[Mapbender-commits] r5889 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sat Apr 10 09:55:53 EDT 2010
Author: verenadiewald
Date: 2010-04-10 09:55:51 -0400 (Sat, 10 Apr 2010)
New Revision: 5889
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
add element var withPasswordInsertion to element editFilteredUser
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql	2010-04-10 13:51:03 UTC (rev 5888)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql	2010-04-10 13:55:51 UTC (rev 5889)
@@ -2267,5 +2267,15 @@
 gui_element.fkey_gui_id
 NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'body' AND var_name = 'resultListCss');
+-- add element var withPasswordInsertion to element editFilteredUser
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
+SELECT gui_element.fkey_gui_id,
+'editFilteredUser', 'withPasswordInsertion', 'true', 'define if admin can set the new user' ,'php_var'
+from gui_element
+WHERE
+gui_element.e_id = 'editFilteredUser' AND
+gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'editFilteredUser' AND var_name = 'withPasswordInsertion');
More information about the Mapbender_commits mailing list
