[Mapbender-commits] r4865 - in branches/2.6/http: javascripts php
svn_mapbender at osgeo.org
Tue Oct 27 09:34:27 EDT 2009
Author: christoph
Date: 2009-10-27 09:34:27 -0400 (Tue, 27 Oct 2009)
New Revision: 4865
branches/2.6/http/javascripts/wms.js
branches/2.6/http/php/mod_createJSLayerObjFromXML.php
branches/2.6/http/php/mod_createJSObjFromDBByWMS.php
branches/2.6/http/php/mod_createJSObjFromXML.php
Modified: branches/2.6/http/javascripts/wms.js
--- branches/2.6/http/javascripts/wms.js 2009-10-27 13:33:48 UTC (rev 4864)
+++ branches/2.6/http/javascripts/wms.js 2009-10-27 13:34:27 UTC (rev 4865)
@@ -115,6 +115,7 @@
this.wms_id = wms_id;
this.wms_version = wms_version;
this.wms_title = wms_title;
+ this.wms_currentTitle = wms_title;
this.wms_abstract = wms_abstract;
this.wms_getmap = wms_getmap;
this.wms_getfeatureinfo = wms_getfeatureinfo;
@@ -736,6 +737,7 @@
this.layer_parent = layer_parent;
this.layer_name = layer_name;
this.layer_title = layer_title;
+ this.layer_currentTitle = layer_title;
this.layer_dataurl_href = layer_dataurl_href;
this.layer_pos = layer_pos;
this.layer_queryable = layer_queryable;
Modified: branches/2.6/http/php/mod_createJSLayerObjFromXML.php
--- branches/2.6/http/php/mod_createJSLayerObjFromXML.php 2009-10-27 13:33:48 UTC (rev 4864)
+++ branches/2.6/http/php/mod_createJSLayerObjFromXML.php 2009-10-27 13:34:27 UTC (rev 4865)
@@ -19,28 +19,59 @@
require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
require_once(dirname(__FILE__)."/../classes/class_wms.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+$capabilitiesURL = $_REQUEST['caps'];
+$layerName = $_REQUEST['layerName'];
+$noHtml = intval($_GET["noHtml"]);
+$output = "";
+$charset = CHARSET;
+$mywms = new wms();
+$mywms->createObjFromXML($capabilitiesURL);
+$errorMessage = _mb("Error: The Capabilities Document could not be accessed. " .
+ "Please check whether the server is responding and accessible to " .
+ "Mapbender.");
+if (!$mywms->wms_status) {
+ $output .= "try {" .
+ "Mapbender.Modules.dialogManager.openDialog({" .
+ "content: '" . $errorMessage . "<br><br><b>" . $capabilitiesURL .
+ "', modal: false, effectShow: 'puff'});" .
+ "} catch (e) {" .
+ "prompt('" . $errorMessage . "', '" . $capabilitiesURL . "');" .
+else {
+ $output .= $mywms->createJsLayerObjFromWMS("TRUE", $layerName);
+$js = administration::convertOutgoingString($output);
+unset($output);
+if ($noHtml) {
+ echo $js;
+else {
+ $js .= "parent.mod_addWMS_refresh();";
+ echo <<<HTML
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
+<title>Load WMS</title>
<meta http-equiv="cache-control" content="no-cache">
<meta http-equiv="pragma" content="no-cache">
<meta http-equiv="expires" content="0">
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>Load WMS with one layer</title>
-<?php
-echo "<script type='text/javascript'>";
-$mywms = new wms();
-$mywms->createObjFromXML(html_entity_decode($_REQUEST['caps']));
-if(!$mywms->wms_status){ echo "alert('Error: The Capabilities Document " . html_entity_decode($_REQUEST['caps']) . " could not be accessed. Please check whether the server is responding and accessible to Mapbender.'); </script>"; die; }
-$mywms->createJsLayerObjFromWMS("TRUE", $_REQUEST['layer_name']);
-echo "parent.mod_addWMS_refresh();";
-echo "</script>";
+<meta http-equiv="Content-Type" content="text/html; charset='$charset'">
+<script type='text/javascript'>
+$js
+</script>
</head>
-<body bgcolor='#ffffff'>
+<body>
+</body>
+</html>
+HTML;
-</body>
-</html>
\ No newline at end of file
Modified: branches/2.6/http/php/mod_createJSObjFromDBByWMS.php
--- branches/2.6/http/php/mod_createJSObjFromDBByWMS.php 2009-10-27 13:33:48 UTC (rev 4864)
+++ branches/2.6/http/php/mod_createJSObjFromDBByWMS.php 2009-10-27 13:34:27 UTC (rev 4865)
@@ -22,19 +22,11 @@
$wms_id = $_GET["wms_id"];
+$gui_id = $_GET["gui_id"];
$user_id = $_SESSION["mb_user_id"];
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<meta http-equiv="Content-Type" content="text/html; charset='<?php echo CHARSET;?>'">
-<script language="JavaScript" type="text/javascript">
-<?php
+$js = "";
// check if user is allowed to access this wms
$admin = new administration();
if ($admin->getWmsPermission($wms_id, $user_id)) {
@@ -46,16 +38,38 @@
$mywms->createObjFromDBNoGui($wms_id);
$output = $mywms->createJsObjFromWMS_(true);
- echo administration::convertOutgoingString($output);
+ $js .= administration::convertOutgoingString($output);
unset($output);
- echo "parent.mod_addWMS_refresh();";
else {
$e = new mb_exception("You are not allowed to access this WMS (WMS ID " . $wms_id . ").");
+if ($noHtml) {
+ echo $js;
+else {
+ $charset = CHARSET;
+ echo <<<HTML
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<title>Load WMS with one layer</title>
+<script language="JavaScript" type="text/javascript">
+$js
</script>
</head>
</body>
</html>
+HTML;
Modified: branches/2.6/http/php/mod_createJSObjFromXML.php
--- branches/2.6/http/php/mod_createJSObjFromXML.php 2009-10-27 13:33:48 UTC (rev 4864)
+++ branches/2.6/http/php/mod_createJSObjFromXML.php 2009-10-27 13:34:27 UTC (rev 4865)
@@ -21,8 +21,41 @@
-$capabilitiesURL = html_entity_decode($_REQUEST['caps']);
+$output = "";
+ "Mapbender.");
+ "} catch (e) {" .
+else {
+ $output .= $mywms->createJsObjFromWMS_(true);
+unset($output);
+if ($noHtml) {
+ echo $js;
+else {
+ echo <<<HTML
<html>
<head>
@@ -30,26 +63,14 @@
-<?php
-$mywms->createObjFromXML($capabilitiesURL);
-$errorMessage = "Error: The Capabilities Document could not be accessed. Please check whether the server is responding and accessible to Mapbender.";
-if (!$mywms->wms_status) {
- echo "prompt('" . $errorMessage . "', '" . $capabilitiesURL . "');";
- die;
-$output = $mywms->createJsObjFromWMS_(true);
-echo administration::convertOutgoingString($output);
-unset($output);
-parent.mod_addWMS_refresh();
+$js
</script>
</head>
+<body>
</body>
</html>
+HTML;
More information about the Mapbender_commits
