[Mapbender-commits] r4947 -
trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Thu Nov 5 09:47:21 EST 2009
Author: christoph
Date: 2009-11-05 09:47:20 -0500 (Thu, 05 Nov 2009)
New Revision: 4947
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql 2009-11-05 14:41:29 UTC (rev 4946)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql 2009-11-05 14:47:20 UTC (rev 4947)
@@ -520,3 +520,6 @@
-- loadwmc from session is now a php var. The initial WMC is only created when this is set to 1
UPDATE gui_element_vars SET var_type = 'php_var' WHERE fkey_e_id = 'loadwmc' AND var_name = 'loadFromSession';
+-- add jquery ui dialog to gui1
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL ,NULL ,'','','div','../plugins/jq_ui_dialog.js','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.dialog.js','','jq_ui','');
More information about the Mapbender_commits
