[Mapbender-commits] r7315 - in trunk/mapbender: http/plugins lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Dec 16 04:43:25 EST 2010
Author: christoph
Date: 2010-12-16 01:43:25 -0800 (Thu, 16 Dec 2010)
New Revision: 7315
   trunk/mapbender/http/plugins/mb_wizard.js
   trunk/mapbender/lib/wizard.js
pass link onClickLink
Modified: trunk/mapbender/http/plugins/mb_wizard.js
--- trunk/mapbender/http/plugins/mb_wizard.js	2010-12-16 09:41:47 UTC (rev 7314)
+++ trunk/mapbender/http/plugins/mb_wizard.js	2010-12-16 09:43:25 UTC (rev 7315)
@@ -14,9 +14,13 @@
 				fade: true,
 				startWith: o.$target.eq(0),
 				onClickLink: function ($targets) {
-					that.events.onClickLink.trigger({
-						path: $targets
+					var args = [{
+							path: $targets
+					for (var i = 1; i < arguments.length; i++) {
+						args.push(arguments[i]);
+					that.events.onClickLink.trigger.apply(this, args);
 				onBeforeClickLink: function (evt, $link) {
 					var proceed = that.events.onBeforeClickLink.trigger({
Modified: trunk/mapbender/lib/wizard.js
--- trunk/mapbender/lib/wizard.js	2010-12-16 09:41:47 UTC (rev 7314)
+++ trunk/mapbender/lib/wizard.js	2010-12-16 09:43:25 UTC (rev 7315)
@@ -12,14 +12,14 @@
 			return true;
-	_navigate: function ($t, path) {
+	_navigate: function ($t, path, $a) {
 		if (this.options.fade) {
 			var that = this;
 			$t.siblings("div,form,iframe").fadeOut(function () {
 				$t.fadeIn(function () {
 					that._trigger("to" + $t.attr("id").toLowerCase(), null, {});
 					that._trigger("to", null, {});
-					that.options.onClickLink(path);
+					that.options.onClickLink(path, $a);
@@ -28,7 +28,7 @@
 			$t.siblings("div,form,iframe").hide();
 			$t.show();
 			this._trigger("to" + $t.attr("id").toLowerCase(), null, {});
-			this.options.onClickLink(path);
+			this.options.onClickLink(path, $a);
 	_getPath: function ($t) {
@@ -42,9 +42,9 @@
 		return p;
-	_clickHandler: function (e, $t) {
+	_clickHandler: function (e, $t, $a) {
 		var p = this._getPath($t);
-		this._navigate($t, p);
+		this._navigate($t, p, $a);
 		if (e) {
 			e.preventDefault();
@@ -106,7 +106,7 @@
 			"Clicked link " + href + " in wizard " +
 			wizardInstance.element.attr("id")
-		this._clickHandler(e, $target);
+		this._clickHandler(e, $target, $(this));
 	_create: function () {
 		var wizardInstance = this;
More information about the Mapbender_commits mailing list
