[Mapbender-commits] r4730 - trunk/mapbender/http/javascripts
    svn_mapbender at osgeo.org
    Sat Sep 26 12:42:42 EDT 2009
Author: marc
Date: 2009-09-26 12:42:42 -0400 (Sat, 26 Sep 2009)
New Revision: 4730
   trunk/mapbender/http/javascripts/mod_loadwmc.js
added some cursor styles
Modified: trunk/mapbender/http/javascripts/mod_loadwmc.js
--- trunk/mapbender/http/javascripts/mod_loadwmc.js	2009-09-26 16:22:21 UTC (rev 4729)
+++ trunk/mapbender/http/javascripts/mod_loadwmc.js	2009-09-26 16:42:42 UTC (rev 4730)
@@ -93,7 +93,7 @@
 			// Load WMC
-			var $loadWmc = $("<img src='../img/button_gray/wmc_load.png' title='load this WMC'>");
+			var $loadWmc = $("<img src='../img/button_gray/wmc_load.png' style='cursor:pointer' title='load this WMC'>");
 			$loadWmc.click(function() {
 				var queryObj = {command:"loadWmc", parameters:{id:currentId}};
 				$.post(serverSideFileName, {queryObj: $.toJSON(queryObj)}, function (json, status) {
@@ -132,7 +132,7 @@
 			// Merge WMC
-			var $mergeWmc = $("<img src='../img/button_gray/wmc_merge.png' title='merge WMC'>");
+			var $mergeWmc = $("<img src='../img/button_gray/wmc_merge.png' style='cursor:pointer' title='merge WMC'>");
 			$mergeWmc.click(function() {
 				var	extensionDataString = null;
 				if (currentWmcExtensionData !== null) {
@@ -182,7 +182,7 @@
 			// Append WMC
-			var $appendWmc = $("<img src='../img/button_gray/wmc_append.png' title='append WMC'>");
+			var $appendWmc = $("<img src='../img/button_gray/wmc_append.png' style='cursor:pointer' title='append WMC'>");
 			$appendWmc.click(function() {
@@ -232,7 +232,7 @@
 			// Display WMC
-			var $displayWmc = $("<img src='../img/button_gray/wmc_xml.png' title='display WMC XML'>");
+			var $displayWmc = $("<img src='../img/button_gray/wmc_xml.png' style='cursor:pointer' title='display WMC XML'>");
 			$displayWmc.click(function() {
 				// create Popup
 				if (wmcDisplayPopup === null) {
@@ -258,7 +258,7 @@
 			// OpenLayers Export
-			var imgHtml = "<img src='../img/OpenLayers.trac.png' " +
+			var imgHtml = "<img src='../img/OpenLayers.trac.png' style='cursor:pointer' " +
 				"title='export to OpenLayers' border=0>";
 			var $openlayersWmc = $(imgHtml);
 			$openlayersWmc.click(function () {
@@ -284,7 +284,7 @@
 			$td = $("<td></td>").append($openlayersWmc);
 			$tr.append($td);
-			var $deleteWmc = $("<img src='../img/button_gray/del.png' title='delete this WMC'>");
+			var $deleteWmc = $("<img src='../img/button_gray/del.png' style='cursor:pointer' title='delete this WMC'>");
 			$deleteWmc.click(function() {
 				var queryObj = {command:"deleteWmc", parameters:{id:currentId}};
More information about the Mapbender_commits
