[Mapbender-commits] r7211 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sat Dec 11 07:27:42 EST 2010
Author: tbaschetti
Date: 2010-12-11 04:27:42 -0800 (Sat, 11 Dec 2010)
New Revision: 7211
Removed:
   trunk/mapbender/http/php/mod_edit_element_vars.php
delete obsolete module
Deleted: trunk/mapbender/http/php/mod_edit_element_vars.php
--- trunk/mapbender/http/php/mod_edit_element_vars.php	2010-12-11 12:18:54 UTC (rev 7210)
+++ trunk/mapbender/http/php/mod_edit_element_vars.php	2010-12-11 12:27:42 UTC (rev 7211)
@@ -1,360 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/mod_edit_element_vars.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-include(dirname(__FILE__)."/../php/mb_validateSession.php");
- * @security_patch irv open
-security_patch_log(__FILE__,__LINE__);
-import_request_variables("PG");
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<meta name="author-mail" content="info at ccgis.de">
-<meta name="author" content="U. Rothstein">
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>Edit Element Vars</title>
-<?php
-include '../include/dyn_css.php';
-<style type="text/css">
-   body{
-      background-color: #ffffff;
-  		font-family: Arial, Helvetica, sans-serif;
-  		font-size : 12px;
-  		color: #808080
-   .guiList1{
-   	position:absolute;
-   	top:30px;
-   	left:10px;
-   	width:200px
-   .buttonbar{
-   	top:40px;
-   	left:10px;
-   .guiList1_text{
-   	top:10px;
-   	left:10px;
-      font-size:16px;
-      color: #0066cc;
-   .guiList2{
-   	top:40px;
-   	left:400px;
-   	width:200px
-   .all{
-   	top:38px;
-   	left:610px;
-   .guiList2_header{
-   	top:10px;
-   	left:400px;
-      font-size:16px;
-      color: #0066cc;
-   .myElements{
-   	top:70px;
-   	left:400px;
-   .myTable{
-   	border: 1px solid;
-      font-size: 11px;
-   .myForm{
-   	top:70px;
-   	left:10px;
-   .textfield{
-      width:277px
-   .on{
-      color: #0066cc;
-</style>
-<?php
-# handle database updates etc.....
-if(isset($mySave) && $mySave == '1'){
-	if ($SYS_DBTYPE=='pgsql') {
-		$sql[0] = "SET AUTOCOMMIT=1;";
-	else {
-		$sql[0] = "SET AUTOCOMMIT=0;shit happens";
-	$v[0] = array();
-	$t[0] = array();
-	$sql[1] = "BEGIN;";
-	$v[1] = array();
-	$t[1] = array();
-	$sql[2] = "DELETE FROM gui_element_vars WHERE fkey_e_id = $1 AND fkey_gui_id = $2";
-	$v[2] = array($e_id, $guiList1);
-	$t[2] = array("s", "s");
-   if($e_left < 1){$e_left = "NULL";}
-   if($e_top < 1){$e_top = "NULL";}
-   if($e_width < 1){$e_width = "NULL";}
-   if($e_height < 1){$e_height = "NULL";}
-   if($e_z_index < 1){$e_z_index = "NULL";}
-	$sql[3] = "INSERT INTO gui_element_vars ";
-	$sql[3] .= "(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, ";
-	$sql[3] .= "e_attributes, e_left, e_top, e_width, e_height, e_z_index, ";
-	$sql[3] .= "e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, ";
-	$sql[3] .= "e_requires) ";
-	$sql[3] .= "VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, $16, $17, $18, $19, $20)";
-	$v[3] = array($guiList1, $e_id, $e_pos, $e_public, db_escape_string($e_comment), $e_element, $e_src, db_escape_string($e_attributes), $e_left, $e_top, $e_width, $e_height, $e_z_index, $e_more_styles, $e_content, $e_closetag, $e_js_file, $e_mb_mod, $e_target, $e_requires);
-	$t[3] = array("s", "s", "i", "s", "s", "s", "s", "s", "i", "i", "i", "i", "i", "s", "s", "s", "s", "s", "s", "s");
-   #echo $sql[3];
-   for ($i = 0; $i < count($sql); $i++) {
-      $res = db_prep_query($sql[$i], $v[$i], $t[$i]);
-   if($res){
-      $res = db_query( "COMMIT");
-      $res = db_query( "SET AUTOCOMMIT=1");
-   else{
-      $res = db_query( "ROLLBACK");
-if(isset($myDelete) && $myDelete == '1'){
-   $sql = "DELETE FROM gui_element_vars WHERE fkey_e_id = $1 AND fkey_gui_id = $2 AND var_name= $3";
-   $v = array($e_id, $guiList1, $var_name);
-   $t = array("s", "s", "s");
-   $res = db_prep_query($sql, $v, $t);
-   $e_id = ""; $e_pos = ""; $e_public = ""; $e_comment = ""; $e_element = "";
-   $e_src = ""; $e_attributes = ""; $e_left = ""; $e_top = ""; $e_width = ""; $e_height = ""; $e_z_index = "";
-   $e_more_styles = ""; $e_content = ""; $e_closetag = ""; $e_js_file = ""; $e_mb_mod = ""; $e_target = ""; $e_requires = "";
-if(isset($myShow) && $myShow == '1'){
-	 Mapbender::session()->set("mb_user_myGui",$guiList1);
-   echo "<script language='javascript'>";
-   echo "window.open('../frames/login.php?".strip_tags (SID)."&mb_user_myGui=".$guiList1."','','');";
-   echo "</script>";
-if(isset($all) && $all == '1'){
-   $sql = "SELECT * FROM gui_element_vars WHERE fkey_gui_id = $1 AND fkey_e_id = $2 and var_name= $3;";
-   $v = array($guiList2, $e_id, $var_name);
-   $cnt = 0;
-   while(db_fetch_row($res)){
-      $sql_del = "DELETE FROM gui_element_vars WHERE fkey_gui_id = $1 AND fkey_e_id = $2 and var_name= $3";
-      $v = array($guiList1, db_result($res,$cnt,"fkey_e_id"), $var_name);
-      $res_del = db_prep_query($sql_del, $v, $t);
-      if(db_result($res,$cnt,"e_left") == ""){$myleft = 'NULL';} else{$myleft = db_result($res,$cnt,"e_left");}
-      if(db_result($res,$cnt,"e_top") == ""){$mytop = 'NULL';} else{$mytop = db_result($res,$cnt,"e_top");}
-      if(db_result($res,$cnt,"e_width") == ""){$mywidth = 'NULL';} else{$mywidth = db_result($res,$cnt,"e_width");}
-      if(db_result($res,$cnt,"e_height") == ""){$myheight = 'NULL';} else{$myheight = db_result($res,$cnt,"e_height");}
-      if(db_result($res,$cnt,"e_z_index") == ""){$my_z_index = 'NULL';} else{$my_z_index = db_result($res,$cnt,"e_z_index");}
-      $sql_ins = "INSERT INTO gui_element_vars ";
-      $sql_ins .= "(fkey_gui_id, e_id, e_pos,e_public, e_comment, e_element, ";
-      $sql_ins .= "e_src, e_attributes, e_left, e_top, e_width, e_height, ";
-      $sql_ins .= "e_z_index, e_more_styles, e_content, e_closetag, e_js_file, ";
-      $sql_ins .= "e_mb_mod, e_target, e_requires) ";
-      $sql_ins .= "VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, ";
-      $sql_ins .= "$10, $11, $12, $13, $14, $15, $16, $17, $18, ";
-      $sql_ins .= "$19, $20)";
-      $v = array($guiList1, db_result($res,$cnt,"e_id"), db_result($res,$cnt,"e_pos"), db_result($res,$cnt,"e_public"), db_escape_string(db_result($res,$cnt,"e_comment")), db_result($res,$cnt,"e_element"), db_result($res,$cnt,"e_src"), db_escape_string(db_result($res,$cnt,"e_attributes")), $myleft, $mytop, $mywidth, $myheight, $my_z_index, db_result($res,$cnt,"e_more_styles"), db_escape_string(db_result($res,$cnt,"e_content")), db_result($res,$cnt,"e_closetag"), db_result($res,$cnt,"e_js_file"), db_result($res,$cnt,"e_mb_mod"), db_result($res,$cnt,"e_target"), db_result($res,$cnt,"e_requires"));
-      $t = array("s", "s", "s", "s", "s", "s", "s", "s", "i", "i", "i", "i", "i", "s", "s", "s", "s", "s", "s", "s");
-      $res_ins = db_prep_query($sql_ins, $v, $t);
-      if (!$res_ins) {
-      	echo db_error($connect);
-      $cnt++;
-# end
-echo "<script language='javascript'>";
-echo "var varIDs = new Array();";
-if(isset($guiList1)){
-   $sql = "SELECT var_name FROM gui_element_vars WHERE fkey_gui_id = $1 AND fkey_e_id = $2";
-   $v = array($guiList1, $e_id);
-   $t = array("s", "s");
-   $cnt = 0;
-      echo  "varIDs[".$cnt."] = '".db_result($res,$cnt,"var_name")."'; ";
-      $cnt++;
-echo "</script>";
-<script type="text/javascript">
-function setGui(val){
-   document.form1.guiList1.value = val;
-   document.form1.submit();
-function clearRadio(){
-   for(var i=0; i< document.form1.elements.length; i++){
-      if(document.form1.elements[i].type == "radio"){
-         document.form1.elements[i].checked = false;
-function thisSave(){
-   if(document.form1.e_id.value == ""){
-      alert("ID ? ");
-      document.form1.e_id.focus();
-      return;
-   var permission = false;
-   var isElement = false;
-   for(var i=0; i<varIDs.length; i++){
-      clearRadio();
-      if(document.form1.var_name.value == varIDs[i]){
-         permission = confirm("update: " + document.form1.var_name.value + " ?");
-         isElement = true;
-         break;
-   if(permission == true || isElement == false){
-      document.form1.mySave.value = 1;
-function thisDelete(){
-   clearRadio();
-   var permission =  confirm("delete: " + document.form1.e_id.value + " ?");
-   if(permission == true){
-      document.form1.myDelete.value = 1;
-function thisShow(){
-   document.form1.myShow.value = 1;
-function addAll(){
-   var permission =  confirm("add all elements ?");
-      clearRadio();
-      document.form1.all.value = 1;
-function thisExport(){
-   window.open("mod_exportElement.php?element=" + document.forms[0].e_id.value+ "&gui=" +document.forms[0].guiList1.value ,"","");
-</script>
-</head>
-<body>
-<?php
-echo "<form name='form1' action='" . $self ."' method='get'>";
-#Gui to edit
-if(!isset($guiList1)){
-  echo "<div class= 'guiList1_text'>GUI:</div>";
-  echo "<select class='guiList1' size='20' name='guiList1' onchange='setGui(this.value)'>";
-  for ($i=0; $i<$count;$i++){
-     echo "<option value='".$gui_id[$i]."' ";
-     if($guiList1 && $guiList1 == $gui_id[$i]){
-        echo "selected";
-     echo ">".$gui_name[$i]."</option>";
-  echo "</select>";
- // echo "<input type='hidden'  name='guiList2' value='' >";
-else{
-   echo "<div class= 'guiList1_text'>Edit Elements: ".$guiList1."</div>";
-   echo "<div class='buttonbar'>";
-   echo "<input type='button' class='' name='' value='save' onclick='thisSave()'> ";
-   echo "<input type='button' class='' name='' value='delete' onclick='thisDelete()'> ";
-   echo "<input type='button' class='' name='' value='show' onclick='thisShow()'> ";
-   echo "<input type='button' class='' name='' value='sql' onclick='thisExport()'> ";
-   echo "</div>";
-   echo "<input type='hidden'  name='guiList1' value='".$guiList1."' >";
-   echo "<input type='hidden'  name='e_id' value='".$e_id."' >";
-#Elements
-   echo "<div class='guiList2_header'>Templates</div>";
-   $sql = "SELECT * FROM gui_element_vars WHERE fkey_gui_id = $1 AND fkey_e_id = $2";
-   $cnt = 0;
-   echo "<div class='myElements'><table>";
-   while($row = db_fetch_array($res)){
-      echo "<tr>";
-      echo "<td class='myTable'><input type='radio' name='var_name' value='".$row["var_name"]."' onclick='submit()' ";
-      if($row["var_name"] == $var_name){echo "checked";}
-      echo "></td><td class='myTable'>";
-      //if(db_result($res,$cnt,"e_public") == 1){echo "<div class='on'>on</div>";}
-      echo "</td><td class='myTable'>". $row["var_name"]. "</td><td class='myTable'>" .$row["context"]."</td>";
-      echo "</tr>";
-      $cnt++;
-   echo "</table></div>";
-#Formular:
-echo "<table class='myForm'>";
-if(isset($guiList1) && isset($var_name)){
-   $sql = "SELECT * FROM gui_element_vars WHERE fkey_gui_id = $1 AND fkey_e_id = '".$e_id."' AND var_name = $2";
-   $v = array($guiList1, $var_name);
-   //echo $sql;
-   if($row = db_fetch_array($res)){
-      echo "<tr><td>ID: </td><td><input type='text' class='textfield' readonly name='e_id' value='".$e_id."'></td></tr>";
-      echo "<tr><td>Var Type: </td><td><input type='text' class='textfield' name='type' value='".$row["type"]."'></td></tr>";
-      echo "<tr><td>Var Name: </td><td><input type='text' class='textfield' name='var_name_edit' value='".$row["var_name"]."'></td></tr>";
-      echo "<tr><td>Content: </td><td><textarea cols='32' rows='4'  name='e_content' >".stripslashes($row["var_value"])."</textarea></td></tr>";
-   echo "</table>";
-<input type='hidden' name='myDelete'>
-<input type='hidden' name='mySave'>
-<input type='hidden' name='myShow'>
-<input type='hidden' name='all'>
-</form>
-</body>
-</html>
\ No newline at end of file
More information about the Mapbender_commits mailing list
