[Mapbender-commits] r4954 -
trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Fri Nov 6 05:21:07 EST 2009
Author: christoph
Date: 2009-11-06 05:21:05 -0500 (Fri, 06 Nov 2009)
New Revision: 4954
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql
add overwrite to savewmc in gui1
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql 2009-11-06 07:41:22 UTC (rev 4953)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql 2009-11-06 10:21:05 UTC (rev 4954)
@@ -523,3 +523,6 @@
-- add jquery ui dialog to gui1
INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL ,NULL ,'','','div','../plugins/jq_ui_dialog.js','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.dialog.js','','jq_ui','');
+-- overwrite WMC documents if name and user are identical (0 == old behaviour, 1 == overwrite)
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'savewmc', 'overwrite', '0', '' ,'var');
More information about the Mapbender_commits
