[Mapbender-commits] r4707 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org
Sat Sep 26 08:00:02 EDT 2009
Author: astrid_emde
Date: 2009-09-26 08:00:01 -0400 (Sat, 26 Sep 2009)
New Revision: 4707
Removed:
trunk/mapbender/resources/db/install_2.6.bat
trunk/mapbender/resources/db/install_2.6.sh
trunk/mapbender/resources/db/update/
folder update committed the update folder is under db/UTF-8/update
Deleted: trunk/mapbender/resources/db/install_2.6.bat
--- trunk/mapbender/resources/db/install_2.6.bat 2009-09-26 11:58:35 UTC (rev 4706)
+++ trunk/mapbender/resources/db/install_2.6.bat 2009-09-26 12:00:01 UTC (rev 4707)
@@ -1,203 +0,0 @@
- at echo off
-REM Script to install Mapbender 2.6 database
-REM
-setlocal
-REM Delete old Logfiles
-del log_*.txt
-del err_*.txt
-:PREP
-echo.
-echo ==============================================================================
-REM Disclaimer
-echo.
-echo DISCLAIMER: this Mapbender database setup script is not stable. USE AT YOUR OWN RISK!
-echo This script will create a database for you and will import the Mapbender data to the new database
-echo It will possibly also compile the Mapbender.mo files
-echo.
-echo You need:
-echo - a running postgresql or mysql database
-echo - database user with write access
-echo.
-echo If everything is prepared you can continue.
-echo.
-echo.
-echo Continue?
-set /p PREPARED="(y)es or (n)o:"
-if %PREPARED%==y goto :PREP_OK
-if %PREPARED%==n goto :End
-goto :PREP
-:PREP_OK
-rem Database
-:DB_TYPE
-echo.
-echo Which Database?
-set /p DBTYPE="(p)ostgresql or (m)ysql:"
-if %DBTYPE%==p goto :DB_PG
-if %DBTYPE%==m goto :DB_MYSQL
-goto :DB_TYPE
-:DB_PG
-set USEDBTYPE=PostgreSQL
-:DB_MYSQL
-IF %USEDBTYPE%x==x set USEDBTYPE=Mysql
-REM Encoding
-:DB_ENC
-echo.
-echo Which Encoding?
-set /p DBENC="(u)tf-8 or (i)so-8859-1/latin1:"
-if %DBENC%==u goto :DB_UTF
-if %DBENC%==i goto :DB_ISO
-goto :DB_ENC
-:DB_UTF
-set USEDBENC=UTF-8
-:DB_ISO
-IF %USEDBENC%x==x set USEDBENC=ISO-8859-1
-echo.
-set /p DBHOST="Database host (localhost if running on local maschine):"
-echo.
-echo.
-set /p DBPORT="Database port (e.g. 5432 for postgres, 3306 for mysql):"
-echo.
-echo.
-set /p DBUSER="Database user:"
-echo.
-rem Password
-rem echo.
-echo Database Password will be asked many times during install...
-echo.
-set /p DBNAME="Database name:"
-:CHOICES
-echo.
-echo Your Choices:
-echo Databasetype: %DBTYPE% - %USEDBTYPE%
-echo Encoding: %DBENC% - %USEDBENC%
-echo Database Host: %DBHOST%
-echo Database Port: %DBPORT%
-echo Database Name: %DBNAME%
-echo Database User: %DBUSER%
-echo Database Password: %DBPASSWORD% (not shown)
-echo.
-echo Looks ok, start install?
-echo.
-set /p START_INSTALL="(y)es or (n)o? "
-if %START_INSTALL%==y goto START_INSTALL
-goto PREP
-:START_INSTALL
-rem echo on
-if %USEDBTYPE% == PostgreSQL goto INSTPOSTGRESQL
-if %USEDBTYPE% == Mysql goto INSTMYSQL
-:INSTPOSTGRESQL
-REM do these exist?
-psql --version 2> nul 1> nul
-if NOT %ERRORLEVEL% == 0 goto PGNOTFOUND
-set /p DBTEMPLATE="database template to use (just hit return for default):"
-IF %DBTEMPLATE%x==x set DBTEMPLATE=template0
-IF %DBHOST%x==x set DBHOST=localhost
-IF %DBPORT%x==x set DBPORT=5432
-echo creating db
-createdb -U %DBUSER% -E %USEDBENC% -h %DBHOST% -p %DBPORT% -T %DBTEMPLATE% %DBNAME% "Mapbender Database Version 2.6"
-echo creating schema
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/pgsql_schema_2.5.sql %DBNAME% 1>log_schema.txt 2> err_schema.txt
-echo importing data
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/pgsql_data_2.5.sql %DBNAME% 1>log_data.txt 2> err_data.txt
-echo setting sequences
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/pgsql_serial_set_sequences_2.5.sql %DBNAME% 1>log_sequences.txt 2> err_sequences.txt
-echo performing updates
-echo to 2.5.1rc1
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.5_to_2.5.1rc1_pgsql_%USEDBENC%.sql %DBNAME% 1>log_update.txt 2> err_update.txt
-echo to 2.5.1
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.5.1rc1_to_2.5.1_pgsql_%USEDBENC%.sql %DBNAME% 1>>log_update.txt 2>> err_update.txt
-echo to 2.6rc1
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.5.1_to_2.6rc1_pgsql_%USEDBENC%.sql %DBNAME% 1>>log_update.txt 2>> err_update.txt
-echo to 2.6
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6rc1_to_2.6_pgsql_%USEDBENC%.sql %DBNAME% 1>>log_update.txt 2>> err_update.txt
-goto POFILES
-:INSTMYSQL
-IF %DBPORT%x==x set DBPORT=3306
-mysql --version 2> nul 1> nul
-if not %ERRORLEVEL% == 0 goto MYSQLNOTFOUND
-echo creating database
-if %USEDBENC% == ISO-8859-1 mysql -h %DBHOST% -P %DBPORT% -u %DBUSER% -e "create database %DBNAME% character set latin1 COLLATE latin1_german1_ci;" -p
-if %USEDBENC% == UTF-8 mysql -h %DBHOST% -P %DBPORT% -e "create database %DBNAME% character set utf8 COLLATE utf8_general__ci;" -p
-mysql %DBNAME% -p -h %DBHOST% -P %DBPORT% -u %DBUSER% < mysql/mysql_schema_2.5.sql > log_schema.txt 2> err_schema.txt
-echo loading data
-mysql %DBNAME% -p -h %DBHOST% -P %DBPORT% -u %DBUSER% < mysql/%USEDBENC%/mysql_data_2.5.sql > log_data.txt 2> err_data.txt
-echo update to 2.5.1rc1
-mysql %DBNAME% -p -h %DBHOST% -P %DBPORT% -u %DBUSER% < mysql/%USEDBENC%/update/update_2.5_to_2.5.1rc1_mysql_%USEDBENC%.sql > log_update.txt 2> err_update.txt
-mysql %DBNAME% -p -h %DBHOST% -P %DBPORT% -u %DBUSER% < mysql/%USEDBENC%/update/update_2.5.1rc1_to_2.5.1_mysql_%USEDBENC%.sql >> log_update.txt 2>> err_update.txt
-echo update to 2.6rc1
-mysql %DBNAME% -p -h %DBHOST% -P %DBPORT% -u %DBUSER% < mysql/%USEDBENC%/update/update_2.5.1_to_2.6rc1_mysql_%USEDBENC%.sql >> log_update.txt 2>> err_update.txt
-echo update to 2.6
-mysql %DBNAME% -p -h %DBHOST% -P %DBPORT% -u %DBUSER% < mysql/%USEDBENC%/update/update_2.6rc1_to_2.6_mysql_%USEDBENC%.sql >> log_update.txt 2>> err_update.txt
-GOTO POFILES
-:POFILES
-rem install mapbender.conf
-if not exist ..\..\conf\mapbender.conf copy ..\..\conf\mapbender.conf-dist ..\..\conf\mapbender.conf
-echo please check and edit your mapbender.conf.
-rem update .po files
-echo ""
-msgfmt --version 2> nul 1> nul
-if NOT %ERRORLEVEL% == 0 goto MSGFMTNOTFOUND
-echo "Compiling .po files..."
-pushd ..\..\tools\
-findstr /v ^# i18n_update_mo.sh > i18n_update_mo.bat
-call i18n_update_mo.bat
-del i18n_update_mo.bat
-popd
-goto END:
-:MSGFMTNOTFOUND
-echo Sorry, msgfmt not found, must be in PATH-Variable, won't compile translations...
-echo Have a look at http://www.mapbender.org/Gettext#Utility_programms for msgfmt.
-goto END:
-goto END:
-:PGNOTFOUND
-echo Sorry, psql not found, must be in PATH-Variable, exiting...
-goto END
-:MYSQLNOTFOUND
-echo Sorry, mysql not found, must be in PATH-Variable, exiting...
-goto END
-REM End, keep Terminal session open
-:END
-endlocal
-echo Finished...check the log files to see if an error occured.
-pause
Deleted: trunk/mapbender/resources/db/install_2.6.sh
--- trunk/mapbender/resources/db/install_2.6.sh 2009-09-26 11:58:35 UTC (rev 4706)
+++ trunk/mapbender/resources/db/install_2.6.sh 2009-09-26 12:00:01 UTC (rev 4707)
@@ -1,272 +0,0 @@
-#!/bin/bash
-# create database for mapbender
-function show_disclaimer() {
- # Disclaimer
- echo ""
- echo "DISCLAIMER: this Mapbender database setup script is not stable. USE AT YOUR OWN RISK!"
- echo "The script will create a database for you and will import the Mapbender data to the new database"
- echo "It will also compile the Mapbender.mo files"
- echo ""
- echo "To run this script you have to set the following options"
- # echo " * set the right to execute on this install script"
- # echo " * set the right to execute on mapbender/tools/i18n_update_mo.sh"
- # echo " * write access to mapbender/log"
- # echo " * write access to mapbender/http/tmp"
- # echo " * write access to mapbender/resources/locale/ and subdirectories"
- echo " * provide a database user that can create a database"
- echo ""
- echo ""
- echo "If everything is prepared you can continue."
- echo ""
-function del_logfile() {
- rm log_*.txt
- rm err_*.txt
-#get Database Configuration
-function get_db_config(){
- until [ "$DBVERSION" = "p" -o "$DBVERSION" = "m" ]
- do
- echo ""
- echo "database version? (p)ostgresql or (m)ysql?"
- read DBVERSION
- done
- # db encoding
- until [ "$DBENCODING" = "i" -o "$DBENCODING" = "u" ]
- do
- echo ""
- echo "database character encoding? (i)so-8859-1 or (u)tf-8?"
- read DBENCODING
- done
- #ask for database template
- if [ "$DBVERSION" = "p" ]
- then
- echo ""
- echo "database template to use (just hit return for default template0)?"
- read DBTEMPLATE
- : ${DBTEMPLATE:="template0"}
- fi
- # db name
- until [ -n "$DBNAME" ]
- do
- echo ""
- echo "database name?"
- read DBNAME
- done
- #nicer vars
- then
- DBVERSION="pgsql"
- else
- DBVERSION="mysql"
- fi
- if [ "$DBENCODING" = "i" ]
- then
- DBENCODING="ISO-8859-1"
- else
- DBENCODING="UTF-8"
- fi
- echo ""
- echo "database host (e.g. localhost)?"
- read DBHOST
- echo ""
- echo "database port (e.g. 5432 for postgres, 3306 for mysql)?"
- read DBPORT
- echo ""
- echo "database user?"
- read DBUSER
-#using a password via commandline oder as shell var could lead to security problems, so we don't do it
-# echo ""
-# echo "Password for $DBUSER (will not be shown)?"
-# stty -echo
-# read DBPASSWORD
-# stty echo
-#show Database Configuration
-function show_db_config(){
- echo ""
- echo "Database Configuration:"
- echo "version:" $DBVERSION
- echo "encoding:" $DBENCODING
- if [ $DBTEMPLATE ]
- then
- echo "postgres template:" $DBTEMPLATE
- fi
- echo "db host:" $DBHOST
- echo "db port:" $DBPORT
- echo "dbname:" $DBNAME
- echo "user:" $DBUSER
- echo ""
-function create_mysql_db(){
- which mysql > /dev/null
- if [ $? -ne 0 ]
- then
- echo "commando mysql, but not found, exiting..."
- echo "is mysql installed?"
- echo ""
- exit 1;
- fi
- echo "Your password will be asked several times, this is normal"
- echo "creating database"
- if [ $DBENCODING = "ISO-8859-1" ]
- then
- mysql -e "create database $DBNAME CHARACTER SET latin1 COLLATE latin1_german1_ci;" -p$DBPASSWORD -u $DBUSER
- else
- mysql -e "create database $DBNAME CHARACTER SET utf8 COLLATE utf8_general_ci;" -p$DBPASSWORD -u $DBUSER
- fi
- echo "creating schema"
- mysql $DBNAME -p$DBPASSWORD -u $DBUSER -h $DBHOST -P $DBPORT < mysql/mysql_schema_2.5.sql > log_schema.txt 2> err_schema.txt
- echo "loading data"
- mysql $DBNAME -p$DBPASSWORD -u $DBUSER -h $DBHOST -P $DBPORT < mysql/$DBENCODING/mysql_data_2.5.sql > log_data.txt 2> err_data.txt
- echo "update to 2.5.1rc1"
- mysql $DBNAME -p$DBPASSWORD -u $DBUSER -h $DBHOST -P $DBPORT < mysql/$DBENCODING/update/update_2.5_to_2.5.1rc1_mysql_$DBENCODING.sql > log_update.txt 2> err_update.txt
- echo "update to 2.5.1"
- mysql $DBNAME -p$DBPASSWORD -u $DBUSER -h $DBHOST -P $DBPORT < mysql/$DBENCODING/update/update_2.5.1rc1_to_2.5.1_mysql_$DBENCODING.sql >> log_update.txt 2>> err_update.txt
- echo "update to 2.6rc1"
- mysql $DBNAME -p$DBPASSWORD -u $DBUSER -h $DBHOST -P $DBPORT < mysql/$DBENCODING/update/update_2.5.1_to_2.6rc1_mysql_$DBENCODING.sql >> log_update.txt 2>> err_update.txt
- echo "update to 2.6"
- mysql $DBNAME -p$DBPASSWORD -u $DBUSER -h $DBHOST -P $DBPORT < mysql/$DBENCODING/update/update_2.6rc1_to_2.6_mysql_$DBENCODING.sql >> log_update.txt 2>> err_update.txt
-#Create Database (Postgres)
-function create_pgsql_db(){
- which psql createdb > /dev/null
- if [ $? -ne 0 ]
- then
- echo "commando pgsql or createdb needed, but not found, exiting..."
- echo "is PostgreSQL installed?"
- echo ""
- exit 1;
- fi
- echo "Your password will be asked several times, this is normal (unless .pgpass is used)"
- createdb -U $DBUSER -h $DBHOST -p $DBPORT -E $DBENCODING $DBNAME -T $DBTEMPLATE
- psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/pgsql_schema_2.5.sql $DBNAME > log_schema.txt 2> err_schema.txt
- psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/pgsql_data_2.5.sql $DBNAME > log_data.txt 2> err_data.txt
- echo "setting sequences"
- psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/pgsql_serial_set_sequences_2.5.sql $DBNAME > log_sequences.txt 2> err_squences.txt
- psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.5_to_2.5.1rc1_pgsql_$DBENCODING.sql $DBNAME > log_update.txt 2> err_update.txt
- psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.5.1rc1_to_2.5.1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
- psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.5.1_to_2.6rc1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
- psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.6rc1_to_2.6_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
-function set_permissions(){
- echo "The installer can set the permissions to the files"
- echo "and directory for you. If you want the installer to"
- echo "do this please enter (y)es else (n)o"
- echo "Please note, to do this you have to be"
- echo "read write access to the Mapbender directory"
- echo "set permissions, (y)es or (n)?"
- read automatic
- if test $automatic != "n"
- then
- echo "Do you want that all files are owned by the apache webserver? (y)es or (n)o"
- read setowner
- if test $setowner != "n"
- then
- echo "Please specify the webserver user"
- read webservuser
- echo "Please specify the webserver group"
- read webservgroup
- chown -R $webservuser:$webservgroup ../../
- fi
- echo "setting permissions on /resources/locale/ and subdirectories"
- chmod -R o+rw ../locale
- echo "setting execute rights on mapbender/tools/i18n_update_mo.sh"
- chmod -R o+rx ../../tools/i18n_update_mo.sh
- # creating mapbender.conf
- if [ -f ../../conf/mapbender.conf ]
- then
- echo "mapbender.conf already exists, not changed"
- else
- cp ../../conf/mapbender.conf-dist ../../conf/mapbender.conf
- fi
- echo ""
- echo "please check and edit the entries in your mapbender.conf manually!"
- fi
-function compile_po(){
- echo ""
- echo "Compiling .po files..."
- cd ../../tools/
- sh ./i18n_update_mo.sh
- cd ../resources/db/
- echo "removing permissions on /resources/locale/ and subdirectories"
- chmod -R o-rw ../locale
- echo "removing execute rights on mapbender/tools/i18n_update_mo.sh"
- chmod -R o-rx ../../tools/i18n_update_mo.sh
- echo ""
-#magic starts here
-show_disclaimer;
-echo "Continue? (y)es or (n)o"
-read disclaimer
-if test $disclaimer != "y"
-then
- exit 1
-fi
-get_db_config;
-show_db_config;
-echo "Look ok? Start Install? (y)es or (n)o"
-read ANSWER
-if [ $ANSWER != "y" ]
-then
- exec $0
-fi
-if [ $DBVERSION = "pgsql" ]
-then
- echo "Creating Postgres Database with encoding:$DBENCODING"
- create_pgsql_db;
-else
- echo "Creating Mysql Database with encoding:$DBENCODING"
- create_mysql_db;
- echo ""
-fi
-set_permissions;
-compile_po;
-echo ""
-echo "Finished...check the log and error files to see if an error occured.";
More information about the Mapbender_commits
