[Mapbender-commits] r7213 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sat Dec 11 09:50:11 EST 2010
Author: christoph
Date: 2010-12-11 06:50:11 -0800 (Sat, 11 Dec 2010)
New Revision: 7213
   trunk/mapbender/http/php/mod_editGuiWms.php
bug fix
Modified: trunk/mapbender/http/php/mod_editGuiWms.php
--- trunk/mapbender/http/php/mod_editGuiWms.php	2010-12-11 14:36:25 UTC (rev 7212)
+++ trunk/mapbender/http/php/mod_editGuiWms.php	2010-12-11 14:50:11 UTC (rev 7213)
@@ -1,4 +1,5 @@
 <?php
 # $Id$
 # http://www.mapbender.org/index.php/mod_editGuiWms.php
 # Copyright (C) 2002 CCGIS
@@ -17,26 +18,44 @@
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+$e_id = "editGUI_WMS";
+require_once (dirname(__FILE__) . "/../php/mb_validatePermission.php");
- * @security_patch irv open
-security_patch_log(__FILE__,__LINE__);
-import_request_variables("PG");
-$e_id="editGUI_WMS";
-require_once(dirname(__FILE__)."/../classes/class_wms.php");
+ * @security_patch irv done
+//security_patch_log(__FILE__,__LINE__);
+$guiList = $_POST["guiList"];
+$wmsList = $_POST["wmsList"];
+$up = $_POST["up"];
+$down = $_POST["down"];
+$del = $_POST["del"];
+$this_gui_wms_mapformat = $_POST["this_gui_wms_mapformat"];
+$this_gui_wms_featureinfoformat = $_POST["this_gui_wms_featureinfoformat"];
+$this_gui_wms_exceptionformat = $_POST["this_gui_wms_exceptionformat"];
+$this_gui_wms_visible = $_POST["this_gui_wms_visible"];
+$this_gui_wms_opacity = $_POST["this_gui_wms_opacity"];
+$this_gui_wms_sldurl = $_POST["this_gui_wms_sldurl"];
+$this_gui = $_POST["this_gui"];
+$this_wms = $_POST["this_wms"];
+$this_layer_count = $_POST["this_layer_count"];
+$update_content = $_POST["update_content"];
+require_once (dirname(__FILE__) . "/../classes/class_wms.php");
 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
 <html>
 <head>
 <?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+echo '<meta http-equiv="Content-Type" content="text/html; charset=' . CHARSET . '">';
 echo '<link rel="stylesheet" type="text/css" href="../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css">';
 <title>Edit GUI WMS</title>
 <?php
 include_once '../include/dyn_css.php';
 function toImage($text) {
@@ -51,11 +70,12 @@
 <script language="JavaScript">
 <?php
-	require_once(dirname(__FILE__) . "/../extensions/jquery-ui-1.7.2.custom/js/jquery-1.3.2.min.js");
-	require_once(dirname(__FILE__) . "/../extensions/jquery-ui-1.7.2.custom/js/jquery-ui-1.7.2.custom.min.js");
-	require_once(dirname(__FILE__) . "/../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.dialog.js");
-	require_once(dirname(__FILE__) . "/../javascripts/mod_wfsLayerObj_conf.js");
-	header('Content-type: text/html');
+require_once (dirname(__FILE__) . "/../extensions/jquery-ui-1.7.2.custom/js/jquery-1.3.2.min.js");
+require_once (dirname(__FILE__) . "/../extensions/jquery-ui-1.7.2.custom/js/jquery-ui-1.7.2.custom.min.js");
+require_once (dirname(__FILE__) . "/../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.dialog.js");
+require_once (dirname(__FILE__) . "/../javascripts/mod_wfsLayerObj_conf.js");
+header('Content-type: text/html');
 function validate(wert){
@@ -163,142 +183,260 @@
 <body>
 <?php
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-$con = db_connect($DBSERVER,$OWNER,$PW);
-db_select_db(DB,$con);
-$mb_user_id = Mapbender::session()->get("mb_user_id");
+require_once (dirname(__FILE__) . "/../../conf/mapbender.conf");
+$con = db_connect($DBSERVER, $OWNER, $PW);
+db_select_db(DB, $con);
+$mb_user_id = Mapbender :: session()->get("mb_user_id");
 #delete gui_wms from gui
-if($del && $del == 'true'){
-	$sql="SELECT DISTINCT gui_wms_position from gui_wms WHERE fkey_gui_id = $1 and fkey_wms_id = $2";
-	$v = array($guiList,$wmsList);
-	$t = array('s','i');
-	$res = db_prep_query($sql,$v,$t);
+if ($del && $del == 'true') {
+	$sql = "SELECT DISTINCT gui_wms_position from gui_wms WHERE fkey_gui_id = $1 and fkey_wms_id = $2";
+	$v = array (
+		$guiList,
+		$wmsList
+	$t = array (
+		's',
+		'i'
+	$res = db_prep_query($sql, $v, $t);
 	$cnt = 0;
-	while($row = db_fetch_array($res)){
+	while ($row = db_fetch_array($res)) {
 		$wms_position = $row["gui_wms_position"];
 		$cnt++;
 	#if($cnt > 1){die("Error: WMS (ID) not unique!");}
-		$sql = "Delete from gui_wms where fkey_gui_id = $1 and fkey_wms_id = $2 ";
-		$sql = "Delete from gui_layer where fkey_gui_id = $1 and gui_layer_wms_id = $2";
-		$del='false';
-		$sql = "UPDATE gui_wms SET gui_wms_position = (gui_wms_position - 1) WHERE gui_wms_position > $1";
-		$sql .= " AND fkey_gui_id = $2 ";
-		$v = array($wms_position,$guiList);
-		$t = array('i','s');
+	$sql = "Delete from gui_wms where fkey_gui_id = $1 and fkey_wms_id = $2 ";
+	$v = array (
+		$guiList,
+		$wmsList
+	$t = array (
+		's',
+		'i'
+	$sql = "Delete from gui_layer where fkey_gui_id = $1 and gui_layer_wms_id = $2";
+	$v = array (
+		$guiList,
+		$wmsList
+	$t = array (
+		's',
+		'i'
+	$del = 'false';
+	$sql = "UPDATE gui_wms SET gui_wms_position = (gui_wms_position - 1) WHERE gui_wms_position > $1";
+	$sql .= " AND fkey_gui_id = $2 ";
+	$v = array (
+		$wms_position,
+		$guiList
+	$t = array (
+		'i',
+		's'
-	unset($wmsList);
+	unset ($wmsList);
 #update gui_wms_position
-if($up && $up == 'true'){
-	if ($wmsList!=""){
+if ($up && $up == 'true') {
+	if ($wmsList != "") {
 		$sql = "SELECT gui_wms_position ";
 		$sql .= "FROM gui_wms WHERE fkey_gui_id = $1 AND fkey_wms_id = $2";
-		if($row = db_fetch_array($res)){
+		$v = array (
+			$guiList,
+			$wmsList
+		$t = array (
+			's',
+			'i'
+		if ($row = db_fetch_array($res)) {
-	if($wms_position > 0){
+	if ($wms_position > 0) {
 		$sql = "UPDATE gui_wms SET ";
 		$sql .= "gui_wms_position = $1";
 		$sql .= " WHERE fkey_gui_id = $2 AND fkey_wms_id = $3";
-		$v = array(($wms_position - 1),$guiList,$wmsList);
-		$t = array('i','s','i');
+		$v = array (
+			($wms_position -1
+		), $guiList, $wmsList);
+		$t = array (
+			'i',
+			's',
+			'i'
 		$sql .= " WHERE gui_wms_position = $2 AND fkey_gui_id = $3 AND fkey_wms_id <> $4 ";
-		$v = array($wms_position,($wms_position - 1),$guiList,$wmsList);
-		$t = array('i','i','s','i');
+		$v = array (
+			$wms_position,
+			 ($wms_position -1
+		$t = array (
+			'i',
+			'i',
+			's',
+			'i'
-if($down && $down == 'true'){
+if ($down && $down == 'true') {
 	$max = 0;
+		$v = array (
+			$guiList,
+			$wmsList
+		$t = array (
+			's',
+			'i'
 		$sql = "SELECT MAX(gui_wms_position) as max FROM gui_wms WHERE fkey_gui_id = $1 ";
-		$v = array($guiList);
-		$t = array('s');
+		$v = array (
+			$guiList
+		$t = array (
+			's'
 			$max = $row["max"];
-	if($wms_position < $max){
+	if ($wms_position < $max) {
-		$v = array(($wms_position + 1),$guiList,$wmsList);
+		$v = array (
+			($wms_position +1
+		$t = array (
+			'i',
+			's',
+			'i'
 		$sql .= " WHERE gui_wms_position = $2 AND fkey_gui_id = $3 AND fkey_wms_id <> $4";
-		$v = array($wms_position,($wms_position + 1),$guiList,$wmsList);
+		$v = array (
+			$wms_position,
+			 ($wms_position +1
+		$t = array (
+			'i',
+			'i',
+			's',
+			'i'
 /*handle Updates*/
-if(isset($update_content) && $update_content == "1"){
-   if(isset($this_gui_wms_epsg)){
-      $sql = "UPDATE gui_wms set gui_wms_epsg = $1, gui_wms_mapformat = $2, ";
-      $sql .= "gui_wms_featureinfoformat = $3, gui_wms_exceptionformat = $4, ";
-      $sql .= "gui_wms_visible = $5, gui_wms_opacity = $6, gui_wms_sldurl = $7 ";
-      $sql .= "WHERE fkey_gui_id = $8 AND fkey_wms_id = $9";
-		$v = array($this_gui_wms_epsg,$this_gui_wms_mapformat,$this_gui_wms_featureinfoformat,$this_gui_wms_exceptionformat,$this_gui_wms_visible,$this_gui_wms_opacity,$this_gui_wms_sldurl,$this_gui,$this_wms);
-		$t = array('s','s','s','s','i','i','s','s','i');
-   else{
+if (isset ($update_content) && $update_content == "1") {
+	if (isset ($this_gui_wms_epsg)) {
+		$sql = "UPDATE gui_wms set gui_wms_epsg = $1, gui_wms_mapformat = $2, ";
+		$sql .= "gui_wms_featureinfoformat = $3, gui_wms_exceptionformat = $4, ";
+		$sql .= "gui_wms_visible = $5, gui_wms_opacity = $6, gui_wms_sldurl = $7 ";
+		$sql .= "WHERE fkey_gui_id = $8 AND fkey_wms_id = $9";
+		$v = array (
+			$this_gui_wms_epsg,
+			$this_gui_wms_mapformat,
+			$this_gui_wms_featureinfoformat,
+			$this_gui_wms_exceptionformat,
+			$this_gui_wms_visible,
+			$this_gui_wms_opacity,
+			$this_gui_wms_sldurl,
+			$this_gui,
+			$this_wms
+		$t = array (
+			's',
+			's',
+			's',
+			's',
+			'i',
+			'i',
+			's',
+			's',
+			'i'
+	} else {
 		$sql = "UPDATE gui_wms set gui_wms_mapformat = $1, ";
 		$sql .= "gui_wms_featureinfoformat = $2, gui_wms_exceptionformat = $3, ";
 		$sql .= "gui_wms_visible = $4, gui_wms_opacity = $5, gui_wms_sldurl = $6 ";
 		$sql .= "WHERE fkey_gui_id = $7 AND fkey_wms_id = $8";
-		$v = array($this_gui_wms_mapformat,$this_gui_wms_featureinfoformat,$this_gui_wms_exceptionformat,$this_gui_wms_visible,$this_gui_wms_opacity,$this_gui_wms_sldurl,$this_gui,$this_wms);
-		$t = array('s','s','s','i','i','s','s','i');
+		$v = array (
+			$this_gui,
+			$this_wms
+		$t = array (
+			's',
+			's',
+			's',
+			'i',
+			'i',
+			's',
+			's',
+			'i'
-   $cnt = 0;
-   while(list($key,$val) = each($_REQUEST)){
-		if(preg_match("/___/", $key)){
+	$cnt = 0;
+	while (list ($key, $val) = each($_POST)) {
+		if (preg_match("/___/", $key)) {
 			$myKey = explode("___", $key);
-			if($myKey[1]!="layer_parent" && $myKey[1]!='layer_id' ){
-				$sql = "UPDATE gui_layer SET ".$myKey[1]." = $1 WHERE fkey_gui_id = $2 AND fkey_layer_id = $3";
-				$v = array($val,$this_gui,preg_replace("/L_/","",$myKey[0]));
-				if($myKey[1]=='gui_layer_style'){
-					$t = array('s','s','i');
+			if ($myKey[1] != "layer_parent" && $myKey[1] != 'layer_id') {
+				$sql = "UPDATE gui_layer SET " . $myKey[1] . " = $1 WHERE fkey_gui_id = $2 AND fkey_layer_id = $3";
+				$v = array (
+					$val,
+					$this_gui,
+					preg_replace("/L_/",
+					$myKey[0]
+				if ($myKey[1] == 'gui_layer_style') {
+					$t = array (
+						's',
+						's',
+						'i'
+				} else {
+					$t = array (
+						'i',
+						's',
+						'i'
-				else{
-				if(!$res = db_prep_query($sql,$v,$t)){
+				if (!$res = db_prep_query($sql, $v, $t)) {
 					echo "FEHLER in ZEILE 288";
@@ -306,7 +444,7 @@
-echo "<form name='form1' action='" . $self ."' method='post'>";
+echo "<form name='form1' action='" . $self . "' method='post'>";
 echo "<table cellpadding='3' cellspacing='3' border='0' class='table_top'>";
 echo "<tr>";
@@ -322,33 +460,32 @@
 echo "<td>";
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
+require_once (dirname(__FILE__) . "/../classes/class_administration.php");
 $admin = new administration();
-$ownguis = $admin->getGuisByOwner(Mapbender::session()->get("mb_user_id"),true);
+$ownguis = $admin->getGuisByOwner(Mapbender :: session()->get("mb_user_id"), true);
-$gui_id =array();
-if (count($ownguis)>0){
-	for($i=0; $i<count($ownguis); $i++){
-		$gui_id[$i]=$ownguis[$i];
+$gui_id = array ();
+if (count($ownguis) > 0) {
+	for ($i = 0; $i < count($ownguis); $i++) {
+		$gui_id[$i] = $ownguis[$i];
-echo"<select size='8' name='guiList' onchange='document.form1.wmsList.selectedIndex = -1;submit()'>";
-$selected_gui_id="";
+echo "<select size='8' name='guiList' onchange='document.form1.wmsList.selectedIndex = -1;submit()'>";
+$selected_gui_id = "";
-for ($i=0; $i<count($ownguis);$i++){
-   echo "<option value='".$gui_id[$i]."' ";
-   if($guiList && $guiList == $gui_id[$i]){
-      echo "selected";
-      $selected_gui_id=$gui_id[$i];
-   else{
-      if ($i==0){
-         echo "selected";
+for ($i = 0; $i < count($ownguis); $i++) {
+	echo "<option value='" . $gui_id[$i] . "' ";
+	if ($guiList && $guiList == $gui_id[$i]) {
+		echo "selected";
+		$selected_gui_id = $gui_id[$i];
+	} else {
+		if ($i == 0) {
+			echo "selected";
-   echo ">".$gui_id[$i]."</option>";
+	echo ">" . $gui_id[$i] . "</option>";
 echo "</select>";
@@ -357,20 +494,24 @@
 $sql = "SELECT * from gui_wms JOIN gui ON gui_wms.fkey_gui_id = gui.gui_id JOIN wms ON ";
 $sql .= "gui_wms.fkey_wms_id = wms.wms_id AND gui_wms.fkey_gui_id=gui.gui_id WHERE gui.gui_id = $1 ORDER BY gui_wms_position";
-$v = array($selected_gui_id);
-$t = array('s');
-$res = db_prep_query($sql,$v,$t);
+$v = array (
+	$selected_gui_id
+$t = array (
+	's'
+$res = db_prep_query($sql, $v, $t);
 $count_wms = 0;
 # WMS select box on right side
 echo "<select size='8' name='wmsList' style='width:600px' onchange='submit()'>";
-while($row = db_fetch_array($res)){
-	echo "<option title='".htmlentities($row["wms_abstract"],ENT_QUOTES,"UTF-8")."'  value='".$row["wms_id"]."' ";
-	if(isset($wmsList) && $wmsList == $row["wms_id"]){
+while ($row = db_fetch_array($res)) {
+	echo "<option title='" . htmlentities($row["wms_abstract"], ENT_QUOTES, "UTF-8") . "'  value='" . $row["wms_id"] . "' ";
+	if (isset ($wmsList) && $wmsList == $row["wms_id"]) {
 		echo "selected";
-	echo ">".$row["gui_wms_position"]." - ".$row["wms_title"]."</option>";
+	echo ">" . $row["gui_wms_position"] . " - " . $row["wms_title"] . "</option>";
 	$count_wms++;
 echo "</select>";
@@ -388,371 +529,434 @@
 echo "</tr>";
 echo "</table>";
+if (isset ($wmsList)) {
+	#gui_wms
+	$sql_gw = "SELECT * FROM gui_wms WHERE fkey_gui_id = $1 AND fkey_wms_id = $2";
+	$v = array (
+		$guiList,
+		$wmsList
+	$t = array (
+		's',
+		'i'
+	$res_gw = db_prep_query($sql_gw, $v, $t);
+	$cnt_gw = 0;
+	while ($row = db_fetch_array($res_gw)) {
+		$gui_wms_position[$cnt_gw] = $row["gui_wms_position"];
+		$gui_wms_mapformat[$cnt_gw] = $row["gui_wms_mapformat"];
+		$gui_wms_featureinfoformat[$cnt_gw] = $row["gui_wms_featureinfoformat"];
+		$gui_wms_exceptionformat[$cnt_gw] = $row["gui_wms_exceptionformat"];
+		$gui_wms_epsg[$cnt_gw] = $row["gui_wms_epsg"];
+		$gui_wms_visible[$cnt_gw] = $row["gui_wms_visible"];
+		$gui_wms_opacity[$cnt_gw] = $row["gui_wms_opacity"];
+		$gui_wms_sldurl[$cnt_gw] = $row["gui_wms_sldurl"]; # sld url
+		$cnt_gw++;
+	#wms
+	$sql_w = "SELECT * FROM wms WHERE wms_id = $1";
+	$v = array (
+		$wmsList
+	$t = array (
+		'i'
+	$res_w = db_prep_query($sql_w, $v, $t);
+	$cnt_w = 0;
+	while ($row = db_fetch_array($res_w)) {
+		$wms_id[$cnt_w] = $row["wms_id"];
+		$wms_version[$cnt_w] = $row["wms_version"];
+		$wms_title[$cnt_w] = $row["wms_title"];
+		$wms_abstract[$cnt_w] = htmlentities($row["wms_abstract"], ENT_QUOTES, "UTF-8");
+		$wms_getcapabilities[$cnt_w] = $row["wms_getcapabilities"];
+		$wms_supportsld[$cnt_w] = $row["wms_supportsld"]; # Buttons zum sld support anzeigen?
+		$cnt_w++;
+	#wms_format
+	$sql_wf = "SELECT * FROM  wms_format WHERE  fkey_wms_id = $1";
+	$v = array (
+		$wmsList
+	$t = array (
+		'i'
+	$res_wf = db_prep_query($sql_wf, $v, $t);
+	$cnt_wf = 0;
+	while ($row = db_fetch_array($res_wf)) {
+		$data_type[$cnt_wf] = $row["data_type"];
+		$data_format[$cnt_wf] = $row["data_format"];
+		$cnt_wf++;
+	#gui_layer
+	$sql_gl = "SELECT l.*, gl.*, sld.sld_user_layer_id, sld.use_sld FROM layer AS l, gui_layer AS gl left outer join sld_user_layer AS sld on sld.fkey_layer_id = gl.fkey_layer_id WHERE l.layer_id = gl.fkey_layer_id AND gl.gui_layer_wms_id = $1 AND gl.fkey_gui_id = $2 AND (sld.fkey_gui_id = $3 or sld.fkey_gui_id is NULL) AND (sld.fkey_mb_user_id = $4 or sld.fkey_mb_user_id is NULL) ORDER BY l.layer_pos";
+	$v = array (
+		$wmsList,
+		$guiList,
+		$guiList,
+		$mb_user_id
+	$t = array (
+		'i',
+		's',
+		's',
+		'i'
-if(isset($wmsList)){
-#gui_wms
-$sql_gw = "SELECT * FROM gui_wms WHERE fkey_gui_id = $1 AND fkey_wms_id = $2";
-$v = array($guiList,$wmsList);
-$t = array('s','i');
-$res_gw = db_prep_query($sql_gw,$v,$t);
-$cnt_gw = 0;
-while($row = db_fetch_array($res_gw)){
-   $gui_wms_position[$cnt_gw] = $row["gui_wms_position"];
-   $gui_wms_mapformat[$cnt_gw] = $row["gui_wms_mapformat"];
-   $gui_wms_featureinfoformat[$cnt_gw] = $row["gui_wms_featureinfoformat"];
-   $gui_wms_exceptionformat[$cnt_gw] = $row["gui_wms_exceptionformat"];
-   $gui_wms_epsg[$cnt_gw] = $row["gui_wms_epsg"];
-   $gui_wms_visible[$cnt_gw] = $row["gui_wms_visible"];
-   $gui_wms_opacity[$cnt_gw] = $row["gui_wms_opacity"];
-   $gui_wms_sldurl[$cnt_gw] = $row["gui_wms_sldurl"]; # sld url
-   $cnt_gw++;
-#wms
-$sql_w = "SELECT * FROM wms WHERE wms_id = $1";
-$v = array($wmsList);
-$t = array('i');
-$res_w = db_prep_query($sql_w,$v,$t);
-$cnt_w = 0;
-while($row = db_fetch_array($res_w)){
-   $wms_id[$cnt_w] = $row["wms_id"];
-   $wms_version[$cnt_w] = $row["wms_version"];
-   $wms_title[$cnt_w] = $row["wms_title"];
-   $wms_abstract[$cnt_w] = htmlentities($row["wms_abstract"],ENT_QUOTES,"UTF-8");
-   $wms_getcapabilities[$cnt_w] = $row["wms_getcapabilities"];
-   $wms_supportsld[$cnt_w] = $row["wms_supportsld"];  # Buttons zum sld support anzeigen?
-   $cnt_w++;
-#wms_format
-$sql_wf = "SELECT * FROM  wms_format WHERE  fkey_wms_id = $1";
-$t = array('i');
-$res_wf = db_prep_query($sql_wf,$v,$t);
-$cnt_wf = 0;
-while($row = db_fetch_array($res_wf)){
-   $data_type[$cnt_wf] = $row["data_type"];
-   $data_format[$cnt_wf] = $row["data_format"];
-   $cnt_wf++;
-#gui_layer
-$sql_gl = "SELECT l.*, gl.*, sld.sld_user_layer_id, sld.use_sld FROM layer AS l, gui_layer AS gl left outer join sld_user_layer AS sld on sld.fkey_layer_id = gl.fkey_layer_id WHERE l.layer_id = gl.fkey_layer_id AND gl.gui_layer_wms_id = $1 AND gl.fkey_gui_id = $2 AND (sld.fkey_gui_id = $3 or sld.fkey_gui_id is NULL) AND (sld.fkey_mb_user_id = $4 or sld.fkey_mb_user_id is NULL) ORDER BY l.layer_pos";
-$v = array($wmsList,$guiList,$guiList,$mb_user_id);
-$t = array('i','s','s','i');
+	$res_gl = db_prep_query($sql_gl, $v, $t);
+	$gui_layer_status = array ();
+	$gui_layer_title = array ();
+	$gui_layer_selectable = array ();
+	$gui_layer_visible = array ();
+	$gui_layer_queryable = array ();
+	$gui_layer_querylayer = array ();
+	$gui_layer_minscale = array ();
+	$gui_layer_maxscale = array ();
+	$gui_layer_priority = array ();
+	$gui_layer_style = array ();
+	$gui_layer_wfs_featuretype = array ();
+	$layer_maxscale = array ();
+	$layer_id = array ();
+	$layer_parent = array ();
+	$layer_name = array ();
+	$layer_title = array ();
+	$layer_queryable = array ();
+	$layer_minscale = array ();
+	$sld_user_layer_id = array ();
+	$use_sld = array ();
+	while ($row = db_fetch_array($res_gl)) {
+		array_push($gui_layer_status, $row["gui_layer_status"]);
+		array_push($gui_layer_title, $row["gui_layer_title"]);
+		array_push($gui_layer_selectable, $row["gui_layer_selectable"]);
+		array_push($gui_layer_visible, $row["gui_layer_visible"]);
+		array_push($gui_layer_queryable, $row["gui_layer_queryable"]);
+		array_push($gui_layer_querylayer, $row["gui_layer_querylayer"]);
+		array_push($gui_layer_minscale, $row["gui_layer_minscale"]);
+		array_push($gui_layer_maxscale, $row["gui_layer_maxscale"]);
+		array_push($gui_layer_priority, $row["gui_layer_priority"]);
+		array_push($gui_layer_style, $row["gui_layer_style"]);
+		array_push($gui_layer_wfs_featuretype, $row["gui_layer_wfs_featuretype"]);
+		array_push($layer_id, $row["layer_id"]);
+		array_push($layer_parent, $row["layer_parent"]);
+		array_push($layer_name, $row["layer_name"]);
+		array_push($layer_title, $row["layer_title"]);
+		array_push($layer_queryable, $row["layer_queryable"]);
+		array_push($layer_minscale, $row["layer_minscale"]);
+		array_push($layer_maxscale, $row["layer_maxscale"]);
+		array_push($sld_user_layer_id, $row["sld_user_layer_id"]);
+		array_push($use_sld, $row["use_sld"]);
-$res_gl = db_prep_query($sql_gl,$v,$t);
-$gui_layer_status = array();
-$gui_layer_title = array();
-$gui_layer_selectable = array();
-$gui_layer_visible = array();
-$gui_layer_queryable = array();
-$gui_layer_querylayer = array();
-$gui_layer_minscale = array();
-$gui_layer_maxscale = array();
-$gui_layer_priority = array();
-$gui_layer_style = array();
-$gui_layer_wfs_featuretype = array();
-$layer_maxscale = array();
-$layer_id = array();
-$layer_parent = array();
-$layer_name = array();
-$layer_title = array();
-$layer_queryable = array();
-$layer_minscale = array();
-$sld_user_layer_id = array();
-$use_sld = array();
-while($row = db_fetch_array($res_gl)){
-	array_push($gui_layer_status, $row["gui_layer_status"]);
-	array_push($gui_layer_title, $row["gui_layer_title"]);
-	array_push($gui_layer_selectable, $row["gui_layer_selectable"]);
-	array_push($gui_layer_visible, $row["gui_layer_visible"]);
-	array_push($gui_layer_queryable, $row["gui_layer_queryable"]);
-	array_push($gui_layer_querylayer, $row["gui_layer_querylayer"]);
-	array_push($gui_layer_minscale, $row["gui_layer_minscale"]);
-	array_push($gui_layer_maxscale, $row["gui_layer_maxscale"]);
-	array_push($gui_layer_priority, $row["gui_layer_priority"]);
-	array_push($gui_layer_style, $row["gui_layer_style"]);
-	array_push($gui_layer_wfs_featuretype, $row["gui_layer_wfs_featuretype"]);
-	array_push($layer_id, $row["layer_id"]);
-	array_push($layer_parent, $row["layer_parent"]);
-	array_push($layer_name, $row["layer_name"]);
-	array_push($layer_title, $row["layer_title"]);
-	array_push($layer_queryable, $row["layer_queryable"]);
-	array_push($layer_minscale, $row["layer_minscale"]);
-	array_push($layer_maxscale, $row["layer_maxscale"]);
-	array_push($sld_user_layer_id, $row["sld_user_layer_id"]);
-	array_push($use_sld, $row["use_sld"]);
+	#layer_epsg
+	$sql_le = "SELECT * FROM layer_epsg WHERE  fkey_layer_id = $1";
+	$v = array (
+		$layer_id[0]
+	$t = array (
+		'i'
+	$res_le = db_prep_query($sql_le, $v, $t);
+	$cnt_le = 0;
+	while ($row = db_fetch_array($res_le)) {
+		$epsg[$cnt_le] = $row["epsg"];
+		$cnt_le++;
-#layer_epsg
-$sql_le = "SELECT * FROM layer_epsg WHERE  fkey_layer_id = $1";
-$v = array($layer_id[0]);
-$t = array('i');
-$res_le = db_prep_query($sql_le,$v,$t);
-$cnt_le = 0;
-while($row = db_fetch_array($res_le)){
-   $epsg[$cnt_le] = $row["epsg"];
-   $cnt_le++;
+	# Save button
+	echo "<div style='position:absolute;left:500px; top:225px;' ><input type='button' style='width:130px;height:80px;background-color:#ffeded' value='Save Settings' onclick='checkBoxValue()'></div>";
+	echo "<table class='table_top'>";
+	echo "<tr>";
+	echo "<td colspan='2'>";
+	echo "<a href='" . $wms_getcapabilities[0];
+	echo wms :: getConjunctionCharacter($wms_getcapabilities[0]);
+	if ($wms_version[0] == "1.0.0") {
+		echo "WMTVER=" . $wms_version[0] . "&REQUEST=capabilities";
+	} else {
+		echo "VERSION=" . $wms_version[0] . "&REQUEST=GetCapabilities&SERVICE=WMS";
+	echo "' style='font-size:14px' target='_blank'>LINK: Capabilities</a>";
+	echo "</td>";
+	echo "<td align = right>WMS ID: " . $wms_id[0] . "</td>";
+	echo "<tr>";
+	#epsg
+	if ($gui_wms_position[0] == 0) {
+		echo "<tr>";
+		echo "<td>EPSG: </td><td>";
+		echo "<select class='mySelect'  name='this_gui_wms_epsg'>";
+		for ($i = 0; $i < count($epsg); $i++) {
+			echo "<option value='" . $epsg[$i] . "' ";
+			if ($epsg[$i] == $gui_wms_epsg[0]) {
+				echo "selected";
+			echo ">" . $epsg[$i] . "</option>";
+		echo "</select>";
+		echo "</td>";
+		echo "</tr>";
+	#format
+	echo "<tr>";
+	echo "<td>Mapformat: </td><td>";
+	echo "<select class='mySelect'  name='this_gui_wms_mapformat'>";
+	for ($i = 0; $i < count($data_format); $i++) {
+		if ($data_type[$i] == 'map') {
+			echo "<option value='" . $data_format[$i] . "' ";
+			if ($data_format[$i] == $gui_wms_mapformat[0]) {
+				echo "selected";
+			echo ">" . $data_format[$i] . "</option>";
+	echo "</select>";
+	echo "</td>";
+	echo "</tr>";
+	echo "<tr>";
+	echo "<td>Infoformat: </td><td>";
+	echo "<select class='mySelect'  name='this_gui_wms_featureinfoformat'>";
+	echo "<option value='text/html'>text/html</option>";
+		if ($data_type[$i] == 'featureinfo') {
+			if ($data_format[$i] == $gui_wms_featureinfoformat[0]) {
+				echo "selected";
+	echo "</select>";
+	echo "</td>";
+	echo "</tr>";
-# Save button
-echo "<div style='position:absolute;left:500px; top:225px;' ><input type='button' style='width:130px;height:80px;background-color:#ffeded' value='Save Settings' onclick='checkBoxValue()'></div>";
-echo "<table class='table_top'>";
-echo "<tr>";
-echo "<td colspan='2'>";
-echo "<a href='".$wms_getcapabilities[0];
-echo wms::getConjunctionCharacter($wms_getcapabilities[0]);
-if ($wms_version[0] == "1.0.0") {
-	echo "WMTVER=". $wms_version[0]."&REQUEST=capabilities";
-else {
-	echo "VERSION=". $wms_version[0]."&REQUEST=GetCapabilities&SERVICE=WMS";
-echo "' style='font-size:14px' target='_blank'>LINK: Capabilities</a>";
-echo "</td>";
-echo "<td align = right>WMS ID: " . $wms_id[0] . "</td>";
-echo "<tr>";
-#epsg
-if($gui_wms_position[0] == 0){
-  echo "<tr>";
-     echo "<td>EPSG: </td><td>";
-     echo "<select class='mySelect'  name='this_gui_wms_epsg'>";
-        for($i=0; $i<count($epsg); $i++){
-           echo "<option value='".$epsg[$i]."' ";
-           if($epsg[$i] == $gui_wms_epsg[0]){ echo "selected";}
-           echo ">".$epsg[$i]."</option>";
-     echo "</select>";
-     echo "</td>";
-  echo "</tr>";
-#format
-echo "<tr>";
-   echo "<td>Mapformat: </td><td>";
-        echo "<select class='mySelect'  name='this_gui_wms_mapformat'>";
-        for($i=0; $i<count($data_format); $i++){
-           if($data_type[$i] == 'map'){
-              echo "<option value='".$data_format[$i]."' ";
-              if($data_format[$i] == $gui_wms_mapformat[0]){ echo "selected";}
-              echo ">".$data_format[$i]."</option>";
-     echo "</select>";
-   echo "</td>";
+	echo "<tr>";
+	echo "<td>Exceptionformat: </td><td>";
+	echo "<select class='mySelect' name='this_gui_wms_exceptionformat'>";
+		if ($data_type[$i] == 'exception') {
+			if ($data_format[$i] == $gui_wms_exceptionformat[0]) {
+				echo "selected";
+	echo "</select>";
+	echo "</td>";
+	echo "</tr><br>";
-echo "</tr>";
-echo "<tr>";
-   echo "<td>Infoformat: </td><td>";
-        echo "<select class='mySelect'  name='this_gui_wms_featureinfoformat'>";
-        echo "<option value='text/html'>text/html</option>";
-           if($data_type[$i] == 'featureinfo'){
-              if($data_format[$i] == $gui_wms_featureinfoformat[0]){ echo "selected";}
-     echo "</select>";
-   echo "</td>";
-echo "</tr>";
-echo "<tr>";
-   echo "<td>Exceptionformat: </td><td>";
-        echo "<select class='mySelect' name='this_gui_wms_exceptionformat'>";
-           if($data_type[$i] == 'exception'){
-              if($data_format[$i] == $gui_wms_exceptionformat[0]){ echo "selected";}
-     echo "</select>";
-   echo "</td>";
-echo "</tr><br>";
-# visibility
-echo "<tr>";
+	# visibility
+	echo "<tr>";
 	echo "<td>Visibility: </td><td>";
 	echo "<select class='mySelect' name='this_gui_wms_visible'>";
-	for($i=0; $i<3; $i++){
-		echo "<option value='".$i."' ";
-		if($i == $gui_wms_visible[0]){ echo "selected";}
+	for ($i = 0; $i < 3; $i++) {
+		echo "<option value='" . $i . "' ";
+		if ($i == $gui_wms_visible[0]) {
+			echo "selected";
 		echo ">";
-		if($i == '0'){
+		if ($i == '0') {
 			echo "hidden";
-		if($i == '1'){
+		if ($i == '1') {
 			echo "visible";
 		echo "</option>";
 	echo "</select>";
 	echo "</td>";
-echo "</tr>";
+	echo "</tr>";
-# opacity
-echo "<tr>";
+	# opacity
+	echo "<tr>";
 	echo "<td>Opacity: </td><td>";
 	echo "<select class='mySelect' name='this_gui_wms_opacity'>";
-	for($i=0; $i<=100; $i+=10){
-		if($i - $gui_wms_opacity[0]<=5&&$i - $gui_wms_opacity[0]>=-4){ echo "selected";}
+	for ($i = 0; $i <= 100; $i += 10) {
+		if ($i - $gui_wms_opacity[0] <= 5 && $i - $gui_wms_opacity[0] >= -4) {
+			echo "selected";
 		echo ">";
-		echo $i."%";
+		echo $i . "%";
 		echo "</option>";
 	echo "</select>";
 	echo "</td>";
-echo "</tr>";
+	echo "</tr>";
-# sld support
-if($wms_supportsld[0]) {
+	# sld support
+	if ($wms_supportsld[0]) {
 		echo "<tr>";
 		echo "<td>SLD-URL: </td><td>";
-		echo "<input type='text' class='myText' name='this_gui_wms_sldurl' id='this_gui_wms_sldurl' title='".$gui_wms_sldurl[0]."' value='".$gui_wms_sldurl[0]."'>";
+		echo "<input type='text' class='myText' name='this_gui_wms_sldurl' id='this_gui_wms_sldurl' title='" . $gui_wms_sldurl[0] . "' value='" . $gui_wms_sldurl[0] . "'>";
 		#echo "<a href='' onclick='return window.open(\"editor-start.php\");'><img src='sld_editor.png' border=0></a>";
 		#$layer_names = implode(",", $layer_name);
-        echo " <a href='javascript:showSld(\"".$gui_wms_sldurl[0]."\");'>SLD laden/anzeigen</a>";
+		echo " <a href='javascript:showSld(\"" . $gui_wms_sldurl[0] . "\");'>SLD laden/anzeigen</a>";
 		echo "</td>";
-	echo "</tr>";
-} else {
-	echo "<input type='hidden' value='' name='this_gui_wms_sldurl'>";
+		echo "</tr>";
+	} else {
+		echo "<input type='hidden' value='' name='this_gui_wms_sldurl'>";
-echo "</table><br>";
+	echo "</table><br>";
-echo "<table border='1' cellpadding='1'>";
-		echo "<tr>";
+	echo "<table border='1' cellpadding='1'>";
+	echo "<tr>";
-                echo "<td>Nr.</td>";
-                echo "<td>ID</td>";
-                echo "<td>" . toImage('Parent') . "</td>";
-                echo "<td>Name</td>";
-                echo "<td>Title</td>";
-                echo "<td>" . toImage('on/off') . "</td>";
-                echo "<td>" . toImage('sel') . "</td>";
-                echo "<td>" . toImage('sel_default') . "</td>";
-                echo "<td>" . toImage('info') . "</td>";
-                echo "<td>" . toImage('info_default') . "</td>";
-                echo "<td>" . toImage('minScale 1:') . "</td>";
-                echo "<td>" . toImage('maxScale 1:') . "</td>";
-                echo "<td>" . toImage('Style') . "</td>";
-                echo "<td>" . toImage('Prio') . "</td>";
-                echo "<td>" . toImage('setWFS') . "</td>";
-                if($wms_supportsld[0]) {echo "<td>" . toImage('SLD') . "</td>";}
-        echo "</tr>";
+	echo "<td>Nr.</td>";
+	echo "<td>ID</td>";
+	echo "<td>" . toImage('Parent') . "</td>";
+	echo "<td>Name</td>";
+	echo "<td>Title</td>";
+	echo "<td>" . toImage('on/off') . "</td>";
+	echo "<td>" . toImage('sel') . "</td>";
+	echo "<td>" . toImage('sel_default') . "</td>";
+	echo "<td>" . toImage('info') . "</td>";
+	echo "<td>" . toImage('info_default') . "</td>";
+	echo "<td>" . toImage('minScale 1:') . "</td>";
+	echo "<td>" . toImage('maxScale 1:') . "</td>";
+	echo "<td>" . toImage('Style') . "</td>";
+	echo "<td>" . toImage('Prio') . "</td>";
+	echo "<td>" . toImage('setWFS') . "</td>";
+		echo "<td>" . toImage('SLD') . "</td>";
+	echo "</tr>";
-#echo "<tr><td>Nr.</td><td>ID</td><td>Parent</td><td>Name</td><td>Title</td><td>on/off</td><td>sel</td><td>sel_default</td><td>info</td><td>info_default</td><td>minScale 1:</td><td>maxScale 1:</td><td>Prio</td><td>setWFS</td></tr>";
-echo "<tr><td></td><td></td><td></td><td></td><td></td><td>";
-echo "<input type='button' class='LButton' value='Sublayer\noff' onclick='setSubs()'>";
-echo "</td><td></td><td>";
-echo "<nobr><input type='button' class='button_on_off' value='off' onclick='setLayer(\"visible\",false)'>&nbsp;";
-echo "<input type='button' class='button_on_off' value='on' onclick='setLayer(\"visible\",true)'></nobr>";
-echo"</td><td></td><td>";
-echo "<nobr><input type='button' class='button_on_off' value='off' onclick='setLayer(\"querylayer\",false)'>&nbsp;";
-echo "<input type='button' class='button_on_off' value='on' onclick='setLayer(\"querylayer\",true)'></nobr>";
-echo "</td><td></td><td></td><td></td></tr>";
+	#echo "<tr><td>Nr.</td><td>ID</td><td>Parent</td><td>Name</td><td>Title</td><td>on/off</td><td>sel</td><td>sel_default</td><td>info</td><td>info_default</td><td>minScale 1:</td><td>maxScale 1:</td><td>Prio</td><td>setWFS</td></tr>";
+	echo "<tr><td></td><td></td><td></td><td></td><td></td><td>";
+	echo "<input type='button' class='LButton' value='Sublayer\noff' onclick='setSubs()'>";
+	echo "</td><td></td><td>";
+	echo "<nobr><input type='button' class='button_on_off' value='off' onclick='setLayer(\"visible\",false)'>&nbsp;";
+	echo "<input type='button' class='button_on_off' value='on' onclick='setLayer(\"visible\",true)'></nobr>";
+	echo "<nobr><input type='button' class='button_on_off' value='off' onclick='setLayer(\"querylayer\",false)'>&nbsp;";
+	echo "<input type='button' class='button_on_off' value='on' onclick='setLayer(\"querylayer\",true)'></nobr>";
+	echo "</td><td></td><td></td><td></td></tr>";
-for($i=0; $i<count($layer_id); $i++){
-#layer_styles
-$sql_styles = "SELECT * FROM layer_style WHERE  fkey_layer_id = $1";
-$v = array($layer_id[$i]);
-$t = array('i');
-$res_styles = db_prep_query($sql_styles,$v,$t);
-$cnt_styles= 0;
-$style = array();
-while($row = db_fetch_array($res_styles)){
-   $style[$cnt_styles] = $row["name"];
-   $cnt_styles++;
+	for ($i = 0; $i < count($layer_id); $i++) {
+		#layer_styles
+		$sql_styles = "SELECT * FROM layer_style WHERE  fkey_layer_id = $1";
+		$v = array (
+			$layer_id[$i]
+		$t = array (
+			'i'
+		$res_styles = db_prep_query($sql_styles, $v, $t);
+		$cnt_styles = 0;
+		$style = array ();
+		while ($row = db_fetch_array($res_styles)) {
+			$style[$cnt_styles] = $row["name"];
+			$cnt_styles++;
- echo "<tr align='center'>";
-  echo "<td><input type='text' size='1' name='L_".$layer_id[$i]."___layer_nr' disabled value='".$i."'></td>";
-  echo "<td style='background:lightgrey'><input type='text' size='2' name='L_".$layer_id[$i]."___layer_id' value='".$layer_id[$i]."' readonly></td>";
-  echo "<td><input type='text' size='1' name='L_".$layer_id[$i]."___layer_parent' value='".$layer_parent[$i]."' readonly></td>";
-  echo "<td style='background:lightgrey'><input type='text' size='7' value='".$layer_name[$i]."' readonly></td>";
-  echo "<td><input type='text' size='12' name='L_".$layer_id[$i]."___gui_layer_title' value='".$gui_layer_title[$i]."' ></td>";
+		echo "<tr align='center'>";
+		echo "<td><input type='text' size='1' name='L_" . $layer_id[$i] . "___layer_nr' disabled value='" . $i . "'></td>";
+		echo "<td style='background:lightgrey'><input type='text' size='2' name='L_" . $layer_id[$i] . "___layer_id' value='" . $layer_id[$i] . "' readonly></td>";
+		echo "<td><input type='text' size='1' name='L_" . $layer_id[$i] . "___layer_parent' value='" . $layer_parent[$i] . "' readonly></td>";
+		echo "<td style='background:lightgrey'><input type='text' size='7' value='" . $layer_name[$i] . "' readonly></td>";
+		echo "<td><input type='text' size='12' name='L_" . $layer_id[$i] . "___gui_layer_title' value='" . $gui_layer_title[$i] . "' ></td>";
-  echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_status' type='checkbox' ";
-  if($gui_layer_status[$i] == 1){ echo "checked";}
-  echo "></td>";
+		echo "<td style='background:lightgrey'><input name='L_" . $layer_id[$i] . "___gui_layer_status' type='checkbox' ";
+		if ($gui_layer_status[$i] == 1) {
+			echo "checked";
+		echo "></td>";
-  echo "<td><input name='L_".$layer_id[$i]."___gui_layer_selectable' type='checkbox' ";
-  if($gui_layer_selectable[$i] == 1){ echo "checked";}
-  echo "></td>";
+		echo "<td><input name='L_" . $layer_id[$i] . "___gui_layer_selectable' type='checkbox' ";
+		if ($gui_layer_selectable[$i] == 1) {
+			echo "checked";
+		echo "></td>";
-  echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_visible' type='checkbox' ";
-  if($gui_layer_visible[$i] == 1){ echo "checked";}
-  echo "></td>";
+		echo "<td style='background:lightgrey'><input name='L_" . $layer_id[$i] . "___gui_layer_visible' type='checkbox' ";
+		if ($gui_layer_visible[$i] == 1) {
+			echo "checked";
+		echo "></td>";
-  echo "<td><input name='L_".$layer_id[$i]."___gui_layer_queryable' type='checkbox' ";
-  if($gui_layer_queryable[$i] == 1){ echo "checked";}
-  if($layer_queryable[$i] == 0){ echo "disabled";}
-  echo "></td>";
+		echo "<td><input name='L_" . $layer_id[$i] . "___gui_layer_queryable' type='checkbox' ";
+		if ($gui_layer_queryable[$i] == 1) {
+			echo "checked";
+		if ($layer_queryable[$i] == 0) {
+			echo "disabled";
+		echo "></td>";
-  echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_querylayer' type='checkbox' ";
-  if($gui_layer_querylayer[$i] == 1){ echo "checked";}
-  echo "></td>";
+		echo "<td style='background:lightgrey'><input name='L_" . $layer_id[$i] . "___gui_layer_querylayer' type='checkbox' ";
+		if ($gui_layer_querylayer[$i] == 1) {
+			echo "checked";
+			echo "disabled";
+		echo "></td>";
-  echo "<td><input name='L_".$layer_id[$i]."___gui_layer_minscale' type='text' size='5' value='".$gui_layer_minscale[$i]."'></td>";
-  echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_maxscale' type='text' size='5' value='".$gui_layer_maxscale[$i]."'></td>";
-  echo "<td>\n";
-  echo "<select class='select_short' name='L_".$layer_id[$i]."___gui_layer_style'>\n";
-  	   echo "<option value=''";
-  	   if(count($style) ==0){ echo "selected";}
-  	   echo ">---</option>\n";
-  for($j=0;$j<count($style); $j++){
-       echo "<option value='".$style[$j]."'";
-       if($style[$j] == $gui_layer_style[$i]){ echo "selected";}
-       echo ">".$style[$j]."</option>\n";
-  echo "</select></td>\n";
-  echo "<td><select class='select_short' name='L_".$layer_id[$i]."___gui_layer_priority'>";
-  for($j=0; $j<count($gui_layer_priority); $j++){
-     echo "<option value='".$j."'";
-     if($j == $gui_layer_priority[$i]){echo "selected";}
-     echo ">".$j;
-     echo "</option>";
-  /* wfs configuration */
-	echo "<td>";
-	if ($i > 0) {
-		echo "<input class='button_wfs' id='buttonLayerWfs_".$layer_id[$i]."' name='gui_layer_gaz' type='button' onclick='getWfsConfs(\"".$guiList."\",".$wmsList.",".$layer_id[$i].",\"".$gui_layer_wfs_featuretype[$i]."\",\"buttonLayerWfs_".$layer_id[$i]."\")' value='";
-		if($gui_layer_wfs_featuretype[$i] == ""){
-			echo "setWFS";
+		echo "<td><input name='L_" . $layer_id[$i] . "___gui_layer_minscale' type='text' size='5' value='" . $gui_layer_minscale[$i] . "'></td>";
+		echo "<td style='background:lightgrey'><input name='L_" . $layer_id[$i] . "___gui_layer_maxscale' type='text' size='5' value='" . $gui_layer_maxscale[$i] . "'></td>";
+		echo "<td>\n";
+		echo "<select class='select_short' name='L_" . $layer_id[$i] . "___gui_layer_style'>\n";
+		echo "<option value=''";
+		if (count($style) == 0) {
+			echo "selected";
-		else{
-			echo "wfs ".$gui_layer_wfs_featuretype[$i];
+		echo ">---</option>\n";
+		for ($j = 0; $j < count($style); $j++) {
+			echo "<option value='" . $style[$j] . "'";
+			if ($style[$j] == $gui_layer_style[$i]) {
+				echo "selected";
+			echo ">" . $style[$j] . "</option>\n";
-		echo "'>";
-	echo "</td>";
+		echo "</select></td>\n";
+		echo "<td><select class='select_short' name='L_" . $layer_id[$i] . "___gui_layer_priority'>";
+		for ($j = 0; $j < count($gui_layer_priority); $j++) {
+			echo "<option value='" . $j . "'";
+			if ($j == $gui_layer_priority[$i]) {
+				echo "selected";
+			echo ">" . $j;
+			echo "</option>";
+		/* wfs configuration */
 		echo "<td>";
 		if ($i > 0) {
-			echo "<input class='button3' name='gui_layer_sld' type='button' onclick='window.open(\"../sld/sld_main.php?".$urlParameters."&sld_gui_id=".$guiList."&sld_wms_id=".$wms_id[0]."&sld_layer_name=".$layer_name[$i]."\");' value='";
-			if ($sld_user_layer_id[$i] != "")
-				echo "sld:".$sld_user_layer_id[$i]."(".$use_sld[$i].")";
-			else
-				echo "SLD";
+			echo "<input class='button_wfs' id='buttonLayerWfs_" . $layer_id[$i] . "' name='gui_layer_gaz' type='button' onclick='getWfsConfs(\"" . $guiList . "\"," . $wmsList . "," . $layer_id[$i] . ",\"" . $gui_layer_wfs_featuretype[$i] . "\",\"buttonLayerWfs_" . $layer_id[$i] . "\")' value='";
+			if ($gui_layer_wfs_featuretype[$i] == "") {
+				echo "setWFS";
+			} else {
+				echo "wfs " . $gui_layer_wfs_featuretype[$i];
 			echo "'>";
 		echo "</td>";
+			echo "<td>";
+			if ($i > 0) {
+				echo "<input class='button3' name='gui_layer_sld' type='button' onclick='window.open(\"../sld/sld_main.php?" . $urlParameters . "&sld_gui_id=" . $guiList . "&sld_wms_id=" . $wms_id[0] . "&sld_layer_name=" . $layer_name[$i] . "\");' value='";
+				if ($sld_user_layer_id[$i] != "")
+					echo "sld:" . $sld_user_layer_id[$i] . "(" . $use_sld[$i] . ")";
+				else
+					echo "SLD";
+				echo "'>";
+			echo "</td>";
+		echo "</tr>\n";
+		if ($i == 0) {
+			echo "<tr><td colspan='16'><hr></td></tr>";
- echo "</tr>\n";
- if($i == 0){ echo "<tr><td colspan='16'><hr></td></tr>";}
+	echo "</table>\n";
+	echo "<input type='hidden' name='this_gui' value='" . $guiList . "'>\n";
+	echo "<input type='hidden' name='this_wms' value='" . $wmsList . "'>\n";
+	echo "<input type='hidden' name='this_layer_count' value='" . $cnt_l . "'>\n";
+	echo "<input type='hidden' name='update_content' value=''>\n";
+	echo "</form>\n";
-echo "</table>\n";
-echo "<input type='hidden' name='this_gui' value='".$guiList."'>\n";
-echo "<input type='hidden' name='this_wms' value='".$wmsList."'>\n";
-echo "<input type='hidden' name='this_layer_count' value='".$cnt_l."'>\n";
-echo "<input type='hidden' name='update_content' value=''>\n";
-echo "</form>\n";
 </body>
 </html>
More information about the Mapbender_commits mailing list
