[Mapbender-commits] r4955 - trunk/mapbender/core
svn_mapbender at osgeo.org
Fri Nov 6 10:30:17 EST 2009
Author: christoph
Date: 2009-11-06 10:30:16 -0500 (Fri, 06 Nov 2009)
New Revision: 4955
trunk/mapbender/core/globalSettings.php
Modified: trunk/mapbender/core/globalSettings.php
--- trunk/mapbender/core/globalSettings.php 2009-11-06 10:21:05 UTC (rev 4954)
+++ trunk/mapbender/core/globalSettings.php 2009-11-06 15:30:16 UTC (rev 4955)
@@ -30,7 +30,7 @@
// Add FirePHP for debugging only, supply a global $firephp
-if (defined(LOG_PHP_WITH_FIREPHP) && LOG_PHP_WITH_FIREPHP === "on") {
+if (defined("LOG_PHP_WITH_FIREPHP") && LOG_PHP_WITH_FIREPHP === "on") {
require_once(dirname(__FILE__)."/../http/extensions/FirePHP-0.3/FirePHP.class.php");
$firephp = FirePHP::getInstance(true);
@@ -42,15 +42,9 @@
require_once(dirname(__FILE__)."/../lib/class_Mapbender.php");
-// until we have decided how to implement a public user,
-// use this constant. In Geoportal.rlp.de it was used as ANONYMOUS_USER
-if (!defined('PUBLIC_USER')) define('PUBLIC_USER', "");
// define LC_MESSAGES if unknown (for Windows platforms)
-if (!defined('LC_MESSAGES')) define('LC_MESSAGES', LC_CTYPE);
+if (!defined("LC_MESSAGES")) define("LC_MESSAGES", LC_CTYPE);
// All data Mapbender handles internally are UTF-8
@@ -83,7 +77,14 @@
require_once(dirname(__FILE__)."/../conf/mapbender.conf");
+// until we have decided how to implement a public user,
+// use this constant. In Geoportal.rlp.de it was used as ANONYMOUS_USER
+if (!defined("PUBLIC_USER")) define("PUBLIC_USER", "");
// database wrapper
if(SYS_DBTYPE=="mysql") {
More information about the Mapbender_commits
