[Mapbender-commits] r5875 - branches/2.6/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Apr 8 03:59:19 EDT 2010
Author: christoph
Date: 2010-04-08 03:59:18 -0400 (Thu, 08 Apr 2010)
New Revision: 5875
Removed:
   branches/2.6/http/php/mod_changeEPSG_dynamic.php
obsolete
Deleted: branches/2.6/http/php/mod_changeEPSG_dynamic.php
--- branches/2.6/http/php/mod_changeEPSG_dynamic.php	2010-04-08 06:54:23 UTC (rev 5874)
+++ branches/2.6/http/php/mod_changeEPSG_dynamic.php	2010-04-08 07:59:18 UTC (rev 5875)
@@ -1,247 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/mod_changeEPSG_dynamic.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/mb_validateSession.php");
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<meta name="author-mail" content="info at ccgis.de">
-<meta name="author" content="U. Rothstein, T. Wirkus">
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>changeEPSG_dynamic</title>
-<style type="text/css">
-.epsg{
-	width:100px;
-	border: solid;
-</style>
-<?php
-$gui_id = $_SESSION["mb_user_gui"];
-$con = db_connect($DBSERVER,$OWNER,$PW);
-db_select_db(DB,$con);
-$sql = "SELECT e_target FROM gui_element WHERE e_id = 'changeEPSG' AND fkey_gui_id = $1";
-$v = array($gui_id);
-$t = array('s');
-$res = db_prep_query($sql,$v,$t);
-$cnt_gui_wms = 0;
-$cnt_epsg_wms = 0;
-$cnt_layer_wms = 0;
-/*get allocated wms from allocated gui  ***********************************************************/
-$sql_gui_wms = "SELECT fkey_wms_id FROM gui_wms WHERE fkey_gui_id = $1 ORDER BY fkey_wms_id";
-$t = array('s');
-$res_gui_wms = db_prep_query($sql_gui_wms,$v,$t);
-while(db_fetch_row($res_gui_wms)){
-	$fkey_gui_id[$cnt_gui_wms] = db_result($res_gui_wms,$cnt_gui_wms,"fkey_gui_id");
-	$fkey_wms_id_1[$cnt_gui_wms] = db_result($res_gui_wms,$cnt_gui_wms,"fkey_wms_id");
-	$cnt_gui_wms++;
-/*get allocated layer_id from allocated gui  ******************************************************/
-$v = array();
-$t = array();
-$sql_layer_wms = "SELECT  layer_id FROM layer WHERE fkey_wms_id IN (";
-for($i=0; $i<count($fkey_wms_id_1); $i++){
-	if($i>0){ $sql_layer_wms .= ",";}
-	$sql_layer_wms .= "$".($i+1);
-	array_push($v,$fkey_wms_id_1[$i]);
-	array_push($t,'i');
-$sql_layer_wms.= ") ORDER BY layer_id";
-$res_layer_wms = db_prep_query($sql_layer_wms,$v,$t);
-while($row = db_fetch_array($res_layer_wms)){
-	$layer_id[$cnt_layer_wms] = $row["layer_id"];
-	$fkey_wms_id[$cnt_layer_wms] = $row["fkey_wms_id"];
-	$cnt_layer_wms++;
-/*get allocated epsg-code from allocated wms  *****************************************************/
-$v = array();
-$t = array();
-$sql_epsg_wms = "SELECT DISTINCT wms_srs FROM wms_srs WHERE fkey_wms_id IN (";
-	if($i>0){ $sql_epsg_wms .= ",";}
-	$sql_epsg_wms .= "$".($i+1);
-$sql_epsg_wms.= ") ORDER BY wms_srs";
-$res_epsg_wms = db_prep_query($sql_epsg_wms,$v,$t);
-while($row = db_fetch_array($res_epsg_wms)){
-	$fkey_wms_id_2[$cnt_epsg_wms] = $row["fkey_wms_id"];
-	$epsg_code[$cnt_epsg_wms] = $row["wms_srs"];
-	$cnt_epsg_wms++;  //possible error because increment before echo statement
-	echo"$epsg_code[$cnt_epsg_wms]";
-echo "<script type='text/javascript'>";
-echo "var myTarget = '".db_result($res,0,"e_target")."';";
-echo "</script>";
-# transform coordinates
-if(isset($_REQUEST["srs"])){
-	require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-	$con = pg_connect ($con_string) or die ("Error while connecting database DBname");
-	$arraymapObj = mb_split("###", $_REQUEST["srs"]);
-	echo "<script type='text/javascript'>";
-	echo "var newExtent = new Array();";
-	for($i=0; $i < count($arraymapObj); $i++){
-		$temp = mb_split(",",$arraymapObj[$i]);
-		$sqlMinx = "SELECT X(transform(GeometryFromText('POINT(".$temp[2]." ".$temp[3].")',".preg_replace("/EPSG:/","",$temp[1])."),".preg_replace("/EPSG:/","",$_REQUEST["newSRS"]).")) as minx";
-		$resMinx = @pg_query($con,$sqlMinx);
-		$minx = pg_result($resMinx,0,"minx");
-		$sqlMiny = "SELECT Y(transform(GeometryFromText('POINT(".$temp[2]." ".$temp[3].")',".preg_replace("/EPSG:/","",$temp[1])."),".preg_replace("/EPSG:/","",$_REQUEST["newSRS"]).")) as miny";
-		$resMiny = @pg_query($con,$sqlMiny);
-		$miny = pg_result($resMiny,0,"miny");
-		$sqlMaxx = "SELECT X(transform(GeometryFromText('POINT(".$temp[4]." ".$temp[5].")',".preg_replace("/EPSG:/","",$temp[1])."),".preg_replace("/EPSG:/","",$_REQUEST["newSRS"]).")) as maxx";
-		$resMaxx = @pg_query($con,$sqlMaxx);
-		$maxx = pg_result($resMaxx,0,"maxx");
-		$sqlMaxy = "SELECT Y(transform(GeometryFromText('POINT(".$temp[4]." ".$temp[5].")',".preg_replace("/EPSG:/","",$temp[1])."),".preg_replace("/EPSG:/","",$_REQUEST["newSRS"]).")) as maxy";
-		$resMaxy = @pg_query($con,$sqlMaxy);
-		$maxy = pg_result($resMaxy,0,"maxy");
-		$extenty = $maxy - $miny;
-		$extentx = $maxx - $minx;
-		$relation_px_x = $temp[6] / $temp[7];
-		$relation_px_y = $temp[7] / $temp[6];
-		$relation_bbox_x = $extentx / $extenty;
-		if($relation_bbox_x <= $relation_px_x){
-			$centerx = $minx + ($extentx/2);
-			$minx = $centerx - $relation_px_x * $extenty / 2;
-			$maxx = $centerx + $relation_px_x * $extenty / 2;
-		if($relation_bbox_x > $relation_px_x){
-			$centery = $miny + ($extenty/2);
-			$miny = $centery - $relation_px_y * $extentx / 2;
-			$maxy = $centery + $relation_px_y * $extentx / 2;
-		echo "newExtent[".$i."] = '".$temp[0].",".$_REQUEST["newSRS"].",".$minx.",".$miny.",".$maxx.",".$maxy."';";
-	echo "</script>";
-else{
-	echo "<script type='text/javascript'>var newExtent = false;</script>";
-<script type='text/javascript'>
-if(newExtent == false){
- parent.mb_registerSubFunctions("window.frames['changeEPSG_dynamic'].mod_changeEPSG_setBox()");
-function mod_changeEPSG_init(){
-//frameName, EPSG, minx, miny, maxx, maxy, width, height
-	var exists = false;
-	if(newExtent){
-		for(var i=0; i<newExtent.length; i++){
-			var temp = newExtent[i].split(",");
-			if(temp[0] == myTarget){
-				for(var ii=0; ii<parent.mb_MapHistoryObj[temp[0]].length; ii++){
-					if(parent.mb_MapHistoryObj[temp[0]][ii].epsg == temp[1]){
-						exists = ii;
-						var goback = true;
-				var ind = parent.getMapObjIndexByName(temp[0]);
-				if(goback){
-					parent.mb_mapObj[ind].epsg = temp[1];
-					parent.mb_mapObj[ind].extent = parent.mb_MapHistoryObj[temp[0]][exists].extent;
-					parent.setMapRequest(temp[0]);
-				else{
-					parent.mb_mapObj[ind].extent = parseFloat(temp[2]) + "," + parseFloat(temp[3]) + "," + parseFloat(temp[4]) + "," + parseFloat(temp[5]);
-			if(temp[0] != myTarget){
-function mod_changeEPSG_setBox(){
-	var myEPSG = parent.mb_mapObj[0].epsg;
-	for(var i=0; i<document.forms[0].epsg.length; i++){
-		if(document.forms[0].epsg.options[i].value == myEPSG){
-			document.forms[0].epsg.selectedIndex = i;
-			isEPSG = true;
-function mod_changeEPSG(){
-	str_srs = "";
-	for(var i=0; i<parent.mb_mapObj.length; i++){
-	if(i>0){str_srs += "###";}
-		str_srs += parent.mb_mapObj[i].frameName + "," + parent.mb_mapObj[i].epsg + "," + parent.mb_mapObj[i].extent + ","+parent.mb_mapObj[i].width+","+parent.mb_mapObj[i].height;
-	document.forms[0].srs.value = str_srs;
-	var ind = document.forms[0].epsg.selectedIndex;
-	document.forms[0].newSRS.value = document.forms[0].epsg.options[ind].value;
-	document.forms[0].submit();
-</script>
-</head>
-<body leftmargin="1" topmargin="1" onload="mod_changeEPSG_init()" bgcolor="#0066cc">
-<?php
-/*insert EPSG into selectbox************************************************************************************/
-echo "<form action='" . $self ."' method='post'>";
-echo "<select  class='epsg' name='epsg' onChange='mod_changeEPSG()'>";
-for($i=0; $i<$cnt_epsg_wms; $i++){
-	echo "<option value='" . $epsg_code[$i] . "' ";
-	if($epsg && $epsg == $epsg_code[$i]){
-	echo ">" . $epsg_code[$i]  . "</option>";
-echo "</select>";
-/*insert EPSG in selectbox************************************************************************************/
-echo"<input type='hidden' name='srs' value=''>";
-echo"<input type='hidden' name='newSRS' value=''>";
-echo"</form>";
-</body>
-</html>
\ No newline at end of file
More information about the Mapbender_commits mailing list
