[Mapbender-commits] r5876 - branches/2.6/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Apr 8 04:57:39 EDT 2010
Author: christoph
Date: 2010-04-08 04:57:38 -0400 (Thu, 08 Apr 2010)
New Revision: 5876
Removed:
   branches/2.6/http/php/mod_displayKML.php
obsolete
Deleted: branches/2.6/http/php/mod_displayKML.php
--- branches/2.6/http/php/mod_displayKML.php	2010-04-08 07:59:18 UTC (rev 5875)
+++ branches/2.6/http/php/mod_displayKML.php	2010-04-08 08:57:38 UTC (rev 5876)
@@ -1,38 +0,0 @@
-<?php
-# $Id: class_wmc.php,v 1.31 2006/03/16 14:49:30 c_baudson Exp $
-# http://www.mapbender.org/index.php/class_wmc.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-mb_internal_encoding("UTF-8");
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-require_once(dirname(__FILE__) . "/../classes/class_kml_ows.php");
-$kmlId = $_GET["kmlId"];
-$kml = new KML();
-$kmlDoc = $kml->getKmlDocumentFromDB($kmlId);
-if ($kmlDoc) {
-	header("Content-type: application/xhtml+xml; charset=" . CHARSET);
-	echo $kmlDoc;
-else {
-	echo "You may not have the rights to access this document. Check your log file.";
\ No newline at end of file
More information about the Mapbender_commits mailing list
