[Mapbender-commits] r7212 - trunk/mapbender/conf
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sat Dec 11 09:36:25 EST 2010
Author: arnulf
Date: 2010-12-11 06:36:25 -0800 (Sat, 11 Dec 2010)
New Revision: 7212
   trunk/mapbender/conf/mapbender.conf-dist
formatted and updated
Modified: trunk/mapbender/conf/mapbender.conf-dist
--- trunk/mapbender/conf/mapbender.conf-dist	2010-12-11 12:27:42 UTC (rev 7211)
+++ trunk/mapbender/conf/mapbender.conf-dist	2010-12-11 14:36:25 UTC (rev 7212)
@@ -1,19 +1,16 @@
 <?php
 # $Id$
-# http://www.mapbender.org/index.php/Mapbender.conf
-# Copyright (C) 2002 CCGIS
+# http://www.mapbender.org/Mapbender.conf
+# Copyright (C) 2010 OSGeo
 # type of mapbender database
 define("SYS_DBTYPE", "pgsql");
 # database information
 define("DBSERVER", "%%DBSERVER%%"); //default "localhost"
 define("PORT", "%%DBPORT%%"); //default "5432"
 define("DB", "%%DBNAME%%");
@@ -33,19 +30,16 @@
 # error_reporting
 //ini_set('error_reporting', 'E_ALL & ~ E_NOTICE');
 # directory for temporary files
 define("TMPDIR", "../tmp");
 # URL to login
 define("LOGIN", "http://localhost/mapbender/frames/login.php");
 define("MAXLOGIN", 3);
 $login = LOGIN;
@@ -54,13 +48,11 @@
 # URL to owsproxy
 # (no terminating slash)
 define("OWSPROXY", "http://<ip or name>/owsproxy");
 # Definitions for HTTP Authentication
 define('REALM', 'mapbender_registry');
 define('NONCEKEY', 'mapbender');
 $nonceLife = 300;
@@ -89,13 +81,11 @@
 # security: path to modules
 define("CHECK", true);
 # enable/disable portal
 define("PORTAL", false);
@@ -104,7 +94,6 @@
 # for further settings check 'class_administration.php'
 # please check phpmailer for more information
 define("USE_PHP_MAILING", "false");
 define("MAILHOST", "<host>");
 define("MAILUSERNAME", "<user>");
@@ -119,7 +108,6 @@
 # wms monitoring
 define("AUTO_UPDATE", "0");
 define("TIME_LIMIT", "300");
 define("PHP_PATH", "/usr/local/bin/");
@@ -127,7 +115,6 @@
 # Mapbender error logging
 define("LOG_LEVEL", "error"); //"off","error","warning","notice" or "all"
 define("LOG_JS", "off"); // "on", "alert", "console" or "off"
@@ -135,7 +122,6 @@
 # Internationalization
 define("USE_I18N", false);  // requires gettext for PHP.
 							// If "false", LANGUAGE is set to english
 define("LANGUAGE", "en");   // only available if USE_I18N is "true".
@@ -146,17 +132,14 @@
 define("GEO_RSS_FILE", "../tmp/georss.xml");
 # PREVIEW
 define("PREVIEW_DIR", "../geoportal/preview");
 # UPLOAD
 define("UPLOAD_DIR", "../tmp");
 define("UPLOAD_WHITELIST_FILE_TYPES", "");
 define("UPLOAD_BLACKLIST_FILE_TYPES", "");
@@ -177,12 +160,10 @@
 #define("SESSION_NAME", "MAPBENDER");
 ###HACK for GLOBALS
 $DBSERVER=DBSERVER;
   $DB=DB;
   $OWNER=OWNER;
   $PW=PW;
More information about the Mapbender_commits mailing list
