[Mapbender-commits] r4946 - in trunk/mapbender/http: classes
javascripts
svn_mapbender at osgeo.org
Thu Nov 5 09:41:30 EST 2009
Author: kmq
Date: 2009-11-05 09:41:29 -0500 (Thu, 05 Nov 2009)
New Revision: 4946
trunk/mapbender/http/classes/class_wmc.php
trunk/mapbender/http/javascripts/mod_loadwmc.js
small fixes and users can see all publich WMCs
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php 2009-11-05 14:14:25 UTC (rev 4945)
+++ trunk/mapbender/http/classes/class_wmc.php 2009-11-05 14:41:29 UTC (rev 4946)
@@ -226,10 +226,10 @@
// DATABASE FUNCTIONS
- public function getOtherUsersPublicWmcIds () {
+ public function getOtherUsersPublicWmcIds ($userId) {
$sql = "SELECT wmc_id FROM mb_user_wmc ";
$sql .= "WHERE fkey_user_id <> $1 AND wmc_public = 1 GROUP BY wmc_id";
- $v = array($this->id);
+ $v = array($userId);
$t = array("i");
$res_wmc = db_prep_query($sql, $v, $t);
@@ -246,9 +246,10 @@
// get WMC ids
$wmcIdArray = $user->getWmcByOwner();
- $publicWmcIdArray = $this->getOtherUsersPublicWmcIds();
+ $publicWmcIdArray = $this->getOtherUsersPublicWmcIds($user->id);
$wmcIdArray = array_merge($wmcIdArray, $publicWmcIdArray);
// get WMC data
$v = array();
$t = array();
@@ -275,7 +276,7 @@
$currentResult["title"] = administration::convertIncomingString($row["wmc_title"]);
$currentResult["timestamp"] = date("M d Y H:i:s", $row["wmc_timestamp"]);
$currentResult["timestamp_create"] = date("M d Y H:i:s", $row["wmc_timestamp_create"]);
- $currentResult["public"] = $row["wmc_public"] == 1? true: false;
+ $currentResult["isPublic"] = $row["wmc_public"] == 1? true: false;
$currentResult["disabled"] = (in_array($currentResult["id"], $publicWmcIdArray)) ?
true : false;
array_push($wmcArray, $currentResult);
@@ -491,18 +492,18 @@
- * sets the WMC's publich flag
+ * sets the WMC's public flag
* @param $public boolean wether access should be public
public function setPublic($public)
- $currentUser = new User(Mapbender::session()->get("mb_user_id"));
+ $currentUser = new User(Mapbender::session()->get("mb_user_id"));
if ($currentUser->isPublic()) {
return false;
$wmcId = $this->wmc_Id;
$public = $public ? 1 :0;
- $sql = "UPDATE mb_user_wmc SET wmc_public = $1 WHERE wmc_id = $2 AND fkey_user_id = $2;";
+ $sql = "UPDATE mb_user_wmc SET wmc_public = $1 WHERE wmc_id = $2 AND fkey_user_id = $3;";
$v = array($public,$wmcId, $currentUser->id);
$t = array("i","s","i");
$res = db_prep_query($sql,$v,$t);
Modified: trunk/mapbender/http/javascripts/mod_loadwmc.js
--- trunk/mapbender/http/javascripts/mod_loadwmc.js 2009-11-05 14:14:25 UTC (rev 4945)
+++ trunk/mapbender/http/javascripts/mod_loadwmc.js 2009-11-05 14:41:29 UTC (rev 4946)
@@ -153,6 +153,7 @@
//WMC is Public
var $publicTd = appendBoolTableCell({
isPublic: wmcObj.wmc[i].isPublic,
+ disabled: wmcObj.wmc[i].disabled,
method: "setWMCPublic",
parameters:{
@@ -310,8 +311,9 @@
function appendBoolTableCell (args){
- var checked = args.isPublic == true ? 'checked="checked"':'' ;
- var checkbox = $('<input type="checkbox" '+ checked +' />');
+ var checked = args.isPublic == true ? 'checked="checked" ':'' ;
+ var disabled = args.disabled == true ? 'disabled="disabled" ':'' ;
+ var checkbox = $('<input type="checkbox" '+ checked + disabled + ' />');
checkbox.change(function(){
args.parameters.isPublic = $(this).attr('checked') ? 1 : 0;
args.callback(args);
More information about the Mapbender_commits
