[Mapbender-commits] r4945 - in trunk/mapbender/http: javascripts php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Nov 5 09:14:26 EST 2009
Author: christoph
Date: 2009-11-05 09:14:25 -0500 (Thu, 05 Nov 2009)
New Revision: 4945
   trunk/mapbender/http/javascripts/mod_loadwmc.js
   trunk/mapbender/http/php/mod_loadwmc_server.php
load wmc from file
Modified: trunk/mapbender/http/javascripts/mod_loadwmc.js
--- trunk/mapbender/http/javascripts/mod_loadwmc.js	2009-11-05 13:51:38 UTC (rev 4944)
+++ trunk/mapbender/http/javascripts/mod_loadwmc.js	2009-11-05 14:14:25 UTC (rev 4945)
@@ -239,15 +239,23 @@
 	$("#" + options.id + "_wmcUpload").upload({
 		callback: function (filename, success, message) {
-			prompt((success ? "Success." : "Failed!") + " " + message, filename);
+			if (!success) {
+				new Mb_exception(message);
+				alert(message);
+			executeJavaScript({
+				method: "loadWmcFromFile",
+				parameters: {
+					filename: filename
+				message: "WMC has been loaded successfully."
 	wmcTable = $("#" + options.id + "_wmclist_table").dataTable({
 		"bPaginate": true,
 		"bJQueryUI": true
-	console.log(wmcTable);
 function executeJavaScript (args) {
Modified: trunk/mapbender/http/php/mod_loadwmc_server.php
--- trunk/mapbender/http/php/mod_loadwmc_server.php	2009-11-05 13:51:38 UTC (rev 4944)
+++ trunk/mapbender/http/php/mod_loadwmc_server.php	2009-11-05 14:14:25 UTC (rev 4945)
@@ -73,6 +73,31 @@
 	break;
+	case 'loadWmcFromFile':
+		$serverFilename = $ajaxResponse->getParameter("filename");
+		$wmc = new wmc();
+		$wmcDoc = file_get_contents(TMPDIR . "/" . $serverFilename);
+		if (!$wmcDoc) {
+			$ajaxResponse->setMessage(_mb("WMC could not be loaded."));
+			$ajaxResponse->setSuccess(false);
+		$wmc->createFromXml($wmcDoc);
+		$updatedWMC = $wmc->updateUrlsFromDb();
+        $wmc->createFromXml($updatedWMC);
+        $jsArray = $wmc->toJavaScript();
+		if ($jsArray) {
+			$resultObj["javascript"] = $jsArray;
+			$ajaxResponse->setResult($resultObj);
+			$ajaxResponse->setSuccess(true);
+		else {
+	break;
 	// merges data with WMC and loads it (returns array of JS code)
 	case "mergeWmc":
 		// generate a WMC for the current client state
More information about the Mapbender_commits mailing list
