[Mapbender-commits] r5908 - branches/3_dev/core/lib
svn_mapbender at osgeo.org
Sun Apr 11 06:36:07 EDT 2010
Author: verenadiewald
Date: 2010-04-11 06:36:07 -0400 (Sun, 11 Apr 2010)
New Revision: 5908
branches/3_dev/core/lib/class_User.php
new fields in class + method to send email to mb_user
Modified: branches/3_dev/core/lib/class_User.php
--- branches/3_dev/core/lib/class_User.php 2010-04-11 10:32:24 UTC (rev 5907)
+++ branches/3_dev/core/lib/class_User.php 2010-04-11 10:36:07 UTC (rev 5908)
@@ -7,6 +7,7 @@
require_once dirname(__FILE__)."/../../conf/mapbender.conf";
require_once dirname(__FILE__)."/class_RPCEndpoint.php";
+require_once(dirname(__FILE__)."/class_Administration.php");
* A Mapbender user as described in the table mb_user.
@@ -34,7 +35,15 @@
var $postalCode;
var $country ="";
var $url ="";
+ var $realName = "";
+ var $street = "";
+ var $houseNumber = "";
+ var $reference = "";
+ var $forAttentionOf = "";
+ var $validFrom = "";
+ var $validTo = "";
+ var $passwordTicket = "";
static $displayName = "User";
static $internalName = "user";
@@ -118,8 +127,15 @@
"city" => $this->city,
"postalCode" => $this->postalCode,
"country" => $this->country,
- "url" => $this->url
+ "url" => $this->url,
+ "realName" => $this->realName,
+ "street" => $this->street,
+ "housenumber" => $this->housenumber,
+ "reference" => $this->reference,
+ "forAttentionOf" => $this->forAttentionOf,
+ "validFrom" => $this->validFrom,
+ "validTo" => $this->validTo,
+ "passwordTicket" => $this->passwordTicket
return $result;
@@ -212,6 +228,14 @@
$this->country = $changes->country ? $changes->country : $this->country;
$this->url = $changes->url ? $changes->url : $this->url;
$this->id = $changes->id ? $changes->id : $this->id;
+ $this->realName = $changes->realName ? $changes->realName : $this->realName;
+ $this->street = $changes->street ? $changes->street : $this->street;
+ $this->houseNumber = $changes->houseNumber ? $changes->houseNumber : $this->houseNumber;
+ $this->reference = $changes->reference ? $changes->reference : $this->reference;
+ $this->forAttentionOf = $changes->forAttentionOf ? $changes->forAttentionOf : $this->forAttentionOf;
+ $this->validFrom = $changes->validFrom ? $changes->validFrom : $this->validFrom;
+ $this->validTo = $changes->validTo ? $changes->validTo : $this->validTo;
+ $this->passwordTicket = $changes->passwordTicket ? $changes->passwordTicket : $this->passwordTicket;
return true;
@@ -235,6 +259,14 @@
"mb_user_postal_code = $14, ".
"mb_user_country = $15, ".
"mb_user_online_resource = $16 ".
+ "mb_user_realname = $18 ".
+ "mb_user_street = $19 ".
+ "mb_user_housenumber = $20 ".
+ "mb_user_reference =$21 ".
+ "mb_user_for_attention_of = $22 ".
+ "mb_user_valid_from = $23 ".
+ "mb_user_valid_to = $24 ".
+ "mb_user_password_ticket = $25 ".
"WHERE mb_user_id = $17;";
@@ -254,9 +286,17 @@
$this->postalCode,
$this->country,
$this->url,
- $this->id);
+ $this->id,
+ $this->realName,
+ $this->street,
+ $this->housenumber,
+ $this->reference,
+ $this->forAttentionOf,
+ $this->validFrom,
+ $this->validTo,
+ $this->passwordTicket);
- $t = array("s", "i", "s", "s", "s", "s", "i", "s", "s", "s", "s", "s", "s", "i", "s", "s", "i");
+ $t = array("s", "i", "s", "s", "s", "s", "i", "s", "s", "s", "s", "s", "s", "i", "s", "s", "i", "s", "s", "s", "s", "s", "s", "s", "s");
$update_result = db_prep_query($sql_update,$v,$t);
if(!$update_result)
@@ -305,8 +345,16 @@
$this->postalCode = $row['mb_user_postal_code'];
$this->country = $row['mb_user_country'];
$this->url = $row['mb_user_online_resource'];
- }else{
+ $this->realName = $row['mb_user_realname'];
+ $this->street = $row['mb_user_street'];
+ $this->housenumber = $row['mb_user_housenumber'];
+ $this->reference = $row['mb_user_reference'];
+ $this->forAttentionOf = $row['mb_user_for_attention_of'];
+ $this->validFrom = $row['mb_user_valid_from'];
+ $this->validTo = $row['mb_user_valid_to'];
+ $this->passwordTicket = $row['mb_user_password_ticket'];
+ else {
throw new Exception("no such User");
return true;
@@ -369,7 +417,27 @@
return true;
+ public function sendUserLoginMail () {
+ $admin = new administration();
+ $userMessage = "Your Mapbender login data:\n";
+ $userMessage .= "Your login name is: ".$this->name."\n";
+ $userMessage .= "Please set your password using the following link: \n";
+ $mbUrl = substr(LOGIN, 0, -9);
+ $userMessage .= $mbUrl."../javascripts/mod_confirmLogin.php?user_id=".$this->id."&user_name=".$this->name."&user_ticket=".$this->passwordTicket."\n";
+ $userMessage .= "Follow this link to login to Mapbender: \n";
+ $userMessage .= LOGIN."\n";
+ $userMail = $admin->getEmailByUserId($this->id);
+ if(!$admin->sendEmail("", "", $userMail, $this->name, utf8_decode("Your Mapbender account"), utf8_decode($userMessage), $error_msg)) {
+ return "Registry data could not be send. Please check mail address.";
+ else {
+ return "Registry data has been sent successfully.";
* @return Array of Users
* @param $filter UNUSED! string that must be contained in the username
More information about the Mapbender_commits
