[Mapbender-commits] r4731 - branches/ur_dev/install
svn_mapbender at osgeo.org
Sat Sep 26 13:37:18 EDT 2009
Author: uli
Date: 2009-09-26 13:37:17 -0400 (Sat, 26 Sep 2009)
New Revision: 4731
Added:
branches/ur_dev/install/class_column.php
branches/ur_dev/install/class_constraint.php
branches/ur_dev/install/class_database.php
branches/ur_dev/install/class_dia.php
branches/ur_dev/install/class_table.php
branches/ur_dev/install/update.php
Added: branches/ur_dev/install/class_column.php
--- branches/ur_dev/install/class_column.php (rev 0)
+++ branches/ur_dev/install/class_column.php 2009-09-26 17:37:17 UTC (rev 4731)
@@ -0,0 +1,18 @@
+<?php
+class Column{
+ private $name;
+ private $type;
+ private $value;
+ private $primaryKey;
+ public function __construct($name,$type,$value,$primaryKey){
+ $this->name = $name;
+ $this->type = $type;
+ $this->value = $value;
+ $this->primaryKey = $primaryKey;
+ public function getName(){
+ return $this->name;
Added: branches/ur_dev/install/class_constraint.php
--- branches/ur_dev/install/class_constraint.php (rev 0)
+++ branches/ur_dev/install/class_constraint.php 2009-09-26 17:37:17 UTC (rev 4731)
@@ -0,0 +1,32 @@
+<?php
+abstract class Constraint{
+ protected $table;
+class ForeignKeyConstraint extends Constraint{
+ private $column;
+ private $referenceTable;
+ private $referenceColumn;
+ private $text;
+ public function __construct($table, $column, $referenceTable, $referenceColumn, $text){
+ $this->table = $table;
+ $this->column = $column;
+ $this->referenceTable = $referenceTable;
+ $this->referenceColumn = $referenceColumn;
+ $this->text = $text;
+class PrimaryKeyConstraint extends Constraint{
+ private $columnArray;
+ public function __construct($table, $columnArray){
+ $this->columnArray = $columnArray;
Modified: branches/ur_dev/install/class_database.php
--- branches/ur_dev/install/class_database.php 2009-09-26 16:42:42 UTC (rev 4730)
+++ branches/ur_dev/install/class_database.php 2009-09-26 17:37:17 UTC (rev 4731)
@@ -1,8 +1,26 @@
<?php
-class database{
+class Database{
+ private $tableArray = array();
public function __construct(){
+ public function addTable($table){
+ if(is_a($table, "Table")){
+ $this->tableArray[] = $table;
+ return true;
+ return false;
+ public function getTableByName($name){
+ foreach($this->tableArray as $table){
+ if($table->getName() == $name){
+ return $table;
+ return null;
Modified: branches/ur_dev/install/class_dia.php
--- branches/ur_dev/install/class_dia.php 2009-09-26 16:42:42 UTC (rev 4730)
+++ branches/ur_dev/install/class_dia.php 2009-09-26 17:37:17 UTC (rev 4731)
@@ -48,13 +48,13 @@
$key = $keys->item(0);
if ($i === 1) {
$left = $this->removeHash($key->firstChild->nodeValue);
- $leftConnection = $key->parentNode->parentNode->nextSibling->firstChild->getAttribute("connection");
+ $leftConnection = $this->getTableNameById($key->parentNode->parentNode->nextSibling->firstChild->getAttribute("to"));
else {
$right = $this->removeHash($key->firstChild->nodeValue);
$text = $this->removeHash($key->nextSibling->firstChild->nodeValue);
- $rightConnection = $key->parentNode->parentNode->nextSibling->firstChild->nextSibling->getAttribute("connection");
+ $rightConnection = $this->getTableNameById($key->parentNode->parentNode->nextSibling->firstChild->nextSibling->getAttribute("to"));
@@ -80,8 +80,7 @@
foreach($constraintIds as $constraintId){
$constraints[] = $this->getConstraintKeys($constraintId);
- print_r($constraints);
- return serialize($constraints);
+ return $constraints;
private function getTableNodeById($id){
@@ -93,7 +92,18 @@
return $table;
+ private function getTableNameById($id){
+ $node = $this->getTableNodeById($id);
+ $attributes = $node->childNodes;
+ foreach($attributes as $attribute){
+ if($attribute->getAttribute('name') == 'name'){
+ return $this->removeHash($attribute->firstChild->nodeValue);
private function getTableIdByName($tablename){
$tables = $this->getTableNodes();
Modified: branches/ur_dev/install/class_table.php
--- branches/ur_dev/install/class_table.php 2009-09-26 16:42:42 UTC (rev 4730)
+++ branches/ur_dev/install/class_table.php 2009-09-26 17:37:17 UTC (rev 4731)
@@ -1,7 +1,40 @@
<?php
-class table{
- public function __construct(){
+class Table{
+ private $columnArray = array();
+ private $name;
+ private $constraintArray = array();
+ public function __construct($name){
+ public function addColumn($column){
+ if(is_a($column, "Column")){
+ $this->columnArray[] = $column;
+ return true;
+ return false;
+ public function addConstraint($constraint){
+ if(is_a($constraint, "Constraint")){
+ $this->constraintArray[] = $constraint;
+ return true;
+ return false;
+ public function getColumnByName($name){
+ foreach($this->columnArray as $column){
+ if($column->getName() == $name){
+ return $column;
+ return null;
Modified: branches/ur_dev/install/update.php
--- branches/ur_dev/install/update.php 2009-09-26 16:42:42 UTC (rev 4730)
+++ branches/ur_dev/install/update.php 2009-09-26 17:37:17 UTC (rev 4731)
@@ -1,5 +1,10 @@
<?php
include("class_dia.php");
+include("class_database.php");
+include("class_table.php");
+include("class_column.php");
+include("class_constraint.php");
$defaultfile = "../resources/db/schema_2.6.dia";
fwrite(STDOUT, "Please enter the path to you *.dia file\n");
@@ -23,15 +28,42 @@
//fwrite(STDOUT, "Hello $name");
+$db = new Database();
$tables = $dia->getTableNames();
foreach($tables as $table){
fwrite(STDOUT, "Found Tables: ".$table."\n");
+ $tab = new Table($table);
+ $db->addTable($tab);
$columns = $dia->getColumns($table);
- #print_r($columns);
+ foreach($columns as $column){
+ $col = new Column($column["name"],$column["type"],$column["value"],$column["primaryKey"]);
+ $tab->addColumn($col);
$constraints = $dia->getConstraints();
+foreach($constraints as $constraint){
+ $table = $db->getTableByName($constraint["rightConnection"]);
+ $column = $table->getColumnByName($constraint["right"]);
+ $referenceTable = $db->getTableByName($constraint["leftConnection"]);
+ $referenceColumn = $table->getColumnByName($constraint["left"]);
+ $const = new ForeignKeyConstraint($table, $column, $referenceTable, $referenceColumn, $constraint["text"]);
+ $tab->addConstraint($const);
+var_dump($db);
+exit(0);
# fwrite(STDOUT, " constraint: ".$constraint."\n");
// von den rightConnection noch alle pk löschen (auf 0)
More information about the Mapbender_commits
