[Mapbender-commits] r5888 - in trunk/mapbender/http: javascripts php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sat Apr 10 09:51:03 EDT 2010
Author: verenadiewald
Date: 2010-04-10 09:51:03 -0400 (Sat, 10 Apr 2010)
New Revision: 5888
Added:
   trunk/mapbender/http/javascripts/mod_confirmLogin.php
   trunk/mapbender/http/php/mod_confirmLogin_server.php
   trunk/mapbender/http/php/mod_registerUser_server.php
   trunk/mapbender/http/php/mod_editFilteredUser.php
new mode for password insertion -> admin can send mail to new mapbender user to set password
Added: trunk/mapbender/http/javascripts/mod_confirmLogin.php
--- trunk/mapbender/http/javascripts/mod_confirmLogin.php	                        (rev 0)
+++ trunk/mapbender/http/javascripts/mod_confirmLogin.php	2010-04-10 13:51:03 UTC (rev 5888)
@@ -0,0 +1,207 @@
+<?php
+# $Id: mod_confirmLogin.php
+# http://www.mapbender.org/index.php/mod_confirmLogin.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+include_once dirname(__FILE__) . "/../../conf/mapbender.conf";
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<meta http-equiv="Content-Type" content="text/html; charset=<?php echo CHARSET;?>">
+<title>Confirm Login</title>
+<?php
+$userId = $_GET["user_id"];
+if (!is_numeric($userId)) {
+	echo "User ID not valid!";
+	die;
+$userName = $_GET["user_name"];
+$pattern = "/[a-z0-9_-]/i";
+if (!preg_match($pattern, $userName)) {
+	echo "User Name not valid!";
+	die;
+$userTicket = $_GET["user_ticket"];
+$pattern = "/[a-z0-9]{30}/i";
+if (!preg_match($pattern, $userTicket)) {
+	echo "User Ticket not valid!";
+	die;
+<style type="text/css">
+body{
+	font-family: Arial, Helvetica, sans-serif;
+	font-size: 10px;
+</style>
+<script type='text/javascript' src="../extensions/jquery.js"></script>
+<script type="text/javascript">
+<?php
+echo "var userId = ".$_REQUEST['user_id'].";\n";
+echo "var userName = '".htmlentities($userName, ENT_QUOTES, CHARSET)."';\n";
+echo "var userTicket = '".htmlentities($userTicket, ENT_QUOTES, CHARSET)."';\n";
+ * Check if ticket number for this user is valid
+ * @return boolean return true if ticket number is valid
+function checkTicketNumber () {
+	var parameters = {
+		"command" : "checkTicket",
+		"userId" : userId,
+		userTicket : userTicket
+	$.post("../php/mod_confirmLogin_server.php", parameters, function (json, status) {
+		if(status == 'success') {
+			if (json == 'true') {
+				createInsertFields();
+			else {
+				$("#contentDiv").text("You are not authorized. Please request a new ticket from your administrator to set your password.");
+ * Creates table with insert fields
+function createInsertFields() {
+	//create table
+	var $table = $("<table></table>");
+	$table.appendTo("#contentDiv");
+	//create lines and fields
+	var $tr1 = $("<tr><td>User name:</td><td><input type='text' readonly id='userName'/></td><td></td></tr>");
+	var $tr2 = $("<tr><td>Password:</td><td><input type='password' id='userPw'/></td><td id='spanTd'></td></tr>");
+	var $tr3 = $("<tr><td>Confirm password:</td><td><input type='password' id='userPw2'/></td><td></td></tr>");
+	$tr1.appendTo($table);
+	$tr2.appendTo($table);
+	$tr3.appendTo($table);
+	//fill in field userName
+	$("#userName").val(userName);
+	//set keyup event for password check
+	$("#userPw").keyup(function () {
+		checkSafety(this.value);
+	//create span for pwd safety message
+	$("<span />").attr("id","pwdSafetyMsg").appendTo("#spanTd");
+	//set div and button for saving pw
+	var $buttonDiv = $("<div><input type='button' value='Save'></div");
+	$buttonDiv.click(function () {
+    	savePwd();
+	$buttonDiv.appendTo("#contentDiv");
+ * Save new password
+function savePwd() {
+	if(checkPassword()) {
+			command : "savePwd",
+			userId : userId,
+			userTicket : userTicket,
+			userPassword : document.getElementById("userPw").value
+				alert(json);
+				var $loginHref = $("<div style='margin-top:20px'><a href='../frames/login.php'>Zum Login</a></div");
+				$loginHref.appendTo("#contentDiv");
+ * Check if password and password confirmation are inserted correctly
+function checkPassword() {
+	var newPw = document.getElementById("userPw");
+	var newPwConfirm = document.getElementById("userPw2");
+	if(newPw.value == '' || newPwConfirm.value == '' || newPw.value != newPwConfirm.value) {
+		alert("Password verification failed. Please insert password twice!");
+	    newPw.value = "";
+	    newPwConfirm.value = "";
+	    newPw.focus();
+	    $("#pwdSafetyMsg").html("");
+	    return false;
+	else {
+		return true;
+function checkSafety(pwdString){
+	var pwdMsg = "";
+	var pwdPoints = pwdString.length;
+	var hasLetter = new RegExp("[a-z]");
+	var hasCaps	= new RegExp("[A-Z]");
+	var hasNumbers = new RegExp("[0-9]");
+	var hasSymbols = new RegExp("\\W");
+	if(hasLetter.test(pwdString)){ pwdPoints += 4; }
+	if(hasCaps.test(pwdString)){ pwdPoints += 4; }
+	if(hasNumbers.test(pwdString)){ pwdPoints += 4; }
+	if(hasSymbols.test(pwdString)){ pwdPoints += 4; }
+	if(pwdPoints >= 24) {
+		$("#pwdSafetyMsg").css("color","#0f0");
+		pwdMsg = "Your password is strong!";
+	else if(pwdPoints >= 16) {
+		$("#pwdSafetyMsg").css("color","#00f");
+		pwdMsg = "Your password is medium!";
+	else if(pwdPoints >= 12) {
+		$("#pwdSafetyMsg").css("color","#fa0");
+		pwdMsg = "Your password is weak!";
+	else {
+		$("#pwdSafetyMsg").css("color","#f00");
+		pwdMsg = "Your password is very weak!";
+	$("#pwdSafetyMsg").html(pwdMsg);
+</script>
+</head>
+<body onload='checkTicketNumber();'>
+	<div id='contentDiv'>
+	</div>
+</body>
+</html>
Added: trunk/mapbender/http/php/mod_confirmLogin_server.php
--- trunk/mapbender/http/php/mod_confirmLogin_server.php	                        (rev 0)
+++ trunk/mapbender/http/php/mod_confirmLogin_server.php	2010-04-10 13:51:03 UTC (rev 5888)
@@ -0,0 +1,63 @@
+<?php
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+$command = $_POST["command"];
+$pattern = "/[a-z]/i";
+if (!preg_match($pattern, $command)) {
+	echo "Command not valid!";
+	die;
+$userId = $_POST["userId"];
+	die;
+$userTicket = $_POST["userTicket"];
+	die;
+$userPassword = $_POST["userPassword"];
+//$pattern = "/[a-z0-9A-Z]/";
+//if (!preg_match($pattern, $userTicket)) {
+//	echo "User Ticket not valid!";
+//	die;
+if($command == 'checkTicket') {
+	$sql = "SELECT * FROM mb_user ";
+	$sql .= "WHERE mb_user_id = $1 AND mb_user_password_ticket = $2";
+    $v = array($userId,$userTicket);
+	$t = array("i","s");
+	$res = db_prep_query($sql,$v,$t);
+    $row = db_fetch_array($res);
+    if ($row) {
+    	if($row['mb_user_password_ticket'] == '' || $row['mb_user_password_ticket'] != $userTicket) {
+    		echo "false";
+    	else {
+    		echo "true";
+    else {
+    	echo "false";
+if($command == 'savePwd') {
+	$sql = "UPDATE mb_user SET mb_user_password = $1, mb_user_password_ticket = '' WHERE mb_user_id = $2 AND mb_user_password_ticket = $3";
+	$v = array(md5($userPassword),$userId,$userTicket);
+	$t = array('s','i','s');
+	if($res){
+		echo "Password saved successfully.";
+	else {
+		echo "Error while saving password.";
Modified: trunk/mapbender/http/php/mod_editFilteredUser.php
--- trunk/mapbender/http/php/mod_editFilteredUser.php	2010-04-10 11:59:02 UTC (rev 5887)
+++ trunk/mapbender/http/php/mod_editFilteredUser.php	2010-04-10 13:51:03 UTC (rev 5888)
@@ -35,8 +35,42 @@
 $myPW = "**********";
 echo "<script language='JavaScript'>var myPW = '".$myPW."';</script>";
+<?php
+	include '../include/dyn_js.php';
+	include '../include/dyn_php.php';
+	$myPW = "**********";
+	echo "var myPW = '".$myPW."';";
+	echo "var withPasswordInsertion = '" . $withPasswordInsertion . "';";
+</script>
 <script language="JavaScript">
+function sendRegisterData() {
+	if (document.form1.email.value == '') {
+		alert("Data could not be sent. No mail address given for this user.");
+		return false;
+		command : "sendMailToCustomer",
+		userId : document.form1.selected_user.options[document.form1.selected_user.selectedIndex].value
+	$.post("../php/mod_registerUser_server.php", parameters, function (json, status) {
+			alert(json);
+function callPick(obj){
+	dTarget = obj;
+	var dp = window.open('../tools/datepicker/datepicker.php?m=Jan_Feb_März_April_Mai_Juni_Juli_Aug_Sept_Okt_Nov_Dez&d=Mo_Di_Mi_Do_Fr_Sa_So&t=heute','dp','left=200,top=200,width=230,height=210,toolbar=0,location=0,directories=0,status=0,menubar=0,scrollbars=0');
+	dp.focus();
+	return false;
 function validate(val){
    var ok = validateInput();
    if(ok == 'true'){
@@ -50,13 +84,18 @@
      if(val == 'delete'){
         permission = confirm("Delete User?");
+     if(val == 'new_pw_ticket'){
+     	permission = confirm("Set new password ticket for this user?");
      if(permission === true){
-        if(document.forms[0].password.value == myPW){
-            document.forms[0].password.value = '';
-        document.forms[0].action.value = val;
-        document.forms[0].submit();
+      	if(withPasswordInsertion == 'true'){
+         	if(document.forms[0].password.value == myPW){
+             	document.forms[0].password.value = '';
+         document.forms[0].action.value = val;
+         document.forms[0].submit();
 function validateInput(){
@@ -66,22 +105,24 @@
       document.forms[0].name.focus();
       return 'false';
-  if(document.forms[0].password.value === ''){
-      alert(str_alert);
-      document.forms[0].password.focus();
-      return 'false';
+  if(withPasswordInsertion == 'true') {
+	  if(document.forms[0].password.value === '') {
+	      alert(str_alert);
+	      document.forms[0].password.focus();
+	      return 'false';
+      if((document.forms[0].password.value != myPW || document.forms[0].v_password.value !== '' )&& document.forms[0].password.value != document.forms[0].v_password.value){
+	      alert("Password verification failed. You have to enter the same password twice!");
+	      document.forms[0].password.value = myPW;
+	      return 'false';
-  if((document.forms[0].password.value != myPW || document.forms[0].v_password.value !== '' )&& document.forms[0].password.value != document.forms[0].v_password.value){
-      alert("Password verification failed. You have to enter the same password twice!");
-      document.forms[0].password.value = myPW;
-      return 'false';
-  if(document.forms[0].resolution.value === ''){
+  if(document.forms[0].resolution.value === '') {
       document.forms[0].resolution.value = 72;
       return 'true';
-  if(document.forms[0].login_count.value === ''){
+  if(document.forms[0].login_count.value === '') {
       document.forms[0].login_count.value = 0;
       return 'true';
@@ -142,11 +183,19 @@
 	else{
 		$sql = "Insert INTO mb_user (mb_user_name, mb_user_password, mb_user_owner, mb_user_description, ";
-		$sql .= "mb_user_email, mb_user_phone, mb_user_department, mb_user_resolution) VALUES ";
-		$sql.= "($1,$2,$3,$4,$5,$6,$7,$8)";
-		$tmpPW = md5($password);
-		$v = array($name,$tmpPW,$owner_id,$description,$email,$phone,$department,$resolution);
-		$t = array('s','s','i','s','s','s','s','i');
+		$sql .= "mb_user_email, mb_user_phone, mb_user_department, mb_user_resolution, mb_user_password_ticket) VALUES ";
+		$sql.= "($1,$2,$3,$4,$5,$6,$7,$8,$9)";
+		if($withPasswordInsertion == 'true') {
+			$tmpPW = md5($password);
+			$passwordTicket = "";
+		else {
+			$tmpPW = md5(microtime());
+			$passwordTicket = substr(md5(uniqid(rand())),0,30);
+		$v = array($name,$tmpPW,$owner_id,$description,$email,$phone,$department,$resolution,$passwordTicket);
+		$t = array('s','s','i','s','s','s','s','i','s');
 		$selected_user = db_insert_id($res,"mb_user","mb_user_id");
@@ -184,6 +233,22 @@
+if($action == 'new_pw_ticket'){
+	$sql = "UPDATE mb_user SET mb_user_password_ticket = $1";
+	$sql.=" WHERE mb_user_id = $2";
+	$v = array($passwordTicket,$selected_user);
+	$t = array('s','i');
+	if($res){
+		echo "<script language='JavaScript'>alert('New password ticket created.');</script>";
 if (!isset($name) || $selected_user == 'new'){
   $name = "";
   $password = "";
@@ -271,28 +336,30 @@
    echo "</td>";
 echo "</tr>";
-#password
-echo "<tr>";
-   echo "<td>Password: </td>";
-   echo "<td>";
-      echo "<input type='password' size='30' name='password' value='";
-      if(isset($selected_user) && $selected_user != 'new'){
-         echo $myPW;
-      echo "' >";
-   echo "</td>";
-echo "</tr>";
+if($withPasswordInsertion == 'true') {
+	#password
+	echo "<tr>";
+	   echo "<td>Password: </td>";
+	   echo "<td>";
+	      echo "<input type='password' size='30' name='password' value='";
+	      if(isset($selected_user) && $selected_user != 'new'){
+	         echo $myPW;
+	      echo "' >";
+	      echo "<input type='hidden' name='password_plain' value='".$password."'>";
+	   echo "</td>";
+	echo "</tr>";
+	#confirm password
+	echo "<tr>";
+	   echo "<td>Confirm password: </td>";
+	   echo "<td>";
+	      echo "<input type='password' size='30' name='v_password' value='";
+	      echo "'>";
+	   echo "</td>";
+	echo "</tr>";
-#confirm password
-echo "<tr>";
-   echo "<td>Confirm password: </td>";
-   echo "<td>";
-      echo "<input type='password' size='30' name='v_password' value='";
-      echo "'>";
-   echo "</td>";
-echo "</tr>";
 #owner
 echo "<tr>";
    echo "<td>Owner: </td>";
@@ -359,6 +426,10 @@
 if(Mapbender::session()->get("mb_user_id") == $owner_id && $selected_user != 'new' && $selected_user != '' ){
    echo "<input type='button' value='save'  onclick='validate(\"update\")'>";
    echo "<input type='button' value='delete'  onclick='validate(\"delete\")'>";
+   if($withPasswordInsertion != 'true') {
+   	  echo "<input type='button' value='Send login data to user'  onclick='sendRegisterData();'>";
+   	  echo "&nbsp;<input type='button' value='New password ticket'  onclick='validate(\"new_pw_ticket\");'>";
 <input type='hidden' name='action' value=''>
Added: trunk/mapbender/http/php/mod_registerUser_server.php
--- trunk/mapbender/http/php/mod_registerUser_server.php	                        (rev 0)
+++ trunk/mapbender/http/php/mod_registerUser_server.php	2010-04-10 13:51:03 UTC (rev 5888)
@@ -0,0 +1,64 @@
+<?php
+# $Id:
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+$command = $_REQUEST["command"];
+if($command == 'sendMailToCustomer') {
+	$admin = new administration();
+	$mailToAddr = $admin->getEmailByUserId($_REQUEST['userId']);
+	$mailToName = $admin->getUsernameByUserId($_REQUEST['userId']);
+	$sql .= "WHERE mb_user_id = $1";
+    $v = array($_REQUEST['userId']);
+	$t = array("i");
+    if ($row) {
+		$userId = $row["mb_user_id"];
+		$userName = $row["mb_user_name"];
+		$email = $row["mb_user_email"];
+		$ticket = $row["mb_user_password_ticket"];
+		$customerMessage = "You are now registered as a Mapbender User.\n";
+		$customerMessage .= "Your login name is: ".$userName."\n";
+		$customerMessage .= "Please set your own password using the following link: \n";
+		$mbUrl = substr(LOGIN, 0, -9);
+		$customerMessage .= $mbUrl."../javascripts/mod_confirmLogin.php?user_id=".$userId."&user_name=".$userName."&user_ticket=".$ticket."\n";
+		$customerMessage .= "Follow this link to login to Mapbender: \n";
+		$customerMessage .= LOGIN."\n";
+		if(!$admin->sendEmail("", "", $mailToAddr, $mailToName, utf8_decode("Your Mapbender account"), utf8_decode($customerMessage), $error_msg)) {
+			echo "Registry data could not be send. Please check mail address.";
+		else {
+			echo "Registry data has been sent successfully to new Mapbender user.";
+	else {
+		echo "User does not exists.";
\ No newline at end of file
More information about the Mapbender_commits mailing list
