[Mapbender-commits] r5907 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org
Sun Apr 11 06:32:25 EDT 2010
Author: verenadiewald
Date: 2010-04-11 06:32:24 -0400 (Sun, 11 Apr 2010)
New Revision: 5907
Added:
trunk/mapbender/http/php/mod_sendUserMail.php
Removed:
trunk/mapbender/http/php/mod_registerUser_server.php
trunk/mapbender/http/classes/class_user.php
trunk/mapbender/http/php/mod_editFilteredUser.php
restructuring of functionality setting password
Modified: trunk/mapbender/http/classes/class_user.php
--- trunk/mapbender/http/classes/class_user.php 2010-04-11 09:31:30 UTC (rev 5906)
+++ trunk/mapbender/http/classes/class_user.php 2010-04-11 10:32:24 UTC (rev 5907)
@@ -19,6 +19,7 @@
require_once(dirname(__FILE__)."/../../core/globalSettings.php");
require_once(dirname(__FILE__)."/../classes/class_RPCEndpoint.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
* A Mapbender user as described in the table mb_user.
@@ -46,7 +47,15 @@
var $postalCode;
var $country ="";
var $url ="";
+ var $realName = "";
+ var $street = "";
+ var $houseNumber = "";
+ var $reference = "";
+ var $forAttentionOf = "";
+ var $validFrom = "";
+ var $validTo = "";
+ var $passwordTicket = "";
static $displayName = "User";
static $internalName = "user";
@@ -102,8 +111,15 @@
"city" => $this->city,
"postalCode" => $this->postalCode,
"country" => $this->country,
- "url" => $this->url
+ "url" => $this->url,
+ "realName" => $this->realName,
+ "street" => $this->street,
+ "housenumber" => $this->housenumber,
+ "reference" => $this->reference,
+ "forAttentionOf" => $this->forAttentionOf,
+ "validFrom" => $this->validFrom,
+ "validTo" => $this->validTo,
+ "passwordTicket" => $this->passwordTicket
return $result;
@@ -196,6 +212,14 @@
$this->country = $changes->country ? $changes->country : $this->country;
$this->url = $changes->url ? $changes->url : $this->url;
$this->id = $changes->id ? $changes->id : $this->id;
+ $this->realName = $changes->realName ? $changes->realName : $this->realName;
+ $this->street = $changes->street ? $changes->street : $this->street;
+ $this->houseNumber = $changes->houseNumber ? $changes->houseNumber : $this->houseNumber;
+ $this->reference = $changes->reference ? $changes->reference : $this->reference;
+ $this->forAttentionOf = $changes->forAttentionOf ? $changes->forAttentionOf : $this->forAttentionOf;
+ $this->validFrom = $changes->validFrom ? $changes->validFrom : $this->validFrom;
+ $this->validTo = $changes->validTo ? $changes->validTo : $this->validTo;
+ $this->passwordTicket = $changes->passwordTicket ? $changes->passwordTicket : $this->passwordTicket;
return true;
@@ -219,6 +243,14 @@
"mb_user_postal_code = $14, ".
"mb_user_country = $15, ".
"mb_user_online_resource = $16 ".
+ "mb_user_realname = $18 ".
+ "mb_user_street = $19 ".
+ "mb_user_housenumber = $20 ".
+ "mb_user_reference =$21 ".
+ "mb_user_for_attention_of = $22 ".
+ "mb_user_valid_from = $23 ".
+ "mb_user_valid_to = $24 ".
+ "mb_user_password_ticket = $25 ".
"WHERE mb_user_id = $17;";
@@ -238,9 +270,17 @@
$this->postalCode,
$this->country,
$this->url,
- $this->id);
+ $this->id,
+ $this->realName,
+ $this->street,
+ $this->housenumber,
+ $this->reference,
+ $this->forAttentionOf,
+ $this->validFrom,
+ $this->validTo,
+ $this->passwordTicket);
- $t = array("s", "i", "s", "s", "s", "s", "i", "s", "s", "s", "s", "s", "s", "i", "s", "s", "i");
+ $t = array("s", "i", "s", "s", "s", "s", "i", "s", "s", "s", "s", "s", "s", "i", "s", "s", "i", "s", "s", "s", "s", "s", "s", "s", "s");
$update_result = db_prep_query($sql_update,$v,$t);
if(!$update_result)
@@ -289,8 +329,16 @@
$this->postalCode = $row['mb_user_postal_code'];
$this->country = $row['mb_user_country'];
$this->url = $row['mb_user_online_resource'];
- }else{
+ $this->realName = $row['mb_user_realname'];
+ $this->street = $row['mb_user_street'];
+ $this->housenumber = $row['mb_user_housenumber'];
+ $this->reference = $row['mb_user_reference'];
+ $this->forAttentionOf = $row['mb_user_for_attention_of'];
+ $this->validFrom = $row['mb_user_valid_from'];
+ $this->validTo = $row['mb_user_valid_to'];
+ $this->passwordTicket = $row['mb_user_password_ticket'];
+ else {
throw new Exception("no such User");
return true;
@@ -354,6 +402,27 @@
return true;
+ public function sendUserLoginMail () {
+ $admin = new administration();
+ $userMessage = "Your Mapbender login data:\n";
+ $userMessage .= "Your login name is: ".$this->name."\n";
+ $userMessage .= "Please set your password using the following link: \n";
+ $mbUrl = substr(LOGIN, 0, -9);
+ $userMessage .= $mbUrl."../javascripts/mod_confirmLogin.php?user_id=".$this->id."&user_name=".$this->name."&user_ticket=".$this->passwordTicket."\n";
+ $userMessage .= "Follow this link to login to Mapbender: \n";
+ $userMessage .= LOGIN."\n";
+ $userMail = $admin->getEmailByUserId($this->id);
+ if(!$admin->sendEmail("", "", $userMail, $this->name, utf8_decode("Your Mapbender account"), utf8_decode($userMessage), $error_msg)) {
+ return "Registry data could not be send. Please check mail address.";
+ else {
+ return "Registry data has been sent successfully.";
* @return Array of Users
* @param $filter UNUSED! string that must be contained in the username
Modified: trunk/mapbender/http/php/mod_editFilteredUser.php
--- trunk/mapbender/http/php/mod_editFilteredUser.php 2010-04-11 09:31:30 UTC (rev 5906)
+++ trunk/mapbender/http/php/mod_editFilteredUser.php 2010-04-11 10:32:24 UTC (rev 5907)
@@ -55,10 +55,10 @@
return false;
var parameters = {
- command : "sendMailToCustomer",
+ command : "sendMailToUser",
userId : document.form1.selected_user.options[document.form1.selected_user.selectedIndex].value
- $.post("../php/mod_registerUser_server.php", parameters, function (json, status) {
+ $.post("../php/mod_sendUserMail.php", parameters, function (json, status) {
if(status == 'success') {
alert(json);
Deleted: trunk/mapbender/http/php/mod_registerUser_server.php
--- trunk/mapbender/http/php/mod_registerUser_server.php 2010-04-11 09:31:30 UTC (rev 5906)
+++ trunk/mapbender/http/php/mod_registerUser_server.php 2010-04-11 10:32:24 UTC (rev 5907)
@@ -1,64 +0,0 @@
-<?php
-# $Id:
-# http://www.mapbender.org/index.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-$command = $_REQUEST["command"];
-if($command == 'sendMailToCustomer') {
- $admin = new administration();
- $mailToAddr = $admin->getEmailByUserId($_REQUEST['userId']);
- $mailToName = $admin->getUsernameByUserId($_REQUEST['userId']);
- $sql = "SELECT * FROM mb_user ";
- $sql .= "WHERE mb_user_id = $1";
- $v = array($_REQUEST['userId']);
- $t = array("i");
- $res = db_prep_query($sql,$v,$t);
- $row = db_fetch_array($res);
- if ($row) {
- $userId = $row["mb_user_id"];
- $userName = $row["mb_user_name"];
- $email = $row["mb_user_email"];
- $ticket = $row["mb_user_password_ticket"];
- $customerMessage = "You are now registered as a Mapbender User.\n";
- $customerMessage .= "Your login name is: ".$userName."\n";
- $customerMessage .= "Please set your own password using the following link: \n";
- $mbUrl = substr(LOGIN, 0, -9);
- $customerMessage .= $mbUrl."../javascripts/mod_confirmLogin.php?user_id=".$userId."&user_name=".$userName."&user_ticket=".$ticket."\n";
- $customerMessage .= "Follow this link to login to Mapbender: \n";
- $customerMessage .= LOGIN."\n";
- if(!$admin->sendEmail("", "", $mailToAddr, $mailToName, utf8_decode("Your Mapbender account"), utf8_decode($customerMessage), $error_msg)) {
- echo "Registry data could not be send. Please check mail address.";
- else {
- echo "Registry data has been sent successfully to new Mapbender user.";
- else {
- echo "User does not exists.";
\ No newline at end of file
Copied: trunk/mapbender/http/php/mod_sendUserMail.php (from rev 5904, trunk/mapbender/http/php/mod_registerUser_server.php)
--- trunk/mapbender/http/php/mod_sendUserMail.php (rev 0)
+++ trunk/mapbender/http/php/mod_sendUserMail.php 2010-04-11 10:32:24 UTC (rev 5907)
@@ -0,0 +1,31 @@
+<?php
+# $Id:
+# http://www.mapbender.org/index.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../classes/class_user.php");
+$command = $_REQUEST["command"];
+if($command == 'sendMailToUser') {
+ $user = new user();
+ $user->id = $_REQUEST['userId'];
+ $sendMail = $user->sendUserLoginMail();
+ echo $sendMail;
More information about the Mapbender_commits
