[Mapbender-commits] r6042 - in trunk/mapbender/http/extensions: jquery.metadata.2.1 jquery.metadata.2.1/test jsTree.v.0.9.9a2 jsTree.v.0.9.9a2/demo jsTree.v.0.9.9a2/demo/syntax jsTree.v.0.9.9a2/lib jsTree.v.0.9.9a2/plugins jsTree.v.0.9.9a2/themes jsTree.v.0.9.9a2/themes/apple jsTree.v.0.9.9a2/themes/checkbox jsTree.v.0.9.9a2/themes/classic jsTree.v.0.9.9a2/themes/default jsTree.v.0.9.9a2/themes/themeroller
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Apr 29 10:27:37 EDT 2010
Author: christoph
Date: 2010-04-29 10:27:35 -0400 (Thu, 29 Apr 2010)
New Revision: 6042
Added:
   trunk/mapbender/http/extensions/jquery.metadata.2.1/test/
   trunk/mapbender/http/extensions/jquery.metadata.2.1/test/index.html
   trunk/mapbender/http/extensions/jquery.metadata.2.1/test/jquery.js
   trunk/mapbender/http/extensions/jquery.metadata.2.1/test/test.js
   trunk/mapbender/http/extensions/jquery.metadata.2.1/test/testrunner.js
   trunk/mapbender/http/extensions/jquery.metadata.2.1/test/testsuite.css
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_html.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_html_data.txt
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_json.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_json_data.json
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_xml_flat.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_xml_flat_data.xml
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_html.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_json.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_xml_flat.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_xml_flat_data.xml
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_xml_nested.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_xml_nested_data.xml
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/callbacks.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/checkbox.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/context.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/cookie.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/create.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/delete.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/drive.png
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/file.png
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/index.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/json_languages.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/keyboard.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/metadata.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/move_copy.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/open_close.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/rename.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/rollback.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/search.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/select.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/static_async_json.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/clipboard.swf
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/help.png
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/magnifier.png
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/page_white_code.png
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/page_white_copy.png
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/printer.png
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shBrushJScript.js
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shBrushPhp.js
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shBrushXml.js
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shCore.css
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shCore.js
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeDefault.css
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeDjango.css
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeEmacs.css
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeFadeToGrey.css
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeMidnight.css
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeRDark.css
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/wrapping.png
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/themeroller.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/themes.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/types.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/xml_flat_from_string.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/xml_flat_with_languages.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/xml_nested_with_languages.html
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/lib/
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/lib/jquery.cookie.js
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/lib/jquery.hotkeys.js
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/lib/jquery.js
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/lib/jquery.metadata.js
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/lib/sarissa.js
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/_jquery.tree.rtl.js
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.checkbox.js
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.contextmenu.js
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.cookie.js
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.hotkeys.js
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.metadata.js
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.themeroller.js
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.xml_flat.js
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.xml_nested.js
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/apple/
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/apple/bg.jpg
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/apple/dot_for_ie.gif
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/apple/icons.png
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/apple/style.css
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/apple/throbber.gif
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/checkbox/
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/checkbox/dot_for_ie.gif
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/checkbox/icons.png
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/checkbox/style.css
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/checkbox/throbber.gif
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/classic/
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/classic/dot_for_ie.gif
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/classic/icons.png
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/classic/style.css
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/classic/throbber.gif
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/default/
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/default/dot_for_ie.gif
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/default/icons.png
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/default/style.css
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/default/throbber.gif
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/themeroller/
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/themeroller/dot_for_ie.gif
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/themeroller/icons.png
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/themeroller/style.css
   trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/themeroller/throbber.gif
Added: trunk/mapbender/http/extensions/jquery.metadata.2.1/test/index.html
--- trunk/mapbender/http/extensions/jquery.metadata.2.1/test/index.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery.metadata.2.1/test/index.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,61 @@
+<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
+<html>
+<head>
+<link rel="stylesheet" href="testsuite.css" />
+<script type="text/javascript" src="jquery.js"></script>
+<script type="text/javascript" src="testrunner.js"></script>
+<!-- include metadata plugin two times to make sure that doesn't hurt anyone -->
+<script type="text/javascript" src="../jquery.metadata.js"></script>
+<script type="text/javascript" src="test.js"></script>
+</head>
+<body>
+<h1>jQuery - Metadata Test Suite</h1>
+<div id="main" style="display: none">
+        <ol id="one">
+                <li class="test test2" data="foo:'bar', bar:'baz', arr:[1,2]">Some stuff</li>
+                <li class="test test2" data="{test:'bar', bar:'baz'}">Some stuff</li>
+                <li class="test test2" data="{zoooo:'bar', bar:{test:'baz'}}">Some stuff</li>
+                <li class="test test2" data="{number:true, stuff:[2,8]}">Some stuff</li>
+        </ol>
+        <ol id="two">
+                <li class="test {foo:'bar',bar:'baz',arr:[1,2]} test2">Some stuff</li>
+                <li class="{test:'bar',bar:'baz'} test test2">Some stuff</li>
+                <li class="test test2 {zoooo:'bar',bar:{test:'baz'}}">Some stuff</li>
+                <li class="some styles {number:true,stuff:[2,8]}">Some stuff</li>
+        </ol>
+        <ol id="three">
+                <li class="test test2"><script type="data">foo:'bar', bar:'baz', arr:[1,2]</script>Some stuff</li>
+                <li class="test test2"><script type="data">{test:'bar', bar:'baz'}</script>Some stuff</li>
+                <li class="test test2"><script type="data">{zoooo:'bar', bar:{test:'baz'}}</script>Some stuff</li>
+                <li class="test test2"><script type="data">{number:true, stuff:[2,8]}</script>Some stuff</li>
+        </ol>
+        <script type="data">test("execute script with type='data'", function() { ok( false, "Script tag with type='data' was executed!"); });</script>
+        <ol id="four">
+        </ol>
+        <ol id="five">
+                <li class="test test2" data-foo="'bar'" data-bar="'baz'" data-arr="[1,2]">Some stuff</li>
+                <li class="test test2" data-test="'bar'" data-bar="'baz'">Some stuff</li>
+                <li class="test test2" data-zoooo="'bar'" data-bar="{test:'baz'}">Some stuff</li>
+                <li class="test test2" data-number="true" data-stuff="[2,8]">Some stuff</li>
+        </ol>
+        <select class="{required:true}" name="meal" id="meal">
+                <option value="">Please select...</option>
+                <option value="1">Food</option>
+                <option value="2">Milk</option>
+        </select>
+</div>
+<ol id="tests"></ol>
+</body>
+</html>
Property changes on: trunk/mapbender/http/extensions/jquery.metadata.2.1/test/index.html
___________________________________________________________________
Added: svn:executable
Added: trunk/mapbender/http/extensions/jquery.metadata.2.1/test/jquery.js
--- trunk/mapbender/http/extensions/jquery.metadata.2.1/test/jquery.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery.metadata.2.1/test/jquery.js	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,3151 @@
+(function(){
+ * jQuery @VERSION - New Wave Javascript
+ * Copyright (c) 2007 John Resig (jquery.com)
+ * Dual licensed under the MIT (MIT-LICENSE.txt)
+ * and GPL (GPL-LICENSE.txt) licenses.
+ * $Date: 2007-10-01 22:15:20 +0200 (Mo, 01 Okt 2007) $
+ * $Rev: 3501 $
+// Map over jQuery in case of overwrite
+if ( typeof jQuery != "undefined" )
+	var _jQuery = jQuery;
+var jQuery = window.jQuery = function( selector, context ) {
+	// If the context is a namespace object, return a new object
+	return this instanceof jQuery ?
+		this.init( selector, context ) :
+		new jQuery( selector, context );
+// Map over the $ in case of overwrite
+if ( typeof $ != "undefined" )
+	var _$ = $;
+// Map the jQuery namespace to the '$' one
+window.$ = jQuery;
+// A simple way to check for HTML strings or ID strings
+// (both of which we optimize for)
+var quickExpr = /^[^<]*(<(.|\s)+>)[^>]*$|^#(\w+)$/;
+jQuery.fn = jQuery.prototype = {
+	init: function( selector, context ) {
+		// Make sure that a selection was provided
+		selector = selector || document;
+		// Handle HTML strings
+		if ( typeof selector  == "string" ) {
+			// Are we dealing with HTML string or an ID?
+			var match = quickExpr.exec( selector );
+			// Verify a match, and that no context was specified for #id
+			if ( match && (match[1] || !context) ) {
+				// HANDLE: $(html) -> $(array)
+				if ( match[1] )
+					selector = jQuery.clean( [ match[1] ], context );
+				// HANDLE: $("#id")
+				else {
+					var elem = document.getElementById( match[3] );
+					// Make sure an element was located
+					if ( elem )
+						// Handle the case where IE and Opera return items
+						// by name instead of ID
+						if ( elem.id != match[3] )
+							return jQuery().find( selector );
+						// Otherwise, we inject the element directly into the jQuery object
+						else {
+							this[0] = elem;
+							this.length = 1;
+							return this;
+					else
+						selector = [];
+			// HANDLE: $(expr, [context])
+			// (which is just equivalent to: $(content).find(expr)
+			} else
+				return new jQuery( context ).find( selector );
+		// HANDLE: $(function)
+		// Shortcut for document ready
+		} else if ( jQuery.isFunction( selector ) )
+			return new jQuery( document )[ jQuery.fn.ready ? "ready" : "load" ]( selector );
+		return this.setArray(
+			// HANDLE: $(array)
+			selector.constructor == Array && selector ||
+			// HANDLE: $(arraylike)
+			// Watch for when an array-like object, contains DOM nodes, is passed in as the selector
+			(selector.jquery || selector.length && selector != window && !selector.nodeType && selector[0] != undefined && selector[0].nodeType) && jQuery.makeArray( selector ) ||
+			// HANDLE: $(*)
+			[ selector ] );
+	// The current version of jQuery being used
+	jquery: "@VERSION",
+	// The number of elements contained in the matched element set
+	size: function() {
+		return this.length;
+	length: 0,
+	// Get the Nth element in the matched element set OR
+	// Get the whole matched element set as a clean array
+	get: function( num ) {
+		return num == undefined ?
+			// Return a 'clean' array
+			jQuery.makeArray( this ) :
+			// Return just the object
+			this[ num ];
+	// Take an array of elements and push it onto the stack
+	// (returning the new matched element set)
+	pushStack: function( elems ) {
+		// Build a new jQuery matched element set
+		var ret = jQuery( elems );
+		// Add the old object onto the stack (as a reference)
+		ret.prevObject = this;
+		// Return the newly-formed element set
+		return ret;
+	// Force the current matched set of elements to become
+	// the specified array of elements (destroying the stack in the process)
+	// You should use pushStack() in order to do this, but maintain the stack
+	setArray: function( elems ) {
+		// Resetting the length to 0, then using the native Array push
+		// is a super-fast way to populate an object with array-like properties
+		this.length = 0;
+		Array.prototype.push.apply( this, elems );
+		return this;
+	// Execute a callback for every element in the matched set.
+	// (You can seed the arguments with an array of args, but this is
+	// only used internally.)
+	each: function( callback, args ) {
+		return jQuery.each( this, callback, args );
+	// Determine the position of an element within
+	// the matched set of elements
+	index: function( elem ) {
+		var ret = -1;
+		// Locate the position of the desired element
+		this.each(function(i){
+			if ( this == elem )
+				ret = i;
+		return ret;
+	attr: function( name, value, type ) {
+		var options = name;
+		// Look for the case where we're accessing a style value
+		if ( name.constructor == String )
+			if ( value == undefined )
+				return this.length && jQuery[ type || "attr" ]( this[0], name ) || undefined;
+			else {
+				options = {};
+				options[ name ] = value;
+		// Check to see if we're setting style values
+		return this.each(function(i){
+			// Set all the styles
+			for ( name in options )
+				jQuery.attr(
+					type ?
+						this.style :
+						this,
+					name, jQuery.prop( this, options[ name ], type, i, name )
+	css: function( key, value ) {
+		return this.attr( key, value, "curCSS" );
+	text: function( text ) {
+		if ( typeof text != "object" && text != null )
+			return this.empty().append( document.createTextNode( text ) );
+		var ret = "";
+		jQuery.each( text || this, function(){
+			jQuery.each( this.childNodes, function(){
+				if ( this.nodeType != 8 )
+					ret += this.nodeType != 1 ?
+						this.nodeValue :
+						jQuery.fn.text( [ this ] );
+		return ret;
+	wrapAll: function( html ) {
+		if ( this[0] )
+			// The elements to wrap the target around
+			jQuery( html, this[0].ownerDocument )
+				.clone()
+				.insertBefore( this[0] )
+				.map(function(){
+					var elem = this;
+					while ( elem.firstChild )
+						elem = elem.firstChild;
+					return elem;
+				.append(this);
+		return this;
+	wrapInner: function( html ) {
+		return this.each(function(){
+			jQuery( this ).contents().wrapAll( html );
+	wrap: function( html ) {
+			jQuery( this ).wrapAll( html );
+	append: function() {
+		return this.domManip(arguments, true, false, function(elem){
+			this.appendChild( elem );
+	prepend: function() {
+		return this.domManip(arguments, true, true, function(elem){
+			this.insertBefore( elem, this.firstChild );
+	before: function() {
+		return this.domManip(arguments, false, false, function(elem){
+			this.parentNode.insertBefore( elem, this );
+	after: function() {
+		return this.domManip(arguments, false, true, function(elem){
+			this.parentNode.insertBefore( elem, this.nextSibling );
+	end: function() {
+		return this.prevObject || jQuery( [] );
+	find: function( selector ) {
+		var elems = jQuery.map(this, function(elem){
+			return jQuery.find( selector, elem );
+		return this.pushStack( /[^+>] [^+>]/.test( selector ) || selector.indexOf("..") > -1 ?
+			jQuery.unique( elems ) :
+			elems );
+	clone: function( events ) {
+		// Do the clone
+		var ret = this.map(function(){
+			return this.outerHTML ?
+				jQuery( this.outerHTML )[0] :
+				this.cloneNode( true );
+		// Need to set the expando to null on the cloned set if it exists
+		// removeData doesn't work here, IE removes it from the original as well
+		// this is primarily for IE but the data expando shouldn't be copied over in any browser
+		var clone = ret.find("*").andSelf().each(function(){
+			if ( this[ expando ] != undefined )
+				this[ expando ] = null;
+		// Copy the events from the original to the clone
+		if ( events === true )
+			this.find("*").andSelf().each(function(i){
+				var events = jQuery.data( this, "events" );
+				for ( var type in events )
+					for ( var handler in events[ type ] )
+						jQuery.event.add( clone[ i ], type, events[ type ][ handler ], events[ type ][ handler ].data );
+		// Return the cloned set
+		return ret;
+	filter: function( selector ) {
+			jQuery.isFunction( selector ) &&
+			jQuery.grep(this, function(elem, i){
+				return selector.call( elem, i );
+			jQuery.multiFilter( selector, this ) );
+	not: function( selector ) {
+			selector.constructor == String &&
+			jQuery.multiFilter( selector, this, true ) ||
+			jQuery.grep(this, function(elem) {
+				return selector.constructor == Array || selector.jquery ?
+					jQuery.inArray( elem, selector ) < 0 :
+					elem != selector;
+	add: function( selector ) {
+		return this.pushStack( jQuery.merge( this.get(), jQuery( selector ) ) );
+	is: function( selector ) {
+		return selector ?
+			jQuery.multiFilter( selector, this ).length > 0 :
+			false;
+	hasClass: function( selector ) {
+		return this.is( "." + selector );
+	val: function( value ) {
+		if ( value == undefined ) {
+			if ( this.length ) {
+				var elem = this[0];
+				// We need to handle select boxes special
+				if ( jQuery.nodeName( elem, "select" ) ) {
+					var index = elem.selectedIndex,
+						values = [],
+						options = elem.options,
+						one = elem.type == "select-one";
+					// Nothing was selected
+					if ( index < 0 )
+						return null;
+					// Loop through all the selected options
+					for ( var i = one ? index : 0, max = one ? index + 1 : options.length; i < max; i++ ) {
+						var option = options[ i ];
+						if ( option.selected ) {
+							// Get the specifc value for the option
+							value = jQuery.browser.msie && !option.attributes.value.specified ? option.text : option.value;
+							// We don't need an array for one selects
+							if ( one )
+								return value;
+							// Multi-Selects return an array
+							values.push( value );
+					return values;
+				// Everything else, we just grab the value
+				} else
+					return this[0].value.replace(/\r/g, "");
+		} else
+				if ( value.constructor == Array && /radio|checkbox/.test( this.type ) )
+					this.checked = (jQuery.inArray(this.value, value) >= 0 ||
+						jQuery.inArray(this.name, value) >= 0);
+				else if ( jQuery.nodeName( this, "select" ) ) {
+					var values = value.constructor == Array ?
+						value :
+						[ value ];
+					jQuery( "option", this ).each(function(){
+						this.selected = (jQuery.inArray( this.value, values ) >= 0 ||
+							jQuery.inArray( this.text, values ) >= 0);
+					if ( !tmp.length )
+						this.selectedIndex = -1;
+				} else
+					this.value = value;
+	html: function( value ) {
+		return value == undefined ?
+			(this.length ?
+				this[0].innerHTML :
+				null) :
+			this.empty().append( value );
+	replaceWith: function( value ) {
+		return this.after( value ).remove();
+	eq: function( i ) {
+		return this.slice( i, i + 1 );
+	slice: function() {
+		return this.pushStack( Array.prototype.slice.apply( this, arguments ) );
+	map: function( callback ) {
+		return this.pushStack( jQuery.map(this, function(elem, i){
+			return callback.call( elem, i, elem );
+	andSelf: function() {
+		return this.add( this.prevObject );
+	domManip: function( args, table, reverse, callback ) {
+		var clone = this.length > 1, elems;
+			if ( !elems ) {
+				elems = jQuery.clean( args, this.ownerDocument );
+				if ( reverse )
+					elems.reverse();
+			var obj = this;
+			if ( table && jQuery.nodeName( this, "table" ) && jQuery.nodeName( elems[0], "tr" ) )
+				obj = this.getElementsByTagName("tbody")[0] || this.appendChild( document.createElement("tbody") );
+			jQuery.each(elems, function(){
+				var elem = clone ?
+					this.cloneNode( true ) :
+					this;
+				if ( !evalScript( 0, elem ) )
+					callback.call( obj, elem );
+function evalScript( i, elem ) {
+	var script = jQuery.nodeName( elem, "script" );
+	if ( script ) {
+		if ( elem.src )
+			jQuery.ajax({
+				url: elem.src,
+				async: false,
+				dataType: "script"
+		else
+			jQuery.globalEval( elem.text || elem.textContent || elem.innerHTML || "" );
+		if ( elem.parentNode )
+			elem.parentNode.removeChild( elem );
+	} else if ( elem.nodeType == 1 )
+		jQuery( "script", elem ).each( evalScript );
+	return script;
+jQuery.extend = jQuery.fn.extend = function() {
+	// copy reference to target object
+	var target = arguments[0] || {}, i = 1, length = arguments.length, deep = false, options;
+	// Handle a deep copy situation
+	if ( target.constructor == Boolean ) {
+		deep = target;
+		target = arguments[1] || {};
+	// extend jQuery itself if only one argument is passed
+	if ( length == 1 ) {
+		target = this;
+		i = 0;
+	for ( ; i < length; i++ )
+		// Only deal with non-null/undefined values
+		if ( (options = arguments[ i ]) != null )
+			// Extend the base object
+			for ( var name in options ) {
+				// Prevent never-ending loop
+				if ( target == options[ name ] )
+					continue;
+				// Recurse if we're merging object values
+				if ( deep && typeof options[ name ] == "object" && target[ name ] )
+					jQuery.extend( target[ name ], options[ name ] );
+				// Don't bring in undefined values
+				else if ( options[ name ] != undefined )
+					target[ name ] = options[ name ];
+	// Return the modified object
+	return target;
+var expando = "jQuery" + (new Date()).getTime(), uuid = 0, windowData = {};
+// exclude the following css properties to add px
+var exclude = /z-?index|font-?weight|opacity|zoom|line-?height/i;
+jQuery.extend({
+	noConflict: function( deep ) {
+		window.$ = _$;
+		if ( deep )
+			window.jQuery = _jQuery;
+		return jQuery;
+	// This may seem like some crazy code, but trust me when I say that this
+	// is the only cross-browser way to do this. --John
+	isFunction: function( fn ) {
+		return !!fn && typeof fn != "string" && !fn.nodeName &&
+			fn.constructor != Array && /function/i.test( fn + "" );
+	// check if an element is in a (or is an) XML document
+	isXMLDoc: function( elem ) {
+		return elem.documentElement && !elem.body ||
+			elem.tagName && elem.ownerDocument && !elem.ownerDocument.body;
+	// Evalulates a script in a global context
+	// Evaluates Async. in Safari 2 :-(
+	globalEval: function( data ) {
+		data = jQuery.trim( data );
+		if ( data ) {
+			// Inspired by code by Andrea Giammarchi
+			// http://webreflection.blogspot.com/2007/08/global-scope-evaluation-and-dom.html
+			var head = document.getElementsByTagName("head")[0] || document.documentElement,
+				script = document.createElement("script");
+			script.type = "text/javascript";
+			if ( jQuery.browser.msie )
+				script.text = data;
+			else
+				script.appendChild( document.createTextNode( data ) );
+			head.appendChild( script );
+			head.removeChild( script );
+	nodeName: function( elem, name ) {
+		return elem.nodeName && elem.nodeName.toUpperCase() == name.toUpperCase();
+	cache: {},
+	data: function( elem, name, data ) {
+		elem = elem == window ?
+			windowData :
+			elem;
+		var id = elem[ expando ];
+		// Compute a unique ID for the element
+		if ( !id )
+			id = elem[ expando ] = ++uuid;
+		// Only generate the data cache if we're
+		// trying to access or manipulate it
+		if ( name && !jQuery.cache[ id ] )
+			jQuery.cache[ id ] = {};
+		// Prevent overriding the named cache with undefined values
+		if ( data != undefined )
+			jQuery.cache[ id ][ name ] = data;
+		// Return the named cache data, or the ID for the element
+		return name ?
+			jQuery.cache[ id ][ name ] :
+			id;
+	removeData: function( elem, name ) {
+			windowData :
+			elem;
+		// If we want to remove a specific section of the element's data
+		if ( name ) {
+			if ( jQuery.cache[ id ] ) {
+				// Remove the section of cache data
+				delete jQuery.cache[ id ][ name ];
+				// If we've removed all the data, remove the element's cache
+				name = "";
+				for ( name in jQuery.cache[ id ] )
+					break;
+				if ( !name )
+					jQuery.removeData( elem );
+		// Otherwise, we want to remove all of the element's data
+		} else {
+			// Clean up the element expando
+			try {
+				delete elem[ expando ];
+			} catch(e){
+				// IE has trouble directly removing the expando
+				// but it's ok with using removeAttribute
+				if ( elem.removeAttribute )
+					elem.removeAttribute( expando );
+			// Completely remove the data cache
+			delete jQuery.cache[ id ];
+	// args is for internal usage only
+	each: function( object, callback, args ) {
+		if ( args ) {
+			if ( object.length == undefined )
+				for ( var name in object )
+					callback.apply( object[ name ], args );
+			else
+				for ( var i = 0, length = object.length; i < length; i++ )
+					if ( callback.apply( object[ i ], args ) === false )
+						break;
+		// A special, fast, case for the most common use of each
+		} else {
+					callback.call( object[ name ], name, object[ name ] );
+			else
+				for ( var i = 0, length = object.length, value = object[0];
+					i < length && callback.call( value, i, value ) !== false; value = object[++i] ){}
+		return object;
+	prop: function( elem, value, type, i, name ) {
+			// Handle executable functions
+			if ( jQuery.isFunction( value ) )
+				value = value.call( elem, i );
+			// Handle passing in a number to a CSS property
+			return value && value.constructor == Number && type == "curCSS" && !exclude.test( name ) ?
+				value + "px" :
+				value;
+	className: {
+		// internal only, use addClass("class")
+		add: function( elem, classNames ) {
+			jQuery.each((classNames || "").split(/\s+/), function(i, className){
+				if ( !jQuery.className.has( elem.className, className ) )
+					elem.className += (elem.className ? " " : "") + className;
+		// internal only, use removeClass("class")
+		remove: function( elem, classNames ) {
+			elem.className = classNames != undefined ?
+				jQuery.grep(elem.className.split(/\s+/), function(className){
+					return !jQuery.className.has( classNames, className );
+				}).join(" ") :
+		// internal only, use is(".class")
+		has: function( elem, className ) {
+			return jQuery.inArray( className, (elem.className || elem).toString().split(/\s+/) ) > -1;
+	// A method for quickly swapping in/out CSS properties to get correct calculations
+	swap: function( elem, options, callback ) {
+		// Remember the old values, and insert the new ones
+			elem.style[ "old" + name ] = elem.style[ name ];
+			elem.style[ name ] = options[ name ];
+		callback.call( elem );
+		// Revert the old values
+			elem.style[ name ] = elem.style[ "old" + name ];
+	css: function( elem, name ) {
+		if ( name == "height" || name == "width" ) {
+			var old = {}, height, width;
+			// Revert the padding and border widths to get the
+			// correct height/width values
+			jQuery.each([ "Top", "Bottom", "Right", "Left" ], function(){
+				old[ "padding" + this ] = 0;
+				old[ "border" + this + "Width" ] = 0;
+			// Swap out the padding/border values temporarily
+			jQuery.swap( elem, old, function() {
+				// If the element is visible, then the calculation is easy
+				if ( jQuery( elem ).is(":visible") ) {
+					height = elem.offsetHeight;
+					width = elem.offsetWidth;
+				// Otherwise, we need to flip out more values
+				} else {
+					elem = jQuery( elem.cloneNode(true) )
+						.find(":radio").removeAttr("checked").end()
+						.css({
+							visibility: "hidden",
+							position: "absolute",
+							display: "block",
+							right: "0",
+							left: "0"
+						}).appendTo( elem.parentNode )[0];
+					var position = jQuery.css( elem.parentNode, "position" ) || "static";
+					if ( position == "static" )
+						elem.parentNode.style.position = "relative";
+					height = elem.clientHeight;
+					width = elem.clientWidth;
+						elem.parentNode.style.position = "static";
+			return name == "height" ?
+				height :
+				width;
+		return jQuery.curCSS( elem, name );
+	curCSS: function( elem, name, force ) {
+		var ret;
+		// A helper method for determining if an element's values are broken
+		function color( elem ) {
+			if ( !jQuery.browser.safari )
+				return false;
+			var ret = document.defaultView.getComputedStyle( elem, null );
+			return !ret || ret.getPropertyValue("color") == "";
+		// We need to handle opacity special in IE
+		if ( name == "opacity" && jQuery.browser.msie ) {
+			ret = jQuery.attr( elem.style, "opacity" );
+			return ret == "" ?
+				"1" :
+				ret;
+		// Make sure we're using the right name for getting the float value
+		if ( name.match( /float/i ) )
+			name = styleFloat;
+		if ( !force && elem.style[ name ] )
+			ret = elem.style[ name ];
+		else if ( document.defaultView && document.defaultView.getComputedStyle ) {
+			// Only "float" is needed here
+				name = "float";
+			name = name.replace( /([A-Z])/g, "-$1" ).toLowerCase();
+			var getComputedStyle = document.defaultView.getComputedStyle( elem, null );
+			if ( getComputedStyle && !color( elem ) )
+				ret = getComputedStyle.getPropertyValue( name );
+			// If the element isn't reporting its values properly in Safari
+			// then some display: none elements are involved
+			else {
+				var swap = [], stack = [];
+				// Locate all of the parent display: none elements
+				for ( var a = elem; a && color(a); a = a.parentNode )
+					stack.unshift(a);
+				// Go through and make them visible, but in reverse
+				// (It would be better if we knew the exact display type that they had)
+				for ( var i = 0; i < stack.length; i++ )
+					if ( color( stack[ i ] ) ) {
+						swap[ i ] = stack[ i ].style.display;
+						stack[ i ].style.display = "block";
+				// Since we flip the display style, we have to handle that
+				// one special, otherwise get the value
+				ret = name == "display" && swap[ stack.length - 1 ] != null ?
+					"none" :
+					document.defaultView.getComputedStyle( elem, null ).getPropertyValue( name ) || "";
+				// Finally, revert the display styles back
+				for ( var i = 0; i < swap.length; i++ )
+					if ( swap[ i ] != null )
+						stack[ i ].style.display = swap[ i ];
+			// We should always get a number back from opacity
+			if ( name == "opacity" && ret == "" )
+				ret = "1";
+		} else if ( elem.currentStyle ) {
+			var camelCase = name.replace(/\-(\w)/g, function(all, letter){
+				return letter.toUpperCase();
+			ret = elem.currentStyle[ name ] || elem.currentStyle[ camelCase ];
+			// From the awesome hack by Dean Edwards
+			// http://erik.eae.net/archives/2007/07/27/18.54.15/#comment-102291
+			// If we're not dealing with a regular pixel number
+			// but a number that has a weird ending, we need to convert it to pixels
+			if ( !/^\d+(px)?$/i.test( ret ) && /^\d/.test( ret ) ) {
+				// Remember the original values
+				var style = elem.style.left, runtimeStyle = elem.runtimeStyle.left;
+				// Put in the new values to get a computed value out
+				elem.runtimeStyle.left = elem.currentStyle.left;
+				elem.style.left = ret || 0;
+				ret = elem.style.pixelLeft + "px";
+				// Revert the changed values
+				elem.style.left = style;
+				elem.runtimeStyle.left = runtimeStyle;
+		return ret;
+	clean: function( elems, context ) {
+		var ret = [];
+		context = context || document;
+		jQuery.each(elems, function(i, elem){
+			if ( !elem )
+				return;
+			if ( elem.constructor == Number )
+				elem = elem.toString();
+			// Convert html string into DOM nodes
+			if ( typeof elem == "string" ) {
+				// Fix "XHTML"-style tags in all browsers
+				elem = elem.replace(/(<(\w+)[^>]*?)\/>/g, function(all, front, tag){
+					return tag.match(/^(abbr|br|col|img|input|link|meta|param|hr|area)$/i) ?
+						all :
+						front + "></" + tag + ">";
+				// Trim whitespace, otherwise indexOf won't work as expected
+				var tags = jQuery.trim( elem ).toLowerCase(), div = context.createElement("div");
+				var wrap =
+					// option or optgroup
+					!tags.indexOf("<opt") &&
+					[ 1, "<select>", "</select>" ] ||
+					!tags.indexOf("<leg") &&
+					[ 1, "<fieldset>", "</fieldset>" ] ||
+					tags.match(/^<(thead|tbody|tfoot|colg|cap)/) &&
+					[ 1, "<table>", "</table>" ] ||
+					!tags.indexOf("<tr") &&
+					[ 2, "<table><tbody>", "</tbody></table>" ] ||
+				 	// <thead> matched above
+					(!tags.indexOf("<td") || !tags.indexOf("<th")) &&
+					[ 3, "<table><tbody><tr>", "</tr></tbody></table>" ] ||
+					!tags.indexOf("<col") &&
+					[ 2, "<table><tbody></tbody><colgroup>", "</colgroup></table>" ] ||
+					// IE can't serialize <link> and <script> tags normally
+					jQuery.browser.msie &&
+					[ 1, "div<div>", "</div>" ] ||
+					[ 0, "", "" ];
+				// Go to html and back, then peel off extra wrappers
+				div.innerHTML = wrap[1] + elem + wrap[2];
+				// Move to the right depth
+				while ( wrap[0]-- )
+					div = div.lastChild;
+				// Remove IE's autoinserted <tbody> from table fragments
+				if ( jQuery.browser.msie ) {
+					// String was a <table>, *may* have spurious <tbody>
+					var tbody = !tags.indexOf("<table") && tags.indexOf("<tbody") < 0 ?
+						div.firstChild && div.firstChild.childNodes :
+						// String was a bare <thead> or <tfoot>
+						wrap[1] == "<table>" && s.indexOf("<tbody") < 0 ?
+							div.childNodes :
+					for ( var i = tbody.length - 1; i >= 0 ; --i )
+						if ( jQuery.nodeName( tbody[ i ], "tbody" ) && !tbody[ i ].childNodes.length )
+							tbody[ i ].parentNode.removeChild( tbody[ i ] );
+					// IE completely kills leading whitespace when innerHTML is used
+					if ( /^\s/.test( elem ) )
+						div.insertBefore( context.createTextNode( elem.match(/^\s*/)[0] ), div.firstChild );
+				elem = jQuery.makeArray( div.childNodes );
+			if ( elem.length === 0 && (!jQuery.nodeName( elem, "form" ) && !jQuery.nodeName( elem, "select" )) )
+				return;
+			if ( elem[0] == undefined || jQuery.nodeName( elem, "form" ) || elem.options )
+				ret.push( elem );
+			else
+				ret = jQuery.merge( ret, elem );
+		return ret;
+	attr: function( elem, name, value ) {
+		var fix = jQuery.isXMLDoc( elem ) ?
+			jQuery.props;
+		// Safari mis-reports the default selected property of a hidden option
+		// Accessing the parent's selectedIndex property fixes it
+		if ( name == "selected" && jQuery.browser.safari )
+			elem.parentNode.selectedIndex;
+		// Certain attributes only work when accessed via the old DOM 0 way
+		if ( fix[ name ] ) {
+			if ( value != undefined )
+				elem[ fix[ name ] ] = value;
+			return elem[ fix[ name ] ];
+		} else if ( jQuery.browser.msie && name == "style" )
+			return jQuery.attr( elem.style, "cssText", value );
+		else if ( value == undefined && jQuery.browser.msie && jQuery.nodeName( elem, "form" ) && (name == "action" || name == "method") )
+			return elem.getAttributeNode( name ).nodeValue;
+		// IE elem.getAttribute passes even for style
+		else if ( elem.tagName ) {
+			if ( value != undefined ) {
+				// We can't allow the type property to be changed (since it causes problems in IE)
+				if ( name == "type" && jQuery.nodeName( elem, "input" ) && elem.parentNode )
+					throw "type property can't be changed";
+				elem.setAttribute( name, value );
+			if ( jQuery.browser.msie && /href|src/.test( name ) && !jQuery.isXMLDoc( elem ) )
+				return elem.getAttribute( name, 2 );
+			return elem.getAttribute( name );
+		// elem is actually elem.style ... set the style
+		} else {
+			// IE actually uses filters for opacity
+					// IE has trouble with opacity if it does not have layout
+					// Force it by setting the zoom level
+					elem.zoom = 1;
+					// Set the alpha filter to set the opacity
+					elem.filter = (elem.filter || "").replace( /alpha\([^)]*\)/, "" ) +
+						(parseFloat( value ).toString() == "NaN" ? "" : "alpha(opacity=" + value * 100 + ")");
+				return elem.filter ?
+					(parseFloat( elem.filter.match(/opacity=([^)]*)/)[1] ) / 100).toString() :
+			name = name.replace(/-([a-z])/ig, function(all, letter){
+				elem[ name ] = value;
+			return elem[ name ];
+	trim: function( text ) {
+		return (text || "").replace( /^\s+|\s+$/g, "" );
+	makeArray: function( array ) {
+		var ret = [];
+		// Need to use typeof to fight Safari childNodes crashes
+		if ( typeof array != "array" )
+			for ( var i = 0, length = array.length; i < length; i++ )
+				ret.push( array[ i ] );
+		else
+			ret = array.slice( 0 );
+		return ret;
+	inArray: function( elem, array ) {
+			if ( array[ i ] == elem )
+				return i;
+		return -1;
+	merge: function( first, second ) {
+		// We have to loop this way because IE & Opera overwrite the length
+		// expando of getElementsByTagName
+		// Also, we need to make sure that the correct elements are being returned
+		// (IE returns comment nodes in a '*' query)
+			for ( var i = 0; second[ i ]; i++ )
+				if ( second[ i ].nodeType != 8 )
+					first.push( second[ i ] );
+		} else
+		return first;
+	unique: function( array ) {
+		var ret = [], done = {};
+		try {
+			for ( var i = 0, length = array.length; i < length; i++ ) {
+				var id = jQuery.data( array[ i ] );
+				if ( !done[ id ] ) {
+					done[ id ] = true;
+		} catch( e ) {
+			ret = array;
+		return ret;
+	grep: function( elems, callback, inv ) {
+		// If a string is passed in for the function, make a function
+		// for it (a handy shortcut)
+		if ( typeof callback == "string" )
+			callback = eval("false||function(a,i){return " + callback + "}");
+		var ret = [];
+		// Go through the array, only saving the items
+		// that pass the validator function
+		for ( var i = 0, length = elems.length; i < length; i++ )
+			if ( !inv && callback( elems[ i ], i ) || inv && !callback( elems[ i ], i ) )
+				ret.push( elems[ i ] );
+		return ret;
+	map: function( elems, callback ) {
+		var ret = [];
+		// Go through the array, translating each of the items to their
+		// new value (or values).
+		for ( var i = 0, length = elems.length; i < length; i++ ) {
+			var value = callback( elems[ i ], i );
+			if ( value !== null && value != undefined ) {
+				if ( value.constructor != Array )
+					value = [ value ];
+				ret = ret.concat( value );
+		return ret;
+var userAgent = navigator.userAgent.toLowerCase();
+// Figure out what browser is being used
+jQuery.browser = {
+	version: (userAgent.match( /.+(?:rv|it|ra|ie)[\/: ]([\d.]+)/ ) || [])[1],
+	safari: /webkit/.test( userAgent ),
+	opera: /opera/.test( userAgent ),
+	msie: /msie/.test( userAgent ) && !/opera/.test( userAgent ),
+	mozilla: /mozilla/.test( userAgent ) && !/(compatible|webkit)/.test( userAgent )
+var styleFloat = jQuery.browser.msie ?
+	"styleFloat" :
+	"cssFloat";
+jQuery.extend({
+	// Check to see if the W3C box model is being used
+	boxModel: !jQuery.browser.msie || document.compatMode == "CSS1Compat",
+	props: {
+		"for": "htmlFor",
+		"class": "className",
+		"float": styleFloat,
+		cssFloat: styleFloat,
+		styleFloat: styleFloat,
+		innerHTML: "innerHTML",
+		className: "className",
+		value: "value",
+		disabled: "disabled",
+		checked: "checked",
+		readonly: "readOnly",
+		selected: "selected",
+		maxlength: "maxLength",
+		selectedIndex: "selectedIndex"
+jQuery.each({
+	parent: "elem.parentNode",
+	parents: "jQuery.dir(elem,'parentNode')",
+	next: "jQuery.nth(elem,2,'nextSibling')",
+	prev: "jQuery.nth(elem,2,'previousSibling')",
+	nextAll: "jQuery.dir(elem,'nextSibling')",
+	prevAll: "jQuery.dir(elem,'previousSibling')",
+	siblings: "jQuery.sibling(elem.parentNode.firstChild,elem)",
+	children: "jQuery.sibling(elem.firstChild)",
+	contents: "jQuery.nodeName(elem,'iframe')?elem.contentDocument||elem.contentWindow.document:jQuery.makeArray(elem.childNodes)"
+}, function(name, fn){
+	fn = eval("false||function(elem){return " + fn + "}");
+	jQuery.fn[ name ] = function( selector ) {
+		var ret = jQuery.map( this, fn );
+		if ( selector && typeof selector == "string" )
+			ret = jQuery.multiFilter( selector, ret );
+		return this.pushStack( jQuery.unique( ret ) );
+jQuery.each({
+	appendTo: "append",
+	prependTo: "prepend",
+	insertBefore: "before",
+	insertAfter: "after",
+	replaceAll: "replaceWith"
+}, function(name, original){
+	jQuery.fn[ name ] = function() {
+		var args = arguments;
+			for ( var i = 0, length = args.length; i < length; i++ )
+				jQuery( args[ i ] )[ original ]( this );
+jQuery.each({
+	removeAttr: function( name ) {
+		jQuery.attr( this, name, "" );
+		this.removeAttribute( name );
+	addClass: function( classNames ) {
+		jQuery.className.add( this, classNames );
+	removeClass: function( classNames ) {
+		jQuery.className.remove( this, classNames );
+	toggleClass: function( classNames ) {
+		jQuery.className[ jQuery.className.has( this, classNames ) ? "remove" : "add" ]( this, classNames );
+	remove: function( selector ) {
+		if ( !selector || jQuery.filter( selector, [ this ] ).r.length ) {
+			jQuery.removeData( this );
+			this.parentNode.removeChild( this );
+	empty: function() {
+		// Clean up the cache
+		jQuery( "*", this ).each(function(){
+			jQuery.removeData(this);
+		while ( this.firstChild )
+			this.removeChild( this.firstChild );
+	jQuery.fn[ name ] = function(){
+		return this.each( fn, arguments );
+jQuery.each([ "Height", "Width" ], function(i, name){
+	var type = name.toLowerCase();
+	jQuery.fn[ type ] = function( size ) {
+		// Get window width or height
+		return this[0] == window ?
+			// Opera reports document.body.client[Width/Height] properly in both quirks and standards
+			jQuery.browser.opera && document.body[ "client" + name ] ||
+			// Safari reports inner[Width/Height] just fine (Mozilla and Opera include scroll bar widths)
+			jQuery.browser.safari && self[ "inner" + name ] ||
+			// Everyone else use document.documentElement or document.body depending on Quirks vs Standards mode
+			document.compatMode == "CSS1Compat" && document.documentElement[ "client" + name ] || document.body[ "client" + name ] :
+			// Get document width or height
+			this[0] == document ?
+				// Either scroll[Width/Height] or offset[Width/Height], whichever is greater (Mozilla reports scrollWidth the same as offsetWidth)
+				Math.max( document.body[ "scroll" + name ], document.body[ "offset" + name ] ) :
+				// Get or set width or height on the element
+				size == undefined ?
+					// Get width or height on the element
+					(this.length ? jQuery.css( this[0], type ) : null) :
+					// Set the width or height on the element (default to pixels if value is unitless)
+					this.css( type, size.constructor == String ? size : size + "px" );
+var chars = jQuery.browser.safari && parseInt(jQuery.browser.version) < 417 ?
+		"(?:[\\w*_-]|\\\\.)" :
+		"(?:[\\w\u0128-\uFFFF*_-]|\\\\.)",
+	quickChild = new RegExp("^>\\s*(" + chars + "+)"),
+	quickID = new RegExp("^(" + chars + "+)(#)(" + chars + "+)"),
+	quickClass = new RegExp("^([#.]?)(" + chars + "*)");
+jQuery.extend({
+	expr: {
+		"": "m[2]=='*'||jQuery.nodeName(a,m[2])",
+		"#": "a.getAttribute('id')==m[2]",
+			// Position Checks
+			lt: "i<m[3]-0",
+			gt: "i>m[3]-0",
+			nth: "m[3]-0==i",
+			eq: "m[3]-0==i",
+			first: "i==0",
+			last: "i==r.length-1",
+			even: "i%2==0",
+			odd: "i%2",
+			// Child Checks
+			"first-child": "a.parentNode.getElementsByTagName('*')[0]==a",
+			"last-child": "jQuery.nth(a.parentNode.lastChild,1,'previousSibling')==a",
+			"only-child": "!jQuery.nth(a.parentNode.lastChild,2,'previousSibling')",
+			// Parent Checks
+			parent: "a.firstChild",
+			empty: "!a.firstChild",
+			// Text Check
+			contains: "(a.textContent||a.innerText||jQuery(a).text()||'').indexOf(m[3])>=0",
+			// Visibility
+			visible: '"hidden"!=a.type&&jQuery.css(a,"display")!="none"&&jQuery.css(a,"visibility")!="hidden"',
+			hidden: '"hidden"==a.type||jQuery.css(a,"display")=="none"||jQuery.css(a,"visibility")=="hidden"',
+			// Form attributes
+			enabled: "!a.disabled",
+			disabled: "a.disabled",
+			checked: "a.checked",
+			selected: "a.selected||jQuery.attr(a,'selected')",
+			// Form elements
+			text: "'text'==a.type",
+			radio: "'radio'==a.type",
+			checkbox: "'checkbox'==a.type",
+			file: "'file'==a.type",
+			password: "'password'==a.type",
+			submit: "'submit'==a.type",
+			image: "'image'==a.type",
+			reset: "'reset'==a.type",
+			button: '"button"==a.type||jQuery.nodeName(a,"button")',
+			input: "/input|select|textarea|button/i.test(a.nodeName)",
+			// :has()
+			has: "jQuery.find(m[3],a).length",
+			// :header
+			header: "/h\\d/i.test(a.nodeName)",
+			// :animated
+			animated: "jQuery.grep(jQuery.timers,function(fn){return a==fn.elem;}).length"
+	// The regular expressions that power the parsing engine
+	parse: [
+		// Match: [@value='test'], [@foo]
+		/^(\[) *@?([\w-]+) *([!*$^~=]*) *('?"?)(.*?)\4 *\]/,
+		// Match: :contains('foo')
+		/^(:)([\w-]+)\("?'?(.*?(\(.*?\))?[^(]*?)"?'?\)/,
+		// Match: :even, :last-chlid, #id, .class
+		new RegExp("^([:.#]*)(" + chars + "+)")
+	multiFilter: function( expr, elems, not ) {
+		var old, cur = [];
+		while ( expr && expr != old ) {
+			old = expr;
+			var f = jQuery.filter( expr, elems, not );
+			expr = f.t.replace(/^\s*,\s*/, "" );
+			cur = not ? elems = f.r : jQuery.merge( cur, f.r );
+		return cur;
+	find: function( t, context ) {
+		// Quickly handle non-string expressions
+		if ( typeof t != "string" )
+			return [ t ];
+		// Make sure that the context is a DOM Element
+		if ( context && !context.nodeType )
+			context = null;
+		// Set the correct context (if none is provided)
+		// Initialize the search
+		var ret = [context], done = [], last;
+		// Continue while a selector expression exists, and while
+		// we're no longer looping upon ourselves
+		while ( t && last != t ) {
+			var r = [];
+			last = t;
+			t = jQuery.trim(t);
+			var foundToken = false;
+			// An attempt at speeding up child selectors that
+			// point to a specific element tag
+			var re = quickChild;
+			var m = re.exec(t);
+			if ( m ) {
+				var nodeName = m[1].toUpperCase();
+				// Perform our own iteration and filter
+				for ( var i = 0; ret[i]; i++ )
+					for ( var c = ret[i].firstChild; c; c = c.nextSibling )
+						if ( c.nodeType == 1 && (nodeName == "*" || c.nodeName.toUpperCase() == nodeName.toUpperCase()) )
+							r.push( c );
+				ret = r;
+				t = t.replace( re, "" );
+				if ( t.indexOf(" ") == 0 ) continue;
+				foundToken = true;
+			} else {
+				re = /^([>+~])\s*(\w*)/i;
+				if ( (m = re.exec(t)) != null ) {
+					r = [];
+					var nodeName = m[2], merge = {};
+					m = m[1];
+					for ( var j = 0, rl = ret.length; j < rl; j++ ) {
+						var n = m == "~" || m == "+" ? ret[j].nextSibling : ret[j].firstChild;
+						for ( ; n; n = n.nextSibling )
+							if ( n.nodeType == 1 ) {
+								var id = jQuery.data(n);
+								if ( m == "~" && merge[id] ) break;
+								if (!nodeName || n.nodeName.toUpperCase() == nodeName.toUpperCase() ) {
+									if ( m == "~" ) merge[id] = true;
+									r.push( n );
+								if ( m == "+" ) break;
+					ret = r;
+					// And remove the token
+					t = jQuery.trim( t.replace( re, "" ) );
+			// See if there's still an expression, and that we haven't already
+			// matched a token
+			if ( t && !foundToken ) {
+				// Handle multiple expressions
+				if ( !t.indexOf(",") ) {
+					// Clean the result set
+					if ( context == ret[0] ) ret.shift();
+					// Merge the result sets
+					done = jQuery.merge( done, ret );
+					// Reset the context
+					r = ret = [context];
+					// Touch up the selector string
+					t = " " + t.substr(1,t.length);
+				} else {
+					// Optimize for the case nodeName#idName
+					var re2 = quickID;
+					var m = re2.exec(t);
+					// Re-organize the results, so that they're consistent
+					if ( m ) {
+					   m = [ 0, m[2], m[3], m[1] ];
+					} else {
+						// Otherwise, do a traditional filter check for
+						// ID, class, and element selectors
+						re2 = quickClass;
+						m = re2.exec(t);
+					m[2] = m[2].replace(/\\/g, "");
+					var elem = ret[ret.length-1];
+					// Try to do a global search by ID, where we can
+					if ( m[1] == "#" && elem && elem.getElementById && !jQuery.isXMLDoc(elem) ) {
+						// Optimization for HTML document case
+						var oid = elem.getElementById(m[2]);
+						// Do a quick check for the existence of the actual ID attribute
+						// to avoid selecting by the name attribute in IE
+						// also check to insure id is a string to avoid selecting an element with the name of 'id' inside a form
+						if ( (jQuery.browser.msie||jQuery.browser.opera) && oid && typeof oid.id == "string" && oid.id != m[2] )
+							oid = jQuery('[@id="'+m[2]+'"]', elem)[0];
+						// Do a quick check for node name (where applicable) so
+						// that div#foo searches will be really fast
+						ret = r = oid && (!m[3] || jQuery.nodeName(oid, m[3])) ? [oid] : [];
+					} else {
+						// We need to find all descendant elements
+						for ( var i = 0; ret[i]; i++ ) {
+							// Grab the tag name being searched for
+							var tag = m[1] == "#" && m[3] ? m[3] : m[1] != "" || m[0] == "" ? "*" : m[2];
+							// Handle IE7 being really dumb about <object>s
+							if ( tag == "*" && ret[i].nodeName.toLowerCase() == "object" )
+								tag = "param";
+							r = jQuery.merge( r, ret[i].getElementsByTagName( tag ));
+						// It's faster to filter by class and be done with it
+						if ( m[1] == "." )
+							r = jQuery.classFilter( r, m[2] );
+						// Same with ID filtering
+						if ( m[1] == "#" ) {
+							var tmp = [];
+							// Try to find the element with the ID
+							for ( var i = 0; r[i]; i++ )
+								if ( r[i].getAttribute("id") == m[2] ) {
+									tmp = [ r[i] ];
+									break;
+							r = tmp;
+						ret = r;
+					t = t.replace( re2, "" );
+			// If a selector string still exists
+			if ( t ) {
+				// Attempt to filter it
+				var val = jQuery.filter(t,r);
+				ret = r = val.r;
+				t = jQuery.trim(val.t);
+		// An error occurred with the selector;
+		// just return an empty set instead
+		if ( t )
+			ret = [];
+		// Remove the root context
+		if ( ret && context == ret[0] )
+			ret.shift();
+		// And combine the results
+		return done;
+	classFilter: function(r,m,not){
+		m = " " + m + " ";
+		var tmp = [];
+		for ( var i = 0; r[i]; i++ ) {
+			var pass = (" " + r[i].className + " ").indexOf( m ) >= 0;
+			if ( !not && pass || not && !pass )
+				tmp.push( r[i] );
+		return tmp;
+	filter: function(t,r,not) {
+		var last;
+		// Look for common filter expressions
+		while ( t  && t != last ) {
+			last = t;
+			var p = jQuery.parse, m;
+			for ( var i = 0; p[i]; i++ ) {
+				m = p[i].exec( t );
+				if ( m ) {
+					// Remove what we just matched
+					t = t.substring( m[0].length );
+					break;
+			if ( !m )
+				break;
+			// :not() is a special case that can be optimized by
+			// keeping it out of the expression list
+			if ( m[1] == ":" && m[2] == "not" )
+				r = jQuery.filter(m[3], r, true).r;
+			// We can get a big speed boost by filtering by class here
+			else if ( m[1] == "." )
+				r = jQuery.classFilter(r, m[2], not);
+			else if ( m[1] == "[" ) {
+				var tmp = [], type = m[3];
+				for ( var i = 0, rl = r.length; i < rl; i++ ) {
+					var a = r[i], z = a[ jQuery.props[m[2]] || m[2] ];
+					if ( z == null || /href|src|selected/.test(m[2]) )
+						z = jQuery.attr(a,m[2]) || '';
+					if ( (type == "" && !!z ||
+						 type == "=" && z == m[5] ||
+						 type == "!=" && z != m[5] ||
+						 type == "^=" && z && !z.indexOf(m[5]) ||
+						 type == "$=" && z.substr(z.length - m[5].length) == m[5] ||
+						 (type == "*=" || type == "~=") && z.indexOf(m[5]) >= 0) ^ not )
+							tmp.push( a );
+				r = tmp;
+			// We can get a speed boost by handling nth-child here
+			} else if ( m[1] == ":" && m[2] == "nth-child" ) {
+				var merge = {}, tmp = [],
+					test = /(\d*)n\+?(\d*)/.exec(
+						m[3] == "even" && "2n" || m[3] == "odd" && "2n+1" ||
+						!/\D/.test(m[3]) && "n+" + m[3] || m[3]),
+					first = (test[1] || 1) - 0, last = test[2] - 0;
+					var node = r[i], parentNode = node.parentNode, id = jQuery.data(parentNode);
+					if ( !merge[id] ) {
+						var c = 1;
+						for ( var n = parentNode.firstChild; n; n = n.nextSibling )
+								n.nodeIndex = c++;
+						merge[id] = true;
+					var add = false;
+					if ( first == 1 ) {
+						if ( last == 0 || node.nodeIndex == last )
+							add = true;
+					} else if ( (node.nodeIndex + last) % first == 0 )
+						add = true;
+					if ( add ^ not )
+						tmp.push( node );
+				r = tmp;
+			// Otherwise, find the expression to execute
+			} else {
+				var f = jQuery.expr[m[1]];
+				if ( typeof f != "string" )
+					f = jQuery.expr[m[1]][m[2]];
+				// Build a custom macro to enclose it
+				f = eval("false||function(a,i){return " + f + "}");
+				// Execute it against the current filter
+				r = jQuery.grep( r, f, not );
+		// Return an array of filtered elements (r)
+		// and the modified expression string (t)
+		return { r: r, t: t };
+	dir: function( elem, dir ){
+		var matched = [];
+		var cur = elem[dir];
+		while ( cur && cur != document ) {
+			if ( cur.nodeType == 1 )
+				matched.push( cur );
+			cur = cur[dir];
+		return matched;
+	nth: function(cur,result,dir,elem){
+		result = result || 1;
+		var num = 0;
+		for ( ; cur; cur = cur[dir] )
+			if ( cur.nodeType == 1 && ++num == result )
+				break;
+		return cur;
+	sibling: function( n, elem ) {
+		var r = [];
+		for ( ; n; n = n.nextSibling ) {
+			if ( n.nodeType == 1 && (!elem || n != elem) )
+				r.push( n );
+		return r;
+ * A number of helper functions used for managing events.
+ * Many of the ideas behind this code orignated from
+ * Dean Edwards' addEvent library.
+jQuery.event = {
+	// Bind an event to an element
+	// Original by Dean Edwards
+	add: function(element, type, handler, data) {
+		// For whatever reason, IE has trouble passing the window object
+		// around, causing it to be cloned in the process
+		if ( jQuery.browser.msie && element.setInterval != undefined )
+			element = window;
+		// Make sure that the function being executed has a unique ID
+		if ( !handler.guid )
+			handler.guid = this.guid++;
+		// if data is passed, bind to handler
+		if( data != undefined ) {
+        		// Create temporary function pointer to original handler
+			var fn = handler;
+			// Create unique handler function, wrapped around original handler
+			handler = function() {
+				// Pass arguments and context to original handler
+				return fn.apply(this, arguments);
+			// Store data in unique handler
+			handler.data = data;
+			// Set the guid of unique handler to the same of original handler, so it can be removed
+			handler.guid = fn.guid;
+		// Namespaced event handlers
+		var parts = type.split(".");
+		type = parts[0];
+		handler.type = parts[1];
+		// Init the element's event structure
+		var events = jQuery.data(element, "events") || jQuery.data(element, "events", {});
+		var handle = jQuery.data(element, "handle", function(){
+			// returned undefined or false
+			var val;
+			// Handle the second event of a trigger and when
+			// an event is called after a page has unloaded
+			if ( typeof jQuery == "undefined" || jQuery.event.triggered )
+				return val;
+			val = jQuery.event.handle.apply(element, arguments);
+			return val;
+		// Get the current list of functions bound to this event
+		var handlers = events[type];
+		// Init the event handler queue
+		if (!handlers) {
+			handlers = events[type] = {};
+			// And bind the global event handler to the element
+			if (element.addEventListener)
+				element.addEventListener(type, handle, false);
+			else
+				element.attachEvent("on" + type, handle);
+		// Add the function to the element's handler list
+		handlers[handler.guid] = handler;
+		// Keep track of which events have been used, for global triggering
+		this.global[type] = true;
+	guid: 1,
+	global: {},
+	// Detach an event or set of events from an element
+	remove: function(element, type, handler) {
+		var events = jQuery.data(element, "events"), ret, index;
+		if ( typeof type == "string" ) {
+			type = parts[0];
+		if ( events ) {
+			// type is actually an event object here
+			if ( type && type.type ) {
+				handler = type.handler;
+				type = type.type;
+			if ( !type ) {
+				for ( type in events )
+					this.remove( element, type );
+			} else if ( events[type] ) {
+				// remove the given handler for the given type
+				if ( handler )
+					delete events[type][handler.guid];
+				// remove all handlers for the given type
+				else
+					for ( handler in events[type] )
+						// Handle the removal of namespaced events
+						if ( !parts[1] || events[type][handler].type == parts[1] )
+							delete events[type][handler];
+				// remove generic event handler if no more handlers exist
+				for ( ret in events[type] ) break;
+				if ( !ret ) {
+					if (element.removeEventListener)
+						element.removeEventListener(type, jQuery.data(element, "handle"), false);
+					else
+						element.detachEvent("on" + type, jQuery.data(element, "handle"));
+					ret = null;
+					delete events[type];
+			// Remove the expando if it's no longer used
+			for ( ret in events ) break;
+			if ( !ret ) {
+				jQuery.removeData( element, "events" );
+				jQuery.removeData( element, "handle" );
+	trigger: function(type, data, element, donative, extra) {
+		// Clone the incoming data, if any
+		data = jQuery.makeArray(data || []);
+		// Handle a global trigger
+		if ( !element ) {
+			// Only trigger if we've ever bound an event for it
+			if ( this.global[type] )
+				jQuery("*").add([window, document]).trigger(type, data);
+		// Handle triggering a single element
+		} else {
+			var val, ret, fn = jQuery.isFunction( element[ type ] || null ),
+				// Check to see if we need to provide a fake event, or not
+				evt = !data[0] || !data[0].preventDefault;
+			// Pass along a fake event
+			if ( evt )
+				data.unshift( this.fix({ type: type, target: element }) );
+			// Enforce the right trigger type
+			data[0].type = type;
+			// Trigger the event
+			if ( jQuery.isFunction( jQuery.data(element, "handle") ) )
+				val = jQuery.data(element, "handle").apply( element, data );
+			// Handle triggering native .onfoo handlers
+			if ( !fn && element["on"+type] && element["on"+type].apply( element, data ) === false )
+				val = false;
+			// Extra functions don't get the custom event object
+			if ( evt )
+				data.shift();
+			// Handle triggering of extra function
+			if ( extra && extra.apply( element, data ) === false )
+				val = false;
+			// Trigger the native events (except for clicks on links)
+			if ( fn && donative !== false && val !== false && !(jQuery.nodeName(element, 'a') && type == "click") ) {
+				this.triggered = true;
+				element[ type ]();
+			this.triggered = false;
+		return val;
+	handle: function(event) {
+		var val;
+		// Empty object is for triggered events with no data
+		event = jQuery.event.fix( event || window.event || {} );
+		var parts = event.type.split(".");
+		event.type = parts[0];
+		var c = jQuery.data(this, "events") && jQuery.data(this, "events")[event.type], args = Array.prototype.slice.call( arguments, 1 );
+		args.unshift( event );
+		for ( var j in c ) {
+			// Pass in a reference to the handler function itself
+			// So that we can later remove it
+			args[0].handler = c[j];
+			args[0].data = c[j].data;
+			// Filter the functions by class
+			if ( !parts[1] || c[j].type == parts[1] ) {
+				var tmp = c[j].apply( this, args );
+				if ( val !== false )
+					val = tmp;
+				if ( tmp === false ) {
+					event.preventDefault();
+					event.stopPropagation();
+		// Clean up added properties in IE to prevent memory leak
+		if (jQuery.browser.msie)
+			event.target = event.preventDefault = event.stopPropagation =
+				event.handler = event.data = null;
+		return val;
+	fix: function(event) {
+		// store a copy of the original event object
+		// and clone to set read-only properties
+		var originalEvent = event;
+		event = jQuery.extend({}, originalEvent);
+		// add preventDefault and stopPropagation since
+		// they will not work on the clone
+		event.preventDefault = function() {
+			// if preventDefault exists run it on the original event
+			if (originalEvent.preventDefault)
+				originalEvent.preventDefault();
+			// otherwise set the returnValue property of the original event to false (IE)
+			originalEvent.returnValue = false;
+		event.stopPropagation = function() {
+			// if stopPropagation exists run it on the original event
+			if (originalEvent.stopPropagation)
+				originalEvent.stopPropagation();
+			// otherwise set the cancelBubble property of the original event to true (IE)
+			originalEvent.cancelBubble = true;
+		// Fix target property, if necessary
+		if ( !event.target && event.srcElement )
+			event.target = event.srcElement;
+		// check if target is a textnode (safari)
+		if (jQuery.browser.safari && event.target.nodeType == 3)
+			event.target = originalEvent.target.parentNode;
+		// Add relatedTarget, if necessary
+		if ( !event.relatedTarget && event.fromElement )
+			event.relatedTarget = event.fromElement == event.target ? event.toElement : event.fromElement;
+		// Calculate pageX/Y if missing and clientX/Y available
+		if ( event.pageX == null && event.clientX != null ) {
+			var e = document.documentElement, b = document.body;
+			event.pageX = event.clientX + (e && e.scrollLeft || b && b.scrollLeft || 0);
+			event.pageY = event.clientY + (e && e.scrollTop || b && b.scrollTop || 0);
+		// Add which for key events
+		if ( !event.which && (event.charCode || event.keyCode) )
+			event.which = event.charCode || event.keyCode;
+		// Add metaKey to non-Mac browsers (use ctrl for PC's and Meta for Macs)
+		if ( !event.metaKey && event.ctrlKey )
+			event.metaKey = event.ctrlKey;
+		// Add which for click: 1 == left; 2 == middle; 3 == right
+		// Note: button is not normalized, so don't use it
+		if ( !event.which && event.button )
+			event.which = (event.button & 1 ? 1 : ( event.button & 2 ? 3 : ( event.button & 4 ? 2 : 0 ) ));
+		return event;
+jQuery.fn.extend({
+	bind: function( type, data, fn ) {
+		return type == "unload" ? this.one(type, data, fn) : this.each(function(){
+			jQuery.event.add( this, type, fn || data, fn && data );
+	one: function( type, data, fn ) {
+			jQuery.event.add( this, type, function(event) {
+				jQuery(this).unbind(event);
+				return (fn || data).apply( this, arguments);
+			}, fn && data);
+	unbind: function( type, fn ) {
+			jQuery.event.remove( this, type, fn );
+	trigger: function( type, data, fn ) {
+			jQuery.event.trigger( type, data, this, true, fn );
+	triggerHandler: function( type, data, fn ) {
+		if ( this[0] )
+			return jQuery.event.trigger( type, data, this[0], false, fn );
+	toggle: function() {
+		// Save reference to arguments for access in closure
+		var a = arguments;
+		return this.click(function(e) {
+			// Figure out which function to execute
+			this.lastToggle = 0 == this.lastToggle ? 1 : 0;
+			// Make sure that clicks stop
+			e.preventDefault();
+			// and execute the function
+			return a[this.lastToggle].apply( this, [e] ) || false;
+	hover: function(f,g) {
+		// A private function for handling mouse 'hovering'
+		function handleHover(e) {
+			// Check if mouse(over|out) are still within the same parent element
+			var p = e.relatedTarget;
+			// Traverse up the tree
+			while ( p && p != this ) try { p = p.parentNode; } catch(e) { p = this; };
+			// If we actually just moused on to a sub-element, ignore it
+			if ( p == this ) return false;
+			// Execute the right function
+			return (e.type == "mouseover" ? f : g).apply(this, [e]);
+		// Bind the function to the two event listeners
+		return this.mouseover(handleHover).mouseout(handleHover);
+	ready: function(f) {
+		// Attach the listeners
+		bindReady();
+		// If the DOM is already ready
+		if ( jQuery.isReady )
+			// Execute the function immediately
+			f.apply( document, [jQuery] );
+		// Otherwise, remember the function for later
+		else
+			// Add the function to the wait list
+			jQuery.readyList.push( function() { return f.apply(this, [jQuery]); } );
+		return this;
+jQuery.extend({
+	 * All the code that makes DOM Ready work nicely.
+	isReady: false,
+	readyList: [],
+	// Handle when the DOM is ready
+	ready: function() {
+		// Make sure that the DOM is not already loaded
+		if ( !jQuery.isReady ) {
+			// Remember that the DOM is ready
+			jQuery.isReady = true;
+			// If there are functions bound, to execute
+			if ( jQuery.readyList ) {
+				// Execute all of them
+				jQuery.each( jQuery.readyList, function(){
+					this.apply( document );
+				// Reset the list of functions
+				jQuery.readyList = null;
+			// Remove event listener to avoid memory leak
+			if ( jQuery.browser.mozilla || jQuery.browser.opera )
+				document.removeEventListener( "DOMContentLoaded", jQuery.ready, false );
+jQuery.each( ("blur,focus,load,resize,scroll,unload,click,dblclick," +
+	"mousedown,mouseup,mousemove,mouseover,mouseout,change,select," +
+	"submit,keydown,keypress,keyup,error").split(","), function(i,o){
+	// Handle event binding
+	jQuery.fn[o] = function(f){
+		return f ? this.bind(o, f) : this.trigger(o);
+var readyBound = false;
+function bindReady(){
+	if ( readyBound ) return;
+	readyBound = true;
+	// If Mozilla is used
+		// Use the handy event callback
+		document.addEventListener( "DOMContentLoaded", jQuery.ready, false );
+	// If Safari or IE is used
+	else {
+		// Continually check to see if the document is ready
+		function timer(){
+			try {
+				// If IE is used, use the trick by Diego Perini
+				// http://javascript.nwbox.com/IEContentLoaded/
+				if ( jQuery.browser.msie || document.readyState != "loaded" && document.readyState != "complete" )
+					document.documentElement.doScroll("left");
+				// and execute any waiting functions
+				jQuery.ready();
+			} catch( error ) {
+				setTimeout( timer, 0 );
+		timer();
+	// A fallback to window.onload, that will always work
+	jQuery.event.add( window, "load", jQuery.ready );
+jQuery.fn.extend({
+	load: function( url, params, callback ) {
+		if ( jQuery.isFunction( url ) )
+			return this.bind("load", url);
+		var off = url.indexOf(" ");
+		if ( off >= 0 ) {
+			var selector = url.slice(off, url.length);
+			url = url.slice(0, off);
+		callback = callback || function(){};
+		// Default to a GET request
+		var type = "GET";
+		// If the second parameter was provided
+		if ( params )
+			// If it's a function
+			if ( jQuery.isFunction( params ) ) {
+				// We assume that it's the callback
+				callback = params;
+				params = null;
+			// Otherwise, build a param string
+			} else {
+				params = jQuery.param( params );
+				type = "POST";
+		var self = this;
+		// Request the remote document
+		jQuery.ajax({
+			url: url,
+			type: type,
+			data: params,
+			complete: function(res, status){
+				// If successful, inject the HTML into all the matched elements
+				if ( status == "success" || status == "notmodified" )
+					// See if a selector was specified
+					self.html( selector ?
+						// Create a dummy div to hold the results
+						jQuery("<div/>")
+							// inject the contents of the document in, removing the scripts
+							// to avoid any 'Permission Denied' errors in IE
+							.append(res.responseText.replace(/<script(.|\s)*?\/script>/g, ""))
+							// Locate the specified elements
+							.find(selector) :
+						// If not, just inject the full result
+						res.responseText );
+				// Add delay to account for Safari's delay in globalEval
+				setTimeout(function(){
+					self.each( callback, [res.responseText, status, res] );
+				}, 13);
+		return this;
+	serialize: function() {
+		return jQuery.param(this.serializeArray());
+	serializeArray: function() {
+		return this.map(function(){
+			return jQuery.nodeName(this, "form") ?
+				jQuery.makeArray(this.elements) : this;
+		.filter(function(){
+			return this.name && !this.disabled &&
+				(this.checked || /select|textarea/i.test(this.nodeName) ||
+					/text|hidden|password/i.test(this.type));
+		.map(function(i, elem){
+			var val = jQuery(this).val();
+			return val == null ? null :
+				val.constructor == Array ?
+					jQuery.map( val, function(val, i){
+						return {name: elem.name, value: val};
+					{name: elem.name, value: val};
+		}).get();
+// Attach a bunch of functions for handling common AJAX events
+jQuery.each( "ajaxStart,ajaxStop,ajaxComplete,ajaxError,ajaxSuccess,ajaxSend".split(","), function(i,o){
+		return this.bind(o, f);
+var jsc = (new Date).getTime();
+jQuery.extend({
+	get: function( url, data, callback, type ) {
+		// shift arguments if data argument was ommited
+		if ( jQuery.isFunction( data ) ) {
+			callback = data;
+			data = null;
+		return jQuery.ajax({
+			type: "GET",
+			url: url,
+			data: data,
+			success: callback,
+			dataType: type
+	getScript: function( url, callback ) {
+		return jQuery.get(url, null, callback, "script");
+	getJSON: function( url, data, callback ) {
+		return jQuery.get(url, data, callback, "json");
+	post: function( url, data, callback, type ) {
+			callback = data;
+			data = {};
+			type: "POST",
+			url: url,
+			data: data,
+			dataType: type
+	ajaxSetup: function( settings ) {
+		jQuery.extend( jQuery.ajaxSettings, settings );
+	ajaxSettings: {
+		global: true,
+		type: "GET",
+		timeout: 0,
+		contentType: "application/x-www-form-urlencoded",
+		processData: true,
+		async: true,
+		data: null
+	// Last-Modified header cache for next request
+	lastModified: {},
+	ajax: function( s ) {
+		var jsonp, jsre = /=(\?|%3F)/g, status, data;
+		// Extend the settings, but re-extend 's' so that it can be
+		// checked again later (in the test suite, specifically)
+		s = jQuery.extend(true, s, jQuery.extend(true, {}, jQuery.ajaxSettings, s));
+		// convert data if not already a string
+		if ( s.data && s.processData && typeof s.data != "string" )
+			s.data = jQuery.param(s.data);
+		// Handle JSONP Parameter Callbacks
+		if ( s.dataType == "jsonp" ) {
+			if ( s.type.toLowerCase() == "get" ) {
+				if ( !s.url.match(jsre) )
+					s.url += (s.url.match(/\?/) ? "&" : "?") + (s.jsonp || "callback") + "=?";
+			} else if ( !s.data || !s.data.match(jsre) )
+				s.data = (s.data ? s.data + "&" : "") + (s.jsonp || "callback") + "=?";
+			s.dataType = "json";
+		// Build temporary JSONP function
+		if ( s.dataType == "json" && (s.data && s.data.match(jsre) || s.url.match(jsre)) ) {
+			jsonp = "jsonp" + jsc++;
+			// Replace the =? sequence both in the query string and the data
+			if ( s.data )
+				s.data = s.data.replace(jsre, "=" + jsonp);
+			s.url = s.url.replace(jsre, "=" + jsonp);
+			// We need to make sure
+			// that a JSONP style response is executed properly
+			s.dataType = "script";
+			// Handle JSONP-style loading
+			window[ jsonp ] = function(tmp){
+				data = tmp;
+				success();
+				complete();
+				// Garbage collect
+				window[ jsonp ] = undefined;
+				try{ delete window[ jsonp ]; } catch(e){}
+		if ( s.dataType == "script" && s.cache == null )
+			s.cache = false;
+		if ( s.cache === false && s.type.toLowerCase() == "get" )
+			s.url += (s.url.match(/\?/) ? "&" : "?") + "_=" + (new Date()).getTime();
+		// If data is available, append data to url for get requests
+		if ( s.data && s.type.toLowerCase() == "get" ) {
+			s.url += (s.url.match(/\?/) ? "&" : "?") + s.data;
+			// IE likes to send both get and post data, prevent this
+			s.data = null;
+		// Watch for a new set of requests
+		if ( s.global && ! jQuery.active++ )
+			jQuery.event.trigger( "ajaxStart" );
+		// If we're requesting a remote document
+		// and trying to load JSON or Script
+		if ( !s.url.indexOf("http") && s.dataType == "script" ) {
+			var head = document.getElementsByTagName("head")[0];
+			var script = document.createElement("script");
+			script.src = s.url;
+			// Handle Script loading
+			if ( !jsonp && (s.success || s.complete) ) {
+				var done = false;
+				// Attach handlers for all browsers
+				script.onload = script.onreadystatechange = function(){
+					if ( !done && (!this.readyState ||
+							this.readyState == "loaded" || this.readyState == "complete") ) {
+						done = true;
+						success();
+						complete();
+			head.appendChild(script);
+			// We handle everything using the script element injection
+			return;
+		var requestDone = false;
+		// Create the request object; Microsoft failed to properly
+		// implement the XMLHttpRequest in IE7, so we use the ActiveXObject when it is available
+		var xml = window.ActiveXObject ? new ActiveXObject("Microsoft.XMLHTTP") : new XMLHttpRequest();
+		// Open the socket
+		xml.open(s.type, s.url, s.async);
+		// Set the correct header, if data is being sent
+		if ( s.data )
+			xml.setRequestHeader("Content-Type", s.contentType);
+		// Set the If-Modified-Since header, if ifModified mode.
+		if ( s.ifModified )
+			xml.setRequestHeader("If-Modified-Since",
+				jQuery.lastModified[s.url] || "Thu, 01 Jan 1970 00:00:00 GMT" );
+		// Set header so the called script knows that it's an XMLHttpRequest
+		xml.setRequestHeader("X-Requested-With", "XMLHttpRequest");
+		// Allow custom headers/mimetypes
+		if ( s.beforeSend )
+			s.beforeSend(xml);
+		if ( s.global )
+		    jQuery.event.trigger("ajaxSend", [xml, s]);
+		// Wait for a response to come back
+		var onreadystatechange = function(isTimeout){
+			// The transfer is complete and the data is available, or the request timed out
+			if ( !requestDone && xml && (xml.readyState == 4 || isTimeout == "timeout") ) {
+				requestDone = true;
+				// clear poll interval
+				if (ival) {
+					clearInterval(ival);
+					ival = null;
+				status = isTimeout == "timeout" && "timeout" ||
+					!jQuery.httpSuccess( xml ) && "error" ||
+					s.ifModified && jQuery.httpNotModified( xml, s.url ) && "notmodified" ||
+					"success";
+				if ( status == "success" ) {
+					// Watch for, and catch, XML document parse errors
+					try {
+						// process the data (runs the xml through httpData regardless of callback)
+						data = jQuery.httpData( xml, s.dataType );
+					} catch(e) {
+						status = "parsererror";
+				// Make sure that the request was successful or notmodified
+					// Cache Last-Modified header, if ifModified mode.
+					var modRes;
+					try {
+						modRes = xml.getResponseHeader("Last-Modified");
+					} catch(e) {} // swallow exception thrown by FF if header is not available
+					if ( s.ifModified && modRes )
+						jQuery.lastModified[s.url] = modRes;
+					// JSONP handles its own success callback
+					if ( !jsonp )
+						success();
+				} else
+					jQuery.handleError(s, xml, status);
+				// Fire the complete handlers
+				complete();
+				// Stop memory leaks
+				if ( s.async )
+					xml = null;
+		if ( s.async ) {
+			// don't attach the handler to the request, just poll it instead
+			var ival = setInterval(onreadystatechange, 13);
+			// Timeout checker
+			if ( s.timeout > 0 )
+					// Check to see if the request is still happening
+					if ( xml ) {
+						// Cancel the request
+						xml.abort();
+						if( !requestDone )
+							onreadystatechange( "timeout" );
+				}, s.timeout);
+		// Send the data
+		try {
+			xml.send(s.data);
+		} catch(e) {
+			jQuery.handleError(s, xml, null, e);
+		// firefox 1.5 doesn't fire statechange for sync requests
+		if ( !s.async )
+			onreadystatechange();
+		// return XMLHttpRequest to allow aborting the request etc.
+		return xml;
+		function success(){
+			// If a local callback was specified, fire it and pass it the data
+			if ( s.success )
+				s.success( data, status );
+			// Fire the global callback
+			if ( s.global )
+				jQuery.event.trigger( "ajaxSuccess", [xml, s] );
+		function complete(){
+			// Process result
+			if ( s.complete )
+				s.complete(xml, status);
+			// The request was completed
+			if ( s.global )
+				jQuery.event.trigger( "ajaxComplete", [xml, s] );
+			// Handle the global AJAX counter
+			if ( s.global && ! --jQuery.active )
+				jQuery.event.trigger( "ajaxStop" );
+	handleError: function( s, xml, status, e ) {
+		if ( s.error ) s.error( xml, status, e );
+		if ( s.global )
+			jQuery.event.trigger( "ajaxError", [xml, s, e] );
+	// Counter for holding the number of active queries
+	active: 0,
+	// Determines if an XMLHttpRequest was successful or not
+	httpSuccess: function( r ) {
+		try {
+			return !r.status && location.protocol == "file:" ||
+				( r.status >= 200 && r.status < 300 ) || r.status == 304 ||
+				jQuery.browser.safari && r.status == undefined;
+		} catch(e){}
+		return false;
+	// Determines if an XMLHttpRequest returns NotModified
+	httpNotModified: function( xml, url ) {
+		try {
+			var xmlRes = xml.getResponseHeader("Last-Modified");
+			// Firefox always returns 200. check Last-Modified date
+			return xml.status == 304 || xmlRes == jQuery.lastModified[url] ||
+				jQuery.browser.safari && xml.status == undefined;
+		} catch(e){}
+		return false;
+	httpData: function( r, type ) {
+		var ct = r.getResponseHeader("content-type");
+		var xml = type == "xml" || !type && ct && ct.indexOf("xml") >= 0;
+		var data = xml ? r.responseXML : r.responseText;
+		if ( xml && data.documentElement.tagName == "parsererror" )
+			throw "parsererror";
+		// If the type is "script", eval it in global context
+		if ( type == "script" )
+			jQuery.globalEval( data );
+		// Get the JavaScript object, if JSON is used.
+		if ( type == "json" )
+			data = eval("(" + data + ")");
+		return data;
+	// Serialize an array of form elements or a set of
+	// key/values into a query string
+	param: function( a ) {
+		var s = [];
+		// If an array was passed in, assume that it is an array
+		// of form elements
+		if ( a.constructor == Array || a.jquery )
+			// Serialize the form elements
+			jQuery.each( a, function(){
+				s.push( encodeURIComponent(this.name) + "=" + encodeURIComponent( this.value ) );
+		// Otherwise, assume that it's an object of key/value pairs
+		else
+			// Serialize the key/values
+			for ( var j in a )
+				// If the value is an array then the key names need to be repeated
+				if ( a[j] && a[j].constructor == Array )
+					jQuery.each( a[j], function(){
+						s.push( encodeURIComponent(j) + "=" + encodeURIComponent( this ) );
+				else
+					s.push( encodeURIComponent(j) + "=" + encodeURIComponent( a[j] ) );
+		// Return the resulting serialization
+		return s.join("&").replace(/%20/g, "+");
+jQuery.fn.extend({
+	show: function(speed,callback){
+		return speed ?
+			this.animate({
+				height: "show", width: "show", opacity: "show"
+			}, speed, callback) :
+			this.filter(":hidden").each(function(){
+				this.style.display = this.oldblock ? this.oldblock : "";
+				if ( jQuery.css(this,"display") == "none" )
+					this.style.display = "block";
+			}).end();
+	hide: function(speed,callback){
+		return speed ?
+			this.animate({
+				height: "hide", width: "hide", opacity: "hide"
+			this.filter(":visible").each(function(){
+				this.oldblock = this.oldblock || jQuery.css(this,"display");
+				if ( this.oldblock == "none" )
+					this.oldblock = "block";
+				this.style.display = "none";
+			}).end();
+	// Save the old toggle function
+	_toggle: jQuery.fn.toggle,
+	toggle: function( fn, fn2 ){
+		return jQuery.isFunction(fn) && jQuery.isFunction(fn2) ?
+			this._toggle( fn, fn2 ) :
+			fn ?
+				this.animate({
+					height: "toggle", width: "toggle", opacity: "toggle"
+				}, fn, fn2) :
+				this.each(function(){
+					jQuery(this)[ jQuery(this).is(":hidden") ? "show" : "hide" ]();
+	slideDown: function(speed,callback){
+		return this.animate({height: "show"}, speed, callback);
+	slideUp: function(speed,callback){
+		return this.animate({height: "hide"}, speed, callback);
+	slideToggle: function(speed, callback){
+		return this.animate({height: "toggle"}, speed, callback);
+	fadeIn: function(speed, callback){
+		return this.animate({opacity: "show"}, speed, callback);
+	fadeOut: function(speed, callback){
+		return this.animate({opacity: "hide"}, speed, callback);
+	fadeTo: function(speed,to,callback){
+		return this.animate({opacity: to}, speed, callback);
+	animate: function( prop, speed, easing, callback ) {
+		var opt = jQuery.speed(speed, easing, callback);
+		return this[ opt.queue === false ? "each" : "queue" ](function(){
+			opt = jQuery.extend({}, opt);
+			var hidden = jQuery(this).is(":hidden"), self = this;
+			for ( var p in prop ) {
+				if ( prop[p] == "hide" && hidden || prop[p] == "show" && !hidden )
+					return jQuery.isFunction(opt.complete) && opt.complete.apply(this);
+				if ( p == "height" || p == "width" ) {
+					// Store display property
+					opt.display = jQuery.css(this, "display");
+					// Make sure that nothing sneaks out
+					opt.overflow = this.style.overflow;
+			if ( opt.overflow != null )
+				this.style.overflow = "hidden";
+			opt.curAnim = jQuery.extend({}, prop);
+			jQuery.each( prop, function(name, val){
+				var e = new jQuery.fx( self, opt, name );
+				if ( /toggle|show|hide/.test(val) )
+					e[ val == "toggle" ? hidden ? "show" : "hide" : val ]( prop );
+				else {
+					var parts = val.toString().match(/^([+-]=)?([\d+-.]+)(.*)$/),
+						start = e.cur(true) || 0;
+					if ( parts ) {
+						var end = parseFloat(parts[2]),
+							unit = parts[3] || "px";
+						// We need to compute starting value
+						if ( unit != "px" ) {
+							self.style[ name ] = (end || 1) + unit;
+							start = ((end || 1) / e.cur(true)) * start;
+							self.style[ name ] = start + unit;
+						// If a +=/-= token was provided, we're doing a relative animation
+						if ( parts[1] )
+							end = ((parts[1] == "-=" ? -1 : 1) * end) + start;
+						e.custom( start, end, unit );
+					} else
+						e.custom( start, val, "" );
+			// For JS strict compliance
+			return true;
+	queue: function(type, fn){
+		if ( jQuery.isFunction(type) ) {
+			fn = type;
+			type = "fx";
+		if ( !type || (typeof type == "string" && !fn) )
+			return queue( this[0], type );
+		return this.each(function(){
+			if ( fn.constructor == Array )
+				queue(this, type, fn);
+			else {
+				queue(this, type).push( fn );
+				if ( queue(this, type).length == 1 )
+					fn.apply(this);
+	stop: function(){
+		var timers = jQuery.timers;
+			for ( var i = 0; i < timers.length; i++ )
+				if ( timers[i].elem == this )
+					timers.splice(i--, 1);
+		}).dequeue();
+var queue = function( elem, type, array ) {
+	if ( !elem )
+		return;
+	var q = jQuery.data( elem, type + "queue" );
+	if ( !q || array )
+		q = jQuery.data( elem, type + "queue",
+			array ? jQuery.makeArray(array) : [] );
+	return q;
+jQuery.fn.dequeue = function(type){
+	type = type || "fx";
+		var q = queue(this, type);
+		q.shift();
+		if ( q.length )
+			q[0].apply( this );
+jQuery.extend({
+	speed: function(speed, easing, fn) {
+		var opt = speed && speed.constructor == Object ? speed : {
+			complete: fn || !fn && easing ||
+				jQuery.isFunction( speed ) && speed,
+			duration: speed,
+			easing: fn && easing || easing && easing.constructor != Function && easing
+		opt.duration = (opt.duration && opt.duration.constructor == Number ?
+			opt.duration :
+			{ slow: 600, fast: 200 }[opt.duration]) || 400;
+		// Queueing
+		opt.old = opt.complete;
+		opt.complete = function(){
+			jQuery(this).dequeue();
+			if ( jQuery.isFunction( opt.old ) )
+				opt.old.apply( this );
+		return opt;
+	easing: {
+		linear: function( p, n, firstNum, diff ) {
+			return firstNum + diff * p;
+		swing: function( p, n, firstNum, diff ) {
+			return ((-Math.cos(p*Math.PI)/2) + 0.5) * diff + firstNum;
+	timers: [],
+	fx: function( elem, options, prop ){
+		this.options = options;
+		this.elem = elem;
+		this.prop = prop;
+		if ( !options.orig )
+			options.orig = {};
+jQuery.fx.prototype = {
+	// Simple function for setting a style value
+	update: function(){
+		if ( this.options.step )
+			this.options.step.apply( this.elem, [ this.now, this ] );
+		(jQuery.fx.step[this.prop] || jQuery.fx.step._default)( this );
+		// Set display property to block for height/width animations
+		if ( this.prop == "height" || this.prop == "width" )
+			this.elem.style.display = "block";
+	// Get the current size
+	cur: function(force){
+		if ( this.elem[this.prop] != null && this.elem.style[this.prop] == null )
+			return this.elem[ this.prop ];
+		var r = parseFloat(jQuery.curCSS(this.elem, this.prop, force));
+		return r && r > -10000 ? r : parseFloat(jQuery.css(this.elem, this.prop)) || 0;
+	// Start an animation from one number to another
+	custom: function(from, to, unit){
+		this.startTime = (new Date()).getTime();
+		this.start = from;
+		this.end = to;
+		this.unit = unit || this.unit || "px";
+		this.now = this.start;
+		this.pos = this.state = 0;
+		this.update();
+		var self = this;
+		function t(){
+			return self.step();
+		t.elem = this.elem;
+		jQuery.timers.push(t);
+		if ( jQuery.timers.length == 1 ) {
+			var timer = setInterval(function(){
+					if ( !timers[i]() )
+				if ( !timers.length )
+					clearInterval( timer );
+			}, 13);
+	// Simple 'show' function
+	show: function(){
+		// Remember where we started, so that we can go back to it later
+		this.options.orig[this.prop] = jQuery.attr( this.elem.style, this.prop );
+		this.options.show = true;
+		// Begin the animation
+		this.custom(0, this.cur());
+		// Make sure that we start at a small width/height to avoid any
+		// flash of content
+		if ( this.prop == "width" || this.prop == "height" )
+			this.elem.style[this.prop] = "1px";
+		// Start by showing the element
+		jQuery(this.elem).show();
+	// Simple 'hide' function
+	hide: function(){
+		this.options.hide = true;
+		this.custom(this.cur(), 0);
+	// Each step of an animation
+	step: function(){
+		var t = (new Date()).getTime();
+		if ( t > this.options.duration + this.startTime ) {
+			this.now = this.end;
+			this.pos = this.state = 1;
+			this.update();
+			this.options.curAnim[ this.prop ] = true;
+			var done = true;
+			for ( var i in this.options.curAnim )
+				if ( this.options.curAnim[i] !== true )
+					done = false;
+			if ( done ) {
+				if ( this.options.display != null ) {
+					// Reset the overflow
+					this.elem.style.overflow = this.options.overflow;
+					// Reset the display
+					this.elem.style.display = this.options.display;
+					if ( jQuery.css(this.elem, "display") == "none" )
+				// Hide the element if the "hide" operation was done
+				if ( this.options.hide )
+					this.elem.style.display = "none";
+				// Reset the properties, if the item has been hidden or shown
+				if ( this.options.hide || this.options.show )
+					for ( var p in this.options.curAnim )
+						jQuery.attr(this.elem.style, p, this.options.orig[p]);
+			// If a callback was provided, execute it
+			if ( done && jQuery.isFunction( this.options.complete ) )
+				// Execute the complete function
+				this.options.complete.apply( this.elem );
+			return false;
+		} else {
+			var n = t - this.startTime;
+			this.state = n / this.options.duration;
+			// Perform the easing function, defaults to swing
+			this.pos = jQuery.easing[this.options.easing || (jQuery.easing.swing ? "swing" : "linear")](this.state, n, 0, 1, this.options.duration);
+			this.now = this.start + ((this.end - this.start) * this.pos);
+			// Perform the next step of the animation
+			this.update();
+		return true;
+jQuery.fx.step = {
+	scrollLeft: function(fx){
+		fx.elem.scrollLeft = fx.now;
+	scrollTop: function(fx){
+		fx.elem.scrollTop = fx.now;
+	opacity: function(fx){
+		jQuery.attr(fx.elem.style, "opacity", fx.now);
+	_default: function(fx){
+		fx.elem.style[ fx.prop ] = fx.now + fx.unit;
+// The Offset Method
+// Originally By Brandon Aaron, part of the Dimension Plugin
+// http://jquery.com/plugins/project/dimensions
+jQuery.fn.offset = function() {
+	var left = 0, top = 0, elem = this[0], results;
+	if ( elem ) with ( jQuery.browser ) {
+		var	parent       = elem.parentNode,
+		    offsetChild  = elem,
+		    offsetParent = elem.offsetParent,
+		    doc          = elem.ownerDocument,
+		    safari2      = safari && parseInt(version) < 522,
+		    fixed        = jQuery.css(elem, "position") == "fixed";
+		// Use getBoundingClientRect if available
+		if ( elem.getBoundingClientRect ) {
+			var box = elem.getBoundingClientRect();
+			// Add the document scroll offsets
+			add(
+				box.left + Math.max(doc.documentElement.scrollLeft, doc.body.scrollLeft),
+				box.top  + Math.max(doc.documentElement.scrollTop,  doc.body.scrollTop)
+			// IE adds the HTML element's border, by default it is medium which is 2px
+			// IE 6 and IE 7 quirks mode the border width is overwritable by the following css html { border: 0; }
+			// IE 7 standards mode, the border is always 2px
+			if ( msie ) {
+				var border = jQuery("html").css("borderWidth");
+				border = (border == "medium" || jQuery.boxModel && parseInt(version) >= 7) && 2 || border;
+				add( -border, -border );
+		// Otherwise loop through the offsetParents and parentNodes
+		} else {
+			// Initial element offsets
+			add( elem.offsetLeft, elem.offsetTop );
+			// Get parent offsets
+			while ( offsetParent ) {
+				// Add offsetParent offsets
+				add( offsetParent.offsetLeft, offsetParent.offsetTop );
+				// Mozilla and Safari > 2 does not include the border on offset parents
+				// However Mozilla adds the border for table or table cells
+				if ( mozilla && !/^t(able|d|h)$/i.test(offsetParent.tagName) || safari && !safari2 )
+					border( offsetParent );
+				// Add the document scroll offsets if position is fixed on any offsetParent
+				if ( !fixed && jQuery.css(offsetParent, "position") == "fixed" )
+					fixed = true;
+				// Set offsetChild to previous offsetParent unless it is the body element
+				offsetChild  = /^body$/i.test(offsetParent.tagName) ? offsetChild : offsetParent;
+				// Get next offsetParent
+				offsetParent = offsetParent.offsetParent;
+			// Get parent scroll offsets
+			while ( parent.tagName && !/^body|html$/i.test(parent.tagName) ) {
+				// Remove parent scroll UNLESS that parent is inline or a table-row to work around Opera inline/table scrollLeft/Top bug
+				if ( !/^inline|table-row.*$/i.test(jQuery.css(parent, "display")) )
+					// Subtract parent scroll offsets
+					add( -parent.scrollLeft, -parent.scrollTop );
+				// Mozilla does not add the border for a parent that has overflow != visible
+				if ( mozilla && jQuery.css(parent, "overflow") != "visible" )
+					border( parent );
+				// Get next parent
+				parent = parent.parentNode;
+			// Safari <= 2 doubles body offsets with a fixed position element/offsetParent or absolutely positioned offsetChild
+			// Mozilla doubles body offsets with a non-absolutely positioned offsetChild
+			if ( (safari2 && (fixed || jQuery.css(offsetChild, "position") == "absolute")) ||
+				(mozilla && jQuery.css(offsetChild, "position") != "absoltue") )
+					add( -doc.body.offsetLeft, -doc.body.offsetTop );
+			if ( fixed )
+				add(
+		// Return an object with top and left properties
+		results = { top: top, left: left };
+	return results;
+	function border(elem) {
+		add( jQuery.css(elem, "borderLeftWidth"), jQuery.css(elem, "borderTopWidth") );
+	function add(l, t) {
+		left += parseInt(l) || 0;
+		top += parseInt(t) || 0;
Property changes on: trunk/mapbender/http/extensions/jquery.metadata.2.1/test/jquery.js
___________________________________________________________________
Added: svn:executable
Added: trunk/mapbender/http/extensions/jquery.metadata.2.1/test/test.js
--- trunk/mapbender/http/extensions/jquery.metadata.2.1/test/test.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery.metadata.2.1/test/test.js	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,85 @@
+function testData(index) {
+  var data = jQuery.metadata.get(this);
+  switch(index) {
+  case 0:
+    ok( data.foo == "bar", "Check foo property" );
+    ok( data.bar == "baz", "Check baz property" );
+    ok( data.arr[0] == 1, "Check arr[0] property" );
+    ok( data.arr[1] == 2, "Check arr[1] property" );
+    break;
+  case 1:
+    ok( data.test == "bar", "Check test property" );
+    ok( data.bar == "baz", "Check bar property" );
+    break;
+  case 2:
+    ok( data.zoooo == "bar", "Check zoooo property" );
+    ok( data.bar.test == "baz", "Check bar.test property" );
+    break;
+  case 3:
+    ok( data.number, "Check number property" );
+    ok( data.stuff[0] == 2, "Check stuff[0] property" );
+    ok( data.stuff[1] == 8, "Check stuff[1] property" );
+    break;
+  default:
+    ok( false, ["Assertion failed on index ", index, ", with data ", data].join('') );
+// check if set can be intercepted without breaking metadata plugin
+var oldSet = jQuery.fn.set;
+jQuery.fn.set = function() {
+  ok( true, "set was interecepted" );
+  oldSet.apply(this, arguments);
+//jQuery.meta.single = "";
+test("meta: type attr - from data attribute", function() {
+  expect(11);
+  jQuery.metadata.setType("attr", "data");
+  jQuery("#one li").each(testData);
+test("meta: type class - from className", function() {
+  expect(11);
+  jQuery.metadata.setType( "class" );
+  jQuery("#two li").each(testData);
+test("meta: children script element - get data from child script element", function() {
+  expect(11);
+  jQuery.metadata.setType( "elem", "script" );
+  jQuery("#three li").each(testData);
+test("check if window doesn't break anything", function() {
+  jQuery(window).get();
+test("meta: default with single data object", function() {
+  expect(11);
+  jQuery.metadata.setType("attr","data");
+  jQuery.metadata.defaults.single = "data";
+  jQuery("#four li").each(testData);
+test("meta with select and class", function() {
+  expect(2);
+  jQuery.metadata.setType("class");
+  jQuery.metadata.single = "stuff";
+  var e = $('#meal').metadata();
+  ok( e, "data property" );
+  ok( e.required, "property on data property" );
+test("try to add and remove classes on metadata elements", function() {
+  $("#two li").addClass("foobar").addClass("foo bar").removeClass("foobar");
+  ok( $("#two li").is(".foo"), 'Check class foo was added.' );
+  ok( $("#two li").is(".bar"), 'Check class bar was added.' );
+test("meta: type html5 - from data-*", function() {
+  expect(11);
+  jQuery.metadata.setType("html5");
+  jQuery("#five li").each(testData);
\ No newline at end of file
Property changes on: trunk/mapbender/http/extensions/jquery.metadata.2.1/test/test.js
Added: trunk/mapbender/http/extensions/jquery.metadata.2.1/test/testrunner.js
--- trunk/mapbender/http/extensions/jquery.metadata.2.1/test/testrunner.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery.metadata.2.1/test/testrunner.js	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,299 @@
+var _config = {
+	fixture: null,
+	Test: [],
+	stats: {
+		all: 0,
+		bad: 0
+	queue: [],
+	blocking: true,
+	timeout: null,
+	expected: null,
+	currentModule: null,
+	asyncTimeout: 2 // seconds for async timeout
+$(function() {
+	$('#userAgent').html(navigator.userAgent);
+	runTest();
+function synchronize(callback) {
+	_config.queue[_config.queue.length] = callback;
+	if(!_config.blocking) {
+		process();
+function process() {
+	while(_config.queue.length && !_config.blocking) {
+		var call = _config.queue[0];
+		_config.queue = _config.queue.slice(1);
+		call();
+function stop(allowFailure) {
+	_config.blocking = true;
+	var handler = allowFailure ? start : function() {
+		ok( false, "Test timed out" );
+		start();
+	_config.timeout = setTimeout(handler, _config.asyncTimeout * 1000);
+function start() {
+	if(_config.timeout)
+		clearTimeout(_config.timeout);
+	_config.blocking = false;
+	process();
+function runTest() {
+	var time = new Date();
+	_config.fixture = document.getElementById('main').innerHTML;
+	reset();
+	synchronize(function() {
+		time = new Date() - time;
+		$("<div>").html(['<p class="result">Tests completed in ',
+			time, ' milliseconds.<br/>',
+			_config.stats.bad, ' tests of ', _config.stats.all, ' failed.</p>']
+			.join(''))
+			.appendTo("body");
+		$("#banner").addClass(_config.stats.bad ? "fail" : "pass");
+function test(name, callback, nowait) {
+	if(_config.currentModule)
+		name = _config.currentModule + " module: " + name;
+	var filter = location.search.slice(1);
+	if ( filter && encodeURIComponent(name) != filter )
+		return;
+		_config.Test = [];
+		try {
+			callback();
+		} catch(e) {
+			if( typeof console != "undefined" && console.error && console.warn ) {
+				console.error("Test " + name + " died, exception and test follows");
+				console.error(e);
+				console.warn(callback.toString());
+			_config.Test.push( [ false, "Died on test #" + (_config.Test.length+1) + ": " + e ] );
+			//throw e;
+		reset();
+		// don't output pause tests
+		if(nowait) return;
+		if(_config.expected && _config.expected != _config.Test.length) {
+			_config.Test.push( [ false, "Expected " + _config.expected + " assertions, but " + _config.Test.length + " were run" ] );
+		_config.expected = null;
+		var good = 0, bad = 0;
+		var ol = document.createElement("ol");
+		ol.style.display = "none";
+		var li = "", state = "pass";
+		for ( var i = 0; i < _config.Test.length; i++ ) {
+			var li = document.createElement("li");
+			li.className = _config.Test[i][0] ? "pass" : "fail";
+			li.innerHTML = _config.Test[i][1];
+			ol.appendChild( li );
+			_config.stats.all++;
+			if ( !_config.Test[i][0] ) {
+				state = "fail";
+				bad++;
+				_config.stats.bad++;
+			} else good++;
+		li.className = state;
+		var b = document.createElement("strong");
+		b.innerHTML = name + " <b style='color:black;'>(<b class='fail'>" + bad + "</b>, <b class='pass'>" + good + "</b>, " + _config.Test.length + ")</b>";
+		b.onclick = function(){
+			var n = this.nextSibling;
+			if ( jQuery.css( n, "display" ) == "none" )
+				n.style.display = "block";
+			else
+				n.style.display = "none";
+		$(b).dblclick(function(event) {
+			var target = jQuery(event.target).filter("strong").clone();
+			if ( target.length ) {
+				target.children().remove();
+				location.href = location.href.match(/^(.+?)(\?.*)?$/)[1] + "?" + encodeURIComponent($.trim(target.text()));
+		li.appendChild( b );
+		li.appendChild( ol );
+		document.getElementById("tests").appendChild( li );
+// call on start of module test to prepend name to all tests
+function module(moduleName) {
+	_config.currentModule = moduleName;
+ * Specify the number of expected assertions to gurantee that failed test (no assertions are run at all) don't slip through.
+function expect(asserts) {
+	_config.expected = asserts;
+ * Resets the test setup. Useful for tests that modify the DOM.
+function reset() {
+	document.getElementById('main').innerHTML = _config.fixture;
+ * Asserts true.
+ * @example ok( $("a").size() > 5, "There must be at least 5 anchors" );
+function ok(a, msg) {
+	_config.Test.push( [ !!a, msg ] );
+ * Asserts that two arrays are the same
+function isSet(a, b, msg) {
+	var ret = true;
+	if ( a && b && a.length != undefined && a.length == b.length ) {
+		for ( var i = 0; i < a.length; i++ )
+			if ( a[i] != b[i] )
+				ret = false;
+	} else
+		ret = false;
+	if ( !ret )
+		_config.Test.push( [ ret, msg + " expected: " + serialArray(b) + " result: " + serialArray(a) ] );
+	else
+		_config.Test.push( [ ret, msg ] );
+ * Asserts that two objects are equivalent
+function isObj(a, b, msg) {
+	var ret = true;
+	if ( a && b ) {
+		for ( var i in a )
+				ret = false;
+		for ( i in b )
+				ret = false;
+	} else
+		ret = false;
+function serialArray( a ) {
+	var r = [];
+	if ( a && a.length )
+        for ( var i = 0; i < a.length; i++ ) {
+            var str = a[i].nodeName;
+            if ( str ) {
+                str = str.toLowerCase();
+                if ( a[i].id )
+                    str += "#" + a[i].id;
+            } else
+                str = a[i];
+            r.push( str );
+	return "[ " + r.join(", ") + " ]"
+ * Returns an array of elements with the given IDs, eg.
+ * @example q("main", "foo", "bar")
+ * @result [<div id="main">, <span id="foo">, <input id="bar">]
+function q() {
+	var r = [];
+	for ( var i = 0; i < arguments.length; i++ )
+		r.push( document.getElementById( arguments[i] ) );
+	return r;
+ * Asserts that a select matches the given IDs
+ * @example t("Check for something", "//[a]", ["foo", "baar"]);
+ * @result returns true if "//[a]" return two elements with the IDs 'foo' and 'baar'
+function t(a,b,c) {
+	var f = jQuery(b);
+	var s = "";
+	for ( var i = 0; i < f.length; i++ )
+		s += (s && ",") + '"' + f[i].id + '"';
+	isSet(f, q.apply(q,c), a + " (" + b + ")");
+ * Add random number to url to stop IE from caching
+ * @example url("data/test.html")
+ * @result "data/test.html?10538358428943"
+ * @example url("data/test.php?foo=bar")
+ * @result "data/test.php?foo=bar&10538358345554"
+function url(value) {
+	return value + (/\?/.test(value) ? "&" : "?") + new Date().getTime() + "" + parseInt(Math.random()*100000);
+ * Checks that the first two arguments are equal, with an optional message.
+ * Prints out both expected and actual values on failure.
+ * Prefered to ok( expected == actual, message )
+ * @example equals( "Expected 2 characters.", v.formatMessage("Expected {0} characters.", 2) );
+ * @param Object expected
+ * @param Object actual
+ * @param String message (optional)
+function equals(expected, actual, message) {
+	var result = expected == actual;
+	message = message || (result ? "okay" : "failed");
+	_config.Test.push( [ result, result ? message + ": " + expected : message + " expected: " + expected + " actual: " + actual ] );
+ * Trigger an event on an element.
+ * @example triggerEvent( document.body, "click" );
+ * @param DOMElement elem
+ * @param String type
+function triggerEvent( elem, type, event ) {
+	if ( jQuery.browser.mozilla || jQuery.browser.opera ) {
+		event = document.createEvent("MouseEvents");
+		event.initMouseEvent(type, true, true, elem.ownerDocument.defaultView,
+			0, 0, 0, 0, 0, false, false, false, false, 0, null);
+		elem.dispatchEvent( event );
+	} else if ( jQuery.browser.msie ) {
+		elem.fireEvent("on"+type);
Property changes on: trunk/mapbender/http/extensions/jquery.metadata.2.1/test/testrunner.js
Added: trunk/mapbender/http/extensions/jquery.metadata.2.1/test/testsuite.css
--- trunk/mapbender/http/extensions/jquery.metadata.2.1/test/testsuite.css	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery.metadata.2.1/test/testsuite.css	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,12 @@
+body, div, h1 { font-family: 'trebuchet ms', verdana, arial; margin: 0; padding: 0 }
+body {font-size: 10pt; }
+h1 { padding: 15px; font-size: large; background-color: #06b; color: white; }
+h2 { padding: 10px; background-color: #eee; color: black; margin: 0; font-size: small; font-weight: normal }
+.pass { color: green; }
+.fail { color: red; }
+p.result { margin-left: 1em; }
+#banner { height: 2em; border-bottom: 1px solid white; }
+h2.pass { background-color: green; }
+h2.fail { background-color: red; }
Property changes on: trunk/mapbender/http/extensions/jquery.metadata.2.1/test/testsuite.css
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_html.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_html.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_html.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,82 @@
+<!DOCTYPE html
+PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
+"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
+<html xmlns="http://www.w3.org/1999/xhtml">
+<head>
+	<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
+	<title>jsTree &raquo; Demos</title>
+	<script type="text/javascript" src="../lib/jquery.js"></script>
+	<script type="text/javascript" src="../lib/jquery.cookie.js"></script>
+	<script type="text/javascript" src="../lib/jquery.hotkeys.js"></script>
+	<script type="text/javascript" src="../lib/jquery.metadata.js"></script>
+	<script type="text/javascript" src="../lib/sarissa.js"></script>
+	<script type="text/javascript" src="../jquery.tree.js"></script>
+	<script type="text/javascript" src="../plugins/jquery.tree.checkbox.js"></script>
+	<script type="text/javascript" src="../plugins/jquery.tree.contextmenu.js"></script>
+	<script type="text/javascript" src="../plugins/jquery.tree.cookie.js"></script>
+	<script type="text/javascript" src="../plugins/jquery.tree.hotkeys.js"></script>
+	<script type="text/javascript" src="../plugins/jquery.tree.metadata.js"></script>
+	<script type="text/javascript" src="../plugins/jquery.tree.themeroller.js"></script>
+	<script type="text/javascript" src="../plugins/jquery.tree.xml_flat.js"></script>
+	<script type="text/javascript" src="../plugins/jquery.tree.xml_nested.js"></script>
+	<link type="text/css" rel="stylesheet" href="syntax/shCore.css"/>
+	<link type="text/css" rel="stylesheet" href="syntax/shThemeDefault.css"/>
+	<style type="text/css">
+	html, body { margin:0; padding:0; }
+	body, td, th, pre, code, select, option, input, textarea { font-family:"Trebuchet MS", Sans-serif; font-size:10pt; }
+	#container { width:800px; margin:10px auto; overflow:hidden; }
+	.demo { height:200px; width:300px; float:left; margin:0; border:1px solid gray; font-family:Verdana; font-size:10px; background:white; overflow:auto; }
+	.code { width:490px; float:right; margin:0 0 10px 0; border:1px solid gray; }
+	pre { display:block; }
+	.syntaxhighlighter { margin:0 0 0 0 !important; padding:0 !important; }
+	</style>
+	<script type="text/javascript" src="syntax/shCore.js"></script>
+	<script type="text/javascript" src="syntax/shBrushJScript.js"></script>
+	<script type="text/javascript" src="syntax/shBrushXml.js"></script>
+	<script type="text/javascript">
+		SyntaxHighlighter.config.clipboardSwf = 'syntax/clipboard.swf';
+		$(function () {
+			var h = 0;
+			$("#container .source").each(function () {
+				var code = $(this).html().replace(/</g,'&lt;').replace(/>/g,'&gt;');
+				var div = $('<div class="code"><pre class="brush:' + ( $(this).is("script") ? 'js' : 'xml' ) + ';">' + code + '</pre></div>');
+				$(this).after(div);
+			SyntaxHighlighter.all();
+	</script>
+</head>
+<body>
+<div id="container">
+	<h1 class="title">Async HTML demo</h1>
+	<p>This time all nodes are loaded from an external file. Notice that when you open the closed node nothing happens.</p>
+	<script type="text/javascript" class="source">
+	$(function () {
+		$("#async_html_1").tree({
+			data : {
+				opts : {
+					url : "async_html_data.txt"
+	</script>
+	<div class="demo" id="async_html_1"></div>
+	<p style="clear:both; padding-top:1.385em;">By setting <code>async : true</code> we are telling jsTree to request its data from the server everytime a closed node is opened (unless of course it is already loaded). If you want to modify the data sent to the server with each request take a look at the <a href="../documentation.html#callback.beforedata">beforedata callback</a>.</p>
+	$(function () {
+		$("#async_html_2").tree({
+			data : {
+				async : true,
+				opts : {
+	</script>
+	<div class="demo" id="async_html_2"></div>
+</div></body></html>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_html_data.txt
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_html_data.txt	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_html_data.txt	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,2 @@
+<li class="closed"><a href="#"><ins>&nbsp;</ins>Node 1</a></li>
+<li><a href="#"><ins>&nbsp;</ins>Node 2</a></li>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_json.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_json.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_json.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,86 @@
+<!DOCTYPE html
+<head>
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">Async JSON demo</h1>
+	<p>Same as with the HTML datastore you can load data from a file.</p>
+	$(function () {
+		$("#async_json_1").tree({
+			data : {
+				type : "json",
+				opts : {
+					url : "async_json_data.json"
+	</script>
+	<div class="demo" id="async_json_1"></div>
+	<p style="clear:both; padding-top:1.385em;">But you can also use the <code>async</code> option. If you want to modify the data sent to the server with each request take a look at the <a href="../documentation.html#callback.beforedata">beforedata callback</a>.</p>
+	$(function () {
+		$("#async_json_2").tree({
+			data : {
+				type : "json",
+				async : true,
+				opts : {
+					method : "POST",
+	</script>
+	<div class="demo" id="async_json_2"></div>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_json_data.json
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_json_data.json	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_json_data.json	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,4 @@
+	{ data : "A node", children : [ { data : "Only child" } ], state : "open" },
+	{ data : "Some other node" }
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_xml_flat.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_xml_flat.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_xml_flat.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,76 @@
+<!DOCTYPE html
+<head>
+	input { font-size:14px; }
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">Async XMl flat with languages</h1>
+	<p>This examples shows how to use async XML flat, keep in mind when using async the parent_id attribute of the returned top nodes on each request should be omitted or set to 0.</p>
+	$(function () {
+		$("#xml_f").tree({
+			languages : [ "en", "bg" ],
+			data : {
+				type : "xml_flat",
+				async : true,
+				opts : {
+					url : "async_xml_flat_data.xml"
+	</script>
+	<div class="demo" id="xml_f"></div>
+	<p class="source">
+		<input type="button" onclick='$.tree.focused().set_lang("en");' value="English" />
+		<input type="button" onclick='$.tree.reference("#xml_f").set_lang("bg");' value="Български" />
+	</p>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_xml_flat_data.xml
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_xml_flat_data.xml	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/async_xml_flat_data.xml	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,14 @@
+<root>
+	<item parent_id="0" state="closed">
+		<content>
+			<name lang="en"><![CDATA[Node 1]]></name>
+			<name lang="bg"><![CDATA[Клон 1]]></name>
+		</content>
+	</item>
+	<item parent_id="0">
+		<content>
+			<name lang="en"><![CDATA[Node 2]]></name>
+			<name lang="bg"><![CDATA[Клон 2]]></name>
+		</content>
+	</item>
+</root>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_html.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_html.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_html.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,72 @@
+<!DOCTYPE html
+<head>
+	.demo { height:200px; width:300px; float:left; margin:0; border:1px solid gray; font-family:Verdana; font-size:10px; background:white; }
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">Basic HTML demo</h1>
+	<p>In this simple example nothing is configured - the default tree options are used. Keep in mind that all the nodes in this example are draggable, renameable, etc (they follow the <a href="../documentation.html#configuration">default config</a>, which you can <a href="../documentation.html#tree.defaults">overwrite</a>). In order to disable this have a look at the <a href="../documentation.html#types">types configuration</a> and <a href="../demo/types.html">types demo</a>.</p>
+	$(function () {
+		$("#basic_html").tree();
+	</script>
+	<div class="demo source" id="basic_html">
+		<ul>
+			<li id="phtml_1" class="open"><a href="#"><ins>&nbsp;</ins>Root node 1</a>
+				<ul>
+					<li id="phtml_2"><a href="#"><ins>&nbsp;</ins>Child node 1</a></li>
+					<li id="phtml_3"><a href="#"><ins>&nbsp;</ins>Child node 2</a></li>
+					<li id="phtml_4"><a href="#"><ins>&nbsp;</ins>Some other child node with longer text</a></li>
+				</ul>
+			</li>
+			<li id="phtml_5"><a href="#"><ins>&nbsp;</ins>Root node 2</a></li>
+		</ul>
+	</div>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_json.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_json.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_json.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,112 @@
+<!DOCTYPE html
+<head>
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">Basic JSON demo</h1>
+	<p>The built in JSON datastore lets you define some static data to use to build the tree. Those two examples show a few basics of the <a href="../documentation.html#json">JSON datastore format</a>.</p>
+	$(function () {
+		$("#basic_json_1").tree({
+			data : {
+				type : "json",
+				opts : {
+					static : [
+							// the short format demo
+							data : "A node",
+							// here are the children
+							children : [
+								{ data : "Child node 1" },
+								{ data : "Child node 2" },
+								{ data : "Child node 3" }
+							attributes : { "id" : "li.node.id" },
+							// this is the long data format
+							data : {
+								title : "Long format demo",
+								attributes : { "href" : "http://jstree.com" }
+	</script>
+	<div class="demo" id="basic_json_1"></div>
+	<p style="clear:both; padding-top:1.385em;">You can also force a node in a closed or open state (notice in the previous example, that the node having children is intially closed).</p>
+	$(function () {
+		$("#basic_json_2").tree({
+			data : {
+				type : "json",
+				opts : {
+					static : [
+							// this node will initially be open
+							state : "open"
+						{ data : "Some other node",
+							// this node will appear closed even though it has no children
+							state : "closed"
+	</script>
+	<div class="demo" id="basic_json_2"></div>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_xml_flat.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_xml_flat.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_xml_flat.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,70 @@
+<!DOCTYPE html
+<head>
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">Basic XML flat</h1>
+	<p>This example loads the tree from a XML flat file.</p>
+	$(function () {
+			data : {
+				opts : {
+					url : "basic_xml_flat_data.xml"
+	</script>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_xml_flat_data.xml
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_xml_flat_data.xml	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_xml_flat_data.xml	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,8 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<root>
+	<item parent_id="0" id="xml_1"><content><name><![CDATA[Root node 1]]></name></content></item>
+	<item parent_id="xml_1" id="xml_2"><content><name><![CDATA[Child node 1]]></name></content></item>
+	<item parent_id="xml_1" id="xml_3"><content><name><![CDATA[Child node 2]]></name></content></item>
+	<item parent_id="xml_1" id="xml_4"><content><name><![CDATA[Some other child node]]></name></content></item>
+	<item parent_id="0" id="xml_5"><content><name><![CDATA[Root node 2]]></name></content></item>
+</root>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_xml_nested.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_xml_nested.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_xml_nested.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,70 @@
+<!DOCTYPE html
+<head>
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">Basic XML nested</h1>
+	<p>This example loads the tree from a XML nested file.</p>
+	$(function () {
+		$("#xml_n").tree({
+			data : {
+				type : "xml_nested",
+				opts : {
+					url : "basic_xml_nested_data.xml"
+	</script>
+	<div class="demo" id="xml_n"></div>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_xml_nested_data.xml
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_xml_nested_data.xml	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/basic_xml_nested_data.xml	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,18 @@
+<root>
+	<item id="pxml_1">
+		<content><name><![CDATA[Root node 1]]></name></content>
+		<item id="pxml_2">
+			<content><name><![CDATA[Child node 1]]></name></content>
+		</item>
+		<item id="pxml_3">
+			<content><name><![CDATA[Child node 2]]></name></content>
+		</item>
+		<item id="pxml_4">
+			<content><name><![CDATA[Some other child node]]></name></content>
+		</item>
+	</item>
+	<item id="pxml_5">
+		<content><name ><![CDATA[Root node 2]]></name></content>
+	</item>
+</root>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/callbacks.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/callbacks.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/callbacks.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,93 @@
+<!DOCTYPE html
+<head>
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">Callbacks demo</h1>
+	<p>Please read the <a href="../documentation.html#callback">documentation on callbacks</a> to see all the available callbacks and what parameters you get with each one.</p>
+	$(function () {
+		$.tree.drag_start = function () {
+			$("#log").append("<br />Drag start ");
+		$.tree.drag = function () {
+			$("#log").append(" .");
+		$.tree.drag_end = function () {
+			$("#log").append(" Drag end<br />");
+		$("#demo_1").tree({
+			callback : {
+				onload : function () {
+					$("#log").append("Loaded<br />");
+				onchange : function () {
+					$("#log").append("Focus changed<br />");
+	</script>
+	<div class="demo" id="demo_1">
+		<ul>
+				<ul>
+				</ul>
+			</li>
+		</ul>
+	</div>
+	<div style="clear:both; min-height:300px;" id="log">Log:<br /></div>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/checkbox.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/checkbox.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/checkbox.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,105 @@
+<!DOCTYPE html
+<head>
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">Checkbox demo</h1>
+	<p>This is a basic checkbox plugin demo.</p>
+	$(function () {
+			ui : {
+				theme_name : "checkbox"
+			plugins : {
+				checkbox : { }
+	</script>
+		<ul>
+				<ul>
+				</ul>
+			</li>
+		</ul>
+	</div>
+	<div class="demo" id="demo_2" style="clear:both;">
+		<ul>
+			<li id="phtml_1a" class="open"><a href="#"><ins>&nbsp;</ins>Root node 1</a>
+				<ul>
+					<li id="phtml_2a"><a href="#"><ins>&nbsp;</ins>Child node 1</a></li>
+					<li id="phtml_3a"><a href="#"><ins>&nbsp;</ins>Child node 2</a></li>
+					<li id="phtml_4a"><a href="#"><ins>&nbsp;</ins>Some other child node with longer text</a></li>
+				</ul>
+			</li>
+			<li id="phtml_5a"><a href="#"><ins>&nbsp;</ins>Root node 2</a></li>
+		</ul>
+	</div>
+	$(function () {
+		$("#demo_2").tree({
+			ui : {
+			plugins : {
+				checkbox : { three_state : false }
+	</script>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/context.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/context.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/context.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,120 @@
+<!DOCTYPE html
+<head>
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">Contextmenu demo</h1>
+	$(function () {
+			plugins : {
+				contextmenu : { }
+	</script>
+		<ul>
+				<ul>
+				</ul>
+			</li>
+		</ul>
+	</div>
+		<ul>
+				<ul>
+				</ul>
+			</li>
+		</ul>
+	</div>
+	$(function () {
+			plugins : {
+				contextmenu : {
+					items : {
+						// get rid of the remove item
+						remove : false,
+						// add an item of our own
+						my_act : {
+							label	: "My own action",
+							icon	: "", // you can set this to a classname or a path to an icon like ./myimage.gif
+							visible	: function (NODE, TREE_OBJ) {
+								// this action will be disabled if more than one node is selected
+								if(NODE.length != 1) return 0;
+								// this action will not be in the list if condition is met
+								if(TREE_OBJ.get_text(NODE) == "Child node 1") return -1;
+								// otherwise - OK
+								return 1;
+							action	: function (NODE, TREE_OBJ) {
+								alert(TREE_OBJ.get(NODE, "xml_nested", false));
+							separator_before : true
+	</script>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/cookie.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/cookie.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/cookie.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,77 @@
+<!DOCTYPE html
+<head>
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">Cookie demo</h1>
+	<p>You can see that initially there is no node selected, and the root node is closed. Select a node and/or open the root node and reload the page.</p>
+	$(function () {
+			plugins : {
+				cookie : { prefix : "jstree_" }
+	</script>
+		<ul>
+			<li id="phtml_1"><a href="#"><ins>&nbsp;</ins>Root node 1</a>
+				<ul>
+				</ul>
+			</li>
+		</ul>
+	</div>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/create.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/create.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/create.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,80 @@
+<!DOCTYPE html
+<head>
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">Creating nodes demo</h1>
+	<p>You may also want to read the documentation on <a href="../documentation.html#create">create</a>, <a href="../documentation.html#type.creatable">type creatable setting</a> and <a href="../documentation.html#rules.createat">the createat config option</a>. When passing data (attributes, title) when creating a node - please follow the <a href="../documentation.html#json">JSON datastore format</a>. When creating the <a href="../documentation.html#callback.beforecreate">beforecreate</a> and <a href="../documentation.html#callback.oncreate">oncreate</a> callbacks are triggered.</p>
+	$(function () {
+		$("#demo_1").tree();
+	</script>
+	<p class="source" style="margin-top:10px;">
+		<input type="button" onclick='var t = $.tree.focused(); if(t.selected) t.create(); else alert("Select a node first");' value="Simple Create" />
+		<input type="button" onclick='$.tree.focused().create(false,"#phtml_2");' value="Create in a parent" />
+		<input type="button" onclick='$.tree.focused().create({ data : "Child node 3" }, "#phtml_1", 2);' value="Create with data at a point" />
+		<input type="button" onclick='$.tree.focused().create({ data : "Root node 3" }, -1);' value="Create a root node" />
+	</p>
+		<ul>
+				<ul>
+				</ul>
+			</li>
+		</ul>
+	</div>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/delete.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/delete.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/delete.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,78 @@
+<!DOCTYPE html
+<head>
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">Deleting nodes demo</h1>
+	<p>You may also want to read the documentation on <a href="../documentation.html#remove">remove</a> and <a href="../documentation.html#type.deletable">type deletable setting</a>. When deleting the <a href="../documentation.html#callback.beforedelete">beforedelete</a> and <a href="../documentation.html#callback.ondelete">ondelete</a> callbacks are triggered.</p>
+	$(function () {
+	</script>
+		<input type="button" onclick='$.tree.focused().remove();' value="Simple delete" />
+		<input type="button" onclick='$.tree.focused().remove("#phtml_4");' value="Delete a specific node" />
+	</p>
+		<ul>
+				<ul>
+				</ul>
+			</li>
+		</ul>
+	</div>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/drive.png
(Binary files differ)
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/drive.png
Added: svn:mime-type
   + application/octet-stream
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/file.png
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/file.png
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/index.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/index.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/index.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,52 @@
+<!DOCTYPE html
+<head>
+</head>
+<body>
+<h1 class="title">Datastores</h1>
+<ul class="columns">
+	<li><a href="basic_html.html">Basic HTML</a></li>
+	<li><a href="async_html.html">Async HTML</a></li>
+	<li><a href="basic_json.html">Basic JSON</a></li>
+	<li><a href="async_json.html">Async JSON</a></li>
+	<li><a href="static_async_json.html">Async JSON with static initial content</a></li>
+	<li><a href="json_languages.html">JSON with languages</a></li>
+	<li><a href="basic_xml_flat.html">Basic XML Flat</a></li>
+	<li><a href="xml_flat_from_string.html">XML Flat from string</a></li>
+	<li><a href="async_xml_flat.html">Async XML Flat with languages</a></li>
+	<li><a href="basic_xml_nested.html">Basic XML Nested</a></li>
+</ul>
+<h1>Operations</h1>
+	<li><a href="select.html">Selecting/Deselecting</a></li>
+	<li><a href="open_close.html">Opening/Closing</a></li>
+	<li><a href="create.html">Creating</a></li>
+	<li><a href="rename.html">Renaming</a></li>
+	<li><a href="delete.html">Deleting</a></li>
+	<li><a href="move_copy.html">Moving/Copying</a></li>
+</ul>
+<h1>Others</h1>
+	<li><a href="types.html">Тypes</a></li>
+	<li><a href="callbacks.html">Callbacks</a></li>
+	<li><a href="themes.html">Themes</a></li>
+	<li><a href="rollback.html">Rollback</a></li>
+	<li><a href="search.html">Search</a></li>
+</ul>
+<h1>Plugins</h1>
+	<li><a href="checkbox.html">Checkbox plugin demo</a></li>
+	<li><a href="context.html">Context menu plugin demo</a></li>
+	<li><a href="cookie.html">Cookie plugin demo (saving state)</a></li>
+	<li><a href="keyboard.html">Keyboard navigation plugin demo</a></li>
+	<li><a href="metadata.html">Metadata plugin demo</a></li>
+	<li><a href="themeroller.html">Themeroller plugin demo</a></li>
+</ul>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/json_languages.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/json_languages.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/json_languages.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,99 @@
+<!DOCTYPE html
+<head>
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">JSON with languages</h1>
+	<p>Here is the demo of the long and short JSON format for multilanguage trees. You need to set the <a href="../documentation.html#languages">languages</a> option. In the buttons code, you can see how to get an instance - either by using <a href="../documentation.html#tree.reference">reference</a> and <a href="../documentation.html#tree.focused">focused</a>.</p>
+	$(function () {
+		$("#l_json").tree({
+			data : {
+				type : "json",
+				opts : {
+					static : [
+							data : { "en" : "A node", "bg" : "Нодче" },
+							children : [
+								{ data : { "en" : "Child node 1", "bg" : "Дете 1" } },
+								{ data : { "en" : "Child node 2", "bg" : "Дете 2" } }
+							data : {
+								bg : {
+									title : "удри баце",
+								en : {
+	</script>
+	<div class="demo" id="l_json"></div>
+		<input type="button" onclick='$.tree.reference("#l_json").set_lang("bg");' value="Български" />
+	</p>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/keyboard.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/keyboard.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/keyboard.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,90 @@
+<!DOCTYPE html
+<head>
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">Hotkeys demo</h1>
+	<p>Try pressing up/down/left/right/del. The buttons below enable/disable the hotkeys (useful if you have another component on the page that may use keyboard navigation). You can attach the enable command to the onfocus event if you will - that way if the user clicks anywhere inside the tree container shortcuts will start working.</p>
+	$(function () {
+			// select a node initially so that you can start pounding up/down/left/right right away :)
+			selected : "phtml_1",
+			plugins : {
+				hotkeys : {
+					functions : {
+						// lets add our own
+						"s" : function () {
+							alert($.tree.focused().container.attr("id"));
+	</script>
+		<ul>
+				<ul>
+				</ul>
+			</li>
+		</ul>
+	</div>
+		<input type="button" onclick='$.tree.plugins.hotkeys.disabled = true; this.blur();' value="Disable" />
+		<input type="button" onclick='$.tree.plugins.hotkeys.disabled = false; this.blur();' value="Enable" />
+	</p>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/metadata.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/metadata.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/metadata.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,81 @@
+<!DOCTYPE html
+<head>
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">Metadata plugin demo</h1>
+	<p>You can set any of the <a href="../documentation.html#types">type rules</a> (except for icon which has a separate syntax for every datastore). The data passed is a string - in every datastore you have the option to pass arguments.</p>
+	$(function () {
+			plugins : {
+				metadata : {
+					// the attribute to read from
+					attribute : "data"
+	</script>
+	<div class="demo source" id="demo_1">
+		<ul>
+				<ul>
+					<li id="phtml_3" data="{ clickable : false }"><a href="#"><ins>&nbsp;</ins>Child node 2</a></li>
+				</ul>
+			</li>
+		</ul>
+	</div>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/move_copy.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/move_copy.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/move_copy.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,103 @@
+<!DOCTYPE html
+<head>
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">Moving nodes demo</h1>
+	<p>As you may have noticed, you can drag nodes around. You can influence the ability to drop a node somewhere using the <a href="../documentation.html#type.max_children">type max_children setting</a>, <a href="../documentation.html#type.max_depth">type max_depth setting</a> and <a href="../documentation.html#type.valid_children">type valid_children setting</a>. If you want to disable dragging a node type use the <a href="../documentation.html#type.draggable">type draggable setting</a> (you can event use it on the default node type). When moving the <a href="../documentation.html#callback.beforemove">beforemove</a>, <a href="../documentation.html#callback.onmove">onmove</a>, <a href="../documentation.html#callback.oncopy">oncopy</a>, <a href="../documentation.html#callback.check_move">check_move</a> and <a href="../documentation.html#callback.ondrop">ondrop</a> callbacks are triggered. Also if you assigned a function to them the global <a href="../documentation.html#tree.drag_start">tree.drag_start</a>, <a href="../documentation.html#tree.drag">tree.drag</a>, <a href="../documentation.html#tree.drag_end">tree.drag_end</a> are fired. Ondrop is only fired when dropping foreign items on the tree - for more on that - check the <a href="../documentation.html#tree.drop_mode">tree.drop_mode</a> function.</p>
+	<p>If you want to copy when dragging without holding control or disable copying - read about the <a href="../documentation.html#rules.drag_copy">drag_copy</a> setting.</p>
+	<p>For dragging items from one tree to another - check the <a href="../documentation.html#rules.multitree">multitree</a> setting.</p>
+	<p>To move nodes programatically use the <a href="../documentation.html#copy">copy</a>, <a href="../documentation.html#cut">cut</a> &amp; <a href="../documentation.html#paste">paste</a> functions.</p>
+	$(function () {
+			rules : {
+				// I have not defined any of these so disabling the checks will save CPU cycles
+				use_max_children : false,
+				use_max_depth : false
+			callback : {
+				onmove : function (NODE,REF_NODE,TYPE,TREE_OBJ,RB) {
+					alert(TREE_OBJ.get_text(NODE) + " " + TYPE + " " + TREE_OBJ.get_text(REF_NODE));
+	</script>
+		<ul>
+				<ul>
+				</ul>
+			</li>
+		</ul>
+	</div>
+		<input type="button" onclick='$.tree.focused().cut();' value="Cut" />
+		<input type="button" onclick='$.tree.focused().copy();' value="Copy" />
+		<input type="button" onclick='$.tree.focused().paste();' value="Paste" />
+	</p>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/open_close.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/open_close.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/open_close.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,96 @@
+<!DOCTYPE html
+<head>
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">Opening and closing nodes demo</h1>
+	<p>You may also want to read the documentation on <a href="../documentation.html#open_branch">open_branch</a>, <a href="../documentation.html#close_branch">close_branch</a>, <a href="../documentation.html#open_all">open_all</a> and <a href="../documentation.html#close_all">close_all</a>. To initially open some nodes when the tree loads - take a look at the <a href="../documentation.html#opened">opened config option</a>. When opening/closing the <a href="../documentation.html#callback.beforeopen">beforeopen</a>, <a href="../documentation.html#callback.beforeclose">beforeclose</a>, <a href="../documentation.html#callback.onopen">onopen</a>, <a href="../documentation.html#callback.onclose">onclose</a>, <a href="../documentation.html#callback.onopen_all">onopen_all</a> and <a href="../documentation.html#callback.onclose_all">onclose_all</a>  callbacks are triggered.</p>
+	$(function () {
+	</script>
+		<input type="button" onclick='$.tree.focused().open_branch("#phtml_1");' value="Open" />
+		<input type="button" onclick='$.tree.focused().close_branch("#phtml_1");' value="Close" />
+		<input type="button" onclick='$.tree.focused().toggle_branch("#phtml_1");' value="Toggle" />
+		<input type="button" onclick='$.tree.focused().open_all("#phtml_1");' value="Open all children" />
+		<input type="button" onclick='$.tree.focused().close_all("#phtml_1");' value="Close all children" />
+	</p>
+		<ul>
+				<ul>
+						<ul>
+							<li><a href="#"><ins>&nbsp;</ins>Child node 1.1</a></li>
+							<li><a href="#"><ins>&nbsp;</ins>Child node 1.2</a></li>
+						</ul>
+					</li>
+						<ul>
+							<li><a href="#"><ins>&nbsp;</ins>Child node 2.1</a></li>
+							<li><a href="#"><ins>&nbsp;</ins>Child node 2.2</a></li>
+						</ul>
+					</li>
+				</ul>
+			</li>
+				<ul>
+					<li><a href="#"><ins>&nbsp;</ins>Child node</a></li>
+				</ul>
+			</li>
+		</ul>
+	</div>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/rename.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/rename.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/rename.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,84 @@
+<!DOCTYPE html
+<head>
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">Renaming nodes demo</h1>
+	<p>You may also want to read the documentation on <a href="../documentation.html#rename">rename</a> and <a href="../documentation.html#type.renameable">type renameable setting</a>. When renaming the <a href="../documentation.html#callback.beforerename">beforerename</a> and <a href="../documentation.html#callback.onrename">onrename</a> callbacks are triggered.</p>
+	$(function () {
+			callback : {
+				onrename : function (NODE, TREE_OBJ) {
+					alert(TREE_OBJ.get_text(NODE));
+	</script>
+		<input type="button" onclick='$.tree.focused().rename();' value="Simple rename" />
+		<input type="button" onclick='$.tree.focused().rename("#phtml_4","Child node 3");' value="Rename a specific node to a specific title" />
+	</p>
+		<ul>
+				<ul>
+				</ul>
+			</li>
+		</ul>
+	</div>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/rollback.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/rollback.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/rollback.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,91 @@
+<!DOCTYPE html
+<head>
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">Rollback demo</h1>
+	<p>All the callbacks that are fired after tree is modified in some way offer you a rollback object that you can use with <a href="../documentation.html#tree.rollback">the rollback function</a>.</p>
+	$(function () {
+			callback : {
+				onrename : function (n,t,r) {
+					if(confirm("Do you want to rollback?")) {
+						$.tree.rollback(r);
+				ondelete : function (n,t,r) {
+	</script>
+		<ul>
+				<ul>
+				</ul>
+			</li>
+		</ul>
+	</div>
+		<input type="button" onclick="$.tree.focused().rename()" value="Rename" />
+		<input type="button" onclick="$.tree.focused().remove()" value="Delete" />
+	</p>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/search.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/search.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/search.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,88 @@
+<!DOCTYPE html
+<head>
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">Search demo</h1>
+	<p>If you decide to go with async - when searching a request to the server is made with the query string. The expected return value would be the ID of the nodes that need to be opened, so that the matching node is loaded. Also take a look at <a href="../documentation.html#search">the search function second parameter</a> for case-insensitive searching.</p>
+	<style type="text/css" class="source">
+	a.search { color:green !important; }
+	</style>
+	$(function () {
+			callback : {
+				onsearch : function (n,t) {
+					t.container.find('.search').removeClass('search');
+					n.addClass('search');
+	</script>
+		<ul>
+				<ul>
+				</ul>
+			</li>
+		</ul>
+	</div>
+		<input type="text" value="Child" />
+		<input type="button" onclick="$.tree.focused().search($(this).prev().val())" value="Search" />
+	</p>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/select.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/select.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/select.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,78 @@
+<!DOCTYPE html
+<head>
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">Selecting nodes demo</h1>
+	<p>You may also want to read the documentation on <a href="../documentation.html#select_branch">select_branch</a>, <a href="../documentation.html#deselect_branch">deselect_branch</a> and <a href="../documentation.html#type.clickable">type clickable setting</a>. To initially select some nodes when the tree loads - take a look at the <a href="../documentation.html#config.selected">selected config option</a>. When selecting/deselecting the <a href="../documentation.html#callback.beforechange">beforechange</a>, <a href="../documentation.html#callback.onchange">onchange</a>, <a href="../documentation.html#callback.onselect">onselect</a> and <a href="../documentation.html#callback.ondeselect">ondeselect</a> callbacks are triggered.</p>
+	$(function () {
+	</script>
+		<input type="button" onclick='$.tree.focused().select_branch("#phtml_2");' value="Select" />
+		<input type="button" onclick='$.tree.focused().deselect_branch("#phtml_2");' value="Deselect" />
+	</p>
+		<ul>
+				<ul>
+				</ul>
+			</li>
+		</ul>
+	</div>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/static_async_json.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/static_async_json.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/static_async_json.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,88 @@
+<!DOCTYPE html
+<head>
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">Static &amp; Async mixing JSON demo</h1>
+	<p>This is a simple example - you could enhance it not to pollute the global namespace.</p>
+	var stat =	[
+		{ attributes : { "id" : "node_1" }, data : "Node 1" },
+		{ attributes : { "id" : "node_2" }, data : "Node 2", state : "closed"},
+		{ attributes : { "id" : "node_3" }, data : "Node 3" }
+	$(function () {
+		$("#sa_json_1").tree({
+			data : {
+				type : "json",
+				async : true,
+				opts : {
+					async : true,
+					method : "POST",
+			callback : {
+				// Make sure static is not used once the tree has loaded for the first time
+				onload : function (t) {
+					t.settings.data.opts.static = false;
+				// Take care of refresh calls - n will be false only when the whole tree is refreshed or loaded of the first time
+				beforedata : function (n, t) {
+					if(n == false) t.settings.data.opts.static = stat;
+	</script>
+	<div class="demo" id="sa_json_1"></div>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/clipboard.swf
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/clipboard.swf
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/help.png
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/help.png
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/magnifier.png
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/magnifier.png
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/page_white_code.png
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/page_white_code.png
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/page_white_copy.png
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/page_white_copy.png
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/printer.png
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/printer.png
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shBrushJScript.js
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shBrushJScript.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shBrushJScript.js	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,52 @@
+ * SyntaxHighlighter
+ * http://alexgorbatchev.com/
+ * SyntaxHighlighter is donationware. If you are using it, please donate.
+ * http://alexgorbatchev.com/wiki/SyntaxHighlighter:Donate
+ * @version
+ * 2.0.320 (May 03 2009)
+ * @copyright
+ * Copyright (C) 2004-2009 Alex Gorbatchev.
+ * @license
+ * This file is part of SyntaxHighlighter.
+ * SyntaxHighlighter is free software: you can redistribute it and/or modify
+ * it under the terms of the GNU Lesser General Public License as published by
+ * the Free Software Foundation, either version 3 of the License, or
+ * (at your option) any later version.
+ * SyntaxHighlighter is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with SyntaxHighlighter.  If not, see <http://www.gnu.org/copyleft/lesser.html>.
+SyntaxHighlighter.brushes.JScript = function()
+	var keywords =	'break case catch continue ' +
+					'default delete do else false  ' +
+					'for function if in instanceof ' +
+					'new null return super switch ' +
+					'this throw true try typeof var while with'
+	this.regexList = [
+		{ regex: SyntaxHighlighter.regexLib.singleLineCComments,	css: 'comments' },			// one line comments
+		{ regex: SyntaxHighlighter.regexLib.multiLineCComments,		css: 'comments' },			// multiline comments
+		{ regex: SyntaxHighlighter.regexLib.doubleQuotedString,		css: 'string' },			// double quoted strings
+		{ regex: SyntaxHighlighter.regexLib.singleQuotedString,		css: 'string' },			// single quoted strings
+		{ regex: /\s*#.*/gm,										css: 'preprocessor' },		// preprocessor tags like #region and #endregion
+		{ regex: new RegExp(this.getKeywords(keywords), 'gm'),		css: 'keyword' }			// keywords
+	this.forHtmlScript(SyntaxHighlighter.regexLib.scriptScriptTags);
+SyntaxHighlighter.brushes.JScript.prototype	= new SyntaxHighlighter.Highlighter();
+SyntaxHighlighter.brushes.JScript.aliases	= ['js', 'jscript', 'javascript'];
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shBrushPhp.js
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shBrushPhp.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shBrushPhp.js	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,91 @@
+ * @version
+ * @copyright
+ * @license
+SyntaxHighlighter.brushes.Php = function()
+	var funcs	=	'abs acos acosh addcslashes addslashes ' +
+					'array_change_key_case array_chunk array_combine array_count_values array_diff '+
+					'array_diff_assoc array_diff_key array_diff_uassoc array_diff_ukey array_fill '+
+					'array_filter array_flip array_intersect array_intersect_assoc array_intersect_key '+
+					'array_intersect_uassoc array_intersect_ukey array_key_exists array_keys array_map '+
+					'array_merge array_merge_recursive array_multisort array_pad array_pop array_product '+
+					'array_push array_rand array_reduce array_reverse array_search array_shift '+
+					'array_slice array_splice array_sum array_udiff array_udiff_assoc '+
+					'array_udiff_uassoc array_uintersect array_uintersect_assoc '+
+					'array_uintersect_uassoc array_unique array_unshift array_values array_walk '+
+					'array_walk_recursive atan atan2 atanh base64_decode base64_encode base_convert '+
+					'basename bcadd bccomp bcdiv bcmod bcmul bindec bindtextdomain bzclose bzcompress '+
+					'bzdecompress bzerrno bzerror bzerrstr bzflush bzopen bzread bzwrite ceil chdir '+
+					'checkdate checkdnsrr chgrp chmod chop chown chr chroot chunk_split class_exists '+
+					'closedir closelog copy cos cosh count count_chars date decbin dechex decoct '+
+					'deg2rad delete ebcdic2ascii echo empty end ereg ereg_replace eregi eregi_replace error_log '+
+					'error_reporting escapeshellarg escapeshellcmd eval exec exit exp explode extension_loaded '+
+					'feof fflush fgetc fgetcsv fgets fgetss file_exists file_get_contents file_put_contents '+
+					'fileatime filectime filegroup fileinode filemtime fileowner fileperms filesize filetype '+
+					'floatval flock floor flush fmod fnmatch fopen fpassthru fprintf fputcsv fputs fread fscanf '+
+					'fseek fsockopen fstat ftell ftok getallheaders getcwd getdate getenv gethostbyaddr gethostbyname '+
+					'gethostbynamel getimagesize getlastmod getmxrr getmygid getmyinode getmypid getmyuid getopt '+
+					'getprotobyname getprotobynumber getrandmax getrusage getservbyname getservbyport gettext '+
+					'gettimeofday gettype glob gmdate gmmktime ini_alter ini_get ini_get_all ini_restore ini_set '+
+					'interface_exists intval ip2long is_a is_array is_bool is_callable is_dir is_double '+
+					'is_executable is_file is_finite is_float is_infinite is_int is_integer is_link is_long '+
+					'is_nan is_null is_numeric is_object is_readable is_real is_resource is_scalar is_soap_fault '+
+					'is_string is_subclass_of is_uploaded_file is_writable is_writeable mkdir mktime nl2br '+
+					'parse_ini_file parse_str parse_url passthru pathinfo readlink realpath rewind rewinddir rmdir '+
+					'round str_ireplace str_pad str_repeat str_replace str_rot13 str_shuffle str_split '+
+					'str_word_count strcasecmp strchr strcmp strcoll strcspn strftime strip_tags stripcslashes '+
+					'stripos stripslashes stristr strlen strnatcasecmp strnatcmp strncasecmp strncmp strpbrk '+
+					'strpos strptime strrchr strrev strripos strrpos strspn strstr strtok strtolower strtotime '+
+					'strtoupper strtr strval substr substr_compare';
+	var keywords =	'and or xor array as break case ' +
+					'cfunction class const continue declare default die do else ' +
+					'elseif enddeclare endfor endforeach endif endswitch endwhile ' +
+					'extends for foreach function include include_once global if ' +
+					'new old_function return static switch use require require_once ' +
+					'var while abstract interface public implements extends private protected throw';
+	var constants	= '__FILE__ __LINE__ __METHOD__ __FUNCTION__ __CLASS__';
+		{ regex: /\$\w+/g,											css: 'variable' },			// variables
+		{ regex: new RegExp(this.getKeywords(funcs), 'gmi'),		css: 'functions' },			// common functions
+		{ regex: new RegExp(this.getKeywords(constants), 'gmi'),	css: 'constants' },			// constants
+	this.forHtmlScript(SyntaxHighlighter.regexLib.phpScriptTags);
+SyntaxHighlighter.brushes.Php.prototype	= new SyntaxHighlighter.Highlighter();
+SyntaxHighlighter.brushes.Php.aliases	= ['php'];
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shBrushXml.js
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shBrushXml.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shBrushXml.js	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,71 @@
+ * @version
+ * @copyright
+ * @license
+SyntaxHighlighter.brushes.Xml = function()
+	function process(match, regexInfo)
+		var constructor = SyntaxHighlighter.Match,
+			code = match[0],
+			tag = new XRegExp('(&lt;|<)[\\s\\/\\?]*(?<name>[:\\w-\\.]+)', 'xg').exec(code),
+			result = []
+		if (match.attributes != null)
+			var attributes,
+				regex = new XRegExp('(?<name> [\\w:\\-\\.]+)' +
+									'\\s*=\\s*' +
+									'(?<value> ".*?"|\'.*?\'|\\w+)',
+									'xg');
+			while ((attributes = regex.exec(code)) != null)
+				result.push(new constructor(attributes.name, match.index + attributes.index, 'color1'));
+				result.push(new constructor(attributes.value, match.index + attributes.index + attributes[0].indexOf(attributes.value), 'string'));
+		if (tag != null)
+			result.push(
+				new constructor(tag.name, match.index + tag[0].indexOf(tag.name), 'keyword')
+		return result;
+		{ regex: new XRegExp('(\\&lt;|<)\\!\\[[\\w\\s]*?\\[(.|\\s)*?\\]\\](\\&gt;|>)', 'gm'),			css: 'color2' },	// <![ ... [ ... ]]>
+		{ regex: new XRegExp('(\\&lt;|<)!--\\s*.*?\\s*--(\\&gt;|>)', 'gm'),								css: 'comments' },	// <!-- ... -->
+		{ regex: new XRegExp('(&lt;|<)[\\s\\/\\?]*(\\w+)(?<attributes>.*?)[\\s\\/\\?]*(&gt;|>)', 'sg'), func: process }
+SyntaxHighlighter.brushes.Xml.prototype	= new SyntaxHighlighter.Highlighter();
+SyntaxHighlighter.brushes.Xml.aliases	= ['xml', 'xhtml', 'xslt', 'html', 'xhtml'];
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shCore.css
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shCore.css	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shCore.css	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,342 @@
+ * @version
+ * @copyright
+ * @license
+.syntaxhighlighter,
+.syntaxhighlighter div,
+.syntaxhighlighter code,
+.syntaxhighlighter span
+	margin: 0 !important;
+	padding: 0 !important;
+	border: 0 !important;
+	outline: 0 !important;
+	background: none !important;
+	text-align: left !important;
+	float: none !important;
+	vertical-align: baseline !important;
+	position: static !important;
+	left: auto !important;
+	top: auto !important;
+	right: auto !important;
+	bottom: auto !important;
+	height: auto !important;
+	width: auto !important;
+	line-height: 1.1em !important;
+	font-family: "Consolas", "Monaco", "Bitstream Vera Sans Mono", "Courier New", Courier, monospace !important;
+	font-weight: normal !important;
+	font-style: normal !important;
+	font-size: 1em !important;
+.syntaxhighlighter
+	width: 100% !important;
+	margin: 1em 0 1em 0 !important;
+	padding: 1px !important; /* adds a little border on top and bottom */
+	position: relative !important;
+.syntaxhighlighter code {
+	display: inline !important;
+.syntaxhighlighter .bold {
+	font-weight: bold !important;
+.syntaxhighlighter .italic {
+	font-style: italic !important;
+.syntaxhighlighter .line .number
+	float: left !important;
+	width: 3em !important;
+	padding-right: .3em !important;
+	text-align: right !important;
+	display: block !important;
+/* Disable numbers when no gutter option is set */
+.syntaxhighlighter.nogutter .line .number
+	display: none !important;
+.syntaxhighlighter .line .content
+	margin-left: 3.3em !important;
+	padding-left: .5em !important;
+.syntaxhighlighter .line .content .block
+	padding-left: 1.5em !important;
+	text-indent: -1.5em !important;
+.syntaxhighlighter .line .content .spaces
+/* Disable border and margin on the lines when no gutter option is set */
+.syntaxhighlighter.nogutter .line .content
+	margin-left: 0 !important;
+	border-left: none !important;
+.syntaxhighlighter .bar
+.syntaxhighlighter .bar.show
+.syntaxhighlighter.collapsed .bar
+.syntaxhighlighter.nogutter .ruler
+	padding-left: 0 !important;
+.syntaxhighlighter .ruler
+	padding: 0 0 .5em .5em !important;
+	overflow: hidden !important;
+/* Adjust some properties when collapsed */
+.syntaxhighlighter.collapsed .lines,
+.syntaxhighlighter.collapsed .ruler
+.syntaxhighlighter .lines.no-wrap
+	overflow: auto;
+	overflow-y: hidden;
+/* Styles for the toolbar */
+.syntaxhighlighter .toolbar
+	position: absolute !important;
+	right: 0px !important;
+	top: 0px !important;
+	font-size: 1px !important;
+	padding: 8px 8px 8px 0 !important; /* in px because images don't scale with ems */
+.syntaxhighlighter.collapsed .toolbar
+	font-size: 80% !important;
+	padding: .2em 0 .5em .5em !important;
+.syntaxhighlighter .toolbar a.item,
+.syntaxhighlighter .toolbar .item
+	margin-left: 8px !important;
+	background-repeat: no-repeat !important;
+	text-indent: -5000px !important;
+.syntaxhighlighter.collapsed .toolbar .item
+.syntaxhighlighter.collapsed .toolbar .item.expandSource
+	background-image: url(magnifier.png) !important;
+	text-indent: 0 !important;
+	height: 16px !important;
+	padding-left: 20px !important;
+.syntaxhighlighter .toolbar .item.viewSource
+	background-image: url(page_white_code.png) !important;
+.syntaxhighlighter .toolbar .item.printSource
+	background-image: url(printer.png) !important;
+.syntaxhighlighter .toolbar .item.copyToClipboard
+	overflow: visible !important;
+.syntaxhighlighter .toolbar .item.about
+	background-image: url(help.png) !important;
+ * Print view.
+ * Colors are based on the default theme without background.
+.syntaxhighlighter.printing,
+.syntaxhighlighter.printing .line.alt1 .content,
+.syntaxhighlighter.printing .line.alt2 .content,
+.syntaxhighlighter.printing .line.highlighted .number,
+.syntaxhighlighter.printing .line.highlighted.alt1 .content,
+.syntaxhighlighter.printing .line.highlighted.alt2 .content,
+.syntaxhighlighter.printing .line .content .block
+.syntaxhighlighter .no-wrap .line .content .block
+	white-space: nowrap !important;
+/* Gutter line numbers */
+.syntaxhighlighter.printing .line .number
+	color: #bbb !important;
+/* Add border to the lines */
+	color: #000 !important;
+/* Toolbar when visible */
+.syntaxhighlighter.printing .toolbar,
+.syntaxhighlighter.printing .ruler
+.syntaxhighlighter.printing a
+	text-decoration: none !important;
+.syntaxhighlighter.printing .plain,
+.syntaxhighlighter.printing .plain a
+.syntaxhighlighter.printing .comments,
+.syntaxhighlighter.printing .comments a
+	color: #008200 !important;
+.syntaxhighlighter.printing .string,
+.syntaxhighlighter.printing .string a
+	color: blue !important;
+.syntaxhighlighter.printing .keyword
+	color: #069 !important;
+.syntaxhighlighter.printing .preprocessor
+	color: gray !important;
+.syntaxhighlighter.printing .variable
+	color: #a70 !important;
+.syntaxhighlighter.printing .value
+	color: #090 !important;
+.syntaxhighlighter.printing .functions
+	color: #ff1493 !important;
+.syntaxhighlighter.printing .constants
+	color: #0066CC !important;
+.syntaxhighlighter.printing .script
+.syntaxhighlighter.printing .color1,
+.syntaxhighlighter.printing .color1 a
+	color: #808080 !important;
+.syntaxhighlighter.printing .color2,
+.syntaxhighlighter.printing .color2 a
+.syntaxhighlighter.printing .color3,
+.syntaxhighlighter.printing .color3 a
+	color: red !important;
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shCore.js
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shCore.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shCore.js	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,30 @@
+ * @version
+ * @copyright
+ * @license
+eval(function(p,a,c,k,e,d){e=function(c){return(c<a?'':e(parseInt(c/a)))+((c=c%a)>35?String.fromCharCode(c+29):c.toString(36))};if(!''.replace(/^/,String)){while(c--){d[e(c)]=k[c]||e(c)}k=[function(e){return d[e]}];e=function(){return'\\w+'};c=1};while(c--){if(k[c]){p=p.replace(new RegExp('\\b'+e(c)+'\\b','g'),k[c])}}return p}('f(!1q.2E){l 2E=h(){l p={77:{"1e-1f":"","79-2P":1,"1I":u,"6V-70":U,"1C-2A":4,"5f":N,"4Z":U,"1z":U,"56":N,"7G-7F":U,"6Z":N,"4S-1m":U},M:{52:u,5P:16,5S:16,8k:N,8l:N,83:"4R",1k:{3Y:"97 1c",41:"9b 1c",5U:"9O 93 7A",6t:"9B I 9E 23 8w 7A 8o",34:"34",6P:"?",1v:"2E\\n\\n",6F:"8p\'t 8I 87 D: ",7X:"8V 8v\'t bD D 2u-2c bf: ",6H:"<!be 2u aV \\"-//9V//6U bz 1.0 bx//bI\\" \\"2g://6D.6v.6m/bi/7c/6U/7c-a4.aw\\"><2u ay=\\"2g://6D.6v.6m/as/8r\\"><6l><8T 2g-92=\\"8P-8L\\" 5B=\\"2d/2u; 8E=8s-8\\" /><3B>8C 2E</3B></6l><2L 1n=\\"3N-8x:8Z,9y,9H,9I-9Q;9S-4v:#9K;4v:#9J;3N-2A:9L;2d-6k:6i;\\"><A 1n=\\"2d-6k:6i;5D-43:99;\\"><A 1n=\\"3N-2A:9p-9o;\\">2E</A><A 1n=\\"3N-2A:.9m;5D-9l:9k;\\"><A>6f 2.0.9j (9n 9s 6n)</A><A><a 2q=\\"2g://6j.4U\\" 9r=\\"57\\" 1n=\\"4v:#9h;2d-9g:98;\\">2g://6j.4U</a></A></A><A>96 I 94 95.</A><A>9f 9e-6n 9c 9t.</A></A></2L></2u>"},6T:N},1t:{4D:u,3k:u,3P:u,5K:{}},2B:{},85:{9u:/\\/\\*[\\s\\S]*?\\*\\//4k,9N:/\\/\\/.*$/4k,9M:/#.*$/4k,9P:/"(?:\\.|(\\\\\\")|[^\\""\\n])*"/g,9T:/\'(?:\\.|(\\\\\\\')|[^\\\'\'\\n])*\'/g,9R:/"(?:\\.|(\\\\\\")|[^\\""])*"/g,9z:/\'(?:\\.|(\\\\\\\')|[^\\\'\'])*\'/g,3p:/\\w+:\\/\\/[\\w-.\\/?%&=]*/g,9x:{E:/(&1F;|<)\\?=?/g,13:/\\?(&2o;|>)/g},9v:{E:/(&1F;|<)%=?/g,13:/%(&2o;|>)/g},9w:{E:/(&1F;|<)\\s*2c.*?(&2o;|>)/4x,13:/(&1F;|<)\\/\\s*2c\\s*(&2o;|>)/4x}},1z:{12:h(3s){l 3y=L.1s("3j"),4o=p.1z.65;3y.J="1z";D(l 2Y 23 4o){l 6o=4o[2Y],4J=T 6o(3s),28=4J.12();3s.5I[2Y]=4J;f(28==u){1H}f(9G(28)=="9F"){28=p.1z.6s(28,3s.1g,2Y)}28.J+="5k "+2Y;3y.1G(28)}q 3y},6s:h(4A,6r,4h){l a=L.1s("a"),4Q=a.1n,4P=p.M,4F=4P.5P,48=4P.5S;a.2q="#"+4h;a.3B=4A;a.5M=6r;a.6q=4h;a.1x=4A;f(55(4F)==N){4Q.1S=4F+"5x"}f(55(48)==N){4Q.2t=48+"5x"}a.8t=h(e){8D{p.1z.6p(c,e||1q.6w,c.5M,c.6q)}8m(e){p.B.1v(e.6u)}q N};q a},6p:h(69,68,6h,6g,67){l 3U=p.1t.5K[6h],3X;f(3U==u||(3X=3U.5I[6g])==u){q u}q 3X.2h(69,68,67)},65:{3Y:h(4b){c.12=h(){f(4b.V("56")!=U){q}q p.M.1k.3Y};c.2h=h(42,8X,91){l A=4b.A;42.7T.5a(42);A.J=A.J.C("51","")}},41:h(66){c.12=h(){q p.M.1k.41};c.2h=h(8R,8Q,8J){l 3Q=p.B.3G(66.4W).C(/</g,"&1F;"),2i=p.B.54("","57",8H,8G,"8K=0, 8O=1, 8N=0, 6O=1");3Q=p.B.2D(3Q);2i.L.3h("<4R>"+3Q+"</4R>");2i.L.5O()}},5U:h(5e){l 3S,8F,5L=5e.1g;c.12=h(){l 2S=p.M;f(2S.52==u){q u}h 1A(5E){l 5s="";D(l 5y 23 5E){5s+="<8S 1f=\'"+5y+"\' 1U=\'"+5E[5y]+"\'/>"}q 5s};h 2v(5t){l 5Q="";D(l 5w 23 5t){5Q+=" "+5w+"=\'"+5t[5w]+"\'"}q 5Q};l 5m={1S:2S.5P,2t:2S.5S,1g:5L+"b8",6N:"b7/x-6a-6b",3B:p.M.1k.5U},5h={b6:"b4",b5:"b9",ba:"5M="+5L,bd:"N"},5g=2S.52,3H;f(/bb/i.1R(5Z.5W)){3H="<6e"+2v({bc:"b3:b2-aU-aT-aS-aQ",aR:"2g://aW.b1.4U/b0/6a/aX/6b/bg.bh#6f=9,0,0,0"})+2v(5m)+">"+1A(5h)+1A({bB:5g})+"</6e>"}F{3H="<bA"+2v(5m)+2v(5h)+2v({bC:5g})+"/>"}3S=L.1s("A");3S.1x=3H;q 3S};c.2h=h(bH,bG,5T){l 6d=5T.bE;6z(6d){2N"7u":l 53=p.B.2D(p.B.3G(5e.4W).C(/&1F;/g,"<").C(/&2o;/g,">").C(/&bw;/g,"&"));f(1q.6c){1q.6c.bm("2d",53)}F{q p.B.2D(53)}2N"bk":p.B.1v(p.M.1k.6t);2m;2N"bj":p.B.1v(5T.6u);2m}}},bo:h(58){c.12=h(){q p.M.1k.34};c.2h=h(bu,bt,bs){l 1W=L.1s("bp"),1O=u;f(p.1t.3P!=u){L.2L.5a(p.1t.3P)}p.1t.3P=1W;1W.1n.bq="aP:aO;1S:6L;2t:6L;E:-6K;43:-6K;";L.2L.1G(1W);1O=1W.5c.L;6J(1O,1q.L);1O.3h("<A 1e=\\""+58.A.J.C("51","")+" ae\\">"+58.A.1x+"</A>");1O.5O();1W.5c.4d();1W.5c.34();h 6J(6M,64){l 2F=64.82("4Y");D(l i=0;i<2F.v;i++){f(2F[i].6R.ac()=="6Q"&&/aa\\.19$/.1R(2F[i].2q)){6M.3h("<4Y 6N=\\"2d/19\\" 6R=\\"6Q\\" 2q=\\""+2F[i].2q+"\\"></4Y>")}}}}},af:h(ag){c.12=h(){q p.M.1k.6P};c.2h=h(aj,ah){l 2i=p.B.54("","57",ai,a9,"6O=0"),1O=2i.L;1O.3h(p.M.1k.6H);1O.5O();2i.4d()}}}},B:{5H:h(6G){q 6G+3J.9Y(3J.9W()*9X).2r()},5o:h(5R,5G){l 3m={},1T;D(1T 23 5R){3m[1T]=5R[1T]}D(1T 23 5G){3m[1T]=5G[1T]}q 3m},8d:h(5z){6z(5z){2N"U":q U;2N"N":q N}q 5z},54:h(3p,6x,44,4c,2J){l x=(6y.1S-44)/2,y=(6y.2t-4c)/2;2J+=", E="+x+", 43="+y+", 1S="+44+", 2t="+4c;2J=2J.C(/^,/,"");l 49=1q.a5(3p,6x,2J);49.4d();q 49},7Q:h(1M,25,24){f(1M.6A){1M["e"+25+24]=24;1M[25+24]=h(){1M["e"+25+24](1q.6w)};1M.6A("an"+25,1M[25+24])}F{1M.aG(25,24,N)}},1v:h(z){1v(p.M.1k.1v+z)},4l:h(4M,6B){l 2k=p.1t.4D,3b=u;f(2k==u){2k={};D(l 4G 23 p.2B){l 37=p.2B[4G].aF;f(37==u){1H}D(l i=0;i<37.v;i++){2k[37[i]]=4G}}p.1t.4D=2k}3b=p.2B[2k[4M]];f(3b==u&&6B!=N){p.B.1v(p.M.1k.6F+4M)}q 3b},4n:h(z,6E){l 2U=z.1P("\\n");D(l i=0;i<2U.v;i++){2U[i]=6E(2U[i])}q 2U.5u("\\n")},74:h(){l A=L.1s("A"),3e=L.1s("A"),6C=10,i=1;29(i<=aD){f(i%6C===0){A.1x+=i;i+=(i+"").v}F{A.1x+="&aI;";i++}}3e.J="5f 2P";3e.1G(A);q 3e},6W:h(z){q z.C(/^[ ]*[\\n]+|[\\n]*[ ]*$/g,"")},84:h(z){l 3d,4u={},4p=T R("^\\\\[(?<4q>(.*?))\\\\]$"),6S=T R("(?<1f>[\\\\w-]+)"+"\\\\s*:\\\\s*"+"(?<1U>"+"[\\\\w-%#]+|"+"\\\\[.*?\\\\]|"+"\\".*?\\"|"+"\'.*?\'"+")\\\\s*;?","g");29((3d=6S.Q(z))!=u){l 2f=3d.1U.C(/^[\'"]|[\'"]$/g,"");f(2f!=u&&4p.1R(2f)){l m=4p.Q(2f);2f=m.4q.v>0?m.4q.1P(/\\s*,\\s*/):[]}4u[3d.1f]=2f}q 4u},7g:h(z,19){f(z==u||z.v==0||z=="\\n"){q z}z=z.C(/</g,"&1F;");z=z.C(/ {2,}/g,h(m){l 4r="";D(l i=0;i<m.v-1;i++){4r+="&1X;"}q 4r+" "});f(19!=u){z=p.B.4n(z,h(2s){f(2s.v==0){q""}l 3c="";2s=2s.C(/^(&1X;| )+/,h(s){3c=s;q""});f(2s.v==0){q 3c}q 3c+"<I 1e=\\""+19+"\\">"+2s+"</I>"})}q z},7a:h(61,62){l 2I=61.2r();29(2I.v<62){2I="0"+2I}q 2I},5p:h(){l 3x=L.1s("A"),35,3r=0,5i=L.2L,1g=p.B.5H("5p"),2Q="<A 1e=\\"",2V="</A>",4H="</1V>";3x.1x=2Q+"7P\\">"+2Q+"1m\\">"+2Q+"2P\\">"+2Q+"5B"+"\\"><1V 1e=\\"7i\\"><1V 1g=\\""+1g+"\\">&1X;"+4H+4H+2V+2V+2V+2V;5i.1G(3x);35=L.ar(1g);f(/aq/i.1R(5Z.5W)){l 63=1q.ao(35,u);3r=7b(63.ap("1S"))}F{3r=35.at}5i.5a(3x);q 3r},76:h(5Y,60){l 1C="";D(l i=0;i<60;i++){1C+=" "}q 5Y.C(/\\t/g,1C)},71:h(2C,4w){l az=2C.1P("\\n"),1C="\\t",40="";D(l i=0;i<50;i++){40+="                    "}h 6I(3z,18,5X){q 3z.1Q(0,18)+40.1Q(0,5X)+3z.1Q(18+1,3z.v)};2C=p.B.4n(2C,h(2a){f(2a.1i(1C)==-1){q 2a}l 18=0;29((18=2a.1i(1C))!=-1){l 7r=4w-18%4w;2a=6I(2a,18,7r)}q 2a});q 2C},3G:h(z){l br=/<br\\s*\\/?>|&1F;br\\s*\\/?&2o;/4x;f(p.M.8k==U){z=z.C(br,"\\n")}f(p.M.8l==U){z=z.C(br,"")}q z},33:h(z){q z.C(/\\s*$/g,"").C(/^\\s*/,"")},2D:h(z){l 21=p.B.3G(z).1P("\\n"),av=T 5V(),8a=/^\\s*/,1Z=ax;D(l i=0;i<21.v&&1Z>0;i++){l 3V=21[i];f(p.B.33(3V).v==0){1H}l 3W=8a.Q(3V);f(3W==u){q z}1Z=3J.1Z(3W[0].v,1Z)}f(1Z>0){D(l i=0;i<21.v;i++){21[i]=21[i].1Q(1Z)}}q 21.5u("\\n")},7d:h(2K,2O){f(2K.G<2O.G){q-1}F{f(2K.G>2O.G){q 1}F{f(2K.v<2O.v){q-1}F{f(2K.v>2O.v){q 1}}}}q 0},30:h(7S,2H){h 7R(4V,7Y){q[T p.4i(4V[0],4V.G,7Y.19)]};l au=0,5N=u,39=[],7Z=2H.4L?2H.4L:7R;29((5N=2H.3q.Q(7S))!=u){39=39.31(7Z(5N,2H))}q 39},7C:h(86){q 86.C(p.85.3p,h(m){q"<a 2q=\\""+m+"\\">"+m+"</a>"})}},1I:h(88,4T){h 81(5j){l 59=[];D(l i=0;i<5j.v;i++){59.K(5j[i])}q 59};l 3g=4T?[4T]:81(L.82(p.M.83)),80="1x",2e=u;f(3g.v===0){q}D(l i=0;i<3g.v;i++){l 2G=3g[i],2l=p.B.84(2G.J),32;2l=p.B.5o(88,2l);32=2l["87"];f(32==u){1H}f(2l["2u-2c"]=="U"){2e=T p.4B(32)}F{l 4O=p.B.4l(32);f(4O){2e=T 4O()}F{1H}}2e.1I(2G[80],2l);l 2p=2e.A;f(p.M.6T){2p=L.1s("aA");2p.1U=2e.A.1x;2p.1n.1S="aB";2p.1n.2t="aK"}2G.7T.aJ(2p,2G)}},aL:h(7U){p.B.7Q(1q,"aM",h(){p.1I(7U)})}};p.4i=h(4j,7V,19){c.1U=4j;c.G=7V;c.v=4j.v;c.19=19};p.4i.Y.2r=h(){q c.1U};p.4B=h(4y){l 1J=p.B.4l(4y),4z=T p.2B.aN(),aH=u;f(1J==u){q}1J=T 1J();c.4E=4z;f(1J.3O==u){p.B.1v(p.M.1k.7X+4y);q}4z.5n.K({3q:1J.3O.I,4L:89});h 3a(4K,7W){D(l j=0;j<4K.v;j++){4K[j].G+=7W}};h 89(17,aC){l 8f=17.I,1L=[],4N=1J.5n,8e=17.G+17.E.v,2Z=1J.3O,1l;D(l i=0;i<4N.v;i++){1l=p.B.30(8f,4N[i]);3a(1l,8e);1L=1L.31(1l)}f(2Z.E!=u&&17.E!=u){1l=p.B.30(17.E,2Z.E);3a(1l,17.G);1L=1L.31(1l)}f(2Z.13!=u&&17.13!=u){1l=p.B.30(17.13,2Z.13);3a(1l,17.G+17[0].aE(17.13));1L=1L.31(1l)}q 1L}};p.4B.Y.1I=h(8h,8i){c.4E.1I(8h,8i);c.A=c.4E.A};p.8b=h(){};p.8b.Y={V:h(8c,8g){l 3Z=c.1A[8c];q p.B.8d(3Z==u?8g:3Z)},12:h(8j){q L.1s(8j)},72:h(38,7O){l 2w=[];f(38!=u){D(l i=0;i<38.v;i++){2w=2w.31(p.B.30(7O,38[i]))}}2w=2w.am(p.B.7d);q 2w},73:h(){l 26=c.2R;D(l i=0;i<26.v;i++){f(26[i]===u){1H}l 2x=26[i],45=2x.G+2x.v;D(l j=i+1;j<26.v&&26[i]!==u;j++){l 20=26[j];f(20===u){1H}F{f(20.G>45){2m}F{f(20.G==2x.G&&20.v>2x.v){c.2R[i]=u}F{f(20.G>=2x.G&&20.G<45){c.2R[j]=u}}}}}}},7m:h(2M){l 36=2M.1P(/\\n/g),3f=7b(c.V("79-2P")),7e=(3f+36.v).2r().v,7f=c.V("1I",[]);2M="";D(l i=0;i<36.v;i++){l 1r=36[i],2y=/^(&1X;|\\s)+/.Q(1r),5A="2P a3"+(i%2==0?1:2),7j=p.B.7a(3f+i,7e),7k=7f.1i((3f+i).2r())!=-1,1E=u;f(2y!=u){1E=2y[0].2r();1r=1r.1Q(1E.v);1E=1E.C(/&1X;/g," ");2y=p.1t.3k*1E.v}F{2y=0}1r=p.B.33(1r);f(1r.v==0){1r="&1X;"}f(7k){5A+=" a6"}2M+="<A 1e=\\""+5A+"\\">"+"<I 1e=\\"a7\\">"+7j+".</I>"+"<1V 1e=\\"5B\\">"+(1E!=u?"<I 1e=\\"a2\\">"+1E.C(/\\s/g,"&1X;")+"</I>":"")+"<1V 1e=\\"7i\\" 1n=\\"5D-E: "+2y+"5x !78;\\">"+1r+"</1V>"+"</1V>"+"</A>"}q 2M},7l:h(5v,5r){l 18=0,3o="",3n=p.B.7g;D(l i=0;i<5r.v;i++){l 1N=5r[i];f(1N===u||1N.v===0){1H}3o+=3n(5v.1Q(18,1N.G-18),"7h")+3n(1N.1U,1N.19);18=1N.G+1N.v}3o+=3n(5v.1Q(18),"7h");q 3o},1I:h(1j,6Y){l a1=p.M,3l=p.1t,A,9Z,3i,a0="78";c.1A={};c.A=u;c.1m=u;c.I=u;c.1h=u;c.5I={};c.1g=p.B.5H("a8");3l.5K[c.1g]=c;f(1j===u){1j=""}f(3l.3k===u){3l.3k=p.B.5p()}c.1A=p.B.5o(p.77,6Y||{});f(c.V("6Z")==U){c.1A.1z=c.1A.4Z=N}c.A=A=c.12("3j");c.1m=c.12("3j");c.1m.J="1m";J="7P";A.1g=c.1g;f(c.V("56")){J+=" 51"}f(c.V("4Z")==N){J+=" ak"}f(c.V("4S-1m")==N){c.1m.J+=" al-4S"}J+=" "+c.V("1e-1f");A.J=J;c.4W=1j;c.I=p.B.6W(1j).C(/\\r/g," ");3i=c.V("1C-2A");c.I=c.V("6V-70")==U?p.B.71(c.I,3i):p.B.76(c.I,3i);c.I=p.B.2D(c.I);f(c.V("1z")){c.1h=c.12("3j");c.1h.J="1h";c.1h.1G(p.1z.12(c));A.1G(c.1h);l 1h=c.1h;h 5d(){1h.J=1h.J.C("75","")};A.ab=h(){5d();1h.J+=" 75"};A.ad=h(){5d()}}f(c.V("5f")){A.1G(p.B.74())}A.1G(c.1m);c.2R=c.72(c.5n,c.I);c.73();1j=c.7l(c.I,c.2R);1j=c.7m(p.B.33(1j));f(c.V("7G-7F")){1j=p.B.7C(1j)}c.1m.1x=1j},bn:h(z){z=z.C(/^\\s+|\\s+$/g,"").C(/\\s+/g,"\\\\b|\\\\b");q"\\\\b"+z+"\\\\b"},bl:h(2W){c.3O={E:{3q:2W.E,19:"2c"},13:{3q:2W.13,19:"2c"},I:T R("(?<E>"+2W.E.1c+")"+"(?<I>.*?)"+"(?<13>"+2W.13.1c+")","bv")}}};q p}()}f(!5V.1i){5V.Y.1i=h(7M,3R){3R=3J.bF(3R||0,0);D(l i=3R;i<c.v;i++){f(c[i]==7M){q i}}q-1}}f(!1q.R){(h(){l 2z={Q:11.Y.Q,7K:5b.Y.7K,C:5b.Y.C,1P:5b.Y.1P},1K={W:/(?:[^\\\\([#\\s.]+|\\\\(?!k<[\\w$]+>|[7B]{[^}]+})[\\S\\s]?|\\((?=\\?(?!#|<[\\w$]+>)))+|(\\()(?:\\?(?:(#)[^)]*\\)|<([$\\w]+)>))?|\\\\(?:k<([\\w$]+)>|[7B]{([^}]+)})|(\\[\\^?)|([\\S\\s])/g,by:/(?:[^$]+|\\$(?![1-9$&`\']|{[$\\w]+}))+|\\$(?:([1-9]\\d*|[$&`\'])|{([$\\w]+)})/g,3M:/^(?:\\s+|#.*)+/,5F:/^(?:[?*+]|{\\d+(?:,\\d*)?})/,7x:/&&\\[\\^?/g,7v:/]/g},7n=h(5l,5k,4X){D(l i=4X||0;i<5l.v;i++){f(5l[i]===5k){q i}}q-1},7y=/()??/.Q("")[1]!==3K,3w={};R=h(1d,1Y){f(1d 3T 11){f(1Y!==3K){3L 7N("4C\'t 4I bJ 7H aY 7J 11 4X aZ")}q 1d.3C()}l 1Y=1Y||"",7w=1Y.1i("s")>-1,6X=1Y.1i("x")>-1,5q=N,3u=[],14=[],W=1K.W,H,3D,3F,3E,3v;W.O=0;29(H=2z.Q.2n(W,1d)){f(H[2]){f(!1K.5F.1R(1d.15(W.O))){14.K("(?:)")}}F{f(H[1]){3u.K(H[3]||u);f(H[3]){5q=U}14.K("(")}F{f(H[4]){3E=7n(3u,H[4]);14.K(3E>-1?"\\\\"+(3E+1)+(55(1d.5J(W.O))?"":"(?:)"):H[0])}F{f(H[5]){14.K(3w.7t?3w.7t.7u(H[5],H[0].5J(1)==="P"):H[0])}F{f(H[6]){f(1d.5J(W.O)==="]"){14.K(H[6]==="["?"(?!)":"[\\\\S\\\\s]");W.O++}F{3D=R.7q("&&"+1d.15(H.G),1K.7x,1K.7v,"",{7s:"\\\\"})[0];14.K(H[6]+3D+"]");W.O+=3D.v+1}}F{f(H[7]){f(7w&&H[7]==="."){14.K("[\\\\S\\\\s]")}F{f(6X&&1K.3M.1R(H[7])){3F=2z.Q.2n(1K.3M,1d.15(W.O-1))[0].v;f(!1K.5F.1R(1d.15(W.O-1+3F))){14.K("(?:)")}W.O+=3F-1}F{14.K(H[7])}}}F{14.K(H[0])}}}}}}}3v=11(14.5u(""),2z.C.2n(1Y,/[8y]+/g,""));3v.1u={1c:1d,2j:5q?3u:u};q 3v};R.8B=h(1f,o){3w[1f]=o};11.Y.Q=h(z){l 1b=2z.Q.2n(c,z),1f,i,5C;f(1b){f(7y&&1b.v>1){5C=T 11("^"+c.1c+"$(?!\\\\s)",c.4a());2z.C.2n(1b[0],5C,h(){D(i=1;i<7z.v-2;i++){f(7z[i]===3K){1b[i]=3K}}})}f(c.1u&&c.1u.2j){D(i=1;i<1b.v;i++){1f=c.1u.2j[i-1];f(1f){1b[1f]=1b[i]}}}f(c.3A&&c.O>(1b.G+1b[0].v)){c.O--}}q 1b}})()}11.Y.4a=h(){q(c.3A?"g":"")+(c.8M?"i":"")+(c.7D?"m":"")+(c.3M?"x":"")+(c.8Y?"y":"")};11.Y.3C=h(7o){l 4g=T R(c.1c,(7o||"")+c.4a());f(c.1u){4g.1u={1c:c.1u.1c,2j:c.1u.2j?c.1u.2j.15(0):u}}q 4g};11.Y.2n=h(90,z){q c.Q(z)};11.Y.8W=h(8U,7p){q c.Q(7p[0])};R.47=h(4f,4e){l 46="/"+4f+"/"+(4e||"");q R.47[46]||(R.47[46]=T R(4f,4e))};R.3t=h(z){q z.C(/[-[\\]{}()*+?.\\\\^$|,#\\s]/g,"\\\\$&")};R.7q=h(z,E,Z,1a,2T){l 2T=2T||{},2X=2T.7s,X=2T.8A,1a=1a||"",4s=1a.1i("g")>-1,7E=1a.1i("i")>-1,7L=1a.1i("m")>-1,4t=1a.1i("y")>-1,1a=1a.C(/y/g,""),E=E 3T 11?(E.3A?E:E.3C("g")):T R(E,"g"+1a),Z=Z 3T 11?(Z.3A?Z:Z.3C("g")):T R(Z,"g"+1a),1D=[],2b=0,1o=0,1p=0,1y=0,27,22,1w,1B,3I,4m;f(2X){f(2X.v>1){3L 8n("4C\'t 4I 8q 8z 7J 3t 7I")}f(7L){3L 7N("4C\'t 4I 3t 7I 7H 9U 9D 7D 9C")}3I=R.3t(2X);4m=T 11("^(?:"+3I+"[\\\\S\\\\s]|(?:(?!"+E.1c+"|"+Z.1c+")[^"+3I+"])+)+",7E?"i":"")}29(U){E.O=Z.O=1p+(2X?(4m.Q(z.15(1p))||[""])[0].v:0);1w=E.Q(z);1B=Z.Q(z);f(1w&&1B){f(1w.G<=1B.G){1B=u}F{1w=u}}f(1w||1B){1o=(1w||1B).G;1p=(1w?E:Z).O}F{f(!2b){2m}}f(4t&&!2b&&1o>1y){2m}f(1w){f(!2b++){27=1o;22=1p}}F{f(1B&&2b){f(!--2b){f(X){f(X[0]&&27>1y){1D.K([X[0],z.15(1y,27),1y,27])}f(X[1]){1D.K([X[1],z.15(27,22),27,22])}f(X[2]){1D.K([X[2],z.15(22,1o),22,1o])}f(X[3]){1D.K([X[3],z.15(1o,1p),1o,1p])}}F{1D.K(z.15(22,1o))}1y=1p;f(!4s){2m}}}F{E.O=Z.O=0;3L 9q("9A 9i 9a 9d 8u")}}f(1o===1p){1p++}}f(4s&&!4t&&X&&X[0]&&z.v>1y){1D.K([X[0],z.15(1y),1y,z.v])}E.O=Z.O=0;q 1D};',62,728,'||||||||||||this|||if||function||||var||||sh|return||||null|length||||str|div|utils|replace|for|left|else|index|_10f|code|className|push|document|config|false|lastIndex||exec|XRegExp||new|true|getParam|part|vN|prototype|_127||RegExp|create|right|_10d|slice||_c4|pos|css|_128|_117|source|_107|class|name|id|bar|indexOf|_f0|strings|_cb|lines|style|_132|_133|window|_e3|createElement|vars|_x|alert|_137|innerHTML|_134|toolbar|params|_138|tab|_130|_e8|lt|appendChild|continue|highlight|_be|lib|_c7|obj|_ef|doc|split|substr|test|width|_4b|value|span|_3c|nbsp|_108|min|_dc|_98|_136|in|_57|_56|_d7|_135|_8|while|_91|_131|script|text|_b2|_6e|http|execute|wnd|captureNames|_5b|_b5|break|call|gt|_b8|href|toString|_75|height|html|attributes|_d5|_d9|_e4|_fe|size|brushes|_88|unindent|SyntaxHighlighter|_40|_b4|_a2|_7a|_51|m1|body|_dd|case|m2|line|_80|matches|_28|_129|_62|_81|_fa|_12a|_5|_ca|getMatches|concat|_b6|trim|print|_7c|_de|_5e|_d3|_a7|offsetMatches|_5c|_76|_6a|_65|_df|_b0|write|_f6|DIV|spaceWidth|_f3|_4a|_ed|_ec|url|regex|_7d|_2|escape|_10c|_113|_106|_7b|_3|_8e|global|title|addFlags|cc|_112|len|fixInputString|_32|_139|Math|undefined|throw|extended|font|htmlScript|printFrame|_22|_fc|_25|instanceof|_17|_9d|_9e|_18|expandSource|_d1|_8c|viewSource|_1a|top|_4f|_da|key|cache|_10|win|getNativeFlags|_19|_50|focus|_122|_121|_11c|_b|Match|_ba|gm|findBrush|esc|eachLine|_4|_6c|values|_73|_12c|_12f|_6b|color|_89|gi|_bd|_bf|_9|HtmlScript|can|discoveredBrushes|xmlBrush|_f|_5d|_82|supply|_7|_c1|func|_59|_c8|_b7|_e|_d|pre|wrap|_ac|com|_a3|originalCode|from|link|gutter||collapsed|clipboardSwf|_37|popup|isNaN|collapse|_blank|_38|_ae|removeChild|String|contentWindow|hide|_24|ruler|swf|_30|_7e|_ad|item|_101|_2f|regexList|merge|measureSpace|_10b|_ea|_2a|_2c|join|_e9|_2e|px|_2b|_4c|_e5|content|r2|margin|_29|quantifier|_49|guid|toolbarCommands|charAt|highlighters|_27|highlighterId|_a6|close|toolbarItemWidth|_2d|_48|toolbarItemHeight|_35|copyToClipboard|Array|userAgent|_90|_84|navigator|_85|_78|_79|_83|_3f|items|_1e|_16|_13|_12|shockwave|flash|clipboardData|_36|object|version|_15|_14|center|alexgorbatchev|align|head|org|2009|_6|executeCommand|commandName|_a|createButton|copyToClipboardConfirmation|message|w3|event|_4e|screen|switch|attachEvent|_5a|_66|www|_61|noBrush|_47|aboutDialog|insertSpaces|copyStyles|500px|0px|_3e|type|scrollbars|help|stylesheet|rel|_6d|debug|DTD|smart|trimFirstAndLastLines|_10a|_f1|light|tabs|processSmartTabs|findMatches|removeNestedMatches|createRuler|show|processTabs|defaults|important|first|padNumber|parseInt|xhtml1|matchesSortCallback|_e0|_e1|decorate|plain|block|_e6|_e7|processMatches|createDisplayLines|_100|_11b|args|matchRecursive|_93|escapeChar|unicode|get|classRight|_109|classLeft|_105|arguments|clipboard|pP|processUrls|multiline|_12d|links|auto|when|character|one|match|_12e|_fb|TypeError|_d4|syntaxhighlighter|addEvent|defaultAdd|_a1|parentNode|_b9|_bb|_c2|brushNotHtmlScript|_a4|_a8|_b1|toArray|getElementsByTagName|tagName|parseParams|regexLib|_a9|brush|_ab|process|_9a|Highlighter|_cf|toBoolean|_c9|_c6|_d0|_cd|_ce|_d2|bloggerMode|stripBrs|catch|SyntaxError|now|Can|more|xhtml|utf|onclick|delimiters|wasn|your|family|sx|than|valueNames|addPlugin|About|try|charset|_26|400|750|find|_21|location|Type|ignoreCase|menubar|resizable|Content|_20|_1f|param|meta|_11f|Brush|apply|_1b|sticky|Geneva|_11d|_1c|equiv|to|syntax|highlighter|JavaScript|expand|none|3em|contains|view|Alex|unbalanced|2004|Copyright|decoration|0099FF|data|320|4em|bottom|75em|May|large|xx|Error|target|03|Gorbatchev|multiLineCComments|aspScriptTags|scriptScriptTags|phpScriptTags|Arial|multiLineSingleQuotedString|subject|The|flag|the|is|string|typeof|Helvetica|sans|000|fff|1em|singleLinePerlComments|singleLineCComments|copy|doubleQuotedString|serif|multiLineDoubleQuotedString|background|singleQuotedString|using|W3C|random|1000000|round|_f5|_f7|_f2|spaces|alt|transitional|open|highlighted|number|highlighter_|250|shCore|onmouseover|toLowerCase|onmouseout|printing|about|_42|_44|500|_43|nogutter|no|sort|on|getComputedStyle|getPropertyValue|opera|getElementById|1999|offsetWidth|_a5|_99|dtd|1000|xmlns|_8a|textarea|70em|_c5|150|lastIndexOf|aliases|addEventListener|_c0|middot|replaceChild|30em|all|load|Xml|absolute|position|444553540000|codebase|96b8|11cf|ae6d|PUBLIC|download|cabs|constructing|another|pub|macromedia|d27cdb6e|clsid|always|wmode|allowScriptAccess|application|_clipboard|transparent|flashVars|msie|classid|menu|DOCTYPE|option|swflash|cab|TR|error|ok|forHtmlScript|setData|getKeywords|printSource|IFRAME|cssText||_3b|_3a|_39|sgi|amp|Transitional|replaceVar|XHTML|embed|movie|src|configured|command|max|_34|_33|EN|flags'.split('|'),0,{}))
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeDefault.css
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeDefault.css	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeDefault.css	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,191 @@
+ * @version
+ * @copyright
+ * @license
+ * Default Syntax Highlighter theme.
+ * Interface elements.
+.syntaxhighlighter
+	background-color: #E7E5DC !important;
+/* Highlighed line number */
+.syntaxhighlighter .line.highlighted .number
+	background-color: #6CE26C !important;
+	color: black !important;
+/* Highlighed line */
+.syntaxhighlighter .line.highlighted.alt1 .content,
+.syntaxhighlighter .line.highlighted.alt2 .content
+	color: #5C5C5C !important;
+	border-left: 3px solid #6CE26C !important;
+/* First line */
+.syntaxhighlighter .line.alt1 .content
+	background-color: #fff !important;
+/* Second line */
+.syntaxhighlighter .line.alt2 .content
+	background-color: #F8F8F8 !important;
+	background: url(wrapping.png) 0 1.1em no-repeat !important;
+	color: silver !important;
+	border: #E7E5DC solid 1px !important;
+	color: #a0a0a0 !important;
+.syntaxhighlighter .toolbar a:hover
+ * Actual syntax highlighter colors.
+.syntaxhighlighter .plain,
+.syntaxhighlighter .plain a
+.syntaxhighlighter .comments,
+.syntaxhighlighter .comments a
+.syntaxhighlighter .string,
+.syntaxhighlighter .string a
+.syntaxhighlighter .keyword
+.syntaxhighlighter .preprocessor
+.syntaxhighlighter .variable
+.syntaxhighlighter .value
+.syntaxhighlighter .functions
+.syntaxhighlighter .constants
+.syntaxhighlighter .script
+	background-color: yellow !important;
+.syntaxhighlighter .color1,
+.syntaxhighlighter .color1 a
+.syntaxhighlighter .color2,
+.syntaxhighlighter .color2 a
+.syntaxhighlighter .color3,
+.syntaxhighlighter .color3 a
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeDjango.css
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeDjango.css	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeDjango.css	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,193 @@
+ * @version
+ * @copyright
+ * @license
+ * Django SyntaxHighlighter theme
+.syntaxhighlighter
+	background-color: #0B2F20 !important;
+	color: #497958 !important;
+	border-left: 3px solid #41A83E !important;
+	color: #B9BDB6 !important;
+/* First line */
+/* Second line */
+	background-color: #0a2b1d !important;
+	background-color: #336442 !important;
+	color: #fff !important;
+	color: #C4B14A !important;
+	background-color: #245032 !important;
+	border: #0B2F20 solid 1px !important;
+	color: #FFE862 !important;
+	color: #F8F8F8 !important;
+	color: #336442 !important;
+	color: #9DF39F !important;
+	color: #96DD3B !important;
+	color: #91BB9E !important;
+	color: #FFAA3E !important;
+	color: #F7E741 !important;
+	color: #E0E8FF !important;
+	background-color: #497958 !important;
+	color: #EB939A !important;
+	color: #EDEF7D !important;
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeEmacs.css
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeEmacs.css	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeEmacs.css	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,192 @@
+ * @version
+ * @copyright
+ * @license
+ * Emacs SyntaxHighlighter theme based on theme by Joshua Emmons
+ * http://www.skia.net/
+.syntaxhighlighter
+	background-color: #000000 !important;
+	color: #D3D3D3 !important;
+	border-left: 3px solid #990000 !important;
+/* First line */
+/* Second line */
+	background-color: #0f0f0f !important;
+	background-color: #435A5F !important;
+	border: #000000 solid 1px !important;
+	color: #646763 !important;
+	color: #9CCFF4 !important;
+	color: #FF7D27 !important;
+	color: #FF9E7B !important;
+	color: #00FFFF !important;
+	color: #AEC4DE !important;
+	color: #81CEF9 !important;
+	background-color: #990000 !important;
+	color: #EBDB8D !important;
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeFadeToGrey.css
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeFadeToGrey.css	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeFadeToGrey.css	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,193 @@
+ * @version
+ * @copyright
+ * @license
+ * Fade to Grey SyntaxHighlighter theme based on theme by Brasten Sager
+ * http://www.ibrasten.com/
+.syntaxhighlighter
+	background-color: #121212 !important;
+	color: #C3C3C3 !important;
+	border-left: 3px solid #3185B9 !important;
+/* First line */
+/* Second line */
+	background-color: #3A3A00 !important;
+	color: #96DAFF !important;
+	color: #FFFFFF !important;
+	color: #696854 !important;
+	color: #E3E658 !important;
+	color: #D01D33 !important;
+	color: #435A5F !important;
+	color: #898989 !important;
+	color: #AAAAAA !important;
+	background-color: #C3C3C3 !important;
+	color: #FFC074 !important;
+	color: #4A8CDB !important;
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeMidnight.css
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeMidnight.css	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeMidnight.css	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,192 @@
+ * @version
+ * @copyright
+ * @license
+ * Midnight SyntaxHighlighter theme based on theme by J.D. Myers
+ * http://webdesign.lsnjd.com/
+.syntaxhighlighter
+	background-color: #0F192A !important;
+	color: #38566F !important;
+	border-left: 3px solid #435A5F !important;
+/* First line */
+/* Second line */
+	background-color: #253E5A !important;
+	color: #8AA6C1 !important;
+	color: #D1EDFF !important;
+	color: #428BDD !important;
+	color: #1DC116 !important;
+	color: #B43D3D !important;
+	background-color: #404040 !important;
+	color: #F8BB00 !important;
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeRDark.css
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeRDark.css	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/shThemeRDark.css	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,192 @@
+ * @version
+ * @copyright
+ * @license
+ * RDark SyntaxHighlighter theme based on theme by Radu Dineiu
+ * http://www.vim.org/scripts/script.php?script_id=1732
+.syntaxhighlighter
+	background-color: #1B2426 !important;
+/* First line */
+/* Second line */
+	color: #878A85 !important;
+	color: #5CE638 !important;
+	color: #5BA1CF !important;
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/wrapping.png
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/syntax/wrapping.png
___________________________________________________________________
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/themeroller.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/themeroller.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/themeroller.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,87 @@
+<!DOCTYPE html
+PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
+"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
+<html xmlns="http://www.w3.org/1999/xhtml">
+<head>
+	<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
+	<title>jsTree &raquo; Demos</title>
+	<script type="text/javascript" src="../lib/jquery.js"></script>
+	<script type="text/javascript" src="../lib/jquery.cookie.js"></script>
+	<script type="text/javascript" src="../lib/jquery.hotkeys.js"></script>
+	<script type="text/javascript" src="../lib/jquery.metadata.js"></script>
+	<script type="text/javascript" src="../lib/sarissa.js"></script>
+	<script type="text/javascript" src="../jquery.tree.js"></script>
+	<script type="text/javascript" src="../plugins/jquery.tree.checkbox.js"></script>
+	<script type="text/javascript" src="../plugins/jquery.tree.contextmenu.js"></script>
+	<script type="text/javascript" src="../plugins/jquery.tree.cookie.js"></script>
+	<script type="text/javascript" src="../plugins/jquery.tree.hotkeys.js"></script>
+	<script type="text/javascript" src="../plugins/jquery.tree.metadata.js"></script>
+	<script type="text/javascript" src="../plugins/jquery.tree.themeroller.js"></script>
+	<script type="text/javascript" src="../plugins/jquery.tree.xml_flat.js"></script>
+	<script type="text/javascript" src="../plugins/jquery.tree.xml_nested.js"></script>
+	<link type="text/css" rel="stylesheet" href="syntax/shCore.css"/>
+	<link type="text/css" rel="stylesheet" href="syntax/shThemeDefault.css"/>
+	<style type="text/css">
+	html, body { margin:0; padding:0; }
+	body, td, th, pre, code, select, option, input, textarea { font-family:"Trebuchet MS", Sans-serif; font-size:10pt; }
+	#container { width:800px; margin:10px auto; overflow:hidden; }
+	.demo { height:200px; width:300px; float:left; margin:0; border:1px solid gray; font-family:Verdana; font-size:10px; background:white; }
+	.code { width:490px; float:right; margin:0 0 10px 0; border:1px solid gray; }
+	pre { display:block; }
+	.syntaxhighlighter { margin:0 0 0 0 !important; padding:0 !important; }
+	</style>
+	<script type="text/javascript" src="syntax/shCore.js"></script>
+	<script type="text/javascript" src="syntax/shBrushJScript.js"></script>
+	<script type="text/javascript" src="syntax/shBrushXml.js"></script>
+	<script type="text/javascript">
+		SyntaxHighlighter.config.clipboardSwf = 'syntax/clipboard.swf';
+		$(function () {
+			var h = 0;
+			$("#container .source").each(function () {
+				var code = $(this).html().replace(/</g,'&lt;').replace(/>/g,'&gt;');
+				var div = $('<div class="code"><pre class="brush:' + ( $(this).is("script") ? 'js' : 'xml' ) + ';">' + code + '</pre></div>');
+				$(this).after(div);
+			SyntaxHighlighter.all();
+	</script>
+</head>
+<body>
+<div id="container">
+	<h1 class="title">Themeroller plugin demo</h1>
+	<script type="text/javascript" class="source">
+	$(function () {
+		$("#demo_1").tree({
+			ui : {
+				// required
+				theme_name : "themeroller"
+			plugins : {
+				themeroller : { }
+	</script>
+	<div class="source" id="demo_1" style="width:300px; height:150px; overflow:auto; float:left; margin-top:10px;">
+		<ul>
+			<li id="phtml_1" class="open"><a href="#"><ins>&nbsp;</ins>Root node 1</a>
+				<ul>
+					<li id="phtml_2"><a href="#"><ins>&nbsp;</ins>Child node 1</a></li>
+					<li id="phtml_3"><a href="#"><ins>&nbsp;</ins>Child node 2</a></li>
+					<li id="phtml_4"><a href="#"><ins>&nbsp;</ins>Some other child node with longer text</a></li>
+				</ul>
+			</li>
+			<li id="phtml_5"><a href="#"><ins>&nbsp;</ins>Root node 2</a></li>
+		</ul>
+	</div>
+	<style class="source" type="text/css">
+	@import "http://ajax.googleapis.com/ajax/libs/jqueryui/1.7.2/themes/humanity/jquery-ui.css";
+	#demo_1, #demo_1 li, #demo_1 li a { font-size:10px; }
+	</style>
+</div></body></html>
\ No newline at end of file
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/themes.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/themes.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/themes.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,100 @@
+<!DOCTYPE html
+<head>
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">Themes demo</h1>
+	<p>You may find <a href="../documentation.html#theme_name">the theme documenation</a> useful. The included themes are apple, classic, default, checkbox &amp; themeroller - the latter two also need their respective plugins to function correctly.</p>
+	$(function () {
+			ui : {
+				theme_name : "classic"
+	</script>
+	<div class="demo" id="demo_1">
+		<ul>
+				<ul>
+				</ul>
+			</li>
+		</ul>
+	</div>
+	<div class="demo" id="demo_2" style="clear:both;">
+		<ul>
+			<li id="aphtml_1" class="open"><a href="#"><ins>&nbsp;</ins>Root node 1</a>
+				<ul>
+					<li id="aphtml_2"><a href="#"><ins>&nbsp;</ins>Child node 1</a></li>
+					<li id="aphtml_3"><a href="#"><ins>&nbsp;</ins>Child node 2</a></li>
+					<li id="aphtml_4"><a href="#"><ins>&nbsp;</ins>Some other child node with longer text</a></li>
+				</ul>
+			</li>
+			<li id="aphtml_5"><a href="#"><ins>&nbsp;</ins>Root node 2</a></li>
+		</ul>
+	</div>
+	$(function () {
+		$("#demo_2").tree({
+			ui : {
+				theme_name : "apple"
+	</script>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/types.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/types.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/types.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,117 @@
+<!DOCTYPE html
+<head>
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">Types demo</h1>
+	<p>You may also want to read the documentation on <a href="../documentation.html#types">types</a> (and also read about <a href="../documentation.html#rules.type_attr">the type attribute</a>).
+	$(function () {
+			rules : {
+				// only nodes of type root can be top level nodes
+				valid_children : [ "root" ]
+			types : {
+				// all node types inherit the "default" node type
+				"default" : {
+					deletable : false,
+					renameable : false
+				"root" : {
+					draggable : false,
+					valid_children : [ "folder" ],
+					icon : {
+						image : "drive.png"
+				"folder" : {
+					valid_children : [ "file" ],
+					max_children : 3
+				"file" : {
+					// the following three rules basically do the same
+					valid_children : "none",
+					max_children : 0,
+					max_depth :0,
+					icon : {
+						image : "file.png"
+	</script>
+		<ul>
+			<li id="phtml_1" rel="root" class="open"><a href="#"><ins>&nbsp;</ins>Root node 1</a>
+				<ul>
+					<li id="phtml_2" rel="folder"><a href="#"><ins>&nbsp;</ins>My Photos</a></li>
+					<li id="phtml_3" rel="folder"><a href="#"><ins>&nbsp;</ins>My Music</a>
+						<ul>
+							<li id="phtml_10" rel="file"><a href="#"><ins>&nbsp;</ins>scream.mp3</a></li>
+							<li id="phtml_11" rel="file"><a href="#"><ins>&nbsp;</ins>shout.wav</a></li>
+							<li id="phtml_12" rel="file"><a href="#"><ins>&nbsp;</ins>cry.ogg</a></li>
+						</ul>
+					</li>
+					<li id="phtml_4" rel="folder"><a href="#"><ins>&nbsp;</ins>My Stuff</a>
+						<ul>
+							<li id="phtml_13" rel="file"><a href="#"><ins>&nbsp;</ins>a.doc</a></li>
+							<li id="phtml_14" rel="file"><a href="#"><ins>&nbsp;</ins>some_picture.jpg</a></li>
+						</ul>
+					</li>
+				</ul>
+			</li>
+			<li id="phtml_5" rel="root"><a href="#"><ins>&nbsp;</ins>Root node 2</a></li>
+		</ul>
+	</div>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/xml_flat_from_string.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/xml_flat_from_string.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/xml_flat_from_string.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,70 @@
+<!DOCTYPE html
+<head>
+	.demo { height:200px; width:300px; float:left; margin:0; border:1px solid gray; font-family:Verdana; font-size:10px; background:white; overflow:auto; }
+	input { font-size:14px; }
+	</style>
+		$(function () {
+			var h = 0;
+	</script>
+</head>
+<body>
+	<h1 class="title">XML flat from string</h1>
+	<p>This example loads the tree from a XML flat string.</p>
+	$(function () {
+		$("#xml_f").tree({
+			data : {
+				type : "xml_flat",
+				opts : {
+					static : '<root><item parent_id="0" id="xml_1"><content><name><![CDATA[Root node 1]]></name></content></item><item parent_id="xml_1" id="xml_2"><content><name><![CDATA[Child node 1]]></name></content></item></root>'
+	</script>
+	<div class="demo" id="xml_f"></div>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/xml_flat_with_languages.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/xml_flat_with_languages.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/xml_flat_with_languages.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,39 @@
+<!DOCTYPE html
+<head>
+	<script type="text/javascript" src="/js/jsTree/source/lib/jquery.js"></script>
+	<script type="text/javascript" src="/js/jsTree/source/lib/jquery.cookie.js"></script>
+	<script type="text/javascript" src="/js/jsTree/source/lib/jquery.hotkeys.js"></script>
+	<script type="text/javascript" src="/js/jsTree/source/lib/jquery.metadata.js"></script>
+	<script type="text/javascript" src="/js/jsTree/source/lib/sarissa.js"></script>
+	<script type="text/javascript" src="/js/jsTree/source/jquery.tree.js"></script>
+	<script type="text/javascript" src="/js/jsTree/source/plugins/jquery.tree.checkbox.js"></script>
+	<script type="text/javascript" src="/js/jsTree/source/plugins/jquery.tree.contextmenu.js"></script>
+	<script type="text/javascript" src="/js/jsTree/source/plugins/jquery.tree.cookie.js"></script>
+	<script type="text/javascript" src="/js/jsTree/source/plugins/jquery.tree.hotkeys.js"></script>
+	<script type="text/javascript" src="/js/jsTree/source/plugins/jquery.tree.metadata.js"></script>
+	<script type="text/javascript" src="/js/jsTree/source/plugins/jquery.tree.themeroller.js"></script>
+	<script type="text/javascript" src="/js/jsTree/source/plugins/jquery.tree.xml_flat.js"></script>
+	<script type="text/javascript" src="/js/jsTree/source/plugins/jquery.tree.xml_nested.js"></script>
+</head>
+<body>
+	$(function () {
+		$("#demo").tree({
+	</script>
+	<div id="demo">
+	</div>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/xml_nested_with_languages.html
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/xml_nested_with_languages.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/demo/xml_nested_with_languages.html	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,39 @@
+<!DOCTYPE html
+<head>
+</head>
+<body>
+	$(function () {
+		$("#demo").tree({
+	</script>
+	<div id="demo">
+	</div>
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/lib/jquery.cookie.js
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/lib/jquery.cookie.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/lib/jquery.cookie.js	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,96 @@
+ * Cookie plugin
+ * Copyright (c) 2006 Klaus Hartl (stilbuero.de)
+ * Dual licensed under the MIT and GPL licenses:
+ * http://www.opensource.org/licenses/mit-license.php
+ * http://www.gnu.org/licenses/gpl.html
+ * Create a cookie with the given name and value and other optional parameters.
+ * @example $.cookie('the_cookie', 'the_value');
+ * @desc Set the value of a cookie.
+ * @example $.cookie('the_cookie', 'the_value', { expires: 7, path: '/', domain: 'jquery.com', secure: true });
+ * @desc Create a cookie with all available options.
+ * @desc Create a session cookie.
+ * @example $.cookie('the_cookie', null);
+ * @desc Delete a cookie by passing null as value. Keep in mind that you have to use the same path and domain
+ *       used when the cookie was set.
+ * @param String name The name of the cookie.
+ * @param String value The value of the cookie.
+ * @param Object options An object literal containing key/value pairs to provide optional cookie attributes.
+ * @option Number|Date expires Either an integer specifying the expiration date from now on in days or a Date object.
+ *                             If a negative value is specified (e.g. a date in the past), the cookie will be deleted.
+ *                             If set to null or omitted, the cookie will be a session cookie and will not be retained
+ *                             when the the browser exits.
+ * @option String path The value of the path atribute of the cookie (default: path of page that created the cookie).
+ * @option String domain The value of the domain attribute of the cookie (default: domain of page that created the cookie).
+ * @option Boolean secure If true, the secure attribute of the cookie will be set and the cookie transmission will
+ *                        require a secure protocol (like HTTPS).
+ * @type undefined
+ * @name $.cookie
+ * @cat Plugins/Cookie
+ * @author Klaus Hartl/klaus.hartl at stilbuero.de
+ * Get the value of a cookie with the given name.
+ * @example $.cookie('the_cookie');
+ * @desc Get the value of a cookie.
+ * @return The value of the cookie.
+ * @type String
+ * @name $.cookie
+jQuery.cookie = function(name, value, options) {
+    if (typeof value != 'undefined') { // name and value given, set cookie
+        options = options || {};
+        if (value === null) {
+            value = '';
+            options.expires = -1;
+        var expires = '';
+        if (options.expires && (typeof options.expires == 'number' || options.expires.toUTCString)) {
+            var date;
+            if (typeof options.expires == 'number') {
+                date = new Date();
+                date.setTime(date.getTime() + (options.expires * 24 * 60 * 60 * 1000));
+            } else {
+                date = options.expires;
+            expires = '; expires=' + date.toUTCString(); // use expires attribute, max-age is not supported by IE
+        // CAUTION: Needed to parenthesize options.path and options.domain
+        // in the following expressions, otherwise they evaluate to undefined
+        // in the packed version for some reason...
+        var path = options.path ? '; path=' + (options.path) : '';
+        var domain = options.domain ? '; domain=' + (options.domain) : '';
+        var secure = options.secure ? '; secure' : '';
+        document.cookie = [name, '=', encodeURIComponent(value), expires, path, domain, secure].join('');
+    } else { // only name given, get cookie
+        var cookieValue = null;
+        if (document.cookie && document.cookie != '') {
+            var cookies = document.cookie.split(';');
+            for (var i = 0; i < cookies.length; i++) {
+                var cookie = jQuery.trim(cookies[i]);
+                // Does this cookie string begin with the name we want?
+                if (cookie.substring(0, name.length + 1) == (name + '=')) {
+                    cookieValue = decodeURIComponent(cookie.substring(name.length + 1));
+                    break;
+        return cookieValue;
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/lib/jquery.hotkeys.js
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/lib/jquery.hotkeys.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/lib/jquery.hotkeys.js	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,244 @@
+(c) Copyrights 2007 - 2008
+Original idea by by Binny V A, http://www.openjs.com/scripts/events/keyboard_shortcuts/
+jQuery Plugin by Tzury Bar Yochay
+tzury.by at gmail.com
+http://evalinux.wordpress.com
+http://facebook.com/profile.php?id=513676303
+Project's sites:
+http://code.google.com/p/js-hotkeys/
+http://github.com/tzuryby/hotkeys/tree/master
+License: same as jQuery license.
+USAGE:
+    // simple usage
+    $(document).bind('keydown', 'Ctrl+c', function(){ alert('copy anyone?');});
+    // special options such as disableInIput
+    $(document).bind('keydown', {combi:'Ctrl+x', disableInInput: true} , function() {});
+Note:
+    This plugin wraps the following jQuery methods: $.fn.find, $.fn.bind and $.fn.unbind
+(function (jQuery){
+    // keep reference to the original $.fn.bind and $.fn.unbind
+    jQuery.fn.__bind__ = jQuery.fn.bind;
+    jQuery.fn.__unbind__ = jQuery.fn.unbind;
+    jQuery.fn.__find__ = jQuery.fn.find;
+    var hotkeys = {
+        version: '0.7.8',
+        override: /keydown|keypress|keyup/g,
+        triggersMap: {},
+        specialKeys: { 27: 'esc', 9: 'tab', 32:'space', 13: 'return', 8:'backspace', 145: 'scroll',
+            20: 'capslock', 144: 'numlock', 19:'pause', 45:'insert', 36:'home', 46:'del',
+            35:'end', 33: 'pageup', 34:'pagedown', 37:'left', 38:'up', 39:'right',40:'down',
+            112:'f1',113:'f2', 114:'f3', 115:'f4', 116:'f5', 117:'f6', 118:'f7', 119:'f8',
+            120:'f9', 121:'f10', 122:'f11', 123:'f12' },
+        shiftNums: { "`":"~", "1":"!", "2":"@", "3":"#", "4":"$", "5":"%", "6":"^", "7":"&",
+            "8":"*", "9":"(", "0":")", "-":"_", "=":"+", ";":":", "'":"\"", ",":"<",
+        newTrigger: function (type, combi, callback) {
+            // i.e. {'keyup': {'ctrl': {cb: callback, disableInInput: false}}}
+            var result = {};
+            result[type] = {};
+            result[type][combi] = {cb: callback, disableInInput: false};
+            return result;
+    // add firefox num pad char codes
+    if (jQuery.browser.mozilla){
+        hotkeys.specialKeys = jQuery.extend(hotkeys.specialKeys, { 96: '0', 97:'1', 98: '2', 99:
+            '3', 100: '4', 101: '5', 102: '6', 103: '7', 104: '8', 105: '9' });
+    // a wrapper around of $.fn.find
+    // see more at: http://groups.google.com/group/jquery-en/browse_thread/thread/18f9825e8d22f18d
+    jQuery.fn.find = function( selector ) {
+        this.query=selector;
+        return jQuery.fn.__find__.apply(this, arguments);
+    jQuery.fn.unbind = function (type, combi, fn){
+        if (jQuery.isFunction(combi)){
+            fn = combi;
+            combi = null;
+        if (combi && typeof combi === 'string'){
+            var selectorId = ((this.prevObject && this.prevObject.query) || (this[0].id && this[0].id) || this[0]).toString();
+            var hkTypes = type.split(' ');
+            for (var x=0; x<hkTypes.length; x++){
+                delete hotkeys.triggersMap[selectorId][hkTypes[x]][combi];
+        // call jQuery original unbind
+        return  this.__unbind__(type, fn);
+    jQuery.fn.bind = function(type, data, fn){
+        // grab keyup,keydown,keypress
+        var handle = type.match(hotkeys.override);
+        if (jQuery.isFunction(data) || !handle){
+            // call jQuery.bind only
+            return this.__bind__(type, data, fn);
+        else{
+            // split the job
+            var result = null,
+            // pass the rest to the original $.fn.bind
+            pass2jq = jQuery.trim(type.replace(hotkeys.override, ''));
+            // see if there are other types, pass them to the original $.fn.bind
+            if (pass2jq){
+                // call original jQuery.bind()
+                result = this.__bind__(pass2jq, data, fn);
+            if (typeof data === "string"){
+                data = {'combi': data};
+            if(data.combi){
+                for (var x=0; x < handle.length; x++){
+                    var eventType = handle[x];
+                    var combi = data.combi.toLowerCase(),
+                        trigger = hotkeys.newTrigger(eventType, combi, fn),
+                        selectorId = ((this.prevObject && this.prevObject.query) || (this[0].id && this[0].id) || this[0]).toString();
+                    //trigger[eventType][combi].propagate = data.propagate;
+                    trigger[eventType][combi].disableInInput = data.disableInInput;
+                    // first time selector is bounded
+                    if (!hotkeys.triggersMap[selectorId]) {
+                        hotkeys.triggersMap[selectorId] = trigger;
+                    // first time selector is bounded with this type
+                    else if (!hotkeys.triggersMap[selectorId][eventType]) {
+                        hotkeys.triggersMap[selectorId][eventType] = trigger[eventType];
+                    // make trigger point as array so more than one handler can be bound
+                    var mapPoint = hotkeys.triggersMap[selectorId][eventType][combi];
+                    if (!mapPoint){
+                        hotkeys.triggersMap[selectorId][eventType][combi] = [trigger[eventType][combi]];
+                    else if (mapPoint.constructor !== Array){
+                        hotkeys.triggersMap[selectorId][eventType][combi] = [mapPoint];
+                    else {
+                        hotkeys.triggersMap[selectorId][eventType][combi][mapPoint.length] = trigger[eventType][combi];
+                    // add attribute and call $.event.add per matched element
+                    this.each(function(){
+                        // jQuery wrapper for the current element
+                        var jqElem = jQuery(this);
+                        // element already associated with another collection
+                        if (jqElem.attr('hkId') && jqElem.attr('hkId') !== selectorId){
+                            selectorId = jqElem.attr('hkId') + ";" + selectorId;
+                        jqElem.attr('hkId', selectorId);
+                    result = this.__bind__(handle.join(' '), data, hotkeys.handler)
+            return result;
+    // work-around for opera and safari where (sometimes) the target is the element which was last
+    // clicked with the mouse and not the document event it would make sense to get the document
+    hotkeys.findElement = function (elem){
+        if (!jQuery(elem).attr('hkId')){
+            if (jQuery.browser.opera || jQuery.browser.safari){
+                while (!jQuery(elem).attr('hkId') && elem.parentNode){
+                    elem = elem.parentNode;
+        return elem;
+    // the event handler
+    hotkeys.handler = function(event) {
+        var target = hotkeys.findElement(event.currentTarget),
+            jTarget = jQuery(target),
+            ids = jTarget.attr('hkId');
+        if(ids){
+            ids = ids.split(';');
+            var code = event.which,
+                type = event.type,
+                special = hotkeys.specialKeys[code],
+                // prevent f5 overlapping with 't' (or f4 with 's', etc.)
+                character = !special && String.fromCharCode(code).toLowerCase(),
+                shift = event.shiftKey,
+                ctrl = event.ctrlKey,
+                // patch for jquery 1.2.5 && 1.2.6 see more at:
+                // http://groups.google.com/group/jquery-en/browse_thread/thread/83e10b3bb1f1c32b
+                alt = event.altKey || event.originalEvent.altKey,
+                mapPoint = null;
+            for (var x=0; x < ids.length; x++){
+                if (hotkeys.triggersMap[ids[x]][type]){
+                    mapPoint = hotkeys.triggersMap[ids[x]][type];
+                    break;
+            //find by: id.type.combi.options
+            if (mapPoint){
+                var trigger;
+                // event type is associated with the hkId
+                if(!shift && !ctrl && !alt) { // No Modifiers
+                    trigger = mapPoint[special] ||  (character && mapPoint[character]);
+                else{
+                    // check combinations (alt|ctrl|shift+anything)
+                    var modif = '';
+                    if(alt) modif +='alt+';
+                    if(ctrl) modif+= 'ctrl+';
+                    if(shift) modif += 'shift+';
+                    // modifiers + special keys or modifiers + character or modifiers + shift character or just shift character
+                    trigger = mapPoint[modif+special];
+                    if (!trigger){
+                        if (character){
+                            trigger = mapPoint[modif+character]
+                                || mapPoint[modif+hotkeys.shiftNums[character]]
+                                // '$' can be triggered as 'Shift+4' or 'Shift+$' or just '$'
+                                || (modif === 'shift+' && mapPoint[hotkeys.shiftNums[character]]);
+                if (trigger){
+                    var result = false;
+                    for (var x=0; x < trigger.length; x++){
+                        if(trigger[x].disableInInput){
+                            // double check event.currentTarget and event.target
+                            var elem = jQuery(event.target);
+                            if (jTarget.is("input") || jTarget.is("textarea")
+                                || elem.is("input") || elem.is("textarea")) {
+                                return true;
+                        // call the registered callback function
+                        result = result || trigger[x].cb.apply(this, [event]);
+                    return result;
+    // place it under window so it can be extended and overridden by others
+    window.hotkeys = hotkeys;
+    return jQuery;
+})(jQuery);
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/lib/jquery.js
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/lib/jquery.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/lib/jquery.js	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,6078 @@
+ * jQuery JavaScript Library v1.4.1
+ * http://jquery.com/
+ * Copyright 2010, John Resig
+ * Dual licensed under the MIT or GPL Version 2 licenses.
+ * http://jquery.org/license
+ * Includes Sizzle.js
+ * http://sizzlejs.com/
+ * Copyright 2010, The Dojo Foundation
+ * Released under the MIT, BSD, and GPL Licenses.
+ * Date: Mon Jan 25 19:43:33 2010 -0500
+(function( window, undefined ) {
+// Define a local copy of jQuery
+var jQuery = function( selector, context ) {
+		// The jQuery object is actually just the init constructor 'enhanced'
+		return new jQuery.fn.init( selector, context );
+	// Map over jQuery in case of overwrite
+	_jQuery = window.jQuery,
+	// Map over the $ in case of overwrite
+	_$ = window.$,
+	// Use the correct document accordingly with window argument (sandbox)
+	document = window.document,
+	// A central reference to the root jQuery(document)
+	rootjQuery,
+	// A simple way to check for HTML strings or ID strings
+	// (both of which we optimize for)
+	quickExpr = /^[^<]*(<[\w\W]+>)[^>]*$|^#([\w-]+)$/,
+	// Is it a simple selector
+	isSimple = /^.[^:#\[\.,]*$/,
+	// Check if a string has a non-whitespace character in it
+	rnotwhite = /\S/,
+	// Used for trimming whitespace
+	rtrim = /^(\s|\u00A0)+|(\s|\u00A0)+$/g,
+	// Match a standalone tag
+	rsingleTag = /^<(\w+)\s*\/?>(?:<\/\1>)?$/,
+	// Keep a UserAgent string for use with jQuery.browser
+	userAgent = navigator.userAgent,
+	// For matching the engine and version of the browser
+	browserMatch,
+	// Has the ready events already been bound?
+	readyBound = false,
+	// The functions to execute on DOM ready
+	readyList = [],
+	// The ready event handler
+	DOMContentLoaded,
+	// Save a reference to some core methods
+	toString = Object.prototype.toString,
+	hasOwnProperty = Object.prototype.hasOwnProperty,
+	push = Array.prototype.push,
+	slice = Array.prototype.slice,
+	indexOf = Array.prototype.indexOf;
+jQuery.fn = jQuery.prototype = {
+	init: function( selector, context ) {
+		var match, elem, ret, doc;
+		// Handle $(""), $(null), or $(undefined)
+		if ( !selector ) {
+			return this;
+		// Handle $(DOMElement)
+		if ( selector.nodeType ) {
+			this.context = this[0] = selector;
+			this.length = 1;
+			return this;
+		// Handle HTML strings
+		if ( typeof selector === "string" ) {
+			// Are we dealing with HTML string or an ID?
+			match = quickExpr.exec( selector );
+			// Verify a match, and that no context was specified for #id
+			if ( match && (match[1] || !context) ) {
+				// HANDLE: $(html) -> $(array)
+				if ( match[1] ) {
+					doc = (context ? context.ownerDocument || context : document);
+					// If a single string is passed in and it's a single tag
+					// just do a createElement and skip the rest
+					ret = rsingleTag.exec( selector );
+					if ( ret ) {
+						if ( jQuery.isPlainObject( context ) ) {
+							selector = [ document.createElement( ret[1] ) ];
+							jQuery.fn.attr.call( selector, context, true );
+						} else {
+							selector = [ doc.createElement( ret[1] ) ];
+					} else {
+						ret = buildFragment( [ match[1] ], [ doc ] );
+						selector = (ret.cacheable ? ret.fragment.cloneNode(true) : ret.fragment).childNodes;
+				// HANDLE: $("#id")
+				} else {
+					elem = document.getElementById( match[2] );
+					if ( elem ) {
+						// Handle the case where IE and Opera return items
+						// by name instead of ID
+						if ( elem.id !== match[2] ) {
+							return rootjQuery.find( selector );
+						// Otherwise, we inject the element directly into the jQuery object
+						this.length = 1;
+						this[0] = elem;
+					this.context = document;
+					this.selector = selector;
+					return this;
+			// HANDLE: $("TAG")
+			} else if ( !context && /^\w+$/.test( selector ) ) {
+				selector = document.getElementsByTagName( selector );
+			// HANDLE: $(expr, $(...))
+			} else if ( !context || context.jquery ) {
+				return (context || rootjQuery).find( selector );
+			// HANDLE: $(expr, context)
+			// (which is just equivalent to: $(context).find(expr)
+			} else {
+				return jQuery( context ).find( selector );
+		// HANDLE: $(function)
+		// Shortcut for document ready
+		} else if ( jQuery.isFunction( selector ) ) {
+			return rootjQuery.ready( selector );
+		if (selector.selector !== undefined) {
+			this.selector = selector.selector;
+			this.context = selector.context;
+		return jQuery.isArray( selector ) ?
+			this.setArray( selector ) :
+			jQuery.makeArray( selector, this );
+	// Start with an empty selector
+	selector: "",
+	// The current version of jQuery being used
+	jquery: "1.4.1",
+	// The default length of a jQuery object is 0
+	length: 0,
+	// The number of elements contained in the matched element set
+	size: function() {
+		return this.length;
+	toArray: function() {
+		return slice.call( this, 0 );
+	// Get the Nth element in the matched element set OR
+	// Get the whole matched element set as a clean array
+	get: function( num ) {
+		return num == null ?
+			// Return a 'clean' array
+			this.toArray() :
+			// Return just the object
+			( num < 0 ? this.slice(num)[ 0 ] : this[ num ] );
+	// Take an array of elements and push it onto the stack
+	// (returning the new matched element set)
+	pushStack: function( elems, name, selector ) {
+		// Build a new jQuery matched element set
+		var ret = jQuery( elems || null );
+		// Add the old object onto the stack (as a reference)
+		ret.prevObject = this;
+		ret.context = this.context;
+		if ( name === "find" ) {
+			ret.selector = this.selector + (this.selector ? " " : "") + selector;
+		} else if ( name ) {
+			ret.selector = this.selector + "." + name + "(" + selector + ")";
+		// Return the newly-formed element set
+		return ret;
+	// Force the current matched set of elements to become
+	// the specified array of elements (destroying the stack in the process)
+	// You should use pushStack() in order to do this, but maintain the stack
+	setArray: function( elems ) {
+		// Resetting the length to 0, then using the native Array push
+		// is a super-fast way to populate an object with array-like properties
+		this.length = 0;
+		push.apply( this, elems );
+		return this;
+	// Execute a callback for every element in the matched set.
+	// (You can seed the arguments with an array of args, but this is
+	// only used internally.)
+	each: function( callback, args ) {
+		return jQuery.each( this, callback, args );
+	ready: function( fn ) {
+		// Attach the listeners
+		jQuery.bindReady();
+		// If the DOM is already ready
+		if ( jQuery.isReady ) {
+			// Execute the function immediately
+			fn.call( document, jQuery );
+		// Otherwise, remember the function for later
+		} else if ( readyList ) {
+			// Add the function to the wait list
+			readyList.push( fn );
+		return this;
+	eq: function( i ) {
+		return i === -1 ?
+			this.slice( i ) :
+			this.slice( i, +i + 1 );
+	first: function() {
+		return this.eq( 0 );
+	last: function() {
+		return this.eq( -1 );
+	slice: function() {
+		return this.pushStack( slice.apply( this, arguments ),
+			"slice", slice.call(arguments).join(",") );
+	map: function( callback ) {
+		return this.pushStack( jQuery.map(this, function( elem, i ) {
+			return callback.call( elem, i, elem );
+	end: function() {
+		return this.prevObject || jQuery(null);
+	// For internal use only.
+	// Behaves like an Array's method, not like a jQuery method.
+	push: push,
+	sort: [].sort,
+	splice: [].splice
+// Give the init function the jQuery prototype for later instantiation
+jQuery.fn.init.prototype = jQuery.fn;
+jQuery.extend = jQuery.fn.extend = function() {
+	// copy reference to target object
+	var target = arguments[0] || {}, i = 1, length = arguments.length, deep = false, options, name, src, copy;
+	// Handle a deep copy situation
+	if ( typeof target === "boolean" ) {
+		deep = target;
+		target = arguments[1] || {};
+		// skip the boolean and the target
+		i = 2;
+	// Handle case when target is a string or something (possible in deep copy)
+	if ( typeof target !== "object" && !jQuery.isFunction(target) ) {
+		target = {};
+	// extend jQuery itself if only one argument is passed
+	if ( length === i ) {
+		target = this;
+		--i;
+	for ( ; i < length; i++ ) {
+		// Only deal with non-null/undefined values
+		if ( (options = arguments[ i ]) != null ) {
+			// Extend the base object
+			for ( name in options ) {
+				src = target[ name ];
+				copy = options[ name ];
+				// Prevent never-ending loop
+				if ( target === copy ) {
+					continue;
+				// Recurse if we're merging object literal values or arrays
+				if ( deep && copy && ( jQuery.isPlainObject(copy) || jQuery.isArray(copy) ) ) {
+					var clone = src && ( jQuery.isPlainObject(src) || jQuery.isArray(src) ) ? src
+						: jQuery.isArray(copy) ? [] : {};
+					// Never move original objects, clone them
+					target[ name ] = jQuery.extend( deep, clone, copy );
+				// Don't bring in undefined values
+				} else if ( copy !== undefined ) {
+					target[ name ] = copy;
+	// Return the modified object
+	return target;
+jQuery.extend({
+	noConflict: function( deep ) {
+		window.$ = _$;
+		if ( deep ) {
+			window.jQuery = _jQuery;
+		return jQuery;
+	// Is the DOM ready to be used? Set to true once it occurs.
+	isReady: false,
+	// Handle when the DOM is ready
+	ready: function() {
+		// Make sure that the DOM is not already loaded
+		if ( !jQuery.isReady ) {
+			// Make sure body exists, at least, in case IE gets a little overzealous (ticket #5443).
+			if ( !document.body ) {
+				return setTimeout( jQuery.ready, 13 );
+			// Remember that the DOM is ready
+			jQuery.isReady = true;
+			// If there are functions bound, to execute
+			if ( readyList ) {
+				// Execute all of them
+				var fn, i = 0;
+				while ( (fn = readyList[ i++ ]) ) {
+				// Reset the list of functions
+				readyList = null;
+			// Trigger any bound ready events
+			if ( jQuery.fn.triggerHandler ) {
+				jQuery( document ).triggerHandler( "ready" );
+	bindReady: function() {
+		if ( readyBound ) {
+			return;
+		readyBound = true;
+		// Catch cases where $(document).ready() is called after the
+		// browser event has already occurred.
+		if ( document.readyState === "complete" ) {
+			return jQuery.ready();
+		// Mozilla, Opera and webkit nightlies currently support this event
+		if ( document.addEventListener ) {
+			// Use the handy event callback
+			document.addEventListener( "DOMContentLoaded", DOMContentLoaded, false );
+			// A fallback to window.onload, that will always work
+			window.addEventListener( "load", jQuery.ready, false );
+		// If IE event model is used
+		} else if ( document.attachEvent ) {
+			// ensure firing before onload,
+			// maybe late but safe also for iframes
+			document.attachEvent("onreadystatechange", DOMContentLoaded);
+			window.attachEvent( "onload", jQuery.ready );
+			// If IE and not a frame
+			// continually check to see if the document is ready
+			var toplevel = false;
+			try {
+				toplevel = window.frameElement == null;
+			} catch(e) {}
+			if ( document.documentElement.doScroll && toplevel ) {
+				doScrollCheck();
+	// See test/unit/core.js for details concerning isFunction.
+	// Since version 1.3, DOM methods and functions like alert
+	// aren't supported. They return false on IE (#2968).
+	isFunction: function( obj ) {
+		return toString.call(obj) === "[object Function]";
+	isArray: function( obj ) {
+		return toString.call(obj) === "[object Array]";
+	isPlainObject: function( obj ) {
+		// Must be an Object.
+		// Because of IE, we also have to check the presence of the constructor property.
+		// Make sure that DOM nodes and window objects don't pass through, as well
+		if ( !obj || toString.call(obj) !== "[object Object]" || obj.nodeType || obj.setInterval ) {
+			return false;
+		// Not own constructor property must be Object
+		if ( obj.constructor
+			&& !hasOwnProperty.call(obj, "constructor")
+			&& !hasOwnProperty.call(obj.constructor.prototype, "isPrototypeOf") ) {
+			return false;
+		// Own properties are enumerated firstly, so to speed up,
+		// if last one is own, then all properties are own.
+		var key;
+		for ( key in obj ) {}
+		return key === undefined || hasOwnProperty.call( obj, key );
+	isEmptyObject: function( obj ) {
+		for ( var name in obj ) {
+			return false;
+		return true;
+	error: function( msg ) {
+		throw msg;
+	parseJSON: function( data ) {
+		if ( typeof data !== "string" || !data ) {
+			return null;
+		// Make sure the incoming data is actual JSON
+		// Logic borrowed from http://json.org/json2.js
+		if ( /^[\],:{}\s]*$/.test(data.replace(/\\(?:["\\\/bfnrt]|u[0-9a-fA-F]{4})/g, "@")
+			.replace(/"[^"\\\n\r]*"|true|false|null|-?\d+(?:\.\d*)?(?:[eE][+\-]?\d+)?/g, "]")
+			.replace(/(?:^|:|,)(?:\s*\[)+/g, "")) ) {
+			// Try to use the native JSON parser first
+			return window.JSON && window.JSON.parse ?
+				window.JSON.parse( data ) :
+				(new Function("return " + data))();
+		} else {
+			jQuery.error( "Invalid JSON: " + data );
+	noop: function() {},
+	// Evalulates a script in a global context
+	globalEval: function( data ) {
+		if ( data && rnotwhite.test(data) ) {
+			// Inspired by code by Andrea Giammarchi
+			// http://webreflection.blogspot.com/2007/08/global-scope-evaluation-and-dom.html
+			var head = document.getElementsByTagName("head")[0] || document.documentElement,
+				script = document.createElement("script");
+			script.type = "text/javascript";
+			if ( jQuery.support.scriptEval ) {
+				script.appendChild( document.createTextNode( data ) );
+			} else {
+				script.text = data;
+			// Use insertBefore instead of appendChild to circumvent an IE6 bug.
+			// This arises when a base node is used (#2709).
+			head.insertBefore( script, head.firstChild );
+			head.removeChild( script );
+	nodeName: function( elem, name ) {
+		return elem.nodeName && elem.nodeName.toUpperCase() === name.toUpperCase();
+	// args is for internal usage only
+	each: function( object, callback, args ) {
+		var name, i = 0,
+			length = object.length,
+			isObj = length === undefined || jQuery.isFunction(object);
+		if ( args ) {
+			if ( isObj ) {
+				for ( name in object ) {
+					if ( callback.apply( object[ name ], args ) === false ) {
+						break;
+			} else {
+				for ( ; i < length; ) {
+					if ( callback.apply( object[ i++ ], args ) === false ) {
+						break;
+		// A special, fast, case for the most common use of each
+		} else {
+			if ( isObj ) {
+					if ( callback.call( object[ name ], name, object[ name ] ) === false ) {
+						break;
+			} else {
+				for ( var value = object[0];
+					i < length && callback.call( value, i, value ) !== false; value = object[++i] ) {}
+		return object;
+	trim: function( text ) {
+		return (text || "").replace( rtrim, "" );
+	// results is for internal usage only
+	makeArray: function( array, results ) {
+		var ret = results || [];
+		if ( array != null ) {
+			// The window, strings (and functions) also have 'length'
+			// The extra typeof function check is to prevent crashes
+			// in Safari 2 (See: #3039)
+			if ( array.length == null || typeof array === "string" || jQuery.isFunction(array) || (typeof array !== "function" && array.setInterval) ) {
+				push.call( ret, array );
+			} else {
+				jQuery.merge( ret, array );
+		return ret;
+	inArray: function( elem, array ) {
+		if ( array.indexOf ) {
+			return array.indexOf( elem );
+		for ( var i = 0, length = array.length; i < length; i++ ) {
+			if ( array[ i ] === elem ) {
+				return i;
+		return -1;
+	merge: function( first, second ) {
+		var i = first.length, j = 0;
+		if ( typeof second.length === "number" ) {
+			for ( var l = second.length; j < l; j++ ) {
+				first[ i++ ] = second[ j ];
+		} else {
+			while ( second[j] !== undefined ) {
+				first[ i++ ] = second[ j++ ];
+		first.length = i;
+		return first;
+	grep: function( elems, callback, inv ) {
+		var ret = [];
+		// Go through the array, only saving the items
+		// that pass the validator function
+		for ( var i = 0, length = elems.length; i < length; i++ ) {
+			if ( !inv !== !callback( elems[ i ], i ) ) {
+				ret.push( elems[ i ] );
+		return ret;
+	// arg is for internal usage only
+	map: function( elems, callback, arg ) {
+		var ret = [], value;
+		// Go through the array, translating each of the items to their
+		// new value (or values).
+			value = callback( elems[ i ], i, arg );
+			if ( value != null ) {
+				ret[ ret.length ] = value;
+		return ret.concat.apply( [], ret );
+	// A global GUID counter for objects
+	guid: 1,
+	proxy: function( fn, proxy, thisObject ) {
+		if ( arguments.length === 2 ) {
+			if ( typeof proxy === "string" ) {
+				thisObject = fn;
+				fn = thisObject[ proxy ];
+				proxy = undefined;
+			} else if ( proxy && !jQuery.isFunction( proxy ) ) {
+				thisObject = proxy;
+		if ( !proxy && fn ) {
+			proxy = function() {
+				return fn.apply( thisObject || this, arguments );
+		// Set the guid of unique handler to the same of original handler, so it can be removed
+		if ( fn ) {
+			proxy.guid = fn.guid = fn.guid || proxy.guid || jQuery.guid++;
+		// So proxy can be declared as an argument
+		return proxy;
+	// Use of jQuery.browser is frowned upon.
+	// More details: http://docs.jquery.com/Utilities/jQuery.browser
+	uaMatch: function( ua ) {
+		ua = ua.toLowerCase();
+		var match = /(webkit)[ \/]([\w.]+)/.exec( ua ) ||
+			/(opera)(?:.*version)?[ \/]([\w.]+)/.exec( ua ) ||
+			/(msie) ([\w.]+)/.exec( ua ) ||
+			!/compatible/.test( ua ) && /(mozilla)(?:.*? rv:([\w.]+))?/.exec( ua ) ||
+		return { browser: match[1] || "", version: match[2] || "0" };
+	browser: {}
+browserMatch = jQuery.uaMatch( userAgent );
+if ( browserMatch.browser ) {
+	jQuery.browser[ browserMatch.browser ] = true;
+	jQuery.browser.version = browserMatch.version;
+// Deprecated, use jQuery.browser.webkit instead
+if ( jQuery.browser.webkit ) {
+	jQuery.browser.safari = true;
+if ( indexOf ) {
+	jQuery.inArray = function( elem, array ) {
+		return indexOf.call( array, elem );
+// All jQuery objects should point back to these
+rootjQuery = jQuery(document);
+// Cleanup functions for the document ready method
+if ( document.addEventListener ) {
+	DOMContentLoaded = function() {
+		document.removeEventListener( "DOMContentLoaded", DOMContentLoaded, false );
+		jQuery.ready();
+} else if ( document.attachEvent ) {
+			document.detachEvent( "onreadystatechange", DOMContentLoaded );
+			jQuery.ready();
+// The DOM ready check for Internet Explorer
+function doScrollCheck() {
+		return;
+	try {
+		// If IE is used, use the trick by Diego Perini
+		// http://javascript.nwbox.com/IEContentLoaded/
+		document.documentElement.doScroll("left");
+	} catch( error ) {
+		setTimeout( doScrollCheck, 1 );
+		return;
+	// and execute any waiting functions
+	jQuery.ready();
+function evalScript( i, elem ) {
+	if ( elem.src ) {
+		jQuery.ajax({
+			url: elem.src,
+			async: false,
+			dataType: "script"
+	} else {
+		jQuery.globalEval( elem.text || elem.textContent || elem.innerHTML || "" );
+	if ( elem.parentNode ) {
+		elem.parentNode.removeChild( elem );
+// Mutifunctional method to get and set values to a collection
+// The value/s can be optionally by executed if its a function
+function access( elems, key, value, exec, fn, pass ) {
+	var length = elems.length;
+	// Setting many attributes
+	if ( typeof key === "object" ) {
+		for ( var k in key ) {
+			access( elems, k, key[k], exec, fn, value );
+		return elems;
+	// Setting one attribute
+	if ( value !== undefined ) {
+		// Optionally, function values get executed if exec is true
+		exec = !pass && exec && jQuery.isFunction(value);
+		for ( var i = 0; i < length; i++ ) {
+			fn( elems[i], key, exec ? value.call( elems[i], i, fn( elems[i], key ) ) : value, pass );
+		return elems;
+	// Getting an attribute
+	return length ? fn( elems[0], key ) : null;
+function now() {
+	return (new Date).getTime();
+(function() {
+	jQuery.support = {};
+	var root = document.documentElement,
+		script = document.createElement("script"),
+		div = document.createElement("div"),
+		id = "script" + now();
+	div.style.display = "none";
+	div.innerHTML = "   <link/><table></table><a href='/a' style='color:red;float:left;opacity:.55;'>a</a><input type='checkbox'/>";
+	var all = div.getElementsByTagName("*"),
+		a = div.getElementsByTagName("a")[0];
+	// Can't get basic test support
+	if ( !all || !all.length || !a ) {
+		return;
+		// IE strips leading whitespace when .innerHTML is used
+		leadingWhitespace: div.firstChild.nodeType === 3,
+		// Make sure that tbody elements aren't automatically inserted
+		// IE will insert them into empty tables
+		tbody: !div.getElementsByTagName("tbody").length,
+		// Make sure that link elements get serialized correctly by innerHTML
+		// This requires a wrapper element in IE
+		htmlSerialize: !!div.getElementsByTagName("link").length,
+		// Get the style information from getAttribute
+		// (IE uses .cssText insted)
+		style: /red/.test( a.getAttribute("style") ),
+		// Make sure that URLs aren't manipulated
+		// (IE normalizes it by default)
+		hrefNormalized: a.getAttribute("href") === "/a",
+		// Make sure that element opacity exists
+		// (IE uses filter instead)
+		// Use a regex to work around a WebKit issue. See #5145
+		opacity: /^0.55$/.test( a.style.opacity ),
+		// Verify style float existence
+		// (IE uses styleFloat instead of cssFloat)
+		cssFloat: !!a.style.cssFloat,
+		// Make sure that if no value is specified for a checkbox
+		// that it defaults to "on".
+		// (WebKit defaults to "" instead)
+		checkOn: div.getElementsByTagName("input")[0].value === "on",
+		// Make sure that a selected-by-default option has a working selected property.
+		// (WebKit defaults to false instead of true, IE too, if it's in an optgroup)
+		optSelected: document.createElement("select").appendChild( document.createElement("option") ).selected,
+		// Will be defined later
+		checkClone: false,
+		scriptEval: false,
+		noCloneEvent: true,
+		boxModel: null
+	try {
+		script.appendChild( document.createTextNode( "window." + id + "=1;" ) );
+	} catch(e) {}
+	root.insertBefore( script, root.firstChild );
+	// Make sure that the execution of code works by injecting a script
+	// tag with appendChild/createTextNode
+	// (IE doesn't support this, fails, and uses .text instead)
+	if ( window[ id ] ) {
+		jQuery.support.scriptEval = true;
+		delete window[ id ];
+	root.removeChild( script );
+	if ( div.attachEvent && div.fireEvent ) {
+		div.attachEvent("onclick", function click() {
+			// Cloning a node shouldn't copy over any
+			// bound event handlers (IE does this)
+			jQuery.support.noCloneEvent = false;
+			div.detachEvent("onclick", click);
+		div.cloneNode(true).fireEvent("onclick");
+	div = document.createElement("div");
+	div.innerHTML = "<input type='radio' name='radiotest' checked='checked'/>";
+	var fragment = document.createDocumentFragment();
+	fragment.appendChild( div.firstChild );
+	// WebKit doesn't clone checked state correctly in fragments
+	jQuery.support.checkClone = fragment.cloneNode(true).cloneNode(true).lastChild.checked;
+	// Figure out if the W3C box model works as expected
+	// document.body must exist before we can do this
+	jQuery(function() {
+		var div = document.createElement("div");
+		div.style.width = div.style.paddingLeft = "1px";
+		document.body.appendChild( div );
+		jQuery.boxModel = jQuery.support.boxModel = div.offsetWidth === 2;
+		document.body.removeChild( div ).style.display = 'none';
+		div = null;
+	// Technique from Juriy Zaytsev
+	// http://thinkweb2.com/projects/prototype/detecting-event-support-without-browser-sniffing/
+	var eventSupported = function( eventName ) {
+		var el = document.createElement("div");
+		eventName = "on" + eventName;
+		var isSupported = (eventName in el);
+		if ( !isSupported ) {
+			el.setAttribute(eventName, "return;");
+			isSupported = typeof el[eventName] === "function";
+		el = null;
+		return isSupported;
+	jQuery.support.submitBubbles = eventSupported("submit");
+	jQuery.support.changeBubbles = eventSupported("change");
+	// release memory in IE
+	root = script = div = all = a = null;
+jQuery.props = {
+	"for": "htmlFor",
+	"class": "className",
+	readonly: "readOnly",
+	maxlength: "maxLength",
+	cellspacing: "cellSpacing",
+	rowspan: "rowSpan",
+	colspan: "colSpan",
+	tabindex: "tabIndex",
+	usemap: "useMap",
+	frameborder: "frameBorder"
+var expando = "jQuery" + now(), uuid = 0, windowData = {};
+var emptyObject = {};
+jQuery.extend({
+	cache: {},
+	expando:expando,
+	// The following elements throw uncatchable exceptions if you
+	// attempt to add expando properties to them.
+	noData: {
+		"embed": true,
+		"object": true,
+		"applet": true
+	data: function( elem, name, data ) {
+		if ( elem.nodeName && jQuery.noData[elem.nodeName.toLowerCase()] ) {
+			return;
+		elem = elem == window ?
+			windowData :
+			elem;
+		var id = elem[ expando ], cache = jQuery.cache, thisCache;
+		// Handle the case where there's no name immediately
+		if ( !name && !id ) {
+			return null;
+		// Compute a unique ID for the element
+		if ( !id ) {
+			id = ++uuid;
+		// Avoid generating a new cache unless none exists and we
+		// want to manipulate it.
+		if ( typeof name === "object" ) {
+			elem[ expando ] = id;
+			thisCache = cache[ id ] = jQuery.extend(true, {}, name);
+		} else if ( cache[ id ] ) {
+			thisCache = cache[ id ];
+		} else if ( typeof data === "undefined" ) {
+			thisCache = emptyObject;
+		} else {
+			thisCache = cache[ id ] = {};
+		// Prevent overriding the named cache with undefined values
+		if ( data !== undefined ) {
+			thisCache[ name ] = data;
+		return typeof name === "string" ? thisCache[ name ] : thisCache;
+	removeData: function( elem, name ) {
+			return;
+			windowData :
+			elem;
+		var id = elem[ expando ], cache = jQuery.cache, thisCache = cache[ id ];
+		// If we want to remove a specific section of the element's data
+		if ( name ) {
+			if ( thisCache ) {
+				// Remove the section of cache data
+				delete thisCache[ name ];
+				// If we've removed all the data, remove the element's cache
+				if ( jQuery.isEmptyObject(thisCache) ) {
+					jQuery.removeData( elem );
+		// Otherwise, we want to remove all of the element's data
+		} else {
+			// Clean up the element expando
+			try {
+				delete elem[ expando ];
+			} catch( e ) {
+				// IE has trouble directly removing the expando
+				// but it's ok with using removeAttribute
+				if ( elem.removeAttribute ) {
+					elem.removeAttribute( expando );
+			// Completely remove the data cache
+			delete cache[ id ];
+jQuery.fn.extend({
+	data: function( key, value ) {
+		if ( typeof key === "undefined" && this.length ) {
+			return jQuery.data( this[0] );
+		} else if ( typeof key === "object" ) {
+			return this.each(function() {
+				jQuery.data( this, key );
+		var parts = key.split(".");
+		parts[1] = parts[1] ? "." + parts[1] : "";
+		if ( value === undefined ) {
+			var data = this.triggerHandler("getData" + parts[1] + "!", [parts[0]]);
+			if ( data === undefined && this.length ) {
+				data = jQuery.data( this[0], key );
+			return data === undefined && parts[1] ?
+				this.data( parts[0] ) :
+				data;
+		} else {
+			return this.trigger("setData" + parts[1] + "!", [parts[0], value]).each(function() {
+				jQuery.data( this, key, value );
+	removeData: function( key ) {
+			jQuery.removeData( this, key );
+jQuery.extend({
+	queue: function( elem, type, data ) {
+		if ( !elem ) {
+			return;
+		type = (type || "fx") + "queue";
+		var q = jQuery.data( elem, type );
+		// Speed up dequeue by getting out quickly if this is just a lookup
+		if ( !data ) {
+			return q || [];
+		if ( !q || jQuery.isArray(data) ) {
+			q = jQuery.data( elem, type, jQuery.makeArray(data) );
+		} else {
+			q.push( data );
+		return q;
+	dequeue: function( elem, type ) {
+		type = type || "fx";
+		var queue = jQuery.queue( elem, type ), fn = queue.shift();
+		// If the fx queue is dequeued, always remove the progress sentinel
+		if ( fn === "inprogress" ) {
+			fn = queue.shift();
+		if ( fn ) {
+			// Add a progress sentinel to prevent the fx queue from being
+			// automatically dequeued
+			if ( type === "fx" ) {
+				queue.unshift("inprogress");
+			fn.call(elem, function() {
+				jQuery.dequeue(elem, type);
+jQuery.fn.extend({
+	queue: function( type, data ) {
+		if ( typeof type !== "string" ) {
+			data = type;
+			type = "fx";
+		if ( data === undefined ) {
+			return jQuery.queue( this[0], type );
+		return this.each(function( i, elem ) {
+			var queue = jQuery.queue( this, type, data );
+			if ( type === "fx" && queue[0] !== "inprogress" ) {
+				jQuery.dequeue( this, type );
+	dequeue: function( type ) {
+	// Based off of the plugin by Clint Helfers, with permission.
+	// http://blindsignals.com/index.php/2009/07/jquery-delay/
+	delay: function( time, type ) {
+		time = jQuery.fx ? jQuery.fx.speeds[time] || time : time;
+		return this.queue( type, function() {
+			var elem = this;
+			setTimeout(function() {
+				jQuery.dequeue( elem, type );
+			}, time );
+	clearQueue: function( type ) {
+		return this.queue( type || "fx", [] );
+var rclass = /[\n\t]/g,
+	rspace = /\s+/,
+	rreturn = /\r/g,
+	rspecialurl = /href|src|style/,
+	rtype = /(button|input)/i,
+	rfocusable = /(button|input|object|select|textarea)/i,
+	rclickable = /^(a|area)$/i,
+	rradiocheck = /radio|checkbox/;
+jQuery.fn.extend({
+	attr: function( name, value ) {
+		return access( this, name, value, true, jQuery.attr );
+	removeAttr: function( name, fn ) {
+		return this.each(function(){
+			jQuery.attr( this, name, "" );
+			if ( this.nodeType === 1 ) {
+				this.removeAttribute( name );
+	addClass: function( value ) {
+		if ( jQuery.isFunction(value) ) {
+			return this.each(function(i) {
+				var self = jQuery(this);
+				self.addClass( value.call(this, i, self.attr("class")) );
+		if ( value && typeof value === "string" ) {
+			var classNames = (value || "").split( rspace );
+			for ( var i = 0, l = this.length; i < l; i++ ) {
+				var elem = this[i];
+				if ( elem.nodeType === 1 ) {
+					if ( !elem.className ) {
+						elem.className = value;
+					} else {
+						var className = " " + elem.className + " ";
+						for ( var c = 0, cl = classNames.length; c < cl; c++ ) {
+							if ( className.indexOf( " " + classNames[c] + " " ) < 0 ) {
+								elem.className += " " + classNames[c];
+		return this;
+	removeClass: function( value ) {
+				self.removeClass( value.call(this, i, self.attr("class")) );
+		if ( (value && typeof value === "string") || value === undefined ) {
+			var classNames = (value || "").split(rspace);
+				if ( elem.nodeType === 1 && elem.className ) {
+					if ( value ) {
+						var className = (" " + elem.className + " ").replace(rclass, " ");
+							className = className.replace(" " + classNames[c] + " ", " ");
+						elem.className = className.substring(1, className.length - 1);
+					} else {
+						elem.className = "";
+		return this;
+	toggleClass: function( value, stateVal ) {
+		var type = typeof value, isBool = typeof stateVal === "boolean";
+		if ( jQuery.isFunction( value ) ) {
+				self.toggleClass( value.call(this, i, self.attr("class"), stateVal), stateVal );
+			if ( type === "string" ) {
+				// toggle individual class names
+				var className, i = 0, self = jQuery(this),
+					state = stateVal,
+					classNames = value.split( rspace );
+				while ( (className = classNames[ i++ ]) ) {
+					// check each className given, space seperated list
+					state = isBool ? state : !self.hasClass( className );
+					self[ state ? "addClass" : "removeClass" ]( className );
+			} else if ( type === "undefined" || type === "boolean" ) {
+				if ( this.className ) {
+					// store className if set
+					jQuery.data( this, "__className__", this.className );
+				// toggle whole className
+				this.className = this.className || value === false ? "" : jQuery.data( this, "__className__" ) || "";
+	hasClass: function( selector ) {
+		var className = " " + selector + " ";
+			if ( (" " + this[i].className + " ").replace(rclass, " ").indexOf( className ) > -1 ) {
+				return true;
+		return false;
+	val: function( value ) {
+			var elem = this[0];
+			if ( elem ) {
+				if ( jQuery.nodeName( elem, "option" ) ) {
+					return (elem.attributes.value || {}).specified ? elem.value : elem.text;
+				// We need to handle select boxes special
+				if ( jQuery.nodeName( elem, "select" ) ) {
+					var index = elem.selectedIndex,
+						values = [],
+						options = elem.options,
+						one = elem.type === "select-one";
+					// Nothing was selected
+					if ( index < 0 ) {
+						return null;
+					// Loop through all the selected options
+					for ( var i = one ? index : 0, max = one ? index + 1 : options.length; i < max; i++ ) {
+						var option = options[ i ];
+						if ( option.selected ) {
+							// Get the specifc value for the option
+							value = jQuery(option).val();
+							// We don't need an array for one selects
+							if ( one ) {
+								return value;
+							// Multi-Selects return an array
+							values.push( value );
+					return values;
+				// Handle the case where in Webkit "" is returned instead of "on" if a value isn't specified
+				if ( rradiocheck.test( elem.type ) && !jQuery.support.checkOn ) {
+					return elem.getAttribute("value") === null ? "on" : elem.value;
+				// Everything else, we just grab the value
+				return (elem.value || "").replace(rreturn, "");
+			return undefined;
+		var isFunction = jQuery.isFunction(value);
+			var self = jQuery(this), val = value;
+			if ( this.nodeType !== 1 ) {
+				return;
+			if ( isFunction ) {
+				val = value.call(this, i, self.val());
+			// Typecast each time if the value is a Function and the appended
+			// value is therefore different each time.
+			if ( typeof val === "number" ) {
+				val += "";
+			if ( jQuery.isArray(val) && rradiocheck.test( this.type ) ) {
+				this.checked = jQuery.inArray( self.val(), val ) >= 0;
+			} else if ( jQuery.nodeName( this, "select" ) ) {
+				var values = jQuery.makeArray(val);
+				jQuery( "option", this ).each(function() {
+					this.selected = jQuery.inArray( jQuery(this).val(), values ) >= 0;
+				if ( !values.length ) {
+					this.selectedIndex = -1;
+			} else {
+				this.value = val;
+jQuery.extend({
+	attrFn: {
+		val: true,
+		css: true,
+		html: true,
+		text: true,
+		data: true,
+		width: true,
+		height: true,
+		offset: true
+	attr: function( elem, name, value, pass ) {
+		// don't set attributes on text and comment nodes
+		if ( !elem || elem.nodeType === 3 || elem.nodeType === 8 ) {
+			return undefined;
+		if ( pass && name in jQuery.attrFn ) {
+			return jQuery(elem)[name](value);
+		var notxml = elem.nodeType !== 1 || !jQuery.isXMLDoc( elem ),
+			// Whether we are setting (or getting)
+			set = value !== undefined;
+		// Try to normalize/fix the name
+		name = notxml && jQuery.props[ name ] || name;
+		// Only do all the following if this is a node (faster for style)
+			// These attributes require special treatment
+			var special = rspecialurl.test( name );
+			// Safari mis-reports the default selected property of an option
+			// Accessing the parent's selectedIndex property fixes it
+			if ( name === "selected" && !jQuery.support.optSelected ) {
+				var parent = elem.parentNode;
+				if ( parent ) {
+					parent.selectedIndex;
+					// Make sure that it also works with optgroups, see #5701
+					if ( parent.parentNode ) {
+						parent.parentNode.selectedIndex;
+			// If applicable, access the attribute via the DOM 0 way
+			if ( name in elem && notxml && !special ) {
+				if ( set ) {
+					// We can't allow the type property to be changed (since it causes problems in IE)
+					if ( name === "type" && rtype.test( elem.nodeName ) && elem.parentNode ) {
+						jQuery.error( "type property can't be changed" );
+					elem[ name ] = value;
+				// browsers index elements by id/name on forms, give priority to attributes.
+				if ( jQuery.nodeName( elem, "form" ) && elem.getAttributeNode(name) ) {
+					return elem.getAttributeNode( name ).nodeValue;
+				// elem.tabIndex doesn't always return the correct value when it hasn't been explicitly set
+				// http://fluidproject.org/blog/2008/01/09/getting-setting-and-removing-tabindex-values-with-javascript/
+				if ( name === "tabIndex" ) {
+					var attributeNode = elem.getAttributeNode( "tabIndex" );
+					return attributeNode && attributeNode.specified ?
+						attributeNode.value :
+						rfocusable.test( elem.nodeName ) || rclickable.test( elem.nodeName ) && elem.href ?
+							0 :
+							undefined;
+				return elem[ name ];
+			if ( !jQuery.support.style && notxml && name === "style" ) {
+				if ( set ) {
+					elem.style.cssText = "" + value;
+				return elem.style.cssText;
+			if ( set ) {
+				// convert the value to a string (all browsers do this but IE) see #1070
+				elem.setAttribute( name, "" + value );
+			var attr = !jQuery.support.hrefNormalized && notxml && special ?
+					// Some attributes require a special call on IE
+					elem.getAttribute( name, 2 ) :
+					elem.getAttribute( name );
+			// Non-existent attributes return null, we normalize to undefined
+			return attr === null ? undefined : attr;
+		// elem is actually elem.style ... set the style
+		// Using attr for specific style information is now deprecated. Use style insead.
+		return jQuery.style( elem, name, value );
+var fcleanup = function( nm ) {
+	return nm.replace(/[^\w\s\.\|`]/g, function( ch ) {
+		return "\\" + ch;
+ * A number of helper functions used for managing events.
+ * Many of the ideas behind this code originated from
+ * Dean Edwards' addEvent library.
+jQuery.event = {
+	// Bind an event to an element
+	// Original by Dean Edwards
+	add: function( elem, types, handler, data ) {
+		if ( elem.nodeType === 3 || elem.nodeType === 8 ) {
+			return;
+		// For whatever reason, IE has trouble passing the window object
+		// around, causing it to be cloned in the process
+		if ( elem.setInterval && ( elem !== window && !elem.frameElement ) ) {
+			elem = window;
+		// Make sure that the function being executed has a unique ID
+		if ( !handler.guid ) {
+			handler.guid = jQuery.guid++;
+		// if data is passed, bind to handler
+			// Create temporary function pointer to original handler
+			var fn = handler;
+			// Create unique handler function, wrapped around original handler
+			handler = jQuery.proxy( fn );
+			// Store data in unique handler
+			handler.data = data;
+		// Init the element's event structure
+		var events = jQuery.data( elem, "events" ) || jQuery.data( elem, "events", {} ),
+			handle = jQuery.data( elem, "handle" ), eventHandle;
+		if ( !handle ) {
+			eventHandle = function() {
+				// Handle the second event of a trigger and when
+				// an event is called after a page has unloaded
+				return typeof jQuery !== "undefined" && !jQuery.event.triggered ?
+					jQuery.event.handle.apply( eventHandle.elem, arguments ) :
+					undefined;
+			handle = jQuery.data( elem, "handle", eventHandle );
+		// If no handle is found then we must be trying to bind to one of the
+		// banned noData elements
+		if ( !handle ) {
+			return;
+		// Add elem as a property of the handle function
+		// This is to prevent a memory leak with non-native
+		// event in IE.
+		handle.elem = elem;
+		// Handle multiple events separated by a space
+		// jQuery(...).bind("mouseover mouseout", fn);
+		types = types.split( /\s+/ );
+		var type, i = 0;
+		while ( (type = types[ i++ ]) ) {
+			// Namespaced event handlers
+			var namespaces = type.split(".");
+			type = namespaces.shift();
+			if ( i > 1 ) {
+				handler = jQuery.proxy( handler );
+			handler.type = namespaces.slice(0).sort().join(".");
+			// Get the current list of functions bound to this event
+			var handlers = events[ type ],
+				special = this.special[ type ] || {};
+			// Init the event handler queue
+			if ( !handlers ) {
+				handlers = events[ type ] = {};
+				// Check for a special event handler
+				// Only use addEventListener/attachEvent if the special
+				// events handler returns false
+				if ( !special.setup || special.setup.call( elem, data, namespaces, handler) === false ) {
+					// Bind the global event handler to the element
+					if ( elem.addEventListener ) {
+						elem.addEventListener( type, handle, false );
+					} else if ( elem.attachEvent ) {
+						elem.attachEvent( "on" + type, handle );
+			if ( special.add ) {
+				var modifiedHandler = special.add.call( elem, handler, data, namespaces, handlers );
+				if ( modifiedHandler && jQuery.isFunction( modifiedHandler ) ) {
+					modifiedHandler.guid = modifiedHandler.guid || handler.guid;
+					modifiedHandler.data = modifiedHandler.data || handler.data;
+					modifiedHandler.type = modifiedHandler.type || handler.type;
+					handler = modifiedHandler;
+			// Add the function to the element's handler list
+			handlers[ handler.guid ] = handler;
+			// Keep track of which events have been used, for global triggering
+			this.global[ type ] = true;
+		// Nullify elem to prevent memory leaks in IE
+		elem = null;
+	global: {},
+	// Detach an event or set of events from an element
+	remove: function( elem, types, handler ) {
+		// don't do events on text and comment nodes
+			return;
+		var events = jQuery.data( elem, "events" ), ret, type, fn;
+		if ( events ) {
+			// Unbind all events for the element
+			if ( types === undefined || (typeof types === "string" && types.charAt(0) === ".") ) {
+				for ( type in events ) {
+					this.remove( elem, type + (types || "") );
+			} else {
+				// types is actually an event object here
+				if ( types.type ) {
+					handler = types.handler;
+					types = types.type;
+				// jQuery(...).unbind("mouseover mouseout", fn);
+				types = types.split(/\s+/);
+				var i = 0;
+					var all = !namespaces.length,
+						cleaned = jQuery.map( namespaces.slice(0).sort(), fcleanup ),
+						namespace = new RegExp("(^|\\.)" + cleaned.join("\\.(?:.*\\.)?") + "(\\.|$)"),
+					if ( events[ type ] ) {
+						// remove the given handler for the given type
+						if ( handler ) {
+							fn = events[ type ][ handler.guid ];
+							delete events[ type ][ handler.guid ];
+						// remove all handlers for the given type
+						} else {
+							for ( var handle in events[ type ] ) {
+								// Handle the removal of namespaced events
+								if ( all || namespace.test( events[ type ][ handle ].type ) ) {
+									delete events[ type ][ handle ];
+						if ( special.remove ) {
+							special.remove.call( elem, namespaces, fn);
+						// remove generic event handler if no more handlers exist
+						for ( ret in events[ type ] ) {
+							break;
+						if ( !ret ) {
+							if ( !special.teardown || special.teardown.call( elem, namespaces ) === false ) {
+								if ( elem.removeEventListener ) {
+									elem.removeEventListener( type, jQuery.data( elem, "handle" ), false );
+								} else if ( elem.detachEvent ) {
+									elem.detachEvent( "on" + type, jQuery.data( elem, "handle" ) );
+							ret = null;
+							delete events[ type ];
+			// Remove the expando if it's no longer used
+			for ( ret in events ) {
+				break;
+			if ( !ret ) {
+				var handle = jQuery.data( elem, "handle" );
+				if ( handle ) {
+					handle.elem = null;
+				jQuery.removeData( elem, "events" );
+				jQuery.removeData( elem, "handle" );
+	// bubbling is internal
+	trigger: function( event, data, elem /*, bubbling */ ) {
+		// Event object or event type
+		var type = event.type || event,
+			bubbling = arguments[3];
+		if ( !bubbling ) {
+			event = typeof event === "object" ?
+				// jQuery.Event object
+				event[expando] ? event :
+				// Object literal
+				jQuery.extend( jQuery.Event(type), event ) :
+				// Just the event type (string)
+				jQuery.Event(type);
+			if ( type.indexOf("!") >= 0 ) {
+				event.type = type = type.slice(0, -1);
+				event.exclusive = true;
+			// Handle a global trigger
+			if ( !elem ) {
+				// Don't bubble custom events when global (to avoid too much overhead)
+				event.stopPropagation();
+				// Only trigger if we've ever bound an event for it
+				if ( this.global[ type ] ) {
+					jQuery.each( jQuery.cache, function() {
+						if ( this.events && this.events[type] ) {
+							jQuery.event.trigger( event, data, this.handle.elem );
+			// Handle triggering a single element
+				return undefined;
+			// Clean up in case it is reused
+			event.result = undefined;
+			event.target = elem;
+			// Clone the incoming data, if any
+			data = jQuery.makeArray( data );
+			data.unshift( event );
+		event.currentTarget = elem;
+		// Trigger the event, it is assumed that "handle" is a function
+		if ( handle ) {
+			handle.apply( elem, data );
+		var parent = elem.parentNode || elem.ownerDocument;
+		// Trigger an inline bound script
+		try {
+			if ( !(elem && elem.nodeName && jQuery.noData[elem.nodeName.toLowerCase()]) ) {
+				if ( elem[ "on" + type ] && elem[ "on" + type ].apply( elem, data ) === false ) {
+					event.result = false;
+		// prevent IE from throwing an error for some elements with some event types, see #3533
+		} catch (e) {}
+		if ( !event.isPropagationStopped() && parent ) {
+			jQuery.event.trigger( event, data, parent, true );
+		} else if ( !event.isDefaultPrevented() ) {
+			var target = event.target, old,
+				isClick = jQuery.nodeName(target, "a") && type === "click";
+			if ( !isClick && !(target && target.nodeName && jQuery.noData[target.nodeName.toLowerCase()]) ) {
+				try {
+					if ( target[ type ] ) {
+						// Make sure that we don't accidentally re-trigger the onFOO events
+						old = target[ "on" + type ];
+						if ( old ) {
+							target[ "on" + type ] = null;
+						this.triggered = true;
+						target[ type ]();
+				} catch (e) {}
+				if ( old ) {
+					target[ "on" + type ] = old;
+				this.triggered = false;
+	handle: function( event ) {
+		// returned undefined or false
+		var all, handlers;
+		event = arguments[0] = jQuery.event.fix( event || window.event );
+		event.currentTarget = this;
+		var namespaces = event.type.split(".");
+		event.type = namespaces.shift();
+		// Cache this now, all = true means, any handler
+		all = !namespaces.length && !event.exclusive;
+		var namespace = new RegExp("(^|\\.)" + namespaces.slice(0).sort().join("\\.(?:.*\\.)?") + "(\\.|$)");
+		handlers = ( jQuery.data(this, "events") || {} )[ event.type ];
+		for ( var j in handlers ) {
+			var handler = handlers[ j ];
+			// Filter the functions by class
+			if ( all || namespace.test(handler.type) ) {
+				// Pass in a reference to the handler function itself
+				// So that we can later remove it
+				event.handler = handler;
+				event.data = handler.data;
+				var ret = handler.apply( this, arguments );
+				if ( ret !== undefined ) {
+					event.result = ret;
+					if ( ret === false ) {
+						event.preventDefault();
+				if ( event.isImmediatePropagationStopped() ) {
+					break;
+		return event.result;
+	props: "altKey attrChange attrName bubbles button cancelable charCode clientX clientY ctrlKey currentTarget data detail eventPhase fromElement handler keyCode layerX layerY metaKey newValue offsetX offsetY originalTarget pageX pageY prevValue relatedNode relatedTarget screenX screenY shiftKey srcElement target toElement view wheelDelta which".split(" "),
+	fix: function( event ) {
+		if ( event[ expando ] ) {
+			return event;
+		// store a copy of the original event object
+		// and "clone" to set read-only properties
+		var originalEvent = event;
+		event = jQuery.Event( originalEvent );
+		for ( var i = this.props.length, prop; i; ) {
+			prop = this.props[ --i ];
+			event[ prop ] = originalEvent[ prop ];
+		// Fix target property, if necessary
+		if ( !event.target ) {
+			event.target = event.srcElement || document; // Fixes #1925 where srcElement might not be defined either
+		// check if target is a textnode (safari)
+		if ( event.target.nodeType === 3 ) {
+			event.target = event.target.parentNode;
+		// Add relatedTarget, if necessary
+		if ( !event.relatedTarget && event.fromElement ) {
+			event.relatedTarget = event.fromElement === event.target ? event.toElement : event.fromElement;
+		// Calculate pageX/Y if missing and clientX/Y available
+		if ( event.pageX == null && event.clientX != null ) {
+			var doc = document.documentElement, body = document.body;
+			event.pageX = event.clientX + (doc && doc.scrollLeft || body && body.scrollLeft || 0) - (doc && doc.clientLeft || body && body.clientLeft || 0);
+			event.pageY = event.clientY + (doc && doc.scrollTop  || body && body.scrollTop  || 0) - (doc && doc.clientTop  || body && body.clientTop  || 0);
+		// Add which for key events
+		if ( !event.which && ((event.charCode || event.charCode === 0) ? event.charCode : event.keyCode) ) {
+			event.which = event.charCode || event.keyCode;
+		// Add metaKey to non-Mac browsers (use ctrl for PC's and Meta for Macs)
+		if ( !event.metaKey && event.ctrlKey ) {
+			event.metaKey = event.ctrlKey;
+		// Add which for click: 1 === left; 2 === middle; 3 === right
+		// Note: button is not normalized, so don't use it
+		if ( !event.which && event.button !== undefined ) {
+			event.which = (event.button & 1 ? 1 : ( event.button & 2 ? 3 : ( event.button & 4 ? 2 : 0 ) ));
+		return event;
+	// Deprecated, use jQuery.guid instead
+	guid: 1E8,
+	// Deprecated, use jQuery.proxy instead
+	proxy: jQuery.proxy,
+	special: {
+		ready: {
+			// Make sure the ready event is setup
+			setup: jQuery.bindReady,
+			teardown: jQuery.noop
+		live: {
+			add: function( proxy, data, namespaces, live ) {
+				jQuery.extend( proxy, data || {} );
+				proxy.guid += data.selector + data.live;
+				data.liveProxy = proxy;
+				jQuery.event.add( this, data.live, liveHandler, data );
+			remove: function( namespaces ) {
+				if ( namespaces.length ) {
+					var remove = 0, name = new RegExp("(^|\\.)" + namespaces[0] + "(\\.|$)");
+					jQuery.each( (jQuery.data(this, "events").live || {}), function() {
+						if ( name.test(this.type) ) {
+							remove++;
+					if ( remove < 1 ) {
+						jQuery.event.remove( this, namespaces[0], liveHandler );
+			special: {}
+		beforeunload: {
+			setup: function( data, namespaces, fn ) {
+				// We only want to do this special case on windows
+				if ( this.setInterval ) {
+					this.onbeforeunload = fn;
+				return false;
+			teardown: function( namespaces, fn ) {
+				if ( this.onbeforeunload === fn ) {
+					this.onbeforeunload = null;
+jQuery.Event = function( src ) {
+	// Allow instantiation without the 'new' keyword
+	if ( !this.preventDefault ) {
+		return new jQuery.Event( src );
+	// Event object
+	if ( src && src.type ) {
+		this.originalEvent = src;
+		this.type = src.type;
+	// Event type
+	} else {
+		this.type = src;
+	// timeStamp is buggy for some events on Firefox(#3843)
+	// So we won't rely on the native value
+	this.timeStamp = now();
+	// Mark it as fixed
+	this[ expando ] = true;
+function returnFalse() {
+	return false;
+function returnTrue() {
+	return true;
+// jQuery.Event is based on DOM3 Events as specified by the ECMAScript Language Binding
+// http://www.w3.org/TR/2003/WD-DOM-Level-3-Events-20030331/ecma-script-binding.html
+jQuery.Event.prototype = {
+	preventDefault: function() {
+		this.isDefaultPrevented = returnTrue;
+		var e = this.originalEvent;
+		if ( !e ) {
+			return;
+		// if preventDefault exists run it on the original event
+		if ( e.preventDefault ) {
+			e.preventDefault();
+		// otherwise set the returnValue property of the original event to false (IE)
+		e.returnValue = false;
+	stopPropagation: function() {
+		this.isPropagationStopped = returnTrue;
+		if ( !e ) {
+			return;
+		// if stopPropagation exists run it on the original event
+		if ( e.stopPropagation ) {
+			e.stopPropagation();
+		// otherwise set the cancelBubble property of the original event to true (IE)
+		e.cancelBubble = true;
+	stopImmediatePropagation: function() {
+		this.isImmediatePropagationStopped = returnTrue;
+		this.stopPropagation();
+	isDefaultPrevented: returnFalse,
+	isPropagationStopped: returnFalse,
+	isImmediatePropagationStopped: returnFalse
+// Checks if an event happened on an element within another element
+// Used in jQuery.event.special.mouseenter and mouseleave handlers
+var withinElement = function( event ) {
+	// Check if mouse(over|out) are still within the same parent element
+	var parent = event.relatedTarget;
+	// Traverse up the tree
+	while ( parent && parent !== this ) {
+		// Firefox sometimes assigns relatedTarget a XUL element
+		// which we cannot access the parentNode property of
+		try {
+			parent = parent.parentNode;
+		// assuming we've left the element since we most likely mousedover a xul element
+		} catch(e) {
+			break;
+	if ( parent !== this ) {
+		// set the correct event type
+		event.type = event.data;
+		// handle event if we actually just moused on to a non sub-element
+		jQuery.event.handle.apply( this, arguments );
+// In case of event delegation, we only need to rename the event.type,
+// liveHandler will take care of the rest.
+delegate = function( event ) {
+// Create mouseenter and mouseleave events
+jQuery.each({
+	mouseenter: "mouseover",
+	mouseleave: "mouseout"
+}, function( orig, fix ) {
+	jQuery.event.special[ orig ] = {
+		setup: function( data ) {
+			jQuery.event.add( this, fix, data && data.selector ? delegate : withinElement, orig );
+		teardown: function( data ) {
+			jQuery.event.remove( this, fix, data && data.selector ? delegate : withinElement );
+// submit delegation
+if ( !jQuery.support.submitBubbles ) {
+jQuery.event.special.submit = {
+		if ( this.nodeName.toLowerCase() !== "form" ) {
+			jQuery.event.add(this, "click.specialSubmit." + fn.guid, function( e ) {
+				var elem = e.target, type = elem.type;
+				if ( (type === "submit" || type === "image") && jQuery( elem ).closest("form").length ) {
+					return trigger( "submit", this, arguments );
+			jQuery.event.add(this, "keypress.specialSubmit." + fn.guid, function( e ) {
+				if ( (type === "text" || type === "password") && jQuery( elem ).closest("form").length && e.keyCode === 13 ) {
+		} else {
+			return false;
+	remove: function( namespaces, fn ) {
+		jQuery.event.remove( this, "click.specialSubmit" + (fn ? "."+fn.guid : "") );
+		jQuery.event.remove( this, "keypress.specialSubmit" + (fn ? "."+fn.guid : "") );
+// change delegation, happens here so we have bind.
+if ( !jQuery.support.changeBubbles ) {
+var formElems = /textarea|input|select/i;
+function getVal( elem ) {
+	var type = elem.type, val = elem.value;
+	if ( type === "radio" || type === "checkbox" ) {
+		val = elem.checked;
+	} else if ( type === "select-multiple" ) {
+		val = elem.selectedIndex > -1 ?
+			jQuery.map( elem.options, function( elem ) {
+				return elem.selected;
+			}).join("-") :
+	} else if ( elem.nodeName.toLowerCase() === "select" ) {
+		val = elem.selectedIndex;
+	return val;
+function testChange( e ) {
+		var elem = e.target, data, val;
+		if ( !formElems.test( elem.nodeName ) || elem.readOnly ) {
+			return;
+		data = jQuery.data( elem, "_change_data" );
+		val = getVal(elem);
+		// the current data will be also retrieved by beforeactivate
+		if ( e.type !== "focusout" || elem.type !== "radio" ) {
+			jQuery.data( elem, "_change_data", val );
+		if ( data === undefined || val === data ) {
+			return;
+		if ( data != null || val ) {
+			e.type = "change";
+			return jQuery.event.trigger( e, arguments[1], elem );
+jQuery.event.special.change = {
+	filters: {
+		focusout: testChange,
+		click: function( e ) {
+			if ( type === "radio" || type === "checkbox" || elem.nodeName.toLowerCase() === "select" ) {
+				return testChange.call( this, e );
+		// Change has to be called before submit
+		// Keydown will be called before keypress, which is used in submit-event delegation
+		keydown: function( e ) {
+			if ( (e.keyCode === 13 && elem.nodeName.toLowerCase() !== "textarea") ||
+				(e.keyCode === 32 && (type === "checkbox" || type === "radio")) ||
+				type === "select-multiple" ) {
+		// Beforeactivate happens also before the previous element is blurred
+		// with this event you can't trigger a change event, but you can store
+		// information/focus[in] is not needed anymore
+		beforeactivate: function( e ) {
+			var elem = e.target;
+			if ( elem.nodeName.toLowerCase() === "input" && elem.type === "radio" ) {
+				jQuery.data( elem, "_change_data", getVal(elem) );
+		for ( var type in changeFilters ) {
+			jQuery.event.add( this, type + ".specialChange." + fn.guid, changeFilters[type] );
+		return formElems.test( this.nodeName );
+			jQuery.event.remove( this, type + ".specialChange" + (fn ? "."+fn.guid : ""), changeFilters[type] );
+var changeFilters = jQuery.event.special.change.filters;
+function trigger( type, elem, args ) {
+	args[0].type = type;
+	return jQuery.event.handle.apply( elem, args );
+// Create "bubbling" focus and blur events
+	jQuery.each({ focus: "focusin", blur: "focusout" }, function( orig, fix ) {
+		jQuery.event.special[ fix ] = {
+			setup: function() {
+				this.addEventListener( orig, handler, true );
+			teardown: function() {
+				this.removeEventListener( orig, handler, true );
+		function handler( e ) {
+			e = jQuery.event.fix( e );
+			e.type = fix;
+			return jQuery.event.handle.call( this, e );
+jQuery.each(["bind", "one"], function( i, name ) {
+	jQuery.fn[ name ] = function( type, data, fn ) {
+		// Handle object literals
+		if ( typeof type === "object" ) {
+			for ( var key in type ) {
+				this[ name ](key, data, type[key], fn);
+			return this;
+		if ( jQuery.isFunction( data ) ) {
+			fn = data;
+			data = undefined;
+		var handler = name === "one" ? jQuery.proxy( fn, function( event ) {
+			jQuery( this ).unbind( event, handler );
+			return fn.apply( this, arguments );
+		}) : fn;
+		return type === "unload" && name !== "one" ?
+			this.one( type, data, fn ) :
+			this.each(function() {
+				jQuery.event.add( this, type, handler, data );
+jQuery.fn.extend({
+	unbind: function( type, fn ) {
+		if ( typeof type === "object" && !type.preventDefault ) {
+				this.unbind(key, type[key]);
+			return this;
+			jQuery.event.remove( this, type, fn );
+	trigger: function( type, data ) {
+			jQuery.event.trigger( type, data, this );
+	triggerHandler: function( type, data ) {
+		if ( this[0] ) {
+			var event = jQuery.Event( type );
+			jQuery.event.trigger( event, data, this[0] );
+	toggle: function( fn ) {
+		// Save reference to arguments for access in closure
+		var args = arguments, i = 1;
+		// link all the functions, so any of them can unbind this click handler
+		while ( i < args.length ) {
+			jQuery.proxy( fn, args[ i++ ] );
+		return this.click( jQuery.proxy( fn, function( event ) {
+			// Figure out which function to execute
+			var lastToggle = ( jQuery.data( this, "lastToggle" + fn.guid ) || 0 ) % i;
+			jQuery.data( this, "lastToggle" + fn.guid, lastToggle + 1 );
+			// Make sure that clicks stop
+			// and execute the function
+			return args[ lastToggle ].apply( this, arguments ) || false;
+	hover: function( fnOver, fnOut ) {
+		return this.mouseenter( fnOver ).mouseleave( fnOut || fnOver );
+jQuery.each(["live", "die"], function( i, name ) {
+	jQuery.fn[ name ] = function( types, data, fn ) {
+		var type, i = 0;
+			fn = data;
+			data = undefined;
+		types = (types || "").split( /\s+/ );
+		while ( (type = types[ i++ ]) != null ) {
+			type = type === "focus" ? "focusin" : // focus --> focusin
+					type === "blur" ? "focusout" : // blur --> focusout
+					type === "hover" ? types.push("mouseleave") && "mouseenter" : // hover support
+					type;
+			if ( name === "live" ) {
+				// bind live handler
+				jQuery( this.context ).bind( liveConvert( type, this.selector ), {
+					data: data, selector: this.selector, live: type
+				}, fn );
+			} else {
+				// unbind live handler
+				jQuery( this.context ).unbind( liveConvert( type, this.selector ), fn ? { guid: fn.guid + this.selector + type } : null );
+		return this;
+function liveHandler( event ) {
+	var stop, elems = [], selectors = [], args = arguments,
+		related, match, fn, elem, j, i, l, data,
+		live = jQuery.extend({}, jQuery.data( this, "events" ).live);
+	// Make sure we avoid non-left-click bubbling in Firefox (#3861)
+	if ( event.button && event.type === "click" ) {
+		return;
+	for ( j in live ) {
+		fn = live[j];
+		if ( fn.live === event.type ||
+				fn.altLive && jQuery.inArray(event.type, fn.altLive) > -1 ) {
+			data = fn.data;
+			if ( !(data.beforeFilter && data.beforeFilter[event.type] &&
+					!data.beforeFilter[event.type](event)) ) {
+				selectors.push( fn.selector );
+		} else {
+			delete live[j];
+	match = jQuery( event.target ).closest( selectors, event.currentTarget );
+	for ( i = 0, l = match.length; i < l; i++ ) {
+			fn = live[j];
+			elem = match[i].elem;
+			related = null;
+			if ( match[i].selector === fn.selector ) {
+				// Those two events require additional checking
+				if ( fn.live === "mouseenter" || fn.live === "mouseleave" ) {
+					related = jQuery( event.relatedTarget ).closest( fn.selector )[0];
+				if ( !related || related !== elem ) {
+					elems.push({ elem: elem, fn: fn });
+	for ( i = 0, l = elems.length; i < l; i++ ) {
+		match = elems[i];
+		event.currentTarget = match.elem;
+		event.data = match.fn.data;
+		if ( match.fn.apply( match.elem, args ) === false ) {
+			stop = false;
+			break;
+	return stop;
+function liveConvert( type, selector ) {
+	return "live." + (type ? type + "." : "") + selector.replace(/\./g, "`").replace(/ /g, "&");
+jQuery.each( ("blur focus focusin focusout load resize scroll unload click dblclick " +
+	"mousedown mouseup mousemove mouseover mouseout mouseenter mouseleave " +
+	"change select submit keydown keypress keyup error").split(" "), function( i, name ) {
+	// Handle event binding
+	jQuery.fn[ name ] = function( fn ) {
+		return fn ? this.bind( name, fn ) : this.trigger( name );
+	if ( jQuery.attrFn ) {
+		jQuery.attrFn[ name ] = true;
+// Prevent memory leaks in IE
+// Window isn't included so as not to unbind existing unload events
+// More info:
+//  - http://isaacschlueter.com/2006/10/msie-memory-leaks/
+if ( window.attachEvent && !window.addEventListener ) {
+	window.attachEvent("onunload", function() {
+		for ( var id in jQuery.cache ) {
+			if ( jQuery.cache[ id ].handle ) {
+				// Try/Catch is to handle iframes being unloaded, see #4280
+				try {
+					jQuery.event.remove( jQuery.cache[ id ].handle.elem );
+				} catch(e) {}
+ * Sizzle CSS Selector Engine - v1.0
+ *  Copyright 2009, The Dojo Foundation
+ *  More information: http://sizzlejs.com/
+(function(){
+var chunker = /((?:\((?:\([^()]+\)|[^()]+)+\)|\[(?:\[[^[\]]*\]|['"][^'"]*['"]|[^[\]'"]+)+\]|\\.|[^ >+~,(\[\\]+)+|[>+~])(\s*,\s*)?((?:.|\r|\n)*)/g,
+	done = 0,
+	hasDuplicate = false,
+	baseHasDuplicate = true;
+// Here we check if the JavaScript engine is using some sort of
+// optimization where it does not always call our comparision
+// function. If that is the case, discard the hasDuplicate value.
+//   Thus far that includes Google Chrome.
+[0, 0].sort(function(){
+	baseHasDuplicate = false;
+	return 0;
+var Sizzle = function(selector, context, results, seed) {
+	results = results || [];
+	var origContext = context = context || document;
+	if ( context.nodeType !== 1 && context.nodeType !== 9 ) {
+		return [];
+	if ( !selector || typeof selector !== "string" ) {
+		return results;
+	var parts = [], m, set, checkSet, extra, prune = true, contextXML = isXML(context),
+		soFar = selector;
+	// Reset the position of the chunker regexp (start from head)
+	while ( (chunker.exec(""), m = chunker.exec(soFar)) !== null ) {
+		soFar = m[3];
+		parts.push( m[1] );
+		if ( m[2] ) {
+			extra = m[3];
+			break;
+	if ( parts.length > 1 && origPOS.exec( selector ) ) {
+		if ( parts.length === 2 && Expr.relative[ parts[0] ] ) {
+			set = posProcess( parts[0] + parts[1], context );
+		} else {
+			set = Expr.relative[ parts[0] ] ?
+				[ context ] :
+				Sizzle( parts.shift(), context );
+			while ( parts.length ) {
+				selector = parts.shift();
+				if ( Expr.relative[ selector ] ) {
+					selector += parts.shift();
+				set = posProcess( selector, set );
+	} else {
+		// Take a shortcut and set the context if the root selector is an ID
+		// (but not if it'll be faster if the inner selector is an ID)
+		if ( !seed && parts.length > 1 && context.nodeType === 9 && !contextXML &&
+				Expr.match.ID.test(parts[0]) && !Expr.match.ID.test(parts[parts.length - 1]) ) {
+			var ret = Sizzle.find( parts.shift(), context, contextXML );
+			context = ret.expr ? Sizzle.filter( ret.expr, ret.set )[0] : ret.set[0];
+		if ( context ) {
+			var ret = seed ?
+				{ expr: parts.pop(), set: makeArray(seed) } :
+				Sizzle.find( parts.pop(), parts.length === 1 && (parts[0] === "~" || parts[0] === "+") && context.parentNode ? context.parentNode : context, contextXML );
+			set = ret.expr ? Sizzle.filter( ret.expr, ret.set ) : ret.set;
+			if ( parts.length > 0 ) {
+				checkSet = makeArray(set);
+			} else {
+				prune = false;
+				var cur = parts.pop(), pop = cur;
+				if ( !Expr.relative[ cur ] ) {
+					cur = "";
+				} else {
+					pop = parts.pop();
+				if ( pop == null ) {
+					pop = context;
+				Expr.relative[ cur ]( checkSet, pop, contextXML );
+		} else {
+			checkSet = parts = [];
+	if ( !checkSet ) {
+		checkSet = set;
+		Sizzle.error( cur || selector );
+	if ( toString.call(checkSet) === "[object Array]" ) {
+		if ( !prune ) {
+			results.push.apply( results, checkSet );
+		} else if ( context && context.nodeType === 1 ) {
+			for ( var i = 0; checkSet[i] != null; i++ ) {
+				if ( checkSet[i] && (checkSet[i] === true || checkSet[i].nodeType === 1 && contains(context, checkSet[i])) ) {
+					results.push( set[i] );
+		} else {
+				if ( checkSet[i] && checkSet[i].nodeType === 1 ) {
+	} else {
+		makeArray( checkSet, results );
+	if ( extra ) {
+		Sizzle( extra, origContext, results, seed );
+		Sizzle.uniqueSort( results );
+	return results;
+Sizzle.uniqueSort = function(results){
+	if ( sortOrder ) {
+		hasDuplicate = baseHasDuplicate;
+		results.sort(sortOrder);
+		if ( hasDuplicate ) {
+			for ( var i = 1; i < results.length; i++ ) {
+				if ( results[i] === results[i-1] ) {
+					results.splice(i--, 1);
+	return results;
+Sizzle.matches = function(expr, set){
+	return Sizzle(expr, null, null, set);
+Sizzle.find = function(expr, context, isXML){
+	var set, match;
+	if ( !expr ) {
+		return [];
+	for ( var i = 0, l = Expr.order.length; i < l; i++ ) {
+		var type = Expr.order[i], match;
+		if ( (match = Expr.leftMatch[ type ].exec( expr )) ) {
+			var left = match[1];
+			match.splice(1,1);
+			if ( left.substr( left.length - 1 ) !== "\\" ) {
+				match[1] = (match[1] || "").replace(/\\/g, "");
+				set = Expr.find[ type ]( match, context, isXML );
+				if ( set != null ) {
+					expr = expr.replace( Expr.match[ type ], "" );
+					break;
+	if ( !set ) {
+		set = context.getElementsByTagName("*");
+	return {set: set, expr: expr};
+Sizzle.filter = function(expr, set, inplace, not){
+	var old = expr, result = [], curLoop = set, match, anyFound,
+		isXMLFilter = set && set[0] && isXML(set[0]);
+	while ( expr && set.length ) {
+		for ( var type in Expr.filter ) {
+			if ( (match = Expr.leftMatch[ type ].exec( expr )) != null && match[2] ) {
+				var filter = Expr.filter[ type ], found, item, left = match[1];
+				anyFound = false;
+				if ( left.substr( left.length - 1 ) === "\\" ) {
+					continue;
+				if ( curLoop === result ) {
+					result = [];
+				if ( Expr.preFilter[ type ] ) {
+					match = Expr.preFilter[ type ]( match, curLoop, inplace, result, not, isXMLFilter );
+					if ( !match ) {
+						anyFound = found = true;
+					} else if ( match === true ) {
+						continue;
+				if ( match ) {
+					for ( var i = 0; (item = curLoop[i]) != null; i++ ) {
+						if ( item ) {
+							found = filter( item, match, i, curLoop );
+							var pass = not ^ !!found;
+							if ( inplace && found != null ) {
+								if ( pass ) {
+									anyFound = true;
+								} else {
+									curLoop[i] = false;
+							} else if ( pass ) {
+								result.push( item );
+								anyFound = true;
+				if ( found !== undefined ) {
+					if ( !inplace ) {
+						curLoop = result;
+					if ( !anyFound ) {
+						return [];
+					break;
+		// Improper expression
+		if ( expr === old ) {
+			if ( anyFound == null ) {
+				Sizzle.error( expr );
+			} else {
+				break;
+		old = expr;
+	return curLoop;
+Sizzle.error = function( msg ) {
+	throw "Syntax error, unrecognized expression: " + msg;
+var Expr = Sizzle.selectors = {
+	order: [ "ID", "NAME", "TAG" ],
+	match: {
+		ID: /#((?:[\w\u00c0-\uFFFF-]|\\.)+)/,
+		CLASS: /\.((?:[\w\u00c0-\uFFFF-]|\\.)+)/,
+		NAME: /\[name=['"]*((?:[\w\u00c0-\uFFFF-]|\\.)+)['"]*\]/,
+		ATTR: /\[\s*((?:[\w\u00c0-\uFFFF-]|\\.)+)\s*(?:(\S?=)\s*(['"]*)(.*?)\3|)\s*\]/,
+		TAG: /^((?:[\w\u00c0-\uFFFF\*-]|\\.)+)/,
+		CHILD: /:(only|nth|last|first)-child(?:\((even|odd|[\dn+-]*)\))?/,
+		POS: /:(nth|eq|gt|lt|first|last|even|odd)(?:\((\d*)\))?(?=[^-]|$)/,
+		PSEUDO: /:((?:[\w\u00c0-\uFFFF-]|\\.)+)(?:\((['"]?)((?:\([^\)]+\)|[^\(\)]*)+)\2\))?/
+	leftMatch: {},
+	attrMap: {
+		"for": "htmlFor"
+	attrHandle: {
+		href: function(elem){
+			return elem.getAttribute("href");
+	relative: {
+		"+": function(checkSet, part){
+			var isPartStr = typeof part === "string",
+				isTag = isPartStr && !/\W/.test(part),
+				isPartStrNotTag = isPartStr && !isTag;
+			if ( isTag ) {
+				part = part.toLowerCase();
+			for ( var i = 0, l = checkSet.length, elem; i < l; i++ ) {
+				if ( (elem = checkSet[i]) ) {
+					while ( (elem = elem.previousSibling) && elem.nodeType !== 1 ) {}
+					checkSet[i] = isPartStrNotTag || elem && elem.nodeName.toLowerCase() === part ?
+						elem || false :
+						elem === part;
+			if ( isPartStrNotTag ) {
+				Sizzle.filter( part, checkSet, true );
+		">": function(checkSet, part){
+			var isPartStr = typeof part === "string";
+			if ( isPartStr && !/\W/.test(part) ) {
+				for ( var i = 0, l = checkSet.length; i < l; i++ ) {
+					var elem = checkSet[i];
+					if ( elem ) {
+						checkSet[i] = parent.nodeName.toLowerCase() === part ? parent : false;
+			} else {
+					if ( elem ) {
+						checkSet[i] = isPartStr ?
+							elem.parentNode :
+							elem.parentNode === part;
+				if ( isPartStr ) {
+		"": function(checkSet, part, isXML){
+			var doneName = done++, checkFn = dirCheck;
+			if ( typeof part === "string" && !/\W/.test(part) ) {
+				var nodeCheck = part = part.toLowerCase();
+				checkFn = dirNodeCheck;
+			checkFn("parentNode", part, doneName, checkSet, nodeCheck, isXML);
+		"~": function(checkSet, part, isXML){
+			checkFn("previousSibling", part, doneName, checkSet, nodeCheck, isXML);
+	find: {
+		ID: function(match, context, isXML){
+			if ( typeof context.getElementById !== "undefined" && !isXML ) {
+				var m = context.getElementById(match[1]);
+				return m ? [m] : [];
+		NAME: function(match, context){
+			if ( typeof context.getElementsByName !== "undefined" ) {
+				var ret = [], results = context.getElementsByName(match[1]);
+				for ( var i = 0, l = results.length; i < l; i++ ) {
+					if ( results[i].getAttribute("name") === match[1] ) {
+						ret.push( results[i] );
+				return ret.length === 0 ? null : ret;
+		TAG: function(match, context){
+			return context.getElementsByTagName(match[1]);
+	preFilter: {
+		CLASS: function(match, curLoop, inplace, result, not, isXML){
+			match = " " + match[1].replace(/\\/g, "") + " ";
+			if ( isXML ) {
+				return match;
+			for ( var i = 0, elem; (elem = curLoop[i]) != null; i++ ) {
+				if ( elem ) {
+					if ( not ^ (elem.className && (" " + elem.className + " ").replace(/[\t\n]/g, " ").indexOf(match) >= 0) ) {
+						if ( !inplace ) {
+							result.push( elem );
+					} else if ( inplace ) {
+			return false;
+		ID: function(match){
+			return match[1].replace(/\\/g, "");
+		TAG: function(match, curLoop){
+			return match[1].toLowerCase();
+		CHILD: function(match){
+			if ( match[1] === "nth" ) {
+				// parse equations like 'even', 'odd', '5', '2n', '3n+2', '4n-1', '-n+6'
+				var test = /(-?)(\d*)n((?:\+|-)?\d*)/.exec(
+					match[2] === "even" && "2n" || match[2] === "odd" && "2n+1" ||
+					!/\D/.test( match[2] ) && "0n+" + match[2] || match[2]);
+				// calculate the numbers (first)n+(last) including if they are negative
+				match[2] = (test[1] + (test[2] || 1)) - 0;
+				match[3] = test[3] - 0;
+			// TODO: Move to normal caching system
+			match[0] = done++;
+			return match;
+		ATTR: function(match, curLoop, inplace, result, not, isXML){
+			var name = match[1].replace(/\\/g, "");
+			if ( !isXML && Expr.attrMap[name] ) {
+				match[1] = Expr.attrMap[name];
+			if ( match[2] === "~=" ) {
+				match[4] = " " + match[4] + " ";
+			return match;
+		PSEUDO: function(match, curLoop, inplace, result, not){
+			if ( match[1] === "not" ) {
+				// If we're dealing with a complex expression, or a simple one
+				if ( ( chunker.exec(match[3]) || "" ).length > 1 || /^\w/.test(match[3]) ) {
+					match[3] = Sizzle(match[3], null, null, curLoop);
+				} else {
+					var ret = Sizzle.filter(match[3], curLoop, inplace, true ^ not);
+					if ( !inplace ) {
+						result.push.apply( result, ret );
+					return false;
+			} else if ( Expr.match.POS.test( match[0] ) || Expr.match.CHILD.test( match[0] ) ) {
+				return true;
+			return match;
+		POS: function(match){
+			match.unshift( true );
+			return match;
+	filters: {
+		enabled: function(elem){
+			return elem.disabled === false && elem.type !== "hidden";
+		disabled: function(elem){
+			return elem.disabled === true;
+		checked: function(elem){
+			return elem.checked === true;
+		selected: function(elem){
+			// Accessing this property makes selected-by-default
+			// options in Safari work properly
+			elem.parentNode.selectedIndex;
+			return elem.selected === true;
+		parent: function(elem){
+			return !!elem.firstChild;
+		empty: function(elem){
+			return !elem.firstChild;
+		has: function(elem, i, match){
+			return !!Sizzle( match[3], elem ).length;
+		header: function(elem){
+			return /h\d/i.test( elem.nodeName );
+		text: function(elem){
+			return "text" === elem.type;
+		radio: function(elem){
+			return "radio" === elem.type;
+		checkbox: function(elem){
+			return "checkbox" === elem.type;
+		file: function(elem){
+			return "file" === elem.type;
+		password: function(elem){
+			return "password" === elem.type;
+		submit: function(elem){
+			return "submit" === elem.type;
+		image: function(elem){
+			return "image" === elem.type;
+		reset: function(elem){
+			return "reset" === elem.type;
+		button: function(elem){
+			return "button" === elem.type || elem.nodeName.toLowerCase() === "button";
+		input: function(elem){
+			return /input|select|textarea|button/i.test(elem.nodeName);
+	setFilters: {
+		first: function(elem, i){
+			return i === 0;
+		last: function(elem, i, match, array){
+			return i === array.length - 1;
+		even: function(elem, i){
+			return i % 2 === 0;
+		odd: function(elem, i){
+			return i % 2 === 1;
+		lt: function(elem, i, match){
+			return i < match[3] - 0;
+		gt: function(elem, i, match){
+			return i > match[3] - 0;
+		nth: function(elem, i, match){
+			return match[3] - 0 === i;
+		eq: function(elem, i, match){
+	filter: {
+		PSEUDO: function(elem, match, i, array){
+			var name = match[1], filter = Expr.filters[ name ];
+			if ( filter ) {
+				return filter( elem, i, match, array );
+			} else if ( name === "contains" ) {
+				return (elem.textContent || elem.innerText || getText([ elem ]) || "").indexOf(match[3]) >= 0;
+			} else if ( name === "not" ) {
+				var not = match[3];
+				for ( var i = 0, l = not.length; i < l; i++ ) {
+					if ( not[i] === elem ) {
+						return false;
+				return true;
+			} else {
+				Sizzle.error( "Syntax error, unrecognized expression: " + name );
+		CHILD: function(elem, match){
+			var type = match[1], node = elem;
+			switch (type) {
+				case 'only':
+				case 'first':
+					while ( (node = node.previousSibling) )	 {
+						if ( node.nodeType === 1 ) {
+							return false;
+					if ( type === "first" ) {
+						return true;
+					node = elem;
+				case 'last':
+					while ( (node = node.nextSibling) )	 {
+							return false;
+					return true;
+				case 'nth':
+					var first = match[2], last = match[3];
+					if ( first === 1 && last === 0 ) {
+						return true;
+					var doneName = match[0],
+						parent = elem.parentNode;
+					if ( parent && (parent.sizcache !== doneName || !elem.nodeIndex) ) {
+						var count = 0;
+						for ( node = parent.firstChild; node; node = node.nextSibling ) {
+								node.nodeIndex = ++count;
+						parent.sizcache = doneName;
+					var diff = elem.nodeIndex - last;
+					if ( first === 0 ) {
+						return diff === 0;
+					} else {
+						return ( diff % first === 0 && diff / first >= 0 );
+		ID: function(elem, match){
+			return elem.nodeType === 1 && elem.getAttribute("id") === match;
+		TAG: function(elem, match){
+			return (match === "*" && elem.nodeType === 1) || elem.nodeName.toLowerCase() === match;
+		CLASS: function(elem, match){
+			return (" " + (elem.className || elem.getAttribute("class")) + " ")
+				.indexOf( match ) > -1;
+		ATTR: function(elem, match){
+				result = Expr.attrHandle[ name ] ?
+					Expr.attrHandle[ name ]( elem ) :
+					elem[ name ] != null ?
+						elem[ name ] :
+						elem.getAttribute( name ),
+				value = result + "",
+				type = match[2],
+				check = match[4];
+			return result == null ?
+				type === "!=" :
+				type === "=" ?
+				value === check :
+				type === "*=" ?
+				value.indexOf(check) >= 0 :
+				type === "~=" ?
+				(" " + value + " ").indexOf(check) >= 0 :
+				!check ?
+				value && result !== false :
+				type === "!=" ?
+				value !== check :
+				type === "^=" ?
+				value.indexOf(check) === 0 :
+				type === "$=" ?
+				value.substr(value.length - check.length) === check :
+				type === "|=" ?
+				value === check || value.substr(0, check.length + 1) === check + "-" :
+				false;
+		POS: function(elem, match, i, array){
+			var name = match[2], filter = Expr.setFilters[ name ];
+			if ( filter ) {
+var origPOS = Expr.match.POS;
+for ( var type in Expr.match ) {
+	Expr.match[ type ] = new RegExp( Expr.match[ type ].source + /(?![^\[]*\])(?![^\(]*\))/.source );
+	Expr.leftMatch[ type ] = new RegExp( /(^(?:.|\r|\n)*?)/.source + Expr.match[ type ].source.replace(/\\(\d+)/g, function(all, num){
+		return "\\" + (num - 0 + 1);
+var makeArray = function(array, results) {
+	array = Array.prototype.slice.call( array, 0 );
+	if ( results ) {
+		results.push.apply( results, array );
+		return results;
+	return array;
+// Perform a simple check to determine if the browser is capable of
+// converting a NodeList to an array using builtin methods.
+try {
+	Array.prototype.slice.call( document.documentElement.childNodes, 0 );
+// Provide a fallback method if it does not work
+} catch(e){
+	makeArray = function(array, results) {
+		var ret = results || [];
+		if ( toString.call(array) === "[object Array]" ) {
+			Array.prototype.push.apply( ret, array );
+		} else {
+			if ( typeof array.length === "number" ) {
+				for ( var i = 0, l = array.length; i < l; i++ ) {
+					ret.push( array[i] );
+			} else {
+				for ( var i = 0; array[i]; i++ ) {
+		return ret;
+var sortOrder;
+if ( document.documentElement.compareDocumentPosition ) {
+	sortOrder = function( a, b ) {
+		if ( !a.compareDocumentPosition || !b.compareDocumentPosition ) {
+			if ( a == b ) {
+				hasDuplicate = true;
+			return a.compareDocumentPosition ? -1 : 1;
+		var ret = a.compareDocumentPosition(b) & 4 ? -1 : a === b ? 0 : 1;
+		if ( ret === 0 ) {
+		return ret;
+} else if ( "sourceIndex" in document.documentElement ) {
+		if ( !a.sourceIndex || !b.sourceIndex ) {
+			if ( a == b ) {
+			return a.sourceIndex ? -1 : 1;
+		var ret = a.sourceIndex - b.sourceIndex;
+		return ret;
+} else if ( document.createRange ) {
+		if ( !a.ownerDocument || !b.ownerDocument ) {
+			if ( a == b ) {
+			return a.ownerDocument ? -1 : 1;
+		var aRange = a.ownerDocument.createRange(), bRange = b.ownerDocument.createRange();
+		aRange.setStart(a, 0);
+		aRange.setEnd(a, 0);
+		bRange.setStart(b, 0);
+		bRange.setEnd(b, 0);
+		var ret = aRange.compareBoundaryPoints(Range.START_TO_END, bRange);
+		return ret;
+// Utility function for retreiving the text value of an array of DOM nodes
+function getText( elems ) {
+	var ret = "", elem;
+	for ( var i = 0; elems[i]; i++ ) {
+		elem = elems[i];
+		// Get the text from text nodes and CDATA nodes
+		if ( elem.nodeType === 3 || elem.nodeType === 4 ) {
+			ret += elem.nodeValue;
+		// Traverse everything else, except comment nodes
+		} else if ( elem.nodeType !== 8 ) {
+			ret += getText( elem.childNodes );
+	return ret;
+// Check to see if the browser returns elements by name when
+// querying by getElementById (and provide a workaround)
+(function(){
+	// We're going to inject a fake input element with a specified name
+	var form = document.createElement("div"),
+		id = "script" + (new Date).getTime();
+	form.innerHTML = "<a name='" + id + "'/>";
+	// Inject it into the root element, check its status, and remove it quickly
+	var root = document.documentElement;
+	root.insertBefore( form, root.firstChild );
+	// The workaround has to do additional checks after a getElementById
+	// Which slows things down for other browsers (hence the branching)
+	if ( document.getElementById( id ) ) {
+		Expr.find.ID = function(match, context, isXML){
+				return m ? m.id === match[1] || typeof m.getAttributeNode !== "undefined" && m.getAttributeNode("id").nodeValue === match[1] ? [m] : undefined : [];
+		Expr.filter.ID = function(elem, match){
+			var node = typeof elem.getAttributeNode !== "undefined" && elem.getAttributeNode("id");
+			return elem.nodeType === 1 && node && node.nodeValue === match;
+	root.removeChild( form );
+	root = form = null; // release memory in IE
+(function(){
+	// Check to see if the browser returns only elements
+	// when doing getElementsByTagName("*")
+	// Create a fake element
+	div.appendChild( document.createComment("") );
+	// Make sure no comments are found
+	if ( div.getElementsByTagName("*").length > 0 ) {
+		Expr.find.TAG = function(match, context){
+			var results = context.getElementsByTagName(match[1]);
+			// Filter out possible comments
+			if ( match[1] === "*" ) {
+				var tmp = [];
+				for ( var i = 0; results[i]; i++ ) {
+					if ( results[i].nodeType === 1 ) {
+						tmp.push( results[i] );
+				results = tmp;
+			return results;
+	// Check to see if an attribute returns normalized href attributes
+	div.innerHTML = "<a href='#'></a>";
+	if ( div.firstChild && typeof div.firstChild.getAttribute !== "undefined" &&
+			div.firstChild.getAttribute("href") !== "#" ) {
+		Expr.attrHandle.href = function(elem){
+			return elem.getAttribute("href", 2);
+	div = null; // release memory in IE
+if ( document.querySelectorAll ) {
+	(function(){
+		var oldSizzle = Sizzle, div = document.createElement("div");
+		div.innerHTML = "<p class='TEST'></p>";
+		// Safari can't handle uppercase or unicode characters when
+		// in quirks mode.
+		if ( div.querySelectorAll && div.querySelectorAll(".TEST").length === 0 ) {
+			return;
+		Sizzle = function(query, context, extra, seed){
+			context = context || document;
+			// Only use querySelectorAll on non-XML documents
+			// (ID selectors don't work in non-HTML documents)
+			if ( !seed && context.nodeType === 9 && !isXML(context) ) {
+				try {
+					return makeArray( context.querySelectorAll(query), extra );
+				} catch(e){}
+			return oldSizzle(query, context, extra, seed);
+		for ( var prop in oldSizzle ) {
+			Sizzle[ prop ] = oldSizzle[ prop ];
+(function(){
+	div.innerHTML = "<div class='test e'></div><div class='test'></div>";
+	// Opera can't find a second classname (in 9.6)
+	// Also, make sure that getElementsByClassName actually exists
+	if ( !div.getElementsByClassName || div.getElementsByClassName("e").length === 0 ) {
+		return;
+	// Safari caches class attributes, doesn't catch changes (in 3.2)
+	div.lastChild.className = "e";
+	if ( div.getElementsByClassName("e").length === 1 ) {
+		return;
+	Expr.order.splice(1, 0, "CLASS");
+	Expr.find.CLASS = function(match, context, isXML) {
+		if ( typeof context.getElementsByClassName !== "undefined" && !isXML ) {
+			return context.getElementsByClassName(match[1]);
+function dirNodeCheck( dir, cur, doneName, checkSet, nodeCheck, isXML ) {
+		if ( elem ) {
+			elem = elem[dir];
+			var match = false;
+			while ( elem ) {
+				if ( elem.sizcache === doneName ) {
+					match = checkSet[elem.sizset];
+					break;
+				if ( elem.nodeType === 1 && !isXML ){
+					elem.sizcache = doneName;
+					elem.sizset = i;
+				if ( elem.nodeName.toLowerCase() === cur ) {
+					match = elem;
+					break;
+				elem = elem[dir];
+			checkSet[i] = match;
+function dirCheck( dir, cur, doneName, checkSet, nodeCheck, isXML ) {
+		if ( elem ) {
+			elem = elem[dir];
+			while ( elem ) {
+					break;
+					if ( !isXML ) {
+						elem.sizset = i;
+					if ( typeof cur !== "string" ) {
+						if ( elem === cur ) {
+							match = true;
+							break;
+					} else if ( Sizzle.filter( cur, [elem] ).length > 0 ) {
+						match = elem;
+						break;
+				elem = elem[dir];
+var contains = document.compareDocumentPosition ? function(a, b){
+	return a.compareDocumentPosition(b) & 16;
+} : function(a, b){
+	return a !== b && (a.contains ? a.contains(b) : true);
+var isXML = function(elem){
+	// documentElement is verified for cases where it doesn't yet exist
+	// (such as loading iframes in IE - #4833)
+	var documentElement = (elem ? elem.ownerDocument || elem : 0).documentElement;
+	return documentElement ? documentElement.nodeName !== "HTML" : false;
+var posProcess = function(selector, context){
+	var tmpSet = [], later = "", match,
+		root = context.nodeType ? [context] : context;
+	// Position selectors must be done after the filter
+	// And so must :not(positional) so we move all PSEUDOs to the end
+	while ( (match = Expr.match.PSEUDO.exec( selector )) ) {
+		later += match[0];
+		selector = selector.replace( Expr.match.PSEUDO, "" );
+	selector = Expr.relative[selector] ? selector + "*" : selector;
+	for ( var i = 0, l = root.length; i < l; i++ ) {
+		Sizzle( selector, root[i], tmpSet );
+	return Sizzle.filter( later, tmpSet );
+// EXPOSE
+jQuery.find = Sizzle;
+jQuery.expr = Sizzle.selectors;
+jQuery.expr[":"] = jQuery.expr.filters;
+jQuery.unique = Sizzle.uniqueSort;
+jQuery.getText = getText;
+jQuery.isXMLDoc = isXML;
+jQuery.contains = contains;
+return;
+window.Sizzle = Sizzle;
+var runtil = /Until$/,
+	rparentsprev = /^(?:parents|prevUntil|prevAll)/,
+	// Note: This RegExp should be improved, or likely pulled from Sizzle
+	rmultiselector = /,/,
+	slice = Array.prototype.slice;
+// Implement the identical functionality for filter and not
+var winnow = function( elements, qualifier, keep ) {
+	if ( jQuery.isFunction( qualifier ) ) {
+		return jQuery.grep(elements, function( elem, i ) {
+			return !!qualifier.call( elem, i, elem ) === keep;
+	} else if ( qualifier.nodeType ) {
+			return (elem === qualifier) === keep;
+	} else if ( typeof qualifier === "string" ) {
+		var filtered = jQuery.grep(elements, function( elem ) {
+			return elem.nodeType === 1;
+		if ( isSimple.test( qualifier ) ) {
+			return jQuery.filter(qualifier, filtered, !keep);
+		} else {
+			qualifier = jQuery.filter( qualifier, filtered );
+		return (jQuery.inArray( elem, qualifier ) >= 0) === keep;
+jQuery.fn.extend({
+	find: function( selector ) {
+		var ret = this.pushStack( "", "find", selector ), length = 0;
+			length = ret.length;
+			jQuery.find( selector, this[i], ret );
+			if ( i > 0 ) {
+				// Make sure that the results are unique
+				for ( var n = length; n < ret.length; n++ ) {
+					for ( var r = 0; r < length; r++ ) {
+						if ( ret[r] === ret[n] ) {
+							ret.splice(n--, 1);
+							break;
+		return ret;
+	has: function( target ) {
+		var targets = jQuery( target );
+		return this.filter(function() {
+			for ( var i = 0, l = targets.length; i < l; i++ ) {
+				if ( jQuery.contains( this, targets[i] ) ) {
+					return true;
+	not: function( selector ) {
+		return this.pushStack( winnow(this, selector, false), "not", selector);
+	filter: function( selector ) {
+		return this.pushStack( winnow(this, selector, true), "filter", selector );
+	is: function( selector ) {
+		return !!selector && jQuery.filter( selector, this ).length > 0;
+	closest: function( selectors, context ) {
+		if ( jQuery.isArray( selectors ) ) {
+			var ret = [], cur = this[0], match, matches = {}, selector;
+			if ( cur && selectors.length ) {
+				for ( var i = 0, l = selectors.length; i < l; i++ ) {
+					selector = selectors[i];
+					if ( !matches[selector] ) {
+						matches[selector] = jQuery.expr.match.POS.test( selector ) ?
+							jQuery( selector, context || this.context ) :
+							selector;
+				while ( cur && cur.ownerDocument && cur !== context ) {
+					for ( selector in matches ) {
+						match = matches[selector];
+						if ( match.jquery ? match.index(cur) > -1 : jQuery(cur).is(match) ) {
+							ret.push({ selector: selector, elem: cur });
+							delete matches[selector];
+					cur = cur.parentNode;
+			return ret;
+		var pos = jQuery.expr.match.POS.test( selectors ) ?
+			jQuery( selectors, context || this.context ) : null;
+		return this.map(function( i, cur ) {
+				if ( pos ? pos.index(cur) > -1 : jQuery(cur).is(selectors) ) {
+					return cur;
+			return null;
+	// Determine the position of an element within
+	// the matched set of elements
+	index: function( elem ) {
+		if ( !elem || typeof elem === "string" ) {
+			return jQuery.inArray( this[0],
+				// If it receives a string, the selector is used
+				// If it receives nothing, the siblings are used
+				elem ? jQuery( elem ) : this.parent().children() );
+		// Locate the position of the desired element
+			// If it receives a jQuery object, the first element is used
+			elem.jquery ? elem[0] : elem, this );
+	add: function( selector, context ) {
+		var set = typeof selector === "string" ?
+				jQuery.makeArray( selector ),
+			all = jQuery.merge( this.get(), set );
+		return this.pushStack( isDisconnected( set[0] ) || isDisconnected( all[0] ) ?
+			all :
+			jQuery.unique( all ) );
+	andSelf: function() {
+		return this.add( this.prevObject );
+// A painfully simple check to see if an element is disconnected
+// from a document (should be improved, where feasible).
+function isDisconnected( node ) {
+	return !node || !node.parentNode || node.parentNode.nodeType === 11;
+jQuery.each({
+	parent: function( elem ) {
+		return parent && parent.nodeType !== 11 ? parent : null;
+	parents: function( elem ) {
+		return jQuery.dir( elem, "parentNode" );
+	parentsUntil: function( elem, i, until ) {
+		return jQuery.dir( elem, "parentNode", until );
+	next: function( elem ) {
+		return jQuery.nth( elem, 2, "nextSibling" );
+	prev: function( elem ) {
+		return jQuery.nth( elem, 2, "previousSibling" );
+	nextAll: function( elem ) {
+		return jQuery.dir( elem, "nextSibling" );
+	prevAll: function( elem ) {
+		return jQuery.dir( elem, "previousSibling" );
+	nextUntil: function( elem, i, until ) {
+		return jQuery.dir( elem, "nextSibling", until );
+	prevUntil: function( elem, i, until ) {
+		return jQuery.dir( elem, "previousSibling", until );
+	siblings: function( elem ) {
+		return jQuery.sibling( elem.parentNode.firstChild, elem );
+	children: function( elem ) {
+		return jQuery.sibling( elem.firstChild );
+	contents: function( elem ) {
+		return jQuery.nodeName( elem, "iframe" ) ?
+			elem.contentDocument || elem.contentWindow.document :
+			jQuery.makeArray( elem.childNodes );
+}, function( name, fn ) {
+	jQuery.fn[ name ] = function( until, selector ) {
+		var ret = jQuery.map( this, fn, until );
+		if ( !runtil.test( name ) ) {
+			selector = until;
+		if ( selector && typeof selector === "string" ) {
+			ret = jQuery.filter( selector, ret );
+		ret = this.length > 1 ? jQuery.unique( ret ) : ret;
+		if ( (this.length > 1 || rmultiselector.test( selector )) && rparentsprev.test( name ) ) {
+			ret = ret.reverse();
+		return this.pushStack( ret, name, slice.call(arguments).join(",") );
+jQuery.extend({
+	filter: function( expr, elems, not ) {
+		if ( not ) {
+			expr = ":not(" + expr + ")";
+		return jQuery.find.matches(expr, elems);
+	dir: function( elem, dir, until ) {
+		var matched = [], cur = elem[dir];
+		while ( cur && cur.nodeType !== 9 && (until === undefined || cur.nodeType !== 1 || !jQuery( cur ).is( until )) ) {
+			if ( cur.nodeType === 1 ) {
+				matched.push( cur );
+			cur = cur[dir];
+		return matched;
+	nth: function( cur, result, dir, elem ) {
+		result = result || 1;
+		var num = 0;
+		for ( ; cur; cur = cur[dir] ) {
+			if ( cur.nodeType === 1 && ++num === result ) {
+				break;
+		return cur;
+	sibling: function( n, elem ) {
+		var r = [];
+		for ( ; n; n = n.nextSibling ) {
+			if ( n.nodeType === 1 && n !== elem ) {
+				r.push( n );
+		return r;
+var rinlinejQuery = / jQuery\d+="(?:\d+|null)"/g,
+	rleadingWhitespace = /^\s+/,
+	rxhtmlTag = /(<([\w:]+)[^>]*?)\/>/g,
+	rselfClosing = /^(?:area|br|col|embed|hr|img|input|link|meta|param)$/i,
+	rtagName = /<([\w:]+)/,
+	rtbody = /<tbody/i,
+	rhtml = /<|&\w+;/,
+	rchecked = /checked\s*(?:[^=]|=\s*.checked.)/i,  // checked="checked" or checked (html5)
+	fcloseTag = function( all, front, tag ) {
+		return rselfClosing.test( tag ) ?
+			all :
+			front + "></" + tag + ">";
+	wrapMap = {
+		option: [ 1, "<select multiple='multiple'>", "</select>" ],
+		legend: [ 1, "<fieldset>", "</fieldset>" ],
+		thead: [ 1, "<table>", "</table>" ],
+		tr: [ 2, "<table><tbody>", "</tbody></table>" ],
+		td: [ 3, "<table><tbody><tr>", "</tr></tbody></table>" ],
+		col: [ 2, "<table><tbody></tbody><colgroup>", "</colgroup></table>" ],
+		area: [ 1, "<map>", "</map>" ],
+		_default: [ 0, "", "" ]
+wrapMap.optgroup = wrapMap.option;
+wrapMap.tbody = wrapMap.tfoot = wrapMap.colgroup = wrapMap.caption = wrapMap.thead;
+wrapMap.th = wrapMap.td;
+// IE can't serialize <link> and <script> tags normally
+if ( !jQuery.support.htmlSerialize ) {
+	wrapMap._default = [ 1, "div<div>", "</div>" ];
+jQuery.fn.extend({
+	text: function( text ) {
+		if ( jQuery.isFunction(text) ) {
+			return this.each(function(i) {
+				var self = jQuery(this);
+				self.text( text.call(this, i, self.text()) );
+		if ( typeof text !== "object" && text !== undefined ) {
+			return this.empty().append( (this[0] && this[0].ownerDocument || document).createTextNode( text ) );
+		return jQuery.getText( this );
+	wrapAll: function( html ) {
+		if ( jQuery.isFunction( html ) ) {
+				jQuery(this).wrapAll( html.call(this, i) );
+		if ( this[0] ) {
+			// The elements to wrap the target around
+			var wrap = jQuery( html, this[0].ownerDocument ).eq(0).clone(true);
+			if ( this[0].parentNode ) {
+				wrap.insertBefore( this[0] );
+			wrap.map(function() {
+				var elem = this;
+				while ( elem.firstChild && elem.firstChild.nodeType === 1 ) {
+					elem = elem.firstChild;
+				return elem;
+			}).append(this);
+		return this;
+	wrapInner: function( html ) {
+				jQuery(this).wrapInner( html.call(this, i) );
+		return this.each(function() {
+			var self = jQuery( this ), contents = self.contents();
+			if ( contents.length ) {
+				contents.wrapAll( html );
+			} else {
+				self.append( html );
+	wrap: function( html ) {
+			jQuery( this ).wrapAll( html );
+	unwrap: function() {
+		return this.parent().each(function() {
+			if ( !jQuery.nodeName( this, "body" ) ) {
+				jQuery( this ).replaceWith( this.childNodes );
+		}).end();
+	append: function() {
+		return this.domManip(arguments, true, function( elem ) {
+			if ( this.nodeType === 1 ) {
+				this.appendChild( elem );
+	prepend: function() {
+				this.insertBefore( elem, this.firstChild );
+	before: function() {
+		if ( this[0] && this[0].parentNode ) {
+			return this.domManip(arguments, false, function( elem ) {
+				this.parentNode.insertBefore( elem, this );
+		} else if ( arguments.length ) {
+			var set = jQuery(arguments[0]);
+			set.push.apply( set, this.toArray() );
+			return this.pushStack( set, "before", arguments );
+	after: function() {
+				this.parentNode.insertBefore( elem, this.nextSibling );
+			var set = this.pushStack( this, "after", arguments );
+			set.push.apply( set, jQuery(arguments[0]).toArray() );
+			return set;
+	clone: function( events ) {
+		// Do the clone
+		var ret = this.map(function() {
+			if ( !jQuery.support.noCloneEvent && !jQuery.isXMLDoc(this) ) {
+				// IE copies events bound via attachEvent when
+				// using cloneNode. Calling detachEvent on the
+				// clone will also remove the events from the orignal
+				// In order to get around this, we use innerHTML.
+				// Unfortunately, this means some modifications to
+				// attributes in IE that are actually only stored
+				// as properties will not be copied (such as the
+				// the name attribute on an input).
+				var html = this.outerHTML, ownerDocument = this.ownerDocument;
+				if ( !html ) {
+					var div = ownerDocument.createElement("div");
+					div.appendChild( this.cloneNode(true) );
+					html = div.innerHTML;
+				return jQuery.clean([html.replace(rinlinejQuery, "")
+					.replace(rleadingWhitespace, "")], ownerDocument)[0];
+			} else {
+				return this.cloneNode(true);
+		// Copy the events from the original to the clone
+		if ( events === true ) {
+			cloneCopyEvent( this, ret );
+			cloneCopyEvent( this.find("*"), ret.find("*") );
+		// Return the cloned set
+		return ret;
+	html: function( value ) {
+		if ( value === undefined ) {
+			return this[0] && this[0].nodeType === 1 ?
+				this[0].innerHTML.replace(rinlinejQuery, "") :
+				null;
+		// See if we can take a shortcut and just use innerHTML
+		} else if ( typeof value === "string" && !/<script/i.test( value ) &&
+			(jQuery.support.leadingWhitespace || !rleadingWhitespace.test( value )) &&
+			!wrapMap[ (rtagName.exec( value ) || ["", ""])[1].toLowerCase() ] ) {
+			value = value.replace(rxhtmlTag, fcloseTag);
+			try {
+				for ( var i = 0, l = this.length; i < l; i++ ) {
+					// Remove element nodes and prevent memory leaks
+					if ( this[i].nodeType === 1 ) {
+						jQuery.cleanData( this[i].getElementsByTagName("*") );
+						this[i].innerHTML = value;
+			// If using innerHTML throws an exception, use the fallback method
+			} catch(e) {
+				this.empty().append( value );
+		} else if ( jQuery.isFunction( value ) ) {
+			this.each(function(i){
+				var self = jQuery(this), old = self.html();
+				self.empty().append(function(){
+					return value.call( this, i, old );
+		} else {
+		return this;
+	replaceWith: function( value ) {
+			// Make sure that the elements are removed from the DOM before they are inserted
+			// this can help fix replacing a parent with child elements
+			if ( !jQuery.isFunction( value ) ) {
+				value = jQuery( value ).detach();
+			} else {
+					self.replaceWith( value.call( this, i, old ) );
+				var next = this.nextSibling, parent = this.parentNode;
+				jQuery(this).remove();
+				if ( next ) {
+					jQuery(next).before( value );
+				} else {
+					jQuery(parent).append( value );
+		} else {
+			return this.pushStack( jQuery(jQuery.isFunction(value) ? value() : value), "replaceWith", value );
+	detach: function( selector ) {
+		return this.remove( selector, true );
+	domManip: function( args, table, callback ) {
+		var results, first, value = args[0], scripts = [];
+		// We can't cloneNode fragments that contain checked, in WebKit
+		if ( !jQuery.support.checkClone && arguments.length === 3 && typeof value === "string" && rchecked.test( value ) ) {
+				jQuery(this).domManip( args, table, callback, true );
+		if ( jQuery.isFunction(value) ) {
+				args[0] = value.call(this, i, table ? self.html() : undefined);
+				self.domManip( args, table, callback );
+		if ( this[0] ) {
+			// If we're in a fragment, just use that instead of building a new one
+			if ( args[0] && args[0].parentNode && args[0].parentNode.nodeType === 11 ) {
+				results = { fragment: args[0].parentNode };
+			} else {
+				results = buildFragment( args, this, scripts );
+			first = results.fragment.firstChild;
+			if ( first ) {
+				table = table && jQuery.nodeName( first, "tr" );
+					callback.call(
+						table ?
+							root(this[i], first) :
+							this[i],
+						results.cacheable || this.length > 1 || i > 0 ?
+							results.fragment.cloneNode(true) :
+							results.fragment
+			if ( scripts ) {
+				jQuery.each( scripts, evalScript );
+		return this;
+		function root( elem, cur ) {
+			return jQuery.nodeName(elem, "table") ?
+				(elem.getElementsByTagName("tbody")[0] ||
+				elem.appendChild(elem.ownerDocument.createElement("tbody"))) :
+				elem;
+function cloneCopyEvent(orig, ret) {
+	var i = 0;
+	ret.each(function() {
+		if ( this.nodeName !== (orig[i] && orig[i].nodeName) ) {
+			return;
+		var oldData = jQuery.data( orig[i++] ), curData = jQuery.data( this, oldData ), events = oldData && oldData.events;
+		if ( events ) {
+			delete curData.handle;
+			curData.events = {};
+			for ( var type in events ) {
+				for ( var handler in events[ type ] ) {
+					jQuery.event.add( this, type, events[ type ][ handler ], events[ type ][ handler ].data );
+function buildFragment( args, nodes, scripts ) {
+	var fragment, cacheable, cacheresults, doc;
+	// webkit does not clone 'checked' attribute of radio inputs on cloneNode, so don't cache if string has a checked
+	if ( args.length === 1 && typeof args[0] === "string" && args[0].length < 512 && args[0].indexOf("<option") < 0 && (jQuery.support.checkClone || !rchecked.test( args[0] )) ) {
+		cacheable = true;
+		cacheresults = jQuery.fragments[ args[0] ];
+		if ( cacheresults ) {
+			if ( cacheresults !== 1 ) {
+				fragment = cacheresults;
+	if ( !fragment ) {
+		doc = (nodes && nodes[0] ? nodes[0].ownerDocument || nodes[0] : document);
+		fragment = doc.createDocumentFragment();
+		jQuery.clean( args, doc, fragment, scripts );
+	if ( cacheable ) {
+		jQuery.fragments[ args[0] ] = cacheresults ? fragment : 1;
+	return { fragment: fragment, cacheable: cacheable };
+jQuery.fragments = {};
+jQuery.each({
+	appendTo: "append",
+	prependTo: "prepend",
+	insertBefore: "before",
+	insertAfter: "after",
+	replaceAll: "replaceWith"
+}, function( name, original ) {
+	jQuery.fn[ name ] = function( selector ) {
+		var ret = [], insert = jQuery( selector );
+		for ( var i = 0, l = insert.length; i < l; i++ ) {
+			var elems = (i > 0 ? this.clone(true) : this).get();
+			jQuery.fn[ original ].apply( jQuery(insert[i]), elems );
+			ret = ret.concat( elems );
+		return this.pushStack( ret, name, insert.selector );
+jQuery.each({
+	// keepData is for internal use only--do not document
+	remove: function( selector, keepData ) {
+		if ( !selector || jQuery.filter( selector, [ this ] ).length ) {
+			if ( !keepData && this.nodeType === 1 ) {
+				jQuery.cleanData( this.getElementsByTagName("*") );
+				jQuery.cleanData( [ this ] );
+			if ( this.parentNode ) {
+				 this.parentNode.removeChild( this );
+	empty: function() {
+		// Remove any remaining nodes
+		while ( this.firstChild ) {
+			this.removeChild( this.firstChild );
+	jQuery.fn[ name ] = function() {
+		return this.each( fn, arguments );
+jQuery.extend({
+	clean: function( elems, context, fragment, scripts ) {
+		// !context.createElement fails in IE with an error but returns typeof 'object'
+		if ( typeof context.createElement === "undefined" ) {
+			context = context.ownerDocument || context[0] && context[0].ownerDocument || document;
+		var ret = [];
+		jQuery.each(elems, function( i, elem ) {
+			if ( typeof elem === "number" ) {
+				elem += "";
+			if ( !elem ) {
+				return;
+			// Convert html string into DOM nodes
+			if ( typeof elem === "string" && !rhtml.test( elem ) ) {
+				elem = context.createTextNode( elem );
+			} else if ( typeof elem === "string" ) {
+				// Fix "XHTML"-style tags in all browsers
+				elem = elem.replace(rxhtmlTag, fcloseTag);
+				// Trim whitespace, otherwise indexOf won't work as expected
+				var tag = (rtagName.exec( elem ) || ["", ""])[1].toLowerCase(),
+					wrap = wrapMap[ tag ] || wrapMap._default,
+					depth = wrap[0],
+					div = context.createElement("div");
+				// Go to html and back, then peel off extra wrappers
+				div.innerHTML = wrap[1] + elem + wrap[2];
+				// Move to the right depth
+				while ( depth-- ) {
+					div = div.lastChild;
+				// Remove IE's autoinserted <tbody> from table fragments
+				if ( !jQuery.support.tbody ) {
+					// String was a <table>, *may* have spurious <tbody>
+					var hasBody = rtbody.test(elem),
+						tbody = tag === "table" && !hasBody ?
+							div.firstChild && div.firstChild.childNodes :
+							// String was a bare <thead> or <tfoot>
+							wrap[1] === "<table>" && !hasBody ?
+								div.childNodes :
+					for ( var j = tbody.length - 1; j >= 0 ; --j ) {
+						if ( jQuery.nodeName( tbody[ j ], "tbody" ) && !tbody[ j ].childNodes.length ) {
+							tbody[ j ].parentNode.removeChild( tbody[ j ] );
+				// IE completely kills leading whitespace when innerHTML is used
+				if ( !jQuery.support.leadingWhitespace && rleadingWhitespace.test( elem ) ) {
+					div.insertBefore( context.createTextNode( rleadingWhitespace.exec(elem)[0] ), div.firstChild );
+				elem = jQuery.makeArray( div.childNodes );
+			if ( elem.nodeType ) {
+				ret.push( elem );
+			} else {
+				ret = jQuery.merge( ret, elem );
+		if ( fragment ) {
+			for ( var i = 0; ret[i]; i++ ) {
+				if ( scripts && jQuery.nodeName( ret[i], "script" ) && (!ret[i].type || ret[i].type.toLowerCase() === "text/javascript") ) {
+					scripts.push( ret[i].parentNode ? ret[i].parentNode.removeChild( ret[i] ) : ret[i] );
+				} else {
+					if ( ret[i].nodeType === 1 ) {
+						ret.splice.apply( ret, [i + 1, 0].concat(jQuery.makeArray(ret[i].getElementsByTagName("script"))) );
+					fragment.appendChild( ret[i] );
+		return ret;
+	cleanData: function( elems ) {
+		for ( var i = 0, elem, id; (elem = elems[i]) != null; i++ ) {
+			jQuery.event.remove( elem );
+			jQuery.removeData( elem );
+// exclude the following css properties to add px
+var rexclude = /z-?index|font-?weight|opacity|zoom|line-?height/i,
+	ralpha = /alpha\([^)]*\)/,
+	ropacity = /opacity=([^)]*)/,
+	rfloat = /float/i,
+	rdashAlpha = /-([a-z])/ig,
+	rupper = /([A-Z])/g,
+	rnumpx = /^-?\d+(?:px)?$/i,
+	rnum = /^-?\d/,
+	cssShow = { position: "absolute", visibility: "hidden", display:"block" },
+	cssWidth = [ "Left", "Right" ],
+	cssHeight = [ "Top", "Bottom" ],
+	// cache check for defaultView.getComputedStyle
+	getComputedStyle = document.defaultView && document.defaultView.getComputedStyle,
+	// normalize float css property
+	styleFloat = jQuery.support.cssFloat ? "cssFloat" : "styleFloat",
+	fcamelCase = function( all, letter ) {
+		return letter.toUpperCase();
+jQuery.fn.css = function( name, value ) {
+	return access( this, name, value, true, function( elem, name, value ) {
+			return jQuery.curCSS( elem, name );
+		if ( typeof value === "number" && !rexclude.test(name) ) {
+			value += "px";
+		jQuery.style( elem, name, value );
+jQuery.extend({
+	style: function( elem, name, value ) {
+		// don't set styles on text and comment nodes
+		if ( !elem || elem.nodeType === 3 || elem.nodeType === 8 ) {
+			return undefined;
+		// ignore negative width and height values #1599
+		if ( (name === "width" || name === "height") && parseFloat(value) < 0 ) {
+			value = undefined;
+		var style = elem.style || elem, set = value !== undefined;
+		// IE uses filters for opacity
+		if ( !jQuery.support.opacity && name === "opacity" ) {
+			if ( set ) {
+				// IE has trouble with opacity if it does not have layout
+				// Force it by setting the zoom level
+				style.zoom = 1;
+				// Set the alpha filter to set the opacity
+				var opacity = parseInt( value, 10 ) + "" === "NaN" ? "" : "alpha(opacity=" + value * 100 + ")";
+				var filter = style.filter || jQuery.curCSS( elem, "filter" ) || "";
+				style.filter = ralpha.test(filter) ? filter.replace(ralpha, opacity) : opacity;
+			return style.filter && style.filter.indexOf("opacity=") >= 0 ?
+				(parseFloat( ropacity.exec(style.filter)[1] ) / 100) + "":
+		// Make sure we're using the right name for getting the float value
+		if ( rfloat.test( name ) ) {
+			name = styleFloat;
+		name = name.replace(rdashAlpha, fcamelCase);
+		if ( set ) {
+			style[ name ] = value;
+		return style[ name ];
+	css: function( elem, name, force, extra ) {
+		if ( name === "width" || name === "height" ) {
+			var val, props = cssShow, which = name === "width" ? cssWidth : cssHeight;
+			function getWH() {
+				val = name === "width" ? elem.offsetWidth : elem.offsetHeight;
+				if ( extra === "border" ) {
+					return;
+				jQuery.each( which, function() {
+					if ( !extra ) {
+						val -= parseFloat(jQuery.curCSS( elem, "padding" + this, true)) || 0;
+					if ( extra === "margin" ) {
+						val += parseFloat(jQuery.curCSS( elem, "margin" + this, true)) || 0;
+					} else {
+						val -= parseFloat(jQuery.curCSS( elem, "border" + this + "Width", true)) || 0;
+			if ( elem.offsetWidth !== 0 ) {
+				getWH();
+			} else {
+				jQuery.swap( elem, props, getWH );
+			return Math.max(0, Math.round(val));
+		return jQuery.curCSS( elem, name, force );
+	curCSS: function( elem, name, force ) {
+		var ret, style = elem.style, filter;
+		if ( !jQuery.support.opacity && name === "opacity" && elem.currentStyle ) {
+			ret = ropacity.test(elem.currentStyle.filter || "") ?
+				(parseFloat(RegExp.$1) / 100) + "" :
+			return ret === "" ?
+				"1" :
+				ret;
+		if ( !force && style && style[ name ] ) {
+			ret = style[ name ];
+		} else if ( getComputedStyle ) {
+			// Only "float" is needed here
+				name = "float";
+			name = name.replace( rupper, "-$1" ).toLowerCase();
+			var defaultView = elem.ownerDocument.defaultView;
+			if ( !defaultView ) {
+				return null;
+			var computedStyle = defaultView.getComputedStyle( elem, null );
+			if ( computedStyle ) {
+				ret = computedStyle.getPropertyValue( name );
+			// We should always get a number back from opacity
+			if ( name === "opacity" && ret === "" ) {
+				ret = "1";
+		} else if ( elem.currentStyle ) {
+			var camelCase = name.replace(rdashAlpha, fcamelCase);
+			ret = elem.currentStyle[ name ] || elem.currentStyle[ camelCase ];
+			// From the awesome hack by Dean Edwards
+			// http://erik.eae.net/archives/2007/07/27/18.54.15/#comment-102291
+			// If we're not dealing with a regular pixel number
+			// but a number that has a weird ending, we need to convert it to pixels
+			if ( !rnumpx.test( ret ) && rnum.test( ret ) ) {
+				// Remember the original values
+				var left = style.left, rsLeft = elem.runtimeStyle.left;
+				// Put in the new values to get a computed value out
+				elem.runtimeStyle.left = elem.currentStyle.left;
+				style.left = camelCase === "fontSize" ? "1em" : (ret || 0);
+				ret = style.pixelLeft + "px";
+				// Revert the changed values
+				style.left = left;
+				elem.runtimeStyle.left = rsLeft;
+		return ret;
+	// A method for quickly swapping in/out CSS properties to get correct calculations
+	swap: function( elem, options, callback ) {
+		var old = {};
+		// Remember the old values, and insert the new ones
+		for ( var name in options ) {
+			old[ name ] = elem.style[ name ];
+			elem.style[ name ] = options[ name ];
+		callback.call( elem );
+		// Revert the old values
+			elem.style[ name ] = old[ name ];
+if ( jQuery.expr && jQuery.expr.filters ) {
+	jQuery.expr.filters.hidden = function( elem ) {
+		var width = elem.offsetWidth, height = elem.offsetHeight,
+			skip = elem.nodeName.toLowerCase() === "tr";
+		return width === 0 && height === 0 && !skip ?
+			true :
+			width > 0 && height > 0 && !skip ?
+				false :
+				jQuery.curCSS(elem, "display") === "none";
+	jQuery.expr.filters.visible = function( elem ) {
+		return !jQuery.expr.filters.hidden( elem );
+var jsc = now(),
+	rscript = /<script(.|\s)*?\/script>/gi,
+	rselectTextarea = /select|textarea/i,
+	rinput = /color|date|datetime|email|hidden|month|number|password|range|search|tel|text|time|url|week/i,
+	jsre = /=\?(&|$)/,
+	rquery = /\?/,
+	rts = /(\?|&)_=.*?(&|$)/,
+	rurl = /^(\w+:)?\/\/([^\/?#]+)/,
+	r20 = /%20/g;
+jQuery.fn.extend({
+	// Keep a copy of the old load
+	_load: jQuery.fn.load,
+	load: function( url, params, callback ) {
+		if ( typeof url !== "string" ) {
+			return this._load( url );
+		// Don't do a request if no elements are being requested
+		} else if ( !this.length ) {
+			return this;
+		var off = url.indexOf(" ");
+		if ( off >= 0 ) {
+			var selector = url.slice(off, url.length);
+			url = url.slice(0, off);
+		// Default to a GET request
+		var type = "GET";
+		// If the second parameter was provided
+		if ( params ) {
+			// If it's a function
+			if ( jQuery.isFunction( params ) ) {
+				// We assume that it's the callback
+				callback = params;
+				params = null;
+			// Otherwise, build a param string
+			} else if ( typeof params === "object" ) {
+				params = jQuery.param( params, jQuery.ajaxSettings.traditional );
+				type = "POST";
+		var self = this;
+		// Request the remote document
+		jQuery.ajax({
+			url: url,
+			type: type,
+			dataType: "html",
+			data: params,
+			complete: function( res, status ) {
+				// If successful, inject the HTML into all the matched elements
+				if ( status === "success" || status === "notmodified" ) {
+					// See if a selector was specified
+					self.html( selector ?
+						// Create a dummy div to hold the results
+						jQuery("<div />")
+							// inject the contents of the document in, removing the scripts
+							// to avoid any 'Permission Denied' errors in IE
+							.append(res.responseText.replace(rscript, ""))
+							// Locate the specified elements
+							.find(selector) :
+						// If not, just inject the full result
+						res.responseText );
+				if ( callback ) {
+					self.each( callback, [res.responseText, status, res] );
+		return this;
+	serialize: function() {
+		return jQuery.param(this.serializeArray());
+	serializeArray: function() {
+		return this.map(function() {
+			return this.elements ? jQuery.makeArray(this.elements) : this;
+		.filter(function() {
+			return this.name && !this.disabled &&
+				(this.checked || rselectTextarea.test(this.nodeName) ||
+					rinput.test(this.type));
+		.map(function( i, elem ) {
+			var val = jQuery(this).val();
+			return val == null ?
+				null :
+				jQuery.isArray(val) ?
+					jQuery.map( val, function( val, i ) {
+						return { name: elem.name, value: val };
+					{ name: elem.name, value: val };
+		}).get();
+// Attach a bunch of functions for handling common AJAX events
+jQuery.each( "ajaxStart ajaxStop ajaxComplete ajaxError ajaxSuccess ajaxSend".split(" "), function( i, o ) {
+	jQuery.fn[o] = function( f ) {
+		return this.bind(o, f);
+jQuery.extend({
+	get: function( url, data, callback, type ) {
+		// shift arguments if data argument was omited
+			type = type || callback;
+			callback = data;
+			data = null;
+		return jQuery.ajax({
+			type: "GET",
+			url: url,
+			data: data,
+			success: callback,
+			dataType: type
+	getScript: function( url, callback ) {
+		return jQuery.get(url, null, callback, "script");
+	getJSON: function( url, data, callback ) {
+		return jQuery.get(url, data, callback, "json");
+	post: function( url, data, callback, type ) {
+			callback = data;
+			data = {};
+			type: "POST",
+			url: url,
+			data: data,
+			dataType: type
+	ajaxSetup: function( settings ) {
+		jQuery.extend( jQuery.ajaxSettings, settings );
+	ajaxSettings: {
+		url: location.href,
+		global: true,
+		type: "GET",
+		contentType: "application/x-www-form-urlencoded",
+		processData: true,
+		async: true,
+		timeout: 0,
+		data: null,
+		username: null,
+		password: null,
+		traditional: false,
+		// Create the request object; Microsoft failed to properly
+		// implement the XMLHttpRequest in IE7 (can't request local files),
+		// so we use the ActiveXObject when it is available
+		// This function can be overriden by calling jQuery.ajaxSetup
+		xhr: window.XMLHttpRequest && (window.location.protocol !== "file:" || !window.ActiveXObject) ?
+			function() {
+				return new window.XMLHttpRequest();
+			function() {
+				try {
+					return new window.ActiveXObject("Microsoft.XMLHTTP");
+				} catch(e) {}
+		accepts: {
+			xml: "application/xml, text/xml",
+			html: "text/html",
+			script: "text/javascript, application/javascript",
+			json: "application/json, text/javascript",
+			text: "text/plain",
+			_default: "*/*"
+	// Last-Modified header cache for next request
+	lastModified: {},
+	etag: {},
+	ajax: function( origSettings ) {
+		var s = jQuery.extend(true, {}, jQuery.ajaxSettings, origSettings);
+		var jsonp, status, data,
+			callbackContext = origSettings && origSettings.context || s,
+			type = s.type.toUpperCase();
+		// convert data if not already a string
+		if ( s.data && s.processData && typeof s.data !== "string" ) {
+			s.data = jQuery.param( s.data, s.traditional );
+		// Handle JSONP Parameter Callbacks
+		if ( s.dataType === "jsonp" ) {
+			if ( type === "GET" ) {
+				if ( !jsre.test( s.url ) ) {
+					s.url += (rquery.test( s.url ) ? "&" : "?") + (s.jsonp || "callback") + "=?";
+			} else if ( !s.data || !jsre.test(s.data) ) {
+				s.data = (s.data ? s.data + "&" : "") + (s.jsonp || "callback") + "=?";
+			s.dataType = "json";
+		// Build temporary JSONP function
+		if ( s.dataType === "json" && (s.data && jsre.test(s.data) || jsre.test(s.url)) ) {
+			jsonp = s.jsonpCallback || ("jsonp" + jsc++);
+			// Replace the =? sequence both in the query string and the data
+			if ( s.data ) {
+				s.data = (s.data + "").replace(jsre, "=" + jsonp + "$1");
+			s.url = s.url.replace(jsre, "=" + jsonp + "$1");
+			// We need to make sure
+			// that a JSONP style response is executed properly
+			s.dataType = "script";
+			// Handle JSONP-style loading
+			window[ jsonp ] = window[ jsonp ] || function( tmp ) {
+				data = tmp;
+				success();
+				complete();
+				// Garbage collect
+				window[ jsonp ] = undefined;
+				try {
+					delete window[ jsonp ];
+				} catch(e) {}
+				if ( head ) {
+					head.removeChild( script );
+		if ( s.dataType === "script" && s.cache === null ) {
+			s.cache = false;
+		if ( s.cache === false && type === "GET" ) {
+			var ts = now();
+			// try replacing _= if it is there
+			var ret = s.url.replace(rts, "$1_=" + ts + "$2");
+			// if nothing was replaced, add timestamp to the end
+			s.url = ret + ((ret === s.url) ? (rquery.test(s.url) ? "&" : "?") + "_=" + ts : "");
+		// If data is available, append data to url for get requests
+		if ( s.data && type === "GET" ) {
+			s.url += (rquery.test(s.url) ? "&" : "?") + s.data;
+		// Watch for a new set of requests
+		if ( s.global && ! jQuery.active++ ) {
+			jQuery.event.trigger( "ajaxStart" );
+		// Matches an absolute URL, and saves the domain
+		var parts = rurl.exec( s.url ),
+			remote = parts && (parts[1] && parts[1] !== location.protocol || parts[2] !== location.host);
+		// If we're requesting a remote document
+		// and trying to load JSON or Script with a GET
+		if ( s.dataType === "script" && type === "GET" && remote ) {
+			var head = document.getElementsByTagName("head")[0] || document.documentElement;
+			var script = document.createElement("script");
+			script.src = s.url;
+			if ( s.scriptCharset ) {
+				script.charset = s.scriptCharset;
+			// Handle Script loading
+			if ( !jsonp ) {
+				var done = false;
+				// Attach handlers for all browsers
+				script.onload = script.onreadystatechange = function() {
+					if ( !done && (!this.readyState ||
+							this.readyState === "loaded" || this.readyState === "complete") ) {
+						done = true;
+						success();
+						complete();
+						// Handle memory leak in IE
+						script.onload = script.onreadystatechange = null;
+						if ( head && script.parentNode ) {
+			// Use insertBefore instead of appendChild  to circumvent an IE6 bug.
+			// This arises when a base node is used (#2709 and #4378).
+			head.insertBefore( script, head.firstChild );
+			// We handle everything using the script element injection
+			return undefined;
+		var requestDone = false;
+		var xhr = s.xhr();
+		if ( !xhr ) {
+			return;
+		// Open the socket
+		// Passing null username, generates a login popup on Opera (#2865)
+		if ( s.username ) {
+			xhr.open(type, s.url, s.async, s.username, s.password);
+		} else {
+			xhr.open(type, s.url, s.async);
+		// Need an extra try/catch for cross domain requests in Firefox 3
+		try {
+			// Set the correct header, if data is being sent
+			if ( s.data || origSettings && origSettings.contentType ) {
+				xhr.setRequestHeader("Content-Type", s.contentType);
+			// Set the If-Modified-Since and/or If-None-Match header, if in ifModified mode.
+			if ( s.ifModified ) {
+				if ( jQuery.lastModified[s.url] ) {
+					xhr.setRequestHeader("If-Modified-Since", jQuery.lastModified[s.url]);
+				if ( jQuery.etag[s.url] ) {
+					xhr.setRequestHeader("If-None-Match", jQuery.etag[s.url]);
+			// Set header so the called script knows that it's an XMLHttpRequest
+			// Only send the header if it's not a remote XHR
+			if ( !remote ) {
+				xhr.setRequestHeader("X-Requested-With", "XMLHttpRequest");
+			// Set the Accepts header for the server, depending on the dataType
+			xhr.setRequestHeader("Accept", s.dataType && s.accepts[ s.dataType ] ?
+				s.accepts[ s.dataType ] + ", */*" :
+				s.accepts._default );
+		} catch(e) {}
+		// Allow custom headers/mimetypes and early abort
+		if ( s.beforeSend && s.beforeSend.call(callbackContext, xhr, s) === false ) {
+			// Handle the global AJAX counter
+			if ( s.global && ! --jQuery.active ) {
+				jQuery.event.trigger( "ajaxStop" );
+			// close opended socket
+			xhr.abort();
+			return false;
+		if ( s.global ) {
+			trigger("ajaxSend", [xhr, s]);
+		// Wait for a response to come back
+		var onreadystatechange = xhr.onreadystatechange = function( isTimeout ) {
+			// The request was aborted
+			if ( !xhr || xhr.readyState === 0 || isTimeout === "abort" ) {
+				// Opera doesn't call onreadystatechange before this point
+				// so we simulate the call
+				if ( !requestDone ) {
+					complete();
+				requestDone = true;
+				if ( xhr ) {
+					xhr.onreadystatechange = jQuery.noop;
+			// The transfer is complete and the data is available, or the request timed out
+			} else if ( !requestDone && xhr && (xhr.readyState === 4 || isTimeout === "timeout") ) {
+				status = isTimeout === "timeout" ?
+					"timeout" :
+					!jQuery.httpSuccess( xhr ) ?
+						"error" :
+						s.ifModified && jQuery.httpNotModified( xhr, s.url ) ?
+							"notmodified" :
+							"success";
+				var errMsg;
+				if ( status === "success" ) {
+					// Watch for, and catch, XML document parse errors
+					try {
+						// process the data (runs the xml through httpData regardless of callback)
+						data = jQuery.httpData( xhr, s.dataType, s );
+					} catch(err) {
+						status = "parsererror";
+						errMsg = err;
+				// Make sure that the request was successful or notmodified
+					// JSONP handles its own success callback
+					if ( !jsonp ) {
+						success();
+				} else {
+					jQuery.handleError(s, xhr, status, errMsg);
+				// Fire the complete handlers
+				complete();
+				if ( isTimeout === "timeout" ) {
+					xhr.abort();
+				// Stop memory leaks
+				if ( s.async ) {
+					xhr = null;
+		// Override the abort handler, if we can (IE doesn't allow it, but that's OK)
+		// Opera doesn't fire onreadystatechange at all on abort
+		try {
+			var oldAbort = xhr.abort;
+			xhr.abort = function() {
+				if ( xhr ) {
+					oldAbort.call( xhr );
+				onreadystatechange( "abort" );
+		} catch(e) { }
+		// Timeout checker
+		if ( s.async && s.timeout > 0 ) {
+			setTimeout(function() {
+				// Check to see if the request is still happening
+				if ( xhr && !requestDone ) {
+					onreadystatechange( "timeout" );
+			}, s.timeout);
+		// Send the data
+		try {
+			xhr.send( type === "POST" || type === "PUT" || type === "DELETE" ? s.data : null );
+		} catch(e) {
+			jQuery.handleError(s, xhr, null, e);
+			complete();
+		// firefox 1.5 doesn't fire statechange for sync requests
+		if ( !s.async ) {
+			onreadystatechange();
+		function success() {
+			// If a local callback was specified, fire it and pass it the data
+			if ( s.success ) {
+				s.success.call( callbackContext, data, status, xhr );
+			// Fire the global callback
+			if ( s.global ) {
+				trigger( "ajaxSuccess", [xhr, s] );
+		function complete() {
+			// Process result
+			if ( s.complete ) {
+				s.complete.call( callbackContext, xhr, status);
+			// The request was completed
+			if ( s.global ) {
+				trigger( "ajaxComplete", [xhr, s] );
+		function trigger(type, args) {
+			(s.context ? jQuery(s.context) : jQuery.event).trigger(type, args);
+		// return XMLHttpRequest to allow aborting the request etc.
+		return xhr;
+	handleError: function( s, xhr, status, e ) {
+		if ( s.error ) {
+			s.error.call( s.context || s, xhr, status, e );
+		if ( s.global ) {
+			(s.context ? jQuery(s.context) : jQuery.event).trigger( "ajaxError", [xhr, s, e] );
+	// Counter for holding the number of active queries
+	active: 0,
+	// Determines if an XMLHttpRequest was successful or not
+	httpSuccess: function( xhr ) {
+		try {
+			// IE error sometimes returns 1223 when it should be 204 so treat it as success, see #1450
+			return !xhr.status && location.protocol === "file:" ||
+				// Opera returns 0 when status is 304
+				( xhr.status >= 200 && xhr.status < 300 ) ||
+				xhr.status === 304 || xhr.status === 1223 || xhr.status === 0;
+		} catch(e) {}
+		return false;
+	// Determines if an XMLHttpRequest returns NotModified
+	httpNotModified: function( xhr, url ) {
+		var lastModified = xhr.getResponseHeader("Last-Modified"),
+			etag = xhr.getResponseHeader("Etag");
+		if ( lastModified ) {
+			jQuery.lastModified[url] = lastModified;
+		if ( etag ) {
+			jQuery.etag[url] = etag;
+		return xhr.status === 304 || xhr.status === 0;
+	httpData: function( xhr, type, s ) {
+		var ct = xhr.getResponseHeader("content-type") || "",
+			xml = type === "xml" || !type && ct.indexOf("xml") >= 0,
+			data = xml ? xhr.responseXML : xhr.responseText;
+		if ( xml && data.documentElement.nodeName === "parsererror" ) {
+			jQuery.error( "parsererror" );
+		// Allow a pre-filtering function to sanitize the response
+		// s is checked to keep backwards compatibility
+		if ( s && s.dataFilter ) {
+			data = s.dataFilter( data, type );
+		// The filter can actually parse the response
+		if ( typeof data === "string" ) {
+			// Get the JavaScript object, if JSON is used.
+			if ( type === "json" || !type && ct.indexOf("json") >= 0 ) {
+				data = jQuery.parseJSON( data );
+			// If the type is "script", eval it in global context
+			} else if ( type === "script" || !type && ct.indexOf("javascript") >= 0 ) {
+				jQuery.globalEval( data );
+		return data;
+	// Serialize an array of form elements or a set of
+	// key/values into a query string
+	param: function( a, traditional ) {
+		var s = [];
+		// Set traditional to true for jQuery <= 1.3.2 behavior.
+		if ( traditional === undefined ) {
+			traditional = jQuery.ajaxSettings.traditional;
+		// If an array was passed in, assume that it is an array of form elements.
+		if ( jQuery.isArray(a) || a.jquery ) {
+			// Serialize the form elements
+			jQuery.each( a, function() {
+				add( this.name, this.value );
+		} else {
+			// If traditional, encode the "old" way (the way 1.3.2 or older
+			// did it), otherwise encode params recursively.
+			for ( var prefix in a ) {
+				buildParams( prefix, a[prefix] );
+		// Return the resulting serialization
+		return s.join("&").replace(r20, "+");
+		function buildParams( prefix, obj ) {
+			if ( jQuery.isArray(obj) ) {
+				// Serialize array item.
+				jQuery.each( obj, function( i, v ) {
+					if ( traditional ) {
+						// Treat each array item as a scalar.
+						add( prefix, v );
+					} else {
+						// If array item is non-scalar (array or object), encode its
+						// numeric index to resolve deserialization ambiguity issues.
+						// Note that rack (as of 1.0.0) can't currently deserialize
+						// nested arrays properly, and attempting to do so may cause
+						// a server error. Possible fixes are to modify rack's
+						// deserialization algorithm or to provide an option or flag
+						// to force array serialization to be shallow.
+						buildParams( prefix + "[" + ( typeof v === "object" || jQuery.isArray(v) ? i : "" ) + "]", v );
+			} else if ( !traditional && obj != null && typeof obj === "object" ) {
+				// Serialize object item.
+				jQuery.each( obj, function( k, v ) {
+					buildParams( prefix + "[" + k + "]", v );
+			} else {
+				// Serialize scalar item.
+				add( prefix, obj );
+		function add( key, value ) {
+			// If value is a function, invoke it and return its value
+			value = jQuery.isFunction(value) ? value() : value;
+			s[ s.length ] = encodeURIComponent(key) + "=" + encodeURIComponent(value);
+var elemdisplay = {},
+	rfxtypes = /toggle|show|hide/,
+	rfxnum = /^([+-]=)?([\d+-.]+)(.*)$/,
+	timerId,
+	fxAttrs = [
+		// height animations
+		[ "height", "marginTop", "marginBottom", "paddingTop", "paddingBottom" ],
+		// width animations
+		[ "width", "marginLeft", "marginRight", "paddingLeft", "paddingRight" ],
+		// opacity animations
+		[ "opacity" ]
+jQuery.fn.extend({
+	show: function( speed, callback ) {
+		if ( speed || speed === 0) {
+			return this.animate( genFx("show", 3), speed, callback);
+		} else {
+				var old = jQuery.data(this[i], "olddisplay");
+				this[i].style.display = old || "";
+				if ( jQuery.css(this[i], "display") === "none" ) {
+					var nodeName = this[i].nodeName, display;
+					if ( elemdisplay[ nodeName ] ) {
+						display = elemdisplay[ nodeName ];
+					} else {
+						var elem = jQuery("<" + nodeName + " />").appendTo("body");
+						display = elem.css("display");
+						if ( display === "none" ) {
+							display = "block";
+						elem.remove();
+						elemdisplay[ nodeName ] = display;
+					jQuery.data(this[i], "olddisplay", display);
+			// Set the display of the elements in a second loop
+			// to avoid the constant reflow
+			for ( var j = 0, k = this.length; j < k; j++ ) {
+				this[j].style.display = jQuery.data(this[j], "olddisplay") || "";
+			return this;
+	hide: function( speed, callback ) {
+		if ( speed || speed === 0 ) {
+			return this.animate( genFx("hide", 3), speed, callback);
+		} else {
+				if ( !old && old !== "none" ) {
+					jQuery.data(this[i], "olddisplay", jQuery.css(this[i], "display"));
+				this[j].style.display = "none";
+			return this;
+	// Save the old toggle function
+	_toggle: jQuery.fn.toggle,
+	toggle: function( fn, fn2 ) {
+		var bool = typeof fn === "boolean";
+		if ( jQuery.isFunction(fn) && jQuery.isFunction(fn2) ) {
+			this._toggle.apply( this, arguments );
+		} else if ( fn == null || bool ) {
+			this.each(function() {
+				var state = bool ? fn : jQuery(this).is(":hidden");
+				jQuery(this)[ state ? "show" : "hide" ]();
+		} else {
+			this.animate(genFx("toggle", 3), fn, fn2);
+		return this;
+	fadeTo: function( speed, to, callback ) {
+		return this.filter(":hidden").css("opacity", 0).show().end()
+					.animate({opacity: to}, speed, callback);
+	animate: function( prop, speed, easing, callback ) {
+		var optall = jQuery.speed(speed, easing, callback);
+		if ( jQuery.isEmptyObject( prop ) ) {
+			return this.each( optall.complete );
+		return this[ optall.queue === false ? "each" : "queue" ](function() {
+			var opt = jQuery.extend({}, optall), p,
+				hidden = this.nodeType === 1 && jQuery(this).is(":hidden"),
+				self = this;
+			for ( p in prop ) {
+				var name = p.replace(rdashAlpha, fcamelCase);
+				if ( p !== name ) {
+					prop[ name ] = prop[ p ];
+					delete prop[ p ];
+					p = name;
+				if ( prop[p] === "hide" && hidden || prop[p] === "show" && !hidden ) {
+					return opt.complete.call(this);
+				if ( ( p === "height" || p === "width" ) && this.style ) {
+					// Store display property
+					opt.display = jQuery.css(this, "display");
+					// Make sure that nothing sneaks out
+					opt.overflow = this.style.overflow;
+				if ( jQuery.isArray( prop[p] ) ) {
+					// Create (if needed) and add to specialEasing
+					(opt.specialEasing = opt.specialEasing || {})[p] = prop[p][1];
+					prop[p] = prop[p][0];
+			if ( opt.overflow != null ) {
+				this.style.overflow = "hidden";
+			opt.curAnim = jQuery.extend({}, prop);
+			jQuery.each( prop, function( name, val ) {
+				var e = new jQuery.fx( self, opt, name );
+				if ( rfxtypes.test(val) ) {
+					e[ val === "toggle" ? hidden ? "show" : "hide" : val ]( prop );
+				} else {
+					var parts = rfxnum.exec(val),
+						start = e.cur(true) || 0;
+					if ( parts ) {
+						var end = parseFloat( parts[2] ),
+							unit = parts[3] || "px";
+						// We need to compute starting value
+						if ( unit !== "px" ) {
+							self.style[ name ] = (end || 1) + unit;
+							start = ((end || 1) / e.cur(true)) * start;
+							self.style[ name ] = start + unit;
+						// If a +=/-= token was provided, we're doing a relative animation
+						if ( parts[1] ) {
+							end = ((parts[1] === "-=" ? -1 : 1) * end) + start;
+						e.custom( start, end, unit );
+					} else {
+						e.custom( start, val, "" );
+			// For JS strict compliance
+			return true;
+	stop: function( clearQueue, gotoEnd ) {
+		var timers = jQuery.timers;
+		if ( clearQueue ) {
+			this.queue([]);
+			// go in reverse order so anything added to the queue during the loop is ignored
+			for ( var i = timers.length - 1; i >= 0; i-- ) {
+				if ( timers[i].elem === this ) {
+					if (gotoEnd) {
+						// force the next step to be the last
+						timers[i](true);
+					timers.splice(i, 1);
+		// start the next in the queue if the last step wasn't forced
+		if ( !gotoEnd ) {
+			this.dequeue();
+		return this;
+// Generate shortcuts for custom animations
+jQuery.each({
+	slideDown: genFx("show", 1),
+	slideUp: genFx("hide", 1),
+	slideToggle: genFx("toggle", 1),
+	fadeIn: { opacity: "show" },
+	fadeOut: { opacity: "hide" }
+}, function( name, props ) {
+	jQuery.fn[ name ] = function( speed, callback ) {
+		return this.animate( props, speed, callback );
+jQuery.extend({
+	speed: function( speed, easing, fn ) {
+		var opt = speed && typeof speed === "object" ? speed : {
+			complete: fn || !fn && easing ||
+				jQuery.isFunction( speed ) && speed,
+			duration: speed,
+			easing: fn && easing || easing && !jQuery.isFunction(easing) && easing
+		opt.duration = jQuery.fx.off ? 0 : typeof opt.duration === "number" ? opt.duration :
+			jQuery.fx.speeds[opt.duration] || jQuery.fx.speeds._default;
+		// Queueing
+		opt.old = opt.complete;
+		opt.complete = function() {
+			if ( opt.queue !== false ) {
+				jQuery(this).dequeue();
+			if ( jQuery.isFunction( opt.old ) ) {
+				opt.old.call( this );
+		return opt;
+	easing: {
+		linear: function( p, n, firstNum, diff ) {
+			return firstNum + diff * p;
+		swing: function( p, n, firstNum, diff ) {
+			return ((-Math.cos(p*Math.PI)/2) + 0.5) * diff + firstNum;
+	timers: [],
+	fx: function( elem, options, prop ) {
+		this.options = options;
+		this.elem = elem;
+		this.prop = prop;
+		if ( !options.orig ) {
+			options.orig = {};
+jQuery.fx.prototype = {
+	// Simple function for setting a style value
+	update: function() {
+		if ( this.options.step ) {
+			this.options.step.call( this.elem, this.now, this );
+		(jQuery.fx.step[this.prop] || jQuery.fx.step._default)( this );
+		// Set display property to block for height/width animations
+		if ( ( this.prop === "height" || this.prop === "width" ) && this.elem.style ) {
+			this.elem.style.display = "block";
+	// Get the current size
+	cur: function( force ) {
+		if ( this.elem[this.prop] != null && (!this.elem.style || this.elem.style[this.prop] == null) ) {
+			return this.elem[ this.prop ];
+		var r = parseFloat(jQuery.css(this.elem, this.prop, force));
+		return r && r > -10000 ? r : parseFloat(jQuery.curCSS(this.elem, this.prop)) || 0;
+	// Start an animation from one number to another
+	custom: function( from, to, unit ) {
+		this.startTime = now();
+		this.start = from;
+		this.end = to;
+		this.unit = unit || this.unit || "px";
+		this.now = this.start;
+		this.pos = this.state = 0;
+		var self = this;
+		function t( gotoEnd ) {
+			return self.step(gotoEnd);
+		t.elem = this.elem;
+		if ( t() && jQuery.timers.push(t) && !timerId ) {
+			timerId = setInterval(jQuery.fx.tick, 13);
+	// Simple 'show' function
+	show: function() {
+		// Remember where we started, so that we can go back to it later
+		this.options.orig[this.prop] = jQuery.style( this.elem, this.prop );
+		this.options.show = true;
+		// Begin the animation
+		// Make sure that we start at a small width/height to avoid any
+		// flash of content
+		this.custom(this.prop === "width" || this.prop === "height" ? 1 : 0, this.cur());
+		// Start by showing the element
+		jQuery( this.elem ).show();
+	// Simple 'hide' function
+	hide: function() {
+		this.options.hide = true;
+		this.custom(this.cur(), 0);
+	// Each step of an animation
+	step: function( gotoEnd ) {
+		var t = now(), done = true;
+		if ( gotoEnd || t >= this.options.duration + this.startTime ) {
+			this.now = this.end;
+			this.pos = this.state = 1;
+			this.update();
+			this.options.curAnim[ this.prop ] = true;
+			for ( var i in this.options.curAnim ) {
+				if ( this.options.curAnim[i] !== true ) {
+					done = false;
+			if ( done ) {
+				if ( this.options.display != null ) {
+					// Reset the overflow
+					this.elem.style.overflow = this.options.overflow;
+					// Reset the display
+					var old = jQuery.data(this.elem, "olddisplay");
+					this.elem.style.display = old ? old : this.options.display;
+					if ( jQuery.css(this.elem, "display") === "none" ) {
+				// Hide the element if the "hide" operation was done
+				if ( this.options.hide ) {
+					jQuery(this.elem).hide();
+				// Reset the properties, if the item has been hidden or shown
+				if ( this.options.hide || this.options.show ) {
+					for ( var p in this.options.curAnim ) {
+						jQuery.style(this.elem, p, this.options.orig[p]);
+				// Execute the complete function
+				this.options.complete.call( this.elem );
+			return false;
+		} else {
+			var n = t - this.startTime;
+			this.state = n / this.options.duration;
+			// Perform the easing function, defaults to swing
+			var specialEasing = this.options.specialEasing && this.options.specialEasing[this.prop];
+			var defaultEasing = this.options.easing || (jQuery.easing.swing ? "swing" : "linear");
+			this.pos = jQuery.easing[specialEasing || defaultEasing](this.state, n, 0, 1, this.options.duration);
+			this.now = this.start + ((this.end - this.start) * this.pos);
+			// Perform the next step of the animation
+			this.update();
+		return true;
+jQuery.extend( jQuery.fx, {
+	tick: function() {
+		for ( var i = 0; i < timers.length; i++ ) {
+			if ( !timers[i]() ) {
+				timers.splice(i--, 1);
+		if ( !timers.length ) {
+			jQuery.fx.stop();
+	stop: function() {
+		clearInterval( timerId );
+		timerId = null;
+	speeds: {
+		slow: 600,
+ 		fast: 200,
+ 		// Default speed
+ 		_default: 400
+	step: {
+		opacity: function( fx ) {
+			jQuery.style(fx.elem, "opacity", fx.now);
+		_default: function( fx ) {
+			if ( fx.elem.style && fx.elem.style[ fx.prop ] != null ) {
+				fx.elem.style[ fx.prop ] = (fx.prop === "width" || fx.prop === "height" ? Math.max(0, fx.now) : fx.now) + fx.unit;
+			} else {
+				fx.elem[ fx.prop ] = fx.now;
+	jQuery.expr.filters.animated = function( elem ) {
+		return jQuery.grep(jQuery.timers, function( fn ) {
+			return elem === fn.elem;
+		}).length;
+function genFx( type, num ) {
+	var obj = {};
+	jQuery.each( fxAttrs.concat.apply([], fxAttrs.slice(0,num)), function() {
+		obj[ this ] = type;
+	return obj;
+if ( "getBoundingClientRect" in document.documentElement ) {
+	jQuery.fn.offset = function( options ) {
+		var elem = this[0];
+		if ( options ) {
+			return this.each(function( i ) {
+				jQuery.offset.setOffset( this, options, i );
+		if ( !elem || !elem.ownerDocument ) {
+			return null;
+		if ( elem === elem.ownerDocument.body ) {
+			return jQuery.offset.bodyOffset( elem );
+		var box = elem.getBoundingClientRect(), doc = elem.ownerDocument, body = doc.body, docElem = doc.documentElement,
+			clientTop = docElem.clientTop || body.clientTop || 0, clientLeft = docElem.clientLeft || body.clientLeft || 0,
+			top  = box.top  + (self.pageYOffset || jQuery.support.boxModel && docElem.scrollTop  || body.scrollTop ) - clientTop,
+			left = box.left + (self.pageXOffset || jQuery.support.boxModel && docElem.scrollLeft || body.scrollLeft) - clientLeft;
+		return { top: top, left: left };
+} else {
+		if ( options ) {
+			return null;
+		jQuery.offset.initialize();
+		var offsetParent = elem.offsetParent, prevOffsetParent = elem,
+			doc = elem.ownerDocument, computedStyle, docElem = doc.documentElement,
+			body = doc.body, defaultView = doc.defaultView,
+			prevComputedStyle = defaultView ? defaultView.getComputedStyle( elem, null ) : elem.currentStyle,
+			top = elem.offsetTop, left = elem.offsetLeft;
+		while ( (elem = elem.parentNode) && elem !== body && elem !== docElem ) {
+			if ( jQuery.offset.supportsFixedPosition && prevComputedStyle.position === "fixed" ) {
+				break;
+			computedStyle = defaultView ? defaultView.getComputedStyle(elem, null) : elem.currentStyle;
+			top  -= elem.scrollTop;
+			left -= elem.scrollLeft;
+			if ( elem === offsetParent ) {
+				top  += elem.offsetTop;
+				left += elem.offsetLeft;
+				if ( jQuery.offset.doesNotAddBorder && !(jQuery.offset.doesAddBorderForTableAndCells && /^t(able|d|h)$/i.test(elem.nodeName)) ) {
+					top  += parseFloat( computedStyle.borderTopWidth  ) || 0;
+					left += parseFloat( computedStyle.borderLeftWidth ) || 0;
+				prevOffsetParent = offsetParent, offsetParent = elem.offsetParent;
+			if ( jQuery.offset.subtractsBorderForOverflowNotVisible && computedStyle.overflow !== "visible" ) {
+			prevComputedStyle = computedStyle;
+		if ( prevComputedStyle.position === "relative" || prevComputedStyle.position === "static" ) {
+			top  += body.offsetTop;
+			left += body.offsetLeft;
+			top  += Math.max( docElem.scrollTop, body.scrollTop );
+			left += Math.max( docElem.scrollLeft, body.scrollLeft );
+jQuery.offset = {
+	initialize: function() {
+		var body = document.body, container = document.createElement("div"), innerDiv, checkDiv, table, td, bodyMarginTop = parseFloat( jQuery.curCSS(body, "marginTop", true) ) || 0,
+			html = "<div style='position:absolute;top:0;left:0;margin:0;border:5px solid #000;padding:0;width:1px;height:1px;'><div></div></div><table style='position:absolute;top:0;left:0;margin:0;border:5px solid #000;padding:0;width:1px;height:1px;' cellpadding='0' cellspacing='0'><tr><td></td></tr></table>";
+		jQuery.extend( container.style, { position: "absolute", top: 0, left: 0, margin: 0, border: 0, width: "1px", height: "1px", visibility: "hidden" } );
+		container.innerHTML = html;
+		body.insertBefore( container, body.firstChild );
+		innerDiv = container.firstChild;
+		checkDiv = innerDiv.firstChild;
+		td = innerDiv.nextSibling.firstChild.firstChild;
+		this.doesNotAddBorder = (checkDiv.offsetTop !== 5);
+		this.doesAddBorderForTableAndCells = (td.offsetTop === 5);
+		checkDiv.style.position = "fixed", checkDiv.style.top = "20px";
+		// safari subtracts parent border width here which is 5px
+		this.supportsFixedPosition = (checkDiv.offsetTop === 20 || checkDiv.offsetTop === 15);
+		checkDiv.style.position = checkDiv.style.top = "";
+		innerDiv.style.overflow = "hidden", innerDiv.style.position = "relative";
+		this.subtractsBorderForOverflowNotVisible = (checkDiv.offsetTop === -5);
+		this.doesNotIncludeMarginInBodyOffset = (body.offsetTop !== bodyMarginTop);
+		body.removeChild( container );
+		body = container = innerDiv = checkDiv = table = td = null;
+		jQuery.offset.initialize = jQuery.noop;
+	bodyOffset: function( body ) {
+		var top = body.offsetTop, left = body.offsetLeft;
+		if ( jQuery.offset.doesNotIncludeMarginInBodyOffset ) {
+			top  += parseFloat( jQuery.curCSS(body, "marginTop",  true) ) || 0;
+			left += parseFloat( jQuery.curCSS(body, "marginLeft", true) ) || 0;
+	setOffset: function( elem, options, i ) {
+		// set position first, in-case top/left are set even on static elem
+		if ( /static/.test( jQuery.curCSS( elem, "position" ) ) ) {
+			elem.style.position = "relative";
+		var curElem   = jQuery( elem ),
+			curOffset = curElem.offset(),
+			curTop    = parseInt( jQuery.curCSS( elem, "top",  true ), 10 ) || 0,
+			curLeft   = parseInt( jQuery.curCSS( elem, "left", true ), 10 ) || 0;
+		if ( jQuery.isFunction( options ) ) {
+			options = options.call( elem, i, curOffset );
+		var props = {
+			top:  (options.top  - curOffset.top)  + curTop,
+			left: (options.left - curOffset.left) + curLeft
+		if ( "using" in options ) {
+			options.using.call( elem, props );
+		} else {
+			curElem.css( props );
+jQuery.fn.extend({
+	position: function() {
+		if ( !this[0] ) {
+			return null;
+		var elem = this[0],
+		// Get *real* offsetParent
+		offsetParent = this.offsetParent(),
+		// Get correct offsets
+		offset       = this.offset(),
+		parentOffset = /^body|html$/i.test(offsetParent[0].nodeName) ? { top: 0, left: 0 } : offsetParent.offset();
+		// Subtract element margins
+		// note: when an element has margin: auto the offsetLeft and marginLeft
+		// are the same in Safari causing offset.left to incorrectly be 0
+		offset.top  -= parseFloat( jQuery.curCSS(elem, "marginTop",  true) ) || 0;
+		offset.left -= parseFloat( jQuery.curCSS(elem, "marginLeft", true) ) || 0;
+		// Add offsetParent borders
+		parentOffset.top  += parseFloat( jQuery.curCSS(offsetParent[0], "borderTopWidth",  true) ) || 0;
+		parentOffset.left += parseFloat( jQuery.curCSS(offsetParent[0], "borderLeftWidth", true) ) || 0;
+		// Subtract the two offsets
+		return {
+			top:  offset.top  - parentOffset.top,
+			left: offset.left - parentOffset.left
+	offsetParent: function() {
+			var offsetParent = this.offsetParent || document.body;
+			while ( offsetParent && (!/^body|html$/i.test(offsetParent.nodeName) && jQuery.css(offsetParent, "position") === "static") ) {
+				offsetParent = offsetParent.offsetParent;
+			return offsetParent;
+// Create scrollLeft and scrollTop methods
+jQuery.each( ["Left", "Top"], function( i, name ) {
+	var method = "scroll" + name;
+	jQuery.fn[ method ] = function(val) {
+		var elem = this[0], win;
+		if ( !elem ) {
+			return null;
+		if ( val !== undefined ) {
+			// Set the scroll offset
+				win = getWindow( this );
+				if ( win ) {
+					win.scrollTo(
+						!i ? val : jQuery(win).scrollLeft(),
+						 i ? val : jQuery(win).scrollTop()
+				} else {
+					this[ method ] = val;
+		} else {
+			win = getWindow( elem );
+			// Return the scroll offset
+			return win ? ("pageXOffset" in win) ? win[ i ? "pageYOffset" : "pageXOffset" ] :
+				jQuery.support.boxModel && win.document.documentElement[ method ] ||
+					win.document.body[ method ] :
+				elem[ method ];
+function getWindow( elem ) {
+	return ("scrollTo" in elem && elem.document) ?
+		elem :
+		elem.nodeType === 9 ?
+			elem.defaultView || elem.parentWindow :
+			false;
+// Create innerHeight, innerWidth, outerHeight and outerWidth methods
+jQuery.each([ "Height", "Width" ], function( i, name ) {
+	var type = name.toLowerCase();
+	// innerHeight and innerWidth
+	jQuery.fn["inner" + name] = function() {
+		return this[0] ?
+			jQuery.css( this[0], type, false, "padding" ) :
+			null;
+	// outerHeight and outerWidth
+	jQuery.fn["outer" + name] = function( margin ) {
+		return this[0] ?
+			jQuery.css( this[0], type, false, margin ? "margin" : "border" ) :
+			null;
+	jQuery.fn[ type ] = function( size ) {
+		// Get window width or height
+		if ( !elem ) {
+			return size == null ? null : this;
+		if ( jQuery.isFunction( size ) ) {
+				var self = jQuery( this );
+				self[ type ]( size.call( this, i, self[ type ]() ) );
+		return ("scrollTo" in elem && elem.document) ? // does it walk and quack like a window?
+			// Everyone else use document.documentElement or document.body depending on Quirks vs Standards mode
+			elem.document.compatMode === "CSS1Compat" && elem.document.documentElement[ "client" + name ] ||
+			elem.document.body[ "client" + name ] :
+			// Get document width or height
+			(elem.nodeType === 9) ? // is it a document
+				// Either scroll[Width/Height] or offset[Width/Height], whichever is greater
+				Math.max(
+					elem.documentElement["client" + name],
+					elem.body["scroll" + name], elem.documentElement["scroll" + name],
+					elem.body["offset" + name], elem.documentElement["offset" + name]
+				// Get or set width or height on the element
+				size === undefined ?
+					// Get width or height on the element
+					jQuery.css( elem, type ) :
+					// Set the width or height on the element (default to pixels if value is unitless)
+					this.css( type, typeof size === "string" ? size : size + "px" );
+// Expose jQuery to the global object
+window.jQuery = window.$ = jQuery;
+})(window);
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/lib/jquery.metadata.js
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/lib/jquery.metadata.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/lib/jquery.metadata.js	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,122 @@
+ * Metadata - jQuery plugin for parsing metadata from elements
+ * Copyright (c) 2006 John Resig, Yehuda Katz, J�örn Zaefferer, Paul McLanahan
+ * Dual licensed under the MIT and GPL licenses:
+ *   http://www.opensource.org/licenses/mit-license.php
+ *   http://www.gnu.org/licenses/gpl.html
+ * Revision: $Id: jquery.metadata.js 4187 2007-12-16 17:15:27Z joern.zaefferer $
+ * Sets the type of metadata to use. Metadata is encoded in JSON, and each property
+ * in the JSON will become a property of the element itself.
+ * There are three supported types of metadata storage:
+ *   attr:  Inside an attribute. The name parameter indicates *which* attribute.
+ *   class: Inside the class attribute, wrapped in curly braces: { }
+ *   elem:  Inside a child element (e.g. a script tag). The
+ *          name parameter indicates *which* element.
+ * The metadata for an element is loaded the first time the element is accessed via jQuery.
+ * As a result, you can define the metadata type, use $(expr) to load the metadata into the elements
+ * matched by expr, then redefine the metadata type and run another $(expr) for other elements.
+ * @name $.metadata.setType
+ * @example <p id="one" class="some_class {item_id: 1, item_label: 'Label'}">This is a p</p>
+ * @before $.metadata.setType("class")
+ * @after $("#one").metadata().item_id == 1; $("#one").metadata().item_label == "Label"
+ * @desc Reads metadata from the class attribute
+ * @example <p id="one" class="some_class" data="{item_id: 1, item_label: 'Label'}">This is a p</p>
+ * @before $.metadata.setType("attr", "data")
+ * @desc Reads metadata from a "data" attribute
+ * @example <p id="one" class="some_class"><script>{item_id: 1, item_label: 'Label'}</script>This is a p</p>
+ * @before $.metadata.setType("elem", "script")
+ * @desc Reads metadata from a nested script element
+ * @param String type The encoding type
+ * @param String name The name of the attribute to be used to get metadata (optional)
+ * @cat Plugins/Metadata
+ * @descr Sets the type of encoding to be used when loading metadata for the first time
+ * @type undefined
+ * @see metadata()
+(function($) {
+$.extend({
+	metadata : {
+		defaults : {
+			type: 'class',
+			name: 'metadata',
+			cre: /({.*})/,
+			single: 'metadata'
+		setType: function( type, name ){
+			this.defaults.type = type;
+			this.defaults.name = name;
+		get: function( elem, opts ){
+			var settings = $.extend({},this.defaults,opts);
+			// check for empty string in single property
+			if ( !settings.single.length ) settings.single = 'metadata';
+			var data = $.data(elem, settings.single);
+			// returned cached data if it already exists
+			if ( data ) return data;
+			data = "{}";
+			if ( settings.type == "class" ) {
+				var m = settings.cre.exec( elem.className );
+				if ( m )
+					data = m[1];
+			} else if ( settings.type == "elem" ) {
+				if( !elem.getElementsByTagName )
+					return undefined;
+				var e = elem.getElementsByTagName(settings.name);
+				if ( e.length )
+					data = $.trim(e[0].innerHTML);
+			} else if ( elem.getAttribute != undefined ) {
+				var attr = elem.getAttribute( settings.name );
+				if ( attr )
+					data = attr;
+			if ( data.indexOf( '{' ) <0 )
+			data = "{" + data + "}";
+			data = eval("(" + data + ")");
+			$.data( elem, settings.single, data );
+			return data;
+ * Returns the metadata object for the first member of the jQuery object.
+ * @name metadata
+ * @descr Returns element's metadata object
+ * @param Object opts An object contianing settings to override the defaults
+ * @type jQuery
+$.fn.metadata = function( opts ){
+	return $.metadata.get( this[0], opts );
+})(jQuery);
\ No newline at end of file
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/lib/sarissa.js
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/lib/sarissa.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/lib/sarissa.js	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,110 @@
+ * About: This a a compressed JS file from the Sarissa library.
+ * see http://dev.abiss.gr/sarissa
+ * Copyright: Manos Batsis, http://dev.abiss.gr
+ * Licence:
+ * Sarissa is free software distributed under the GNU GPL version 2
+ * or higher, GNU LGPL version 2.1 or higher and Apache Software
+ * License 2.0 or higher. The licenses are available online see:
+ * http://www.apache.org
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY
+ * KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE
+ * WARRANTIES OF MERCHANTABILITY,FITNESS FOR A PARTICULAR PURPOSE
+ * AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
+ * COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR
+ * OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE
+ * SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
+function Sarissa(){}
+Sarissa.VERSION="0.9.9.4";Sarissa.PARSED_OK="Document contains no parsing errors";Sarissa.PARSED_EMPTY="Document is empty";Sarissa.PARSED_UNKNOWN_ERROR="Not well-formed or other error";Sarissa.IS_ENABLED_TRANSFORM_NODE=false;Sarissa.REMOTE_CALL_FLAG="gr.abiss.sarissa.REMOTE_CALL_FLAG";Sarissa._lastUniqueSuffix=0;Sarissa._getUniqueSuffix=function(){return Sarissa._lastUniqueSuffix++;};Sarissa._SARISSA_IEPREFIX4XSLPARAM="";Sarissa._SARISSA_HAS_DOM_IMPLEMENTATION=document.implementation&&true;Sarissa._SARISSA_HAS_DOM_CREATE_DOCUMENT=Sarissa._SARISSA_HAS_DOM_IMPLEMENTATION&&document.implementation.createDocument;Sarissa._SARISSA_HAS_DOM_FEATURE=Sarissa._SARISSA_HAS_DOM_IMPLEMENTATION&&document.implementation.hasFeature;Sarissa._SARISSA_IS_MOZ=Sarissa._SARISSA_HAS_DOM_CREATE_DOCUMENT&&Sarissa._SARISSA_HAS_DOM_FEATURE;Sarissa._SARISSA_IS_SAFARI=navigator.userAgent.toLowerCase().indexOf("safari")!=-1||navigator.userAgent.toLowerCase().indexOf("konqueror")!=-1;Sarissa._SARISSA_IS_SAFARI_OLD=Sarissa._SARISSA_IS_SAFARI&&(parseInt((navigator.userAgent.match(/AppleWebKit\/(\d+)/)||{})[1],10)<420);Sarissa._SARISSA_IS_IE=document.all&&window.ActiveXObject&&navigator.userAgent.toLowerCase().indexOf("msie")>-1&&navigator.userAgent.toLowerCase().indexOf("opera")==-1;Sarissa._SARISSA_IS_OPERA=navigator.userAgent.toLowerCase().indexOf("opera")!=-1;if(!window.Node||!Node.ELEMENT_NODE){Node={ELEMENT_NODE:1,ATTRIBUTE_NODE:2,TEXT_NODE:3,CDATA_SECTION_NODE:4,ENTITY_REFERENCE_NODE:5,ENTITY_NODE:6,PROCESSING_INSTRUCTION_NODE:7,COMMENT_NODE:8,DOCUMENT_NODE:9,DOCUMENT_TYPE_NODE:10,DOCUMENT_FRAGMENT_NODE:11,NOTATION_NODE:12};}
+if(Sarissa._SARISSA_IS_SAFARI_OLD){HTMLHtmlElement=document.createElement("html").constructor;Node=HTMLElement={};HTMLElement.prototype=HTMLHtmlElement.__proto__.__proto__;HTMLDocument=Document=document.constructor;var x=new DOMParser();XMLDocument=x.constructor;Element=x.parseFromString("<Single />","text/xml").documentElement.constructor;x=null;}
+if(typeof XMLDocument=="undefined"&&typeof Document!="undefined"){XMLDocument=Document;}
+if(Sarissa._SARISSA_IS_IE){Sarissa._SARISSA_IEPREFIX4XSLPARAM="xsl:";var _SARISSA_DOM_PROGID="";var _SARISSA_XMLHTTP_PROGID="";var _SARISSA_DOM_XMLWRITER="";Sarissa.pickRecentProgID=function(idList){var bFound=false,e;var o2Store;for(var i=0;i<idList.length&&!bFound;i++){try{var oDoc=new ActiveXObject(idList[i]);o2Store=idList[i];bFound=true;}catch(objException){e=objException;}}
+if(!bFound){throw"Could not retrieve a valid progID of Class: "+idList[idList.length-1]+". (original exception: "+e+")";}
+idList=null;return o2Store;};_SARISSA_DOM_PROGID=null;_SARISSA_THREADEDDOM_PROGID=null;_SARISSA_XSLTEMPLATE_PROGID=null;_SARISSA_XMLHTTP_PROGID=null;XMLHttpRequest=function(){if(!_SARISSA_XMLHTTP_PROGID){_SARISSA_XMLHTTP_PROGID=Sarissa.pickRecentProgID(["Msxml2.XMLHTTP.6.0","MSXML2.XMLHTTP.3.0","MSXML2.XMLHTTP","Microsoft.XMLHTTP"]);}
+return new ActiveXObject(_SARISSA_XMLHTTP_PROGID);};Sarissa.getDomDocument=function(sUri,sName){if(!_SARISSA_DOM_PROGID){_SARISSA_DOM_PROGID=Sarissa.pickRecentProgID(["Msxml2.DOMDocument.6.0","Msxml2.DOMDocument.3.0","MSXML2.DOMDocument","MSXML.DOMDocument","Microsoft.XMLDOM"]);}
+var oDoc=new ActiveXObject(_SARISSA_DOM_PROGID);if(sName){var prefix="";if(sUri){if(sName.indexOf(":")>1){prefix=sName.substring(0,sName.indexOf(":"));sName=sName.substring(sName.indexOf(":")+1);}else{prefix="a"+Sarissa._getUniqueSuffix();}}
+if(sUri){oDoc.loadXML('<'+prefix+':'+sName+" xmlns:"+prefix+"=\""+sUri+"\""+" />");}else{oDoc.loadXML('<'+sName+" />");}}
+return oDoc;};Sarissa.getParseErrorText=function(oDoc){var parseErrorText=Sarissa.PARSED_OK;if(oDoc&&oDoc.parseError&&oDoc.parseError.errorCode&&oDoc.parseError.errorCode!=0){parseErrorText="XML Parsing Error: "+oDoc.parseError.reason+"\nLocation: "+oDoc.parseError.url+"\nLine Number "+oDoc.parseError.line+", Column "+
+oDoc.parseError.linepos+":\n"+oDoc.parseError.srcText+"\n";for(var i=0;i<oDoc.parseError.linepos;i++){parseErrorText+="-";}
+parseErrorText+="^\n";}
+else if(oDoc.documentElement===null){parseErrorText=Sarissa.PARSED_EMPTY;}
+return parseErrorText;};Sarissa.setXpathNamespaces=function(oDoc,sNsSet){oDoc.setProperty("SelectionLanguage","XPath");oDoc.setProperty("SelectionNamespaces",sNsSet);};XSLTProcessor=function(){if(!_SARISSA_XSLTEMPLATE_PROGID){_SARISSA_XSLTEMPLATE_PROGID=Sarissa.pickRecentProgID(["Msxml2.XSLTemplate.6.0","MSXML2.XSLTemplate.3.0"]);}
+this.template=new ActiveXObject(_SARISSA_XSLTEMPLATE_PROGID);this.processor=null;};XSLTProcessor.prototype.importStylesheet=function(xslDoc){if(!_SARISSA_THREADEDDOM_PROGID){_SARISSA_THREADEDDOM_PROGID=Sarissa.pickRecentProgID(["MSXML2.FreeThreadedDOMDocument.6.0","MSXML2.FreeThreadedDOMDocument.3.0"]);}
+xslDoc.setProperty("SelectionLanguage","XPath");xslDoc.setProperty("SelectionNamespaces","xmlns:xsl='http://www.w3.org/1999/XSL/Transform'");var converted=new ActiveXObject(_SARISSA_THREADEDDOM_PROGID);try{converted.resolveExternals=true;converted.setProperty("AllowDocumentFunction",true);}
+catch(e){}
+if(xslDoc.url&&xslDoc.selectSingleNode("//xsl:*[local-name() = 'import' or local-name() = 'include']")!=null){converted.async=false;converted.load(xslDoc.url);}
+else{converted.loadXML(xslDoc.xml);}
+converted.setProperty("SelectionNamespaces","xmlns:xsl='http://www.w3.org/1999/XSL/Transform'");var output=converted.selectSingleNode("//xsl:output");if(output){this.outputMethod=output.getAttribute("method");}
+else{delete this.outputMethod;}
+this.template.stylesheet=converted;this.processor=this.template.createProcessor();this.paramsSet=[];};XSLTProcessor.prototype.transformToDocument=function(sourceDoc){var outDoc;if(_SARISSA_THREADEDDOM_PROGID){this.processor.input=sourceDoc;outDoc=new ActiveXObject(_SARISSA_DOM_PROGID);this.processor.output=outDoc;this.processor.transform();return outDoc;}
+else{if(!_SARISSA_DOM_XMLWRITER){_SARISSA_DOM_XMLWRITER=Sarissa.pickRecentProgID(["Msxml2.MXXMLWriter.6.0","Msxml2.MXXMLWriter.3.0","MSXML2.MXXMLWriter","MSXML.MXXMLWriter","Microsoft.XMLDOM"]);}
+this.processor.input=sourceDoc;outDoc=new ActiveXObject(_SARISSA_DOM_XMLWRITER);this.processor.output=outDoc;this.processor.transform();var oDoc=new ActiveXObject(_SARISSA_DOM_PROGID);oDoc.loadXML(outDoc.output+"");return oDoc;}};XSLTProcessor.prototype.transformToFragment=function(sourceDoc,ownerDoc){this.processor.input=sourceDoc;this.processor.transform();var s=this.processor.output;var f=ownerDoc.createDocumentFragment();var container;if(this.outputMethod=='text'){f.appendChild(ownerDoc.createTextNode(s));}else if(ownerDoc.body&&ownerDoc.body.innerHTML){container=ownerDoc.createElement('div');container.innerHTML=s;while(container.hasChildNodes()){f.appendChild(container.firstChild);}}
+else{var oDoc=new ActiveXObject(_SARISSA_DOM_PROGID);if(s.substring(0,5)=='<?xml'){s=s.substring(s.indexOf('?>')+2);}
+var xml=''.concat('<my>',s,'</my>');oDoc.loadXML(xml);container=oDoc.documentElement;while(container.hasChildNodes()){f.appendChild(container.firstChild);}}
+return f;};XSLTProcessor.prototype.setParameter=function(nsURI,name,value){value=value?value:"";if(nsURI){this.processor.addParameter(name,value,nsURI);}else{this.processor.addParameter(name,value);}
+nsURI=""+(nsURI||"");if(!this.paramsSet[nsURI]){this.paramsSet[nsURI]=[];}
+this.paramsSet[nsURI][name]=value;};XSLTProcessor.prototype.getParameter=function(nsURI,name){nsURI=""+(nsURI||"");if(this.paramsSet[nsURI]&&this.paramsSet[nsURI][name]){return this.paramsSet[nsURI][name];}else{return null;}};XSLTProcessor.prototype.clearParameters=function(){for(var nsURI in this.paramsSet){for(var name in this.paramsSet[nsURI]){if(nsURI!=""){this.processor.addParameter(name,"",nsURI);}else{this.processor.addParameter(name,"");}}}
+this.paramsSet=[];};}else{if(Sarissa._SARISSA_HAS_DOM_CREATE_DOCUMENT){Sarissa.__handleLoad__=function(oDoc){Sarissa.__setReadyState__(oDoc,4);};_sarissa_XMLDocument_onload=function(){Sarissa.__handleLoad__(this);};Sarissa.__setReadyState__=function(oDoc,iReadyState){oDoc.readyState=iReadyState;oDoc.readystate=iReadyState;if(oDoc.onreadystatechange!=null&&typeof oDoc.onreadystatechange=="function"){oDoc.onreadystatechange();}};Sarissa.getDomDocument=function(sUri,sName){var oDoc=document.implementation.createDocument(sUri?sUri:null,sName?sName:null,null);if(!oDoc.onreadystatechange){oDoc.onreadystatechange=null;}
+if(!oDoc.readyState){oDoc.readyState=0;}
+oDoc.addEventListener("load",_sarissa_XMLDocument_onload,false);return oDoc;};if(window.XMLDocument){}
+else if(Sarissa._SARISSA_HAS_DOM_FEATURE&&window.Document&&!Document.prototype.load&&document.implementation.hasFeature('LS','3.0')){Sarissa.getDomDocument=function(sUri,sName){var oDoc=document.implementation.createDocument(sUri?sUri:null,sName?sName:null,null);return oDoc;};}
+else{Sarissa.getDomDocument=function(sUri,sName){var oDoc=document.implementation.createDocument(sUri?sUri:null,sName?sName:null,null);if(oDoc&&(sUri||sName)&&!oDoc.documentElement){oDoc.appendChild(oDoc.createElementNS(sUri,sName));}
+return oDoc;};}}}
+if(!window.DOMParser){if(Sarissa._SARISSA_IS_SAFARI){DOMParser=function(){};DOMParser.prototype.parseFromString=function(sXml,contentType){var xmlhttp=new XMLHttpRequest();xmlhttp.open("GET","data:text/xml;charset=utf-8,"+encodeURIComponent(sXml),false);xmlhttp.send(null);return xmlhttp.responseXML;};}else if(Sarissa.getDomDocument&&Sarissa.getDomDocument()&&Sarissa.getDomDocument(null,"bar").xml){DOMParser=function(){};DOMParser.prototype.parseFromString=function(sXml,contentType){var doc=Sarissa.getDomDocument();doc.loadXML(sXml);return doc;};}}
+if((typeof(document.importNode)=="undefined")&&Sarissa._SARISSA_IS_IE){try{document.importNode=function(oNode,bChildren){var tmp;if(oNode.nodeName=='#text'){return document.createTextNode(oNode.data);}
+else{if(oNode.nodeName=="tbody"||oNode.nodeName=="tr"){tmp=document.createElement("table");}
+else if(oNode.nodeName=="td"){tmp=document.createElement("tr");}
+else if(oNode.nodeName=="option"){tmp=document.createElement("select");}
+else{tmp=document.createElement("div");}
+if(bChildren){tmp.innerHTML=oNode.xml?oNode.xml:oNode.outerHTML;}else{tmp.innerHTML=oNode.xml?oNode.cloneNode(false).xml:oNode.cloneNode(false).outerHTML;}
+return tmp.getElementsByTagName("*")[0];}};}catch(e){}}
+if(!Sarissa.getParseErrorText){Sarissa.getParseErrorText=function(oDoc){var parseErrorText=Sarissa.PARSED_OK;if((!oDoc)||(!oDoc.documentElement)){parseErrorText=Sarissa.PARSED_EMPTY;}else if(oDoc.documentElement.tagName=="parsererror"){parseErrorText=oDoc.documentElement.firstChild.data;parseErrorText+="\n"+oDoc.documentElement.firstChild.nextSibling.firstChild.data;}else if(oDoc.getElementsByTagName("parsererror").length>0){var parsererror=oDoc.getElementsByTagName("parsererror")[0];parseErrorText=Sarissa.getText(parsererror,true)+"\n";}else if(oDoc.parseError&&oDoc.parseError.errorCode!=0){parseErrorText=Sarissa.PARSED_UNKNOWN_ERROR;}
+return parseErrorText;};}
+Sarissa.getText=function(oNode,deep){var s="";var nodes=oNode.childNodes;for(var i=0;i<nodes.length;i++){var node=nodes[i];var nodeType=node.nodeType;if(nodeType==Node.TEXT_NODE||nodeType==Node.CDATA_SECTION_NODE){s+=node.data;}else if(deep===true&&(nodeType==Node.ELEMENT_NODE||nodeType==Node.DOCUMENT_NODE||nodeType==Node.DOCUMENT_FRAGMENT_NODE)){s+=Sarissa.getText(node,true);}}
+return s;};if(!window.XMLSerializer&&Sarissa.getDomDocument&&Sarissa.getDomDocument("","foo",null).xml){XMLSerializer=function(){};XMLSerializer.prototype.serializeToString=function(oNode){return oNode.xml;};}
+Sarissa.stripTags=function(s){return s?s.replace(/<[^>]+>/g,""):s;};Sarissa.clearChildNodes=function(oNode){while(oNode.firstChild){oNode.removeChild(oNode.firstChild);}};Sarissa.copyChildNodes=function(nodeFrom,nodeTo,bPreserveExisting){if(Sarissa._SARISSA_IS_SAFARI&&nodeTo.nodeType==Node.DOCUMENT_NODE){nodeTo=nodeTo.documentElement;}
+if((!nodeFrom)||(!nodeTo)){throw"Both source and destination nodes must be provided";}
+if(!bPreserveExisting){Sarissa.clearChildNodes(nodeTo);}
+var ownerDoc=nodeTo.nodeType==Node.DOCUMENT_NODE?nodeTo:nodeTo.ownerDocument;var nodes=nodeFrom.childNodes;var i;if(typeof(ownerDoc.importNode)!="undefined"){for(i=0;i<nodes.length;i++){nodeTo.appendChild(ownerDoc.importNode(nodes[i],true));}}else{for(i=0;i<nodes.length;i++){nodeTo.appendChild(nodes[i].cloneNode(true));}}};Sarissa.moveChildNodes=function(nodeFrom,nodeTo,bPreserveExisting){if((!nodeFrom)||(!nodeTo)){throw"Both source and destination nodes must be provided";}
+var nodes=nodeFrom.childNodes;if(nodeFrom.ownerDocument==nodeTo.ownerDocument){while(nodeFrom.firstChild){nodeTo.appendChild(nodeFrom.firstChild);}}else{var ownerDoc=nodeTo.nodeType==Node.DOCUMENT_NODE?nodeTo:nodeTo.ownerDocument;var i;if(typeof(ownerDoc.importNode)!="undefined"){for(i=0;i<nodes.length;i++){nodeTo.appendChild(ownerDoc.importNode(nodes[i],true));}}else{for(i=0;i<nodes.length;i++){nodeTo.appendChild(nodes[i].cloneNode(true));}}
+Sarissa.clearChildNodes(nodeFrom);}};Sarissa.xmlize=function(anyObject,objectName,indentSpace){indentSpace=indentSpace?indentSpace:'';var s=indentSpace+'<'+objectName+'>';var isLeaf=false;if(!(anyObject instanceof Object)||anyObject instanceof Number||anyObject instanceof String||anyObject instanceof Boolean||anyObject instanceof Date){s+=Sarissa.escape(""+anyObject);isLeaf=true;}else{s+="\n";var isArrayItem=anyObject instanceof Array;for(var name in anyObject){s+=Sarissa.xmlize(anyObject[name],(isArrayItem?"array-item key=\""+name+"\"":name),indentSpace+"   ");}
+s+=indentSpace;}
+return(s+=(objectName.indexOf(' ')!=-1?"</array-item>\n":"</"+objectName+">\n"));};Sarissa.escape=function(sXml){return sXml.replace(/&/g,"&amp;").replace(/</g,"&lt;").replace(/>/g,"&gt;").replace(/"/g,"&quot;").replace(/'/g,"&apos;");};Sarissa.unescape=function(sXml){return sXml.replace(/&apos;/g,"'").replace(/&quot;/g,"\"").replace(/&gt;/g,">").replace(/&lt;/g,"<").replace(/&amp;/g,"&");};Sarissa.updateCursor=function(oTargetElement,sValue){if(oTargetElement&&oTargetElement.style&&oTargetElement.style.cursor!=undefined){oTargetElement.style.cursor=sValue;}};Sarissa.updateContentFromURI=function(sFromUrl,oTargetElement,xsltproc,callback,skipCache){try{Sarissa.updateCursor(oTargetElement,"wait");var xmlhttp=new XMLHttpRequest();xmlhttp.open("GET",sFromUrl,true);xmlhttp.onreadystatechange=function(){if(xmlhttp.readyState==4){try{var oDomDoc=xmlhttp.responseXML;if(oDomDoc&&Sarissa.getParseErrorText(oDomDoc)==Sarissa.PARSED_OK){Sarissa.updateContentFromNode(xmlhttp.responseXML,oTargetElement,xsltproc);if(callback){callback(sFromUrl,oTargetElement);}}
+else{throw Sarissa.getParseErrorText(oDomDoc);}}
+catch(e){if(callback){callback(sFromUrl,oTargetElement,e);}
+else{throw e;}}}};if(skipCache){var oldage="Sat, 1 Jan 2000 00:00:00 GMT";xmlhttp.setRequestHeader("If-Modified-Since",oldage);}
+xmlhttp.send("");}
+catch(e){Sarissa.updateCursor(oTargetElement,"auto");if(callback){callback(sFromUrl,oTargetElement,e);}
+else{throw e;}}};Sarissa.updateContentFromNode=function(oNode,oTargetElement,xsltproc){try{Sarissa.updateCursor(oTargetElement,"wait");Sarissa.clearChildNodes(oTargetElement);var ownerDoc=oNode.nodeType==Node.DOCUMENT_NODE?oNode:oNode.ownerDocument;if(ownerDoc.parseError&&ownerDoc.parseError.errorCode!=0){var pre=document.createElement("pre");pre.appendChild(document.createTextNode(Sarissa.getParseErrorText(ownerDoc)));oTargetElement.appendChild(pre);}
+else{if(xsltproc){oNode=xsltproc.transformToDocument(oNode);}
+if(oTargetElement.tagName.toLowerCase()=="textarea"||oTargetElement.tagName.toLowerCase()=="input"){oTargetElement.value=new XMLSerializer().serializeToString(oNode);}
+else{try{oTargetElement.appendChild(oTargetElement.ownerDocument.importNode(oNode,true));}
+catch(e){oTargetElement.innerHTML=new XMLSerializer().serializeToString(oNode);}}}}
+catch(e){throw e;}
+finally{Sarissa.updateCursor(oTargetElement,"auto");}};Sarissa.formToQueryString=function(oForm){var qs="";for(var i=0;i<oForm.elements.length;i++){var oField=oForm.elements[i];var sFieldName=oField.getAttribute("name")?oField.getAttribute("name"):oField.getAttribute("id");if(sFieldName&&((!oField.disabled)||oField.type=="hidden")){switch(oField.type){case"hidden":case"text":case"textarea":case"password":qs+=sFieldName+"="+encodeURIComponent(oField.value)+"&";break;case"select-one":qs+=sFieldName+"="+encodeURIComponent(oField.options[oField.selectedIndex].value)+"&";break;case"select-multiple":for(var j=0;j<oField.length;j++){var optElem=oField.options[j];if(optElem.selected===true){qs+=sFieldName+"[]"+"="+encodeURIComponent(optElem.value)+"&";}}
+break;case"checkbox":case"radio":if(oField.checked){qs+=sFieldName+"="+encodeURIComponent(oField.value)+"&";}
+break;}}}
+return qs.substr(0,qs.length-1);};Sarissa.updateContentFromForm=function(oForm,oTargetElement,xsltproc,callback){try{Sarissa.updateCursor(oTargetElement,"wait");var params=Sarissa.formToQueryString(oForm)+"&"+Sarissa.REMOTE_CALL_FLAG+"=true";var xmlhttp=new XMLHttpRequest();var bUseGet=oForm.getAttribute("method")&&oForm.getAttribute("method").toLowerCase()=="get";if(bUseGet){xmlhttp.open("GET",oForm.getAttribute("action")+"?"+params,true);}
+else{xmlhttp.open('POST',oForm.getAttribute("action"),true);xmlhttp.setRequestHeader("Content-type","application/x-www-form-urlencoded");xmlhttp.setRequestHeader("Content-length",params.length);xmlhttp.setRequestHeader("Connection","close");}
+xmlhttp.onreadystatechange=function(){try{if(xmlhttp.readyState==4){var oDomDoc=xmlhttp.responseXML;if(oDomDoc&&Sarissa.getParseErrorText(oDomDoc)==Sarissa.PARSED_OK){Sarissa.updateContentFromNode(xmlhttp.responseXML,oTargetElement,xsltproc);if(callback){callback(oForm,oTargetElement);}}
+else{throw Sarissa.getParseErrorText(oDomDoc);}}}
+catch(e){if(callback){callback(oForm,oTargetElement,e);}
+else{throw e;}}};xmlhttp.send(bUseGet?"":params);}
+catch(e){Sarissa.updateCursor(oTargetElement,"auto");if(callback){callback(oForm,oTargetElement,e);}
+else{throw e;}}
+return false;};Sarissa.FUNCTION_NAME_REGEXP=new RegExp("");Sarissa.getFunctionName=function(oFunc,bForce){var name;if(!name){if(bForce){name="SarissaAnonymous"+Sarissa._getUniqueSuffix();window[name]=oFunc;}
+else{name=null;}}
+if(name){window[name]=oFunc;}
+return name;};Sarissa.setRemoteJsonCallback=function(url,callback,callbackParam){if(!callbackParam){callbackParam="callback";}
+var callbackFunctionName=Sarissa.getFunctionName(callback,true);var id="sarissa_json_script_id_"+Sarissa._getUniqueSuffix();var oHead=document.getElementsByTagName("head")[0];var scriptTag=document.createElement('script');scriptTag.type='text/javascript';scriptTag.id=id;scriptTag.onload=function(){};if(url.indexOf("?")!=-1){url+=("&"+callbackParam+"="+callbackFunctionName);}
+else{url+=("?"+callbackParam+"="+callbackFunctionName);}
+scriptTag.src=url;oHead.appendChild(scriptTag);return id;};
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/_jquery.tree.rtl.js
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/_jquery.tree.rtl.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/_jquery.tree.rtl.js	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,32 @@
+(function ($) {
+	$.extend($.tree.plugins, {
+		"rtl" : {
+			defaults : {
+				attribute	: "data"
+			callbacks : {
+				onload : function() {
+					this.container.css("direction","rtl").children("ul:eq(0)").removeClass("ltr").addClass("rtl");
+				oninit : function() {
+					if(!$.tree.plugins.rtl.css) {
+						var css = '.tree .rtl li.last { float:right; } #jstree-dragged .rtl { margin:0; padding:0; } #jstree-marker.marker_rtl { width:40px; background-position:right center; } /* RTL modification */ .tree .rtl, .tree .rtl ul { margin:0 10px 0 0; } .tree .rtl li { padding:0 10px 0 0; } .tree .rtl li a, .tree .rtl li span { padding:1px 4px 1px 4px; } .tree > .rtl > li { display:table; } .tree .rtl ins { margin:0 0px 0 4px; }';
+						if(/msie/.test(u) && !/opera/.test(u)) {
+							if(parseInt(v) == 6) css += '#jstree-dragged .rtl { width:20px; } .tree .rtl li.last { margin-top: expression( (this.previousSibling && /open/.test(this.previousSibling.className) ) ? "-2px" : "0"); } .marker_rtl { width:40px; background-position:right center; } ';
+							if(parseInt(v) == 7) css += '.tree .rtl li.last { float:none; } #jstree-dragged .rtl { width:200px; }';
+						if(/mozilla/.test(u) && !/(compatible|webkit)/.test(u) && v.indexOf("1.8") == 0) css += '.tree .rtl li a { display:inline; float:right; }';
+						$.tree.plugins.rtl.css = this.add_sheet({ str : css });
+})(jQuery);
+// in mousemove:
+//  tmp.drag_help.css({ "left" : (event.pageX - (tmp.origin_tree.settings.ui.rtl ? tmp.w : -5 ) ), "top" : (event.pageY + 15) });
+//  if(cnt.children("ul:eq(0)").hasClass("rtl")) goTo.x += et.width() - 28;
+//  if(cnt.children("ul:eq(0)").hasClass("rtl"))	{ tree_component.drag_drop.marker.attr("class","marker_rtl"); }
+//  if(cnt.children("ul:eq(0)").hasClass("rtl")) goTo.x += 36;
+//  tree_component.drag_drop.marker.css({ "left" : et_off.left + ( cnt.children("ul:eq(0)").hasClass("rtl") ? (cnt.width() - 10) : 10 ) , "top" : et_off.top + 15 }).show();
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.checkbox.js
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.checkbox.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.checkbox.js	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,75 @@
+(function ($) {
+		"checkbox" : {
+			defaults : {
+				three_state : true
+			get_checked : function (t) {
+				if(!t) t = $.tree.focused();
+				return t.container.find("a.checked").parent();
+			get_undeterminded : function (t) {
+				return t.container.find("a.undetermined").parent();
+			get_unchecked : function (t) {
+				return t.container.find("a:not(.checked, .undetermined)").parent();
+			check : function (n) {
+				if(!n) return false;
+				var t = $.tree.reference(n);
+				n = t.get_node(n);
+				if(n.children("a").hasClass("checked")) return true;
+				var opts = $.extend(true, {}, $.tree.plugins.checkbox.defaults, t.settings.plugins.checkbox);
+				if(opts.three_state) {
+					n.find("li").andSelf().children("a").removeClass("unchecked undetermined").addClass("checked");
+					n.parents("li").each(function () {
+						if($(this).children("ul").find("a:not(.checked):eq(0)").size() > 0) {
+							$(this).parents("li").andSelf().children("a").removeClass("unchecked checked").addClass("undetermined");
+							return false;
+						else $(this).children("a").removeClass("unchecked undetermined").addClass("checked");
+				else n.children("a").removeClass("unchecked").addClass("checked");
+				return true;
+			uncheck : function (n) {
+				if(n.children("a").hasClass("unchecked")) return true;
+					n.find("li").andSelf().children("a").removeClass("checked undetermined").addClass("unchecked");
+						if($(this).find("a.checked, a.undetermined").size() - 1 > 0) {
+							return false;
+						else $(this).children("a").removeClass("checked undetermined").addClass("unchecked");
+				else n.children("a").removeClass("checked").addClass("unchecked");
+				return true;
+			toggle : function (n) {
+				if(n.children("a").hasClass("checked")) $.tree.plugins.checkbox.uncheck(n);
+				else $.tree.plugins.checkbox.check(n);
+			callbacks : {
+				onchange : function(n, t) {
+					$.tree.plugins.checkbox.toggle(n);
+})(jQuery);
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.contextmenu.js
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.contextmenu.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.contextmenu.js	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,129 @@
+(function ($) {
+		"contextmenu" : {
+			object : $("<ul id='jstree-contextmenu' class='tree-context' />"),
+			data : {
+				t : false,
+				a : false,
+				r : false
+			defaults : {
+				class_name : "hover",
+				items : {
+					create : {
+						label	: "Create",
+						icon	: "create",
+						visible	: function (NODE, TREE_OBJ) { if(NODE.length != 1) return 0; return TREE_OBJ.check("creatable", NODE); },
+						action	: function (NODE, TREE_OBJ) { TREE_OBJ.create(false, TREE_OBJ.get_node(NODE[0])); },
+						separator_after : true
+					rename : {
+						label	: "Rename",
+						icon	: "rename",
+						visible	: function (NODE, TREE_OBJ) { if(NODE.length != 1) return false; return TREE_OBJ.check("renameable", NODE); },
+						action	: function (NODE, TREE_OBJ) { TREE_OBJ.rename(NODE); }
+					remove : {
+						label	: "Delete",
+						icon	: "remove",
+						visible	: function (NODE, TREE_OBJ) { var ok = true; $.each(NODE, function () { if(TREE_OBJ.check("deletable", this) == false) ok = false; return false; }); return ok; },
+						action	: function (NODE, TREE_OBJ) { $.each(NODE, function () { TREE_OBJ.remove(this); }); }
+			show : function(obj, t) {
+				var opts = $.extend(true, {}, $.tree.plugins.contextmenu.defaults, t.settings.plugins.contextmenu);
+				obj = $(obj);
+				$.tree.plugins.contextmenu.object.empty();
+				var str = "";
+				var cnt = 0;
+				for(var i in opts.items) {
+					if(!opts.items.hasOwnProperty(i)) continue;
+					if(opts.items[i] === false) continue;
+					var r = 1;
+					if(typeof opts.items[i].visible == "function") r = opts.items[i].visible.call(null, $.tree.plugins.contextmenu.data.a, t);
+					if(r == -1) continue;
+					else cnt ++;
+					if(opts.items[i].separator_before === true) str += "<li class='separator'><span>&nbsp;</span></li>";
+					str += '<li><a href="#" rel="' + i + '" class="' + i + ' ' + (r == 0 ? 'disabled' : '') + '">';
+					if(opts.items[i].icon) str += "<ins " + (opts.items[i].icon.indexOf("/") == -1 ? " class='" + opts.items[i].icon + "' " : " style='background-image:url(\"" + opts.items[i].icon + "\");' " ) + ">&nbsp;</ins>";
+					else str += "<ins>&nbsp;</ins>";
+					str += "<span>" + opts.items[i].label + '</span></a></li>';
+					if(opts.items[i].separator_after === true) str += "<li class='separator'><span>&nbsp;</span></li>";
+				var tmp = obj.children("a:visible").offset();
+				$.tree.plugins.contextmenu.object.attr("class","tree-context tree-" + t.settings.ui.theme_name.toString() + "-context").html(str);
+				var h = $.tree.plugins.contextmenu.object.height();
+				var w = $.tree.plugins.contextmenu.object.width();
+				var x = tmp.left;
+				var y = tmp.top + parseInt(obj.children("a:visible").height()) + 2;
+				var max_y = $(window).height() + $(window).scrollTop();
+				var max_x = $(window).width() + $(window).scrollLeft();
+				if(y + h > max_y) y = Math.max( (max_y - h - 2), 0);
+				if(x + w > max_x) x = Math.max( (max_x - w - 2), 0);
+				$.tree.plugins.contextmenu.object.css({ "left" : (x), "top" : (y) }).fadeIn("fast");
+			hide : function () {
+				if(!$.tree.plugins.contextmenu.data.t) return;
+				var opts = $.extend(true, {}, $.tree.plugins.contextmenu.defaults, $.tree.plugins.contextmenu.data.t.settings.plugins.contextmenu);
+				if($.tree.plugins.contextmenu.data.r && $.tree.plugins.contextmenu.data.a) {
+					$.tree.plugins.contextmenu.data.a.children("a, span").removeClass(opts.class_name);
+				$.tree.plugins.contextmenu.data = { a : false, r : false, t : false };
+				$.tree.plugins.contextmenu.object.fadeOut("fast");
+			exec : function (cmd) {
+				if($.tree.plugins.contextmenu.data.t == false) return;
+				try { opts.items[cmd].action.apply(null, [$.tree.plugins.contextmenu.data.a, $.tree.plugins.contextmenu.data.t]); } catch(e) { };
+			callbacks : {
+				oninit : function () {
+					if(!$.tree.plugins.contextmenu.css) {
+						var css = '#jstree-contextmenu { display:none; position:absolute; z-index:2000; list-style-type:none; margin:0; padding:0; left:-2000px; top:-2000px; } .tree-context { margin:20px; padding:0; width:180px; border:1px solid #979797; padding:2px; background:#f5f5f5; list-style-type:none; }.tree-context li { height:22px; margin:0 0 0 27px; padding:0; background:#ffffff; border-left:1px solid #e0e0e0; }.tree-context li a { position:relative; display:block; height:22px; line-height:22px; margin:0 0 0 -28px; text-decoration:none; color:black; padding:0; }.tree-context li a ins { text-decoration:none; float:left; width:16px; height:16px; margin:0 0 0 0; background-color:#f0f0f0; border:1px solid #f0f0f0; border-width:3px 5px 3px 6px; line-height:16px; }.tree-context li a span { display:block; background:#f0f0f0; margin:0 0 0 29px; padding-left:5px; }.tree-context li.separator { background:#f0f0f0; height:2px; line-height:2px; font-size:1px; border:0; margin:0; padding:0; }.tree-context li.separator span { display:block; margin:0px 0 0px 27px; height:1px; border-top:1px solid #e0e0e0; border-left:1px solid #e0e0e0; line-height:1px; font-size:1px; background:white; }.tree-context li a:hover { border:1px solid #d8f0fa; height:20px; line-height:20px; }.tree-context li a:hover span { background:#e7f4f9; margin-left:28px; }.tree-context li a:hover ins { background-color:#e7f4f9; border-color:#e7f4f9; border-width:2px 5px 2px 5px; }.tree-context li a.disabled { color:gray; }.tree-context li a.disabled ins { }.tree-context li a.disabled:hover { border:0; height:22px; line-height:22px; }.tree-context li a.disabled:hover span { background:#f0f0f0; margin-left:29px; }.tree-context li a.disabled:hover ins { border-color:#f0f0f0; background-color:#f0f0f0; border-width:3px 5px 3px 6px; }';
+						$.tree.plugins.contextmenu.css = this.add_sheet({ str : css });
+				onrgtclk : function (n, t, e) {
+					n = $(n);
+					if(n.size() == 0) return;
+					$.tree.plugins.contextmenu.data.t = t;
+					if(!n.children("a:eq(0)").hasClass("clicked")) {
+						$.tree.plugins.contextmenu.data.a = n;
+						$.tree.plugins.contextmenu.data.r = true;
+						n.children("a").addClass(opts.class_name);
+						e.target.blur();
+					else {
+						$.tree.plugins.contextmenu.data.r = false;
+						$.tree.plugins.contextmenu.data.a = (t.selected_arr && t.selected_arr.length > 1) ? t.selected_arr : t.selected;
+					$.tree.plugins.contextmenu.show(n, t);
+					e.preventDefault();
+					e.stopPropagation();
+					// return false; // commented out because you might want to do something in your own callback
+				onchange : function () { $.tree.plugins.contextmenu.hide(); },
+				beforedata : function () { $.tree.plugins.contextmenu.hide(); },
+				ondestroy : function () { $.tree.plugins.contextmenu.hide(); }
+	$(function () {
+		$.tree.plugins.contextmenu.object.hide().appendTo("body");
+		$("a", $.tree.plugins.contextmenu.object[0])
+			.live("click", function (event) {
+				if(!$(this).hasClass("disabled")) {
+					$.tree.plugins.contextmenu.exec.apply(null, [$(this).attr("rel")]);
+					$.tree.plugins.contextmenu.hide();
+				event.stopPropagation();
+				event.preventDefault();
+				return false;
+		$(document).bind("mousedown", function(event) { if($(event.target).parents("#jstree-contextmenu").size() == 0) $.tree.plugins.contextmenu.hide(); });
+})(jQuery);
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.cookie.js
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.cookie.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.cookie.js	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,70 @@
+(function ($) {
+	if(typeof $.cookie == "undefined") throw "jsTree cookie: jQuery cookie plugin not included.";
+		"cookie" : {
+			defaults : {
+				prefix		: "",	// a prefix that will be used for all cookies for this tree
+				options		: {
+					expires: false,
+					path: false,
+					domain: false,
+					secure: false
+				types : {
+					selected	: true,		// should we set the selected cookie
+					open		: true		// should we set the open cookie
+				keep_selected	: false,	// should we merge with the selected option or overwrite it
+				keep_opened		: false		// should we merge with the opened option or overwrite it
+			set_cookie : function (type) {
+				var opts = $.extend(true, {}, $.tree.plugins.cookie.defaults, this.settings.plugins.cookie);
+				if(opts.types[type] !== true) return false;
+				switch(type) {
+					case "selected":
+						if(this.settings.rules.multiple != false && this.selected_arr.length > 1) {
+							var val = Array();
+							$.each(this.selected_arr, function () {
+								if(this.attr("id")) { val.push(this.attr("id")); }
+							val = val.join(",");
+						else var val = this.selected ? this.selected.attr("id") : false;
+						$.cookie(opts.prefix + 'selected', val, opts.options);
+						break;
+					case "open":
+						var str = "";
+						this.container.find("li.open").each(function (i) { if(this.id) { str += this.id + ","; } });
+						$.cookie(opts.prefix + 'open', str.replace(/,$/ig,""), opts.options);
+						break;
+			callbacks : {
+				oninit : function (t) {
+					var tmp = false;
+					tmp = $.cookie(opts.prefix + 'open');
+					if(tmp) {
+						tmp = tmp.split(",");
+						if(opts.keep_opened)	this.settings.opened = $.unique($.merge(tmp, this.settings.opened));
+						else					this.settings.opened = tmp;
+					tmp = $.cookie(opts.prefix + 'selected');
+					if(tmp) {
+						if(opts.keep_selected)	this.settings.selected = $.unique($.merge(tmp, this.settings.opened));
+						else					this.settings.selected = tmp;
+				onchange	: function() { $.tree.plugins.cookie.set_cookie.apply(this, ["selected"]); },
+				onopen		: function() { $.tree.plugins.cookie.set_cookie.apply(this, ["open"]); },
+				onclose		: function() { $.tree.plugins.cookie.set_cookie.apply(this, ["open"]); },
+				ondelete	: function() { $.tree.plugins.cookie.set_cookie.apply(this, ["open"]); },
+				oncopy		: function() { $.tree.plugins.cookie.set_cookie.apply(this, ["open"]); },
+				oncreate	: function() { $.tree.plugins.cookie.set_cookie.apply(this, ["open"]); },
+				onmoved		: function() { $.tree.plugins.cookie.set_cookie.apply(this, ["open"]); }
+})(jQuery);
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.hotkeys.js
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.hotkeys.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.hotkeys.js	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,78 @@
+(function ($) {
+	if(typeof window.hotkeys == "undefined") throw "jsTree hotkeys: jQuery hotkeys plugin not included.";
+		"hotkeys" : {
+			bound : [],
+			disabled : false,
+			defaults : {
+				hover_mode : false,
+				functions : {
+					"up"	: function () { $.tree.plugins.hotkeys.get_prev.apply(this); return false; },
+					"down"	: function () { $.tree.plugins.hotkeys.get_next.apply(this); return false; },
+					"left"	: function () { $.tree.plugins.hotkeys.get_left.apply(this); return false; },
+					"right"	: function () { $.tree.plugins.hotkeys.get_right.apply(this); return false; },
+					"f2"	: function () { if(this.selected) this.rename(); return false; },
+					"del"	: function () { if(this.selected) this.remove(); return false; },
+					"ctrl+c": function () { if(this.selected) this.copy(); return false; },
+					"ctrl+x": function () { if(this.selected) this.cut(); return false; },
+					"ctrl+v": function () { if(this.selected) this.paste(); return false; }
+			exec : function(key) {
+				if($.tree.plugins.hotkeys.disabled) return false;
+				var t = $.tree.focused();
+				if(typeof t.settings.plugins.hotkeys == "undefined") return;
+				var opts = $.extend(true, {}, $.tree.plugins.hotkeys.defaults, t.settings.plugins.hotkeys);
+				if(typeof opts.functions[key] == "function") return opts.functions[key].apply(t);
+			get_next : function() {
+				var opts = $.extend(true, {}, $.tree.plugins.hotkeys.defaults, this.settings.plugins.hotkeys);
+				var obj = this.hovered || this.selected;
+				return opts.hover_mode ? this.hover_branch(this.next(obj)) : this.select_branch(this.next(obj));
+			get_prev : function() {
+				return opts.hover_mode ? this.hover_branch(this.prev(obj)) : this.select_branch(this.prev(obj));
+			get_left : function() {
+				if(obj) {
+					if(obj.hasClass("open"))	this.close_branch(obj);
+					else {
+						return opts.hover_mode ? this.hover_branch(this.parent(obj)) : this.select_branch(this.parent(obj));
+			get_right : function() {
+				if(obj) {
+					if(obj.hasClass("closed"))	this.open_branch(obj);
+					else {
+						return opts.hover_mode ? this.hover_branch(obj.find("li:eq(0)")) : this.select_branch(obj.find("li:eq(0)"));
+			callbacks : {
+					for(var i in opts.functions) {
+						if(opts.functions.hasOwnProperty(i) && $.inArray(i, $.tree.plugins.hotkeys.bound) == -1) {
+							(function (k) {
+								$(document).bind("keydown", { combi : k, disableInInput: true }, function (event) {
+									return $.tree.plugins.hotkeys.exec(k);
+							})(i);
+							$.tree.plugins.hotkeys.bound.push(i);
+})(jQuery);
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.metadata.js
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.metadata.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.metadata.js	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,17 @@
+(function ($) {
+	if(typeof $.metadata == "undefined") throw "jsTree metadata: jQuery metadata plugin not included.";
+		"metadata" : {
+			defaults : {
+			callbacks : {
+				check : function(rule, obj, value, tree) {
+					var opts = $.extend(true, {}, $.tree.plugins.metadata.defaults, this.settings.plugins.metadata);
+					if(typeof $(obj).metadata({ type : "attr", name : opts.attribute })[rule] != "undefined") return $(obj).metadata()[rule];
+})(jQuery);
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.themeroller.js
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.themeroller.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.themeroller.js	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,33 @@
+(function ($) {
+		"themeroller" : {
+			defaults : {
+			callbacks : {
+					if(this.settings.ui.theme_name != "themeroller") return;
+					var opts = $.extend(true, {}, $.tree.plugins.themeroller.defaults, this.settings.plugins.themeroller);
+					this.container.addClass("ui-widget ui-widget-content");
+					$("#" + this.container.attr("id") + " li a").live("mouseover", function () { $(this).addClass("ui-state-hover"); });
+					$("#" + this.container.attr("id") + " li a").live("mouseout",  function () { $(this).removeClass("ui-state-hover"); });
+				onparse : function (s, t) {
+					return $(s).find("a").not(".ui-state-default").addClass("ui-state-default").children("ins").addClass("ui-icon").end().end().end();
+				onselect : function(n, t) {
+					$(n).children("a").addClass("ui-state-active");
+				ondeselect : function(n, t) {
+					$(n).children("a").removeClass("ui-state-active");
+})(jQuery);
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.xml_flat.js
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.xml_flat.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.xml_flat.js	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,123 @@
+(function ($) {
+	if(typeof Sarissa == "undefined") throw "jsTree xml_flat: Sarissa is not included.";
+	$.extend($.tree.datastores, {
+		"xml_flat" : function () {
+			return {
+				get		: function(obj, t, opts) {
+					var str = "";
+					if(!obj || $(obj).size() == 0) {
+						obj = t.container.children("ul").children("li");
+					else obj = $(obj);
+					if(obj.size() > 1) {
+						var _this = this;
+						var str	 = '<root>';
+						obj.each(function () {
+							opts.callback = true;
+							str += _this.get(this, t, opts);
+						str		+= '</root>';
+						return str;
+					if(!opts) var opts = {};
+					if(!opts.outer_attrib) opts.outer_attrib = [ "id", "rel", "class" ];
+					if(!opts.inner_attrib) opts.inner_attrib = [ ];
+					if(!opts.callback) str += '<root>';
+					str += '<item ';
+					str += ' parent_id="' + (obj.parents("li:eq(0)").size() ? obj.parents("li:eq(0)").attr("id") : 0) + '" ';
+					for(var i in opts.outer_attrib) {
+						if(!opts.outer_attrib.hasOwnProperty(i)) continue;
+						var val = (opts.outer_attrib[i] == "class") ? obj.attr(opts.outer_attrib[i]).toString().replace(/(^| )last( |$)/ig," ").replace(/(^| )(leaf|closed|open)( |$)/ig," ") : obj.attr(opts.outer_attrib[i]);
+						if(typeof val != "undefined" && val.toString().replace(" ","").length > 0) str += ' ' + opts.outer_attrib[i] + '="' + val.toString() + '" ';
+						delete val;
+					str += '>';
+					str += '<content>';
+					if(t.settings.languages.length) {
+						for(var i in t.settings.languages) {
+							if(!t.settings.languages.hasOwnProperty(i)) continue;
+							str += this.process_inner(obj.children("a." + t.settings.languages[i]), t, opts, t.settings.languages[i]);
+					else {
+						str += this.process_inner(obj.children("a"), t, opts);
+					str += '</content>';
+					str += '</item>';
+					if(obj.children("ul").size() > 0) {
+						var _this = this;
+						obj.children("ul").children("li").each(function () {
+						opts.callback = false;
+					if(!opts.callback) str += '</root>';
+					return str;
+				process_inner : function(obj, t, opts, lang) {
+					var str = '<name ';
+					if(lang) str += ' lang="' + lang + '" ';
+					if(opts.inner_attrib.length || obj.children("ins").get(0).style.backgroundImage.toString().length || obj.children("ins").get(0).className.length) {
+						if(obj.children("ins").get(0).style.className.length) {
+							str += ' icon="' + obj.children("ins").get(0).style.className + '" ';
+						if(obj.children("ins").get(0).style.backgroundImage.length) {
+							str += ' icon="' + obj.children("ins").get(0).style.backgroundImage.replace("url(","").replace(")","") + '" ';
+						if(opts.inner_attrib.length) {
+							for(var j in opts.inner_attrib) {
+								if(!opts.inner_attrib.hasOwnProperty(j)) continue;
+								var val = obj.attr(opts.inner_attrib[j]);
+								if(typeof val != "undefined" && val.toString().replace(" ","").length > 0) str += ' ' + opts.inner_attrib[j] + '="' + val.toString() + '" ';
+								delete val;
+					str += '><![CDATA[' + t.get_text(obj,lang) + ']]></name>';
+					return str;
+				parse	: function(data, t, opts, callback) {
+					var processor = new XSLTProcessor();
+					processor.importStylesheet($.tree.datastores.xml_flat.xsl);
+					var result = $((new XMLSerializer()).serializeToString(processor.transformToDocument(data)));
+					if(result.is("ul"))	result = result.html();
+					else				result = result.find("ul").html();
+					if(callback) callback.call(null,result);
+					// Disabled because of Chrome issues
+					// if(callback) callback.call(null,(new XMLSerializer()).serializeToString(processor.transformToDocument(data)).replace(/^<ul[^>]*>/i,"").replace(/<\/ul>$/i,""));
+				load	: function(data, t, opts, callback) {
+					if(opts.static) {
+						callback.call(null, (new DOMParser()).parseFromString(opts.static,'text/xml'));
+					else {
+						$.ajax({
+							'type'		: opts.method,
+							'url'		: opts.url,
+							'data'		: data,
+							'dataType'	: "xml",
+							'success'	: function (d, textStatus) {
+								callback.call(null, d);
+							'error'		: function (xhttp, textStatus, errorThrown) {
+								callback.call(null, false);
+								t.error(errorThrown + " " + textStatus);
+	$.tree.datastores.xml_flat.xsl = (new DOMParser()).parseFromString('<?xml version="1.0" encoding="utf-8" ?><xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" ><xsl:output method="html" encoding="utf-8" omit-xml-declaration="yes" standalone="no" indent="no" media-type="text/xml" /><xsl:template match="/"><ul><xsl:for-each select="//item[not(@parent_id) or @parent_id=0]"><xsl:call-template name="nodes"><xsl:with-param name="node" select="." /><xsl:with-param name="is_last" select="number(position() = last())" /></xsl:call-template></xsl:for-each></ul></xsl:template><xsl:template name="nodes"><xsl:param name="node" /><xsl:param name="theme_path" /><xsl:param name="theme_name" /><xsl:param name="is_last" /><xsl:variable name="children" select="count(//item[@parent_id=$node/attribute::id]) &gt; 0" /><li><xsl:attribute name="class"><xsl:if test="$is_last = true()"> last </xsl:if><xsl:choose><xsl:when test="@state = \'open\'"> open </xsl:when><xsl:when test="$children or @hasChildren or @state = \'closed\'"> closed </xsl:when><xsl:otherwise> leaf </xsl:otherwise></xsl:choose><xsl:value-of select="@class" /></xsl:attribute><xsl:for-each select="@*"><xsl:if test="name() != \'parent_id\' and name() != \'hasChildren\' and name() != \'class\' and name() != \'state\'"><xsl:attribute name="{name()}"><xsl:value-of select="." /></xsl:attribute></xsl:if></xsl:for-each><xsl:for-each select="content/name"><a href="#"><xsl:attribute name="class"><xsl:value-of select="@lang" /><xsl:value-of select="@class" /></xsl:attribute><xsl:attribute name="style"><xsl:value-of select="@style" /></xsl:attribute><xsl:for-each select="@*"><xsl:if test="name() != \'style\' and name() != \'class\'"><xsl:attribute name="{name()}"><xsl:value-of select="." /></xsl:attribute></xsl:if></xsl:for-each><ins><xsl:if test="string-length(attribute::icon) > 0"><xsl:choose><xsl:when test="not(contains(@icon,\'/\'))"><xsl:attribute name="class"><xsl:value-of select="@icon" /></xsl:attribute></xsl:when><xsl:otherwise><xsl:attribute name="style">background-image:url(<xsl:value-of select="@icon" />);</xsl:attribute></xsl:otherwise></xsl:choose></xsl:if><xsl:text>&#xa0;</xsl:text></ins><xsl:value-of select="." /></a></xsl:for-each><xsl:if test="$children or @hasChildren"><ul><xsl:for-each select="//item[@parent_id=$node/attribute::id]"><xsl:call-template name="nodes"><xsl:with-param name="node" select="." /><xsl:with-param name="is_last" select="number(position() = last())" /></xsl:call-template></xsl:for-each></ul></xsl:if></li></xsl:template></xsl:stylesheet>','text/xml');
+})(jQuery);
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.xml_nested.js
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.xml_nested.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.xml_nested.js	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,121 @@
+(function ($) {
+	if(typeof Sarissa == "undefined") throw "jsTree xml_nested: Sarissa is not included.";
+		"xml_nested" : function () {
+			return {
+				get		: function(obj, tree, opts) {
+					var str = "";
+						obj = tree.container.children("ul").children("li");
+						var _this = this;
+							str += _this.get(this, tree, $.extend(true, {}, opts, { callback : true }));
+						str		+= '</root>';
+						return str;
+					str += '<item ';
+						var val = (opts.outer_attrib[i] == "class") ? obj.attr(opts.outer_attrib[i]).replace(/(^| )last( |$)/ig," ").replace(/(^| )(leaf|closed|open)( |$)/ig," ") : obj.attr(opts.outer_attrib[i]);
+						delete val;
+					str += '>';
+					if(tree.settings.languages.length) {
+						for(var i in tree.settings.languages) {
+							if(!tree.settings.languages.hasOwnProperty(i)) continue;
+							str += this.process_inner(obj.children("a." + tree.settings.languages[i]), tree, opts, tree.settings.languages[i]);
+					else {
+						str += this.process_inner(obj.children("a"), tree, opts);
+						var _this = this;
+					str += '</item>';
+					return str;
+				process_inner : function(obj, tree, opts, lang) {
+								delete val;
+					str += '><![CDATA[' + tree.get_text(obj,lang) + ']]></name>';
+					return str;
+				parse	: function(data, tree, opts, callback) {
+					processor.importStylesheet($.tree.datastores.xml_nested.xsl);
+					var result = $((new XMLSerializer()).serializeToString(processor.transformToDocument(data)).replace('<?xml version="1.0"?>',''));
+					// Opera bug
+					if(result.size() > 1)	result = result.eq(1);
+					else					result = result.find("ul:eq(0)").html();
+				load	: function(data, tree, opts, callback) {
+					if(opts.staticData) {
+						callback.call(null, (new DOMParser()).parseFromString(opts.staticData,'text/xml'));
+					else {
+						$.ajax({
+							'url'		: opts.url,
+							'data'		: data,
+								tree.error(errorThrown + " " + textStatus);
+	$.tree.datastores.xml_nested.xsl = (new DOMParser()).parseFromString('<?xml version="1.0" encoding="utf-8" ?><xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" ><xsl:output method="html" encoding="utf-8" omit-xml-declaration="yes" standalone="no" indent="no" media-type="text/html" /><xsl:template match="/"><xsl:call-template name="nodes"><xsl:with-param name="node" select="/root" /></xsl:call-template></xsl:template><xsl:template name="nodes"><xsl:param name="node" /><ul><xsl:for-each select="$node/item"><xsl:variable name="children" select="count(./item) &gt; 0" /><li><xsl:attribute name="class"><xsl:if test="position() = last()"> last </xsl:if><xsl:choose><xsl:when test="@state = \'open\'"> open </xsl:when><xsl:when test="$children or @hasChildren"> closed </xsl:when><xsl:otherwise> leaf </xsl:otherwise></xsl:choose><xsl:value-of select="@class" /></xsl:attribute><xsl:for-each select="@*"><xsl:if test="name() != \'class\' and name() != \'state\' and name() != \'hasChildren\'"><xsl:attribute name="{name()}"><xsl:value-of select="." /></xsl:attribute></xsl:if></xsl:for-each><xsl:for-each select="content/name"><a href=""><xsl:attribute name="class"><xsl:value-of select="@lang" /><xsl:value-of select="@class" /></xsl:attribute><xsl:attribute name="style"><xsl:value-of select="@style" /></xsl:attribute><xsl:for-each select="@*"><xsl:if test="name() != \'style\' and name() != \'class\'"><xsl:attribute name="{name()}"><xsl:value-of select="." /></xsl:attribute></xsl:if></xsl:for-each><ins><xsl:if test="string-length(attribute::icon) > 0"><xsl:choose><xsl:when test="not(contains(@icon,\'/\'))"><xsl:attribute name="class"><xsl:value-of select="@icon" /></xsl:attribute></xsl:when><xsl:otherwise><xsl:attribute name="style">background-image:url(<xsl:value-of select="@icon" />);</xsl:attribute></xsl:otherwise></xsl:choose></xsl:if><xsl:text>&#xa0;</xsl:text></ins><xsl:value-of select="current()" /></a></xsl:for-each><xsl:if test="$children or @hasChildren"><xsl:call-template name="nodes"><xsl:with-param name="node" select="current()" /></xsl:call-template></xsl:if></li></xsl:for-each></ul></xsl:template></xsl:stylesheet>','text/xml');
+})(jQuery);
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/apple/bg.jpg
(Binary files differ)
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/apple/bg.jpg
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/apple/dot_for_ie.gif
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/apple/dot_for_ie.gif
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/apple/icons.png
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/apple/icons.png
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/apple/style.css
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/apple/style.css	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/apple/style.css	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,34 @@
+/* BACKGROUND */
+.tree-apple .ltr, .tree-apple .rtl { background:url("bg.jpg") left top repeat; min-width:100%; _width:100%; margin-left:0; margin-right:0; display:table; }
+.tree-apple .ltr > li.leaf, .tree-apple .rtl > li.leaf { background-image:none; }
+/* LOCKED */
+.tree-apple .locked li a { color:gray; }
+/* DOTS */
+.tree-apple ul { background-position:6px 1px; background-repeat:repeat-y; background-image:url(data:image/gif;base64,R0lGODlhAgACAIAAAB4dGf///yH5BAEAAAEALAAAAAACAAIAAAICRF4AOw==); _background-image:url("dot_for_ie.gif"); *background-image:url("dot_for_ie.gif"); }
+.tree-apple li { background-position:-64px -16px; background-repeat:no-repeat; background-image:url("icons.png"); }
+/* NO DOTS */
+.tree-apple .no_dots, .tree-apple .no_dots ul { background:transparent; }
+.tree-apple .no_dots li.leaf { background-image:none; background-color:transparent; }
+/* OPEN or CLOSED */
+.tree-apple li.open { background:url("icons.png") -32px -48px no-repeat; }
+.tree-apple li.closed, #jstree-dragged.tree-apple li li.open { background:url("icons.png") -48px -32px no-repeat; }
+#jstree-marker { background-image:url("icons.png"); }
+/* DEFAULT, HOVER, CLICKED, LOADING STATES */
+.tree-apple li a, .tree-apple li span { border-radius:3px; -moz-border-radius:3px; -webkit-border-radius:3px; }
+.tree-apple li a:hover, .tree-apple li a.hover, .tree-apple li span { background: #e7f4f9; border:1px solid #d8f0fa; padding:0px 3px 0px 3px; }
+.tree-apple li a.clicked, .tree-apple li a.clicked:hover, .tree-apple li span.clicked { background: #beebff; border:1px solid #99defd; padding:0px 3px 0px 3px; }
+/* ICONS */
+.tree-apple ins { background-image:url("icons.png"); background-position:0 0; background-repeat:no-repeat; }
+.tree-apple ul li a.loading ins { background-image:url("throbber.gif") !important; background-position:0 0 !important; } /* UL is added to make selector stronger */
+.tree-apple li a ins.forbidden { background-position:-16px -16px; }
+.tree-apple .locked li a ins { background-position:0 -48px; }
+.tree-apple li span ins { background-position:-16px 0; }
+#jstree-dragged.tree-apple ins { background:url("icons.png") -16px -32px no-repeat; }
+#jstree-dragged.tree-apple ins.forbidden { background:url("icons.png") -16px -16px no-repeat; }
+/* CONTEXT MENU */
+.tree-apple-context a ins { background-image:url("icons.png"); background-repeat:no-repeat; background-position:-64px -64px; }
+.tree-apple-context a ins.create { background-position:0 -16px; }
+.tree-apple-context a ins.rename { background-position:-16px 0px; }
+.tree-apple-context a ins.remove { background-position:0 -32px; }
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/apple/throbber.gif
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/apple/throbber.gif
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/checkbox/dot_for_ie.gif
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/checkbox/dot_for_ie.gif
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/checkbox/icons.png
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/checkbox/icons.png
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/checkbox/style.css
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/checkbox/style.css	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/checkbox/style.css	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,38 @@
+/* LOCKED */
+.tree-checkbox .locked li a { color:gray; }
+/* DOTS */
+.tree-checkbox ul { background-position:6px 1px; background-repeat:repeat-y; background-image:url(data:image/gif;base64,R0lGODlhAgACAIAAAB4dGf///yH5BAEAAAEALAAAAAACAAIAAAICRF4AOw==); _background-image:url("dot_for_ie.gif"); *background-image:url("dot_for_ie.gif"); }
+.tree-checkbox li { background-position:-64px -16px; background-repeat:no-repeat; background-image:url("icons.png"); }
+/* NO DOTS */
+.tree-checkbox .no_dots, .tree-checkbox .no_dots ul { background:transparent; }
+.tree-checkbox .no_dots li.leaf { background-image:none; background-color:transparent; }
+.tree-checkbox li.open { background:url("icons.png") -32px -48px no-repeat; }
+.tree-checkbox li.closed, #jstree-dragged.tree-checkbox li li.open { background:url("icons.png") -48px -32px no-repeat; }
+.tree-checkbox li a, .tree-checkbox li span { border-radius:3px; -moz-border-radius:3px; -webkit-border-radius:3px; }
+.tree-checkbox li a:hover, .tree-checkbox li a.hover, .tree-checkbox li span { background: #e7f4f9; border:1px solid #d8f0fa; padding:0px 3px 0px 3px; }
+.tree-checkbox li a.clicked, .tree-checkbox li a.clicked:hover, .tree-checkbox li span.clicked { background: #beebff; border:1px solid #99defd; padding:0px 3px 0px 3px; }
+/* ICONS */
+.tree-checkbox ins { background-image:url("icons.png"); background-position:0 0; background-repeat:no-repeat; }
+.tree-checkbox ul li a.loading ins { background-image:url("throbber.gif") !important; background-position:0 0 !important; } /* UL is added to make selector stronger */
+.tree-checkbox li a ins.forbidden { background-position:-16px -48px; }
+.tree-checkbox li a.undetermined ins { background-position:0px -16px; }
+.tree-checkbox li a.checked ins { background-position:0px -32px; }
+.tree-checkbox li a:hover ins { background-position:-16px 0px; }
+.tree-checkbox li a.undetermined:hover ins { background-position:-16px -16px; }
+.tree-checkbox li a.checked:hover ins { background-position:-16px -32px; }
+#jstree-dragged.tree-checkbox ins { background:url("icons.png") 0 -48px no-repeat; }
+#jstree-dragged.tree-checkbox ins.forbidden { background:url("icons.png") -16px -48px no-repeat; }
+/* CONTEXT MENU */
+.tree-checkbox-context a ins { background-image:url("icons.png"); background-repeat:no-repeat; background-position:-64px -64px; }
+.tree-checkbox-context a ins.create { background-position:0 -16px; }
+.tree-checkbox-context a ins.rename { background-position:-16px 0px; }
+.tree-checkbox-context a ins.remove { background-position:0 -32px; }
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/checkbox/throbber.gif
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/checkbox/throbber.gif
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/classic/dot_for_ie.gif
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/classic/dot_for_ie.gif
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/classic/icons.png
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/classic/icons.png
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/classic/style.css
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/classic/style.css	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/classic/style.css	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,31 @@
+/* LOCKED */
+.tree-classic .locked li a { color:gray; }
+/* DOTS */
+.tree-classic ul { background-position:6px 1px; background-repeat:repeat-y; background-image:url(data:image/gif;base64,R0lGODlhAgACAIAAAB4dGf///yH5BAEAAAEALAAAAAACAAIAAAICRF4AOw==); _background-image:url("dot_for_ie.gif"); *background-image:url("dot_for_ie.gif"); }
+.tree-classic li { background-position:-64px -16px; background-repeat:no-repeat; background-image:url("icons.png"); }
+/* NO DOTS */
+.tree-classic .no_dots, .tree-classic .no_dots ul { background:transparent; }
+.tree-classic .no_dots li.leaf { background-image:none; background-color:transparent; }
+.tree-classic li.open { background:url("icons.png") -32px -48px no-repeat; }
+.tree-classic li.closed, #jstree-dragged.tree-classic li li.open { background:url("icons.png") -48px -32px no-repeat; }
+.tree-classic li a:hover, .tree-classic li a.hover, .tree-classic li span { /*background: #e7f4f9; border:1px solid #d8f0fa; padding:0px 3px 0px 3px;*/ }
+.tree-classic li a.clicked, .tree-classic li a.clicked:hover, .tree-classic li span.clicked { background: navy; border:1px solid navy; color:white; padding:0px 3px 0px 3px; }
+/* ICONS */
+.tree-classic ins { background-image:url("icons.png"); background-position:0 0; background-repeat:no-repeat; }
+.tree-classic ul li a.loading ins { background-image:url("throbber.gif") !important; background-position:0 0 !important; } /* UL is added to make selector stronger */
+.tree-classic li.closed a ins, .tree-classic li.leaf a ins { background-position:0 0px; } /* UL is added to make selector stronger */
+.tree-classic ul li a.loading ins { background-image:url("throbber.gif"); background-position:0 0; } /* UL is added to make selector stronger */
+.tree-classic li a ins.forbidden { background-position:-16px -16px; }
+.tree-classic .locked li a ins { background-position:0 -48px; }
+.tree-classic li span ins { background-position:-16px 0; }
+#jstree-dragged.tree-classic ins { background:url("icons.png") -16px -32px no-repeat; }
+#jstree-dragged.tree-classic ins.forbidden { background:url("icons.png") -16px -16px no-repeat; }
+/* CONTEXT MENU */
+.tree-classic-context a ins { background-image:url("icons.png"); background-repeat:no-repeat; background-position:-64px -64px; }
+.tree-classic-context a ins.create { background-position:0 -16px; }
+.tree-classic-context a ins.rename { background-position:-16px 0px; }
+.tree-classic-context a ins.remove { background-position:-32px -16px; }
\ No newline at end of file
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/classic/throbber.gif
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/classic/throbber.gif
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/default/dot_for_ie.gif
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/default/dot_for_ie.gif
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/default/icons.png
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/default/icons.png
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/default/style.css
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/default/style.css	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/default/style.css	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,30 @@
+/* LOCKED */
+.tree-default .locked li a { color:gray; }
+/* DOTS */
+.tree-default ul { background-position:6px 1px; background-repeat:repeat-y; background-image:url(data:image/gif;base64,R0lGODlhAgACAIAAAB4dGf///yH5BAEAAAEALAAAAAACAAIAAAICRF4AOw==); _background-image:url("dot_for_ie.gif"); *background-image:url("dot_for_ie.gif"); }
+.tree-default li { background-position:-64px -16px; background-repeat:no-repeat; background-image:url("icons.png"); }
+/* NO DOTS */
+.tree-default .no_dots, .tree-default .no_dots ul { background:transparent; }
+.tree-default .no_dots li.leaf { background-image:none; background-color:transparent; }
+.tree-default li.open { background:url("icons.png") -32px -48px no-repeat; }
+.tree-default li.closed, #jstree-dragged.tree-default li li.open { background:url("icons.png") -48px -32px no-repeat; }
+.tree-default li a, .tree-default li span { border-radius:3px; -moz-border-radius:3px; -webkit-border-radius:3px; }
+.tree-default li a:hover, .tree-default li a.hover, .tree-default li span { background: #e7f4f9; border:1px solid #d8f0fa; padding:0px 3px 0px 3px; }
+.tree-default li a.clicked, .tree-default li a.clicked:hover, .tree-default li span.clicked { background: #beebff; border:1px solid #99defd; padding:0px 3px 0px 3px; }
+/* ICONS */
+.tree-default ins { background-image:url("icons.png"); background-position:0 0; background-repeat:no-repeat; }
+.tree-default ul li a.loading ins { background-image:url("throbber.gif") !important; background-position:0 0 !important; } /* UL is added to make selector stronger */
+.tree-default li a ins.forbidden { background-position:-16px -16px; }
+.tree-default .locked li a ins { background-position:0 -48px; }
+.tree-default li span ins { background-position:-16px 0; }
+#jstree-dragged.tree-default ins { background:url("icons.png") -16px -32px no-repeat; }
+#jstree-dragged.tree-default ins.forbidden { background:url("icons.png") -16px -16px no-repeat; }
+/* CONTEXT MENU */
+.tree-default-context a ins { background-image:url("icons.png"); background-repeat:no-repeat; background-position:-64px -64px; }
+.tree-default-context a ins.create { background-position:0 -16px; }
+.tree-default-context a ins.rename { background-position:-16px 0px; }
+.tree-default-context a ins.remove { background-position:0 -32px; }
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/default/throbber.gif
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/default/throbber.gif
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/themeroller/dot_for_ie.gif
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/themeroller/dot_for_ie.gif
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/themeroller/icons.png
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/themeroller/icons.png
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/themeroller/style.css
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/themeroller/style.css	                        (rev 0)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/themeroller/style.css	2010-04-29 14:27:35 UTC (rev 6042)
@@ -0,0 +1,39 @@
+/* LOCKED */
+.tree-themeroller .locked li a { color:gray; }
+/* DOTS */
+.tree-themeroller ul { background-position:6px 1px; background-repeat:repeat-y; background-image:url(data:image/gif;base64,R0lGODlhAgACAIAAAB4dGf///yH5BAEAAAEALAAAAAACAAIAAAICRF4AOw==); _background-image:url("dot_for_ie.gif"); *background-image:url("dot_for_ie.gif"); }
+.tree-themeroller li { background-position:-64px -16px; background-repeat:no-repeat; background-image:url("icons.png"); }
+/* NO DOTS */
+.tree-themeroller .no_dots, .tree-themeroller .no_dots ul { background:transparent; }
+.tree-themeroller .no_dots li.leaf { background-image:none; background-color:transparent; }
+.tree-themeroller li.open { background:url("icons.png") -32px -48px no-repeat; }
+.tree-themeroller li.closed, #jstree-dragged.tree-themeroller li li.open { background:url("icons.png") -48px -32px no-repeat; }
+.tree-themeroller li, .tree-themeroller li a, .tree-themeroller li a ins { line-height:16px !important; }
+.tree-themeroller li a .ui-icon { overflow:visible; }
+.tree-themeroller li a, .tree-themeroller li span { border-radius:3px; -moz-border-radius:3px; -webkit-border-radius:3px; }
+.tree-themeroller li a:hover, .tree-themeroller li a.hover, .tree-themeroller li span { background: #e7f4f9; border:1px solid #d8f0fa; padding:0px 3px 0px 3px; }
+.tree-themeroller li a.clicked, .tree-themeroller li a.clicked:hover, .tree-themeroller li span.clicked { background: #beebff; border:1px solid #99defd; padding:0px 3px 0px 3px; }
+/* ICONS */
+.tree-themeroller ul li a.loading ins { background-image:url("throbber.gif") !important; background-position:0 0 !important; } /* UL is added to make selector stronger */
+.tree-themeroller ins { background-image:url("icons.png"); background-position:0 0; background-repeat:no-repeat; }
+.tree-themeroller li a ins.forbidden { background-position:-16px -16px; }
+.tree-themeroller .locked li a ins { background-position:0 -48px; }
+.tree-themeroller li span ins { background-position:-16px 0; }
+#jstree-dragged.tree-themeroller ins { background:url("icons.png") -16px -32px no-repeat; }
+#jstree-dragged.tree-themeroller ins.forbidden { background:url("icons.png") -16px -16px no-repeat; }
+/* CONTEXT MENU
+.tree-themeroller-context a ins { background-image:url("icons.png"); background-repeat:no-repeat; background-position:-64px -64px; }
+.tree-themeroller-context a ins.create { background-position:0 -16px; }
+.tree-themeroller-context a ins.rename { background-position:-16px 0px; }
+.tree-themeroller-context a ins.remove { background-position:0 -32px; }
Added: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/themeroller/throbber.gif
Property changes on: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/themes/themeroller/throbber.gif
More information about the Mapbender_commits mailing list
