[Mapbender-commits] r5025 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Tue Nov 24 05:00:33 EST 2009
Author: verenadiewald
Date: 2009-11-24 05:00:33 -0500 (Tue, 24 Nov 2009)
New Revision: 5025
trunk/mapbender/http/php/mod_customTree_server.php
check if wms exists still in gui
Modified: trunk/mapbender/http/php/mod_customTree_server.php
--- trunk/mapbender/http/php/mod_customTree_server.php 2009-11-23 20:14:12 UTC (rev 5024)
+++ trunk/mapbender/http/php/mod_customTree_server.php 2009-11-24 10:00:33 UTC (rev 5025)
@@ -2,6 +2,7 @@
require_once dirname(__FILE__) . "/../classes/class_json.php";
require_once dirname(__FILE__) . "/../classes/class_user.php";
+require_once dirname(__FILE__) . "/../classes/class_administration.php";
* encodes and delivers the data
@@ -115,18 +116,27 @@
$res = db_prep_query($sql,$v,$t);
$nodeArray = array();
+ //check if wms exists in gui
+ $n = new administration();
+ $applicationArray = array($applicationId);
+ $mywms = $n->getWmsByOwnGuis($applicationArray);
while ($row = db_fetch_array($res)) {
$wmsIdArray = explode(",", $row["wms_id"]);
$wmsArray = array();
foreach ($wmsIdArray as $wmsId) {
- if (is_numeric($wmsId)) {
- $sqlWms = "SELECT wms_title FROM wms WHERE wms_id = $1";
- $vWms = array($wmsId);
- $tWms = array("i");
- $resWms = db_prep_query($sqlWms, $vWms, $tWms);
- $rowWms = db_fetch_array($resWms);
- $wmsArray[$wmsId] = $rowWms[0];
+ if (in_array($wmsId, $mywms)) {
+ if (is_numeric($wmsId)) {
+ $sqlWms = "SELECT wms_title FROM wms WHERE wms_id = $1";
+ $vWms = array($wmsId);
+ $tWms = array("i");
+ $resWms = db_prep_query($sqlWms, $vWms, $tWms);
+ $rowWms = db_fetch_array($resWms);
+ $wmsArray[$wmsId] = $rowWms[0];
$currentNode = array(
More information about the Mapbender_commits
