[Mapbender-commits] r4634 - in branches/2.6/resources/db/pgsql:
ISO-8859-1/update UTF-8/update
svn_mapbender at osgeo.org
Tue Sep 15 11:45:34 EDT 2009
Author: christoph
Date: 2009-09-15 11:45:34 -0400 (Tue, 15 Sep 2009)
New Revision: 4634
branches/2.6/resources/db/pgsql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_pgsql_ISO-8859-1.sql
branches/2.6/resources/db/pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql
removed public schema!
Modified: branches/2.6/resources/db/pgsql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_pgsql_ISO-8859-1.sql
--- branches/2.6/resources/db/pgsql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_pgsql_ISO-8859-1.sql 2009-09-15 15:43:16 UTC (rev 4633)
+++ branches/2.6/resources/db/pgsql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_pgsql_ISO-8859-1.sql 2009-09-15 15:45:34 UTC (rev 4634)
@@ -165,69 +165,69 @@
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Back', 'Zoom previo');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Forward', 'Zoom siguiente');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Coordinates', 'Mostrar coordinadas');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Zoom by rectangle', 'Zoom retángulo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Zoom by rectangle', 'Zoom ret�ngulo');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Redraw', 'Refrescar');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Query', 'Procurar dados');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Logout', 'Terminar sessão');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Logout', 'Terminar sess�o');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'WMS preferences', 'Ajuste WMS');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Adding WMS from filtered list', 'Adicionar WMS desde lista filtrada');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Set map center', 'Centrar');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Help', 'Ajuda');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Show WMS infos', 'Mostrar informação sobre WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Show WMS infos', 'Mostrar informa��o sobre WMS');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Save workspace as web map context document', 'Guardar vista como arquivo Web Map Context');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Resize Mapsize', 'Modificar tamanho do mapa');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Rubber', 'Apagar');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Get Area', 'Calcular area');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Close Polygon', 'Fechar polígono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Close Polygon', 'Fechar pol�gono');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Move back to your GUI list', 'Volver a lista WMS');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Legend', 'Legenda');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Print', 'Imprimir');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Imprint', 'Expediente');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Maps', 'Mapas');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Search', 'Procura');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Meetingpoint', 'Lugar de reunião, ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Meetingpoint', 'Lugar de reuni�o, ');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Metadatasearch', 'Procura metadados');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Adding WMS', 'Adicionar WMS');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Adding WMS from List', 'Adicionar WMS desde lista');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Info', 'Informação');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Info', 'Informa��o');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Change Projection', 'Trocar projeto');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Copyright', 'Copyright');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Digitize', 'Captura');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Overview', 'Mapa de vição geral');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Overview', 'Mapa de vi��o geral');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Drag Mapsize', 'Ampliar janela do mapa');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Mapframe', 'Janela do mapa');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Navigation Frame', 'Janela do navegação');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Navigation Frame', 'Janela do navega��o');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'scaleSelect', 'Selecionar escala');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Scale Text', 'Texto da escala');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Scalebar', 'Barra de escala');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Set Background', 'Pôr fondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Set Background', 'P�r fondo');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Zoom to Coordinates', 'Zoom pra coordinadas');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Change Password', 'Trocar senha');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Load a web map context document', 'Carregar documento do Web Map Context');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Logo', 'Logo');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Measure distance', 'Medir distância');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Measure distance', 'Medir dist�ncia');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'languaje', 'Selecionar Linguajem');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'navFrame', 'Marco de navegacion');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'dragMapSize', 'Agrandar Mapa');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Pan', 'Desplazamento');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Display complete map', 'Zoom na Extensão Total');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Display complete map', 'Zoom na Extens�o Total');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Zoom in', 'Zoom +');
-- new translation entries for french
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Pan', 'Déplacer la sélection');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Pan', 'D�placer la s�lection');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Display complete map', 'Afficher toute la carte');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Zoom in', 'Zoomer');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Zoom out', 'Dézoomer');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Back', 'Précédent');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Zoom out', 'D�zoomer');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Back', 'Pr�c�dent');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Forward', 'Suivant');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Coordinates', 'Afficher les coordonnées');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Zoom by rectangle', 'Zoomer sur la sélection');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Coordinates', 'Afficher les coordonn�es');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Zoom by rectangle', 'Zoomer sur la s�lection');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Redraw', 'Actualiser [Espace]');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Query', 'Interroger la base de données');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Logout', 'Déconnexion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Query', 'Interroger la base de donn�es');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Logout', 'D�connexion');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'WMS preferences', 'Configuration du WMS');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Adding WMS from filtered list', 'Ajouter un WMS de la liste filtrée');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Set map center', 'Définir le centre de la carte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Adding WMS from filtered list', 'Ajouter un WMS de la liste filtr�e');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Set map center', 'D�finir le centre de la carte');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Help', 'Aide');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Show WMS infos', 'Affichage des informations du WMS');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Save workspace as web map context document', 'Sauvegarder la vue/l''espace de travail en tant que Web Map Context');
@@ -235,29 +235,29 @@
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Rubber', 'Gomme');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Get Area', 'Calculer la superficie');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Close Polygon', 'Fermer le polygone');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Move back to your GUI list', 'Retour à votre liste GUI');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Legend', 'Légende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Move back to your GUI list', 'Retour � votre liste GUI');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Legend', 'L�gende');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Print', 'Imprimer');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Imprint', 'Envoyer / Imprint');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Maps', 'Cartes');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Search', 'Recherche');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Meetingpoint', 'Point de rencontre');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Metadatasearch', 'Recherche des métadonnées');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Metadatasearch', 'Recherche des m�tadonn�es');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Adding WMS', 'Ajouter WMS');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Adding WMS from List', 'Ajouter WMS depuis la liste');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Info', 'Info');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Change Projection', 'Changer la projection');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Copyright', 'Copyright');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Digitize', 'Numériser');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Overview', 'Carte d''aperçu');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Digitize', 'Num�riser');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Overview', 'Carte d''aper�u');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Drag Mapsize', 'Modifier la taille de la carte');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Mapframe', 'Fenêtre de la carte');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Navigation Frame', 'Fenêtre de navigation');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Scale Select', 'Sélection de l ''échelle');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Scale Text', 'Texte de l''échelle');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Mapframe', 'Fen�tre de la carte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Navigation Frame', 'Fen�tre de navigation');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Scale Select', 'S�lection de l ''�chelle');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Scale Text', 'Texte de l''�chelle');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Scalebar', 'Echelle graphique');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Set Background', 'Sélectionner la carte d''arrière-plan');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Zoom to Coordinates', 'Zoomer aux coordonnées');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Set Background', 'S�lectionner la carte d''arri�re-plan');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Zoom to Coordinates', 'Zoomer aux coordonn�es');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Change Password', 'Changer le mot de passe');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Load a web map context document', 'Charger un fichier Web Map Context');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Logo', 'Logo');
@@ -279,14 +279,14 @@
-- new tables for category handling
-CREATE TABLE public.gui_gui_category
+CREATE TABLE gui_gui_category
fkey_gui_id character varying(50),
fkey_gui_category_id integer
-CREATE TABLE public.gui_category
+CREATE TABLE gui_category
category_id serial,
category_name character varying(50),
Modified: branches/2.6/resources/db/pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql
--- branches/2.6/resources/db/pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql 2009-09-15 15:43:16 UTC (rev 4633)
+++ branches/2.6/resources/db/pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql 2009-09-15 15:45:34 UTC (rev 4634)
category_id serial,
More information about the Mapbender_commits
