[Mapbender-commits] r4635 - in trunk/mapbender/resources/db: . mysql/ISO-8859-1/update mysql/UTF-8/update pgsql pgsql/ISO-8859-1/update pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Sep 15 12:51:15 EDT 2009
Author: tbaschetti
Date: 2009-09-15 12:51:14 -0400 (Tue, 15 Sep 2009)
New Revision: 4635
Added:
   trunk/mapbender/resources/db/install_2.6.bat
   trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_mysql_ISO-8859-1.sql
   trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.6rc1_to_2.6_mysql_ISO-8859-1.sql
   trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.5.1_to_2.6rc1_mysql_UTF-8.sql
   trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.6rc1_to_2.6_mysql_UTF-8.sql
   trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_pgsql_ISO-8859-1.sql
   trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.6rc1_to_2.6_pgsql_ISO-8859-1.sql
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql
Removed:
   trunk/mapbender/resources/db/install_2.6rc1.sh
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql
   trunk/mapbender/resources/db/pgsql/pgsql_serial_set_sequences_7x_2.5.sql
   trunk/mapbender/resources/db/install_2.6.sh
synced database-scripts and install-script with 2.6
dropped support for PostgreSQL 7.x
Added: trunk/mapbender/resources/db/install_2.6.bat
--- trunk/mapbender/resources/db/install_2.6.bat	                        (rev 0)
+++ trunk/mapbender/resources/db/install_2.6.bat	2009-09-15 16:51:14 UTC (rev 4635)
@@ -0,0 +1,203 @@
+ at echo off
+REM Script to install Mapbender 2.6 database
+REM
+setlocal
+REM Delete old Logfiles
+del log_*.txt
+del err_*.txt
+:PREP
+echo.
+echo ==============================================================================
+REM Disclaimer
+echo.
+echo DISCLAIMER: this Mapbender database setup script is not stable. USE AT YOUR OWN RISK!
+echo This script will create a database for you and will import the Mapbender data to the new database
+echo It will possibly also compile the Mapbender.mo files
+echo.
+echo You need:
+echo - a running postgresql or mysql database
+echo - database user with write access
+echo.
+echo If everything is prepared you can continue.
+echo.
+echo.
+echo Continue?
+set /p PREPARED="(y)es or (n)o:"
+if %PREPARED%==y goto :PREP_OK
+if %PREPARED%==n goto :End
+goto :PREP
+:PREP_OK
+rem Database
+:DB_TYPE
+echo.
+echo Which Database?
+set /p DBTYPE="(p)ostgresql or (m)ysql:"
+if %DBTYPE%==p goto :DB_PG
+if %DBTYPE%==m goto :DB_MYSQL
+goto :DB_TYPE
+:DB_PG
+set USEDBTYPE=PostgreSQL
+:DB_MYSQL
+IF %USEDBTYPE%x==x set USEDBTYPE=Mysql
+REM Encoding
+:DB_ENC
+echo.
+echo Which Encoding?
+set /p DBENC="(u)tf-8 or (i)so-8859-1/latin1:"
+if %DBENC%==u goto :DB_UTF
+if %DBENC%==i goto :DB_ISO
+goto :DB_ENC
+:DB_UTF
+set USEDBENC=UTF-8
+:DB_ISO
+IF %USEDBENC%x==x set USEDBENC=ISO-8859-1
+echo.
+set /p DBHOST="Database host (localhost if running on local maschine):"
+echo.
+echo.
+set /p DBPORT="Database port (e.g. 5432 for postgres, 3306 for mysql):"
+echo.
+echo.
+set /p DBUSER="Database user:"
+echo.
+rem Password
+rem echo.
+echo Database Password will be asked many times during install...
+echo.
+set /p DBNAME="Database name:"
+:CHOICES
+echo.
+echo Your Choices:
+echo Databasetype: %DBTYPE% - %USEDBTYPE%
+echo Encoding: %DBENC% - %USEDBENC%
+echo Database Host: %DBHOST%
+echo Database Port: %DBPORT%
+echo Database Name: %DBNAME%
+echo Database User: %DBUSER%
+echo Database Password: %DBPASSWORD% (not shown)
+echo.
+echo Looks ok, start install?
+echo.
+set /p START_INSTALL="(y)es or (n)o? "
+if %START_INSTALL%==y goto START_INSTALL
+goto PREP
+:START_INSTALL
+rem echo on
+if %USEDBTYPE% == PostgreSQL goto INSTPOSTGRESQL
+if %USEDBTYPE% == Mysql goto INSTMYSQL
+:INSTPOSTGRESQL
+REM do these exist?
+psql --version 2> nul 1> nul
+if NOT %ERRORLEVEL% == 0 goto PGNOTFOUND
+set /p DBTEMPLATE="database template to use (just hit return for default):"
+IF %DBTEMPLATE%x==x set DBTEMPLATE=template0
+IF %DBHOST%x==x set DBHOST=localhost
+IF %DBPORT%x==x set DBPORT=5432
+echo creating db
+createdb -U %DBUSER% -E %USEDBENC% -h %DBHOST% -p %DBPORT% -T %DBTEMPLATE% %DBNAME% "Mapbender Database Version 2.6"
+echo creating schema
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/pgsql_schema_2.5.sql %DBNAME% 1>log_schema.txt 2> err_schema.txt
+echo importing data
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/pgsql_data_2.5.sql %DBNAME% 1>log_data.txt 2> err_data.txt
+echo setting sequences
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/pgsql_serial_set_sequences_2.5.sql %DBNAME% 1>log_sequences.txt 2> err_sequences.txt
+echo performing updates
+echo to 2.5.1rc1
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.5_to_2.5.1rc1_pgsql_%USEDBENC%.sql %DBNAME% 1>log_update.txt 2> err_update.txt
+echo to 2.5.1
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.5.1rc1_to_2.5.1_pgsql_%USEDBENC%.sql %DBNAME% 1>>log_update.txt 2>> err_update.txt
+echo to 2.6rc1
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.5.1_to_2.6rc1_pgsql_%USEDBENC%.sql %DBNAME% 1>>log_update.txt 2>> err_update.txt
+echo to 2.6
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6rc1_to_2.6_pgsql_%USEDBENC%.sql %DBNAME% 1>>log_update.txt 2>> err_update.txt
+goto POFILES
+:INSTMYSQL
+IF %DBPORT%x==x set DBPORT=3306
+mysql --version 2> nul 1> nul
+if not %ERRORLEVEL% == 0 goto MYSQLNOTFOUND
+echo creating database
+if %USEDBENC% == ISO-8859-1 mysql -h %DBHOST% -P %DBPORT% -u %DBUSER% -e "create database %DBNAME% character set latin1 COLLATE latin1_german1_ci;" -p
+if %USEDBENC% == UTF-8 mysql -h %DBHOST% -P %DBPORT% -e "create database %DBNAME% character set utf8 COLLATE utf8_general__ci;" -p
+mysql %DBNAME% -p -h %DBHOST% -P %DBPORT% -u %DBUSER% < mysql/mysql_schema_2.5.sql > log_schema.txt 2> err_schema.txt
+echo loading data
+mysql %DBNAME% -p -h %DBHOST% -P %DBPORT% -u %DBUSER% < mysql/%USEDBENC%/mysql_data_2.5.sql > log_data.txt 2> err_data.txt
+echo update to 2.5.1rc1
+mysql %DBNAME% -p -h %DBHOST% -P %DBPORT% -u %DBUSER% < mysql/%USEDBENC%/update/update_2.5_to_2.5.1rc1_mysql_%USEDBENC%.sql > log_update.txt 2> err_update.txt
+mysql %DBNAME% -p -h %DBHOST% -P %DBPORT% -u %DBUSER% < mysql/%USEDBENC%/update/update_2.5.1rc1_to_2.5.1_mysql_%USEDBENC%.sql >> log_update.txt 2>> err_update.txt
+echo update to 2.6rc1
+mysql %DBNAME% -p -h %DBHOST% -P %DBPORT% -u %DBUSER% < mysql/%USEDBENC%/update/update_2.5.1_to_2.6rc1_mysql_%USEDBENC%.sql >> log_update.txt 2>> err_update.txt
+echo update to 2.6
+mysql %DBNAME% -p -h %DBHOST% -P %DBPORT% -u %DBUSER% < mysql/%USEDBENC%/update/update_2.6rc1_to_2.6_mysql_%USEDBENC%.sql >> log_update.txt 2>> err_update.txt
+GOTO POFILES
+:POFILES
+rem install mapbender.conf
+if not exist ..\..\conf\mapbender.conf copy ..\..\conf\mapbender.conf-dist ..\..\conf\mapbender.conf
+echo please check and edit your mapbender.conf.
+rem update .po files
+echo ""
+msgfmt --version 2> nul 1> nul
+if NOT %ERRORLEVEL% == 0 goto MSGFMTNOTFOUND
+echo "Compiling .po files..."
+pushd ..\..\tools\
+findstr /v ^# i18n_update_mo.sh > i18n_update_mo.bat
+call i18n_update_mo.bat
+del i18n_update_mo.bat
+popd
+goto END:
+:MSGFMTNOTFOUND
+echo Sorry, msgfmt not found, must be in PATH-Variable, won't compile translations...
+echo Have a look at http://www.mapbender.org/Gettext#Utility_programms for msgfmt.
+goto END:
+goto END:
+:PGNOTFOUND
+echo Sorry, psql not found, must be in PATH-Variable, exiting...
+goto END
+:MYSQLNOTFOUND
+echo Sorry, mysql not found, must be in PATH-Variable, exiting...
+goto END
+REM End, keep Terminal session open
+:END
+endlocal
+echo Finished...check the log files to see if an error occured.
+pause
Modified: trunk/mapbender/resources/db/install_2.6.sh
--- trunk/mapbender/resources/db/install_2.6.sh	2009-09-15 15:45:34 UTC (rev 4634)
+++ trunk/mapbender/resources/db/install_2.6.sh	2009-09-15 16:51:14 UTC (rev 4635)
@@ -1,225 +1,272 @@
 #!/bin/bash
+# create database for mapbender
-rm log_*.txt
+function show_disclaimer() {
+    # Disclaimer
+    echo ""
+    echo "DISCLAIMER: this Mapbender database setup script is not stable. USE AT YOUR OWN RISK!"
+    echo "The script will create a database for you and will import the Mapbender data to the new database"
+    echo "It will also compile the Mapbender.mo files"
+    echo ""
+    echo "To run this script you have to set the following options"
+    # echo " * set the right to execute on this install script"
+    # echo " * set the right to execute on mapbender/tools/i18n_update_mo.sh"
+    # echo " * write access to mapbender/log"
+    # echo " * write access to mapbender/http/tmp"
+    # echo " * write access to mapbender/resources/locale/ and subdirectories"
+    echo " * provide a database user that can create a database"
+    echo ""
+    echo ""
+    echo "If everything is prepared you can continue."
+    echo ""
-# Disclaimer
-echo ""
-echo "DISCLAIMER: this Mapbender database setup script is not stable. USE AT YOUR OWN RISK!"
-echo "The script will create a database for you and will import the Mapbender data to the new database"
-echo "It will also compile the Mapbender.mo files"
-echo ""
-echo "To run this script you have to set the following options"
-# echo " * set the right to execute on this install script"
-# echo " * set the right to execute on mapbender/tools/i18n_update_mo.sh"
-# echo " * write access to mapbender/log"
-# echo " * write access to mapbender/http/tmp"
-# echo " * write access to mapbender/resources/locale/ and subdirectories"
-echo " * provide a database user that can create a database"
-echo ""
-echo ""
-echo "If everything is prepared you can continue."
-echo ""
-echo "Continue? (y)es or (n)o"
-read disclaimer
+function del_logfile() {
+	rm log_*.txt
+	rm err_*.txt
-if test $disclaimer != "y"
-then
-	exit 1
-fi
-# ask for db version
-echo ""
-echo "Database version? (p)ostgresql or (m)ysql?"
-read dbversion
+#get Database Configuration
+function get_db_config(){
+    until [ "$DBVERSION" = "p" -o "$DBVERSION" = "m" ]
+    do
+        echo ""
+        echo "database version? (p)ostgresql or (m)ysql?"
+        read DBVERSION
+    done
-if test $dbversion != "p" -a $dbversion != "m"
-then
-	echo ""
-	echo "Incorrect database type. Terminating the script..."
-	exit 1
-fi
+    # db encoding
+    until [ "$DBENCODING" = "i" -o "$DBENCODING" = "u" ]
+    do
+        echo ""
+        echo "database character encoding? (i)so-8859-1 or (u)tf-8?"
+        read DBENCODING
+    done
+   #ask for database template
+    if [ "$DBVERSION" = "p" ]
+    then
+        echo ""
+        echo "database template to use (just hit return for default template0)?"
+        read DBTEMPLATE
+        : ${DBTEMPLATE:="template0"}
+    fi
+    # db name
+    until [ -n "$DBNAME" ]
+    do
+        echo ""
+        echo "database name?"
+        read DBNAME
+    done
-# ask for db character encoding-U $dbuser
-echo ""
-echo "Database character encoding? (i)so-8859-1 or (u)tf-8?"
-read dbenc
+    #nicer vars
+    then
+        DBVERSION="pgsql"
+    else
+        DBVERSION="mysql"
+    fi
-if test $dbenc != "i" -a $dbenc != "u"
-then
-	echo ""
-	echo "Incorrect database character encoding. Terminating the script..."
-	exit 1
-fi
+    if [  "$DBENCODING" = "i" ]
+    then
+        DBENCODING="ISO-8859-1"
+    else
+        DBENCODING="UTF-8"
+    fi
-# ask for database name
-echo ""
-echo "Name of database?"
-read dbname
+    echo ""
+    echo "database host (e.g. localhost)?"
+    read DBHOST
+    echo ""
+    echo "database port (e.g. 5432 for postgres, 3306 for mysql)?"
+    read DBPORT
-if test $dbversion = "m"
-then
+    echo ""
+    echo "database user?"
+    read DBUSER
-	echo "Not available!!!"
-	exit 1
+#using a password via commandline oder as shell var could lead to security problems, so we don't do it
+#    echo ""
+#    echo "Password for $DBUSER (will not be shown)?"
+#	stty -echo
+#	read DBPASSWORD
+#	stty echo
-	echo ""
-	echo "Enter your MySQL password:"
-	stty -echo
-	read password
-	stty echo
-	echo ""
-	if test $dbenc = "i"
-	then
-		echo ""
-		echo "Installing Mapbender with MySQL (ISO-8859-1) in database $dbname";
-		echo ""
+#show Database Configuration
+function show_db_config(){
+    echo ""
+    echo "Database Configuration:"
+    echo "version:"  $DBVERSION
+    echo "encoding:" $DBENCODING
+    if [ $DBTEMPLATE ]
+    then
+        echo "postgres template:" $DBTEMPLATE
+    fi
+    echo "db host:" $DBHOST
+    echo "db port:" $DBPORT
+    echo "dbname:" $DBNAME
+    echo "user:"     $DBUSER
+    echo ""
-		mysql -e "create database $dbname CHARACTER SET latin1 COLLATE latin1_german1_ci;" -p$password
-		mysql $dbname -p$password < mysql/mysql_schema_2.5.sql > log_schema.txt
-		mysql $dbname -p$password < mysql/ISO-8859-1/mysql_data_2.5.sql > log_data.txt
-		mysql $dbname -p$password < mysql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_mysql_ISO-8859-1.sql > log_update.txt
-		mysql $dbname -p$password < mysql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_mysql_ISO-8859-1.sql > log_update.txt
-		mysql $dbname -p$password < mysql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_mysql_ISO-8859-1.sql > log_update.txt
-	elif test $dbenc = "u"
-	then
-		echo ""
-		echo "Installing Mapbender with MySQL (UTF-8) in database $dbname";
-		echo ""
-		mysql -e "create database $dbname CHARACTER SET utf8 COLLATE utf8_general_ci;" -p$password
-		mysql $dbname -p$password < mysql/UTF-8/mysql_data_2.5.sql > log_data.txt
-		mysql $dbname -p$password < mysql/UTF-8/update/update_2.5_to_2.5.1rc1_mysql_UTF-8.sql > log_update.txt
-		mysql $dbname -p$password < mysql/UTF-8/update/update_2.5.1rc1_to_2.5.1_mysql_UTF-8.sql > log_update.txt
-		mysql $dbname -p$password < mysql/UTF-8/update/update_2.5.1_to_2.6rc1_mysql_UTF-8.sql > log_update.txt
-	fi
-elif test $dbversion = "p" -a $dbenc = "i"
-then
-	#Creating database user with rw access
-	echo "Please specify a user for the database"
-	read mapbenderuser
+function create_mysql_db(){
+    which mysql > /dev/null
+    if [ $? -ne 0 ]
+    then
+        echo "commando mysql, but not found, exiting..."
+        echo "is mysql installed?"
+        echo ""
+        exit 1;
+    fi
+    echo "Your password will be asked several times, this is normal"
+    echo "creating database"
+    if [ $DBENCODING = "ISO-8859-1" ]
+    then
+        mysql -e "create database $DBNAME CHARACTER SET latin1 COLLATE latin1_german1_ci;" -p$DBPASSWORD -u $DBUSER
+    else
+        mysql -e "create database $DBNAME CHARACTER SET utf8 COLLATE utf8_general_ci;" -p$DBPASSWORD -u $DBUSER
+    fi
+	echo "creating schema"
+	mysql $DBNAME -p$DBPASSWORD -u $DBUSER -h $DBHOST -P $DBPORT < mysql/mysql_schema_2.5.sql > log_schema.txt 2> err_schema.txt
+	echo "loading data"
+	mysql $DBNAME -p$DBPASSWORD -u $DBUSER -h $DBHOST -P $DBPORT < mysql/$DBENCODING/mysql_data_2.5.sql > log_data.txt 2> err_data.txt
+	echo "update to 2.5.1rc1"
+	mysql $DBNAME -p$DBPASSWORD -u $DBUSER -h $DBHOST -P $DBPORT < mysql/$DBENCODING/update/update_2.5_to_2.5.1rc1_mysql_$DBENCODING.sql > log_update.txt 2> err_update.txt
+	echo "update to 2.5.1"
+	mysql $DBNAME -p$DBPASSWORD -u $DBUSER -h $DBHOST -P $DBPORT < mysql/$DBENCODING/update/update_2.5.1rc1_to_2.5.1_mysql_$DBENCODING.sql >> log_update.txt 2>> err_update.txt
+	echo "update to 2.6rc1"
+	mysql $DBNAME -p$DBPASSWORD -u $DBUSER -h $DBHOST -P $DBPORT < mysql/$DBENCODING/update/update_2.5.1_to_2.6rc1_mysql_$DBENCODING.sql >> log_update.txt 2>> err_update.txt
+	echo "update to 2.6"
+	mysql $DBNAME -p$DBPASSWORD -u $DBUSER -h $DBHOST -P $DBPORT < mysql/$DBENCODING/update/update_2.6rc1_to_2.6_mysql_$DBENCODING.sql >> log_update.txt 2>> err_update.txt
-    	echo ""
-	    echo "Installing Mapbender with PostgreSQL (ISO-8859-1) in database $dbname";
-	    echo ""
-        # ask for database user
+#Create Database (Postgres)
+function create_pgsql_db(){
+    which psql createdb > /dev/null
+    if [ $? -ne 0 ]
+    then
+        echo "commando pgsql or createdb needed, but not found, exiting..."
+        echo "is PostgreSQL installed?"
         echo ""
-        echo "Name of database user?"
-        read dbuser
+        exit 1;
+    fi
+    echo "Your password will be asked several times, this is normal (unless .pgpass is used)"
+    createdb -U $DBUSER  -h $DBHOST -p $DBPORT -E $DBENCODING $DBNAME -T $DBTEMPLATE
+	psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/pgsql_schema_2.5.sql $DBNAME > log_schema.txt 2> err_schema.txt
+    psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/pgsql_data_2.5.sql $DBNAME > log_data.txt 2> err_data.txt
+	echo "setting sequences"
+    psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/pgsql_serial_set_sequences_2.5.sql $DBNAME > log_sequences.txt 2> err_squences.txt
+    psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.5_to_2.5.1rc1_pgsql_$DBENCODING.sql $DBNAME > log_update.txt 2> err_update.txt
+	psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.5.1rc1_to_2.5.1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
+	psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.5.1_to_2.6rc1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
+	psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.6rc1_to_2.6_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
-        #ask for database template
-        echo ""
-        echo "Do you want to use a database template? (y)es or (n)o "
-        read dbtemplateuse
-        if test $dbtemplateuse = "y"
-        then
-           #ask for template name
-           echo ""
-           echo "Name of the template?"
-           read dbtemplate
-        fi
-        if test dbtemplate != ""
-        then
-           createdb -U $dbuser -E ISO-8859-1 $dbname -T $dbtemplate
-        else
-        fi
-	psql -U $dbuser -f pgsql/pgsql_schema_2.5.sql $dbname > log_schema.txt
-	psql -U $dbuser -f pgsql/ISO-8859-1/pgsql_data_2.5.sql $dbname > log_data.txt
-	psql -U $dbuser -f pgsql/pgsql_serial_set_sequences_2.5.sql $dbname > log_sequences.txt
-	psql -U $dbuser -f pgsql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_pgsql_ISO-8859-1.sql $dbname > log_update.txt
-	psql -U $dbuser -f pgsql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_pgsql_ISO-8859-1.sql $dbname > log_update.txt
-	psql -U $dbuser -f pgsql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_pgsql_ISO-8859-1.sql $dbname > log_update.txt
+function set_permissions(){
+    echo "The installer can set the permissions to the files"
+    echo "and directory for you. If you want the installer to"
+    echo "do this please enter (y)es else (n)o"
+    echo "Please note, to do this you have to be"
+    echo "read write access to the Mapbender directory"
+    echo "set permissions, (y)es or (n)?"
+    read automatic
-elif test $dbversion = "p" -a $dbenc = "u"
-then
-	echo ""
-	echo "Installing Mapbender with PostgreSQL (UTF-8) in database $dbname";
-	echo ""
-        echo ""
-        read dbuser
+    if test $automatic != "n"
+    then
+          echo "Do you want that all files are owned by the apache webserver? (y)es or (n)o"
+          read setowner
+          if test $setowner != "n"
+          then
+	        echo "Please specify the webserver user"
+	        read webservuser
+	        echo "Please specify the webserver group"
+	        read webservgroup
-        echo ""
+	        chown -R $webservuser:$webservgroup ../../
+          fi
+          echo "setting permissions on /resources/locale/ and subdirectories"
+          chmod -R o+rw ../locale
+          echo "setting execute rights on mapbender/tools/i18n_update_mo.sh"
+          chmod -R o+rx ../../tools/i18n_update_mo.sh
+          # creating mapbender.conf
+          if [ -f ../../conf/mapbender.conf ]
+          then
+            echo "mapbender.conf already exists, not changed"
+          else
+            cp ../../conf/mapbender.conf-dist ../../conf/mapbender.conf
+          fi
+          echo ""
+          echo "please check and edit the entries in your mapbender.conf manually!"
+    fi
-        then
-           echo ""
-           read dbtemplate
-        fi
+function compile_po(){
+    echo ""
+    echo "Compiling .po files..."
+    cd ../../tools/
+    sh ./i18n_update_mo.sh
+    cd ../resources/db/
+    echo "removing permissions on /resources/locale/ and subdirectories"
+    chmod -R o-rw ../locale
+    echo "removing execute rights on mapbender/tools/i18n_update_mo.sh"
+    chmod -R o-rx ../../tools/i18n_update_mo.sh
+    echo ""
-    echo "The script will ask you several times for your database password. Don't be confused about this."
-        if test $dbtemplate != ""
-        then
-           createdb -U $dbuser -E UTF-8 $dbname -T $dbtemplate
-        else
-        fi
-	psql -U $dbuser -f pgsql/UTF-8/pgsql_data_2.5.sql $dbname > log_data.txt
-	psql -U $dbuser -f pgsql/UTF-8/update/update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql $dbname > log_update.txt
-	psql -U $dbuser -f pgsql/UTF-8/update/update_2.5.1rc1_to_2.5.1_pgsql_UTF-8.sql $dbname > log_update.txt
-	psql -U $dbuser -f pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql $dbname > log_update.txt
-	psql -U $dbuser -f pgsql/UTF-8/update/update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql $dbname > log_update.txt
+#magic starts here
+show_disclaimer;
+echo "Continue? (y)es or (n)o"
+read disclaimer
+if test $disclaimer != "y"
+then
+	exit 1
 fi
+get_db_config;
+show_db_config;
+echo "Look ok? Start Install? (y)es or (n)o"
+read ANSWER
+if [ $ANSWER != "y" ]
+then
+    exec $0
+fi
-echo "The installer can set the permissions to the files"
-echo "and directory for you. If you want the installer to"
-echo "do this please enter (y)es else (n)o"
-echo "Please note, to do this you have to be"
-echo "read write access to the Mapbender directory"
-read automatic
-if test $automatic != "n"
+if [ $DBVERSION = "pgsql" ]
 then
-      echo "Do you want that all files are owned by the apache webserver? (y)es or (n)o"
-      read setowner
-      if test $setowner != "n"
-      then
-	    echo "Please specify the webserver user"
-	    read webservuser
-	    chown -R $webservuser:$webservuser ../../
-      fi
-      echo "setting permissions on /resources/locale/ and subdirectories"
-      chmod -R o+rw ../locale
-      echo "setting execute rights on mapbender/tools/i18n_update_mo.sh"
-      chmod -R o+rx ../../tools/i18n_update_mo.sh
-      # creating mapbender.conf
-      cp ../../conf/mapbender.conf-dist ../../conf/mapbender.conf
+    echo "Creating Postgres Database with encoding:$DBENCODING"
+    create_pgsql_db;
+else
+    echo "Creating Mysql Database with encoding:$DBENCODING"
+    create_mysql_db;
+    echo ""
 fi
+set_permissions;
+compile_po;
 echo ""
-echo "Compiling .po files..."
-cd ../../tools/
-./i18n_update_mo.sh
-cd ../resources/db/
-echo "removing permissions on /resources/locale/ and subdirectories"
-chmod -R o-rw ../locale
-echo "removing execute rights on mapbender/tools/i18n_update_mo.sh"
-chmod -R o-rx ../../tools/i18n_update_mo.sh
-echo ""
-echo ""
-echo "Finished...check the log files to see if an error occured.";
+echo "Finished...check the log and error files to see if an error occured.";
Deleted: trunk/mapbender/resources/db/install_2.6rc1.sh
--- trunk/mapbender/resources/db/install_2.6rc1.sh	2009-09-15 15:45:34 UTC (rev 4634)
+++ trunk/mapbender/resources/db/install_2.6rc1.sh	2009-09-15 16:51:14 UTC (rev 4635)
@@ -1,187 +0,0 @@
-#!/bin/bash
-rm log_*.txt
-# Disclaimer
-echo ""
-echo "The script will create a database for you and will import the Mapbender datat to the new database"
-echo ""
-echo " * set the right to execute on this install script"
-echo " * set the right to execute on mapbender/tools/i18n_update_mo.sh"
-echo " * write access to mapbender/log"
-echo " * write access to mapbender/http/tmp"
-echo " * write access to mapbender/resources/locale/ and subdirectories"
-echo ""
-echo ""
-echo ""
-read disclaimer
-then
-	exit 1
-fi
-echo ""
-read dbversion
-then
-	echo ""
-	exit 1
-fi
-echo ""
-read dbenc
-then
-	echo ""
-	exit 1
-fi
-echo ""
-read dbname
-then
-	exit 1
-	echo ""
-	stty -echo
-	read password
-	stty echo
-	echo ""
-	then
-		echo ""
-		echo ""
-	then
-		echo ""
-		echo ""
-	fi
-then
-    	echo ""
-	    echo ""
-        echo ""
-        read dbuser
-        echo ""
-        then
-           echo ""
-           read dbtemplate
-        fi
-        then
-        else
-        fi
-then
-	echo ""
-	echo ""
-        echo ""
-        read dbuser
-        echo ""
-        then
-           echo ""
-           read dbtemplate
-        fi
-        then
-        else
-        fi
-fi
-echo ""
-cd ../../tools/
-echo ""
-echo ""
Added: trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_mysql_ISO-8859-1.sql
--- trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_mysql_ISO-8859-1.sql	                        (rev 0)
+++ trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_mysql_ISO-8859-1.sql	2009-09-15 16:51:14 UTC (rev 4635)
@@ -0,0 +1,495 @@
+UPDATE gui_element SET e_mb_mod = 'map_obj.js,map.js,wms.js,wfs_obj.js,initWms.php' WHERE e_id = 'mapframe1';
+-- new fields for wfs_conf
+ALTER TABLE wfs_conf_element ADD COLUMN f_detailpos int4 DEFAULT 0;
+ALTER TABLE wfs_conf_element ADD COLUMN f_min_input int4 DEFAULT 0;
+-- new element vars for wfs_gazetteer
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'gazetteerWFS', 'showResultInPopup', '1', 'if value is 1 search results will be displayed in popup, otherwise in gazetteer div' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'gazetteerWFS', 'wfs_spatial_request_conf_filename', 'wfs_additional_spatial_search.conf', 'location and name of the WFS configuration file for spatialRequest' ,'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'gazetteerWFS', 'showResultInPopup', '1', 'if value is 1 search results will be displayed in popup, otherwise in gazetteer div' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'gazetteerWFS', 'wfs_spatial_request_conf_filename', 'wfs_additional_spatial_search.conf', 'location and name of the WFS configuration file for spatialRequest' ,'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'gazetteerWFS', 'showResultInPopup', '1', 'if value is 1 search results will be displayed in popup, otherwise in gazetteer div' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'gazetteerWFS', 'wfs_spatial_request_conf_filename', 'wfs_additional_spatial_search.conf', 'location and name of the WFS configuration file for spatialRequest' ,'php_var');
+-- new element vars for body for css style of popups and tablesorter
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'body', 'tablesortercss', '../css/tablesorter.css', 'file css' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'body', 'tablesortercss', '../css/tablesorter.css', 'file css' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'body', 'tablesortercss', '../css/tablesorter.css', 'file css' ,'file/css');
+-- add all used modules for gazetteerWFS
+ALTER TABLE gui_element MODIFY e_mb_mod varchar(100);
+UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/jquery.tablesorter.js' WHERE e_id = 'gazetteerWFS' AND fkey_gui_id = 'gui';
+UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/jquery.tablesorter.js' WHERE e_id = 'gazetteerWFS' AND fkey_gui_id = 'gui2';
+UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/jquery.tablesorter.js' WHERE e_id = 'gazetteerWFS' AND fkey_gui_id = 'gui_digitize';
+-- update wfs configuration Mapbender User (ID: 1) to show new functionality of gazetteerWFS
+UPDATE wfs_conf_element SET f_show_detail = 1, f_detailpos = 1, f_operator = 'rightside' WHERE wfs_conf_element_id = 2 AND fkey_wfs_conf_id = 1;
+UPDATE wfs_conf_element SET f_show_detail = 1, f_detailpos = 2, f_min_input = 1, f_operator = 'bothside' WHERE wfs_conf_element_id = 3 AND fkey_wfs_conf_id = 1;
+UPDATE wfs_conf_element SET f_show_detail = 1, f_detailpos = 3, f_label = 'Organization:', f_label_id = 'd' WHERE wfs_conf_element_id = 5 AND fkey_wfs_conf_id = 1;
+UPDATE wfs_conf_element SET f_show_detail = 1, f_detailpos = 4, f_label = 'URL:', f_label_id = 'd', f_form_element_html = '<a href=""></a>' WHERE wfs_conf_element_id = 6 AND fkey_wfs_conf_id = 1;
+UPDATE wfs_conf_element SET f_search = 1, f_pos = 3, f_style_id = 'c', f_label_id = 'd', f_show_detail = 1, f_detailpos = 5, f_label = 'Usertype:', f_form_element_html = '<select id="usertype" name="usertype">
+<option value="">...</option>
+<option value="1">Company</option>
+<option value="2">Administration</option>
+<option value="3">University</option>
+<option value="4">Individual</option>
+</select>', f_operator = 'equal' WHERE wfs_conf_element_id = 4 AND fkey_wfs_conf_id = 1;
+-- add style class to element var text css of element digitize in gui_digitize
+UPDATE gui_element_vars SET var_value =
+.digitizeGeometryList {position:absolute; top:50px; left:0px;}
+.digitizeGeometryListItem {color:#000000; font-size:10px;}
+body {font-family: Arial, Helvetica, sans-serif; font-size:12px; color:#ff00ff; background-color:#ffffff; margin-top: 0px; margin-left:0px;}
+.button {height:18px; width:32px;}
+WHERE fkey_e_id = 'digitize' AND var_name = 'text css';
+-- http://trac.osgeo.org/mapbender/ticket/336
+UPDATE gui_element SET e_js_file = 'wfs.php', e_target='mapframe1,overview' WHERE e_id = 'wfs';
+UPDATE gui_element SET e_attributes = 'onload="init()"' WHERE e_id = 'body' AND fkey_gui_id IN ('admin1', 'admin2_de', 'admin2_en', 'admin_de_services', 'admin_en_services');
+-- new capabilities diff column for monitoring
+ALTER TABLE mb_monitor ADD COLUMN caps_diff text;
+-- BLOB/Text can't have default value
+-- ALTER TABLE mb_monitor MODIFY COLUMN caps_diff SET DEFAULT '';
+-- scope
+-- ticket #
+-- remove event handlers, are now in the script
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'forward';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'back';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'zoomIn1';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'zoomOut1';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'measure';
+UPDATE gui_element SET e_content = '<div id="mbN" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_n" style="position:relative;top:0;left:0" src="../img/arrows/arrow_n.gif" width="15" height="10">
+</div>
+<div id="mbNE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_ne" style="position:relative;top:0;left:0" src="../img/arrows/arrow_ne.gif" width="10" height="10">
+</div>
+<div id="mbE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_e" style="position:relative;top:0;left:0" src="../img/arrows/arrow_e.gif" width="10" height="15">
+</div>
+<div id="mbSE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_se" style="position:relative;top:0;left:0" src="../img/arrows/arrow_se.gif" width="10" height="10">
+</div>
+<div id="mbS" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_s" style="position:relative;top:0;left:0" src="../img/arrows/arrow_s.gif" width="15" height="10">
+</div>
+<div id="mbSW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_sw" style="position:relative;top:0;left:0" src="../img/arrows/arrow_sw.gif" width="10" height="10">
+</div>
+<div id="mbW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_w" style="position:relative;top:0;left:0" src="../img/arrows/arrow_w.gif" width="10" height="15">
+</div>
+<div id="mbNW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_nw" style="position:relative;top:0;left:0" src="../img/arrows/arrow_nw.gif" width="10" height="10">
+</div>' WHERE e_id = 'navFrame';
+UPDATE gui_element SET e_pos = 1, e_element = 'div', e_src = '', e_attributes = '', e_more_styles = 'overflow:hidden;', e_content = '<div id="markResult" name="maps" style ="position: absolute; left: 0px; top: 0px; width: 0px; height: 0px; z-index:26"> </div>
+<div id="mapframe1_maps" name="maps" style ="position: absolute; left: 0px; top: 0px; width: 0px; height: 0px; z-index:2;"> </div>
+<div id="highlight" style="position:absolute;top:-10px;left:-10px;width:14px;height:14px;z-index:3;visibility:visible"><img src="../img/redball.gif"/></div>
+<div id="l_right" name="l_right" style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:10;visibility:hidden;background-color:#ff0000;cursor: crosshair;"></div>
+<div id="l_bottom"  name="l_bottom" style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:11;visibility:hidden;background-color:#ff0000;cursor: crosshair;"></div>
+<div id="l_left" name="l_left" style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:12;visibility:hidden;background-color:#ff0000;cursor: crosshair;"></div>
+<div id="l_top" name="l_top" style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:13;visibility:hidden;background-color:#ff0000;cursor: crosshair;"></div>
+<div id="sandclock" style="position:absolute; top:0px; left:0px; z-index:14;"></div>
+<div id="scalebar" style="position:absolute; top:0px; left:0px; z-index:15;"></div>
+<div id="measuring" style="position:absolute; top:0px; left:0px; z-index:16; font-size:10px"></div>
+<div id="measure_display" style="position:absolute; top:0px; left:0px; z-index:17;"></div>
+<div id="copyright" style="position:absolute; top:0px; left:0px; z-index:18;"></div>
+<div id="measure_sub" style="position:absolute; top:0px; left:0px; z-index:19;"></div>
+<div id="permanent" style="position:absolute;top:-10px;left:-10px;width:14px;height:14px;z-index:13;visibility:hidden"><img src="../img/redball.gif"/></div>
+<div id="digitize_sub" style="position:absolute; top:0px; left:0px; z-index:24;"></div>
+<div id="digitize_display" style="position:absolute; top:0px; left:0px; z-index:25;"></div>
+<div id="um_title" name="um_title" style="font-family: Arial, Helvetica, sans-serif; DISPLAY:none; OVERFLOW:visible; POSITION:absolute; DISPLAY:none; BACKGROUND:#BEC1C4;border:1px solid black; z-index:98;"></div>
+<div id="um_draw" name="um_draw" style="LEFT:0px;OVERFLOW:visible;POSITION:absolute;TOP:0px;z-index:99;"></div>
+<img id="um_img" name="um_img" style ="position: absolute; left: 0px; top: 0px; width: 0px; height: 0px; border:0;z-index:100" src="../img/transparent.gif" useMap="#um">
+<map name="um" id="um"></map>', e_closetag = 'div', e_js_file = 'mapnf.php' WHERE e_id = 'mapframe1';
+UPDATE gui_element SET e_element = 'div', e_src = '', e_attributes = '', e_more_styles = 'overflow:hidden;', e_content = '<div id="overview_maps" style="position:absolute;left:0px;right:0px;"></div>', e_closetag = 'div', e_js_file = 'ovnf.php', e_target = 'mapframe1', e_requires = 'mapframe1' WHERE e_id = 'overview';
+INSERT INTO gui_element_vars select fkey_gui_id,'overview' as fkey_e_id, 'overview_wms' as var_name, '0' as var_value, 'wms that shows up as overview' as context, 'var' as var_type from gui_element where e_id = 'overview';
+UPDATE gui_element SET e_pos = 2, e_element = 'div', e_more_styles = 'visibility:visible;overflow:scroll', e_content = '', e_closetag = 'div', e_js_file = '../html/mod_treefolderPlain.php', e_mb_mod = 'jsTree.js', e_requires = 'mapframe1' WHERE e_id = 'treeGDE';
+INSERT INTO gui_element_vars select fkey_gui_id,'body' as fkey_e_id, 'treeGDE_css' as var_name, '../css/treeGDE2.css' as var_value, 'cssfile for TreeGDE' as context, 'file/css' as var_type from gui_element where e_id = 'treeGDE';
+UPDATE gui_element SET e_element = 'select', e_src = '', e_attributes = '', e_content = '<option value="">undefined</option>
+<option value="EPSG:4326">EPSG:4326</option>
+<option value="EPSG:31466">EPSG:31466</option>
+<option value="EPSG:31467">EPSG:31467</option>
+<option value="EPSG:31468">EPSG:31468</option>
+<option value="EPSG:31469">EPSG:31469</option>', e_closetag = 'select', e_js_file = 'mod_changeEPSG.php' WHERE e_id = 'changeEPSG';
+DELETE FROM gui_element WHERE e_id = 'closePolygon';
+DELETE FROM gui_element WHERE e_id = 'rubber';
+DELETE FROM gui_element WHERE e_id = 'getArea';
+DELETE FROM gui_element WHERE e_id = 'rubberExt';
+UPDATE gui_element SET e_element = 'div', e_src = '', e_attributes = '', e_more_styles = 'overflow:hidden;', e_content = '', e_closetag = 'div', e_js_file = 'mod_zoomCoords.php', e_target = 'mapframe1,overview', e_requires = 'mapframe1' WHERE e_id = 'zoomCoords';
+-- a demo splash screen for gui1
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'body', 'use_load_message', 'true', '' ,'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'body', 'includeWhileLoading', '../include/gui1_splash.php', '' ,'php_var');
+UPDATE gui_element SET e_mb_mod = '../extensions/wz_jsgraphics.js,geometry.js' WHERE e_id = 'wfs';
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Measure distance', 'Messen');
+UPDATE gui_element SET e_attributes = 'onload="init()"' WHERE e_id = 'body' AND fkey_gui_id IN ('wms_africa', 'wms_australia', 'wms_europe', 'wms_gdi_de', 'wms_germany', 'wms_north_america', 'wms_worldwide');
+-- gui: tab: increase the size of the frames onmouseover
+UPDATE gui_element SET e_attributes = 'frameborder = "0" onmouseover="this.style.zIndex=300;this.style.width=350;" onmouseout="this.style.zIndex=2;this.style.width=200"',
+e_more_styles = 'visibility:hidden; border: 1px solid #a19c8f;' WHERE e_id IN ('treeGDE','printPDF','legend','imprint','meetiongPoint','gazetteerWFS') AND fkey_gui_id IN ('gui');
+UPDATE gui_element SET e_more_styles = e_more_styles || ' background-color:#FFFFFF;' WHERE e_id IN ('treeGDE','imprint') AND fkey_gui_id IN ('gui');
+-- gui_treegde - delete entries which are not needed
+Delete from gui_treegde where fkey_gui_id IN ('gui','gui1','gui2','gui_digitize') and my_layer_title ='new';
+-- new translation entries for portuguese
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Zoom out', 'Zoom -');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Back', 'Zoom previo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Forward', 'Zoom siguiente');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Coordinates', 'Mostrar coordinadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Zoom by rectangle', 'Zoom retángulo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Redraw', 'Refrescar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Query', 'Procurar dados');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Logout', 'Terminar sessão');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'WMS preferences', 'Ajuste WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Adding WMS from filtered list', 'Adicionar WMS desde lista filtrada');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Set map center', 'Centrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Help', 'Ajuda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Show WMS infos', 'Mostrar informação sobre WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Save workspace as web map context document', 'Guardar vista como arquivo Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Resize Mapsize', 'Modificar tamanho do mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Rubber', 'Apagar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Get Area', 'Calcular area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Close Polygon', 'Fechar polígono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Move back to your GUI list', 'Volver a lista WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Legend', 'Legenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Print', 'Imprimir');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Imprint', 'Expediente');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Maps', 'Mapas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Search', 'Procura');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Meetingpoint', 'Lugar de reunião, ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Metadatasearch', 'Procura metadados');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Adding WMS', 'Adicionar WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Adding WMS from List', 'Adicionar WMS desde lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Info', 'Informação');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Change Projection', 'Trocar projeto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Digitize', 'Captura');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Overview', 'Mapa de vição geral');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Drag Mapsize', 'Ampliar janela do mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Mapframe', 'Janela do mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Navigation Frame', 'Janela do navegação');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'scaleSelect', 'Selecionar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Scale Text', 'Texto da escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Scalebar', 'Barra de escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Set Background', 'Pôr fondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Zoom to Coordinates', 'Zoom pra coordinadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Change Password', 'Trocar senha');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Load a web map context document', 'Carregar documento do Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Measure distance', 'Medir distância');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'languaje', 'Selecionar Linguajem');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'navFrame', 'Marco de navegacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'dragMapSize', 'Agrandar Mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Pan', 'Desplazamento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Display complete map', 'Zoom na Extensão Total');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Zoom in', 'Zoom +');
+-- new translation entries for french
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Pan', 'Déplacer la sélection');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Display complete map', 'Afficher toute la carte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Zoom in', 'Zoomer');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Zoom out', 'Dézoomer');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Back', 'Précédent');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Forward', 'Suivant');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Coordinates', 'Afficher les coordonnées');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Zoom by rectangle', 'Zoomer sur la sélection');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Redraw', 'Actualiser [Espace]');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Query', 'Interroger la base de données');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Logout', 'Déconnexion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'WMS preferences', 'Configuration du WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Adding WMS from filtered list', 'Ajouter un WMS de la liste filtrée');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Set map center', 'Définir le centre de la carte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Help', 'Aide');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Show WMS infos', 'Affichage des informations du WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Save workspace as web map context document', 'Sauvegarder la vue/l''espace de travail en tant que Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Resize Mapsize', 'Redimensionner la taille de la carte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Rubber', 'Gomme');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Get Area', 'Calculer la superficie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Close Polygon', 'Fermer le polygone');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Move back to your GUI list', 'Retour à votre liste GUI');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Legend', 'Légende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Print', 'Imprimer');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Imprint', 'Envoyer / Imprint');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Maps', 'Cartes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Search', 'Recherche');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Meetingpoint', 'Point de rencontre');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Metadatasearch', 'Recherche des métadonnées');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Adding WMS', 'Ajouter WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Adding WMS from List', 'Ajouter WMS depuis la liste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Info', 'Info');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Change Projection', 'Changer la projection');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Digitize', 'Numériser');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Overview', 'Carte d''aperçu');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Drag Mapsize', 'Modifier la taille de la carte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Mapframe', 'Fenêtre de la carte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Navigation Frame', 'Fenêtre de navigation');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Scale Select', 'Sélection de l ''échelle');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Scale Text', 'Texte de l''échelle');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Scalebar', 'Echelle graphique');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Set Background', 'Sélectionner la carte d''arrière-plan');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Zoom to Coordinates', 'Zoomer aux coordonnées');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Change Password', 'Changer le mot de passe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Load a web map context document', 'Charger un fichier Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Logo', 'Logo');
+-- entries espaniol
+Update translations set msgstr='Seleccionar Idioma' where locale= 'es' and msgid = 'Set language';
+Update translations set msgstr='Agrandar Mapa' where locale= 'es' and msgid = 'dragMapSize';
+Update translations set msgstr='Marco de navegacion' where locale= 'es' and msgid = 'navFrame';
+Update translations set msgstr='Escala de texto' where locale= 'es' and msgid = 'Scale Text';
+Update translations set msgstr='Barra de escala' where locale= 'es' and msgid = 'Scalebar';
+Update translations set msgstr='Referencia' where locale= 'es' and msgid = 'Legend';
+Update translations set msgstr='Mostrar mapa completo' where locale= 'es' and msgid = 'Display complete map';
+UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js' WHERE e_id = 'setSpatialRequest';
+-- building categories to sort the guis in the login.php
+-- have a look at http://www.mapbender.org/GUI_Category
+-- new tables for category handling
+CREATE TABLE gui_gui_category
+  fkey_gui_id character varying(50),
+  fkey_gui_category_id integer
+) TYPE=InnoDB DEFAULT CHARSET=utf8;
+CREATE TABLE gui_category
+  category_id int(11) NOT NULL auto_increment,
+  category_name character varying(50),
+  category_description character varying(255),
+  CONSTRAINT pk_category_id PRIMARY KEY (category_id)
+ALTER TABLE gui_gui_category
+    ADD CONSTRAINT gui_gui_category_ibfk_2 FOREIGN KEY (fkey_gui_id) REFERENCES gui(gui_id) ON UPDATE CASCADE ON DELETE CASCADE;
+    ADD CONSTRAINT gui_gui_category_ibfk_1 FOREIGN KEY (fkey_gui_category_id) REFERENCES gui_category(category_id) ON UPDATE CASCADE ON DELETE CASCADE;
+INSERT INTO gui_category (category_id, category_name, category_description) VALUES (1, 'Administration', 'Applications for administration');
+INSERT INTO gui_category (category_id, category_name, category_description) VALUES (3, 'WMS Container', NULL);
+INSERT INTO gui_category (category_id, category_name, category_description) VALUES (2, 'Mapbender Template Applications', 'Template Applications');
+INSERT INTO gui_gui_category VALUES ('admin1',1);
+INSERT INTO gui_gui_category VALUES('admin2_de',1);
+INSERT INTO gui_gui_category VALUES('admin2_en',1);
+INSERT INTO gui_gui_category VALUES('admin_de_services',1);
+INSERT INTO gui_gui_category VALUES('admin_en_services',1);
+INSERT INTO gui_gui_category VALUES ('gui',2);
+INSERT INTO gui_gui_category VALUES('gui1',2);
+INSERT INTO gui_gui_category VALUES('gui2',2);
+INSERT INTO gui_gui_category VALUES('gui_digitize',2);
+INSERT INTO gui_gui_category VALUES('wms_gdi_de',3);
+INSERT INTO gui_gui_category VALUES('wms_germany',3);
+INSERT INTO gui_gui_category VALUES('wms_europe',3);
+-- admin2_de background
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_de','headline_GUI_Category',3,1,'Hintergrund GUI Kategorien verwalten','GUI Categories','div','','',5,685,193,66,2,'','GUI Kategorien verwalten','div','','','','','');
+-- admin2_de - create a new category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_de','createCategory',2,1,'create a gui category','Create a new category','a','','href = "../php/mod_createCategory.php?sessionID" target = "AdminFrame" ',8,708,140,20,5,'','GUI Kategorien anlegen','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin2_de', 'createCategory', 'cssfile', '../css/administration_alloc.css', '' ,'file/css');
+-- admin2_de - add a gui to a category, remove it from a category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_de','category_filteredGUI',2,1,'add Gui to Category','Add one user to serveral groups','a','','href = "../php/mod_category_filteredGUI.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,728,190,20,10,'','GUI zu Kategorie zuordnen','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin2_de', 'category_filteredGUI', 'cssfile', '../css/administration_alloc.css', 'css file for admin module' ,'file/css');
+-- admin2_en background
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_en','headline_GUI_Category',3,1,'Hintergrund GUI Kategorien verwalten','GUI Categories','div','','',5,685,193,66,2,'','GUI Category Management','div','','','','','');
+-- admin2_en - create a new category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_en','createCategory',2,1,'create a gui category','Create a new category','a','','href = "../php/mod_createCategory.php?sessionID" target = "AdminFrame" ',8,708,140,20,5,'','create a GUI category','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin2_en', 'createCategory', 'cssfile', '../css/administration_alloc.css', '' ,'file/css');
+-- admin2_en - add a gui to a category, remove it from a category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_en','category_filteredGUI',2,1,'add Gui to Category','Add one user to serveral groups','a','','href = "../php/mod_category_filteredGUI.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,728,190,20,10,'','add GUI to Category','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin2_en', 'category_filteredGUI', 'cssfile', '../css/administration_alloc.css', 'css file for admin module' ,'file/css');
+-- admin1 - create a new category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','createCategory',2,1,'create a gui category','Create a new category','a','','href = "../php/mod_createCategory.php?sessionID" target = "AdminFrame" ',8,1030,140,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','create a GUI category','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin1', 'createCategory', 'cssfile', '../css/administration_alloc.css', '' ,'file/css');
+-- admin1 - add a gui to a category, remove it from a category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','category_filteredGUI',2,1,'add Gui to Category','Add one user to serveral groups','a','','href = "../php/mod_category_filteredGUI.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,1050,190,20,10,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','add GUI to Category','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin1', 'category_filteredGUI', 'cssfile', '../css/administration_alloc.css', 'css file for admin module' ,'file/css');
+-- remove module addWMSfromfilteredList_ajax from every standard gui and set it new with new parameters and new element vars
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui' and e_id = 'addWMSfromfilteredList_ajax';
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_gray/add_filtered_list_off.png','onclick=''var addWmsFromFilteredListPopup = new mb_popup({title:"Add WMS from filtered list",url:"../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID",width:720, height:600,left:20, top:20});addWmsFromFilteredListPopup.show()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js,popup.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'addWMSfromfilteredList_ajax', 'cssfileAddWMS', '../css/addwms.css', '' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'addWMSfromfilteredList_ajax', 'capabilitiesInput', '1', 'load wms by capabilities url' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'addWMSfromfilteredList_ajax', 'option_dball', '1', '1 enables option "load all configured wms from db"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'addWMSfromfilteredList_ajax', 'option_dbgroup', '1', '1 enables option "load configured wms by group"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'addWMSfromfilteredList_ajax', 'option_dbgui', '1', '1 enables option "load configured wms by gui"' ,'var');
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui1' and e_id = 'addWMSfromfilteredList_ajax';
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_gray/add_filtered_list_off.png','onclick=''var addWmsFromFilteredListPopup = new mb_popup({title:"Add WMS from filtered list",url:"../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID",width:720, height:600,left:20, top:20});addWmsFromFilteredListPopup.show()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',620,60,24,24,1,'','','','','mod_addWMSgeneralFunctions.js,popup.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addWMSfromfilteredList_ajax', 'cssfileAddWMS', '../css/addwms.css', '' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addWMSfromfilteredList_ajax', 'capabilitiesInput', '1', 'load wms by capabilities url' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addWMSfromfilteredList_ajax', 'option_dball', '1', '1 enables option "load all configured wms from db"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addWMSfromfilteredList_ajax', 'option_dbgroup', '0', '1 enables option "load configured wms by group"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addWMSfromfilteredList_ajax', 'option_dbgui', '0', '1 enables option "load configured wms by gui"' ,'var');
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui_digitize' and e_id = 'addWMSfromfilteredList_ajax';
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui_digitize','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_gray/add_filtered_list_off.png','onclick=''var addWmsFromFilteredListPopup = new mb_popup({title:"Add WMS from filtered list",url:"../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID",width:720, height:600,left:20, top:20});addWmsFromFilteredListPopup.show()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js,popup.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'addWMSfromfilteredList_ajax', 'cssfileAddWMS', '../css/addwms.css', '' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'addWMSfromfilteredList_ajax', 'capabilitiesInput', '1', 'load wms by capabilities url' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_dball', '1', '1 enables option "load all configured wms from db"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_dbgroup', '0', '1 enables option "load configured wms by group"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_dbgui', '0', '1 enables option "load configured wms by gui"' ,'var');
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui2' and e_id = 'addWMSfromfilteredList_ajax';
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui2','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blue/add_filtered_list_off.png','onclick=''var addWmsFromFilteredListPopup = new mb_popup({title:"Add WMS from filtered list",url:"../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID",width:720, height:600,left:20, top:20});addWmsFromFilteredListPopup.show()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',556,40,28,28,1,'','','','','mod_addWMSgeneralFunctions.js,popup.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'cssfileAddWMS', '../css/addwms.css', '' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'capabilitiesInput', '1', 'load wms by capabilities url' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'option_dball', '1', '1 enables option "load all configured wms from db"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'option_dbgroup', '0', '1 enables option "load configured wms by group"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'option_dbgui', '0', '1 enables option "load configured wms by gui"' ,'var');
+-- set popup.js as required module for gui element loadwmc
+UPDATE gui_element SET e_mb_mod = 'popup.js' WHERE e_id = 'loadwmc';
+-- set popup.js as required module for gui element featureInfoTunnel
+UPDATE gui_element SET e_mb_mod = 'popup.js' WHERE e_id = 'featureInfoTunnel';
+-- set standard element vars for possibility to use popup in featureInfoTunnel; activated for gui_digitize
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfoTunnel', 'featureInfoLayerPopup', 'false', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfoTunnel', 'featureInfoLayerPopup', 'false', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoLayerPopup', 'true', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
+-- increase size
+ALTER TABLE gui_element MODIFY e_js_file varchar(255);
+ALTER TABLE gui_element MODIFY  e_mb_mod  varchar(255);
+ALTER TABLE gui_element MODIFY  e_requires varchar(255);
+-- changed some styles for gui2
+UPDATE gui_element SET e_left = 225 WHERE fkey_gui_id = 'gui2' AND e_id = 'mapframe1';
+UPDATE gui_element SET e_top = 250 WHERE fkey_gui_id = 'gui2' AND e_id = 'tabs';
+UPDATE gui_element SET e_content = '<div id="mbN" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbNE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbSE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbS" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbSW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbNW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>' WHERE fkey_gui_id = 'gui2' AND e_id = 'navFrame';
+-- layer 19011 and 19015 not queryable for gui2 for demo of tooltip
+UPDATE gui_layer SET gui_layer_queryable = 0, gui_layer_querylayer = 0 WHERE fkey_gui_id = 'gui2' AND fkey_layer_id = 19011 AND gui_layer_wms_id = 893;
+UPDATE gui_layer SET gui_layer_queryable = 0, gui_layer_querylayer = 0 WHERE fkey_gui_id = 'gui2' AND fkey_layer_id = 19015 AND gui_layer_wms_id = 893;
+-- tooltip module in gui2 + required gui elements wfs and wfs conf
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','tooltip',1,1,'Tooltip demo modul','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','mod_tooltip.php','popup.js,geometry.js,wfsFilter.js','mapframe1','wfs,wfs_conf,featureInfoTunnel,popup','');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui2','wfs',2,1,'wfs request and result handling','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','wfs.php','../extensions/wz_jsgraphics.js,geometry.js','mapframe1,overview','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'wfs', 'displayWfsResultList', '1', '' ,'var');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui2','wfs_conf',2,1,'get all wfs_conf-params','','iframe','../php/mod_wfs.php','frameborder = "0"',1,1,1,1,NULL ,'visibility:hidden','','iframe','','','','','');
+-- element vars for tooltip
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_destinationFrame', '', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_noResultArray', '["Kein Ergebnis.","<body onload=\"javascript:window.close()\">"]', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_styles', '.list_even{font-size:11px;color:red;}.list_uneven{font-size:11px;color:blue;}', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_styles_detail', '.list_even{font-size:11px;color:green;}.list_uneven{font-size:11px;color:blue;}', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_timeDelay', '1000', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'wfs_conf_filename', 'wfs_default.conf', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_width', '270', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_height', '200', '', 'var');
+-- Update URL to Mapbender help
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/AddWMS' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'addWMS';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Back' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'back';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Copyright' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'copyright';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/DragMapSize' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'dragMapSize';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/DependentDiv' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'dependentDiv';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/FeatureInfo' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'featureInfo1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/FeatureInfoRedirect' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'FeatureInfoRedirect';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/FeatureInfoTunnel' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'featureInfoTunnel';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Forward' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'forward';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/GazetteerWFS' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'gazetteerWFS';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Logout' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'logout';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Mapframe' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'mapframe1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Metadata' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'metadata';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/NavFrame' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'navFrame';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Overview' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'overview';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Pan' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'pan1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Print' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'printPDF';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/SaveWMC' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'savewmc';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/SelArea1' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'selArea1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/SetBackground' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'setBackground';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/ShowCoords_div' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'showCoords_div';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/TreeGde' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'treeGDE';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/WMS_preferences' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'WMS_preferences';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/ZoomFull' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'zoomFull';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/ZoomIn' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'zoomIn1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/ZoomOut' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'zoomOut1';
+-- new language fr, es pt
+Update gui_element_vars set var_value = 'de,en,bg,gr,nl,it,fr,es,pt' where fkey_gui_id = 'gui' AND fkey_e_id = 'switchLocale_noreload';
+-- customisable tree in admin1
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','Customize Tree',0002,1,'Create a set of nested folders that contain the applications WMS','Customize Tree','a','','href = "../php/mod_customTree.php?sessionID" target="AdminFrame"',10,975,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','CUSTOMIZE TREE','a','','','','AdminFrame','');
+-- Bugfix for treegde in gui (tabs wideout)
+UPDATE gui_element SET e_more_styles='visibility:hidden; background-color:#ffffff;border: 1px solid #a19c8f;overflow:auto;' WHERE fkey_gui_id='gui' AND e_id='treeGDE';
+-- remove treeGDE-css statement from 'treeGDE' because its handled in 'body' element
+DELETE  from gui_element_vars WHERE fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND fkey_e_id= 'treeGDE' AND var_name='cssfile';
Property changes on: trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_mysql_ISO-8859-1.sql
___________________________________________________________________
Added: svn:keywords
   + Id
Added: trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.6rc1_to_2.6_mysql_ISO-8859-1.sql
--- trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.6rc1_to_2.6_mysql_ISO-8859-1.sql	                        (rev 0)
+++ trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.6rc1_to_2.6_mysql_ISO-8859-1.sql	2009-09-15 16:51:14 UTC (rev 4635)
@@ -0,0 +1,211 @@
+Update gui_element set e_top = 10 where fkey_gui_id = 'gui' and e_id = 'setBackground';
+Update gui_element_vars set var_value = 'de,en,bg,gr,nl,hu,it,fr,es,pt' where fkey_gui_id = 'gui' AND fkey_e_id = 'switchLocale_noreload';
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Pan', 'Nézetet mozgat');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Display complete map', 'Teljes nézet');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Zoom in', 'Nagyít');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Zoom out', 'Kicsnyít');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Back', 'Vissza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Forward', 'El"ore');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Coordinates', 'Koordináták kijelzése');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Zoom by rectangle', 'Kijelölt területre nagyít');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Redraw', 'Újrarajzol');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Query', 'Adatok lekérése');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Logout', 'Kijelentkezés');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'WMS preferences', 'WMS beállítások');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Adding WMS from filtered list', 'WMS hozzáadása sz"urt listából');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Set map center', 'Nézet középpontja');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Help', 'Segítség');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Show WMS infos', 'WMS adatok megjelenítése');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Save workspace as web map context document', 'Nézet mentése Web Map Context formában');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Resize Mapsize', 'Térkép átméretezése');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Rubber', 'Törlés');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Get Area', 'Területszámítás');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Close Polygon', 'Sokszög bezárása');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Move back to your GUI list', 'Vissza a GUI listához');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Legend', 'Jelmagyarázat');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Print', 'Nyomtat');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Imprint', 'Impresszum');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Maps', 'Térképek');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Search', 'Keres');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Meetingpoint', 'Találkozási pont');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Metadatasearch', 'Metaadat keresés');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Adding WMS', 'WMS hozzáadása');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Adding WMS from List', 'WMS hozzáadása listából');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Info', 'Információ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Change Projection', 'Más vetület választása');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Digitize', 'Digitalizálás');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Overview', 'Átnézeti térkép');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Drag Mapsize', 'Térkép átméretezése');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Mapframe', 'Térképablak');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Navigation Frame', 'Navigációs ablak');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Scale Select', 'Lépték választása');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Scale Text', 'Lépték megadása');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Scalebar', 'Aránymérték');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Set Background', 'Háttér beállítása');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Zoom to Coordinates', 'Ugrás adott koordinátákra');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Change Password', 'Jelszó módosítása');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Load a web map context document', 'Web Map Context dokumentum betöltése');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Logo', 'Logó');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Measure distance', 'Távolságmérés');
+-- http://trac.osgeo.org/mapbender/ticket/442
+DELETE FROM gui_element_vars WHERE fkey_gui_id = 'gui2' AND fkey_e_id = 'tooltip' AND var_name = 'tooltip_noResultArray';
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_noResultArray', '["Kein Ergebnis.","<body onload=\'javascript:window.close()\'>"]', '', 'var');
+-- new element vars for module tooltip to control whether user likes to have wfs getFeature request and/or whether user likes to have wms getfeatureInfo requests
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_disableWfs', '0', 'disable WFS getFeature Request', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_disableWms', '1', 'disable WMS getFeatureInfo Request', 'var');
+-- update style of wfs_conf myPolygons (coloured buttons, background)
+UPDATE wfs_conf SET g_style = 'body{
+ font-family:Verdana,Arial,sans-serif;
+ font-size: 12px;
+ line-height:2;
+ background-color:#CFD2D4;
+.a{
+ font-weight:bold;
+.b{
+ font-size: 12px;
+ font-weight: bold;
+ width:40px;
+ color: #FFFFFF;
+ -moz-border-radius:5px;
+ -khtml-border-radius:5px;
+ background-color: #1874CD;
+ border-color: #1874CD;
+.d{
+ color:#000000;
+.hidden{
+ visibility: hidden;
+.buttonDelFilter{
+ font-size: 12px;
+ width:40px;
+ color:#FFFFFF;
+ background-color: #8B0000;
+ border-color: #8B0000;
+' WHERE wfs_conf_id = 2;
+-- insert statement for switchWMS is in template Guis was missing.
+-- http://trac.osgeo.org/mapbender/ticket/472
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var');
+ALTER TABLE gui_element ALTER COLUMN e_pos SET DEFAULT 2;
+ALTER TABLE gui_element MODIFY COLUMN e_pos tinyint(4) NOT NULL;
+ALTER TABLE gui_element ALTER COLUMN e_public SET DEFAULT 1;
+ALTER TABLE gui_element MODIFY COLUMN e_public tinyint(1) NOT NULL;
+-- new columns for table mb_user (more information fields + validity date fields)
+ALTER TABLE mb_user ADD COLUMN mb_user_realname varchar(100);
+ALTER TABLE mb_user ADD COLUMN mb_user_street varchar(100);
+ALTER TABLE mb_user ADD COLUMN mb_user_housenumber varchar(50);
+ALTER TABLE mb_user ADD COLUMN mb_user_reference varchar(100);
+ALTER TABLE mb_user ADD COLUMN mb_user_for_attention_of varchar(100);
+ALTER TABLE mb_user ADD COLUMN mb_user_valid_from date;
+ALTER TABLE mb_user ADD COLUMN mb_user_valid_to date;
+ALTER TABLE mb_user ADD COLUMN mb_user_password_ticket varchar(100);
+-- enable favicon per gui using element_var
+-- http://trac.osgeo.org/mapbender/ticket/514
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'body', 'favicon', '../img/favicon.png', 'favicon' ,'php_var');
+-- pt update entries for translations table
+update translations set msgid = 'Set language' where msgid = 'languaje' and locale = 'pt';
+update translations set msgstr = 'Selecionar Linguagem' where msgstr = 'Selecionar Linguajem' and locale = 'pt';
+update translations set msgstr = 'Marco de navegação' where msgstr = 'Marco de navegacion' and locale = 'pt';
+update translations set msgstr = 'Zoom seguinte' where msgid = 'Forward' and locale = 'pt';
+update translations set msgstr = 'Zoom para coordinadas' where msgid = 'Zoom to Coordinates' and locale = 'pt';
+update translations set msgid = 'Drag Mapsize' where msgid = 'dragMapSize' and locale = 'pt';
+update translations set msgid = 'Navigation Frame' where msgid = 'navFrame' and locale = 'pt';
+update translations set msgid = 'Scale Select' where msgid = 'scaleSelect' and locale = 'pt';
+-- polish entries for translations table
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Pan', 'Przesu´n');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Display complete map', 'Pokaz cala mape');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom in', 'Powieksz');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom out', 'Pomniejsz');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Back', 'Wró´c');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Forward', 'Do przodu');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Coordinates', 'Wspólrzedne');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom by rectangle', 'Wybierz fragment mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Redraw', 'Zaladuj ponownie');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Query', 'Szukaj danych');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Logout', 'Wymelduj');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'WMS preferences', 'Ustawienia WMS');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS from filtered list', 'Dodaj WMS z listy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set map center', 'Zaznacz ´srodek mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Help', 'Pomoc');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Show WMS infos', 'Informacje WMS');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Save workspace as web map context document', 'Zapisz widok jako web map context dokument');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Resize Mapsize', 'Zmie´n rozmiar mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Rubber', 'Usu´n szkic');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Get Area', 'Oblicz powierzchnie');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Close Polygon', 'Zamknij poligon');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Move back to your GUI list', 'Z powrotem do listy GUI');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Legend', 'Legenda');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Print', 'Drukuj');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Imprint', 'Imprint');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Maps', 'Mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Search', 'Szukaj');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Meetingpoint', 'Miejsce spotka´n');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Metadatasearch', 'Wyszukiwanie metadanych');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS', 'Dodaj WMS');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS from List', 'Dodaj WMS z listy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Info', 'Informacja');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Change Projection', 'Zmie´n uklad wspólrzednych');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Digitize', 'Dygitalizacja');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Overview', 'Mapa przegladowa');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Drag Mapsize', 'Powieksz');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Mapframe', 'Okno mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Navigation Frame', 'Pasek narzedzi');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scale Select', 'Wybierz skale');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scale Text', 'Wpisz skale');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scalebar', 'Podzialka');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set Background', 'Wybierz mape tematyczna jako tlo');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom to Coordinates', 'Powieksz wedlug wspólrzednych');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Change Password', 'Zmie´n haslo');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Load a web map context document', 'Zaladuj web map context dokument');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Measure distance', 'Zmierz odleglo´s´c');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set language', 'Wybierz jezyk');
+-- hungarian entry for translations table
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Set language', 'Másik nyelv...');
+-- italian entry for translations table
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set language', 'Assegnare linguaggio');
+-- dutch entry for translations table
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Set language', 'Taal instellen');
Property changes on: trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.6rc1_to_2.6_mysql_ISO-8859-1.sql
Added: svn:keywords
   + Id
Added: trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.5.1_to_2.6rc1_mysql_UTF-8.sql
--- trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.5.1_to_2.6rc1_mysql_UTF-8.sql	                        (rev 0)
+++ trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.5.1_to_2.6rc1_mysql_UTF-8.sql	2009-09-15 16:51:14 UTC (rev 4635)
@@ -0,0 +1,495 @@
+UPDATE gui_element SET e_mb_mod = 'map_obj.js,map.js,wms.js,wfs_obj.js,initWms.php' WHERE e_id = 'mapframe1';
+-- new fields for wfs_conf
+ALTER TABLE wfs_conf_element ADD COLUMN f_detailpos int4 DEFAULT 0;
+ALTER TABLE wfs_conf_element ADD COLUMN f_min_input int4 DEFAULT 0;
+-- new element vars for wfs_gazetteer
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'gazetteerWFS', 'showResultInPopup', '1', 'if value is 1 search results will be displayed in popup, otherwise in gazetteer div' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'gazetteerWFS', 'wfs_spatial_request_conf_filename', 'wfs_additional_spatial_search.conf', 'location and name of the WFS configuration file for spatialRequest' ,'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'gazetteerWFS', 'showResultInPopup', '1', 'if value is 1 search results will be displayed in popup, otherwise in gazetteer div' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'gazetteerWFS', 'wfs_spatial_request_conf_filename', 'wfs_additional_spatial_search.conf', 'location and name of the WFS configuration file for spatialRequest' ,'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'gazetteerWFS', 'showResultInPopup', '1', 'if value is 1 search results will be displayed in popup, otherwise in gazetteer div' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'gazetteerWFS', 'wfs_spatial_request_conf_filename', 'wfs_additional_spatial_search.conf', 'location and name of the WFS configuration file for spatialRequest' ,'php_var');
+-- new element vars for body for css style of popups and tablesorter
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'body', 'tablesortercss', '../css/tablesorter.css', 'file css' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'body', 'tablesortercss', '../css/tablesorter.css', 'file css' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'body', 'tablesortercss', '../css/tablesorter.css', 'file css' ,'file/css');
+-- add all used modules for gazetteerWFS
+ALTER TABLE gui_element MODIFY e_mb_mod varchar(100);
+UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/jquery.tablesorter.js' WHERE e_id = 'gazetteerWFS' AND fkey_gui_id = 'gui';
+UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/jquery.tablesorter.js' WHERE e_id = 'gazetteerWFS' AND fkey_gui_id = 'gui2';
+UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/jquery.tablesorter.js' WHERE e_id = 'gazetteerWFS' AND fkey_gui_id = 'gui_digitize';
+-- update wfs configuration Mapbender User (ID: 1) to show new functionality of gazetteerWFS
+UPDATE wfs_conf_element SET f_show_detail = 1, f_detailpos = 1, f_operator = 'rightside' WHERE wfs_conf_element_id = 2 AND fkey_wfs_conf_id = 1;
+UPDATE wfs_conf_element SET f_show_detail = 1, f_detailpos = 2, f_min_input = 1, f_operator = 'bothside' WHERE wfs_conf_element_id = 3 AND fkey_wfs_conf_id = 1;
+UPDATE wfs_conf_element SET f_show_detail = 1, f_detailpos = 3, f_label = 'Organization:', f_label_id = 'd' WHERE wfs_conf_element_id = 5 AND fkey_wfs_conf_id = 1;
+UPDATE wfs_conf_element SET f_show_detail = 1, f_detailpos = 4, f_label = 'URL:', f_label_id = 'd', f_form_element_html = '<a href=""></a>' WHERE wfs_conf_element_id = 6 AND fkey_wfs_conf_id = 1;
+UPDATE wfs_conf_element SET f_search = 1, f_pos = 3, f_style_id = 'c', f_label_id = 'd', f_show_detail = 1, f_detailpos = 5, f_label = 'Usertype:', f_form_element_html = '<select id="usertype" name="usertype">
+<option value="">...</option>
+<option value="1">Company</option>
+<option value="2">Administration</option>
+<option value="3">University</option>
+<option value="4">Individual</option>
+</select>', f_operator = 'equal' WHERE wfs_conf_element_id = 4 AND fkey_wfs_conf_id = 1;
+-- add style class to element var text css of element digitize in gui_digitize
+UPDATE gui_element_vars SET var_value =
+.digitizeGeometryList {position:absolute; top:50px; left:0px;}
+.digitizeGeometryListItem {color:#000000; font-size:10px;}
+body {font-family: Arial, Helvetica, sans-serif; font-size:12px; color:#ff00ff; background-color:#ffffff; margin-top: 0px; margin-left:0px;}
+.button {height:18px; width:32px;}
+WHERE fkey_e_id = 'digitize' AND var_name = 'text css';
+-- http://trac.osgeo.org/mapbender/ticket/336
+UPDATE gui_element SET e_js_file = 'wfs.php', e_target='mapframe1,overview' WHERE e_id = 'wfs';
+UPDATE gui_element SET e_attributes = 'onload="init()"' WHERE e_id = 'body' AND fkey_gui_id IN ('admin1', 'admin2_de', 'admin2_en', 'admin_de_services', 'admin_en_services');
+-- new capabilities diff column for monitoring
+ALTER TABLE mb_monitor ADD COLUMN caps_diff text;
+-- BLOB/TEXT can't have default value!
+-- ALTER TABLE mb_monitor ALTER COLUMN caps_diff SET DEFAULT '';
+-- scope
+-- ticket #
+-- remove event handlers, are now in the script
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'forward';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'back';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'zoomIn1';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'zoomOut1';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'measure';
+UPDATE gui_element SET e_content = '<div id="mbN" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_n" style="position:relative;top:0;left:0" src="../img/arrows/arrow_n.gif" width="15" height="10">
+</div>
+<div id="mbNE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_ne" style="position:relative;top:0;left:0" src="../img/arrows/arrow_ne.gif" width="10" height="10">
+</div>
+<div id="mbE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_e" style="position:relative;top:0;left:0" src="../img/arrows/arrow_e.gif" width="10" height="15">
+</div>
+<div id="mbSE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_se" style="position:relative;top:0;left:0" src="../img/arrows/arrow_se.gif" width="10" height="10">
+</div>
+<div id="mbS" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_s" style="position:relative;top:0;left:0" src="../img/arrows/arrow_s.gif" width="15" height="10">
+</div>
+<div id="mbSW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_sw" style="position:relative;top:0;left:0" src="../img/arrows/arrow_sw.gif" width="10" height="10">
+</div>
+<div id="mbW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_w" style="position:relative;top:0;left:0" src="../img/arrows/arrow_w.gif" width="10" height="15">
+</div>
+<div id="mbNW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_nw" style="position:relative;top:0;left:0" src="../img/arrows/arrow_nw.gif" width="10" height="10">
+</div>' WHERE e_id = 'navFrame';
+UPDATE gui_element SET e_pos = 1, e_element = 'div', e_src = '', e_attributes = '', e_more_styles = 'overflow:hidden;', e_content = '<div id="markResult" name="maps" style ="position: absolute; left: 0px; top: 0px; width: 0px; height: 0px; z-index:26"> </div>
+<div id="mapframe1_maps" name="maps" style ="position: absolute; left: 0px; top: 0px; width: 0px; height: 0px; z-index:2;"> </div>
+<div id="highlight" style="position:absolute;top:-10px;left:-10px;width:14px;height:14px;z-index:3;visibility:visible"><img src="../img/redball.gif"/></div>
+<div id="l_right" name="l_right" style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:10;visibility:hidden;background-color:#ff0000;cursor: crosshair;"></div>
+<div id="l_bottom"  name="l_bottom" style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:11;visibility:hidden;background-color:#ff0000;cursor: crosshair;"></div>
+<div id="l_left" name="l_left" style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:12;visibility:hidden;background-color:#ff0000;cursor: crosshair;"></div>
+<div id="l_top" name="l_top" style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:13;visibility:hidden;background-color:#ff0000;cursor: crosshair;"></div>
+<div id="sandclock" style="position:absolute; top:0px; left:0px; z-index:14;"></div>
+<div id="scalebar" style="position:absolute; top:0px; left:0px; z-index:15;"></div>
+<div id="measuring" style="position:absolute; top:0px; left:0px; z-index:16; font-size:10px"></div>
+<div id="measure_display" style="position:absolute; top:0px; left:0px; z-index:17;"></div>
+<div id="copyright" style="position:absolute; top:0px; left:0px; z-index:18;"></div>
+<div id="measure_sub" style="position:absolute; top:0px; left:0px; z-index:19;"></div>
+<div id="permanent" style="position:absolute;top:-10px;left:-10px;width:14px;height:14px;z-index:13;visibility:hidden"><img src="../img/redball.gif"/></div>
+<div id="digitize_sub" style="position:absolute; top:0px; left:0px; z-index:24;"></div>
+<div id="digitize_display" style="position:absolute; top:0px; left:0px; z-index:25;"></div>
+<div id="um_title" name="um_title" style="font-family: Arial, Helvetica, sans-serif; DISPLAY:none; OVERFLOW:visible; POSITION:absolute; DISPLAY:none; BACKGROUND:#BEC1C4;border:1px solid black; z-index:98;"></div>
+<div id="um_draw" name="um_draw" style="LEFT:0px;OVERFLOW:visible;POSITION:absolute;TOP:0px;z-index:99;"></div>
+<img id="um_img" name="um_img" style ="position: absolute; left: 0px; top: 0px; width: 0px; height: 0px; border:0;z-index:100" src="../img/transparent.gif" useMap="#um">
+<map name="um" id="um"></map>', e_closetag = 'div', e_js_file = 'mapnf.php' WHERE e_id = 'mapframe1';
+UPDATE gui_element SET e_element = 'div', e_src = '', e_attributes = '', e_more_styles = 'overflow:hidden;', e_content = '<div id="overview_maps" style="position:absolute;left:0px;right:0px;"></div>', e_closetag = 'div', e_js_file = 'ovnf.php', e_target = 'mapframe1', e_requires = 'mapframe1' WHERE e_id = 'overview';
+INSERT INTO gui_element_vars select fkey_gui_id,'overview' as fkey_e_id, 'overview_wms' as var_name, '0' as var_value, 'wms that shows up as overview' as context, 'var' as var_type from gui_element where e_id = 'overview';
+UPDATE gui_element SET e_pos = 2, e_element = 'div', e_more_styles = 'visibility:visible;overflow:scroll', e_content = '', e_closetag = 'div', e_js_file = '../html/mod_treefolderPlain.php', e_mb_mod = 'jsTree.js', e_requires = 'mapframe1' WHERE e_id = 'treeGDE';
+INSERT INTO gui_element_vars select fkey_gui_id,'body' as fkey_e_id, 'treeGDE_css' as var_name, '../css/treeGDE2.css' as var_value, 'cssfile for TreeGDE' as context, 'file/css' as var_type from gui_element where e_id = 'treeGDE';
+UPDATE gui_element SET e_element = 'select', e_src = '', e_attributes = '', e_content = '<option value="">undefined</option>
+<option value="EPSG:4326">EPSG:4326</option>
+<option value="EPSG:31466">EPSG:31466</option>
+<option value="EPSG:31467">EPSG:31467</option>
+<option value="EPSG:31468">EPSG:31468</option>
+<option value="EPSG:31469">EPSG:31469</option>', e_closetag = 'select', e_js_file = 'mod_changeEPSG.php' WHERE e_id = 'changeEPSG';
+DELETE FROM gui_element WHERE e_id = 'closePolygon';
+DELETE FROM gui_element WHERE e_id = 'rubber';
+DELETE FROM gui_element WHERE e_id = 'getArea';
+DELETE FROM gui_element WHERE e_id = 'rubberExt';
+UPDATE gui_element SET e_element = 'div', e_src = '', e_attributes = '', e_more_styles = 'overflow:hidden;', e_content = '', e_closetag = 'div', e_js_file = 'mod_zoomCoords.php', e_target = 'mapframe1,overview', e_requires = 'mapframe1' WHERE e_id = 'zoomCoords';
+-- a demo splash screen for gui1
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'body', 'use_load_message', 'true', '' ,'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'body', 'includeWhileLoading', '../include/gui1_splash.php', '' ,'php_var');
+UPDATE gui_element SET e_mb_mod = '../extensions/wz_jsgraphics.js,geometry.js' WHERE e_id = 'wfs';
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Measure distance', 'Messen');
+UPDATE gui_element SET e_attributes = 'onload="init()"' WHERE e_id = 'body' AND fkey_gui_id IN ('wms_africa', 'wms_australia', 'wms_europe', 'wms_gdi_de', 'wms_germany', 'wms_north_america', 'wms_worldwide');
+-- gui: tab: increase the size of the frames onmouseover
+UPDATE gui_element SET e_attributes = 'frameborder = "0" onmouseover="this.style.zIndex=300;this.style.width=350;" onmouseout="this.style.zIndex=2;this.style.width=200"',
+e_more_styles = 'visibility:hidden; border: 1px solid #a19c8f;' WHERE e_id IN ('treeGDE','printPDF','legend','imprint','meetiongPoint','gazetteerWFS') AND fkey_gui_id IN ('gui');
+UPDATE gui_element SET e_more_styles = e_more_styles || ' background-color:#FFFFFF;' WHERE e_id IN ('treeGDE','imprint') AND fkey_gui_id IN ('gui');
+-- gui_treegde - delete entries which are not needed
+Delete from gui_treegde where fkey_gui_id IN ('gui','gui1','gui2','gui_digitize') and my_layer_title ='new';
+-- new translation entries for portuguese
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Zoom out', 'Zoom -');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Back', 'Zoom previo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Forward', 'Zoom siguiente');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Coordinates', 'Mostrar coordinadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Zoom by rectangle', 'Zoom retángulo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Redraw', 'Refrescar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Query', 'Procurar dados');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Logout', 'Terminar sessão');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'WMS preferences', 'Ajuste WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Adding WMS from filtered list', 'Adicionar WMS desde lista filtrada');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Set map center', 'Centrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Help', 'Ajuda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Show WMS infos', 'Mostrar informação sobre WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Save workspace as web map context document', 'Guardar vista como arquivo Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Resize Mapsize', 'Modificar tamanho do mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Rubber', 'Apagar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Get Area', 'Calcular area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Close Polygon', 'Fechar polígono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Move back to your GUI list', 'Volver a lista WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Legend', 'Legenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Print', 'Imprimir');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Imprint', 'Expediente');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Maps', 'Mapas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Search', 'Procura');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Meetingpoint', 'Lugar de reunião, ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Metadatasearch', 'Procura metadados');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Adding WMS', 'Adicionar WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Adding WMS from List', 'Adicionar WMS desde lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Info', 'Informação');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Change Projection', 'Trocar projeto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Digitize', 'Captura');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Overview', 'Mapa de vição geral');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Drag Mapsize', 'Ampliar janela do mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Mapframe', 'Janela do mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Navigation Frame', 'Janela do navegação');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'scaleSelect', 'Selecionar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Scale Text', 'Texto da escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Scalebar', 'Barra de escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Set Background', 'Pôr fondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Zoom to Coordinates', 'Zoom pra coordinadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Change Password', 'Trocar senha');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Load a web map context document', 'Carregar documento do Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Measure distance', 'Medir distância');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'languaje', 'Selecionar Linguajem');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'navFrame', 'Marco de navegacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'dragMapSize', 'Agrandar Mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Pan', 'Desplazamento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Display complete map', 'Zoom na Extensão Total');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Zoom in', 'Zoom +');
+-- new translation entries for french
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Pan', 'Déplacer la sélection');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Display complete map', 'Afficher toute la carte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Zoom in', 'Zoomer');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Zoom out', 'Dézoomer');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Back', 'Précédent');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Forward', 'Suivant');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Coordinates', 'Afficher les coordonnées');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Zoom by rectangle', 'Zoomer sur la sélection');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Redraw', 'Actualiser [Espace]');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Query', 'Interroger la base de données');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Logout', 'Déconnexion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'WMS preferences', 'Configuration du WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Adding WMS from filtered list', 'Ajouter un WMS de la liste filtrée');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Set map center', 'Définir le centre de la carte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Help', 'Aide');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Show WMS infos', 'Affichage des informations du WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Save workspace as web map context document', 'Sauvegarder la vue/l''espace de travail en tant que Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Resize Mapsize', 'Redimensionner la taille de la carte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Rubber', 'Gomme');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Get Area', 'Calculer la superficie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Close Polygon', 'Fermer le polygone');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Move back to your GUI list', 'Retour à votre liste GUI');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Legend', 'Légende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Print', 'Imprimer');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Imprint', 'Envoyer / Imprint');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Maps', 'Cartes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Search', 'Recherche');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Meetingpoint', 'Point de rencontre');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Metadatasearch', 'Recherche des métadonnées');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Adding WMS', 'Ajouter WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Adding WMS from List', 'Ajouter WMS depuis la liste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Info', 'Info');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Change Projection', 'Changer la projection');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Digitize', 'Numériser');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Overview', 'Carte d''aperçu');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Drag Mapsize', 'Modifier la taille de la carte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Mapframe', 'Fenêtre de la carte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Navigation Frame', 'Fenêtre de navigation');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Scale Select', 'Sélection de l ''échelle');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Scale Text', 'Texte de l''échelle');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Scalebar', 'Echelle graphique');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Set Background', 'Sélectionner la carte d''arrière-plan');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Zoom to Coordinates', 'Zoomer aux coordonnées');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Change Password', 'Changer le mot de passe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Load a web map context document', 'Charger un fichier Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Logo', 'Logo');
+-- entries espaniol
+Update translations set msgstr='Seleccionar Idioma' where locale= 'es' and msgid = 'Set language';
+Update translations set msgstr='Agrandar Mapa' where locale= 'es' and msgid = 'dragMapSize';
+Update translations set msgstr='Marco de navegacion' where locale= 'es' and msgid = 'navFrame';
+Update translations set msgstr='Escala de texto' where locale= 'es' and msgid = 'Scale Text';
+Update translations set msgstr='Barra de escala' where locale= 'es' and msgid = 'Scalebar';
+Update translations set msgstr='Referencia' where locale= 'es' and msgid = 'Legend';
+Update translations set msgstr='Mostrar mapa completo' where locale= 'es' and msgid = 'Display complete map';
+UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js' WHERE e_id = 'setSpatialRequest';
+-- building categories to sort the guis in the login.php
+-- have a look at http://www.mapbender.org/GUI_Category
+-- new tables for category handling
+CREATE TABLE gui_gui_category
+  fkey_gui_id character varying(50),
+  fkey_gui_category_id integer
+) TYPE=InnoDB;
+CREATE TABLE gui_category
+  category_id int(11) NOT NULL auto_increment,
+  category_name character varying(50),
+  category_description character varying(255),
+  CONSTRAINT pk_category_id PRIMARY KEY (category_id)
+) TYPE=InnoDB;
+ALTER TABLE gui_gui_category
+    ADD CONSTRAINT gui_gui_category_ibfk_2 FOREIGN KEY (fkey_gui_id) REFERENCES gui(gui_id) ON UPDATE CASCADE ON DELETE CASCADE;
+    ADD CONSTRAINT gui_gui_category_ibfk_1 FOREIGN KEY (fkey_gui_category_id) REFERENCES gui_category(category_id) ON UPDATE CASCADE ON DELETE CASCADE;
+INSERT INTO gui_category (category_id, category_name, category_description) VALUES (1, 'Administration', 'Applications for administration');
+INSERT INTO gui_category (category_id, category_name, category_description) VALUES (3, 'WMS Container', NULL);
+INSERT INTO gui_category (category_id, category_name, category_description) VALUES (2, 'Mapbender Template Applications', 'Template Applications');
+INSERT INTO gui_gui_category VALUES ('admin1',1);
+INSERT INTO gui_gui_category VALUES('admin2_de',1);
+INSERT INTO gui_gui_category VALUES('admin2_en',1);
+INSERT INTO gui_gui_category VALUES('admin_de_services',1);
+INSERT INTO gui_gui_category VALUES('admin_en_services',1);
+INSERT INTO gui_gui_category VALUES ('gui',2);
+INSERT INTO gui_gui_category VALUES('gui1',2);
+INSERT INTO gui_gui_category VALUES('gui2',2);
+INSERT INTO gui_gui_category VALUES('gui_digitize',2);
+INSERT INTO gui_gui_category VALUES('wms_gdi_de',3);
+INSERT INTO gui_gui_category VALUES('wms_germany',3);
+INSERT INTO gui_gui_category VALUES('wms_europe',3);
+-- admin2_de background
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_de','headline_GUI_Category',3,1,'Hintergrund GUI Kategorien verwalten','GUI Categories','div','','',5,685,193,66,2,'','GUI Kategorien verwalten','div','','','','','');
+-- admin2_de - create a new category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_de','createCategory',2,1,'create a gui category','Create a new category','a','','href = "../php/mod_createCategory.php?sessionID" target = "AdminFrame" ',8,708,140,20,5,'','GUI Kategorien anlegen','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin2_de', 'createCategory', 'cssfile', '../css/administration_alloc.css', '' ,'file/css');
+-- admin2_de - add a gui to a category, remove it from a category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_de','category_filteredGUI',2,1,'add Gui to Category','Add one user to serveral groups','a','','href = "../php/mod_category_filteredGUI.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,728,190,20,10,'','GUI zu Kategorie zuordnen','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin2_de', 'category_filteredGUI', 'cssfile', '../css/administration_alloc.css', 'css file for admin module' ,'file/css');
+-- admin2_en background
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_en','headline_GUI_Category',3,1,'Hintergrund GUI Kategorien verwalten','GUI Categories','div','','',5,685,193,66,2,'','GUI Category Management','div','','','','','');
+-- admin2_en - create a new category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_en','createCategory',2,1,'create a gui category','Create a new category','a','','href = "../php/mod_createCategory.php?sessionID" target = "AdminFrame" ',8,708,140,20,5,'','create a GUI category','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin2_en', 'createCategory', 'cssfile', '../css/administration_alloc.css', '' ,'file/css');
+-- admin2_en - add a gui to a category, remove it from a category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_en','category_filteredGUI',2,1,'add Gui to Category','Add one user to serveral groups','a','','href = "../php/mod_category_filteredGUI.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,728,190,20,10,'','add GUI to Category','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin2_en', 'category_filteredGUI', 'cssfile', '../css/administration_alloc.css', 'css file for admin module' ,'file/css');
+-- admin1 - create a new category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','createCategory',2,1,'create a gui category','Create a new category','a','','href = "../php/mod_createCategory.php?sessionID" target = "AdminFrame" ',8,1030,140,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','create a GUI category','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin1', 'createCategory', 'cssfile', '../css/administration_alloc.css', '' ,'file/css');
+-- admin1 - add a gui to a category, remove it from a category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','category_filteredGUI',2,1,'add Gui to Category','Add one user to serveral groups','a','','href = "../php/mod_category_filteredGUI.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,1050,190,20,10,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','add GUI to Category','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin1', 'category_filteredGUI', 'cssfile', '../css/administration_alloc.css', 'css file for admin module' ,'file/css');
+-- remove module addWMSfromfilteredList_ajax from every standard gui and set it new with new parameters and new element vars
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui' and e_id = 'addWMSfromfilteredList_ajax';
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_gray/add_filtered_list_off.png','onclick=''var addWmsFromFilteredListPopup = new mb_popup({title:"Add WMS from filtered list",url:"../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID",width:720, height:600,left:20, top:20});addWmsFromFilteredListPopup.show()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js,popup.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'addWMSfromfilteredList_ajax', 'cssfileAddWMS', '../css/addwms.css', '' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'addWMSfromfilteredList_ajax', 'capabilitiesInput', '1', 'load wms by capabilities url' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'addWMSfromfilteredList_ajax', 'option_dball', '1', '1 enables option "load all configured wms from db"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'addWMSfromfilteredList_ajax', 'option_dbgroup', '1', '1 enables option "load configured wms by group"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'addWMSfromfilteredList_ajax', 'option_dbgui', '1', '1 enables option "load configured wms by gui"' ,'var');
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui1' and e_id = 'addWMSfromfilteredList_ajax';
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_gray/add_filtered_list_off.png','onclick=''var addWmsFromFilteredListPopup = new mb_popup({title:"Add WMS from filtered list",url:"../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID",width:720, height:600,left:20, top:20});addWmsFromFilteredListPopup.show()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',620,60,24,24,1,'','','','','mod_addWMSgeneralFunctions.js,popup.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addWMSfromfilteredList_ajax', 'cssfileAddWMS', '../css/addwms.css', '' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addWMSfromfilteredList_ajax', 'capabilitiesInput', '1', 'load wms by capabilities url' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addWMSfromfilteredList_ajax', 'option_dball', '1', '1 enables option "load all configured wms from db"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addWMSfromfilteredList_ajax', 'option_dbgroup', '0', '1 enables option "load configured wms by group"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addWMSfromfilteredList_ajax', 'option_dbgui', '0', '1 enables option "load configured wms by gui"' ,'var');
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui_digitize' and e_id = 'addWMSfromfilteredList_ajax';
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui_digitize','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_gray/add_filtered_list_off.png','onclick=''var addWmsFromFilteredListPopup = new mb_popup({title:"Add WMS from filtered list",url:"../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID",width:720, height:600,left:20, top:20});addWmsFromFilteredListPopup.show()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js,popup.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'addWMSfromfilteredList_ajax', 'cssfileAddWMS', '../css/addwms.css', '' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'addWMSfromfilteredList_ajax', 'capabilitiesInput', '1', 'load wms by capabilities url' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_dball', '1', '1 enables option "load all configured wms from db"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_dbgroup', '0', '1 enables option "load configured wms by group"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_dbgui', '0', '1 enables option "load configured wms by gui"' ,'var');
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui2' and e_id = 'addWMSfromfilteredList_ajax';
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui2','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blue/add_filtered_list_off.png','onclick=''var addWmsFromFilteredListPopup = new mb_popup({title:"Add WMS from filtered list",url:"../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID",width:720, height:600,left:20, top:20});addWmsFromFilteredListPopup.show()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',556,40,28,28,1,'','','','','mod_addWMSgeneralFunctions.js,popup.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'cssfileAddWMS', '../css/addwms.css', '' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'capabilitiesInput', '1', 'load wms by capabilities url' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'option_dball', '1', '1 enables option "load all configured wms from db"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'option_dbgroup', '0', '1 enables option "load configured wms by group"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'option_dbgui', '0', '1 enables option "load configured wms by gui"' ,'var');
+-- set popup.js as required module for gui element loadwmc
+UPDATE gui_element SET e_mb_mod = 'popup.js' WHERE e_id = 'loadwmc';
+-- set popup.js as required module for gui element featureInfoTunnel
+UPDATE gui_element SET e_mb_mod = 'popup.js' WHERE e_id = 'featureInfoTunnel';
+-- set standard element vars for possibility to use popup in featureInfoTunnel; activated for gui_digitize
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfoTunnel', 'featureInfoLayerPopup', 'false', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfoTunnel', 'featureInfoLayerPopup', 'false', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoLayerPopup', 'true', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
+-- increase size
+ALTER TABLE gui_element MODIFY e_js_file varchar(255);
+ALTER TABLE gui_element MODIFY e_mb_mod  varchar(255);
+ALTER TABLE gui_element MODIFY e_requires  varchar(255);
+-- changed some styles for gui2
+UPDATE gui_element SET e_left = 225 WHERE fkey_gui_id = 'gui2' AND e_id = 'mapframe1';
+UPDATE gui_element SET e_top = 250 WHERE fkey_gui_id = 'gui2' AND e_id = 'tabs';
+UPDATE gui_element SET e_content = '<div id="mbN" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbNE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbSE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbS" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbSW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbNW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>' WHERE fkey_gui_id = 'gui2' AND e_id = 'navFrame';
+-- layer 19011 and 19015 not queryable for gui2 for demo of tooltip
+UPDATE gui_layer SET gui_layer_queryable = 0, gui_layer_querylayer = 0 WHERE fkey_gui_id = 'gui2' AND fkey_layer_id = 19011 AND gui_layer_wms_id = 893;
+UPDATE gui_layer SET gui_layer_queryable = 0, gui_layer_querylayer = 0 WHERE fkey_gui_id = 'gui2' AND fkey_layer_id = 19015 AND gui_layer_wms_id = 893;
+-- tooltip module in gui2 + required gui elements wfs and wfs conf
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','tooltip',1,1,'Tooltip demo modul','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','mod_tooltip.php','popup.js,geometry.js,wfsFilter.js','mapframe1','wfs,wfs_conf,featureInfoTunnel,popup','');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui2','wfs',2,1,'wfs request and result handling','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','wfs.php','../extensions/wz_jsgraphics.js,geometry.js','mapframe1,overview','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'wfs', 'displayWfsResultList', '1', '' ,'var');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui2','wfs_conf',2,1,'get all wfs_conf-params','','iframe','../php/mod_wfs.php','frameborder = "0"',1,1,1,1,NULL ,'visibility:hidden','','iframe','','','','','');
+-- element vars for tooltip
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_destinationFrame', '', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_noResultArray', '["Kein Ergebnis.","<body onload=\"javascript:window.close()\">"]', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_styles', '.list_even{font-size:11px;color:red;}.list_uneven{font-size:11px;color:blue;}', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_styles_detail', '.list_even{font-size:11px;color:green;}.list_uneven{font-size:11px;color:blue;}', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_timeDelay', '1000', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'wfs_conf_filename', 'wfs_default.conf', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_width', '270', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_height', '200', '', 'var');
+-- Update URL to Mapbender help
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/AddWMS' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'addWMS';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Back' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'back';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Copyright' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'copyright';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/DragMapSize' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'dragMapSize';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/DependentDiv' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'dependentDiv';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/FeatureInfo' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'featureInfo1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/FeatureInfoRedirect' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'FeatureInfoRedirect';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/FeatureInfoTunnel' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'featureInfoTunnel';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Forward' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'forward';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/GazetteerWFS' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'gazetteerWFS';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Logout' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'logout';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Mapframe' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'mapframe1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Metadata' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'metadata';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/NavFrame' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'navFrame';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Overview' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'overview';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Pan' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'pan1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Print' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'printPDF';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/SaveWMC' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'savewmc';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/SelArea1' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'selArea1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/SetBackground' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'setBackground';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/ShowCoords_div' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'showCoords_div';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/TreeGde' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'treeGDE';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/WMS_preferences' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'WMS_preferences';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/ZoomFull' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'zoomFull';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/ZoomIn' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'zoomIn1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/ZoomOut' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'zoomOut1';
+-- new language fr, es pt
+Update gui_element_vars set var_value = 'de,en,bg,gr,nl,it,fr,es,pt' where fkey_gui_id = 'gui' AND fkey_e_id = 'switchLocale_noreload';
+-- customisable tree in admin1
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','Customize Tree',0002,1,'Create a set of nested folders that contain the applications WMS','Customize Tree','a','','href = "../php/mod_customTree.php?sessionID" target="AdminFrame"',10,975,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','CUSTOMIZE TREE','a','','','','AdminFrame','');
+-- Bugfix for treegde in gui (tabs wideout)
+UPDATE gui_element SET e_more_styles='visibility:hidden; background-color:#ffffff;border: 1px solid #a19c8f;overflow:auto;' WHERE fkey_gui_id='gui' AND e_id='treeGDE';
+-- remove treeGDE-css statement from 'treeGDE' because its handled in 'body' element
+DELETE  from gui_element_vars WHERE fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND fkey_e_id= 'treeGDE' AND var_name='cssfile';
Property changes on: trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.5.1_to_2.6rc1_mysql_UTF-8.sql
___________________________________________________________________
Added: svn:keywords
   + Id
Added: trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.6rc1_to_2.6_mysql_UTF-8.sql
--- trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.6rc1_to_2.6_mysql_UTF-8.sql	                        (rev 0)
+++ trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.6rc1_to_2.6_mysql_UTF-8.sql	2009-09-15 16:51:14 UTC (rev 4635)
@@ -0,0 +1,210 @@
+Update gui_element set e_top = 10 where fkey_gui_id = 'gui' and e_id = 'setBackground';
+Update gui_element_vars set var_value = 'de,en,bg,gr,nl,hu,it,fr,es,pt' where fkey_gui_id = 'gui' AND fkey_e_id = 'switchLocale_noreload';
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Pan', 'Nézetet mozgat');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Display complete map', 'Teljes nézet');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Zoom in', 'Nagyít');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Zoom out', 'Kicsnyít');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Back', 'Vissza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Forward', 'Előre');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Coordinates', 'Koordináták kijelzése');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Zoom by rectangle', 'Kijelölt területre nagyít');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Redraw', 'Újrarajzol');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Query', 'Adatok lekérése');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Logout', 'Kijelentkezés');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'WMS preferences', 'WMS beállítások');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Adding WMS from filtered list', 'WMS hozzáadása szűrt listából');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Set map center', 'Nézet középpontja');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Help', 'Segítség');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Show WMS infos', 'WMS adatok megjelenítése');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Save workspace as web map context document', 'Nézet mentése Web Map Context formában');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Resize Mapsize', 'Térkép átméretezése');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Rubber', 'Törlés');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Get Area', 'Területszámítás');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Close Polygon', 'Sokszög bezárása');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Move back to your GUI list', 'Vissza a GUI listához');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Legend', 'Jelmagyarázat');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Print', 'Nyomtat');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Imprint', 'Impresszum');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Maps', 'Térképek');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Search', 'Keres');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Meetingpoint', 'Találkozási pont');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Metadatasearch', 'Metaadat keresés');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Adding WMS', 'WMS hozzáadása');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Adding WMS from List', 'WMS hozzáadása listából');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Info', 'Információ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Change Projection', 'Más vetület választása');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Digitize', 'Digitalizálás');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Overview', 'Átnézeti térkép');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Drag Mapsize', 'Térkép átméretezése');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Mapframe', 'Térképablak');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Navigation Frame', 'Navigációs ablak');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Scale Select', 'Lépték választása');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Scale Text', 'Lépték megadása');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Scalebar', 'Aránymérték');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Set Background', 'Háttér beállítása');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Zoom to Coordinates', 'Ugrás adott koordinátákra');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Change Password', 'Jelszó módosítása');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Load a web map context document', 'Web Map Context dokumentum betöltése');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Logo', 'Logó');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Measure distance', 'Távolságmérés');
+-- http://trac.osgeo.org/mapbender/ticket/442
+DELETE FROM gui_element_vars WHERE fkey_gui_id = 'gui2' AND fkey_e_id = 'tooltip' AND var_name = 'tooltip_noResultArray';
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_noResultArray', '["Kein Ergebnis.","<body onload=\'javascript:window.close()\'>"]', '', 'var');
+-- new element vars for module tooltip to control whether user likes to have wfs getFeature request and/or whether user likes to have wms getfeatureInfo requests
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_disableWfs', '0', 'disable WFS getFeature Request', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_disableWms', '1', 'disable WMS getFeatureInfo Request', 'var');
+-- update style of wfs_conf myPolygons (coloured buttons, background)
+UPDATE wfs_conf SET g_style = 'body{
+ font-family:Verdana,Arial,sans-serif;
+ font-size: 12px;
+ line-height:2;
+ background-color:#CFD2D4;
+.a{
+ font-weight:bold;
+.b{
+ font-size: 12px;
+ font-weight: bold;
+ width:40px;
+ color: #FFFFFF;
+ -moz-border-radius:5px;
+ -khtml-border-radius:5px;
+ background-color: #1874CD;
+ border-color: #1874CD;
+.d{
+ color:#000000;
+.hidden{
+ visibility: hidden;
+.buttonDelFilter{
+ font-size: 12px;
+ width:40px;
+ color:#FFFFFF;
+ background-color: #8B0000;
+ border-color: #8B0000;
+' WHERE wfs_conf_id = 2;
+-- insert statement for switchWMS is in template Guis was missing.
+-- http://trac.osgeo.org/mapbender/ticket/472
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var');
+ALTER TABLE gui_element ALTER COLUMN e_pos SET DEFAULT 2;
+ALTER TABLE gui_element MODIFY COLUMN e_pos tinyint(4) NOT NULL;
+ALTER TABLE gui_element ALTER COLUMN e_public SET DEFAULT 1;
+ALTER TABLE gui_element MODIFY COLUMN e_public tinyint(1) NOT NULL;
+-- new columns for table mb_user (more information fields + validity date fields)
+ALTER TABLE mb_user ADD COLUMN mb_user_realname varchar(100);
+ALTER TABLE mb_user ADD COLUMN mb_user_street varchar(100);
+ALTER TABLE mb_user ADD COLUMN mb_user_housenumber varchar(50);
+ALTER TABLE mb_user ADD COLUMN mb_user_reference varchar(100);
+ALTER TABLE mb_user ADD COLUMN mb_user_for_attention_of varchar(100);
+ALTER TABLE mb_user ADD COLUMN mb_user_valid_from date;
+ALTER TABLE mb_user ADD COLUMN mb_user_valid_to date;
+ALTER TABLE mb_user ADD COLUMN mb_user_password_ticket varchar(100);
+-- enable favicon per gui using element_var
+-- http://trac.osgeo.org/mapbender/ticket/514
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'body', 'favicon', '../img/favicon.png', 'favicon' ,'php_var');
+-- pt update entries for translations table
+update translations set msgid = 'Set language' where msgid = 'languaje' and locale = 'pt';
+update translations set msgstr = 'Selecionar Linguagem' where msgstr = 'Selecionar Linguajem' and locale = 'pt';
+update translations set msgstr = 'Marco de navegação' where msgstr = 'Marco de navegacion' and locale = 'pt';
+update translations set msgstr = 'Zoom seguinte' where msgid = 'Forward' and locale = 'pt';
+update translations set msgstr = 'Zoom para coordinadas' where msgid = 'Zoom to Coordinates' and locale = 'pt';
+update translations set msgid = 'Drag Mapsize' where msgid = 'dragMapSize' and locale = 'pt';
+update translations set msgid = 'Navigation Frame' where msgid = 'navFrame' and locale = 'pt';
+update translations set msgid = 'Scale Select' where msgid = 'scaleSelect' and locale = 'pt';
+-- polish entries for translations table
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Pan', 'Przesuń');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Display complete map', 'Pokaż calą mapę');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom in', 'Powiększ');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom out', 'Pomniejsz');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Back', 'Wróć');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Forward', 'Do przodu');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Coordinates', 'Współrzędne');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom by rectangle', 'Wybierz fragment mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Redraw', 'Załaduj ponownie');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Query', 'Szukaj danych');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Logout', 'Wymelduj');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'WMS preferences', 'Ustawienia WMS');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS from filtered list', 'Dodaj WMS z listy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set map center', 'Zaznacz środek mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Help', 'Pomoc');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Show WMS infos', 'Informacje WMS');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Save workspace as web map context document', 'Zapisz widok jako web map context dokument');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Resize Mapsize', 'Zmień rozmiar mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Rubber', 'Usuń szkic');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Get Area', 'Oblicz powierzchniÄ™');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Close Polygon', 'Zamknij poligon');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Move back to your GUI list', 'Z powrotem do listy GUI');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Legend', 'Legenda');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Print', 'Drukuj');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Imprint', 'Imprint');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Maps', 'Mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Search', 'Szukaj');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Meetingpoint', 'Miejsce spotkań');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Metadatasearch', 'Wyszukiwanie metadanych');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS', 'Dodaj WMS');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS from List', 'Dodaj WMS z listy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Info', 'Informacja');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Change Projection', 'Zmień układ współrzędnych');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Digitize', 'Dygitalizacja');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Overview', 'Mapa przeglÄ…dowa');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Drag Mapsize', 'Powiększ');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Mapframe', 'Okno mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Navigation Frame', 'Pasek narzędzi');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scale Select', 'Wybierz skalÄ™');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scale Text', 'Wpisz skalÄ™');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scalebar', 'Podziałka');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set Background', 'Wybierz mapę tematyczną jako tło');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom to Coordinates', 'Powiększ według współrzędnych');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Change Password', 'Zmień hasło');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Load a web map context document', 'Załaduj web map context dokument');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Measure distance', 'Zmierz odległość');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set language', 'Wybierz język');
+-- hungarian entry for translations table
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Set language', 'Másik nyelv...');
+-- italian entry for translations table
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set language', 'Assegnare linguaggio');
+-- dutch entry for translations table
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Set language', 'Taal instellen');
Property changes on: trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.6rc1_to_2.6_mysql_UTF-8.sql
Added: svn:keywords
   + Id
Added: trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_pgsql_ISO-8859-1.sql
--- trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_pgsql_ISO-8859-1.sql	                        (rev 0)
+++ trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_pgsql_ISO-8859-1.sql	2009-09-15 16:51:14 UTC (rev 4635)
@@ -0,0 +1,496 @@
+UPDATE gui_element SET e_mb_mod = 'map_obj.js,map.js,wms.js,wfs_obj.js,initWms.php' WHERE e_id = 'mapframe1';
+--new fields for wfs_conf
+ALTER TABLE wfs_conf_element ADD COLUMN f_detailpos int4 DEFAULT 0;
+ALTER TABLE wfs_conf_element ADD COLUMN f_min_input int4 DEFAULT 0;
+--new element vars for wfs_gazetteer
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'gazetteerWFS', 'showResultInPopup', '1', 'if value is 1 search results will be displayed in popup, otherwise in gazetteer div' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'gazetteerWFS', 'wfs_spatial_request_conf_filename', 'wfs_additional_spatial_search.conf', 'location and name of the WFS configuration file for spatialRequest' ,'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'gazetteerWFS', 'showResultInPopup', '1', 'if value is 1 search results will be displayed in popup, otherwise in gazetteer div' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'gazetteerWFS', 'wfs_spatial_request_conf_filename', 'wfs_additional_spatial_search.conf', 'location and name of the WFS configuration file for spatialRequest' ,'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'gazetteerWFS', 'showResultInPopup', '1', 'if value is 1 search results will be displayed in popup, otherwise in gazetteer div' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'gazetteerWFS', 'wfs_spatial_request_conf_filename', 'wfs_additional_spatial_search.conf', 'location and name of the WFS configuration file for spatialRequest' ,'php_var');
+--new element vars for body for css style of popups and tablesorter
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'body', 'tablesortercss', '../css/tablesorter.css', 'file css' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'body', 'tablesortercss', '../css/tablesorter.css', 'file css' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'body', 'tablesortercss', '../css/tablesorter.css', 'file css' ,'file/css');
+--add all used modules for gazetteerWFS
+ALTER TABLE gui_element ALTER e_mb_mod TYPE varchar(100);
+UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/jquery.tablesorter.js' WHERE e_id = 'gazetteerWFS' AND fkey_gui_id = 'gui';
+UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/jquery.tablesorter.js' WHERE e_id = 'gazetteerWFS' AND fkey_gui_id = 'gui2';
+UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/jquery.tablesorter.js' WHERE e_id = 'gazetteerWFS' AND fkey_gui_id = 'gui_digitize';
+-- update wfs configuration Mapbender User (ID: 1) to show new functionality of gazetteerWFS
+UPDATE wfs_conf_element SET f_show_detail = 1, f_detailpos = 1, f_operator = 'rightside' WHERE wfs_conf_element_id = 2 AND fkey_wfs_conf_id = 1;
+UPDATE wfs_conf_element SET f_show_detail = 1, f_detailpos = 2, f_min_input = 1, f_operator = 'bothside' WHERE wfs_conf_element_id = 3 AND fkey_wfs_conf_id = 1;
+UPDATE wfs_conf_element SET f_show_detail = 1, f_detailpos = 3, f_label = 'Organization:', f_label_id = 'd' WHERE wfs_conf_element_id = 5 AND fkey_wfs_conf_id = 1;
+UPDATE wfs_conf_element SET f_show_detail = 1, f_detailpos = 4, f_label = 'URL:', f_label_id = 'd', f_form_element_html = '<a href=""></a>' WHERE wfs_conf_element_id = 6 AND fkey_wfs_conf_id = 1;
+UPDATE wfs_conf_element SET f_search = 1, f_pos = 3, f_style_id = 'c', f_label_id = 'd', f_show_detail = 1, f_detailpos = 5, f_label = 'Usertype:', f_form_element_html = '<select id="usertype" name="usertype">
+<option value="">...</option>
+<option value="1">Company</option>
+<option value="2">Administration</option>
+<option value="3">University</option>
+<option value="4">Individual</option>
+</select>', f_operator = 'equal' WHERE wfs_conf_element_id = 4 AND fkey_wfs_conf_id = 1;
+--add style class to element var text css of element digitize in gui_digitize
+UPDATE gui_element_vars SET var_value =
+.digitizeGeometryList {position:absolute; top:50px; left:0px;}
+.digitizeGeometryListItem {color:#000000; font-size:10px;}
+body {font-family: Arial, Helvetica, sans-serif; font-size:12px; color:#ff00ff; background-color:#ffffff; margin-top: 0px; margin-left:0px;}
+.button {height:18px; width:32px;}
+WHERE fkey_e_id = 'digitize' AND var_name = 'text css';
+-- http://trac.osgeo.org/mapbender/ticket/336
+UPDATE gui_element SET e_js_file = 'wfs.php', e_target='mapframe1,overview' WHERE e_id = 'wfs';
+UPDATE gui_element SET e_attributes = 'onload="init()"' WHERE e_id = 'body' AND fkey_gui_id IN ('admin1', 'admin2_de', 'admin2_en', 'admin_de_services', 'admin_en_services');
+-- new capabilities diff column for monitoring
+ALTER TABLE mb_monitor ADD COLUMN caps_diff text;
+ALTER TABLE mb_monitor ALTER COLUMN caps_diff SET DEFAULT ''::text;
+-- scope
+-- ticket #
+-- remove event handlers, are now in the script
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'forward';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'back';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'zoomIn1';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'zoomOut1';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'measure';
+UPDATE gui_element SET e_content = '<div id="mbN" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_n" style="position:relative;top:0;left:0" src="../img/arrows/arrow_n.gif" width="15" height="10">
+</div>
+<div id="mbNE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_ne" style="position:relative;top:0;left:0" src="../img/arrows/arrow_ne.gif" width="10" height="10">
+</div>
+<div id="mbE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_e" style="position:relative;top:0;left:0" src="../img/arrows/arrow_e.gif" width="10" height="15">
+</div>
+<div id="mbSE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_se" style="position:relative;top:0;left:0" src="../img/arrows/arrow_se.gif" width="10" height="10">
+</div>
+<div id="mbS" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_s" style="position:relative;top:0;left:0" src="../img/arrows/arrow_s.gif" width="15" height="10">
+</div>
+<div id="mbSW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_sw" style="position:relative;top:0;left:0" src="../img/arrows/arrow_sw.gif" width="10" height="10">
+</div>
+<div id="mbW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_w" style="position:relative;top:0;left:0" src="../img/arrows/arrow_w.gif" width="10" height="15">
+</div>
+<div id="mbNW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_nw" style="position:relative;top:0;left:0" src="../img/arrows/arrow_nw.gif" width="10" height="10">
+</div>' WHERE e_id = 'navFrame';
+UPDATE gui_element SET e_pos = 1, e_element = 'div', e_src = '', e_attributes = '', e_more_styles = 'overflow:hidden;', e_content = '<div id="markResult" name="maps" style ="position: absolute; left: 0px; top: 0px; width: 0px; height: 0px; z-index:26"> </div>
+<div id="mapframe1_maps" name="maps" style ="position: absolute; left: 0px; top: 0px; width: 0px; height: 0px; z-index:2;"> </div>
+<div id="highlight" style="position:absolute;top:-10px;left:-10px;width:14px;height:14px;z-index:3;visibility:visible"><img src="../img/redball.gif"/></div>
+<div id="l_right" name="l_right" style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:10;visibility:hidden;background-color:#ff0000;cursor: crosshair;"></div>
+<div id="l_bottom"  name="l_bottom" style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:11;visibility:hidden;background-color:#ff0000;cursor: crosshair;"></div>
+<div id="l_left" name="l_left" style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:12;visibility:hidden;background-color:#ff0000;cursor: crosshair;"></div>
+<div id="l_top" name="l_top" style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:13;visibility:hidden;background-color:#ff0000;cursor: crosshair;"></div>
+<div id="sandclock" style="position:absolute; top:0px; left:0px; z-index:14;"></div>
+<div id="scalebar" style="position:absolute; top:0px; left:0px; z-index:15;"></div>
+<div id="measuring" style="position:absolute; top:0px; left:0px; z-index:16; font-size:10px"></div>
+<div id="measure_display" style="position:absolute; top:0px; left:0px; z-index:17;"></div>
+<div id="copyright" style="position:absolute; top:0px; left:0px; z-index:18;"></div>
+<div id="measure_sub" style="position:absolute; top:0px; left:0px; z-index:19;"></div>
+<div id="permanent" style="position:absolute;top:-10px;left:-10px;width:14px;height:14px;z-index:13;visibility:hidden"><img src="../img/redball.gif"/></div>
+<div id="digitize_sub" style="position:absolute; top:0px; left:0px; z-index:24;"></div>
+<div id="digitize_display" style="position:absolute; top:0px; left:0px; z-index:25;"></div>
+<div id="um_title" name="um_title" style="font-family: Arial, Helvetica, sans-serif; DISPLAY:none; OVERFLOW:visible; POSITION:absolute; DISPLAY:none; BACKGROUND:#BEC1C4;border:1px solid black; z-index:98;"></div>
+<div id="um_draw" name="um_draw" style="LEFT:0px;OVERFLOW:visible;POSITION:absolute;TOP:0px;z-index:99;"></div>
+<img id="um_img" name="um_img" style ="position: absolute; left: 0px; top: 0px; width: 0px; height: 0px; border:0;z-index:100" src="../img/transparent.gif" useMap="#um">
+<map name="um" id="um"></map>', e_closetag = 'div', e_js_file = 'mapnf.php' WHERE e_id = 'mapframe1';
+UPDATE gui_element SET e_element = 'div', e_src = '', e_attributes = '', e_more_styles = 'overflow:hidden;', e_content = '<div id="overview_maps" style="position:absolute;left:0px;right:0px;"></div>', e_closetag = 'div', e_js_file = 'ovnf.php', e_target = 'mapframe1', e_requires = 'mapframe1' WHERE e_id = 'overview';
+INSERT INTO gui_element_vars select fkey_gui_id,'overview' as fkey_e_id, 'overview_wms' as var_name, '0' as var_value, 'wms that shows up as overview' as context, 'var' as var_type from gui_element where e_id = 'overview';
+UPDATE gui_element SET e_pos = 2, e_element = 'div', e_more_styles = 'visibility:visible;overflow:scroll', e_content = '', e_closetag = 'div', e_js_file = '../html/mod_treefolderPlain.php', e_mb_mod = 'jsTree.js', e_requires = 'mapframe1' WHERE e_id = 'treeGDE';
+INSERT INTO gui_element_vars select fkey_gui_id,'body' as fkey_e_id, 'treeGDE_css' as var_name, '../css/treeGDE2.css' as var_value, 'cssfile for TreeGDE' as context, 'file/css' as var_type from gui_element where e_id = 'treeGDE';
+UPDATE gui_element SET e_element = 'select', e_src = '', e_attributes = '', e_content = '<option value="">undefined</option>
+<option value="EPSG:4326">EPSG:4326</option>
+<option value="EPSG:31466">EPSG:31466</option>
+<option value="EPSG:31467">EPSG:31467</option>
+<option value="EPSG:31468">EPSG:31468</option>
+<option value="EPSG:31469">EPSG:31469</option>', e_closetag = 'select', e_js_file = 'mod_changeEPSG.php' WHERE e_id = 'changeEPSG';
+DELETE FROM gui_element WHERE e_id = 'closePolygon';
+DELETE FROM gui_element WHERE e_id = 'rubber';
+DELETE FROM gui_element WHERE e_id = 'getArea';
+DELETE FROM gui_element WHERE e_id = 'rubberExt';
+UPDATE gui_element SET e_element = 'div', e_src = '', e_attributes = '', e_more_styles = 'overflow:hidden;', e_content = '', e_closetag = 'div', e_js_file = 'mod_zoomCoords.php', e_target = 'mapframe1,overview', e_requires = 'mapframe1' WHERE e_id = 'zoomCoords';
+-- a demo splash screen for gui1
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'body', 'use_load_message', 'true', '' ,'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'body', 'includeWhileLoading', '../include/gui1_splash.php', '' ,'php_var');
+UPDATE gui_element SET e_mb_mod = '../extensions/wz_jsgraphics.js,geometry.js' WHERE e_id = 'wfs';
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Measure distance', 'Messen');
+UPDATE gui_element SET e_attributes = 'onload="init()"' WHERE e_id = 'body' AND fkey_gui_id IN ('wms_africa', 'wms_australia', 'wms_europe', 'wms_gdi_de', 'wms_germany', 'wms_north_america', 'wms_worldwide');
+-- gui: tab: increase the size of the frames onmouseover
+UPDATE gui_element SET e_attributes = 'frameborder = "0" onmouseover="this.style.zIndex=300;this.style.width=350;" onmouseout="this.style.zIndex=2;this.style.width=200"',
+e_more_styles = 'visibility:hidden; border: 1px solid #a19c8f;' WHERE e_id IN ('treeGDE','printPDF','legend','imprint','meetiongPoint','gazetteerWFS') AND fkey_gui_id IN ('gui');
+UPDATE gui_element SET e_more_styles = e_more_styles || ' background-color:#FFFFFF;' WHERE e_id IN ('treeGDE','imprint') AND fkey_gui_id IN ('gui');
+-- gui_treegde - delete entries which are not needed
+Delete from gui_treegde where fkey_gui_id IN ('gui','gui1','gui2','gui_digitize') and my_layer_title ='new';
+-- new translation entries for portuguese
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Zoom out', 'Zoom -');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Back', 'Zoom previo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Forward', 'Zoom siguiente');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Coordinates', 'Mostrar coordinadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Zoom by rectangle', 'Zoom retángulo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Redraw', 'Refrescar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Query', 'Procurar dados');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Logout', 'Terminar sessão');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'WMS preferences', 'Ajuste WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Adding WMS from filtered list', 'Adicionar WMS desde lista filtrada');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Set map center', 'Centrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Help', 'Ajuda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Show WMS infos', 'Mostrar informação sobre WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Save workspace as web map context document', 'Guardar vista como arquivo Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Resize Mapsize', 'Modificar tamanho do mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Rubber', 'Apagar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Get Area', 'Calcular area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Close Polygon', 'Fechar polígono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Move back to your GUI list', 'Volver a lista WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Legend', 'Legenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Print', 'Imprimir');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Imprint', 'Expediente');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Maps', 'Mapas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Search', 'Procura');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Meetingpoint', 'Lugar de reunião, ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Metadatasearch', 'Procura metadados');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Adding WMS', 'Adicionar WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Adding WMS from List', 'Adicionar WMS desde lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Info', 'Informação');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Change Projection', 'Trocar projeto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Digitize', 'Captura');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Overview', 'Mapa de vição geral');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Drag Mapsize', 'Ampliar janela do mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Mapframe', 'Janela do mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Navigation Frame', 'Janela do navegação');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'scaleSelect', 'Selecionar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Scale Text', 'Texto da escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Scalebar', 'Barra de escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Set Background', 'Pôr fondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Zoom to Coordinates', 'Zoom pra coordinadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Change Password', 'Trocar senha');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Load a web map context document', 'Carregar documento do Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Measure distance', 'Medir distância');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'languaje', 'Selecionar Linguajem');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'navFrame', 'Marco de navegacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'dragMapSize', 'Agrandar Mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Pan', 'Desplazamento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Display complete map', 'Zoom na Extensão Total');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Zoom in', 'Zoom +');
+-- new translation entries for french
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Pan', 'Déplacer la sélection');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Display complete map', 'Afficher toute la carte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Zoom in', 'Zoomer');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Zoom out', 'Dézoomer');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Back', 'Précédent');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Forward', 'Suivant');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Coordinates', 'Afficher les coordonnées');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Zoom by rectangle', 'Zoomer sur la sélection');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Redraw', 'Actualiser [Espace]');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Query', 'Interroger la base de données');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Logout', 'Déconnexion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'WMS preferences', 'Configuration du WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Adding WMS from filtered list', 'Ajouter un WMS de la liste filtrée');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Set map center', 'Définir le centre de la carte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Help', 'Aide');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Show WMS infos', 'Affichage des informations du WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Save workspace as web map context document', 'Sauvegarder la vue/l''espace de travail en tant que Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Resize Mapsize', 'Redimensionner la taille de la carte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Rubber', 'Gomme');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Get Area', 'Calculer la superficie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Close Polygon', 'Fermer le polygone');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Move back to your GUI list', 'Retour à votre liste GUI');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Legend', 'Légende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Print', 'Imprimer');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Imprint', 'Envoyer / Imprint');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Maps', 'Cartes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Search', 'Recherche');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Meetingpoint', 'Point de rencontre');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Metadatasearch', 'Recherche des métadonnées');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Adding WMS', 'Ajouter WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Adding WMS from List', 'Ajouter WMS depuis la liste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Info', 'Info');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Change Projection', 'Changer la projection');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Digitize', 'Numériser');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Overview', 'Carte d''aperçu');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Drag Mapsize', 'Modifier la taille de la carte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Mapframe', 'Fenêtre de la carte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Navigation Frame', 'Fenêtre de navigation');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Scale Select', 'Sélection de l ''échelle');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Scale Text', 'Texte de l''échelle');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Scalebar', 'Echelle graphique');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Set Background', 'Sélectionner la carte d''arrière-plan');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Zoom to Coordinates', 'Zoomer aux coordonnées');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Change Password', 'Changer le mot de passe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Load a web map context document', 'Charger un fichier Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Logo', 'Logo');
+-- entries espaniol
+Update translations set msgstr='Seleccionar Idioma' where locale= 'es' and msgid = 'Set language';
+Update translations set msgstr='Agrandar Mapa' where locale= 'es' and msgid = 'dragMapSize';
+Update translations set msgstr='Marco de navegacion' where locale= 'es' and msgid = 'navFrame';
+Update translations set msgstr='Escala de texto' where locale= 'es' and msgid = 'Scale Text';
+Update translations set msgstr='Barra de escala' where locale= 'es' and msgid = 'Scalebar';
+Update translations set msgstr='Referencia' where locale= 'es' and msgid = 'Legend';
+Update translations set msgstr='Mostrar mapa completo' where locale= 'es' and msgid = 'Display complete map';
+UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js' WHERE e_id = 'setSpatialRequest';
+-- building categories to sort the guis in the login.php
+-- have a look at http://www.mapbender.org/GUI_Category
+-- new tables for category handling
+CREATE TABLE public.gui_gui_category
+  fkey_gui_id character varying(50),
+  fkey_gui_category_id integer
+CREATE TABLE public.gui_category
+  category_id serial,
+  category_name character varying(50),
+  category_description character varying(255),
+  CONSTRAINT pk_category_id PRIMARY KEY (category_id)
+ALTER TABLE ONLY gui_gui_category
+    ADD CONSTRAINT gui_gui_category_ibfk_2 FOREIGN KEY (fkey_gui_id) REFERENCES gui(gui_id) ON UPDATE CASCADE ON DELETE CASCADE;
+    ADD CONSTRAINT gui_gui_category_ibfk_1 FOREIGN KEY (fkey_gui_category_id) REFERENCES gui_category(category_id) ON UPDATE CASCADE ON DELETE CASCADE;
+INSERT INTO gui_category (category_id, category_name, category_description) VALUES (1, 'Administration', 'Applications for administration');
+INSERT INTO gui_category (category_id, category_name, category_description) VALUES (3, 'WMS Container', NULL);
+INSERT INTO gui_category (category_id, category_name, category_description) VALUES (2, 'Mapbender Template Applications', 'Template Applications');
+INSERT INTO gui_gui_category VALUES ('admin1',1);
+INSERT INTO gui_gui_category VALUES('admin2_de',1);
+INSERT INTO gui_gui_category VALUES('admin2_en',1);
+INSERT INTO gui_gui_category VALUES('admin_de_services',1);
+INSERT INTO gui_gui_category VALUES('admin_en_services',1);
+INSERT INTO gui_gui_category VALUES ('gui',2);
+INSERT INTO gui_gui_category VALUES('gui1',2);
+INSERT INTO gui_gui_category VALUES('gui2',2);
+INSERT INTO gui_gui_category VALUES('gui_digitize',2);
+INSERT INTO gui_gui_category VALUES('wms_gdi_de',3);
+INSERT INTO gui_gui_category VALUES('wms_germany',3);
+INSERT INTO gui_gui_category VALUES('wms_europe',3);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('gui_category', 'category_id'), (Select max(category_id) from gui_category), true);
+-- admin2_de background
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_de','headline_GUI_Category',3,1,'Hintergrund GUI Kategorien verwalten','GUI Categories','div','','',5,685,193,66,2,'','GUI Kategorien verwalten','div','','','','','');
+-- admin2_de - create a new category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_de','createCategory',2,1,'create a gui category','Create a new category','a','','href = "../php/mod_createCategory.php?sessionID" target = "AdminFrame" ',8,708,140,20,5,'','GUI Kategorien anlegen','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin2_de', 'createCategory', 'cssfile', '../css/administration_alloc.css', '' ,'file/css');
+-- admin2_de - add a gui to a category, remove it from a category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_de','category_filteredGUI',2,1,'add Gui to Category','Add one user to serveral groups','a','','href = "../php/mod_category_filteredGUI.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,728,190,20,10,'','GUI zu Kategorie zuordnen','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin2_de', 'category_filteredGUI', 'cssfile', '../css/administration_alloc.css', 'css file for admin module' ,'file/css');
+-- admin2_en background
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_en','headline_GUI_Category',3,1,'Hintergrund GUI Kategorien verwalten','GUI Categories','div','','',5,685,193,66,2,'','GUI Category Management','div','','','','','');
+-- admin2_en - create a new category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_en','createCategory',2,1,'create a gui category','Create a new category','a','','href = "../php/mod_createCategory.php?sessionID" target = "AdminFrame" ',8,708,140,20,5,'','create a GUI category','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin2_en', 'createCategory', 'cssfile', '../css/administration_alloc.css', '' ,'file/css');
+-- admin2_en - add a gui to a category, remove it from a category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_en','category_filteredGUI',2,1,'add Gui to Category','Add one user to serveral groups','a','','href = "../php/mod_category_filteredGUI.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,728,190,20,10,'','add GUI to Category','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin2_en', 'category_filteredGUI', 'cssfile', '../css/administration_alloc.css', 'css file for admin module' ,'file/css');
+-- admin1 - create a new category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','createCategory',2,1,'create a gui category','Create a new category','a','','href = "../php/mod_createCategory.php?sessionID" target = "AdminFrame" ',8,1030,140,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','create a GUI category','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin1', 'createCategory', 'cssfile', '../css/administration_alloc.css', '' ,'file/css');
+-- admin1 - add a gui to a category, remove it from a category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','category_filteredGUI',2,1,'add Gui to Category','Add one user to serveral groups','a','','href = "../php/mod_category_filteredGUI.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,1050,190,20,10,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','add GUI to Category','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin1', 'category_filteredGUI', 'cssfile', '../css/administration_alloc.css', 'css file for admin module' ,'file/css');
+-- remove module addWMSfromfilteredList_ajax from every standard gui and set it new with new parameters and new element vars
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui' and e_id = 'addWMSfromfilteredList_ajax';
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_gray/add_filtered_list_off.png','onclick=''var addWmsFromFilteredListPopup = new mb_popup({title:"Add WMS from filtered list",url:"../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID",width:720, height:600,left:20, top:20});addWmsFromFilteredListPopup.show()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js,popup.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'addWMSfromfilteredList_ajax', 'cssfileAddWMS', '../css/addwms.css', '' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'addWMSfromfilteredList_ajax', 'capabilitiesInput', '1', 'load wms by capabilities url' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'addWMSfromfilteredList_ajax', 'option_dball', '1', '1 enables option "load all configured wms from db"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'addWMSfromfilteredList_ajax', 'option_dbgroup', '1', '1 enables option "load configured wms by group"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'addWMSfromfilteredList_ajax', 'option_dbgui', '1', '1 enables option "load configured wms by gui"' ,'var');
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui1' and e_id = 'addWMSfromfilteredList_ajax';
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_gray/add_filtered_list_off.png','onclick=''var addWmsFromFilteredListPopup = new mb_popup({title:"Add WMS from filtered list",url:"../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID",width:720, height:600,left:20, top:20});addWmsFromFilteredListPopup.show()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',620,60,24,24,1,'','','','','mod_addWMSgeneralFunctions.js,popup.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addWMSfromfilteredList_ajax', 'cssfileAddWMS', '../css/addwms.css', '' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addWMSfromfilteredList_ajax', 'capabilitiesInput', '1', 'load wms by capabilities url' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addWMSfromfilteredList_ajax', 'option_dball', '1', '1 enables option "load all configured wms from db"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addWMSfromfilteredList_ajax', 'option_dbgroup', '0', '1 enables option "load configured wms by group"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addWMSfromfilteredList_ajax', 'option_dbgui', '0', '1 enables option "load configured wms by gui"' ,'var');
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui_digitize' and e_id = 'addWMSfromfilteredList_ajax';
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui_digitize','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_gray/add_filtered_list_off.png','onclick=''var addWmsFromFilteredListPopup = new mb_popup({title:"Add WMS from filtered list",url:"../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID",width:720, height:600,left:20, top:20});addWmsFromFilteredListPopup.show()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js,popup.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'addWMSfromfilteredList_ajax', 'cssfileAddWMS', '../css/addwms.css', '' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'addWMSfromfilteredList_ajax', 'capabilitiesInput', '1', 'load wms by capabilities url' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_dball', '1', '1 enables option "load all configured wms from db"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_dbgroup', '0', '1 enables option "load configured wms by group"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_dbgui', '0', '1 enables option "load configured wms by gui"' ,'var');
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui2' and e_id = 'addWMSfromfilteredList_ajax';
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui2','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blue/add_filtered_list_off.png','onclick=''var addWmsFromFilteredListPopup = new mb_popup({title:"Add WMS from filtered list",url:"../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID",width:720, height:600,left:20, top:20});addWmsFromFilteredListPopup.show()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',556,40,28,28,1,'','','','','mod_addWMSgeneralFunctions.js,popup.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'cssfileAddWMS', '../css/addwms.css', '' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'capabilitiesInput', '1', 'load wms by capabilities url' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'option_dball', '1', '1 enables option "load all configured wms from db"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'option_dbgroup', '0', '1 enables option "load configured wms by group"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'option_dbgui', '0', '1 enables option "load configured wms by gui"' ,'var');
+-- set popup.js as required module for gui element loadwmc
+UPDATE gui_element SET e_mb_mod = 'popup.js' WHERE e_id = 'loadwmc';
+-- set popup.js as required module for gui element featureInfoTunnel
+UPDATE gui_element SET e_mb_mod = 'popup.js' WHERE e_id = 'featureInfoTunnel';
+-- set standard element vars for possibility to use popup in featureInfoTunnel; activated for gui_digitize
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfoTunnel', 'featureInfoLayerPopup', 'false', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfoTunnel', 'featureInfoLayerPopup', 'false', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoLayerPopup', 'true', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
+-- increase size
+ALTER TABLE gui_element ALTER e_js_file TYPE varchar(255);
+ALTER TABLE gui_element ALTER  e_mb_mod  TYPE varchar(255);
+ALTER TABLE gui_element ALTER  e_requires  TYPE varchar(255);
+-- changed some styles for gui2
+UPDATE gui_element SET e_left = 225 WHERE fkey_gui_id = 'gui2' AND e_id = 'mapframe1';
+UPDATE gui_element SET e_top = 250 WHERE fkey_gui_id = 'gui2' AND e_id = 'tabs';
+UPDATE gui_element SET e_content = '<div id="mbN" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbNE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbSE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbS" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbSW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbNW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>' WHERE fkey_gui_id = 'gui2' AND e_id = 'navFrame';
+-- layer 19011 and 19015 not queryable for gui2 for demo of tooltip
+UPDATE gui_layer SET gui_layer_queryable = 0, gui_layer_querylayer = 0 WHERE fkey_gui_id = 'gui2' AND fkey_layer_id = 19011 AND gui_layer_wms_id = 893;
+UPDATE gui_layer SET gui_layer_queryable = 0, gui_layer_querylayer = 0 WHERE fkey_gui_id = 'gui2' AND fkey_layer_id = 19015 AND gui_layer_wms_id = 893;
+-- tooltip module in gui2 + required gui elements wfs and wfs conf
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','tooltip',1,1,'Tooltip demo modul','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','mod_tooltip.php','popup.js,geometry.js,wfsFilter.js','mapframe1','wfs,wfs_conf,featureInfoTunnel,popup','');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui2','wfs',2,1,'wfs request and result handling','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','wfs.php','../extensions/wz_jsgraphics.js,geometry.js','mapframe1,overview','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'wfs', 'displayWfsResultList', '1', '' ,'var');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui2','wfs_conf',2,1,'get all wfs_conf-params','','iframe','../php/mod_wfs.php','frameborder = "0"',1,1,1,1,NULL ,'visibility:hidden','','iframe','','','','','');
+-- element vars for tooltip
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_destinationFrame', '', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_noResultArray', E'["Kein Ergebnis.","<body onload=\"javascript:window.close()\">"]', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_styles', '.list_even{font-size:11px;color:red;}.list_uneven{font-size:11px;color:blue;}', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_styles_detail', '.list_even{font-size:11px;color:green;}.list_uneven{font-size:11px;color:blue;}', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_timeDelay', '1000', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'wfs_conf_filename', 'wfs_default.conf', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_width', '270', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_height', '200', '', 'var');
+-- Update URL to Mapbender help
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/AddWMS' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'addWMS';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Back' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'back';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Copyright' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'copyright';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/DragMapSize' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'dragMapSize';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/DependentDiv' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'dependentDiv';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/FeatureInfo' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'featureInfo1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/FeatureInfoRedirect' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'FeatureInfoRedirect';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/FeatureInfoTunnel' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'featureInfoTunnel';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Forward' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'forward';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/GazetteerWFS' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'gazetteerWFS';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Logout' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'logout';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Mapframe' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'mapframe1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Metadata' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'metadata';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/NavFrame' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'navFrame';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Overview' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'overview';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Pan' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'pan1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Print' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'printPDF';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/SaveWMC' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'savewmc';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/SelArea1' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'selArea1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/SetBackground' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'setBackground';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/ShowCoords_div' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'showCoords_div';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/TreeGde' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'treeGDE';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/WMS_preferences' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'WMS_preferences';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/ZoomFull' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'zoomFull';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/ZoomIn' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'zoomIn1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/ZoomOut' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'zoomOut1';
+-- new language fr, es pt
+Update gui_element_vars set var_value = 'de,en,bg,gr,nl,it,fr,es,pt' where fkey_gui_id = 'gui' AND fkey_e_id = 'switchLocale_noreload';
+-- customisable tree in admin1
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','Customize Tree',0002,1,'Create a set of nested folders that contain the applications WMS','Customize Tree','a','','href = "../php/mod_customTree.php?sessionID" target="AdminFrame"',10,975,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','CUSTOMIZE TREE','a','','','','AdminFrame','');
+--Bugfix for treegde in gui (tabs wideout)
+UPDATE gui_element SET e_more_styles='visibility:hidden; background-color:#ffffff;border: 1px solid #a19c8f;overflow:auto;' WHERE fkey_gui_id='gui' AND e_id='treeGDE';
+--remove treeGDE-css statement from 'treeGDE' because its handled in 'body' element
+DELETE  from gui_element_vars WHERE fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND fkey_e_id= 'treeGDE' AND var_name='cssfile';
Property changes on: trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_pgsql_ISO-8859-1.sql
___________________________________________________________________
Added: svn:keywords
   + Id
Added: trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.6rc1_to_2.6_pgsql_ISO-8859-1.sql
--- trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.6rc1_to_2.6_pgsql_ISO-8859-1.sql	                        (rev 0)
+++ trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.6rc1_to_2.6_pgsql_ISO-8859-1.sql	2009-09-15 16:51:14 UTC (rev 4635)
@@ -0,0 +1,209 @@
+Update gui_element set e_top = 10 where fkey_gui_id = 'gui' and e_id = 'setBackground';
+Update gui_element_vars set var_value = 'de,en,bg,gr,nl,hu,it,fr,es,pt' where fkey_gui_id = 'gui' AND fkey_e_id = 'switchLocale_noreload';
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Pan', 'Nézetet mozgat');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Display complete map', 'Teljes nézet');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Zoom in', 'Nagyít');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Zoom out', 'Kicsnyít');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Back', 'Vissza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Forward', 'El"ore');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Coordinates', 'Koordináták kijelzése');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Zoom by rectangle', 'Kijelölt területre nagyít');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Redraw', 'Újrarajzol');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Query', 'Adatok lekérése');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Logout', 'Kijelentkezés');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'WMS preferences', 'WMS beállítások');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Adding WMS from filtered list', 'WMS hozzáadása sz"urt listából');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Set map center', 'Nézet középpontja');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Help', 'Segítség');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Show WMS infos', 'WMS adatok megjelenítése');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Save workspace as web map context document', 'Nézet mentése Web Map Context formában');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Resize Mapsize', 'Térkép átméretezése');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Rubber', 'Törlés');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Get Area', 'Területszámítás');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Close Polygon', 'Sokszög bezárása');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Move back to your GUI list', 'Vissza a GUI listához');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Legend', 'Jelmagyarázat');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Print', 'Nyomtat');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Imprint', 'Impresszum');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Maps', 'Térképek');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Search', 'Keres');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Meetingpoint', 'Találkozási pont');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Metadatasearch', 'Metaadat keresés');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Adding WMS', 'WMS hozzáadása');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Adding WMS from List', 'WMS hozzáadása listából');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Info', 'Információ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Change Projection', 'Más vetület választása');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Digitize', 'Digitalizálás');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Overview', 'Átnézeti térkép');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Drag Mapsize', 'Térkép átméretezése');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Mapframe', 'Térképablak');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Navigation Frame', 'Navigációs ablak');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Scale Select', 'Lépték választása');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Scale Text', 'Lépték megadása');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Scalebar', 'Aránymérték');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Set Background', 'Háttér beállítása');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Zoom to Coordinates', 'Ugrás adott koordinátákra');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Change Password', 'Jelszó módosítása');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Load a web map context document', 'Web Map Context dokumentum betöltése');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Logo', 'Logó');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Measure distance', 'Távolságmérés');
+-- http://trac.osgeo.org/mapbender/ticket/442
+DELETE FROM gui_element_vars WHERE fkey_gui_id = 'gui2' AND fkey_e_id = 'tooltip' AND var_name = 'tooltip_noResultArray';
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_noResultArray', E'["Kein Ergebnis.","<body onload=\'javascript:window.close()\'>"]', '', 'var');
+--new element vars for module tooltip to control whether user likes to have wfs getFeature request and/or whether user likes to have wms getfeatureInfo requests
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_disableWfs', '0', 'disable WFS getFeature Request', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_disableWms', '1', 'disable WMS getFeatureInfo Request', 'var');
+--update style of wfs_conf myPolygons (coloured buttons, background)
+UPDATE wfs_conf SET g_style = 'body{
+ font-family:Verdana,Arial,sans-serif;
+ font-size: 12px;
+ line-height:2;
+ background-color:#CFD2D4;
+.a{
+ font-weight:bold;
+.b{
+ font-size: 12px;
+ font-weight: bold;
+ width:40px;
+ color: #FFFFFF;
+ -moz-border-radius:5px;
+ -khtml-border-radius:5px;
+ background-color: #1874CD;
+ border-color: #1874CD;
+.d{
+ color:#000000;
+.hidden{
+ visibility: hidden;
+.buttonDelFilter{
+ font-size: 12px;
+ width:40px;
+ color:#FFFFFF;
+ background-color: #8B0000;
+ border-color: #8B0000;
+' WHERE wfs_conf_id = 2;
+-- insert statement for switchWMS is in template Guis was missing.
+-- http://trac.osgeo.org/mapbender/ticket/472
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var');
+ALTER TABLE gui_element ALTER COLUMN e_pos SET DEFAULT 2;
+ALTER TABLE gui_element ALTER COLUMN e_pos SET NOT NULL;
+ALTER TABLE gui_element ALTER COLUMN e_public SET DEFAULT 1;
+ALTER TABLE gui_element ALTER COLUMN e_public SET NOT NULL;
+-- new columns for table mb_user (more information fields + validity date fields)
+ALTER TABLE mb_user ADD COLUMN mb_user_realname varchar(100);
+ALTER TABLE mb_user ADD COLUMN mb_user_street varchar(100);
+ALTER TABLE mb_user ADD COLUMN mb_user_housenumber varchar(50);
+ALTER TABLE mb_user ADD COLUMN mb_user_reference varchar(100);
+ALTER TABLE mb_user ADD COLUMN mb_user_for_attention_of varchar(100);
+ALTER TABLE mb_user ADD COLUMN mb_user_valid_from date;
+ALTER TABLE mb_user ADD COLUMN mb_user_valid_to date;
+ALTER TABLE mb_user ADD COLUMN mb_user_password_ticket varchar(100);
+-- enable favicon per gui using element_var
+-- http://trac.osgeo.org/mapbender/ticket/514
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'body', 'favicon', '../img/favicon.png', 'favicon' ,'php_var');
+-- pt update entries for translations table
+update translations set msgid = 'Set language' where msgid = 'languaje' and locale = 'pt';
+update translations set msgstr = 'Selecionar Linguagem' where msgstr = 'Selecionar Linguajem' and locale = 'pt';
+update translations set msgstr = 'Marco de navegação' where msgstr = 'Marco de navegacion' and locale = 'pt';
+update translations set msgstr = 'Zoom seguinte' where msgid = 'Forward' and locale = 'pt';
+update translations set msgstr = 'Zoom para coordinadas' where msgid = 'Zoom to Coordinates' and locale = 'pt';
+update translations set msgid = 'Drag Mapsize' where msgid = 'dragMapSize' and locale = 'pt';
+update translations set msgid = 'Navigation Frame' where msgid = 'navFrame' and locale = 'pt';
+update translations set msgid = 'Scale Select' where msgid = 'scaleSelect' and locale = 'pt';
+-- polish entries for translations table
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Pan', 'Przesu´n');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Display complete map', 'Pokaz cala mape');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom in', 'Powieksz');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom out', 'Pomniejsz');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Back', 'Wró´c');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Forward', 'Do przodu');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Coordinates', 'Wspólrzedne');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom by rectangle', 'Wybierz fragment mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Redraw', 'Zaladuj ponownie');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Query', 'Szukaj danych');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Logout', 'Wymelduj');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'WMS preferences', 'Ustawienia WMS');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS from filtered list', 'Dodaj WMS z listy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set map center', 'Zaznacz ´srodek mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Help', 'Pomoc');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Show WMS infos', 'Informacje WMS');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Save workspace as web map context document', 'Zapisz widok jako web map context dokument');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Resize Mapsize', 'Zmie´n rozmiar mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Rubber', 'Usu´n szkic');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Get Area', 'Oblicz powierzchnie');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Close Polygon', 'Zamknij poligon');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Move back to your GUI list', 'Z powrotem do listy GUI');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Legend', 'Legenda');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Print', 'Drukuj');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Imprint', 'Imprint');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Maps', 'Mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Search', 'Szukaj');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Meetingpoint', 'Miejsce spotka´n');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Metadatasearch', 'Wyszukiwanie metadanych');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS', 'Dodaj WMS');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS from List', 'Dodaj WMS z listy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Info', 'Informacja');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Change Projection', 'Zmie´n uklad wspólrzednych');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Digitize', 'Dygitalizacja');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Overview', 'Mapa przegladowa');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Drag Mapsize', 'Powieksz');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Mapframe', 'Okno mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Navigation Frame', 'Pasek narzedzi');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scale Select', 'Wybierz skale');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scale Text', 'Wpisz skale');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scalebar', 'Podzialka');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set Background', 'Wybierz mape tematyczna jako tlo');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom to Coordinates', 'Powieksz wedlug wspólrzednych');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Change Password', 'Zmie´n haslo');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Load a web map context document', 'Zaladuj web map context dokument');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Measure distance', 'Zmierz odleglo´s´c');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set language', 'Wybierz jezyk');
+-- hungarian entry for translations table
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Set language', 'Másik nyelv...');
+-- italian entry for translations table
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set language', 'Assegnare linguaggio');
+-- dutch entry for translations table
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Set language', 'Taal instellen');
Property changes on: trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.6rc1_to_2.6_pgsql_ISO-8859-1.sql
Added: svn:keywords
   + Id
Copied: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql (from rev 4631, trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql)
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql	                        (rev 0)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql	2009-09-15 16:51:14 UTC (rev 4635)
@@ -0,0 +1,209 @@
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Forward', 'Előre');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Adding WMS from filtered list', 'WMS hozzáadása szűrt listából');
+ font-size: 12px;
+ line-height:2;
+.a{
+ font-weight:bold;
+.b{
+ font-size: 12px;
+ width:40px;
+ color: #FFFFFF;
+.d{
+ color:#000000;
+.hidden{
+.buttonDelFilter{
+ font-size: 12px;
+ width:40px;
+ color:#FFFFFF;
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Pan', 'Przesuń');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Display complete map', 'Pokaż calą mapę');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom in', 'Powiększ');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Back', 'Wróć');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Coordinates', 'Współrzędne');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Redraw', 'Załaduj ponownie');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set map center', 'Zaznacz środek mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Resize Mapsize', 'Zmień rozmiar mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Rubber', 'Usuń szkic');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Get Area', 'Oblicz powierzchniÄ™');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Meetingpoint', 'Miejsce spotkań');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Change Projection', 'Zmień układ współrzędnych');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Overview', 'Mapa przeglÄ…dowa');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Drag Mapsize', 'Powiększ');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Navigation Frame', 'Pasek narzędzi');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scale Select', 'Wybierz skalÄ™');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scale Text', 'Wpisz skalÄ™');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scalebar', 'Podziałka');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set Background', 'Wybierz mapę tematyczną jako tło');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom to Coordinates', 'Powiększ według współrzędnych');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Change Password', 'Zmień hasło');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Load a web map context document', 'Załaduj web map context dokument');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Measure distance', 'Zmierz odległość');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set language', 'Wybierz język');
Property changes on: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql
Added: svn:mergeinfo
   + /branches/kmq_dev/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql:4021-4487
Deleted: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql	2009-09-15 15:45:34 UTC (rev 4634)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql	2009-09-15 16:51:14 UTC (rev 4635)
@@ -1,138 +0,0 @@
-Update gui_element set e_top = 10 where fkey_gui_id = 'gui' and e_id = 'setBackground';
--- new language fr, es pt
-Update gui_element_vars set var_value = 'de,en,bg,gr,nl,hu,it,fr,es,pt' where fkey_gui_id = 'gui' AND fkey_e_id = 'switchLocale_noreload';
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Pan', 'Nézetet mozgat');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Display complete map', 'Teljes nézet');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Zoom in', 'Nagyít');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Zoom out', 'Kicsnyít');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Back', 'Vissza');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Forward', 'Előre');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Coordinates', 'Koordináták kijelzése');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Zoom by rectangle', 'Kijelölt területre nagyít');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Redraw', 'Újrarajzol');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Query', 'Adatok lekérése');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Logout', 'Kijelentkezés');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'WMS preferences', 'WMS beállítások');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Adding WMS from filtered list', 'WMS hozzáadása szűrt listából');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Set map center', 'Nézet középpontja');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Help', 'Segítség');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Show WMS infos', 'WMS adatok megjelenítése');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Save workspace as web map context document', 'Nézet mentése Web Map Context formában');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Resize Mapsize', 'Térkép átméretezése');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Rubber', 'Törlés');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Get Area', 'Területszámítás');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Close Polygon', 'Sokszög bezárása');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Move back to your GUI list', 'Vissza a GUI listához');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Legend', 'Jelmagyarázat');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Print', 'Nyomtat');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Imprint', 'Impresszum');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Maps', 'Térképek');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Search', 'Keres');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Meetingpoint', 'Találkozási pont');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Metadatasearch', 'Metaadat keresés');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Adding WMS', 'WMS hozzáadása');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Adding WMS from List', 'WMS hozzáadása listából');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Info', 'Információ');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Change Projection', 'Más vetület választása');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Copyright', 'Copyright');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Digitize', 'Digitalizálás');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Overview', 'Átnézeti térkép');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Drag Mapsize', 'Térkép átméretezése');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Mapframe', 'Térképablak');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Navigation Frame', 'Navigációs ablak');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Scale Select', 'Lépték választása');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Scale Text', 'Lépték megadása');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Scalebar', 'Aránymérték');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Set Background', 'Háttér beállítása');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Zoom to Coordinates', 'Ugrás adott koordinátákra');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Change Password', 'Jelszó módosítása');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Load a web map context document', 'Web Map Context dokumentum betöltése');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Logo', 'Logó');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('hu', 'Measure distance', 'Távolságmérés');
---Bugfix for treegde in gui (tabs wideout)
-UPDATE gui_element SET e_more_styles='visibility:hidden; background-color:#ffffff;border: 1px solid #a19c8f;overflow:auto;' WHERE fkey_gui_id='gui' AND e_id='treeGDE';
---remove treeGDE-css statement from 'treeGDE' because its handled in 'body' element
-DELETE  from gui_element_vars WHERE fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND fkey_e_id= 'treeGDE' AND var_name='cssfile';
--- http://trac.osgeo.org/mapbender/ticket/442
-DELETE FROM gui_element_vars WHERE fkey_gui_id = 'gui2' AND fkey_e_id = 'tooltip' AND var_name = 'tooltip_noResultArray';
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_noResultArray', E'["Kein Ergebnis.","<body onload=\'javascript:window.close()\'>"]', '', 'var');
---new element vars for module tooltip to control whether user likes to have wfs getFeature request and/or whether user likes to have wms getfeatureInfo requests
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_disableWfs', '0', 'disable WFS getFeature Request', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_disableWms', '1', 'disable WMS getFeatureInfo Request', 'var');
---update style of wfs_conf myPolygons (coloured buttons, background)
-UPDATE wfs_conf SET g_style = 'body{
- font-family:Verdana,Arial,sans-serif;
- font-size: 12px;
- line-height:2;
- background-color:#CFD2D4;
-.a{
- font-weight:bold;
-.b{
- font-size: 12px;
- font-weight: bold;
- width:40px;
- color: #FFFFFF;
- -moz-border-radius:5px;
- -khtml-border-radius:5px;
- background-color: #1874CD;
- border-color: #1874CD;
-.d{
- color:#000000;
-.hidden{
- visibility: hidden;
-.buttonDelFilter{
- font-size: 12px;
- width:40px;
- color:#FFFFFF;
- background-color: #8B0000;
- border-color: #8B0000;
-' WHERE wfs_conf_id = 2;
---insert statement for switchWMS is in template Guis was missing.
---http://trac.osgeo.org/mapbender/ticket/472
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var');
-ALTER TABLE gui_element ALTER COLUMN e_pos SET DEFAULT 2;
-ALTER TABLE gui_element ALTER COLUMN e_pos SET NOT NULL;
-ALTER TABLE gui_element ALTER COLUMN e_public SET DEFAULT 1;
-ALTER TABLE gui_element ALTER COLUMN e_public SET NOT NULL;
--- new columns for table mb_user (more information fields + validity date fields)
-ALTER TABLE mb_user ADD COLUMN mb_user_realname varchar(100);
-ALTER TABLE mb_user ADD COLUMN mb_user_street varchar(100);
-ALTER TABLE mb_user ADD COLUMN mb_user_housenumber varchar(50);
-ALTER TABLE mb_user ADD COLUMN mb_user_reference varchar(100);
-ALTER TABLE mb_user ADD COLUMN mb_user_for_attention_of varchar(100);
-ALTER TABLE mb_user ADD COLUMN mb_user_valid_from date;
-ALTER TABLE mb_user ADD COLUMN mb_user_valid_to date;
-ALTER TABLE mb_user ADD COLUMN mb_user_password_ticket varchar(100);
--- enable favicon per gui using element_var
--- http://trac.osgeo.org/mapbender/ticket/514
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'body', 'favicon', '../img/favicon.png', 'favicon' ,'php_var');
Deleted: trunk/mapbender/resources/db/pgsql/pgsql_serial_set_sequences_7x_2.5.sql
--- trunk/mapbender/resources/db/pgsql/pgsql_serial_set_sequences_7x_2.5.sql	2009-09-15 15:45:34 UTC (rev 4634)
+++ trunk/mapbender/resources/db/pgsql/pgsql_serial_set_sequences_7x_2.5.sql	2009-09-15 16:51:14 UTC (rev 4635)
@@ -1,37 +0,0 @@
--- Set Sequence for serial values
-SELECT pg_catalog.setval('gui_treegde_id_seq', (Select max(id) from gui_treegde), true);
-SELECT pg_catalog.setval('layer_layer_id_seq', (Select max(layer_id) from layer), true);
-SELECT pg_catalog.setval('mb_group_mb_group_id_seq', (Select max(mb_group_id) from mb_group), true);
-SELECT pg_catalog.setval('mb_log_id_seq', (Select max(id) from mb_log), true);
-SELECT pg_catalog.setval('mb_user_mb_user_id_seq', (Select max(mb_user_id) from mb_user), true);
-SELECT pg_catalog.setval('wfs_wfs_id_seq', (Select max(wfs_id) from wfs), true);
-SELECT pg_catalog.setval('wfs_conf_wfs_conf_id_seq', (Select max(wfs_conf_id) from wfs_conf), true);
-SELECT pg_catalog.setval('wfs_conf_element_wfs_conf_element_id_seq', (Select max(wfs_conf_element_id) from wfs_conf_element), true);
-SELECT pg_catalog.setval('wfs_element_element_id_seq', (Select max(element_id) from wfs_element), true);
-SELECT pg_catalog.setval('wfs_featuretype_featuretype_id_seq', (Select max(featuretype_id) from wfs_featuretype), true);
-SELECT pg_catalog.setval('wms_wms_id_seq', (Select max(wms_id) from wms), true);
--- new sequences from Mapbender version 2.4.1
-SELECT pg_catalog.setval('keyword_id_seq', (Select max(keyword_id) from keyword), true);
-SELECT pg_catalog.setval('md_topic_category_id_seq', (Select max(md_topic_category_id) from md_topic_category), true);
--- new sequences from Mapbender version 2.5
-SELECT pg_catalog.setval('trs_id_seq', (Select max(trs_id) from translations), true);
-SELECT pg_catalog.setval('kml_id_seq', (Select max(kml_id) from gui_kml), true);
-SELECT pg_catalog.setval('sld_user_layer_id_seq', (Select max(sld_user_layer_id) from sld_user_layer), true);
More information about the Mapbender_commits mailing list
