[Mapbender-commits] r6043 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Apr 29 10:38:55 EDT 2010
Author: christoph
Date: 2010-04-29 10:38:54 -0400 (Thu, 29 Apr 2010)
New Revision: 6043
Added:
   trunk/mapbender/http/plugins/mb_metadata_layerTree.js
   trunk/mapbender/http/plugins/mb_metadata_edit.js
   trunk/mapbender/http/plugins/mb_metadata_layer.js
   trunk/mapbender/http/plugins/mb_metadata_select.js
   trunk/mapbender/http/plugins/mb_metadata_server.php
   trunk/mapbender/http/plugins/mb_tabs_horizontal.js
Modified: trunk/mapbender/http/plugins/mb_metadata_edit.js
--- trunk/mapbender/http/plugins/mb_metadata_edit.js	2010-04-29 14:27:35 UTC (rev 6042)
+++ trunk/mapbender/http/plugins/mb_metadata_edit.js	2010-04-29 14:38:54 UTC (rev 6043)
@@ -32,28 +32,38 @@
-	this.edit = function (obj) {
-		$metadataForm.load("../plugins/mb_metadata_edit.html", function () {
-			validator = $metadataForm.validate();
+	var formReady = false;
-			// get metadata from server
-			var req = new Mapbender.Ajax.Request({
-				url: "../plugins/mb_metadata_server.php",
-				method: "getWmsMetadata",
-				parameters: {
-					"id": obj.wmsId
-				callback: function (obj, result, message) {
-					if (!result) {
-						return;
-					$metadataForm.easyform("reset");
-					$metadataForm.easyform("fill", obj);
+	var fillForm = function (obj) {
+		// get metadata from server
+		var req = new Mapbender.Ajax.Request({
+			url: "../plugins/mb_metadata_server.php",
+			method: "getWmsMetadata",
+			parameters: {
+				"id": obj
+			callback: function (obj, result, message) {
+				if (!result) {
+					return;
-			req.send();
+				$metadataForm.easyform("reset");
+				$metadataForm.easyform("fill", obj);
+		req.send();
+	this.init = function (obj) {
+		if (!formReady) {
+			$metadataForm.load("../plugins/mb_metadata_edit.html", function () {
+				validator = $metadataForm.validate();
+				fillForm(obj);
+				formReady = true;
+			return;
+		fillForm(obj);
 	Mapbender.events.localize.register(function () {
 		that.valid();
Modified: trunk/mapbender/http/plugins/mb_metadata_layer.js
--- trunk/mapbender/http/plugins/mb_metadata_layer.js	2010-04-29 14:27:35 UTC (rev 6042)
+++ trunk/mapbender/http/plugins/mb_metadata_layer.js	2010-04-29 14:38:54 UTC (rev 6043)
@@ -25,32 +25,30 @@
 var MetadataLayerApi = function (o) {
 	var that = this;
 	var validator;
 	this.valid = function () {
 		if (validator && validator.numberOfInvalids() > 0) {
 			$metadataForm.valid();
-		$metadataForm.load("../plugins/mb_metadata_layer.html", function () {
-			// get layer from server
-				method: "getLayerByWms",
-				parameters: {
-					"id": obj.wmsId
-					if (!result) {
-						return;
-					console.log(obj);
+	this.events = {
+		initialized: new Mapbender.Event()
+		if (!that.events.initialized.done) {
+			$metadataForm.load("../plugins/mb_metadata_layer.html", function () {
+				that.events.initialized.trigger({
+					wmsId: obj
+				that.events.initialized.done = true;
-//			req.send();
+			return;
+			wmsId: obj
Added: trunk/mapbender/http/plugins/mb_metadata_layerTree.js
--- trunk/mapbender/http/plugins/mb_metadata_layerTree.js	                        (rev 0)
+++ trunk/mapbender/http/plugins/mb_metadata_layerTree.js	2010-04-29 14:38:54 UTC (rev 6043)
@@ -0,0 +1,149 @@
+ * Package: mb_metadata_layerTree
+ * Description:
+ * Files:
+ * SQL:
+ * Help:
+ * Maintainer:
+ * http://www.mapbender.org/User:Christoph_Baudson
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+var $metadataLayerTree = $(this);
+var MetadataLayerTreeApi = function (o) {
+	var that = this;
+	var instanceId = "choose";
+	var createFolder = function (set) {
+		return {
+			attributes: {
+				data: $.toJSON(set.attr)
+			data: set.attr.title,
+			state: "closed",
+			children: []
+	var createLeaf = function (set) {
+		return {
+			attributes: {
+			data: {
+				title: set.attr.title
+	var toJsTreeJson = function (nestedSets) {
+		if (!nestedSets.length && nestedSets.length !== 0) {
+			new Mapbender.Exception("Nested sets not an array.");
+			return [];
+		var right = null;
+		if (arguments.length === 2) {
+			right = arguments[1];
+		var children = [];
+		while (nestedSets.length > 0) {
+			set = nestedSets.shift();
+			if (typeof set.left != "number" || typeof set.right != "number") {
+				new Mapbender.Exception("Left or right not set.");
+				return [];
+			// is a different subtree, go back
+			if (right !== null && right < set.right) {
+				nestedSets.unshift(set);
+				return children;
+			// is a leaf
+			else if (set.right - set.left === 1) {
+				children.push(createLeaf(set));
+			// is a folder
+			else {
+				var node = createFolder(set);
+				var nodeChildren = toJsTreeJson(nestedSets, set.right);
+				children.push($.extend(node, {
+					children: nodeChildren
+		return children;
+	var initTree = function (nestedSets) {
+		var jsTreeData = toJsTreeJson(nestedSets);
+		jsTreeData[0].state = "open";
+		var jsTree = $.tree.reference(instanceId);
+		if (jsTree !== null) {
+			jsTree.destroy();
+		$("#" + instanceId).tree({
+			ui: {
+				theme_path: "../extensions/jsTree.v.0.9.9a2/themes/checkbox/style.css",
+				theme_name: "checkbox"
+			plugins: {
+				checkbox: {
+			data : {
+				type : "json",
+				opts : {
+					static : jsTreeData
+			callback: {
+				onselect: function (node, treeObj) {
+					var data = $(node).metadata({
+						type: "attr",
+						name: "data"
+					that.events.selected.trigger(data);
+	this.events = {
+		selected: new Mapbender.Event()
+		// get layer from server
+			method: "getLayerByWms",
+			parameters: {
+				"id": obj
+				if (!result) {
+					return;
+				initTree(obj.nestedSets);
+		req.send();
+$metadataLayerTree.mapbender(new MetadataLayerTreeApi(options));
Modified: trunk/mapbender/http/plugins/mb_metadata_select.js
--- trunk/mapbender/http/plugins/mb_metadata_select.js	2010-04-29 14:27:35 UTC (rev 6042)
+++ trunk/mapbender/http/plugins/mb_metadata_select.js	2010-04-29 14:38:54 UTC (rev 6043)
@@ -79,8 +79,11 @@
 					$(e.target.parentNode).addClass('row_selected');
 					var selectedRow = fnGetSelected(table);
-					that.events.selected.trigger({
-						wmsId: $(selectedRow).data("wmsId")
+					$metadataSelect.fadeOut(function () {
+						that.events.selected.trigger({
+							wmsId: $(selectedRow).data("wmsId")
+						$metadataSelect.show();
@@ -89,7 +92,7 @@
 	this.events = {
-		"selected": new Mapbender.Event()
Modified: trunk/mapbender/http/plugins/mb_metadata_server.php
--- trunk/mapbender/http/plugins/mb_metadata_server.php	2010-04-29 14:27:35 UTC (rev 6042)
+++ trunk/mapbender/http/plugins/mb_metadata_server.php	2010-04-29 14:38:54 UTC (rev 6043)
@@ -5,6 +5,7 @@
 $ajaxResponse = new AjaxResponse($_POST);
 function abort ($message) {
+	global $ajaxResponse;
 	$ajaxResponse->setSuccess(false);
 	$ajaxResponse->setMessage($message);
 	$ajaxResponse->send();
@@ -80,7 +81,7 @@
 		break;
 	case "getLayerByWms" :
 		$wmsId = $ajaxResponse->getParameter("id");
-		getWms($wmsId);
+//		getWms($wmsId);
 		$sql = <<<SQL
@@ -94,49 +95,69 @@
 		while ($row = db_fetch_assoc($res)) {
 			$rows[] = $row;
-		$resultObj = array();
-		$previousParent = null;
 		$left = 1;
-		$resultObj[]= array(
-			"left" => $left,
-			"right" => 2*(count($rows) + 1),
-			"wms" => ""
-		function addSubTree ($rows, $i, $left) {
-			$currentRow = $rows[$i];
-			$layer_parent = $currentRow["layer_parent"];
-			$layer_pos = $currentRow["layer_pos"];
-			$node = array(
+		function createNode ($left, $right, $row) {
+			return array(
 				"left" => $left,
-				"right" => null,
-				"wms" => $rows["layer_id"]
+				"right" => $right,
+				"parent" => $row["layer_parent"] !== "" ? intval($row["layer_parent"]) : null,
+				"pos" => intval($row["layer_pos"]),
+				"attr" => array (
+					"id" => intval($row["layer_id"]),
+					"name" => $row["layer_name"],
+					"title" => $row["layer_title"]
-			$previousParent = is_numeric($layer_parent) ? $layer_parent : null;
-			for ($j = $i+1; $j < count($rows); $j++) {
+		function addSubTree ($rows, $i, $left) {
+			$nodeArray = array();
+			$addNewNode = true;
+			for ($j = $i; $j < count($rows); $j++) {
 				$row = $rows[$j];
-				$parent = $row["layer_parent"];
-				$pos = $row["layer_pos"];
-				if (!is_null($previousParent) && $previousParent > $parent) {
-					break;
+				$pos = intval($row["layer_pos"]);
+				$parent = $row["layer_parent"] !== "" ? intval($row["layer_parent"]) : null;
+				// first node of subtree
+				if ($addNewNode) {
+					$nodeArray[]= createNode($left, null, $row);
+					$addNewNode = false;
-				if (is_null($previousParent)) {
+				else {
+					// new sub tree
+					if ($parent === $nodeArray[count($nodeArray)-1]["pos"]) {
+						$addedNodeArray = addSubTree($rows, $j, ++$left);
+						$nodeArray[count($nodeArray)-1]["right"] =
+							$nodeArray[count($nodeArray)-1]["left"] +
+							2 * count($addedNodeArray) + 1;
+						$left = $nodeArray[count($nodeArray)-1]["right"] + 1;
+						$nodeArray = array_merge($nodeArray, $addedNodeArray);
+						$j += count($addedNodeArray) - 1;
+					// siblings
+					elseif ($parent === $nodeArray[count($nodeArray)-1]["parent"]) {
+						$nodeArray[count($nodeArray)-1]["right"] = ++$left;
+						$nodeArray[]= createNode(++$left, null, $row);
-				if ($previousParent < $parent) {
-			return $subTree;
+			if (is_null($nodeArray[count($nodeArray)-1]["right"])) {
+			return $nodeArray;
-		addSubTree($rows, 0, 0, $left);
+		$nodeArray = addSubTree($rows, 0, 1);
+		$resultObj = array(
+			"nestedSets" => $nodeArray
 		$ajaxResponse->setResult($resultObj);
 		$ajaxResponse->setSuccess(true);
Modified: trunk/mapbender/http/plugins/mb_tabs_horizontal.js
--- trunk/mapbender/http/plugins/mb_tabs_horizontal.js	2010-04-29 14:27:35 UTC (rev 6042)
+++ trunk/mapbender/http/plugins/mb_tabs_horizontal.js	2010-04-29 14:38:54 UTC (rev 6043)
@@ -33,21 +33,38 @@
 var $tabs = $(this);
-options.$target.each(function () {
-	var $currentTabEntry = $(this);
-	var tabId = $tabs.attr("id") + "_" + this.id;
+var HorizontalTabsApi = function (o) {
+	this.create = function () {
+		o.$target.each(function () {
+			var $currentTabEntry = $(this);
+			var tabId = $tabs.attr("id") + "_" + this.id;
+			$tabs.find("ul").append(
+				"<li><a href='#" + tabId + "'>" +
+				$currentTabEntry.mapbender("currentTitle") +
+				"</a></li>"
+			.end()
+			.append("<div id='" + tabId + "'/>")
+			.find("#" + tabId)
+			.append($currentTabEntry);
-	$tabs.find("ul").append(
-		"<li><a href='#" + tabId + "'>" +
-		$currentTabEntry.mapbender("currentTitle") +
-		"</a></li>"
-	.end()
-	.append("<div id='" + tabId + "'/>")
-	.find("#" + tabId)
-	.append($currentTabEntry);
+		if (o.$target.size() > 0) {
+			$tabs.tabs();
+	this.select = function (id) {
+		var index = $.inArray(id, o.target);
+		if (index === -1) {
+			return;
+		$tabs.tabs("select", index);
+	this.create();
-if (options.$target.size() > 0) {
-	$tabs.tabs();
+$tabs.mapbender(new HorizontalTabsApi(options));
More information about the Mapbender_commits mailing list
