document:window).width()-this.helperProportions.width-this.margins.left,($(o.containment=='document'?document:window).height()||document.body.parentNode.scrollHeight)-this.helperProportions.height-this.margins.top];if(!(/^(document|window|parent)$/).test(o.containment)){var ce=$(o.containment)[0];var co=$(o.containment).offset();var over=($(ce).css("overflow")!='hidden');this.containment=[co.left+(parseInt($(ce).css("borderLeftWidth"),10)||0)+(parseInt($(ce).css("paddingLeft"),10)||0)-this.margins.left,co.top+(parseInt($(ce).css("borderTopWidth"),10)||0)+(parseInt($(ce).css("paddingTop"),10)||0)-this.margins.top,co.left+(over?Math.max(ce.scrollWidth,ce.offsetWidth):ce.offsetWidth)-(parseInt($(ce).css("borderLeftWidth"),10)||0)-(parseInt($(ce).css("paddingRight"),10)||0)-this.helperProportions.width-this.margins.left,co.top+(over?Math.max(ce.scrollHeight,ce.offsetHeight):ce.offsetHeight)-(parseInt($(ce).css("borderTopWidth"),10)||0)-(parseInt($(ce).css("paddingBottom"),10)||0)-this.helperProportions.height-this.margins.top];}},_convertPositionTo:function(d,pos){if(!pos)pos=this.position;var mod=d=="absolute"?1:-1;var o=this.options,scroll=this.cssPosition=='absolute'&&!(this.scrollParent[0]!=document&&$.ui.contains(this.scrollParent[0],this.offsetParent[0]))?this.offsetParent:this.scrollParent,scrollIsRootNode=(/(html|body)/i).test(scroll[0].tagName);return{top:(pos.top
++this.offset.relative.top*mod
++this.offset.parent.top*mod
+-($.browser.safari&&this.cssPosition=='fixed'?0:(this.cssPosition=='fixed'?-this.scrollParent.scrollTop():(scrollIsRootNode?0:scroll.scrollTop()))*mod)),left:(pos.left
++this.offset.relative.left*mod
++this.offset.parent.left*mod
+-($.browser.safari&&this.cssPosition=='fixed'?0:(this.cssPosition=='fixed'?-this.scrollParent.scrollLeft():scrollIsRootNode?0:scroll.scrollLeft())*mod))};},_generatePosition:function(event){var o=this.options,scroll=this.cssPosition=='absolute'&&!(this.scrollParent[0]!=document&&$.ui.contains(this.scrollParent[0],this.offsetParent[0]))?this.offsetParent:this.scrollParent,scrollIsRootNode=(/(html|body)/i).test(scroll[0].tagName);if(this.cssPosition=='relative'&&!(this.scrollParent[0]!=document&&this.scrollParent[0]!=this.offsetParent[0])){this.offset.relative=this._getRelativeOffset();}
+var pageX=event.pageX;var pageY=event.pageY;if(this.originalPosition){if(this.containment){if(event.pageX-this.offset.click.left<this.containment[0])pageX=this.containment[0]+this.offset.click.left;if(event.pageY-this.offset.click.top<this.containment[1])pageY=this.containment[1]+this.offset.click.top;if(event.pageX-this.offset.click.left>this.containment[2])pageX=this.containment[2]+this.offset.click.left;if(event.pageY-this.offset.click.top>this.containment[3])pageY=this.containment[3]+this.offset.click.top;}
+if(o.grid){var top=this.originalPageY+Math.round((pageY-this.originalPageY)/o.grid[1])*o.grid[1];pageY=this.containment?(!(top-this.offset.click.top<this.containment[1]||top-this.offset.click.top>this.containment[3])?top:(!(top-this.offset.click.top<this.containment[1])?top-o.grid[1]:top+o.grid[1])):top;var left=this.originalPageX+Math.round((pageX-this.originalPageX)/o.grid[0])*o.grid[0];pageX=this.containment?(!(left-this.offset.click.left<this.containment[0]||left-this.offset.click.left>this.containment[2])?left:(!(left-this.offset.click.left<this.containment[0])?left-o.grid[0]:left+o.grid[0])):left;}}
+return{top:(pageY
+-this.offset.click.top
+-this.offset.relative.top
+-this.offset.parent.top
++($.browser.safari&&this.cssPosition=='fixed'?0:(this.cssPosition=='fixed'?-this.scrollParent.scrollTop():(scrollIsRootNode?0:scroll.scrollTop())))),left:(pageX
+-this.offset.click.left
+-this.offset.relative.left
+-this.offset.parent.left
++($.browser.safari&&this.cssPosition=='fixed'?0:(this.cssPosition=='fixed'?-this.scrollParent.scrollLeft():scrollIsRootNode?0:scroll.scrollLeft())))};},_rearrange:function(event,i,a,hardRefresh){a?a[0].appendChild(this.placeholder[0]):i.item[0].parentNode.insertBefore(this.placeholder[0],(this.direction=='down'?i.item[0]:i.item[0].nextSibling));this.counter=this.counter?++this.counter:1;var self=this,counter=this.counter;window.setTimeout(function(){if(counter==self.counter)self.refreshPositions(!hardRefresh);},0);},_clear:function(event,noPropagation){this.reverting=false;var delayedTriggers=[],self=this;if(!this._noFinalSort&&this.currentItem[0].parentNode)this.placeholder.before(this.currentItem);this._noFinalSort=null;if(this.helper[0]==this.currentItem[0]){for(var i in this._storedCSS){if(this._storedCSS[i]=='auto'||this._storedCSS[i]=='static')this._storedCSS[i]='';}
+this.currentItem.css(this._storedCSS).removeClass("ui-sortable-helper");}else{this.currentItem.show();}
+if(this.fromOutside&&!noPropagation)delayedTriggers.push(function(event){this._trigger("receive",event,this._uiHash(this.fromOutside));});if((this.fromOutside||this.domPosition.prev!=this.currentItem.prev().not(".ui-sortable-helper")[0]||this.domPosition.parent!=this.currentItem.parent()[0])&&!noPropagation)delayedTriggers.push(function(event){this._trigger("update",event,this._uiHash());});if(!$.ui.contains(this.element[0],this.currentItem[0])){if(!noPropagation)delayedTriggers.push(function(event){this._trigger("remove",event,this._uiHash());});for(var i=this.containers.length-1;i>=0;i--){if($.ui.contains(this.containers[i].element[0],this.currentItem[0])&&!noPropagation){delayedTriggers.push((function(c){return function(event){c._trigger("receive",event,this._uiHash(this));};}).call(this,this.containers[i]));delayedTriggers.push((function(c){return function(event){c._trigger("update",event,this._uiHash(this));};}).call(this,this.containers[i]));}};};for(var i=this.containers.length-1;i>=0;i--){if(!noPropagation)delayedTriggers.push((function(c){return function(event){c._trigger("deactivate",event,this._uiHash(this));};}).call(this,this.containers[i]));if(this.containers[i].containerCache.over){delayedTriggers.push((function(c){return function(event){c._trigger("out",event,this._uiHash(this));};}).call(this,this.containers[i]));this.containers[i].containerCache.over=0;}}
+if(this._storedCursor)$('body').css("cursor",this._storedCursor);if(this._storedOpacity)this.helper.css("opacity",this._storedOpacity);if(this._storedZIndex)this.helper.css("zIndex",this._storedZIndex=='auto'?'':this._storedZIndex);this.dragging=false;if(this.cancelHelperRemoval){if(!noPropagation){this._trigger("beforeStop",event,this._uiHash());for(var i=0;i<delayedTriggers.length;i++){delayedTriggers[i].call(this,event);};this._trigger("stop",event,this._uiHash());}
+return false;}
+if(!noPropagation)this._trigger("beforeStop",event,this._uiHash());this.placeholder[0].parentNode.removeChild(this.placeholder[0]);if(this.helper[0]!=this.currentItem[0])this.helper.remove();this.helper=null;if(!noPropagation){for(var i=0;i<delayedTriggers.length;i++){delayedTriggers[i].call(this,event);};this._trigger("stop",event,this._uiHash());}
+this.fromOutside=false;return true;},_trigger:function(){if($.widget.prototype._trigger.apply(this,arguments)===false){this.cancel();}},_uiHash:function(inst){var self=inst||this;return{helper:self.helper,placeholder:self.placeholder||$([]),position:self.position,absolutePosition:self.positionAbs,offset:self.positionAbs,item:self.currentItem,sender:inst?inst.element:null};}}));$.extend($.ui.sortable,{getter:"serialize toArray",version:"1.7.2",eventPrefix:"sort",defaults:{appendTo:"parent",axis:false,cancel:":input,option",connectWith:false,containment:false,cursor:'auto',cursorAt:false,delay:0,distance:1,dropOnEmpty:true,forcePlaceholderSize:false,forceHelperSize:false,grid:false,handle:false,helper:"original",items:'> *',opacity:false,placeholder:false,revert:false,scroll:true,scrollSensitivity:20,scrollSpeed:20,scope:"default",tolerance:"intersect",zIndex:1000}});})(jQuery);(function($){$.widget("ui.accordion",{_init:function(){var o=this.options,self=this;this.running=0;if(o.collapsible==$.ui.accordion.defaults.collapsible&&o.alwaysOpen!=$.ui.accordion.defaults.alwaysOpen){o.collapsible=!o.alwaysOpen;}
+if(o.navigation){var current=this.element.find("a").filter(o.navigationFilter);if(current.length){if(current.filter(o.header).length){this.active=current;}else{this.active=current.parent().parent().prev();current.addClass("ui-accordion-content-active");}}}
+this.element.addClass("ui-accordion ui-widget ui-helper-reset");if(this.element[0].nodeName=="UL"){this.element.children("li").addClass("ui-accordion-li-fix");}
+this.headers=this.element.find(o.header).addClass("ui-accordion-header ui-helper-reset ui-state-default ui-corner-all").bind("mouseenter.accordion",function(){$(this).addClass('ui-state-hover');}).bind("mouseleave.accordion",function(){$(this).removeClass('ui-state-hover');}).bind("focus.accordion",function(){$(this).addClass('ui-state-focus');}).bind("blur.accordion",function(){$(this).removeClass('ui-state-focus');});this.headers.next().addClass("ui-accordion-content ui-helper-reset ui-widget-content ui-corner-bottom");this.active=this._findActive(this.active||o.active).toggleClass("ui-state-default").toggleClass("ui-state-active").toggleClass("ui-corner-all").toggleClass("ui-corner-top");this.active.next().addClass('ui-accordion-content-active');$("<span/>").addClass("ui-icon "+o.icons.header).prependTo(this.headers);this.active.find(".ui-icon").toggleClass(o.icons.header).toggleClass(o.icons.headerSelected);if($.browser.msie){this.element.find('a').css('zoom','1');}
+this.resize();this.element.attr('role','tablist');this.headers.attr('role','tab').bind('keydown',function(event){return self._keydown(event);}).next().attr('role','tabpanel');this.headers.not(this.active||"").attr('aria-expanded','false').attr("tabIndex","-1").next().hide();if(!this.active.length){this.headers.eq(0).attr('tabIndex','0');}else{this.active.attr('aria-expanded','true').attr('tabIndex','0');}
+if(!$.browser.safari)
+this.headers.find('a').attr('tabIndex','-1');if(o.event){this.headers.bind((o.event)+".accordion",function(event){return self._clickHandler.call(self,event,this);});}},destroy:function(){var o=this.options;this.element.removeClass("ui-accordion ui-widget ui-helper-reset").removeAttr("role").unbind('.accordion').removeData('accordion');this.headers.unbind(".accordion").removeClass("ui-accordion-header ui-helper-reset ui-state-default ui-corner-all ui-state-active ui-corner-top").removeAttr("role").removeAttr("aria-expanded").removeAttr("tabindex");this.headers.find("a").removeAttr("tabindex");this.headers.children(".ui-icon").remove();var contents=this.headers.next().css("display","").removeAttr("role").removeClass("ui-helper-reset ui-widget-content ui-corner-bottom ui-accordion-content ui-accordion-content-active");if(o.autoHeight||o.fillHeight){contents.css("height","");}},_setData:function(key,value){if(key=='alwaysOpen'){key='collapsible';value=!value;}
+$.widget.prototype._setData.apply(this,arguments);},_keydown:function(event){var o=this.options,keyCode=$.ui.keyCode;if(o.disabled||event.altKey||event.ctrlKey)
+return;var length=this.headers.length;var currentIndex=this.headers.index(event.target);var toFocus=false;switch(event.keyCode){case keyCode.RIGHT:case keyCode.DOWN:toFocus=this.headers[(currentIndex+1)%length];break;case keyCode.LEFT:case keyCode.UP:toFocus=this.headers[(currentIndex-1+length)%length];break;case keyCode.SPACE:case keyCode.ENTER:return this._clickHandler({target:event.target},event.target);}
+if(toFocus){$(event.target).attr('tabIndex','-1');$(toFocus).attr('tabIndex','0');toFocus.focus();return false;}
+return true;},resize:function(){var o=this.options,maxHeight;if(o.fillSpace){if($.browser.msie){var defOverflow=this.element.parent().css('overflow');this.element.parent().css('overflow','hidden');}
+maxHeight=this.element.parent().height();if($.browser.msie){this.element.parent().css('overflow',defOverflow);}
+this.headers.each(function(){maxHeight-=$(this).outerHeight();});var maxPadding=0;this.headers.next().each(function(){maxPadding=Math.max(maxPadding,$(this).innerHeight()-$(this).height());}).height(Math.max(0,maxHeight-maxPadding)).css('overflow','auto');}else if(o.autoHeight){maxHeight=0;this.headers.next().each(function(){maxHeight=Math.max(maxHeight,$(this).outerHeight());}).height(maxHeight);}},activate:function(index){var active=this._findActive(index)[0];this._clickHandler({target:active},active);},_findActive:function(selector){return selector?typeof selector=="number"?this.headers.filter(":eq("+selector+")"):this.headers.not(this.headers.not(selector)):selector===false?$([]):this.headers.filter(":eq(0)");},_clickHandler:function(event,target){var o=this.options;if(o.disabled)return false;if(!event.target&&o.collapsible){this.active.removeClass("ui-state-active ui-corner-top").addClass("ui-state-default ui-corner-all").find(".ui-icon").removeClass(o.icons.headerSelected).addClass(o.icons.header);this.active.next().addClass('ui-accordion-content-active');var toHide=this.active.next(),data={options:o,newHeader:$([]),oldHeader:o.active,newContent:$([]),oldContent:toHide},toShow=(this.active=$([]));this._toggle(toShow,toHide,data);return false;}
+var clicked=$(event.currentTarget||target);var clickedIsActive=clicked[0]==this.active[0];if(this.running||(!o.collapsible&&clickedIsActive)){return false;}
+this.active.removeClass("ui-state-active ui-corner-top").addClass("ui-state-default ui-corner-all").find(".ui-icon").removeClass(o.icons.headerSelected).addClass(o.icons.header);this.active.next().addClass('ui-accordion-content-active');if(!clickedIsActive){clicked.removeClass("ui-state-default ui-corner-all").addClass("ui-state-active ui-corner-top").find(".ui-icon").removeClass(o.icons.header).addClass(o.icons.headerSelected);clicked.next().addClass('ui-accordion-content-active');}
+var toShow=clicked.next(),toHide=this.active.next(),data={options:o,newHeader:clickedIsActive&&o.collapsible?$([]):clicked,oldHeader:this.active,newContent:clickedIsActive&&o.collapsible?$([]):toShow.find('> *'),oldContent:toHide.find('> *')},down=this.headers.index(this.active[0])>this.headers.index(clicked[0]);this.active=clickedIsActive?$([]):clicked;this._toggle(toShow,toHide,data,clickedIsActive,down);return false;},_toggle:function(toShow,toHide,data,clickedIsActive,down){var o=this.options,self=this;this.toShow=toShow;this.toHide=toHide;this.data=data;var complete=function(){if(!self)return;return self._completed.apply(self,arguments);};this._trigger("changestart",null,this.data);this.running=toHide.size()===0?toShow.size():toHide.size();if(o.animated){var animOptions={};if(o.collapsible&&clickedIsActive){animOptions={toShow:$([]),toHide:toHide,complete:complete,down:down,autoHeight:o.autoHeight||o.fillSpace};}else{animOptions={toShow:toShow,toHide:toHide,complete:complete,down:down,autoHeight:o.autoHeight||o.fillSpace};}
+if(!o.proxied){o.proxied=o.animated;}
+if(!o.proxiedDuration){o.proxiedDuration=o.duration;}
+o.animated=$.isFunction(o.proxied)?o.proxied(animOptions):o.proxied;o.duration=$.isFunction(o.proxiedDuration)?o.proxiedDuration(animOptions):o.proxiedDuration;var animations=$.ui.accordion.animations,duration=o.duration,easing=o.animated;if(!animations[easing]){animations[easing]=function(options){this.slide(options,{easing:easing,duration:duration||700});};}
+animations[easing](animOptions);}else{if(o.collapsible&&clickedIsActive){toShow.toggle();}else{toHide.hide();toShow.show();}
+complete(true);}
+toHide.prev().attr('aria-expanded','false').attr("tabIndex","-1").blur();toShow.prev().attr('aria-expanded','true').attr("tabIndex","0").focus();},_completed:function(cancel){var o=this.options;this.running=cancel?0:--this.running;if(this.running)return;if(o.clearStyle){this.toShow.add(this.toHide).css({height:"",overflow:""});}
+this._trigger('change',null,this.data);}});$.extend($.ui.accordion,{version:"1.7.2",defaults:{active:null,alwaysOpen:true,animated:'slide',autoHeight:true,clearStyle:false,collapsible:false,event:"click",fillSpace:false,header:"> li > :first-child,> :not(li):even",icons:{header:"ui-icon-triangle-1-e",headerSelected:"ui-icon-triangle-1-s"},navigation:false,navigationFilter:function(){return this.href.toLowerCase()==location.href.toLowerCase();}},animations:{slide:function(options,additions){options=$.extend({easing:"swing",duration:300},options,additions);if(!options.toHide.size()){options.toShow.animate({height:"show"},options);return;}
+if(!options.toShow.size()){options.toHide.animate({height:"hide"},options);return;}
+var overflow=options.toShow.css('overflow'),percentDone,showProps={},hideProps={},fxAttrs=["height","paddingTop","paddingBottom"],originalWidth;var s=options.toShow;originalWidth=s[0].style.width;s.width(parseInt(s.parent().width(),10)-parseInt(s.css("paddingLeft"),10)-parseInt(s.css("paddingRight"),10)-(parseInt(s.css("borderLeftWidth"),10)||0)-(parseInt(s.css("borderRightWidth"),10)||0));$.each(fxAttrs,function(i,prop){hideProps[prop]='hide';var parts=(''+$.css(options.toShow[0],prop)).match(/^([\d+-.]+)(.*)$/);showProps[prop]={value:parts[1],unit:parts[2]||'px'};});options.toShow.css({height:0,overflow:'hidden'}).show();options.toHide.filter(":hidden").each(options.complete).end().filter(":visible").animate(hideProps,{step:function(now,settings){if(settings.prop=='height'){percentDone=(settings.now-settings.start)/(settings.end-settings.start);}
+options.toShow[0].style[settings.prop]=(percentDone*showProps[settings.prop].value)+showProps[settings.prop].unit;},duration:options.duration,easing:options.easing,complete:function(){if(!options.autoHeight){options.toShow.css("height","");}
+options.toShow.css("width",originalWidth);options.toShow.css({overflow:overflow});options.complete();}});},bounceslide:function(options){this.slide(options,{easing:options.down?"easeOutBounce":"swing",duration:options.down?1000:200});},easeslide:function(options){this.slide(options,{easing:"easeinout",duration:700});}}});})(jQuery);(function($){var setDataSwitch={dragStart:"start.draggable",drag:"drag.draggable",dragStop:"stop.draggable",maxHeight:"maxHeight.resizable",minHeight:"minHeight.resizable",maxWidth:"maxWidth.resizable",minWidth:"minWidth.resizable",resizeStart:"start.resizable",resize:"drag.resizable",resizeStop:"stop.resizable"},uiDialogClasses='ui-dialog '+'ui-widget '+'ui-widget-content '+'ui-corner-all ';$.widget("ui.dialog",{_init:function(){this.originalTitle=this.element.attr('title');var self=this,options=this.options,title=options.title||this.originalTitle||'&nbsp;',titleId=$.ui.dialog.getTitleId(this.element),uiDialog=(this.uiDialog=$('<div/>')).appendTo(document.body).hide().addClass(uiDialogClasses+options.dialogClass).css({position:'absolute',overflow:'hidden',zIndex:options.zIndex}).attr('tabIndex',-1).css('outline',0).keydown(function(event){(options.closeOnEscape&&event.keyCode&&event.keyCode==$.ui.keyCode.ESCAPE&&self.close(event));}).attr({role:'dialog','aria-labelledby':titleId}).mousedown(function(event){self.moveToTop(false,event);}),uiDialogContent=this.element.show().removeAttr('title').addClass('ui-dialog-content '+'ui-widget-content').appendTo(uiDialog),uiDialogTitlebar=(this.uiDialogTitlebar=$('<div></div>')).addClass('ui-dialog-titlebar '+'ui-widget-header '+'ui-corner-all '+'ui-helper-clearfix').prependTo(uiDialog),uiDialogTitlebarClose=$('<a href="#"/>').addClass('ui-dialog-titlebar-close '+'ui-corner-all').attr('role','button').hover(function(){uiDialogTitlebarClose.addClass('ui-state-hover');},function(){uiDialogTitlebarClose.removeClass('ui-state-hover');}).focus(function(){uiDialogTitlebarClose.addClass('ui-state-focus');}).blur(function(){uiDialogTitlebarClose.removeClass('ui-state-focus');}).mousedown(function(ev){ev.stopPropagation();}).click(function(event){self.close(event);return false;}).appendTo(uiDialogTitlebar),uiDialogTitlebarCloseText=(this.uiDialogTitlebarCloseText=$('<span/>')).addClass('ui-icon '+'ui-icon-closethick').text(options.closeText).appendTo(uiDialogTitlebarClose),uiDialogTitle=$('<span/>').addClass('ui-dialog-title').attr('id',titleId).html(title).prependTo(uiDialogTitlebar);uiDialogTitlebar.find("*").add(uiDialogTitlebar).disableSelection();(options.draggable&&$.fn.draggable&&this._makeDraggable());(options.resizable&&$.fn.resizable&&this._makeResizable());this._createButtons(options.buttons);this._isOpen=false;(options.bgiframe&&$.fn.bgiframe&&uiDialog.bgiframe());(options.autoOpen&&this.open());},destroy:function(){(this.overlay&&this.overlay.destroy());this.uiDialog.hide();this.element.unbind('.dialog').removeData('dialog').removeClass('ui-dialog-content ui-widget-content').hide().appendTo('body');this.uiDialog.remove();(this.originalTitle&&this.element.attr('title',this.originalTitle));},close:function(event){var self=this;if(false===self._trigger('beforeclose',event)){return;}
+(self.overlay&&self.overlay.destroy());self.uiDialog.unbind('keypress.ui-dialog');(self.options.hide?self.uiDialog.hide(self.options.hide,function(){self._trigger('close',event);}):self.uiDialog.hide()&&self._trigger('close',event));$.ui.dialog.overlay.resize();self._isOpen=false;if(self.options.modal){var maxZ=0;$('.ui-dialog').each(function(){if(this!=self.uiDialog[0]){maxZ=Math.max(maxZ,$(this).css('z-index'));}});$.ui.dialog.maxZ=maxZ;}},isOpen:function(){return this._isOpen;},moveToTop:function(force,event){if((this.options.modal&&!force)||(!this.options.stack&&!this.options.modal)){return this._trigger('focus',event);}
+if(this.options.zIndex>$.ui.dialog.maxZ){$.ui.dialog.maxZ=this.options.zIndex;}
+(this.overlay&&this.overlay.$el.css('z-index',$.ui.dialog.overlay.maxZ=++$.ui.dialog.maxZ));var saveScroll={scrollTop:this.element.attr('scrollTop'),scrollLeft:this.element.attr('scrollLeft')};this.uiDialog.css('z-index',++$.ui.dialog.maxZ);this.element.attr(saveScroll);this._trigger('focus',event);},open:function(){if(this._isOpen){return;}
+var options=this.options,uiDialog=this.uiDialog;this.overlay=options.modal?new $.ui.dialog.overlay(this):null;(uiDialog.next().length&&uiDialog.appendTo('body'));this._size();this._position(options.position);uiDialog.show(options.show);this.moveToTop(true);(options.modal&&uiDialog.bind('keypress.ui-dialog',function(event){if(event.keyCode!=$.ui.keyCode.TAB){return;}
+var tabbables=$(':tabbable',this),first=tabbables.filter(':first')[0],last=tabbables.filter(':last')[0];if(event.target==last&&!event.shiftKey){setTimeout(function(){first.focus();},1);}else if(event.target==first&&event.shiftKey){setTimeout(function(){last.focus();},1);}}));$([]).add(uiDialog.find('.ui-dialog-content :tabbable:first')).add(uiDialog.find('.ui-dialog-buttonpane :tabbable:first')).add(uiDialog).filter(':first').focus();this._trigger('open');this._isOpen=true;},_createButtons:function(buttons){var self=this,hasButtons=false,uiDialogButtonPane=$('<div></div>').addClass('ui-dialog-buttonpane '+'ui-widget-content '+'ui-helper-clearfix');this.uiDialog.find('.ui-dialog-buttonpane').remove();(typeof buttons=='object'&&buttons!==null&&$.each(buttons,function(){return!(hasButtons=true);}));if(hasButtons){$.each(buttons,function(name,fn){$('<button type="button"></button>').addClass('ui-state-default '+'ui-corner-all').text(name).click(function(){fn.apply(self.element[0],arguments);}).hover(function(){$(this).addClass('ui-state-hover');},function(){$(this).removeClass('ui-state-hover');}).focus(function(){$(this).addClass('ui-state-focus');}).blur(function(){$(this).removeClass('ui-state-focus');}).appendTo(uiDialogButtonPane);});uiDialogButtonPane.appendTo(this.uiDialog);}},_makeDraggable:function(){var self=this,options=this.options,heightBeforeDrag;this.uiDialog.draggable({cancel:'.ui-dialog-content',handle:'.ui-dialog-titlebar',containment:'document',start:function(){heightBeforeDrag=options.height;$(this).height($(this).height()).addClass("ui-dialog-dragging");(options.dragStart&&options.dragStart.apply(self.element[0],arguments));},drag:function(){(options.drag&&options.drag.apply(self.element[0],arguments));},stop:function(){$(this).removeClass("ui-dialog-dragging").height(heightBeforeDrag);(options.dragStop&&options.dragStop.apply(self.element[0],arguments));$.ui.dialog.overlay.resize();}});},_makeResizable:function(handles){handles=(handles===undefined?this.options.resizable:handles);var self=this,options=this.options,resizeHandles=typeof handles=='string'?handles:'n,e,s,w,se,sw,ne,nw';this.uiDialog.resizable({cancel:'.ui-dialog-content',alsoResize:this.element,maxWidth:options.maxWidth,maxHeight:options.maxHeight,minWidth:options.minWidth,minHeight:options.minHeight,start:function(){$(this).addClass("ui-dialog-resizing");(options.resizeStart&&options.resizeStart.apply(self.element[0],arguments));},resize:function(){(options.resize&&options.resize.apply(self.element[0],arguments));},handles:resizeHandles,stop:function(){$(this).removeClass("ui-dialog-resizing");options.height=$(this).height();options.width=$(this).width();(options.resizeStop&&options.resizeStop.apply(self.element[0],arguments));$.ui.dialog.overlay.resize();}}).find('.ui-resizable-se').addClass('ui-icon ui-icon-grip-diagonal-se');},_position:function(pos){var wnd=$(window),doc=$(document),pTop=doc.scrollTop(),pLeft=doc.scrollLeft(),minTop=pTop;if($.inArray(pos,['center','top','right','bottom','left'])>=0){pos=[pos=='right'||pos=='left'?pos:'center',pos=='top'||pos=='bottom'?pos:'middle'];}
+if(pos.constructor!=Array){pos=['center','middle'];}
+if(pos[0].constructor==Number){pLeft+=pos[0];}else{switch(pos[0]){case'left':pLeft+=0;break;case'right':pLeft+=wnd.width()-this.uiDialog.outerWidth();break;default:case'center':pLeft+=(wnd.width()-this.uiDialog.outerWidth())/2;}}
+if(pos[1].constructor==Number){pTop+=pos[1];}else{switch(pos[1]){case'top':pTop+=0;break;case'bottom':pTop+=wnd.height()-this.uiDialog.outerHeight();break;default:case'middle':pTop+=(wnd.height()-this.uiDialog.outerHeight())/2;}}
+pTop=Math.max(pTop,minTop);this.uiDialog.css({top:pTop,left:pLeft});},_setData:function(key,value){(setDataSwitch[key]&&this.uiDialog.data(setDataSwitch[key],value));switch(key){case"buttons":this._createButtons(value);break;case"closeText":this.uiDialogTitlebarCloseText.text(value);break;case"dialogClass":this.uiDialog.removeClass(this.options.dialogClass).addClass(uiDialogClasses+value);break;case"draggable":(value?this._makeDraggable():this.uiDialog.draggable('destroy'));break;case"height":this.uiDialog.height(value);break;case"position":this._position(value);break;case"resizable":var uiDialog=this.uiDialog,isResizable=this.uiDialog.is(':data(resizable)');(isResizable&&!value&&uiDialog.resizable('destroy'));(isResizable&&typeof value=='string'&&uiDialog.resizable('option','handles',value));(isResizable||this._makeResizable(value));break;case"title":$(".ui-dialog-title",this.uiDialogTitlebar).html(value||'&nbsp;');break;case"width":this.uiDialog.width(value);break;}
+$.widget.prototype._setData.apply(this,arguments);},_size:function(){var options=this.options;this.element.css({height:0,minHeight:0,width:'auto'});var nonContentHeight=this.uiDialog.css({height:'auto',width:options.width}).height();this.element.css({minHeight:Math.max(options.minHeight-nonContentHeight,0),height:options.height=='auto'?'auto':Math.max(options.height-nonContentHeight,0)});}});$.extend($.ui.dialog,{version:"1.7.2",defaults:{autoOpen:true,bgiframe:false,buttons:{},closeOnEscape:true,closeText:'close',dialogClass:'',draggable:true,hide:null,height:'auto',maxHeight:false,maxWidth:false,minHeight:150,minWidth:150,modal:false,position:'center',resizable:true,show:null,stack:true,title:'',width:300,zIndex:1000},getter:'isOpen',uuid:0,maxZ:0,getTitleId:function($el){return'ui-dialog-title-'+($el.attr('id')||++this.uuid);},overlay:function(dialog){this.$el=$.ui.dialog.overlay.create(dialog);}});$.extend($.ui.dialog.overlay,{instances:[],maxZ:0,events:$.map('focus,mousedown,mouseup,keydown,keypress,click'.split(','),function(event){return event+'.dialog-overlay';}).join(' '),create:function(dialog){if(this.instances.length===0){setTimeout(function(){if($.ui.dialog.overlay.instances.length){$(document).bind($.ui.dialog.overlay.events,function(event){var dialogZ=$(event.target).parents('.ui-dialog').css('zIndex')||0;return(dialogZ>$.ui.dialog.overlay.maxZ);});}},1);$(document).bind('keydown.dialog-overlay',function(event){(dialog.options.closeOnEscape&&event.keyCode&&event.keyCode==$.ui.keyCode.ESCAPE&&dialog.close(event));});$(window).bind('resize.dialog-overlay',$.ui.dialog.overlay.resize);}
+var $el=$('<div></div>').appendTo(document.body).addClass('ui-widget-overlay').css({width:this.width(),height:this.height()});(dialog.options.bgiframe&&$.fn.bgiframe&&$el.bgiframe());this.instances.push($el);return $el;},destroy:function($el){this.instances.splice($.inArray(this.instances,$el),1);if(this.instances.length===0){$([document,window]).unbind('.dialog-overlay');}
+$el.remove();var maxZ=0;$.each(this.instances,function(){maxZ=Math.max(maxZ,this.css('z-index'));});this.maxZ=maxZ;},height:function(){if($.browser.msie&&$.browser.version<7){var scrollHeight=Math.max(document.documentElement.scrollHeight,document.body.scrollHeight);var offsetHeight=Math.max(document.documentElement.offsetHeight,document.body.offsetHeight);if(scrollHeight<offsetHeight){return $(window).height()+'px';}else{return scrollHeight+'px';}}else{return $(document).height()+'px';}},width:function(){if($.browser.msie&&$.browser.version<7){var scrollWidth=Math.max(document.documentElement.scrollWidth,document.body.scrollWidth);var offsetWidth=Math.max(document.documentElement.offsetWidth,document.body.offsetWidth);if(scrollWidth<offsetWidth){return $(window).width()+'px';}else{return scrollWidth+'px';}}else{return $(document).width()+'px';}},resize:function(){var $overlays=$([]);$.each($.ui.dialog.overlay.instances,function(){$overlays=$overlays.add(this);});$overlays.css({width:0,height:0}).css({width:$.ui.dialog.overlay.width(),height:$.ui.dialog.overlay.height()});}});$.extend($.ui.dialog.overlay.prototype,{destroy:function(){$.ui.dialog.overlay.destroy(this.$el);}});})(jQuery);(function($){$.widget("ui.slider",$.extend({},$.ui.mouse,{_init:function(){var self=this,o=this.options;this._keySliding=false;this._handleIndex=null;this._detectOrientation();this._mouseInit();this.element.addClass("ui-slider"
++" ui-slider-"+this.orientation
++" ui-widget"
++" ui-widget-content"
++" ui-corner-all");this.range=$([]);if(o.range){if(o.range===true){this.range=$('<div></div>');if(!o.values)o.values=[this._valueMin(),this._valueMin()];if(o.values.length&&o.values.length!=2){o.values=[o.values[0],o.values[0]];}}else{this.range=$('<div></div>');}
+this.range.appendTo(this.element).addClass("ui-slider-range");if(o.range=="min"||o.range=="max"){this.range.addClass("ui-slider-range-"+o.range);}
+this.range.addClass("ui-widget-header");}
+if($(".ui-slider-handle",this.element).length==0)
+$('<a href="#"></a>').appendTo(this.element).addClass("ui-slider-handle");if(o.values&&o.values.length){while($(".ui-slider-handle",this.element).length<o.values.length)
+$('<a href="#"></a>').appendTo(this.element).addClass("ui-slider-handle");}
+this.handles=$(".ui-slider-handle",this.element).addClass("ui-state-default"
++" ui-corner-all");this.handle=this.handles.eq(0);this.handles.add(this.range).filter("a").click(function(event){event.preventDefault();}).hover(function(){if(!o.disabled){$(this).addClass('ui-state-hover');}},function(){$(this).removeClass('ui-state-hover');}).focus(function(){if(!o.disabled){$(".ui-slider .ui-state-focus").removeClass('ui-state-focus');$(this).addClass('ui-state-focus');}else{$(this).blur();}}).blur(function(){$(this).removeClass('ui-state-focus');});this.handles.each(function(i){$(this).data("index.ui-slider-handle",i);});this.handles.keydown(function(event){var ret=true;var index=$(this).data("index.ui-slider-handle");if(self.options.disabled)
+return;switch(event.keyCode){case $.ui.keyCode.HOME:case $.ui.keyCode.END:case $.ui.keyCode.UP:case $.ui.keyCode.RIGHT:case $.ui.keyCode.DOWN:case $.ui.keyCode.LEFT:ret=false;if(!self._keySliding){self._keySliding=true;$(this).addClass("ui-state-active");self._start(event,index);}
+break;}
+var curVal,newVal,step=self._step();if(self.options.values&&self.options.values.length){curVal=newVal=self.values(index);}else{curVal=newVal=self.value();}
+switch(event.keyCode){case $.ui.keyCode.HOME:newVal=self._valueMin();break;case $.ui.keyCode.END:newVal=self._valueMax();break;case $.ui.keyCode.UP:case $.ui.keyCode.RIGHT:if(curVal==self._valueMax())return;newVal=curVal+step;break;case $.ui.keyCode.DOWN:case $.ui.keyCode.LEFT:if(curVal==self._valueMin())return;newVal=curVal-step;break;}
+self._slide(event,index,newVal);return ret;}).keyup(function(event){var index=$(this).data("index.ui-slider-handle");if(self._keySliding){self._stop(event,index);self._change(event,index);self._keySliding=false;$(this).removeClass("ui-state-active");}});this._refreshValue();},destroy:function(){this.handles.remove();this.range.remove();this.element.removeClass("ui-slider"
++" ui-slider-horizontal"
++" ui-slider-vertical"
++" ui-slider-disabled"
++" ui-widget"
++" ui-corner-all").removeData("slider").unbind(".slider");this._mouseDestroy();},_mouseCapture:function(event){var o=this.options;if(o.disabled)
+return false;this.elementSize={width:this.element.outerWidth(),height:this.element.outerHeight()};this.elementOffset=this.element.offset();var position={x:event.pageX,y:event.pageY};var normValue=this._normValueFromMouse(position);var distance=this._valueMax()-this._valueMin()+1,closestHandle;var self=this,index;this.handles.each(function(i){var thisDistance=Math.abs(normValue-self.values(i));if(distance>thisDistance){distance=thisDistance;closestHandle=$(this);index=i;}});if(o.range==true&&this.values(1)==o.min){closestHandle=$(this.handles[++index]);}
+this._start(event,index);self._handleIndex=index;closestHandle.addClass("ui-state-active").focus();var offset=closestHandle.offset();var mouseOverHandle=!$(event.target).parents().andSelf().is('.ui-slider-handle');this._clickOffset=mouseOverHandle?{left:0,top:0}:{left:event.pageX-offset.left-(closestHandle.width()/2),top:event.pageY-offset.top
+-(closestHandle.height()/2)
+-(parseInt(closestHandle.css('borderTopWidth'),10)||0)
+-(parseInt(closestHandle.css('borderBottomWidth'),10)||0)
++(parseInt(closestHandle.css('marginTop'),10)||0)};normValue=this._normValueFromMouse(position);this._slide(event,index,normValue);return true;},_mouseStart:function(event){return true;},_mouseDrag:function(event){var position={x:event.pageX,y:event.pageY};var normValue=this._normValueFromMouse(position);this._slide(event,this._handleIndex,normValue);return false;},_mouseStop:function(event){this.handles.removeClass("ui-state-active");this._stop(event,this._handleIndex);this._change(event,this._handleIndex);this._handleIndex=null;this._clickOffset=null;return false;},_detectOrientation:function(){this.orientation=this.options.orientation=='vertical'?'vertical':'horizontal';},_normValueFromMouse:function(position){var pixelTotal,pixelMouse;if('horizontal'==this.orientation){pixelTotal=this.elementSize.width;pixelMouse=position.x-this.elementOffset.left-(this._clickOffset?this._clickOffset.left:0);}else{pixelTotal=this.elementSize.height;pixelMouse=position.y-this.elementOffset.top-(this._clickOffset?this._clickOffset.top:0);}
+var percentMouse=(pixelMouse/pixelTotal);if(percentMouse>1)percentMouse=1;if(percentMouse<0)percentMouse=0;if('vertical'==this.orientation)
+percentMouse=1-percentMouse;var valueTotal=this._valueMax()-this._valueMin(),valueMouse=percentMouse*valueTotal,valueMouseModStep=valueMouse%this.options.step,normValue=this._valueMin()+valueMouse-valueMouseModStep;if(valueMouseModStep>(this.options.step/2))
+normValue+=this.options.step;return parseFloat(normValue.toFixed(5));},_start:function(event,index){var uiHash={handle:this.handles[index],value:this.value()};if(this.options.values&&this.options.values.length){uiHash.value=this.values(index);uiHash.values=this.values();}
+this._trigger("start",event,uiHash);},_slide:function(event,index,newVal){var handle=this.handles[index];if(this.options.values&&this.options.values.length){var otherVal=this.values(index?0:1);if((this.options.values.length==2&&this.options.range===true)&&((index==0&&newVal>otherVal)||(index==1&&newVal<otherVal))){newVal=otherVal;}
+if(newVal!=this.values(index)){var newValues=this.values();newValues[index]=newVal;var allowed=this._trigger("slide",event,{handle:this.handles[index],value:newVal,values:newValues});var otherVal=this.values(index?0:1);if(allowed!==false){this.values(index,newVal,(event.type=='mousedown'&&this.options.animate),true);}}}else{if(newVal!=this.value()){var allowed=this._trigger("slide",event,{handle:this.handles[index],value:newVal});if(allowed!==false){this._setData('value',newVal,(event.type=='mousedown'&&this.options.animate));}}}},_stop:function(event,index){var uiHash={handle:this.handles[index],value:this.value()};if(this.options.values&&this.options.values.length){uiHash.value=this.values(index);uiHash.values=this.values();}
+this._trigger("stop",event,uiHash);},_change:function(event,index){var uiHash={handle:this.handles[index],value:this.value()};if(this.options.values&&this.options.values.length){uiHash.value=this.values(index);uiHash.values=this.values();}
+this._trigger("change",event,uiHash);},value:function(newValue){if(arguments.length){this._setData("value",newValue);this._change(null,0);}
+return this._value();},values:function(index,newValue,animated,noPropagation){if(arguments.length>1){this.options.values[index]=newValue;this._refreshValue(animated);if(!noPropagation)this._change(null,index);}
+if(arguments.length){if(this.options.values&&this.options.values.length){return this._values(index);}else{return this.value();}}else{return this._values();}},_setData:function(key,value,animated){$.widget.prototype._setData.apply(this,arguments);switch(key){case'disabled':if(value){this.handles.filter(".ui-state-focus").blur();this.handles.removeClass("ui-state-hover");this.handles.attr("disabled","disabled");}else{this.handles.removeAttr("disabled");}
+case'orientation':this._detectOrientation();this.element.removeClass("ui-slider-horizontal ui-slider-vertical").addClass("ui-slider-"+this.orientation);this._refreshValue(animated);break;case'value':this._refreshValue(animated);break;}},_step:function(){var step=this.options.step;return step;},_value:function(){var val=this.options.value;if(val<this._valueMin())val=this._valueMin();if(val>this._valueMax())val=this._valueMax();return val;},_values:function(index){if(arguments.length){var val=this.options.values[index];if(val<this._valueMin())val=this._valueMin();if(val>this._valueMax())val=this._valueMax();return val;}else{return this.options.values;}},_valueMin:function(){var valueMin=this.options.min;return valueMin;},_valueMax:function(){var valueMax=this.options.max;return valueMax;},_refreshValue:function(animate){var oRange=this.options.range,o=this.options,self=this;if(this.options.values&&this.options.values.length){var vp0,vp1;this.handles.each(function(i,j){var valPercent=(self.values(i)-self._valueMin())/(self._valueMax()-self._valueMin())*100;var _set={};_set[self.orientation=='horizontal'?'left':'bottom']=valPercent+'%';$(this).stop(1,1)[animate?'animate':'css'](_set,o.animate);if(self.options.range===true){if(self.orientation=='horizontal'){(i==0)&&self.range.stop(1,1)[animate?'animate':'css']({left:valPercent+'%'},o.animate);(i==1)&&self.range[animate?'animate':'css']({width:(valPercent-lastValPercent)+'%'},{queue:false,duration:o.animate});}else{(i==0)&&self.range.stop(1,1)[animate?'animate':'css']({bottom:(valPercent)+'%'},o.animate);(i==1)&&self.range[animate?'animate':'css']({height:(valPercent-lastValPercent)+'%'},{queue:false,duration:o.animate});}}
+lastValPercent=valPercent;});}else{var value=this.value(),valueMin=this._valueMin(),valueMax=this._valueMax(),valPercent=valueMax!=valueMin?(value-valueMin)/(valueMax-valueMin)*100:0;var _set={};_set[self.orientation=='horizontal'?'left':'bottom']=valPercent+'%';this.handle.stop(1,1)[animate?'animate':'css'](_set,o.animate);(oRange=="min")&&(this.orientation=="horizontal")&&this.range.stop(1,1)[animate?'animate':'css']({width:valPercent+'%'},o.animate);(oRange=="max")&&(this.orientation=="horizontal")&&this.range[animate?'animate':'css']({width:(100-valPercent)+'%'},{queue:false,duration:o.animate});(oRange=="min")&&(this.orientation=="vertical")&&this.range.stop(1,1)[animate?'animate':'css']({height:valPercent+'%'},o.animate);(oRange=="max")&&(this.orientation=="vertical")&&this.range[animate?'animate':'css']({height:(100-valPercent)+'%'},{queue:false,duration:o.animate});}}}));$.extend($.ui.slider,{getter:"value values",version:"1.7.2",eventPrefix:"slide",defaults:{animate:false,delay:0,distance:0,max:100,min:0,orientation:'horizontal',range:false,step:1,value:0,values:null}});})(jQuery);(function($){$.widget("ui.tabs",{_init:function(){if(this.options.deselectable!==undefined){this.options.collapsible=this.options.deselectable;}
+this._tabify(true);},_setData:function(key,value){if(key=='selected'){if(this.options.collapsible&&value==this.options.selected){return;}
+this.select(value);}
+else{this.options[key]=value;if(key=='deselectable'){this.options.collapsible=value;}
+this._tabify();}},_tabId:function(a){return a.title&&a.title.replace(/\s/g,'_').replace(/[^A-Za-z0-9\-_:\.]/g,'')||this.options.idPrefix+$.data(a);},_sanitizeSelector:function(hash){return hash.replace(/:/g,'\\:');},_cookie:function(){var cookie=this.cookie||(this.cookie=this.options.cookie.name||'ui-tabs-'+$.data(this.list[0]));return $.cookie.apply(null,[cookie].concat($.makeArray(arguments)));},_ui:function(tab,panel){return{tab:tab,panel:panel,index:this.anchors.index(tab)};},_cleanup:function(){this.lis.filter('.ui-state-processing').removeClass('ui-state-processing').find('span:data(label.tabs)').each(function(){var el=$(this);el.html(el.data('label.tabs')).removeData('label.tabs');});},_tabify:function(init){this.list=this.element.children('ul:first');this.lis=$('li:has(a[href])',this.list);this.anchors=this.lis.map(function(){return $('a',this)[0];});this.panels=$([]);var self=this,o=this.options;var fragmentId=/^#.+/;this.anchors.each(function(i,a){var href=$(a).attr('href');var hrefBase=href.split('#')[0],baseEl;if(hrefBase&&(hrefBase===location.toString().split('#')[0]||(baseEl=$('base')[0])&&hrefBase===baseEl.href)){href=a.hash;a.href=href;}
+if(fragmentId.test(href)){self.panels=self.panels.add(self._sanitizeSelector(href));}
+else if(href!='#'){$.data(a,'href.tabs',href);$.data(a,'load.tabs',href.replace(/#.*$/,''));var id=self._tabId(a);a.href='#'+id;var $panel=$('#'+id);if(!$panel.length){$panel=$(o.panelTemplate).attr('id',id).addClass('ui-tabs-panel ui-widget-content ui-corner-bottom').insertAfter(self.panels[i-1]||self.list);$panel.data('destroy.tabs',true);}
+self.panels=self.panels.add($panel);}
+else{o.disabled.push(i);}});if(init){this.element.addClass('ui-tabs ui-widget ui-widget-content ui-corner-all');this.list.addClass('ui-tabs-nav ui-helper-reset ui-helper-clearfix ui-widget-header ui-corner-all');this.lis.addClass('ui-state-default ui-corner-top');this.panels.addClass('ui-tabs-panel ui-widget-content ui-corner-bottom');if(o.selected===undefined){if(location.hash){this.anchors.each(function(i,a){if(a.hash==location.hash){o.selected=i;return false;}});}
+if(typeof o.selected!='number'&&o.cookie){o.selected=parseInt(self._cookie(),10);}
+if(typeof o.selected!='number'&&this.lis.filter('.ui-tabs-selected').length){o.selected=this.lis.index(this.lis.filter('.ui-tabs-selected'));}
+o.selected=o.selected||0;}
+else if(o.selected===null){o.selected=-1;}
+o.selected=((o.selected>=0&&this.anchors[o.selected])||o.selected<0)?o.selected:0;o.disabled=$.unique(o.disabled.concat($.map(this.lis.filter('.ui-state-disabled'),function(n,i){return self.lis.index(n);}))).sort();if($.inArray(o.selected,o.disabled)!=-1){o.disabled.splice($.inArray(o.selected,o.disabled),1);}
+this.panels.addClass('ui-tabs-hide');this.lis.removeClass('ui-tabs-selected ui-state-active');if(o.selected>=0&&this.anchors.length){this.panels.eq(o.selected).removeClass('ui-tabs-hide');this.lis.eq(o.selected).addClass('ui-tabs-selected ui-state-active');self.element.queue("tabs",function(){self._trigger('show',null,self._ui(self.anchors[o.selected],self.panels[o.selected]));});this.load(o.selected);}
+$(window).bind('unload',function(){self.lis.add(self.anchors).unbind('.tabs');self.lis=self.anchors=self.panels=null;});}
+else{o.selected=this.lis.index(this.lis.filter('.ui-tabs-selected'));}
+this.element[o.collapsible?'addClass':'removeClass']('ui-tabs-collapsible');if(o.cookie){this._cookie(o.selected,o.cookie);}
+for(var i=0,li;(li=this.lis[i]);i++){$(li)[$.inArray(i,o.disabled)!=-1&&!$(li).hasClass('ui-tabs-selected')?'addClass':'removeClass']('ui-state-disabled');}
+if(o.cache===false){this.anchors.removeData('cache.tabs');}
+this.lis.add(this.anchors).unbind('.tabs');if(o.event!='mouseover'){var addState=function(state,el){if(el.is(':not(.ui-state-disabled)')){el.addClass('ui-state-'+state);}};var removeState=function(state,el){el.removeClass('ui-state-'+state);};this.lis.bind('mouseover.tabs',function(){addState('hover',$(this));});this.lis.bind('mouseout.tabs',function(){removeState('hover',$(this));});this.anchors.bind('focus.tabs',function(){addState('focus',$(this).closest('li'));});this.anchors.bind('blur.tabs',function(){removeState('focus',$(this).closest('li'));});}
+var hideFx,showFx;if(o.fx){if($.isArray(o.fx)){hideFx=o.fx[0];showFx=o.fx[1];}
+else{hideFx=showFx=o.fx;}}
+function resetStyle($el,fx){$el.css({display:''});if($.browser.msie&&fx.opacity){$el[0].style.removeAttribute('filter');}}
+var showTab=showFx?function(clicked,$show){$(clicked).closest('li').removeClass('ui-state-default').addClass('ui-tabs-selected ui-state-active');$show.hide().removeClass('ui-tabs-hide').animate(showFx,showFx.duration||'normal',function(){resetStyle($show,showFx);self._trigger('show',null,self._ui(clicked,$show[0]));});}:function(clicked,$show){$(clicked).closest('li').removeClass('ui-state-default').addClass('ui-tabs-selected ui-state-active');$show.removeClass('ui-tabs-hide');self._trigger('show',null,self._ui(clicked,$show[0]));};var hideTab=hideFx?function(clicked,$hide){$hide.animate(hideFx,hideFx.duration||'normal',function(){self.lis.removeClass('ui-tabs-selected ui-state-active').addClass('ui-state-default');$hide.addClass('ui-tabs-hide');resetStyle($hide,hideFx);self.element.dequeue("tabs");});}:function(clicked,$hide,$show){self.lis.removeClass('ui-tabs-selected ui-state-active').addClass('ui-state-default');$hide.addClass('ui-tabs-hide');self.element.dequeue("tabs");};this.anchors.bind(o.event+'.tabs',function(){var el=this,$li=$(this).closest('li'),$hide=self.panels.filter(':not(.ui-tabs-hide)'),$show=$(self._sanitizeSelector(this.hash));if(($li.hasClass('ui-tabs-selected')&&!o.collapsible)||$li.hasClass('ui-state-disabled')||$li.hasClass('ui-state-processing')||self._trigger('select',null,self._ui(this,$show[0]))===false){this.blur();return false;}
+o.selected=self.anchors.index(this);self.abort();if(o.collapsible){if($li.hasClass('ui-tabs-selected')){o.selected=-1;if(o.cookie){self._cookie(o.selected,o.cookie);}
+self.element.queue("tabs",function(){hideTab(el,$hide);}).dequeue("tabs");this.blur();return false;}
+else if(!$hide.length){if(o.cookie){self._cookie(o.selected,o.cookie);}
+self.element.queue("tabs",function(){showTab(el,$show);});self.load(self.anchors.index(this));this.blur();return false;}}
+if(o.cookie){self._cookie(o.selected,o.cookie);}
+if($show.length){if($hide.length){self.element.queue("tabs",function(){hideTab(el,$hide);});}
+self.element.queue("tabs",function(){showTab(el,$show);});self.load(self.anchors.index(this));}
+else{throw'jQuery UI Tabs: Mismatching fragment identifier.';}
+if($.browser.msie){this.blur();}});this.anchors.bind('click.tabs',function(){return false;});},destroy:function(){var o=this.options;this.abort();this.element.unbind('.tabs').removeClass('ui-tabs ui-widget ui-widget-content ui-corner-all ui-tabs-collapsible').removeData('tabs');this.list.removeClass('ui-tabs-nav ui-helper-reset ui-helper-clearfix ui-widget-header ui-corner-all');this.anchors.each(function(){var href=$.data(this,'href.tabs');if(href){this.href=href;}
+var $this=$(this).unbind('.tabs');$.each(['href','load','cache'],function(i,prefix){$this.removeData(prefix+'.tabs');});});this.lis.unbind('.tabs').add(this.panels).each(function(){if($.data(this,'destroy.tabs')){$(this).remove();}
+else{$(this).removeClass(['ui-state-default','ui-corner-top','ui-tabs-selected','ui-state-active','ui-state-hover','ui-state-focus','ui-state-disabled','ui-tabs-panel','ui-widget-content','ui-corner-bottom','ui-tabs-hide'].join(' '));}});if(o.cookie){this._cookie(null,o.cookie);}},add:function(url,label,index){if(index===undefined){index=this.anchors.length;}
+var self=this,o=this.options,$li=$(o.tabTemplate.replace(/#\{href\}/g,url).replace(/#\{label\}/g,label)),id=!url.indexOf('#')?url.replace('#',''):this._tabId($('a',$li)[0]);$li.addClass('ui-state-default ui-corner-top').data('destroy.tabs',true);var $panel=$('#'+id);if(!$panel.length){$panel=$(o.panelTemplate).attr('id',id).data('destroy.tabs',true);}
+$panel.addClass('ui-tabs-panel ui-widget-content ui-corner-bottom ui-tabs-hide');if(index>=this.lis.length){$li.appendTo(this.list);$panel.appendTo(this.list[0].parentNode);}
+else{$li.insertBefore(this.lis[index]);$panel.insertBefore(this.panels[index]);}
+o.disabled=$.map(o.disabled,function(n,i){return n>=index?++n:n;});this._tabify();if(this.anchors.length==1){$li.addClass('ui-tabs-selected ui-state-active');$panel.removeClass('ui-tabs-hide');this.element.queue("tabs",function(){self._trigger('show',null,self._ui(self.anchors[0],self.panels[0]));});this.load(0);}
+this._trigger('add',null,this._ui(this.anchors[index],this.panels[index]));},remove:function(index){var o=this.options,$li=this.lis.eq(index).remove(),$panel=this.panels.eq(index).remove();if($li.hasClass('ui-tabs-selected')&&this.anchors.length>1){this.select(index+(index+1<this.anchors.length?1:-1));}
+o.disabled=$.map($.grep(o.disabled,function(n,i){return n!=index;}),function(n,i){return n>=index?--n:n;});this._tabify();this._trigger('remove',null,this._ui($li.find('a')[0],$panel[0]));},enable:function(index){var o=this.options;if($.inArray(index,o.disabled)==-1){return;}
+this.lis.eq(index).removeClass('ui-state-disabled');o.disabled=$.grep(o.disabled,function(n,i){return n!=index;});this._trigger('enable',null,this._ui(this.anchors[index],this.panels[index]));},disable:function(index){var self=this,o=this.options;if(index!=o.selected){this.lis.eq(index).addClass('ui-state-disabled');o.disabled.push(index);o.disabled.sort();this._trigger('disable',null,this._ui(this.anchors[index],this.panels[index]));}},select:function(index){if(typeof index=='string'){index=this.anchors.index(this.anchors.filter('[href$='+index+']'));}
+else if(index===null){index=-1;}
+if(index==-1&&this.options.collapsible){index=this.options.selected;}
+this.anchors.eq(index).trigger(this.options.event+'.tabs');},load:function(index){var self=this,o=this.options,a=this.anchors.eq(index)[0],url=$.data(a,'load.tabs');this.abort();if(!url||this.element.queue("tabs").length!==0&&$.data(a,'cache.tabs')){this.element.dequeue("tabs");return;}
+this.lis.eq(index).addClass('ui-state-processing');if(o.spinner){var span=$('span',a);span.data('label.tabs',span.html()).html(o.spinner);}
+this.xhr=$.ajax($.extend({},o.ajaxOptions,{url:url,success:function(r,s){$(self._sanitizeSelector(a.hash)).html(r);self._cleanup();if(o.cache){$.data(a,'cache.tabs',true);}
+self._trigger('load',null,self._ui(self.anchors[index],self.panels[index]));try{o.ajaxOptions.success(r,s);}
+catch(e){}
+self.element.dequeue("tabs");}}));},abort:function(){this.element.queue([]);this.panels.stop(false,true);if(this.xhr){this.xhr.abort();delete this.xhr;}
+this._cleanup();},url:function(index,url){this.anchors.eq(index).removeData('cache.tabs').data('load.tabs',url);},length:function(){return this.anchors.length;}});$.extend($.ui.tabs,{version:'1.7.2',getter:'length',defaults:{ajaxOptions:null,cache:false,cookie:null,collapsible:false,disabled:[],event:'click',fx:null,idPrefix:'ui-tabs-',panelTemplate:'<div></div>',spinner:'<em>Loading&#8230;</em>',tabTemplate:'<li><a href="#{href}"><span>#{label}</span></a></li>'}});$.extend($.ui.tabs.prototype,{rotation:null,rotate:function(ms,continuing){var self=this,o=this.options;var rotate=self._rotate||(self._rotate=function(e){clearTimeout(self.rotation);self.rotation=setTimeout(function(){var t=o.selected;self.select(++t<self.anchors.length?t:0);},ms);if(e){e.stopPropagation();}});var stop=self._unrotate||(self._unrotate=!continuing?function(e){if(e.clientX){self.rotate(null);}}:function(e){t=o.selected;rotate();});if(ms){this.element.bind('tabsshow',rotate);this.anchors.bind(o.event+'.tabs',stop);rotate();}
+else{clearTimeout(self.rotation);this.element.unbind('tabsshow',rotate);this.anchors.unbind(o.event+'.tabs',stop);delete this._rotate;delete this._unrotate;}}});})(jQuery);(function($){$.extend($.ui,{datepicker:{version:"1.7.2"}});var PROP_NAME='datepicker';function Datepicker(){this.debug=false;this._curInst=null;this._keyEvent=false;this._disabledInputs=[];this._datepickerShowing=false;this._inDialog=false;this._mainDivId='ui-datepicker-div';this._inlineClass='ui-datepicker-inline';this._appendClass='ui-datepicker-append';this._triggerClass='ui-datepicker-trigger';this._dialogClass='ui-datepicker-dialog';this._disableClass='ui-datepicker-disabled';this._unselectableClass='ui-datepicker-unselectable';this._currentClass='ui-datepicker-current-day';this._dayOverClass='ui-datepicker-days-cell-over';this.regional=[];this.regional['']={closeText:'Done',prevText:'Prev',nextText:'Next',currentText:'Today',monthNames:['January','February','March','April','May','June','July','August','September','October','November','December'],monthNamesShort:['Jan','Feb','Mar','Apr','May','Jun','Jul','Aug','Sep','Oct','Nov','Dec'],dayNames:['Sunday','Monday','Tuesday','Wednesday','Thursday','Friday','Saturday'],dayNamesShort:['Sun','Mon','Tue','Wed','Thu','Fri','Sat'],dayNamesMin:['Su','Mo','Tu','We','Th','Fr','Sa'],dateFormat:'mm/dd/yy',firstDay:0,isRTL:false};this._defaults={showOn:'focus',showAnim:'show',showOptions:{},defaultDate:null,appendText:'',buttonText:'...',buttonImage:'',buttonImageOnly:false,hideIfNoPrevNext:false,navigationAsDateFormat:false,gotoCurrent:false,changeMonth:false,changeYear:false,showMonthAfterYear:false,yearRange:'-10:+10',showOtherMonths:false,calculateWeek:this.iso8601Week,shortYearCutoff:'+10',minDate:null,maxDate:null,duration:'normal',beforeShowDay:null,beforeShow:null,onSelect:null,onChangeMonthYear:null,onClose:null,numberOfMonths:1,showCurrentAtPos:0,stepMonths:1,stepBigMonths:12,altField:'',altFormat:'',constrainInput:true,showButtonPanel:false};$.extend(this._defaults,this.regional['']);this.dpDiv=$('<div id="'+this._mainDivId+'" class="ui-datepicker ui-widget ui-widget-content ui-helper-clearfix ui-corner-all ui-helper-hidden-accessible"></div>');}
+$.extend(Datepicker.prototype,{markerClassName:'hasDatepicker',log:function(){if(this.debug)
+console.log.apply('',arguments);},setDefaults:function(settings){extendRemove(this._defaults,settings||{});return this;},_attachDatepicker:function(target,settings){var inlineSettings=null;for(var attrName in this._defaults){var attrValue=target.getAttribute('date:'+attrName);if(attrValue){inlineSettings=inlineSettings||{};try{inlineSettings[attrName]=eval(attrValue);}catch(err){inlineSettings[attrName]=attrValue;}}}
+var nodeName=target.nodeName.toLowerCase();var inline=(nodeName=='div'||nodeName=='span');if(!target.id)
+target.id='dp'+(++this.uuid);var inst=this._newInst($(target),inline);inst.settings=$.extend({},settings||{},inlineSettings||{});if(nodeName=='input'){this._connectDatepicker(target,inst);}else if(inline){this._inlineDatepicker(target,inst);}},_newInst:function(target,inline){var id=target[0].id.replace(/([:\[\]\.])/g,'\\\\$1');return{id:id,input:target,selectedDay:0,selectedMonth:0,selectedYear:0,drawMonth:0,drawYear:0,inline:inline,dpDiv:(!inline?this.dpDiv:$('<div class="'+this._inlineClass+' ui-datepicker ui-widget ui-widget-content ui-helper-clearfix ui-corner-all"></div>'))};},_connectDatepicker:function(target,inst){var input=$(target);inst.append=$([]);inst.trigger=$([]);if(input.hasClass(this.markerClassName))
+return;var appendText=this._get(inst,'appendText');var isRTL=this._get(inst,'isRTL');if(appendText){inst.append=$('<span class="'+this._appendClass+'">'+appendText+'</span>');input[isRTL?'before':'after'](inst.append);}
+var showOn=this._get(inst,'showOn');if(showOn=='focus'||showOn=='both')
+input.focus(this._showDatepicker);if(showOn=='button'||showOn=='both'){var buttonText=this._get(inst,'buttonText');var buttonImage=this._get(inst,'buttonImage');inst.trigger=$(this._get(inst,'buttonImageOnly')?$('<img/>').addClass(this._triggerClass).attr({src:buttonImage,alt:buttonText,title:buttonText}):$('<button type="button"></button>').addClass(this._triggerClass).html(buttonImage==''?buttonText:$('<img/>').attr({src:buttonImage,alt:buttonText,title:buttonText})));input[isRTL?'before':'after'](inst.trigger);inst.trigger.click(function(){if($.datepicker._datepickerShowing&&$.datepicker._lastInput==target)
+$.datepicker._hideDatepicker();else
+$.datepicker._showDatepicker(target);return false;});}
+input.addClass(this.markerClassName).keydown(this._doKeyDown).keypress(this._doKeyPress).bind("setData.datepicker",function(event,key,value){inst.settings[key]=value;}).bind("getData.datepicker",function(event,key){return this._get(inst,key);});$.data(target,PROP_NAME,inst);},_inlineDatepicker:function(target,inst){var divSpan=$(target);if(divSpan.hasClass(this.markerClassName))
+return;divSpan.addClass(this.markerClassName).append(inst.dpDiv).bind("setData.datepicker",function(event,key,value){inst.settings[key]=value;}).bind("getData.datepicker",function(event,key){return this._get(inst,key);});$.data(target,PROP_NAME,inst);this._setDate(inst,this._getDefaultDate(inst));this._updateDatepicker(inst);this._updateAlternate(inst);},_dialogDatepicker:function(input,dateText,onSelect,settings,pos){var inst=this._dialogInst;if(!inst){var id='dp'+(++this.uuid);this._dialogInput=$('<input type="text" id="'+id+'" size="1" style="position: absolute; top: -100px;"/>');this._dialogInput.keydown(this._doKeyDown);$('body').append(this._dialogInput);inst=this._dialogInst=this._newInst(this._dialogInput,false);inst.settings={};$.data(this._dialogInput[0],PROP_NAME,inst);}
+extendRemove(inst.settings,settings||{});this._dialogInput.val(dateText);this._pos=(pos?(pos.length?pos:[pos.pageX,pos.pageY]):null);if(!this._pos){var browserWidth=window.innerWidth||document.documentElement.clientWidth||document.body.clientWidth;var browserHeight=window.innerHeight||document.documentElement.clientHeight||document.body.clientHeight;var scrollX=document.documentElement.scrollLeft||document.body.scrollLeft;var scrollY=document.documentElement.scrollTop||document.body.scrollTop;this._pos=[(browserWidth/2)-100+scrollX,(browserHeight/2)-150+scrollY];}
+this._dialogInput.css('left',this._pos[0]+'px').css('top',this._pos[1]+'px');inst.settings.onSelect=onSelect;this._inDialog=true;this.dpDiv.addClass(this._dialogClass);this._showDatepicker(this._dialogInput[0]);if($.blockUI)
+$.blockUI(this.dpDiv);$.data(this._dialogInput[0],PROP_NAME,inst);return this;},_destroyDatepicker:function(target){var $target=$(target);var inst=$.data(target,PROP_NAME);if(!$target.hasClass(this.markerClassName)){return;}
+var nodeName=target.nodeName.toLowerCase();$.removeData(target,PROP_NAME);if(nodeName=='input'){inst.append.remove();inst.trigger.remove();$target.removeClass(this.markerClassName).unbind('focus',this._showDatepicker).unbind('keydown',this._doKeyDown).unbind('keypress',this._doKeyPress);}else if(nodeName=='div'||nodeName=='span')
+$target.removeClass(this.markerClassName).empty();},_enableDatepicker:function(target){var $target=$(target);var inst=$.data(target,PROP_NAME);if(!$target.hasClass(this.markerClassName)){return;}
+var nodeName=target.nodeName.toLowerCase();if(nodeName=='input'){target.disabled=false;inst.trigger.filter('button').each(function(){this.disabled=false;}).end().filter('img').css({opacity:'1.0',cursor:''});}
+else if(nodeName=='div'||nodeName=='span'){var inline=$target.children('.'+this._inlineClass);inline.children().removeClass('ui-state-disabled');}
+this._disabledInputs=$.map(this._disabledInputs,function(value){return(value==target?null:value);});},_disableDatepicker:function(target){var $target=$(target);var inst=$.data(target,PROP_NAME);if(!$target.hasClass(this.markerClassName)){return;}
+var nodeName=target.nodeName.toLowerCase();if(nodeName=='input'){target.disabled=true;inst.trigger.filter('button').each(function(){this.disabled=true;}).end().filter('img').css({opacity:'0.5',cursor:'default'});}
+else if(nodeName=='div'||nodeName=='span'){var inline=$target.children('.'+this._inlineClass);inline.children().addClass('ui-state-disabled');}
+this._disabledInputs=$.map(this._disabledInputs,function(value){return(value==target?null:value);});this._disabledInputs[this._disabledInputs.length]=target;},_isDisabledDatepicker:function(target){if(!target){return false;}
+for(var i=0;i<this._disabledInputs.length;i++){if(this._disabledInputs[i]==target)
+return true;}
+return false;},_getInst:function(target){try{return $.data(target,PROP_NAME);}
+catch(err){throw'Missing instance data for this datepicker';}},_optionDatepicker:function(target,name,value){var inst=this._getInst(target);if(arguments.length==2&&typeof name=='string'){return(name=='defaults'?$.extend({},$.datepicker._defaults):(inst?(name=='all'?$.extend({},inst.settings):this._get(inst,name)):null));}
+var settings=name||{};if(typeof name=='string'){settings={};settings[name]=value;}
+if(inst){if(this._curInst==inst){this._hideDatepicker(null);}
+var date=this._getDateDatepicker(target);extendRemove(inst.settings,settings);this._setDateDatepicker(target,date);this._updateDatepicker(inst);}},_changeDatepicker:function(target,name,value){this._optionDatepicker(target,name,value);},_refreshDatepicker:function(target){var inst=this._getInst(target);if(inst){this._updateDatepicker(inst);}},_setDateDatepicker:function(target,date,endDate){var inst=this._getInst(target);if(inst){this._setDate(inst,date,endDate);this._updateDatepicker(inst);this._updateAlternate(inst);}},_getDateDatepicker:function(target){var inst=this._getInst(target);if(inst&&!inst.inline)
+this._setDateFromField(inst);return(inst?this._getDate(inst):null);},_doKeyDown:function(event){var inst=$.datepicker._getInst(event.target);var handled=true;var isRTL=inst.dpDiv.is('.ui-datepicker-rtl');inst._keyEvent=true;if($.datepicker._datepickerShowing)
+switch(event.keyCode){case 9:$.datepicker._hideDatepicker(null,'');break;case 13:var sel=$('td.'+$.datepicker._dayOverClass+', td.'+$.datepicker._currentClass,inst.dpDiv);if(sel[0])
+$.datepicker._selectDay(event.target,inst.selectedMonth,inst.selectedYear,sel[0]);else
+$.datepicker._hideDatepicker(null,$.datepicker._get(inst,'duration'));return false;break;case 27:$.datepicker._hideDatepicker(null,$.datepicker._get(inst,'duration'));break;case 33:$.datepicker._adjustDate(event.target,(event.ctrlKey?-$.datepicker._get(inst,'stepBigMonths'):-$.datepicker._get(inst,'stepMonths')),'M');break;case 34:$.datepicker._adjustDate(event.target,(event.ctrlKey?+$.datepicker._get(inst,'stepBigMonths'):+$.datepicker._get(inst,'stepMonths')),'M');break;case 35:if(event.ctrlKey||event.metaKey)$.datepicker._clearDate(event.target);handled=event.ctrlKey||event.metaKey;break;case 36:if(event.ctrlKey||event.metaKey)$.datepicker._gotoToday(event.target);handled=event.ctrlKey||event.metaKey;break;case 37:if(event.ctrlKey||event.metaKey)$.datepicker._adjustDate(event.target,(isRTL?+1:-1),'D');handled=event.ctrlKey||event.metaKey;if(event.originalEvent.altKey)$.datepicker._adjustDate(event.target,(event.ctrlKey?-$.datepicker._get(inst,'stepBigMonths'):-$.datepicker._get(inst,'stepMonths')),'M');break;case 38:if(event.ctrlKey||event.metaKey)$.datepicker._adjustDate(event.target,-7,'D');handled=event.ctrlKey||event.metaKey;break;case 39:if(event.ctrlKey||event.metaKey)$.datepicker._adjustDate(event.target,(isRTL?-1:+1),'D');handled=event.ctrlKey||event.metaKey;if(event.originalEvent.altKey)$.datepicker._adjustDate(event.target,(event.ctrlKey?+$.datepicker._get(inst,'stepBigMonths'):+$.datepicker._get(inst,'stepMonths')),'M');break;case 40:if(event.ctrlKey||event.metaKey)$.datepicker._adjustDate(event.target,+7,'D');handled=event.ctrlKey||event.metaKey;break;default:handled=false;}
+else if(event.keyCode==36&&event.ctrlKey)
+$.datepicker._showDatepicker(this);else{handled=false;}
+if(handled){event.preventDefault();event.stopPropagation();}},_doKeyPress:function(event){var inst=$.datepicker._getInst(event.target);if($.datepicker._get(inst,'constrainInput')){var chars=$.datepicker._possibleChars($.datepicker._get(inst,'dateFormat'));var chr=String.fromCharCode(event.charCode==undefined?event.keyCode:event.charCode);return event.ctrlKey||(chr<' '||!chars||chars.indexOf(chr)>-1);}},_showDatepicker:function(input){input=input.target||input;if(input.nodeName.toLowerCase()!='input')
+input=$('input',input.parentNode)[0];if($.datepicker._isDisabledDatepicker(input)||$.datepicker._lastInput==input)
+return;var inst=$.datepicker._getInst(input);var beforeShow=$.datepicker._get(inst,'beforeShow');extendRemove(inst.settings,(beforeShow?beforeShow.apply(input,[input,inst]):{}));$.datepicker._hideDatepicker(null,'');$.datepicker._lastInput=input;$.datepicker._setDateFromField(inst);if($.datepicker._inDialog)
+input.value='';if(!$.datepicker._pos){$.datepicker._pos=$.datepicker._findPos(input);$.datepicker._pos[1]+=input.offsetHeight;}
+var isFixed=false;$(input).parents().each(function(){isFixed|=$(this).css('position')=='fixed';return!isFixed;});if(isFixed&&$.browser.opera){$.datepicker._pos[0]-=document.documentElement.scrollLeft;$.datepicker._pos[1]-=document.documentElement.scrollTop;}
+var offset={left:$.datepicker._pos[0],top:$.datepicker._pos[1]};$.datepicker._pos=null;inst.rangeStart=null;inst.dpDiv.css({position:'absolute',display:'block',top:'-1000px'});$.datepicker._updateDatepicker(inst);offset=$.datepicker._checkOffset(inst,offset,isFixed);inst.dpDiv.css({position:($.datepicker._inDialog&&$.blockUI?'static':(isFixed?'fixed':'absolute')),display:'none',left:offset.left+'px',top:offset.top+'px'});if(!inst.inline){var showAnim=$.datepicker._get(inst,'showAnim')||'show';var duration=$.datepicker._get(inst,'duration');var postProcess=function(){$.datepicker._datepickerShowing=true;if($.browser.msie&&parseInt($.browser.version,10)<7)
+$('iframe.ui-datepicker-cover').css({width:inst.dpDiv.width()+4,height:inst.dpDiv.height()+4});};if($.effects&&$.effects[showAnim])
+inst.dpDiv.show(showAnim,$.datepicker._get(inst,'showOptions'),duration,postProcess);else
+inst.dpDiv[showAnim](duration,postProcess);if(duration=='')
+postProcess();if(inst.input[0].type!='hidden')
+inst.input[0].focus();$.datepicker._curInst=inst;}},_updateDatepicker:function(inst){var dims={width:inst.dpDiv.width()+4,height:inst.dpDiv.height()+4};var self=this;inst.dpDiv.empty().append(this._generateHTML(inst)).find('iframe.ui-datepicker-cover').css({width:dims.width,height:dims.height}).end().find('button, .ui-datepicker-prev, .ui-datepicker-next, .ui-datepicker-calendar td a').bind('mouseout',function(){$(this).removeClass('ui-state-hover');if(this.className.indexOf('ui-datepicker-prev')!=-1)$(this).removeClass('ui-datepicker-prev-hover');if(this.className.indexOf('ui-datepicker-next')!=-1)$(this).removeClass('ui-datepicker-next-hover');}).bind('mouseover',function(){if(!self._isDisabledDatepicker(inst.inline?inst.dpDiv.parent()[0]:inst.input[0])){$(this).parents('.ui-datepicker-calendar').find('a').removeClass('ui-state-hover');$(this).addClass('ui-state-hover');if(this.className.indexOf('ui-datepicker-prev')!=-1)$(this).addClass('ui-datepicker-prev-hover');if(this.className.indexOf('ui-datepicker-next')!=-1)$(this).addClass('ui-datepicker-next-hover');}}).end().find('.'+this._dayOverClass+' a').trigger('mouseover').end();var numMonths=this._getNumberOfMonths(inst);var cols=numMonths[1];var width=17;if(cols>1){inst.dpDiv.addClass('ui-datepicker-multi-'+cols).css('width',(width*cols)+'em');}else{inst.dpDiv.removeClass('ui-datepicker-multi-2 ui-datepicker-multi-3 ui-datepicker-multi-4').width('');}
+inst.dpDiv[(numMonths[0]!=1||numMonths[1]!=1?'add':'remove')+'Class']('ui-datepicker-multi');inst.dpDiv[(this._get(inst,'isRTL')?'add':'remove')+'Class']('ui-datepicker-rtl');if(inst.input&&inst.input[0].type!='hidden'&&inst==$.datepicker._curInst)
+$(inst.input[0]).focus();},_checkOffset:function(inst,offset,isFixed){var dpWidth=inst.dpDiv.outerWidth();var dpHeight=inst.dpDiv.outerHeight();var inputWidth=inst.input?inst.input.outerWidth():0;var inputHeight=inst.input?inst.input.outerHeight():0;var viewWidth=(window.innerWidth||document.documentElement.clientWidth||document.body.clientWidth)+$(document).scrollLeft();var viewHeight=(window.innerHeight||document.documentElement.clientHeight||document.body.clientHeight)+$(document).scrollTop();offset.left-=(this._get(inst,'isRTL')?(dpWidth-inputWidth):0);offset.left-=(isFixed&&offset.left==inst.input.offset().left)?$(document).scrollLeft():0;offset.top-=(isFixed&&offset.top==(inst.input.offset().top+inputHeight))?$(document).scrollTop():0;offset.left-=(offset.left+dpWidth>viewWidth&&viewWidth>dpWidth)?Math.abs(offset.left+dpWidth-viewWidth):0;offset.top-=(offset.top+dpHeight>viewHeight&&viewHeight>dpHeight)?Math.abs(offset.top+dpHeight+inputHeight*2-viewHeight):0;return offset;},_findPos:function(obj){while(obj&&(obj.type=='hidden'||obj.nodeType!=1)){obj=obj.nextSibling;}
+var position=$(obj).offset();return[position.left,position.top];},_hideDatepicker:function(input,duration){var inst=this._curInst;if(!inst||(input&&inst!=$.data(input,PROP_NAME)))
+return;if(inst.stayOpen)
+this._selectDate('#'+inst.id,this._formatDate(inst,inst.currentDay,inst.currentMonth,inst.currentYear));inst.stayOpen=false;if(this._datepickerShowing){duration=(duration!=null?duration:this._get(inst,'duration'));var showAnim=this._get(inst,'showAnim');var postProcess=function(){$.datepicker._tidyDialog(inst);};if(duration!=''&&$.effects&&$.effects[showAnim])
+inst.dpDiv.hide(showAnim,$.datepicker._get(inst,'showOptions'),duration,postProcess);else
+inst.dpDiv[(duration==''?'hide':(showAnim=='slideDown'?'slideUp':(showAnim=='fadeIn'?'fadeOut':'hide')))](duration,postProcess);if(duration=='')
+this._tidyDialog(inst);var onClose=this._get(inst,'onClose');if(onClose)
+onClose.apply((inst.input?inst.input[0]:null),[(inst.input?inst.input.val():''),inst]);this._datepickerShowing=false;this._lastInput=null;if(this._inDialog){this._dialogInput.css({position:'absolute',left:'0',top:'-100px'});if($.blockUI){$.unblockUI();$('body').append(this.dpDiv);}}
+this._inDialog=false;}
+this._curInst=null;},_tidyDialog:function(inst){inst.dpDiv.removeClass(this._dialogClass).unbind('.ui-datepicker-calendar');},_checkExternalClick:function(event){if(!$.datepicker._curInst)
+return;var $target=$(event.target);if(($target.parents('#'+$.datepicker._mainDivId).length==0)&&!$target.hasClass($.datepicker.markerClassName)&&!$target.hasClass($.datepicker._triggerClass)&&$.datepicker._datepickerShowing&&!($.datepicker._inDialog&&$.blockUI))
+$.datepicker._hideDatepicker(null,'');},_adjustDate:function(id,offset,period){var target=$(id);var inst=this._getInst(target[0]);if(this._isDisabledDatepicker(target[0])){return;}
+this._adjustInstDate(inst,offset+
+(period=='M'?this._get(inst,'showCurrentAtPos'):0),period);this._updateDatepicker(inst);},_gotoToday:function(id){var target=$(id);var inst=this._getInst(target[0]);if(this._get(inst,'gotoCurrent')&&inst.currentDay){inst.selectedDay=inst.currentDay;inst.drawMonth=inst.selectedMonth=inst.currentMonth;inst.drawYear=inst.selectedYear=inst.currentYear;}
+else{var date=new Date();inst.selectedDay=date.getDate();inst.drawMonth=inst.selectedMonth=date.getMonth();inst.drawYear=inst.selectedYear=date.getFullYear();}
+this._notifyChange(inst);this._adjustDate(target);},_selectMonthYear:function(id,select,period){var target=$(id);var inst=this._getInst(target[0]);inst._selectingMonthYear=false;inst['selected'+(period=='M'?'Month':'Year')]=inst['draw'+(period=='M'?'Month':'Year')]=parseInt(select.options[select.selectedIndex].value,10);this._notifyChange(inst);this._adjustDate(target);},_clickMonthYear:function(id){var target=$(id);var inst=this._getInst(target[0]);if(inst.input&&inst._selectingMonthYear&&!$.browser.msie)
+inst.input[0].focus();inst._selectingMonthYear=!inst._selectingMonthYear;},_selectDay:function(id,month,year,td){var target=$(id);if($(td).hasClass(this._unselectableClass)||this._isDisabledDatepicker(target[0])){return;}
+var inst=this._getInst(target[0]);inst.selectedDay=inst.currentDay=$('a',td).html();inst.selectedMonth=inst.currentMonth=month;inst.selectedYear=inst.currentYear=year;if(inst.stayOpen){inst.endDay=inst.endMonth=inst.endYear=null;}
+this._selectDate(id,this._formatDate(inst,inst.currentDay,inst.currentMonth,inst.currentYear));if(inst.stayOpen){inst.rangeStart=this._daylightSavingAdjust(new Date(inst.currentYear,inst.currentMonth,inst.currentDay));this._updateDatepicker(inst);}},_clearDate:function(id){var target=$(id);var inst=this._getInst(target[0]);inst.stayOpen=false;inst.endDay=inst.endMonth=inst.endYear=inst.rangeStart=null;this._selectDate(target,'');},_selectDate:function(id,dateStr){var target=$(id);var inst=this._getInst(target[0]);dateStr=(dateStr!=null?dateStr:this._formatDate(inst));if(inst.input)
+inst.input.val(dateStr);this._updateAlternate(inst);var onSelect=this._get(inst,'onSelect');if(onSelect)
+onSelect.apply((inst.input?inst.input[0]:null),[dateStr,inst]);else if(inst.input)
+inst.input.trigger('change');if(inst.inline)
+this._updateDatepicker(inst);else if(!inst.stayOpen){this._hideDatepicker(null,this._get(inst,'duration'));this._lastInput=inst.input[0];if(typeof(inst.input[0])!='object')
+inst.input[0].focus();this._lastInput=null;}},_updateAlternate:function(inst){var altField=this._get(inst,'altField');if(altField){var altFormat=this._get(inst,'altFormat')||this._get(inst,'dateFormat');var date=this._getDate(inst);dateStr=this.formatDate(altFormat,date,this._getFormatConfig(inst));$(altField).each(function(){$(this).val(dateStr);});}},noWeekends:function(date){var day=date.getDay();return[(day>0&&day<6),''];},iso8601Week:function(date){var checkDate=new Date(date.getFullYear(),date.getMonth(),date.getDate());var firstMon=new Date(checkDate.getFullYear(),1-1,4);var firstDay=firstMon.getDay()||7;firstMon.setDate(firstMon.getDate()+1-firstDay);if(firstDay<4&&checkDate<firstMon){checkDate.setDate(checkDate.getDate()-3);return $.datepicker.iso8601Week(checkDate);}else if(checkDate>new Date(checkDate.getFullYear(),12-1,28)){firstDay=new Date(checkDate.getFullYear()+1,1-1,4).getDay()||7;if(firstDay>4&&(checkDate.getDay()||7)<firstDay-3){return 1;}}
+return Math.floor(((checkDate-firstMon)/86400000)/7)+1;},parseDate:function(format,value,settings){if(format==null||value==null)
+throw'Invalid arguments';value=(typeof value=='object'?value.toString():value+'');if(value=='')
+return null;var shortYearCutoff=(settings?settings.shortYearCutoff:null)||this._defaults.shortYearCutoff;var dayNamesShort=(settings?settings.dayNamesShort:null)||this._defaults.dayNamesShort;var dayNames=(settings?settings.dayNames:null)||this._defaults.dayNames;var monthNamesShort=(settings?settings.monthNamesShort:null)||this._defaults.monthNamesShort;var monthNames=(settings?settings.monthNames:null)||this._defaults.monthNames;var year=-1;var month=-1;var day=-1;var doy=-1;var literal=false;var lookAhead=function(match){var matches=(iFormat+1<format.length&&format.charAt(iFormat+1)==match);if(matches)
+iFormat++;return matches;};var getNumber=function(match){lookAhead(match);var origSize=(match=='@'?14:(match=='y'?4:(match=='o'?3:2)));var size=origSize;var num=0;while(size>0&&iValue<value.length&&value.charAt(iValue)>='0'&&value.charAt(iValue)<='9'){num=num*10+parseInt(value.charAt(iValue++),10);size--;}
+if(size==origSize)
+throw'Missing number at position '+iValue;return num;};var getName=function(match,shortNames,longNames){var names=(lookAhead(match)?longNames:shortNames);var size=0;for(var j=0;j<names.length;j++)
+size=Math.max(size,names[j].length);var name='';var iInit=iValue;while(size>0&&iValue<value.length){name+=value.charAt(iValue++);for(var i=0;i<names.length;i++)
+if(name==names[i])
+return i+1;size--;}
+throw'Unknown name at position '+iInit;};var checkLiteral=function(){if(value.charAt(iValue)!=format.charAt(iFormat))
+throw'Unexpected literal at position '+iValue;iValue++;};var iValue=0;for(var iFormat=0;iFormat<format.length;iFormat++){if(literal)
+if(format.charAt(iFormat)=="'"&&!lookAhead("'"))
+literal=false;else
+checkLiteral();else
+switch(format.charAt(iFormat)){case'd':day=getNumber('d');break;case'D':getName('D',dayNamesShort,dayNames);break;case'o':doy=getNumber('o');break;case'm':month=getNumber('m');break;case'M':month=getName('M',monthNamesShort,monthNames);break;case'y':year=getNumber('y');break;case'@':var date=new Date(getNumber('@'));year=date.getFullYear();month=date.getMonth()+1;day=date.getDate();break;case"'":if(lookAhead("'"))
+literal=true;break;default:checkLiteral();}}
+if(year==-1)
+year=new Date().getFullYear();else if(year<100)
+year+=new Date().getFullYear()-new Date().getFullYear()%100+
+(year<=shortYearCutoff?0:-100);if(doy>-1){month=1;day=doy;do{var dim=this._getDaysInMonth(year,month-1);if(day<=dim)
+break;month++;day-=dim;}while(true);}
+var date=this._daylightSavingAdjust(new Date(year,month-1,day));if(date.getFullYear()!=year||date.getMonth()+1!=month||date.getDate()!=day)
+throw'Invalid date';return date;},ATOM:'yy-mm-dd',COOKIE:'D, dd M yy',ISO_8601:'yy-mm-dd',RFC_822:'D, d M y',RFC_850:'DD, dd-M-y',RFC_1036:'D, d M y',RFC_1123:'D, d M yy',RFC_2822:'D, d M yy',RSS:'D, d M y',TIMESTAMP:'@',W3C:'yy-mm-dd',formatDate:function(format,date,settings){if(!date)
+return'';var dayNamesShort=(settings?settings.dayNamesShort:null)||this._defaults.dayNamesShort;var dayNames=(settings?settings.dayNames:null)||this._defaults.dayNames;var monthNamesShort=(settings?settings.monthNamesShort:null)||this._defaults.monthNamesShort;var monthNames=(settings?settings.monthNames:null)||this._defaults.monthNames;var lookAhead=function(match){var matches=(iFormat+1<format.length&&format.charAt(iFormat+1)==match);if(matches)
+iFormat++;return matches;};var formatNumber=function(match,value,len){var num=''+value;if(lookAhead(match))
+while(num.length<len)
+num='0'+num;return num;};var formatName=function(match,value,shortNames,longNames){return(lookAhead(match)?longNames[value]:shortNames[value]);};var output='';var literal=false;if(date)
+for(var iFormat=0;iFormat<format.length;iFormat++){if(literal)
+literal=false;else
+output+=format.charAt(iFormat);else
+switch(format.charAt(iFormat)){case'd':output+=formatNumber('d',date.getDate(),2);break;case'D':output+=formatName('D',date.getDay(),dayNamesShort,dayNames);break;case'o':var doy=date.getDate();for(var m=date.getMonth()-1;m>=0;m--)
+doy+=this._getDaysInMonth(date.getFullYear(),m);output+=formatNumber('o',doy,3);break;case'm':output+=formatNumber('m',date.getMonth()+1,2);break;case'M':output+=formatName('M',date.getMonth(),monthNamesShort,monthNames);break;case'y':output+=(lookAhead('y')?date.getFullYear():(date.getYear()%100<10?'0':'')+date.getYear()%100);break;case'@':output+=date.getTime();break;case"'":if(lookAhead("'"))
+output+="'";else
+literal=true;break;default:output+=format.charAt(iFormat);}}
+return output;},_possibleChars:function(format){var chars='';var literal=false;for(var iFormat=0;iFormat<format.length;iFormat++)
+if(literal)
+literal=false;else
+chars+=format.charAt(iFormat);else
+switch(format.charAt(iFormat)){case'd':case'm':case'y':case'@':chars+='0123456789';break;case'D':case'M':return null;case"'":if(lookAhead("'"))
+chars+="'";else
+literal=true;break;default:chars+=format.charAt(iFormat);}
+return chars;},_get:function(inst,name){return inst.settings[name]!==undefined?inst.settings[name]:this._defaults[name];},_setDateFromField:function(inst){var dateFormat=this._get(inst,'dateFormat');var dates=inst.input?inst.input.val():null;inst.endDay=inst.endMonth=inst.endYear=null;var date=defaultDate=this._getDefaultDate(inst);var settings=this._getFormatConfig(inst);try{date=this.parseDate(dateFormat,dates,settings)||defaultDate;}catch(event){this.log(event);date=defaultDate;}
+inst.selectedDay=date.getDate();inst.drawMonth=inst.selectedMonth=date.getMonth();inst.drawYear=inst.selectedYear=date.getFullYear();inst.currentDay=(dates?date.getDate():0);inst.currentMonth=(dates?date.getMonth():0);inst.currentYear=(dates?date.getFullYear():0);this._adjustInstDate(inst);},_getDefaultDate:function(inst){var date=this._determineDate(this._get(inst,'defaultDate'),new Date());var minDate=this._getMinMaxDate(inst,'min',true);var maxDate=this._getMinMaxDate(inst,'max');date=(minDate&&date<minDate?minDate:date);date=(maxDate&&date>maxDate?maxDate:date);return date;},_determineDate:function(date,defaultDate){var offsetNumeric=function(offset){var date=new Date();date.setDate(date.getDate()+offset);return date;};var offsetString=function(offset,getDaysInMonth){var date=new Date();var year=date.getFullYear();var month=date.getMonth();var day=date.getDate();var pattern=/([+-]?[0-9]+)\s*(d|D|w|W|m|M|y|Y)?/g;var matches=pattern.exec(offset);while(matches){switch(matches[2]||'d'){case'd':case'D':day+=parseInt(matches[1],10);break;case'w':case'W':day+=parseInt(matches[1],10)*7;break;case'm':case'M':month+=parseInt(matches[1],10);day=Math.min(day,getDaysInMonth(year,month));break;case'y':case'Y':year+=parseInt(matches[1],10);day=Math.min(day,getDaysInMonth(year,month));break;}
+matches=pattern.exec(offset);}
+return new Date(year,month,day);};date=(date==null?defaultDate:(typeof date=='string'?offsetString(date,this._getDaysInMonth):(typeof date=='number'?(isNaN(date)?defaultDate:offsetNumeric(date)):date)));date=(date&&date.toString()=='Invalid Date'?defaultDate:date);if(date){date.setHours(0);date.setMinutes(0);date.setSeconds(0);date.setMilliseconds(0);}
+return this._daylightSavingAdjust(date);},_daylightSavingAdjust:function(date){if(!date)return null;date.setHours(date.getHours()>12?date.getHours()+2:0);return date;},_setDate:function(inst,date,endDate){var clear=!(date);var origMonth=inst.selectedMonth;var origYear=inst.selectedYear;date=this._determineDate(date,new Date());inst.selectedDay=inst.currentDay=date.getDate();inst.drawMonth=inst.selectedMonth=inst.currentMonth=date.getMonth();inst.drawYear=inst.selectedYear=inst.currentYear=date.getFullYear();if(origMonth!=inst.selectedMonth||origYear!=inst.selectedYear)
+this._notifyChange(inst);this._adjustInstDate(inst);if(inst.input){inst.input.val(clear?'':this._formatDate(inst));}},_getDate:function(inst){var startDate=(!inst.currentYear||(inst.input&&inst.input.val()=='')?null:this._daylightSavingAdjust(new Date(inst.currentYear,inst.currentMonth,inst.currentDay)));return startDate;},_generateHTML:function(inst){var today=new Date();today=this._daylightSavingAdjust(new Date(today.getFullYear(),today.getMonth(),today.getDate()));var isRTL=this._get(inst,'isRTL');var showButtonPanel=this._get(inst,'showButtonPanel');var hideIfNoPrevNext=this._get(inst,'hideIfNoPrevNext');var navigationAsDateFormat=this._get(inst,'navigationAsDateFormat');var numMonths=this._getNumberOfMonths(inst);var showCurrentAtPos=this._get(inst,'showCurrentAtPos');var stepMonths=this._get(inst,'stepMonths');var stepBigMonths=this._get(inst,'stepBigMonths');var isMultiMonth=(numMonths[0]!=1||numMonths[1]!=1);var currentDate=this._daylightSavingAdjust((!inst.currentDay?new Date(9999,9,9):new Date(inst.currentYear,inst.currentMonth,inst.currentDay)));var minDate=this._getMinMaxDate(inst,'min',true);var maxDate=this._getMinMaxDate(inst,'max');var drawMonth=inst.drawMonth-showCurrentAtPos;var drawYear=inst.drawYear;if(drawMonth<0){drawMonth+=12;drawYear--;}
+if(maxDate){var maxDraw=this._daylightSavingAdjust(new Date(maxDate.getFullYear(),maxDate.getMonth()-numMonths[1]+1,maxDate.getDate()));maxDraw=(minDate&&maxDraw<minDate?minDate:maxDraw);while(this._daylightSavingAdjust(new Date(drawYear,drawMonth,1))>maxDraw){drawMonth--;if(drawMonth<0){drawMonth=11;drawYear--;}}}
+inst.drawMonth=drawMonth;inst.drawYear=drawYear;var prevText=this._get(inst,'prevText');prevText=(!navigationAsDateFormat?prevText:this.formatDate(prevText,this._daylightSavingAdjust(new Date(drawYear,drawMonth-stepMonths,1)),this._getFormatConfig(inst)));var prev=(this._canAdjustMonth(inst,-1,drawYear,drawMonth)?'<a class="ui-datepicker-prev ui-corner-all" onclick="DP_jQuery.datepicker._adjustDate(\'#'+inst.id+'\', -'+stepMonths+', \'M\');"'+' title="'+prevText+'"><span class="ui-icon ui-icon-circle-triangle-'+(isRTL?'e':'w')+'">'+prevText+'</span></a>':(hideIfNoPrevNext?'':'<a class="ui-datepicker-prev ui-corner-all ui-state-disabled" title="'+prevText+'"><span class="ui-icon ui-icon-circle-triangle-'+(isRTL?'e':'w')+'">'+prevText+'</span></a>'));var nextText=this._get(inst,'nextText');nextText=(!navigationAsDateFormat?nextText:this.formatDate(nextText,this._daylightSavingAdjust(new Date(drawYear,drawMonth+stepMonths,1)),this._getFormatConfig(inst)));var next=(this._canAdjustMonth(inst,+1,drawYear,drawMonth)?'<a class="ui-datepicker-next ui-corner-all" onclick="DP_jQuery.datepicker._adjustDate(\'#'+inst.id+'\', +'+stepMonths+', \'M\');"'+' title="'+nextText+'"><span class="ui-icon ui-icon-circle-triangle-'+(isRTL?'w':'e')+'">'+nextText+'</span></a>':(hideIfNoPrevNext?'':'<a class="ui-datepicker-next ui-corner-all ui-state-disabled" title="'+nextText+'"><span class="ui-icon ui-icon-circle-triangle-'+(isRTL?'w':'e')+'">'+nextText+'</span></a>'));var currentText=this._get(inst,'currentText');var gotoDate=(this._get(inst,'gotoCurrent')&&inst.currentDay?currentDate:today);currentText=(!navigationAsDateFormat?currentText:this.formatDate(currentText,gotoDate,this._getFormatConfig(inst)));var controls=(!inst.inline?'<button type="button" class="ui-datepicker-close ui-state-default ui-priority-primary ui-corner-all" onclick="DP_jQuery.datepicker._hideDatepicker();">'+this._get(inst,'closeText')+'</button>':'');var buttonPanel=(showButtonPanel)?'<div class="ui-datepicker-buttonpane ui-widget-content">'+(isRTL?controls:'')+
+(this._isInRange(inst,gotoDate)?'<button type="button" class="ui-datepicker-current ui-state-default ui-priority-secondary ui-corner-all" onclick="DP_jQuery.datepicker._gotoToday(\'#'+inst.id+'\');"'+'>'+currentText+'</button>':'')+(isRTL?'':controls)+'</div>':'';var firstDay=parseInt(this._get(inst,'firstDay'),10);firstDay=(isNaN(firstDay)?0:firstDay);var dayNames=this._get(inst,'dayNames');var dayNamesShort=this._get(inst,'dayNamesShort');var dayNamesMin=this._get(inst,'dayNamesMin');var monthNames=this._get(inst,'monthNames');var monthNamesShort=this._get(inst,'monthNamesShort');var beforeShowDay=this._get(inst,'beforeShowDay');var showOtherMonths=this._get(inst,'showOtherMonths');var calculateWeek=this._get(inst,'calculateWeek')||this.iso8601Week;var endDate=inst.endDay?this._daylightSavingAdjust(new Date(inst.endYear,inst.endMonth,inst.endDay)):currentDate;var defaultDate=this._getDefaultDate(inst);var html='';for(var row=0;row<numMonths[0];row++){var group='';for(var col=0;col<numMonths[1];col++){var selectedDate=this._daylightSavingAdjust(new Date(drawYear,drawMonth,inst.selectedDay));var cornerClass=' ui-corner-all';var calender='';if(isMultiMonth){calender+='<div class="ui-datepicker-group ui-datepicker-group-';switch(col){case 0:calender+='first';cornerClass=' ui-corner-'+(isRTL?'right':'left');break;case numMonths[1]-1:calender+='last';cornerClass=' ui-corner-'+(isRTL?'left':'right');break;default:calender+='middle';cornerClass='';break;}
+calender+='">';}
+calender+='<div class="ui-datepicker-header ui-widget-header ui-helper-clearfix'+cornerClass+'">'+
+(/all|left/.test(cornerClass)&&row==0?(isRTL?next:prev):'')+
+(/all|right/.test(cornerClass)&&row==0?(isRTL?prev:next):'')+
+this._generateMonthYearHeader(inst,drawMonth,drawYear,minDate,maxDate,selectedDate,row>0||col>0,monthNames,monthNamesShort)+'</div><table class="ui-datepicker-calendar"><thead>'+'<tr>';var thead='';for(var dow=0;dow<7;dow++){var day=(dow+firstDay)%7;thead+='<th'+((dow+firstDay+6)%7>=5?' class="ui-datepicker-week-end"':'')+'>'+'<span title="'+dayNames[day]+'">'+dayNamesMin[day]+'</span></th>';}
+calender+=thead+'</tr></thead><tbody>';var daysInMonth=this._getDaysInMonth(drawYear,drawMonth);if(drawYear==inst.selectedYear&&drawMonth==inst.selectedMonth)
+inst.selectedDay=Math.min(inst.selectedDay,daysInMonth);var leadDays=(this._getFirstDayOfMonth(drawYear,drawMonth)-firstDay+7)%7;var numRows=(isMultiMonth?6:Math.ceil((leadDays+daysInMonth)/7));var printDate=this._daylightSavingAdjust(new Date(drawYear,drawMonth,1-leadDays));for(var dRow=0;dRow<numRows;dRow++){calender+='<tr>';var tbody='';for(var dow=0;dow<7;dow++){var daySettings=(beforeShowDay?beforeShowDay.apply((inst.input?inst.input[0]:null),[printDate]):[true,'']);var otherMonth=(printDate.getMonth()!=drawMonth);var unselectable=otherMonth||!daySettings[0]||(minDate&&printDate<minDate)||(maxDate&&printDate>maxDate);tbody+='<td class="'+
+((dow+firstDay+6)%7>=5?' ui-datepicker-week-end':'')+
+(otherMonth?' ui-datepicker-other-month':'')+
+((printDate.getTime()==selectedDate.getTime()&&drawMonth==inst.selectedMonth&&inst._keyEvent)||(defaultDate.getTime()==printDate.getTime()&&defaultDate.getTime()==selectedDate.getTime())?' '+this._dayOverClass:'')+
+(unselectable?' '+this._unselectableClass+' ui-state-disabled':'')+
+(otherMonth&&!showOtherMonths?'':' '+daySettings[1]+
+(printDate.getTime()>=currentDate.getTime()&&printDate.getTime()<=endDate.getTime()?' '+this._currentClass:'')+
+(printDate.getTime()==today.getTime()?' ui-datepicker-today':''))+'"'+
+((!otherMonth||showOtherMonths)&&daySettings[2]?' title="'+daySettings[2]+'"':'')+
+(unselectable?'':' onclick="DP_jQuery.datepicker._selectDay(\'#'+
+inst.id+'\','+drawMonth+','+drawYear+', this);return false;"')+'>'+
+(otherMonth?(showOtherMonths?printDate.getDate():'&#xa0;'):(unselectable?'<span class="ui-state-default">'+printDate.getDate()+'</span>':'<a class="ui-state-default'+
+(printDate.getTime()==today.getTime()?' ui-state-highlight':'')+
+(printDate.getTime()>=currentDate.getTime()&&printDate.getTime()<=endDate.getTime()?' ui-state-active':'')+'" href="#">'+printDate.getDate()+'</a>'))+'</td>';printDate.setDate(printDate.getDate()+1);printDate=this._daylightSavingAdjust(printDate);}
+calender+=tbody+'</tr>';}
+drawMonth++;if(drawMonth>11){drawMonth=0;drawYear++;}
+calender+='</tbody></table>'+(isMultiMonth?'</div>'+
+((numMonths[0]>0&&col==numMonths[1]-1)?'<div class="ui-datepicker-row-break"></div>':''):'');group+=calender;}
+html+=group;}
+html+=buttonPanel+($.browser.msie&&parseInt($.browser.version,10)<7&&!inst.inline?'<iframe src="javascript:false;" class="ui-datepicker-cover" frameborder="0"></iframe>':'');inst._keyEvent=false;return html;},_generateMonthYearHeader:function(inst,drawMonth,drawYear,minDate,maxDate,selectedDate,secondary,monthNames,monthNamesShort){minDate=(inst.rangeStart&&minDate&&selectedDate<minDate?selectedDate:minDate);var changeMonth=this._get(inst,'changeMonth');var changeYear=this._get(inst,'changeYear');var showMonthAfterYear=this._get(inst,'showMonthAfterYear');var html='<div class="ui-datepicker-title">';var monthHtml='';if(secondary||!changeMonth)
+monthHtml+='<span class="ui-datepicker-month">'+monthNames[drawMonth]+'</span> ';else{var inMinYear=(minDate&&minDate.getFullYear()==drawYear);var inMaxYear=(maxDate&&maxDate.getFullYear()==drawYear);monthHtml+='<select class="ui-datepicker-month" '+'onchange="DP_jQuery.datepicker._selectMonthYear(\'#'+inst.id+'\', this, \'M\');" '+'onclick="DP_jQuery.datepicker._clickMonthYear(\'#'+inst.id+'\');"'+'>';for(var month=0;month<12;month++){if((!inMinYear||month>=minDate.getMonth())&&(!inMaxYear||month<=maxDate.getMonth()))
+monthHtml+='<option value="'+month+'"'+
+(month==drawMonth?' selected="selected"':'')+'>'+monthNamesShort[month]+'</option>';}
+monthHtml+='</select>';}
+if(!showMonthAfterYear)
+html+=monthHtml+((secondary||changeMonth||changeYear)&&(!(changeMonth&&changeYear))?'&#xa0;':'');if(secondary||!changeYear)
+html+='<span class="ui-datepicker-year">'+drawYear+'</span>';else{var years=this._get(inst,'yearRange').split(':');var year=0;var endYear=0;if(years.length!=2){year=drawYear-10;endYear=drawYear+10;}else if(years[0].charAt(0)=='+'||years[0].charAt(0)=='-'){year=drawYear+parseInt(years[0],10);endYear=drawYear+parseInt(years[1],10);}else{year=parseInt(years[0],10);endYear=parseInt(years[1],10);}
+year=(minDate?Math.max(year,minDate.getFullYear()):year);endYear=(maxDate?Math.min(endYear,maxDate.getFullYear()):endYear);html+='<select class="ui-datepicker-year" '+'onchange="DP_jQuery.datepicker._selectMonthYear(\'#'+inst.id+'\', this, \'Y\');" '+'onclick="DP_jQuery.datepicker._clickMonthYear(\'#'+inst.id+'\');"'+'>';for(;year<=endYear;year++){html+='<option value="'+year+'"'+
+(year==drawYear?' selected="selected"':'')+'>'+year+'</option>';}
+html+='</select>';}
+if(showMonthAfterYear)
+html+=(secondary||changeMonth||changeYear?'&#xa0;':'')+monthHtml;html+='</div>';return html;},_adjustInstDate:function(inst,offset,period){var year=inst.drawYear+(period=='Y'?offset:0);var month=inst.drawMonth+(period=='M'?offset:0);var day=Math.min(inst.selectedDay,this._getDaysInMonth(year,month))+
+(period=='D'?offset:0);var date=this._daylightSavingAdjust(new Date(year,month,day));var minDate=this._getMinMaxDate(inst,'min',true);var maxDate=this._getMinMaxDate(inst,'max');date=(minDate&&date<minDate?minDate:date);date=(maxDate&&date>maxDate?maxDate:date);inst.selectedDay=date.getDate();inst.drawMonth=inst.selectedMonth=date.getMonth();inst.drawYear=inst.selectedYear=date.getFullYear();if(period=='M'||period=='Y')
+this._notifyChange(inst);},_notifyChange:function(inst){var onChange=this._get(inst,'onChangeMonthYear');if(onChange)
+onChange.apply((inst.input?inst.input[0]:null),[inst.selectedYear,inst.selectedMonth+1,inst]);},_getNumberOfMonths:function(inst){var numMonths=this._get(inst,'numberOfMonths');return(numMonths==null?[1,1]:(typeof numMonths=='number'?[1,numMonths]:numMonths));},_getMinMaxDate:function(inst,minMax,checkRange){var date=this._determineDate(this._get(inst,minMax+'Date'),null);return(!checkRange||!inst.rangeStart?date:(!date||inst.rangeStart>date?inst.rangeStart:date));},_getDaysInMonth:function(year,month){return 32-new Date(year,month,32).getDate();},_getFirstDayOfMonth:function(year,month){return new Date(year,month,1).getDay();},_canAdjustMonth:function(inst,offset,curYear,curMonth){var numMonths=this._getNumberOfMonths(inst);var date=this._daylightSavingAdjust(new Date(curYear,curMonth+(offset<0?offset:numMonths[1]),1));if(offset<0)
+date.setDate(this._getDaysInMonth(date.getFullYear(),date.getMonth()));return this._isInRange(inst,date);},_isInRange:function(inst,date){var newMinDate=(!inst.rangeStart?null:this._daylightSavingAdjust(new Date(inst.selectedYear,inst.selectedMonth,inst.selectedDay)));newMinDate=(newMinDate&&inst.rangeStart<newMinDate?inst.rangeStart:newMinDate);var minDate=newMinDate||this._getMinMaxDate(inst,'min');var maxDate=this._getMinMaxDate(inst,'max');return((!minDate||date>=minDate)&&(!maxDate||date<=maxDate));},_getFormatConfig:function(inst){var shortYearCutoff=this._get(inst,'shortYearCutoff');shortYearCutoff=(typeof shortYearCutoff!='string'?shortYearCutoff:new Date().getFullYear()%100+parseInt(shortYearCutoff,10));return{shortYearCutoff:shortYearCutoff,dayNamesShort:this._get(inst,'dayNamesShort'),dayNames:this._get(inst,'dayNames'),monthNamesShort:this._get(inst,'monthNamesShort'),monthNames:this._get(inst,'monthNames')};},_formatDate:function(inst,day,month,year){if(!day){inst.currentDay=inst.selectedDay;inst.currentMonth=inst.selectedMonth;inst.currentYear=inst.selectedYear;}
+var date=(day?(typeof day=='object'?day:this._daylightSavingAdjust(new Date(year,month,day))):this._daylightSavingAdjust(new Date(inst.currentYear,inst.currentMonth,inst.currentDay)));return this.formatDate(this._get(inst,'dateFormat'),date,this._getFormatConfig(inst));}});function extendRemove(target,props){$.extend(target,props);for(var name in props)
+if(props[name]==null||props[name]==undefined)
+target[name]=props[name];return target;};function isArray(a){return(a&&(($.browser.safari&&typeof a=='object'&&a.length)||(a.constructor&&a.constructor.toString().match(/\Array\(\)/))));};$.fn.datepicker=function(options){if(!$.datepicker.initialized){$(document).mousedown($.datepicker._checkExternalClick).find('body').append($.datepicker.dpDiv);$.datepicker.initialized=true;}
+var otherArgs=Array.prototype.slice.call(arguments,1);if(typeof options=='string'&&(options=='isDisabled'||options=='getDate'))
+return $.datepicker['_'+options+'Datepicker'].apply($.datepicker,[this[0]].concat(otherArgs));if(options=='option'&&arguments.length==2&&typeof arguments[1]=='string')
+return $.datepicker['_'+options+'Datepicker'].apply($.datepicker,[this[0]].concat(otherArgs));return this.each(function(){typeof options=='string'?$.datepicker['_'+options+'Datepicker'].apply($.datepicker,[this].concat(otherArgs)):$.datepicker._attachDatepicker(this,options);});};$.datepicker=new Datepicker();$.datepicker.initialized=false;$.datepicker.uuid=new Date().getTime();$.datepicker.version="1.7.2";window.DP_jQuery=$;})(jQuery);(function($){$.widget("ui.progressbar",{_init:function(){this.element.addClass("ui-progressbar"
++" ui-widget"
++" ui-widget-content"
++" ui-corner-all").attr({role:"progressbar","aria-valuemin":this._valueMin(),"aria-valuemax":this._valueMax(),"aria-valuenow":this._value()});this.valueDiv=$('<div class="ui-progressbar-value ui-widget-header ui-corner-left"></div>').appendTo(this.element);this._refreshValue();},destroy:function(){this.element.removeClass("ui-progressbar"
++" ui-widget"
++" ui-corner-all").removeAttr("role").removeAttr("aria-valuemin").removeAttr("aria-valuemax").removeAttr("aria-valuenow").removeData("progressbar").unbind(".progressbar");this.valueDiv.remove();$.widget.prototype.destroy.apply(this,arguments);},value:function(newValue){if(newValue===undefined){return this._value();}
+this._setData('value',newValue);return this;},_setData:function(key,value){switch(key){case'value':this.options.value=value;this._refreshValue();this._trigger('change',null,{});break;}
+$.widget.prototype._setData.apply(this,arguments);},_value:function(){var val=this.options.value;if(val<this._valueMin())val=this._valueMin();if(val>this._valueMax())val=this._valueMax();return val;},_valueMin:function(){var valueMin=0;return valueMin;},_valueMax:function(){var valueMax=100;return valueMax;},_refreshValue:function(){var value=this.value();this.valueDiv[value==this._valueMax()?'addClass':'removeClass']("ui-corner-right");this.valueDiv.width(value+'%');this.element.attr("aria-valuenow",value);}});$.extend($.ui.progressbar,{version:"1.7.2",defaults:{value:0}});})(jQuery);;jQuery.effects||(function($){$.effects={version:"1.7.2",save:function(element,set){for(var i=0;i<set.length;i++){if(set[i]!==null)element.data("ec.storage."+set[i],element[0].style[set[i]]);}},restore:function(element,set){for(var i=0;i<set.length;i++){if(set[i]!==null)element.css(set[i],element.data("ec.storage."+set[i]));}},setMode:function(el,mode){if(mode=='toggle')mode=el.is(':hidden')?'show':'hide';return mode;},getBaseline:function(origin,original){var y,x;switch(origin[0]){case'top':y=0;break;case'middle':y=0.5;break;case'bottom':y=1;break;default:y=origin[0]/original.height;};switch(origin[1]){case'left':x=0;break;case'center':x=0.5;break;case'right':x=1;break;default:x=origin[1]/original.width;};return{x:x,y:y};},createWrapper:function(element){if(element.parent().is('.ui-effects-wrapper'))
+return element.parent();var props={width:element.outerWidth(true),height:element.outerHeight(true),'float':element.css('float')};element.wrap('<div class="ui-effects-wrapper" style="font-size:100%;background:transparent;border:none;margin:0;padding:0"></div>');var wrapper=element.parent();if(element.css('position')=='static'){wrapper.css({position:'relative'});element.css({position:'relative'});}else{var top=element.css('top');if(isNaN(parseInt(top,10)))top='auto';var left=element.css('left');if(isNaN(parseInt(left,10)))left='auto';wrapper.css({position:element.css('position'),top:top,left:left,zIndex:element.css('z-index')}).show();element.css({position:'relative',top:0,left:0});}
+wrapper.css(props);return wrapper;},removeWrapper:function(element){if(element.parent().is('.ui-effects-wrapper'))
+return element.parent().replaceWith(element);return element;},setTransition:function(element,list,factor,value){value=value||{};$.each(list,function(i,x){unit=element.cssUnit(x);if(unit[0]>0)value[x]=unit[0]*factor+unit[1];});return value;},animateClass:function(value,duration,easing,callback){var cb=(typeof easing=="function"?easing:(callback?callback:null));var ea=(typeof easing=="string"?easing:null);return this.each(function(){var offset={};var that=$(this);var oldStyleAttr=that.attr("style")||'';if(typeof oldStyleAttr=='object')oldStyleAttr=oldStyleAttr["cssText"];if(value.toggle){that.hasClass(value.toggle)?value.remove=value.toggle:value.add=value.toggle;}
+var oldStyle=$.extend({},(document.defaultView?document.defaultView.getComputedStyle(this,null):this.currentStyle));if(value.add)that.addClass(value.add);if(value.remove)that.removeClass(value.remove);var newStyle=$.extend({},(document.defaultView?document.defaultView.getComputedStyle(this,null):this.currentStyle));if(value.add)that.removeClass(value.add);if(value.remove)that.addClass(value.remove);for(var n in newStyle){if(typeof newStyle[n]!="function"&&newStyle[n]&&n.indexOf("Moz")==-1&&n.indexOf("length")==-1&&newStyle[n]!=oldStyle[n]&&(n.match(/color/i)||(!n.match(/color/i)&&!isNaN(parseInt(newStyle[n],10))))&&(oldStyle.position!="static"||(oldStyle.position=="static"&&!n.match(/left|top|bottom|right/))))offset[n]=newStyle[n];}
+that.animate(offset,duration,ea,function(){if(typeof $(this).attr("style")=='object'){$(this).attr("style")["cssText"]="";$(this).attr("style")["cssText"]=oldStyleAttr;}else $(this).attr("style",oldStyleAttr);if(value.add)$(this).addClass(value.add);if(value.remove)$(this).removeClass(value.remove);if(cb)cb.apply(this,arguments);});});}};function _normalizeArguments(a,m){var o=a[1]&&a[1].constructor==Object?a[1]:{};if(m)o.mode=m;var speed=a[1]&&a[1].constructor!=Object?a[1]:(o.duration?o.duration:a[2]);speed=$.fx.off?0:typeof speed==="number"?speed:$.fx.speeds[speed]||$.fx.speeds._default;var callback=o.callback||($.isFunction(a[1])&&a[1])||($.isFunction(a[2])&&a[2])||($.isFunction(a[3])&&a[3]);return[a[0],o,speed,callback];}
+$.fn.extend({_show:$.fn.show,_hide:$.fn.hide,__toggle:$.fn.toggle,_addClass:$.fn.addClass,_removeClass:$.fn.removeClass,_toggleClass:$.fn.toggleClass,effect:function(fx,options,speed,callback){return $.effects[fx]?$.effects[fx].call(this,{method:fx,options:options||{},duration:speed,callback:callback}):null;},show:function(){if(!arguments[0]||(arguments[0].constructor==Number||(/(slow|normal|fast)/).test(arguments[0])))
+return this._show.apply(this,arguments);else{return this.effect.apply(this,_normalizeArguments(arguments,'show'));}},hide:function(){if(!arguments[0]||(arguments[0].constructor==Number||(/(slow|normal|fast)/).test(arguments[0])))
+return this._hide.apply(this,arguments);else{return this.effect.apply(this,_normalizeArguments(arguments,'hide'));}},toggle:function(){if(!arguments[0]||(arguments[0].constructor==Number||(/(slow|normal|fast)/).test(arguments[0]))||($.isFunction(arguments[0])||typeof arguments[0]=='boolean')){return this.__toggle.apply(this,arguments);}else{return this.effect.apply(this,_normalizeArguments(arguments,'toggle'));}},addClass:function(classNames,speed,easing,callback){return speed?$.effects.animateClass.apply(this,[{add:classNames},speed,easing,callback]):this._addClass(classNames);},removeClass:function(classNames,speed,easing,callback){return speed?$.effects.animateClass.apply(this,[{remove:classNames},speed,easing,callback]):this._removeClass(classNames);},toggleClass:function(classNames,speed,easing,callback){return((typeof speed!=="boolean")&&speed)?$.effects.animateClass.apply(this,[{toggle:classNames},speed,easing,callback]):this._toggleClass(classNames,speed);},morph:function(remove,add,speed,easing,callback){return $.effects.animateClass.apply(this,[{add:add,remove:remove},speed,easing,callback]);},switchClass:function(){return this.morph.apply(this,arguments);},cssUnit:function(key){var style=this.css(key),val=[];$.each(['em','px','%','pt'],function(i,unit){if(style.indexOf(unit)>0)
+val=[parseFloat(style),unit];});return val;}});$.each(['backgroundColor','borderBottomColor','borderLeftColor','borderRightColor','borderTopColor','color','outlineColor'],function(i,attr){$.fx.step[attr]=function(fx){if(fx.state==0){fx.start=getColor(fx.elem,attr);fx.end=getRGB(fx.end);}
+fx.elem.style[attr]="rgb("+[Math.max(Math.min(parseInt((fx.pos*(fx.end[0]-fx.start[0]))+fx.start[0],10),255),0),Math.max(Math.min(parseInt((fx.pos*(fx.end[1]-fx.start[1]))+fx.start[1],10),255),0),Math.max(Math.min(parseInt((fx.pos*(fx.end[2]-fx.start[2]))+fx.start[2],10),255),0)].join(",")+")";};});function getRGB(color){var result;if(color&&color.constructor==Array&&color.length==3)
+return color;if(result=/rgb\(\s*([0-9]{1,3})\s*,\s*([0-9]{1,3})\s*,\s*([0-9]{1,3})\s*\)/.exec(color))
+return[parseInt(result[1],10),parseInt(result[2],10),parseInt(result[3],10)];if(result=/rgb\(\s*([0-9]+(?:\.[0-9]+)?)\%\s*,\s*([0-9]+(?:\.[0-9]+)?)\%\s*,\s*([0-9]+(?:\.[0-9]+)?)\%\s*\)/.exec(color))
+return[parseFloat(result[1])*2.55,parseFloat(result[2])*2.55,parseFloat(result[3])*2.55];if(result=/#([a-fA-F0-9]{2})([a-fA-F0-9]{2})([a-fA-F0-9]{2})/.exec(color))
+return[parseInt(result[1],16),parseInt(result[2],16),parseInt(result[3],16)];if(result=/#([a-fA-F0-9])([a-fA-F0-9])([a-fA-F0-9])/.exec(color))
+return[parseInt(result[1]+result[1],16),parseInt(result[2]+result[2],16),parseInt(result[3]+result[3],16)];if(result=/rgba\(0, 0, 0, 0\)/.exec(color))
+return colors['transparent'];return colors[$.trim(color).toLowerCase()];}
+function getColor(elem,attr){var color;do{color=$.curCSS(elem,attr);if(color!=''&&color!='transparent'||$.nodeName(elem,"body"))
+break;attr="backgroundColor";}while(elem=elem.parentNode);return getRGB(color);};var colors={aqua:[0,255,255],azure:[240,255,255],beige:[245,245,220],black:[0,0,0],blue:[0,0,255],brown:[165,42,42],cyan:[0,255,255],darkblue:[0,0,139],darkcyan:[0,139,139],darkgrey:[169,169,169],darkgreen:[0,100,0],darkkhaki:[189,183,107],darkmagenta:[139,0,139],darkolivegreen:[85,107,47],darkorange:[255,140,0],darkorchid:[153,50,204],darkred:[139,0,0],darksalmon:[233,150,122],darkviolet:[148,0,211],fuchsia:[255,0,255],gold:[255,215,0],green:[0,128,0],indigo:[75,0,130],khaki:[240,230,140],lightblue:[173,216,230],lightcyan:[224,255,255],lightgreen:[144,238,144],lightgrey:[211,211,211],lightpink:[255,182,193],lightyellow:[255,255,224],lime:[0,255,0],magenta:[255,0,255],maroon:[128,0,0],navy:[0,0,128],olive:[128,128,0],orange:[255,165,0],pink:[255,192,203],purple:[128,0,128],violet:[128,0,128],red:[255,0,0],silver:[192,192,192],white:[255,255,255],yellow:[255,255,0],transparent:[255,255,255]};$.easing.jswing=$.easing.swing;$.extend($.easing,{def:'easeOutQuad',swing:function(x,t,b,c,d){return $.easing[$.easing.def](x,t,b,c,d);},easeInQuad:function(x,t,b,c,d){return c*(t/=d)*t+b;},easeOutQuad:function(x,t,b,c,d){return-c*(t/=d)*(t-2)+b;},easeInOutQuad:function(x,t,b,c,d){if((t/=d/2)<1)return c/2*t*t+b;return-c/2*((--t)*(t-2)-1)+b;},easeInCubic:function(x,t,b,c,d){return c*(t/=d)*t*t+b;},easeOutCubic:function(x,t,b,c,d){return c*((t=t/d-1)*t*t+1)+b;},easeInOutCubic:function(x,t,b,c,d){if((t/=d/2)<1)return c/2*t*t*t+b;return c/2*((t-=2)*t*t+2)+b;},easeInQuart:function(x,t,b,c,d){return c*(t/=d)*t*t*t+b;},easeOutQuart:function(x,t,b,c,d){return-c*((t=t/d-1)*t*t*t-1)+b;},easeInOutQuart:function(x,t,b,c,d){if((t/=d/2)<1)return c/2*t*t*t*t+b;return-c/2*((t-=2)*t*t*t-2)+b;},easeInQuint:function(x,t,b,c,d){return c*(t/=d)*t*t*t*t+b;},easeOutQuint:function(x,t,b,c,d){return c*((t=t/d-1)*t*t*t*t+1)+b;},easeInOutQuint:function(x,t,b,c,d){if((t/=d/2)<1)return c/2*t*t*t*t*t+b;return c/2*((t-=2)*t*t*t*t+2)+b;},easeInSine:function(x,t,b,c,d){return-c*Math.cos(t/d*(Math.PI/2))+c+b;},easeOutSine:function(x,t,b,c,d){return c*Math.sin(t/d*(Math.PI/2))+b;},easeInOutSine:function(x,t,b,c,d){return-c/2*(Math.cos(Math.PI*t/d)-1)+b;},easeInExpo:function(x,t,b,c,d){return(t==0)?b:c*Math.pow(2,10*(t/d-1))+b;},easeOutExpo:function(x,t,b,c,d){return(t==d)?b+c:c*(-Math.pow(2,-10*t/d)+1)+b;},easeInOutExpo:function(x,t,b,c,d){if(t==0)return b;if(t==d)return b+c;if((t/=d/2)<1)return c/2*Math.pow(2,10*(t-1))+b;return c/2*(-Math.pow(2,-10*--t)+2)+b;},easeInCirc:function(x,t,b,c,d){return-c*(Math.sqrt(1-(t/=d)*t)-1)+b;},easeOutCirc:function(x,t,b,c,d){return c*Math.sqrt(1-(t=t/d-1)*t)+b;},easeInOutCirc:function(x,t,b,c,d){if((t/=d/2)<1)return-c/2*(Math.sqrt(1-t*t)-1)+b;return c/2*(Math.sqrt(1-(t-=2)*t)+1)+b;},easeInElastic:function(x,t,b,c,d){var s=1.70158;var p=0;var a=c;if(t==0)return b;if((t/=d)==1)return b+c;if(!p)p=d*.3;if(a<Math.abs(c)){a=c;var s=p/4;}
+else var s=p/(2*Math.PI)*Math.asin(c/a);return-(a*Math.pow(2,10*(t-=1))*Math.sin((t*d-s)*(2*Math.PI)/p))+b;},easeOutElastic:function(x,t,b,c,d){var s=1.70158;var p=0;var a=c;if(t==0)return b;if((t/=d)==1)return b+c;if(!p)p=d*.3;if(a<Math.abs(c)){a=c;var s=p/4;}
+else var s=p/(2*Math.PI)*Math.asin(c/a);return a*Math.pow(2,-10*t)*Math.sin((t*d-s)*(2*Math.PI)/p)+c+b;},easeInOutElastic:function(x,t,b,c,d){var s=1.70158;var p=0;var a=c;if(t==0)return b;if((t/=d/2)==2)return b+c;if(!p)p=d*(.3*1.5);if(a<Math.abs(c)){a=c;var s=p/4;}
+else var s=p/(2*Math.PI)*Math.asin(c/a);if(t<1)return-.5*(a*Math.pow(2,10*(t-=1))*Math.sin((t*d-s)*(2*Math.PI)/p))+b;return a*Math.pow(2,-10*(t-=1))*Math.sin((t*d-s)*(2*Math.PI)/p)*.5+c+b;},easeInBack:function(x,t,b,c,d,s){if(s==undefined)s=1.70158;return c*(t/=d)*t*((s+1)*t-s)+b;},easeOutBack:function(x,t,b,c,d,s){if(s==undefined)s=1.70158;return c*((t=t/d-1)*t*((s+1)*t+s)+1)+b;},easeInOutBack:function(x,t,b,c,d,s){if(s==undefined)s=1.70158;if((t/=d/2)<1)return c/2*(t*t*(((s*=(1.525))+1)*t-s))+b;return c/2*((t-=2)*t*(((s*=(1.525))+1)*t+s)+2)+b;},easeInBounce:function(x,t,b,c,d){return c-$.easing.easeOutBounce(x,d-t,0,c,d)+b;},easeOutBounce:function(x,t,b,c,d){if((t/=d)<(1/2.75)){return c*(7.5625*t*t)+b;}else if(t<(2/2.75)){return c*(7.5625*(t-=(1.5/2.75))*t+.75)+b;}else if(t<(2.5/2.75)){return c*(7.5625*(t-=(2.25/2.75))*t+.9375)+b;}else{return c*(7.5625*(t-=(2.625/2.75))*t+.984375)+b;}},easeInOutBounce:function(x,t,b,c,d){if(t<d/2)return $.easing.easeInBounce(x,t*2,0,c,d)*.5+b;return $.easing.easeOutBounce(x,t*2-d,0,c,d)*.5+c*.5+b;}});})(jQuery);(function($){$.effects.blind=function(o){return this.queue(function(){var el=$(this),props=['position','top','left'];var mode=$.effects.setMode(el,o.options.mode||'hide');var direction=o.options.direction||'vertical';$.effects.save(el,props);el.show();var wrapper=$.effects.createWrapper(el).css({overflow:'hidden'});var ref=(direction=='vertical')?'height':'width';var distance=(direction=='vertical')?wrapper.height():wrapper.width();if(mode=='show')wrapper.css(ref,0);var animation={};animation[ref]=mode=='show'?distance:0;wrapper.animate(animation,o.duration,o.options.easing,function(){if(mode=='hide')el.hide();$.effects.restore(el,props);$.effects.removeWrapper(el);if(o.callback)o.callback.apply(el[0],arguments);el.dequeue();});});};})(jQuery);(function($){$.effects.bounce=function(o){return this.queue(function(){var el=$(this),props=['position','top','left'];var mode=$.effects.setMode(el,o.options.mode||'effect');var direction=o.options.direction||'up';var distance=o.options.distance||20;var times=o.options.times||5;var speed=o.duration||250;if(/show|hide/.test(mode))props.push('opacity');$.effects.save(el,props);el.show();$.effects.createWrapper(el);var ref=(direction=='up'||direction=='down')?'top':'left';var motion=(direction=='up'||direction=='left')?'pos':'neg';var distance=o.options.distance||(ref=='top'?el.outerHeight({margin:true})/3:el.outerWidth({margin:true})/3);if(mode=='show')el.css('opacity',0).css(ref,motion=='pos'?-distance:distance);if(mode=='hide')distance=distance/(times*2);if(mode!='hide')times--;if(mode=='show'){var animation={opacity:1};animation[ref]=(motion=='pos'?'+=':'-=')+distance;el.animate(animation,speed/2,o.options.easing);distance=distance/2;times--;};for(var i=0;i<times;i++){var animation1={},animation2={};animation1[ref]=(motion=='pos'?'-=':'+=')+distance;animation2[ref]=(motion=='pos'?'+=':'-=')+distance;el.animate(animation1,speed/2,o.options.easing).animate(animation2,speed/2,o.options.easing);distance=(mode=='hide')?distance*2:distance/2;};if(mode=='hide'){var animation={opacity:0};animation[ref]=(motion=='pos'?'-=':'+=')+distance;el.animate(animation,speed/2,o.options.easing,function(){el.hide();$.effects.restore(el,props);$.effects.removeWrapper(el);if(o.callback)o.callback.apply(this,arguments);});}else{var animation1={},animation2={};animation1[ref]=(motion=='pos'?'-=':'+=')+distance;animation2[ref]=(motion=='pos'?'+=':'-=')+distance;el.animate(animation1,speed/2,o.options.easing).animate(animation2,speed/2,o.options.easing,function(){$.effects.restore(el,props);$.effects.removeWrapper(el);if(o.callback)o.callback.apply(this,arguments);});};el.queue('fx',function(){el.dequeue();});el.dequeue();});};})(jQuery);(function($){$.effects.clip=function(o){return this.queue(function(){var el=$(this),props=['position','top','left','height','width'];var mode=$.effects.setMode(el,o.options.mode||'hide');var direction=o.options.direction||'vertical';$.effects.save(el,props);el.show();var wrapper=$.effects.createWrapper(el).css({overflow:'hidden'});var animate=el[0].tagName=='IMG'?wrapper:el;var ref={size:(direction=='vertical')?'height':'width',position:(direction=='vertical')?'top':'left'};var distance=(direction=='vertical')?animate.height():animate.width();if(mode=='show'){animate.css(ref.size,0);animate.css(ref.position,distance/2);}
+var animation={};animation[ref.size]=mode=='show'?distance:0;animation[ref.position]=mode=='show'?0:distance/2;animate.animate(animation,{queue:false,duration:o.duration,easing:o.options.easing,complete:function(){if(mode=='hide')el.hide();$.effects.restore(el,props);$.effects.removeWrapper(el);if(o.callback)o.callback.apply(el[0],arguments);el.dequeue();}});});};})(jQuery);(function($){$.effects.drop=function(o){return this.queue(function(){var el=$(this),props=['position','top','left','opacity'];var mode=$.effects.setMode(el,o.options.mode||'hide');var direction=o.options.direction||'left';$.effects.save(el,props);el.show();$.effects.createWrapper(el);var ref=(direction=='up'||direction=='down')?'top':'left';var motion=(direction=='up'||direction=='left')?'pos':'neg';var distance=o.options.distance||(ref=='top'?el.outerHeight({margin:true})/2:el.outerWidth({margin:true})/2);if(mode=='show')el.css('opacity',0).css(ref,motion=='pos'?-distance:distance);var animation={opacity:mode=='show'?1:0};animation[ref]=(mode=='show'?(motion=='pos'?'+=':'-='):(motion=='pos'?'-=':'+='))+distance;el.animate(animation,{queue:false,duration:o.duration,easing:o.options.easing,complete:function(){if(mode=='hide')el.hide();$.effects.restore(el,props);$.effects.removeWrapper(el);if(o.callback)o.callback.apply(this,arguments);el.dequeue();}});});};})(jQuery);(function($){$.effects.explode=function(o){return this.queue(function(){var rows=o.options.pieces?Math.round(Math.sqrt(o.options.pieces)):3;var cells=o.options.pieces?Math.round(Math.sqrt(o.options.pieces)):3;o.options.mode=o.options.mode=='toggle'?($(this).is(':visible')?'hide':'show'):o.options.mode;var el=$(this).show().css('visibility','hidden');var offset=el.offset();offset.top-=parseInt(el.css("marginTop"),10)||0;offset.left-=parseInt(el.css("marginLeft"),10)||0;var width=el.outerWidth(true);var height=el.outerHeight(true);for(var i=0;i<rows;i++){for(var j=0;j<cells;j++){el.clone().appendTo('body').wrap('<div></div>').css({position:'absolute',visibility:'visible',left:-j*(width/cells),top:-i*(height/rows)}).parent().addClass('ui-effects-explode').css({position:'absolute',overflow:'hidden',width:width/cells,height:height/rows,left:offset.left+j*(width/cells)+(o.options.mode=='show'?(j-Math.floor(cells/2))*(width/cells):0),top:offset.top+i*(height/rows)+(o.options.mode=='show'?(i-Math.floor(rows/2))*(height/rows):0),opacity:o.options.mode=='show'?0:1}).animate({left:offset.left+j*(width/cells)+(o.options.mode=='show'?0:(j-Math.floor(cells/2))*(width/cells)),top:offset.top+i*(height/rows)+(o.options.mode=='show'?0:(i-Math.floor(rows/2))*(height/rows)),opacity:o.options.mode=='show'?1:0},o.duration||500);}}
+setTimeout(function(){o.options.mode=='show'?el.css({visibility:'visible'}):el.css({visibility:'visible'}).hide();if(o.callback)o.callback.apply(el[0]);el.dequeue();$('div.ui-effects-explode').remove();},o.duration||500);});};})(jQuery);(function($){$.effects.fold=function(o){return this.queue(function(){var el=$(this),props=['position','top','left'];var mode=$.effects.setMode(el,o.options.mode||'hide');var size=o.options.size||15;var horizFirst=!(!o.options.horizFirst);var duration=o.duration?o.duration/2:$.fx.speeds._default/2;$.effects.save(el,props);el.show();var wrapper=$.effects.createWrapper(el).css({overflow:'hidden'});var widthFirst=((mode=='show')!=horizFirst);var ref=widthFirst?['width','height']:['height','width'];var distance=widthFirst?[wrapper.width(),wrapper.height()]:[wrapper.height(),wrapper.width()];var percent=/([0-9]+)%/.exec(size);if(percent)size=parseInt(percent[1],10)/100*distance[mode=='hide'?0:1];if(mode=='show')wrapper.css(horizFirst?{height:0,width:size}:{height:size,width:0});var animation1={},animation2={};animation1[ref[0]]=mode=='show'?distance[0]:size;animation2[ref[1]]=mode=='show'?distance[1]:0;wrapper.animate(animation1,duration,o.options.easing).animate(animation2,duration,o.options.easing,function(){if(mode=='hide')el.hide();$.effects.restore(el,props);$.effects.removeWrapper(el);if(o.callback)o.callback.apply(el[0],arguments);el.dequeue();});});};})(jQuery);(function($){$.effects.highlight=function(o){return this.queue(function(){var el=$(this),props=['backgroundImage','backgroundColor','opacity'];var mode=$.effects.setMode(el,o.options.mode||'show');var color=o.options.color||"#ffff99";var oldColor=el.css("backgroundColor");$.effects.save(el,props);el.show();el.css({backgroundImage:'none',backgroundColor:color});var animation={backgroundColor:oldColor};if(mode=="hide")animation['opacity']=0;el.animate(animation,{queue:false,duration:o.duration,easing:o.options.easing,complete:function(){if(mode=="hide")el.hide();$.effects.restore(el,props);if(mode=="show"&&$.browser.msie)this.style.removeAttribute('filter');if(o.callback)o.callback.apply(this,arguments);el.dequeue();}});});};})(jQuery);(function($){$.effects.pulsate=function(o){return this.queue(function(){var el=$(this);var mode=$.effects.setMode(el,o.options.mode||'show');var times=o.options.times||5;var duration=o.duration?o.duration/2:$.fx.speeds._default/2;if(mode=='hide')times--;if(el.is(':hidden')){el.css('opacity',0);el.show();el.animate({opacity:1},duration,o.options.easing);times=times-2;}
+for(var i=0;i<times;i++){el.animate({opacity:0},duration,o.options.easing).animate({opacity:1},duration,o.options.easing);};if(mode=='hide'){el.animate({opacity:0},duration,o.options.easing,function(){el.hide();if(o.callback)o.callback.apply(this,arguments);});}else{el.animate({opacity:0},duration,o.options.easing).animate({opacity:1},duration,o.options.easing,function(){if(o.callback)o.callback.apply(this,arguments);});};el.queue('fx',function(){el.dequeue();});el.dequeue();});};})(jQuery);(function($){$.effects.puff=function(o){return this.queue(function(){var el=$(this);var options=$.extend(true,{},o.options);var mode=$.effects.setMode(el,o.options.mode||'hide');var percent=parseInt(o.options.percent,10)||150;options.fade=true;var original={height:el.height(),width:el.width()};var factor=percent/100;el.from=(mode=='hide')?original:{height:original.height*factor,width:original.width*factor};options.from=el.from;options.percent=(mode=='hide')?percent:100;options.mode=mode;el.effect('scale',options,o.duration,o.callback);el.dequeue();});};$.effects.scale=function(o){return this.queue(function(){var el=$(this);var options=$.extend(true,{},o.options);var mode=$.effects.setMode(el,o.options.mode||'effect');var percent=parseInt(o.options.percent,10)||(parseInt(o.options.percent,10)==0?0:(mode=='hide'?0:100));var direction=o.options.direction||'both';var origin=o.options.origin;if(mode!='effect'){options.origin=origin||['middle','center'];options.restore=true;}
+var original={height:el.height(),width:el.width()};el.from=o.options.from||(mode=='show'?{height:0,width:0}:original);var factor={y:direction!='horizontal'?(percent/100):1,x:direction!='vertical'?(percent/100):1};el.to={height:original.height*factor.y,width:original.width*factor.x};if(o.options.fade){if(mode=='show'){el.from.opacity=0;el.to.opacity=1;};if(mode=='hide'){el.from.opacity=1;el.to.opacity=0;};};options.from=el.from;options.to=el.to;options.mode=mode;el.effect('size',options,o.duration,o.callback);el.dequeue();});};$.effects.size=function(o){return this.queue(function(){var el=$(this),props=['position','top','left','width','height','overflow','opacity'];var props1=['position','top','left','overflow','opacity'];var props2=['width','height','overflow'];var cProps=['fontSize'];var vProps=['borderTopWidth','borderBottomWidth','paddingTop','paddingBottom'];var hProps=['borderLeftWidth','borderRightWidth','paddingLeft','paddingRight'];var mode=$.effects.setMode(el,o.options.mode||'effect');var restore=o.options.restore||false;var scale=o.options.scale||'both';var origin=o.options.origin;var original={height:el.height(),width:el.width()};el.from=o.options.from||original;el.to=o.options.to||original;if(origin){var baseline=$.effects.getBaseline(origin,original);el.from.top=(original.height-el.from.height)*baseline.y;el.from.left=(original.width-el.from.width)*baseline.x;el.to.top=(original.height-el.to.height)*baseline.y;el.to.left=(original.width-el.to.width)*baseline.x;};var factor={from:{y:el.from.height/original.height,x:el.from.width/original.width},to:{y:el.to.height/original.height,x:el.to.width/original.width}};if(scale=='box'||scale=='both'){if(factor.from.y!=factor.to.y){props=props.concat(vProps);el.from=$.effects.setTransition(el,vProps,factor.from.y,el.from);el.to=$.effects.setTransition(el,vProps,factor.to.y,el.to);};if(factor.from.x!=factor.to.x){props=props.concat(hProps);el.from=$.effects.setTransition(el,hProps,factor.from.x,el.from);el.to=$.effects.setTransition(el,hProps,factor.to.x,el.to);};};if(scale=='content'||scale=='both'){if(factor.from.y!=factor.to.y){props=props.concat(cProps);el.from=$.effects.setTransition(el,cProps,factor.from.y,el.from);el.to=$.effects.setTransition(el,cProps,factor.to.y,el.to);};};$.effects.save(el,restore?props:props1);el.show();$.effects.createWrapper(el);el.css('overflow','hidden').css(el.from);if(scale=='content'||scale=='both'){vProps=vProps.concat(['marginTop','marginBottom']).concat(cProps);hProps=hProps.concat(['marginLeft','marginRight']);props2=props.concat(vProps).concat(hProps);el.find("*[width]").each(function(){child=$(this);if(restore)$.effects.save(child,props2);var c_original={height:child.height(),width:child.width()};child.from={height:c_original.height*factor.from.y,width:c_original.width*factor.from.x};child.to={height:c_original.height*factor.to.y,width:c_original.width*factor.to.x};if(factor.from.y!=factor.to.y){child.from=$.effects.setTransition(child,vProps,factor.from.y,child.from);child.to=$.effects.setTransition(child,vProps,factor.to.y,child.to);};if(factor.from.x!=factor.to.x){child.from=$.effects.setTransition(child,hProps,factor.from.x,child.from);child.to=$.effects.setTransition(child,hProps,factor.to.x,child.to);};child.css(child.from);child.animate(child.to,o.duration,o.options.easing,function(){if(restore)$.effects.restore(child,props2);});});};el.animate(el.to,{queue:false,duration:o.duration,easing:o.options.easing,complete:function(){if(mode=='hide')el.hide();$.effects.restore(el,restore?props:props1);$.effects.removeWrapper(el);if(o.callback)o.callback.apply(this,arguments);el.dequeue();}});});};})(jQuery);(function($){$.effects.shake=function(o){return this.queue(function(){var el=$(this),props=['position','top','left'];var mode=$.effects.setMode(el,o.options.mode||'effect');var direction=o.options.direction||'left';var distance=o.options.distance||20;var times=o.options.times||3;var speed=o.duration||o.options.duration||140;$.effects.save(el,props);el.show();$.effects.createWrapper(el);var ref=(direction=='up'||direction=='down')?'top':'left';var motion=(direction=='up'||direction=='left')?'pos':'neg';var animation={},animation1={},animation2={};animation[ref]=(motion=='pos'?'-=':'+=')+distance;animation1[ref]=(motion=='pos'?'+=':'-=')+distance*2;animation2[ref]=(motion=='pos'?'-=':'+=')+distance*2;el.animate(animation,speed,o.options.easing);for(var i=1;i<times;i++){el.animate(animation1,speed,o.options.easing).animate(animation2,speed,o.options.easing);};el.animate(animation1,speed,o.options.easing).animate(animation,speed/2,o.options.easing,function(){$.effects.restore(el,props);$.effects.removeWrapper(el);if(o.callback)o.callback.apply(this,arguments);});el.queue('fx',function(){el.dequeue();});el.dequeue();});};})(jQuery);(function($){$.effects.slide=function(o){return this.queue(function(){var el=$(this),props=['position','top','left'];var mode=$.effects.setMode(el,o.options.mode||'show');var direction=o.options.direction||'left';$.effects.save(el,props);el.show();$.effects.createWrapper(el).css({overflow:'hidden'});var ref=(direction=='up'||direction=='down')?'top':'left';var motion=(direction=='up'||direction=='left')?'pos':'neg';var distance=o.options.distance||(ref=='top'?el.outerHeight({margin:true}):el.outerWidth({margin:true}));if(mode=='show')el.css(ref,motion=='pos'?-distance:distance);var animation={};animation[ref]=(mode=='show'?(motion=='pos'?'+=':'-='):(motion=='pos'?'-=':'+='))+distance;el.animate(animation,{queue:false,duration:o.duration,easing:o.options.easing,complete:function(){if(mode=='hide')el.hide();$.effects.restore(el,props);$.effects.removeWrapper(el);if(o.callback)o.callback.apply(this,arguments);el.dequeue();}});});};})(jQuery);(function($){$.effects.transfer=function(o){return this.queue(function(){var elem=$(this),target=$(o.options.to),endPosition=target.offset(),animation={top:endPosition.top,left:endPosition.left,height:target.innerHeight(),width:target.innerWidth()},startPosition=elem.offset(),transfer=$('<div class="ui-effects-transfer"></div>').appendTo(document.body).addClass(o.options.className).css({top:startPosition.top,left:startPosition.left,height:elem.innerHeight(),width:elem.innerWidth(),position:'absolute'}).animate(animation,o.duration,o.options.easing,function(){transfer.remove();(o.callback&&o.callback.apply(elem[0],arguments));elem.dequeue();});});};})(jQuery);
\ No newline at end of file
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.accordion.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.accordion.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.accordion.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,28 @@
+(function($){$.widget("ui.accordion",{_init:function(){var o=this.options,self=this;this.running=0;if(o.collapsible==$.ui.accordion.defaults.collapsible&&o.alwaysOpen!=$.ui.accordion.defaults.alwaysOpen){o.collapsible=!o.alwaysOpen;}
+if(o.navigation){var current=this.element.find("a").filter(o.navigationFilter);if(current.length){if(current.filter(o.header).length){this.active=current;}else{this.active=current.parent().parent().prev();current.addClass("ui-accordion-content-active");}}}
+this.element.addClass("ui-accordion ui-widget ui-helper-reset");if(this.element[0].nodeName=="UL"){this.element.children("li").addClass("ui-accordion-li-fix");}
+this.headers=this.element.find(o.header).addClass("ui-accordion-header ui-helper-reset ui-state-default ui-corner-all").bind("mouseenter.accordion",function(){$(this).addClass('ui-state-hover');}).bind("mouseleave.accordion",function(){$(this).removeClass('ui-state-hover');}).bind("focus.accordion",function(){$(this).addClass('ui-state-focus');}).bind("blur.accordion",function(){$(this).removeClass('ui-state-focus');});this.headers.next().addClass("ui-accordion-content ui-helper-reset ui-widget-content ui-corner-bottom");this.active=this._findActive(this.active||o.active).toggleClass("ui-state-default").toggleClass("ui-state-active").toggleClass("ui-corner-all").toggleClass("ui-corner-top");this.active.next().addClass('ui-accordion-content-active');$("<span/>").addClass("ui-icon "+o.icons.header).prependTo(this.headers);this.active.find(".ui-icon").toggleClass(o.icons.header).toggleClass(o.icons.headerSelected);if($.browser.msie){this.element.find('a').css('zoom','1');}
+this.resize();this.element.attr('role','tablist');this.headers.attr('role','tab').bind('keydown',function(event){return self._keydown(event);}).next().attr('role','tabpanel');this.headers.not(this.active||"").attr('aria-expanded','false').attr("tabIndex","-1").next().hide();if(!this.active.length){this.headers.eq(0).attr('tabIndex','0');}else{this.active.attr('aria-expanded','true').attr('tabIndex','0');}
+if(!$.browser.safari)
+this.headers.find('a').attr('tabIndex','-1');if(o.event){this.headers.bind((o.event)+".accordion",function(event){return self._clickHandler.call(self,event,this);});}},destroy:function(){var o=this.options;this.element.removeClass("ui-accordion ui-widget ui-helper-reset").removeAttr("role").unbind('.accordion').removeData('accordion');this.headers.unbind(".accordion").removeClass("ui-accordion-header ui-helper-reset ui-state-default ui-corner-all ui-state-active ui-corner-top").removeAttr("role").removeAttr("aria-expanded").removeAttr("tabindex");this.headers.find("a").removeAttr("tabindex");this.headers.children(".ui-icon").remove();var contents=this.headers.next().css("display","").removeAttr("role").removeClass("ui-helper-reset ui-widget-content ui-corner-bottom ui-accordion-content ui-accordion-content-active");if(o.autoHeight||o.fillHeight){contents.css("height","");}},_setData:function(key,value){if(key=='alwaysOpen'){key='collapsible';value=!value;}
+$.widget.prototype._setData.apply(this,arguments);},_keydown:function(event){var o=this.options,keyCode=$.ui.keyCode;if(o.disabled||event.altKey||event.ctrlKey)
+return;var length=this.headers.length;var currentIndex=this.headers.index(event.target);var toFocus=false;switch(event.keyCode){case keyCode.RIGHT:case keyCode.DOWN:toFocus=this.headers[(currentIndex+1)%length];break;case keyCode.LEFT:case keyCode.UP:toFocus=this.headers[(currentIndex-1+length)%length];break;case keyCode.SPACE:case keyCode.ENTER:return this._clickHandler({target:event.target},event.target);}
+if(toFocus){$(event.target).attr('tabIndex','-1');$(toFocus).attr('tabIndex','0');toFocus.focus();return false;}
+return true;},resize:function(){var o=this.options,maxHeight;if(o.fillSpace){if($.browser.msie){var defOverflow=this.element.parent().css('overflow');this.element.parent().css('overflow','hidden');}
+maxHeight=this.element.parent().height();if($.browser.msie){this.element.parent().css('overflow',defOverflow);}
+this.headers.each(function(){maxHeight-=$(this).outerHeight();});var maxPadding=0;this.headers.next().each(function(){maxPadding=Math.max(maxPadding,$(this).innerHeight()-$(this).height());}).height(Math.max(0,maxHeight-maxPadding)).css('overflow','auto');}else if(o.autoHeight){maxHeight=0;this.headers.next().each(function(){maxHeight=Math.max(maxHeight,$(this).outerHeight());}).height(maxHeight);}},activate:function(index){var active=this._findActive(index)[0];this._clickHandler({target:active},active);},_findActive:function(selector){return selector?typeof selector=="number"?this.headers.filter(":eq("+selector+")"):this.headers.not(this.headers.not(selector)):selector===false?$([]):this.headers.filter(":eq(0)");},_clickHandler:function(event,target){var o=this.options;if(o.disabled)return false;if(!event.target&&o.collapsible){this.active.removeClass("ui-state-active ui-corner-top").addClass("ui-state-default ui-corner-all").find(".ui-icon").removeClass(o.icons.headerSelected).addClass(o.icons.header);this.active.next().addClass('ui-accordion-content-active');var toHide=this.active.next(),data={options:o,newHeader:$([]),oldHeader:o.active,newContent:$([]),oldContent:toHide},toShow=(this.active=$([]));this._toggle(toShow,toHide,data);return false;}
+var clicked=$(event.currentTarget||target);var clickedIsActive=clicked[0]==this.active[0];if(this.running||(!o.collapsible&&clickedIsActive)){return false;}
+this.active.removeClass("ui-state-active ui-corner-top").addClass("ui-state-default ui-corner-all").find(".ui-icon").removeClass(o.icons.headerSelected).addClass(o.icons.header);this.active.next().addClass('ui-accordion-content-active');if(!clickedIsActive){clicked.removeClass("ui-state-default ui-corner-all").addClass("ui-state-active ui-corner-top").find(".ui-icon").removeClass(o.icons.header).addClass(o.icons.headerSelected);clicked.next().addClass('ui-accordion-content-active');}
+var toShow=clicked.next(),toHide=this.active.next(),data={options:o,newHeader:clickedIsActive&&o.collapsible?$([]):clicked,oldHeader:this.active,newContent:clickedIsActive&&o.collapsible?$([]):toShow.find('> *'),oldContent:toHide.find('> *')},down=this.headers.index(this.active[0])>this.headers.index(clicked[0]);this.active=clickedIsActive?$([]):clicked;this._toggle(toShow,toHide,data,clickedIsActive,down);return false;},_toggle:function(toShow,toHide,data,clickedIsActive,down){var o=this.options,self=this;this.toShow=toShow;this.toHide=toHide;this.data=data;var complete=function(){if(!self)return;return self._completed.apply(self,arguments);};this._trigger("changestart",null,this.data);this.running=toHide.size()===0?toShow.size():toHide.size();if(o.animated){var animOptions={};if(o.collapsible&&clickedIsActive){animOptions={toShow:$([]),toHide:toHide,complete:complete,down:down,autoHeight:o.autoHeight||o.fillSpace};}else{animOptions={toShow:toShow,toHide:toHide,complete:complete,down:down,autoHeight:o.autoHeight||o.fillSpace};}
+if(!o.proxied){o.proxied=o.animated;}
+if(!o.proxiedDuration){o.proxiedDuration=o.duration;}
+o.animated=$.isFunction(o.proxied)?o.proxied(animOptions):o.proxied;o.duration=$.isFunction(o.proxiedDuration)?o.proxiedDuration(animOptions):o.proxiedDuration;var animations=$.ui.accordion.animations,duration=o.duration,easing=o.animated;if(!animations[easing]){animations[easing]=function(options){this.slide(options,{easing:easing,duration:duration||700});};}
+animations[easing](animOptions);}else{if(o.collapsible&&clickedIsActive){toShow.toggle();}else{toHide.hide();toShow.show();}
+complete(true);}
+toHide.prev().attr('aria-expanded','false').attr("tabIndex","-1").blur();toShow.prev().attr('aria-expanded','true').attr("tabIndex","0").focus();},_completed:function(cancel){var o=this.options;this.running=cancel?0:--this.running;if(this.running)return;if(o.clearStyle){this.toShow.add(this.toHide).css({height:"",overflow:""});}
+this._trigger('change',null,this.data);}});$.extend($.ui.accordion,{version:"1.7.2",defaults:{active:null,alwaysOpen:true,animated:'slide',autoHeight:true,clearStyle:false,collapsible:false,event:"click",fillSpace:false,header:"> li > :first-child,> :not(li):even",icons:{header:"ui-icon-triangle-1-e",headerSelected:"ui-icon-triangle-1-s"},navigation:false,navigationFilter:function(){return this.href.toLowerCase()==location.href.toLowerCase();}},animations:{slide:function(options,additions){options=$.extend({easing:"swing",duration:300},options,additions);if(!options.toHide.size()){options.toShow.animate({height:"show"},options);return;}
+if(!options.toShow.size()){options.toHide.animate({height:"hide"},options);return;}
+var overflow=options.toShow.css('overflow'),percentDone,showProps={},hideProps={},fxAttrs=["height","paddingTop","paddingBottom"],originalWidth;var s=options.toShow;originalWidth=s[0].style.width;s.width(parseInt(s.parent().width(),10)-parseInt(s.css("paddingLeft"),10)-parseInt(s.css("paddingRight"),10)-(parseInt(s.css("borderLeftWidth"),10)||0)-(parseInt(s.css("borderRightWidth"),10)||0));$.each(fxAttrs,function(i,prop){hideProps[prop]='hide';var parts=(''+$.css(options.toShow[0],prop)).match(/^([\d+-.]+)(.*)$/);showProps[prop]={value:parts[1],unit:parts[2]||'px'};});options.toShow.css({height:0,overflow:'hidden'}).show();options.toHide.filter(":hidden").each(options.complete).end().filter(":visible").animate(hideProps,{step:function(now,settings){if(settings.prop=='height'){percentDone=(settings.now-settings.start)/(settings.end-settings.start);}
+options.toShow[0].style[settings.prop]=(percentDone*showProps[settings.prop].value)+showProps[settings.prop].unit;},duration:options.duration,easing:options.easing,complete:function(){if(!options.autoHeight){options.toShow.css("height","");}
+options.toShow.css("width",originalWidth);options.toShow.css({overflow:overflow});options.complete();}});},bounceslide:function(options){this.slide(options,{easing:options.down?"easeOutBounce":"swing",duration:options.down?1000:200});},easeslide:function(options){this.slide(options,{easing:"easeinout",duration:700});}}});})(jQuery);
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.core.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.core.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.core.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,25 @@
+;jQuery.ui||(function($){var _remove=$.fn.remove,isFF2=$.browser.mozilla&&(parseFloat($.browser.version)<1.9);$.ui={version:"1.7.2",plugin:{add:function(module,option,set){var proto=$.ui[module].prototype;for(var i in set){proto.plugins[i]=proto.plugins[i]||[];proto.plugins[i].push([option,set[i]]);}},call:function(instance,name,args){var set=instance.plugins[name];if(!set||!instance.element[0].parentNode){return;}
+for(var i=0;i<set.length;i++){if(instance.options[set[i][0]]){set[i][1].apply(instance.element,args);}}}},contains:function(a,b){return document.compareDocumentPosition?a.compareDocumentPosition(b)&16:a!==b&&a.contains(b);},hasScroll:function(el,a){if($(el).css('overflow')=='hidden'){return false;}
+var scroll=(a&&a=='left')?'scrollLeft':'scrollTop',has=false;if(el[scroll]>0){return true;}
+el[scroll]=1;has=(el[scroll]>0);el[scroll]=0;return has;},isOverAxis:function(x,reference,size){return(x>reference)&&(x<(reference+size));},isOver:function(y,x,top,left,height,width){return $.ui.isOverAxis(y,top,height)&&$.ui.isOverAxis(x,left,width);},keyCode:{BACKSPACE:8,CAPS_LOCK:20,COMMA:188,CONTROL:17,DELETE:46,DOWN:40,END:35,ENTER:13,ESCAPE:27,HOME:36,INSERT:45,LEFT:37,NUMPAD_ADD:107,NUMPAD_DECIMAL:110,NUMPAD_DIVIDE:111,NUMPAD_ENTER:108,NUMPAD_MULTIPLY:106,NUMPAD_SUBTRACT:109,PAGE_DOWN:34,PAGE_UP:33,PERIOD:190,RIGHT:39,SHIFT:16,SPACE:32,TAB:9,UP:38}};if(isFF2){var attr=$.attr,removeAttr=$.fn.removeAttr,ariaNS="http://www.w3.org/2005/07/aaa",ariaState=/^aria-/,ariaRole=/^wairole:/;$.attr=function(elem,name,value){var set=value!==undefined;return(name=='role'?(set?attr.call(this,elem,name,"wairole:"+value):(attr.apply(this,arguments)||"").replace(ariaRole,"")):(ariaState.test(name)?(set?elem.setAttributeNS(ariaNS,name.replace(ariaState,"aaa:"),value):attr.call(this,elem,name.replace(ariaState,"aaa:"))):attr.apply(this,arguments)));};$.fn.removeAttr=function(name){return(ariaState.test(name)?this.each(function(){this.removeAttributeNS(ariaNS,name.replace(ariaState,""));}):removeAttr.call(this,name));};}
+$.fn.extend({remove:function(){$("*",this).add(this).each(function(){$(this).triggerHandler("remove");});return _remove.apply(this,arguments);},enableSelection:function(){return this.attr('unselectable','off').css('MozUserSelect','').unbind('selectstart.ui');},disableSelection:function(){return this.attr('unselectable','on').css('MozUserSelect','none').bind('selectstart.ui',function(){return false;});},scrollParent:function(){var scrollParent;if(($.browser.msie&&(/(static|relative)/).test(this.css('position')))||(/absolute/).test(this.css('position'))){scrollParent=this.parents().filter(function(){return(/(relative|absolute|fixed)/).test($.curCSS(this,'position',1))&&(/(auto|scroll)/).test($.curCSS(this,'overflow',1)+$.curCSS(this,'overflow-y',1)+$.curCSS(this,'overflow-x',1));}).eq(0);}else{scrollParent=this.parents().filter(function(){return(/(auto|scroll)/).test($.curCSS(this,'overflow',1)+$.curCSS(this,'overflow-y',1)+$.curCSS(this,'overflow-x',1));}).eq(0);}
+return(/fixed/).test(this.css('position'))||!scrollParent.length?$(document):scrollParent;}});$.extend($.expr[':'],{data:function(elem,i,match){return!!$.data(elem,match[3]);},focusable:function(element){var nodeName=element.nodeName.toLowerCase(),tabIndex=$.attr(element,'tabindex');return(/input|select|textarea|button|object/.test(nodeName)?!element.disabled:'a'==nodeName||'area'==nodeName?element.href||!isNaN(tabIndex):!isNaN(tabIndex))&&!$(element)['area'==nodeName?'parents':'closest'](':hidden').length;},tabbable:function(element){var tabIndex=$.attr(element,'tabindex');return(isNaN(tabIndex)||tabIndex>=0)&&$(element).is(':focusable');}});function getter(namespace,plugin,method,args){function getMethods(type){var methods=$[namespace][plugin][type]||[];return(typeof methods=='string'?methods.split(/,?\s+/):methods);}
+var methods=getMethods('getter');if(args.length==1&&typeof args[0]=='string'){methods=methods.concat(getMethods('getterSetter'));}
+return($.inArray(method,methods)!=-1);}
+$.widget=function(name,prototype){var namespace=name.split(".")[0];name=name.split(".")[1];$.fn[name]=function(options){var isMethodCall=(typeof options=='string'),args=Array.prototype.slice.call(arguments,1);if(isMethodCall&&options.substring(0,1)=='_'){return this;}
+if(isMethodCall&&getter(namespace,name,options,args)){var instance=$.data(this[0],name);return(instance?instance[options].apply(instance,args):undefined);}
+return this.each(function(){var instance=$.data(this,name);(!instance&&!isMethodCall&&$.data(this,name,new $[namespace][name](this,options))._init());(instance&&isMethodCall&&$.isFunction(instance[options])&&instance[options].apply(instance,args));});};$[namespace]=$[namespace]||{};$[namespace][name]=function(element,options){var self=this;this.namespace=namespace;this.widgetName=name;this.widgetEventPrefix=$[namespace][name].eventPrefix||name;this.widgetBaseClass=namespace+'-'+name;this.options=$.extend({},$.widget.defaults,$[namespace][name].defaults,$.metadata&&$.metadata.get(element)[name],options);this.element=$(element).bind('setData.'+name,function(event,key,value){if(event.target==element){return self._setData(key,value);}}).bind('getData.'+name,function(event,key){if(event.target==element){return self._getData(key);}}).bind('remove',function(){return self.destroy();});};$[namespace][name].prototype=$.extend({},$.widget.prototype,prototype);$[namespace][name].getterSetter='option';};$.widget.prototype={_init:function(){},destroy:function(){this.element.removeData(this.widgetName).removeClass(this.widgetBaseClass+'-disabled'+' '+this.namespace+'-state-disabled').removeAttr('aria-disabled');},option:function(key,value){var options=key,self=this;if(typeof key=="string"){if(value===undefined){return this._getData(key);}
+options={};options[key]=value;}
+$.each(options,function(key,value){self._setData(key,value);});},_getData:function(key){return this.options[key];},_setData:function(key,value){this.options[key]=value;if(key=='disabled'){this.element
+[value?'addClass':'removeClass'](this.widgetBaseClass+'-disabled'+' '+
+this.namespace+'-state-disabled').attr("aria-disabled",value);}},enable:function(){this._setData('disabled',false);},disable:function(){this._setData('disabled',true);},_trigger:function(type,event,data){var callback=this.options[type],eventName=(type==this.widgetEventPrefix?type:this.widgetEventPrefix+type);event=$.Event(event);event.type=eventName;if(event.originalEvent){for(var i=$.event.props.length,prop;i;){prop=$.event.props[--i];event[prop]=event.originalEvent[prop];}}
+this.element.trigger(event,data);return!($.isFunction(callback)&&callback.call(this.element[0],event,data)===false||event.isDefaultPrevented());}};$.widget.defaults={disabled:false};$.ui.mouse={_mouseInit:function(){var self=this;this.element.bind('mousedown.'+this.widgetName,function(event){return self._mouseDown(event);}).bind('click.'+this.widgetName,function(event){if(self._preventClickEvent){self._preventClickEvent=false;event.stopImmediatePropagation();return false;}});if($.browser.msie){this._mouseUnselectable=this.element.attr('unselectable');this.element.attr('unselectable','on');}
+this.started=false;},_mouseDestroy:function(){this.element.unbind('.'+this.widgetName);($.browser.msie&&this.element.attr('unselectable',this._mouseUnselectable));},_mouseDown:function(event){event.originalEvent=event.originalEvent||{};if(event.originalEvent.mouseHandled){return;}
+(this._mouseStarted&&this._mouseUp(event));this._mouseDownEvent=event;var self=this,btnIsLeft=(event.which==1),elIsCancel=(typeof this.options.cancel=="string"?$(event.target).parents().add(event.target).filter(this.options.cancel).length:false);if(!btnIsLeft||elIsCancel||!this._mouseCapture(event)){return true;}
+this.mouseDelayMet=!this.options.delay;if(!this.mouseDelayMet){this._mouseDelayTimer=setTimeout(function(){self.mouseDelayMet=true;},this.options.delay);}
+if(this._mouseDistanceMet(event)&&this._mouseDelayMet(event)){this._mouseStarted=(this._mouseStart(event)!==false);if(!this._mouseStarted){event.preventDefault();return true;}}
+this._mouseMoveDelegate=function(event){return self._mouseMove(event);};this._mouseUpDelegate=function(event){return self._mouseUp(event);};$(document).bind('mousemove.'+this.widgetName,this._mouseMoveDelegate).bind('mouseup.'+this.widgetName,this._mouseUpDelegate);($.browser.safari||event.preventDefault());event.originalEvent.mouseHandled=true;return true;},_mouseMove:function(event){if($.browser.msie&&!event.button){return this._mouseUp(event);}
+if(this._mouseStarted){this._mouseDrag(event);return event.preventDefault();}
+if(this._mouseDistanceMet(event)&&this._mouseDelayMet(event)){this._mouseStarted=(this._mouseStart(this._mouseDownEvent,event)!==false);(this._mouseStarted?this._mouseDrag(event):this._mouseUp(event));}
+return!this._mouseStarted;},_mouseUp:function(event){$(document).unbind('mousemove.'+this.widgetName,this._mouseMoveDelegate).unbind('mouseup.'+this.widgetName,this._mouseUpDelegate);if(this._mouseStarted){this._mouseStarted=false;this._preventClickEvent=(event.target==this._mouseDownEvent.target);this._mouseStop(event);}
+return false;},_mouseDistanceMet:function(event){return(Math.max(Math.abs(this._mouseDownEvent.pageX-event.pageX),Math.abs(this._mouseDownEvent.pageY-event.pageY))>=this.options.distance);},_mouseDelayMet:function(event){return this.mouseDelayMet;},_mouseStart:function(event){},_mouseDrag:function(event){},_mouseStop:function(event){},_mouseCapture:function(event){return true;}};$.ui.mouse.defaults={cancel:null,distance:1,delay:0};})(jQuery);
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.datepicker.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.datepicker.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.datepicker.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,174 @@
+(function($){$.extend($.ui,{datepicker:{version:"1.7.2"}});var PROP_NAME='datepicker';function Datepicker(){this.debug=false;this._curInst=null;this._keyEvent=false;this._disabledInputs=[];this._datepickerShowing=false;this._inDialog=false;this._mainDivId='ui-datepicker-div';this._inlineClass='ui-datepicker-inline';this._appendClass='ui-datepicker-append';this._triggerClass='ui-datepicker-trigger';this._dialogClass='ui-datepicker-dialog';this._disableClass='ui-datepicker-disabled';this._unselectableClass='ui-datepicker-unselectable';this._currentClass='ui-datepicker-current-day';this._dayOverClass='ui-datepicker-days-cell-over';this.regional=[];this.regional['']={closeText:'Done',prevText:'Prev',nextText:'Next',currentText:'Today',monthNames:['January','February','March','April','May','June','July','August','September','October','November','December'],monthNamesShort:['Jan','Feb','Mar','Apr','May','Jun','Jul','Aug','Sep','Oct','Nov','Dec'],dayNames:['Sunday','Monday','Tuesday','Wednesday','Thursday','Friday','Saturday'],dayNamesShort:['Sun','Mon','Tue','Wed','Thu','Fri','Sat'],dayNamesMin:['Su','Mo','Tu','We','Th','Fr','Sa'],dateFormat:'mm/dd/yy',firstDay:0,isRTL:false};this._defaults={showOn:'focus',showAnim:'show',showOptions:{},defaultDate:null,appendText:'',buttonText:'...',buttonImage:'',buttonImageOnly:false,hideIfNoPrevNext:false,navigationAsDateFormat:false,gotoCurrent:false,changeMonth:false,changeYear:false,showMonthAfterYear:false,yearRange:'-10:+10',showOtherMonths:false,calculateWeek:this.iso8601Week,shortYearCutoff:'+10',minDate:null,maxDate:null,duration:'normal',beforeShowDay:null,beforeShow:null,onSelect:null,onChangeMonthYear:null,onClose:null,numberOfMonths:1,showCurrentAtPos:0,stepMonths:1,stepBigMonths:12,altField:'',altFormat:'',constrainInput:true,showButtonPanel:false};$.extend(this._defaults,this.regional['']);this.dpDiv=$('<div id="'+this._mainDivId+'" class="ui-datepicker ui-widget ui-widget-content ui-helper-clearfix ui-corner-all ui-helper-hidden-accessible"></div>');}
+$.extend(Datepicker.prototype,{markerClassName:'hasDatepicker',log:function(){if(this.debug)
+console.log.apply('',arguments);},setDefaults:function(settings){extendRemove(this._defaults,settings||{});return this;},_attachDatepicker:function(target,settings){var inlineSettings=null;for(var attrName in this._defaults){var attrValue=target.getAttribute('date:'+attrName);if(attrValue){inlineSettings=inlineSettings||{};try{inlineSettings[attrName]=eval(attrValue);}catch(err){inlineSettings[attrName]=attrValue;}}}
+var nodeName=target.nodeName.toLowerCase();var inline=(nodeName=='div'||nodeName=='span');if(!target.id)
+target.id='dp'+(++this.uuid);var inst=this._newInst($(target),inline);inst.settings=$.extend({},settings||{},inlineSettings||{});if(nodeName=='input'){this._connectDatepicker(target,inst);}else if(inline){this._inlineDatepicker(target,inst);}},_newInst:function(target,inline){var id=target[0].id.replace(/([:\[\]\.])/g,'\\\\$1');return{id:id,input:target,selectedDay:0,selectedMonth:0,selectedYear:0,drawMonth:0,drawYear:0,inline:inline,dpDiv:(!inline?this.dpDiv:$('<div class="'+this._inlineClass+' ui-datepicker ui-widget ui-widget-content ui-helper-clearfix ui-corner-all"></div>'))};},_connectDatepicker:function(target,inst){var input=$(target);inst.append=$([]);inst.trigger=$([]);if(input.hasClass(this.markerClassName))
+return;var appendText=this._get(inst,'appendText');var isRTL=this._get(inst,'isRTL');if(appendText){inst.append=$('<span class="'+this._appendClass+'">'+appendText+'</span>');input[isRTL?'before':'after'](inst.append);}
+var showOn=this._get(inst,'showOn');if(showOn=='focus'||showOn=='both')
+input.focus(this._showDatepicker);if(showOn=='button'||showOn=='both'){var buttonText=this._get(inst,'buttonText');var buttonImage=this._get(inst,'buttonImage');inst.trigger=$(this._get(inst,'buttonImageOnly')?$('<img/>').addClass(this._triggerClass).attr({src:buttonImage,alt:buttonText,title:buttonText}):$('<button type="button"></button>').addClass(this._triggerClass).html(buttonImage==''?buttonText:$('<img/>').attr({src:buttonImage,alt:buttonText,title:buttonText})));input[isRTL?'before':'after'](inst.trigger);inst.trigger.click(function(){if($.datepicker._datepickerShowing&&$.datepicker._lastInput==target)
+$.datepicker._hideDatepicker();else
+$.datepicker._showDatepicker(target);return false;});}
+input.addClass(this.markerClassName).keydown(this._doKeyDown).keypress(this._doKeyPress).bind("setData.datepicker",function(event,key,value){inst.settings[key]=value;}).bind("getData.datepicker",function(event,key){return this._get(inst,key);});$.data(target,PROP_NAME,inst);},_inlineDatepicker:function(target,inst){var divSpan=$(target);if(divSpan.hasClass(this.markerClassName))
+return;divSpan.addClass(this.markerClassName).append(inst.dpDiv).bind("setData.datepicker",function(event,key,value){inst.settings[key]=value;}).bind("getData.datepicker",function(event,key){return this._get(inst,key);});$.data(target,PROP_NAME,inst);this._setDate(inst,this._getDefaultDate(inst));this._updateDatepicker(inst);this._updateAlternate(inst);},_dialogDatepicker:function(input,dateText,onSelect,settings,pos){var inst=this._dialogInst;if(!inst){var id='dp'+(++this.uuid);this._dialogInput=$('<input type="text" id="'+id+'" size="1" style="position: absolute; top: -100px;"/>');this._dialogInput.keydown(this._doKeyDown);$('body').append(this._dialogInput);inst=this._dialogInst=this._newInst(this._dialogInput,false);inst.settings={};$.data(this._dialogInput[0],PROP_NAME,inst);}
+extendRemove(inst.settings,settings||{});this._dialogInput.val(dateText);this._pos=(pos?(pos.length?pos:[pos.pageX,pos.pageY]):null);if(!this._pos){var browserWidth=window.innerWidth||document.documentElement.clientWidth||document.body.clientWidth;var browserHeight=window.innerHeight||document.documentElement.clientHeight||document.body.clientHeight;var scrollX=document.documentElement.scrollLeft||document.body.scrollLeft;var scrollY=document.documentElement.scrollTop||document.body.scrollTop;this._pos=[(browserWidth/2)-100+scrollX,(browserHeight/2)-150+scrollY];}
+this._dialogInput.css('left',this._pos[0]+'px').css('top',this._pos[1]+'px');inst.settings.onSelect=onSelect;this._inDialog=true;this.dpDiv.addClass(this._dialogClass);this._showDatepicker(this._dialogInput[0]);if($.blockUI)
+$.blockUI(this.dpDiv);$.data(this._dialogInput[0],PROP_NAME,inst);return this;},_destroyDatepicker:function(target){var $target=$(target);var inst=$.data(target,PROP_NAME);if(!$target.hasClass(this.markerClassName)){return;}
+var nodeName=target.nodeName.toLowerCase();$.removeData(target,PROP_NAME);if(nodeName=='input'){inst.append.remove();inst.trigger.remove();$target.removeClass(this.markerClassName).unbind('focus',this._showDatepicker).unbind('keydown',this._doKeyDown).unbind('keypress',this._doKeyPress);}else if(nodeName=='div'||nodeName=='span')
+$target.removeClass(this.markerClassName).empty();},_enableDatepicker:function(target){var $target=$(target);var inst=$.data(target,PROP_NAME);if(!$target.hasClass(this.markerClassName)){return;}
+var nodeName=target.nodeName.toLowerCase();if(nodeName=='input'){target.disabled=false;inst.trigger.filter('button').each(function(){this.disabled=false;}).end().filter('img').css({opacity:'1.0',cursor:''});}
+else if(nodeName=='div'||nodeName=='span'){var inline=$target.children('.'+this._inlineClass);inline.children().removeClass('ui-state-disabled');}
+this._disabledInputs=$.map(this._disabledInputs,function(value){return(value==target?null:value);});},_disableDatepicker:function(target){var $target=$(target);var inst=$.data(target,PROP_NAME);if(!$target.hasClass(this.markerClassName)){return;}
+var nodeName=target.nodeName.toLowerCase();if(nodeName=='input'){target.disabled=true;inst.trigger.filter('button').each(function(){this.disabled=true;}).end().filter('img').css({opacity:'0.5',cursor:'default'});}
+else if(nodeName=='div'||nodeName=='span'){var inline=$target.children('.'+this._inlineClass);inline.children().addClass('ui-state-disabled');}
+this._disabledInputs=$.map(this._disabledInputs,function(value){return(value==target?null:value);});this._disabledInputs[this._disabledInputs.length]=target;},_isDisabledDatepicker:function(target){if(!target){return false;}
+for(var i=0;i<this._disabledInputs.length;i++){if(this._disabledInputs[i]==target)
+return true;}
+return false;},_getInst:function(target){try{return $.data(target,PROP_NAME);}
+catch(err){throw'Missing instance data for this datepicker';}},_optionDatepicker:function(target,name,value){var inst=this._getInst(target);if(arguments.length==2&&typeof name=='string'){return(name=='defaults'?$.extend({},$.datepicker._defaults):(inst?(name=='all'?$.extend({},inst.settings):this._get(inst,name)):null));}
+var settings=name||{};if(typeof name=='string'){settings={};settings[name]=value;}
+if(inst){if(this._curInst==inst){this._hideDatepicker(null);}
+var date=this._getDateDatepicker(target);extendRemove(inst.settings,settings);this._setDateDatepicker(target,date);this._updateDatepicker(inst);}},_changeDatepicker:function(target,name,value){this._optionDatepicker(target,name,value);},_refreshDatepicker:function(target){var inst=this._getInst(target);if(inst){this._updateDatepicker(inst);}},_setDateDatepicker:function(target,date,endDate){var inst=this._getInst(target);if(inst){this._setDate(inst,date,endDate);this._updateDatepicker(inst);this._updateAlternate(inst);}},_getDateDatepicker:function(target){var inst=this._getInst(target);if(inst&&!inst.inline)
+this._setDateFromField(inst);return(inst?this._getDate(inst):null);},_doKeyDown:function(event){var inst=$.datepicker._getInst(event.target);var handled=true;var isRTL=inst.dpDiv.is('.ui-datepicker-rtl');inst._keyEvent=true;if($.datepicker._datepickerShowing)
+switch(event.keyCode){case 9:$.datepicker._hideDatepicker(null,'');break;case 13:var sel=$('td.'+$.datepicker._dayOverClass+', td.'+$.datepicker._currentClass,inst.dpDiv);if(sel[0])
+$.datepicker._selectDay(event.target,inst.selectedMonth,inst.selectedYear,sel[0]);else
+$.datepicker._hideDatepicker(null,$.datepicker._get(inst,'duration'));return false;break;case 27:$.datepicker._hideDatepicker(null,$.datepicker._get(inst,'duration'));break;case 33:$.datepicker._adjustDate(event.target,(event.ctrlKey?-$.datepicker._get(inst,'stepBigMonths'):-$.datepicker._get(inst,'stepMonths')),'M');break;case 34:$.datepicker._adjustDate(event.target,(event.ctrlKey?+$.datepicker._get(inst,'stepBigMonths'):+$.datepicker._get(inst,'stepMonths')),'M');break;case 35:if(event.ctrlKey||event.metaKey)$.datepicker._clearDate(event.target);handled=event.ctrlKey||event.metaKey;break;case 36:if(event.ctrlKey||event.metaKey)$.datepicker._gotoToday(event.target);handled=event.ctrlKey||event.metaKey;break;case 37:if(event.ctrlKey||event.metaKey)$.datepicker._adjustDate(event.target,(isRTL?+1:-1),'D');handled=event.ctrlKey||event.metaKey;if(event.originalEvent.altKey)$.datepicker._adjustDate(event.target,(event.ctrlKey?-$.datepicker._get(inst,'stepBigMonths'):-$.datepicker._get(inst,'stepMonths')),'M');break;case 38:if(event.ctrlKey||event.metaKey)$.datepicker._adjustDate(event.target,-7,'D');handled=event.ctrlKey||event.metaKey;break;case 39:if(event.ctrlKey||event.metaKey)$.datepicker._adjustDate(event.target,(isRTL?-1:+1),'D');handled=event.ctrlKey||event.metaKey;if(event.originalEvent.altKey)$.datepicker._adjustDate(event.target,(event.ctrlKey?+$.datepicker._get(inst,'stepBigMonths'):+$.datepicker._get(inst,'stepMonths')),'M');break;case 40:if(event.ctrlKey||event.metaKey)$.datepicker._adjustDate(event.target,+7,'D');handled=event.ctrlKey||event.metaKey;break;default:handled=false;}
+else if(event.keyCode==36&&event.ctrlKey)
+$.datepicker._showDatepicker(this);else{handled=false;}
+if(handled){event.preventDefault();event.stopPropagation();}},_doKeyPress:function(event){var inst=$.datepicker._getInst(event.target);if($.datepicker._get(inst,'constrainInput')){var chars=$.datepicker._possibleChars($.datepicker._get(inst,'dateFormat'));var chr=String.fromCharCode(event.charCode==undefined?event.keyCode:event.charCode);return event.ctrlKey||(chr<' '||!chars||chars.indexOf(chr)>-1);}},_showDatepicker:function(input){input=input.target||input;if(input.nodeName.toLowerCase()!='input')
+input=$('input',input.parentNode)[0];if($.datepicker._isDisabledDatepicker(input)||$.datepicker._lastInput==input)
+return;var inst=$.datepicker._getInst(input);var beforeShow=$.datepicker._get(inst,'beforeShow');extendRemove(inst.settings,(beforeShow?beforeShow.apply(input,[input,inst]):{}));$.datepicker._hideDatepicker(null,'');$.datepicker._lastInput=input;$.datepicker._setDateFromField(inst);if($.datepicker._inDialog)
+input.value='';if(!$.datepicker._pos){$.datepicker._pos=$.datepicker._findPos(input);$.datepicker._pos[1]+=input.offsetHeight;}
+var isFixed=false;$(input).parents().each(function(){isFixed|=$(this).css('position')=='fixed';return!isFixed;});if(isFixed&&$.browser.opera){$.datepicker._pos[0]-=document.documentElement.scrollLeft;$.datepicker._pos[1]-=document.documentElement.scrollTop;}
+var offset={left:$.datepicker._pos[0],top:$.datepicker._pos[1]};$.datepicker._pos=null;inst.rangeStart=null;inst.dpDiv.css({position:'absolute',display:'block',top:'-1000px'});$.datepicker._updateDatepicker(inst);offset=$.datepicker._checkOffset(inst,offset,isFixed);inst.dpDiv.css({position:($.datepicker._inDialog&&$.blockUI?'static':(isFixed?'fixed':'absolute')),display:'none',left:offset.left+'px',top:offset.top+'px'});if(!inst.inline){var showAnim=$.datepicker._get(inst,'showAnim')||'show';var duration=$.datepicker._get(inst,'duration');var postProcess=function(){$.datepicker._datepickerShowing=true;if($.browser.msie&&parseInt($.browser.version,10)<7)
+$('iframe.ui-datepicker-cover').css({width:inst.dpDiv.width()+4,height:inst.dpDiv.height()+4});};if($.effects&&$.effects[showAnim])
+inst.dpDiv.show(showAnim,$.datepicker._get(inst,'showOptions'),duration,postProcess);else
+inst.dpDiv[showAnim](duration,postProcess);if(duration=='')
+postProcess();if(inst.input[0].type!='hidden')
+inst.input[0].focus();$.datepicker._curInst=inst;}},_updateDatepicker:function(inst){var dims={width:inst.dpDiv.width()+4,height:inst.dpDiv.height()+4};var self=this;inst.dpDiv.empty().append(this._generateHTML(inst)).find('iframe.ui-datepicker-cover').css({width:dims.width,height:dims.height}).end().find('button, .ui-datepicker-prev, .ui-datepicker-next, .ui-datepicker-calendar td a').bind('mouseout',function(){$(this).removeClass('ui-state-hover');if(this.className.indexOf('ui-datepicker-prev')!=-1)$(this).removeClass('ui-datepicker-prev-hover');if(this.className.indexOf('ui-datepicker-next')!=-1)$(this).removeClass('ui-datepicker-next-hover');}).bind('mouseover',function(){if(!self._isDisabledDatepicker(inst.inline?inst.dpDiv.parent()[0]:inst.input[0])){$(this).parents('.ui-datepicker-calendar').find('a').removeClass('ui-state-hover');$(this).addClass('ui-state-hover');if(this.className.indexOf('ui-datepicker-prev')!=-1)$(this).addClass('ui-datepicker-prev-hover');if(this.className.indexOf('ui-datepicker-next')!=-1)$(this).addClass('ui-datepicker-next-hover');}}).end().find('.'+this._dayOverClass+' a').trigger('mouseover').end();var numMonths=this._getNumberOfMonths(inst);var cols=numMonths[1];var width=17;if(cols>1){inst.dpDiv.addClass('ui-datepicker-multi-'+cols).css('width',(width*cols)+'em');}else{inst.dpDiv.removeClass('ui-datepicker-multi-2 ui-datepicker-multi-3 ui-datepicker-multi-4').width('');}
+inst.dpDiv[(numMonths[0]!=1||numMonths[1]!=1?'add':'remove')+'Class']('ui-datepicker-multi');inst.dpDiv[(this._get(inst,'isRTL')?'add':'remove')+'Class']('ui-datepicker-rtl');if(inst.input&&inst.input[0].type!='hidden'&&inst==$.datepicker._curInst)
+$(inst.input[0]).focus();},_checkOffset:function(inst,offset,isFixed){var dpWidth=inst.dpDiv.outerWidth();var dpHeight=inst.dpDiv.outerHeight();var inputWidth=inst.input?inst.input.outerWidth():0;var inputHeight=inst.input?inst.input.outerHeight():0;var viewWidth=(window.innerWidth||document.documentElement.clientWidth||document.body.clientWidth)+$(document).scrollLeft();var viewHeight=(window.innerHeight||document.documentElement.clientHeight||document.body.clientHeight)+$(document).scrollTop();offset.left-=(this._get(inst,'isRTL')?(dpWidth-inputWidth):0);offset.left-=(isFixed&&offset.left==inst.input.offset().left)?$(document).scrollLeft():0;offset.top-=(isFixed&&offset.top==(inst.input.offset().top+inputHeight))?$(document).scrollTop():0;offset.left-=(offset.left+dpWidth>viewWidth&&viewWidth>dpWidth)?Math.abs(offset.left+dpWidth-viewWidth):0;offset.top-=(offset.top+dpHeight>viewHeight&&viewHeight>dpHeight)?Math.abs(offset.top+dpHeight+inputHeight*2-viewHeight):0;return offset;},_findPos:function(obj){while(obj&&(obj.type=='hidden'||obj.nodeType!=1)){obj=obj.nextSibling;}
+var position=$(obj).offset();return[position.left,position.top];},_hideDatepicker:function(input,duration){var inst=this._curInst;if(!inst||(input&&inst!=$.data(input,PROP_NAME)))
+return;if(inst.stayOpen)
+this._selectDate('#'+inst.id,this._formatDate(inst,inst.currentDay,inst.currentMonth,inst.currentYear));inst.stayOpen=false;if(this._datepickerShowing){duration=(duration!=null?duration:this._get(inst,'duration'));var showAnim=this._get(inst,'showAnim');var postProcess=function(){$.datepicker._tidyDialog(inst);};if(duration!=''&&$.effects&&$.effects[showAnim])
+inst.dpDiv.hide(showAnim,$.datepicker._get(inst,'showOptions'),duration,postProcess);else
+inst.dpDiv[(duration==''?'hide':(showAnim=='slideDown'?'slideUp':(showAnim=='fadeIn'?'fadeOut':'hide')))](duration,postProcess);if(duration=='')
+this._tidyDialog(inst);var onClose=this._get(inst,'onClose');if(onClose)
+onClose.apply((inst.input?inst.input[0]:null),[(inst.input?inst.input.val():''),inst]);this._datepickerShowing=false;this._lastInput=null;if(this._inDialog){this._dialogInput.css({position:'absolute',left:'0',top:'-100px'});if($.blockUI){$.unblockUI();$('body').append(this.dpDiv);}}
+this._inDialog=false;}
+this._curInst=null;},_tidyDialog:function(inst){inst.dpDiv.removeClass(this._dialogClass).unbind('.ui-datepicker-calendar');},_checkExternalClick:function(event){if(!$.datepicker._curInst)
+return;var $target=$(event.target);if(($target.parents('#'+$.datepicker._mainDivId).length==0)&&!$target.hasClass($.datepicker.markerClassName)&&!$target.hasClass($.datepicker._triggerClass)&&$.datepicker._datepickerShowing&&!($.datepicker._inDialog&&$.blockUI))
+$.datepicker._hideDatepicker(null,'');},_adjustDate:function(id,offset,period){var target=$(id);var inst=this._getInst(target[0]);if(this._isDisabledDatepicker(target[0])){return;}
+this._adjustInstDate(inst,offset+
+(period=='M'?this._get(inst,'showCurrentAtPos'):0),period);this._updateDatepicker(inst);},_gotoToday:function(id){var target=$(id);var inst=this._getInst(target[0]);if(this._get(inst,'gotoCurrent')&&inst.currentDay){inst.selectedDay=inst.currentDay;inst.drawMonth=inst.selectedMonth=inst.currentMonth;inst.drawYear=inst.selectedYear=inst.currentYear;}
+else{var date=new Date();inst.selectedDay=date.getDate();inst.drawMonth=inst.selectedMonth=date.getMonth();inst.drawYear=inst.selectedYear=date.getFullYear();}
+this._notifyChange(inst);this._adjustDate(target);},_selectMonthYear:function(id,select,period){var target=$(id);var inst=this._getInst(target[0]);inst._selectingMonthYear=false;inst['selected'+(period=='M'?'Month':'Year')]=inst['draw'+(period=='M'?'Month':'Year')]=parseInt(select.options[select.selectedIndex].value,10);this._notifyChange(inst);this._adjustDate(target);},_clickMonthYear:function(id){var target=$(id);var inst=this._getInst(target[0]);if(inst.input&&inst._selectingMonthYear&&!$.browser.msie)
+inst.input[0].focus();inst._selectingMonthYear=!inst._selectingMonthYear;},_selectDay:function(id,month,year,td){var target=$(id);if($(td).hasClass(this._unselectableClass)||this._isDisabledDatepicker(target[0])){return;}
+var inst=this._getInst(target[0]);inst.selectedDay=inst.currentDay=$('a',td).html();inst.selectedMonth=inst.currentMonth=month;inst.selectedYear=inst.currentYear=year;if(inst.stayOpen){inst.endDay=inst.endMonth=inst.endYear=null;}
+this._selectDate(id,this._formatDate(inst,inst.currentDay,inst.currentMonth,inst.currentYear));if(inst.stayOpen){inst.rangeStart=this._daylightSavingAdjust(new Date(inst.currentYear,inst.currentMonth,inst.currentDay));this._updateDatepicker(inst);}},_clearDate:function(id){var target=$(id);var inst=this._getInst(target[0]);inst.stayOpen=false;inst.endDay=inst.endMonth=inst.endYear=inst.rangeStart=null;this._selectDate(target,'');},_selectDate:function(id,dateStr){var target=$(id);var inst=this._getInst(target[0]);dateStr=(dateStr!=null?dateStr:this._formatDate(inst));if(inst.input)
+inst.input.val(dateStr);this._updateAlternate(inst);var onSelect=this._get(inst,'onSelect');if(onSelect)
+onSelect.apply((inst.input?inst.input[0]:null),[dateStr,inst]);else if(inst.input)
+inst.input.trigger('change');if(inst.inline)
+this._updateDatepicker(inst);else if(!inst.stayOpen){this._hideDatepicker(null,this._get(inst,'duration'));this._lastInput=inst.input[0];if(typeof(inst.input[0])!='object')
+inst.input[0].focus();this._lastInput=null;}},_updateAlternate:function(inst){var altField=this._get(inst,'altField');if(altField){var altFormat=this._get(inst,'altFormat')||this._get(inst,'dateFormat');var date=this._getDate(inst);dateStr=this.formatDate(altFormat,date,this._getFormatConfig(inst));$(altField).each(function(){$(this).val(dateStr);});}},noWeekends:function(date){var day=date.getDay();return[(day>0&&day<6),''];},iso8601Week:function(date){var checkDate=new Date(date.getFullYear(),date.getMonth(),date.getDate());var firstMon=new Date(checkDate.getFullYear(),1-1,4);var firstDay=firstMon.getDay()||7;firstMon.setDate(firstMon.getDate()+1-firstDay);if(firstDay<4&&checkDate<firstMon){checkDate.setDate(checkDate.getDate()-3);return $.datepicker.iso8601Week(checkDate);}else if(checkDate>new Date(checkDate.getFullYear(),12-1,28)){firstDay=new Date(checkDate.getFullYear()+1,1-1,4).getDay()||7;if(firstDay>4&&(checkDate.getDay()||7)<firstDay-3){return 1;}}
+return Math.floor(((checkDate-firstMon)/86400000)/7)+1;},parseDate:function(format,value,settings){if(format==null||value==null)
+throw'Invalid arguments';value=(typeof value=='object'?value.toString():value+'');if(value=='')
+return null;var shortYearCutoff=(settings?settings.shortYearCutoff:null)||this._defaults.shortYearCutoff;var dayNamesShort=(settings?settings.dayNamesShort:null)||this._defaults.dayNamesShort;var dayNames=(settings?settings.dayNames:null)||this._defaults.dayNames;var monthNamesShort=(settings?settings.monthNamesShort:null)||this._defaults.monthNamesShort;var monthNames=(settings?settings.monthNames:null)||this._defaults.monthNames;var year=-1;var month=-1;var day=-1;var doy=-1;var literal=false;var lookAhead=function(match){var matches=(iFormat+1<format.length&&format.charAt(iFormat+1)==match);if(matches)
+iFormat++;return matches;};var getNumber=function(match){lookAhead(match);var origSize=(match=='@'?14:(match=='y'?4:(match=='o'?3:2)));var size=origSize;var num=0;while(size>0&&iValue<value.length&&value.charAt(iValue)>='0'&&value.charAt(iValue)<='9'){num=num*10+parseInt(value.charAt(iValue++),10);size--;}
+if(size==origSize)
+throw'Missing number at position '+iValue;return num;};var getName=function(match,shortNames,longNames){var names=(lookAhead(match)?longNames:shortNames);var size=0;for(var j=0;j<names.length;j++)
+size=Math.max(size,names[j].length);var name='';var iInit=iValue;while(size>0&&iValue<value.length){name+=value.charAt(iValue++);for(var i=0;i<names.length;i++)
+if(name==names[i])
+return i+1;size--;}
+throw'Unknown name at position '+iInit;};var checkLiteral=function(){if(value.charAt(iValue)!=format.charAt(iFormat))
+throw'Unexpected literal at position '+iValue;iValue++;};var iValue=0;for(var iFormat=0;iFormat<format.length;iFormat++){if(literal)
+if(format.charAt(iFormat)=="'"&&!lookAhead("'"))
+literal=false;else
+checkLiteral();else
+switch(format.charAt(iFormat)){case'd':day=getNumber('d');break;case'D':getName('D',dayNamesShort,dayNames);break;case'o':doy=getNumber('o');break;case'm':month=getNumber('m');break;case'M':month=getName('M',monthNamesShort,monthNames);break;case'y':year=getNumber('y');break;case'@':var date=new Date(getNumber('@'));year=date.getFullYear();month=date.getMonth()+1;day=date.getDate();break;case"'":if(lookAhead("'"))
+literal=true;break;default:checkLiteral();}}
+if(year==-1)
+year=new Date().getFullYear();else if(year<100)
+year+=new Date().getFullYear()-new Date().getFullYear()%100+
+(year<=shortYearCutoff?0:-100);if(doy>-1){month=1;day=doy;do{var dim=this._getDaysInMonth(year,month-1);if(day<=dim)
+break;month++;day-=dim;}while(true);}
+var date=this._daylightSavingAdjust(new Date(year,month-1,day));if(date.getFullYear()!=year||date.getMonth()+1!=month||date.getDate()!=day)
+throw'Invalid date';return date;},ATOM:'yy-mm-dd',COOKIE:'D, dd M yy',ISO_8601:'yy-mm-dd',RFC_822:'D, d M y',RFC_850:'DD, dd-M-y',RFC_1036:'D, d M y',RFC_1123:'D, d M yy',RFC_2822:'D, d M yy',RSS:'D, d M y',TIMESTAMP:'@',W3C:'yy-mm-dd',formatDate:function(format,date,settings){if(!date)
+return'';var dayNamesShort=(settings?settings.dayNamesShort:null)||this._defaults.dayNamesShort;var dayNames=(settings?settings.dayNames:null)||this._defaults.dayNames;var monthNamesShort=(settings?settings.monthNamesShort:null)||this._defaults.monthNamesShort;var monthNames=(settings?settings.monthNames:null)||this._defaults.monthNames;var lookAhead=function(match){var matches=(iFormat+1<format.length&&format.charAt(iFormat+1)==match);if(matches)
+iFormat++;return matches;};var formatNumber=function(match,value,len){var num=''+value;if(lookAhead(match))
+while(num.length<len)
+num='0'+num;return num;};var formatName=function(match,value,shortNames,longNames){return(lookAhead(match)?longNames[value]:shortNames[value]);};var output='';var literal=false;if(date)
+for(var iFormat=0;iFormat<format.length;iFormat++){if(literal)
+literal=false;else
+output+=format.charAt(iFormat);else
+switch(format.charAt(iFormat)){case'd':output+=formatNumber('d',date.getDate(),2);break;case'D':output+=formatName('D',date.getDay(),dayNamesShort,dayNames);break;case'o':var doy=date.getDate();for(var m=date.getMonth()-1;m>=0;m--)
+doy+=this._getDaysInMonth(date.getFullYear(),m);output+=formatNumber('o',doy,3);break;case'm':output+=formatNumber('m',date.getMonth()+1,2);break;case'M':output+=formatName('M',date.getMonth(),monthNamesShort,monthNames);break;case'y':output+=(lookAhead('y')?date.getFullYear():(date.getYear()%100<10?'0':'')+date.getYear()%100);break;case'@':output+=date.getTime();break;case"'":if(lookAhead("'"))
+output+="'";else
+literal=true;break;default:output+=format.charAt(iFormat);}}
+return output;},_possibleChars:function(format){var chars='';var literal=false;for(var iFormat=0;iFormat<format.length;iFormat++)
+if(literal)
+literal=false;else
+chars+=format.charAt(iFormat);else
+switch(format.charAt(iFormat)){case'd':case'm':case'y':case'@':chars+='0123456789';break;case'D':case'M':return null;case"'":if(lookAhead("'"))
+chars+="'";else
+literal=true;break;default:chars+=format.charAt(iFormat);}
+return chars;},_get:function(inst,name){return inst.settings[name]!==undefined?inst.settings[name]:this._defaults[name];},_setDateFromField:function(inst){var dateFormat=this._get(inst,'dateFormat');var dates=inst.input?inst.input.val():null;inst.endDay=inst.endMonth=inst.endYear=null;var date=defaultDate=this._getDefaultDate(inst);var settings=this._getFormatConfig(inst);try{date=this.parseDate(dateFormat,dates,settings)||defaultDate;}catch(event){this.log(event);date=defaultDate;}
+inst.selectedDay=date.getDate();inst.drawMonth=inst.selectedMonth=date.getMonth();inst.drawYear=inst.selectedYear=date.getFullYear();inst.currentDay=(dates?date.getDate():0);inst.currentMonth=(dates?date.getMonth():0);inst.currentYear=(dates?date.getFullYear():0);this._adjustInstDate(inst);},_getDefaultDate:function(inst){var date=this._determineDate(this._get(inst,'defaultDate'),new Date());var minDate=this._getMinMaxDate(inst,'min',true);var maxDate=this._getMinMaxDate(inst,'max');date=(minDate&&date<minDate?minDate:date);date=(maxDate&&date>maxDate?maxDate:date);return date;},_determineDate:function(date,defaultDate){var offsetNumeric=function(offset){var date=new Date();date.setDate(date.getDate()+offset);return date;};var offsetString=function(offset,getDaysInMonth){var date=new Date();var year=date.getFullYear();var month=date.getMonth();var day=date.getDate();var pattern=/([+-]?[0-9]+)\s*(d|D|w|W|m|M|y|Y)?/g;var matches=pattern.exec(offset);while(matches){switch(matches[2]||'d'){case'd':case'D':day+=parseInt(matches[1],10);break;case'w':case'W':day+=parseInt(matches[1],10)*7;break;case'm':case'M':month+=parseInt(matches[1],10);day=Math.min(day,getDaysInMonth(year,month));break;case'y':case'Y':year+=parseInt(matches[1],10);day=Math.min(day,getDaysInMonth(year,month));break;}
+matches=pattern.exec(offset);}
+return new Date(year,month,day);};date=(date==null?defaultDate:(typeof date=='string'?offsetString(date,this._getDaysInMonth):(typeof date=='number'?(isNaN(date)?defaultDate:offsetNumeric(date)):date)));date=(date&&date.toString()=='Invalid Date'?defaultDate:date);if(date){date.setHours(0);date.setMinutes(0);date.setSeconds(0);date.setMilliseconds(0);}
+return this._daylightSavingAdjust(date);},_daylightSavingAdjust:function(date){if(!date)return null;date.setHours(date.getHours()>12?date.getHours()+2:0);return date;},_setDate:function(inst,date,endDate){var clear=!(date);var origMonth=inst.selectedMonth;var origYear=inst.selectedYear;date=this._determineDate(date,new Date());inst.selectedDay=inst.currentDay=date.getDate();inst.drawMonth=inst.selectedMonth=inst.currentMonth=date.getMonth();inst.drawYear=inst.selectedYear=inst.currentYear=date.getFullYear();if(origMonth!=inst.selectedMonth||origYear!=inst.selectedYear)
+this._notifyChange(inst);this._adjustInstDate(inst);if(inst.input){inst.input.val(clear?'':this._formatDate(inst));}},_getDate:function(inst){var startDate=(!inst.currentYear||(inst.input&&inst.input.val()=='')?null:this._daylightSavingAdjust(new Date(inst.currentYear,inst.currentMonth,inst.currentDay)));return startDate;},_generateHTML:function(inst){var today=new Date();today=this._daylightSavingAdjust(new Date(today.getFullYear(),today.getMonth(),today.getDate()));var isRTL=this._get(inst,'isRTL');var showButtonPanel=this._get(inst,'showButtonPanel');var hideIfNoPrevNext=this._get(inst,'hideIfNoPrevNext');var navigationAsDateFormat=this._get(inst,'navigationAsDateFormat');var numMonths=this._getNumberOfMonths(inst);var showCurrentAtPos=this._get(inst,'showCurrentAtPos');var stepMonths=this._get(inst,'stepMonths');var stepBigMonths=this._get(inst,'stepBigMonths');var isMultiMonth=(numMonths[0]!=1||numMonths[1]!=1);var currentDate=this._daylightSavingAdjust((!inst.currentDay?new Date(9999,9,9):new Date(inst.currentYear,inst.currentMonth,inst.currentDay)));var minDate=this._getMinMaxDate(inst,'min',true);var maxDate=this._getMinMaxDate(inst,'max');var drawMonth=inst.drawMonth-showCurrentAtPos;var drawYear=inst.drawYear;if(drawMonth<0){drawMonth+=12;drawYear--;}
+if(maxDate){var maxDraw=this._daylightSavingAdjust(new Date(maxDate.getFullYear(),maxDate.getMonth()-numMonths[1]+1,maxDate.getDate()));maxDraw=(minDate&&maxDraw<minDate?minDate:maxDraw);while(this._daylightSavingAdjust(new Date(drawYear,drawMonth,1))>maxDraw){drawMonth--;if(drawMonth<0){drawMonth=11;drawYear--;}}}
+inst.drawMonth=drawMonth;inst.drawYear=drawYear;var prevText=this._get(inst,'prevText');prevText=(!navigationAsDateFormat?prevText:this.formatDate(prevText,this._daylightSavingAdjust(new Date(drawYear,drawMonth-stepMonths,1)),this._getFormatConfig(inst)));var prev=(this._canAdjustMonth(inst,-1,drawYear,drawMonth)?'<a class="ui-datepicker-prev ui-corner-all" onclick="DP_jQuery.datepicker._adjustDate(\'#'+inst.id+'\', -'+stepMonths+', \'M\');"'+' title="'+prevText+'"><span class="ui-icon ui-icon-circle-triangle-'+(isRTL?'e':'w')+'">'+prevText+'</span></a>':(hideIfNoPrevNext?'':'<a class="ui-datepicker-prev ui-corner-all ui-state-disabled" title="'+prevText+'"><span class="ui-icon ui-icon-circle-triangle-'+(isRTL?'e':'w')+'">'+prevText+'</span></a>'));var nextText=this._get(inst,'nextText');nextText=(!navigationAsDateFormat?nextText:this.formatDate(nextText,this._daylightSavingAdjust(new Date(drawYear,drawMonth+stepMonths,1)),this._getFormatConfig(inst)));var next=(this._canAdjustMonth(inst,+1,drawYear,drawMonth)?'<a class="ui-datepicker-next ui-corner-all" onclick="DP_jQuery.datepicker._adjustDate(\'#'+inst.id+'\', +'+stepMonths+', \'M\');"'+' title="'+nextText+'"><span class="ui-icon ui-icon-circle-triangle-'+(isRTL?'w':'e')+'">'+nextText+'</span></a>':(hideIfNoPrevNext?'':'<a class="ui-datepicker-next ui-corner-all ui-state-disabled" title="'+nextText+'"><span class="ui-icon ui-icon-circle-triangle-'+(isRTL?'w':'e')+'">'+nextText+'</span></a>'));var currentText=this._get(inst,'currentText');var gotoDate=(this._get(inst,'gotoCurrent')&&inst.currentDay?currentDate:today);currentText=(!navigationAsDateFormat?currentText:this.formatDate(currentText,gotoDate,this._getFormatConfig(inst)));var controls=(!inst.inline?'<button type="button" class="ui-datepicker-close ui-state-default ui-priority-primary ui-corner-all" onclick="DP_jQuery.datepicker._hideDatepicker();">'+this._get(inst,'closeText')+'</button>':'');var buttonPanel=(showButtonPanel)?'<div class="ui-datepicker-buttonpane ui-widget-content">'+(isRTL?controls:'')+
+(this._isInRange(inst,gotoDate)?'<button type="button" class="ui-datepicker-current ui-state-default ui-priority-secondary ui-corner-all" onclick="DP_jQuery.datepicker._gotoToday(\'#'+inst.id+'\');"'+'>'+currentText+'</button>':'')+(isRTL?'':controls)+'</div>':'';var firstDay=parseInt(this._get(inst,'firstDay'),10);firstDay=(isNaN(firstDay)?0:firstDay);var dayNames=this._get(inst,'dayNames');var dayNamesShort=this._get(inst,'dayNamesShort');var dayNamesMin=this._get(inst,'dayNamesMin');var monthNames=this._get(inst,'monthNames');var monthNamesShort=this._get(inst,'monthNamesShort');var beforeShowDay=this._get(inst,'beforeShowDay');var showOtherMonths=this._get(inst,'showOtherMonths');var calculateWeek=this._get(inst,'calculateWeek')||this.iso8601Week;var endDate=inst.endDay?this._daylightSavingAdjust(new Date(inst.endYear,inst.endMonth,inst.endDay)):currentDate;var defaultDate=this._getDefaultDate(inst);var html='';for(var row=0;row<numMonths[0];row++){var group='';for(var col=0;col<numMonths[1];col++){var selectedDate=this._daylightSavingAdjust(new Date(drawYear,drawMonth,inst.selectedDay));var cornerClass=' ui-corner-all';var calender='';if(isMultiMonth){calender+='<div class="ui-datepicker-group ui-datepicker-group-';switch(col){case 0:calender+='first';cornerClass=' ui-corner-'+(isRTL?'right':'left');break;case numMonths[1]-1:calender+='last';cornerClass=' ui-corner-'+(isRTL?'left':'right');break;default:calender+='middle';cornerClass='';break;}
+calender+='">';}
+calender+='<div class="ui-datepicker-header ui-widget-header ui-helper-clearfix'+cornerClass+'">'+
+(/all|left/.test(cornerClass)&&row==0?(isRTL?next:prev):'')+
+(/all|right/.test(cornerClass)&&row==0?(isRTL?prev:next):'')+
+this._generateMonthYearHeader(inst,drawMonth,drawYear,minDate,maxDate,selectedDate,row>0||col>0,monthNames,monthNamesShort)+'</div><table class="ui-datepicker-calendar"><thead>'+'<tr>';var thead='';for(var dow=0;dow<7;dow++){var day=(dow+firstDay)%7;thead+='<th'+((dow+firstDay+6)%7>=5?' class="ui-datepicker-week-end"':'')+'>'+'<span title="'+dayNames[day]+'">'+dayNamesMin[day]+'</span></th>';}
+calender+=thead+'</tr></thead><tbody>';var daysInMonth=this._getDaysInMonth(drawYear,drawMonth);if(drawYear==inst.selectedYear&&drawMonth==inst.selectedMonth)
+inst.selectedDay=Math.min(inst.selectedDay,daysInMonth);var leadDays=(this._getFirstDayOfMonth(drawYear,drawMonth)-firstDay+7)%7;var numRows=(isMultiMonth?6:Math.ceil((leadDays+daysInMonth)/7));var printDate=this._daylightSavingAdjust(new Date(drawYear,drawMonth,1-leadDays));for(var dRow=0;dRow<numRows;dRow++){calender+='<tr>';var tbody='';for(var dow=0;dow<7;dow++){var daySettings=(beforeShowDay?beforeShowDay.apply((inst.input?inst.input[0]:null),[printDate]):[true,'']);var otherMonth=(printDate.getMonth()!=drawMonth);var unselectable=otherMonth||!daySettings[0]||(minDate&&printDate<minDate)||(maxDate&&printDate>maxDate);tbody+='<td class="'+
+((dow+firstDay+6)%7>=5?' ui-datepicker-week-end':'')+
+(otherMonth?' ui-datepicker-other-month':'')+
+((printDate.getTime()==selectedDate.getTime()&&drawMonth==inst.selectedMonth&&inst._keyEvent)||(defaultDate.getTime()==printDate.getTime()&&defaultDate.getTime()==selectedDate.getTime())?' '+this._dayOverClass:'')+
+(unselectable?' '+this._unselectableClass+' ui-state-disabled':'')+
+(otherMonth&&!showOtherMonths?'':' '+daySettings[1]+
+(printDate.getTime()>=currentDate.getTime()&&printDate.getTime()<=endDate.getTime()?' '+this._currentClass:'')+
+(printDate.getTime()==today.getTime()?' ui-datepicker-today':''))+'"'+
+((!otherMonth||showOtherMonths)&&daySettings[2]?' title="'+daySettings[2]+'"':'')+
+(unselectable?'':' onclick="DP_jQuery.datepicker._selectDay(\'#'+
+inst.id+'\','+drawMonth+','+drawYear+', this);return false;"')+'>'+
+(otherMonth?(showOtherMonths?printDate.getDate():'&#xa0;'):(unselectable?'<span class="ui-state-default">'+printDate.getDate()+'</span>':'<a class="ui-state-default'+
+(printDate.getTime()==today.getTime()?' ui-state-highlight':'')+
+(printDate.getTime()>=currentDate.getTime()&&printDate.getTime()<=endDate.getTime()?' ui-state-active':'')+'" href="#">'+printDate.getDate()+'</a>'))+'</td>';printDate.setDate(printDate.getDate()+1);printDate=this._daylightSavingAdjust(printDate);}
+calender+=tbody+'</tr>';}
+drawMonth++;if(drawMonth>11){drawMonth=0;drawYear++;}
+calender+='</tbody></table>'+(isMultiMonth?'</div>'+
+((numMonths[0]>0&&col==numMonths[1]-1)?'<div class="ui-datepicker-row-break"></div>':''):'');group+=calender;}
+html+=group;}
+html+=buttonPanel+($.browser.msie&&parseInt($.browser.version,10)<7&&!inst.inline?'<iframe src="javascript:false;" class="ui-datepicker-cover" frameborder="0"></iframe>':'');inst._keyEvent=false;return html;},_generateMonthYearHeader:function(inst,drawMonth,drawYear,minDate,maxDate,selectedDate,secondary,monthNames,monthNamesShort){minDate=(inst.rangeStart&&minDate&&selectedDate<minDate?selectedDate:minDate);var changeMonth=this._get(inst,'changeMonth');var changeYear=this._get(inst,'changeYear');var showMonthAfterYear=this._get(inst,'showMonthAfterYear');var html='<div class="ui-datepicker-title">';var monthHtml='';if(secondary||!changeMonth)
+monthHtml+='<span class="ui-datepicker-month">'+monthNames[drawMonth]+'</span> ';else{var inMinYear=(minDate&&minDate.getFullYear()==drawYear);var inMaxYear=(maxDate&&maxDate.getFullYear()==drawYear);monthHtml+='<select class="ui-datepicker-month" '+'onchange="DP_jQuery.datepicker._selectMonthYear(\'#'+inst.id+'\', this, \'M\');" '+'onclick="DP_jQuery.datepicker._clickMonthYear(\'#'+inst.id+'\');"'+'>';for(var month=0;month<12;month++){if((!inMinYear||month>=minDate.getMonth())&&(!inMaxYear||month<=maxDate.getMonth()))
+monthHtml+='<option value="'+month+'"'+
+(month==drawMonth?' selected="selected"':'')+'>'+monthNamesShort[month]+'</option>';}
+monthHtml+='</select>';}
+if(!showMonthAfterYear)
+html+=monthHtml+((secondary||changeMonth||changeYear)&&(!(changeMonth&&changeYear))?'&#xa0;':'');if(secondary||!changeYear)
+html+='<span class="ui-datepicker-year">'+drawYear+'</span>';else{var years=this._get(inst,'yearRange').split(':');var year=0;var endYear=0;if(years.length!=2){year=drawYear-10;endYear=drawYear+10;}else if(years[0].charAt(0)=='+'||years[0].charAt(0)=='-'){year=drawYear+parseInt(years[0],10);endYear=drawYear+parseInt(years[1],10);}else{year=parseInt(years[0],10);endYear=parseInt(years[1],10);}
+year=(minDate?Math.max(year,minDate.getFullYear()):year);endYear=(maxDate?Math.min(endYear,maxDate.getFullYear()):endYear);html+='<select class="ui-datepicker-year" '+'onchange="DP_jQuery.datepicker._selectMonthYear(\'#'+inst.id+'\', this, \'Y\');" '+'onclick="DP_jQuery.datepicker._clickMonthYear(\'#'+inst.id+'\');"'+'>';for(;year<=endYear;year++){html+='<option value="'+year+'"'+
+(year==drawYear?' selected="selected"':'')+'>'+year+'</option>';}
+html+='</select>';}
+if(showMonthAfterYear)
+html+=(secondary||changeMonth||changeYear?'&#xa0;':'')+monthHtml;html+='</div>';return html;},_adjustInstDate:function(inst,offset,period){var year=inst.drawYear+(period=='Y'?offset:0);var month=inst.drawMonth+(period=='M'?offset:0);var day=Math.min(inst.selectedDay,this._getDaysInMonth(year,month))+
+(period=='D'?offset:0);var date=this._daylightSavingAdjust(new Date(year,month,day));var minDate=this._getMinMaxDate(inst,'min',true);var maxDate=this._getMinMaxDate(inst,'max');date=(minDate&&date<minDate?minDate:date);date=(maxDate&&date>maxDate?maxDate:date);inst.selectedDay=date.getDate();inst.drawMonth=inst.selectedMonth=date.getMonth();inst.drawYear=inst.selectedYear=date.getFullYear();if(period=='M'||period=='Y')
+this._notifyChange(inst);},_notifyChange:function(inst){var onChange=this._get(inst,'onChangeMonthYear');if(onChange)
+onChange.apply((inst.input?inst.input[0]:null),[inst.selectedYear,inst.selectedMonth+1,inst]);},_getNumberOfMonths:function(inst){var numMonths=this._get(inst,'numberOfMonths');return(numMonths==null?[1,1]:(typeof numMonths=='number'?[1,numMonths]:numMonths));},_getMinMaxDate:function(inst,minMax,checkRange){var date=this._determineDate(this._get(inst,minMax+'Date'),null);return(!checkRange||!inst.rangeStart?date:(!date||inst.rangeStart>date?inst.rangeStart:date));},_getDaysInMonth:function(year,month){return 32-new Date(year,month,32).getDate();},_getFirstDayOfMonth:function(year,month){return new Date(year,month,1).getDay();},_canAdjustMonth:function(inst,offset,curYear,curMonth){var numMonths=this._getNumberOfMonths(inst);var date=this._daylightSavingAdjust(new Date(curYear,curMonth+(offset<0?offset:numMonths[1]),1));if(offset<0)
+date.setDate(this._getDaysInMonth(date.getFullYear(),date.getMonth()));return this._isInRange(inst,date);},_isInRange:function(inst,date){var newMinDate=(!inst.rangeStart?null:this._daylightSavingAdjust(new Date(inst.selectedYear,inst.selectedMonth,inst.selectedDay)));newMinDate=(newMinDate&&inst.rangeStart<newMinDate?inst.rangeStart:newMinDate);var minDate=newMinDate||this._getMinMaxDate(inst,'min');var maxDate=this._getMinMaxDate(inst,'max');return((!minDate||date>=minDate)&&(!maxDate||date<=maxDate));},_getFormatConfig:function(inst){var shortYearCutoff=this._get(inst,'shortYearCutoff');shortYearCutoff=(typeof shortYearCutoff!='string'?shortYearCutoff:new Date().getFullYear()%100+parseInt(shortYearCutoff,10));return{shortYearCutoff:shortYearCutoff,dayNamesShort:this._get(inst,'dayNamesShort'),dayNames:this._get(inst,'dayNames'),monthNamesShort:this._get(inst,'monthNamesShort'),monthNames:this._get(inst,'monthNames')};},_formatDate:function(inst,day,month,year){if(!day){inst.currentDay=inst.selectedDay;inst.currentMonth=inst.selectedMonth;inst.currentYear=inst.selectedYear;}
+var date=(day?(typeof day=='object'?day:this._daylightSavingAdjust(new Date(year,month,day))):this._daylightSavingAdjust(new Date(inst.currentYear,inst.currentMonth,inst.currentDay)));return this.formatDate(this._get(inst,'dateFormat'),date,this._getFormatConfig(inst));}});function extendRemove(target,props){$.extend(target,props);for(var name in props)
+if(props[name]==null||props[name]==undefined)
+target[name]=props[name];return target;};function isArray(a){return(a&&(($.browser.safari&&typeof a=='object'&&a.length)||(a.constructor&&a.constructor.toString().match(/\Array\(\)/))));};$.fn.datepicker=function(options){if(!$.datepicker.initialized){$(document).mousedown($.datepicker._checkExternalClick).find('body').append($.datepicker.dpDiv);$.datepicker.initialized=true;}
+var otherArgs=Array.prototype.slice.call(arguments,1);if(typeof options=='string'&&(options=='isDisabled'||options=='getDate'))
+return $.datepicker['_'+options+'Datepicker'].apply($.datepicker,[this[0]].concat(otherArgs));if(options=='option'&&arguments.length==2&&typeof arguments[1]=='string')
+return $.datepicker['_'+options+'Datepicker'].apply($.datepicker,[this[0]].concat(otherArgs));return this.each(function(){typeof options=='string'?$.datepicker['_'+options+'Datepicker'].apply($.datepicker,[this].concat(otherArgs)):$.datepicker._attachDatepicker(this,options);});};$.datepicker=new Datepicker();$.datepicker.initialized=false;$.datepicker.uuid=new Date().getTime();$.datepicker.version="1.7.2";window.DP_jQuery=$;})(jQuery);
\ No newline at end of file
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.dialog.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.dialog.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.dialog.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,14 @@
+(function($){var setDataSwitch={dragStart:"start.draggable",drag:"drag.draggable",dragStop:"stop.draggable",maxHeight:"maxHeight.resizable",minHeight:"minHeight.resizable",maxWidth:"maxWidth.resizable",minWidth:"minWidth.resizable",resizeStart:"start.resizable",resize:"drag.resizable",resizeStop:"stop.resizable"},uiDialogClasses='ui-dialog '+'ui-widget '+'ui-widget-content '+'ui-corner-all ';$.widget("ui.dialog",{_init:function(){this.originalTitle=this.element.attr('title');var self=this,options=this.options,title=options.title||this.originalTitle||'&nbsp;',titleId=$.ui.dialog.getTitleId(this.element),uiDialog=(this.uiDialog=$('<div/>')).appendTo(document.body).hide().addClass(uiDialogClasses+options.dialogClass).css({position:'absolute',overflow:'hidden',zIndex:options.zIndex}).attr('tabIndex',-1).css('outline',0).keydown(function(event){(options.closeOnEscape&&event.keyCode&&event.keyCode==$.ui.keyCode.ESCAPE&&self.close(event));}).attr({role:'dialog','aria-labelledby':titleId}).mousedown(function(event){self.moveToTop(false,event);}),uiDialogContent=this.element.show().removeAttr('title').addClass('ui-dialog-content '+'ui-widget-content').appendTo(uiDialog),uiDialogTitlebar=(this.uiDialogTitlebar=$('<div></div>')).addClass('ui-dialog-titlebar '+'ui-widget-header '+'ui-corner-all '+'ui-helper-clearfix').prependTo(uiDialog),uiDialogTitlebarClose=$('<a href="#"/>').addClass('ui-dialog-titlebar-close '+'ui-corner-all').attr('role','button').hover(function(){uiDialogTitlebarClose.addClass('ui-state-hover');},function(){uiDialogTitlebarClose.removeClass('ui-state-hover');}).focus(function(){uiDialogTitlebarClose.addClass('ui-state-focus');}).blur(function(){uiDialogTitlebarClose.removeClass('ui-state-focus');}).mousedown(function(ev){ev.stopPropagation();}).click(function(event){self.close(event);return false;}).appendTo(uiDialogTitlebar),uiDialogTitlebarCloseText=(this.uiDialogTitlebarCloseText=$('<span/>')).addClass('ui-icon '+'ui-icon-closethick').text(options.closeText).appendTo(uiDialogTitlebarClose),uiDialogTitle=$('<span/>').addClass('ui-dialog-title').attr('id',titleId).html(title).prependTo(uiDialogTitlebar);uiDialogTitlebar.find("*").add(uiDialogTitlebar).disableSelection();(options.draggable&&$.fn.draggable&&this._makeDraggable());(options.resizable&&$.fn.resizable&&this._makeResizable());this._createButtons(options.buttons);this._isOpen=false;(options.bgiframe&&$.fn.bgiframe&&uiDialog.bgiframe());(options.autoOpen&&this.open());},destroy:function(){(this.overlay&&this.overlay.destroy());this.uiDialog.hide();this.element.unbind('.dialog').removeData('dialog').removeClass('ui-dialog-content ui-widget-content').hide().appendTo('body');this.uiDialog.remove();(this.originalTitle&&this.element.attr('title',this.originalTitle));},close:function(event){var self=this;if(false===self._trigger('beforeclose',event)){return;}
+(self.overlay&&self.overlay.destroy());self.uiDialog.unbind('keypress.ui-dialog');(self.options.hide?self.uiDialog.hide(self.options.hide,function(){self._trigger('close',event);}):self.uiDialog.hide()&&self._trigger('close',event));$.ui.dialog.overlay.resize();self._isOpen=false;if(self.options.modal){var maxZ=0;$('.ui-dialog').each(function(){if(this!=self.uiDialog[0]){maxZ=Math.max(maxZ,$(this).css('z-index'));}});$.ui.dialog.maxZ=maxZ;}},isOpen:function(){return this._isOpen;},moveToTop:function(force,event){if((this.options.modal&&!force)||(!this.options.stack&&!this.options.modal)){return this._trigger('focus',event);}
+if(this.options.zIndex>$.ui.dialog.maxZ){$.ui.dialog.maxZ=this.options.zIndex;}
+(this.overlay&&this.overlay.$el.css('z-index',$.ui.dialog.overlay.maxZ=++$.ui.dialog.maxZ));var saveScroll={scrollTop:this.element.attr('scrollTop'),scrollLeft:this.element.attr('scrollLeft')};this.uiDialog.css('z-index',++$.ui.dialog.maxZ);this.element.attr(saveScroll);this._trigger('focus',event);},open:function(){if(this._isOpen){return;}
+var options=this.options,uiDialog=this.uiDialog;this.overlay=options.modal?new $.ui.dialog.overlay(this):null;(uiDialog.next().length&&uiDialog.appendTo('body'));this._size();this._position(options.position);uiDialog.show(options.show);this.moveToTop(true);(options.modal&&uiDialog.bind('keypress.ui-dialog',function(event){if(event.keyCode!=$.ui.keyCode.TAB){return;}
+var tabbables=$(':tabbable',this),first=tabbables.filter(':first')[0],last=tabbables.filter(':last')[0];if(event.target==last&&!event.shiftKey){setTimeout(function(){first.focus();},1);}else if(event.target==first&&event.shiftKey){setTimeout(function(){last.focus();},1);}}));$([]).add(uiDialog.find('.ui-dialog-content :tabbable:first')).add(uiDialog.find('.ui-dialog-buttonpane :tabbable:first')).add(uiDialog).filter(':first').focus();this._trigger('open');this._isOpen=true;},_createButtons:function(buttons){var self=this,hasButtons=false,uiDialogButtonPane=$('<div></div>').addClass('ui-dialog-buttonpane '+'ui-widget-content '+'ui-helper-clearfix');this.uiDialog.find('.ui-dialog-buttonpane').remove();(typeof buttons=='object'&&buttons!==null&&$.each(buttons,function(){return!(hasButtons=true);}));if(hasButtons){$.each(buttons,function(name,fn){$('<button type="button"></button>').addClass('ui-state-default '+'ui-corner-all').text(name).click(function(){fn.apply(self.element[0],arguments);}).hover(function(){$(this).addClass('ui-state-hover');},function(){$(this).removeClass('ui-state-hover');}).focus(function(){$(this).addClass('ui-state-focus');}).blur(function(){$(this).removeClass('ui-state-focus');}).appendTo(uiDialogButtonPane);});uiDialogButtonPane.appendTo(this.uiDialog);}},_makeDraggable:function(){var self=this,options=this.options,heightBeforeDrag;this.uiDialog.draggable({cancel:'.ui-dialog-content',handle:'.ui-dialog-titlebar',containment:'document',start:function(){heightBeforeDrag=options.height;$(this).height($(this).height()).addClass("ui-dialog-dragging");(options.dragStart&&options.dragStart.apply(self.element[0],arguments));},drag:function(){(options.drag&&options.drag.apply(self.element[0],arguments));},stop:function(){$(this).removeClass("ui-dialog-dragging").height(heightBeforeDrag);(options.dragStop&&options.dragStop.apply(self.element[0],arguments));$.ui.dialog.overlay.resize();}});},_makeResizable:function(handles){handles=(handles===undefined?this.options.resizable:handles);var self=this,options=this.options,resizeHandles=typeof handles=='string'?handles:'n,e,s,w,se,sw,ne,nw';this.uiDialog.resizable({cancel:'.ui-dialog-content',alsoResize:this.element,maxWidth:options.maxWidth,maxHeight:options.maxHeight,minWidth:options.minWidth,minHeight:options.minHeight,start:function(){$(this).addClass("ui-dialog-resizing");(options.resizeStart&&options.resizeStart.apply(self.element[0],arguments));},resize:function(){(options.resize&&options.resize.apply(self.element[0],arguments));},handles:resizeHandles,stop:function(){$(this).removeClass("ui-dialog-resizing");options.height=$(this).height();options.width=$(this).width();(options.resizeStop&&options.resizeStop.apply(self.element[0],arguments));$.ui.dialog.overlay.resize();}}).find('.ui-resizable-se').addClass('ui-icon ui-icon-grip-diagonal-se');},_position:function(pos){var wnd=$(window),doc=$(document),pTop=doc.scrollTop(),pLeft=doc.scrollLeft(),minTop=pTop;if($.inArray(pos,['center','top','right','bottom','left'])>=0){pos=[pos=='right'||pos=='left'?pos:'center',pos=='top'||pos=='bottom'?pos:'middle'];}
+if(pos.constructor!=Array){pos=['center','middle'];}
+if(pos[0].constructor==Number){pLeft+=pos[0];}else{switch(pos[0]){case'left':pLeft+=0;break;case'right':pLeft+=wnd.width()-this.uiDialog.outerWidth();break;default:case'center':pLeft+=(wnd.width()-this.uiDialog.outerWidth())/2;}}
+if(pos[1].constructor==Number){pTop+=pos[1];}else{switch(pos[1]){case'top':pTop+=0;break;case'bottom':pTop+=wnd.height()-this.uiDialog.outerHeight();break;default:case'middle':pTop+=(wnd.height()-this.uiDialog.outerHeight())/2;}}
+pTop=Math.max(pTop,minTop);this.uiDialog.css({top:pTop,left:pLeft});},_setData:function(key,value){(setDataSwitch[key]&&this.uiDialog.data(setDataSwitch[key],value));switch(key){case"buttons":this._createButtons(value);break;case"closeText":this.uiDialogTitlebarCloseText.text(value);break;case"dialogClass":this.uiDialog.removeClass(this.options.dialogClass).addClass(uiDialogClasses+value);break;case"draggable":(value?this._makeDraggable():this.uiDialog.draggable('destroy'));break;case"height":this.uiDialog.height(value);break;case"position":this._position(value);break;case"resizable":var uiDialog=this.uiDialog,isResizable=this.uiDialog.is(':data(resizable)');(isResizable&&!value&&uiDialog.resizable('destroy'));(isResizable&&typeof value=='string'&&uiDialog.resizable('option','handles',value));(isResizable||this._makeResizable(value));break;case"title":$(".ui-dialog-title",this.uiDialogTitlebar).html(value||'&nbsp;');break;case"width":this.uiDialog.width(value);break;}
+$.widget.prototype._setData.apply(this,arguments);},_size:function(){var options=this.options;this.element.css({height:0,minHeight:0,width:'auto'});var nonContentHeight=this.uiDialog.css({height:'auto',width:options.width}).height();this.element.css({minHeight:Math.max(options.minHeight-nonContentHeight,0),height:options.height=='auto'?'auto':Math.max(options.height-nonContentHeight,0)});}});$.extend($.ui.dialog,{version:"1.7.2",defaults:{autoOpen:true,bgiframe:false,buttons:{},closeOnEscape:true,closeText:'close',dialogClass:'',draggable:true,hide:null,height:'auto',maxHeight:false,maxWidth:false,minHeight:150,minWidth:150,modal:false,position:'center',resizable:true,show:null,stack:true,title:'',width:300,zIndex:1000},getter:'isOpen',uuid:0,maxZ:0,getTitleId:function($el){return'ui-dialog-title-'+($el.attr('id')||++this.uuid);},overlay:function(dialog){this.$el=$.ui.dialog.overlay.create(dialog);}});$.extend($.ui.dialog.overlay,{instances:[],maxZ:0,events:$.map('focus,mousedown,mouseup,keydown,keypress,click'.split(','),function(event){return event+'.dialog-overlay';}).join(' '),create:function(dialog){if(this.instances.length===0){setTimeout(function(){if($.ui.dialog.overlay.instances.length){$(document).bind($.ui.dialog.overlay.events,function(event){var dialogZ=$(event.target).parents('.ui-dialog').css('zIndex')||0;return(dialogZ>$.ui.dialog.overlay.maxZ);});}},1);$(document).bind('keydown.dialog-overlay',function(event){(dialog.options.closeOnEscape&&event.keyCode&&event.keyCode==$.ui.keyCode.ESCAPE&&dialog.close(event));});$(window).bind('resize.dialog-overlay',$.ui.dialog.overlay.resize);}
+var $el=$('<div></div>').appendTo(document.body).addClass('ui-widget-overlay').css({width:this.width(),height:this.height()});(dialog.options.bgiframe&&$.fn.bgiframe&&$el.bgiframe());this.instances.push($el);return $el;},destroy:function($el){this.instances.splice($.inArray(this.instances,$el),1);if(this.instances.length===0){$([document,window]).unbind('.dialog-overlay');}
+$el.remove();var maxZ=0;$.each(this.instances,function(){maxZ=Math.max(maxZ,this.css('z-index'));});this.maxZ=maxZ;},height:function(){if($.browser.msie&&$.browser.version<7){var scrollHeight=Math.max(document.documentElement.scrollHeight,document.body.scrollHeight);var offsetHeight=Math.max(document.documentElement.offsetHeight,document.body.offsetHeight);if(scrollHeight<offsetHeight){return $(window).height()+'px';}else{return scrollHeight+'px';}}else{return $(document).height()+'px';}},width:function(){if($.browser.msie&&$.browser.version<7){var scrollWidth=Math.max(document.documentElement.scrollWidth,document.body.scrollWidth);var offsetWidth=Math.max(document.documentElement.offsetWidth,document.body.offsetWidth);if(scrollWidth<offsetWidth){return $(window).width()+'px';}else{return scrollWidth+'px';}}else{return $(document).width()+'px';}},resize:function(){var $overlays=$([]);$.each($.ui.dialog.overlay.instances,function(){$overlays=$overlays.add(this);});$overlays.css({width:0,height:0}).css({width:$.ui.dialog.overlay.width(),height:$.ui.dialog.overlay.height()});}});$.extend($.ui.dialog.overlay.prototype,{destroy:function(){$.ui.dialog.overlay.destroy(this.$el);}});})(jQuery);
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.draggable.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.draggable.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.draggable.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,54 @@
+(function($){$.widget("ui.draggable",$.extend({},$.ui.mouse,{_init:function(){if(this.options.helper=='original'&&!(/^(?:r|a|f)/).test(this.element.css("position")))
+this.element[0].style.position='relative';(this.options.addClasses&&this.element.addClass("ui-draggable"));(this.options.disabled&&this.element.addClass("ui-draggable-disabled"));this._mouseInit();},destroy:function(){if(!this.element.data('draggable'))return;this.element.removeData("draggable").unbind(".draggable").removeClass("ui-draggable"
++" ui-draggable-dragging"
++" ui-draggable-disabled");this._mouseDestroy();},_mouseCapture:function(event){var o=this.options;if(this.helper||o.disabled||$(event.target).is('.ui-resizable-handle'))
+return false;this.handle=this._getHandle(event);if(!this.handle)
+return false;return true;},_mouseStart:function(event){var o=this.options;this.helper=this._createHelper(event);this._cacheHelperProportions();if($.ui.ddmanager)
+$.ui.ddmanager.current=this;this._cacheMargins();this.cssPosition=this.helper.css("position");this.scrollParent=this.helper.scrollParent();this.offset=this.element.offset();this.offset={top:this.offset.top-this.margins.top,left:this.offset.left-this.margins.left};$.extend(this.offset,{click:{left:event.pageX-this.offset.left,top:event.pageY-this.offset.top},parent:this._getParentOffset(),relative:this._getRelativeOffset()});this.originalPosition=this._generatePosition(event);this.originalPageX=event.pageX;this.originalPageY=event.pageY;if(o.cursorAt)
+this._adjustOffsetFromHelper(o.cursorAt);if(o.containment)
+this._setContainment();this._trigger("start",event);this._cacheHelperProportions();if($.ui.ddmanager&&!o.dropBehaviour)
+$.ui.ddmanager.prepareOffsets(this,event);this.helper.addClass("ui-draggable-dragging");this._mouseDrag(event,true);return true;},_mouseDrag:function(event,noPropagation){this.position=this._generatePosition(event);this.positionAbs=this._convertPositionTo("absolute");if(!noPropagation){var ui=this._uiHash();this._trigger('drag',event,ui);this.position=ui.position;}
+if(!this.options.axis||this.options.axis!="y")this.helper[0].style.left=this.position.left+'px';if(!this.options.axis||this.options.axis!="x")this.helper[0].style.top=this.position.top+'px';if($.ui.ddmanager)$.ui.ddmanager.drag(this,event);return false;},_mouseStop:function(event){var dropped=false;if($.ui.ddmanager&&!this.options.dropBehaviour)
+dropped=$.ui.ddmanager.drop(this,event);if(this.dropped){dropped=this.dropped;this.dropped=false;}
+if((this.options.revert=="invalid"&&!dropped)||(this.options.revert=="valid"&&dropped)||this.options.revert===true||($.isFunction(this.options.revert)&&this.options.revert.call(this.element,dropped))){var self=this;$(this.helper).animate(this.originalPosition,parseInt(this.options.revertDuration,10),function(){self._trigger("stop",event);self._clear();});}else{this._trigger("stop",event);this._clear();}
+return false;},_getHandle:function(event){var handle=!this.options.handle||!$(this.options.handle,this.element).length?true:false;$(this.options.handle,this.element).find("*").andSelf().each(function(){if(this==event.target)handle=true;});return handle;},_createHelper:function(event){var o=this.options;var helper=$.isFunction(o.helper)?$(o.helper.apply(this.element[0],[event])):(o.helper=='clone'?this.element.clone():this.element);if(!helper.parents('body').length)
+helper.appendTo((o.appendTo=='parent'?this.element[0].parentNode:o.appendTo));if(helper[0]!=this.element[0]&&!(/(fixed|absolute)/).test(helper.css("position")))
+helper.css("position","absolute");return helper;},_adjustOffsetFromHelper:function(obj){if(obj.left!=undefined)this.offset.click.left=obj.left+this.margins.left;if(obj.right!=undefined)this.offset.click.left=this.helperProportions.width-obj.right+this.margins.left;if(obj.top!=undefined)this.offset.click.top=obj.top+this.margins.top;if(obj.bottom!=undefined)this.offset.click.top=this.helperProportions.height-obj.bottom+this.margins.top;},_getParentOffset:function(){this.offsetParent=this.helper.offsetParent();var po=this.offsetParent.offset();if(this.cssPosition=='absolute'&&this.scrollParent[0]!=document&&$.ui.contains(this.scrollParent[0],this.offsetParent[0])){po.left+=this.scrollParent.scrollLeft();po.top+=this.scrollParent.scrollTop();}
+if((this.offsetParent[0]==document.body)||(this.offsetParent[0].tagName&&this.offsetParent[0].tagName.toLowerCase()=='html'&&$.browser.msie))
+po={top:0,left:0};return{top:po.top+(parseInt(this.offsetParent.css("borderTopWidth"),10)||0),left:po.left+(parseInt(this.offsetParent.css("borderLeftWidth"),10)||0)};},_getRelativeOffset:function(){if(this.cssPosition=="relative"){var p=this.element.position();return{top:p.top-(parseInt(this.helper.css("top"),10)||0)+this.scrollParent.scrollTop(),left:p.left-(parseInt(this.helper.css("left"),10)||0)+this.scrollParent.scrollLeft()};}else{return{top:0,left:0};}},_cacheMargins:function(){this.margins={left:(parseInt(this.element.css("marginLeft"),10)||0),top:(parseInt(this.element.css("marginTop"),10)||0)};},_cacheHelperProportions:function(){this.helperProportions={width:this.helper.outerWidth(),height:this.helper.outerHeight()};},_setContainment:function(){var o=this.options;if(o.containment=='parent')o.containment=this.helper[0].parentNode;if(o.containment=='document'||o.containment=='window')this.containment=[0-this.offset.relative.left-this.offset.parent.left,0-this.offset.relative.top-this.offset.parent.top,$(o.containment=='document'?document:window).width()-this.helperProportions.width-this.margins.left,($(o.containment=='document'?document:window).height()||document.body.parentNode.scrollHeight)-this.helperProportions.height-this.margins.top];if(!(/^(document|window|parent)$/).test(o.containment)&&o.containment.constructor!=Array){var ce=$(o.containment)[0];if(!ce)return;var co=$(o.containment).offset();var over=($(ce).css("overflow")!='hidden');this.containment=[co.left+(parseInt($(ce).css("borderLeftWidth"),10)||0)+(parseInt($(ce).css("paddingLeft"),10)||0)-this.margins.left,co.top+(parseInt($(ce).css("borderTopWidth"),10)||0)+(parseInt($(ce).css("paddingTop"),10)||0)-this.margins.top,co.left+(over?Math.max(ce.scrollWidth,ce.offsetWidth):ce.offsetWidth)-(parseInt($(ce).css("borderLeftWidth"),10)||0)-(parseInt($(ce).css("paddingRight"),10)||0)-this.helperProportions.width-this.margins.left,co.top+(over?Math.max(ce.scrollHeight,ce.offsetHeight):ce.offsetHeight)-(parseInt($(ce).css("borderTopWidth"),10)||0)-(parseInt($(ce).css("paddingBottom"),10)||0)-this.helperProportions.height-this.margins.top];}else if(o.containment.constructor==Array){this.containment=o.containment;}},_convertPositionTo:function(d,pos){if(!pos)pos=this.position;var mod=d=="absolute"?1:-1;var o=this.options,scroll=this.cssPosition=='absolute'&&!(this.scrollParent[0]!=document&&$.ui.contains(this.scrollParent[0],this.offsetParent[0]))?this.offsetParent:this.scrollParent,scrollIsRootNode=(/(html|body)/i).test(scroll[0].tagName);return{top:(pos.top
++this.offset.relative.top*mod
++this.offset.parent.top*mod
+-($.browser.safari&&this.cssPosition=='fixed'?0:(this.cssPosition=='fixed'?-this.scrollParent.scrollTop():(scrollIsRootNode?0:scroll.scrollTop()))*mod)),left:(pos.left
++this.offset.relative.left*mod
++this.offset.parent.left*mod
+-($.browser.safari&&this.cssPosition=='fixed'?0:(this.cssPosition=='fixed'?-this.scrollParent.scrollLeft():scrollIsRootNode?0:scroll.scrollLeft())*mod))};},_generatePosition:function(event){var o=this.options,scroll=this.cssPosition=='absolute'&&!(this.scrollParent[0]!=document&&$.ui.contains(this.scrollParent[0],this.offsetParent[0]))?this.offsetParent:this.scrollParent,scrollIsRootNode=(/(html|body)/i).test(scroll[0].tagName);if(this.cssPosition=='relative'&&!(this.scrollParent[0]!=document&&this.scrollParent[0]!=this.offsetParent[0])){this.offset.relative=this._getRelativeOffset();}
+var pageX=event.pageX;var pageY=event.pageY;if(this.originalPosition){if(this.containment){if(event.pageX-this.offset.click.left<this.containment[0])pageX=this.containment[0]+this.offset.click.left;if(event.pageY-this.offset.click.top<this.containment[1])pageY=this.containment[1]+this.offset.click.top;if(event.pageX-this.offset.click.left>this.containment[2])pageX=this.containment[2]+this.offset.click.left;if(event.pageY-this.offset.click.top>this.containment[3])pageY=this.containment[3]+this.offset.click.top;}
+if(o.grid){var top=this.originalPageY+Math.round((pageY-this.originalPageY)/o.grid[1])*o.grid[1];pageY=this.containment?(!(top-this.offset.click.top<this.containment[1]||top-this.offset.click.top>this.containment[3])?top:(!(top-this.offset.click.top<this.containment[1])?top-o.grid[1]:top+o.grid[1])):top;var left=this.originalPageX+Math.round((pageX-this.originalPageX)/o.grid[0])*o.grid[0];pageX=this.containment?(!(left-this.offset.click.left<this.containment[0]||left-this.offset.click.left>this.containment[2])?left:(!(left-this.offset.click.left<this.containment[0])?left-o.grid[0]:left+o.grid[0])):left;}}
+return{top:(pageY
+-this.offset.click.top
+-this.offset.relative.top
+-this.offset.parent.top
++($.browser.safari&&this.cssPosition=='fixed'?0:(this.cssPosition=='fixed'?-this.scrollParent.scrollTop():(scrollIsRootNode?0:scroll.scrollTop())))),left:(pageX
+-this.offset.click.left
+-this.offset.relative.left
+-this.offset.parent.left
++($.browser.safari&&this.cssPosition=='fixed'?0:(this.cssPosition=='fixed'?-this.scrollParent.scrollLeft():scrollIsRootNode?0:scroll.scrollLeft())))};},_clear:function(){this.helper.removeClass("ui-draggable-dragging");if(this.helper[0]!=this.element[0]&&!this.cancelHelperRemoval)this.helper.remove();this.helper=null;this.cancelHelperRemoval=false;},_trigger:function(type,event,ui){ui=ui||this._uiHash();$.ui.plugin.call(this,type,[event,ui]);if(type=="drag")this.positionAbs=this._convertPositionTo("absolute");return $.widget.prototype._trigger.call(this,type,event,ui);},plugins:{},_uiHash:function(event){return{helper:this.helper,position:this.position,absolutePosition:this.positionAbs,offset:this.positionAbs};}}));$.extend($.ui.draggable,{version:"1.7.2",eventPrefix:"drag",defaults:{addClasses:true,appendTo:"parent",axis:false,cancel:":input,option",connectToSortable:false,containment:false,cursor:"auto",cursorAt:false,delay:0,distance:1,grid:false,handle:false,helper:"original",iframeFix:false,opacity:false,refreshPositions:false,revert:false,revertDuration:500,scope:"default",scroll:true,scrollSensitivity:20,scrollSpeed:20,snap:false,snapMode:"both",snapTolerance:20,stack:false,zIndex:false}});$.ui.plugin.add("draggable","connectToSortable",{start:function(event,ui){var inst=$(this).data("draggable"),o=inst.options,uiSortable=$.extend({},ui,{item:inst.element});inst.sortables=[];$(o.connectToSortable).each(function(){var sortable=$.data(this,'sortable');if(sortable&&!sortable.options.disabled){inst.sortables.push({instance:sortable,shouldRevert:sortable.options.revert});sortable._refreshItems();sortable._trigger("activate",event,uiSortable);}});},stop:function(event,ui){var inst=$(this).data("draggable"),uiSortable=$.extend({},ui,{item:inst.element});$.each(inst.sortables,function(){if(this.instance.isOver){this.instance.isOver=0;inst.cancelHelperRemoval=true;this.instance.cancelHelperRemoval=false;if(this.shouldRevert)this.instance.options.revert=true;this.instance._mouseStop(event);this.instance.options.helper=this.instance.options._helper;if(inst.options.helper=='original')
+this.instance.currentItem.css({top:'auto',left:'auto'});}else{this.instance.cancelHelperRemoval=false;this.instance._trigger("deactivate",event,uiSortable);}});},drag:function(event,ui){var inst=$(this).data("draggable"),self=this;var checkPos=function(o){var dyClick=this.offset.click.top,dxClick=this.offset.click.left;var helperTop=this.positionAbs.top,helperLeft=this.positionAbs.left;var itemHeight=o.height,itemWidth=o.width;var itemTop=o.top,itemLeft=o.left;return $.ui.isOver(helperTop+dyClick,helperLeft+dxClick,itemTop,itemLeft,itemHeight,itemWidth);};$.each(inst.sortables,function(i){this.instance.positionAbs=inst.positionAbs;this.instance.helperProportions=inst.helperProportions;this.instance.offset.click=inst.offset.click;if(this.instance._intersectsWith(this.instance.containerCache)){if(!this.instance.isOver){this.instance.isOver=1;this.instance.currentItem=$(self).clone().appendTo(this.instance.element).data("sortable-item",true);this.instance.options._helper=this.instance.options.helper;this.instance.options.helper=function(){return ui.helper[0];};event.target=this.instance.currentItem[0];this.instance._mouseCapture(event,true);this.instance._mouseStart(event,true,true);this.instance.offset.click.top=inst.offset.click.top;this.instance.offset.click.left=inst.offset.click.left;this.instance.offset.parent.left-=inst.offset.parent.left-this.instance.offset.parent.left;this.instance.offset.parent.top-=inst.offset.parent.top-this.instance.offset.parent.top;inst._trigger("toSortable",event);inst.dropped=this.instance.element;inst.currentItem=inst.element;this.instance.fromOutside=inst;}
+if(this.instance.currentItem)this.instance._mouseDrag(event);}else{if(this.instance.isOver){this.instance.isOver=0;this.instance.cancelHelperRemoval=true;this.instance.options.revert=false;this.instance._trigger('out',event,this.instance._uiHash(this.instance));this.instance._mouseStop(event,true);this.instance.options.helper=this.instance.options._helper;this.instance.currentItem.remove();if(this.instance.placeholder)this.instance.placeholder.remove();inst._trigger("fromSortable",event);inst.dropped=false;}};});}});$.ui.plugin.add("draggable","cursor",{start:function(event,ui){var t=$('body'),o=$(this).data('draggable').options;if(t.css("cursor"))o._cursor=t.css("cursor");t.css("cursor",o.cursor);},stop:function(event,ui){var o=$(this).data('draggable').options;if(o._cursor)$('body').css("cursor",o._cursor);}});$.ui.plugin.add("draggable","iframeFix",{start:function(event,ui){var o=$(this).data('draggable').options;$(o.iframeFix===true?"iframe":o.iframeFix).each(function(){$('<div class="ui-draggable-iframeFix" style="background: #fff;"></div>').css({width:this.offsetWidth+"px",height:this.offsetHeight+"px",position:"absolute",opacity:"0.001",zIndex:1000}).css($(this).offset()).appendTo("body");});},stop:function(event,ui){$("div.ui-draggable-iframeFix").each(function(){this.parentNode.removeChild(this);});}});$.ui.plugin.add("draggable","opacity",{start:function(event,ui){var t=$(ui.helper),o=$(this).data('draggable').options;if(t.css("opacity"))o._opacity=t.css("opacity");t.css('opacity',o.opacity);},stop:function(event,ui){var o=$(this).data('draggable').options;if(o._opacity)$(ui.helper).css('opacity',o._opacity);}});$.ui.plugin.add("draggable","scroll",{start:function(event,ui){var i=$(this).data("draggable");if(i.scrollParent[0]!=document&&i.scrollParent[0].tagName!='HTML')i.overflowOffset=i.scrollParent.offset();},drag:function(event,ui){var i=$(this).data("draggable"),o=i.options,scrolled=false;if(i.scrollParent[0]!=document&&i.scrollParent[0].tagName!='HTML'){if(!o.axis||o.axis!='x'){if((i.overflowOffset.top+i.scrollParent[0].offsetHeight)-event.pageY<o.scrollSensitivity)
+i.scrollParent[0].scrollTop=scrolled=i.scrollParent[0].scrollTop+o.scrollSpeed;else if(event.pageY-i.overflowOffset.top<o.scrollSensitivity)
+i.scrollParent[0].scrollTop=scrolled=i.scrollParent[0].scrollTop-o.scrollSpeed;}
+if(!o.axis||o.axis!='y'){if((i.overflowOffset.left+i.scrollParent[0].offsetWidth)-event.pageX<o.scrollSensitivity)
+i.scrollParent[0].scrollLeft=scrolled=i.scrollParent[0].scrollLeft+o.scrollSpeed;else if(event.pageX-i.overflowOffset.left<o.scrollSensitivity)
+i.scrollParent[0].scrollLeft=scrolled=i.scrollParent[0].scrollLeft-o.scrollSpeed;}}else{if(!o.axis||o.axis!='x'){if(event.pageY-$(document).scrollTop()<o.scrollSensitivity)
+scrolled=$(document).scrollTop($(document).scrollTop()-o.scrollSpeed);else if($(window).height()-(event.pageY-$(document).scrollTop())<o.scrollSensitivity)
+scrolled=$(document).scrollTop($(document).scrollTop()+o.scrollSpeed);}
+if(!o.axis||o.axis!='y'){if(event.pageX-$(document).scrollLeft()<o.scrollSensitivity)
+scrolled=$(document).scrollLeft($(document).scrollLeft()-o.scrollSpeed);else if($(window).width()-(event.pageX-$(document).scrollLeft())<o.scrollSensitivity)
+scrolled=$(document).scrollLeft($(document).scrollLeft()+o.scrollSpeed);}}
+if(scrolled!==false&&$.ui.ddmanager&&!o.dropBehaviour)
+$.ui.ddmanager.prepareOffsets(i,event);}});$.ui.plugin.add("draggable","snap",{start:function(event,ui){var i=$(this).data("draggable"),o=i.options;i.snapElements=[];$(o.snap.constructor!=String?(o.snap.items||':data(draggable)'):o.snap).each(function(){var $t=$(this);var $o=$t.offset();if(this!=i.element[0])i.snapElements.push({item:this,width:$t.outerWidth(),height:$t.outerHeight(),top:$o.top,left:$o.left});});},drag:function(event,ui){var inst=$(this).data("draggable"),o=inst.options;var d=o.snapTolerance;var x1=ui.offset.left,x2=x1+inst.helperProportions.width,y1=ui.offset.top,y2=y1+inst.helperProportions.height;for(var i=inst.snapElements.length-1;i>=0;i--){var l=inst.snapElements[i].left,r=l+inst.snapElements[i].width,t=inst.snapElements[i].top,b=t+inst.snapElements[i].height;if(!((l-d<x1&&x1<r+d&&t-d<y1&&y1<b+d)||(l-d<x1&&x1<r+d&&t-d<y2&&y2<b+d)||(l-d<x2&&x2<r+d&&t-d<y1&&y1<b+d)||(l-d<x2&&x2<r+d&&t-d<y2&&y2<b+d))){if(inst.snapElements[i].snapping)(inst.options.snap.release&&inst.options.snap.release.call(inst.element,event,$.extend(inst._uiHash(),{snapItem:inst.snapElements[i].item})));inst.snapElements[i].snapping=false;continue;}
+if(o.snapMode!='inner'){var ts=Math.abs(t-y2)<=d;var bs=Math.abs(b-y1)<=d;var ls=Math.abs(l-x2)<=d;var rs=Math.abs(r-x1)<=d;if(ts)ui.position.top=inst._convertPositionTo("relative",{top:t-inst.helperProportions.height,left:0}).top-inst.margins.top;if(bs)ui.position.top=inst._convertPositionTo("relative",{top:b,left:0}).top-inst.margins.top;if(ls)ui.position.left=inst._convertPositionTo("relative",{top:0,left:l-inst.helperProportions.width}).left-inst.margins.left;if(rs)ui.position.left=inst._convertPositionTo("relative",{top:0,left:r}).left-inst.margins.left;}
+var first=(ts||bs||ls||rs);if(o.snapMode!='outer'){var ts=Math.abs(t-y1)<=d;var bs=Math.abs(b-y2)<=d;var ls=Math.abs(l-x1)<=d;var rs=Math.abs(r-x2)<=d;if(ts)ui.position.top=inst._convertPositionTo("relative",{top:t,left:0}).top-inst.margins.top;if(bs)ui.position.top=inst._convertPositionTo("relative",{top:b-inst.helperProportions.height,left:0}).top-inst.margins.top;if(ls)ui.position.left=inst._convertPositionTo("relative",{top:0,left:l}).left-inst.margins.left;if(rs)ui.position.left=inst._convertPositionTo("relative",{top:0,left:r-inst.helperProportions.width}).left-inst.margins.left;}
+if(!inst.snapElements[i].snapping&&(ts||bs||ls||rs||first))
+(inst.options.snap.snap&&inst.options.snap.snap.call(inst.element,event,$.extend(inst._uiHash(),{snapItem:inst.snapElements[i].item})));inst.snapElements[i].snapping=(ts||bs||ls||rs||first);};}});$.ui.plugin.add("draggable","stack",{start:function(event,ui){var o=$(this).data("draggable").options;var group=$.makeArray($(o.stack.group)).sort(function(a,b){return(parseInt($(a).css("zIndex"),10)||o.stack.min)-(parseInt($(b).css("zIndex"),10)||o.stack.min);});$(group).each(function(i){this.style.zIndex=o.stack.min+i;});this[0].style.zIndex=o.stack.min+group.length;}});$.ui.plugin.add("draggable","zIndex",{start:function(event,ui){var t=$(ui.helper),o=$(this).data("draggable").options;if(t.css("zIndex"))o._zIndex=t.css("zIndex");t.css('zIndex',o.zIndex);},stop:function(event,ui){var o=$(this).data("draggable").options;if(o._zIndex)$(ui.helper).css('zIndex',o._zIndex);}});})(jQuery);
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.droppable.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.droppable.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.droppable.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,8 @@
+(function($){$.widget("ui.droppable",{_init:function(){var o=this.options,accept=o.accept;this.isover=0;this.isout=1;this.options.accept=this.options.accept&&$.isFunction(this.options.accept)?this.options.accept:function(d){return d.is(accept);};this.proportions={width:this.element[0].offsetWidth,height:this.element[0].offsetHeight};$.ui.ddmanager.droppables[this.options.scope]=$.ui.ddmanager.droppables[this.options.scope]||[];$.ui.ddmanager.droppables[this.options.scope].push(this);(this.options.addClasses&&this.element.addClass("ui-droppable"));},destroy:function(){var drop=$.ui.ddmanager.droppables[this.options.scope];for(var i=0;i<drop.length;i++)
+if(drop[i]==this)
+drop.splice(i,1);this.element.removeClass("ui-droppable ui-droppable-disabled").removeData("droppable").unbind(".droppable");},_setData:function(key,value){if(key=='accept'){this.options.accept=value&&$.isFunction(value)?value:function(d){return d.is(value);};}else{$.widget.prototype._setData.apply(this,arguments);}},_activate:function(event){var draggable=$.ui.ddmanager.current;if(this.options.activeClass)this.element.addClass(this.options.activeClass);(draggable&&this._trigger('activate',event,this.ui(draggable)));},_deactivate:function(event){var draggable=$.ui.ddmanager.current;if(this.options.activeClass)this.element.removeClass(this.options.activeClass);(draggable&&this._trigger('deactivate',event,this.ui(draggable)));},_over:function(event){var draggable=$.ui.ddmanager.current;if(!draggable||(draggable.currentItem||draggable.element)[0]==this.element[0])return;if(this.options.accept.call(this.element[0],(draggable.currentItem||draggable.element))){if(this.options.hoverClass)this.element.addClass(this.options.hoverClass);this._trigger('over',event,this.ui(draggable));}},_out:function(event){var draggable=$.ui.ddmanager.current;if(!draggable||(draggable.currentItem||draggable.element)[0]==this.element[0])return;if(this.options.accept.call(this.element[0],(draggable.currentItem||draggable.element))){if(this.options.hoverClass)this.element.removeClass(this.options.hoverClass);this._trigger('out',event,this.ui(draggable));}},_drop:function(event,custom){var draggable=custom||$.ui.ddmanager.current;if(!draggable||(draggable.currentItem||draggable.element)[0]==this.element[0])return false;var childrenIntersection=false;this.element.find(":data(droppable)").not(".ui-draggable-dragging").each(function(){var inst=$.data(this,'droppable');if(inst.options.greedy&&$.ui.intersect(draggable,$.extend(inst,{offset:inst.element.offset()}),inst.options.tolerance)){childrenIntersection=true;return false;}});if(childrenIntersection)return false;if(this.options.accept.call(this.element[0],(draggable.currentItem||draggable.element))){if(this.options.activeClass)this.element.removeClass(this.options.activeClass);if(this.options.hoverClass)this.element.removeClass(this.options.hoverClass);this._trigger('drop',event,this.ui(draggable));return this.element;}
+return false;},ui:function(c){return{draggable:(c.currentItem||c.element),helper:c.helper,position:c.position,absolutePosition:c.positionAbs,offset:c.positionAbs};}});$.extend($.ui.droppable,{version:"1.7.2",eventPrefix:'drop',defaults:{accept:'*',activeClass:false,addClasses:true,greedy:false,hoverClass:false,scope:'default',tolerance:'intersect'}});$.ui.intersect=function(draggable,droppable,toleranceMode){if(!droppable.offset)return false;var x1=(draggable.positionAbs||draggable.position.absolute).left,x2=x1+draggable.helperProportions.width,y1=(draggable.positionAbs||draggable.position.absolute).top,y2=y1+draggable.helperProportions.height;var l=droppable.offset.left,r=l+droppable.proportions.width,t=droppable.offset.top,b=t+droppable.proportions.height;switch(toleranceMode){case'fit':return(l<x1&&x2<r&&t<y1&&y2<b);break;case'intersect':return(l<x1+(draggable.helperProportions.width/2)&&x2-(draggable.helperProportions.width/2)<r&&t<y1+(draggable.helperProportions.height/2)&&y2-(draggable.helperProportions.height/2)<b);break;case'pointer':var draggableLeft=((draggable.positionAbs||draggable.position.absolute).left+(draggable.clickOffset||draggable.offset.click).left),draggableTop=((draggable.positionAbs||draggable.position.absolute).top+(draggable.clickOffset||draggable.offset.click).top),isOver=$.ui.isOver(draggableTop,draggableLeft,t,l,droppable.proportions.height,droppable.proportions.width);return isOver;break;case'touch':return((y1>=t&&y1<=b)||(y2>=t&&y2<=b)||(y1<t&&y2>b))&&((x1>=l&&x1<=r)||(x2>=l&&x2<=r)||(x1<l&&x2>r));break;default:return false;break;}};$.ui.ddmanager={current:null,droppables:{'default':[]},prepareOffsets:function(t,event){var m=$.ui.ddmanager.droppables[t.options.scope];var type=event?event.type:null;var list=(t.currentItem||t.element).find(":data(droppable)").andSelf();droppablesLoop:for(var i=0;i<m.length;i++){if(m[i].options.disabled||(t&&!m[i].options.accept.call(m[i].element[0],(t.currentItem||t.element))))continue;for(var j=0;j<list.length;j++){if(list[j]==m[i].element[0]){m[i].proportions.height=0;continue droppablesLoop;}};m[i].visible=m[i].element.css("display")!="none";if(!m[i].visible)continue;m[i].offset=m[i].element.offset();m[i].proportions={width:m[i].element[0].offsetWidth,height:m[i].element[0].offsetHeight};if(type=="mousedown")m[i]._activate.call(m[i],event);}},drop:function(draggable,event){var dropped=false;$.each($.ui.ddmanager.droppables[draggable.options.scope],function(){if(!this.options)return;if(!this.options.disabled&&this.visible&&$.ui.intersect(draggable,this,this.options.tolerance))
+dropped=this._drop.call(this,event);if(!this.options.disabled&&this.visible&&this.options.accept.call(this.element[0],(draggable.currentItem||draggable.element))){this.isout=1;this.isover=0;this._deactivate.call(this,event);}});return dropped;},drag:function(draggable,event){if(draggable.options.refreshPositions)$.ui.ddmanager.prepareOffsets(draggable,event);$.each($.ui.ddmanager.droppables[draggable.options.scope],function(){if(this.options.disabled||this.greedyChild||!this.visible)return;var intersects=$.ui.intersect(draggable,this,this.options.tolerance);var c=!intersects&&this.isover==1?'isout':(intersects&&this.isover==0?'isover':null);if(!c)return;var parentInstance;if(this.options.greedy){var parent=this.element.parents(':data(droppable):eq(0)');if(parent.length){parentInstance=$.data(parent[0],'droppable');parentInstance.greedyChild=(c=='isover'?1:0);}}
+if(parentInstance&&c=='isover'){parentInstance['isover']=0;parentInstance['isout']=1;parentInstance._out.call(parentInstance,event);}
+this[c]=1;this[c=='isout'?'isover':'isout']=0;this[c=="isover"?"_over":"_out"].call(this,event);if(parentInstance&&c=='isout'){parentInstance['isout']=0;parentInstance['isover']=1;parentInstance._over.call(parentInstance,event);}});}};})(jQuery);
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.progressbar.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.progressbar.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.progressbar.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,10 @@
+(function($){$.widget("ui.progressbar",{_init:function(){this.element.addClass("ui-progressbar"
++" ui-widget"
++" ui-widget-content"
++" ui-corner-all").attr({role:"progressbar","aria-valuemin":this._valueMin(),"aria-valuemax":this._valueMax(),"aria-valuenow":this._value()});this.valueDiv=$('<div class="ui-progressbar-value ui-widget-header ui-corner-left"></div>').appendTo(this.element);this._refreshValue();},destroy:function(){this.element.removeClass("ui-progressbar"
++" ui-widget"
++" ui-corner-all").removeAttr("role").removeAttr("aria-valuemin").removeAttr("aria-valuemax").removeAttr("aria-valuenow").removeData("progressbar").unbind(".progressbar");this.valueDiv.remove();$.widget.prototype.destroy.apply(this,arguments);},value:function(newValue){if(newValue===undefined){return this._value();}
+this._setData('value',newValue);return this;},_setData:function(key,value){switch(key){case'value':this.options.value=value;this._refreshValue();this._trigger('change',null,{});break;}
+$.widget.prototype._setData.apply(this,arguments);},_value:function(){var val=this.options.value;if(val<this._valueMin())val=this._valueMin();if(val>this._valueMax())val=this._valueMax();return val;},_valueMin:function(){var valueMin=0;return valueMin;},_valueMax:function(){var valueMax=100;return valueMax;},_refreshValue:function(){var value=this.value();this.valueDiv[value==this._valueMax()?'addClass':'removeClass']("ui-corner-right");this.valueDiv.width(value+'%');this.element.attr("aria-valuenow",value);}});$.extend($.ui.progressbar,{version:"1.7.2",defaults:{value:0}});})(jQuery);
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.resizable.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.resizable.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.resizable.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,36 @@
+(function($){$.widget("ui.resizable",$.extend({},$.ui.mouse,{_init:function(){var self=this,o=this.options;this.element.addClass("ui-resizable");$.extend(this,{_aspectRatio:!!(o.aspectRatio),aspectRatio:o.aspectRatio,originalElement:this.element,_proportionallyResizeElements:[],_helper:o.helper||o.ghost||o.animate?o.helper||'ui-resizable-helper':null});if(this.element[0].nodeName.match(/canvas|textarea|input|select|button|img/i)){if(/relative/.test(this.element.css('position'))&&$.browser.opera)
+this.element.css({position:'relative',top:'auto',left:'auto'});this.element.wrap($('<div class="ui-wrapper" style="overflow: hidden;"></div>').css({position:this.element.css('position'),width:this.element.outerWidth(),height:this.element.outerHeight(),top:this.element.css('top'),left:this.element.css('left')}));this.element=this.element.parent().data("resizable",this.element.data('resizable'));this.elementIsWrapper=true;this.element.css({marginLeft:this.originalElement.css("marginLeft"),marginTop:this.originalElement.css("marginTop"),marginRight:this.originalElement.css("marginRight"),marginBottom:this.originalElement.css("marginBottom")});this.originalElement.css({marginLeft:0,marginTop:0,marginRight:0,marginBottom:0});this.originalResizeStyle=this.originalElement.css('resize');this.originalElement.css('resize','none');this._proportionallyResizeElements.push(this.originalElement.css({position:'static',zoom:1,display:'block'}));this.originalElement.css({margin:this.originalElement.css('margin')});this._proportionallyResize();}
+this.handles=o.handles||(!$('.ui-resizable-handle',this.element).length?"e,s,se":{n:'.ui-resizable-n',e:'.ui-resizable-e',s:'.ui-resizable-s',w:'.ui-resizable-w',se:'.ui-resizable-se',sw:'.ui-resizable-sw',ne:'.ui-resizable-ne',nw:'.ui-resizable-nw'});if(this.handles.constructor==String){if(this.handles=='all')this.handles='n,e,s,w,se,sw,ne,nw';var n=this.handles.split(",");this.handles={};for(var i=0;i<n.length;i++){var handle=$.trim(n[i]),hname='ui-resizable-'+handle;var axis=$('<div class="ui-resizable-handle '+hname+'"></div>');if(/sw|se|ne|nw/.test(handle))axis.css({zIndex:++o.zIndex});if('se'==handle){axis.addClass('ui-icon ui-icon-gripsmall-diagonal-se');};this.handles[handle]='.ui-resizable-'+handle;this.element.append(axis);}}
+this._renderAxis=function(target){target=target||this.element;for(var i in this.handles){if(this.handles[i].constructor==String)
+this.handles[i]=$(this.handles[i],this.element).show();if(this.elementIsWrapper&&this.originalElement[0].nodeName.match(/textarea|input|select|button/i)){var axis=$(this.handles[i],this.element),padWrapper=0;padWrapper=/sw|ne|nw|se|n|s/.test(i)?axis.outerHeight():axis.outerWidth();var padPos=['padding',/ne|nw|n/.test(i)?'Top':/se|sw|s/.test(i)?'Bottom':/^e$/.test(i)?'Right':'Left'].join("");target.css(padPos,padWrapper);this._proportionallyResize();}
+if(!$(this.handles[i]).length)
+continue;}};this._renderAxis(this.element);this._handles=$('.ui-resizable-handle',this.element).disableSelection();this._handles.mouseover(function(){if(!self.resizing){if(this.className)
+var axis=this.className.match(/ui-resizable-(se|sw|ne|nw|n|e|s|w)/i);self.axis=axis&&axis[1]?axis[1]:'se';}});if(o.autoHide){this._handles.hide();$(this.element).addClass("ui-resizable-autohide").hover(function(){$(this).removeClass("ui-resizable-autohide");self._handles.show();},function(){if(!self.resizing){$(this).addClass("ui-resizable-autohide");self._handles.hide();}});}
+this._mouseInit();},destroy:function(){this._mouseDestroy();var _destroy=function(exp){$(exp).removeClass("ui-resizable ui-resizable-disabled ui-resizable-resizing").removeData("resizable").unbind(".resizable").find('.ui-resizable-handle').remove();};if(this.elementIsWrapper){_destroy(this.element);var wrapper=this.element;wrapper.parent().append(this.originalElement.css({position:wrapper.css('position'),width:wrapper.outerWidth(),height:wrapper.outerHeight(),top:wrapper.css('top'),left:wrapper.css('left')})).end().remove();}
+this.originalElement.css('resize',this.originalResizeStyle);_destroy(this.originalElement);},_mouseCapture:function(event){var handle=false;for(var i in this.handles){if($(this.handles[i])[0]==event.target)handle=true;}
+return this.options.disabled||!!handle;},_mouseStart:function(event){var o=this.options,iniPos=this.element.position(),el=this.element;this.resizing=true;this.documentScroll={top:$(document).scrollTop(),left:$(document).scrollLeft()};if(el.is('.ui-draggable')||(/absolute/).test(el.css('position'))){el.css({position:'absolute',top:iniPos.top,left:iniPos.left});}
+if($.browser.opera&&(/relative/).test(el.css('position')))
+el.css({position:'relative',top:'auto',left:'auto'});this._renderProxy();var curleft=num(this.helper.css('left')),curtop=num(this.helper.css('top'));if(o.containment){curleft+=$(o.containment).scrollLeft()||0;curtop+=$(o.containment).scrollTop()||0;}
+this.offset=this.helper.offset();this.position={left:curleft,top:curtop};this.size=this._helper?{width:el.outerWidth(),height:el.outerHeight()}:{width:el.width(),height:el.height()};this.originalSize=this._helper?{width:el.outerWidth(),height:el.outerHeight()}:{width:el.width(),height:el.height()};this.originalPosition={left:curleft,top:curtop};this.sizeDiff={width:el.outerWidth()-el.width(),height:el.outerHeight()-el.height()};this.originalMousePosition={left:event.pageX,top:event.pageY};this.aspectRatio=(typeof o.aspectRatio=='number')?o.aspectRatio:((this.originalSize.width/this.originalSize.height)||1);var cursor=$('.ui-resizable-'+this.axis).css('cursor');$('body').css('cursor',cursor=='auto'?this.axis+'-resize':cursor);el.addClass("ui-resizable-resizing");this._propagate("start",event);return true;},_mouseDrag:function(event){var el=this.helper,o=this.options,props={},self=this,smp=this.originalMousePosition,a=this.axis;var dx=(event.pageX-smp.left)||0,dy=(event.pageY-smp.top)||0;var trigger=this._change[a];if(!trigger)return false;var data=trigger.apply(this,[event,dx,dy]),ie6=$.browser.msie&&$.browser.version<7,csdif=this.sizeDiff;if(this._aspectRatio||event.shiftKey)
+data=this._updateRatio(data,event);data=this._respectSize(data,event);this._propagate("resize",event);el.css({top:this.position.top+"px",left:this.position.left+"px",width:this.size.width+"px",height:this.size.height+"px"});if(!this._helper&&this._proportionallyResizeElements.length)
+this._proportionallyResize();this._updateCache(data);this._trigger('resize',event,this.ui());return false;},_mouseStop:function(event){this.resizing=false;var o=this.options,self=this;if(this._helper){var pr=this._proportionallyResizeElements,ista=pr.length&&(/textarea/i).test(pr[0].nodeName),soffseth=ista&&$.ui.hasScroll(pr[0],'left')?0:self.sizeDiff.height,soffsetw=ista?0:self.sizeDiff.width;var s={width:(self.size.width-soffsetw),height:(self.size.height-soffseth)},left=(parseInt(self.element.css('left'),10)+(self.position.left-self.originalPosition.left))||null,top=(parseInt(self.element.css('top'),10)+(self.position.top-self.originalPosition.top))||null;if(!o.animate)
+this.element.css($.extend(s,{top:top,left:left}));self.helper.height(self.size.height);self.helper.width(self.size.width);if(this._helper&&!o.animate)this._proportionallyResize();}
+$('body').css('cursor','auto');this.element.removeClass("ui-resizable-resizing");this._propagate("stop",event);if(this._helper)this.helper.remove();return false;},_updateCache:function(data){var o=this.options;this.offset=this.helper.offset();if(isNumber(data.left))this.position.left=data.left;if(isNumber(data.top))this.position.top=data.top;if(isNumber(data.height))this.size.height=data.height;if(isNumber(data.width))this.size.width=data.width;},_updateRatio:function(data,event){var o=this.options,cpos=this.position,csize=this.size,a=this.axis;if(data.height)data.width=(csize.height*this.aspectRatio);else if(data.width)data.height=(csize.width/this.aspectRatio);if(a=='sw'){data.left=cpos.left+(csize.width-data.width);data.top=null;}
+if(a=='nw'){data.top=cpos.top+(csize.height-data.height);data.left=cpos.left+(csize.width-data.width);}
+return data;},_respectSize:function(data,event){var el=this.helper,o=this.options,pRatio=this._aspectRatio||event.shiftKey,a=this.axis,ismaxw=isNumber(data.width)&&o.maxWidth&&(o.maxWidth<data.width),ismaxh=isNumber(data.height)&&o.maxHeight&&(o.maxHeight<data.height),isminw=isNumber(data.width)&&o.minWidth&&(o.minWidth>data.width),isminh=isNumber(data.height)&&o.minHeight&&(o.minHeight>data.height);if(isminw)data.width=o.minWidth;if(isminh)data.height=o.minHeight;if(ismaxw)data.width=o.maxWidth;if(ismaxh)data.height=o.maxHeight;var dw=this.originalPosition.left+this.originalSize.width,dh=this.position.top+this.size.height;var cw=/sw|nw|w/.test(a),ch=/nw|ne|n/.test(a);if(isminw&&cw)data.left=dw-o.minWidth;if(ismaxw&&cw)data.left=dw-o.maxWidth;if(isminh&&ch)data.top=dh-o.minHeight;if(ismaxh&&ch)data.top=dh-o.maxHeight;var isNotwh=!data.width&&!data.height;if(isNotwh&&!data.left&&data.top)data.top=null;else if(isNotwh&&!data.top&&data.left)data.left=null;return data;},_proportionallyResize:function(){var o=this.options;if(!this._proportionallyResizeElements.length)return;var element=this.helper||this.element;for(var i=0;i<this._proportionallyResizeElements.length;i++){var prel=this._proportionallyResizeElements[i];if(!this.borderDif){var b=[prel.css('borderTopWidth'),prel.css('borderRightWidth'),prel.css('borderBottomWidth'),prel.css('borderLeftWidth')],p=[prel.css('paddingTop'),prel.css('paddingRight'),prel.css('paddingBottom'),prel.css('paddingLeft')];this.borderDif=$.map(b,function(v,i){var border=parseInt(v,10)||0,padding=parseInt(p[i],10)||0;return border+padding;});}
+if($.browser.msie&&!(!($(element).is(':hidden')||$(element).parents(':hidden').length)))
+continue;prel.css({height:(element.height()-this.borderDif[0]-this.borderDif[2])||0,width:(element.width()-this.borderDif[1]-this.borderDif[3])||0});};},_renderProxy:function(){var el=this.element,o=this.options;this.elementOffset=el.offset();if(this._helper){this.helper=this.helper||$('<div style="overflow:hidden;"></div>');var ie6=$.browser.msie&&$.browser.version<7,ie6offset=(ie6?1:0),pxyoffset=(ie6?2:-1);this.helper.addClass(this._helper).css({width:this.element.outerWidth()+pxyoffset,height:this.element.outerHeight()+pxyoffset,position:'absolute',left:this.elementOffset.left-ie6offset+'px',top:this.elementOffset.top-ie6offset+'px',zIndex:++o.zIndex});this.helper.appendTo("body").disableSelection();}else{this.helper=this.element;}},_change:{e:function(event,dx,dy){return{width:this.originalSize.width+dx};},w:function(event,dx,dy){var o=this.options,cs=this.originalSize,sp=this.originalPosition;return{left:sp.left+dx,width:cs.width-dx};},n:function(event,dx,dy){var o=this.options,cs=this.originalSize,sp=this.originalPosition;return{top:sp.top+dy,height:cs.height-dy};},s:function(event,dx,dy){return{height:this.originalSize.height+dy};},se:function(event,dx,dy){return $.extend(this._change.s.apply(this,arguments),this._change.e.apply(this,[event,dx,dy]));},sw:function(event,dx,dy){return $.extend(this._change.s.apply(this,arguments),this._change.w.apply(this,[event,dx,dy]));},ne:function(event,dx,dy){return $.extend(this._change.n.apply(this,arguments),this._change.e.apply(this,[event,dx,dy]));},nw:function(event,dx,dy){return $.extend(this._change.n.apply(this,arguments),this._change.w.apply(this,[event,dx,dy]));}},_propagate:function(n,event){$.ui.plugin.call(this,n,[event,this.ui()]);(n!="resize"&&this._trigger(n,event,this.ui()));},plugins:{},ui:function(){return{originalElement:this.originalElement,element:this.element,helper:this.helper,position:this.position,size:this.size,originalSize:this.originalSize,originalPosition:this.originalPosition};}}));$.extend($.ui.resizable,{version:"1.7.2",eventPrefix:"resize",defaults:{alsoResize:false,animate:false,animateDuration:"slow",animateEasing:"swing",aspectRatio:false,autoHide:false,cancel:":input,option",containment:false,delay:0,distance:1,ghost:false,grid:false,handles:"e,s,se",helper:false,maxHeight:null,maxWidth:null,minHeight:10,minWidth:10,zIndex:1000}});$.ui.plugin.add("resizable","alsoResize",{start:function(event,ui){var self=$(this).data("resizable"),o=self.options;_store=function(exp){$(exp).each(function(){$(this).data("resizable-alsoresize",{width:parseInt($(this).width(),10),height:parseInt($(this).height(),10),left:parseInt($(this).css('left'),10),top:parseInt($(this).css('top'),10)});});};if(typeof(o.alsoResize)=='object'&&!o.alsoResize.parentNode){if(o.alsoResize.length){o.alsoResize=o.alsoResize[0];_store(o.alsoResize);}
+else{$.each(o.alsoResize,function(exp,c){_store(exp);});}}else{_store(o.alsoResize);}},resize:function(event,ui){var self=$(this).data("resizable"),o=self.options,os=self.originalSize,op=self.originalPosition;var delta={height:(self.size.height-os.height)||0,width:(self.size.width-os.width)||0,top:(self.position.top-op.top)||0,left:(self.position.left-op.left)||0},_alsoResize=function(exp,c){$(exp).each(function(){var el=$(this),start=$(this).data("resizable-alsoresize"),style={},css=c&&c.length?c:['width','height','top','left'];$.each(css||['width','height','top','left'],function(i,prop){var sum=(start[prop]||0)+(delta[prop]||0);if(sum&&sum>=0)
+style[prop]=sum||null;});if(/relative/.test(el.css('position'))&&$.browser.opera){self._revertToRelativePosition=true;el.css({position:'absolute',top:'auto',left:'auto'});}
+el.css(style);});};if(typeof(o.alsoResize)=='object'&&!o.alsoResize.nodeType){$.each(o.alsoResize,function(exp,c){_alsoResize(exp,c);});}else{_alsoResize(o.alsoResize);}},stop:function(event,ui){var self=$(this).data("resizable");if(self._revertToRelativePosition&&$.browser.opera){self._revertToRelativePosition=false;el.css({position:'relative'});}
+$(this).removeData("resizable-alsoresize-start");}});$.ui.plugin.add("resizable","animate",{stop:function(event,ui){var self=$(this).data("resizable"),o=self.options;var pr=self._proportionallyResizeElements,ista=pr.length&&(/textarea/i).test(pr[0].nodeName),soffseth=ista&&$.ui.hasScroll(pr[0],'left')?0:self.sizeDiff.height,soffsetw=ista?0:self.sizeDiff.width;var style={width:(self.size.width-soffsetw),height:(self.size.height-soffseth)},left=(parseInt(self.element.css('left'),10)+(self.position.left-self.originalPosition.left))||null,top=(parseInt(self.element.css('top'),10)+(self.position.top-self.originalPosition.top))||null;self.element.animate($.extend(style,top&&left?{top:top,left:left}:{}),{duration:o.animateDuration,easing:o.animateEasing,step:function(){var data={width:parseInt(self.element.css('width'),10),height:parseInt(self.element.css('height'),10),top:parseInt(self.element.css('top'),10),left:parseInt(self.element.css('left'),10)};if(pr&&pr.length)$(pr[0]).css({width:data.width,height:data.height});self._updateCache(data);self._propagate("resize",event);}});}});$.ui.plugin.add("resizable","containment",{start:function(event,ui){var self=$(this).data("resizable"),o=self.options,el=self.element;var oc=o.containment,ce=(oc instanceof $)?oc.get(0):(/parent/.test(oc))?el.parent().get(0):oc;if(!ce)return;self.containerElement=$(ce);if(/document/.test(oc)||oc==document){self.containerOffset={left:0,top:0};self.containerPosition={left:0,top:0};self.parentData={element:$(document),left:0,top:0,width:$(document).width(),height:$(document).height()||document.body.parentNode.scrollHeight};}
+else{var element=$(ce),p=[];$(["Top","Right","Left","Bottom"]).each(function(i,name){p[i]=num(element.css("padding"+name));});self.containerOffset=element.offset();self.containerPosition=element.position();self.containerSize={height:(element.innerHeight()-p[3]),width:(element.innerWidth()-p[1])};var co=self.containerOffset,ch=self.containerSize.height,cw=self.containerSize.width,width=($.ui.hasScroll(ce,"left")?ce.scrollWidth:cw),height=($.ui.hasScroll(ce)?ce.scrollHeight:ch);self.parentData={element:ce,left:co.left,top:co.top,width:width,height:height};}},resize:function(event,ui){var self=$(this).data("resizable"),o=self.options,ps=self.containerSize,co=self.containerOffset,cs=self.size,cp=self.position,pRatio=self._aspectRatio||event.shiftKey,cop={top:0,left:0},ce=self.containerElement;if(ce[0]!=document&&(/static/).test(ce.css('position')))cop=co;if(cp.left<(self._helper?co.left:0)){self.size.width=self.size.width+(self._helper?(self.position.left-co.left):(self.position.left-cop.left));if(pRatio)self.size.height=self.size.width/o.aspectRatio;self.position.left=o.helper?co.left:0;}
+if(cp.top<(self._helper?co.top:0)){self.size.height=self.size.height+(self._helper?(self.position.top-co.top):self.position.top);if(pRatio)self.size.width=self.size.height*o.aspectRatio;self.position.top=self._helper?co.top:0;}
+self.offset.left=self.parentData.left+self.position.left;self.offset.top=self.parentData.top+self.position.top;var woset=Math.abs((self._helper?self.offset.left-cop.left:(self.offset.left-cop.left))+self.sizeDiff.width),hoset=Math.abs((self._helper?self.offset.top-cop.top:(self.offset.top-co.top))+self.sizeDiff.height);var isParent=self.containerElement.get(0)==self.element.parent().get(0),isOffsetRelative=/relative|absolute/.test(self.containerElement.css('position'));if(isParent&&isOffsetRelative)woset-=self.parentData.left;if(woset+self.size.width>=self.parentData.width){self.size.width=self.parentData.width-woset;if(pRatio)self.size.height=self.size.width/self.aspectRatio;}
+if(hoset+self.size.height>=self.parentData.height){self.size.height=self.parentData.height-hoset;if(pRatio)self.size.width=self.size.height*self.aspectRatio;}},stop:function(event,ui){var self=$(this).data("resizable"),o=self.options,cp=self.position,co=self.containerOffset,cop=self.containerPosition,ce=self.containerElement;var helper=$(self.helper),ho=helper.offset(),w=helper.outerWidth()-self.sizeDiff.width,h=helper.outerHeight()-self.sizeDiff.height;if(self._helper&&!o.animate&&(/relative/).test(ce.css('position')))
+$(this).css({left:ho.left-cop.left-co.left,width:w,height:h});if(self._helper&&!o.animate&&(/static/).test(ce.css('position')))
+$(this).css({left:ho.left-cop.left-co.left,width:w,height:h});}});$.ui.plugin.add("resizable","ghost",{start:function(event,ui){var self=$(this).data("resizable"),o=self.options,cs=self.size;self.ghost=self.originalElement.clone();self.ghost.css({opacity:.25,display:'block',position:'relative',height:cs.height,width:cs.width,margin:0,left:0,top:0}).addClass('ui-resizable-ghost').addClass(typeof o.ghost=='string'?o.ghost:'');self.ghost.appendTo(self.helper);},resize:function(event,ui){var self=$(this).data("resizable"),o=self.options;if(self.ghost)self.ghost.css({position:'relative',height:self.size.height,width:self.size.width});},stop:function(event,ui){var self=$(this).data("resizable"),o=self.options;if(self.ghost&&self.helper)self.helper.get(0).removeChild(self.ghost.get(0));}});$.ui.plugin.add("resizable","grid",{resize:function(event,ui){var self=$(this).data("resizable"),o=self.options,cs=self.size,os=self.originalSize,op=self.originalPosition,a=self.axis,ratio=o._aspectRatio||event.shiftKey;o.grid=typeof o.grid=="number"?[o.grid,o.grid]:o.grid;var ox=Math.round((cs.width-os.width)/(o.grid[0]||1))*(o.grid[0]||1),oy=Math.round((cs.height-os.height)/(o.grid[1]||1))*(o.grid[1]||1);if(/^(se|s|e)$/.test(a)){self.size.width=os.width+ox;self.size.height=os.height+oy;}
+else if(/^(ne)$/.test(a)){self.size.width=os.width+ox;self.size.height=os.height+oy;self.position.top=op.top-oy;}
+else if(/^(sw)$/.test(a)){self.size.width=os.width+ox;self.size.height=os.height+oy;self.position.left=op.left-ox;}
+else{self.size.width=os.width+ox;self.size.height=os.height+oy;self.position.top=op.top-oy;self.position.left=op.left-ox;}}});var num=function(v){return parseInt(v,10)||0;};var isNumber=function(value){return!isNaN(parseInt(value,10));};})(jQuery);
\ No newline at end of file
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.selectable.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.selectable.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.selectable.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,13 @@
+(function($){$.widget("ui.selectable",$.extend({},$.ui.mouse,{_init:function(){var self=this;this.element.addClass("ui-selectable");this.dragged=false;var selectees;this.refresh=function(){selectees=$(self.options.filter,self.element[0]);selectees.each(function(){var $this=$(this);var pos=$this.offset();$.data(this,"selectable-item",{element:this,$element:$this,left:pos.left,top:pos.top,right:pos.left+$this.outerWidth(),bottom:pos.top+$this.outerHeight(),startselected:false,selected:$this.hasClass('ui-selected'),selecting:$this.hasClass('ui-selecting'),unselecting:$this.hasClass('ui-unselecting')});});};this.refresh();this.selectees=selectees.addClass("ui-selectee");this._mouseInit();this.helper=$(document.createElement('div')).css({border:'1px dotted black'}).addClass("ui-selectable-helper");},destroy:function(){this.element.removeClass("ui-selectable ui-selectable-disabled").removeData("selectable").unbind(".selectable");this._mouseDestroy();},_mouseStart:function(event){var self=this;this.opos=[event.pageX,event.pageY];if(this.options.disabled)
+return;var options=this.options;this.selectees=$(options.filter,this.element[0]);this._trigger("start",event);$(options.appendTo).append(this.helper);this.helper.css({"z-index":100,"position":"absolute","left":event.clientX,"top":event.clientY,"width":0,"height":0});if(options.autoRefresh){this.refresh();}
+this.selectees.filter('.ui-selected').each(function(){var selectee=$.data(this,"selectable-item");selectee.startselected=true;if(!event.metaKey){selectee.$element.removeClass('ui-selected');selectee.selected=false;selectee.$element.addClass('ui-unselecting');selectee.unselecting=true;self._trigger("unselecting",event,{unselecting:selectee.element});}});$(event.target).parents().andSelf().each(function(){var selectee=$.data(this,"selectable-item");if(selectee){selectee.$element.removeClass("ui-unselecting").addClass('ui-selecting');selectee.unselecting=false;selectee.selecting=true;selectee.selected=true;self._trigger("selecting",event,{selecting:selectee.element});return false;}});},_mouseDrag:function(event){var self=this;this.dragged=true;if(this.options.disabled)
+return;var options=this.options;var x1=this.opos[0],y1=this.opos[1],x2=event.pageX,y2=event.pageY;if(x1>x2){var tmp=x2;x2=x1;x1=tmp;}
+if(y1>y2){var tmp=y2;y2=y1;y1=tmp;}
+this.helper.css({left:x1,top:y1,width:x2-x1,height:y2-y1});this.selectees.each(function(){var selectee=$.data(this,"selectable-item");if(!selectee||selectee.element==self.element[0])
+return;var hit=false;if(options.tolerance=='touch'){hit=(!(selectee.left>x2||selectee.right<x1||selectee.top>y2||selectee.bottom<y1));}else if(options.tolerance=='fit'){hit=(selectee.left>x1&&selectee.right<x2&&selectee.top>y1&&selectee.bottom<y2);}
+if(hit){if(selectee.selected){selectee.$element.removeClass('ui-selected');selectee.selected=false;}
+if(selectee.unselecting){selectee.$element.removeClass('ui-unselecting');selectee.unselecting=false;}
+if(!selectee.selecting){selectee.$element.addClass('ui-selecting');selectee.selecting=true;self._trigger("selecting",event,{selecting:selectee.element});}}else{if(selectee.selecting){if(event.metaKey&&selectee.startselected){selectee.$element.removeClass('ui-selecting');selectee.selecting=false;selectee.$element.addClass('ui-selected');selectee.selected=true;}else{selectee.$element.removeClass('ui-selecting');selectee.selecting=false;if(selectee.startselected){selectee.$element.addClass('ui-unselecting');selectee.unselecting=true;}
+self._trigger("unselecting",event,{unselecting:selectee.element});}}
+if(selectee.selected){if(!event.metaKey&&!selectee.startselected){selectee.$element.removeClass('ui-selected');selectee.selected=false;selectee.$element.addClass('ui-unselecting');selectee.unselecting=true;self._trigger("unselecting",event,{unselecting:selectee.element});}}}});return false;},_mouseStop:function(event){var self=this;this.dragged=false;var options=this.options;$('.ui-unselecting',this.element[0]).each(function(){var selectee=$.data(this,"selectable-item");selectee.$element.removeClass('ui-unselecting');selectee.unselecting=false;selectee.startselected=false;self._trigger("unselected",event,{unselected:selectee.element});});$('.ui-selecting',this.element[0]).each(function(){var selectee=$.data(this,"selectable-item");selectee.$element.removeClass('ui-selecting').addClass('ui-selected');selectee.selecting=false;selectee.selected=true;selectee.startselected=true;self._trigger("selected",event,{selected:selectee.element});});this._trigger("stop",event);this.helper.remove();return false;}}));$.extend($.ui.selectable,{version:"1.7.2",defaults:{appendTo:'body',autoRefresh:true,cancel:":input,option",delay:0,distance:0,filter:'*',tolerance:'touch'}});})(jQuery);
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.slider.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.slider.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.slider.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,41 @@
+(function($){$.widget("ui.slider",$.extend({},$.ui.mouse,{_init:function(){var self=this,o=this.options;this._keySliding=false;this._handleIndex=null;this._detectOrientation();this._mouseInit();this.element.addClass("ui-slider"
++" ui-slider-"+this.orientation
++" ui-widget"
++" ui-corner-all");this.range=$([]);if(o.range){if(o.range===true){this.range=$('<div></div>');if(!o.values)o.values=[this._valueMin(),this._valueMin()];if(o.values.length&&o.values.length!=2){o.values=[o.values[0],o.values[0]];}}else{this.range=$('<div></div>');}
+this.range.appendTo(this.element).addClass("ui-slider-range");if(o.range=="min"||o.range=="max"){this.range.addClass("ui-slider-range-"+o.range);}
+this.range.addClass("ui-widget-header");}
+if($(".ui-slider-handle",this.element).length==0)
+$('<a href="#"></a>').appendTo(this.element).addClass("ui-slider-handle");if(o.values&&o.values.length){while($(".ui-slider-handle",this.element).length<o.values.length)
+$('<a href="#"></a>').appendTo(this.element).addClass("ui-slider-handle");}
+this.handles=$(".ui-slider-handle",this.element).addClass("ui-state-default"
++" ui-corner-all");this.handle=this.handles.eq(0);this.handles.add(this.range).filter("a").click(function(event){event.preventDefault();}).hover(function(){if(!o.disabled){$(this).addClass('ui-state-hover');}},function(){$(this).removeClass('ui-state-hover');}).focus(function(){if(!o.disabled){$(".ui-slider .ui-state-focus").removeClass('ui-state-focus');$(this).addClass('ui-state-focus');}else{$(this).blur();}}).blur(function(){$(this).removeClass('ui-state-focus');});this.handles.each(function(i){$(this).data("index.ui-slider-handle",i);});this.handles.keydown(function(event){var ret=true;var index=$(this).data("index.ui-slider-handle");if(self.options.disabled)
+return;switch(event.keyCode){case $.ui.keyCode.HOME:case $.ui.keyCode.END:case $.ui.keyCode.UP:case $.ui.keyCode.RIGHT:case $.ui.keyCode.DOWN:case $.ui.keyCode.LEFT:ret=false;if(!self._keySliding){self._keySliding=true;$(this).addClass("ui-state-active");self._start(event,index);}
+break;}
+var curVal,newVal,step=self._step();if(self.options.values&&self.options.values.length){curVal=newVal=self.values(index);}else{curVal=newVal=self.value();}
+switch(event.keyCode){case $.ui.keyCode.HOME:newVal=self._valueMin();break;case $.ui.keyCode.END:newVal=self._valueMax();break;case $.ui.keyCode.UP:case $.ui.keyCode.RIGHT:if(curVal==self._valueMax())return;newVal=curVal+step;break;case $.ui.keyCode.DOWN:case $.ui.keyCode.LEFT:if(curVal==self._valueMin())return;newVal=curVal-step;break;}
+self._slide(event,index,newVal);return ret;}).keyup(function(event){var index=$(this).data("index.ui-slider-handle");if(self._keySliding){self._stop(event,index);self._change(event,index);self._keySliding=false;$(this).removeClass("ui-state-active");}});this._refreshValue();},destroy:function(){this.handles.remove();this.range.remove();this.element.removeClass("ui-slider"
++" ui-slider-horizontal"
++" ui-slider-vertical"
++" ui-slider-disabled"
++" ui-widget"
++" ui-corner-all").removeData("slider").unbind(".slider");this._mouseDestroy();},_mouseCapture:function(event){var o=this.options;if(o.disabled)
+return false;this.elementSize={width:this.element.outerWidth(),height:this.element.outerHeight()};this.elementOffset=this.element.offset();var position={x:event.pageX,y:event.pageY};var normValue=this._normValueFromMouse(position);var distance=this._valueMax()-this._valueMin()+1,closestHandle;var self=this,index;this.handles.each(function(i){var thisDistance=Math.abs(normValue-self.values(i));if(distance>thisDistance){distance=thisDistance;closestHandle=$(this);index=i;}});if(o.range==true&&this.values(1)==o.min){closestHandle=$(this.handles[++index]);}
+this._start(event,index);self._handleIndex=index;closestHandle.addClass("ui-state-active").focus();var offset=closestHandle.offset();var mouseOverHandle=!$(event.target).parents().andSelf().is('.ui-slider-handle');this._clickOffset=mouseOverHandle?{left:0,top:0}:{left:event.pageX-offset.left-(closestHandle.width()/2),top:event.pageY-offset.top
+-(closestHandle.height()/2)
+-(parseInt(closestHandle.css('borderTopWidth'),10)||0)
+-(parseInt(closestHandle.css('borderBottomWidth'),10)||0)
++(parseInt(closestHandle.css('marginTop'),10)||0)};normValue=this._normValueFromMouse(position);this._slide(event,index,normValue);return true;},_mouseStart:function(event){return true;},_mouseDrag:function(event){var position={x:event.pageX,y:event.pageY};var normValue=this._normValueFromMouse(position);this._slide(event,this._handleIndex,normValue);return false;},_mouseStop:function(event){this.handles.removeClass("ui-state-active");this._stop(event,this._handleIndex);this._change(event,this._handleIndex);this._handleIndex=null;this._clickOffset=null;return false;},_detectOrientation:function(){this.orientation=this.options.orientation=='vertical'?'vertical':'horizontal';},_normValueFromMouse:function(position){var pixelTotal,pixelMouse;if('horizontal'==this.orientation){pixelTotal=this.elementSize.width;pixelMouse=position.x-this.elementOffset.left-(this._clickOffset?this._clickOffset.left:0);}else{pixelTotal=this.elementSize.height;pixelMouse=position.y-this.elementOffset.top-(this._clickOffset?this._clickOffset.top:0);}
+var percentMouse=(pixelMouse/pixelTotal);if(percentMouse>1)percentMouse=1;if(percentMouse<0)percentMouse=0;if('vertical'==this.orientation)
+percentMouse=1-percentMouse;var valueTotal=this._valueMax()-this._valueMin(),valueMouse=percentMouse*valueTotal,valueMouseModStep=valueMouse%this.options.step,normValue=this._valueMin()+valueMouse-valueMouseModStep;if(valueMouseModStep>(this.options.step/2))
+normValue+=this.options.step;return parseFloat(normValue.toFixed(5));},_start:function(event,index){var uiHash={handle:this.handles[index],value:this.value()};if(this.options.values&&this.options.values.length){uiHash.value=this.values(index);uiHash.values=this.values();}
+this._trigger("start",event,uiHash);},_slide:function(event,index,newVal){var handle=this.handles[index];if(this.options.values&&this.options.values.length){var otherVal=this.values(index?0:1);if((this.options.values.length==2&&this.options.range===true)&&((index==0&&newVal>otherVal)||(index==1&&newVal<otherVal))){newVal=otherVal;}
+if(newVal!=this.values(index)){var newValues=this.values();newValues[index]=newVal;var allowed=this._trigger("slide",event,{handle:this.handles[index],value:newVal,values:newValues});var otherVal=this.values(index?0:1);if(allowed!==false){this.values(index,newVal,(event.type=='mousedown'&&this.options.animate),true);}}}else{if(newVal!=this.value()){var allowed=this._trigger("slide",event,{handle:this.handles[index],value:newVal});if(allowed!==false){this._setData('value',newVal,(event.type=='mousedown'&&this.options.animate));}}}},_stop:function(event,index){var uiHash={handle:this.handles[index],value:this.value()};if(this.options.values&&this.options.values.length){uiHash.value=this.values(index);uiHash.values=this.values();}
+this._trigger("stop",event,uiHash);},_change:function(event,index){var uiHash={handle:this.handles[index],value:this.value()};if(this.options.values&&this.options.values.length){uiHash.value=this.values(index);uiHash.values=this.values();}
+this._trigger("change",event,uiHash);},value:function(newValue){if(arguments.length){this._setData("value",newValue);this._change(null,0);}
+return this._value();},values:function(index,newValue,animated,noPropagation){if(arguments.length>1){this.options.values[index]=newValue;this._refreshValue(animated);if(!noPropagation)this._change(null,index);}
+if(arguments.length){if(this.options.values&&this.options.values.length){return this._values(index);}else{return this.value();}}else{return this._values();}},_setData:function(key,value,animated){$.widget.prototype._setData.apply(this,arguments);switch(key){case'disabled':if(value){this.handles.filter(".ui-state-focus").blur();this.handles.removeClass("ui-state-hover");this.handles.attr("disabled","disabled");}else{this.handles.removeAttr("disabled");}
+case'orientation':this._detectOrientation();this.element.removeClass("ui-slider-horizontal ui-slider-vertical").addClass("ui-slider-"+this.orientation);this._refreshValue(animated);break;case'value':this._refreshValue(animated);break;}},_step:function(){var step=this.options.step;return step;},_value:function(){var val=this.options.value;if(val<this._valueMin())val=this._valueMin();if(val>this._valueMax())val=this._valueMax();return val;},_values:function(index){if(arguments.length){var val=this.options.values[index];if(val<this._valueMin())val=this._valueMin();if(val>this._valueMax())val=this._valueMax();return val;}else{return this.options.values;}},_valueMin:function(){var valueMin=this.options.min;return valueMin;},_valueMax:function(){var valueMax=this.options.max;return valueMax;},_refreshValue:function(animate){var oRange=this.options.range,o=this.options,self=this;if(this.options.values&&this.options.values.length){var vp0,vp1;this.handles.each(function(i,j){var valPercent=(self.values(i)-self._valueMin())/(self._valueMax()-self._valueMin())*100;var _set={};_set[self.orientation=='horizontal'?'left':'bottom']=valPercent+'%';$(this).stop(1,1)[animate?'animate':'css'](_set,o.animate);if(self.options.range===true){if(self.orientation=='horizontal'){(i==0)&&self.range.stop(1,1)[animate?'animate':'css']({left:valPercent+'%'},o.animate);(i==1)&&self.range[animate?'animate':'css']({width:(valPercent-lastValPercent)+'%'},{queue:false,duration:o.animate});}else{(i==0)&&self.range.stop(1,1)[animate?'animate':'css']({bottom:(valPercent)+'%'},o.animate);(i==1)&&self.range[animate?'animate':'css']({height:(valPercent-lastValPercent)+'%'},{queue:false,duration:o.animate});}}
+lastValPercent=valPercent;});}else{var value=this.value(),valueMin=this._valueMin(),valueMax=this._valueMax(),valPercent=valueMax!=valueMin?(value-valueMin)/(valueMax-valueMin)*100:0;var _set={};_set[self.orientation=='horizontal'?'left':'bottom']=valPercent+'%';this.handle.stop(1,1)[animate?'animate':'css'](_set,o.animate);(oRange=="min")&&(this.orientation=="horizontal")&&this.range.stop(1,1)[animate?'animate':'css']({width:valPercent+'%'},o.animate);(oRange=="max")&&(this.orientation=="horizontal")&&this.range[animate?'animate':'css']({width:(100-valPercent)+'%'},{queue:false,duration:o.animate});(oRange=="min")&&(this.orientation=="vertical")&&this.range.stop(1,1)[animate?'animate':'css']({height:valPercent+'%'},o.animate);(oRange=="max")&&(this.orientation=="vertical")&&this.range[animate?'animate':'css']({height:(100-valPercent)+'%'},{queue:false,duration:o.animate});}}}));$.extend($.ui.slider,{getter:"value values",version:"1.7.2",eventPrefix:"slide",defaults:{animate:false,delay:0,distance:0,max:100,min:0,orientation:'horizontal',range:false,step:1,value:0,values:null}});})(jQuery);
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.sortable.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.sortable.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.sortable.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,75 @@
+(function($){$.widget("ui.sortable",$.extend({},$.ui.mouse,{_init:function(){var o=this.options;this.containerCache={};this.element.addClass("ui-sortable");this.refresh();this.floating=this.items.length?(/left|right/).test(this.items[0].item.css('float')):false;this.offset=this.element.offset();this._mouseInit();},destroy:function(){this.element.removeClass("ui-sortable ui-sortable-disabled").removeData("sortable").unbind(".sortable");this._mouseDestroy();for(var i=this.items.length-1;i>=0;i--)
+this.items[i].item.removeData("sortable-item");},_mouseCapture:function(event,overrideHandle){if(this.reverting){return false;}
+if(this.options.disabled||this.options.type=='static')return false;this._refreshItems(event);var currentItem=null,self=this,nodes=$(event.target).parents().each(function(){if($.data(this,'sortable-item')==self){currentItem=$(this);return false;}});if($.data(event.target,'sortable-item')==self)currentItem=$(event.target);if(!currentItem)return false;if(this.options.handle&&!overrideHandle){var validHandle=false;$(this.options.handle,currentItem).find("*").andSelf().each(function(){if(this==event.target)validHandle=true;});if(!validHandle)return false;}
+this.currentItem=currentItem;this._removeCurrentsFromItems();return true;},_mouseStart:function(event,overrideHandle,noActivation){var o=this.options,self=this;this.currentContainer=this;this.refreshPositions();this.helper=this._createHelper(event);this._cacheHelperProportions();this._cacheMargins();this.scrollParent=this.helper.scrollParent();this.offset=this.currentItem.offset();this.offset={top:this.offset.top-this.margins.top,left:this.offset.left-this.margins.left};this.helper.css("position","absolute");this.cssPosition=this.helper.css("position");$.extend(this.offset,{click:{left:event.pageX-this.offset.left,top:event.pageY-this.offset.top},parent:this._getParentOffset(),relative:this._getRelativeOffset()});this.originalPosition=this._generatePosition(event);this.originalPageX=event.pageX;this.originalPageY=event.pageY;if(o.cursorAt)
+this._adjustOffsetFromHelper(o.cursorAt);this.domPosition={prev:this.currentItem.prev()[0],parent:this.currentItem.parent()[0]};if(this.helper[0]!=this.currentItem[0]){this.currentItem.hide();}
+this._createPlaceholder();if(o.containment)
+this._setContainment();if(o.cursor){if($('body').css("cursor"))this._storedCursor=$('body').css("cursor");$('body').css("cursor",o.cursor);}
+if(o.opacity){if(this.helper.css("opacity"))this._storedOpacity=this.helper.css("opacity");this.helper.css("opacity",o.opacity);}
+if(o.zIndex){if(this.helper.css("zIndex"))this._storedZIndex=this.helper.css("zIndex");this.helper.css("zIndex",o.zIndex);}
+if(this.scrollParent[0]!=document&&this.scrollParent[0].tagName!='HTML')
+this.overflowOffset=this.scrollParent.offset();this._trigger("start",event,this._uiHash());if(!this._preserveHelperProportions)
+this._cacheHelperProportions();if(!noActivation){for(var i=this.containers.length-1;i>=0;i--){this.containers[i]._trigger("activate",event,self._uiHash(this));}}
+if($.ui.ddmanager)
+$.ui.ddmanager.current=this;if($.ui.ddmanager&&!o.dropBehaviour)
+$.ui.ddmanager.prepareOffsets(this,event);this.dragging=true;this.helper.addClass("ui-sortable-helper");this._mouseDrag(event);return true;},_mouseDrag:function(event){this.position=this._generatePosition(event);this.positionAbs=this._convertPositionTo("absolute");if(!this.lastPositionAbs){this.lastPositionAbs=this.positionAbs;}
+if(this.options.scroll){var o=this.options,scrolled=false;if(this.scrollParent[0]!=document&&this.scrollParent[0].tagName!='HTML'){if((this.overflowOffset.top+this.scrollParent[0].offsetHeight)-event.pageY<o.scrollSensitivity)
+this.scrollParent[0].scrollTop=scrolled=this.scrollParent[0].scrollTop+o.scrollSpeed;else if(event.pageY-this.overflowOffset.top<o.scrollSensitivity)
+this.scrollParent[0].scrollTop=scrolled=this.scrollParent[0].scrollTop-o.scrollSpeed;if((this.overflowOffset.left+this.scrollParent[0].offsetWidth)-event.pageX<o.scrollSensitivity)
+this.scrollParent[0].scrollLeft=scrolled=this.scrollParent[0].scrollLeft+o.scrollSpeed;else if(event.pageX-this.overflowOffset.left<o.scrollSensitivity)
+this.scrollParent[0].scrollLeft=scrolled=this.scrollParent[0].scrollLeft-o.scrollSpeed;}else{if(event.pageY-$(document).scrollTop()<o.scrollSensitivity)
+scrolled=$(document).scrollTop($(document).scrollTop()+o.scrollSpeed);if(event.pageX-$(document).scrollLeft()<o.scrollSensitivity)
+$.ui.ddmanager.prepareOffsets(this,event);}
+this.positionAbs=this._convertPositionTo("absolute");if(!this.options.axis||this.options.axis!="y")this.helper[0].style.left=this.position.left+'px';if(!this.options.axis||this.options.axis!="x")this.helper[0].style.top=this.position.top+'px';for(var i=this.items.length-1;i>=0;i--){var item=this.items[i],itemElement=item.item[0],intersection=this._intersectsWithPointer(item);if(!intersection)continue;if(itemElement!=this.currentItem[0]&&this.placeholder[intersection==1?"next":"prev"]()[0]!=itemElement&&!$.ui.contains(this.placeholder[0],itemElement)&&(this.options.type=='semi-dynamic'?!$.ui.contains(this.element[0],itemElement):true)){this.direction=intersection==1?"down":"up";if(this.options.tolerance=="pointer"||this._intersectsWithSides(item)){this._rearrange(event,item);}else{break;}
+this._trigger("change",event,this._uiHash());break;}}
+this._contactContainers(event);if($.ui.ddmanager)$.ui.ddmanager.drag(this,event);this._trigger('sort',event,this._uiHash());this.lastPositionAbs=this.positionAbs;return false;},_mouseStop:function(event,noPropagation){if(!event)return;if($.ui.ddmanager&&!this.options.dropBehaviour)
+$.ui.ddmanager.drop(this,event);if(this.options.revert){var self=this;var cur=self.placeholder.offset();self.reverting=true;$(this.helper).animate({left:cur.left-this.offset.parent.left-self.margins.left+(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollLeft),top:cur.top-this.offset.parent.top-self.margins.top+(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollTop)},parseInt(this.options.revert,10)||500,function(){self._clear(event);});}else{this._clear(event,noPropagation);}
+return false;},cancel:function(){var self=this;if(this.dragging){this._mouseUp();if(this.options.helper=="original")
+this.currentItem.css(this._storedCSS).removeClass("ui-sortable-helper");else
+this.currentItem.show();for(var i=this.containers.length-1;i>=0;i--){this.containers[i]._trigger("deactivate",null,self._uiHash(this));if(this.containers[i].containerCache.over){this.containers[i]._trigger("out",null,self._uiHash(this));this.containers[i].containerCache.over=0;}}}
+if(this.placeholder[0].parentNode)this.placeholder[0].parentNode.removeChild(this.placeholder[0]);if(this.options.helper!="original"&&this.helper&&this.helper[0].parentNode)this.helper.remove();$.extend(this,{helper:null,dragging:false,reverting:false,_noFinalSort:null});if(this.domPosition.prev){$(this.domPosition.prev).after(this.currentItem);}else{$(this.domPosition.parent).prepend(this.currentItem);}
+return true;},serialize:function(o){var items=this._getItemsAsjQuery(o&&o.connected);var str=[];o=o||{};$(items).each(function(){var res=($(o.item||this).attr(o.attribute||'id')||'').match(o.expression||(/(.+)[-=_](.+)/));if(res)str.push((o.key||res[1]+'[]')+'='+(o.key&&o.expression?res[1]:res[2]));});return str.join('&');},toArray:function(o){var items=this._getItemsAsjQuery(o&&o.connected);var ret=[];o=o||{};items.each(function(){ret.push($(o.item||this).attr(o.attribute||'id')||'');});return ret;},_intersectsWith:function(item){var x1=this.positionAbs.left,x2=x1+this.helperProportions.width,y1=this.positionAbs.top,y2=y1+this.helperProportions.height;var l=item.left,r=l+item.width,t=item.top,b=t+item.height;var dyClick=this.offset.click.top,dxClick=this.offset.click.left;var isOverElement=(y1+dyClick)>t&&(y1+dyClick)<b&&(x1+dxClick)>l&&(x1+dxClick)<r;if(this.options.tolerance=="pointer"||this.options.forcePointerForContainers||(this.options.tolerance!="pointer"&&this.helperProportions[this.floating?'width':'height']>item[this.floating?'width':'height'])){return isOverElement;}else{return(l<x1+(this.helperProportions.width/2)&&x2-(this.helperProportions.width/2)<r&&t<y1+(this.helperProportions.height/2)&&y2-(this.helperProportions.height/2)<b);}},_intersectsWithPointer:function(item){var isOverElementHeight=$.ui.isOverAxis(this.positionAbs.top+this.offset.click.top,item.top,item.height),isOverElementWidth=$.ui.isOverAxis(this.positionAbs.left+this.offset.click.left,item.left,item.width),isOverElement=isOverElementHeight&&isOverElementWidth,verticalDirection=this._getDragVerticalDirection(),horizontalDirection=this._getDragHorizontalDirection();if(!isOverElement)
+return false;return this.floating?(((horizontalDirection&&horizontalDirection=="right")||verticalDirection=="down")?2:1):(verticalDirection&&(verticalDirection=="down"?2:1));},_intersectsWithSides:function(item){var isOverBottomHalf=$.ui.isOverAxis(this.positionAbs.top+this.offset.click.top,item.top+(item.height/2),item.height),isOverRightHalf=$.ui.isOverAxis(this.positionAbs.left+this.offset.click.left,item.left+(item.width/2),item.width),verticalDirection=this._getDragVerticalDirection(),horizontalDirection=this._getDragHorizontalDirection();if(this.floating&&horizontalDirection){return((horizontalDirection=="right"&&isOverRightHalf)||(horizontalDirection=="left"&&!isOverRightHalf));}else{return verticalDirection&&((verticalDirection=="down"&&isOverBottomHalf)||(verticalDirection=="up"&&!isOverBottomHalf));}},_getDragVerticalDirection:function(){var delta=this.positionAbs.top-this.lastPositionAbs.top;return delta!=0&&(delta>0?"down":"up");},_getDragHorizontalDirection:function(){var delta=this.positionAbs.left-this.lastPositionAbs.left;return delta!=0&&(delta>0?"right":"left");},refresh:function(event){this._refreshItems(event);this.refreshPositions();},_connectWith:function(){var options=this.options;return options.connectWith.constructor==String?[options.connectWith]:options.connectWith;},_getItemsAsjQuery:function(connected){var self=this;var items=[];var queries=[];var connectWith=this._connectWith();if(connectWith&&connected){for(var i=connectWith.length-1;i>=0;i--){var cur=$(connectWith[i]);for(var j=cur.length-1;j>=0;j--){var inst=$.data(cur[j],'sortable');if(inst&&inst!=this&&!inst.options.disabled){queries.push([$.isFunction(inst.options.items)?inst.options.items.call(inst.element):$(inst.options.items,inst.element).not(".ui-sortable-helper"),inst]);}};};}
+queries.push([$.isFunction(this.options.items)?this.options.items.call(this.element,null,{options:this.options,item:this.currentItem}):$(this.options.items,this.element).not(".ui-sortable-helper"),this]);for(var i=queries.length-1;i>=0;i--){queries[i][0].each(function(){items.push(this);});};return $(items);},_removeCurrentsFromItems:function(){var list=this.currentItem.find(":data(sortable-item)");for(var i=0;i<this.items.length;i++){for(var j=0;j<list.length;j++){if(list[j]==this.items[i].item[0])
+this.items.splice(i,1);};};},_refreshItems:function(event){this.items=[];this.containers=[this];var items=this.items;var self=this;var queries=[[$.isFunction(this.options.items)?this.options.items.call(this.element[0],event,{item:this.currentItem}):$(this.options.items,this.element),this]];var connectWith=this._connectWith();if(connectWith){for(var i=connectWith.length-1;i>=0;i--){var cur=$(connectWith[i]);for(var j=cur.length-1;j>=0;j--){var inst=$.data(cur[j],'sortable');if(inst&&inst!=this&&!inst.options.disabled){queries.push([$.isFunction(inst.options.items)?inst.options.items.call(inst.element[0],event,{item:this.currentItem}):$(inst.options.items,inst.element),inst]);this.containers.push(inst);}};};}
+for(var i=queries.length-1;i>=0;i--){var targetData=queries[i][1];var _queries=queries[i][0];for(var j=0,queriesLength=_queries.length;j<queriesLength;j++){var item=$(_queries[j]);item.data('sortable-item',targetData);items.push({item:item,instance:targetData,width:0,height:0,left:0,top:0});};};},refreshPositions:function(fast){if(this.offsetParent&&this.helper){this.offset.parent=this._getParentOffset();}
+for(var i=this.items.length-1;i>=0;i--){var item=this.items[i];if(item.instance!=this.currentContainer&&this.currentContainer&&item.item[0]!=this.currentItem[0])
+continue;var t=this.options.toleranceElement?$(this.options.toleranceElement,item.item):item.item;if(!fast){item.width=t.outerWidth();item.height=t.outerHeight();}
+var p=t.offset();item.left=p.left;item.top=p.top;};if(this.options.custom&&this.options.custom.refreshContainers){this.options.custom.refreshContainers.call(this);}else{for(var i=this.containers.length-1;i>=0;i--){var p=this.containers[i].element.offset();this.containers[i].containerCache.left=p.left;this.containers[i].containerCache.top=p.top;this.containers[i].containerCache.width=this.containers[i].element.outerWidth();this.containers[i].containerCache.height=this.containers[i].element.outerHeight();};}},_createPlaceholder:function(that){var self=that||this,o=self.options;if(!o.placeholder||o.placeholder.constructor==String){var className=o.placeholder;o.placeholder={element:function(){var el=$(document.createElement(self.currentItem[0].nodeName)).addClass(className||self.currentItem[0].className+" ui-sortable-placeholder").removeClass("ui-sortable-helper")[0];if(!className)
+el.style.visibility="hidden";return el;},update:function(container,p){if(className&&!o.forcePlaceholderSize)return;if(!p.height()){p.height(self.currentItem.innerHeight()-parseInt(self.currentItem.css('paddingTop')||0,10)-parseInt(self.currentItem.css('paddingBottom')||0,10));};if(!p.width()){p.width(self.currentItem.innerWidth()-parseInt(self.currentItem.css('paddingLeft')||0,10)-parseInt(self.currentItem.css('paddingRight')||0,10));};}};}
+self.placeholder=$(o.placeholder.element.call(self.element,self.currentItem));self.currentItem.after(self.placeholder);o.placeholder.update(self,self.placeholder);},_contactContainers:function(event){for(var i=this.containers.length-1;i>=0;i--){if(this._intersectsWith(this.containers[i].containerCache)){if(!this.containers[i].containerCache.over){if(this.currentContainer!=this.containers[i]){var dist=10000;var itemWithLeastDistance=null;var base=this.positionAbs[this.containers[i].floating?'left':'top'];for(var j=this.items.length-1;j>=0;j--){if(!$.ui.contains(this.containers[i].element[0],this.items[j].item[0]))continue;var cur=this.items[j][this.containers[i].floating?'left':'top'];if(Math.abs(cur-base)<dist){dist=Math.abs(cur-base);itemWithLeastDistance=this.items[j];}}
+if(!itemWithLeastDistance&&!this.options.dropOnEmpty)
+continue;this.currentContainer=this.containers[i];itemWithLeastDistance?this._rearrange(event,itemWithLeastDistance,null,true):this._rearrange(event,null,this.containers[i].element,true);this._trigger("change",event,this._uiHash());this.containers[i]._trigger("change",event,this._uiHash(this));this.options.placeholder.update(this.currentContainer,this.placeholder);}
+this.containers[i]._trigger("over",event,this._uiHash(this));this.containers[i].containerCache.over=1;}}else{if(this.containers[i].containerCache.over){this.containers[i]._trigger("out",event,this._uiHash(this));this.containers[i].containerCache.over=0;}}};},_createHelper:function(event){var o=this.options;var helper=$.isFunction(o.helper)?$(o.helper.apply(this.element[0],[event,this.currentItem])):(o.helper=='clone'?this.currentItem.clone():this.currentItem);if(!helper.parents('body').length)
+$(o.appendTo!='parent'?o.appendTo:this.currentItem[0].parentNode)[0].appendChild(helper[0]);if(helper[0]==this.currentItem[0])
+this._storedCSS={width:this.currentItem[0].style.width,height:this.currentItem[0].style.height,position:this.currentItem.css("position"),top:this.currentItem.css("top"),left:this.currentItem.css("left")};if(helper[0].style.width==''||o.forceHelperSize)helper.width(this.currentItem.width());if(helper[0].style.height==''||o.forceHelperSize)helper.height(this.currentItem.height());return helper;},_adjustOffsetFromHelper:function(obj){if(obj.left!=undefined)this.offset.click.left=obj.left+this.margins.left;if(obj.right!=undefined)this.offset.click.left=this.helperProportions.width-obj.right+this.margins.left;if(obj.top!=undefined)this.offset.click.top=obj.top+this.margins.top;if(obj.bottom!=undefined)this.offset.click.top=this.helperProportions.height-obj.bottom+this.margins.top;},_getParentOffset:function(){this.offsetParent=this.helper.offsetParent();var po=this.offsetParent.offset();if(this.cssPosition=='absolute'&&this.scrollParent[0]!=document&&$.ui.contains(this.scrollParent[0],this.offsetParent[0])){po.left+=this.scrollParent.scrollLeft();po.top+=this.scrollParent.scrollTop();}
+if((this.offsetParent[0]==document.body)||(this.offsetParent[0].tagName&&this.offsetParent[0].tagName.toLowerCase()=='html'&&$.browser.msie))
+po={top:0,left:0};return{top:po.top+(parseInt(this.offsetParent.css("borderTopWidth"),10)||0),left:po.left+(parseInt(this.offsetParent.css("borderLeftWidth"),10)||0)};},_getRelativeOffset:function(){if(this.cssPosition=="relative"){var p=this.currentItem.position();return{top:p.top-(parseInt(this.helper.css("top"),10)||0)+this.scrollParent.scrollTop(),left:p.left-(parseInt(this.helper.css("left"),10)||0)+this.scrollParent.scrollLeft()};}else{return{top:0,left:0};}},_cacheMargins:function(){this.margins={left:(parseInt(this.currentItem.css("marginLeft"),10)||0),top:(parseInt(this.currentItem.css("marginTop"),10)||0)};},_cacheHelperProportions:function(){this.helperProportions={width:this.helper.outerWidth(),height:this.helper.outerHeight()};},_setContainment:function(){var o=this.options;if(o.containment=='parent')o.containment=this.helper[0].parentNode;if(o.containment=='document'||o.containment=='window')this.containment=[0-this.offset.relative.left-this.offset.parent.left,0-this.offset.relative.top-this.offset.parent.top,$(o.containment=='document'?document:window).width()-this.helperProportions.width-this.margins.left,($(o.containment=='document'?document:window).height()||document.body.parentNode.scrollHeight)-this.helperProportions.height-this.margins.top];if(!(/^(document|window|parent)$/).test(o.containment)){var ce=$(o.containment)[0];var co=$(o.containment).offset();var over=($(ce).css("overflow")!='hidden');this.containment=[co.left+(parseInt($(ce).css("borderLeftWidth"),10)||0)+(parseInt($(ce).css("paddingLeft"),10)||0)-this.margins.left,co.top+(parseInt($(ce).css("borderTopWidth"),10)||0)+(parseInt($(ce).css("paddingTop"),10)||0)-this.margins.top,co.left+(over?Math.max(ce.scrollWidth,ce.offsetWidth):ce.offsetWidth)-(parseInt($(ce).css("borderLeftWidth"),10)||0)-(parseInt($(ce).css("paddingRight"),10)||0)-this.helperProportions.width-this.margins.left,co.top+(over?Math.max(ce.scrollHeight,ce.offsetHeight):ce.offsetHeight)-(parseInt($(ce).css("borderTopWidth"),10)||0)-(parseInt($(ce).css("paddingBottom"),10)||0)-this.helperProportions.height-this.margins.top];}},_convertPositionTo:function(d,pos){if(!pos)pos=this.position;var mod=d=="absolute"?1:-1;var o=this.options,scroll=this.cssPosition=='absolute'&&!(this.scrollParent[0]!=document&&$.ui.contains(this.scrollParent[0],this.offsetParent[0]))?this.offsetParent:this.scrollParent,scrollIsRootNode=(/(html|body)/i).test(scroll[0].tagName);return{top:(pos.top
++this.offset.relative.top*mod
++this.offset.parent.top*mod
+-($.browser.safari&&this.cssPosition=='fixed'?0:(this.cssPosition=='fixed'?-this.scrollParent.scrollTop():(scrollIsRootNode?0:scroll.scrollTop()))*mod)),left:(pos.left
++this.offset.relative.left*mod
++this.offset.parent.left*mod
+-($.browser.safari&&this.cssPosition=='fixed'?0:(this.cssPosition=='fixed'?-this.scrollParent.scrollLeft():scrollIsRootNode?0:scroll.scrollLeft())*mod))};},_generatePosition:function(event){var o=this.options,scroll=this.cssPosition=='absolute'&&!(this.scrollParent[0]!=document&&$.ui.contains(this.scrollParent[0],this.offsetParent[0]))?this.offsetParent:this.scrollParent,scrollIsRootNode=(/(html|body)/i).test(scroll[0].tagName);if(this.cssPosition=='relative'&&!(this.scrollParent[0]!=document&&this.scrollParent[0]!=this.offsetParent[0])){this.offset.relative=this._getRelativeOffset();}
+var pageX=event.pageX;var pageY=event.pageY;if(this.originalPosition){if(this.containment){if(event.pageX-this.offset.click.left<this.containment[0])pageX=this.containment[0]+this.offset.click.left;if(event.pageY-this.offset.click.top<this.containment[1])pageY=this.containment[1]+this.offset.click.top;if(event.pageX-this.offset.click.left>this.containment[2])pageX=this.containment[2]+this.offset.click.left;if(event.pageY-this.offset.click.top>this.containment[3])pageY=this.containment[3]+this.offset.click.top;}
+if(o.grid){var top=this.originalPageY+Math.round((pageY-this.originalPageY)/o.grid[1])*o.grid[1];pageY=this.containment?(!(top-this.offset.click.top<this.containment[1]||top-this.offset.click.top>this.containment[3])?top:(!(top-this.offset.click.top<this.containment[1])?top-o.grid[1]:top+o.grid[1])):top;var left=this.originalPageX+Math.round((pageX-this.originalPageX)/o.grid[0])*o.grid[0];pageX=this.containment?(!(left-this.offset.click.left<this.containment[0]||left-this.offset.click.left>this.containment[2])?left:(!(left-this.offset.click.left<this.containment[0])?left-o.grid[0]:left+o.grid[0])):left;}}
+return{top:(pageY
+-this.offset.click.top
+-this.offset.relative.top
+-this.offset.parent.top
++($.browser.safari&&this.cssPosition=='fixed'?0:(this.cssPosition=='fixed'?-this.scrollParent.scrollTop():(scrollIsRootNode?0:scroll.scrollTop())))),left:(pageX
+-this.offset.click.left
+-this.offset.relative.left
+-this.offset.parent.left
++($.browser.safari&&this.cssPosition=='fixed'?0:(this.cssPosition=='fixed'?-this.scrollParent.scrollLeft():scrollIsRootNode?0:scroll.scrollLeft())))};},_rearrange:function(event,i,a,hardRefresh){a?a[0].appendChild(this.placeholder[0]):i.item[0].parentNode.insertBefore(this.placeholder[0],(this.direction=='down'?i.item[0]:i.item[0].nextSibling));this.counter=this.counter?++this.counter:1;var self=this,counter=this.counter;window.setTimeout(function(){if(counter==self.counter)self.refreshPositions(!hardRefresh);},0);},_clear:function(event,noPropagation){this.reverting=false;var delayedTriggers=[],self=this;if(!this._noFinalSort&&this.currentItem[0].parentNode)this.placeholder.before(this.currentItem);this._noFinalSort=null;if(this.helper[0]==this.currentItem[0]){for(var i in this._storedCSS){if(this._storedCSS[i]=='auto'||this._storedCSS[i]=='static')this._storedCSS[i]='';}
+this.currentItem.css(this._storedCSS).removeClass("ui-sortable-helper");}else{this.currentItem.show();}
+if(this.fromOutside&&!noPropagation)delayedTriggers.push(function(event){this._trigger("receive",event,this._uiHash(this.fromOutside));});if((this.fromOutside||this.domPosition.prev!=this.currentItem.prev().not(".ui-sortable-helper")[0]||this.domPosition.parent!=this.currentItem.parent()[0])&&!noPropagation)delayedTriggers.push(function(event){this._trigger("update",event,this._uiHash());});if(!$.ui.contains(this.element[0],this.currentItem[0])){if(!noPropagation)delayedTriggers.push(function(event){this._trigger("remove",event,this._uiHash());});for(var i=this.containers.length-1;i>=0;i--){if($.ui.contains(this.containers[i].element[0],this.currentItem[0])&&!noPropagation){delayedTriggers.push((function(c){return function(event){c._trigger("receive",event,this._uiHash(this));};}).call(this,this.containers[i]));delayedTriggers.push((function(c){return function(event){c._trigger("update",event,this._uiHash(this));};}).call(this,this.containers[i]));}};};for(var i=this.containers.length-1;i>=0;i--){if(!noPropagation)delayedTriggers.push((function(c){return function(event){c._trigger("deactivate",event,this._uiHash(this));};}).call(this,this.containers[i]));if(this.containers[i].containerCache.over){delayedTriggers.push((function(c){return function(event){c._trigger("out",event,this._uiHash(this));};}).call(this,this.containers[i]));this.containers[i].containerCache.over=0;}}
+if(this._storedCursor)$('body').css("cursor",this._storedCursor);if(this._storedOpacity)this.helper.css("opacity",this._storedOpacity);if(this._storedZIndex)this.helper.css("zIndex",this._storedZIndex=='auto'?'':this._storedZIndex);this.dragging=false;if(this.cancelHelperRemoval){if(!noPropagation){this._trigger("beforeStop",event,this._uiHash());for(var i=0;i<delayedTriggers.length;i++){delayedTriggers[i].call(this,event);};this._trigger("stop",event,this._uiHash());}
+return false;}
+if(!noPropagation)this._trigger("beforeStop",event,this._uiHash());this.placeholder[0].parentNode.removeChild(this.placeholder[0]);if(this.helper[0]!=this.currentItem[0])this.helper.remove();this.helper=null;if(!noPropagation){for(var i=0;i<delayedTriggers.length;i++){delayedTriggers[i].call(this,event);};this._trigger("stop",event,this._uiHash());}
+this.fromOutside=false;return true;},_trigger:function(){if($.widget.prototype._trigger.apply(this,arguments)===false){this.cancel();}},_uiHash:function(inst){var self=inst||this;return{helper:self.helper,placeholder:self.placeholder||$([]),position:self.position,absolutePosition:self.positionAbs,offset:self.positionAbs,item:self.currentItem,sender:inst?inst.element:null};}}));$.extend($.ui.sortable,{getter:"serialize toArray",version:"1.7.2",eventPrefix:"sort",defaults:{appendTo:"parent",axis:false,cancel:":input,option",connectWith:false,containment:false,cursor:'auto',cursorAt:false,delay:0,distance:1,dropOnEmpty:true,forcePlaceholderSize:false,forceHelperSize:false,grid:false,handle:false,helper:"original",items:'> *',opacity:false,placeholder:false,revert:false,scroll:true,scrollSensitivity:20,scrollSpeed:20,scope:"default",tolerance:"intersect",zIndex:1000}});})(jQuery);
Added: trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.tabs.js
--- trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.tabs.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.tabs.js	2009-11-04 10:29:29 UTC (rev 4914)
@@ -0,0 +1,54 @@
+(function($){$.widget("ui.tabs",{_init:function(){if(this.options.deselectable!==undefined){this.options.collapsible=this.options.deselectable;}
+this._tabify(true);},_setData:function(key,value){if(key=='selected'){if(this.options.collapsible&&value==this.options.selected){return;}
+this.select(value);}
+else{this.options[key]=value;if(key=='deselectable'){this.options.collapsible=value;}
+this._tabify();}},_tabId:function(a){return a.title&&a.title.replace(/\s/g,'_').replace(/[^A-Za-z0-9\-_:\.]/g,'')||this.options.idPrefix+$.data(a);},_sanitizeSelector:function(hash){return hash.replace(/:/g,'\\:');},_cookie:function(){var cookie=this.cookie||(this.cookie=this.options.cookie.name||'ui-tabs-'+$.data(this.list[0]));return $.cookie.apply(null,[cookie].concat($.makeArray(arguments)));},_ui:function(tab,panel){return{tab:tab,panel:panel,index:this.anchors.index(tab)};},_cleanup:function(){this.lis.filter('.ui-state-processing').removeClass('ui-state-processing').find('span:data(label.tabs)').each(function(){var el=$(this);el.html(el.data('label.tabs')).removeData('label.tabs');});},_tabify:function(init){this.list=this.element.children('ul:first');this.lis=$('li:has(a[href])',this.list);this.anchors=this.lis.map(function(){return $('a',this)[0];});this.panels=$([]);var self=this,o=this.options;var fragmentId=/^#.+/;this.anchors.each(function(i,a){var href=$(a).attr('href');var hrefBase=href.split('#')[0],baseEl;if(hrefBase&&(hrefBase===location.toString().split('#')[0]||(baseEl=$('base')[0])&&hrefBase===baseEl.href)){href=a.hash;a.href=href;}
+if(fragmentId.test(href)){self.panels=self.panels.add(self._sanitizeSelector(href));}
+else if(href!='#'){$.data(a,'href.tabs',href);$.data(a,'load.tabs',href.replace(/#.*$/,''));var id=self._tabId(a);a.href='#'+id;var $panel=$('#'+id);if(!$panel.length){$panel=$(o.panelTemplate).attr('id',id).addClass('ui-tabs-panel ui-widget-content ui-corner-bottom').insertAfter(self.panels[i-1]||self.list);$panel.data('destroy.tabs',true);}
+self.panels=self.panels.add($panel);}
+else{o.disabled.push(i);}});if(init){this.element.addClass('ui-tabs ui-widget ui-widget-content ui-corner-all');this.list.addClass('ui-tabs-nav ui-helper-reset ui-helper-clearfix ui-widget-header ui-corner-all');this.lis.addClass('ui-state-default ui-corner-top');this.panels.addClass('ui-tabs-panel ui-widget-content ui-corner-bottom');if(o.selected===undefined){if(location.hash){this.anchors.each(function(i,a){if(a.hash==location.hash){o.selected=i;return false;}});}
+if(typeof o.selected!='number'&&o.cookie){o.selected=parseInt(self._cookie(),10);}
+if(typeof o.selected!='number'&&this.lis.filter('.ui-tabs-selected').length){o.selected=this.lis.index(this.lis.filter('.ui-tabs-selected'));}
+o.selected=o.selected||0;}
+else if(o.selected===null){o.selected=-1;}
+o.selected=((o.selected>=0&&this.anchors[o.selected])||o.selected<0)?o.selected:0;o.disabled=$.unique(o.disabled.concat($.map(this.lis.filter('.ui-state-disabled'),function(n,i){return self.lis.index(n);}))).sort();if($.inArray(o.selected,o.disabled)!=-1){o.disabled.splice($.inArray(o.selected,o.disabled),1);}
+this.panels.addClass('ui-tabs-hide');this.lis.removeClass('ui-tabs-selected ui-state-active');if(o.selected>=0&&this.anchors.length){this.panels.eq(o.selected).removeClass('ui-tabs-hide');this.lis.eq(o.selected).addClass('ui-tabs-selected ui-state-active');self.element.queue("tabs",function(){self._trigger('show',null,self._ui(self.anchors[o.selected],self.panels[o.selected]));});this.load(o.selected);}
+$(window).bind('unload',function(){self.lis.add(self.anchors).unbind('.tabs');self.lis=self.anchors=self.panels=null;});}
+else{o.selected=this.lis.index(this.lis.filter('.ui-tabs-selected'));}
+this.element[o.collapsible?'addClass':'removeClass']('ui-tabs-collapsible');if(o.cookie){this._cookie(o.selected,o.cookie);}
+for(var i=0,li;(li=this.lis[i]);i++){$(li)[$.inArray(i,o.disabled)!=-1&&!$(li).hasClass('ui-tabs-selected')?'addClass':'removeClass']('ui-state-disabled');}
+if(o.cache===false){this.anchors.removeData('cache.tabs');}
+this.lis.add(this.anchors).unbind('.tabs');if(o.event!='mouseover'){var addState=function(state,el){if(el.is(':not(.ui-state-disabled)')){el.addClass('ui-state-'+state);}};var removeState=function(state,el){el.removeClass('ui-state-'+state);};this.lis.bind('mouseover.tabs',function(){addState('hover',$(this));});this.lis.bind('mouseout.tabs',function(){removeState('hover',$(this));});this.anchors.bind('focus.tabs',function(){addState('focus',$(this).closest('li'));});this.anchors.bind('blur.tabs',function(){removeState('focus',$(this).closest('li'));});}
+var hideFx,showFx;if(o.fx){if($.isArray(o.fx)){hideFx=o.fx[0];showFx=o.fx[1];}
+else{hideFx=showFx=o.fx;}}
+function resetStyle($el,fx){$el.css({display:''});if($.browser.msie&&fx.opacity){$el[0].style.removeAttribute('filter');}}
+var showTab=showFx?function(clicked,$show){$(clicked).closest('li').removeClass('ui-state-default').addClass('ui-tabs-selected ui-state-active');$show.hide().removeClass('ui-tabs-hide').animate(showFx,showFx.duration||'normal',function(){resetStyle($show,showFx);self._trigger('show',null,self._ui(clicked,$show[0]));});}:function(clicked,$show){$(clicked).closest('li').removeClass('ui-state-default').addClass('ui-tabs-selected ui-state-active');$show.removeClass('ui-tabs-hide');self._trigger('show',null,self._ui(clicked,$show[0]));};var hideTab=hideFx?function(clicked,$hide){$hide.animate(hideFx,hideFx.duration||'normal',function(){self.lis.removeClass('ui-tabs-selected ui-state-active').addClass('ui-state-default');$hide.addClass('ui-tabs-hide');resetStyle($hide,hideFx);self.element.dequeue("tabs");});}:function(clicked,$hide,$show){self.lis.removeClass('ui-tabs-selected ui-state-active').addClass('ui-state-default');$hide.addClass('ui-tabs-hide');self.element.dequeue("tabs");};this.anchors.bind(o.event+'.tabs',function(){var el=this,$li=$(this).closest('li'),$hide=self.panels.filter(':not(.ui-tabs-hide)'),$show=$(self._sanitizeSelector(this.hash));if(($li.hasClass('ui-tabs-selected')&&!o.collapsible)||$li.hasClass('ui-state-disabled')||$li.hasClass('ui-state-processing')||self._trigger('select',null,self._ui(this,$show[0]))===false){this.blur();return false;}
+o.selected=self.anchors.index(this);self.abort();if(o.collapsible){if($li.hasClass('ui-tabs-selected')){o.selected=-1;if(o.cookie){self._cookie(o.selected,o.cookie);}
+self.element.queue("tabs",function(){hideTab(el,$hide);}).dequeue("tabs");this.blur();return false;}
+else if(!$hide.length){if(o.cookie){self._cookie(o.selected,o.cookie);}
+self.element.queue("tabs",function(){showTab(el,$show);});self.load(self.anchors.index(this));this.blur();return false;}}
+if(o.cookie){self._cookie(o.selected,o.cookie);}
+if($show.length){if($hide.length){self.element.queue("tabs",function(){hideTab(el,$hide);});}
+self.element.queue("tabs",function(){showTab(el,$show);});self.load(self.anchors.index(this));}
+else{throw'jQuery UI Tabs: Mismatching fragment identifier.';}
+if($.browser.msie){this.blur();}});this.anchors.bind('click.tabs',function(){return false;});},destroy:function(){var o=this.options;this.abort();this.element.unbind('.tabs').removeClass('ui-tabs ui-widget ui-widget-content ui-corner-all ui-tabs-collapsible').removeData('tabs');this.list.removeClass('ui-tabs-nav ui-helper-reset ui-helper-clearfix ui-widget-header ui-corner-all');this.anchors.each(function(){var href=$.data(this,'href.tabs');if(href){this.href=href;}
+var $this=$(this).unbind('.tabs');$.each(['href','load','cache'],function(i,prefix){$this.removeData(prefix+'.tabs');});});this.lis.unbind('.tabs').add(this.panels).each(function(){if($.data(this,'destroy.tabs')){$(this).remove();}
+else{$(this).removeClass(['ui-state-default','ui-corner-top','ui-tabs-selected','ui-state-active','ui-state-hover','ui-state-focus','ui-state-disabled','ui-tabs-panel','ui-widget-content','ui-corner-bottom','ui-tabs-hide'].join(' '));}});if(o.cookie){this._cookie(null,o.cookie);}},add:function(url,label,index){if(index===undefined){index=this.anchors.length;}
+var self=this,o=this.options,$li=$(o.tabTemplate.replace(/#\{href\}/g,url).replace(/#\{label\}/g,label)),id=!url.indexOf('#')?url.replace('#',''):this._tabId($('a',$li)[0]);$li.addClass('ui-state-default ui-corner-top').data('destroy.tabs',true);var $panel=$('#'+id);if(!$panel.length){$panel=$(o.panelTemplate).attr('id',id).data('destroy.tabs',true);}
+$panel.addClass('ui-tabs-panel ui-widget-content ui-corner-bottom ui-tabs-hide');if(index>=this.lis.length){$li.appendTo(this.list);$panel.appendTo(this.list[0].parentNode);}
+else{$li.insertBefore(this.lis[index]);$panel.insertBefore(this.panels[index]);}
+o.disabled=$.map(o.disabled,function(n,i){return n>=index?++n:n;});this._tabify();if(this.anchors.length==1){$li.addClass('ui-tabs-selected ui-state-active');$panel.removeClass('ui-tabs-hide');this.element.queue("tabs",function(){self._trigger('show',null,self._ui(self.anchors[0],self.panels[0]));});this.load(0);}
+this._trigger('add',null,this._ui(this.anchors[index],this.panels[index]));},remove:function(index){var o=this.options,$li=this.lis.eq(index).remove(),$panel=this.panels.eq(index).remove();if($li.hasClass('ui-tabs-selected')&&this.anchors.length>1){this.select(index+(index+1<this.anchors.length?1:-1));}
+o.disabled=$.map($.grep(o.disabled,function(n,i){return n!=index;}),function(n,i){return n>=index?--n:n;});this._tabify();this._trigger('remove',null,this._ui($li.find('a')[0],$panel[0]));},enable:function(index){var o=this.options;if($.inArray(index,o.disabled)==-1){return;}
+this.lis.eq(index).removeClass('ui-state-disabled');o.disabled=$.grep(o.disabled,function(n,i){return n!=index;});this._trigger('enable',null,this._ui(this.anchors[index],this.panels[index]));},disable:function(index){var self=this,o=this.options;if(index!=o.selected){this.lis.eq(index).addClass('ui-state-disabled');o.disabled.push(index);o.disabled.sort();this._trigger('disable',null,this._ui(this.anchors[index],this.panels[index]));}},select:function(index){if(typeof index=='string'){index=this.anchors.index(this.anchors.filter('[href$='+index+']'));}
+else if(index===null){index=-1;}
+if(index==-1&&this.options.collapsible){index=this.options.selected;}
+this.anchors.eq(index).trigger(this.options.event+'.tabs');},load:function(index){var self=this,o=this.options,a=this.anchors.eq(index)[0],url=$.data(a,'load.tabs');this.abort();if(!url||this.element.queue("tabs").length!==0&&$.data(a,'cache.tabs')){this.element.dequeue("tabs");return;}
+this.lis.eq(index).addClass('ui-state-processing');if(o.spinner){var span=$('span',a);span.data('label.tabs',span.html()).html(o.spinner);}
+this.xhr=$.ajax($.extend({},o.ajaxOptions,{url:url,success:function(r,s){$(self._sanitizeSelector(a.hash)).html(r);self._cleanup();if(o.cache){$.data(a,'cache.tabs',true);}
+self._trigger('load',null,self._ui(self.anchors[index],self.panels[index]));try{o.ajaxOptions.success(r,s);}
+catch(e){}
+self.element.dequeue("tabs");}}));},abort:function(){this.element.queue([]);this.panels.stop(false,true);if(this.xhr){this.xhr.abort();delete this.xhr;}
+this._cleanup();},url:function(index,url){this.anchors.eq(index).removeData('cache.tabs').data('load.tabs',url);},length:function(){return this.anchors.length;}});$.extend($.ui.tabs,{version:'1.7.2',getter:'length',defaults:{ajaxOptions:null,cache:false,cookie:null,collapsible:false,disabled:[],event:'click',fx:null,idPrefix:'ui-tabs-',panelTemplate:'<div></div>',spinner:'<em>Loading&#8230;</em>',tabTemplate:'<li><a href="#{href}"><span>#{label}</span></a></li>'}});$.extend($.ui.tabs.prototype,{rotation:null,rotate:function(ms,continuing){var self=this,o=this.options;var rotate=self._rotate||(self._rotate=function(e){clearTimeout(self.rotation);self.rotation=setTimeout(function(){var t=o.selected;self.select(++t<self.anchors.length?t:0);},ms);if(e){e.stopPropagation();}});var stop=self._unrotate||(self._unrotate=!continuing?function(e){if(e.clientX){self.rotate(null);}}:function(e){t=o.selected;rotate();});if(ms){this.element.bind('tabsshow',rotate);this.anchors.bind(o.event+'.tabs',stop);rotate();}
+else{clearTimeout(self.rotation);this.element.unbind('tabsshow',rotate);this.anchors.unbind(o.event+'.tabs',stop);delete this._rotate;delete this._unrotate;}}});})(jQuery);
More information about the Mapbender_commits mailing list
