[Mapbender-commits] r6044 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Apr 29 11:02:47 EDT 2010
Author: christoph
Date: 2010-04-29 11:02:45 -0400 (Thu, 29 Apr 2010)
New Revision: 6044
Removed:
   trunk/mapbender/http/plugins/mb_metadata_controller.js
Deleted: trunk/mapbender/http/plugins/mb_metadata_controller.js
--- trunk/mapbender/http/plugins/mb_metadata_controller.js	2010-04-29 14:38:54 UTC (rev 6043)
+++ trunk/mapbender/http/plugins/mb_metadata_controller.js	2010-04-29 15:02:45 UTC (rev 6044)
@@ -1,27 +0,0 @@
-Mapbender.events.init.register(function () {
-	if (options.$target.length < 3) {
-		return;
-	var tabsIndex = 0;
-	var selectIndex = 1;
-	var editIndex = 2;
-	var layerIndex = 3;
-	var $tabs = options.$target.eq(tabsIndex);
-	var $select = options.$target.eq(selectIndex);
-	var $edit = options.$target.eq(editIndex);
-	var $layer = options.$target.eq(layerIndex);
-	var select = $select.mapbender();
-	var edit = $edit.mapbender();
-	var layer = $layer.mapbender();
-	select.events.selected.register(function (obj) {
-		$select.fadeOut(function () {
-			$tabs.tabs("select", editIndex-1);
-			edit.edit(obj);
-			layer.edit(obj);
-			$select.show();
More information about the Mapbender_commits mailing list
