[Mapbender-commits] r5024 -
	branches/2.6/resources/db/pgsql/UTF-8/update
    svn_mapbender at osgeo.org
    Mon Nov 23 15:14:13 EST 2009
Author: astrid_emde
Date: 2009-11-23 15:14:12 -0500 (Mon, 23 Nov 2009)
New Revision: 5024
   branches/2.6/resources/db/pgsql/UTF-8/update/update_my_guis.sql
merged with verenas SQLs at trunk update_2.6_to_2.7rc1_pgsql_UTF-8.sql
Modified: branches/2.6/resources/db/pgsql/UTF-8/update/update_my_guis.sql
--- branches/2.6/resources/db/pgsql/UTF-8/update/update_my_guis.sql	2009-11-23 13:09:23 UTC (rev 5023)
+++ branches/2.6/resources/db/pgsql/UTF-8/update/update_my_guis.sql	2009-11-23 20:14:12 UTC (rev 5024)
@@ -1,146 +1,86 @@
+-- mapframe1 set e_mb_mod
 UPDATE gui_element SET e_mb_mod = 'map_obj.js,map.js,wms.js,wfs_obj.js,initWms.php' WHERE e_id = 'mapframe1';
+-- wfs target mapframe1 and overview --## what if gui has no overview?
 UPDATE gui_element SET e_js_file = 'wfs.php', e_target='mapframe1,overview' WHERE e_id = 'wfs';
+-- element wfs
+UPDATE gui_element SET e_mb_mod = '../extensions/wz_jsgraphics.js,geometry.js' WHERE e_id = 'wfs';
+-- update e_attributes for some elements - new definition
 UPDATE gui_element SET e_attributes = '' WHERE e_id = 'forward';
 UPDATE gui_element SET e_attributes = '' WHERE e_id = 'back';
 UPDATE gui_element SET e_attributes = '' WHERE e_id = 'zoomIn1';
 UPDATE gui_element SET e_attributes = '' WHERE e_id = 'zoomOut1';
 UPDATE gui_element SET e_attributes = '' WHERE e_id = 'measure';
+-- delete deprecated elements
 DELETE FROM gui_element WHERE e_id = 'closePolygon';
 DELETE FROM gui_element WHERE e_id = 'rubber';
 DELETE FROM gui_element WHERE e_id = 'getArea';
 DELETE FROM gui_element WHERE e_id = 'rubberExt';
-UPDATE gui_element SET e_element = 'select', e_src = '', e_attributes = '', e_content = '<option value="">undefined</option>
-<option value="EPSG:4326">EPSG:4326</option>
-<option value="EPSG:31466">EPSG:31466</option>
-<option value="EPSG:31467">EPSG:31467</option>
-<option value="EPSG:31468">EPSG:31468</option>
-<option value="EPSG:31469">EPSG:31469</option>', e_closetag = 'select', e_js_file = 'mod_changeEPSG.php' WHERE e_id = 'changeEPSG';
+-- gazetteerWFS - add new elements var where needed (showResultInPopup)
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
+SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'showResultInPopup', '1',
+'if value is 1 search results will be displayed in popup, otherwise in gazetteer div' ,'var' FROM gui_element
+WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN
+(SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'showResultInPopup' AND fkey_e_id = 'gazetteerWFS');
-UPDATE gui_element SET e_element = 'div',
-e_src = '',
-e_attributes = '',
-e_more_styles = 'overflow:hidden;',
-e_content = '',
-e_closetag = 'div',
-e_js_file = 'mod_zoomCoords.php',
---e_target = 'mapframe1,overview',
-e_requires = 'mapframe1' WHERE e_id = 'zoomCoords';
---#new element vars for wfs_gazetteer
---INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
---VALUES('gui', 'gazetteerWFS', 'showResultInPopup', '1', 'if value is 1 search results will be displayed in popup, otherwise in gazetteer div' ,'var');
---VALUES('gui', 'gazetteerWFS', 'wfs_spatial_request_conf_filename', 'wfs_additional_spatial_search.conf', 'location and name of the WFS configuration file for spatialRequest' ,'php_var');
--- Fuer welche GUIs kommt das in Frage?
---  SELECT fkey_gui_id
---    FROM gui_element
---   WHERE e_id = 'gazetteerWFS'
---     AND fkey_gui_id not like 'gui%'
---   ORDER BY fkey_gui_id;
--- Update ueber Subquery
+-- gazetteerWFS - element var wfs_spatial_request_conf_filename for gui element gazetteerWFS
-  SELECT fkey_gui_id, 'gazetteerWFS', 'showResultInPopup', '1', 'if value is 1 search results will be displayed in popup, otherwise in gazetteer div' ,'var'
-    FROM gui_element
-     AND fkey_gui_id not like 'gui%';
+SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'wfs_spatial_request_conf_filename', 'wfs_additional_spatial_search.conf',
+'location and name of the WFS configuration file for spatialRequest' ,'php_var' FROM gui_element
+(SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'wfs_spatial_request_conf_filename' AND fkey_e_id = 'gazetteerWFS');
-  SELECT fkey_gui_id, 'gazetteerWFS', 'wfs_spatial_request_conf_filename', 'wfs_additional_spatial_search.conf', 'location and name of the WFS configuration file for spatialRequest' ,'php_var'
-    FROM gui_element
---#ENDE new element vars for wfs_gazetteer
---#used modules
---add all used modules for gazetteerWFS
---UPDATE gui_element
---   SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/jquery.tablesorter.js'
---   AND fkey_gui_id = 'gui';
--- Warum nicht gui2, die enthält auch 'gazetteerWFS' ???
--- Wirklich auf alle anwenden?
--- Welche GUIs wären betroffen?
---SELECT fkey_gui_id, e_mb_mod FROM gui_element WHERE e_id     = 'gazetteerWFS'   AND fkey_gui_id not IN ('gui','gui1','gui_digitize','gui2');
+-- gazetteerWFS add tablesorter.js
 UPDATE gui_element
-   AND fkey_gui_id not IN ('gui','gui1','gui_digitize','gui2');
---#ENDE used modules
+SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/jquery.tablesorter.js'
+WHERE e_id = 'gazetteerWFS';
--- Hier das Muster für GUI "gui"
--- INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
--- VALUES ('gui', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+-- element var popupcss for gui element body
+SELECT gui_element.fkey_gui_id, 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css'
+FROM gui_element WHERE gui_element.e_id = 'body'
+AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars
+WHERE var_name = 'popupcss' AND fkey_e_id = 'body');
--- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
--- VALUES('gui', 'body', 'tablesortercss', '../css/tablesorter.css', 'file css' ,'file/css');
---SELECT *
---  FROM gui_element_vars
---WHERE  fkey_e_id = 'body'
---  AND var_name   ='popupcss'
---  AND fkey_gui_id IN
---    ( SELECT fkey_gui_id  FROM   gui_gui_category
---      WHERE  fkey_gui_category_id in (3, 4, 5, 6, 7)
--- gesteuert ueber Kategorie
--- Bei (fast) allen schon vorhanden, Löschen, sonst Schlüsselverletzung
-DELETE
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
-   SELECT fkey_gui_id,  'body', 'popupcss', '../css/popup.css', 'file css', 'file/css'
-   FROM   gui_gui_category
-   WHERE  fkey_gui_category_id in (3, 4, 5, 6, 7);
---SELECT *
---  AND var_name   ='tablesortercss'
--- noch keins vorhanden ausser bei gui & Co.
+-- element var tablesortercss for gui element body
-   SELECT fkey_gui_id, 'body', 'tablesortercss', '../css/tablesorter.css', 'file css' ,'file/css'
+SELECT gui_element.fkey_gui_id, 'body', 'tablesortercss', '../css/tablesorter.css', 'file css' ,'file/css'
+WHERE var_name = 'tablesortercss' AND fkey_e_id = 'body');
 --#style in gui_digitize
---add style class to element var text css of element digitize in gui_digitize
+-- add style class to element var text css of element digitize in gui_digitize
 UPDATE gui_element_vars
 SET var_value =
 'digitizeGeometryList {position:absolute; top:50px; left:0px;}
@@ -149,610 +89,190 @@
 .button {height:18px; width:32px;}'
 WHERE fkey_e_id = 'digitize'
   AND var_name  = 'text css';
---#ENDE style in gui_digitize
---#Admin-GUIs
--- eigene Admin-GUI "Benutzerverwaltung" nachtragen
-UPDATE gui_element
-   SET e_attributes = 'onload="init()"'
- WHERE e_id = 'body'
-   AND fkey_gui_id IN ('Benutzerverwaltung');
---#ENDE Admin-GUIs
---#Koordinatensysteme
- UPDATE gui_element
- SET e_element = 'select',
-     e_src = '',
-     e_attributes = '',
-     e_content = '<option value="">undefined</option>
- <option value="EPSG:4326">EPSG:4326</option>
- <option value="EPSG:31466">EPSG:31466</option>
- <option value="EPSG:31467">EPSG:31467</option>
- <option value="EPSG:31468">EPSG:31468</option>
- <option value="EPSG:31469">EPSG:31469</option>',
- e_closetag = 'select',
- e_js_file = 'mod_changeEPSG.php'
- WHERE e_id = 'changeEPSG';
---#ENDE Koordinatensysteme
+-- overview as div
+-- element_var for overview_wms
+-- wms=int from former overview definition and add it to the new element_var (example ../php/mod_mapOV.php?wms=22&sessionID)
+select fkey_gui_id, 'overview' as fkey_e_id, 'overview_wms' as var_name,
+substr(e_src,strpos(e_src,'wms=')+4,strpos(e_src,'&')-strpos(e_src,'wms=')-4) as var_value,
+'wms that shows up as overview' as context,
+'var' as var_type from gui_element where e_id = 'overview'
+AND strpos(e_src,'wms=') > 0;
+-- update overview as a div
+UPDATE gui_element SET e_element = 'div',
+e_src = '',
+e_attributes = '',
+e_more_styles = 'overflow:hidden;',
+e_content = '<div id="overview_maps" style="position:absolute;left:0px;right:0px;"></div>',
+e_closetag = 'div',
+e_js_file = 'ovnf.php',
+e_target = 'mapframe1',
+e_requires = 'mapframe1' WHERE e_id = 'overview';
---#demo splash screen for ....
--- Muster fuer gui1
---VALUES('gui1', 'body', 'use_load_message', 'true', '' ,'php_var');
---VALUES('gui1', 'body', 'includeWhileLoading', '../include/splash.php', '' ,'php_var');
+-- UPDATE treeGDE - div
+-- treeGDE new element_var for treeGDE in body
+-- css nun Teil vom Body
+UPDATE gui_element_vars set
+fkey_e_id ='body',
+var_name = 'treeGDE_css'
+where fkey_e_id = 'treeGDE'
+and var_type = 'file/css';
-   SELECT gui_id, 'body', 'use_load_message', 'true', '' ,'php_var'
-	FROM gui WHERE gui_id not IN ('gui','gui1','gui_digitize','gui2','admin1', 'admin2_de','admin2_en','admin_de_services','admin_en_services')
-	and gui_id not LIKE 'wms_%';
-   SELECT fkey_gui_id, 'body', 'includeWhileLoading', '../include/splash.php', '' ,'php_var'
-   --#Ende Splash
+-- treeGDE - div
+e_pos = 2,
+e_element = 'div',
+e_more_styles = 'visibility:visible;overflow:scroll',
+e_content = '', e_closetag = 'div',
+e_js_file = '../html/mod_treefolderPlain.php',
+e_mb_mod = 'jsTree.js', e_requires = 'mapframe1' WHERE e_id = 'treeGDE';
+-- remove treeGDE-css statement from 'treeGDE' because its handled in 'body' element
+DELETE  from gui_element_vars WHERE fkey_e_id= 'treeGDE' AND var_name='cssfile';
+-- End treeGDE
---#WMS-Container
-UPDATE gui_element
- --AND fkey_gui_id IN (...'wms_germany', '...);
-   AND fkey_gui_id like 'wms at _%'  ESCAPE '@'
-    OR fkey_gui_id like 'WFS at _%'  ESCAPE '@';
---#ENDE WMS-Container
+-- Update ChangeEPSG
+-- Notice: EPSG-Codes are now defined in e_content and not in the file itself
+UPDATE gui_element SET e_element = 'select', e_src = '', e_attributes = '', e_content = '<option value="">undefined</option>
+<option value="EPSG:4326">EPSG:4326</option>
+<option value="EPSG:31466">EPSG:31466</option>
+<option value="EPSG:31467">EPSG:31467</option>
+<option value="EPSG:31468">EPSG:31468</option>
+<option value="EPSG:31469">EPSG:31469</option>', e_closetag = 'select', e_js_file = 'mod_changeEPSG.php'
+WHERE e_id = 'changeEPSG';
---#gui: tab: increase the size of the frames onmouseover
---   SET e_attributes  = 'frameborder = "0" onmouseover="this.style.zIndex=300;this.style.width=350;" onmouseout="this.style.zIndex=2;this.style.width=200"',
---       e_more_styles = 'visibility:hidden; border: 1px solid #a19c8f;'
---WHERE e_id IN ('treeGDE','printPDF','legend','imprint','meetiongPoint','gazetteerWFS')
---  AND fkey_gui_id IN ('gui');  --                            *
+-- zoomCoords - new definition
+UPDATE gui_element SET e_element = 'div', e_src = '',
+e_attributes = '',
+e_js_file = 'mod_zoomCoords.php',
+e_target = 'mapframe1,overview',
+e_requires = 'mapframe1' WHERE e_id = 'zoomCoords';
-UPDATE gui_element
-WHERE e_id IN ('treeGDE', 'legend')
-  ( -- Subquery liefert GUIs aus bestimmten Katagorien
-   SELECT gui_id
+-- splash screen - add splash to all application
+SELECT gui_element.fkey_gui_id, 'body', 'use_load_message', 'true' as var_value,
+'show splash screen while the application is loading' as context ,
+'php_var' as var_type
+FROM gui_element WHERE gui_element.e_id = 'body' AND
+gui_element.fkey_gui_id NOT IN
+(SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'use_load_message' AND fkey_e_id = 'body');
--- set background colour of gazetteer
---SET e_more_styles = 'visibility:hidden; background:#fff; border: 1px solid #a19c8f;'
---WHERE e_id = 'gazetteerWFS' AND fkey_gui_id IN ('gui');
+SELECT gui_element.fkey_gui_id, 'body', 'includeWhileLoading',
+'' as var_value,
+(SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'includeWhileLoading' AND fkey_e_id = 'body');
--- "gazetteerWFS" oben raus genommen, wird hier getrennt behandelt statt nachträglich punktuell korrigiert
-UPDATE gui_element
-   SET e_attributes  = 'frameborder = "0" onmouseover="this.style.zIndex=300;this.style.width=350;" onmouseout="this.style.zIndex=2;this.style.width=280"',
-       e_more_styles = 'visibility:hidden; background:#fff; border: 1px solid #a19c8f;'
-WHERE e_id IN ('gazetteerWFS')
-   SELECT gui_id
+-- gui: tab: increase the size of the frames onmouseover
+UPDATE gui_element SET e_attributes = 'frameborder = "0" onmouseover="this.style.zIndex=300;this.style.width=350;" onmouseout="this.style.zIndex=2;this.style.width=200"',
+e_more_styles = 'visibility:hidden; border: 1px solid #a19c8f;'
+WHERE e_id IN ('treeGDE','printPDF','legend','imprint','meetingPoint','gazetteerWFS')
+AND fkey_gui_id IN ('gui');
+-- ## UPDATE gui_element SET e_more_styles = e_more_styles || ' background-color:#FFFFFF;' WHERE e_id IN ('treeGDE','imprint') AND fkey_gui_id IN ('gui');
--- "MeetingPoint" ist im Original falsch geschrieben.
--- .             .. ist aber sowieso breit genug und braucht gar nicht dynamisch erweitert werden
--- "printPDF" ist ebenfalls breit genug: aus IN-Liste raus genommen
--- 'imprint'  wird hier nicht verwendet: aus IN-Liste raus genommen
---   SET e_more_styles = e_more_styles || ' background-color:#FFFFFF;'
--- WHERE e_id IN ('treeGDE','imprint')
+-- setSpatialRequest
+UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js' WHERE e_id = 'setSpatialRequest';
--- nicht angepasst, weil:
---   Wird unter "tabs wideout" sowieso wieder überschrieben
---##Ende tab: "increase"
---#tabs wideout
--- Bugfix for treegde in gui (tabs wideout)
---   SET e_more_styles='visibility:hidden; background-color:#ffffff;border: 1px solid #a19c8f;overflow:auto;'
--- WHERE fkey_gui_id='gui'
---   AND e_id='treeGDE';
-UPDATE gui_element
- WHERE e_id='treeGDE'
-   SELECT gui_id
---#ENDE tabs wideout
---#gui_treegde - delete entries which are not needed
---DELETE
---FROM gui_treegde
---WHERE fkey_gui_id IN ('gui','gui1','gui2','gui_digitize')
---  AND my_layer_title ='new';
-DELETE FROM gui_treegde
-   (   SELECT gui_id
---#Ende "gui_treegde"
---#module addWMSfromfilteredList_ajax
--- remove module addWMSfromfilteredList_ajax from every standard gui and set it new with new parameters and new element vars
---DELETE FROM gui_element
---WHERE fkey_gui_id = 'gui'   -- Beispiel
---  AND e_id        = 'addWMSfromfilteredList_ajax';
--- Wo kommt das vor?
---   SELECT *
---    WHERE e_id = 'addWMSfromfilteredList_ajax';
--- wieder einfügen
---* Muster (ALT)
---INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
---VALUES('Buende_2',
---'addWMSfromfilteredList_ajax',
---2,1,
---'add a WMS to the running application from a filtered list',
---'Adding WMS from filtered list',
---'img',
---'../img/button_blink_red/add_filtered_list_off.png',
---'onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="WMS hinzufügen aus gefilterter Liste"',
---249,115,24,24,1,
---'mod_addWMSgeneralFunctions.js',
---'treeGDE,mapframe1',
---'loadData',
---'http://mapserver.krz.de/?Oberfl%E4che:Werkzeugleiste:WMS-Buttons');
---* Ende Muster (Alt)
---* Muster (NEU)
---VALUES('gui',
---2,1,
---'img',
---'../img/button_gray/add_filtered_list_off.png',
---'onclick=''var addWmsFromFilteredListPopup = new mb_popup({title:"Add WMS from filtered list",url:"../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID",width:720, height:600,left:20, top:20});addWmsFromFilteredListPopup.show()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',
---490,10,24,24,1,
---'mod_addWMSgeneralFunctions.js,popup.js',
---'loadData',
---'http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
---* Ende Muster (NEU)
--- Zerlegung NEU
---key_gui_id	='gui'
---e_id		='addWMSfromfilteredList_ajax'
---e_pos		=2
---e_public	=1
---e_comment	='add a WMS to the running application from a filtered list'
---e_title	='Adding WMS from filtered list'
---e_element	='img'
---e_src		='../img/button_gray/add_filtered_list_off.png'
---e_attributes	='onclick=''var addWmsFromFilteredListPopup = new mb_popup({title:"Add WMS from filtered list",url:"../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID",width:720, height:600,left:20, top:20});addWmsFromFilteredListPopup.show()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"'
---e_left	=490
---e_top		=10
---e_width	=24
---e_height	=24
---e_z_index	=1
---e_more_styles	=''
---e_content	=''
---e_closetag	=''
---e_js_file	=''
---e_mb_mod	='mod_addWMSgeneralFunctions.js,popup.js'
---e_target	='treeGDE,mapframe1'
---e_requires	='loadData'
---e_url		='http://www.mapbender.org/index.php/Add_WMS_from_filtered_list'
--- Synthese aus alt/neu:
--- Nur zu ändernde Teile in 'gui_element' überschreiben, andere Felder unberührt lassen
-UPDATE gui_element
-  SET  e_attributes ='onclick=''var addWmsFromFilteredListPopup = new mb_popup({title:"Add WMS from filtered list",url:"../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID",width:720, height:600,left:20, top:20});addWmsFromFilteredListPopup.show()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',
-       e_mb_mod     ='mod_addWMSgeneralFunctions.js,popup.js'
-   AND fkey_gui_id IN (SELECT DISTINCT fkey_gui_id FROM gui_gui_category
-                      WHERE fkey_gui_category_id in (3, 4, 5, 6, 7)     );
--- Alte Werte aus 'gui_element_vars' komplett löschen
-DELETE FROM gui_element_vars
-WHERE fkey_e_id = 'addWMSfromfilteredList_ajax'
---*Muster vars (neu)
----1
---VALUES('gui', 'addWMSfromfilteredList_ajax', 'cssfileAddWMS', '../css/addwms.css', '' ,'file/css');
----2
---VALUES('gui', 'addWMSfromfilteredList_ajax', 'capabilitiesInput', '1', 'load wms by capabilities url' ,'var');
----3
---VALUES('gui', 'addWMSfromfilteredList_ajax', 'option_dball', '1', '1 enables option "load all configured wms from db"' ,'var');
----4
---VALUES('gui', 'addWMSfromfilteredList_ajax', 'option_dbgroup', '1', '1 enables option "load configured wms by group"' ,'var');
----5
---VALUES('gui', 'addWMSfromfilteredList_ajax', 'option_dbgui', '1', '1 enables option "load configured wms by gui"' ,'var');
---*Ende vars (neu)
--- Einfügen der Element-Vars für 'addWMSfromfilteredList_ajax' für alle GUIs, die dieses Element besitzen,
--- die aber noch nicht von den mitgelieferten Scripten aktualisiert wurden
---1
+-- element var cssfileAddWMS for gui element addWMSfromfilteredList_ajax
-SELECT fkey_gui_id, 'addWMSfromfilteredList_ajax', 'cssfileAddWMS', '../css/addwms.css', '' ,'file/css'
- WHERE fkey_gui_category_id in (3, 4, 5, 6, 7)   -- GUI Kategorie
-   AND fkey_gui_id          in (
-     SELECT DISTINCT fkey_gui_id
-       FROM gui_element
-      WHERE e_id ='addWMSfromfilteredList_ajax') -- Element vorhanden
+SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'cssfileAddWMS', '../css/addwms.css', '' ,'file/css'
+FROM gui_element WHERE gui_element.e_id = 'addWMSfromfilteredList_ajax' AND
+(SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'cssfileAddWMS' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
---2
+-- element var capabilitiesInput for gui element addWMSfromfilteredList_ajax
-SELECT fkey_gui_id, 'addWMSfromfilteredList_ajax', 'capabilitiesInput', '1', 'load wms by capabilities url' ,'var'
-       FROM gui_element
+SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'capabilitiesInput', '1', 'load wms by capabilities url' ,'var'
+(SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'capabilitiesInput' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
---3
+-- element var option_dball for gui element addWMSfromfilteredList_ajax
-SELECT fkey_gui_id, 'addWMSfromfilteredList_ajax', 'option_dball', '1', '1 enables option "load all configured wms from db"' ,'var'
-       FROM gui_element
+SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'option_dball', '1', '1 enables option "load all configured wms from db"' ,'var'
+FROM gui_element WHERE gui_element.e_id = 'addWMSfromfilteredList_ajax' AND gui_element.fkey_gui_id NOT IN
+WHERE var_name = 'option_dball' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
---4
+-- element var option_dbgroup for gui element addWMSfromfilteredList_ajax
-SELECT fkey_gui_id, 'addWMSfromfilteredList_ajax', 'option_dbgroup', '1', '1 enables option "load configured wms by group"' ,'var'
-       FROM gui_element
+SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'option_dbgroup', '1', '1 enables option "load configured wms by group"' ,'var'
+(SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'option_dbgroup' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
---5
+-- element var option_dbgui for gui element addWMSfromfilteredList_ajax
-SELECT fkey_gui_id, 'addWMSfromfilteredList_ajax', 'option_dbgui', '1', '1 enables option "load configured wms by gui"' ,'var'
-       FROM gui_element
---#Ende module addWMSfromfilteredList_ajax
+SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'option_dbgui', '1', '1 enables option "load configured wms by gui"' ,'var'
+(SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'option_dbgui' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
+-- featureinfoTunnel - element var featureInfoPopupHeight for gui element featureInfoTunnel
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'featureInfoTunnel' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'featureInfoPopupHeight' AND fkey_e_id = 'featureInfoTunnel');
---#popup in featureInfoTunnel
--- set standard element vars for possibility to use popup in featureInfoTunnel; activated for gui_digitize
---VALUES('gui', 'featureInfoTunnel', 'featureInfoLayerPopup', 'false', '' ,'var');
+-- featureinfoTunnel - element var featureInfoPopupWidth for gui element featureInfoTunnel
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'featureInfoTunnel' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'featureInfoPopupWidth' AND fkey_e_id = 'featureInfoTunnel');
---VALUES('gui', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
+-- delete old element_vars for 'addWMSfromfilteredList_ajax' completely
+DELETE FROM gui_element_vars
+WHERE fkey_e_id = 'addWMSfromfilteredList_ajax'
+and var_name NOT IN ('cssfileAddWMS','capabilitiesInput','option_dbgui','option_dball','option_dbgroup');
---VALUES('gui', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
--- Nachsehen. Duplicate Keys
---SELECT *
--- WHERE fkey_e_id = 'featureInfoTunnel'
---   AND var_name IN ('featureInfoLayerPopup', 'featureInfoPopupHeight', 'featureInfoPopupWidth');
-DELETE
- WHERE fkey_gui_id = 'lage_digitize'
-   AND fkey_e_id   = 'featureInfoTunnel'
+-- body add flavicon - element var favicon for gui element body
-SELECT fkey_gui_id, 'featureInfoTunnel', 'featureInfoLayerPopup', 'false', '' ,'var'
-       FROM gui_element
-      WHERE e_id ='featureInfoTunnel') -- Element in GUI vorhanden
-SELECT fkey_gui_id, 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var'
-       FROM gui_element
-SELECT fkey_gui_id, 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var'
-       FROM gui_element
---#ENDE popup in featureInfoTunnel
---#tooltip module
---*Muster-GUIs:
--- tooltip module in gui2 + required gui elements wfs and wfs conf
--- 1
---INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url)
---VALUES ('gui2','tooltip',1,1,'Tooltip demo modul','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','mod_tooltip.php','popup.js,geometry.js,wfsFilter.js','mapframe1','wfs,wfs_conf,featureInfoTunnel,popup','');
--- 2
---VALUES('gui2','wfs',2,1,'wfs request and result handling','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','wfs.php','../extensions/wz_jsgraphics.js,geometry.js','mapframe1,overview','','');
--- 3
---VALUES('gui2', 'wfs', 'displayWfsResultList', '1', '' ,'var');
--- 4
---VALUES('gui2','wfs_conf',2,1,'get all wfs_conf-params','','iframe','../php/mod_wfs.php','frameborder = "0"',1,1,1,1,NULL ,'visibility:hidden','','iframe','','','','','');
--- von dort kann es in andere GUIUs manuell kopiert werden
--- 1
-SELECT fkey_gui_id, 'tooltip',1,1,'Tooltip demo modul','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','mod_tooltip.php','popup.js,geometry.js,wfsFilter.js','mapframe1','wfs,wfs_conf,featureInfoTunnel,popup',''
- WHERE fkey_gui_category_id in (4)
--- 2
-SELECT fkey_gui_id, 'wfs',2,1,'wfs request and result handling','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','wfs.php','../extensions/wz_jsgraphics.js,geometry.js','mapframe1,overview','',''
--- 3
-SELECT fkey_gui_id, 'wfs', 'displayWfsResultList', '1', '' ,'var'
--- 4
-SELECT fkey_gui_id, 'wfs_conf',2,1,'get all wfs_conf-params','','iframe','../php/mod_wfs.php','frameborder = "0"',1,1,1,1,NULL ,'visibility:hidden','','iframe','','','','',''
--- element vars for tooltip
---* Muster-GUIs
---1
---VALUES ('gui2', 'tooltip', 'tooltip_destinationFrame', '', '', 'var');
---2
---VALUES ('gui2', 'tooltip', 'tooltip_noResultArray', E'["Kein Ergebnis.","<body onload=\"javascript:window.close()\">"]', '', 'var');
---3
---VALUES ('gui2', 'tooltip', 'tooltip_styles', '.list_even{font-size:11px;color:red;}.list_uneven{font-size:11px;color:blue;}', '', 'var');
---4
---VALUES ('gui2', 'tooltip', 'tooltip_styles_detail', '.list_even{font-size:11px;color:green;}.list_uneven{font-size:11px;color:blue;}', '', 'var');
---5
---VALUES ('gui2', 'tooltip', 'tooltip_timeDelay', '1000', '', 'var');
---6
---VALUES ('gui2', 'tooltip', 'wfs_conf_filename', 'wfs_default.conf', '', 'php_var');
---7
---VALUES ('gui2', 'tooltip', 'tooltip_width', '270', '', 'var');
---8
---VALUES ('gui2', 'tooltip', 'tooltip_height', '200', '', 'var');
---1
-SELECT fkey_gui_id, 'tooltip', 'tooltip_destinationFrame', '', '', 'var'
- WHERE fkey_gui_category_id in (4);
---2
-SELECT fkey_gui_id, 'tooltip', 'tooltip_noResultArray', E'["Kein Ergebnis.","<body onload=\'javascript:window.close()\'>"]', '', 'var'
---3
-SELECT fkey_gui_id, 'tooltip', 'tooltip_styles', '.list_even{font-size:11px;color:red;}.list_uneven{font-size:11px;color:blue;}', '', 'var'
---4
-SELECT fkey_gui_id, 'tooltip', 'tooltip_styles_detail', '.list_even{font-size:11px;color:green;}.list_uneven{font-size:11px;color:blue;}', '', 'var'
---5
-SELECT fkey_gui_id, 'tooltip', 'tooltip_timeDelay', '1000', '', 'var'
---6
-SELECT fkey_gui_id, 'tooltip', 'wfs_conf_filename', 'wfs_default.conf', '', 'php_var'
---7
-SELECT fkey_gui_id, 'tooltip', 'tooltip_width', '350', '', 'var' -- Weite angepasst
---8
-SELECT fkey_gui_id, 'tooltip', 'tooltip_height', '280', '', 'var' -- Hoehe angepasst
--- new element vars for module tooltip to control whether user likes to have wfs getFeature request and/or whether user likes to have wms getfeatureInfo requests
---VALUES ('gui2', 'tooltip', 'tooltip_disableWfs', '0', 'disable WFS getFeature Request', 'var');
---VALUES ('gui2', 'tooltip', 'tooltip_disableWms', '1', 'disable WMS getFeatureInfo Request', 'var');
--- Tool-Tipp: WMS Ja, WFS Nein
-SELECT fkey_gui_id, 'tooltip', 'tooltip_disableWfs', '1', 'disable WFS getFeature Request', 'var'
-SELECT fkey_gui_id, 'tooltip', 'tooltip_disableWms', '0', 'disable WMS getFeatureInfo Request', 'var'
--- auch auf andere GUIs anwenden?  _2  _3 ?
---       Nein!
--- weil ...
---  Probleme mit dem ToolTipp:
---  - Pfad vom Template zum .css passt nicht (relativ zum UMN-Home)
---  - Umlaute falsch (Codes des Mapbender muss Code der Daten sein)
--- ToDo:
---  - Erst alle Datenbanken umstellen auf UTF8 (wie Mapbender)
---  - in allen UMN-Templates die .css mit kompletten Pfaden verknüpfen.
--- Das Templates würde man für ToolTip anders aufbauen als für einen neuen Rahmen.
---#ENDE tooltip module
---#treeGDE-css statement
---remove treeGDE-css statement from 'treeGDE' because its handled in 'body' element
---DELETE  from gui_element_vars
---WHERE fkey_gui_id IN ('gui','gui2','gui1','gui_digitize')    -- mitgelieferte
---  AND fkey_e_id = 'treeGDE'
---  AND var_name  ='cssfile';
--- Betroffen sind ...  134 GUIs
---SELECT *
---FROM  gui_element_vars
---WHERE fkey_e_id = 'treeGDE'
-DELETE
---#ENDE treeGDE-css statement
---#new language fr, es pt
-UPDATE gui_element_vars
-   SET var_value = 'de,en,bg,gr,nl,hu,it,fr,es,pt'
- WHERE fkey_e_id = 'switchLocale_noreload';
---#ENDE new language
---#switchWMS
--- insert statement for switchWMS in template Guis was missing.
--- http://trac.osgeo.org/mapbender/ticket/472
---VALUES('gui', 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var');
-SELECT fkey_gui_id, 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var'
-       FROM gui_element
-      WHERE e_id ='treeGDE') -- Element in GUI vorhanden
--- http://www.mapbender.org/Switchwms#DE
---#ENDE switchWMS
---#Favicon
--- enable favicon per gui using element_var
--- http://trac.osgeo.org/mapbender/ticket/514
---VALUES('gui', 'body', 'favicon', '../img/favicon.png', 'favicon' ,'php_var');
---#ENDE Favicon
---#printPDF Focus
--- Button - kommt das vor?
---SELECT *
--- WHERE e_id = 'printPDF'
--- --AND e_element = 'img';
-UPDATE gui_element
-   SET e_attributes = 'onclick=\'printWindow = window.open("../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF_b.conf","printWin","width=260, height=380, resizable=yes ");printWindow.focus();\'  onmouseover=\'this.src = this.src.replace(/_off/,"_over");\'  onmouseout=\'this.src = this.src.replace(/_over/, "_off");\''
- WHERE fkey_gui_id  = 'gui1'
-   AND e_id         = 'printPDF'
-   AND e_element    = 'img' ;
---#ENDE Focus
+SELECT gui_element.fkey_gui_id, 'body', 'favicon', '../img/favicon.png', 'favicon' ,'php_var' FROM gui_element
+WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id NOT IN
+(SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'favicon' AND fkey_e_id = 'body');
More information about the Mapbender_commits
