[Mapbender-commits] r4864 - branches/2.6/http/javascripts
svn_mapbender at osgeo.org
Tue Oct 27 09:33:48 EDT 2009
Author: christoph
Date: 2009-10-27 09:33:48 -0400 (Tue, 27 Oct 2009)
New Revision: 4864
branches/2.6/http/javascripts/mod_poi.php
Modified: branches/2.6/http/javascripts/mod_poi.php
--- branches/2.6/http/javascripts/mod_poi.php 2009-10-25 22:23:24 UTC (rev 4863)
+++ branches/2.6/http/javascripts/mod_poi.php 2009-10-27 13:33:48 UTC (rev 4864)
@@ -88,14 +88,45 @@
#$language = parse_ini_file("../language/".$lingo.".txt");
echo "<script type='text/javascript'>";
-echo "var conffile = '".$_REQUEST["conf_file"]."';";
-echo "var lingo = '".$_REQUEST["lingo"]."';";
-echo "var backlink = '".$_REQUEST["backlink"]."';";
+$queryString = $_REQUEST["search"];
+if (!preg_match("/^[\*a-zA-Z0-9_-\s]*$/", $queryString)) {
+ $errorMessage = _mb("Invalid search term");
+ $e = new mb_exception($errorMessage);
+ die;
+$backlink = $_REQUEST["backlink"];
+if ($backlink !== "parent") {
+ $backlink = false;
+echo "var backlink = '".$backlink."';";
$lingo = $_REQUEST["lingo"];
+if (!preg_match("/^[a-zA-Z]+$/", $lingo)) {
+ $errorMessage = _mb("Invalid language") . ": " . $lingo;
+ die;
+echo "var lingo = '".$lingo."';";
$title = "layername_".$lingo;
-require_once(dirname(__FILE__) . "/../../conf/".$_REQUEST["conf_file"]);
+$confFile = basename($_REQUEST["conf_file"]);
+if (!preg_match("/^[a-zA-Z0-9_-]+(\.[a-zA-Z0-9]+)$/", $confFile) ||
+ !file_exists(dirname(__FILE__) . "/../../conf/".$confFile)) {
+ $errorMessage = _mb("Invalid configuration file") . ": " . $confFile;
+ die;
+echo "var conffile = '".$confFile."';";
+require_once(dirname(__FILE__) . "/../../conf/".$confFile);
echo "</script>";
<script type="text/javascript">
@@ -188,7 +219,7 @@
<body leftmargin="2" topmargin="0" bgcolor="#ffffff">
<?php
-if(!isset($_REQUEST["search"]) || $_REQUEST["search"] == ""){
+if(!isset($queryString) || $queryString == ""){
echo "<form name='form1' target='result' onsubmit='return validate();'>";
echo "Suchen: <input class='textfield' name='search' type='text'> ";
echo "<input class='sbutton' type='submit' name='send' value='ok'>";
@@ -196,8 +227,8 @@
echo "</form>";
else{
- if(preg_match("/\*/",$_REQUEST["search"])){
- $search = trim(preg_replace("/\*/i","", $_REQUEST["search"]));
+ if(preg_match("/\*/",$queryString)){
+ $search = trim(preg_replace("/\*/i","", $queryString));
$con = pg_connect ($con_string) or die ("Error while connecting database $dbname");
@@ -213,7 +244,7 @@
$md_fileidentifier[$cnt] = pg_result($res,$cnt,"md_fileidentifier"); # Layername
$layername[$cnt] = pg_result($res,$cnt,"md_fileidentifier"); # Layername in der Mapdatei
$result_title[$cnt] = pg_result($res,$cnt,"\"".$title."\""); # layer_deutsch Ergebnisname
- $search_columns[$cnt] = pg_result($res,$cnt,"search_columns"); # Suchspalten, Trennung �ber ,
+ $search_columns[$cnt] = pg_result($res,$cnt,"search_columns"); # Suchspalten, Trennung über ,
$search_result[$cnt] = pg_result($res,$cnt,"search_result"); # Ergebnisspalte
$search_keywords[$cnt] = pg_result($res,$cnt,"search_keywords"); # Ergebnisspalte
$wms_title[$cnt] = pg_result($res,$cnt,"wms_title"); # WMS tile
@@ -223,7 +254,7 @@
$array_search_keywords = explode(",", $search_keywords[$cnt]);
$all[$cnt] = false;
for ($p=0 ; $p<count($array_search_keywords);$p++){
- $hit = preg_match("/".$_REQUEST["search"]."/i",$array_search_keywords[$p]);
+ $hit = preg_match("/".$queryString."/i",$array_search_keywords[$p]);
if ($hit >0){
$all[$cnt] = true;
@@ -270,7 +301,7 @@
$field_has_parent = true;
$sql1 .= pg_field_name($res,$j) ." ILIKE ";
- $sql1 .= "'%".$_REQUEST["search"]."%'";
+ $sql1 .= "'%".$queryString."%'";
$field_has_parent = false;
@@ -291,7 +322,7 @@
echo "<div class='header'>".$result_title[$i]. "</div>";
- if($_REQUEST["backlink"]=='parent'){
+ if($backlink=='parent'){
echo "<nobr><a href='javascript:hideHighlight();parent.parent.mb_repaintScale(\"mapframe1\"," .pg_result($res1,$cnt,"x"). ",".pg_result($res1,$cnt,"y"). ",$scale);'";
else{
More information about the Mapbender_commits
