[Mapbender-commits] r4586 - in trunk/mapbender: . conf http/classes http/php http_auth http_auth/http owsproxy/http owsproxy/http/classes resources/db/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Sep 2 08:59:49 EDT 2009
Author: christoph
Date: 2009-09-02 08:59:49 -0400 (Wed, 02 Sep 2009)
New Revision: 4586
Added:
   trunk/mapbender/http_auth/
   trunk/mapbender/http_auth/http/
   trunk/mapbender/http_auth/http/index.php
   trunk/mapbender/conf/mapbender.conf-dist
   trunk/mapbender/http/classes/class_administration.php
   trunk/mapbender/http/classes/class_connector.php
   trunk/mapbender/http/classes/class_wms.php
   trunk/mapbender/http/php/mod_layerMetadata.php
   trunk/mapbender/http/php/mod_loadCapabilities.php
   trunk/mapbender/http/php/mod_loadwms.php
   trunk/mapbender/http/php/mod_owsproxy_conf.php
   trunk/mapbender/owsproxy/http/classes/class_QueryHandler.php
   trunk/mapbender/owsproxy/http/index.php
   trunk/mapbender/resources/db/update/update_2.7.sql
http://trac.osgeo.org/mapbender/ticket/527
Modified: trunk/mapbender/conf/mapbender.conf-dist
--- trunk/mapbender/conf/mapbender.conf-dist	2009-09-01 13:49:30 UTC (rev 4585)
+++ trunk/mapbender/conf/mapbender.conf-dist	2009-09-02 12:59:49 UTC (rev 4586)
@@ -80,6 +80,15 @@
 define("OWSPROXY", "http://<ip or name>/owsproxy");
+# Definitions for HTTP Authentication
+define('REALM', 'mapbender_registry');
+define('NONCEKEY', 'mapbender');
+$nonceLife = 300;
+define('HTTP_AUTH_PROXY',"https://".$_SERVER['HTTP_HOST']."/http_auth"); //Problem - behind a rewrite rule - define it hardcoded?
 # type of server-connection
 # curl, socket, http
@@ -88,10 +97,11 @@
 define("CONNECTION", "http");
 #define("CONNECTION", "socket");
-define("CONNECTION_PROXY", "<ip>");
-define("CONNECTION_PORT", "<port>");
-define("CONNECTION_USER", "<user>");
-define("CONNECTION_PASSWORD", "<password>");
+define("CONNECTION_PROXY", ""); // ip
+define("CONNECTION_PORT", ""); // port
+define("CONNECTION_USER", ""); // user
+define("CONNECTION_PASSWORD", ""); // password
+define("CONNECTION_USERAGENT", "Mapbender");
 # HOSTs not for Proxy (curl)
Modified: trunk/mapbender/http/classes/class_administration.php
--- trunk/mapbender/http/classes/class_administration.php	2009-09-01 13:49:30 UTC (rev 4585)
+++ trunk/mapbender/http/classes/class_administration.php	2009-09-02 12:59:49 UTC (rev 4586)
@@ -1037,7 +1037,20 @@
+	 * unset the proxy definitions and logging/pricing for the owned wms proxy list
+	 * @param string the wms-list
+   	function unsetWmsProxy($wms_list){
+   		$sql = "UPDATE wms set wms_owsproxy='', wms_pricevolume=0,wms_proxylog=0  WHERE  wms_id IN ($1)";
+   		$t = array("s");
+		$v = array($wms_list);
+   		$res = db_prep_query($sql,$v,$t);
 	 * log wms getmap proxy urls to db
@@ -1124,6 +1137,49 @@
    		return $newOwsString;
+	 * get the authentication info out of wms table
+	 * @param integer the wms-id
+	 * @return array auth - 'username', 'password', 'auth_type' if not set, return false
+   	function getAuthInfoOfWMS($wms_id){
+   		$sql = "SELECT wms_username, wms_password, wms_auth_type from wms WHERE  wms_id = $1 ";
+   		$t = array("i");
+		$v = array($wms_id);
+		if($row = db_fetch_array($res)){
+   			$auth['username'] = $row["wms_username"];
+			$auth['password'] = $row["wms_password"];
+			$auth['auth_type'] = $row["wms_auth_type"];
+			return $auth;
+   		else{
+   			return false;
+	 * get the wms_id info out of wms table when wms_owsproxy is given
+	 * @param integer the owsproxy string
+	 * @return wms_id - if not set, return false
+   	function getWmsIdFromOwsproxyString($owsproxy){
+   		$sql = "SELECT wms_id from wms WHERE  wms_owsproxy = $1 ";
+   		$t = array("s");
+		$v = array($owsproxy);
+			return $row["wms_id"];
+   		else{
+   			return false;
    	function checkURL($url){
 		$pos_qm = strpos($url,"?");
 		if($pos_qm > 0 && $pos_qm < (mb_strlen($url)-1) && mb_substr($url,(mb_strlen($url)-1)) != "&"){
Modified: trunk/mapbender/http/classes/class_connector.php
--- trunk/mapbender/http/classes/class_connector.php	2009-09-01 13:49:30 UTC (rev 4585)
+++ trunk/mapbender/http/classes/class_connector.php	2009-09-02 12:59:49 UTC (rev 4586)
@@ -42,8 +42,17 @@
 		$this->set("connectionType", CONNECTION);
 		if (func_num_args() == 1) {
 			$url = func_get_arg(0);
-			$this->load($url);
+			if ($url) {
+				$this->load($url);
+		else if (func_num_args() == 2) {
+       		$auth = func_get_arg(1);
+			$url = func_get_arg(0);
+			if ($url) {
+				$this->load($url,$auth);
@@ -67,7 +76,15 @@
 				else {
 				    $e = new mb_notice("CURL host:".$host);
-					$this->file = $this->getCURL($url);
+					if (func_num_args() == 2) {
+						if (isset($auth)) {
+							$this->file = $this->getCURL($url,$auth);
+					else {
+						$this->file = $this->getCURL($url);
 				break;
 			case "http":
@@ -155,17 +172,46 @@
 	private function getCURL($url){
+		$url=Str_replace(" ","+",$url); //to have no problems with image/png; mode=24bit!
+		$url=str_replace(";","%3B",$url);
+		} //auth should be an array of ['username', 'realm', 'password', 'auth_type'] - or false - problem would be, that these are stored without hashing them!
 		$ch = curl_init ($url);
 //		curl_setopt($ch, CURLOPT_BINARYTRANSFER, 1);
 		curl_setopt($ch, CURLOPT_FOLLOWLOCATION, 1);
+		//allow https connections and handle certificates quite simply ;-)
+		curl_setopt($ch,CURLOPT_SSL_VERIFYHOST,0);
+		curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, 0);
 		if(CONNECTION_PROXY != ""){
 			curl_setopt($ch, CURLOPT_PROXY,CONNECTION_PROXY.":".CONNECTION_PORT);
 		if(CONNECTION_PASSWORD != ""){
 			curl_setopt ($ch, CURLOPT_PROXYUSERPWD, CONNECTION_USER.':'.CONNECTION_PASSWORD);
+		//TODO maybe allow basic authentication for client, but this will store the passwords in plain text
+		//TODO: store the  passwords as digest hash. Therefor we have to handle the realm which is defined in the 401 header and return it back to the scripts like mod_loadwms.php to store the digest into the database - problem: curl cannot handle digest connection without clear username and password - we have to send our own headers
+		if(isset($auth) && $auth != false) {
+			curl_setopt($ch, CURLOPT_USERPWD, $auth['username'].':'.$auth['password']);
+			if ($auth['auth_type'] == 'digest') {
+				curl_setopt($ch, CURLOPT_HTTPAUTH, CURLAUTH_DIGEST);
+			if ($auth['auth_type'] == 'basic') {
+				curl_setopt($ch, CURLOPT_HTTPAUTH, CURLAUTH_BASIC);
 		curl_setopt ($ch, CURLOPT_RETURNTRANSFER, 1);
+		$useragent=CONNECTION_USERAGENT;
+		$e = new mb_exception("connector: CURL connect to: ".$url);
+		curl_setopt ($ch,CURLOPT_USERAGENT,$useragent);
 		$file = curl_exec ($ch);
+		//handle http authentication
+		$info = curl_getinfo($ch);
+		if ($info['http_code'] == '401') {
+			curl_close ($ch);
+			return $info['http_code'];
 		curl_close ($ch);
 		return $file;
Modified: trunk/mapbender/http/classes/class_wms.php
--- trunk/mapbender/http/classes/class_wms.php	2009-09-01 13:49:30 UTC (rev 4585)
+++ trunk/mapbender/http/classes/class_wms.php	2009-09-02 12:59:49 UTC (rev 4586)
@@ -242,10 +242,17 @@
 	function createObjFromXML($url){
-		$x = new connector($url);
+		if (func_num_args() == 2) { //new for HTTP Authentication
+			$x = new connector($url,$auth);
+		else {
+			$x = new connector($url);
 		$data = $x->file;
+		if ($data=='401') {
+			echo "<br>HTTP Error:<b>".$data." - Authorization required. This seems to be a service which needs HTTP Authentication!</b><br>";
 		if(!$data){
 			$this->wms_status = false;
 			return false;
@@ -726,6 +733,7 @@
 			if($this->objLayer[$i]->layer_name == ""){
 				$this->objLayer[$i]->layer_name = $this->objLayer[$i]->layer_title;
+#$this->objLayer[$i]->layer_name = "";
 			if($this->objLayer[$i]->layer_minscale == ""){
 				$this->objLayer[$i]->layer_minscale = 0;
@@ -1154,6 +1162,17 @@
 	function writeObjInDB($gui_id){
 		global $con;
+			$username = $auth['username'];
+			$password = $auth['password'];
+			$authType = $auth['auth_type'];
+		else {
+			$username = '';
+			$password = '';
+			$authType = '';
 		$admin = new administration();
 		$this->checkObj();
@@ -1164,24 +1183,30 @@
 		$sql.= "wms_getfeatureinfo, wms_getlegendurl, wms_getcapabilities_doc, wms_upload_url, fees, ";
 		$sql .= "accessconstraints, contactperson, contactposition, contactorganization, address, city, ";
 		$sql .= "stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, ";
-		$sql .= "wms_owner,wms_timestamp, ";
+		$sql .= "wms_owner,wms_timestamp,wms_username,wms_password,wms_auth_type,";
 		$sql .= "wms_supportsld, wms_userlayer, wms_userstyle, wms_remotewfs) ";
-		$sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$15,$16,$17,$18,$19,$20,$21,$22,$23,$24,$25,$26,$27,$28)";
+		$sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$15,$16,$17,$18,$19,$20,$21,$22,$23,$24,$25,$26,$27,$28,$29,$30,$31)";
 		$v = array($this->wms_version,$this->wms_title,$this->wms_abstract,$this->wms_getcapabilities,
 			$this->wms_getmap,$this->wms_getfeatureinfo,$this->wms_getlegendurl,$admin->char_encode($this->wms_getcapabilities_doc),
 			$this->wms_upload_url,$this->fees,$this->accessconstraints,$this->contactperson,$this->contactposition,
 			$this->contactorganization,$this->address,$this->city,$this->stateorprovince,$this->postcode,$this->country,
 			$this->contactvoicetelephone,$this->contactfacsimiletelephone,$this->contactelectronicmailaddress,
-			Mapbender::session()->get('mb_user_id'),strtotime("now"),
+			Mapbender::session()->get('mb_user_id'),strtotime("now"),$username,$password,$authType,
 			$this->wms_supportsld,$this->wms_userlayer,$this->wms_userstyle,$this->wms_remotewfs );
-		$t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','i','i','s','s','s','s');
+		$t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','i','i','s','s','s','s','s','s','s');
 		if(!$res){
 			db_rollback();
 		$myWMS = db_insert_id($con,'wms', 'wms_id');
+		if ($authType != '') { //some authentication is needed!
+			$admin = new administration();
+			echo "WMS ID: ".$myWMS;
+			$admin->setWMSOWSstring($myWMS, 1);
 		# TABLE layer and gui_layer
 		for($i=0; $i<count($this->objLayer); $i++){
Modified: trunk/mapbender/http/php/mod_layerMetadata.php
--- trunk/mapbender/http/php/mod_layerMetadata.php	2009-09-01 13:49:30 UTC (rev 4585)
+++ trunk/mapbender/http/php/mod_layerMetadata.php	2009-09-02 12:59:49 UTC (rev 4586)
@@ -101,7 +101,15 @@
 	$layer = array();
 	$row = db_fetch_array($res);
 	$layer_id = $row['layer_id'];
+	$layer_name = $row['layer_name'];
+if($row['wms_owsproxy']!='') {
+	$secured=true;
+else {
+	$secured=false;
 	$sql_dep = "SELECT mb_group_name FROM mb_group AS a, mb_user AS b, mb_user_mb_group AS c WHERE b.mb_user_id = $1  AND b.mb_user_id = c.fkey_mb_user_id AND c.fkey_mb_group_id = a.mb_group_id AND b.mb_user_department = a.mb_group_description LIMIT 1";
 	$v_dep = array($row['wms_owner']);
 	$t_dep = array('i');
@@ -221,6 +229,11 @@
 					_mb("Monitoring abonnieren") . "</a></td></tr>";
+		//if service is secured
+		if ($secured=true){
+			$slink=HTTP_AUTH_PROXY."/".$layer_id."?REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS";
+			echo "<tr><th>Abgesicherte Verbindung</th><td><a href = '".$slink."' target=_blank>Secured Capabilities-Dokument</a></td></tr>";
 		$metadataStr .= "</table>\n";
 		$metadataStr .=  '</div></body></html>';
 		echo $metadataStr;
Modified: trunk/mapbender/http/php/mod_loadCapabilities.php
--- trunk/mapbender/http/php/mod_loadCapabilities.php	2009-09-01 13:49:30 UTC (rev 4585)
+++ trunk/mapbender/http/php/mod_loadCapabilities.php	2009-09-02 12:59:49 UTC (rev 4586)
@@ -156,11 +156,22 @@
 	#echo "Load WMS capabilities URL:<br>"
 	if (isset($xml_file)){
-		echo"<input type='text' name='xml_file' size='50' value='".$xml_file."'>";
+		echo"<input type='text' name='xml_file' size='50' value='".$xml_file."'><br>";
 	}else{
-		echo"<input type='text' name='xml_file' size='50' value='http://'>";
+		echo"<input type='text' name='xml_file' size='50' value='http://'><br>";
-	echo"<input type='button' name='loadCap' value='Load' onClick='validate(\"guiList\")'>";
+	//show fields for authentication - only possible if curl is used as connector!
+	if (CONNECTION == 'curl') {
+		echo"HTTP Authentication:<br>";
+		echo"<input type='radio' name='auth_type' checked='checked' value='none'>None<br>";
+		echo"<input type='radio' name='auth_type' value='digest'>Digest<br>";
+    		echo"<input type='radio' name='auth_type' value='basic'>Basic<br>";
+		echo"Username<br>";
+		echo"<input type='text' name='username' size='50' value=''><br>";
+		echo"Password:<br>";
+		echo"<input type='text' name='password' size='50' value=''><br>";
+	echo"<input type='button' name='loadCap' value='Load' onClick='validate(\"guiList\")'>";
 	echo "</form>";
 else{
@@ -168,4 +179,4 @@
 </body>
-</html>
\ No newline at end of file
+</html>
Modified: trunk/mapbender/http/php/mod_loadwms.php
--- trunk/mapbender/http/php/mod_loadwms.php	2009-09-01 13:49:30 UTC (rev 4585)
+++ trunk/mapbender/http/php/mod_loadwms.php	2009-09-02 12:59:49 UTC (rev 4586)
@@ -20,13 +20,36 @@
 require_once(dirname(__FILE__) . "/mb_validatePermission.php");
 require_once(dirname(__FILE__) . "/../classes/class_wms.php");
-$guiList = $_REQUEST["guiList"];
-$xml = $_REQUEST["xml_file"];
-echo "file: ".$xml;
-$mywms = new wms();
-$mywms->createObjFromXML($xml);
-$mywms->writeObjInDB($guiList);
-$mywms->displayWMS();
+if(isset($_REQUEST["wms_id"]) == false)
+    echo "file: ".$_REQUEST["xml_file"];
+    $gui_id = $_REQUEST["guiList"];
+    $xml = $_REQUEST["xml_file"];
+    if ($_REQUEST["auth_type"] == 'basic' || $_REQUEST["auth_type"] == 'digest') {
+	$auth = array();
+    	$auth['username'] = $_REQUEST["username"];
+    	$auth['password'] = $_REQUEST["password"];
+    	$auth['auth_type'] = $_REQUEST["auth_type"];
+    $mywms = new wms();
+if (isset($auth)){
+	$mywms->createObjFromXML($xml,$auth);
+    	$mywms->writeObjInDB($gui_id,$auth);
+else
+	$mywms->createObjFromXML($xml);
+	$mywms->writeObjInDB($gui_id);
+    	$mywms->displayWMS();
+	$wms_id = $mywms->wms_id;
+else
+	$wms_id = $_REQUEST["wms_id"];
+require_once(dirname(__FILE__)."/../php/mod_editWMS_Metadata.php");
+ editWMSByWMSID ($wms_id);
Modified: trunk/mapbender/http/php/mod_owsproxy_conf.php
--- trunk/mapbender/http/php/mod_owsproxy_conf.php	2009-09-01 13:49:30 UTC (rev 4585)
+++ trunk/mapbender/http/php/mod_owsproxy_conf.php	2009-09-02 12:59:49 UTC (rev 4586)
@@ -168,10 +168,13 @@
 	if($admin->getWMSOWSstring($ownwms[$i]) == false){ $status_proxy = 0 ;} else {$status_proxy = 1;};
 	if($admin->getWmsLogTag($ownwms[$i]) == 1){$status_log=1;} else {$status_log=0;};
 	if ($admin->getWmsPrice($ownwms[$i]) != 0 ){$status_price=$admin->getWmsPrice($ownwms[$i]);} else {$status_price=0;};
+	$auth=$admin->getAuthInfoOfWMS($ownwms[$i]);
+	if($auth['auth_type'] == ''){$status_auth = 0;} else {$status_auth = 1;};
 	echo "<tr>";
 	echo "<td>".$ownwms[$i]."</td>";
-	echo "<td>".$admin->getWmsTitleByWmsId($ownwms[$i])."</td>";
+	echo "<td";
+	if($status_auth == 1){echo " bgcolor=\"#FF0000\"";};
+	echo ">".$admin->getWmsTitleByWmsId($ownwms[$i]);
 	echo "<td>";
 	#for owsproxy
 	echo "<input type='checkbox' id='wms_".$ownwms[$i]."_proxy' name='wms_".$ownwms[$i]."_proxy' onclick='if(this.checked){document.getElementById(\"wms_\"+".$ownwms[$i]."+\"_log\").disabled=false;document.getElementById(\"wms_\"+".$ownwms[$i]."+\"_price\").disabled=true;document.getElementById(\"status_\"+".$ownwms[$i]."+\"_proxy\").value=\"1\"}else{document.getElementById(\"wms_\"+".$ownwms[$i]."+\"_log\").checked=false;document.getElementById(\"wms_\"+".$ownwms[$i]."+\"_log\").disabled=true;document.getElementById(\"wms_\"+".$ownwms[$i]."+\"_price\").disabled=true;document.getElementById(\"wms_\"+".$ownwms[$i]."+\"_price\").value=\"0\";document.getElementById(\"status_\"+".$ownwms[$i]."+\"_proxy\").value=\"0\";document.getElementById(\"status_\"+".$ownwms[$i]."+\"_log\").value=\"0\"}'";
@@ -179,6 +182,7 @@
 	#default
 	if($status_proxy == 1){ echo " checked";  } else {echo " unchecked"; };  //if a proxy string is set
+	if($status_auth == 1){ echo " disabled";};
 	echo ">";
 	#initialize hidden field for status proxy:
@@ -216,6 +220,10 @@
 echo "</table>";
+echo "<br>";
+echo "<table><tr><td bgcolor=\"#FF0000\">Service with authentication information</td></tr></table>";
 echo "<input type='submit' name='save' value='save'  ></form>";
 </table>
Added: trunk/mapbender/http_auth/http/index.php
--- trunk/mapbender/http_auth/http/index.php	                        (rev 0)
+++ trunk/mapbender/http_auth/http/index.php	2009-09-02 12:59:49 UTC (rev 4586)
@@ -0,0 +1,521 @@
+<?php
+require(dirname(__FILE__) . "/../../conf/mapbender.conf");
+require(dirname(__FILE__) . "/../../http/classes/class_administration.php");
+require(dirname(__FILE__) . "/../../http/classes/class_connector.php");
+require_once(dirname(__FILE__) . "/../../http/classes/class_mb_exception.php");
+require(dirname(__FILE__) . "/../../owsproxy/http/classes/class_QueryHandler.php");
+//database connection
+$db = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db(DB,$db);
+$imageformats = array("image/png","image/gif","image/jpeg", "image/jpg");
+//control if digest auth is set, if not set, generate the challenge with getNonce()
+if (empty($_SERVER['PHP_AUTH_DIGEST'])) {
+    header('HTTP/1.1 401 Unauthorized');
+    header('WWW-Authenticate: Digest realm="'.REALM.
+           '",qop="auth",nonce="'.getNonce().'",opaque="'.md5(REALM).'"');
+    die('Text to send if user hits Cancel button');
+//read out the header in an array
+$requestHeaderArray = http_digest_parse($_SERVER['PHP_AUTH_DIGEST']);
+//error if header could not be read
+if (!($requestHeaderArray)) {
+	echo 'Following Header information cannot be validated - check your clientsoftware!<br>';
+	echo $_SERVER['PHP_AUTH_DIGEST'].'<br>';
+	die();
+//get mb_username and email out of http_auth username string
+$userIdentification = explode(';',$requestHeaderArray['username']);
+$mbUsername = $userIdentification[0];
+$mbEmail = $userIdentification[1];
+$userInformation = getUserInfo($mbUsername,$mbEmail);
+if ($userInformation[0] == '-1') {
+	die('User with name: '.$mbUsername.' and email: '.$mbEmail.' not known to security proxy!');
+if ($userInformation[1]=='') { //check if digest exists in db - if no digest exists it should be a null string!
+	die('User with name: '.$mbUsername.' and email: '.$mbEmail.' has no digest - please set a new password and try again!');
+//first check the stale!
+if($requestHeaderArray['nonce'] == getNonce()) {
+                        // Up-to-date nonce received
+                        $stale = false;
+                    } else {
+                        // Stale nonce received (probably more than x seconds old)
+                        $stale = true;
+			//give another chance to authenticate
+    			header('WWW-Authenticate: Digest realm="'.REALM.'",qop="auth",nonce="'.getNonce().'",opaque="'.md5(REALM).'" ,stale=true');
+// generate the valid response to check the request of the client
+$A1 = $userInformation[1];
+$A2 = md5($_SERVER['REQUEST_METHOD'].':'.$requestHeaderArray['uri']);
+$valid_response = $A1.':'.getNonce().':'.$requestHeaderArray['nc'];
+$valid_response .= ':'.$requestHeaderArray['cnonce'].':'.$requestHeaderArray['qop'].':'.$A2;
+$valid_response=md5($valid_response);
+if ($requestHeaderArray['response'] != $valid_response) {//the user have to authenticate new - cause something in the authentication went wrong
+    die('Authentication failed - sorry, you have to authenticate once more!');
+//if we are here - authentication has been done well!
+//let's do the proxy things (came from owsproxy.php):
+$postdata = $HTTP_RAW_POST_DATA;
+$layerId = $_REQUEST['layer_id'];
+$query = new QueryHandler();
+// an array with keys and values toLoserCase -> caseinsensitiv
+$reqParams = $query->getRequestParams();
+$n = new administration();
+$wmsId = getWmsIdByLayerId($layerId);
+$owsproxyString = $n->getWMSOWSstring($wmsId);
+if (!$owsproxyString) {
+	die('The requested ressource does not exists or the routing through mapbenders owsproxy is not activated!');
+//get authentication infos if they are available in wms table! if not $auth = false
+$auth = $n->getAuthInfoOfWMS($wmsId);
+if ($auth['auth_type']==''){
+	unset($auth);
+$e = new mb_exception("REQUEST to HTTP_AUTH: ".strtolower($reqParams['request']));
+//what the proxy does
+switch (strtolower($reqParams['request'])) {
+	case 'getcapabilities':
+		$arrayOnlineresources = checkWmsPermission($wmsId,$userInformation[0]);
+		$query->setOnlineResource($arrayOnlineresources['wms_getcapabilities']);
+		$request = 'http://'.$_SERVER['HTTP_HOST'].'/mapbender/x_geoportal/wms.php?layer_id='.$layerId;
+		$requestFull .= $request.'&REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS';
+		if(isset($auth)){
+			getCapabilities($request,$requestFull,$auth);
+		else {
+			getCapabilities($request,$requestFull);
+		break;
+	case 'getfeatureinfo':
+		$query->setOnlineResource($arrayOnlineresources['wms_getfeatureinfo']);
+		$layers = checkLayerPermission($wmsId,$reqParams['layers'],$userInformation[0]);
+		if ($layers == '' ) {
+		throwE("GetFeatureInfo permission denied on layer with id".$layerId);
+		die();
+		$request = $query->getRequest();
+		if(isset($auth)){
+			getFeatureInfo($request,$auth);
+		else {
+			getFeatureInfo($request);
+		break;
+	case 'getmap':
+		$query->setOnlineResource($arrayOnlineresources['wms_getmap']);
+			throwE("GetMap permission denied on layer with id ".$layerId);
+		die();
+		$query->setParam("layers",$layers);
+		#log proxy requests
+		if($n->getWmsLogTag($wmsId)==1) {
+			#do log to db
+			#TODO read out size of bbox and calculate price
+		        #get price out of db
+			$price=intval($n->getWmsPrice($wmsId));
+			$n->logWmsProxyRequest($wmsId,$userInformation[0],$request,$price);
+		if(isset($auth)){
+			getImage($request,$auth);
+		else {
+			getImage($request);
+		break;
+	case 'getlegendgraphic':
+		$url = getLegendUrl($wmsId);
+		$e = new mb_exception("URL for getlegendgraphic: ");
+		if(isset($auth)){
+			getImage($url,$auth);
+		else {
+			getImage($url);
+		break;
+	default:
+echo 'Your are logged in as: <b>' .$requestHeaderArray['username'].'</b> and requested the layer with id=<b>'.$layerId.'</b> but your request is not a valid OWS request';
+//functions for http_auth
+// function to parse the http auth header
+function http_digest_parse($txt)
+    // protect against missing data
+    $needed_parts = array('nonce'=>1, 'nc'=>1, 'cnonce'=>1, 'qop'=>1, 'username'=>1, 'uri'=>1, 'response'=>1);
+    $data = array();
+    $keys = implode('|', array_keys($needed_parts));
+    preg_match_all('@(' . $keys . ')=(?:([\'"])([^\2]+?)\2|([^\s,]+))@', $txt, $matches, PREG_SET_ORDER);
+    foreach ($matches as $m) {
+        $data[$m[1]] = $m[3] ? $m[3] : $m[4];
+        unset($needed_parts[$m[1]]);
+    return $needed_parts ? false : $data;
+// function to get relevant user information from mb db
+function getUserInfo($mbUsername,$mbEmail) {
+	$result = array();
+	$sql = "SELECT mb_user_id, mb_user_digest FROM mb_user where mb_user_name = $1 AND mb_user_email= $2";
+	$v = array($mbUsername, $mbEmail);
+	$t = array("s","s");
+	$res = db_prep_query($sql, $v, $t);
+	if(!($row = db_fetch_array($res))){
+		$result[0] = "-1";
+	else {
+		$result[0] = $row['mb_user_id'];
+		$result[1] = $row['mb_user_digest'];
+	return $result;
+function getNonce() {
+	global $nonceLife;
+	$time = ceil(time() / $nonceLife) * $nonceLife;
+	return md5(date('Y-m-d H:i', $time).':'.$_SERVER['REMOTE_ADDR'].':'.NONCEKEY);
+//functions of owsproxy/http/index.php
+function throwE($e){
+	global $reqParams, $imageformats;
+	if(in_array($reqParams['format'],$imageformats)){
+		throwImage($e);
+	else{
+		throwText($e);
+function throwImage($e){
+	global $reqParams;
+	if (!$reqParams['width'] || !$reqParams['height']) { //width or height are not set by ows request - maybe for legendgraphics
+		$width = 300;
+		$height = 20;
+	$image = imagecreate($width,$height);
+	$transparent = ImageColorAllocate($image,155,155,155);
+	ImageFilledRectangle($image,0,0,$width,$height,$transparent);
+	imagecolortransparent($image, $transparent);
+	$text_color = ImageColorAllocate ($image, 233, 14, 91);
+	for($i=0; $i<count($e); $i++){
+		ImageString ($image, 3, 5, $i*20, $e[$i], $text_color);
+	responseImage($image);
+function throwText($e){
+	echo join(" ", $e);
+function responseImage($im){
+	$format = $reqParams['format'];
+	if($format == 'image/png'){header("Content-Type: image/png");}
+	if($format == 'image/jpeg' || $format == 'image/jpg'){header("Content-Type: image/jpeg");}
+	if($format == 'image/gif'){header("Content-Type: image/gif");}
+	if($format == 'image/png'){imagepng($im);}
+	if($format == 'image/jpeg' || $format == 'image/jpg'){imagejpeg($im);}
+	if($format == 'image/gif'){imagegif($im);}
+function completeURL($url){
+	$mykeys = array_keys($reqParams);
+	for($i=0; $i<count($mykeys);$i++){
+		if($i > 0){ $url .= "&"; }
+		$url .= $mykeys[$i]."=".urlencode($reqParams[$mykeys[$i]]);
+	return $url;
+ * fetch and returns an image to client
+ * @param string the original url of the image to send
+function getImage($or){
+	header("Content-Type: ".$reqParams['format']);
+		echo getDocumentContent($or,$auth);
+	else
+		echo getDocumentContent($or);
+ * fetchs and returns the content of the FeatureInfo Response
+ * @param string the url of the FeatureInfoRequest
+ * @return string the content of the FeatureInfo document
+function getFeatureInfo($url){
+	global $info_format;
+	$e = new mb_exception("owsproxy: Try to fetch FeatureInfoRequest: ".$url);
+	header("Content-Type: ".$info_format);
+		echo getDocumentContent($url,$auth);
+	else
+		echo getDocumentContent($url);
+function matchUrls($content){
+	if(!session_is_registered("owsproxyUrls")){
+		$_SESSION["owsproxyUrls"] = array();
+		$_SESSION["owsproxyUrls"]["id"] = array();
+		$_SESSION["owsproxyUrls"]["url"] = array();
+	$pattern = "/[\"|\'](https*:\/\/[^\"|^\']*)[\"|\']/";
+	preg_match_all($pattern,$content,$matches);
+	for($i=0; $i<count($matches[1]); $i++){
+		$req = $matches[1][$i];
+		$e = new mb_exception("Gefundene URL ".$i.": ".$req);
+		#$notice = new mb_notice("owsproxy id:".$req);
+		$id = registerURL($req);
+		$extReq = setExternalRequest($id);
+		$e = new mb_exception("MD5 URL ".$id."-Externer Link: ".$extReq);
+		$content = str_replace($req,$extReq,$content);
+	return $content;
+function setExternalRequest($id){
+	global $reqParams,$query;
+	$extReq = "http://".$_SESSION['HTTP_HOST'] ."/owsproxy/". $reqParams['sid'] ."/".$id."?request=external";
+	return $extReq;
+function getExternalRequest($id){
+	for($i=0; $i<count($_SESSION["owsproxyUrls"]["url"]); $i++){
+		if($id == $_SESSION["owsproxyUrls"]["id"][$i]){
+			$cUrl = $_SESSION["owsproxyUrls"]["url"][$i];
+			$query_string = removeOWSGetParams($_SERVER["QUERY_STRING"]);
+			if($query_string != ''){
+				$cUrl .= getConjunctionCharacter($cUrl).$query_string;
+			$metainfo = get_headers($cUrl,1);
+			// just for the stupid InternetExplorer
+			header('Pragma: private');
+			header('Cache-control: private, must-revalidate');
+			header("Content-Type: ".$metainfo['Content-Type']);
+			$content = getDocumentContent($cUrl,false);
+			#$content = matchUrls($content); //In the case of http_auth - this is not possible cause we cannot save them in the header - maybe we could create a special session to do so later on?
+			echo $content;
+function removeOWSGetParams($query_string){
+	$r = preg_replace("/.*request=external&/","",$query_string);
+	#return $r;
+	return "";
+function getConjunctionCharacter($url){
+	if(strpos($url,"?")){
+		if(strpos($url,"?") == strlen($url)){
+			$cchar = "";
+		}else if(strpos($url,"&") == strlen($url)){
+			$cchar = "";
+		}else{
+			$cchar = "&";
+	if(strpos($url,"?") === false){
+		$cchar = "?";
+	return $cchar;
+function registerUrl($url){
+	if(!in_array($url,$_SESSION["owsproxyUrls"]["url"])){
+		$e = new mb_exception("Is noch net drin!");
+		$id = md5($url);
+		$e = new mb_exception("ID: ".$id."  URL: ".$url." will be written to session");
+		array_push($_SESSION["owsproxyUrls"]["url"],$url);
+		array_push($_SESSION["owsproxyUrls"]["id"], $id);
+	else{
+		$e = new mb_exception("It was found! Search content and return ID!");
+		$e = new mb_exception("Content ".$i." : proxyurl:".$_SESSION["owsproxyUrls"]["url"][$i]." - new: ".$url);
+		if($url == $_SESSION["owsproxyUrls"]["url"][$i]){
+			$e = new mb_exception("Identical! ID:".$_SESSION["owsproxyUrls"]["id"][$i]." will be used");
+			$id = $_SESSION["owsproxyUrls"]["id"][$i];
+	return $id;
+function getCapabilities($request,$requestFull){
+	global $arrayOnlineresources;
+	global $layerId;
+	header("Content-Type: application/xml");
+	if (func_num_args() == 3) { //new for HTTP Authentication
+		$auth = func_get_arg(2);
+		$content = getDocumentContent($requestFull,$auth);
+	print_r($auth);
+	else
+		$content = getDocumentContent($requestFull);
+	$new = "href=\"".HTTP_AUTH_PROXY ."/". $layerId."?";
+        $pattern = "#href=\"".OWSPROXY."/[a-z0-9]{32}\/[a-z0-9]{32}\?#m";
+	$content = preg_replace($pattern,$new,$content);
+	#TODO: maybe do this by parsing xml rather then regexpr cause they are hungry ;-) - but fast
+	$new = "href=\"".HTTP_AUTH_PROXY ."/". $layerId."?$1\"";
+	$pattern = "#href=\"".str_replace('?','\?',str_replace('/','\/',$request))."\"#";
+	echo $content;
+ * gets the original url of the requested legend graphic
+ * @param string owsproxy md5
+ * @return string url to legend graphic
+function getLegendUrl($wmsId){
+	//get the url
+	$sql = "SELECT layer_style.legendurl ";
+	$sql .= "FROM layer_style JOIN layer ";
+	$sql .= "ON layer_style.fkey_layer_id = layer.layer_id ";
+	$sql .= "WHERE layer.layer_name = $2 AND layer.fkey_wms_id = $1 ";
+	$sql .= "AND layer_style.name = $3 AND layer_style.legendurlformat = $4";
+	if ($reqParams['style']==''){
+		$style='default';
+	else {
+		$style='';
+	$v = array($wmsId, $reqParams['layer'], $style, $reqParams['format']);
+	$t = array("i", "s", "s", "s");
+		return $row["legendurl"];
+	else{
+		throwE(array("No legendurl available."));
+		die();
+ * validated access permission on requested wms
+ * @param wmsId integer, userId - integer
+ * @return array array with detailed information about requested wms
+function checkWmsPermission($wmsId,$userId){
+	global $con, $n;
+	$myguis = $n->getGuisByPermission($userId,true);
+	$mywms = $n->getWmsByOwnGuis($myguis);
+	$sql = "SELECT * FROM wms WHERE wms_id = $1";
+	$v = array($wmsId);
+	$t = array("s");
+	$service = array();
+		$service["wms_id"] = $row["wms_id"];
+		$service["wms_getcapabilities"] = $row["wms_getcapabilities"];
+		$service["wms_getmap"] = $row["wms_getmap"];
+		$service["wms_getfeatureinfo"] = $row["wms_getfeatureinfo"];
+		$service["wms_getcapabilities_doc"] = $row["wms_getcapabilities_doc"];
+	if(!$row || count($mywms) == 0){
+		throwE(array("No wms data available."));
+		die();
+	if(!in_array($service["wms_id"], $mywms)){
+		throwE(array("Permission denied."," -> ".$service["wms_id"], implode(",", $mywms)));
+		die();
+	return $service;
+function checkLayerPermission($wms_id,$l,$userId){
+	global $n, $owsproxyService;
+	$e = new mb_exception("owsproxy: checkLayerpermission: wms: ".$wms_id.", layer: ".$l.' user_id: '.$userId);
+	$myl = split(",",$l);
+	$r = array();
+	foreach($myl as $mysl){
+		if($n->getLayerPermission($wms_id, $mysl, $userId) === true){
+			array_push($r, $mysl);
+	$ret = implode(",",$r);
+	return $ret;
+function getDocumentContent($url){
+		$d = new connector($url, $auth);
+	else {
+		$d = new connector($url);
+	return $d->file;
+//extra functions TODO: push them in class_administration.php
+     * selects the wms id for a given layer id.
+     * @param <integer> the layer id
+     * @return <string|boolean> either the id of the wms as integer or false when none exists
+	function getWmsIdByLayerId($id){
+		$sql = "SELECT fkey_wms_id FROM layer WHERE layer_id = $1";
+		$v = array($id);
+		$t = array('i');
+		$row = db_fetch_array($res);
+		if ($row) return $row["fkey_wms_id"]; else return false;
Modified: trunk/mapbender/owsproxy/http/classes/class_QueryHandler.php
--- trunk/mapbender/owsproxy/http/classes/class_QueryHandler.php	2009-09-01 13:49:30 UTC (rev 4585)
+++ trunk/mapbender/owsproxy/http/classes/class_QueryHandler.php	2009-09-02 12:59:49 UTC (rev 4586)
@@ -82,6 +82,9 @@
 		else if($key == 'request' && $this->reqParams[$key] == 'external'){
 			return false;
+		else if($key == 'layer_id'){ //for request to restful layer proxy - id would become part of the url!
+			return false;
 		else{
 			return true;
@@ -162,4 +165,4 @@
Modified: trunk/mapbender/owsproxy/http/index.php
--- trunk/mapbender/owsproxy/http/index.php	2009-09-01 13:49:30 UTC (rev 4585)
+++ trunk/mapbender/owsproxy/http/index.php	2009-09-02 12:59:49 UTC (rev 4586)
@@ -51,12 +51,21 @@
 	throwE("Permission denied");
 	die();
+$n = new administration;
 //if($_SESSION['mb_user_ip'] != $_SERVER['REMOTE_ADDR']){
 //	throwE(array("No session data available.","Permission denied.","Please authenticate."));
 //	die();
+$wmsId = $n->getWmsIdFromOwsproxyString($query->getOwsproxyServiceId());
+#$notice = new mb_notice("wmsid:".$wmsId);
+#$mb_exception = new mb_exception("auth: ".$auth['username']);
+	unset($auth);
 /*************  workflow ************/
@@ -64,13 +73,24 @@
 		$arrayOnlineresources = checkWmsPermission($query->getOwsproxyServiceId());
-		getCapabilities($request);
+		if(isset($auth)){
+			getCapabilities($request,$auth);
+			#$mb_exception = new mb_exception("auth: ".$auth['auth_type']);
+		else {
+			getCapabilities($request);
 		break;
-		getFeatureInfo($request);
+		if(isset($auth)){
+		else {
 		break;
 	case 'getmap':
 		$arrayOnlineresources = checkWmsPermission($owsproxyService);
@@ -90,7 +110,13 @@
 			$price=intval($n->getWmsPrice($arrayOnlineresources['wms_id']));
 			$n->logWmsProxyRequest($arrayOnlineresources['wms_id'],$_SESSION['mb_user_id'],$request,$price);
-		getImage($request);
+		if(isset($auth)){
+#$mb_exception = new mb_exception("auth: ".$auth['auth_type']);
+		else {
 		break;
 	case 'map':
@@ -102,11 +128,21 @@
+		if(isset($auth)){
+		else {
+			getImage($url);
 		break;
 		$url = getLegendUrl($query->getOwsproxyServiceId());
-		getImage($url);
+		if(isset($auth)){
+		else {
+			getImage($url);
 		break;
 	case 'external':
 		getExternalRequest($query->getOwsproxyServiceId());
@@ -191,7 +227,15 @@
 	#timestamp,user_id,getmaprequest,amount pixel,price - but do this only for wms to log - therefor first get log tag out of wms!
-	echo getDocumentContent($or);
+	else
@@ -204,7 +248,14 @@
 	//$e = new mb_notice("owsproxy: Try to fetch FeatureInfoRequest: ".$url);
-	$content = getDocumentContent($url);
+		$content = getDocumentContent($url,$auth);
+	else {
+		$content = getDocumentContent($url);
 	echo $content;
@@ -575,7 +626,14 @@
 	return $ret;
-	$d = new connector($url);
+	else {
 	return $d->file;
Modified: trunk/mapbender/resources/db/update/update_2.7.sql
--- trunk/mapbender/resources/db/update/update_2.7.sql	2009-09-01 13:49:30 UTC (rev 4585)
+++ trunk/mapbender/resources/db/update/update_2.7.sql	2009-09-02 12:59:49 UTC (rev 4586)
@@ -276,3 +276,23 @@
 ALTER TABLE wms ADD COLUMN wms_pricevolume integer;
 ALTER TABLE wms ALTER COLUMN wms_pricevolume SET STORAGE PLAIN;
+-- http auth
+ALTER TABLE wms ADD COLUMN wms_username VARCHAR(255) NOT NULL DEFAULT '';
+ALTER TABLE wms ADD COLUMN wms_password VARCHAR(255) NOT NULL DEFAULT '';
+ALTER TABLE wms ADD COLUMN wms_auth_type VARCHAR(255) NOT NULL DEFAULT '';
+-- Column: mb_user_digest
+-- ALTER TABLE mb_user DROP COLUMN mb_user_digest;
+ALTER TABLE mb_user ADD COLUMN mb_user_digest text;
+ALTER TABLE mb_user ALTER COLUMN mb_user_digest SET STORAGE EXTENDED;
+--Initial filling with empty strings
+UPDATE mb_user set mb_user_digest='';
+--howto set up the http_auth digest hash
+--update mb_user set mb_user_digest=md5(mb_user_name || ';' || mb_user_email || ':' || '<realm_name>' || ':' || 'password') where mb_user_id = <ID>;
More information about the Mapbender_commits mailing list
